[ Upstream commit 11bca0a83f83f6093d816295668e74ef24595944 ]
An interrupt storm on a bad interrupt will cause the kernel
log to be clogged.
[ 60.089234] ->handle_irq(): ffffffffbe2f803f,
[ 60.090455] 0xffffffffbf2af380
[ 60.090510] handle_bad_irq+0x0/0x2e5
[ 60.090522] ->irq_data.chip(): ffffffffbf2af380,
[ 60.090553] IRQ_NOPROBE set
[ 60.090584] ->handle_irq(): ffffffffbe2f803f,
[ 60.090590] handle_bad_irq+0x0/0x2e5
[ 60.090596] ->irq_data.chip(): ffffffffbf2af380,
[ 60.090602] 0xffffffffbf2af380
[ 60.090608] ->action(): (null)
[ 60.090779] handle_bad_irq+0x0/0x2e5
This was seen when running an upstream kernel on Acer Chromebook R11. The
system was unstable as result.
Guard the log message with __printk_ratelimit to reduce the impact. This
won't prevent the interrupt storm from happening, but at least the system
remains stable.
Cc: Dmitry Torokhov <dtor@chromium.org>
Cc: Joe Perches <joe@perches.com>
Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Cc: Mika Westerberg <mika.westerberg@linux.intel.com>
Link: https://bugzilla.kernel.org/show_bug.cgi?id=197953
Link: https://lkml.kernel.org/r/1512234784-21038-1-git-send-email-linux@roeck-us.net
commit 48d0c9becc7f3c66874c100c126459a9da0fdced upstream.
The POSIX specification defines that relative CLOCK_REALTIME timers are not
affected by clock modifications. Those timers have to use CLOCK_MONOTONIC
to ensure POSIX compliance.
The introduction of the additional HRTIMER_MODE_PINNED mode broke this
requirement for pinned timers.
There is no user space visible impact because user space timers are not
using pinned mode, but for consistency reasons this needs to be fixed.
Check whether the mode has the HRTIMER_MODE_REL bit set instead of
comparing with HRTIMER_MODE_ABS.
Signed-off-by: Anna-Maria Gleixner <anna-maria@linutronix.de>
Cc: John Stultz <john.stultz@linaro.org>
Cc: keescook@chromium.org
Fixes: 597d0275736d ("timers: Framework for identifying pinned timers")
Link: http://lkml.kernel.org/r/20171221104205.7269-7-anna-maria@linutronix.de
commit 77dd66a3c67c93ab401ccc15efff25578be281fd upstream.
If devm_memremap_pages() detects a collision while adding entries
to the radix-tree, we call pgmap_radix_release(). Unfortunately,
the function removes *all* entries for the range -- including the
entries that caused the collision in the first place.
Modify pgmap_radix_release() to take an additional argument to
indicate where to stop, so that only newly added entries are removed
from the tree.
Cc: <stable@vger.kernel.org>
Fixes: 9476df7d80df ("mm: introduce find_dev_pagemap()")
Signed-off-by: Jan H. Schönherr <jschoenh@amazon.de>
commit a77660d231f8b3d84fd23ed482e0964f7aa546d6 upstream.
Currently KCOV_ENABLE does not check if the current task is already
associated with another kcov descriptor. As the result it is possible
to associate a single task with more than one kcov descriptor, which
later leads to a memory leak of the old descriptor. This relation is
really meant to be one-to-one (task has only one back link).
Extend validation to detect such misuse.
Link: http://lkml.kernel.org/r/20180122082520.15716-1-dvyukov@google.com
Fixes: 5c9a8750a640 ("kernel: add kcov code coverage")
Signed-off-by: Dmitry Vyukov <dvyukov@google.com>
Reported-by: Shankara Pailoor <sp3485@columbia.edu>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: syzbot <syzkaller@googlegroups.com>
commit a6da0024ffc19e0d47712bb5ca4fd083f76b07df upstream.
We need to ensure that tracepoints are registered and unregistered
with the users of them. The existing atomic count isn't enough for
that. Add a lock around the tracepoints, so we serialize access
to them.
This fixes cases where we have multiple users setting up and
tearing down tracepoints, like this:
CPU: 0 PID: 2995 Comm: syzkaller857118 Not tainted
4.14.0-rc5-next-20171018+ #36
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS
Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:16 [inline]
dump_stack+0x194/0x257 lib/dump_stack.c:52
panic+0x1e4/0x41c kernel/panic.c:183
__warn+0x1c4/0x1e0 kernel/panic.c:546
report_bug+0x211/0x2d0 lib/bug.c:183
fixup_bug+0x40/0x90 arch/x86/kernel/traps.c:177
do_trap_no_signal arch/x86/kernel/traps.c:211 [inline]
do_trap+0x260/0x390 arch/x86/kernel/traps.c:260
do_error_trap+0x120/0x390 arch/x86/kernel/traps.c:297
do_invalid_op+0x1b/0x20 arch/x86/kernel/traps.c:310
invalid_op+0x18/0x20 arch/x86/entry/entry_64.S:905
RIP: 0010:tracepoint_add_func kernel/tracepoint.c:210 [inline]
RIP: 0010:tracepoint_probe_register_prio+0x397/0x9a0 kernel/tracepoint.c:283
RSP: 0018:ffff8801d1d1f6c0 EFLAGS: 00010293
RAX: ffff8801d22e8540 RBX: 00000000ffffffef RCX: ffffffff81710f07
RDX: 0000000000000000 RSI: ffffffff85b679c0 RDI: ffff8801d5f19818
RBP: ffff8801d1d1f7c8 R08: ffffffff81710c10 R09: 0000000000000004
R10: ffff8801d1d1f6b0 R11: 0000000000000003 R12: ffffffff817597f0
R13: 0000000000000000 R14: 00000000ffffffff R15: ffff8801d1d1f7a0
tracepoint_probe_register+0x2a/0x40 kernel/tracepoint.c:304
register_trace_block_rq_insert include/trace/events/block.h:191 [inline]
blk_register_tracepoints+0x1e/0x2f0 kernel/trace/blktrace.c:1043
do_blk_trace_setup+0xa10/0xcf0 kernel/trace/blktrace.c:542
blk_trace_setup+0xbd/0x180 kernel/trace/blktrace.c:564
sg_ioctl+0xc71/0x2d90 drivers/scsi/sg.c:1089
vfs_ioctl fs/ioctl.c:45 [inline]
do_vfs_ioctl+0x1b1/0x1520 fs/ioctl.c:685
SYSC_ioctl fs/ioctl.c:700 [inline]
SyS_ioctl+0x8f/0xc0 fs/ioctl.c:691
entry_SYSCALL_64_fastpath+0x1f/0xbe
RIP: 0033:0x444339
RSP: 002b:00007ffe05bb5b18 EFLAGS: 00000206 ORIG_RAX: 0000000000000010
RAX: ffffffffffffffda RBX: 00000000006d66c0 RCX: 0000000000444339
RDX: 000000002084cf90 RSI: 00000000c0481273 RDI: 0000000000000009
RBP: 0000000000000082 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000206 R12: ffffffffffffffff
R13: 00000000c0481273 R14: 0000000000000000 R15: 0000000000000000
since we can now run these in parallel. Ensure that the exported helpers
for doing this are grabbing the queue trace mutex.
