latency
The display of absolute time and duration fields is based on the
latency field. This was added during the irqsoff/wakeup tracers
graph support changes.
It's causing confusion in what fields will be displayed for the
function_graph tracer itself. So I'm removing this depency, and
adding absolute time and duration fields to the preemptirqsoff
preemptoff irqsoff wakeup tracers.
With following commands:
# echo function_graph > ./current_tracer
# cat trace
This is what it looked like before:
# tracer: function_graph
# TIME CPU DURATION FUNCTION CALLS
0) 0.068 us | } /* page_add_file_rmap */
0) | _raw_spin_unlock() {
This is what it looks like now:
# CPU DURATION FUNCTION CALLS
0) 0.068 us | } /* add_preempt_count */
0) 0.993 us | } /* vfsmount_lock_local_lock */
For preemptirqsoff preemptoff irqsoff wakeup tracers,
this is what it looked like before:
SNIP
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / _-=> lock-depth
# CPU TASK/PID ||||| DURATION FUNCTION CALLS
1) <idle>-0 | d..1 0.000 us | acpi_idle_enter_simple();
SNIP
# _-----=> irqs-off
# TIME CPU TASK/PID |||| DURATION FUNCTION CALLS
19.847735 | 1) <idle>-0 | d..1 0.000 us | acpi_idle_enter_simple();
Signed-off-by: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/r/1307113131-10045-2-git-send-email-jolsa@redhat.com
ftrace_ops that are registered to trace functions can now be
agnostic to each other in respect to what functions they trace.
Each ops has their own hash of the functions they want to trace
and a hash to what they do not want to trace. A empty hash for
the functions they want to trace denotes all functions should
be traced that are not in the notrace hash.
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
The function start_func_tracer() was incorrectly added in the
#ifdef CONFIG_FUNCTION_TRACER condition, but is still used even
when function tracing is not enabled.
The calls to register_ftrace_function() and register_ftrace_graph()
become nops (and their arguments are even ignored), thus there is
no reason to hide start_func_tracer() when function tracing is
not enabled.
Reported-by: Ingo Molnar <mingo@elte.hu>
The wakeup tracer has three types of function tracers. Normal
function tracer, function graph entry, and function graph return.
Each of these use a complex dance to prevent recursion and whether
to trace the data or not (depending on the wake_task variable).
This patch moves the duplicate code into a single routine, to
prevent future mistakes with modifying duplicate complex code.
Cc: Jiri Olsa <jolsa@redhat.com>
Add function graph support for wakeup latency tracer.
The graph output is enabled by setting the 'display-graph'
trace option.
LKML-Reference: <1285243253-7372-4-git-send-email-jolsa@redhat.com>
Documentation/trace/ftrace.txt says
buffer_size_kb:
This sets or displays the number of kilobytes each CPU
buffer can hold. The tracer buffers are the same size
for each CPU. The displayed number is the size of the
CPU buffer and not total size of all buffers. The
trace buffers are allocated in pages (blocks of memory
that the kernel uses for allocation, usually 4 KB in size).
If the last page allocated has room for more bytes
than requested, the rest of the page will be used,
making the actual allocation bigger than requested.
( Note, the size may not be a multiple of the page size
due to buffer management overhead. )
This can only be updated when the current_tracer
is set to "nop".
But it's incorrect. currently total memory consumption is
'buffer_size_kb x CPUs x 2'.
Why two times difference is there? because ftrace implicitly allocate
the buffer for max latency too.
That makes sad result when admin want to use large buffer. (If admin
want full logging and makes detail analysis). example, If admin
have 24 CPUs machine and write 200MB to buffer_size_kb, the system
consume ~10GB memory (200MB x 24 x 2). umm.. 5GB memory waste is
usually unacceptable.
Fortunatelly, almost all users don't use max latency feature.
The max latency buffer can be disabled easily.
This patch shrink buffer size of the max latency buffer if
unnecessary.
LKML-Reference: <20100701104554.DA2D.A69D9226@jp.fujitsu.com>
The ftrace_preempt_disable/enable functions were to address a
recursive race caused by the function tracer. The function tracer
traces all functions which makes it easily susceptible to recursion.
