path: root/kernel/user.c
2011-03-23userns: add a user_namespace as creator/owner of uts_namespaceSerge E. Hallyn
The expected course of development for user namespaces targeted capabilities is laid out at https://wiki.ubuntu.com/UserNamespace. Goals: - Make it safe for an unprivileged user to unshare namespaces. They will be privileged with respect to the new namespace, but this should only include resources which the unprivileged user already owns. - Provide separate limits and accounting for userids in different namespaces. Status: Currently (as of 2.6.38) you can clone with the CLONE_NEWUSER flag to get a new user namespace if you have the CAP_SYS_ADMIN, CAP_SETUID, and CAP_SETGID capabilities. What this gets you is a whole new set of userids, meaning that user 500 will have a different 'struct user' in your namespace than in other namespaces. So any accounting information stored in struct user will be unique to your namespace. However, throughout the kernel there are checks which - simply check for a capability. Since root in a child namespace has all capabilities, this means that a child namespace is not constrained. - simply compare uid1 == uid2. Since these are the integer uids, uid 500 in namespace 1 will be said to be equal to uid 500 in namespace 2. As a result, the lxc implementation at lxc.sf.net does not use user namespaces. This is actually helpful because it leaves us free to develop user namespaces in such a way that, for some time, user namespaces may be unuseful. Bugs aside, this patchset is supposed to not at all affect systems which are not actively using user namespaces, and only restrict what tasks in child user namespace can do. They begin to limit privilege to a user namespace, so that root in a container cannot kill or ptrace tasks in the parent user namespace, and can only get world access rights to files. Since all files currently belong to the initila user namespace, that means that child user namespaces can only get world access rights to *all* files. While this temporarily makes user namespaces bad for system containers, it starts to get useful for some sandboxing. I've run the 'runltplite.sh' with and without this patchset and found no difference. This patch: copy_process() handles CLONE_NEWUSER before the rest of the namespaces. So in the case of clone(CLONE_NEWUSER|CLONE_NEWUTS) the new uts namespace will have the new user namespace as its owner. That is what we want, since we want root in that new userns to be able to have privilege over it. Changelog: Feb 15: don't set uts_ns->user_ns if we didn't create a new uts_ns. Feb 23: Move extern init_user_ns declaration from init/version.c to utsname.h. Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-29fix freeing user_struct in user cacheHillf Danton
When racing on adding into user cache, the new allocated from mm slab is freed without putting user namespace. Since the user namespace is already operated by getting, putting has to be issued. Signed-off-by: Hillf Danton <dhillf@gmail.com> Acked-by: Serge Hallyn <serge@hallyn.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26kernel/user.c: add lock release annotation on free_user()Namhyung Kim
free_user() releases uidhash_lock but was missing annotation. Add it. This removes following sparse warnings: include/linux/spinlock.h:339:9: warning: context imbalance in 'free_user' - unexpected unlock kernel/user.c:120:6: warning: context imbalance in 'free_uid' - wrong count at exit Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Dhaval Giani <dhaval.giani@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-10sched: Remove a stale commentLi Zefan
This comment should have been removed together with uids_mutex when removing user sched. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Dhaval Giani <dhaval.giani@gmail.com> LKML-Reference: <4BE77C6B.5010402@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-02sched: Remove remaining USER_SCHED codeLi Zefan
This is left over from commit 7c9414385e ("sched: Remove USER_SCHED"") Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Dhaval Giani <dhaval.giani@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: David Howells <dhowells@redhat.com> LKML-Reference: <4BA9A05F.7010407@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-16sched: Remove some dead codeDan Carpenter
This was left over from "7c9414385e sched: Remove USER_SCHED" Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Dhaval Giani <dhaval.giani@gmail.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Greg Kroah-Hartman <gregkh@suse.de> LKML-Reference: <20100315082148.GD18181@bicker> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-01-21sched: Remove USER_SCHEDDhaval Giani
Remove the USER_SCHED feature. It has been scheduled to be removed in 2.6.34 as per http://marc.info/?l=linux-kernel&m=125728479022976&w=2 Signed-off-by: Dhaval Giani <dhaval.giani@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1263990378.24844.3.camel@localhost> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-02uids: Prevent tear down raceThomas Gleixner
