"echo noglobal-clock > trace_options" can be used to change trace
clock but "echo 0 > options/global-clock" can't. The flag toggling
will be silently accepted without actually changing the clock callback.
We can fix it by using set_tracer_flags() in
trace_options_core_write().
Changelog:
v1->v2: Simplified switch() after Li Zefan <lizf@cn.fujitsu.com>'s
suggestion
Signed-off-by: Zhao Lei <zhaolei@cn.fujitsu.com>
Cc: Steven Rostedt <srostedt@redhat.com>
Cc: Li Zefan <lizf@cn.fujitsu.com>
This patch implements the kernel side support for ftrace event
record sampling.
A new counter sampling attribute is added:
PERF_SAMPLE_TP_RECORD
which requests ftrace events record sampling. In this case
if a PERF_TYPE_TRACEPOINT counter is active and a tracepoint
fires, we emit the tracepoint binary record to the
perfcounter event buffer, as a sample.
Result, after setting PERF_SAMPLE_TP_RECORD attribute from perf
record:
perf record -f -F 1 -a -e workqueue:workqueue_execution
perf report -D
0x21e18 [0x48]: event: 9
. ... raw event: size 72 bytes
. 0000: 09 00 00 00 01 00 48 00 d0 c7 00 81 ff ff ff ff ......H........
. 0010: 0a 00 00 00 0a 00 00 00 21 00 00 00 00 00 00 00 ........!......
. 0020: 2b 00 01 02 0a 00 00 00 0a 00 00 00 65 76 65 6e +...........eve
. 0030: 74 73 2f 31 00 00 00 00 00 00 00 00 0a 00 00 00 ts/1...........
. 0040: e0 b1 31 81 ff ff ff ff .......
0x21e18 [0x48]: PERF_EVENT_SAMPLE (IP, 1): 10: 0xffffffff8100c7d0 period: 33
The raw ftrace binary record starts at offset 0020.
Translation:
struct trace_entry {
type = 0x2b = 43;
flags = 1;
preempt_count = 2;
pid = 0xa = 10;
tgid = 0xa = 10;
thread_comm = "events/1"
thread_pid = 0xa = 10;
func = 0xffffffff8131b1e0 = flush_to_ldisc()
What will come next?
- Userspace support ('perf trace'), 'flight data recorder' mode
for perf trace, etc.
- The unconditional copy from the profiling callback brings
some costs however if someone wants no such sampling to
occur, and needs to be fixed in the future. For that we need
to have an instant access to the perf counter attribute.
This is a matter of a flag to add in the struct ftrace_event.
- Take care of the events recursivity! Don't ever try to record
a lock event for example, it seems some locking is used in
the profiling fast path and lead to a tracing recursivity.
That will be fixed using raw spinlock or recursivity
protection.
- Profit! :-)
Cc: Tom Zanussi <tzanussi@gmail.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
Cc: Gabriel Munteanu <eduard.munteanu@linux360.ro>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing into tracing/urgent
About a half events are missing when we splice_read
from trace_pipe. They are unexpectedly consumed because we ignore
the TRACE_TYPE_NO_CONSUME return value used by the function graph
tracer when it needs to consume the events by itself to walk on
the ring buffer.
The same problem appears with ftrace_dump()
Example of an output before this patch:
1) | ktime_get_real() {
1) 2.846 us | read_hpet();
1) 4.558 us | }
1) 6.195 us | }
After this patch:
0) | ktime_get_real() {
0) | getnstimeofday() {
0) 1.960 us | read_hpet();
0) 3.597 us | }
0) 5.196 us | }
The fix also applies on 2.6.30
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Cc: stable@kernel.org
LKML-Reference: <4A6EEC52.90704@cn.fujitsu.com>
The current code will truncate the ftrace files contents if O_APPEND
is not set and the file is opened in write mode. This is incorrect.
It should only truncate the file if O_TRUNC is set. Otherwise
if one of these files is opened by a C program with fopen "r+",
it will incorrectly truncate the file.
Reported-by: Jiri Olsa <jolsa@redhat.com>
* Remove smp_lock.h from files which don't need it (including some headers!)
