path: root/kernel/trace
2010-06-10perf/tracing: Fix regression of perf losing kprobe eventsSteven Rostedt
With the addition of the code to shrink the kernel tracepoint infrastructure, we lost kprobes being traced by perf. The reason is that I tested if the "tp_event->class->perf_probe" existed before enabling it. This prevents "ftrace only" events (like the function trace events) from being enabled by perf. Unfortunately, kprobe events do not use perf_probe. This causes kprobes to be missed by perf. To fix this, we add the test to see if "tp_event->class->reg" exists as well as perf_probe. Normal trace events have only "perf_probe" but no "reg" function, and kprobes and syscalls have the "reg" but no "perf_probe". The ftrace unique events do not have either, so this is a valid test. If a kprobe or syscall is not to be probed by perf, the "reg" function is called anyway, and will return a failure and prevent perf from probing it. Reported-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Tested-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-05-31blktrace: Fix new kernel-doc warningsRandy Dunlap
Fix blktrace.c kernel-doc warnings: Warning(kernel/trace/blktrace.c:858): No description found for parameter 'ignore' Warning(kernel/trace/blktrace.c:890): No description found for parameter 'ignore' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20100529114507.c466fc1e.randy.dunlap@oracle.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-31perf_events, trace: Fix perf_trace_destroy(), mutex went missingPeter Zijlstra
Steve spotted I forgot to do the destroy under event_mutex. Reported-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1274451913.1674.1707.camel@laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-31perf_events, trace: Fix probe unregister racePeter Zijlstra
tracepoint_probe_unregister() does not synchronize against the probe callbacks, so do that explicitly. This properly serializes the callbacks and the free of the data used therein. Also, use this_cpu_ptr() where possible. Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1274438476.1674.1702.camel@laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-30Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf tui: Fix last use_browser problem related to .perfconfig perf symbols: Add the build id cache to the vmlinux path perf tui: Reset use_browser if stdout is not a tty ring-buffer: Move zeroing out excess in page to ring buffer code ring-buffer: Reset "real_end" when page is filled
2010-05-27Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (61 commits) tracing: Add __used annotation to event variable perf, trace: Fix !x86 build bug perf report: Support multiple events on the TUI perf annotate: Fix up usage of the build id cache x86/mmiotrace: Remove redundant instruction prefix checks perf annotate: Add TUI interface perf tui: Remove annotate from popup menu after failure perf report: Don't start the TUI if -D is used perf: Fix getline undeclared perf: Optimize perf_tp_event_match() perf: Remove more code from the fastpath perf: Optimize the !vmalloc backed buffer perf: Optimize perf_output_copy() perf: Fix wakeup storm for RO mmap()s perf-record: Share per-cpu buffers perf-record: Remove -M perf: Ensure that IOC_OUTPUT isn't used to create multi-writer buffers perf, trace: Optimize tracepoints by using per-tracepoint-per-cpu hlist to track events perf, trace: Optimize tracepoints by removing IRQ-disable from perf/tracepoint interaction perf tui: Allow disabling the TUI on a per command basis in ~/.perfconfig ...