Reported-by: Steven Rostedt <rostedt@goodmis.org>
Tested-by: Dmitry Vyukov <dvyukov@google.com>
commit 10a0cd6e4932b5078215b1ec2c896597eec0eff9 upstream.
The functions devm_memremap_pages() and devm_memremap_pages_release() use
different ways to calculate the section-aligned amount of memory. The
latter function may use an incorrect size if the memory region is small
but straddles a section border.
Use the same code for both.
Fixes: 5f29a77cd957 ("mm: fix mixed zone detection in devm_memremap_pages")
commit 7b6586562708d2b3a04fe49f217ddbadbbbb0546 upstream.
__unregister_ftrace_function_probe() will incorrectly parse the glob filter
because it resets the search variable that was setup by filter_parse_regex().
Al Viro reported this:
After that call of filter_parse_regex() we could have func_g.search not
equal to glob only if glob started with '!' or '*'. In the former case
we would've buggered off with -EINVAL (not = 1). In the latter we
would've set func_g.search equal to glob + 1, calculated the length of
that thing in func_g.len and proceeded to reset func_g.search back to
glob.
Suppose the glob is e.g. *foo*. We end up with
func_g.type = MATCH_MIDDLE_ONLY;
func_g.len = 3;
func_g.search = "*foo";
Feeding that to ftrace_match_record() will not do anything sane - we
will be looking for names containing "*foo" (->len is ignored for that
one).
Link: http://lkml.kernel.org/r/20180127031706.GE13338@ZenIV.linux.org.uk
Fixes: 3ba009297149f ("ftrace: Introduce ftrace_glob structure")
Reviewed-by: Dmitry Safonov <0x7f454c46@gmail.com>
Reviewed-by: Masami Hiramatsu <mhiramat@kernel.org>
Reported-by: Al Viro <viro@ZenIV.linux.org.uk>
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
commit a1be1f3931bfe0a42b46fef77a04593c2b136e7f upstream.
This reverts commit ba62bafe942b ("kernel/relay.c: fix potential memory leak").
This commit introduced a double free bug, because 'chan' is already
freed by the line:
kref_put(&chan->kref, relay_destroy_channel);
This bug was found by syzkaller, using the BLKTRACESETUP ioctl.
Link: http://lkml.kernel.org/r/20180127004759.101823-1-ebiggers3@gmail.com
Fixes: ba62bafe942b ("kernel/relay.c: fix potential memory leak")
Reported-by: syzbot <syzkaller@googlegroups.com>
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
Cc: Zhouyi Zhou <yizhouzhou@ict.ac.cn>
commit 4f7e988e63e336827f4150de48163bed05d653bd upstream.
This reverts commit 92266d6ef60c ("async: simplify lowest_in_progress()")
which was simply wrong: In the case where domain is NULL, we now use the
wrong offsetof() in the list_first_entry macro, so we don't actually
fetch the ->cookie value, but rather the eight bytes located
sizeof(struct list_head) further into the struct async_entry.
On 64 bit, that's the data member, while on 32 bit, that's a u64 built
from func and data in some order.
I think the bug happens to be harmless in practice: It obviously only
affects callers which pass a NULL domain, and AFAICT the only such
caller is
async_synchronize_full() ->
async_synchronize_full_domain(NULL) ->
async_synchronize_cookie_domain(ASYNC_COOKIE_MAX, NULL)
and the ASYNC_COOKIE_MAX means that in practice we end up waiting for
the async_global_pending list to be empty - but it would break if
somebody happened to pass (void*)-1 as the data element to
async_schedule, and of course also if somebody ever does a
async_synchronize_cookie_domain(, NULL) with a "finite" cookie value.
Maybe the "harmless in practice" means this isn't -stable material. But
I'm not completely confident my quick git grep'ing is enough, and there
might be affected code in one of the earlier kernels that has since been
removed, so I'll leave the decision to the stable guys.
Link: http://lkml.kernel.org/r/20171128104938.3921-1-linux@rasmusvillemoes.dk
Fixes: 92266d6ef60c "async: simplify lowest_in_progress()"
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Acked-by: Tejun Heo <tj@kernel.org>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: Adam Wallis <awallis@codeaurora.org>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
commit 364f56653708ba8bcdefd4f0da2a42904baa8eeb upstream.
When issuing an IPI RT push, where an IPI is sent to each CPU that has more
than one RT task scheduled on it, it references the root domain's rto_mask,
that contains all the CPUs within the root domain that has more than one RT
task in the runable state. The problem is, after the IPIs are initiated, the
rq->lock is released. This means that the root domain that is associated to
the run queue could be freed while the IPIs are going around.
