path: root/kernel/time/tick-common.c
2009-12-14clockevents: Convert to raw_spinlockThomas Gleixner
Convert locks which cannot be sleeping locks in preempt-rt to raw_spinlocks. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Ingo Molnar <mingo@elte.hu>
2009-12-14clockevents: Make tick_device_lock staticThomas Gleixner
2009-05-02clockevents: prevent endless loop in tick_handle_periodic()john stultz
tick_handle_periodic() can lock up hard when a one shot clock event device is used in combination with jiffies clocksource. Avoid an endless loop issue by requiring that a highres valid clocksource be installed before we call tick_periodic() in a loop when using ONESHOT mode. The result is we will only increment jiffies once per interrupt until a continuous hardware clocksource is available. Without this, we can run into a endless loop, where each cycle through the loop, jiffies is updated which increments time by tick_period or more (due to clock steering), which can cause the event programming to think the next event was before the newly incremented time and fail causing tick_periodic() to be called again and the whole process loops forever. [ Impact: prevent hard lock up ] Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: stable@kernel.org
2009-01-30hrtimers: allow the hot-unplugging of all cpusSebastien Dugue
Impact: fix CPU hotplug hang on Power6 testbox On architectures that support offlining all cpus (at least powerpc/pseries), hot-unpluging the tick_do_timer_cpu can result in a system hang. This comes from the fact that if the cpu going down happens to be the cpu doing the tick, then as the tick_do_timer_cpu handover happens after the cpu is dead (via the CPU_DEAD notification), we're left without ticks, jiffies are frozen and any task relying on timers (msleep, ...) is stuck. That's particularly the case for the cpu looping in __cpu_die() waiting for the dying cpu to be dead. This patch addresses this by having the tick_do_timer_cpu handover happen earlier during the CPU_DYING notification. For this, a new clockevent notification type is introduced (CLOCK_EVT_NOTIFY_CPU_DYING) which is triggered in hrtimer_cpu_notify(). Signed-off-by: Sebastien Dugue <sebastien.dugue@bull.net> Cc: <stable@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-01cpumask: convert kernel time functionsRusty Russell
Impact: Use new APIs Convert kernel/time functions to use struct cpumask *. Note the ugly bitmap declarations in tick-broadcast.c. These should be cpumask_var_t, but there was no obvious initialization function to put the alloc_cpumask_var() calls in. This was safe. (Eventually 'struct cpumask' will be undefined for CONFIG_CPUMASK_OFFSTACK, so we use a bitmap here to show we really mean it). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Mike Travis <travis@sgi.com>
2008-12-13cpumask: convert struct clock_event_device to cpumask pointers.Rusty Russell
Impact: change calling convention of existing clock_event APIs struct clock_event_timer's cpumask field gets changed to take pointer, as does the ->broadcast function. Another single-patch change. For safety, we BUG_ON() in clockevents_register_device() if it's not set. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Ingo Molnar <mingo@elte.hu>
2008-12-13cpumask: make irq_set_affinity() take a const struct cpumaskRusty Russell
Impact: change existing irq_chip API Not much point with gentle transition here: the struct irq_chip's setaffinity method signature needs to change. Fortunately, not widely used code, but hits a few architectures. Note: In irq_select_affinity() I save a temporary in by mangling irq_desc[irq].affinity directly. Ingo, does this break anything? (Folded in fix from KOSAKI Motohiro) Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Mike Travis <travis@sgi.com> Reviewed-by: Grant Grundler <grundler@parisc-linux.org> Acked-by: Ingo Molnar <mingo@redhat.com> Cc: ralf@linux-mips.org Cc: grundler@parisc-linux.org Cc: jeremy@xensource.com Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
2008-09-23clockevents: prevent mode mismatch on cpu onlineThomas Gleixner
Impact: timer hang on CPU online observed on AMD C1E systems When a CPU is brought online then the broadcast machinery can be in the one shot state already. Check this and setup the timer device of the new CPU in one shot mode so the broadcast code can pick up the next_event value correctly. Another AMD C1E oddity, as we switch to broadcast immediately and not after the full bring up via the ACPI cpu idle code. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-09-23clockevents: prevent cpu online to interfere with nohzThomas Gleixner