2010-05-25ring-buffer: Move zeroing out excess in page to ring buffer codeSteven Rostedt
Currently the trace splice code zeros out the excess bytes in the page before sending it off to userspace. This is to make sure userspace is not getting anything it should not be when reading the pages, because the excess data was never initialized to zero before writing (for perfomance reasons). But the splice code has no business in doing this work, it should be done by the ring buffer. With the latest changes for recording lost events, the splice code gets it wrong anyway. Move the zeroing out of excess bytes into the ring buffer code. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-05-25ring-buffer: Reset "real_end" when page is filledSteven Rostedt
The code to store the "lost events" requires knowing the real end of the page. Since the 'commit' includes the padding at the end of a page a "real_end" variable was used to keep track of the end not including the padding. If events were lost, the reader can place the count of events in the padded area if there is enough room. The bug this patch fixes is that when we fill the page we do not reset the real_end variable, and if the writer had wrapped a few times, the real_end would be incorrect. This patch simply resets the real_end if the page was filled. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-05-25perf, trace: Fix !x86 build bugPeter Zijlstra
Patch b7e2ecef92 (perf, trace: Optimize tracepoints by removing IRQ-disable from perf/tracepoint interaction) made the unfortunate mistake of assuming the world is x86 only, correct this. The problem was that perf_fetch_caller_regs() did local_save_flags() into regs->flags, and I re-used that to remove another local_save_flags(), forgetting !x86 doesn't have regs->flags. Do the reverse, remove the local_save_flags() from perf_fetch_caller_regs() and let the ftrace site do the local_save_flags() instead. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Paul Mackerras <paulus@samba.org> Cc: acme@redhat.com Cc: efault@gmx.de Cc: fweisbec@gmail.com Cc: rostedt@goodmis.org LKML-Reference: <1274778175.5882.623.camel@twins> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-21Merge branch 'master' into for-2.6.35Jens Axboe
Conflicts: fs/ext3/fsync.c Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-05-21pipe: add support for shrinking and growing pipesJens Axboe
This patch adds F_GETPIPE_SZ and F_SETPIPE_SZ fcntl() actions for growing and shrinking the size of a pipe and adjusts pipe.c and splice.c (and relay and network splice) usage to work with these larger (or smaller) pipes. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-05-21Merge branch 'perf/core' of ↵Steven Rostedt
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip into trace/tip/tracing/core-7 Conflicts: include/linux/ftrace_event.h include/trace/ftrace.h kernel/trace/trace_event_perf.c kernel/trace/trace_kprobe.c kernel/trace/trace_syscalls.c Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-05-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (182 commits) [SCSI] aacraid: add an ifdef'd device delete case instead of taking the device offline [SCSI] aacraid: prohibit access to array container space [SCSI] aacraid: add support for handling ATA pass-through commands. [SCSI] aacraid: expose physical devices for models with newer firmware [SCSI] aacraid: respond automatically to volumes added by config tool [SCSI] fcoe: fix fcoe module ref counting [SCSI] libfcoe: FIP Keep-Alive messages for VPorts are sent with incorrect port_id and wwn [SCSI] libfcoe: Fix incorrect MAC address clearing [SCSI] fcoe: fix a circular locking issue with rtnl and sysfs mutex [SCSI] libfc: Move the port_id into lport [SCSI] fcoe: move link speed checking into its own routine [SCSI] libfc: Remove extra pointer check [SCSI] libfc: Remove unused fc_get_host_port_type [SCSI] fcoe: fixes wrong error exit in fcoe_create [SCSI] libfc: set seq_id for incoming sequence [SCSI] qla2xxx: Updates to ISP82xx support. [SCSI] qla2xxx: Optionally disable target reset. [SCSI] qla2xxx: ensure flash operation and host reset via sg_reset are mutually exclusive [SCSI] qla2xxx: Silence bogus warning by gcc for wrap and did. [SCSI] qla2xxx: T10 DIF support added. ...