Add a sched_get_rd() and a sched_put_rd() that will increment and decrement
the root domain's ref count respectively. This way when initiating the IPIs,
the scheduler will up the root domain's ref count before releasing the
rq->lock, ensuring that the root domain does not go away until the IPI round
is complete.
Reported-by: Pavan Kondeti <pkondeti@codeaurora.org>
Fixes: 4bdced5c9a292 ("sched/rt: Simplify the IPI based RT balancing logic")
Link: http://lkml.kernel.org/r/CAEU1=PkiHO35Dzna8EQqNSKW1fr1y1zRQ5y66X117MG06sQtNA@mail.gmail.com
commit ad0f1d9d65938aec72a698116cd73a980916895e upstream.
When the rto_push_irq_work_func() is called, it looks at the RT overloaded
bitmask in the root domain via the runqueue (rq->rd). The problem is that
during CPU up and down, nothing here stops rq->rd from changing between
taking the rq->rd->rto_lock and releasing it. That means the lock that is
released is not the same lock that was taken.
Instead of using this_rq()->rd to get the root domain, as the irq work is
part of the root domain, we can simply get the root domain from the irq work
that is passed to the routine:
container_of(work, struct root_domain, rto_push_work)
This keeps the root domain consistent.
commit cef31d9af908243421258f1df35a4a644604efbe upstream.
timer_create() specifies via sigevent->sigev_notify the signal delivery for
the new timer. The valid modes are SIGEV_NONE, SIGEV_SIGNAL, SIGEV_THREAD
and (SIGEV_SIGNAL | SIGEV_THREAD_ID).
The sanity check in good_sigevent() is only checking the valid combination
for the SIGEV_THREAD_ID bit, i.e. SIGEV_SIGNAL, but if SIGEV_THREAD_ID is
not set it accepts any random value.
This has no real effects on the posix timer and signal delivery code, but
it affects show_timer() which handles the output of /proc/$PID/timers. That
function uses a string array to pretty print sigev_notify. The access to
that array has no bound checks, so random sigev_notify cause access beyond
the array bounds.
Add proper checks for the valid notify modes and remove the SIGEV_THREAD_ID
masking from various code pathes as SIGEV_NONE can never be set in
combination with SIGEV_THREAD_ID.
Reported-by: Eric Biggers <ebiggers3@gmail.com>
Reported-by: Alexey Dobriyan <adobriyan@gmail.com>
(cherry picked from commit caf7501a1b4ec964190f31f9c3f163de252273b8)
There's a risk that a kernel which has full retpoline mitigations becomes
vulnerable when a module gets loaded that hasn't been compiled with the
right compiler or the right option.
To enable detection of that mismatch at module load time, add a module info
string "retpoline" at build time when the module was compiled with
retpoline support. This only covers compiled C source, but assembler source
or prebuilt object files are not checked.
If a retpoline enabled kernel detects a non retpoline protected module at
load time, print a warning and report it in the sysfs vulnerability file.
[ tglx: Massaged changelog ]
Cc: gregkh@linuxfoundation.org
Cc: torvalds@linux-foundation.org
Cc: jeyu@kernel.org
Cc: arjan@linux.intel.com
Link: https://lkml.kernel.org/r/20180125235028.31211-1-andi@firstfloor.org
Signed-off-by: David Woodhouse <dwmw@amazon.co.uk>
[ upstream commit f37a8cb84cce18762e8f86a70bd6a49a66ab964c ]
Alexei found that verifier does not reject stores into context
via BPF_ST instead of BPF_STX. And while looking at it, we
also should not allow XADD variant of BPF_STX.
The context rewriter is only assuming either BPF_LDX_MEM- or
BPF_STX_MEM-type operations, thus reject anything other than
that so that assumptions in the rewriter properly hold. Add
test cases as well for BPF selftests.
Fixes: d691f9e8d440 ("bpf: allow programs to write to certain skb fields")
Reported-by: Alexei Starovoitov <ast@kernel.org>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
[ upstream commit 68fda450a7df51cff9e5a4d4a4d9d0d5f2589153 ]
due to some JITs doing if (src_reg == 0) check in 64-bit mode
for div/mod operations mask upper 32-bits of src register
before doing the check
Fixes: 622582786c9e ("net: filter: x86: internal BPF JIT")
Fixes: 7a12b5031c6b ("sparc64: Add eBPF JIT.")
Reported-by: syzbot+48340bb518e88849e2e3@syzkaller.appspotmail.com
[ upstream commit c366287ebd698ef5e3de300d90cd62ee9ee7373e ]
Divides by zero are not nice, lets avoid them if possible.
Also do_div() seems not needed when dealing with 32bit operands,
but this seems a minor detail.
Fixes: bd4cf0ed331a ("net: filter: rework/optimize internal BPF interpreter's instruction set")
[ upstream commit 7891a87efc7116590eaba57acc3c422487802c6f ]
The following snippet was throwing an 'unknown opcode cc' warning
in BPF interpreter:
0: (18) r0 = 0x0
2: (7b) *(u64 *)(r10 -16) = r0
3: (cc) (u32) r0 s>>= (u32) r0
4: (95) exit
Although a number of JITs do support BPF_ALU | BPF_ARSH | BPF_{K,X}
generation, not all of them do and interpreter does neither. We can
leave existing ones and implement it later in bpf-next for the
remaining ones, but reject this properly in verifier for the time
being.
Fixes: 17a5267067f3 ("bpf: verifier (add verifier core)")
Reported-by: syzbot+93c4904c5c70348a6890@syzkaller.appspotmail.com
[ upstream commit 290af86629b25ffd1ed6232c4e9107da031705cb ]
The BPF interpreter has been used as part of the spectre 2 attack CVE-2017-5715.
A quote from goolge project zero blog:
"At this point, it would normally be necessary to locate gadgets in
the host kernel code that can be used to actually leak data by reading
from an attacker-controlled location, shifting and masking the result
appropriately and then using the result of that as offset to an
attacker-controlled address for a load. But piecing gadgets together
and figuring out which ones work in a speculation context seems annoying.
