path: root/kernel/trace/trace_sched_switch.c
2011-02-08tracing: Remove obsolete sched_switch tracerSteven Rostedt
The trace events sched_switch and sched_wakeup do the same thing as the stand alone sched_switch tracer does. It is no longer needed. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-05-14tracing: Let tracepoints have data passed to tracepoint callbacksSteven Rostedt
This patch adds data to be passed to tracepoint callbacks. The created functions from DECLARE_TRACE() now need a mandatory data parameter. For example: DECLARE_TRACE(mytracepoint, int value, value) Will create the register function: int register_trace_mytracepoint((void(*)(void *data, int value))probe, void *data); As the first argument, all callbacks (probes) must take a (void *data) parameter. So a callback for the above tracepoint will look like: void myprobe(void *data, int value) { } The callback may choose to ignore the data parameter. This change allows callbacks to register a private data pointer along with the function probe. void mycallback(void *data, int value); register_trace_mytracepoint(mycallback, mydata); Then the mycallback() will receive the "mydata" as the first parameter before the args. A more detailed example: DECLARE_TRACE(mytracepoint, TP_PROTO(int status), TP_ARGS(status)); /* In the C file */ DEFINE_TRACE(mytracepoint, TP_PROTO(int status), TP_ARGS(status)); [...] trace_mytracepoint(status); /* In a file registering this tracepoint */ int my_callback(void *data, int status) { struct my_struct my_data = data; [...] } [...] my_data = kmalloc(sizeof(*my_data), GFP_KERNEL); init_my_data(my_data); register_trace_mytracepoint(my_callback, my_data); The same callback can also be registered to the same tracepoint as long as the data registered is different. Note, the data must also be used to unregister the callback: unregister_trace_mytracepoint(my_callback, my_data); Because of the data parameter, tracepoints declared this way can not have no args. That is: DECLARE_TRACE(mytracepoint, TP_PROTO(void), TP_ARGS()); will cause an error. If no arguments are needed, a new macro can be used instead: DECLARE_TRACE_NOARGS(mytracepoint); Since there are no arguments, the proto and args fields are left out. This is part of a series to make the tracepoint footprint smaller: text data bss dec hex filename 4913961 1088356 861512 6863829 68bbd5 vmlinux.orig 4914025 1088868 861512 6864405 68be15 vmlinux.class 4918492 1084612 861512 6864616 68bee8 vmlinux.tracepoint Again, this patch also increases the size of the kernel, but lays the ground work for decreasing it. v5: Fixed net/core/drop_monitor.c to handle these updates. v4: Moved the DECLARE_TRACE() DECLARE_TRACE_NOARGS out of the #ifdef CONFIG_TRACE_POINTS, since the two are the same in both cases. The __DECLARE_TRACE() is what changes. Thanks to Frederic Weisbecker for pointing this out. v3: Made all register_* functions require data to be passed and all callbacks to take a void * parameter as its first argument. This makes the calling functions comply with C standards. Also added more comments to the modifications of DECLARE_TRACE(). v2: Made the DECLARE_TRACE() have the ability to pass arguments and added a new DECLARE_TRACE_NOARGS() for tracepoints that do not need any arguments. Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Acked-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Neil Horman <nhorman@tuxdriver.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-05-07sched: Remove rq argument to the tracepointsPeter Zijlstra
struct rq isn't visible outside of sched.o so its near useless to expose the pointer, also there are no users of it, so remove it. Acked-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1272997616.1642.207.camel@laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-04tracing: pass around ring buffer instead of tracerSteven Rostedt
The latency tracers (irqsoff and wakeup) can swap trace buffers on the fly. If an event is happening and has reserved data on one of the buffers, and the latency tracer swaps the global buffer with the max buffer, the result is that the event may commit the data to the wrong buffer. This patch changes the API to the trace recording to be recieve the buffer that was used to reserve a commit. Then this buffer can be passed in to the commit. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-08-06tracing: Move sched event insertion helpers in the sched switch tracer fileFrederic Weisbecker