2010-05-21perf, trace: Optimize tracepoints by using per-tracepoint-per-cpu hlist to ↵Peter Zijlstra
track events Avoid the swevent hash-table by using per-tracepoint hlists. Also, avoid conditionals on the fast path by ordering with probe unregister so that we should never get on the callback path without the data being there. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <20100521090710.473188012@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-21perf, trace: Optimize tracepoints by removing IRQ-disable from ↵Peter Zijlstra
perf/tracepoint interaction Improves performance. Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <1274259525.5605.10352.camel@twins> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-20Merge branch 'perf/urgent' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing into perf/core
2010-05-18perf/ftrace: Optimize perf/tracepoint interaction for single eventsPeter Zijlstra
When we've got but a single event per tracepoint there is no reason to try and multiplex it so don't. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Tested-by: Ingo Molnar <mingo@elte.hu> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-18Merge branch 'tracing-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: tracing: Fix "integer as NULL pointer" warning. tracing: Fix tracepoint.h DECLARE_TRACE() to allow more than one header tracing: Make the documentation clear on trace_event boot option ring-buffer: Wrap open-coded WARN_ONCE tracing: Convert nop macros to static inlines tracing: Fix sleep time function profiling tracing: Show sample std dev in function profiling tracing: Add documentation for trace commands mod, traceon/traceoff ring-buffer: Make benchmark handle missed events ring-buffer: Make non-consuming read less expensive with lots of cpus. tracing: Add graph output support for irqsoff tracer tracing: Have graph flags passed in to ouput functions tracing: Add ftrace events for graph tracer tracing: Dump either the oops's cpu source or all cpus buffers tracing: Fix uninitialized variable of tracing/trace output
2010-05-18Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (49 commits) stop_machine: Move local variable closer to the usage site in cpu_stop_cpu_callback() sched, wait: Use wrapper functions sched: Remove a stale comment ondemand: Make the iowait-is-busy time a sysfs tunable ondemand: Solve a big performance issue by counting IOWAIT time as busy sched: Intoduce get_cpu_iowait_time_us() sched: Eliminate the ts->idle_lastupdate field sched: Fold updating of the last_update_time_info into update_ts_time_stats() sched: Update the idle statistics in get_cpu_idle_time_us() sched: Introduce a function to update the idle statistics sched: Add a comment to get_cpu_idle_time_us() cpu_stop: add dummy implementation for UP sched: Remove rq argument to the tracepoints rcu: need barrier() in UP synchronize_sched_expedited() sched: correctly place paranioa memory barriers in synchronize_sched_expedited() sched: kill paranoia check in synchronize_sched_expedited() sched: replace migration_thread with cpu_stop stop_machine: reimplement using cpu_stop cpu_stop: implement stop_cpu[s]() sched: Fix select_idle_sibling() logic in select_task_rq_fair() ...
2010-05-18Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (311 commits) perf tools: Add mode to build without newt support perf symbols: symbol inconsistency message should be done only at verbose=1 perf tui: Add explicit -lslang option perf options: Type check all the remaining OPT_ variants perf options: Type check OPT_BOOLEAN and fix the offenders perf options: Check v type in OPT_U?INTEGER perf options: Introduce OPT_UINTEGER perf tui: Add workaround for slang < 2.1.4 perf record: Fix bug mismatch with -c option definition perf options: Introduce OPT_U64 perf tui: Add help window to show key associations perf tui: Make <- exit menus too perf newt: Add single key shortcuts for zoom into DSO and threads perf newt: Exit browser unconditionally when CTRL+C, q or Q is pressed perf newt: Fix the 'A'/'a' shortcut for annotate perf newt: Make <- exit the ui_browser x86, perf: P4 PMU - fix counters management logic perf newt: Make <- zoom out filters perf report: Report number of events, not samples perf hist: Clarify events_stats fields usage ... Fix up trivial conflicts in kernel/fork.c and tools/perf/builtin-record.c
2010-05-18Merge branch 'perf/core' of ↵Steven Rostedt
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip into trace/tip/tracing/core-6 Conflicts: include/trace/ftrace.h kernel/trace/trace_kprobe.c Acked-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-05-14tracing: Fix function declarations if !CONFIG_STACKTRACELi Zefan
