path: root/kernel
2015-02-11PM / Domains: Add generic OF-based PM domain look-upTomasz Figa
This patch introduces generic code to perform PM domain look-up using device tree and automatically bind devices to their PM domains. Generic device tree bindings are introduced to specify PM domains of devices in their device tree nodes. Backwards compatibility with legacy Samsung-specific PM domain bindings is provided, but for now the new code is not compiled when CONFIG_ARCH_EXYNOS is selected to avoid collision with legacy code. This will change as soon as the Exynos PM domain code gets converted to use the generic framework in further patch. This patch was originally submitted by Tomasz Figa when he was employed by Samsung. Link: http://marc.info/?l=linux-pm&m=139955349702152&w=2 Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Acked-by: Rob Herring <robh@kernel.org> Tested-by: Philipp Zabel <p.zabel@pengutronix.de> Reviewed-by: Kevin Hilman <khilman@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> (cherry picked from commit aa42240ab2544a8bcb2efb400193826f57f3175e) (cherry picked from commit 4a2d7a846761e3b86e08b903e5a1a088686e2181)
2015-02-11MLK-10238-1: Revert "base: power: Add generic OF-based power domain look-up"Robin Gong
This reverts commit 4aa055cb0634bc8d0389070104fe6aa7cfa99b8c. Signed-off-by: Robin Gong <b38343@freescale.com> (cherry picked from commit e599f64de890a60a3b9884dd5838c43472f145e2)
2015-01-15Move x86_64 idle notifiers to genericTodd Poynor
Move the x86_64 idle notifiers originally by Andi Kleen and Venkatesh Pallipadi to generic. Change-Id: Idf29cda15be151f494ff245933c12462643388d5 Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Signed-off-by: Todd Poynor <toddpoynor@google.com>
2015-01-15base: power: Add generic OF-based power domain look-upTomasz Figa
This patch introduces generic code to perform power domain look-up using device tree and automatically bind devices to their power domains. Generic device tree binding is introduced to specify power domains of devices in their device tree nodes. Backwards compatibility with legacy Samsung-specific power domain bindings is provided, but for now the new code is not compiled when CONFIG_ARCH_EXYNOS is selected to avoid collision with legacy code. This will change as soon as Exynos power domain code gets converted to use the generic framework in further patch. Signed-off-by: Tomasz Figa <t.figa@samsung.com> Reviewed-by: Mark Brown <broonie@linaro.org> Reviewed-by: Kevin Hilman <khilman@linaro.org> Reviewed-by: Philipp Zabel <philipp.zabel@gmail.com> [on i.MX6 GK802] Tested-by: Philipp Zabel <philipp.zabel@gmail.com> Reviewed-by: Ulf Hansson <ulf.hansson@linaro.org> [shawn.guo: http://thread.gmane.org/gmane.linux.kernel.samsung-soc/31029] Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2015-01-08exit: pidns: alloc_pid() leaks pid_namespace if child_reaper is exitingOleg Nesterov
commit 24c037ebf5723d4d9ab0996433cee4f96c292a4d upstream. alloc_pid() does get_pid_ns() beforehand but forgets to put_pid_ns() if it fails because disable_pid_allocation() was called by the exiting child_reaper. We could simply move get_pid_ns() down to successful return, but this fix tries to be as trivial as possible. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Reviewed-by: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Aaron Tomlin <atomlin@redhat.com> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Serge Hallyn <serge.hallyn@ubuntu.com> Cc: Sterling Alexander <stalexan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-08audit: restore AUDIT_LOGINUID unset ABIRichard Guy Briggs
commit 041d7b98ffe59c59fdd639931dea7d74f9aa9a59 upstream. A regression was caused by commit 780a7654cee8: audit: Make testing for a valid loginuid explicit. (which in turn attempted to fix a regression caused by e1760bd) When audit_krule_to_data() fills in the rules to get a listing, there was a missing clause to convert back from AUDIT_LOGINUID_SET to AUDIT_LOGINUID. This broke userspace by not returning the same information that was sent and expected. The rule: auditctl -a exit,never -F auid=-1 gives: auditctl -l LIST_RULES: exit,never f24=0 syscall=all when it should give: LIST_RULES: exit,never auid=-1 (0xffffffff) syscall=all Tag it so that it is reported the same way it was set. Create a new private flags audit_krule field (pflags) to store it that won't interact with the public one from the API. Signed-off-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-08userns: Allow setting gid_maps without privilege when setgroups is disabledEric W. Biederman
commit 66d2f338ee4c449396b6f99f5e75cd18eb6df272 upstream. Now that setgroups can be disabled and not reenabled, setting gid_map without privielge can now be enabled when setgroups is disabled. This restores most of the functionality that was lost when unprivileged setting of gid_map was removed. Applications that use this functionality will need to check to see if they use setgroups or init_groups, and if they don't they can be fixed by simply disabling setgroups before writing to gid_map. Reviewed-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-08userns: Add a knob to disable setgroups on a per user namespace basisEric W. Biederman
commit 9cc46516ddf497ea16e8d7cb986ae03a0f6b92f8 upstream. - Expose the knob to user space through a proc file /proc/<pid>/setgroups A value of "deny" means the setgroups system call is disabled in the current processes user namespace and can not be enabled in the future in this user namespace. A value of "allow" means the segtoups system call is enabled. - Descendant user namespaces inherit the value of setgroups from their parents. - A proc file is used (instead of a sysctl) as sysctls currently do not allow checking the permissions at open time. - Writing to the proc file is restricted to before the gid_map for the user namespace is set. This ensures that disabling setgroups at a user namespace level will never remove the ability to call setgroups from a process that already has that ability. A process may opt in to the setgroups disable for itself by creating, entering and configuring a user namespace or by calling setns on an existing user namespace with setgroups disabled. Processes without privileges already can not call setgroups so this is a noop. Prodcess with privilege become processes without privilege when entering a user namespace and as with any other path to dropping privilege they would not have the ability to call setgroups. So this remains within the bounds of what is possible without a knob to disable setgroups permanently in a user namespace. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-08userns: Rename id_map_mutex to userns_state_mutexEric W. Biederman
commit f0d62aec931e4ae3333c797d346dc4f188f454ba upstream. Generalize id_map_mutex so it can be used for more state of a user namespace. Reviewed-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-08userns: Only allow the creator of the userns unprivileged mappingsEric W. Biederman
commit f95d7918bd1e724675de4940039f2865e5eec5fe upstream. If you did not create the user namespace and are allowed to write to uid_map or gid_map you should already have the necessary privilege in the parent user namespace to establish any mapping you want so this will not affect userspace in practice. Limiting unprivileged uid mapping establishment to the creator of the user namespace makes it easier to verify all credentials obtained with the uid mapping can be obtained without the uid mapping without privilege. Limiting unprivileged gid mapping establishment (which is temporarily absent) to the creator of the user namespace also ensures that the combination of uid and gid can already be obtained without privilege. This is part of the fix for CVE-2014-8989. Reviewed-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-08userns: Check euid no fsuid when establishing an unprivileged uid mappingEric W. Biederman
commit 80dd00a23784b384ccea049bfb3f259d3f973b9d upstream. setresuid allows the euid to be set to any of uid, euid, suid, and fsuid. Therefor it is safe to allow an unprivileged user to map their euid and use CAP_SETUID privileged with exactly that uid, as no new credentials can be obtained. I can not find a combination of existing system calls that allows setting uid, euid, suid, and fsuid from the fsuid making the previous use of fsuid for allowing unprivileged mappings a bug. This is part of a fix for CVE-2014-8989. Reviewed-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-08userns: Don't allow unprivileged creation of gid mappingsEric W. Biederman