The sched events helpers which insert the sched switch and wakeup events into the ring buffer currently reside in trace.c But this file is quite overloaded and the right place for these helpers is in the sched switch tracer file. Then move them to trace_functions.c Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org>
2009-04-14tracing/events: move trace point headers into include/trace/eventsSteven Rostedt
Impact: clean up Create a sub directory in include/trace called events to keep the trace point headers in their own separate directory. Only headers that declare trace points should be defined in this directory. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Neil Horman <nhorman@tuxdriver.com> Cc: Zhao Lei <zhaolei@cn.fujitsu.com> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-04-07ftrace: clean up enable logic for sched_switchZhaolei
Unify sched_switch and sched_wakeup's action to following logic: Do record_cmdline when start_cmdline_record() is called. Start tracing events when the tracer is started. Signed-off-by: Zhao Lei <zhaolei@cn.fujitsu.com> LKML-Reference: <49D1C596.5050203@cn.fujitsu.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-04-07ftrace: Add check of sched_stopped for probe_sched_wakeupZhaolei
The wakeup tracing in sched_switch does not stop when a user disables tracing. This is because the probe_sched_wakeup() is missing the check to prevent the wakeup from being traced. Signed-off-by: Zhao Lei <zhaolei@cn.fujitsu.com> LKML-Reference: <49D1C543.3010307@cn.fujitsu.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-17tracing: make sched_switch stop/start light weightSteven Rostedt
The stopping and starting of a tracer should be light weight and be able to be called in all contexts. The sched_switch grabbed mutexes in the start/stop functions. This patch changes it to a simple variable, on/off. Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2009-02-18tracing/core: use appropriate waiting on trace_pipeFrederic Weisbecker
Impact: api and pipe waiting change Currently, the waiting used in tracing_read_pipe() is done through a 100 msecs schedule_timeout() loop which periodically check if there are traces on the buffer. This can cause small latencies for programs which are reading the incoming events. This patch makes the reader waiting for the trace_wait waitqueue except for few tracers such as the sched and functions tracers which might be already hold the runqueue lock while waking up the reader. This is performed through a new callback wait_pipe() on struct tracer. If none is implemented on a specific tracer, the default waiting for trace_wait queue is attached. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-17tracing: fix typing mistake in hint message and commentsWenji Huang
Impact: cleanup Fix incorrect hint message in code and typos in comments. Signed-off-by: Wenji Huang <wenji.huang@oracle.com> Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2009-02-06trace: Call tracing_reset_online_cpus before tracer->init()Arnaldo Carvalho de Melo
Impact: cleanup To make it easy for ftrace plugin writers, as this was open coded in the existing plugins Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Acked-by: Frédéric Weisbecker <fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-05trace: Remove unused trace_array_cpu parameterArnaldo Carvalho de Melo
Impact: cleanup Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-25sched, trace: update trace_sched_wakeup()Peter Zijlstra
Impact: extend the wakeup tracepoint with the info whether the wakeup was real Add the information needed to distinguish 'real' wakeups from 'false' wakeups. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-19ftrace: introduce tracing_reset_online_cpus() helperPekka J Enberg
Impact: cleanup This patch factors out common code from multiple tracers into a tracing_reset_online_cpus() function and converts the tracers to use it. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-19tracing: fix warnings in kernel/trace/trace_sched_switch.cIngo Molnar
these warnings: kernel/trace/trace_sched_switch.c: In function ‘tracing_sched_register’: kernel/trace/trace_sched_switch.c:96: warning: passing argument 1 of ‘register_trace_sched_wakeup_new’ from incompatible pointer type kernel/trace/trace_sched_switch.c:112: warning: passing argument 1 of ‘unregister_trace_sched_wakeup_new’ from incompatible pointer type kernel/trace/trace_sched_switch.c: In function ‘tracing_sched_unregister’: kernel/trace/trace_sched_switch.c:121: warning: passing argument 1 of ‘unregister_trace_sched_wakeup_new’ from incompatible pointer type Trigger because sched_wakeup_new tracepoints need the same trace signature as sched_wakeup - which was changed recently. Fix it. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-16tracing/ftrace: change the type of the init() callbackFrederic Weisbecker
