path: root/kernel/trace/ring_buffer.c
2011-06-14ring-buffer: Set __GFP_NORETRY flag for ring buffer allocating processVaibhav Nagarnaik
The tracing ring buffer is allocated from kernel memory. While allocating a large chunk of memory, OOM might happen which destabilizes the system. Thus random processes might get killed during the allocation. This patch adds __GFP_NORETRY flag to the ring buffer allocation calls to make it fail more gracefully if the system will not be able to complete the allocation request. Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Vaibhav Nagarnaik <vnagarnaik@google.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Michael Rubin <mrubin@google.com> Cc: David Sharp <dhsharp@google.com> Link: http://lkml.kernel.org/r/1307491302-9236-1-git-send-email-vnagarnaik@google.com Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-06-14tracing: Convert to kstrtoul_from_userPeter Huewe
This patch replaces the code for getting an unsigned long from a userspace buffer by a simple call to kstroul_from_user. This makes it easier to read and less error prone. Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Link: http://lkml.kernel.org/r/1307476707-14762-1-git-send-email-peterhuewe@gmx.de Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-06-14tracing: Use NUMA allocation for per-cpu ring buffer pagesVaibhav Nagarnaik
The tracing ring buffer is a group of per-cpu ring buffers where allocation and logging is done on a per-cpu basis. The events that are generated on a particular CPU are logged in the corresponding buffer. This is to provide wait-free writes between CPUs and good NUMA node locality while accessing the ring buffer. However, the allocation routines consider NUMA locality only for buffer page metadata and not for the actual buffer page. This causes the pages to be allocated on the NUMA node local to the CPU where the allocation routine is running at the time. This patch fixes the problem by using a NUMA node specific allocation routine so that the pages are allocated from a NUMA node local to the logging CPU. I tested with the getuid_microbench from autotest. It is a simple binary that calls getuid() in a loop and measures the average time for the syscall to complete. The following command was used to test: $ getuid_microbench 1000000 Compared the numbers found on kernel with and without this patch and found that logging latency decreases by 30-50 ns/call. tracing with non-NUMA allocation - 569 ns/call tracing with NUMA allocation - 512 ns/call Signed-off-by: Vaibhav Nagarnaik <vnagarnaik@google.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Michael Rubin <mrubin@google.com> Cc: David Sharp <dhsharp@google.com> Link: http://lkml.kernel.org/r/1304470602-20366-1-git-send-email-vnagarnaik@google.com Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-05-25ftrace: Add internal recursive checksSteven Rostedt
Witold reported a reboot caused by the selftests of the dynamic function tracer. He sent me a config and I used ktest to do a config_bisect on it (as my config did not cause the crash). It pointed out that the problem config was CONFIG_PROVE_RCU. What happened was that if multiple callbacks are attached to the function tracer, we iterate a list of callbacks. Because the list is managed by synchronize_sched() and preempt_disable, the access to the pointers uses rcu_dereference_raw(). When PROVE_RCU is enabled, the rcu_dereference_raw() calls some debugging functions, which happen to be traced. The tracing of the debug function would then call rcu_dereference_raw() which would then call the debug function and then... well you get the idea. I first wrote two different patches to solve this bug. 1) add a __rcu_dereference_raw() that would not do any checks. 2) add notrace to the offending debug functions. Both of these patches worked. Talking with Paul McKenney on IRC, he suggested to add recursion detection instead. This seemed to be a better solution, so I decided to implement it. As the task_struct already has a trace_recursion to detect recursion in the ring buffer, and that has a very small number it allows, I decided to use that same variable to add flags that can detect the recursion inside the infrastructure of the function tracer. I plan to change it so that the task struct bit can be checked in mcount, but as that requires changes to all archs, I will hold that off to the next merge window. Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Link: http://lkml.kernel.org/r/1306348063.1465.116.camel@gandalf.stny.rr.com Reported-by: Witold Baryluk <baryluk@smp.if.uj.edu.pl> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-03-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (47 commits) doc: CONFIG_UNEVICTABLE_LRU doesn't exist anymore Update cpuset info & webiste for cgroups dcdbas: force SMI to happen when expected arch/arm/Kconfig: remove one to many l's in the word. asm-generic/user.h: Fix spelling in comment drm: fix printk typo 'sracth' Remove one to many n's in a word Documentation/filesystems/romfs.txt: fixing link to genromfs drivers:scsi Change printk typo initate -> initiate serial, pch uart: Remove duplicate inclusion of linux/pci.h header fs/eventpoll.c: fix spelling mm: Fix out-of-date comments which refers non-existent functions drm: Fix printk typo 'failled' coh901318.c: Change initate to initiate. mbox-db5500.c Change initate to initiate. edac: correct i82975x error-info reported edac: correct i82975x mci initialisation edac: correct commented info fs: update comments to point correct document target: remove duplicate include of target/target_core_device.h from drivers/target/target_core_hba.c ... Trivial conflict in fs/eventpoll.c (spelling vs addition)
2011-03-10tracing: Explain about unstable clock on resume with ring buffer warningJiri Olsa
The "Delta way too big" warning might appear on a system with a unstable shed clock right after the system is resumed and tracing was enabled at time of suspend. Since it's not realy a bug, and the unstable sched clock is working fast and reliable otherwise, Steven suggested to keep using the sched clock in any case and just to make note in the warning itself. v2 changes: - added #ifdef CONFIG_HAVE_UNSTABLE_SCHED_CLOCK Signed-off-by: Jiri Olsa <jolsa@redhat.com> LKML-Reference: <20110218145219.GD2604@jolsa.brq.redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-03-09ring-buffer: Remove unused #include <linux/trace_irq.h>David Sharp
Signed-off-by: David Sharp <dhsharp@google.com> LKML-Reference: <1291421609-14665-3-git-send-email-dhsharp@google.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-03-09tracing: Add an 'overwrite' trace_option.David Sharp
Add an "overwrite" trace_option for ftrace to control whether the buffer should be overwritten on overflow or not. The default remains to overwrite old events when the buffer is full. This patch adds the option to instead discard newest events when the buffer is full. This is useful to get a snapshot of traces just after enabling traces. Dropping the current event is also a simpler code path. Signed-off-by: David Sharp <dhsharp@google.com> LKML-Reference: <1291844807-15481-1-git-send-email-dhsharp@google.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-02-18Revert "tracing: Add unstable sched clock note to the warning"Ingo Molnar
This reverts commit 5e38ca8f3ea423442eaafe1b7e206084aa38120a. Breaks the build of several !CONFIG_HAVE_UNSTABLE_SCHED_CLOCK architectures. Cc: Jiri Olsa <jolsa@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Message-ID: <20110217171823.GB17058@elte.hu> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-02-08tracing: Add unstable sched clock note to the warningJiri Olsa
The warning "Delta way too big" warning might appear on a system with unstable shed clock right after the system is resumed and tracing was enabled during the suspend. Since it's not realy bug, and the unstable sched clock is working fast and reliable otherwise, Steven suggested to keep using the sched clock in any case and just to make note in the warning itself. Signed-off-by: Jiri Olsa <jolsa@redhat.com> LKML-Reference: <1296649698-6003-1-git-send-email-jolsa@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-01-19Kill off warning: ‘inline’ is not at beginning of declarationJesper Juhl
