path: root/kernel/trace/trace_kdb.c
2010-10-22kdb,ftdump: Remove reference to internal kdb includeJason Wessel
Now that include/linux/kdb.h properly exports all the functions required to dynamically add a kdb shell command, the reference to the private kdb header can be removed. Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2010-08-05ftrace,kdb: Allow dumping a specific cpu's buffer with ftdumpJason Wessel
In systems with more than one processor it is desirable to look at the per cpu trace buffers. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> CC: Frederic Weisbecker <fweisbec@gmail.com>
2010-08-05ftrace,kdb: Extend kdb to be able to dump the ftrace bufferJason Wessel
Add in a helper function to allow the kdb shell to dump the ftrace buffer. Modify trace.c to expose the capability to iterate over the ftrace buffer in a read only capacity. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> CC: Frederic Weisbecker <fweisbec@gmail.com>
