path: root/kernel/timer.c
2007-07-20Pull ia64-clocksource into release branchTony Luck
2007-07-20[IA64] remove time interpolatorBob Picco
Remove time_interpolator code (This is generic code, but only user was ia64. It has been superseded by the CONFIG_GENERIC_TIME code). Signed-off-by: Bob Picco <bob.picco@hp.com> Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Peter Keilty <peter.keilty@hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-07-19timer.c: cleanup recently introduced whitespace damageThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17Slab allocators: Replace explicit zeroing with __GFP_ZEROChristoph Lameter
kmalloc_node() and kmem_cache_alloc_node() were not available in a zeroing variant in the past. But with __GFP_ZERO it is possible now to do zeroing while allocating. Use __GFP_ZERO to remove the explicit clearing of memory via memset whereever we can. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Add a flag to indicate deferrable timers in /proc/timer_statsVenki Pallipadi
Add a flag in /proc/timer_stats to indicate deferrable timers. This will let developers/users to differentiate between types of tiemrs in /proc/timer_stats. Deferrable timer and normal timer will appear in /proc/timer_stats as below. 10D, 1 swapper queue_delayed_work_on (delayed_work_timer_fn) 10, 1 swapper queue_delayed_work_on (delayed_work_timer_fn) Also version of timer_stats changes from v0.1 to v0.2 Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Use boot based time for uptime in /procTomas Janousek
Commit 411187fb05cd11676b0979d9fbf3291db69dbce2 caused uptime not to increase during suspend. This may cause confusion so I restore the old behaviour by using the boot based time instead of monotonic for uptime. Signed-off-by: Tomas Janousek <tjanouse@redhat.com> Acked-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-29NOHZ: prevent multiplication overflow - stop timer for huge timeoutsThomas Gleixner
get_next_timer_interrupt() returns a delta of (LONG_MAX > 1) in case there is no timer pending. On 64 bit machines this results in a multiplication overflow in tick_nohz_stop_sched_tick(). Reported by: Dave Miller <davem@davemloft.net> Make the return value a constant and limit the return value to a 32 bit value. When the max timeout value is returned, we can safely stop the tick timer device. The max jiffies delta results in a 12 days timeout for HZ=1000. In the long term the get_next_timer_interrupt() code needs to be reworked to return ktime instead of jiffies, but we have to wait until the last users of the original NO_IDLE_HZ code are converted. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-14timekeeping fix patch got mis-appliedThomas Gleixner
The time keeping code move to kernel/time/timekeeping.c broke the clocksource resume logic patch, which got applied to the old file by a fuzzy application. Fix it up and move the clocksource_resume() call to the appropriate place. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> [ tssk, tssk, everybody should use --fuzz=0 ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-10timer: revert parenthesis fix in tbase_get_deferrable() etcakpm@linux-foundation.org
On 09-05-2007 21:10, Pallipadi, Venkatesh wrote: ... > On a 64 bit system, converting pointer to int causes unnecessary > compiler warning, and intermediate long conversion was to avoid that. > I will have to rephrase my comment to remove 32 bit value and use int, > as that is what the function returns. So, this patch reverts all changes done by my previous patch. I apologize for my wrong comment about "logical error" here. Cc: "Pallipadi, Venkatesh" <venkatesh.pallipadi@intel.com> Cc: Satyam Sharma <satyam.sharma@gmail.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Jarek Poplawski <jarkao2@o2.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09clocksource: fix resume logicThomas Gleixner
We need to make sure that the clocksources are resumed, when timekeeping is resumed. The current resume logic does not guarantee this. Add a resume function pointer to the clocksource struct, so clocksource drivers which need to reinitialize the clocksource can provide a resume function. Add a resume function, which calls the maybe available clocksource resume functions and resets the watchdog function, so a stable TSC can be used accross suspend/resume. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Cc: Andi Kleen <ak@suse.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09Add suspend-related notifications for CPU hotplugRafael J. Wysocki