commit be7c6dba2332cef0677fbabb606e279ae76652c3 upstream. As any gid mapping will allow and must allow for backwards compatibility dropping groups don't allow any gid mappings to be established without CAP_SETGID in the parent user namespace. For a small class of applications this change breaks userspace and removes useful functionality. This small class of applications includes tools/testing/selftests/mount/unprivilged-remount-test.c Most of the removed functionality will be added back with the addition of a one way knob to disable setgroups. Once setgroups is disabled setting the gid_map becomes as safe as setting the uid_map. For more common applications that set the uid_map and the gid_map with privilege this change will have no affect. This is part of a fix for CVE-2014-8989. Reviewed-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-08userns: Don't allow setgroups until a gid mapping has been setablishedEric W. Biederman
commit 273d2c67c3e179adb1e74f403d1e9a06e3f841b5 upstream. setgroups is unique in not needing a valid mapping before it can be called, in the case of setgroups(0, NULL) which drops all supplemental groups. The design of the user namespace assumes that CAP_SETGID can not actually be used until a gid mapping is established. Therefore add a helper function to see if the user namespace gid mapping has been established and call that function in the setgroups permission check. This is part of the fix for CVE-2014-8989, being able to drop groups without privilege using user namespaces. Reviewed-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-08userns: Document what the invariant required for safe unprivileged mappings.Eric W. Biederman
commit 0542f17bf2c1f2430d368f44c8fcf2f82ec9e53e upstream. The rule is simple. Don't allow anything that wouldn't be allowed without unprivileged mappings. It was previously overlooked that establishing gid mappings would allow dropping groups and potentially gaining permission to files and directories that had lesser permissions for a specific group than for all other users. This is the rule needed to fix CVE-2014-8989 and prevent any other security issues with new_idmap_permitted. The reason for this rule is that the unix permission model is old and there are programs out there somewhere that take advantage of every little corner of it. So allowing a uid or gid mapping to be established without privielge that would allow anything that would not be allowed without that mapping will result in expectations from some code somewhere being violated. Violated expectations about the behavior of the OS is a long way to say a security issue. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-08groups: Consolidate the setgroups permission checksEric W. Biederman
commit 7ff4d90b4c24a03666f296c3d4878cd39001e81e upstream. Today there are 3 instances of setgroups and due to an oversight their permission checking has diverged. Add a common function so that they may all share the same permission checking code. This corrects the current oversight in the current permission checks and adds a helper to avoid this in the future. A user namespace security fix will update this new helper, shortly. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-12-06uprobes, x86: Fix _TIF_UPROBE vs _TIF_NOTIFY_RESUMEAndy Lutomirski
commit 82975bc6a6df743b9a01810fb32cb65d0ec5d60b upstream. x86 call do_notify_resume on paranoid returns if TIF_UPROBE is set but not on non-paranoid returns. I suspect that this is a mistake and that the code only works because int3 is paranoid. Setting _TIF_NOTIFY_RESUME in the uprobe code was probably a workaround for the x86 bug. With that bug fixed, we can remove _TIF_NOTIFY_RESUME from the uprobes code. Reported-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Acked-by: Borislav Petkov <bp@suse.de> Signed-off-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21perf: Handle compat ioctlPawel Moll
commit b3f207855f57b9c8f43a547a801340bb5cbc59e5 upstream. When running a 32-bit userspace on a 64-bit kernel (eg. i386 application on x86_64 kernel or 32-bit arm userspace on arm64 kernel) some of the perf ioctls must be treated with special care, as they have a pointer size encoded in the command. For example, PERF_EVENT_IOC_ID in 32-bit world will be encoded as 0x80042407, but 64-bit kernel will expect 0x80082407. In result the ioctl will fail returning -ENOTTY. This patch solves the problem by adding code fixing up the size as compat_ioctl file operation. Reported-by: Drew Richardson <drew.richardson@arm.com> Signed-off-by: Pawel Moll <pawel.moll@arm.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1402671812-9078-1-git-send-email-pawel.moll@arm.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: David Ahern <daahern@cisco.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21rcu: Use rcu_gp_kthread_wake() to wake up grace period kthreadsPranith Kumar
commit 2aa792e6faf1a00f5accf1f69e87e11a390ba2cd upstream. The rcu_gp_kthread_wake() function checks for three conditions before waking up grace period kthreads: * Is the thread we are trying to wake up the current thread? * Are the gp_flags zero? (all threads wait on non-zero gp_flags condition) * Is there no thread created for this flavour, hence nothing to wake up? If any one of these condition is true, we do not call wake_up(). It was found that there are quite a few avoidable wake ups both during idle time and under stress induced by rcutorture. Idle: Total:66000, unnecessary:66000, case1:61827, case2:66000, case3:0 Total:68000, unnecessary:68000, case1:63696, case2:68000, case3:0 rcutorture: Total:254000, unnecessary:254000, case1:199913, case2:254000, case3:0 Total:256000, unnecessary:256000, case1:201784, case2:256000, case3:0 Here case{1-3} are the cases listed above. We can avoid these wake ups by using rcu_gp_kthread_wake() to conditionally wake up the grace period kthreads. There is a comment about an implied barrier supplied by the wake_up() logic. This barrier is necessary for the awakened thread to see the updated ->gp_flags. This flag is always being updated with the root node lock held. Also, the awakened thread tries to acquire the root node lock before reading ->gp_flags because of which there is proper ordering. Hence this commit tries to avoid calling wake_up() whenever we can by using rcu_gp_kthread_wake() function. Signed-off-by: Pranith Kumar <bobby.prani@gmail.com> CC: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Kamal Mostafa <kamal@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21rcu: Make callers awaken grace-period kthreadPaul E. McKenney
commit 48a7639ce80cf279834d0d44865e49ecd714f37d upstream. The rcu_start_gp_advanced() function currently uses irq_work_queue() to defer wakeups of the RCU grace-period kthread. This deferring is necessary to avoid RCU-scheduler deadlocks involving the rcu_node structure's lock, meaning that RCU cannot call any of the scheduler's wake-up functions while holding one of these locks. Unfortunately, the second and subsequent calls to irq_work_queue() are ignored, and the first call will be ignored (aside from queuing the work item) if the scheduler-clock tick is turned off. This is OK for many uses, especially those where irq_work_queue() is called from an interrupt or softirq handler, because in those cases the scheduler-clock-tick state will be re-evaluated, which will turn the scheduler-clock tick back on. On the next tick, any deferred work will then be processed. However, this strategy does not always work for RCU, which can be invoked at process level from idle CPUs. In this case, the tick might never be turned back on, indefinitely defering a grace-period start request. Note that the RCU CPU stall detector cannot see this condition, because there is no RCU grace period in progress. Therefore, we can (and do!) see long tens-of-seconds stalls in grace-period handling. In theory, we could see a full grace-period hang, but rcutorture testing to date has seen only the tens-of-seconds stalls. Event tracing demonstrates that irq_work_queue() is being called repeatedly to no effect during these stalls: The "newreq" event appears repeatedly from a task that is not one of the grace-period kthreads. In theory, irq_work_queue() might be fixed to avoid this sort of issue, but RCU's requirements are unusual and it is quite straightforward to pass wake-up responsibility up through RCU's call chain, so that the wakeup happens when the offending locks are released. This commit therefore makes this change. The rcu_start_gp_advanced(), rcu_start_future_gp(), rcu_accelerate_cbs(), rcu_advance_cbs(), __note_gp_changes(), and rcu_start_gp() functions now return a boolean which indicates when a wake-up is needed. A new rcu_gp_kthread_wake() does the wakeup when it is necessary and safe to do so: No self-wakes, no wake-ups if the ->gp_flags field indicates there is no need (as in someone else did the wake-up before we got around to it), and no wake-ups before the grace-period kthread has been created. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> [ Pranith: backport to 3.13-stable: just rcu_gp_kthread_wake(), prereq for 2aa792e "rcu: Use rcu_gp_kthread_wake() to wake up grace period kthreads" ] Signed-off-by: Pranith Kumar <bobby.prani@gmail.com> Signed-off-by: Kamal Mostafa <kamal@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21audit: keep inode pinnedMiklos Szeredi
commit 799b601451b21ebe7af0e6e8f6e2ccd4683c5064 upstream. Audit rules disappear when an inode they watch is evicted from the cache. This is likely not what we want. The guilty commit is "fsnotify: allow marks to not pin inodes in core", which didn't take into account that audit_tree adds watches with a zero mask. Adding any mask should fix this. Fixes: 90b1e7a57880 ("fsnotify: allow marks to not pin inodes in core") Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21audit: AUDIT_FEATURE_CHANGE message format missing delimiting spaceRichard Guy Briggs
commit 897f1acbb6702ddaa953e8d8436eee3b12016c7e upstream. Add a space between subj= and feature= fields to make them parsable. Signed-off-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-21audit: correct AUDIT_GET_FEATURE return message typeRichard Guy Briggs
commit 9ef91514774a140e468f99d73d7593521e6d25dc upstream. When an AUDIT_GET_FEATURE message is sent from userspace to the kernel, it should reply with a message tagged as an AUDIT_GET_FEATURE type with a struct audit_feature. The current reply is a message tagged as an AUDIT_GET type with a struct audit_feature. This appears to have been a cut-and-paste-eo in commit b0fed40. Reported-by: Steve Grubb <sgrubb@redhat.com> Signed-off-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-14sched: Use rq->rd in sched_setaffinity() under RCU read lockKirill Tkhai
commit f1e3a0932f3a9554371792a7daaf1e0eb19f66d5 upstream. Probability of use-after-free isn't zero in this place. Signed-off-by: Kirill Tkhai <ktkhai@parallels.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/20140922183636.11015.83611.stgit@localhost Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-14posix-timers: Fix stack info leak in timer_create()Mathias Krause
commit 6891c4509c792209c44ced55a60f13954cb50ef4 upstream. If userland creates a timer without specifying a sigevent info, we'll create one ourself, using a stack local variable. Particularly will we use the timer ID as sival_int. But as sigev_value is a union containing a pointer and an int, that assignment will only partially initialize sigev_value on systems where the size of a pointer is bigger than the size of an int. On such systems we'll copy the uninitialized stack bytes from the timer_create() call to userland when the timer actually fires and we're going to deliver the signal. Initialize sigev_value with 0 to plug the stack info leak. Found in the PaX patch, written by the PaX Team. Fixes: 5a9fa7307285 ("posix-timers: kill ->it_sigev_signo and...") Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Brad Spengler <spender@grsecurity.net> Cc: PaX Team <pageexec@freemail.hu> Link: http://lkml.kernel.org/r/1412456799-32339-1-git-send-email-minipli@googlemail.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-14PM / Sleep: fix recovery during resuming from hibernationImre Deak
commit 94fb823fcb4892614f57e59601bb9d4920f24711 upstream. If a device's dev_pm_ops::freeze callback fails during the QUIESCE phase, we don't rollback things correctly calling the thaw and complete callbacks. This could leave some devices in a suspended state in case of an error during resuming from hibernation. Signed-off-by: Imre Deak <imre.deak@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-14OOM, PM: OOM killed task shouldn't escape PM suspendMichal Hocko
commit 5695be142e203167e3cb515ef86a88424f3524eb upstream. PM freezer relies on having all tasks frozen by the time devices are getting frozen so that no task will touch them while they are getting frozen. But OOM killer is allowed to kill an already frozen task in order to handle OOM situtation. In order to protect from late wake ups OOM killer is disabled after all tasks are frozen. This, however, still keeps a window open when a killed task didn't manage to die by the time freeze_processes finishes. Reduce the race window by checking all tasks after OOM killer has been disabled. This is still not race free completely unfortunately because oom_killer_disable cannot stop an already ongoing OOM killer so a task might still wake up from the fridge and get killed without freeze_processes noticing. Full synchronization of OOM and freezer is, however, too heavy weight for this highly unlikely case. Introduce and check oom_kills counter which gets incremented early when the allocator enters __alloc_pages_may_oom path and only check all the tasks if the counter changes during the freezing attempt. The counter is updated so early to reduce the race window since allocator checked oom_killer_disabled which is set by PM-freezing code. A false positive will push the PM-freezer into a slow path but that is not a big deal. Changes since v1 - push the re-check loop out of freeze_processes into check_frozen_processes and invert the condition to make the code more readable as per Rafael Fixes: f660daac474c6f (oom: thaw threads if oom killed thread is frozen before deferring) Signed-off-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-14freezer: Do not freeze tasks killed by OOM killerCong Wang
commit 51fae6da640edf9d266c94f36bc806c63c301991 upstream. Since f660daac474c6f (oom: thaw threads if oom killed thread is frozen before deferring) OOM killer relies on being able to thaw a frozen task to handle OOM situation but a3201227f803 (freezer: make freezing() test freeze conditions in effect instead of TIF_FREEZE) has reorganized the code and stopped clearing freeze flag in __thaw_task. This means that the target task only wakes up and goes into the fridge again because the freezing condition hasn't changed for it. This reintroduces the bug fixed by f660daac474c6f. Fix the issue by checking for TIF_MEMDIE thread flag in freezing_slow_path and exclude the task from freezing completely. If a task was already frozen it would get woken by __thaw_task from OOM killer and get out of freezer after rechecking freezing(). Changes since v1 - put TIF_MEMDIE check into freezing_slowpath rather than in __refrigerator as per Oleg - return __thaw_task into oom_scan_process_thread because oom_kill_process will not wake task in the fridge because it is sleeping uninterruptible [mhocko@suse.cz: rewrote the changelog] Fixes: a3201227f803 (freezer: make freezing() test freeze conditions in effect instead of TIF_FREEZE) Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Michal Hocko <mhocko@suse.cz> Acked-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-14modules, lock around setting of MODULE_STATE_UNFORMEDPrarit Bhargava
