commit cb59974742aea24adf6637eb0c4b8e7b48bca6fb upstream.
Fix a bug introduced by e9dbfae5, which prevents event_subsystem from
ever being released.
Ref_count was added to keep track of subsystem users, not for counting
events. Subsystem is created with ref_count = 1, so there is no need to
increment it for every event, we have nr_events for that. Fix this by
touching ref_count only when we actually have a new user -
subsystem_open().
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
Link: http://lkml.kernel.org/r/1320052062-7846-1-git-send-email-idryomov@gmail.com
Merge reason: pick up the latest fixes - they won't make v3.0.
The "enable" file for the event system can be removed when a module
is unloaded and the event system only has events from that module.
As the event system nr_events count goes to zero, it may be freed
if its ref_count is also set to zero.
Like the "filter" file, the "enable" file may be opened by a task and
referenced later, after a module has been unloaded and the events for
that event system have been removed.
Although the "filter" file referenced the event system structure,
the "enable" file only references a pointer to the event system
name. Since the name is freed when the event system is removed,
it is possible that an access to the "enable" file may reference
a freed pointer.
Update the "enable" file to use the subsystem_open() routine that
the "filter" file uses, to keep a reference to the event system
structure while the "enable" file is opened.
Cc: <stable@kernel.org>
Reported-by: Johannes Berg <johannes.berg@intel.com>
The event system is freed when its nr_events is set to zero. This happens
when a module created an event system and then later the module is
removed. Modules may share systems, so the system is allocated when
it is created and freed when the modules are unloaded and all the
events under the system are removed (nr_events set to zero).
The problem arises when a task opened the "filter" file for the
system. If the module is unloaded and it removed the last event for
that system, the system structure is freed. If the task that opened
the filter file accesses the "filter" file after the system has
been freed, the system will access an invalid pointer.
By adding a ref_count, and using it to keep track of what
is using the event system, we can free it after all users
are finished with the event system.
This patch replaces the code for getting an unsigned long from a
userspace buffer by a simple call to kstroul_from_user.
This makes it easier to read and less error prone.
Signed-off-by: Peter Huewe <peterhuewe@gmx.de>
Link: http://lkml.kernel.org/r/1307476707-14762-1-git-send-email-peterhuewe@gmx.de
The self tests for event tracer does not check if the function
tracing was successfully activated. It needs to before it continues
the tests, otherwise the wrong errors may be reported.
This partially reverts commit e6e1e2593592a8f6f6380496655d8c6f67431266.
That commit changed the structure layout of the trace structure, which
in turn broke PowerTOP (1.9x generation) quite badly.
I appreciate not wanting to expose the variable in question, and
PowerTOP was not using it, so I've replaced the variable with just a
padding field - that way if in the future a new field is needed it can
just use this padding field.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Trace events belonging to a module only exists when the module is
loaded. Well, we can use trace_set_clr_event funtion to enable some
trace event at the module init routine, so that we will not miss
something while loading then module.
So, Export the trace_set_clr_event function so that module can use it.
Signed-off-by: Yuanhan Liu <yuanhan.liu@linux.intel.com>
LKML-Reference: <1289196312-25323-1-git-send-email-yuanhan.liu@linux.intel.com>
The lock_depth field in the event headers was added as a temporary
data point for help in removing the BKL. Now that the BKL is pretty
much been removed, we can remove this field.
This in turn changes the header from 12 bytes to 8 bytes,
removing the 4 byte buffer that gcc would insert if the first field
in the data load was 8 bytes in size.
Currently the trace_event structures are placed in the _ftrace_events
section, and at link time, the linker makes one large array of all
the trace_event structures. On boot up, this array is read (much like
the initcall sections) and the events are processed.
The problem is that there is no guarantee that gcc will place complex
structures nicely together in an array format. Two structures in the
same file may be placed awkwardly, because gcc has no clue that they
are suppose to be in an array.