ftrace_trace_stack() and frace_trace_userstacke() take a struct ring_buffer argument, not struct trace_array. Commit e77405ad("tracing: pass around ring buffer instead of tracer") made this change. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> LKML-Reference: <4BE77C14.5010806@cn.fujitsu.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-05-14tracing: Combine event filter_active and enable into single flags fieldSteven Rostedt
The filter_active and enable both use an int (4 bytes each) to set a single flag. We can save 4 bytes per event by combining the two into a single integer. text data bss dec hex filename 4913961 1088356 861512 6863829 68bbd5 vmlinux.orig 4894944 1018052 861512 6774508 675eec vmlinux.id 4894871 1012292 861512 6768675 674823 vmlinux.flags This gives us another 5K in savings. The modification of both the enable and filter fields are done under the event_mutex, so it is still safe to combine the two. Note: Although Mathieu gave his Acked-by, he would like it documented that the reads of flags are not protected by the mutex. The way the code works, these reads will not break anything, but will have a residual effect. Since this behavior is the same even before this patch, describing this situation is left to another patch, as this patch does not change the behavior, but just brought it to Mathieu's attention. v2: Updated the event trace self test to for this change. Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Acked-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Tom Zanussi <tzanussi@gmail.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-05-14tracing: Remove duplicate id information in event structureSteven Rostedt
Now that the trace_event structure is embedded in the ftrace_event_call structure, there is no need for the ftrace_event_call id field. The id field is the same as the trace_event type field. Removing the id and re-arranging the structure brings down the tracepoint footprint by another 5K. text data bss dec hex filename 4913961 1088356 861512 6863829 68bbd5 vmlinux.orig 4895024 1023812 861512 6780348 6775bc vmlinux.print 4894944 1018052 861512 6774508 675eec vmlinux.id Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Acked-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-05-14tracing: Move print functions into event classSteven Rostedt
Currently, every event has its own trace_event structure. This is fine since the structure is needed anyway. But the print function structure (trace_event_functions) is now separate. Since the output of the trace event is done by the class (with the exception of events defined by DEFINE_EVENT_PRINT), it makes sense to have the class define the print functions that all events in the class can use. This makes a bigger deal with the syscall events since all syscall events use the same class. The savings here is another 30K. text data bss dec hex filename 4913961 1088356 861512 6863829 68bbd5 vmlinux.orig 4900382 1048964 861512 6810858 67ecea vmlinux.init 4900446 1049028 861512 6810986 67ed6a vmlinux.preprint 4895024 1023812 861512 6780348 6775bc vmlinux.print To accomplish this, and to let the class know what event is being printed, the event structure is embedded in the ftrace_event_call structure. This should not be an issues since the event structure was created for each event anyway. Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Acked-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-05-14tracing: Allow events to share their print functionsSteven Rostedt
Multiple events may use the same method to print their data. Instead of having all events have a pointer to their print funtions, the trace_event structure now points to a trace_event_functions structure that will hold the way to print ouf the event. The event itself is now passed to the print function to let the print function know what kind of event it should print. This opens the door to consolidating the way several events print their output. text data bss dec hex filename 4913961 1088356 861512 6863829 68bbd5 vmlinux.orig 4900382 1048964 861512 6810858 67ecea vmlinux.init 4900446 1049028 861512 6810986 67ed6a vmlinux.preprint This change slightly increases the size but is needed for the next change. v3: Fix the branch tracer events to handle this change. v2: Fix the new function graph tracer event calls to handle this change. Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Acked-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-05-14tracing: Move raw_init from events to classSteven Rostedt