Fix a bunch of warning: ‘inline’ is not at beginning of declaration messages when building a 'make allyesconfig' kernel with -Wextra. These warnings are trivial to kill, yet rather annoying when building with -Wextra. The more we can cut down on pointless crap like this the better (IMHO). A previous patch to do this for a 'allnoconfig' build has already been merged. This just takes the cleanup a little further. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-12-23ring_buffer: Off-by-one and duplicate events in ring_buffer_read_pageDavid Sharp
Fix two related problems in the event-copying loop of ring_buffer_read_page. The loop condition for copying events is off-by-one. "len" is the remaining space in the caller-supplied page. "size" is the size of the next event (or two events). If len == size, then there is just enough space for the next event. size was set to rb_event_ts_length, which may include the size of two events if the first event is a time-extend, in order to assure time- extends are kept together with the event after it. However, rb_advance_reader always advances by one event. This would result in the event after any time-extend being duplicated. Instead, get the size of a single event for the memcpy, but use rb_event_ts_length for the loop condition. Signed-off-by: David Sharp <dhsharp@google.com> LKML-Reference: <1293064704-8101-1-git-send-email-dhsharp@google.com> LKML-Reference: <AANLkTin7nLrRPc9qGjdjHbeVDDWiJjAiYyb-L=gH85bx@mail.gmail.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-10-27Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (50 commits) perf python scripting: Add futex-contention script perf python scripting: Fixup cut'n'paste error in sctop script perf scripting: Shut up 'perf record' final status perf record: Remove newline character from perror() argument perf python scripting: Support fedora 11 (audit 1.7.17) perf python scripting: Improve the syscalls-by-pid script perf python scripting: print the syscall name on sctop perf python scripting: Improve the syscalls-counts script perf python scripting: Improve the failed-syscalls-by-pid script kprobes: Remove redundant text_mutex lock in optimize x86/oprofile: Fix uninitialized variable use in debug printk tracing: Fix 'faild' -> 'failed' typo perf probe: Fix format specified for Dwarf_Off parameter perf trace: Fix detection of script extension perf trace: Use $PERF_EXEC_PATH in canned report scripts perf tools: Document event modifiers perf tools: Remove direct slang.h include perf_events: Fix for transaction recovery in group_sched_in() perf_events: Revert: Fix transaction recovery in group_sched_in() perf, x86: Use NUMA aware allocations for PEBS/BTS/DS allocations ...
2010-10-26Merge branch 'tip/perf/ringbuffer-2' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into perf/urgent
2010-10-22Merge branch 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: vfs: make no_llseek the default vfs: don't use BKL in default_llseek llseek: automatically add .llseek fop libfs: use generic_file_llseek for simple_attr mac80211: disallow seeks in minstrel debug code lirc: make chardev nonseekable viotape: use noop_llseek raw: use explicit llseek file operations ibmasmfs: use generic_file_llseek spufs: use llseek in all file operations arm/omap: use generic_file_llseek in iommu_debug lkdtm: use generic_file_llseek in debugfs net/wireless: use generic_file_llseek in debugfs drm: use noop_llseek
2010-10-21Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (163 commits) tracing: Fix compile issue for trace_sched_wakeup.c [S390] hardirq: remove pointless header file includes [IA64] Move local_softirq_pending() definition perf, powerpc: Fix power_pmu_event_init to not use event->ctx ftrace: Remove recursion between recordmcount and scripts/mod/empty jump_label: Add COND_STMT(), reducer wrappery perf: Optimize sw events perf: Use jump_labels to optimize the scheduler hooks jump_label: Add atomic_t interface jump_label: Use more consistent naming perf, hw_breakpoint: Fix crash in hw_breakpoint creation perf: Find task before event alloc perf: Fix task refcount bugs perf: Fix group moving irq_work: Add generic hardirq context callbacks perf_events: Fix transaction recovery in group_sched_in() perf_events: Fix bogus AMD64 generic TLB events perf_events: Fix bogus context time tracking tracing: Remove parent recording in latency tracer graph options tracing: Use one prologue for the preempt irqs off tracer function tracers ...
