path: root/kernel
2018-08-15cpu/hotplug: Non-SMP machines do not make use of booted_onceAbel Vesa
commit 269777aa530f3438ec1781586cdac0b5fe47b061 upstream. Commit 0cc3cd21657b ("cpu/hotplug: Boot HT siblings at least once") breaks non-SMP builds. [ I suspect the 'bool' fields should just be made to be bitfields and be exposed regardless of configuration, but that's a separate cleanup that I'll leave to the owners of this file for later. - Linus ] Fixes: 0cc3cd21657b ("cpu/hotplug: Boot HT siblings at least once") Cc: Dave Hansen <dave.hansen@intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Signed-off-by: Abel Vesa <abelvesa@linux.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-15cpu/hotplug: Fix SMT supported evaluationThomas Gleixner
commit bc2d8d262cba5736332cbc866acb11b1c5748aa9 upstream Josh reported that the late SMT evaluation in cpu_smt_state_init() sets cpu_smt_control to CPU_SMT_NOT_SUPPORTED in case that 'nosmt' was supplied on the kernel command line as it cannot differentiate between SMT disabled by BIOS and SMT soft disable via 'nosmt'. That wreckages the state and makes the sysfs interface unusable. Rework this so that during bringup of the non boot CPUs the availability of SMT is determined in cpu_smt_allowed(). If a newly booted CPU is not a 'primary' thread then set the local cpu_smt_available marker and evaluate this explicitely right after the initial SMP bringup has finished. SMT evaulation on x86 is a trainwreck as the firmware has all the information _before_ booting the kernel, but there is no interface to query it. Fixes: 73d5e2b47264 ("cpu/hotplug: detect SMT disabled by BIOS") Reported-by: Josh Poimboeuf <jpoimboe@redhat.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-15cpu/hotplug: detect SMT disabled by BIOSJosh Poimboeuf
commit 73d5e2b472640b1fcdb61ae8be389912ef211bda upstream If SMT is disabled in BIOS, the CPU code doesn't properly detect it. The /sys/devices/system/cpu/smt/control file shows 'on', and the 'l1tf' vulnerabilities file shows SMT as vulnerable. Fix it by forcing 'cpu_smt_control' to CPU_SMT_NOT_SUPPORTED in such a case. Unfortunately the detection can only be done after bringing all the CPUs online, so we have to overwrite any previous writes to the variable. Reported-by: Joe Mario <jmario@redhat.com> Tested-by: Jiri Kosina <jkosina@suse.cz> Fixes: f048c399e0f7 ("x86/topology: Provide topology_smt_supported()") Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-15cpu/hotplug: Set CPU_SMT_NOT_SUPPORTED earlyThomas Gleixner
commit fee0aede6f4739c87179eca76136f83210953b86 upstream The CPU_SMT_NOT_SUPPORTED state is set (if the processor does not support SMT) when the sysfs SMT control file is initialized. That was fine so far as this was only required to make the output of the control file correct and to prevent writes in that case. With the upcoming l1tf command line parameter, this needs to be set up before the L1TF mitigation selection and command line parsing happens. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Jiri Kosina <jkosina@suse.cz> Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Reviewed-by: Josh Poimboeuf <jpoimboe@redhat.com> Link: https://lkml.kernel.org/r/20180713142323.121795971@linutronix.de Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-15cpu/hotplug: Expose SMT control init functionJiri Kosina
commit 8e1b706b6e819bed215c0db16345568864660393 upstream The L1TF mitigation will gain a commend line parameter which allows to set a combination of hypervisor mitigation and SMT control. Expose cpu_smt_disable() so the command line parser can tweak SMT settings. [ tglx: Split out of larger patch and made it preserve an already existing force off state ] Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Jiri Kosina <jkosina@suse.cz> Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Reviewed-by: Josh Poimboeuf <jpoimboe@redhat.com> Link: https://lkml.kernel.org/r/20180713142323.039715135@linutronix.de Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-15cpu/hotplug: Online siblings when SMT control is turned onThomas Gleixner
commit 215af5499d9e2b55f111d2431ea20218115f29b3 upstream Writing 'off' to /sys/devices/system/cpu/smt/control offlines all SMT siblings. Writing 'on' merily enables the abilify to online them, but does not online them automatically. Make 'on' more useful by onlining all offline siblings. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-15x86/KVM: Warn user if KVM is loaded SMT and L1TF CPU bug being presentKonrad Rzeszutek Wilk
