path: root/kernel/utsname.c
2011-05-10ns proc: Add support for the uts namespaceEric W. Biederman
Acked-by: Daniel Lezcano <daniel.lezcano@free.fr> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2011-03-23userns: allow sethostname in a containerSerge E. Hallyn
Changelog: Feb 23: let clone_uts_ns() handle setting uts->user_ns To do so we need to pass in the task_struct who'll get the utsname, so we can get its user_ns. Feb 23: As per Oleg's coment, just pass in tsk, instead of two of its members. Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23userns: add a user_namespace as creator/owner of uts_namespaceSerge E. Hallyn
The expected course of development for user namespaces targeted capabilities is laid out at https://wiki.ubuntu.com/UserNamespace. Goals: - Make it safe for an unprivileged user to unshare namespaces. They will be privileged with respect to the new namespace, but this should only include resources which the unprivileged user already owns. - Provide separate limits and accounting for userids in different namespaces. Status: Currently (as of 2.6.38) you can clone with the CLONE_NEWUSER flag to get a new user namespace if you have the CAP_SYS_ADMIN, CAP_SETUID, and CAP_SETGID capabilities. What this gets you is a whole new set of userids, meaning that user 500 will have a different 'struct user' in your namespace than in other namespaces. So any accounting information stored in struct user will be unique to your namespace. However, throughout the kernel there are checks which - simply check for a capability. Since root in a child namespace has all capabilities, this means that a child namespace is not constrained. - simply compare uid1 == uid2. Since these are the integer uids, uid 500 in namespace 1 will be said to be equal to uid 500 in namespace 2. As a result, the lxc implementation at lxc.sf.net does not use user namespaces. This is actually helpful because it leaves us free to develop user namespaces in such a way that, for some time, user namespaces may be unuseful. Bugs aside, this patchset is supposed to not at all affect systems which are not actively using user namespaces, and only restrict what tasks in child user namespace can do. They begin to limit privilege to a user namespace, so that root in a container cannot kill or ptrace tasks in the parent user namespace, and can only get world access rights to files. Since all files currently belong to the initila user namespace, that means that child user namespaces can only get world access rights to *all* files. While this temporarily makes user namespaces bad for system containers, it starts to get useful for some sandboxing. I've run the 'runltplite.sh' with and without this patchset and found no difference. This patch: copy_process() handles CLONE_NEWUSER before the rest of the namespaces. So in the case of clone(CLONE_NEWUSER|CLONE_NEWUTS) the new uts namespace will have the new user namespace as its owner. That is what we want, since we want root in that new userns to be able to have privilege over it. Changelog: Feb 15: don't set uts_ns->user_ns if we didn't create a new uts_ns. Feb 23: Move extern init_user_ns declaration from init/version.c to utsname.h. Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18utsns: extract creeate_uts_ns()Alexey Dobriyan
create_uts_ns() will be used by C/R to create fresh uts_ns. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-23removed unused #include <linux/version.h>'sAdrian Bunk
This patch lets the files using linux/version.h match the files that #include it. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29kernel: explicitly include required header files under kernel/Robert P. J. Day
Following an experimental deletion of the unnecessary directive #include <linux/slab.h> from the header file <linux/percpu.h>, these files under kernel/ were exposed as needing to include one of <linux/slab.h> or <linux/gfp.h>, so explicit includes were added where necessary. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-09-19Fix UTS corruption during clone(CLONE_NEWUTS)Alexey Dobriyan
struct utsname is copied from master one without any exclusion. Here is sample output from one proggie doing sethostname("aaaaaaaaaaaaaaaaaaaaaaaaaaaaaa"); sethostname("bbbbbbbbbbbbbbbbbbbbbbbbbbbbbb"); and another clone(,, CLONE_NEWUTS, ...) uname() hostname = 'aaaaaaaaaaaaaaaaaaaaaaaaabbbbb' hostname = 'bbbaaaaaaaaaaaaaaaaaaaaaaaaaaa' hostname = 'aaaaaaaabbbbbbbbbbbbbbbbbbbbbb' hostname = 'aaaaaaaaaaaaaaaaaaaaaaaaaabbbb' hostname = 'aaaaaaaaaaaaaaaaaaaaaaaaaaaabb' hostname = 'aaabbbbbbbbbbbbbbbbbbbbbbbbbbb' hostname = 'bbbbbbbbbbbbbbbbaaaaaaaaaaaaaa' Hostname is sometimes corrupted. Yes, even _the_ simplest namespace activity had bug in it. :-( Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16namespace: ensure clone_flags are always stored in an unsigned longEric W. Biederman
While working on unshare support for the network namespace I noticed we were putting clone flags in an int. Which is weird because the syscall uses unsigned long and we at least need an unsigned to properly hold all of the unshare flags. So to make the code consistent, this patch updates the code to use unsigned long instead of int for the clone flags in those places where we get it wrong today. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16fix create_new_namespaces() return valueCedric Le Goater
dup_mnt_ns() and clone_uts_ns() return NULL on failure. This is wrong, create_new_namespaces() uses ERR_PTR() to catch an error. This means that the subsequent create_new_namespaces() will hit BUG_ON() in copy_mnt_ns() or copy_utsname(). Modify create_new_namespaces() to also use the errors returned by the copy_*_ns routines and not to systematically return ENOMEM. [oleg@tv-sign.ru: better changelog] Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Cc: Serge E. Hallyn <serue@us.ibm.com> Cc: Badari Pulavarty <pbadari@us.ibm.com> Cc: Pavel Emelianov <xemul@openvz.org> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Merge sys_clone()/sys_unshare() nsproxy and namespace handlingBadari Pulavarty
sys_clone() and sys_unshare() both makes copies of nsproxy and its associated namespaces. But they have different code paths. This patch merges all the nsproxy and its associated namespace copy/clone handling (as much as possible). Posted on container list earlier for feedback. - Create a new nsproxy and its associated namespaces and pass it back to caller to attach it to right process. - Changed all copy_*_ns() routines to return a new copy of namespace instead of attaching it to task->nsproxy. - Moved the CAP_SYS_ADMIN checks out of copy_*_ns() routines. - Removed unnessary !ns checks from copy_*_ns() and added BUG_ON() just incase. - Get rid of all individual unshare_*_ns() routines and make use of copy_*_ns() instead. [akpm@osdl.org: cleanups, warning fix] [clg@fr.ibm.com: remove dup_namespaces() declaration] [serue@us.ibm.com: fix CONFIG_IPC_NS=n, clone(CLONE_NEWIPC) retval] [akpm@linux-foundation.org: fix build with CONFIG_SYSVIPC=n] Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Serge Hallyn <serue@us.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: <containers@lists.osdl.org> Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-02[PATCH] namespaces: utsname: implement CLONE_NEWUTS flagSerge E. Hallyn
Implement a CLONE_NEWUTS flag, and use it at clone and sys_unshare. [clg@fr.ibm.com: IPC unshare fix] [bunk@stusta.de: cleanup] Signed-off-by: Serge Hallyn <serue@us.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Andrey Savochkin <saw@sw.ru> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] namespaces: utsname: implement utsname namespacesSerge E. Hallyn
This patch defines the uts namespace and some manipulators. Adds the uts namespace to task_struct, and initializes a system-wide init namespace. It leaves a #define for system_utsname so sysctl will compile. This define will be removed in a separate patch. [akpm@osdl.org: build fix, cleanup] Signed-off-by: Serge Hallyn <serue@us.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Andrey Savochkin <saw@sw.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