2010-10-20ring-buffer: Remove unused macro RB_TIMESTAMPS_PER_PAGESteven Rostedt
With the binding of time extends to events we no longer need to use the macro RB_TIMESTAMPS_PER_PAGE. Remove it. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-10-20ring-buffer: Micro-optimize with some strategic inliningSteven Rostedt
By using inline and noinline, we are able to make the fast path of recording an event 4% faster. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-10-20ring-buffer: Remove condition to add timestamp in fast pathSteven Rostedt
There's a condition to check if we should add a time extend or not in the fast path. But this condition is racey (in the sense that we can add a unnecessary time extend, but nothing that can break anything). We later check if the time or event time delta should be zero or have real data in it (not racey), making this first check redundant. This check may help save space once in a while, but really is not worth the hassle to try to save some space that happens at most 134 ms at a time. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-10-20ring-buffer: Bind time extend and data events togetherSteven Rostedt
When the time between two timestamps is greater than 2^27 nanosecs (~134 ms) a time extend event is added that extends the time difference to 59 bits (~18 years). This is due to events only having a 27 bit field to store time. Currently this time extend is a separate event. We add it just before the event data that is being written to the buffer. But before the event data is committed, the event data can also be discarded (as with the case of filters). But because the time extend has already been committed, it will stay in the buffer. If lots of events are being filtered and no event is being written, then every 134ms a time extend can be added to the buffer without any data attached. To keep from filling the entire buffer with time extends, a time extend will never be the first event in a page because the page timestamp can be used. Time extends can only fill the rest of a page with some data at the beginning. This patch binds the time extend with the data. The difference here is that the time extend is not committed before the data is added. Instead, when a time extend is needed, the space reserved on the ring buffer is the time extend + the data event size. The time extend is added to the first part of the reserved block and the data is added to the second. The time extend event is passed back to the reserver, but since the reserver also uses a function to find the data portion of the reserved block, no changes to the ring buffer interface need to be made. When a commit is discarded, we now remove both the time extend and the event. With this approach no more than one time extend can be in the buffer in a row. Data must always follow a time extend. Thanks to Mathieu Desnoyers for suggesting this idea. Suggested-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-10-20ring-buffer: Pass delta by value and not by referenceSteven Rostedt
The delta between events is passed to the timestamp code by reference and the timestamp code will reset the value. But it can be reset from the caller. No need to pass it in by reference. By changing the call to pass by value, lets gcc optimize the code a bit more where it can store the delta in a register and not worry about updating the reference. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-10-20ring-buffer: Pass timestamp by value and not by referenceSteven Rostedt
The original code for the ring buffer had locations that modified the timestamp and that change was used by the callers. Now, the timestamp is not reused by the callers and there is no reason to pass it by reference. By changing the call to pass by value, lets gcc optimize the code a bit more where it can store the timestamp in a register and not worry about updating the reference. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-10-19ring-buffer: Make write slow path out of lineSteven Rostedt
Gcc inlines the slow path of the ring buffer write which can hurt performance. This patch simply forces the slow path function rb_move_tail() to always be a function. The ring_buffer_benchmark module with reader_disabled=1 shows that this patch changes the time to record an event from 135 ns to 132 ns. (3 ns or 2.22% improvement) Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-10-12ring-buffer: Fix typo of time extends per pageSteven Rostedt