commit 26acfb666a473d960f0fd971fe68f3e3ad16c70b upstream If the L1TF CPU bug is present we allow the KVM module to be loaded as the major of users that use Linux and KVM have trusted guests and do not want a broken setup. Cloud vendors are the ones that are uncomfortable with CVE 2018-3620 and as such they are the ones that should set nosmt to one. Setting 'nosmt' means that the system administrator also needs to disable SMT (Hyper-threading) in the BIOS, or via the 'nosmt' command line parameter, or via the /sys/devices/system/cpu/smt/control. See commit 05736e4ac13c ("cpu/hotplug: Provide knobs to control SMT"). Other mitigations are to use task affinity, cpu sets, interrupt binding, etc - anything to make sure that _only_ the same guests vCPUs are running on sibling threads. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-15cpu/hotplug: Boot HT siblings at least onceThomas Gleixner
commit 0cc3cd21657be04cb0559fe8063f2130493f92cf upstream Due to the way Machine Check Exceptions work on X86 hyperthreads it's required to boot up _all_ logical cores at least once in order to set the CR4.MCE bit. So instead of ignoring the sibling threads right away, let them boot up once so they can configure themselves. After they came out of the initial boot stage check whether its a "secondary" sibling and cancel the operation which puts the CPU back into offline state. [dwmw2: Backport to 4.9] Reported-by: Dave Hansen <dave.hansen@intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Tony Luck <tony.luck@intel.com> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-15cpu/hotplug: Provide knobs to control SMTThomas Gleixner
commit 05736e4ac13c08a4a9b1ef2de26dd31a32cbee57 upstream Provide a command line and a sysfs knob to control SMT. The command line options are: 'nosmt': Enumerate secondary threads, but do not online them 'nosmt=force': Ignore secondary threads completely during enumeration via MP table and ACPI/MADT. The sysfs control file has the following states (read/write): 'on': SMT is enabled. Secondary threads can be freely onlined 'off': SMT is disabled. Secondary threads, even if enumerated cannot be onlined 'forceoff': SMT is permanentely disabled. Writes to the control file are rejected. 'notsupported': SMT is not supported by the CPU The command line option 'nosmt' sets the sysfs control to 'off'. This can be changed to 'on' to reenable SMT during runtime. The command line option 'nosmt=force' sets the sysfs control to 'forceoff'. This cannot be changed during runtime. When SMT is 'on' and the control file is changed to 'off' then all online secondary threads are offlined and attempts to online a secondary thread later on are rejected. When SMT is 'off' and the control file is changed to 'on' then secondary threads can be onlined again. The 'off' -> 'on' transition does not automatically online the secondary threads. When the control file is set to 'forceoff', the behaviour is the same as setting it to 'off', but the operation is irreversible and later writes to the control file are rejected. When the control status is 'notsupported' then writes to the control file are rejected. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Acked-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-15cpu/hotplug: Split do_cpu_down()Thomas Gleixner
commit cc1fe215e1efa406b03aa4389e6269b61342dec5 upstream Split out the inner workings of do_cpu_down() to allow reuse of that function for the upcoming SMT disabling mechanism. No functional change. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Acked-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-15cpu/hotplug: Make bringup/teardown of smp threads symmetricThomas Gleixner
commit c4de65696d865c225fda3b9913b31284ea65ea96 upstream The asymmetry caused a warning to trigger if the bootup was stopped in state CPUHP_AP_ONLINE_IDLE. The warning no longer triggers as kthread_park() can now be invoked on already or still parked threads. But there is still no reason to have this be asymmetric. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Acked-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-15init: rename and re-order boot_cpu_state_init()Linus Torvalds