One area was preempt_enable(). This would call the scheduler and
the schedulre would call the function tracer and loop.
(So was it thought).
The ftrace_preempt_disable/enable was made to protect against recursion
inside the scheduler by storing the NEED_RESCHED flag. If it was
set before the ftrace_preempt_disable() it would not call schedule
on ftrace_preempt_enable(), thinking that if it was set before then
it would have already scheduled unless it was already in the scheduler.
This worked fine except in the case of SMP, where another task would set
the NEED_RESCHED flag for a task on another CPU, and then kick off an
IPI to trigger it. This could cause the NEED_RESCHED to be saved at
ftrace_preempt_disable() but the IPI to arrive in the the preempt
disabled section. The ftrace_preempt_enable() would not call the scheduler
because the flag was already set before entring the section.
This bug would cause a missed preemption check and cause lower latencies.
Investigating further, I found that the recusion caused by the function
tracer was not due to schedule(), but due to preempt_schedule(). Now
that preempt_schedule is completely annotated with notrace, the recusion
no longer is an issue.
Reported-by: Thomas Gleixner <tglx@linutronix.de>
This patch adds data to be passed to tracepoint callbacks.
The created functions from DECLARE_TRACE() now need a mandatory data
parameter. For example:
DECLARE_TRACE(mytracepoint, int value, value)
Will create the register function:
int register_trace_mytracepoint((void(*)(void *data, int value))probe,
void *data);
As the first argument, all callbacks (probes) must take a (void *data)
parameter. So a callback for the above tracepoint will look like:
void myprobe(void *data, int value)
The callback may choose to ignore the data parameter.
This change allows callbacks to register a private data pointer along
with the function probe.
void mycallback(void *data, int value);
register_trace_mytracepoint(mycallback, mydata);
Then the mycallback() will receive the "mydata" as the first parameter
before the args.
A more detailed example:
DECLARE_TRACE(mytracepoint, TP_PROTO(int status), TP_ARGS(status));
/* In the C file */
DEFINE_TRACE(mytracepoint, TP_PROTO(int status), TP_ARGS(status));
trace_mytracepoint(status);
/* In a file registering this tracepoint */
int my_callback(void *data, int status)
struct my_struct my_data = data;
my_data = kmalloc(sizeof(*my_data), GFP_KERNEL);
init_my_data(my_data);
register_trace_mytracepoint(my_callback, my_data);
The same callback can also be registered to the same tracepoint as long
as the data registered is different. Note, the data must also be used
to unregister the callback:
unregister_trace_mytracepoint(my_callback, my_data);
Because of the data parameter, tracepoints declared this way can not have
no args. That is:
DECLARE_TRACE(mytracepoint, TP_PROTO(void), TP_ARGS());
will cause an error.
If no arguments are needed, a new macro can be used instead:
DECLARE_TRACE_NOARGS(mytracepoint);
Since there are no arguments, the proto and args fields are left out.
This is part of a series to make the tracepoint footprint smaller:
4913961 1088356 861512 6863829 68bbd5 vmlinux.orig
4914025 1088868 861512 6864405 68be15 vmlinux.class
4918492 1084612 861512 6864616 68bee8 vmlinux.tracepoint
Again, this patch also increases the size of the kernel, but
lays the ground work for decreasing it.
v5: Fixed net/core/drop_monitor.c to handle these updates.
v4: Moved the DECLARE_TRACE() DECLARE_TRACE_NOARGS out of the
#ifdef CONFIG_TRACE_POINTS, since the two are the same in both
cases. The __DECLARE_TRACE() is what changes.
Thanks to Frederic Weisbecker for pointing this out.
v3: Made all register_* functions require data to be passed and
all callbacks to take a void * parameter as its first argument.
This makes the calling functions comply with C standards.
Also added more comments to the modifications of DECLARE_TRACE().
v2: Made the DECLARE_TRACE() have the ability to pass arguments
and added a new DECLARE_TRACE_NOARGS() for tracepoints that
do not need any arguments.
Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Acked-by: Masami Hiramatsu <mhiramat@redhat.com>
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
Cc: Neil Horman <nhorman@tuxdriver.com>
struct rq isn't visible outside of sched.o so its near useless to
expose the pointer, also there are no users of it, so remove it.
Acked-by: Steven Rostedt <rostedt@goodmis.org>
LKML-Reference: <1272997616.1642.207.camel@laptop>
Name space cleanup. No functional change.
Acked-by: Peter Zijlstra <peterz@infradead.org>
Further name space cleanup. No functional change
The raw_spin* namespace was taken by lockdep for the architecture
specific implementations. raw_spin_* would be the ideal name space for
the spinlocks which are not converted to sleeping locks in preempt-rt.
Linus suggested to convert the raw_ to arch_ locks and cleanup the
name space instead of using an artifical name like core_spin,
atomic_spin or whatever
The state of the function pair tracing_stop()/tracing_start() is
correctly considered when tracer data are updated. However, the global
and externally accessible variable tracing_max_latency is always updated
- even when tracing is stopped.
The update should only occur, if tracing was not stopped.
Signed-off-by: Carsten Emde <C.Emde@osadl.org>
When the nsecs_to_usecs() conversion in probe_wakeup_sched_switch() and
check_critical_timing() was moved to a later stage in order to avoid
unnecessary computing, it was overlooked to remove the original
variables, assignments and comments..
The wakeup tracer, when enabled, has its own function tracer.
It only traces the functions on the CPU where the task it is following
is on. If a task is woken on one CPU but then migrates to another CPU
before it wakes up, the latency tracer will then start tracing functions
on the other CPU.
To find which CPU the task is on, the wakeup function tracer performs
a task_cpu(wakeup_task). But to make sure the task does not disappear
it grabs the wakeup_lock, which is also taken when the task wakes up.
By taking this lock, the function tracer does not need to worry about
the task being freed as it checks its cpu.
Jan Blunck found a problem with this approach on his 32 CPU box. When
a task is being traced by the wakeup tracer, all functions take this
lock. That means that on all 32 CPUs, each function call is taking
this one lock to see if the task is on that CPU. This lock has just
serialized all functions on all 32 CPUs. Needless to say, this caused
major issues on that box. It would even lockup.
This patch changes the wakeup latency to insert a probe on the migrate task
tracepoint. When a task changes its CPU that it will run on, the
probe will take note. Now the wakeup function tracer no longer needs
to take the lock. It only compares the current CPU with a variable that
holds the current CPU the task is on. We don't worry about races since
it is OK to add or miss a function trace.
Reported-by: Jan Blunck <jblunck@suse.de>
Tested-by: Jan Blunck <jblunck@suse.de>
Currently the latency tracers reset the ring buffer. Unfortunately
if a commit is in process (due to a trace event), this can corrupt
the ring buffer. When this happens, the ring buffer will detect
the corruption and then permanently disable the ring buffer.
The bug does not crash the system, but it does prevent further tracing
after the bug is hit.
Instead of reseting the trace buffers, the timestamp of the start of
the trace is used instead. The buffers will still contain the previous
data, but the output will not count any data that is before the
timestamp of the trace.
Note, this only affects the static trace output (trace) and not the
runtime trace output (trace_pipe). The runtime trace output does not
make sense for the latency tracers anyway.
Reported-by: Arnaldo Carvalho de Melo <acme@redhat.com>
The code had the following outside the lock:
if (next != wakeup_task)
return;
pc = preempt_count();
/* The task we are waiting for is waking up */
data = wakeup_trace->data[wakeup_cpu];
On initialization, wakeup_task is NULL and wakeup_cpu -1. This code
is not under a lock. If wakeup_task is set on another CPU as that
task is waking up, we can see the wakeup_task before wakeup_cpu is
set. If we read wakeup_cpu while it is still -1 then we will have
a bad data pointer.
This patch moves the reading of wakeup_cpu within the protection of
the spinlock used to protect the writing of wakeup_cpu and wakeup_task.