commit d3051b489aa81ca9ba62af366149ef42b8dae97c upstream. A panic was seen in the following sitation. There are two threads running on the system. The first thread is a system monitoring thread that is reading /proc/modules. The second thread is loading and unloading a module (in this example I'm using my simple dummy-module.ko). Note, in the "real world" this occurred with the qlogic driver module. When doing this, the following panic occurred: ------------[ cut here ]------------ kernel BUG at kernel/module.c:3739! invalid opcode: 0000 [#1] SMP Modules linked in: binfmt_misc sg nfsv3 rpcsec_gss_krb5 nfsv4 dns_resolver nfs fscache intel_powerclamp coretemp kvm_intel kvm crct10dif_pclmul crc32_pclmul crc32c_intel ghash_clmulni_intel aesni_intel lrw igb gf128mul glue_helper iTCO_wdt iTCO_vendor_support ablk_helper ptp sb_edac cryptd pps_core edac_core shpchp i2c_i801 pcspkr wmi lpc_ich ioatdma mfd_core dca ipmi_si nfsd ipmi_msghandler auth_rpcgss nfs_acl lockd sunrpc xfs libcrc32c sr_mod cdrom sd_mod crc_t10dif crct10dif_common mgag200 syscopyarea sysfillrect sysimgblt i2c_algo_bit drm_kms_helper ttm isci drm libsas ahci libahci scsi_transport_sas libata i2c_core dm_mirror dm_region_hash dm_log dm_mod [last unloaded: dummy_module] CPU: 37 PID: 186343 Comm: cat Tainted: GF O-------------- 3.10.0+ #7 Hardware name: Intel Corporation S2600CP/S2600CP, BIOS RMLSDP.86I.00.29.D696.1311111329 11/11/2013 task: ffff8807fd2d8000 ti: ffff88080fa7c000 task.ti: ffff88080fa7c000 RIP: 0010:[<ffffffff810d64c5>] [<ffffffff810d64c5>] module_flags+0xb5/0xc0 RSP: 0018:ffff88080fa7fe18 EFLAGS: 00010246 RAX: 0000000000000003 RBX: ffffffffa03b5200 RCX: 0000000000000000 RDX: 0000000000001000 RSI: ffff88080fa7fe38 RDI: ffffffffa03b5000 RBP: ffff88080fa7fe28 R08: 0000000000000010 R09: 0000000000000000 R10: 0000000000000000 R11: 000000000000000f R12: ffffffffa03b5000 R13: ffffffffa03b5008 R14: ffffffffa03b5200 R15: ffffffffa03b5000 FS: 00007f6ae57ef740(0000) GS:ffff88101e7a0000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000404f70 CR3: 0000000ffed48000 CR4: 00000000001407e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Stack: ffffffffa03b5200 ffff8810101e4800 ffff88080fa7fe70 ffffffff810d666c ffff88081e807300 000000002e0f2fbf 0000000000000000 ffff88100f257b00 ffffffffa03b5008 ffff88080fa7ff48 ffff8810101e4800 ffff88080fa7fee0 Call Trace: [<ffffffff810d666c>] m_show+0x19c/0x1e0 [<ffffffff811e4d7e>] seq_read+0x16e/0x3b0 [<ffffffff812281ed>] proc_reg_read+0x3d/0x80 [<ffffffff811c0f2c>] vfs_read+0x9c/0x170 [<ffffffff811c1a58>] SyS_read+0x58/0xb0 [<ffffffff81605829>] system_call_fastpath+0x16/0x1b Code: 48 63 c2 83 c2 01 c6 04 03 29 48 63 d2 eb d9 0f 1f 80 00 00 00 00 48 63 d2 c6 04 13 2d 41 8b 0c 24 8d 50 02 83 f9 01 75 b2 eb cb <0f> 0b 66 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 55 48 89 e5 41 RIP [<ffffffff810d64c5>] module_flags+0xb5/0xc0 RSP <ffff88080fa7fe18> Consider the two processes running on the system. CPU 0 (/proc/modules reader) CPU 1 (loading/unloading module) CPU 0 opens /proc/modules, and starts displaying data for each module by traversing the modules list via fs/seq_file.c:seq_open() and fs/seq_file.c:seq_read(). For each module in the modules list, seq_read does op->start() <-- this is a pointer to m_start() op->show() <- this is a pointer to m_show() op->stop() <-- this is a pointer to m_stop() The m_start(), m_show(), and m_stop() module functions are defined in kernel/module.c. The m_start() and m_stop() functions acquire and release the module_mutex respectively. ie) When reading /proc/modules, the module_mutex is acquired and released for each module. m_show() is called with the module_mutex held. It accesses the module struct data and attempts to write out module data. It is in this code path that the above BUG_ON() warning is encountered, specifically m_show() calls static char *module_flags(struct module *mod, char *buf) { int bx = 0; BUG_ON(mod->state == MODULE_STATE_UNFORMED); ... The other thread, CPU 1, in unloading the module calls the syscall delete_module() defined in kernel/module.c. The module_mutex is acquired for a short time, and then released. free_module() is called without the module_mutex. free_module() then sets mod->state = MODULE_STATE_UNFORMED, also without the module_mutex. Some additional code is called and then the module_mutex is reacquired to remove the module from the modules list: /* Now we can delete it from the lists */ mutex_lock(&module_mutex); stop_machine(__unlink_module, mod, NULL); mutex_unlock(&module_mutex); This is the sequence of events that leads to the panic. CPU 1 is removing dummy_module via delete_module(). It acquires the module_mutex, and then releases it. CPU 1 has NOT set dummy_module->state to MODULE_STATE_UNFORMED yet. CPU 0, which is reading the /proc/modules, acquires the module_mutex and acquires a pointer to the dummy_module which is still in the modules list. CPU 0 calls m_show for dummy_module. The check in m_show() for MODULE_STATE_UNFORMED passed for dummy_module even though it is being torn down. Meanwhile CPU 1, which has been continuing to remove dummy_module without holding the module_mutex, now calls free_module() and sets dummy_module->state to MODULE_STATE_UNFORMED. CPU 0 now calls module_flags() with dummy_module and ... static char *module_flags(struct module *mod, char *buf) { int bx = 0; BUG_ON(mod->state == MODULE_STATE_UNFORMED); and BOOM. Acquire and release the module_mutex lock around the setting of MODULE_STATE_UNFORMED in the teardown path, which should resolve the problem. Testing: In the unpatched kernel I can panic the system within 1 minute by doing while (true) do insmod dummy_module.ko; rmmod dummy_module.ko; done and while (true) do cat /proc/modules; done in separate terminals. In the patched kernel I was able to run just over one hour without seeing any issues. I also verified the output of panic via sysrq-c and the output of /proc/modules looks correct for all three states for the dummy_module. dummy_module 12661 0 - Unloading 0xffffffffa03a5000 (OE-) dummy_module 12661 0 - Live 0xffffffffa03bb000 (OE) dummy_module 14015 1 - Loading 0xffffffffa03a5000 (OE+) Signed-off-by: Prarit Bhargava <prarit@redhat.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-14sched: Use dl_bw_of() under RCU read lockKirill Tkhai
commit 66339c31bc3978d5fff9c4b4cb590a861def4db2 upstream. dl_bw_of() dereferences rq->rd which has to have RCU read lock held. Probability of use-after-free isn't zero here. Also add lockdep assert into dl_bw_cpus(). Signed-off-by: Kirill Tkhai <ktkhai@parallels.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/20140922183624.11015.71558.stgit@localhost Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-14tracing/syscalls: Ignore numbers outside NR_syscalls' rangeRabin Vincent
commit 086ba77a6db00ed858ff07451bedee197df868c9 upstream. ARM has some private syscalls (for example, set_tls(2)) which lie outside the range of NR_syscalls. If any of these are called while syscall tracing is being performed, out-of-bounds array access will occur in the ftrace and perf sys_{enter,exit} handlers. # trace-cmd record -e raw_syscalls:* true && trace-cmd report ... true-653 [000] 384.675777: sys_enter: NR 192 (0, 1000, 3, 4000022, ffffffff, 0) true-653 [000] 384.675812: sys_exit: NR 192 = 1995915264 true-653 [000] 384.675971: sys_enter: NR 983045 (76f74480, 76f74000, 76f74b28, 76f74480, 76f76f74, 1) true-653 [000] 384.675988: sys_exit: NR 983045 = 0 ... # trace-cmd record -e syscalls:* true [ 17.289329] Unable to handle kernel paging request at virtual address aaaaaace [ 17.289590] pgd = 9e71c000 [ 17.289696] [aaaaaace] *pgd=00000000 [ 17.289985] Internal error: Oops: 5 [#1] PREEMPT SMP ARM [ 17.290169] Modules linked in: [ 17.290391] CPU: 0 PID: 704 Comm: true Not tainted 3.18.0-rc2+ #21 [ 17.290585] task: 9f4dab00 ti: 9e710000 task.ti: 9e710000 [ 17.290747] PC is at ftrace_syscall_enter+0x48/0x1f8 [ 17.290866] LR is at syscall_trace_enter+0x124/0x184 Fix this by ignoring out-of-NR_syscalls-bounds syscall numbers. Commit cd0980fc8add "tracing: Check invalid syscall nr while tracing syscalls" added the check for less than zero, but it should have also checked for greater than NR_syscalls. Link: http://lkml.kernel.org/p/1414620418-29472-1-git-send-email-rabin@rab.in Fixes: cd0980fc8add "tracing: Check invalid syscall nr while tracing syscalls" Signed-off-by: Rabin Vincent <rabin@rab.in> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-30futex: Ensure get_futex_key_refs() always implies a barrierCatalin Marinas