Ingo triggered the following warning: WARNING: at lib/debugobjects.c:255 debug_print_object+0x42/0x50() Hardware name: System Product Name ODEBUG: init active object type: timer_list Modules linked in: Pid: 2619, comm: dmesg Tainted: G W 2.6.32-rc5-tip+ #5298 Call Trace: [<81035443>] warn_slowpath_common+0x6a/0x81 [<8120e483>] ? debug_print_object+0x42/0x50 [<81035498>] warn_slowpath_fmt+0x29/0x2c [<8120e483>] debug_print_object+0x42/0x50 [<8120ec2a>] __debug_object_init+0x279/0x2d7 [<8120ecb3>] debug_object_init+0x13/0x18 [<810409d2>] init_timer_key+0x17/0x6f [<81041526>] free_uid+0x50/0x6c [<8104ed2d>] put_cred_rcu+0x61/0x72 [<81067fac>] rcu_do_batch+0x70/0x121 debugobjects warns about an enqueued timer being initialized. If CONFIG_USER_SCHED=y the user management code uses delayed work to remove the user from the hash table and tear down the sysfs objects. free_uid is called from RCU and initializes/schedules delayed work if the usage count of the user_struct is 0. The init/schedule happens outside of the uidhash_lock protected region which allows a concurrent caller of find_user() to reference the about to be destroyed user_struct w/o preventing the work from being scheduled. If the next free_uid call happens before the work timer expired then the active timer is initialized and the work scheduled again. The race was introduced in commit 5cb350ba (sched: group scheduling, sysfs tunables) and made more prominent by commit 3959214f (sched: delayed cleanup of user_struct) Move the init/schedule_delayed_work inside of the uidhash_lock protected region to prevent the race. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Dhaval Giani <dhaval@linux.vnet.ibm.com> Cc: Paul E. McKenney <paulmck@us.ibm.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: stable@kernel.org
2009-06-15sched: delayed cleanup of user_structKay Sievers
During bootup performance tracing we see repeated occurrences of /sys/kernel/uid/* events for the same uid, leading to a, in this case, rather pointless userspace processing for the same uid over and over. This is usually caused by tools which change their uid to "nobody", to run without privileges to read data supplied by untrusted users. This change delays the execution of the (already existing) scheduled work, to cleanup the uid after one second, so the allocated and announced uid can possibly be re-used by another process. This is the current behavior, where almost every invocation of a binary, which changes the uid, creates two events: $ read START < /sys/kernel/uevent_seqnum; \ for i in `seq 100`; do su --shell=/bin/true bin; done; \ read END < /sys/kernel/uevent_seqnum; \ echo $(($END - $START)) 178 With the delayed cleanup, we get only two events, and userspace finishes a bit faster too: $ read START < /sys/kernel/uevent_seqnum; \ for i in `seq 100`; do su --shell=/bin/true bin; done; \ read END < /sys/kernel/uevent_seqnum; \ echo $(($END - $START)) 1 Acked-by: Dhaval Giani <dhaval@linux.vnet.ibm.com> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24Merge branch 'master' into nextJames Morris
2009-03-10kernel/user.c: fix a memory leak when freeing up non-init usernamespaces usersDhaval Giani
We were returning early in the sysfs directory cleanup function if the user belonged to a non init usernamespace. Due to this a lot of the cleanup was not done and we were left with a leak. Fix the leak. Reported-by: Serge Hallyn <serue@linux.vnet.ibm.com> Signed-off-by: Dhaval Giani <dhaval@linux.vnet.ibm.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Tested-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-27sched: don't allow setuid to succeed if the user does not have rt bandwidthDhaval Giani
Impact: fix hung task with certain (non-default) rt-limit settings Corey Hickey reported that on using setuid to change the uid of a rt process, the process would be unkillable and not be running. This is because there was no rt runtime for that user group. Add in a check to see if a user can attach an rt task to its task group. On failure, return EINVAL, which is also returned in CONFIG_CGROUP_SCHED. Reported-by: Corey Hickey <bugfood-ml@fatooh.org> Signed-off-by: Dhaval Giani <dhaval@linux.vnet.ibm.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-27keys: distinguish per-uid keys in different namespacesSerge E. Hallyn
per-uid keys were looked by uid only. Use the user namespace to distinguish the same uid in different namespaces. This does not address key_permission. So a task can for instance try to join a keyring owned by the same uid in another namespace. That will be handled by a separate patch. Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-02-13User namespaces: Only put the userns when we unhash the uidSerge E. Hallyn