The raw_init function pointer in the event is used to initialize various kinds of events. The type of initialization needed is usually classed to the kind of event it is. Two events with the same class will always have the same initialization function, so it makes sense to move this to the class structure. Perhaps even making a special system structure would work since the initialization is the same for all events within a system. But since there's no system structure (yet), this will just move it to the class. text data bss dec hex filename 4913961 1088356 861512 6863829 68bbd5 vmlinux.orig 4900375 1053380 861512 6815267 67fe23 vmlinux.fields 4900382 1048964 861512 6810858 67ecea vmlinux.init The text grew very slightly, but this is a constant growth that happened with the changing of the C files that call the init code. The bigger savings is the data which will be saved the more events share a class. Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Acked-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-05-14tracing: Move fields from event to class structureSteven Rostedt
Move the defined fields from the event to the class structure. Since the fields of the event are defined by the class they belong to, it makes sense to have the class hold the information instead of the individual events. The events of the same class would just hold duplicate information. After this change the size of the kernel dropped another 3K: text data bss dec hex filename 4913961 1088356 861512 6863829 68bbd5 vmlinux.orig 4900252 1057412 861512 6819176 680d68 vmlinux.regs 4900375 1053380 861512 6815267 67fe23 vmlinux.fields Although the text increased, this was mainly due to the C files having to adapt to the change. This is a constant increase, where new tracepoints will not increase the Text. But the big drop is in the data size (as well as needed allocations to hold the fields). This will give even more savings as more tracepoints are created. Note, if just TRACE_EVENT()s are used and not DECLARE_EVENT_CLASS() with several DEFINE_EVENT()s, then the savings will be lost. But we are pushing developers to consolidate events with DEFINE_EVENT() so this should not be an issue. The kprobes define a unique class to every new event, but are dynamic so it should not be a issue. The syscalls however have a single class but the fields for the individual events are different. The syscalls use a metadata to define the fields. I moved the fields list from the event to the metadata and added a "get_fields()" function to the class. This function is used to find the fields. For normal events and kprobes, get_fields() just returns a pointer to the fields list_head in the class. For syscall events, it returns the fields list_head in the metadata for the event. v2: Fixed the syscall fields. The syscall metadata needs a list of fields for both enter and exit. Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Acked-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-05-14tracing: Remove per event trace registeringSteven Rostedt
This patch removes the register functions of TRACE_EVENT() to enable and disable tracepoints. The registering of a event is now down directly in the trace_events.c file. The tracepoint_probe_register() is now called directly. The prototypes are no longer type checked, but this should not be an issue since the tracepoints are created automatically by the macros. If a prototype is incorrect in the TRACE_EVENT() macro, then other macros will catch it. The trace_event_class structure now holds the probes to be called by the callbacks. This removes needing to have each event have a separate pointer for the probe. To handle kprobes and syscalls, since they register probes in a different manner, a "reg" field is added to the ftrace_event_class structure. If the "reg" field is assigned, then it will be called for enabling and disabling of the probe for either ftrace or perf. To let the reg function know what is happening, a new enum (trace_reg) is created that has the type of control that is needed. With this new rework, the 82 kernel events and 618 syscall events has their footprint dramatically lowered: text data bss dec hex filename 4913961 1088356 861512 6863829 68bbd5 vmlinux.orig 4914025 1088868 861512 6864405 68be15 vmlinux.class 4918492 1084612 861512 6864616 68bee8 vmlinux.tracepoint 4900252 1057412 861512 6819176 680d68 vmlinux.regs The size went from 6863829 to 6819176, that's a total of 44K in savings. With tracepoints being continuously added, this is critical that the footprint becomes minimal. v5: Added #ifdef CONFIG_PERF_EVENTS around a reference to perf specific structure in trace_events.c. v4: Fixed trace self tests to check probe because regfunc no longer exists. v3: Updated to handle void *data in beginning of probe parameters. Also added the tracepoint: check_trace_callback_type_##call(). v2: Changed the callback probes to pass void * and typecast the value within the function. Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Acked-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-05-14tracing: Let tracepoints have data passed to tracepoint callbacksSteven Rostedt