commit 76835b0ebf8a7fe85beb03c75121419a7dec52f0 upstream. Commit b0c29f79ecea (futexes: Avoid taking the hb->lock if there's nothing to wake up) changes the futex code to avoid taking a lock when there are no waiters. This code has been subsequently fixed in commit 11d4616bd07f (futex: revert back to the explicit waiter counting code). Both the original commit and the fix-up rely on get_futex_key_refs() to always imply a barrier. However, for private futexes, none of the cases in the switch statement of get_futex_key_refs() would be hit and the function completes without a memory barrier as required before checking the "waiters" in futex_wake() -> hb_waiters_pending(). The consequence is a race with a thread waiting on a futex on another CPU, allowing the waker thread to read "waiters == 0" while the waiter thread to have read "futex_val == locked" (in kernel). Without this fix, the problem (user space deadlocks) can be seen with Android bionic's mutex implementation on an arm64 multi-cluster system. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Reported-by: Matteo Franchin <Matteo.Franchin@arm.com> Fixes: b0c29f79ecea (futexes: Avoid taking the hb->lock if there's nothing to wake up) Acked-by: Davidlohr Bueso <dave@stgolabs.net> Tested-by: Mike Galbraith <umgwanakikbuti@gmail.com> Cc: Darren Hart <dvhart@linux.intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-09mm: per-thread vma cachingDavidlohr Bueso
commit 615d6e8756c87149f2d4c1b93d471bca002bd849 upstream. This patch is a continuation of efforts trying to optimize find_vma(), avoiding potentially expensive rbtree walks to locate a vma upon faults. The original approach (https://lkml.org/lkml/2013/11/1/410), where the largest vma was also cached, ended up being too specific and random, thus further comparison with other approaches were needed. There are two things to consider when dealing with this, the cache hit rate and the latency of find_vma(). Improving the hit-rate does not necessarily translate in finding the vma any faster, as the overhead of any fancy caching schemes can be too high to consider. We currently cache the last used vma for the whole address space, which provides a nice optimization, reducing the total cycles in find_vma() by up to 250%, for workloads with good locality. On the other hand, this simple scheme is pretty much useless for workloads with poor locality. Analyzing ebizzy runs shows that, no matter how many threads are running, the mmap_cache hit rate is less than 2%, and in many situations below 1%. The proposed approach is to replace this scheme with a small per-thread cache, maximizing hit rates at a very low maintenance cost. Invalidations are performed by simply bumping up a 32-bit sequence number. The only expensive operation is in the rare case of a seq number overflow, where all caches that share the same address space are flushed. Upon a miss, the proposed replacement policy is based on the page number that contains the virtual address in question. Concretely, the following results are seen on an 80 core, 8 socket x86-64 box: 1) System bootup: Most programs are single threaded, so the per-thread scheme does improve ~50% hit rate by just adding a few more slots to the cache. +----------------+----------+------------------+ | caching scheme | hit-rate | cycles (billion) | +----------------+----------+------------------+ | baseline | 50.61% | 19.90 | | patched | 73.45% | 13.58 | +----------------+----------+------------------+ 2) Kernel build: This one is already pretty good with the current approach as we're dealing with good locality. +----------------+----------+------------------+ | caching scheme | hit-rate | cycles (billion) | +----------------+----------+------------------+ | baseline | 75.28% | 11.03 | | patched | 88.09% | 9.31 | +----------------+----------+------------------+ 3) Oracle 11g Data Mining (4k pages): Similar to the kernel build workload. +----------------+----------+------------------+ | caching scheme | hit-rate | cycles (billion) | +----------------+----------+------------------+ | baseline | 70.66% | 17.14 | | patched | 91.15% | 12.57 | +----------------+----------+------------------+ 4) Ebizzy: There's a fair amount of variation from run to run, but this approach always shows nearly perfect hit rates, while baseline is just about non-existent. The amounts of cycles can fluctuate between anywhere from ~60 to ~116 for the baseline scheme, but this approach reduces it considerably. For instance, with 80 threads: +----------------+----------+------------------+ | caching scheme | hit-rate | cycles (billion) | +----------------+----------+------------------+ | baseline | 1.06% | 91.54 | | patched | 99.97% | 14.18 | +----------------+----------+------------------+ [akpm@linux-foundation.org: fix nommu build, per Davidlohr] [akpm@linux-foundation.org: document vmacache_valid() logic] [akpm@linux-foundation.org: attempt to untangle header files] [akpm@linux-foundation.org: add vmacache_find() BUG_ON] [hughd@google.com: add vmacache_valid_mm() (from Oleg)] [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: adjust and enhance comments] Signed-off-by: Davidlohr Bueso <davidlohr@hp.com> Reviewed-by: Rik van Riel <riel@redhat.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Reviewed-by: Michel Lespinasse <walken@google.com> Cc: Oleg Nesterov <oleg@redhat.com> Tested-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-09mm: optimize put_mems_allowed() usageMel Gorman
commit d26914d11751b23ca2e8747725f2cae10c2f2c1b upstream. Since put_mems_allowed() is strictly optional, its a seqcount retry, we don't need to evaluate the function if the allocation was in fact successful, saving a smp_rmb some loads and comparisons on some relative fast-paths. Since the naming, get/put_mems_allowed() does suggest a mandatory pairing, rename the interface, as suggested by Mel, to resemble the seqcount interface. This gives us: read_mems_allowed_begin() and read_mems_allowed_retry(), where it is important to note that the return value of the latter call is inverted from its previous incarnation. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-09jiffies: Fix timeval conversion to jiffiesAndrew Hunter
commit d78c9300c51d6ceed9f6d078d4e9366f259de28c upstream. timeval_to_jiffies tried to round a timeval up to an integral number of jiffies, but the logic for doing so was incorrect: intervals corresponding to exactly N jiffies would become N+1. This manifested itself particularly repeatedly stopping/starting an itimer: setitimer(ITIMER_PROF, &val, NULL); setitimer(ITIMER_PROF, NULL, &val); would add a full tick to val, _even if it was exactly representable in terms of jiffies_ (say, the result of a previous rounding.) Doing this repeatedly would cause unbounded growth in val. So fix the math. Here's what was wrong with the conversion: we essentially computed (eliding seconds) jiffies = usec * (NSEC_PER_USEC/TICK_NSEC) by using scaling arithmetic, which took the best approximation of NSEC_PER_USEC/TICK_NSEC with denominator of 2^USEC_JIFFIE_SC = x/(2^USEC_JIFFIE_SC), and computed: jiffies = (usec * x) >> USEC_JIFFIE_SC and rounded this calculation up in the intermediate form (since we can't necessarily exactly represent TICK_NSEC in usec.) But the scaling arithmetic is a (very slight) *over*approximation of the true value; that is, instead of dividing by (1 usec/ 1 jiffie), we effectively divided by (1 usec/1 jiffie)-epsilon (rounding down). This would normally be fine, but we want to round timeouts up, and we did so by adding 2^USEC_JIFFIE_SC - 1 before the shift; this would be fine if our division was exact, but dividing this by the slightly smaller factor was equivalent to adding just _over_ 1 to the final result (instead of just _under_ 1, as desired.) In particular, with HZ=1000, we consistently computed that 10000 usec was 11 jiffies; the same was true for any exact multiple of TICK_NSEC. We could possibly still round in the intermediate form, adding something less than 2^USEC_JIFFIE_SC - 1, but easier still is to convert usec->nsec, round in nanoseconds, and then convert using time*spec*_to_jiffies. This adds one constant multiplication, and is not observably slower in microbenchmarks on recent x86 hardware. Tested: the following program: int main() { struct itimerval zero = {{0, 0}, {0, 0}}; /* Initially set to 10 ms. */ struct itimerval initial = zero; initial.it_interval.tv_usec = 10000; setitimer(ITIMER_PROF, &initial, NULL); /* Save and restore several times. */ for (size_t i = 0; i < 10; ++i) { struct itimerval prev; setitimer(ITIMER_PROF, &zero, &prev); /* on old kernels, this goes up by TICK_USEC every iteration */ printf("previous value: %ld %ld %ld %ld\n", prev.it_interval.tv_sec, prev.it_interval.tv_usec, prev.it_value.tv_sec, prev.it_value.tv_usec); setitimer(ITIMER_PROF, &prev, NULL); } return 0; } Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: Paul Turner <pjt@google.com> Cc: Richard Cochran <richardcochran@gmail.com> Cc: Prarit Bhargava <prarit@redhat.com> Reviewed-by: Paul Turner <pjt@google.com> Reported-by: Aaron Jacobs <jacobsa@google.com> Signed-off-by: Andrew Hunter <ahh@google.com> [jstultz: Tweaked to apply to 3.17-rc] Signed-off-by: John Stultz <john.stultz@linaro.org> [bwh: Backported to 3.16: adjust filename] Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-09ring-buffer: Fix infinite spin in reading bufferSteven Rostedt (Red Hat)