uids in namespaces other than init don't get a sysfs entry. For those in the init namespace, while we're waiting to remove the sysfs entry for the uid the uid is still hashed, and alloc_uid() may re-grab that uid without getting a new reference to the user_ns, which we've already put in free_user before scheduling remove_user_sysfs_dir(). Reported-and-tested-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Acked-by: David Howells <dhowells@redhat.com> Tested-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-28Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (31 commits) sched: fix warning in fs/proc/base.c schedstat: consolidate per-task cpu runtime stats sched: use RCU variant of list traversal in for_each_leaf_rt_rq() sched, cpuacct: export percpu cpuacct cgroup stats sched, cpuacct: refactoring cpuusage_read / cpuusage_write sched: optimize update_curr() sched: fix wakeup preemption clock sched: add missing arch_update_cpu_topology() call sched: let arch_update_cpu_topology indicate if topology changed sched: idle_balance() does not call load_balance_newidle() sched: fix sd_parent_degenerate on non-numa smp machine sched: add uid information to sched_debug for CONFIG_USER_SCHED sched: move double_unlock_balance() higher sched: update comment for move_task_off_dead_cpu sched: fix inconsistency when redistribute per-cpu tg->cfs_rq shares sched/rt: removed unneeded defintion sched: add hierarchical accounting to cpu accounting controller sched: include group statistics in /proc/sched_debug sched: rename SCHED_NO_NO_OMIT_FRAME_POINTER => SCHED_OMIT_FRAME_POINTER sched: clean up SCHED_CPUMASK_ALLOC ...
2008-12-09user namespaces: document CFS behaviorSerge E. Hallyn
Documented the currently bogus state of support for CFS user groups with user namespaces. In particular, all users in a user namespace should be children of the user which created the user namespace. This is yet to be implemented. Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Acked-by: Dhaval Giani <dhaval@linux.vnet.ibm.com> Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-12-08user namespaces: let user_ns be cloned with fairschedSerge E. Hallyn
(These two patches are in the next-unacked branch of git://git.kernel.org/pub/scm/linux/kernel/git/sergeh/userns-2.6. If they get some ACKs, then I hope to feed this into security-next. After these two, I think we're ready to tackle userns+capabilities) Fairsched creates a per-uid directory under /sys/kernel/uids/. So when you clone(CLONE_NEWUSER), it tries to create /sys/kernel/uids/0, which already exists, and you get back -ENOMEM. This was supposed to be fixed by sysfs tagging, but that was postponed (ok, rejected until sysfs locking is fixed). So, just as with network namespaces, we just don't create those directories for user namespaces other than the init. Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-12-01sched: add uid information to sched_debug for CONFIG_USER_SCHEDArun R Bharadwaj
Impact: extend information in /proc/sched_debug This patch adds uid information in sched_debug for CONFIG_USER_SCHED Signed-off-by: Arun R Bharadwaj <arun@linux.vnet.ibm.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-24User namespaces: use the current_user_ns() macroSerge Hallyn
Fix up the last current_user()->user_ns instance to use current_user_ns(). Signed-off-by: Serge E. Hallyn <serue@us.ibm.com>
2008-11-24User namespaces: set of cleanups (v2)Serge Hallyn
The user_ns is moved from nsproxy to user_struct, so that a struct cred by itself is sufficient to determine access (which it otherwise would not be). Corresponding ecryptfs fixes (by David Howells) are here as well. Fix refcounting. The following rules now apply: 1. The task pins the user struct. 2. The user struct pins its user namespace. 3. The user namespace pins the struct user which created it. User namespaces are cloned during copy_creds(). Unsharing a new user_ns is no longer possible. (We could re-add that, but it'll cause code duplication and doesn't seem useful if PAM doesn't need to clone user namespaces). When a user namespace is created, its first user (uid 0) gets empty keyrings and a clean group_info. This incorporates a previous patch by David Howells. Here is his original patch description: >I suggest adding the attached incremental patch. It makes the following >changes: > > (1) Provides a current_user_ns() macro to wrap accesses to current's user > namespace. > > (2) Fixes eCryptFS. > > (3) Renames create_new_userns() to create_user_ns() to be more consistent > with the other associated functions and because the 'new' in the name is > superfluous. > > (4) Moves the argument and permission checks made for CLONE_NEWUSER to the > beginning of do_fork() so that they're done prior to making any attempts > at allocation. > > (5) Calls create_user_ns() after prepare_creds(), and gives it the new creds > to fill in rather than have it return the new root user. I don't imagine > the new root user being used for anything other than filling in a cred > struct. > > This also permits me to get rid of a get_uid() and a free_uid(), as the > reference the creds were holding on the old user_struct can just be > transferred to the new namespace's creator pointer. > > (6) Makes create_user_ns() reset the UIDs and GIDs of the creds under > preparation rather than doing it in copy_creds(). > >David >Signed-off-by: David Howells <dhowells@redhat.com> Changelog: Oct 20: integrate dhowells comments 1. leave thread_keyring alone 2. use current_user_ns() in set_user() Signed-off-by: Serge Hallyn <serue@us.ibm.com>