Impact: rare hang which can be triggered on CPU online. tick_do_timer_cpu keeps track of the CPU which updates jiffies via do_timer. The value -1 is used to signal, that currently no CPU is doing this. There are two cases, where the variable can have this state: boot: necessary for systems where the boot cpu id can be != 0 nohz long idle sleep: When the CPU which did the jiffies update last goes into a long idle sleep it drops the update jiffies duty so another CPU which is not idle can pick it up and keep jiffies going. Using the same value for both situations is wrong, as the CPU online code can see the -1 state when the timer of the newly onlined CPU is setup. The setup for a newly onlined CPU goes through periodic mode and can pick up the do_timer duty without being aware of the nohz / highres mode of the already running system. Use two separate states and make them constants to avoid magic numbers confusion. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-09-16clockevents: make device shutdown robustThomas Gleixner
The device shut down does not cleanup the next_event variable of the clock event device. So when the device is reactivated the possible stale next_event value can prevent the device to be reprogrammed as it claims to wait on a event already. This is the root cause of the resurfacing suspend/resume problem, where systems need key press to come back to life. Fix this by setting next_event to KTIME_MAX when the device is shut down. Use a separate function for shutdown which takes care of that and only keep the direct set mode call in the broadcast code, where we can not touch the next_event value. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-09-05clockevents: prevent clockevent event_handler ending up handler_noopVenkatesh Pallipadi
There is a ordering related problem with clockevents code, due to which clockevents_register_device() called after tickless/highres switch will not work. The new clockevent ends up with clockevents_handle_noop as event handler, resulting in no timer activity. The problematic path seems to be * old device already has hrtimer_interrupt as the event_handler * new clockevent device registers with a higher rating * tick_check_new_device() is called * clockevents_exchange_device() gets called * old->event_handler is set to clockevents_handle_noop * tick_setup_device() is called for the new device * which sets new->event_handler using the old->event_handler which is noop. Change the ordering so that new device inherits the proper handler. This does not have any issue in normal case as most likely all the clockevent devices are setup before the highres switch. But, can potentially be affecting some corner case where HPET force detect happens after the highres switch. This was a problem with HPET in MSI mode code that we have been experimenting with. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-26cpumask: change cpumask_of_cpu_ptr to use new cpumask_of_cpuMike Travis
* Replace previous instances of the cpumask_of_cpu_ptr* macros with a the new (lvalue capable) generic cpumask_of_cpu(). Signed-off-by: Mike Travis <travis@sgi.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Jack Steiner <steiner@sgi.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-18cpumask: Optimize cpumask_of_cpu in kernel/time/tick-common.cMike Travis
* Optimize various places where a pointer to the cpumask_of_cpu value will result in reducing stack pressure. Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17[S390] genirq/clockevents: move irq affinity prototypes/inlines to interrupt.hRussell King
> Generic code is not supposed to include irq.h. Replace this include > by linux/hardirq.h instead and add/replace an include of linux/irq.h > in asm header files where necessary. > This change should only matter for architectures that make use of > GENERIC_CLOCKEVENTS. > Architectures in question are mips, x86, arm, sh, powerpc, uml and sparc64. > > I did some cross compile tests for mips, x86_64, arm, powerpc and sparc64. > This patch fixes also build breakages caused by the include replacement in > tick-common.h. I generally dislike adding optional linux/* includes in asm/* includes - I'm nervous about this causing include loops. However, there's a separate point to be discussed here. That is, what interfaces are expected of every architecture in the kernel. If generic code wants to be able to set the affinity of interrupts, then that needs to become part of the interfaces listed in linux/interrupt.h rather than linux/irq.h. So what I suggest is this approach instead (against Linus' tree of a couple of days ago) - we move irq_set_affinity() and irq_can_set_affinity() to linux/interrupt.h, change the linux/irq.h includes to linux/interrupt.h and include asm/irq_regs.h where needed (asm/irq_regs.h is supposed to be rarely used include since not much touches the stacked parent context registers.) Build tested on ARM PXA family kernels and ARM's Realview platform kernels which both use genirq. [ tglx@linutronix.de: add GENERIC_HARDIRQ dependencies ] Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2007-10-14clockevents: introduce force broadcast notifierThomas Gleixner