commit 24607f114fd14f2f37e3e0cb3d47bce96e81e848 upstream. Commit 651e22f2701b "ring-buffer: Always reset iterator to reader page" fixed one bug but in the process caused another one. The reset is to update the header page, but that fix also changed the way the cached reads were updated. The cache reads are used to test if an iterator needs to be updated or not. A ring buffer iterator, when created, disables writes to the ring buffer but does not stop other readers or consuming reads from happening. Although all readers are synchronized via a lock, they are only synchronized when in the ring buffer functions. Those functions may be called by any number of readers. The iterator continues down when its not interrupted by a consuming reader. If a consuming read occurs, the iterator starts from the beginning of the buffer. The way the iterator sees that a consuming read has happened since its last read is by checking the reader "cache". The cache holds the last counts of the read and the reader page itself. Commit 651e22f2701b changed what was saved by the cache_read when the rb_iter_reset() occurred, making the iterator never match the cache. Then if the iterator calls rb_iter_reset(), it will go into an infinite loop by checking if the cache doesn't match, doing the reset and retrying, just to see that the cache still doesn't match! Which should never happen as the reset is suppose to set the cache to the current value and there's locks that keep a consuming reader from having access to the data. Fixes: 651e22f2701b "ring-buffer: Always reset iterator to reader page" Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-09perf: fix perf bug in fork()Peter Zijlstra
commit 6c72e3501d0d62fc064d3680e5234f3463ec5a86 upstream. Oleg noticed that a cleanup by Sylvain actually uncovered a bug; by calling perf_event_free_task() when failing sched_fork() we will not yet have done the memset() on ->perf_event_ctxp[] and will therefore try and 'free' the inherited contexts, which are still in use by the parent process. This is bad.. Suggested-by: Oleg Nesterov <oleg@redhat.com> Reported-by: Oleg Nesterov <oleg@redhat.com> Reported-by: Sylvain 'ythier' Hitier <sylvain.hitier@gmail.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-05PM / sleep: Use valid_state() for platform-dependent sleep states onlyRafael J. Wysocki
commit 43e8317b0bba1d6eb85f38a4a233d82d7c20d732 upstream. Use the observation that, for platform-dependent sleep states (PM_SUSPEND_STANDBY, PM_SUSPEND_MEM), a given state is either always supported or always unsupported and store that information in pm_states[] instead of calling valid_state() every time we need to check it. Also do not use valid_state() for PM_SUSPEND_FREEZE, which is always valid, and move the pm_test_level validity check for PM_SUSPEND_FREEZE directly into enter_state(). Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Cc: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-05PM / sleep: Add state field to pm_states[] entriesRafael J. Wysocki
commit 27ddcc6596e50cb8f03d2e83248897667811d8f6 upstream. To allow sleep states corresponding to the "mem", "standby" and "freeze" lables to be different from the pm_states[] indexes of those strings, introduce struct pm_sleep_state, consisting of a string label and a state number, and turn pm_states[] into an array of objects of that type. This modification should not lead to any functional changes. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Cc: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-05perf: Fix a race condition in perf_remove_from_context()Cong Wang
commit 3577af70a2ce4853d58e57d832e687d739281479 upstream. We saw a kernel soft lockup in perf_remove_from_context(), it looks like the `perf` process, when exiting, could not go out of the retry loop. Meanwhile, the target process was forking a child. So either the target process should execute the smp function call to deactive the event (if it was running) or it should do a context switch which deactives the event. It seems we optimize out a context switch in perf_event_context_sched_out(), and what's more important, we still test an obsolete task pointer when retrying, so no one actually would deactive that event in this situation. Fix it directly by reloading the task pointer in perf_remove_from_context(). This should cure the above soft lockup. Signed-off-by: Cong Wang <cwang@twopensource.com> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/1409696840-843-1-git-send-email-xiyou.wangcong@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-05alarmtimer: Lock k_itimer during timer callbackRichard Larocque
commit 474e941bed9262f5fa2394f9a4a67e24499e5926 upstream. Locks the k_itimer's it_lock member when handling the alarm timer's expiry callback. The regular posix timers defined in posix-timers.c have this lock held during timout processing because their callbacks are routed through posix_timer_fn(). The alarm timers follow a different path, so they ought to grab the lock somewhere else. Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@kernel.org> Cc: Richard Cochran <richardcochran@gmail.com> Cc: Prarit Bhargava <prarit@redhat.com> Cc: Sharvil Nanavati <sharvil@google.com> Signed-off-by: Richard Larocque <rlarocque@google.com> Signed-off-by: John Stultz <john.stultz@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-05alarmtimer: Do not signal SIGEV_NONE timersRichard Larocque
commit 265b81d23a46c39df0a735a3af4238954b41a4c2 upstream. Avoids sending a signal to alarm timers created with sigev_notify set to SIGEV_NONE by checking for that special case in the timeout callback. The regular posix timers avoid sending signals to SIGEV_NONE timers by not scheduling any callbacks for them in the first place. Although it would be possible to do something similar for alarm timers, it's simpler to handle this as a special case in the timeout. Prior to this patch, the alarm timer would ignore the sigev_notify value and try to deliver signals to the process anyway. Even worse, the sanity check for the value of sigev_signo is skipped when SIGEV_NONE was specified, so the signal number could be bogus. If sigev_signo was an unitialized value (as it often would be if SIGEV_NONE is used), then it's hard to predict which signal will be sent. Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@kernel.org> Cc: Richard Cochran <richardcochran@gmail.com> Cc: Prarit Bhargava <prarit@redhat.com> Cc: Sharvil Nanavati <sharvil@google.com> Signed-off-by: Richard Larocque <rlarocque@google.com> Signed-off-by: John Stultz <john.stultz@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-05alarmtimer: Return relative times in timer_gettimeRichard Larocque
commit e86fea764991e00a03ff1e56409ec9cacdbda4c9 upstream. Returns the time remaining for an alarm timer, rather than the time at which it is scheduled to expire. If the timer has already expired or it is not currently scheduled, the it_value's members are set to zero. This new behavior matches that of the other posix-timers and the POSIX specifications. This is a change in user-visible behavior, and may break existing applications. Hopefully, few users rely on the old incorrect behavior. Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@kernel.org> Cc: Richard Cochran <richardcochran@gmail.com> Cc: Prarit Bhargava <prarit@redhat.com> Cc: Sharvil Nanavati <sharvil@google.com> Signed-off-by: Richard Larocque <rlarocque@google.com> [jstultz: minor style tweak] Signed-off-by: John Stultz <john.stultz@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-05kcmp: fix standard comparison bugRasmus Villemoes