2008-11-14CRED: Inaugurate COW credentialsDavid Howells
Inaugurate copy-on-write credentials management. This uses RCU to manage the credentials pointer in the task_struct with respect to accesses by other tasks. A process may only modify its own credentials, and so does not need locking to access or modify its own credentials. A mutex (cred_replace_mutex) is added to the task_struct to control the effect of PTRACE_ATTACHED on credential calculations, particularly with respect to execve(). With this patch, the contents of an active credentials struct may not be changed directly; rather a new set of credentials must be prepared, modified and committed using something like the following sequence of events: struct cred *new = prepare_creds(); int ret = blah(new); if (ret < 0) { abort_creds(new); return ret; } return commit_creds(new); There are some exceptions to this rule: the keyrings pointed to by the active credentials may be instantiated - keyrings violate the COW rule as managing COW keyrings is tricky, given that it is possible for a task to directly alter the keys in a keyring in use by another task. To help enforce this, various pointers to sets of credentials, such as those in the task_struct, are declared const. The purpose of this is compile-time discouragement of altering credentials through those pointers. Once a set of credentials has been made public through one of these pointers, it may not be modified, except under special circumstances: (1) Its reference count may incremented and decremented. (2) The keyrings to which it points may be modified, but not replaced. The only safe way to modify anything else is to create a replacement and commit using the functions described in Documentation/credentials.txt (which will be added by a later patch). This patch and the preceding patches have been tested with the LTP SELinux testsuite. This patch makes several logical sets of alteration: (1) execve(). This now prepares and commits credentials in various places in the security code rather than altering the current creds directly. (2) Temporary credential overrides. do_coredump() and sys_faccessat() now prepare their own credentials and temporarily override the ones currently on the acting thread, whilst preventing interference from other threads by holding cred_replace_mutex on the thread being dumped. This will be replaced in a future patch by something that hands down the credentials directly to the functions being called, rather than altering the task's objective credentials. (3) LSM interface. A number of functions have been changed, added or removed: (*) security_capset_check(), ->capset_check() (*) security_capset_set(), ->capset_set() Removed in favour of security_capset(). (*) security_capset(), ->capset() New. This is passed a pointer to the new creds, a pointer to the old creds and the proposed capability sets. It should fill in the new creds or return an error. All pointers, barring the pointer to the new creds, are now const. (*) security_bprm_apply_creds(), ->bprm_apply_creds() Changed; now returns a value, which will cause the process to be killed if it's an error. (*) security_task_alloc(), ->task_alloc_security() Removed in favour of security_prepare_creds(). (*) security_cred_free(), ->cred_free() New. Free security data attached to cred->security. (*) security_prepare_creds(), ->cred_prepare() New. Duplicate any security data attached to cred->security. (*) security_commit_creds(), ->cred_commit() New. Apply any security effects for the upcoming installation of new security by commit_creds(). (*) security_task_post_setuid(), ->task_post_setuid() Removed in favour of security_task_fix_setuid(). (*) security_task_fix_setuid(), ->task_fix_setuid() Fix up the proposed new credentials for setuid(). This is used by cap_set_fix_setuid() to implicitly adjust capabilities in line with setuid() changes. Changes are made to the new credentials, rather than the task itself as in security_task_post_setuid(). (*) security_task_reparent_to_init(), ->task_reparent_to_init() Removed. Instead the task being reparented to init is referred directly to init's credentials. NOTE! This results in the loss of some state: SELinux's osid no longer records the sid of the thread that forked it. (*) security_key_alloc(), ->key_alloc() (*) security_key_permission(), ->key_permission() Changed. These now take cred pointers rather than task pointers to refer to the security context. (4) sys_capset(). This has been simplified and uses less locking. The LSM functions it calls have been merged. (5) reparent_to_kthreadd(). This gives the current thread the same credentials as init by simply using commit_thread() to point that way. (6) __sigqueue_alloc() and switch_uid() __sigqueue_alloc() can't stop the target task from changing its creds beneath it, so this function gets a reference to the currently applicable user_struct which it then passes into the sigqueue struct it returns if