Since nonboot CPUs are now disabled after tasks and devices have been frozen and the CPU hotplug infrastructure is used for this purpose, we need special CPU hotplug notifications that will help the CPU-hotplug-aware subsystems distinguish normal CPU hotplug events from CPU hotplug events related to a system-wide suspend or resume operation in progress. This patch introduces such notifications and causes them to be used during suspend and resume transitions. It also changes all of the CPU-hotplug-aware subsystems to take these notifications into consideration (for now they are handled in the same way as the corresponding "normal" ones). [oleg@tv-sign.ru: cleanups] Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Gautham R Shenoy <ego@in.ibm.com> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09timer: parenthesis fix in tbase_get_deferrable() etcJarek Poplawski
Signed-off-by: Jarek Poplawski <jarkao2@o2.pl> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Introduce a handy list_first_entry macroPavel Emelianov
There are many places in the kernel where the construction like foo = list_entry(head->next, struct foo_struct, list); are used. The code might look more descriptive and neat if using the macro list_first_entry(head, type, member) \ list_entry((head)->next, type, member) Here is the macro itself and the examples of its usage in the generic code. If it will turn out to be useful, I can prepare the set of patches to inject in into arch-specific code, drivers, networking, etc. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Signed-off-by: Kirill Korotaev <dev@openvz.org> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Zach Brown <zach.brown@oracle.com> Cc: Davide Libenzi <davidel@xmailserver.org> Cc: John McCutchan <ttb@tentacle.dhs.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: john stultz <johnstul@us.ibm.com> Cc: Ram Pai <linuxram@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Move timekeeping code to timekeeping.cjohn stultz
Move the timekeeping code out of kernel/timer.c and into kernel/time/timekeeping.c. I made no cleanups or other changes in transit. [akpm@linux-foundation.org: build fix] Signed-off-by: John Stultz <johnstul@us.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Add support for deferrable timersVenki Pallipadi
Introduce a new flag for timers - deferrable: Timers that work normally when system is busy. But, will not cause CPU to come out of idle (just to service this timer), when CPU is idle. Instead, this timer will be serviced when CPU eventually wakes up with a subsequent non-deferrable timer. The main advantage of this is to avoid unnecessary timer interrupts when CPU is idle. If the routine currently called by a timer can wait until next event without any issues, this new timer can be used to setup timer event for that routine. This, with dynticks, allows CPUs to be lazy, allowing them to stay in idle for extended period of time by reducing unnecesary wakeup and thereby reducing the power consumption. This patch: Builds this new timer on top of existing timer infrastructure. It uses last bit in 'base' pointer of timer_list structure to store this deferrable timer flag. __next_timer_interrupt() function skips over these deferrable timers when CPU looks for next timer event for which it has to wake up. This is exported by a new interface init_timer_deferrable() that can be called in place of regular init_timer(). [akpm@linux-foundation.org: Privatise a #define] Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Dave Jones <davej@codemonkey.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-26[AF_RXRPC]: Make it possible to merely try to cancel timers from a moduleDavid Howells
Export try_to_del_timer_sync() for use by the AF_RXRPC module. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-07[PATCH] high-res timers: resume fixIngo Molnar
Soeren Sonnenburg reported that upon resume he is getting this backtrace: [<c0119637>] smp_apic_timer_interrupt+0x57/0x90 [<c0142d30>] retrigger_next_event+0x0/0xb0 [<c0104d30>] apic_timer_interrupt+0x28/0x30 [<c0142d30>] retrigger_next_event+0x0/0xb0 [<c0140068>] __kfifo_put+0x8/0x90 [<c0130fe5>] on_each_cpu+0x35/0x60 [<c0143538>] clock_was_set+0x18/0x20 [<c0135cdc>] timekeeping_resume+0x7c/0xa0 [<c02aabe1>] __sysdev_resume+0x11/0x80 [<c02ab0c7>] sysdev_resume+0x47/0x80 [<c02b0b05>] device_power_up+0x5/0x10 it turns out that on resume we mistakenly re-enable interrupts too early. Do the timer retrigger only on the current CPU. Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Soeren Sonnenburg <kernel@nn7.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-25[PATCH] dynticks: fix hrtimer rounding error in next_timer_interruptThomas Gleixner