commit b5b1404d0815894de0690de8a1ab58269e56eae6 upstream. This is purely a preparatory patch for upcoming changes during the 4.19 merge window. We have a function called "boot_cpu_state_init()" that isn't really about the bootup cpu state: that is done much earlier by the similarly named "boot_cpu_init()" (note lack of "state" in name). This function initializes some hotplug CPU state, and needs to run after the percpu data has been properly initialized. It even has a comment to that effect. Except it _doesn't_ actually run after the percpu data has been properly initialized. On x86 it happens to do that, but on at least arm and arm64, the percpu base pointers are initialized by the arch-specific 'smp_prepare_boot_cpu()' hook, which ran _after_ boot_cpu_state_init(). This had some unexpected results, and in particular we have a patch pending for the merge window that did the obvious cleanup of using 'this_cpu_write()' in the cpu hotplug init code: - per_cpu_ptr(&cpuhp_state, smp_processor_id())->state = CPUHP_ONLINE; + this_cpu_write(cpuhp_state.state, CPUHP_ONLINE); which is obviously the right thing to do. Except because of the ordering issue, it actually failed miserably and unexpectedly on arm64. So this just fixes the ordering, and changes the name of the function to be 'boot_cpu_hotplug_init()' to make it obvious that it's about cpu hotplug state, because the core CPU state was supposed to have already been done earlier. Marked for stable, since the (not yet merged) patch that will show this problem is marked for stable. Reported-by: Vlastimil Babka <vbabka@suse.cz> Reported-by: Mian Yousaf Kaukab <yousaf.kaukab@suse.com> Suggested-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Will Deacon <will.deacon@arm.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-15Mark HI and TASKLET softirq synchronousLinus Torvalds
commit 3c53776e29f81719efcf8f7a6e30cdf753bee94d upstream. Way back in 4.9, we committed 4cd13c21b207 ("softirq: Let ksoftirqd do its job"), and ever since we've had small nagging issues with it. For example, we've had: 1ff688209e2e ("watchdog: core: make sure the watchdog_worker is not deferred") 8d5755b3f77b ("watchdog: softdog: fire watchdog even if softirqs do not get to run") 217f69743681 ("net: busy-poll: allow preemption in sk_busy_loop()") all of which worked around some of the effects of that commit. The DVB people have also complained that the commit causes excessive USB URB latencies, which seems to be due to the USB code using tasklets to schedule USB traffic. This seems to be an issue mainly when already living on the edge, but waiting for ksoftirqd to handle it really does seem to cause excessive latencies. Now Hanna Hawa reports that this issue isn't just limited to USB URB and DVB, but also causes timeout problems for the Marvell SoC team: "I'm facing kernel panic issue while running raid 5 on sata disks connected to Macchiatobin (Marvell community board with Armada-8040 SoC with 4 ARMv8 cores of CA72) Raid 5 built with Marvell DMA engine and async_tx mechanism (ASYNC_TX_DMA [=y]); the DMA driver (mv_xor_v2) uses a tasklet to clean the done descriptors from the queue" The latency problem causes a panic: mv_xor_v2 f0400000.xor: dma_sync_wait: timeout! Kernel panic - not syncing: async_tx_quiesce: DMA error waiting for transaction We've discussed simply just reverting the original commit entirely, and also much more involved solutions (with per-softirq threads etc). This patch is intentionally stupid and fairly limited, because the issue still remains, and the other solutions either got sidetracked or had other issues. We should probably also consider the timer softirqs to be synchronous and not be delayed to ksoftirqd (since they were the issue with the earlier watchdog problems), but that should be done as a separate patch. This does only the tasklet cases. Reported-and-tested-by: Hanna Hawa <hannah@marvell.com> Reported-and-tested-by: Josef Griebichler <griebichler.josef@gmx.at> Reported-by: Mauro Carvalho Chehab <mchehab@s-opensource.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Eric Dumazet <edumazet@google.com> Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-09fork: unconditionally clear stack on forkKees Cook