successful. switch_uid() is now called from commit_creds(), and possibly should be folded into that. commit_creds() should take care of protecting __sigqueue_alloc(). (7) [sg]et[ug]id() and co and [sg]et_current_groups. The set functions now all use prepare_creds(), commit_creds() and abort_creds() to build and check a new set of credentials before applying it. security_task_set[ug]id() is called inside the prepared section. This guarantees that nothing else will affect the creds until we've finished. The calling of set_dumpable() has been moved into commit_creds(). Much of the functionality of set_user() has been moved into commit_creds(). The get functions all simply access the data directly. (8) security_task_prctl() and cap_task_prctl(). security_task_prctl() has been modified to return -ENOSYS if it doesn't want to handle a function, or otherwise return the return value directly rather than through an argument. Additionally, cap_task_prctl() now prepares a new set of credentials, even if it doesn't end up using it. (9) Keyrings. A number of changes have been made to the keyrings code: (a) switch_uid_keyring(), copy_keys(), exit_keys() and suid_keys() have all been dropped and built in to the credentials functions directly. They may want separating out again later. (b) key_alloc() and search_process_keyrings() now take a cred pointer rather than a task pointer to specify the security context. (c) copy_creds() gives a new thread within the same thread group a new thread keyring if its parent had one, otherwise it discards the thread keyring. (d) The authorisation key now points directly to the credentials to extend the search into rather pointing to the task that carries them. (e) Installing thread, process or session keyrings causes a new set of credentials to be created, even though it's not strictly necessary for process or session keyrings (they're shared). (10) Usermode helper. The usermode helper code now carries a cred struct pointer in its subprocess_info struct instead of a new session keyring pointer. This set of credentials is derived from init_cred and installed on the new process after it has been cloned. call_usermodehelper_setup() allocates the new credentials and call_usermodehelper_freeinfo() discards them if they haven't been used. A special cred function (prepare_usermodeinfo_creds()) is provided specifically for call_usermodehelper_setup() to call. call_usermodehelper_setkeys() adjusts the credentials to sport the supplied keyring as the new session keyring. (11) SELinux. SELinux has a number of changes, in addition to those to support the LSM interface changes mentioned above: (a) selinux_setprocattr() no longer does its check for whether the current ptracer can access processes with the new SID inside the lock that covers getting the ptracer's SID. Whilst this lock ensures that the check is done with the ptracer pinned, the result is only valid until the lock is released, so there's no point doing it inside the lock. (12) is_single_threaded(). This function has been extracted from selinux_setprocattr() and put into a file of its own in the lib/ directory as join_session_keyring() now wants to use it too. The code in SELinux just checked to see whether a task shared mm_structs with other tasks (CLONE_VM), but that isn't good enough. We really want to know if they're part of the same thread group (CLONE_THREAD). (13) nfsd. The NFS server daemon now has to use the COW credentials to set the credentials it is going to use. It really needs to pass the credentials down to the functions it calls, but it can't do that until other patches in this series have been applied. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Separate task security context from task_structDavid Howells
Separate the task security context from task_struct. At this point, the security data is temporarily embedded in the task_struct with two pointers pointing to it. Note that the Alpha arch is altered as it refers to (E)UID and (E)GID in entry.S via asm-offsets. With comment fixes Signed-off-by: Marc Dionne <marc.c.dionne@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-08-19sched: rt-bandwidth for user grouping interfacePeter Zijlstra
rt_runtime is a signed value Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-30alloc_uid: cleanupAndrew Morton
Use kmem_cache_zalloc(), remove large amounts of initialisation code and ifdeffery. Note: this assumes that memset(*atomic_t, 0) correctly initialises the atomic_t. This is true for all present archtiectures and if it becomes false for a future architecture then we'll need to make large changes all over the place anyway. Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29keys: don't generate user and user session keyrings unless they're accessedDavid Howells