* Add smp_lock.h to files which do need it
* Make smp_lock.h include conditional in hardirq.h
It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT
This will make hardirq.h inclusion cheaper for every PREEMPT=n config
(which includes allmodconfig/allyesconfig, BTW)
We should be able to specify [KMG] when setting trace_buf_size
boot option, as documented in kernel-parameters.txt
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
LKML-Reference: <4A41F2DB.4020102@cn.fujitsu.com>
The iterator is m->private, but it's not reset to trace_types in
t_start(). If the output is larger than PAGE_SIZE and t_start()
is called the 2nd time, things will go wrong.
Reviewed-by: Liming Wang <liming.wang@windriver.com>
LKML-Reference: <4A418728.5020506@cn.fujitsu.com>
* 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (24 commits)
tracing/urgent: warn in case of ftrace_start_up inbalance
tracing/urgent: fix unbalanced ftrace_start_up
function-graph: add stack frame test
function-graph: disable when both x86_32 and optimize for size are configured
ring-buffer: have benchmark test print to trace buffer
ring-buffer: do not grab locks in nmi
ring-buffer: add locks around rb_per_cpu_empty
ring-buffer: check for less than two in size allocation
ring-buffer: remove useless compile check for buffer_page size
ring-buffer: remove useless warn on check
ring-buffer: use BUF_PAGE_HDR_SIZE in calculating index
tracing: update sample event documentation
tracing/filters: fix race between filter setting and module unload
tracing/filters: free filter_string in destroy_preds()
ring-buffer: use commit counters for commit pointer accounting
ring-buffer: remove unused variable
ring-buffer: have benchmark test handle discarded events
ring-buffer: prevent adding write in discarded area
tracing/filters: strloc should be unsigned short
tracing/filters: operand can be negative
Fix up kmemcheck-induced conflict in kernel/trace/ring_buffer.c manually
Many developers use "/debug/" or "/debugfs/" or "/sys/kernel/debug/"
directory name to mount debugfs filesystem for ftrace according to
./Documentation/tracers/ftrace.txt file.
And, three directory names(ex:/debug/, /debugfs/, /sys/kernel/debug/) is
existed in kernel source like ftrace, DRM, Wireless, Documentation,
Network[sky2]files to mount debugfs filesystem.
debugfs means debug filesystem for debugging easy to use by greg kroah
hartman. "/sys/kernel/debug/" name is suitable as directory name
of debugfs filesystem.
- debugfs related reference: http://lwn.net/Articles/334546/
Fix inconsistency of directory name to mount debugfs filesystem.
* From Steven Rostedt
- find_debugfs() and tracing_files() in this patch.
Signed-off-by: GeunSik Lim <geunsik.lim@samsung.com>
Acked-by : Inaky Perez-Gonzalez <inaky@linux.intel.com>
Reviewed-by : Steven Rostedt <rostedt@goodmis.org>
Reviewed-by : James Smart <james.smart@emulex.com>
CC: Jiri Kosina <trivial@kernel.org>
CC: David Airlie <airlied@linux.ie>
CC: Peter Osterlund <petero2@telia.com>
CC: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
CC: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com>
CC: Masami Hiramatsu <mhiramat@redhat.com>
Atomic allocation is not needed here.
[ Impact: clean up of memory alloction type ]
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
LKML-Reference: <4A35B898.2050607@cn.fujitsu.com>
It's tracing_cpumask_new that should be kfree()ed.
This causes tracing_cpumask to be freed due to the typo:
# echo z > tracing_cpumask
bash: echo: write error: Invalid argument
And subsequent reads/writes to tracing_cpuamsk will access this
already-freed tracing_cpumask, thus may lead to crash.