The rework of next_timer_interrupt() fixed the timer wheel bugs, but invented a rounding error versus the next hrtimer event. This is caused by the conversion of the hrtimer internal representation to relative jiffies. This causes bug #8100: http://bugzilla.kernel.org/show_bug.cgi?id=8100 next_timer_interrupt() returns "now" in such a case and causes the code in tick_nohz_stop_sched_tick() to trigger the timer softirq, which is bogus as no timer is due for expiry. This results in an endless context switching between idle and ksoftirqd until a timer is due for expiry. Modify the hrtimer evaluation so that, it returns now + 1, when the conversion results in a delta < 1 jiffie. It's confirmed to resolve bug #8100 Reported-by: Emil Karlson <jkarlson@cc.hut.fi> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-06[PATCH] fix vsyscall settimeofdayDaniel Walker
I've only seen this on x86_64. The vsyscall state only gets updated when a timer interrupts comes in. So if the time is set long before the next timer, there will be a period when a gettimeofday() won't reflect the correct time. I added an explicit update_vsyscall() during the settimeofday(), that way the vsyscall state doesn't get stale. Signed-off-by: Daniel Walker <dwalker@mvista.com> Cc: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-06[PATCH] Save/restore periodic tick information over suspend/resumeThomas Gleixner
The programming of periodic tick devices needs to be saved/restored across suspend/resume - otherwise we might end up with a system coming up that relies on getting a PIT (or HPET) interrupt, while those devices default to 'no interrupts' after powerup. (To confuse things it worked to a certain degree on some systems because the lapic gets initialized as a side-effect of SMP bootup.) This suspend / resume thing was dropped unintentionally during the last-minute -mm code reshuffling. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-05[PATCH] timer/hrtimer: take per cpu locks in sane orderHeiko Carstens
Doing something like this on a two cpu system # echo 0 > /sys/devices/system/cpu/cpu0/online # echo 1 > /sys/devices/system/cpu/cpu0/online # echo 0 > /sys/devices/system/cpu/cpu1/online will give me this: ======================================================= [ INFO: possible circular locking dependency detected ] 2.6.21-rc2-g562aa1d4-dirty #7 ------------------------------------------------------- bash/1282 is trying to acquire lock: (&cpu_base->lock_key){.+..}, at: [<000000000005f17e>] hrtimer_cpu_notify+0xc6/0x240 but task is already holding lock: (&cpu_base->lock_key#2){.+..}, at: [<000000000005f174>] hrtimer_cpu_notify+0xbc/0x240 which lock already depends on the new lock. This happens because we have the following code in kernel/hrtimer.c: migrate_hrtimers(int cpu) [...] old_base = &per_cpu(hrtimer_bases, cpu); new_base = &get_cpu_var(hrtimer_bases); [...] spin_lock(&new_base->lock); spin_lock(&old_base->lock); Which means the spinlocks are taken in an order which depends on which cpu gets shut down from which other cpu. Therefore lockdep complains that there might be an ABBA deadlock. Since migrate_hrtimers() gets only called on cpu hotplug it's safe to assume that it isn't executed concurrently on a The same problem exists in kernel/timer.c: migrate_timers(). As pointed out by Christian Borntraeger one possible solution to avoid the locking order complaints would be to make sure that the locks are always taken in the same order. E.g. by taking the lock of the cpu with the lower number first. To achieve this we introduce two new spinlock functions double_spin_lock and double_spin_unlock which lock or unlock two locks in a given order. Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: John Stultz <johnstul@us.ibm.com> Cc: Christian Borntraeger <cborntra@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-01[PATCH] kernel-doc fixes for 2.6.20-git15 (non-drivers)Randy Dunlap
Fix kernel-doc warnings in 2.6.20-git15 (lib/, mm/, kernel/, include/). Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-01[PATCH] update timekeeping_is_continuous commentDaniel Walker
Signed-off-by: Daniel Walker <dwalker@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] generic: vsyscall-gtod support for GENERIC_TIMEjohn stultz
Provides generic infrastructure for vsyscall-gtod. [akpm@osdl.org: cleanup] Signed-off-by: John Stultz <johnstul@us.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Andi Kleen <ak@muc.de> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] Add debugging feature /proc/timer_statIngo Molnar