A hack was used previous to force the alignment to 4, to pack the
structures together. But this caused alignment issues with other
architectures (sparc).
Instead of packing the structures into an array, the structures' addresses
are now put into the _ftrace_event section. As pointers are always the
natural alignment, gcc should always pack them tightly together
(otherwise initcall, extable, etc would also fail).
By having the pointers to the structures in the section, we can still
iterate the trace_events without causing unnecessary alignment problems
with other architectures, or depending on the current behaviour of
gcc that will likely change in the future just to tick us kernel developers
off a little more.
The _ftrace_event section is also moved into the .init.data section
as it is now only needed at boot up.
Suggested-by: David Miller <davem@davemloft.net>
Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Currently we have in something like the sched_switch event:
field:char prev_comm[TASK_COMM_LEN]; offset:12; size:16; signed:1;
When a userspace tool such as perf tries to parse this, the
TASK_COMM_LEN is meaningless. This is done because the TRACE_EVENT() macro
simply uses a #len to show the string of the length. When the length is
an enum, we get a string that means nothing for tools.
By adding a static buffer and a mutex to protect it, we can store the
string into that buffer with snprintf and show the actual number.
Now we get:
field:char prev_comm[16]; offset:12; size:16; signed:1;
Something much more useful.
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl:
vfs: make no_llseek the default
vfs: don't use BKL in default_llseek
llseek: automatically add .llseek fop
libfs: use generic_file_llseek for simple_attr
mac80211: disallow seeks in minstrel debug code
lirc: make chardev nonseekable
viotape: use noop_llseek
raw: use explicit llseek file operations
ibmasmfs: use generic_file_llseek
spufs: use llseek in all file operations
arm/omap: use generic_file_llseek in iommu_debug
lkdtm: use generic_file_llseek in debugfs
net/wireless: use generic_file_llseek in debugfs
drm: use noop_llseek
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
Remove the nasty hack that marks a pointer's LSB to distinguish common
fields from event fields. Replace it with a more sane approach.
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
LKML-Reference: <4C6A23C2.9020606@cn.fujitsu.com>
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into trace/tip/perf/urgent-4
kernel/trace/trace_events.c
Two new events were added that broke the current format output.
Both from the SCSI system: scsi_dispatch_cmd_done and scsi_dispatch_cmd_timeout
The reason is that their print_fmt exceeded a page size. Since the output
of the format used simple_read_from_buffer and trace_seq, it was limited
to a page size in output.
This patch converts the printing of the format of an event into seq_file,
which allows greater than a page size to be shown.
I diffed all event formats comparing the output with and without this
patch. All matched except for the above two, which showed just:
FORMAT TOO BIG
without this patch, but now properly displays the output with this patch.
v2: Remove updating *pos in seq start function.
[ Thanks to Li Zefan for pointing that out ]
Reviewed-by: Li Zefan <lizf@cn.fujitsu.com>
Cc: Martin K. Petersen <martin.petersen@oracle.com>
Cc: Kei Tokunaga <tokunaga.keiich@jp.fujitsu.com>
Cc: James Bottomley <James.Bottomley@suse.de>
Cc: Tomohiro Kusumi <kusumi.tomohiro@jp.fujitsu.com>
Cc: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com>
We found that even enabling a single trace event that will rarely be
triggered can add big overhead to context switch.
(lmbench context switch test)
2p/0K 2p/16K 2p/64K 8p/16K 8p/64K 16p/16K 16p/64K
ctxsw ctxsw ctxsw ctxsw ctxsw ctxsw ctxsw
2.19 2.3 2.21 2.56 2.13 2.54 2.07
2.39 2.51 2.35 2.75 2.27 2.81 2.24
The overhead is 6% ~ 11%.
It's because when a trace event is enabled 3 tracepoints (sched_switch,
sched_wakeup, sched_wakeup_new) will be activated to map pid to cmdname.
We'd like to avoid this overhead, so add a trace option '(no)record-cmd'
to allow to disable cmdline recording.
