timekeeping_init() can set the wall time offset, so we need to
increment the clock_was_set_seq counter. That way hrtimers will pick
up the early offset immediately. Otherwise on a machine which does not
set wall time later in the boot process the hrtimer offset is stale at
0 and wall time timers are going to expire with a delay of 45 years.
Fixes: 868a3e915f7f "hrtimer: Make offset update smarter"
Reported-and-tested-by: Heiko Carstens <heiko.carstens@de.ibm.com>
Cc: Stefan Liebler <stli@linux.vnet.ibm.com>
Cc: John Stultz <john.stultz@linaro.org>
The internal clocksteering done for fine-grained error
correction uses a logarithmic approximation, so any time
adjtimex() adjusts the clock steering, timekeeping_freqadjust()
quickly approximates the correct clock frequency over a series
of ticks.
Unfortunately, the logic in timekeeping_freqadjust(), introduced
in commit:
dc491596f639 ("timekeeping: Rework frequency adjustments to work better w/ nohz")
used the abs() function with a s64 error value to calculate the
size of the approximated adjustment to be made.
Per include/linux/kernel.h:
"abs() should not be used for 64-bit types (s64, u64, long long) - use abs64()".
Thus on 32-bit platforms, this resulted in the clocksteering to
take a quite dampended random walk trying to converge on the
proper frequency, which caused the adjustments to be made much
slower then intended (most easily observed when large
adjustments are made).
This patch fixes the issue by using abs64() instead.
Reported-by: Nuno Gonçalves <nunojpg@gmail.com>
Tested-by: Nuno Goncalves <nunojpg@gmail.com>
Signed-off-by: John Stultz <john.stultz@linaro.org>
Cc: <stable@vger.kernel.org> # v3.17+
Cc: Miroslav Lichvar <mlichvar@redhat.com>
Cc: Prarit Bhargava <prarit@redhat.com>
Cc: Richard Cochran <richardcochran@gmail.com>
Link: http://lkml.kernel.org/r/1441840051-20244-1-git-send-email-john.stultz@linaro.org
The current_kernel_time() is not year 2038 safe on 32bit systems
since it returns a timespec value. Introduce current_kernel_time64()
which returns a timespec64 value.
Signed-off-by: Baolin Wang <baolin.wang@linaro.org>
Two issues were found on an IMX6 development board without an
enabled RTC device(resulting in the boot time and monotonic
time being initialized to 0).
Issue 1:exportfs -a generate:
"exportfs: /opt/nfs/arm does not support NFS export"
Issue 2:cat /proc/stat:
"btime 4294967236"
The same issues can be reproduced on x86 after running the
following code:
int main(void)
struct timeval val;
int ret;
val.tv_sec = 0;
val.tv_usec = 0;
ret = settimeofday(&val, NULL);
return 0;
Two issues are different symptoms of same problem:
The reason is a positive wall_to_monotonic pushes boot time back
to the time before Epoch, and getboottime will return negative
value.
In symptom 1:
negative boot time cause get_expiry() to overflow time_t
when input expire time is 2147483647, then cache_flush()
always clears entries just added in ip_map_parse.
In symptom 2:
show_stat() uses "unsigned long" to print negative btime
value returned by getboottime.
This patch fix the problem by prohibiting time from being set to a value which
would cause a negative boot time. As a result one can't set the CLOCK_REALTIME
time prior to (1970 + system uptime).
Signed-off-by: Wang YanQing <udknight@gmail.com>
[jstultz: reworded commit message]
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull module updates from Rusty Russell:
"Main excitement here is Peter Zijlstra's lockless rbtree optimization
to speed module address lookup. He found some abusers of the module
lock doing that too.