Impact: extend the ->init() method with the ability to fail This bring a way to know if the initialization of a tracer successed. A tracer must return 0 on success and a traditional error (ie: -ENOMEM) if it fails. If a tracer fails to init, it is free to print a detailed warn. The tracing api will not and switch to a new tracer will just return the error from the init callback. Note: this will be used for the return tracer. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-08ftrace: remove trace array ctrlSteven Rostedt
Impact: remove obsolete variable in trace_array structure With the new start / stop method of ftrace, the ctrl variable in the trace_array structure is now obsolete. Remove it. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-08ftrace: remove ctrl_update methodSteven Rostedt
Impact: Remove the ctrl_update tracer method With the new quick start/stop method of tracing, the ctrl_update method is out of date. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-08ftrace: fix sched_switch APISteven Rostedt
Impact: fix for sched_switch that broke dynamic ftrace startup The commit: tracing/fastboot: use sched switch tracer from boot tracer broke the API of the sched_switch trace. The use of the tracing_start/stop_cmdline record is for only recording the cmdline, NOT recording the schedule switches themselves. Seeing that the boot tracer broke the API to do something that it wanted, this patch adds a new interface for the API while puting back the original interface of the old API. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-08ftrace: fix boot trace sched startupSteven Rostedt
Impact: boot tracer startup modified The boot tracer calls into some of the schedule tracing private functions that should not be exported. This patch cleans it up, and makes way for further changes in the ftrace infrastructure. This patch adds a api to assign a tracer array to the schedule context switch tracer. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-06ftrace: restructure tracing start/stop infrastructureSteven Rostedt
Impact: change where tracing is started up and stopped Currently, when a new tracer is selected via echo'ing a tracer name into the current_tracer file, the startup is only done if tracing_enabled is set to one. If tracing_enabled is changed to zero (by echo'ing 0 into the tracing_enabled file) a full shutdown is performed. The full startup and shutdown of a tracer can be expensive and the user can lose out traces when echo'ing in 0 to the tracing_enabled file, because the process takes too long. There can also be places that the user would like to start and stop the tracer several times and doing the full startup and shutdown of a tracer might be too expensive. This patch performs the full startup and shutdown when a tracer is selected. It also adds a way to do a quick start or stop of a tracer. The quick version is just a flag that prevents the tracing from taking place, but the overhead of the code is still there. For example, the startup of a tracer may enable tracepoints, or enable the function tracer. The stop and start will just set a flag to have the tracer ignore the calls when the tracepoint or function trace is called. The overhead of the tracer may still be present when the tracer is stopped, but no tracing will occur. Setting the tracer to the 'nop' tracer (or any other tracer) will perform the shutdown of the tracer which will disable the tracepoint or disable the function tracer. The tracing_enabled file will simply start or stop tracing. This change is all internal. The end result for the user should be the same as before. If tracing_enabled is not set, no trace will happen. If tracing_enabled is set, then the trace will happen. The tracing_enabled variable is static between tracers. Enabling tracing_enabled and going to another tracer will keep tracing_enabled enabled. Same is true with disabling tracing_enabled. This patch will now provide a fast start/stop method to the users for enabling or disabling tracing. Note: There were two methods to the struct tracer that were never used: The methods start and stop. These were to be used as a hook to the reading of the trace output, but ended up not being necessary. These two methods are now used to enable the start and stop of each tracer, in case the tracer needs to do more than just not write into the buffer. For example, the irqsoff tracer must stop recording max latencies when tracing is stopped. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-04tracing/ftrace: fix a bug when switch current tracer to sched tracerFrederic Weisbecker