Add /proc/timer_stats support: debugging feature to profile timer expiration. Both the starting site, process/PID and the expiration function is captured. This allows the quick identification of timer event sources in a system. Sample output: # echo 1 > /proc/timer_stats # cat /proc/timer_stats Timer Stats Version: v0.1 Sample period: 4.010 s 24, 0 swapper hrtimer_stop_sched_tick (hrtimer_sched_tick) 11, 0 swapper sk_reset_timer (tcp_delack_timer) 6, 0 swapper hrtimer_stop_sched_tick (hrtimer_sched_tick) 2, 1 swapper queue_delayed_work_on (delayed_work_timer_fn) 17, 0 swapper hrtimer_restart_sched_tick (hrtimer_sched_tick) 2, 1 swapper queue_delayed_work_on (delayed_work_timer_fn) 4, 2050 pcscd do_nanosleep (hrtimer_wakeup) 5, 4179 sshd sk_reset_timer (tcp_write_timer) 4, 2248 yum-updatesd schedule_timeout (process_timeout) 18, 0 swapper hrtimer_restart_sched_tick (hrtimer_sched_tick) 3, 0 swapper sk_reset_timer (tcp_delack_timer) 1, 1 swapper neigh_table_init_no_netlink (neigh_periodic_timer) 2, 1 swapper e1000_up (e1000_watchdog) 1, 1 init schedule_timeout (process_timeout) 100 total events, 25.24 events/sec [ cleanups and hrtimers support from Thomas Gleixner <tglx@linutronix.de> ] [bunk@stusta.de: nr_entries can become static] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] tick-management: dyntick / highres functionalityThomas Gleixner
With Ingo Molnar <mingo@elte.hu> Add functions to provide dynamic ticks and high resolution timers. The code which keeps track of jiffies and handles the long idle periods is shared between tick based and high resolution timer based dynticks. The dyntick functionality can be disabled on the kernel commandline. Provide also the infrastructure to support high resolution timers. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] clockevents: add core functionalityThomas Gleixner
Architectures register their clock event devices, in the clock events core. Users of the clockevents core can get clock event devices for their use. The clockevents core code provides notification mechanisms for various clock related management events. This allows to control the clock event devices without the architectures having to worry about the details of function assignment. This is also a preliminary for high resolution timers and dynamic ticks to allow the core code to control the clock functionality without intrusive changes to the architecture code. [Fixes-by: Ingo Molnar <mingo@elte.hu>] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: john stultz <johnstul@us.ibm.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] Extend next_timer_interrupt() to use a reference jiffieThomas Gleixner
For CONFIG_NO_HZ we need to calculate the next timer wheel event based on a given jiffie value. Extend the existing code to allow the extra 'now' argument. Provide a compability function for the existing implementations to call the function with now == jiffies. (This also solves the racyness of the original code vs. jiffies changing during the iteration.) No functional changes to existing users of this infrastructure. [ remove WARN_ON() that triggered on s390, by Carsten Otte <cotte@de.ibm.com> ] [ made new helper static, Adrian Bunk <bunk@stusta.de> ] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] Fix cascade lookup of next_timer_interruptThomas Gleixner
When searching for the next pending timer in the timer wheel we need to take the cascade into account. The current code has several problems: 1. it looks into the previous cascade 2. it ignores a pending cascade 3. it ignores multiple cascades Change the cascade lookup, so it calculates the array index from the point of the next cascade and always look at the cascade buckets, when the cascade is pending, i.e. gets executed in the next timer softirq. When multiple cascades are pending, then lookup the next buckets too. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] clocksource: Add verification (watchdog) helperThomas Gleixner
The TSC needs to be verified against another clocksource. Instead of using hardwired assumptions of available hardware, provide a generic verification mechanism. The verification uses the best available clocksource and handles the usability for high resolution timers / dynticks of the clocksource which needs to be verified. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] clocksource: Remove the update callbackThomas Gleixner
The clocksource code allows direct updates of the rating of a given clocksource now. Change TSC unstable tracking to use this interface and remove the update callback. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] clocksource: replace is_continuous by a flag fieldThomas Gleixner