A little bit of parameter work here too; including Dan Streetman's
breaking up the big param mutex so writing a parameter can load
another module (yeah, really). Unfortunately that broke the usual
suspects, !CONFIG_MODULES and !CONFIG_SYSFS, so those fixes were
appended too"
* tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (26 commits)
modules: only use mod->param_lock if CONFIG_MODULES
param: fix module param locks when !CONFIG_SYSFS.
rcu: merge fix for Convert ACCESS_ONCE() to READ_ONCE() and WRITE_ONCE()
module: add per-module param_lock
module: make perm const
params: suppress unused variable error, warn once just in case code changes.
modules: clarify CONFIG_MODULE_COMPRESS help, suggest 'N'.
kernel/module.c: avoid ifdefs for sig_enforce declaration
kernel/workqueue.c: remove ifdefs over wq_power_efficient
kernel/params.c: export param_ops_bool_enable_only
kernel/params.c: generalize bool_enable_only
kernel/module.c: use generic module param operaters for sig_enforce
kernel/params: constify struct kernel_param_ops uses
sysfs: tightened sysfs permission checks
module: Rework module_addr_{min,max}
module: Use __module_address() for module_address_lookup()
module: Make the mod_tree stuff conditional on PERF_EVENTS || TRACING
module: Optimize __module_address() using a latched RB-tree
rbtree: Implement generic latch_tree
seqlock: Introduce raw_read_seqcount_latch()
The fix in d151832650ed9 (time: Move clock_was_set_seq update
before updating shadow-timekeeper) was unfortunately incomplete.
The main gist of that change was to do the shadow-copy update
last, so that any state changes were properly duplicated, and
we wouldn't accidentally have stale data in the shadow.
Unfortunately in the main update_wall_time() logic, we update
use the shadow-timekeeper to calculate the next update values,
then while holding the lock, copy the shadow-timekeeper over,
then call timekeeping_update() to do some additional
bookkeeping, (skipping the shadow mirror). The bug with this is
the additional bookkeeping isn't all read-only, and some
changes timkeeper state. Thus we might then overwrite this state
change on the next update.
To avoid this problem, do the timekeeping_update() on the
shadow-timekeeper prior to copying the full state over to
the real-timekeeper.
This avoids problems with both the clock_was_set_seq and
next_leap_ktime being overwritten and possibly the
fast-timekeepers as well.
Many thanks to Prarit for his rigorous testing, which discovered
this problem, along with Prarit and Daniel's work validating this
fix.
Reported-by: Prarit Bhargava <prarit@redhat.com>
Tested-by: Prarit Bhargava <prarit@redhat.com>
Tested-by: Daniel Bristot de Oliveira <bristot@redhat.com>
Cc: Jan Kara <jack@suse.cz>
Cc: Jiri Bohac <jbohac@suse.cz>
Link: http://lkml.kernel.org/r/1434560753-7441-1-git-send-email-john.stultz@linaro.org
Currently, leapsecond adjustments are done at tick time. As a result,
the leapsecond was applied at the first timer tick *after* the
leapsecond (~1-10ms late depending on HZ), rather then exactly on the
second edge.
This was in part historical from back when we were always tick based,
but correcting this since has been avoided since it adds extra
conditional checks in the gettime fastpath, which has performance
overhead.
However, it was recently pointed out that ABS_TIME CLOCK_REALTIME
timers set for right after the leapsecond could fire a second early,
since some timers may be expired before we trigger the timekeeping
timer, which then applies the leapsecond.
This isn't quite as bad as it sounds, since behaviorally it is similar
to what is possible w/ ntpd made leapsecond adjustments done w/o using
the kernel discipline. Where due to latencies, timers may fire just
prior to the settimeofday call. (Also, one should note that all
applications using CLOCK_REALTIME timers should always be careful,
since they are prone to quirks from settimeofday() disturbances.)
However, the purpose of having the kernel do the leap adjustment is to
avoid such latencies, so I think this is worth fixing.
So in order to properly keep those timers from firing a second early,
this patch modifies the ntp and timekeeping logic so that we keep
enough state so that the update_base_offsets_now accessor, which
provides the hrtimer core the current time, can check and apply the
leapsecond adjustment on the second edge. This prevents the hrtimer
core from expiring timers too early.
This patch does not modify any other time read path, so no additional
overhead is incurred. However, this also means that the leap-second
continues to be applied at tick time for all other read-paths.