Time stamps for the ring buffer are created by the difference between two events. Each page of the ring buffer holds a full 64 bit timestamp. Each event has a 27 bit delta stamp from the last event. The unit of time is nanoseconds, so 27 bits can hold ~134 milliseconds. If two events happen more than 134 milliseconds apart, a time extend is inserted to add more bits for the delta. The time extend has 59 bits, which is good for ~18 years. Currently the time extend is committed separately from the event. If an event is discarded before it is committed, due to filtering, the time extend still exists. If all events are being filtered, then after ~134 milliseconds a new time extend will be added to the buffer. This can only happen till the end of the page. Since each page holds a full timestamp, there is no reason to add a time extend to the beginning of a page. Time extends can only fill a page that has actual data at the beginning, so there is no fear that time extends will fill more than a page without any data. When reading an event, a loop is made to skip over time extends since they are only used to maintain the time stamp and are never given to the caller. As a paranoid check to prevent the loop running forever, with the knowledge that time extends may only fill a page, a check is made that tests the iteration of the loop, and if the iteration is more than the number of time extends that can fit in a page a warning is printed and the ring buffer is disabled (all of ftrace is also disabled with it). There is another event type that is called a TIMESTAMP which can hold 64 bits of data in the theoretical case that two events happen 18 years apart. This code has not been implemented, but the name of this event exists, as well as the structure for it. The size of a TIMESTAMP is 16 bytes, where as a time extend is only 8 bytes. The macro used to calculate how many time extends can fit on a page used the TIMESTAMP size instead of the time extend size cutting the amount in half. The following test case can easily trigger the warning since we only need to have half the page filled with time extends to trigger the warning: # cd /sys/kernel/debug/tracing/ # echo function > current_tracer # echo 'common_pid < 0' > events/ftrace/function/filter # echo > trace # echo 1 > trace_marker # sleep 120 # cat trace Enabling the function tracer and then setting the filter to only trace functions where the process id is negative (no events), then clearing the trace buffer to ensure that we have nothing in the buffer, then write to trace_marker to add an event to the beginning of a page, sleep for 2 minutes (only 35 seconds is probably needed, but this guarantees the bug), and then finally reading the trace which will trigger the bug. This patch fixes the typo and prevents the false positive of that warning. Reported-by: Hans J. Koch <hjk@linutronix.de> Tested-by: Hans J. Koch <hjk@linutronix.de> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Stable Kernel <stable@kernel.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-09-15Merge branch 'tip/perf/core' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into perf/core
2010-09-05gcc-4.6: kernel/*: Fix unused but set warningsAndi Kleen
No real bugs I believe, just some dead code. Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: andi@firstfloor.org Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-09-01ring-buffer: Place duplicate expression into a single functionSteven Rostedt
While discussing the strictness of the 80 character limit on the Kernel Summit Discussion mailing list, I showed examples that I broke that limit slightly with some algorithms. In discussing with John Linville, what looked better, I realized that two of the 80 char breaking culprits were an identical expression. As a clean up, this patch moves the identical expression into its own helper function and that is used instead. As a side effect, the offending code is now under the 80 character limit. :-) This clean up code also changes the expression from (A - B) - C to A - (B + C) This makes the code look a little nicer too. Cc: John W. Linville <linville@tuxdriver.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-08-16Merge branch 'tip/perf/urgent-3' of ↵Steven Rostedt
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into trace/tip/perf/urgent-4 Conflicts: kernel/trace/trace_events.c Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-08-06tracing: Fix ring_buffer_read_page reading out of page boundaryHuang Ying
With the configuration: CONFIG_DEBUG_PAGEALLOC=y and Shaohua's patch: [PATCH]x86: make spurious_fault check correct pte bit Function call graph trace with the following will trigger a page fault. # cd /sys/kernel/debug/tracing/ # echo function_graph > current_tracer # cat per_cpu/cpu1/trace_pipe_raw > /dev/null BUG: unable to handle kernel paging request at ffff880006e99000 IP: [<ffffffff81085572>] rb_event_length+0x1/0x3f PGD 1b19063 PUD 1b1d063 PMD 3f067 PTE 6e99160 Oops: 0000 [#1] SMP DEBUG_PAGEALLOC last sysfs file: /sys/devices/virtual/net/lo/operstate CPU 1 Modules linked in: Pid: 1982, comm: cat Not tainted 2.6.35-rc6-aes+ #300 /Bochs RIP: 0010:[<ffffffff81085572>] [<ffffffff81085572>] rb_event_length+0x1/0x3f RSP: 0018:ffff880006475e38 EFLAGS: 00010006 RAX: 0000000000000ff0 RBX: ffff88000786c630 RCX: 000000000000001d RDX: ffff880006e98000 RSI: 0000000000000ff0 RDI: ffff880006e99000 RBP: ffff880006475eb8 R08: 000000145d7008bd R09: 0000000000000000 R10: 0000000000008000 R11: ffffffff815d9336 R12: ffff880006d08000 R13: ffff880006e605d8 R14: 0000000000000000 R15: 0000000000000018 FS: 00007f2b83e456f0(0000) GS:ffff880002100000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: ffff880006e99000 CR3: 00000000064a8000 CR4: 00000000000006e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process cat (pid: 1982, threadinfo ffff880006474000, task ffff880006e40770) Stack: ffff880006475eb8 ffffffff8108730f 0000000000000ff0 000000145d7008bd <0> ffff880006e98010 ffff880006d08010 0000000000000296 ffff88000786c640 <0> ffffffff81002956 0000000000000000 ffff8800071f4680 ffff8800071f4680 Call Trace: [<ffffffff8108730f>] ? ring_buffer_read_page+0x15a/0x24a [<ffffffff81002956>] ? return_to_handler+0x15/0x2f [<ffffffff8108a575>] tracing_buffers_read+0xb9/0x164 [<ffffffff810debfe>] vfs_read+0xaf/0x150 [<ffffffff81002941>] return_to_handler+0x0/0x2f [<ffffffff810248b0>] __bad_area_nosemaphore+0x17e/0x1a1 [<ffffffff81002941>] return_to_handler+0x0/0x2f [<ffffffff810248e6>] bad_area_nosemaphore+0x13/0x15 Code: 80 25 b2 16 b3 00 fe c9 c3 55 48 89 e5 f0 80 0d a4 16 b3 00 02 c9 c3 55 31 c0 48 89 e5 48 83 3d 94 16 b3 00 01 c9 0f 94 c0 c3 55 <8a> 0f 48 89 e5 83 e1 1f b8 08 00 00 00 0f b6 d1 83 fa 1e 74 27 RIP [<ffffffff81085572>] rb_event_length+0x1/0x3f RSP <ffff880006475e38> CR2: ffff880006e99000 ---[ end trace a6877bb92ccb36bb ]--- The root cause is that ring_buffer_read_page() may read out of page boundary, because the boundary checking is done after reading. This is fixed via doing boundary checking before reading. Reported-by: Shaohua Li <shaohua.li@intel.com> Cc: <stable@kernel.org> Signed-off-by: Huang Ying <ying.huang@intel.com> LKML-Reference: <1280297641.2771.307.camel@yhuang-dev> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-07-20trace: Reorder struct ring_buffer_per_cpu to remove padding on 64bitRichard Kennedy
Reorder structure to remove 8 bytes of padding on 64 bit builds. This shrinks the size to 128 bytes so allowing allocation from a smaller slab & needed one fewer cache lines. Signed-off-by: Richard Kennedy <richard@rsk.demon.co.uk> LKML-Reference: <1269516456.2054.8.camel@localhost> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-06-08Merge branch 'tip/perf/core-3' of ↵Ingo Molnar
2010-06-03tracing: Remove ftrace_preempt_disable/enableSteven Rostedt
The ftrace_preempt_disable/enable functions were to address a recursive race caused by the function tracer. The function tracer traces all functions which makes it easily susceptible to recursion. One area was preempt_enable(). This would call the scheduler and the schedulre would call the function tracer and loop. (So was it thought). The ftrace_preempt_disable/enable was made to protect against recursion inside the scheduler by storing the NEED_RESCHED flag. If it was set before the ftrace_preempt_disable() it would not call schedule on ftrace_preempt_enable(), thinking that if it was set before then it would have already scheduled unless it was already in the scheduler. This worked fine except in the case of SMP, where another task would set the NEED_RESCHED flag for a task on another CPU, and then kick off an IPI to trigger it. This could cause the NEED_RESCHED to be saved at ftrace_preempt_disable() but the IPI to arrive in the the preempt disabled section. The ftrace_preempt_enable() would not call the scheduler because the flag was already set before entring the section. This bug would cause a missed preemption check and cause lower latencies. Investigating further, I found that the recusion caused by the function tracer was not due to schedule(), but due to preempt_schedule(). Now that preempt_schedule is completely annotated with notrace, the recusion no longer is an issue. Reported-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-05-25ring-buffer: Move zeroing out excess in page to ring buffer codeSteven Rostedt
Currently the trace splice code zeros out the excess bytes in the page before sending it off to userspace. This is to make sure userspace is not getting anything it should not be when reading the pages, because the excess data was never initialized to zero before writing (for perfomance reasons). But the splice code has no business in doing this work, it should be done by the ring buffer. With the latest changes for recording lost events, the splice code gets it wrong anyway. Move the zeroing out of excess bytes into the ring buffer code. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-05-25ring-buffer: Reset "real_end" when page is filledSteven Rostedt
The code to store the "lost events" requires knowing the real end of the page. Since the 'commit' includes the padding at the end of a page a "real_end" variable was used to keep track of the end not including the padding. If events were lost, the reader can place the count of events in the padded area if there is enough room. The bug this patch fixes is that when we fill the page we do not reset the real_end variable, and if the writer had wrapped a few times, the real_end would be incorrect. This patch simply resets the real_end if the page was filled. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-05-04ring-buffer: Wrap open-coded WARN_ONCEBorislav Petkov