So instead, we decided to use the eBPF interpreter, which is built into
the host kernel - while there is no legitimate way to invoke it from inside
a VM, the presence of the code in the host kernel's text section is sufficient
to make it usable for the attack, just like with ordinary ROP gadgets."
To make attacker job harder introduce BPF_JIT_ALWAYS_ON config
option that removes interpreter from the kernel in favor of JIT-only mode.
So far eBPF JIT is supported by:
x64, arm64, arm32, sparc64, s390, powerpc64, mips64
The start of JITed program is randomized and code page is marked as read-only.
In addition "constant blinding" can be turned on with net.core.bpf_jit_harden
v2->v3:
- move __bpf_prog_ret0 under ifdef (Daniel)
v1->v2:
- fix init order, test_bpf and cBPF (Daniel's feedback)
- fix offloaded bpf (Jakub's feedback)
- add 'return 0' dummy in case something can invoke prog->bpf_func
- retarget bpf tree. For bpf-next the patch would need one extra hunk.
It will be sent when the trees are merged back to net-next
Considered doing:
int bpf_jit_enable __read_mostly = BPF_EBPF_JIT_DEFAULT;
but it seems better to land the patch as-is and in bpf-next remove
bpf_jit_enable global variable from all JITs, consolidate in one place
and remove this jit_init() function.
[ upstream commit 90caccdd8cc0215705f18b92771b449b01e2474a ]
- bpf prog_array just like all other types of bpf array accepts 32-bit index.
Clarify that in the comment.
- fix x64 JIT of bpf_tail_call which was incorrectly loading 8 instead of 4 bytes
- tighten corresponding check in the interpreter to stay consistent
The JIT bug can be triggered after introduction of BPF_F_NUMA_NODE flag
in commit 96eabe7a40aa in 4.14. Before that the map_flags would stay zero and
though JIT code is wrong it will check bounds correctly.
Hence two fixes tags. All other JITs don't have this problem.
Fixes: 96eabe7a40aa ("bpf: Allow selecting numa node during map creation")
Fixes: b52f00e6a715 ("x86: bpf_jit: implement bpf_tail_call() helper")
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
Acked-by: Martin KaFai Lau <kafai@fb.com>
Reviewed-by: Eric Dumazet <edumazet@google.com>
commit d5421ea43d30701e03cadc56a38854c36a8b4433 upstream.
The hrtimer interrupt code contains a hang detection and mitigation
mechanism, which prevents that a long delayed hrtimer interrupt causes a
continous retriggering of interrupts which prevent the system from making
progress. If a hang is detected then the timer hardware is programmed with
a certain delay into the future and a flag is set in the hrtimer cpu base
which prevents newly enqueued timers from reprogramming the timer hardware
prior to the chosen delay. The subsequent hrtimer interrupt after the delay
clears the flag and resumes normal operation.
If such a hang happens in the last hrtimer interrupt before a CPU is
unplugged then the hang_detected flag is set and stays that way when the
CPU is plugged in again. At that point the timer hardware is not armed and
it cannot be armed because the hang_detected flag is still active, so
nothing clears that flag. As a consequence the CPU does not receive hrtimer
interrupts and no timers expire on that CPU which results in RCU stalls and
other malfunctions.
Clear the flag along with some other less critical members of the hrtimer
cpu base to ensure starting from a clean state when a CPU is plugged in.
Thanks to Paul, Sebastian and Anna-Maria for their help to get down to the
root cause of that hard to reproduce heisenbug. Once understood it's
trivial and certainly justifies a brown paperbag.
Fixes: 41d2e4949377 ("hrtimer: Tune hrtimer_interrupt hang logic")
Reported-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Sebastian Sewior <bigeasy@linutronix.de>
Cc: Anna-Maria Gleixner <anna-maria@linutronix.de>
Link: https://lkml.kernel.org/r/alpine.DEB.2.20.1801261447590.2067@nanos
commit 62635ea8c18f0f62df4cc58379e4f1d33afd5801 upstream.
show_workqueue_state() can print out a lot of messages while being in
atomic context, e.g. sysrq-t -> show_workqueue_state(). If the console
device is slow it may end up triggering NMI hard lockup watchdog.
Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
commit 1ebe1eaf2f02784921759992ae1fde1a9bec8fd0 upstream.
Since enums do not get converted by the TRACE_EVENT macro into their values,
the event format displaces the enum name and not the value. This breaks
tools like perf and trace-cmd that need to interpret the raw binary data. To
solve this, an enum map was created to convert these enums into their actual
numbers on boot up. This is done by TRACE_EVENTS() adding a
TRACE_DEFINE_ENUM() macro.
Some enums were not being converted. This was caused by an optization that
had a bug in it.
All calls get checked against this enum map to see if it should be converted
or not, and it compares the call's system to the system that the enum map
was created under. If they match, then they call is processed.
To cut down on the number of iterations needed to find the maps with a
matching system, since calls and maps are grouped by system, when a match is
made, the index into the map array is saved, so that the next call, if it
belongs to the same system as the previous call, could start right at that
array index and not have to scan all the previous arrays.
The problem was, the saved index was used as the variable to know if this is
a call in a new system or not. If the index was zero, it was assumed that
the call is in a new system and would keep incrementing the saved index
until it found a matching system. The issue arises when the first matching
system was at index zero. The next map, if it belonged to the same system,
would then think it was the first match and increment the index to one. If
the next call belong to the same system, it would begin its search of the
maps off by one, and miss the first enum that should be converted. This left
a single enum not converted properly.
Also add a comment to describe exactly what that index was for. It took me a
bit too long to figure out what I was thinking when debugging this issue.