Apologies to Richard Cochran, who pushed for similar changes years
ago, which I resisted due to the concerns about the performance
overhead.
While I suspect this isn't extremely critical, folks who care about
strict leap-second correctness will likely want to watch
this. Potentially a -stable candidate eventually.
Originally-suggested-by: Richard Cochran <richardcochran@gmail.com>
Reported-by: Daniel Bristot de Oliveira <bristot@redhat.com>
Cc: Shuah Khan <shuahkh@osg.samsung.com>
Link: http://lkml.kernel.org/r/1434063297-28657-4-git-send-email-john.stultz@linaro.org
It was reported that 868a3e915f7f5eba (hrtimer: Make offset
update smarter) was causing timer problems after suspend/resume.
The problem with that change is the modification to
clock_was_set_seq in timekeeping_update is done prior to
mirroring the time state to the shadow-timekeeper. Thus the
next time we do update_wall_time() the updated sequence is
overwritten by whats in the shadow copy.
This patch moves the shadow-timekeeper mirroring to the end
of the function, after all updates have been made, so all data
is kept in sync.
(This patch also affects the update_fast_timekeeper calls which
were also problematically done prior to the mirroring).
Reported-and-tested-by: Jeremiah Mahler <jmmahler@gmail.com>
Cc: Preeti U Murthy <preeti@linux.vnet.ibm.com>
Cc: Viresh Kumar <viresh.kumar@linaro.org>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Link: http://lkml.kernel.org/r/1434063297-28657-2-git-send-email-john.stultz@linaro.org
Because with latches there is a strict data dependency on the seq load
we can avoid the rmb in favour of a read_barrier_depends.
Suggested-by: Ingo Molnar <mingo@kernel.org>
Improve the documentation of the latch technique as used in the
current timekeeping code, such that it can be readily employed
elsewhere.
Borrow from the comments in timekeeping and replace those with a
reference to this more generic comment.
Cc: David Woodhouse <David.Woodhouse@intel.com>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Reviewed-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Acked-by: Michel Lespinasse <walken@google.com>
Now that we have a read_boot_clock64() function available on every
architecture, and converted all the users to it, it's time to remove
the (now unused) read_boot_clock() completely from the kernel.
Signed-off-by: Xunlei Pang <pang.xunlei@linaro.org>
[jstultz: Minor commit message tweak suggested by Ingo]
Ingo suggested that the timekeeping debugging variables
recently added should not be global, and should be tied
to the timekeeper's read_base.
Thus this patch implements that suggestion.
This version is different from the earlier versions
as it keeps the variables in the timekeeper structure
rather then in the tkr.
This patch series introduces a new function
u32 ktime_get_resolution_ns(void)
which allows to clean up some driver code.
In particular the IIO subsystem has a function to provide timestamps for
events but no means to get their resolution. So currently the dht11 driver
tries to guess the resolution in a rather messy and convoluted way. We
can do much better with the new code.
This API is not designed to be exposed to user space.
This has been tested on i386, sunxi and mxs.
Signed-off-by: Harald Geyer <harald@ccbib.org>
[jstultz: Tweaked to make it build after upstream changes]
On every tick/hrtimer interrupt we update the offset variables of the
clock bases. That's silly because these offsets change very seldom.
Add a sequence counter to the time keeping code which keeps track of
the offset updates (clock_was_set()). Have a sequence cache in the
hrtimer cpu bases to evaluate whether the offsets must be updated or
not. This allows us later to avoid pointless cacheline pollution.
Reviewed-by: Preeti U Murthy <preeti@linux.vnet.ibm.com>
Acked-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/20150414203501.132820245@linutronix.de
The softirq time field in the clock bases is an optimization from the
early days of hrtimers. It provides a coarse "jiffies" like time
mostly for self rearming timers.
But that comes with a price:
- Larger code size
- Extra storage space
- Duplicated functions with really small differences
The benefit of this is optimization is marginal for contemporary
systems.
Consolidate everything on the high resolution timer
implementation. This makes further optimizations possible.