Using a flag filed allows to encode more than one information into a variable. Preparatory patch for the generic clocksource verification. [mingo@elte.hu: convert vmitime.c to the new clocksource flag] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] GTOD: persistent clock supportJohn Stultz
Persistent clock support: do proper timekeeping across suspend/resume. [bunk@stusta.de: cleanup] Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] HZ free ntpjohn stultz
Distangle the NTP update from HZ. This is necessary for dynamic tick enabled kernels. Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-13[PATCH] x86-64: get rid of ARCH_HAVE_XTIME_LOCKEric Dumazet
ARCH_HAVE_XTIME_LOCK is used by x86_64 arch . This arch needs to place a read only copy of xtime_lock into vsyscall page. This read only copy is named __xtime_lock, and xtime_lock is defined in arch/x86_64/kernel/vmlinux.lds.S as an alias. So the declaration of xtime_lock in kernel/timer.c was guarded by ARCH_HAVE_XTIME_LOCK define, defined to true on x86_64. We can get same result with _attribute__((weak)) in the declaration. linker should do the job. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Andi Kleen <ak@suse.de> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org>
2007-02-11[PATCH] Common compat_sys_sysinfoKyle McMartin
I noticed that almost all architectures implemented exactly the same sys32_sysinfo... except parisc, where a bug was to be found in handling of the uptime. So let's remove a whole whack of code for fun and profit. Cribbed compat_sys_sysinfo from x86_64's implementation, since I figured it would be the best tested. This patch incorporates Arnd's suggestion of not using set_fs/get_fs, but instead extracting out the common code from sys_sysinfo. Cc: Christoph Hellwig <hch@infradead.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Numerous fixes to kernel-doc info in source files.Robert P. J. Day
A variety of (mostly) innocuous fixes to the embedded kernel-doc content in source files, including: * make multi-line initial descriptions single line * denote some function names, constants and structs as such * change erroneous opening '/*' to '/**' in a few places * reword some text for clarity Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] use cycle_t instead of u64 in struct time_interpolatorHelge Deller
The 32bit and 64bit PARISC Linux kernels suffers from the problem, that the gettimeofday() call sometimes returns non-monotonic times. The easiest way to fix this, is to drop the PARISC-specific implementation and switch over to the generic TIME_INTERPOLATION framework. But in order to make it even compile on 32bit PARISC, the patch below which touches the generic Linux code, is mandatory. More information and the full patch with the parisc-specific changes is included in this thread: http://lists.parisc-linux.org/pipermail/parisc-linux/2006-December/031003.html As far as I could see, this patch does not change anything for the existing architectures which use this framework (IA64 and SPARC64), since "cycles_t" is defined there as unsigned 64bit-integer anyway (which then makes this patch a no-change for them). Signed-off-by: Helge Deller <deller@gmx.de> Cc: <linux-arch@vger.kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-22[PATCH] schedule_timeout(): improve warning messageAndrew Morton
Kyle is hitting this warning, and we don't have a clue what it's caused by. Add the obligatory dump_stack(). Cc: kyle <kylewong@southa.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-13[PATCH] Optimize calc_load()Eric Dumazet
calc_load() is called by timer interrupt to update avenrun[]. It currently calls nr_active() at each timer tick (HZ per second), while the update of avenrun[] is done only once every 5 seconds. (LOAD_FREQ=5 Hz) nr_active() is quite expensive on SMP machines, since it has to sum up nr_running and nr_uninterruptible of all online CPUS, bringing foreign dirty cache lines. This patch is an optimization of calc_load() so that nr_active() is called only if we need it. The use of unlikely() is welcome since the condition is true only once every 5*HZ time. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Cc: Ingo Molnar <mingo@elte.hu> Acked-by: "Siddha, Suresh B" <suresh.b.siddha@intel.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-10[PATCH] clocksource: small cleanupDaniel Walker
Mostly changing alignment. Just some general cleanup. [akpm@osdl.org: build fix] Signed-off-by: Daniel Walker <dwalker@mvista.com> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-10[PATCH] round_jiffies infrastructureArjan van de Ven