[ Impact: remove possible race causing invalid pointer dereference ]
Reported-by: Maneesh Soni <maneesh@in.ibm.com>
Signed-off-by: Steven Rostedt <srostedt@redhat.com>
Impact: clean up
Create a sub directory in include/trace called events to keep the
trace point headers in their own separate directory. Only headers that
declare trace points should be defined in this directory.
Cc: Zhao Lei <zhaolei@cn.fujitsu.com>
Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro>
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
Maneesh Soni was getting a crash when running the wakeup tracer.
We debugged it down to the recording of the function with the
CALLER_ADDR2 macro. This is used to get the location of the caller
to schedule.
But the problem comes when schedule is called by assmebly. In the case
that Maneesh had, retint_careful would call schedule. But retint_careful
does not set up a proper frame pointer. CALLER_ADDR2 is defined as
__builtin_return_address(2). This produces the following assembly in
the wakeup tracer code.
mov 0x0(%rbp),%rcx <--- get the frame pointer of the caller
mov %r14d,%r8d
mov 0xf2de8e(%rip),%rdi
mov 0x8(%rcx),%rsi <-- this is __builtin_return_address(1)
mov 0x28(%rdi,%rax,8),%rbx
mov (%rcx),%rax <-- get the frame pointer of the caller's caller
mov %r12,%rcx
mov 0x8(%rax),%rdx <-- this is __builtin_return_address(2)
At the reading of 0x8(%rax) Maneesh's machine would take a fault.
The reason is that retint_careful did not set up the return address
and the content of %rax here was zero.
To verify this, I sent Maneesh a patch to create a frame pointer
in retint_careful. He ran the test again but this time he would take
the same type of fault from sysret_careful. The retint_careful was no
longer an issue, but there are other callers that still have issues.
Instead of adding frame pointers for all callers to schedule (in possibly
all archs), it is much safer to simply not use CALLER_ADDR2. This
loses out on knowing what called schedule, but the function tracer
will help there if needed.
The latency tracers (irqsoff, preemptoff, preemptirqsoff, and wakeup)
are pretty useless with the default output format. This patch makes them
automatically enable the latency format when they are selected. They
also record the state of the latency option, and if it was not enabled
when selected, they disable it on reset.
Impact: api and pipe waiting change
Currently, the waiting used in tracing_read_pipe() is done through a
100 msecs schedule_timeout() loop which periodically check if there
are traces on the buffer.
This can cause small latencies for programs which are reading the incoming
events.
This patch makes the reader waiting for the trace_wait waitqueue except
for few tracers such as the sched and functions tracers which might be
already hold the runqueue lock while waking up the reader.
This is performed through a new callback wait_pipe() on struct tracer.
If none is implemented on a specific tracer, the default waiting for
trace_wait queue is attached.
Impact: cleanup
Fix incorrect hint message in code and typos in comments.
Signed-off-by: Wenji Huang <wenji.huang@oracle.com>
Impact: cleanup
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Impact: cleanup
Impact: better data for wakeup tracer
This patch adds the wakeup and schedule calls that are used by
the scheduler tracer to make the wakeup tracer more readable.
Impact: add option to trace all tasks or just RT tasks
The current wakeup tracer only traces RT task wakeups. This is
fine for those interested in wake up timings of RT tasks, but
it is useless for those that are interested in the causes
of long wakeups for non RT tasks.
This patch creates a "wakeup_rt" to implement the tracing of just
RT tasks (as the current "wakeup" does). And makes "wakeup" now
trace all tasks as an average developer would expect.
Impact: fix to erased trace output
To try not to have the outputing of a trace interfere with the wakeup
tracer, it would disable tracing while the output was printing. But
if a trace had started when it was disabled, it can show a partial
trace. To try to solve this, on closing of the tracer, it would
clear the trace buffer.
The latency tracers (wakeup and irqsoff) have two buffers. One for
recording and one for holding the max trace that is printed. The
clearing of the trace above should only affect the recording buffer.
But for some reason it would move the erased trace to the print
buffer. Probably due to a race with the closing of the trace and
the saving ofhe max race.
The above is all pretty useless, and if the user does not want the
printing of the trace to be traced itself, then the user can manual
disable tracing. This patch removes all the code that tries to keep
the output of the tracer from modifying the trace.