commit e01e80634ecdde1dd113ac43b3adad21b47f3957 upstream. One of the classes of kernel stack content leaks[1] is exposing the contents of prior heap or stack contents when a new process stack is allocated. Normally, those stacks are not zeroed, and the old contents remain in place. In the face of stack content exposure flaws, those contents can leak to userspace. Fixing this will make the kernel no longer vulnerable to these flaws, as the stack will be wiped each time a stack is assigned to a new process. There's not a meaningful change in runtime performance; it almost looks like it provides a benefit. Performing back-to-back kernel builds before: Run times: 157.86 157.09 158.90 160.94 160.80 Mean: 159.12 Std Dev: 1.54 and after: Run times: 159.31 157.34 156.71 158.15 160.81 Mean: 158.46 Std Dev: 1.46 Instead of making this a build or runtime config, Andy Lutomirski recommended this just be enabled by default. [1] A noisy search for many kinds of stack content leaks can be seen here: https://cve.mitre.org/cgi-bin/cvekey.cgi?keyword=linux+kernel+stack+leak I did some more with perf and cycle counts on running 100,000 execs of /bin/true. before: Cycles: 218858861551 218853036130 214727610969 227656844122 224980542841 Mean: 221015379122.60 Std Dev: 4662486552.47 after: Cycles: 213868945060 213119275204 211820169456 224426673259 225489986348 Mean: 217745009865.40 Std Dev: 5935559279.99 It continues to look like it's faster, though the deviation is rather wide, but I'm not sure what I could do that would be less noisy. I'm open to ideas! Link: http://lkml.kernel.org/r/20180221021659.GA37073@beast Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Michal Hocko <mhocko@suse.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@kernel.org> Cc: Laura Abbott <labbott@redhat.com> Cc: Rasmus Villemoes <rasmus.villemoes@prevas.dk> Cc: Mel Gorman <mgorman@techsingularity.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> [ Srivatsa: Backported to 4.9.y ] Signed-off-by: Srivatsa S. Bhat <srivatsa@csail.mit.edu> Reviewed-by: Srinidhi Rao <srinidhir@vmware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-09kmemleak: clear stale pointers from task stacksKonstantin Khlebnikov
commit ca182551857cc2c1e6a2b7f1e72090a137a15008 upstream. Kmemleak considers any pointers on task stacks as references. This patch clears newly allocated and reused vmap stacks. Link: http://lkml.kernel.org/r/150728990124.744199.8403409836394318684.stgit@buzz Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> [ Srivatsa: Backported to 4.9.y ] Signed-off-by: Srivatsa S. Bhat <srivatsa@csail.mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-09ring_buffer: tracing: Inherit the tracing setting to next ring bufferMasami Hiramatsu
commit 73c8d8945505acdcbae137c2e00a1232e0be709f upstream. Maintain the tracing on/off setting of the ring_buffer when switching to the trace buffer snapshot. Taking a snapshot is done by swapping the backup ring buffer (max_tr_buffer). But since the tracing on/off setting is defined by the ring buffer, when swapping it, the tracing on/off setting can also be changed. This causes a strange result like below: /sys/kernel/debug/tracing # cat tracing_on 1 /sys/kernel/debug/tracing # echo 0 > tracing_on /sys/kernel/debug/tracing # cat tracing_on 0 /sys/kernel/debug/tracing # echo 1 > snapshot /sys/kernel/debug/tracing # cat tracing_on 1 /sys/kernel/debug/tracing # echo 1 > snapshot /sys/kernel/debug/tracing # cat tracing_on 0 We don't touch tracing_on, but snapshot changes tracing_on setting each time. This is an anomaly, because user doesn't know that each "ring_buffer" stores its own tracing-enable state and the snapshot is done by swapping ring buffers. Link: http://lkml.kernel.org/r/153149929558.11274.11730609978254724394.stgit@devbox Cc: Ingo Molnar <mingo@redhat.com> Cc: Shuah Khan <shuah@kernel.org> Cc: Tom Zanussi <tom.zanussi@linux.intel.com> Cc: Hiraku Toyooka <hiraku.toyooka@cybertrust.co.jp> Cc: stable@vger.kernel.org Fixes: debdd57f5145 ("tracing: Make a snapshot feature available from userspace") Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> [ Updated commit log and comment in the code ] Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Signed-off-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-09nohz: Fix local_timer_softirq_pending()Anna-Maria Gleixner
commit 80d20d35af1edd632a5e7a3b9c0ab7ceff92769e upstream. local_timer_softirq_pending() checks whether the timer softirq is pending with: local_softirq_pending() & TIMER_SOFTIRQ. This is wrong because TIMER_SOFTIRQ is the softirq number and not a bitmask. So the test checks for the wrong bit. Use BIT(TIMER_SOFTIRQ) instead. Fixes: 5d62c183f9e9 ("nohz: Prevent a timer interrupt storm in tick_nohz_stop_sched_tick()") Signed-off-by: Anna-Maria Gleixner <anna-maria@linutronix.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Daniel Bristot de Oliveira <bristot@redhat.com> Acked-by: Frederic Weisbecker <frederic@kernel.org> Cc: bigeasy@linutronix.de Cc: peterz@infradead.org Cc: stable@vger.kernel.org Link: https://lkml.kernel.org/r/20180731161358.29472-1-anna-maria@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-09genirq: Make force irq threading setup more robustThomas Gleixner