This patch adds data to be passed to tracepoint callbacks. The created functions from DECLARE_TRACE() now need a mandatory data parameter. For example: DECLARE_TRACE(mytracepoint, int value, value) Will create the register function: int register_trace_mytracepoint((void(*)(void *data, int value))probe, void *data); As the first argument, all callbacks (probes) must take a (void *data) parameter. So a callback for the above tracepoint will look like: void myprobe(void *data, int value) { } The callback may choose to ignore the data parameter. This change allows callbacks to register a private data pointer along with the function probe. void mycallback(void *data, int value); register_trace_mytracepoint(mycallback, mydata); Then the mycallback() will receive the "mydata" as the first parameter before the args. A more detailed example: DECLARE_TRACE(mytracepoint, TP_PROTO(int status), TP_ARGS(status)); /* In the C file */ DEFINE_TRACE(mytracepoint, TP_PROTO(int status), TP_ARGS(status)); [...] trace_mytracepoint(status); /* In a file registering this tracepoint */ int my_callback(void *data, int status) { struct my_struct my_data = data; [...] } [...] my_data = kmalloc(sizeof(*my_data), GFP_KERNEL); init_my_data(my_data); register_trace_mytracepoint(my_callback, my_data); The same callback can also be registered to the same tracepoint as long as the data registered is different. Note, the data must also be used to unregister the callback: unregister_trace_mytracepoint(my_callback, my_data); Because of the data parameter, tracepoints declared this way can not have no args. That is: DECLARE_TRACE(mytracepoint, TP_PROTO(void), TP_ARGS()); will cause an error. If no arguments are needed, a new macro can be used instead: DECLARE_TRACE_NOARGS(mytracepoint); Since there are no arguments, the proto and args fields are left out. This is part of a series to make the tracepoint footprint smaller: text data bss dec hex filename 4913961 1088356 861512 6863829 68bbd5 vmlinux.orig 4914025 1088868 861512 6864405 68be15 vmlinux.class 4918492 1084612 861512 6864616 68bee8 vmlinux.tracepoint Again, this patch also increases the size of the kernel, but lays the ground work for decreasing it. v5: Fixed net/core/drop_monitor.c to handle these updates. v4: Moved the DECLARE_TRACE() DECLARE_TRACE_NOARGS out of the #ifdef CONFIG_TRACE_POINTS, since the two are the same in both cases. The __DECLARE_TRACE() is what changes. Thanks to Frederic Weisbecker for pointing this out. v3: Made all register_* functions require data to be passed and all callbacks to take a void * parameter as its first argument. This makes the calling functions comply with C standards. Also added more comments to the modifications of DECLARE_TRACE(). v2: Made the DECLARE_TRACE() have the ability to pass arguments and added a new DECLARE_TRACE_NOARGS() for tracepoints that do not need any arguments. Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Acked-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Neil Horman <nhorman@tuxdriver.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-05-14tracing: Create class struct for eventsSteven Rostedt
This patch creates a ftrace_event_class struct that event structs point to. This class struct will be made to hold information to modify the events. Currently the class struct only holds the events system name. This patch slightly increases the size, but this change lays the ground work of other changes to make the footprint of tracepoints smaller. With 82 standard tracepoints, and 618 system call tracepoints (two tracepoints per syscall: enter and exit): text data bss dec hex filename 4913961 1088356 861512 6863829 68bbd5 vmlinux.orig 4914025 1088868 861512 6864405 68be15 vmlinux.class This patch also cleans up some stale comments in ftrace.h. v2: Fixed missing semi-colon in macro. Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Acked-by: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-05-14Merge branch 'sched/core' of ↵Steven Rostedt
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip into trace/tip/tracing/core-4
2010-05-07sched: Remove rq argument to the tracepointsPeter Zijlstra
struct rq isn't visible outside of sched.o so its near useless to expose the pointer, also there are no users of it, so remove it. Acked-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1272997616.1642.207.camel@laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-06perf: Fix check at end of event searchDan Carpenter
The original code doesn't work because "call" is never NULL there. Signed-off-by: Dan Carpenter <error27@gmail.com> LKML-Reference: <20100320143911.GF5331@bicker> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-05-05tracing: Fix "integer as NULL pointer" warning.Thiago Farina