[ Impact: fix leak and crash when writing invalid val to tracing_cpumask ]
LKML-Reference: <4A35B86A.7070608@cn.fujitsu.com>
* 'tracing-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (244 commits)
Revert "x86, bts: reenable ptrace branch trace support"
tracing: do not translate event helper macros in print format
ftrace/documentation: fix typo in function grapher name
tracing/events: convert block trace points to TRACE_EVENT(), fix !CONFIG_BLOCK
tracing: add protection around module events unload
tracing: add trace_seq_vprint interface
tracing: fix the block trace points print size
ring-buffer: fix ret in rb_add_time_stamp
ring-buffer: pass in lockdep class key for reader_lock
tracing: add annotation to what type of stack trace is recorded
tracing: fix multiple use of __print_flags and __print_symbolic
tracing/events: fix output format of user stack
tracing/events: fix output format of kernel stack
tracing/trace_stack: fix the number of entries in the header
ring-buffer: discard timestamps that are at the start of the buffer
ring-buffer: try to discard unneeded timestamps
ring-buffer: fix bug in ring_buffer_discard_commit
ftrace: do not profile functions when disabled
tracing: make trace pipe recognize latency format flag
The trace_pipe did not recognize the latency format flag and would produce
different output than the trace file. The problem was partly due that
the trace flags in the iterator was not set as well as the trace_pipe
zeros out part of the iterator (including the flags) to be able to use
the same routines as the trace file. trace_flags of the iterator should
not cause any problems when not zeroed out by for trace_pipe.
Reported-by: Johannes Berg <johannes@sipsolutions.net>
s390 code uses smp_processor_id() in __raw_spin_lock() code which
reveals that a (raw) spinlock is taken without preemption disabled.
This can potentially deadlock.
To fix this explicitly disable and enable preemption.
BUG: using smp_processor_id() in preemptible [00000000] code: cat/2278
caller is trace_find_cmdline+0x40/0xfc
CPU: 0 Not tainted 2.6.30-rc7-dirty #39
Process cat (pid: 2278, task: 000000003faedb68, ksp: 000000003b33b988)
000000003b33b988 000000003b33bae0 0000000000000002 0000000000000000
000000003b33bb80 000000003b33baf8 000000003b33baf8 00000000000175d6
0000000000000001 000000003b33b988 000000003f9b0000 000000000000000b
000000000000000c 000000003b33bb40 000000003b33bae0 0000000000000000
0000000000000000 00000000000175d6 000000003b33bae0 000000003b33bb28
Call Trace:
([<00000000000174b2>] show_trace+0x112/0x170)
[<0000000000017582>] show_stack+0x72/0x100
[<0000000000441538>] dump_stack+0xc8/0xd8
[<000000000025c350>] debug_smp_processor_id+0x114/0x130
[<00000000000bf0e4>] trace_find_cmdline+0x40/0xfc
[<00000000000c35d4>] trace_print_context+0x58/0xac
[<00000000000bb676>] print_trace_line+0x416/0x470
[<00000000000bc8fe>] s_show+0x4e/0x428
[<000000000013834e>] seq_read+0x36a/0x5d4
[<0000000000112a78>] vfs_read+0xc8/0x174
[<0000000000112c58>] SyS_read+0x74/0xc4
[<000000000002c7ae>] sysc_noemu+0x10/0x16
[<000002000012436c>] 0x2000012436c
1 lock held by cat/2278:
#0: (&p->lock){+.+.+.}, at: [<0000000000138056>] seq_read+0x72/0x5d4
[ Impact: fix preempt-unsafe raw spinlock ]
Acked-by: Steven Rostedt <rostedt@goodmis.org>
I found that there is nothing to protect event_hash in
ftrace_find_event(). Rcu protects the event hashlist
but not the event itself while we use it after its extraction
through ftrace_find_event().
This lack of a proper locking in this spot opens a race
window between any event dereferencing and module removal.
Eg:
--Task A--
print_trace_line(trace) {
event = find_ftrace_event(trace)
--Task B--
trace_module_remove_events(mod) {
list_trace_events_module(ev, mod) {
unregister_ftrace_event(ev->event) {
hlist_del(ev->event->node)
list_del(....)
|--> module removed, the event has been dropped
--Task A--
event->print(trace); // Dereferencing freed memory
If the event retrieved belongs to a module and this module
is concurrently removed, we may end up dereferencing a data
from a freed module.