LKML-Reference: <4C2D57F4.2050204@cn.fujitsu.com>
Because kprobes and syscalls need special processing to register
events, the class->reg() method was created to handle the differences.
But instead of creating a default ->reg for perf and ftrace events,
the code was scattered with:
if (class->reg)
class->reg();
else
default_reg();
This is messy and can also lead to bugs.
This patch cleans up this code and creates a default reg() entry for
the events allowing for the code to directly call the class->reg()
without the condition.
Reported-by: Peter Zijlstra <peterz@infradead.org>
Acked-by: Peter Zijlstra <peterz@infradead.org>
Let trace_module_add_events() and event_trace_init() call
__trace_add_event_call().
LKML-Reference: <4BFA37E9.1020106@cn.fujitsu.com>
Every event (or event class) has it's define_fields callback,
so the test is redundant.
LKML-Reference: <4BFA37BC.8080707@cn.fujitsu.com>
Every event has the same common fields, so it's a big waste of
memory to have a copy of those fields for every event.
LKML-Reference: <4BFA3759.30105@cn.fujitsu.com>
The ftrace_preempt_disable/enable functions were to address a
recursive race caused by the function tracer. The function tracer
traces all functions which makes it easily susceptible to recursion.
One area was preempt_enable(). This would call the scheduler and
the schedulre would call the function tracer and loop.
(So was it thought).
The ftrace_preempt_disable/enable was made to protect against recursion
inside the scheduler by storing the NEED_RESCHED flag. If it was
set before the ftrace_preempt_disable() it would not call schedule
on ftrace_preempt_enable(), thinking that if it was set before then
it would have already scheduled unless it was already in the scheduler.
This worked fine except in the case of SMP, where another task would set
the NEED_RESCHED flag for a task on another CPU, and then kick off an
IPI to trigger it. This could cause the NEED_RESCHED to be saved at
ftrace_preempt_disable() but the IPI to arrive in the the preempt
disabled section. The ftrace_preempt_enable() would not call the scheduler
because the flag was already set before entring the section.
This bug would cause a missed preemption check and cause lower latencies.
Investigating further, I found that the recusion caused by the function
tracer was not due to schedule(), but due to preempt_schedule(). Now
that preempt_schedule is completely annotated with notrace, the recusion
no longer is an issue.
Reported-by: Thomas Gleixner <tglx@linutronix.de>
The filter_active and enable both use an int (4 bytes each) to
set a single flag. We can save 4 bytes per event by combining the
two into a single integer.
4913961 1088356 861512 6863829 68bbd5 vmlinux.orig
4894944 1018052 861512 6774508 675eec vmlinux.id
4894871 1012292 861512 6768675 674823 vmlinux.flags
This gives us another 5K in savings.
The modification of both the enable and filter fields are done
under the event_mutex, so it is still safe to combine the two.
Note: Although Mathieu gave his Acked-by, he would like it documented
that the reads of flags are not protected by the mutex. The way the
code works, these reads will not break anything, but will have a
residual effect. Since this behavior is the same even before this
patch, describing this situation is left to another patch, as this
patch does not change the behavior, but just brought it to Mathieu's
attention.
v2: Updated the event trace self test to for this change.
Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Acked-by: Masami Hiramatsu <mhiramat@redhat.com>
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
Cc: Tom Zanussi <tzanussi@gmail.com>
Now that the trace_event structure is embedded in the ftrace_event_call
structure, there is no need for the ftrace_event_call id field.
The id field is the same as the trace_event type field.
Removing the id and re-arranging the structure brings down the tracepoint
footprint by another 5K.
4895024 1023812 861512 6780348 6775bc vmlinux.print
Currently, every event has its own trace_event structure. This is
fine since the structure is needed anyway. But the print function
structure (trace_event_functions) is now separate. Since the output
of the trace event is done by the class (with the exception of events
defined by DEFINE_EVENT_PRINT), it makes sense to have the class
define the print functions that all events in the class can use.