Wrap open-coded WARN_ONCE functionality into the equivalent macro. Signed-off-by: Borislav Petkov <bp@alien8.de> LKML-Reference: <20100502060354.GA5281@liondog.tnic> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-04-27ring-buffer: Make non-consuming read less expensive with lots of cpus.David Miller
When performing a non-consuming read, a synchronize_sched() is performed once for every cpu which is actively tracing. This is very expensive, and can make it take several seconds to open up the 'trace' file with lots of cpus. Only one synchronize_sched() call is actually necessary. What is desired is for all cpus to see the disabling state change. So we transform the existing sequence: for_each_cpu() { ring_buffer_read_start(); } where each ring_buffer_start() call performs a synchronize_sched(), into the following: for_each_cpu() { ring_buffer_read_prepare(); } ring_buffer_read_prepare_sync(); for_each_cpu() { ring_buffer_read_start(); } wherein only the single ring_buffer_read_prepare_sync() call needs to do the synchronize_sched(). The first phase, via ring_buffer_read_prepare(), allocates the 'iter' memory and increments ->record_disabled. In the second phase, ring_buffer_read_prepare_sync() makes sure this ->record_disabled state is visible fully to all cpus. And in the final third phase, the ring_buffer_read_start() calls reset the 'iter' objects allocated in the first phase since we now know that none of the cpus are adding trace entries any more. This makes openning the 'trace' file nearly instantaneous on a sparc64 Niagara2 box with 128 cpus tracing. Signed-off-by: David S. Miller <davem@davemloft.net> LKML-Reference: <20100420.154711.11246950.davem@davemloft.net> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-04-08Merge branch 'linus' into tracing/coreIngo Molnar
Conflicts: include/linux/module.h kernel/module.c Semantic conflict: include/trace/events/module.h Merge reason: Resolve the conflict with upstream commit 5fbfb18 ("Fix up possibly racy module refcounting") Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-05Merge branch 'master' into export-slabhTejun Heo
2010-03-31ring-buffer: Add lost event count to end of sub bufferSteven Rostedt
Currently, binary readers of the ring buffer only know where events were lost, but not how many events were lost at that location. This information is available, but it would require adding another field to the sub buffer header to include it. But when a event can not fit at the end of a sub buffer, it is written to the next sub buffer. This means there is a good chance that the buffer may have room to hold this counter. If it does, write the counter at the end of the sub buffer and set another flag in the data size field that states that this information exists. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-03-31ring-buffer: Add place holder recording of dropped eventsSteven Rostedt
Currently, when the ring buffer drops events, it does not record the fact that it did so. It does inform the writer that the event was dropped by returning a NULL event, but it does not put in any place holder where the event was dropped. This is not a trivial thing to add because the ring buffer mostly runs in overwrite (flight recorder) mode. That is, when the ring buffer is full, new data will overwrite old data. In a produce/consumer mode, where new data is simply dropped when the ring buffer is full, it is trivial to add the placeholder for dropped events. When there's more room to write new data, then a special event can be added to notify the reader about the dropped events. But in overwrite mode, any new write can overwrite events. A place holder can not be inserted into the ring buffer since there never may be room. A reader could also come in at anytime and miss the placeholder. Luckily, the way the ring buffer works, the read side can find out if events were lost or not, and how many events. Everytime a write takes place, if it overwrites the header page (the next read) it updates a "overrun" variable that keeps track of the number of lost events. When a reader swaps out a page from the ring buffer, it can record this number, perfom the swap, and then check to see if the number changed, and take the diff if it has, which would be the number of events dropped. This can be stored by the reader and returned to callers of the reader. Since the reader page swap will fail if the writer moved the head page since the time the reader page set up the swap, this gives room to record the overruns without worrying about races. If the reader sets up the pages, records the overrun, than performs the swap, if the swap succeeds, then the overrun variable has not been updated since the setup before the swap. For binary readers of the ring buffer, a flag is set in the header of each