Link: http://lkml.kernel.org/r/717BE572-2070-4C1E-9902-9F2E0FEDA4F8@oracle.com
Fixes: 0c564a538aa93 ("tracing: Add TRACE_DEFINE_ENUM() macro to map enums to their values")
Reported-by: Chuck Lever <chuck.lever@oracle.com>
Teste-by: Chuck Lever <chuck.lever@oracle.com>
commit ae83b56a56f8d9643dedbee86b457fa1c5d42f59 upstream.
When a contrained task is throttled by dl_check_constrained_dl(),
it may carry the remaining positive runtime, as a result when
dl_task_timer() fires and calls replenish_dl_entity(), it will
not be replenished correctly due to the positive dl_se->runtime.
This patch assigns its runtime to 0 if positive after throttling.
Signed-off-by: Xunlei Pang <xlpang@redhat.com>
Acked-by: Daniel Bristot de Oliveira <bristot@redhat.com>
Cc: Juri Lelli <juri.lelli@arm.com>
Cc: Luca Abeni <luca.abeni@santannapisa.it>
Fixes: df8eac8cafce ("sched/deadline: Throttle a constrained deadline task activated after the deadline)
Link: http://lkml.kernel.org/r/1494421417-27550-1-git-send-email-xlpang@redhat.com
Cc: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit ed4bbf7910b28ce3c691aef28d245585eaabda06 upstream.
When the timer base is checked for expired timers then the deferrable base
must be checked as well. This was missed when making the deferrable base
independent of base::nohz_active.
Fixes: ced6d5c11d3e ("timers: Use deferrable base independent of base::nohz_active")
Cc: Sebastian Siewior <bigeasy@linutronix.de>
Cc: Paul McKenney <paulmck@linux.vnet.ibm.com>
Cc: rt@linutronix.de
commit fbe0e839d1e22d88810f3ee3e2f1479be4c0aa4a upstream.
UBSAN reports signed integer overflow in kernel/futex.c:
UBSAN: Undefined behaviour in kernel/futex.c:2041:18
signed integer overflow:
0 - -2147483648 cannot be represented in type 'int'
Add a sanity check to catch negative values of nr_wake and nr_requeue.
Signed-off-by: Li Jinyue <lijinyue@huawei.com>
Cc: peterz@infradead.org
Cc: dvhart@infradead.org
Link: https://lkml.kernel.org/r/1513242294-31786-1-git-send-email-lijinyue@huawei.com
commit bbeb6e4323dad9b5e0ee9f60c223dd532e2403b1 upstream.
syzkaller tried to alloc a map with 0xfffffffd entries out of a userns,
and thus unprivileged. With the recently added logic in b2157399cc98
("bpf: prevent out-of-bounds speculation") we round this up to the next
power of two value for max_entries for unprivileged such that we can
apply proper masking into potentially zeroed out map slots.
However, this will generate an index_mask of 0xffffffff, and therefore
a + 1 will let this overflow into new max_entries of 0. This will pass
allocation, etc, and later on map access we still enforce on the original
attr->max_entries value which was 0xfffffffd, therefore triggering GPF
all over the place. Thus bail out on overflow in such case.
Moreover, on 32 bit archs roundup_pow_of_two() can also not be used,
since fls_long(max_entries - 1) can result in 32 and 1UL << 32 in 32 bit
space is undefined. Therefore, do this by hand in a 64 bit variable.
This fixes all the issues triggered by syzkaller's reproducers.
Fixes: b2157399cc98 ("bpf: prevent out-of-bounds speculation")
Reported-by: syzbot+b0efb8e572d01bce1ae0@syzkaller.appspotmail.com
Reported-by: syzbot+6c15e9744f75f2364773@syzkaller.appspotmail.com
Reported-by: syzbot+d2f5524fb46fd3b312ee@syzkaller.appspotmail.com
Reported-by: syzbot+61d23c95395cc90dbc2b@syzkaller.appspotmail.com
Reported-by: syzbot+0d363c942452cca68c01@syzkaller.appspotmail.com
commit b2157399cc9898260d6031c5bfe45fe137c1fbe7 upstream.
Under speculation, CPUs may mis-predict branches in bounds checks. Thus,
memory accesses under a bounds check may be speculated even if the
bounds check fails, providing a primitive for building a side channel.
To avoid leaking kernel data round up array-based maps and mask the index
after bounds check, so speculated load with out of bounds index will load
either valid value from the array or zero from the padded area.
Unconditionally mask index for all array types even when max_entries
are not rounded to power of 2 for root user.
When map is created by unpriv user generate a sequence of bpf insns
that includes AND operation to make sure that JITed code includes
the same 'index & index_mask' operation.
If prog_array map is created by unpriv user replace
bpf_tail_call(ctx, map, index);
with
if (index >= max_entries) {
index &= map->index_mask;
(along with roundup to power 2) to prevent out-of-bounds speculation.
There is secondary redundant 'if (index >= max_entries)' in the interpreter
and in all JITs, but they can be optimized later if necessary.
Other array-like maps (cpumap, devmap, sockmap, perf_event_array, cgroup_array)
cannot be used by unpriv, so no changes there.
That fixes bpf side of "Variant 1: bounds check bypass (CVE-2017-5753)" on
all architectures with and without JIT.
v2->v3:
Daniel noticed that attack potentially can be crafted via syscall commands
without loading the program, so add masking to those paths as well.
Acked-by: John Fastabend <john.fastabend@gmail.com>
Cc: Jiri Slaby <jslaby@suse.cz>
[ Backported to 4.9 - gregkh ]
commit 79741b3bdec01a8628368fbcfccc7d189ed606cb upstream.
reduce indent and make it iterate over instructions similar to
convert_ctx_accesses(). Also convert hard BUG_ON into soft verifier error.
[Backported to 4.9.y - gregkh]
commit e245c5c6a5656e4d61aa7bb08e9694fd6e5b2b9d upstream.
no functional change.
move fixup_bpf_calls() to verifier.c
it's being refactored in the next patch
[backported to 4.9 - gregkh]
complete_signal()
commit 426915796ccaf9c2bd9bb06dc5702225957bc2e5 upstream.
complete_signal() checks SIGNAL_UNKILLABLE before it starts to destroy
the thread group, today this is wrong in many ways.