Text size reduction:
x8664 -95, i386 -356, ARM -148, ARM64 -40, power64 -16
Link: http://lkml.kernel.org/r/20150414203501.039977424@linutronix.de
Arch specific management of xtime/jiffies/wall_to_monotonic is
gone for quite a while. Zap the stale comment.
Acked-by: John Stultz <john.stultz@linaro.org>
Link: http://lkml.kernel.org/r/2422730.dmO29q661S@vostro.rjw.lan
If a system does not provide a persistent_clock(), the time
will be updated on resume by rtc_resume(). With the addition
of the non-stop clocksources for suspend timing, those systems
set the time on resume in timekeeping_resume(), but may not
provide a valid persistent_clock().
This results in the rtc_resume() logic thinking no one has set
the time and it then will over-write the suspend time again,
which is not necessary and only increases clock error.
So, fix this for rtc_resume().
This patch also improves the name of persistent_clock_exist to
make it more grammatical.
Link: http://lkml.kernel.org/r/1427945681-29972-19-git-send-email-john.stultz@linaro.org
When there's no persistent clock, normally
timekeeping_suspend_time should always be zero, but this can
break in timekeeping_suspend().
At T1, there was a system suspend, so old_delta was assigned T1.
After some time, one time adjustment happened, and xtime got the
value of T1-dt(0s<dt<2s). Then, there comes another system
suspend soon after this adjustment, obviously we will get a
small negative delta_delta, resulting in a negative
timekeeping_suspend_time.
This is problematic, when doing timekeeping_resume() if there is
no nonstop clocksource for example, it will hit the else leg and
inject the improper sleeptime which is the wrong logic.
So, we can solve this problem by only doing delta related code
when the persistent clock is existent. Actually the code only
makes sense for persistent clock cases.
Link: http://lkml.kernel.org/r/1427945681-29972-18-git-send-email-john.stultz@linaro.org
timekeeping_inject_sleeptime64() is only used by RTC
suspend/resume, so add build dependencies on the necessary RTC
related macros.
[ Improve commit message clarity. ]
Link: http://lkml.kernel.org/r/1427945681-29972-16-git-send-email-john.stultz@linaro.org
As part of addressing in-kernel y2038 issues, this patch adds
read_persistent_clock64() and replaces all the call sites of
read_persistent_clock() with this function. This is a __weak
implementation, which simply calls the existing y2038 unsafe
read_persistent_clock().
This allows architecture specific implementations to be
converted independently, and eventually the y2038 unsafe
read_persistent_clock() can be removed after all its
architecture specific implementations have been converted to
read_persistent_clock64().
Suggested-by: Arnd Bergmann <arnd@arndb.de>
Link: http://lkml.kernel.org/r/1427945681-29972-3-git-send-email-john.stultz@linaro.org
read_boot_clock64() and replaces all the call sites of
read_boot_clock() with this function. This is a __weak
read_boot_clock().
read_boot_clock() can be removed after all its architecture
read_boot_clock64().
Link: http://lkml.kernel.org/r/1427945681-29972-2-git-send-email-john.stultz@linaro.org
clockevents_notify() is a leftover from the early design of the
clockevents facility. It's really not a notification mechanism,
it's a multiplex call.
We are way better off to have explicit calls instead of this
monstrosity. Split out the suspend/resume() calls and invoke
them directly from the call sites.
No locking required at this point because these calls happen
with interrupts disabled and a single cpu online.
[ Rebased on top of 4.0-rc5. ]
Link: http://lkml.kernel.org/r/713674030.jVm1qaHuPf@vostro.rjw.lan
[ Rebased on top of latest timers/core. ]
Add the NMI safe CLOCK_MONOTONIC_RAW accessor..
Link: http://lkml.kernel.org/r/20150319093400.562746929@infradead.org
In preparation for more tk_fast instances, remove all hard-coded
tk_fast_mono references.
Link: http://lkml.kernel.org/r/20150319093400.484279927@infradead.org
Introduce tkr_raw and make use of it.
base_raw -> tkr_raw.base
clock->{mult,shift} -> tkr_raw.{mult.shift}
Kill timekeeping_get_ns_raw() in favour of
timekeeping_get_ns(&tkr_raw), this removes all mono_raw special
casing.