The 64bit SMP bootup is slightly different to the 32bit one. It enables the boot CPU local APIC timer before all CPUs are brought up. Some AMD C1E systems have the C1E feature flag only set in the secondary CPU. Due to the early enable of the boot CPU local APIC timer the APIC timer is registered as a fully functional device. When we detect the wreckage during the bringup of the secondary CPU, we need to force the boot CPU into broadcast mode. Add a new notifier reason and implement the force broadcast in the clock events layer. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-12clock events: allow replacement of broadcast timerVenki Pallipadi
Change the broadcast timer, if a timer with higher rating becomes available. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Cc: Andi Kleen <ak@suse.de> Cc: john stultz <johnstul@us.ibm.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-07-21clockevents: fix resume logicThomas Gleixner
We need to make sure, that the clockevent devices are resumed, before the tick is resumed. The current resume logic does not guarantee this. Add CLOCK_EVT_MODE_RESUME and call the set mode functions of the clock event devices before resuming the tick / oneshot functionality. Fixup the existing users. Thanks to Nigel Cunningham for tracking down a long standing thinko, which affected the jinxed VAIO. [akpm@linux-foundation.org: xen build fix] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08highres/dyntick: prevent xtime lock contentionThomas Gleixner
While the !highres/!dyntick code assigns the duty of the do_timer() call to one specific CPU, this was dropped in the highres/dyntick part during development. Steven Rostedt discovered the xtime lock contention on highres/dyntick due to several CPUs trying to update jiffies. Add the single CPU assignement back. In the dyntick case this needs to be handled carefully, as the CPU which has the do_timer() duty must drop the assignement and let it be grabbed by another CPU, which is active. Otherwise the do_timer() calls would not happen during the long sleep. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Steven Rostedt <rostedt@goodmis.org> Acked-by: Mark Lord <mlord@pobox.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-16[PATCH] clockevents: Fix suspend/resume to disk hangsThomas Gleixner
I finally found a dual core box, which survives suspend/resume without crashing in the middle of nowhere. Sigh, I never figured out from the code and the bug reports what's going on. The observed hangs are caused by a stale state transition of the clock event devices, which keeps the RCU synchronization away from completion, when the non boot CPU is brought back up. The suspend/resume in oneshot mode needs the similar care as the periodic mode during suspend to RAM. My assumption that the state transitions during the different shutdown/bringups of s2disk would go through the periodic boot phase and then switch over to highres resp. nohz mode were simply wrong. Add the appropriate suspend / resume handling for the non periodic modes. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-06[PATCH] Save/restore periodic tick information over suspend/resumeThomas Gleixner
The programming of periodic tick devices needs to be saved/restored across suspend/resume - otherwise we might end up with a system coming up that relies on getting a PIT (or HPET) interrupt, while those devices default to 'no interrupts' after powerup. (To confuse things it worked to a certain degree on some systems because the lapic gets initialized as a side-effect of SMP bootup.) This suspend / resume thing was dropped unintentionally during the last-minute -mm code reshuffling. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-26[TICK] tick-common: Fix one-shot handling in tick_handle_periodic().David S. Miller