Impact: fix boot tracer + sched tracer coupling bug Fix a bug that made the sched_switch tracer unable to run if set as the current_tracer after the boot tracer. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-04tracing/ftrace: types and naming corrections for sched tracerFrederic Weisbecker
Impact: cleanup This patch applies some corrections suggested by Steven Rostedt. Change the type of shed_ref into int since it is used into a Mutex, we don't need it anymore as an atomic variable in the sched_switch tracer. Also change the name of the register mutex. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-04tracing/fastboot: use sched switch tracer from boot tracerFrederic Weisbecker
Impact: enhance boot trace output with scheduling events Use the sched_switch tracer from the boot tracer. We also can trace schedule events inside the initcalls. Sched tracing is disabled after the initcall has finished and then reenabled before the next one is started. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-04tracing/ftrace: remove unused code in sched_switch tracerFrederic Weisbecker
Impact: cleanup When init_sched_switch_trace() is called, it has no reason to start the sched tracer if the sched_ref is not zero. _ If this is non-zero, the tracer is already used, but we can register it to the tracing engine. There is already a security which avoid the tracer probes not to be resgistered twice. _ If this is zero, this block will not be used. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-04tracing/ftrace: fix a race condition in sched_switch tracerFrederic Weisbecker
Impact: fix race condition in sched_switch tracer This patch fixes a race condition in the sched_switch tracer. If several tasks (IE: concurrent initcalls) are playing with tracing_start_cmdline_record() and tracing_stop_cmdline_record(), the following situation could happen: _ Task A and B are using the same tracepoint probe. Task A holds it. Task B is sleeping and doesn't hold it. _ Task A frees the sched tracer, then sched_ref is decremented to 0. _ Task A is preempted and hadn't yet unregistered its tracepoint probe, then B runs. _ B increments sched_ref, sees it's 1 and then guess it has to register its probe. But it has not been freed by task A. _ A lot of bad things can happen after that... Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-14ftrace: make some tracers reentrantSteven Rostedt
Now that the ring buffer is reentrant, some of the ftrace tracers (sched_swich, debugging traces) can also be reentrant. Note: Never make the function tracer reentrant, that can cause recursion problems all over the kernel. The function tracer must disable reentrancy. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-14ftrace: preempt disable over interrupt disableSteven Rostedt
With the new ring buffer infrastructure in ftrace, I'm trying to make ftrace a little more light weight. This patch converts a lot of the local_irq_save/restore into preempt_disable/enable. The original preempt count in a lot of cases has to be sent in as a parameter so that it can be recorded correctly. Some places were recording it incorrectly before anyway. This is also laying the ground work to make ftrace a little bit more reentrant, and remove all locking. The function tracers must still protect from reentrancy. Note: All the function tracers must be careful when using preempt_disable. It must do the following: resched = need_resched(); preempt_disable_notrace(); [...] if (resched) preempt_enable_no_resched_notrace(); else preempt_enable_notrace(); The reason is that if this function traces schedule() itself, the preempt_enable_notrace() will cause a schedule, which will lead us into a recursive failure. If we needed to reschedule before calling preempt_disable, we should have already scheduled. Since we did not, this is most likely that we should not and are probably inside a schedule function. If resched was not set, we still need to catch the need resched flag being set when preemption was off and the if case at the end will catch that for us. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-14ftrace: make work with new ring bufferSteven Rostedt
This patch ports ftrace over to the new ring buffer. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-14ftrace: port to tracepointsMathieu Desnoyers