This makes a bigger deal with the syscall events since all syscall events
use the same class. The savings here is another 30K.
4900382 1048964 861512 6810858 67ecea vmlinux.init
4900446 1049028 861512 6810986 67ed6a vmlinux.preprint
To accomplish this, and to let the class know what event is being
printed, the event structure is embedded in the ftrace_event_call
structure. This should not be an issues since the event structure
was created for each event anyway.
The raw_init function pointer in the event is used to initialize
various kinds of events. The type of initialization needed is usually
classed to the kind of event it is.
Two events with the same class will always have the same initialization
function, so it makes sense to move this to the class structure.
Perhaps even making a special system structure would work since
the initialization is the same for all events within a system.
But since there's no system structure (yet), this will just move it
to the class.
4900375 1053380 861512 6815267 67fe23 vmlinux.fields
The text grew very slightly, but this is a constant growth that happened
with the changing of the C files that call the init code.
The bigger savings is the data which will be saved the more events share
a class.
Move the defined fields from the event to the class structure.
Since the fields of the event are defined by the class they belong
to, it makes sense to have the class hold the information instead
of the individual events. The events of the same class would just
hold duplicate information.
After this change the size of the kernel dropped another 3K:
4900252 1057412 861512 6819176 680d68 vmlinux.regs
Although the text increased, this was mainly due to the C files
having to adapt to the change. This is a constant increase, where
new tracepoints will not increase the Text. But the big drop is
in the data size (as well as needed allocations to hold the fields).
This will give even more savings as more tracepoints are created.
Note, if just TRACE_EVENT()s are used and not DECLARE_EVENT_CLASS()
with several DEFINE_EVENT()s, then the savings will be lost. But
we are pushing developers to consolidate events with DEFINE_EVENT()
so this should not be an issue.
The kprobes define a unique class to every new event, but are dynamic
so it should not be a issue.
The syscalls however have a single class but the fields for the individual
events are different. The syscalls use a metadata to define the
fields. I moved the fields list from the event to the metadata and
added a "get_fields()" function to the class. This function is used
to find the fields. For normal events and kprobes, get_fields() just
returns a pointer to the fields list_head in the class. For syscall
events, it returns the fields list_head in the metadata for the event.
v2: Fixed the syscall fields. The syscall metadata needs a list
of fields for both enter and exit.
This patch removes the register functions of TRACE_EVENT() to enable
and disable tracepoints. The registering of a event is now down
directly in the trace_events.c file. The tracepoint_probe_register()
is now called directly.
The prototypes are no longer type checked, but this should not be
an issue since the tracepoints are created automatically by the
macros. If a prototype is incorrect in the TRACE_EVENT() macro, then
other macros will catch it.
The trace_event_class structure now holds the probes to be called
by the callbacks. This removes needing to have each event have
a separate pointer for the probe.
To handle kprobes and syscalls, since they register probes in a
different manner, a "reg" field is added to the ftrace_event_class
structure. If the "reg" field is assigned, then it will be called for
enabling and disabling of the probe for either ftrace or perf. To let
the reg function know what is happening, a new enum (trace_reg) is
created that has the type of control that is needed.
With this new rework, the 82 kernel events and 618 syscall events
has their footprint dramatically lowered:
4914025 1088868 861512 6864405 68be15 vmlinux.class
4918492 1084612 861512 6864616 68bee8 vmlinux.tracepoint
The size went from 6863829 to 6819176, that's a total of 44K
in savings. With tracepoints being continuously added, this is
critical that the footprint becomes minimal.
v5: Added #ifdef CONFIG_PERF_EVENTS around a reference to perf
specific structure in trace_events.c.
v4: Fixed trace self tests to check probe because regfunc no longer
exists.
v3: Updated to handle void *data in beginning of probe parameters.
Also added the tracepoint: check_trace_callback_type_##call().
v2: Changed the callback probes to pass void * and typecast the
value within the function.