sub page (sub buffer) of the ring buffer. This flag is embedded in the size field of the data on the sub buffer, in the 31st bit (the size can be 32 or 64 bits depending on the architecture), but only 27 bits needs to be used for the actual size (less actually). We could add a new field in the sub buffer header to also record the number of events dropped since the last read, but this will change the format of the binary ring buffer a bit too much. Perhaps this change can be made if the information on the number of events dropped is considered important enough. Note, the notification of dropped events is only used by consuming reads or peeking at the ring buffer. Iterating over the ring buffer does not keep this information because the necessary data is only available when a page swap is made, and the iterator does not swap out pages. Cc: Robert Richter <robert.richter@amd.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: "Luis Claudio R. Goncalves" <lclaudio@uudg.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-29ring-buffer: Add missing unlockJulia Lawall
In some error handling cases the lock is not unlocked. The return is converted to a goto, to share the unlock at the end of the function. A simplified version of the semantic patch that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r exists@ expression E1; identifier f; @@ f (...) { <+... * spin_lock_irq (E1,...); ... when != E1 * return ...; ...+> } // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> LKML-Reference: <Pine.LNX.4.64.1003291736440.21896@ask.diku.dk> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-03-18ring-buffer: Do 8 byte alignment for 64 bit that can not handle 4 byte alignSteven Rostedt
The ring buffer uses 4 byte alignment while recording events into the buffer, even on 64bit machines. This saves space when there are lots of events being recorded at 4 byte boundaries. The ring buffer has a zero copy method to write into the buffer, with the reserving of space and then committing it. This may cause problems when writing an 8 byte word into a 4 byte alignment (not 8). For x86 and PPC this is not an issue, but on some architectures this would cause an out-of-alignment exception. This patch uses CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS to determine if it is OK to use 4 byte alignments on 64 bit machines. If it is not, it forces the ring buffer event header to be 8 bytes and not 4, and will align the length of the data to be 8 byte aligned. This keeps the data payload at 8 byte alignments and will allow these machines to run without issue. The trick to this is that the header can be either 4 bytes or 8 bytes depending on the length of the data payload. The 4 byte header has a length field that supports up to 112 bytes. If the length of the data is more than 112, the length field is set to zero, and the actual length is stored in the next 4 bytes after the header. When CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS is not set, the code forces zero in the 4 byte header forcing the length to be stored in the 4 byte array, even with a small data load. It also forces the length of the data load to be 8 byte aligned. The combination of these two guarantee that the data is always at 8 byte alignment. Tested-by: Frederic Weisbecker <fweisbec@gmail.com> (on sparc64) Reported-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-03-13Merge branch 'tracing-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: tracing: Do not record user stack trace from NMI context tracing: Disable buffer switching when starting or stopping trace tracing: Use same local variable when resetting the ring buffer function-graph: Init curr_ret_stack with ret_stack ring-buffer: Move disabled check into preempt disable section function-graph: Add tracing_thresh support to function_graph tracer tracing: Update the comm field in the right variable in update_max_tr function-graph: Use comment notation for func names of dangling '}' function-graph: Fix unused reference to ftrace_set_func() tracing: Fix warning in s_next of trace file ops tracing: Include irqflags headers from trace clock
2010-03-12ring-buffer: Move disabled check into preempt disable sectionLai Jiangshan
The ring buffer resizing and resetting relies on a schedule RCU action. The buffers are disabled, a synchronize_sched() is called and then the resize or reset takes place. But this only works if the disabling of the buffers are within the preempt disabled section, otherwise a window exists that the buffers can be written to while a reset or resize takes place. Cc: stable@kernel.org Reported-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> LKML-Reference: <4B949E43.2010906@cn.fujitsu.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-02-04Fix misspellings of "truly" in comments.Adam Buchbinder
Some comments misspell "truly"; this fixes them. No code changes. Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-02-02Merge branch 'master' into percpuTejun Heo