Impact: trace max latencies on start of latency tracing
This patch sets the max latency to zero whenever one of the
irq variant tracers or the wakeup tracer is set to current tracer.
Most developers expect to see output when starting up a latency
tracer. But since the max_latency is already set to max, and
it takes a latency greater than max_latency to be recorded, there
is no trace. This is not the expected behavior and has even confused
myself.
Impact: extend the wakeup tracepoint with the info whether the wakeup was real
Add the information needed to distinguish 'real' wakeups from 'false'
wakeups.
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Impact: extend the ->init() method with the ability to fail
This bring a way to know if the initialization of a tracer successed.
A tracer must return 0 on success and a traditional error (ie:
-ENOMEM) if it fails.
If a tracer fails to init, it is free to print a detailed warn. The
tracing api will not and switch to a new tracer will just return the
error from the init callback.
Note: this will be used for the return tracer.
Impact: remove obsolete variable in trace_array structure
With the new start / stop method of ftrace, the ctrl variable
in the trace_array structure is now obsolete. Remove it.
Impact: Remove the ctrl_update tracer method
With the new quick start/stop method of tracing, the ctrl_update
method is out of date.
Impact: change where tracing is started up and stopped
Currently, when a new tracer is selected via echo'ing a tracer name into
the current_tracer file, the startup is only done if tracing_enabled is
set to one. If tracing_enabled is changed to zero (by echo'ing 0 into
the tracing_enabled file) a full shutdown is performed.
The full startup and shutdown of a tracer can be expensive and the
user can lose out traces when echo'ing in 0 to the tracing_enabled file,
because the process takes too long. There can also be places that
the user would like to start and stop the tracer several times and
doing the full startup and shutdown of a tracer might be too expensive.
This patch performs the full startup and shutdown when a tracer is
selected. It also adds a way to do a quick start or stop of a tracer.
The quick version is just a flag that prevents the tracing from
taking place, but the overhead of the code is still there.
For example, the startup of a tracer may enable tracepoints, or enable
the function tracer. The stop and start will just set a flag to
have the tracer ignore the calls when the tracepoint or function trace
is called. The overhead of the tracer may still be present when
the tracer is stopped, but no tracing will occur. Setting the tracer
to the 'nop' tracer (or any other tracer) will perform the shutdown
of the tracer which will disable the tracepoint or disable the
function tracer.
The tracing_enabled file will simply start or stop tracing.
This change is all internal. The end result for the user should be the same
as before. If tracing_enabled is not set, no trace will happen.
If tracing_enabled is set, then the trace will happen. The tracing_enabled
variable is static between tracers. Enabling tracing_enabled and
going to another tracer will keep tracing_enabled enabled. Same
is true with disabling tracing_enabled.
This patch will now provide a fast start/stop method to the users
for enabling or disabling tracing.
Note: There were two methods to the struct tracer that were never
used: The methods start and stop. These were to be used as a hook
to the reading of the trace output, but ended up not being
necessary. These two methods are now used to enable the start
and stop of each tracer, in case the tracer needs to do more than
just not write into the buffer. For example, the irqsoff tracer
must stop recording max latencies when tracing is stopped.
Impact: use new, consolidated APIs in ftrace plugins
This patch replaces the schedule safe preempt disable code with the
ftrace_preempt_disable() and ftrace_preempt_enable() safe functions.
Due to confusion between the ftrace infrastructure and the gcc profiling
tracer "ftrace", this patch renames the config options from FTRACE to
FUNCTION_TRACER. The other two names that are offspring from FTRACE
DYNAMIC_FTRACE and FTRACE_MCOUNT_RECORD will stay the same.
This patch was generated mostly by script, and partially by hand.
With the new ring buffer infrastructure in ftrace, I'm trying to make
ftrace a little more light weight.
This patch converts a lot of the local_irq_save/restore into
preempt_disable/enable. The original preempt count in a lot of cases
has to be sent in as a parameter so that it can be recorded correctly.
Some places were recording it incorrectly before anyway.
This is also laying the ground work to make ftrace a little bit
more reentrant, and remove all locking. The function tracers must
still protect from reentrancy.