commit acbbe6fbb240a927ee1f5994f04d31267d422215 upstream. The C operator <= defines a perfectly fine total ordering on the set of values representable in a long. However, unlike its namesake in the integers, it is not translation invariant, meaning that we do not have "b <= c" iff "a+b <= a+c" for all a,b,c. This means that it is always wrong to try to boil down the relationship between two longs to a question about the sign of their difference, because the resulting relation [a LEQ b iff a-b <= 0] is neither anti-symmetric or transitive. The former is due to -LONG_MIN==LONG_MIN (take any two a,b with a-b = LONG_MIN; then a LEQ b and b LEQ a, but a != b). The latter can either be seen observing that x LEQ x+1 for all x, implying x LEQ x+1 LEQ x+2 ... LEQ x-1 LEQ x; or more directly with the simple example a=LONG_MIN, b=0, c=1, for which a-b < 0, b-c < 0, but a-c > 0. Note that it makes absolutely no difference that a transmogrying bijection has been applied before the comparison is done. In fact, had the obfuscation not been done, one could probably not observe the bug (assuming all values being compared always lie in one half of the address space, the mathematical value of a-b is always representable in a long). As it stands, one can easily obtain three file descriptors exhibiting the non-transitivity of kcmp(). Side note 1: I can't see that ensuring the MSB of the multiplier is set serves any purpose other than obfuscating the obfuscating code. Side note 2: #include <stdio.h> #include <stdlib.h> #include <string.h> #include <fcntl.h> #include <unistd.h> #include <assert.h> #include <sys/syscall.h> enum kcmp_type { KCMP_FILE, KCMP_VM, KCMP_FILES, KCMP_FS, KCMP_SIGHAND, KCMP_IO, KCMP_SYSVSEM, KCMP_TYPES, }; pid_t pid; int kcmp(pid_t pid1, pid_t pid2, int type, unsigned long idx1, unsigned long idx2) { return syscall(SYS_kcmp, pid1, pid2, type, idx1, idx2); } int cmp_fd(int fd1, int fd2) { int c = kcmp(pid, pid, KCMP_FILE, fd1, fd2); if (c < 0) { perror("kcmp"); exit(1); } assert(0 <= c && c < 3); return c; } int cmp_fdp(const void *a, const void *b) { static const int normalize[] = {0, -1, 1}; return normalize[cmp_fd(*(int*)a, *(int*)b)]; } #define MAX 100 /* This is plenty; I've seen it trigger for MAX==3 */ int main(int argc, char *argv[]) { int r, s, count = 0; int REL[3] = {0,0,0}; int fd[MAX]; pid = getpid(); while (count < MAX) { r = open("/dev/null", O_RDONLY); if (r < 0) break; fd[count++] = r; } printf("opened %d file descriptors\n", count); for (r = 0; r < count; ++r) { for (s = r+1; s < count; ++s) { REL[cmp_fd(fd[r], fd[s])]++; } } printf("== %d\t< %d\t> %d\n", REL[0], REL[1], REL[2]); qsort(fd, count, sizeof(fd[0]), cmp_fdp); memset(REL, 0, sizeof(REL)); for (r = 0; r < count; ++r) { for (s = r+1; s < count; ++s) { REL[cmp_fd(fd[r], fd[s])]++; } } printf("== %d\t< %d\t> %d\n", REL[0], REL[1], REL[2]); return (REL[0] + REL[2] != 0); } Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Reviewed-by: Cyrill Gorcunov <gorcunov@openvz.org> "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-05futex: Unlock hb->lock in futex_wait_requeue_pi() error pathThomas Gleixner
commit 13c42c2f43b19aab3195f2d357db00d1e885eaa8 upstream. futex_wait_requeue_pi() calls futex_wait_setup(). If futex_wait_setup() succeeds it returns with hb->lock held and preemption disabled. Now the sanity check after this does: if (match_futex(&q.key, &key2)) { ret = -EINVAL; goto out_put_keys; } which releases the keys but does not release hb->lock. So we happily return to user space with hb->lock held and therefor preemption disabled. Unlock hb->lock before taking the exit route. Reported-by: Dave "Trinity" Jones <davej@redhat.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Darren Hart <dvhart@linux.intel.com> Reviewed-by: Davidlohr Bueso <dave@stgolabs.net> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1409112318500.4178@nanos Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-05cgroup: fix unbalanced lockingZefan Li
commit eb4aec84d6bdf98d00cedb41c18000f7a31e648a upstream. cgroup_pidlist_start() holds cgrp->pidlist_mutex and then calls pidlist_array_load(), and cgroup_pidlist_stop() releases the mutex. It is wrong that we release the mutex in the failure path in pidlist_array_load(), because cgroup_pidlist_stop() will be called no matter if cgroup_pidlist_start() returns errno or not. Fixes: 4bac00d16a8760eae7205e41d2c246477d42a210 Signed-off-by: Zefan Li <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-05trace: Fix epoll hang when we race with new entriesJosef Bacik
commit 4ce97dbf50245227add17c83d87dc838e7ca79d0 upstream. Epoll on trace_pipe can sometimes hang in a weird case. If the ring buffer is empty when we set waiters_pending but an event shows up exactly at that moment we can miss being woken up by the ring buffers irq work. Since ring_buffer_empty() is inherently racey we will sometimes think that the buffer is not empty. So we don't get woken up and we don't think there are any events even though there were some ready when we added the watch, which makes us hang. This patch fixes this by making sure that we are actually on the wait list before we set waiters_pending, and add a memory barrier to make sure ring_buffer_empty() is going to be correct. Link: http://lkml.kernel.org/p/1408989581-23727-1-git-send-email-jbacik@fb.com Cc: Martin Lau <kafai@fb.com> Signed-off-by: Josef Bacik <jbacik@fb.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-17ring-buffer: Up rb_iter_peek() loop count to 3Steven Rostedt (Red Hat)
commit 021de3d904b88b1771a3a2cfc5b75023c391e646 upstream. After writting a test to try to trigger the bug that caused the ring buffer iterator to become corrupted, I hit another bug: WARNING: CPU: 1 PID: 5281 at kernel/trace/ring_buffer.c:3766 rb_iter_peek+0x113/0x238() Modules linked in: ipt_MASQUERADE sunrpc [...] CPU: 1 PID: 5281 Comm: grep Tainted: G W 3.16.0-rc3-test+ #143 Hardware name: To Be Filled By O.E.M. To Be Filled By O.E.M./To be filled by O.E.M., BIOS SDBLI944.86P 05/08/2007 0000000000000000 ffffffff81809a80 ffffffff81503fb0 0000000000000000 ffffffff81040ca1 ffff8800796d6010 ffffffff810c138d ffff8800796d6010 ffff880077438c80 ffff8800796d6010 ffff88007abbe600 0000000000000003 Call Trace: [<ffffffff81503fb0>] ? dump_stack+0x4a/0x75 [<ffffffff81040ca1>] ? warn_slowpath_common+0x7e/0x97 [<ffffffff810c138d>] ? rb_iter_peek+0x113/0x238 [<ffffffff810c138d>] ? rb_iter_peek+0x113/0x238 [<ffffffff810c14df>] ? ring_buffer_iter_peek+0x2d/0x5c [<ffffffff810c6f73>] ? tracing_iter_reset+0x6e/0x96 [<ffffffff810c74a3>] ? s_start+0xd7/0x17b [<ffffffff8112b13e>] ? kmem_cache_alloc_trace+0xda/0xea [<ffffffff8114cf94>] ? seq_read+0x148/0x361 [<ffffffff81132d98>] ? vfs_read+0x93/0xf1 [<ffffffff81132f1b>] ? SyS_read+0x60/0x8e [<ffffffff8150bf9f>] ? tracesys+0xdd/0xe2 Debugging this bug, which triggers when the rb_iter_peek() loops too many times (more than 2 times), I discovered there's a case that can cause that function to legitimately loop 3 times! rb_iter_peek() is different than rb_buffer_peek() as the rb_buffer_peek() only deals with the reader page (it's for consuming reads). The rb_iter_peek() is for traversing the buffer without consuming it, and as such, it can loop for one more reason. That is, if we hit the end of the reader page or any page, it will go to the next page and try again. That is, we have this: 1. iter->head > iter->head_page->page->commit (rb_inc_iter() which moves the iter to the next page) try again 2. event = rb_iter_head_event() event->type_len == RINGBUF_TYPE_TIME_EXTEND rb_advance_iter() try again 3. read the event. But we never get to 3, because the count is greater than 2 and we cause the WARNING and return NULL. Up the counter to 3. Fixes: 69d1b839f7ee "ring-buffer: Bind time extend and data events together" Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-17ring-buffer: Always reset iterator to reader pageSteven Rostedt (Red Hat)