If nothing else, fatal_signal_pending() should always imply that the
whole thread group (except ->group_exit_task if it is not NULL) is
killed, this check breaks the rule.
After the previous changes we can rely on sig_task_ignored();
sig_fatal(sig) && SIGNAL_UNKILLABLE can only be true if we actually want
to kill this task and sig == SIGKILL OR it is traced and debugger can
intercept the signal.
This should hopefully fix the problem reported by Dmitry. This
test-case
static int init(void *arg)
for (;;)
pause();
int main(void)
char stack[16 * 1024];
for (;;) {
int pid = clone(init, stack + sizeof(stack)/2,
CLONE_NEWPID | SIGCHLD, NULL);
assert(pid > 0);
assert(ptrace(PTRACE_ATTACH, pid, 0, 0) == 0);
assert(waitpid(-1, NULL, WSTOPPED) == pid);
assert(ptrace(PTRACE_DETACH, pid, 0, SIGSTOP) == 0);
assert(syscall(__NR_tkill, pid, SIGKILL) == 0);
assert(pid == wait(NULL));
triggers the WARN_ON_ONCE(!(task->jobctl & JOBCTL_STOP_PENDING)) in
task_participate_group_stop(). do_signal_stop()->signal_group_exit()
checks SIGNAL_GROUP_EXIT and return false, but task_set_jobctl_pending()
checks fatal_signal_pending() and does not set JOBCTL_STOP_PENDING.
And his should fix the minor security problem reported by Kyle,
SECCOMP_RET_TRACE can miss fatal_signal_pending() the same way if the
task is the root of a pid namespace.
Link: http://lkml.kernel.org/r/20171103184246.GD21036@redhat.com
Reported-by: Kyle Huey <me@kylehuey.com>
Tested-by: Kyle Huey <me@kylehuey.com>
signals
commit ac25385089f673560867eb5179228a44ade0cfc1 upstream.
Change sig_task_ignored() to drop the SIG_DFL && !sig_kernel_only()
signals even if force == T. This simplifies the next change and this
matches the same check in get_signal() which will drop these signals
anyway.
Link: http://lkml.kernel.org/r/20171103184227.GC21036@redhat.com
commit 628c1bcba204052d19b686b5bac149a644cdb72e upstream.
The comment in sig_ignored() says "Tracers may want to know about even
ignored signals" but SIGKILL can not be reported to debugger and it is
just wrong to return 0 in this case: SIGKILL should only kill the
SIGNAL_UNKILLABLE task if it comes from the parent ns.
Change sig_ignored() to ignore ->ptrace if sig == SIGKILL and rely on
sig_task_ignored().
SISGTOP coming from within the namespace is not really right too but at
least debugger can intercept it, and we can't drop it here because this
will break "gdb -p 1": ptrace_attach() won't work. Perhaps we will add
another ->ptrace check later, we will see.
Link: http://lkml.kernel.org/r/20171103184206.GB21036@redhat.com
commit bdcf0a423ea1c40bbb40e7ee483b50fc8aa3d758 upstream.
In testing, we found that nfsd threads may call set_groups in parallel
for the same entry cached in auth.unix.gid, racing in the call of
groups_sort, corrupting the groups for that entry and leading to
permission denials for the client.
This patch:
- Make groups_sort globally visible.
- Move the call to groups_sort to the modifiers of group_info
- Remove the call to groups_sort from set_groups
Link: http://lkml.kernel.org/r/20171211151420.18655-1-thiago.becker@gmail.com
Signed-off-by: Thiago Rafael Becker <thiago.becker@gmail.com>
Reviewed-by: Matthew Wilcox <mawilcox@microsoft.com>
Reviewed-by: NeilBrown <neilb@suse.com>
Acked-by: "J. Bruce Fields" <bfields@fieldses.org>
commit 4d9570158b6260f449e317a5f9ed030c2504a615 upstream.
As Tsukada explains, the time_is_before_jiffies(acct->needcheck) check
is very wrong, we need time_is_after_jiffies() to make sys_acct() work.
Ignoring the overflows, the code should "goto out" if needcheck >
jiffies, while currently it checks "needcheck < jiffies" and thus in the
likely case check_free_space() does nothing until jiffies overflow.
In particular this means that sys_acct() is simply broken, acct_on()
sets acct->needcheck = jiffies and expects that check_free_space()
should set acct->active = 1 after the free-space check, but this won't
happen if jiffies increments in between.
This was broken by commit 32dc73086015 ("get rid of timer in
kern/acct.c") in 2011, then another (correct) commit 795a2f22a8ea
("acct() should honour the limits from the very beginning") made the
problem more visible.
Link: http://lkml.kernel.org/r/20171213133940.GA6554@redhat.com
Fixes: 32dc73086015 ("get rid of timer in kern/acct.c")
Reported-by: TSUKADA Koutaro <tsukada@ascade.co.jp>
Suggested-by: TSUKADA Koutaro <tsukada@ascade.co.jp>
Kaiser only needs to map one page of the stack; and
kernel/fork.c did not build on powerpc (no __PAGE_KERNEL).
It's all cleaner if linux/kaiser.h provides kaiser_map_thread_stack()
and kaiser_unmap_thread_stack() wrappers around asm/kaiser.h's
kaiser_add_mapping() and kaiser_remove_mapping(). And use
linux/kaiser.h in init/main.c to avoid the #ifdefs there.
Merged fixes and cleanups, rebased to 4.9.51 tree (no 5-level paging).
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
This patch introduces our implementation of KAISER (Kernel Address Isolation to
have Side-channels Efficiently Removed), a kernel isolation technique to close
hardware side channels on kernel address information.