Note: All the function tracers must be careful when using preempt_disable.
It must do the following:
resched = need_resched();
preempt_disable_notrace();
if (resched)
preempt_enable_no_resched_notrace();
else
preempt_enable_notrace();
The reason is that if this function traces schedule() itself, the
preempt_enable_notrace() will cause a schedule, which will lead
us into a recursive failure.
If we needed to reschedule before calling preempt_disable, we
should have already scheduled. Since we did not, this is most
likely that we should not and are probably inside a schedule
function.
If resched was not set, we still need to catch the need resched
flag being set when preemption was off and the if case at the
end will catch that for us.
This patch ports ftrace over to the new ring buffer.
Porting the trace_mark() used by ftrace to tracepoints. (cleanup)
Changelog :
- Change error messages : marker -> tracepoint
[ mingo@elte.hu: conflict resolutions ]
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
Acked-by: 'Peter Zijlstra' <peterz@infradead.org>
check_flags (ftrace)
On Wed, 16 Jul 2008, Vegard Nossum wrote:
> When booting 4d3702b6, I got this huge thing:
> Testing tracer wakeup: <4>------------[ cut here ]------------
> WARNING: at kernel/lockdep.c:2731 check_flags+0x123/0x160()
> Modules linked in:
> Pid: 1, comm: swapper Not tainted 2.6.26-crashing-02127-g4d3702b6 #30
> [<c015c349>] warn_on_slowpath+0x59/0xb0
> [<c01276c6>] ? ftrace_call+0x5/0x8
> [<c012d800>] ? native_read_tsc+0x0/0x20
> [<c0158de2>] ? sub_preempt_count+0x12/0xf0
> [<c01814eb>] ? trace_hardirqs_off+0xb/0x10
> [<c0182fbc>] ? __lock_acquire+0x2cc/0x1120
> [<c01276af>] ? mcount_call+0x5/0xa
> [<c017ff53>] check_flags+0x123/0x160
> [<c0183e61>] lock_acquire+0x51/0xd0
> [<c0613d4f>] _spin_lock_irqsave+0x5f/0xa0
> [<c01a8d45>] ? ftrace_record_ip+0xf5/0x220
> [<c02d5413>] ? debug_locks_off+0x3/0x50
> [<c01a8d45>] ftrace_record_ip+0xf5/0x220
> [<c01276af>] mcount_call+0x5/0xa
> [<c02d5418>] ? debug_locks_off+0x8/0x50
> [<c017ff27>] check_flags+0xf7/0x160
> [<c01affcd>] ? wakeup_tracer_call+0x6d/0xf0
> [<c01625e2>] ? _local_bh_enable+0x62/0xb0
> [<c0158ddd>] ? sub_preempt_count+0xd/0xf0
> [<c01affcd>] wakeup_tracer_call+0x6d/0xf0
> [<c0162724>] ? __do_softirq+0xf4/0x110
> [<c01afff1>] ? wakeup_tracer_call+0x91/0xf0
> [<c01276c6>] ftrace_call+0x5/0x8
> [<c01625e2>] _local_bh_enable+0x62/0xb0
> [<c0162724>] __do_softirq+0xf4/0x110
> [<c01627ed>] do_softirq+0xad/0xb0
> [<c0162a15>] irq_exit+0xa5/0xb0
> [<c013a506>] smp_apic_timer_interrupt+0x66/0xa0
> [<c02d3fac>] ? trace_hardirqs_off_thunk+0xc/0x10
> [<c0127449>] apic_timer_interrupt+0x2d/0x34
> [<c018007b>] ? find_usage_backwards+0xb/0xf0
> [<c0613a09>] ? _spin_unlock_irqrestore+0x69/0x80
> [<c014ef32>] tg_shares_up+0x132/0x1d0
> [<c014d2a2>] walk_tg_tree+0x62/0xa0
> [<c014ee00>] ? tg_shares_up+0x0/0x1d0
> [<c014a860>] ? tg_nop+0x0/0x10
> [<c015499d>] update_shares+0x5d/0x80
> [<c0154a2f>] try_to_wake_up+0x6f/0x280
> [<c01a8b90>] ? __ftrace_modify_code+0x0/0xc0
> [<c0154c94>] wake_up_process+0x14/0x20
> [<c01725f6>] kthread_create+0x66/0xb0
> [<c0195400>] ? do_stop+0x0/0x200
> [<c0195320>] ? __stop_machine_run+0x30/0xb0