Introduce a round_jiffies() function as well as a round_jiffies_relative() function. These functions round a jiffies value to the next whole second. The primary purpose of this rounding is to cause all "we don't care exactly when" timers to happen at the same jiffy. This avoids multiple timers firing within the second for no real reason; with dynamic ticks these extra timers cause wakeups from deep sleep CPU sleep states and thus waste power. The exact wakeup moment is skewed by the cpu number, to avoid all cpus from waking up at the exact same time (and hitting the same lock/cachelines there) [akpm@osdl.org: fix variable type] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] kill wall_jiffiesAtsushi Nemoto
With 2.6.18-rc4-mm2, now wall_jiffies will always be the same as jiffies. So we can kill wall_jiffies completely. This is just a cleanup and logically should not change any real behavior except for one thing: RTC updating code in (old) ppc and xtensa use a condition "jiffies - wall_jiffies == 1". This condition is never met so I suppose it is just a bug. I just remove that condition only instead of kill the whole "if" block. [heiko.carstens@de.ibm.com: s390 build fix and cleanup] Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Andi Kleen <ak@muc.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Hirokazu Takata <takata.hirokazu@renesas.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Chris Zankel <chris@zankel.net> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] ntp: add time_adjust to tick lengthRoman Zippel
This folds update_ntp_one_tick() into second_overflow() and adds time_adjust to the tick length, this makes time_next_adjust unnecessary. This slightly changes the adjtime() behaviour, instead of applying it to the next tick, it's applied to the next second. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] ntp: add ntp_update_frequencyRoman Zippel
This introduces ntp_update_frequency() and deinlines ntp_clear() (as it's not performance critical). ntp_update_frequency() calculates the base tick length using tick_usec and adds a base adjustment, in case the frequency doesn't divide evenly by HZ. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] NTP: Move all the NTP related code to ntp.cjohn stultz
Move all the NTP related code to ntp.c [akpm@osdl.org: cleanups, build fix] Signed-off-by: John Stultz <johnstul@us.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] simplify update_times (avoid jiffies/jiffies_64 aliasing problem)Atsushi Nemoto
Pass ticks to do_timer() and update_times(), and adjust x86_64 and s390 timer interrupt handler with this change. Currently update_times() calculates ticks by "jiffies - wall_jiffies", but callers of do_timer() should know how many ticks to update. Passing ticks get rid of this redundant calculation. Also there are another redundancy pointed out by Martin Schwidefsky. This cleanup make a barrier added by 5aee405c662ca644980c184774277fc6d0769a84 needless. So this patch removes it. As a bonus, this cleanup make wall_jiffies can be removed easily, since now wall_jiffies is always synced with jiffies. (This patch does not really remove wall_jiffies. It would be another cleanup patch) Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: john stultz <johnstul@us.ibm.com> Cc: Andi Kleen <ak@muc.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Acked-by: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Hirokazu Takata <takata.hirokazu@renesas.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Chris Zankel <chris@zankel.net> Acked-by: "Luck, Tony" <tony.luck@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] check return value of cpu_callbackAkinobu Mita
Spawing ksoftirqd, migration, or watchdog, and calling init_timers_cpu() may fail with small memory. If it happens in initcalls, kernel NULL pointer dereference happens later. This patch makes crash happen immediately in such cases. It seems a bit better than getting kernel NULL pointer dereference later. Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] Fix kerneldoc comments in kernel/timer.cRolf Eike Beer
Some of the kerneldoc comments in this file are ignored since the lead-in is malformed, using either "/*" or "/***" instead of "/**". [rdunlap@xenotime.net: kerneldoc fixes] Signed-off-by: Rolf Eike Beer <eike-kernel@sf-tec.de> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] timer: add lock annotation to lock_timer_baseJosh Triplett
lock_timer_base acquires a lock and returns with that lock held. Add a lock annotation to this function so that sparse can check callers for lock pairing, and so that sparse will not complain about this function since it intentionally uses the lock in this manner. Signed-off-by: Josh Triplett <josh@freedesktop.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