More information about the patch can be found on:
https://github.com/IAIK/KAISER
From: Richard Fellner <richard.fellner@student.tugraz.at>
Subject: [RFC, PATCH] x86_64: KAISER - do not map kernel in user mode
Date: Thu, 4 May 2017 14:26:50 +0200
Link: http://marc.info/?l=linux-kernel&m=149390087310405&w=2
Kaiser-4.10-SHA1: c4b1831d44c6144d3762ccc72f0c4e71a0c713e5
To: <linux-kernel@vger.kernel.org>
To: <kernel-hardening@lists.openwall.com>
Cc: <clementine.maurice@iaik.tugraz.at>
Cc: <moritz.lipp@iaik.tugraz.at>
Cc: Michael Schwarz <michael.schwarz@iaik.tugraz.at>
Cc: Richard Fellner <richard.fellner@student.tugraz.at>
Cc: <kirill.shutemov@linux.intel.com>
Cc: <anders.fogh@gdata-adan.de>
After several recent works [1,2,3] KASLR on x86_64 was basically
considered dead by many researchers. We have been working on an
efficient but effective fix for this problem and found that not mapping
the kernel space when running in user mode is the solution to this
problem [4] (the corresponding paper [5] will be presented at ESSoS17).
With this RFC patch we allow anybody to configure their kernel with the
flag CONFIG_KAISER to add our defense mechanism.
If there are any questions we would love to answer them.
We also appreciate any comments!
Cheers,
Daniel (+ the KAISER team from Graz University of Technology)
[1] http://www.ieee-security.org/TC/SP2013/papers/4977a191.pdf
[2] https://www.blackhat.com/docs/us-16/materials/us-16-Fogh-Using-Undocumented-CPU-Behaviour-To-See-Into-Kernel-Mode-And-Break-KASLR-In-The-Process.pdf
[3] https://www.blackhat.com/docs/us-16/materials/us-16-Jang-Breaking-Kernel-Address-Space-Layout-Randomization-KASLR-With-Intel-TSX.pdf
[4] https://github.com/IAIK/KAISER
[5] https://gruss.cc/files/kaiser.pdf
[patch based also on
https://raw.githubusercontent.com/IAIK/KAISER/master/KAISER/0001-KAISER-Kernel-Address-Isolation.patch]
Signed-off-by: Richard Fellner <richard.fellner@student.tugraz.at>
Signed-off-by: Moritz Lipp <moritz.lipp@iaik.tugraz.at>
Signed-off-by: Daniel Gruss <daniel.gruss@iaik.tugraz.at>
Signed-off-by: Michael Schwarz <michael.schwarz@iaik.tugraz.at>
Acked-by: Jiri Kosina <jkosina@suse.cz>
commit 5d62c183f9e9df1deeea0906d099a94e8a43047a upstream.
The conditions in irq_exit() to invoke tick_nohz_irq_exit() which
subsequently invokes tick_nohz_stop_sched_tick() are:
if ((idle_cpu(cpu) && !need_resched()) || tick_nohz_full_cpu(cpu))
If need_resched() is not set, but a timer softirq is pending then this is
an indication that the softirq code punted and delegated the execution to
softirqd. need_resched() is not true because the current interrupted task
takes precedence over softirqd.
Invoking tick_nohz_irq_exit() in this case can cause an endless loop of
timer interrupts because the timer wheel contains an expired timer, but
softirqs are not yet executed. So it returns an immediate expiry request,
which causes the timer to fire immediately again. Lather, rinse and
repeat....
Prevent that by adding a check for a pending timer soft interrupt to the
conditions in tick_nohz_stop_sched_tick() which avoid calling
get_next_timer_interrupt(). That keeps the tick sched timer on the tick and
prevents a repetitive programming of an already expired timer.
Reported-by: Sebastian Siewior <bigeasy@linutronix.d>
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
Link: https://lkml.kernel.org/r/alpine.DEB.2.20.1712272156050.2431@nanos
commit 26456f87aca7157c057de65c9414b37f1ab881d1 upstream.
The timer wheel bases are not (re)initialized on CPU hotplug. That leaves
them with a potentially stale clk and next_expiry valuem, which can cause
trouble then the CPU is plugged.
Add a prepare callback which forwards the clock, sets next_expiry to far in
the future and reset the control flags to a known state.
Set base->must_forward_clk so the first timer which is queued will try to
forward the clock to current jiffies.
Fixes: 500462a9de65 ("timers: Switch to a non-cascading wheel")
Link: https://lkml.kernel.org/r/alpine.DEB.2.20.1712272152200.2431@nanos
commit fd45bb77ad682be728d1002431d77b8c73342836 upstream.
The timer start debug function is called before the proper timer base is
set. As a consequence the trace data contains the stale CPU and flags
values.
Call the debug function after setting the new base and flags.
Link: https://lkml.kernel.org/r/20171222145337.792907137@linutronix.de
commit ced6d5c11d3e7b342f1a80f908e6756ebd4b8ddd upstream.
During boot and before base::nohz_active is set in the timer bases, deferrable
timers are enqueued into the standard timer base. This works correctly as
long as base::nohz_active is false.
Once it base::nohz_active is set and a timer which was enqueued before that
is accessed the lock selector code choses the lock of the deferred
base. This causes unlocked access to the standard base and in case the
timer is removed it does not clear the pending flag in the standard base
bitmap which causes get_next_timer_interrupt() to return bogus values.
To prevent that, the deferrable timers must be enqueued in the deferrable
base, even when base::nohz_active is not set. Those deferrable timers also
need to be expired unconditional.
Reviewed-by: Frederic Weisbecker <fweisbec@gmail.com>
Link: https://lkml.kernel.org/r/20171222145337.633328378@linutronix.de
commit 45d8b80c2ac5d21cd1e2954431fb676bc2b1e099 upstream.
Two info bits were added to the "commit" part of the ring buffer data page
when returned to be consumed. This was to inform the user space readers that
events have been missed, and that the count may be stored at the end of the
page.