> [<c0195340>] __stop_machine_run+0x50/0xb0
> [<c061242d>] ? mutex_unlock+0xd/0x10
> [<c01953cc>] stop_machine_run+0x2c/0x60
> [<c01a94d3>] unregister_ftrace_function+0x103/0x180
> [<c01b0517>] stop_wakeup_tracer+0x17/0x60
> [<c01b056f>] wakeup_tracer_ctrl_update+0xf/0x30
> [<c01ab8d5>] trace_selftest_startup_wakeup+0xb5/0x130
> [<c01ab950>] ? trace_wakeup_test_thread+0x0/0x70
> [<c01aadf5>] register_tracer+0x135/0x1b0
> [<c0877d02>] init_wakeup_tracer+0xd/0xf
> [<c085d437>] kernel_init+0x1a9/0x2ce
> [<c061397b>] ? _spin_unlock_irq+0x3b/0x60
> [<c02d3f9c>] ? trace_hardirqs_on_thunk+0xc/0x10
> [<c0877cf5>] ? init_wakeup_tracer+0x0/0xf
> [<c0182646>] ? trace_hardirqs_on_caller+0x126/0x180
> [<c01269c8>] ? restore_nocheck_notrace+0x0/0xe
> [<c085d28e>] ? kernel_init+0x0/0x2ce
> [<c01275fb>] kernel_thread_helper+0x7/0x10
> ---[ end trace a7919e7f17c0a725 ]---
> irq event stamp: 579530
> hardirqs last enabled at (579528): [<c01826ab>] trace_hardirqs_on+0xb/0x10
> hardirqs last disabled at (579529): [<c01814eb>] trace_hardirqs_off+0xb/0x10
> softirqs last enabled at (579530): [<c0162724>] __do_softirq+0xf4/0x110
> softirqs last disabled at (579517): [<c01627ed>] do_softirq+0xad/0xb0
> PASSED
> Incidentally, the kernel also hung while I was typing in this report.
Things get weird between lockdep and ftrace because ftrace can be called
within lockdep internal code (via the mcount pointer) and lockdep can be
called with ftrace (via spin_locks).
Tested-by: Vegard Nossum <vegard.nossum@gmail.com>
Enabling the wakeup tracer before enabling the function tracing causes
some strange results due to the dynamic enabling of the functions.
Cc: Steven Rostedt <srostedt@redhat.com>
This patch adds function tracing to the functions that are called
on the CPU of the task being traced.
Cc: pq@iki.fi
Cc: proski@gnu.org
Cc: sandmann@redhat.com
Cc: a.p.zijlstra@chello.nl
Porting ftrace to the marker infrastructure.
Don't need to chain to the wakeup tracer from the sched tracer, because markers
support multiple probes connected.
CC: Steven Rostedt <rostedt@goodmis.org>
printk called from wakeup critical timings and irqs off can
cause deadlocks since printk might do a wakeup itself. If the
call to printk happens with the runqueue lock held, it can
deadlock.
This patch protects the printk from being called in trace irqs off
with a test to see if the runqueue for the current CPU is locked.
If it is locked, the printk is skipped.
The wakeup always holds the runqueue lock, so the printk is
simply removed.
now that we have a kbuild method for notrace, no need to pollute the
C code with the annotations.
A new check was added in the ftrace function that wont trace if the CPU
trace buffer is disabled. Unfortunately, other tracers used ftrace() to
write to the buffer after they disabled it. The new disable check makes
these calls into a nop.
This patch changes the __ftrace that is called without the check into a
new api for the other tracers to use, called "trace_function". The other
tracers use this interface instead when the trace CPU buffer is already
disabled.
rename and uninline now() to ftrace_now().
factor out code and clean it up.