When clockevents_program_event() is given an expire time in the past, it does not update dev->next_event, so this looping code would loop forever once the first in-the-past expiration time was used. Keep advancing "next" locally to fix this bug. Acked-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-16[PATCH] Add debugging feature /proc/timer_listIngo Molnar
add /proc/timer_list, which prints all currently pending (high-res) timers, all clock-event sources and their parameters in a human-readable form. Sample output: Timer List Version: v0.1 HRTIMER_MAX_CLOCK_BASES: 2 now at 4246046273872 nsecs cpu: 0 clock 0: .index: 0 .resolution: 1 nsecs .get_time: ktime_get_real .offset: 1273998312645738432 nsecs active timers: clock 1: .index: 1 .resolution: 1 nsecs .get_time: ktime_get .offset: 0 nsecs active timers: #0: <f5a90ec8>, hrtimer_sched_tick, hrtimer_stop_sched_tick, swapper/0 # expires at 4246432689566 nsecs [in 386415694 nsecs] #1: <f5a90ec8>, hrtimer_wakeup, do_nanosleep, pcscd/2050 # expires at 4247018194689 nsecs [in 971920817 nsecs] #2: <f5a90ec8>, hrtimer_wakeup, do_nanosleep, irqbalance/1909 # expires at 4247351358392 nsecs [in 1305084520 nsecs] #3: <f5a90ec8>, hrtimer_wakeup, do_nanosleep, crond/2157 # expires at 4249097614968 nsecs [in 3051341096 nsecs] #4: <f5a90ec8>, it_real_fn, do_setitimer, syslogd/1888 # expires at 4251329900926 nsecs [in 5283627054 nsecs] .expires_next : 4246432689566 nsecs .hres_active : 1 .check_clocks : 0 .nr_events : 31306 .idle_tick : 4246020791890 nsecs .tick_stopped : 1 .idle_jiffies : 986504 .idle_calls : 40700 .idle_sleeps : 36014 .idle_entrytime : 4246019418883 nsecs .idle_sleeptime : 4178181972709 nsecs cpu: 1 clock 0: .index: 0 .resolution: 1 nsecs .get_time: ktime_get_real .offset: 1273998312645738432 nsecs active timers: clock 1: .index: 1 .resolution: 1 nsecs .get_time: ktime_get .offset: 0 nsecs active timers: #0: <f5a90ec8>, hrtimer_sched_tick, hrtimer_restart_sched_tick, swapper/0 # expires at 4246050084568 nsecs [in 3810696 nsecs] #1: <f5a90ec8>, hrtimer_wakeup, do_nanosleep, atd/2227 # expires at 4261010635003 nsecs [in 14964361131 nsecs] #2: <f5a90ec8>, hrtimer_wakeup, do_nanosleep, smartd/2332 # expires at 5469485798970 nsecs [in 1223439525098 nsecs] .expires_next : 4246050084568 nsecs .hres_active : 1 .check_clocks : 0 .nr_events : 24043 .idle_tick : 4246046084568 nsecs .tick_stopped : 0 .idle_jiffies : 986510 .idle_calls : 26360 .idle_sleeps : 22551 .idle_entrytime : 4246043874339 nsecs .idle_sleeptime : 4170763761184 nsecs tick_broadcast_mask: 00000003 event_broadcast_mask: 00000001 CPU#0's local event device: Clock Event Device: lapic capabilities: 0000000e max_delta_ns: 807385544 min_delta_ns: 1443 mult: 44624025 shift: 32 set_next_event: lapic_next_event set_mode: lapic_timer_setup event_handler: hrtimer_interrupt .installed: 1 .expires: 4246432689566 nsecs CPU#1's local event device: Clock Event Device: lapic capabilities: 0000000e max_delta_ns: 807385544 min_delta_ns: 1443 mult: 44624025 shift: 32 set_next_event: lapic_next_event set_mode: lapic_timer_setup event_handler: hrtimer_interrupt .installed: 1 .expires: 4246050084568 nsecs Clock Event Device: hpet capabilities: 00000007 max_delta_ns: 2147483647 min_delta_ns: 3352 mult: 61496110 shift: 32 set_next_event: hpet_next_event set_mode: hpet_set_mode event_handler: handle_nextevt_broadcast Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] tick-management: dyntick / highres functionalityThomas Gleixner
With Ingo Molnar <mingo@elte.hu> Add functions to provide dynamic ticks and high resolution timers. The code which keeps track of jiffies and handles the long idle periods is shared between tick based and high resolution timer based dynticks. The dyntick functionality can be disabled on the kernel commandline. Provide also the infrastructure to support high resolution timers. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] tick-management: broadcast functionalityThomas Gleixner
With Ingo Molnar <mingo@elte.hu> Add broadcast functionality, so per cpu clock event devices can be registered as dummy devices or switched from/to broadcast on demand. The broadcast function distributes the events via the broadcast function of the clock event device. This is primarily designed to replace the switch apic timer to / from IPI in power states, where the apic stops. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] tick-management: core functionalityThomas Gleixner
With Ingo Molnar <mingo@elte.hu> The tick-management code is the first user of the clockevents layer. It takes clock event devices from the clock events core and uses them to provide the periodic tick. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