What wasn't handled, was the splice code that actually called a function to
return the length of the data in order to zero out the rest of the page
before sending it up to user space. These data bits were returned with the
length making the value negative, and that negative value was not checked.
It was compared to PAGE_SIZE, and only used if the size was less than
PAGE_SIZE. Luckily PAGE_SIZE is unsigned long which made the compare an
unsigned compare, meaning the negative size value did not end up causing a
large portion of memory to be randomly zeroed out.
Fixes: 66a8cb95ed040 ("ring-buffer: Add place holder recording of dropped events")
commit 24f2aaf952ee0b59f31c3a18b8b36c9e3d3c2cf5 upstream.
Double free of the ring buffer happens when it fails to alloc new
ring buffer instance for max_buffer if TRACER_MAX_TRACE is configured.
The root cause is that the pointer is not set to NULL after the buffer
is freed in allocate_trace_buffers(), and the freeing of the ring
buffer is invoked again later if the pointer is not equal to Null,
as:
instance_mkdir()
|-allocate_trace_buffers()
|-allocate_trace_buffer(tr, &tr->trace_buffer...)
|-allocate_trace_buffer(tr, &tr->max_buffer...)
// allocate fail(-ENOMEM),first free
// and the buffer pointer is not set to null
|-ring_buffer_free(tr->trace_buffer.buffer)
// out_free_tr
|-free_trace_buffers()
|-free_trace_buffer(&tr->trace_buffer);
//if trace_buffer is not null, free again
|-ring_buffer_free(buf->buffer)
|-rb_free_cpu_buffer(buffer->buffers[cpu])
// ring_buffer_per_cpu is null, and
// crash in ring_buffer_per_cpu->pages
Link: http://lkml.kernel.org/r/20171226071253.8968-1-chunyan.zhang@spreadtrum.com
Fixes: 737223fbca3b1 ("tracing: Consolidate buffer allocation code")
Signed-off-by: Jing Xia <jing.xia@spreadtrum.com>
Signed-off-by: Chunyan Zhang <chunyan.zhang@spreadtrum.com>
commit 4397f04575c44e1440ec2e49b6302785c95fd2f8 upstream.
Jing Xia and Chunyan Zhang reported that on failing to allocate part of the
tracing buffer, memory is freed, but the pointers that point to them are not
initialized back to NULL, and later paths may try to free the freed memory
again. Jing and Chunyan fixed one of the locations that does this, but
missed a spot.
Reported-by: Jing Xia <jing.xia@spreadtrum.com>
Reported-by: Chunyan Zhang <chunyan.zhang@spreadtrum.com>
commit 6b7e633fe9c24682df550e5311f47fb524701586 upstream.
The ring_buffer_read_page() takes care of zeroing out any extra data in the
page that it returns. There's no need to zero it out again from the
consumer. It was removed from one consumer of this function, but
read_buffers_splice_read() did not remove it, and worse, it contained a
nasty bug because of it.
Fixes: 2711ca237a084 ("ring-buffer: Move zeroing out excess in page to ring buffer code")
An UNKNOWN_VALUE is not supposed to be derived from a pointer, unless
pointer leaks are allowed. Therefore, states_equal() must not treat
a state with a pointer in a register as "equal" to a state with an
UNKNOWN_VALUE in that register.
This was fixed differently upstream, but the code around here was
largely rewritten in 4.14 by commit f1174f77b50c "bpf/verifier: rework
value tracking". The bug can be detected by the bpf/verifier sub-test
"pointer/scalar confusion in state equality check (way 1)".
Cc: Edward Cree <ecree@solarflare.com>
Cc: Jann Horn <jannh@google.com>
Cc: Alexei Starovoitov <ast@kernel.org>
Cc: Daniel Borkmann <daniel@iogearbox.net>
[ Upstream commit 95a762e2c8c942780948091f8f2a4f32fce1ac6f ]
Distinguish between
BPF_ALU64|BPF_MOV|BPF_K (load 32-bit immediate, sign-extended to 64-bit)
and BPF_ALU|BPF_MOV|BPF_K (load 32-bit immediate, zero-padded to 64-bit);
only perform sign extension in the first case.
Starting with v4.14, this is exploitable by unprivileged users as long as
the unprivileged_bpf_disabled sysctl isn't set.
Debian assigned CVE-2017-16995 for this issue.
v3:
- add CVE number (Ben Hutchings)
Fixes: 484611357c19 ("bpf: allow access into map value arrays")
Signed-off-by: Jann Horn <jannh@google.com>
Acked-by: Edward Cree <ecree@solarflare.com>
Reject programs that compute wildly out-of-bounds stack pointers.
Otherwise, pointers can be computed with an offset that doesn't fit into an
`int`, causing security issues in the stack memory access check (as well as
signed integer overflow during offset addition).
This is a fix specifically for the v4.9 stable tree because the mainline
code looks very different at this point.
Fixes: 7bca0a9702edf ("bpf: enhance verifier to understand stack pointer arithmetic")
[ Upstream commit c131187db2d3fa2f8bf32fdf4e9a4ef805168467 ]
when the verifier detects that register contains a runtime constant
and it's compared with another constant it will prune exploration
of the branch that is guaranteed not to be taken at runtime.
This is all correct, but malicious program may be constructed
in such a way that it always has a constant comparison and
the other branch is never taken under any conditions.
In this case such path through the program will not be explored
by the verifier. It won't be taken at run-time either, but since
all instructions are JITed the malicious program may cause JITs
to complain about using reserved fields, etc.
To fix the issue we have to track the instructions explored by
the verifier and sanitize instructions that are dead at run time
with NOPs. We cannot reject such dead code, since llvm generates
it for valid C code, since it doesn't do as much data flow
analysis as the verifier does.
[ Upstream commit 8041902dae5299c1f194ba42d14383f734631009 ]
convert_ctx_accesses() replaces single bpf instruction with a set of
instructions. Adjust corresponding insn_aux_data while patching.
It's needed to make sure subsequent 'for(all insn)' loops
have matching insn and insn_aux_data.