Duplicate the updates to tkr_mono.cycle_last into tkr_raw.cycle_last,
both need the same value.
Link: http://lkml.kernel.org/r/20150319093400.422589590@infradead.org
In preparation of adding another tkr field, rename this one to
tkr_mono. Also rename tk_read_base::base_mono to tk_read_base::base,
since the structure is not specific to CLOCK_MONOTONIC and the mono
name got added to the tk_read_base instance.
Lots of trivial churn.
Link: http://lkml.kernel.org/r/20150319093400.344679419@infradead.org
It was suggested that the underflow/overflow protection
should probably throw some sort of warning out, rather
than just silently fixing the issue.
So this patch adds some warnings here. The flag variables
used are not protected by locks, but since we can't print
from the reading functions, just being able to say we
saw an issue in the update interval is useful enough,
and can be slightly racy without real consequence.
The big complication is that we're only under a read
seqlock, so the data could shift under us during
our calculation to see if there was a problem. This
patch avoids this issue by nesting another seqlock
which allows us to snapshot the just required values
atomically. So we shouldn't see false positives.
I also added some basic rate-limiting here, since
on one build machine w/ skewed TSCs it was fairly
noisy at bootup.
Cc: Dave Jones <davej@codemonkey.org.uk>
Cc: Stephen Boyd <sboyd@codeaurora.org>
Link: http://lkml.kernel.org/r/1426133800-29329-8-git-send-email-john.stultz@linaro.org
In the case where there is a broken clocksource
where there are multiple actual clocks that
aren't perfectly aligned, we may see small "negative"
deltas when we subtract 'now' from 'cycle_last'.
The values are actually negative with respect to the
clocksource mask value, not necessarily negative
if cast to a s64, but we can check by checking the
delta to see if it is a small (relative to the mask)
negative value (again negative relative to the mask).
If so, we assume we jumped backwards somehow and
instead use zero for our delta.
Link: http://lkml.kernel.org/r/1426133800-29329-7-git-send-email-john.stultz@linaro.org
When calculating the current delta since the last tick, we
currently have no hard protections to prevent a multiplication
overflow from occuring.
This patch introduces infrastructure to allow a cap that
limits the clocksource read delta value to the 'max_cycles' value,
which is where an overflow would occur.
Since this is in the hotpath, it adds the extra checking under
CONFIG_DEBUG_TIMEKEEPING=y.
There was some concern that capping time like this could cause
problems as we may stop expiring timers, which could go circular
if the timer that triggers time accumulation were mis-scheduled
too far in the future, which would cause time to stop.
However, since the mult overflow would result in a smaller time
value, we would effectively have the same problem there.
Link: http://lkml.kernel.org/r/1426133800-29329-6-git-send-email-john.stultz@linaro.org
Recently there's been requests for better sanity
checking in the time code, so that it's more clear
when something is going wrong, since timekeeping issues
could manifest in a large number of strange ways in
various subsystems.
Thus, this patch adds some extra infrastructure to
add a check to update_wall_time() to print two new
warnings:
1) if we see the call delayed beyond the 'max_cycles'
overflow point,
2) or if we see the call delayed beyond the clocksource's
'max_idle_ns' value, which is currently 50% of the
overflow point.
This extra infrastructure is conditional on
a new CONFIG_DEBUG_TIMEKEEPING option, also
added in this patch - default off.
Tested this a bit by halting qemu for specified
lengths of time to trigger the warnings.
Link: http://lkml.kernel.org/r/1426133800-29329-5-git-send-email-john.stultz@linaro.org
[ Improved the changelog and the messages a bit. ]
The efficiency of suspend-to-idle depends on being able to keep CPUs
in the deepest available idle states for as much time as possible.
Ideally, they should only be brought out of idle by system wakeup
interrupts.
However, timer interrupts occurring periodically prevent that from
happening and it is not practical to chase all of the "misbehaving"
timers in a whack-a-mole fashion. A much more effective approach is
to suspend the local ticks for all CPUs and the entire timekeeping
along the lines of what is done during full suspend, which also
helps to keep suspend-to-idle and full suspend reasonably similar.