commit 651e22f2701b4113989237c3048d17337dd2185c upstream. When performing a consuming read, the ring buffer swaps out a page from the ring buffer with a empty page and this page that was swapped out becomes the new reader page. The reader page is owned by the reader and since it was swapped out of the ring buffer, writers do not have access to it (there's an exception to that rule, but it's out of scope for this commit). When reading the "trace" file, it is a non consuming read, which means that the data in the ring buffer will not be modified. When the trace file is opened, a ring buffer iterator is allocated and writes to the ring buffer are disabled, such that the iterator will not have issues iterating over the data. Although the ring buffer disabled writes, it does not disable other reads, or even consuming reads. If a consuming read happens, then the iterator is reset and starts reading from the beginning again. My tests would sometimes trigger this bug on my i386 box: WARNING: CPU: 0 PID: 5175 at kernel/trace/trace.c:1527 __trace_find_cmdline+0x66/0xaa() Modules linked in: CPU: 0 PID: 5175 Comm: grep Not tainted 3.16.0-rc3-test+ #8 Hardware name: /DG965MQ, BIOS MQ96510J.86A.0372.2006.0605.1717 06/05/2006 00000000 00000000 f09c9e1c c18796b3 c1b5d74c f09c9e4c c103a0e3 c1b5154b f09c9e78 00001437 c1b5d74c 000005f7 c10bd85a c10bd85a c1cac57c f09c9eb0 ed0e0000 f09c9e64 c103a185 00000009 f09c9e5c c1b5154b f09c9e78 f09c9e80^M Call Trace: [<c18796b3>] dump_stack+0x4b/0x75 [<c103a0e3>] warn_slowpath_common+0x7e/0x95 [<c10bd85a>] ? __trace_find_cmdline+0x66/0xaa [<c10bd85a>] ? __trace_find_cmdline+0x66/0xaa [<c103a185>] warn_slowpath_fmt+0x33/0x35 [<c10bd85a>] __trace_find_cmdline+0x66/0xaa^M [<c10bed04>] trace_find_cmdline+0x40/0x64 [<c10c3c16>] trace_print_context+0x27/0xec [<c10c4360>] ? trace_seq_printf+0x37/0x5b [<c10c0b15>] print_trace_line+0x319/0x39b [<c10ba3fb>] ? ring_buffer_read+0x47/0x50 [<c10c13b1>] s_show+0x192/0x1ab [<c10bfd9a>] ? s_next+0x5a/0x7c [<c112e76e>] seq_read+0x267/0x34c [<c1115a25>] vfs_read+0x8c/0xef [<c112e507>] ? seq_lseek+0x154/0x154 [<c1115ba2>] SyS_read+0x54/0x7f [<c188488e>] syscall_call+0x7/0xb ---[ end trace 3f507febd6b4cc83 ]--- >>>> ##### CPU 1 buffer started #### Which was the __trace_find_cmdline() function complaining about the pid in the event record being negative. After adding more test cases, this would trigger more often. Strangely enough, it would never trigger on a single test, but instead would trigger only when running all the tests. I believe that was the case because it required one of the tests to be shutting down via delayed instances while a new test started up. After spending several days debugging this, I found that it was caused by the iterator becoming corrupted. Debugging further, I found out why the iterator became corrupted. It happened with the rb_iter_reset(). As consuming reads may not read the full reader page, and only part of it, there's a "read" field to know where the last read took place. The iterator, must also start at the read position. In the rb_iter_reset() code, if the reader page was disconnected from the ring buffer, the iterator would start at the head page within the ring buffer (where writes still happen). But the mistake there was that it still used the "read" field to start the iterator on the head page, where it should always start at zero because readers never read from within the ring buffer where writes occur. I originally wrote a patch to have it set the iter->head to 0 instead of iter->head_page->read, but then I questioned why it wasn't always setting the iter to point to the reader page, as the reader page is still valid. The list_empty(reader_page->list) just means that it was successful in swapping out. But the reader_page may still have data. There was a bug report a long time ago that was not reproducible that had something about trace_pipe (consuming read) not matching trace (iterator read). This may explain why that happened. Anyway, the correct answer to this bug is to always use the reader page an not reset the iterator to inside the writable ring buffer. Fixes: d769041f8653 "ring_buffer: implement new locking" Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-17kernel/smp.c:on_each_cpu_cond(): fix warning in fallback pathSasha Levin
commit 618fde872163e782183ce574c77f1123e2be8887 upstream. The rarely-executed memry-allocation-failed callback path generates a WARN_ON_ONCE() when smp_call_function_single() succeeds. Presumably it's supposed to warn on failures. Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Christoph Lameter <cl@gentwo.org> Cc: Gilad Ben-Yossef <gilad@benyossef.com> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Tejun Heo <htejun@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-17CAPABILITIES: remove undefined caps from all processesEric Paris
commit 7d8b6c63751cfbbe5eef81a48c22978b3407a3ad upstream. This is effectively a revert of 7b9a7ec565505699f503b4fcf61500dceb36e744 plus fixing it a different way... We found, when trying to run an application from an application which had dropped privs that the kernel does security checks on undefined capability bits. This was ESPECIALLY difficult to debug as those undefined bits are hidden from /proc/$PID/status. Consider a root application which drops all capabilities from ALL 4 capability sets. We assume, since the application is going to set eff/perm/inh from an array that it will clear not only the defined caps less than CAP_LAST_CAP, but also the higher 28ish bits which are undefined future capabilities. The BSET gets cleared differently. Instead it is cleared one bit at a time. The problem here is that in security/commoncap.c::cap_task_prctl() we actually check the validity of a capability being read. So any task which attempts to 'read all things set in bset' followed by 'unset all things set in bset' will not even attempt to unset the undefined bits higher than CAP_LAST_CAP. So the 'parent' will look something like: CapInh: 0000000000000000 CapPrm: 0000000000000000 CapEff: 0000000000000000 CapBnd: ffffffc000000000 All of this 'should' be fine. Given that these are undefined bits that aren't supposed to have anything to do with permissions. But they do... So lets now consider a task which cleared the eff/perm/inh completely and cleared all of the valid caps in the bset (but not the invalid caps it couldn't read out of the kernel). We know that this is exactly what the libcap-ng library does and what the go capabilities library does. They both leave you in that above situation if you try to clear all of you capapabilities from all 4 sets. If that root task calls execve() the child task will pick up all caps not blocked by the bset. The bset however does not block bits higher than CAP_LAST_CAP. So now the child task has bits in eff which are not in the parent. These are 'meaningless' undefined bits, but still bits which the parent doesn't have. The problem is now in cred_cap_issubset() (or any operation which does a subset test) as the child, while a subset for valid cap bits, is not a subset for invalid cap bits! So now we set durring commit creds that the child is not dumpable. Given it is 'more priv' than its parent. It also means the parent cannot ptrace the child and other stupidity. The solution here: 1) stop hiding capability bits in status This makes debugging easier! 2) stop giving any task undefined capability bits. it's simple, it you don't put those invalid bits in CAP_FULL_SET you won't get them in init and you won't get them in any other task either. This fixes the cap_issubset() tests and resulting fallout (which made the init task in a docker container untraceable among other things) 3) mask out undefined bits when sys_capset() is called as it might use ~0, ~0 to denote 'all capabilities' for backward/forward compatibility. This lets 'capsh --caps="all=eip" -- -c /bin/bash' run. 4) mask out undefined bit when we read a file capability off of disk as again likely all bits are set in the xattr for forward/backward compatibility. This lets 'setcap all+pe /bin/bash; /bin/bash' run Signed-off-by: Eric Paris <eparis@redhat.com> Reviewed-by: Kees Cook <keescook@chromium.org> Cc: Andrew Vagin <avagin@openvz.org> Cc: Andrew G. Morgan <morgan@kernel.org> Cc: Serge E. Hallyn <serge.hallyn@canonical.com> Cc: Kees Cook <keescook@chromium.org> Cc: Steve Grubb <sgrubb@redhat.com> Cc: Dan Walsh <dwalsh@redhat.com> Signed-off-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