kernel/trace/trace_output.c:256:24: warning: Using plain integer as NULL pointer Signed-off-by: Thiago Farina <tfransosi@gmail.com> LKML-Reference: <1264349038-1766-3-git-send-email-tfransosi@gmail.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-05-04ring-buffer: Wrap open-coded WARN_ONCEBorislav Petkov
Wrap open-coded WARN_ONCE functionality into the equivalent macro. Signed-off-by: Borislav Petkov <bp@alien8.de> LKML-Reference: <20100502060354.GA5281@liondog.tnic> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-05-01hw-breakpoints: Get the number of available registers on boot dynamicallyFrederic Weisbecker
The breakpoint generic layer assumes that archs always know in advance the static number of address registers available to host breakpoints through the HBP_NUM macro. However this is not true for every archs. For example Arm needs to get this information dynamically to handle the compatiblity between different versions. To solve this, this patch proposes to drop the static HBP_NUM macro and let the arch provide the number of available slots through a new hw_breakpoint_slots() function. For archs that have CONFIG_HAVE_MIXED_BREAKPOINTS_REGS selected, it will be called once as the number of registers fits for instruction and data breakpoints together. For the others it will be called first to get the number of instruction breakpoint registers and another time to get the data breakpoint registers, the targeted type is given as a parameter of hw_breakpoint_slots(). Reported-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: Mahesh Salgaonkar <mahesh@linux.vnet.ibm.com> Cc: K. Prasad <prasad@linux.vnet.ibm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Jason Wessel <jason.wessel@windriver.com> Cc: Ingo Molnar <mingo@elte.hu>
2010-04-30[SCSI] add scsi trace core functions and put trace pointsKei Tokunaga
Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Signed-off-by: Tomohiro Kusumi <kusumi.tomohiro@jp.fujitsu.com> Signed-off-by: Kei Tokunaga <tokunaga.keiich@jp.fujitsu.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-04-30[SCSI] ftrace: add __print_hex()Kei Tokunaga
__print_hex() prints values in an array in hex (w/o '0x') (space separated) EX) 92 33 32 f3 ee 4d Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Tomohiro Kusumi <kusumi.tomohiro@jp.fujitsu.com> Signed-off-by: Kei Tokunaga <tokunaga.keiich@jp.fujitsu.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-04-27tracing: Fix sleep time function profilingSteven Rostedt
When sleep_time is off the function profiler ignores the time that a task is scheduled out. When the task is scheduled out a timestamp is taken. When the task is scheduled back in, the timestamp is compared to the current time and the saved calltimes are adjusted accordingly. But when stopping the function profiler, the sched switch hook that does this adjustment was stopped before shutting down the tracer. This allowed some tasks to not get their timestamps set when they scheduled out. When the function profiler started again, this would skew the times of the scheduler functions. This patch moves the stopping of the sched switch to after the function profiler is stopped. It also ignores zero set calltimes, which may happen on start up. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-04-27tracing: Show sample std dev in function profilingChase Douglas
When combined with function graph tracing the ftrace function profiler also prints the average run time of functions. While this gives us some good information, it doesn't tell us anything about the variance of the run times of the function. This change prints out the s^2 sample standard deviation alongside the average. This change adds one entry to the profile record structure. This increases the memory footprint of the function profiler by 1/3 on a 32-bit system, and by 1/5 on a 64-bit system when function graphing is enabled, though the memory is only allocated when the profiler is turned on. During the profiling, one extra line of code adds the squared calltime to the new record entry, so this should not adversly affect performance. Note that the square of the sample standard deviation is printed because there is no sqrt implementation for unsigned long long in the kernel. Signed-off-by: Chase Douglas <chase.douglas@canonical.com> LKML-Reference: <1272304925-2436-1-git-send-email-chase.douglas@canonical.com> [ fixed comment about ns^2 -> us^2 conversion ] Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-04-27ring-buffer: Make benchmark handle missed eventsSteven Rostedt