Porting the trace_mark() used by ftrace to tracepoints. (cleanup) Changelog : - Change error messages : marker -> tracepoint [ mingo@elte.hu: conflict resolutions ] Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Acked-by: 'Peter Zijlstra' <peterz@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-11ftrace: move sched_switch enable after markersSteven Rostedt
We have two markers now that are enabled on sched_switch. One that records the context switching and the other that records task wake ups. Currently we enable the tracing first and then set the markers. This causes some confusing traces: # tracer: sched_switch # # TASK-PID CPU# TIMESTAMP FUNCTION # | | | | | trace-cmd-3973 [00] 115.834817: 3973:120:R + 3: 0:S trace-cmd-3973 [01] 115.834910: 3973:120:R + 6: 0:S trace-cmd-3973 [02] 115.834910: 3973:120:R + 9: 0:S trace-cmd-3973 [03] 115.834910: 3973:120:R + 12: 0:S trace-cmd-3973 [02] 115.834910: 3973:120:R + 9: 0:S <idle>-0 [02] 115.834910: 0:140:R ==> 3973:120:R Here we see that trace-cmd with PID 3973 wakes up task 9 but the next line shows the idle task doing a context switch to task 3973. Enabling the tracing to _after_ the markers are set creates a much saner output: # tracer: sched_switch # # TASK-PID CPU# TIMESTAMP FUNCTION # | | | | | <idle>-0 [02] 7922.634225: 0:140:R ==> 4790:120:R trace-cmd-4789 [03] 7922.634225: 0:140:R + 4790:120:R Signed-off-by: Steven Rostedt <srostedt@redhat.com> Cc: Steven Rostedt <srostedt@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-16namespacecheck: fixesIngo Molnar
2008-05-26ftrace: fix up cmdline recordingSteven Rostedt
The new work with converting the trace hooks over to markers broke the command line recording of ftrace. This patch fixes it again. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-26ftrace: move ftrace_special to trace.cSteven Rostedt
Move the ftrace_special out of sched_switch to trace.c. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Cc: pq@iki.fi Cc: proski@gnu.org Cc: sandmann@redhat.com Cc: a.p.zijlstra@chello.nl Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-23Port ftrace to markersMathieu Desnoyers
Porting ftrace to the marker infrastructure. Don't need to chain to the wakeup tracer from the sched tracer, because markers support multiple probes connected. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> CC: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-23ftrace: fix comm on function trace outputSteven Rostedt
In cleaning up of the sched_switch code, the function trace recording of task comms was removed. This patch adds back the recording of comms for function trace. The output of ftrace now has the task comm instead of <...>. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-23ftrace: remove add-hoc codeIngo Molnar
2008-05-23ftrace: sched specialIngo Molnar
2008-05-23ftrace: fix cmdline tracingIngo Molnar
2008-05-23ftrace: trace scheduler rbtreeIngo Molnar
2008-05-23ftrace: sched tracer, trace full rbtreeIngo Molnar
2008-05-23ftrace: add wakeup events to sched tracerIngo Molnar
2008-05-23ftrace: remove notraceIngo Molnar
now that we have a kbuild method for notrace, no need to pollute the C code with the annotations. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-23ftrace: timestamp syncing, prepareIngo Molnar
rename and uninline now() to ftrace_now(). Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-23ftrace: add self-testsSteven Rostedt
2008-05-23ftrace: don't use raw_local_irq_save/restoreSteven Rostedt
Using raw_local_irq_save/restore confuses lockdep. It's fine to use the normal ones. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-23ftrace: add tracing of context switchesSteven Rostedt
This patch adds context switch tracing, of the format of: _------=> CPU# / _-----=> irqs-off | / _----=> need-resched || / _---=> hardirq/softirq ||| / _--=> preempt-depth |||| / ||||| delay cmd pid ||||| time | pid:prio:state \ / ||||| \ | / swapper-0 1d..3 137us+: 0:140:R --> 2912:120 sshd-2912 1d..3 216us+: 2912:120:S --> 0:140 swapper-0 1d..3 261us+: 0:140:R --> 2912:120 bash-2920 0d..3 267us+: 2920:120:S --> 0:140 sshd-2912 1d..3 330us!: 2912:120:S --> 0:140 swapper-0 1d..3 2389us+: 0:140:R --> 2847:120 yum-upda-2847 1d..3 2411us!: 2847:120:S --> 0:140 swapper-0 0d..3 11089us+: 0:140:R --> 3139:120 gdm-bina-3139 0d..3 11113us!: 3139:120:S --> 0:140 swapper-0 1d..3 102328us+: 0:140:R --> 2847:120 yum-upda-2847 1d..3 102348us!: 2847:120:S --> 0:140 "sched_switch" is added to /debugfs/tracing/available_tracers [ Eugene Teo <eugeneteo@kernel.sg: remove unused tracing_sched_switch_enabled ] Signed-off-by: Steven Rostedt <srostedt@redhat.com> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