The idea is to suspend the local tick on each CPU executing
cpuidle_enter_freeze() and to make the last of them suspend the
entire timekeeping. That should prevent timer interrupts from
triggering until an IO interrupt wakes up one of the CPUs. It
needs to be done with interrupts disabled on all of the CPUs,
though, because otherwise the suspended clocksource might be
accessed by an interrupt handler which might lead to fatal
consequences.
Unfortunately, the existing ->enter callbacks provided by cpuidle
drivers generally cannot be used for implementing that, because some
of them re-enable interrupts temporarily and some idle entry methods
cause interrupts to be re-enabled automatically on exit. Also some
of these callbacks manipulate local clock event devices of the CPUs
which really shouldn't be done after suspending their ticks.
To overcome that difficulty, introduce a new cpuidle state callback,
->enter_freeze, that will be guaranteed (1) to keep interrupts
disabled all the time (and return with interrupts disabled) and (2)
not to touch the CPU timer devices. Modify cpuidle_enter_freeze() to
look for the deepest available idle state with ->enter_freeze present
and to make the CPU execute that callback with suspended tick (and the
last of the online CPUs to execute it with suspended timekeeping).
Suggested-by: Thomas Gleixner <tglx@linutronix.de>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Theoretically, ktime_get_mono_fast_ns() may be executed after
timekeeping has been suspended (or before it is resumed) which
in turn may lead to undefined behavior, for example, when the
clocksource read from timekeeping_get_ns() called by it is
not accessible at that time.
Prevent that from happening by setting up a dummy readout base for
the fast timekeeper during timekeeping_suspend() such that it will
always return the same number of cycles.
After the last timekeeping_update() in timekeeping_suspend() the
clocksource is read and the result is stored as cycles_at_suspend.
The readout base from the current timekeeper is copied onto the
dummy and the ->read pointer of the dummy is set to a routine
unconditionally returning cycles_at_suspend. Next, the dummy is
passed to update_fast_timekeeper().
Then, ktime_get_mono_fast_ns() will work until the subsequent
timekeeping_resume() and the proper readout base for the fast
timekeeper will be restored by the timekeeping_update() called
right after clearing timekeeping_suspended.
Modify update_fast_timekeeper() to take a struct tk_read_base
pointer as its argument (instead of a struct timekeeper pointer)
and update its kerneldoc comment to reflect that.
That will allow a struct tk_read_base that is not part of a
struct timekeeper to be passed to it in the next patch.
Adds a timespec64 based getboottime64() implementation
that can be used as we convert internal users of
getboottime away from using timespecs.
Cc: pang.xunlei <pang.xunlei@linaro.org>
Cc: Arnd Bergmann <arnd.bergmann@linaro.org>
Pull more 2038 timer work from Thomas Gleixner:
"Two more patches for the ongoing 2038 work:
- New accessors to clock MONOTONIC and REALTIME seconds
This is a seperate branch as Arnd has follow up work depending on
this"
* 'timers-2038-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
timekeeping: Provide y2038 safe accessor to the seconds portion of CLOCK_REALTIME
timekeeping: Provide fast accessor to the seconds part of CLOCK_MONOTONIC
In commit 6067dc5a8c2b ("time: Avoid possible NTP adjustment
mult overflow") a new check was added to watch for adjustments
that could cause a mult overflow.
Unfortunately the check compares a signed with unsigned value
and ignored the case where the adjustment was negative, which
causes spurious warn-ons on some systems (and seems like it
would result in problematic time adjustments there as well, due
to the early return).
Thus this patch adds a check to make sure the adjustment is
positive before we check for an overflow, and resovles the issue
in my testing.
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Debugged-by: pang.xunlei <pang.xunlei@linaro.org>
Link: http://lkml.kernel.org/r/1416890145-30048-1-git-send-email-john.stultz@linaro.org
Fix up a few comments that weren't updated when the
functions were converted to use timespec64 structures.