RCU could solve this, but it would add latency to the kernel and
forbid tracers output callbacks to call any sleepable code.
So this fix converts 'trace_event_mutex' to a read/write semaphore,
and adds trace_event_read_lock() to protect ftrace_find_event().
[ Impact: fix possible freed memory dereference in ftrace ]
LKML-Reference: <4A114806.7090302@cn.fujitsu.com>
append prompt in /debug/tracing/README file.
This is trivial issue. Fix typo Mini Howto file(README) for ftrace.
[ Impact: cleanup ]
Cc: williams <williams@redhat.com>
LKML-Reference: <1242289418.31161.45.camel@centos51>
Li Zefan found that there's a race using the event ids of events and
modules. When a module is loaded, an event id is incremented. We only
have 16 bits for event ids (65536) and there is a possible (but highly
unlikely) race that we could load and unload a module that registers
events so many times that the event id counter overflows.
When it overflows, it then restarts and goes looking for available
ids. An id is available if it was added by a module and released.
The race is if you have one module add an id, and then is removed.
Another module loaded can use that same event id. But if the old module
still had events in the ring buffer, the new module's call back would
get bogus data. At best (and most likely) the output would just be
garbage. But if the module for some reason used pointers (not recommended)
then this could potentially crash.
The safest thing to do is just reset the ring buffer if a module that
registered events is removed.
[ Impact: prevent unpredictable results of event id overflows ]
Reported-by: Li Zefan <lizf@cn.fujitsu.com>
LKML-Reference: <49FEAFD0.30106@cn.fujitsu.com>
When adding the EXPORT_SYMBOL to some of the tracing API, I accidently
used EXPORT_SYMBOL instead of EXPORT_SYMBOL_GPL. This patch fixes
that mistake.
[ Impact: export the tracing code only for GPL modules ]
Reported-by: Christoph Hellwig <hch@lst.de>
This patch adds stats to the ftrace ring buffers:
# cat /debugfs/tracing/per_cpu/cpu0/stats
entries: 42360
overrun: 30509326
commit overrun: 0
nmi dropped: 0
Where entries are the total number of data entries in the buffer.
overrun is the number of entries not consumed and were overwritten by
the writer.
commit overrun is the number of entries dropped due to nested writers
wrapping the buffer before the initial writer finished the commit.
nmi dropped is the number of entries dropped due to the ring buffer
lock being held when an nmi was going to write to the ring buffer.
Note, this field will be meaningless and will go away when the ring
buffer becomes lockless.
[ Impact: let userspace know what is happening in the ring buffers ]
The pages allocated for the splice binary buffer did not initialize
the ref count correctly. This caused pages not to be freed and causes
a drastic memory leak.
Thanks to logdev I was able to trace the tracer to find where the leak
was.
[ Impact: stop memory leak when using splice ]
Splice works with pages, it is much more effecient to use an entire
page than to copy bits over several pages.
Using logdev to trace the internals of the splice mechanism, I was
able to see that splice can be very aggressive. When tracing is
occurring, and the reader caught up to the writer, and the writer
is on the reader page, the reader will copy what is there into the
splice page. Splice may iterate over several pages and if the
writer is still writing to the page, the reader will keep copying
bits to new pages to pass to userspace.
This patch changes it to only pass data to userspace if the page
is full (the writer has left the page). This has a small side effect
that splice can not read a partial page, and must wait for the
page to fill. This should not be an issue. If tracing has stopped,
then a use of "read" will still read all of the page.
[ Impact: better performance for ring buffer splice code ]
The splice code allocates a page even when the ring buffer is empty.
It detects the ring buffer being empty when it it fails to copy
anything from the ring buffer into the page.
This patch adds a check to see if there is anything in the ring buffer
before allocating a page.
Thanks to logdev for letting me trace the tracer to find this.
[ Impact: speed up due to removing unnecessary allocation ]
was.
ftrace_dump is used for printing out the contents of the ftrace ring buffer
to the console on failure. Currently it uses a spinlock to synchronize
the output from multiple failures on different CPUs. This spin lock
currently is a normal spinlock and can cause issues with lockdep and
lock tracing.