This patch creates a ftrace_event_class struct that event structs point to.
This class struct will be made to hold information to modify the
events. Currently the class struct only holds the events system name.
This patch slightly increases the size, but this change lays the ground work
of other changes to make the footprint of tracepoints smaller.
With 82 standard tracepoints, and 618 system call tracepoints
(two tracepoints per syscall: enter and exit):
This patch also cleans up some stale comments in ftrace.h.
v2: Fixed missing semi-colon in macro.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Drop the obsolete "profile" naming used by perf for trace events.
Perf can now do more than simple events counting, so generalize
the API naming.
Cc: Masami Hiramatsu <mhiramat@redhat.com>
Cc: Jason Baron <jbaron@redhat.com>
Discard freeing field->type since it is not necessary.
Signed-off-by: Wenji Huang <wenji.huang@oracle.com>
LKML-Reference: <1266997226-6833-5-git-send-email-wenji.huang@oracle.com>
The previous patches added the use of print_fmt string and changes
the trace_define_field() function to also create the fields and
format output for the event format files.
5857201 1355780 9336808 16549789 fc879d vmlinux
5884589 1351684 9337896 16574169 fce6d9 vmlinux-orig
The above shows the size of the vmlinux after this patch set
compared to the vmlinux-orig which is before the patch set.
This saves us 27k on text, 1k on bss and adds just 4k of data.
The total savings of 24k in size.
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
LKML-Reference: <4B273D4D.40604@cn.fujitsu.com>
The calls ftrace_format_##call() and ftrace_define_fields_##call()
are almost duplicate in functionality. With the addition of the
print_fmt in previous patches, these two functions can be merged
into one.
The trace_define_field() defines the fields and links them into
the struct ftrace_event_call. The previous patches introduced
the print_fmt field and this can now be used with the trace_define_field()
to create the event format file fields and print_fmt field.
The struct ftrace_event_call->fields are used to print the fields
The struct ftrace_event_call->print_fmt is used to print
the "print fmt: XXXXXXXXXXX" line.
LKML-Reference: <4B273D49.5000006@cn.fujitsu.com>
Move the printk from each ftrace_raw_reg_event_foo() to
its caller ftrace_event_enable_disable(). This avoids each
regfunc trace event callbacks to handle a same error report
that can be carried from the caller.
See how much space this saves:
5345151 1961864 7103260 14410275 dbe223 vmlinux.o.old
5331487 1961864 7103260 14396611 dbacc3 vmlinux.o
Acked-by: Steven Rostedt <rostedt@goodmis.org>
LKML-Reference: <4B1DC4AC.802@cn.fujitsu.com>
[start cmdline record before calling regfunc to avoid lost
window of pid to comm resolution]
Call trace_define_common_fields() in event_create_dir() only.
This avoids trace events to handle it from their define_fields
callbacks and shrinks the kernel code size:
5346802 1961864 7103260 14411926 dbe896 vmlinux.o.old
LKML-Reference: <4B1DC49C.8000107@cn.fujitsu.com>
Use a generic trace_event_raw_init() function for all event's raw_init
callbacks (but kprobes) instead of defining the same version for each
of these.
This shrinks the kernel code:
5355293 1961928 7103260 14420481 dc0a01 vmlinux.o.old
raw_init can't be removed, because ftrace events and kprobe events
use different raw_init callbacks. Though it's possible to totally
remove raw_init, I choose to leave it as it is for now.
LKML-Reference: <4B1DC48C.7080603@cn.fujitsu.com>
tools/perf/Makefile
Merge reason:
- fix the conflict
- pick up the pr_*() infrastructure to queue up dependent patch
kernel/trace/trace_event_profile.c
Merge reason: update to -rc5 and resolve conflict.