Acked-by: Arnd Bergmann <arnd.bergmann@linaro.org>
Adds a timespec64 based get_monotonic_coarse64() implementation
get_monotonic_coarse away from using timespecs.
Adds a timespec64 based getrawmonotonic64() implementation
getrawmonotonic away from using timespecs.
As part of addressing "y2038 problem" for in-kernel uses, this
patch adds timekeeping_inject_sleeptime64() using timespec64.
After this patch, timekeeping_inject_sleeptime() is deprecated
and all its call sites will be fixed using the new interface,
after that it can be removed.
NOTE: timekeeping_inject_sleeptime() is safe actually, but we
want to eliminate timespec eventually, so comes this patch.
Signed-off-by: pang.xunlei <pang.xunlei@linaro.org>
The kernel uses 32-bit signed value(time_t) for seconds elapsed
1970-01-01:00:00:00, thus it will overflow at 2038-01-19 03:14:08
on 32-bit systems. This is widely known as the y2038 problem.
As part of addressing "y2038 problem" for in-kernel uses, this patch
adds safe do_settimeofday64() using timespec64.
After this patch, do_settimeofday() is deprecated and all its call
sites will be fixed using do_settimeofday64(), after that it can be
removed.
The clocksource mult-adjustment threshold is [mult-maxadj, mult+maxadj],
timekeeping_adjust() only deals with the upper threshold, but misses the
lower threshold.
This patch adds the lower threshold judging condition.
[jstultz: Minor fix for > 80 char line]
Ideally, __clocksource_updatefreq_scale, selects the largest shift
value possible for a clocksource. This results in the mult memember of
struct clocksource being particularly large, although not so large
that NTP would adjust the clock to cause it to overflow.
That said, nothing actually prohibits an overflow from occuring, its
just that it "shouldn't" occur.
So while very unlikely, and so far never observed, the value of
(cs->mult+cs->maxadj) may have a chance to reach very near 0xFFFFFFFF,
so there is a possibility it may overflow when doing NTP positive
adjustment
See the following detail: When NTP slewes the clock, kernel goes
through update_wall_time()->...->timekeeping_apply_adjustment():
tk->tkr.mult += mult_adj;
Since there is no guard against it, its possible tk->tkr.mult may
overflow during this operation.
This patch avoids any possible mult overflow by judging the overflow
case before adding mult_adj to mult, also adds the WARNING message
when capturing such case.
[jstultz: Reworded commit message]
CLOCK_REALTIME
ktime_get_real_seconds() is the replacement function for get_seconds()
returning the seconds portion of CLOCK_REALTIME in a time64_t. For
64bit the function is equivivalent to get_seconds(), but for 32bit it
protects the readout with the timekeeper sequence count. This is
required because 32-bit machines cannot access 64-bit tk->xtime_sec
variable atomically.
[tglx: Massaged changelog and added docbook comment ]
Signed-off-by: Heena Sirwani <heenasirwani@gmail.com>
Reviewed-by: Arnd Bergman <arnd@arndb.de>
Cc: opw-kernel@googlegroups.com
Link: http://lkml.kernel.org/r/7adcfaa8962b8ad58785d9a2456c3f77d93c0ffb.1414578445.git.heenasirwani@gmail.com
This is the counterpart to get_seconds() based on CLOCK_MONOTONIC. The
use case for this interface are kernel internal coarse grained
timestamps which do neither require the nanoseconds fraction of
current time nor the CLOCK_REALTIME properties. Such timestamps can
currently only retrieved by calling ktime_get_ts64() and using the
tv_sec field of the returned timespec64. That's inefficient as it
involves the read of the clocksource, math operations and must be
protected by the timekeeper sequence counter.
To avoid the sequence counter protection we restrict the return value
to unsigned 32bit on 32bit machines. This covers ~136 years of uptime
and therefor an overflow is not expected to hit anytime soon.
To avoid math in the function we calculate the current seconds portion
of CLOCK_MONOTONIC when the timekeeper gets updated in
tk_update_ktime_data() similar to the CLOCK_REALTIME counterpart
xtime_sec.