This patch converts it to raw since it is for error handling only.
The lock is local to the ftrace_dump and is not used by any other
infrastructure.
[ Impact: prevent ftrace_dump from locking up by internal tracing ]
struct trace_entry->type is unsigned char, while trace event's id is
int type, thus for a event with id >= 256, it's entry->type is cast
to (id % 256), and then we can't see the trace output of this event.
# insmod trace-events-sample.ko
# echo foo_bar > /mnt/tracing/set_event
# cat /debug/tracing/events/trace-events-sample/foo_bar/id
256
# cat /mnt/tracing/trace_pipe
<...>-3548 [001] 215.091142: Unknown type 0
<...>-3548 [001] 216.089207: Unknown type 0
<...>-3548 [001] 217.087271: Unknown type 0
<...>-3548 [001] 218.085332: Unknown type 0
[ Impact: fix output for trace events with id >= 256 ]
LKML-Reference: <49EEDB0E.5070207@cn.fujitsu.com>
trace_printk can be called from any context, including NMIs.
If this happens, then we must test for for recursion before
grabbing any spinlocks.
This patch prevents trace_printk from being called recursively.
[ Impact: prevent hard lockup in lockdep event tracer ]
Not all the necessary symbols were exported to allow for tracing
by modules. This patch adds them in.
[ Impact: allow modules to commit data to the ring buffer ]
trace is read-write and README is read-only.
[ Impact: fix /debug/tracing/ file permissions. ]
LKML-Reference: <49E7EAB6.4070605@cn.fujitsu.com>
Export the cached task comms to userspace. This allows user apps to translate
the pids from a trace into their respective task command lines.
[ Impact: let userspace apps reading binary buffer know comm's of pids ]
Signed-off-by: Avadh Patel <avadh4all@gmail.com>
[ added error checking and use of buf pointer to index file_buf ]
Impact: let modules add trace events
The trace event code requires some functions to be exported to allow
modules to use TRACE_EVENT. This patch adds EXPORT_SYMBOL_GPL to the
necessary functions.
This patch changes filter_check_discard() to make use of the new
ring_buffer_discard_commit() function and modifies the current users to
call the old commit function in the non-discard case.
It also introduces a version of filter_check_discard() that uses the
global trace buffer (filter_current_check_discard()) for those cases.
v2 changes:
- fix compile error noticed by Ingo Molnar
Signed-off-by: Tom Zanussi <tzanussi@gmail.com>
Cc: fweisbec@gmail.com
LKML-Reference: <1239178554.10295.36.camel@tropicana>
The ring_buffer_discard_commit makes better usage of the ring_buffer
when an event has been discarded. It tries to remove it completely if
possible.
This patch converts the trace event filtering to use
ring_buffer_discard_commit instead of the ring_buffer_event_discard.
Signed-off-by: Steven Rostedt <srostedt@redhat.com>
Frederic Weisbecker suggested that the trace_special event shouldn't be
filterable; this patch adds a TRACE_EVENT_FORMAT_NOFILTER event macro
that allows an event format to be exported without having a filter
attached, and removes filtering from the trace_special event.
This patch adds run-time field descriptions to all the event formats
exported using TRACE_EVENT_FORMAT. It also hooks up all the tracers
that use them (i.e. the tracers in the 'ftrace subsystem') so they can
also have their output filtered by the event-filtering mechanism.
When I was testing this, there were a couple of things that fooled me
into thinking the filters weren't working, when actually they were -
I'll mention them here so others don't make the same mistakes (and file
bug reports. ;-)
One is that some of the tracers trace multiple events e.g. the
sched_switch tracer uses the context_switch and wakeup events, and if
you don't set filters on all of the traced events, the unfiltered output
from the events without filters on them can make it look like the
filtering as a whole isn't working properly, when actually it is doing
what it was asked to do - it just wasn't asked to do the right thing.
The other is that for the really high-volume tracers e.g. the function
tracer, the volume of filtered events can be so high that it pushes the
unfiltered events out of the ring buffer before they can be read so e.g.
cat'ing the trace file repeatedly shows either no output, or once in
awhile some output but that isn't there the next time you read the
trace, which isn't what you normally expect when reading the trace file.