commit d1f0301b3333eef5efbfa1fe0f0edbea01863d5d upstream. The support of force threading interrupts which are set up with both a primary and a threaded handler wreckaged the setup of regular requested threaded interrupts (primary handler == NULL). The reason is that it does not check whether the primary handler is set to the default handler which wakes the handler thread. Instead it replaces the thread handler with the primary handler as it would do with force threaded interrupts which have been requested via request_irq(). So both the primary and the thread handler become the same which then triggers the warnon that the thread handler tries to wakeup a not configured secondary thread. Fortunately this only happens when the driver omits the IRQF_ONESHOT flag when requesting the threaded interrupt, which is normaly caught by the sanity checks when force irq threading is disabled. Fix it by skipping the force threading setup when a regular threaded interrupt is requested. As a consequence the interrupt request which lacks the IRQ_ONESHOT flag is rejected correctly instead of silently wreckaging it. Fixes: 2a1d3ab8986d ("genirq: Handle force threading of irqs with primary and thread handler") Reported-by: Kurt Kanzenbach <kurt.kanzenbach@linutronix.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Kurt Kanzenbach <kurt.kanzenbach@linutronix.de> Cc: stable@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-06sched/wait: Remove the lockless swait_active() check in swake_up*()Boqun Feng
commit 35a2897c2a306cca344ca5c0b43416707018f434 upstream. Steven Rostedt reported a potential race in RCU core because of swake_up(): CPU0 CPU1 ---- ---- __call_rcu_core() { spin_lock(rnp_root) need_wake = __rcu_start_gp() { rcu_start_gp_advanced() { gp_flags = FLAG_INIT } } rcu_gp_kthread() { swait_event_interruptible(wq, gp_flags & FLAG_INIT) { spin_lock(q->lock) *fetch wq->task_list here! * list_add(wq->task_list, q->task_list) spin_unlock(q->lock); *fetch old value of gp_flags here * spin_unlock(rnp_root) rcu_gp_kthread_wake() { swake_up(wq) { swait_active(wq) { list_empty(wq->task_list) } * return false * if (condition) * false * schedule(); In this case, a wakeup is missed, which could cause the rcu_gp_kthread waits for a long time. The reason of this is that we do a lockless swait_active() check in swake_up(). To fix this, we can either 1) add a smp_mb() in swake_up() before swait_active() to provide the proper order or 2) simply remove the swait_active() in swake_up(). The solution 2 not only fixes this problem but also keeps the swait and wait API as close as possible, as wake_up() doesn't provide a full barrier and doesn't do a lockless check of the wait queue either. Moreover, there are users already using swait_active() to do their quick checks for the wait queues, so it make less sense that swake_up() and swake_up_all() do this on their own. This patch then removes the lockless swait_active() check in swake_up() and swake_up_all(). Reported-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Boqun Feng <boqun.feng@gmail.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Krister Johansen <kjlx@templeofstupid.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20170615041828.zk3a3sfyudm5p6nl@tardis Signed-off-by: Ingo Molnar <mingo@kernel.org> Cc: David Chen <david.chen@nutanix.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-03audit: allow not equal op for audit by executableOndrej Mosnáček
[ Upstream commit 23bcc480dac204c7dbdf49d96b2c918ed98223c2 ] Current implementation of auditing by executable name only implements the 'equal' operator. This patch extends it to also support the 'not equal' operator. See: https://github.com/linux-audit/audit-kernel/issues/53 Signed-off-by: Ondrej Mosnacek <omosnace@redhat.com> Reviewed-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Paul Moore <paul@paul-moore.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-03stop_machine: Use raw spinlocksThomas Gleixner