[ tglx: Massaged changelog, simplified and commented the update
function, added docbook comment ]
Link: http://lkml.kernel.org/r/da0b63f4bdf3478909f92becb35861197da3a905.1414578445.git.heenasirwani@gmail.com
The update_walltime() code works on the shadow timekeeper to make the
seqcount protected region as short as possible. But that update to the
shadow timekeeper does not update all timekeeper fields because it's
sufficient to do that once before it becomes life. One of these fields
is tkr.base_mono. That stays stale in the shadow timekeeper unless an
operation happens which copies the real timekeeper to the shadow.
The update function is called after the update calls to vsyscall and
pvclock. While not correct, it did not cause any problems because none
of the invoked update functions used base_mono.
commit cbcf2dd3b3d4 (x86: kvm: Make kvm_get_time_and_clockread()
nanoseconds based) changed that in the kvm pvclock update function, so
the stale mono_base value got used and caused kvm-clock to malfunction.
Put the update where it belongs and fix the issue.
Reported-by: Chris J Arges <chris.j.arges@canonical.com>
Reported-by: Paolo Bonzini <pbonzini@redhat.com>
Cc: Gleb Natapov <gleb@kernel.org>
Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1409050000570.3333@nanos
Benjamin Herrenschmidt pointed out that I further missed modifying
update_vsyscall after the wall_to_mono value was changed to a
timespec64. This causes issues on powerpc32, which expects a 32bit
timespec.
This patch fixes the problem by properly converting from a timespec64 to
a timespec before passing the value on to the arch-specific vsyscall
logic.
[ Thomas is currently on vacation, but reviewed it and wanted me to send
this fix on to you directly. ]
Cc: LKML <linux-kernel@vger.kernel.org>
Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
By caching the ntp_tick_length() when we correct the frequency error,
and then using that cached value to accumulate error, we avoid large
initial errors when the tick length is changed.
This makes convergence happen much faster in the simulator, since the
initial error doesn't have to be slowly whittled away.
This initially seems like an accounting error, but Miroslav pointed out
that ntp_tick_length() can change mid-tick, so when we apply it in the
error accumulation, we are applying any recent change to the entire tick.
This approach chooses to apply changes in the ntp_tick_length() only to
the next tick, which allows us to calculate the freq correction before
using the new tick length, which avoids accummulating error.
Credit to Miroslav for pointing this out and providing the original patch
this functionality has been pulled out from, along with the rational.
Reported-by: Miroslav Lichvar <mlichvar@redhat.com>
The existing timekeeping_adjust logic has always been complicated
to understand. Further, since it was developed prior to NOHZ becoming
common, its not surprising it performs poorly when NOHZ is enabled.
Since Miroslav pointed out the problematic nature of the existing code
in the NOHZ case, I've tried to refactor the code to perform better.
The problem with the previous approach was that it tried to adjust
for the total cumulative error using a scaled dampening factor. This
resulted in large errors to be corrected slowly, while small errors
were corrected quickly. With NOHZ the timekeeping code doesn't know
how far out the next tick will be, so this results in bad
over-correction to small errors, and insufficient correction to large
errors.
Inspired by Miroslav's patch, I've refactored the code to try to
address the correction in two steps.
1) Check the future freq error for the next tick, and if the frequency
error is large, try to make sure we correct it so it doesn't cause
much accumulated error.
2) Then make a small single unit adjustment to correct any cumulative
error that has collected over time.
This method performs fairly well in the simulator Miroslav created.
Major credit to Miroslav for pointing out the issue, providing the
original patch to resolve this, a simulator for testing, as well as
helping debug and resolve issues in my implementation so that it
performed closer to his original implementation.
In the GENERIC_TIME_VSYSCALL_OLD update_vsyscall implementation,
we take the tk_xtime() value, which returns a timespec64, and
store it in a timespec.
This luckily is ok, since the only architectures that use
GENERIC_TIME_VSYSCALL_OLD are ia64 and ppc64, which are both
64 bit systems where timespec64 is the same as a timespec.
Even so, for cleanliness reasons, use the conversion function
to assign the proper type.