Merge reason: to add event filter support we need the following
commits from the tracing tree:
3f6fe06: tracing/filters: Unify the regex parsing helpers
1889d20: tracing/filters: Provide basic regex support
737f453: tracing/filters: Cleanup useless headers
The sign info used for filters in the kernel is also useful to
applications that process the trace stream. Add it to the format
files and make it available to userspace.
Signed-off-by: Tom Zanussi <tzanussi@gmail.com>
Cc: rostedt@goodmis.org
Cc: lizf@cn.fujitsu.com
Cc: hch@infradead.org
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
LKML-Reference: <1254809398-8078-2-git-send-email-tzanussi@gmail.com>
Check result of event_create_dir() and add ftrace_event_call to
ftrace_events list only if it is succeeded. Thanks to Li for pointing
it out.
Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com>
Cc: Jim Keniston <jkenisto@us.ibm.com>
Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cc: Frank Ch. Eigler <fche@redhat.com>
Cc: K.Prasad <prasad@linux.vnet.ibm.com>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
Cc: Li Zefan <lizf@cn.fujitsu.com>
Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
LKML-Reference: <20090925182054.10157.55219.stgit@omoto>
Merge reason: Pick up latest fixes and update to latest upstream.
Cleanup the useless dentry variable while creating a kernel
event set of files. trace_create_file() warns if it fails to
create the file anyway, and we don't store the dentry anywhere.
v2: Fix a small conflict in kernel/trace/trace_events.c
kernel/trace/Makefile
kernel/trace/trace.h
kernel/trace/trace_event_types.h
kernel/trace/trace_export.c
Merge reason:
Sync with latest significant tracing core changes.
Return immediately if trace_get_user() returned failure.
Cc: Jiri Olsa <jolsa@redhat.com>
LKML-Reference: <4AB86614.7020803@cn.fujitsu.com>
Simplify s_next() and t_next().
LKML-Reference: <4AB32389.1030005@cn.fujitsu.com>
Merge reason: Pick up kernel/softirq.c update for dependent fix.
Lock not only event_mutex but also trace_event_mutex in
trace_remove_event_call() to protect __unregister_ftrace_event().
LKML-Reference: <20090914204912.18779.68734.stgit@dhcp-100-2-132.bos.redhat.com>
Handle failure path in trace_add_event_call() to fix the below bug
which occurred when I tried to add invalid event twice.
Could not create debugfs 'kmalloc' directory
Failed to register kprobe event: kmalloc
Faild to register probe event(-1)
WARNING: at /home/mhiramat/ksrc/random-tracing/lib/list_debug.c:26
__list_add+0x27/0x5c()
Hardware name:
list_add corruption. next->prev should be prev (c07d78cc), but was
00001000. (next=d854236c).
Modules linked in: sunrpc uinput virtio_net virtio_balloon i2c_piix4 pcspkr
i2c_core virtio_blk virtio_pci virtio_ring virtio [last unloaded:
scsi_wait_scan]
Pid: 1394, comm: tee Not tainted 2.6.31-rc9 #51
Call Trace:
[<c0438424>] warn_slowpath_common+0x65/0x7c
[<c05371b3>] ? __list_add+0x27/0x5c
[<c043846f>] warn_slowpath_fmt+0x24/0x27
[<c05371b3>] __list_add+0x27/0x5c
[<c047f050>] list_add+0xa/0xc
[<c047f8f5>] trace_add_event_call+0x60/0x97
[<c0483133>] command_trace_probe+0x42c/0x51b
[<c044a1b3>] ? remove_wait_queue+0x22/0x27
[<c042a9c0>] ? __wake_up+0x32/0x3b
[<c04832f6>] probes_write+0xd4/0x10a
[<c0483222>] ? probes_write+0x0/0x10a
[<c04b27a9>] vfs_write+0x80/0xdf
[<c04b289c>] sys_write+0x3b/0x5d
[<c0670d41>] syscall_call+0x7/0xb
---[ end trace 2b962b5dc1fdc07d ]---
LKML-Reference: <4AB1077F.6020107@redhat.com>