Don't generate the per-UID user and user session keyrings unless they're explicitly accessed. This solves a problem during a login process whereby set*uid() is called before the SELinux PAM module, resulting in the per-UID keyrings having the wrong security labels. This also cures the problem of multiple per-UID keyrings sometimes appearing due to PAM modules (including pam_keyinit) setuiding and causing user_structs to come into and go out of existence whilst the session keyring pins the user keyring. This is achieved by first searching for extant per-UID keyrings before inventing new ones. The serial bound argument is also dropped from find_keyring_by_name() as it's not currently made use of (setting it to 0 disables the feature). Signed-off-by: David Howells <dhowells@redhat.com> Cc: <kwc@citi.umich.edu> Cc: <arunsr@cse.iitk.ac.in> Cc: <dwalsh@redhat.com> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Cc: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-19sched: fix the task_group hierarchy for UID groupingPeter Zijlstra
UID grouping doesn't actually have a task_group representing the root of the task_group tree. Add one. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-19sched: allow the group scheduler to have multiple levelsDhaval Giani
This patch makes the group scheduler multi hierarchy aware. [a.p.zijlstra@chello.nl: rt-parts and assorted fixes] Signed-off-by: Dhaval Giani <dhaval@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-19sched: rt-group: synchonised bandwidth periodPeter Zijlstra
Various SMP balancing algorithms require that the bandwidth period run in sync. Possible improvements are moving the rt_bandwidth thing into root_domain and keeping a span per rt_bandwidth which marks throttled cpus. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-13sched: rt-group: make rt groups scheduling configurablePeter Zijlstra
Make the rt group scheduler compile time configurable. Keep it experimental for now. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-13sched: rt-group: interfacePeter Zijlstra
Change the rt_ratio interface to rt_runtime_us, to match rt_period_us. This avoids picking a granularity for the ratio. Extend the /sys/kernel/uids/<uid>/ interface to allow setting the group's rt_runtime. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-08namespaces: cleanup the code managed with the USER_NS optionPavel Emelyanov
Make the user_namespace.o compilation depend on this option and move the init_user_ns into user.c file to make the kernel compile and work without the namespaces support. This make the user namespace code be organized similar to other namespaces'. Also mask the USER_NS option as "depend on NAMESPACES". [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Kirill Korotaev <dev@sw.ru> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-25uids: merge multiple error paths in alloc_uid() into onePavel Emelyanov
There are already 4 error paths in alloc_uid() that do incremental rollbacks. I think it's time to merge them. This costs us 8 lines of code :) Maybe it would be better to merge this patch with the previous one, but I remember that some time ago I sent a similar patch (fixing the error path and cleaning it), but I was told to make two patches in such cases. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Dhaval Giani <dhaval@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-24Kobject: convert kernel/user.c to use kobject_init/add_ng()Greg Kroah-Hartman
This converts the code to use the new kobject functions, cleaning up the logic in doing so. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kobject: convert kernel_kset to be a kobjectGreg Kroah-Hartman
kernel_kset does not need to be a kset, but a much simpler kobject now that we have kobj_attributes. We also rename kernel_kset to kernel_kobj to catch all users of this symbol with a build error instead of an easy-to-ignore build warning. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24fix struct user_info export's sysfs interactionKay Sievers
Clean up the use of ksets and kobjects. Kobjects are instances of objects (like struct user_info), ksets are collections of objects of a similar type (like the uids directory containing the user_info directories). So, use kobjects for the user_info directories, and a kset for the "uids" directory. On object cleanup, the final kobject_put() was missing. Cc: Dhaval Giani <dhaval@linux.vnet.ibm.com> Cc: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kset: convert kernel_subsys to use kset_createGreg Kroah-Hartman
Dynamically create the kset instead of declaring it statically. We also rename kernel_subsys to kernel_kset to catch all users of this symbol with a build error instead of an easy-to-ignore build warning. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-11-26sched: don't forget to unlock uids_mutex on error pathsPavel Emelyanov
The commit commit 5cb350baf580017da38199625b7365b1763d7180 Author: Dhaval Giani <dhaval@linux.vnet.ibm.com> Date: Mon Oct 15 17:00:14 2007 +0200 sched: group scheduling, sysfs tunables introduced the uids_mutex and the helpers to lock/unlock it. Unfortunately, the error paths of alloc_uid() were not patched to unlock it. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Dhaval Giani <dhaval@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-24sched: make cpu_shares_{show,store}() staticAdrian Bunk