If you read from the trace_pipe file though, you can catch them before
they disappear.
Changes from v1:
As suggested by Frederic Weisbecker:
- get rid of externs in functions
- added unlikely() to filter_check_discard()
Merge reason: pick up both v2.6.30-rc1 [which includes tracing/urgent fixes]
and pick up the current lineup of tracing/urgent fixes as well
I got these from strace:
splice(0x3, 0, 0x5, 0, 0x1000, 0x1) = 12288
splice(0x3, 0, 0x5, 0, 0x1000, 0x1) = 16384
splice(0x3, 0, 0x5, 0, 0x1000, 0x1) = 8192
I wanted to splice_read 4096 bytes, but it returns 8192 or larger.
It is because the return value of tracing_buffers_splice_read()
does not include "zero out any left over data" bytes.
But tracing_buffers_read() includes these bytes, we make them
consistent.
LKML-Reference: <49D46674.9030804@cn.fujitsu.com>
Impact: Cleanup
These two lines:
if (unlikely(*ppos))
return -ESPIPE;
in tracing_buffers_splice_read() are not needed, VFS layer
has disabled seek(2).
We remove these two lines, and then we can update file->f_pos.
And tracing_buffers_read() updates file->f_pos, this fix
make tracing_buffers_splice_read() updates file->f_pos too.
LKML-Reference: <49D46670.4010503@cn.fujitsu.com>
Impact: Cleanup
Sometimes, we open trace_pipe_raw, but we don't read(2) it,
we just splice(2) it, thus, the page is not used.
LKML-Reference: <49D4666B.4010608@cn.fujitsu.com>
Impact: disable pread()
We set tracing_buffers_fops.llseek to no_llseek,
but we can still perform pread() to read this file.
That is not expected.
This fix uses nonseekable_open() to disable it.
tracing_buffers_fops.llseek is still set to no_llseek,
it mark this file is a "non-seekable device" and is used by
sys_splice(). See also do_splice() or manual of splice(2):
ERRORS
EINVAL Target file system doesn't support splicing;
neither of the descriptors refers to a pipe;
or offset given for non-seekable device.
LKML-Reference: <49D46668.8030806@cn.fujitsu.com>
Impact: cleanup
Most of the tracing files creation follow the same pattern:
ret = debugfs_create_file(...)
if (!ret)
pr_warning("Couldn't create ... entry\n")
Unify it!
Reported-by: Ingo Molnar <mingo@elte.hu>
LKML-Reference: <1238109938-11840-1-git-send-email-fweisbec@gmail.com>
Some of the tracers have been renamed, which was not updated in the in-kernel
run-time README file. Update it.
Signed-off-by: Nikanth Karthikesan <knikanth@suse.de>
LKML-Reference: <200903231158.32151.knikanth@suse.de>
Impact: fix a crash while cat trace file
Currently we are using a cpumask to remind each cpu where a
trace occured. It lets us notice the user that a cpu just had
its first trace.