With the addition of the "missed events" flags that is stored in the commit field of the ring buffer page, the ring_buffer_benchmark was not updated to handle this. If events are missed, then the missed events flag is set in the ring buffer page, the benchmark will count that flag as part of the size of the page and will hit the BUG() when it tries to read beyond the page. The solution is simply to have the ring buffer benchmark mask off the extra bits. Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-04-27ring-buffer: Make non-consuming read less expensive with lots of cpus.David Miller
When performing a non-consuming read, a synchronize_sched() is performed once for every cpu which is actively tracing. This is very expensive, and can make it take several seconds to open up the 'trace' file with lots of cpus. Only one synchronize_sched() call is actually necessary. What is desired is for all cpus to see the disabling state change. So we transform the existing sequence: for_each_cpu() { ring_buffer_read_start(); } where each ring_buffer_start() call performs a synchronize_sched(), into the following: for_each_cpu() { ring_buffer_read_prepare(); } ring_buffer_read_prepare_sync(); for_each_cpu() { ring_buffer_read_start(); } wherein only the single ring_buffer_read_prepare_sync() call needs to do the synchronize_sched(). The first phase, via ring_buffer_read_prepare(), allocates the 'iter' memory and increments ->record_disabled. In the second phase, ring_buffer_read_prepare_sync() makes sure this ->record_disabled state is visible fully to all cpus. And in the final third phase, the ring_buffer_read_start() calls reset the 'iter' objects allocated in the first phase since we now know that none of the cpus are adding trace entries any more. This makes openning the 'trace' file nearly instantaneous on a sparc64 Niagara2 box with 128 cpus tracing. Signed-off-by: David S. Miller <davem@davemloft.net> LKML-Reference: <20100420.154711.11246950.davem@davemloft.net> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-04-27tracing: Add graph output support for irqsoff tracerJiri Olsa
Add function graph output to irqsoff tracer. The graph output is enabled by setting new 'display-graph' trace option. Signed-off-by: Jiri Olsa <jolsa@redhat.com> LKML-Reference: <1270227683-14631-4-git-send-email-jolsa@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-04-26tracing: Have graph flags passed in to ouput functionsJiri Olsa
Let the function graph tracer have custom flags passed to its output functions. Signed-off-by: Jiri Olsa <jolsa@redhat.com> LKML-Reference: <1270227683-14631-3-git-send-email-jolsa@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-04-26tracing: Add ftrace events for graph tracerJiri Olsa
Add ftrace events for graph tracer, so the graph output could be shared with other tracers. Signed-off-by: Jiri Olsa <jolsa@redhat.com> LKML-Reference: <1270227683-14631-2-git-send-email-jolsa@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-04-21tracing: Dump either the oops's cpu source or all cpus buffersFrederic Weisbecker
The ftrace_dump_on_oops kernel parameter, sysctl and sysrq let one dump every cpu buffers when an oops or panic happens. It's nice when you have few cpus but it may take ages if have many, plus you miss the real origin of the problem in all the cpu traces. Sometimes, all you need is to dump the cpu buffer that triggered the opps, most of the time it is our main interest. This patch modifies ftrace_dump_on_oops to handle this choice. The ftrace_dump_on_oops kernel parameter, when it comes alone, has the same behaviour than before. But ftrace_dump_on_oops=orig_cpu will only dump the buffer of the cpu that oops'ed. Similarly, sysctl kernel.ftrace_dump_on_oops=1 and echo 1 > /proc/sys/kernel/ftrace_dump_on_oops keep their previous behaviour. But setting 2 jumps into cpu origin dump mode. v2: Fix double setup v3: Fix spelling issues reported by Randy Dunlap v4: Also update __ftrace_dump in the selftests Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
2010-04-14tracing/kprobes: Support basic types on dynamic eventsMasami Hiramatsu
Support basic types of integer (u8, u16, u32, u64, s8, s16, s32, s64) in kprobe tracer. With this patch, users can specify above basic types on each arguments after ':'. If omitted, the argument type is set as unsigned long (u32 or u64, arch-dependent). e.g. echo 'p account_system_time+0 hardirq_offset=%si:s32' > kprobe_events adds a probe recording hardirq_offset in signed-32bits value on the entry of account_system_time. Cc: Ingo Molnar <mingo@elte.hu> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20100412171708.3790.18599.stgit@localhost6.localdomain6> Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-04-14Merge branch 'tip/tracing/core' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into tracing/core
2010-04-08Merge branch 'linus' into perf/coreIngo Molnar
Semantic conflict: arch/x86/kernel/cpu/perf_event_intel_ds.c Merge reason: pick up latest fixes, fix the conflict Signed-off-by: Ingo Molnar <mingo@elte.hu>