cpu_shares_{show,store}() can become static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-schedLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-sched: sched: fix new task startup crash sched: fix !SYSFS build breakage sched: fix improper load balance across sched domain sched: more robust sd-sysctl entry freeing
2007-10-17user.c: #ifdef ->mq_bytesAlexey Dobriyan
For those who deselect POSIX message queues. Reduces SLAB size of user_struct from 64 to 32 bytes here, SLUB size -- from 40 bytes to 32 bytes. [akpm@linux-foundation.org: fix build] Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17user.c: deinlineAlexey Dobriyan
Save some space because uid_hash_find() has 3 callsites. Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17sched: fix !SYSFS build breakageDhaval Giani
When CONFIG_SYSFS is not set, CONFIG_FAIR_USER_SCHED fails to build with kernel/built-in.o: In function `uids_kobject_init': (.init.text+0x1488): undefined reference to `kernel_subsys' kernel/built-in.o: In function `uids_kobject_init': (.init.text+0x1490): undefined reference to `kernel_subsys' kernel/built-in.o: In function `uids_kobject_init': (.init.text+0x1480): undefined reference to `kernel_subsys' kernel/built-in.o: In function `uids_kobject_init': (.init.text+0x1494): undefined reference to `kernel_subsys' This patch fixes this build error. Signed-off-by: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Signed-off-by: Dhaval Giani <dhaval@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-15sched: generate uevents for user creation/destructionSrivatsa Vaddagiri
Generate uevents when a user is being created/destroyed. These events can be used to configure cpu share of a new user. Signed-off-by: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Signed-off-by: Dhaval Giani <dhaval@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-15sched: group scheduling, sysfs tunablesDhaval Giani
Add tunables in sysfs to modify a user's cpu share. A directory is created in sysfs for each new user in the system. /sys/kernel/uids/<uid>/cpu_share Reading this file returns the cpu shares granted for the user. Writing into this file modifies the cpu share for the user. Only an administrator is allowed to modify a user's cpu share. Ex: # cd /sys/kernel/uids/ # cat 512/cpu_share 1024 # echo 2048 > 512/cpu_share # cat 512/cpu_share 2048 # Signed-off-by: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Signed-off-by: Dhaval Giani <dhaval@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-15sched: cleanup: rename task_grp to task_groupIngo Molnar
cleanup: rename task_grp to task_group. No need to save two characters and 'grp' is annoying to read. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-15sched: add fair-user schedulerSrivatsa Vaddagiri
Enable user-id based fair group scheduling. This is useful for anyone who wants to test the group scheduler w/o having to enable CONFIG_CGROUPS. A separate scheduling group (i.e struct task_grp) is automatically created for every new user added to the system. Upon uid change for a task, it is made to move to the corresponding scheduling group. A /proc tunable (/proc/root_user_share) is also provided to tune root user's quota of cpu bandwidth. Signed-off-by: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Signed-off-by: Dhaval Giani <dhaval@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reviewed-by: Thomas Gleixner <tglx@linutronix.de>
2007-09-19Fix user namespace exiting OOPsPavel Emelyanov
It turned out, that the user namespace is released during the do_exit() in exit_task_namespaces(), but the struct user_struct is released only during the put_task_struct(), i.e. MUCH later. On debug kernels with poisoned slabs this will cause the oops in uid_hash_remove() because the head of the chain, which resides inside the struct user_namespace, will be already freed and poisoned. Since the uid hash itself is required only when someone can search it, i.e. when the namespace is alive, we can safely unhash all the user_struct-s from it during the namespace exiting. The subsequent free_uid() will complete the user_struct destruction. For example simple program #include <sched.h> char stack[2 * 1024 * 1024]; int f(void *foo) { return 0; } int main(void) { clone(f, stack + 1 * 1024 * 1024, 0x10000000, 0); return 0; } run on kernel with CONFIG_USER_NS turned on will oops the kernel immediately. This was spotted during OpenVZ kernel testing. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org> Acked-by: "Serge E. Hallyn" <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-09-19Convert uid hash to hlistPavel Emelyanov
Surprisingly, but (spotted by Alexey Dobriyan) the uid hash still uses list_heads, thus occupying twice as much place as it could. Convert it to hlist_heads. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-09-19kernel/user.c: Use list_for_each_entry instead of list_for_eachMatthias Kaehlcke
kernel/user.c: Convert list_for_each to list_for_each_entry in uid_hash_find() Signed-off-by: Matthias Kaehlcke <matthias.kaehlcke@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