But on latest -tip we have the following crash once we cat the trace
file:
IP: [<c0270c4a>] print_trace_fmt+0x45/0xe7
*pde = 00000000
Oops: 0000 [#1] PREEMPT SMP
last sysfs file: /sys/class/net/eth0/carrier
Pid: 3897, comm: cat Not tainted (2.6.29-tip-02825-g0f22972-dirty #81)
EIP: 0060:[<c0270c4a>] EFLAGS: 00010297 CPU: 0
EIP is at print_trace_fmt+0x45/0xe7
EAX: 00000000 EBX: 00000000 ECX: c12d9e98 EDX: ccdb7010
ESI: d31f4000 EDI: 00322401 EBP: d31f3f10 ESP: d31f3efc
DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068
Process cat (pid: 3897, ti=d31f2000 task=d3b3cf20 task.ti=d31f2000)
Stack:
d31f4080 ccdb7010 d31f4000 d691fe70 ccdb7010 d31f3f24 c0270e5c d31f4000
d691fe70 d31f4000 d31f3f34 c02718e8 c12d9e98 d691fe70 d31f3f70 c02bfc33
00001000 09130000 d3b46e00 d691fe98 00000000 00000079 00000001 00000000
Call Trace:
[<c0270e5c>] ? print_trace_line+0x170/0x17c
[<c02718e8>] ? s_show+0xa7/0xbd
[<c02bfc33>] ? seq_read+0x24a/0x327
[<c02bf9e9>] ? seq_read+0x0/0x327
[<c02ab18b>] ? vfs_read+0x86/0xe1
[<c02ab289>] ? sys_read+0x40/0x65
[<c0202d8f>] ? sysenter_do_call+0x12/0x3c
Code: 00 00 00 89 45 ec f7 c7 00 20 00 00 89 55 f0 74 4e f6 86 98 10 00 00 02 74 45 8b 86 8c 10 00 00 8b 9e a8 10 00 00 e8 52 f3 ff ff <0f> a3 03 19 c0 85 c0 75 2b 8b 86 8c 10 00 00 8b 9e a8 10 00 00
EIP: [<c0270c4a>] print_trace_fmt+0x45/0xe7 SS:ESP 0068:d31f3efc
CR2: 0000000000000000
---[ end trace aa9cf38e5ebed9dd ]---
This is because we alloc the iter->started cpumask on tracing_pipe_open but
not on tracing_open.
It hadn't been noticed until now because we need to have ring buffer overruns
to activate the starting of cpu buffer detection.
Also, we need a check to not print the messagge for the first trace on the file.
LKML-Reference: <1238619188-6109-1-git-send-email-fweisbec@gmail.com>
Building a kernel with tracing can raise the following warning on
tip/master:
kernel/trace/trace.c:1249: error: implicit declaration of function 'vbin_printf'
We are missing an include to string.h
LKML-Reference: <1238160130-7437-1-git-send-email-fweisbec@gmail.com>
Impact: fix time output bug in 32bits system
ns2usecs() returns 'long', it's incorrect.
(In i386)
<idle>-0 [000] 521.442100: _spin_lock <-tick_do_update_jiffies64
<idle>-0 [000] 521.442101: do_timer <-tick_do_update_jiffies64
<idle>-0 [000] 521.442102: update_wall_time <-do_timer
<idle>-0 [000] 521.442102: update_xtime_cache <-update_wall_time
(It always print the time less than 2200 seconds besides ...)
Because 'long' is 32bits in i386. ( (1<<31) useconds is about 2200 seconds)
<idle>-0 [001] 4154502640.134759: rcu_bh_qsctr_inc <-__do_softirq
<idle>-0 [001] 4154502640.134760: _local_bh_enable <-__do_softirq
<idle>-0 [001] 4154502640.134761: idle_cpu <-irq_exit
(very large value)
Because 'long' is a signed type and it is 32bits in i386.
Changes in v2:
return 'unsigned long long' instead of 'cycle_t'
LKML-Reference: <49D05D10.4030009@cn.fujitsu.com>
Merge reason: update to upstream tracing facilities
'tracing/kprobes', 'tracing/blktrace-v2' and 'tracing/textedit' into tracing/core-v2
graph time is the time that a function is executing another function.
Thus if function A calls B, if graph-time is set, then the time for
A includes B. This is the default behavior. But if graph-time is off,
then the time spent executing B is subtracted from A.
If the function graph trace is enabled, the function profiler will
use it to take the timing of the functions.
cat /debug/tracing/trace_stat/functions
Function Hit Time
mwait_idle 127 183028.4 us
schedule 26 151997.7 us
__schedule 31 151975.1 us
sys_wait4 2 74080.53 us
do_wait 2 74077.80 us
sys_newlstat 138 39929.16 us
do_path_lookup 179 39845.79 us
vfs_lstat_fd 138 39761.97 us
user_path_at 153 39469.58 us
path_walk 179 39435.76 us
__link_path_walk 189 39143.73 us
Note the times are skewed due to the function graph tracer not taking
into account schedules.