[ Upstream commit de5b55c1d4e30740009864eb35ce4ed856aac01d ] Use raw-locks in stop_machine() to allow locking in irq-off and preempt-disabled regions on -RT. This also documents the possible locking context in general. [bigeasy: update patch description.] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Link: https://lkml.kernel.org/r/20180423191635.6014-1-bigeasy@linutronix.de Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-03bpf: fix references to free_bpf_prog_info() in commentsJakub Kicinski
[ Upstream commit ab7f5bf0928be2f148d000a6eaa6c0a36e74750e ] Comments in the verifier refer to free_bpf_prog_info() which seems to have never existed in tree. Replace it with free_used_maps(). Signed-off-by: Jakub Kicinski <jakub.kicinski@netronome.com> Reviewed-by: Quentin Monnet <quentin.monnet@netronome.com> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-03kcov: ensure irq code sees a valid areaMark Rutland
[ Upstream commit c9484b986ef03492357fddd50afbdd02929cfa72 ] Patch series "kcov: fix unexpected faults". These patches fix a few issues where KCOV code could trigger recursive faults, discovered while debugging a patch enabling KCOV for arch/arm: * On CONFIG_PREEMPT kernels, there's a small race window where __sanitizer_cov_trace_pc() can see a bogus kcov_area. * Lazy faulting of the vmalloc area can cause mutual recursion between fault handling code and __sanitizer_cov_trace_pc(). * During the context switch, switching the mm can cause the kcov_area to be transiently unmapped. These are prerequisites for enabling KCOV on arm, but the issues themsevles are generic -- we just happen to avoid them by chance rather than design on x86-64 and arm64. This patch (of 3): For kernels built with CONFIG_PREEMPT, some C code may execute before or after the interrupt handler, while the hardirq count is zero. In these cases, in_task() can return true. A task can be interrupted in the middle of a KCOV_DISABLE ioctl while it resets the task's kcov data via kcov_task_init(). Instrumented code executed during this period will call __sanitizer_cov_trace_pc(), and as in_task() returns true, will inspect t->kcov_mode before trying to write to t->kcov_area. In kcov_init_task() we update t->kcov_{mode,area,size} with plain stores, which may be re-ordered, torn, etc. Thus __sanitizer_cov_trace_pc() may see bogus values for any of these fields, and may attempt to write to memory which is not mapped. Let's avoid this by using WRITE_ONCE() to set t->kcov_mode, with a barrier() to ensure this is ordered before we clear t->kov_{area,size}. This ensures that any code execute while kcov_init_task() is preempted will either see valid values for t->kcov_{area,size}, or will see that t->kcov_mode is KCOV_MODE_DISABLED, and bail out without touching t->kcov_area. Link: http://lkml.kernel.org/r/20180504135535.53744-2-mark.rutland@arm.com Signed-off-by: Mark Rutland <mark.rutland@arm.com> Acked-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-03tracing: Quiet gcc warning about maybe unused link variableSteven Rostedt (VMware)
commit 2519c1bbe38d7acacc9aacba303ca6f97482ed53 upstream. Commit 57ea2a34adf4 ("tracing/kprobes: Fix trace_probe flags on enable_trace_kprobe() failure") added an if statement that depends on another if statement that gcc doesn't see will initialize the "link" variable and gives the warning: "warning: 'link' may be used uninitialized in this function" It is really a false positive, but to quiet the warning, and also to make sure that it never actually is used uninitialized, initialize the "link" variable to NULL and add an if (!WARN_ON_ONCE(!link)) where the compiler thinks it could be used uninitialized. Cc: stable@vger.kernel.org Fixes: 57ea2a34adf4 ("tracing/kprobes: Fix trace_probe flags on enable_trace_kprobe() failure") Reported-by: kbuild test robot <lkp@intel.com> Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-03tracing/kprobes: Fix trace_probe flags on enable_trace_kprobe() failureArtem Savkov
commit 57ea2a34adf40f3a6e88409aafcf803b8945619a upstream. If enable_trace_kprobe fails to enable the probe in enable_k(ret)probe it returns an error, but does not unset the tp flags it set previously. This results in a probe being considered enabled and failures like being unable to remove the probe through kprobe_events file since probes_open() expects every probe to be disabled. Link: http://lkml.kernel.org/r/20180725102826.8300-1-asavkov@redhat.com Link: http://lkml.kernel.org/r/20180725142038.4765-1-asavkov@redhat.com Cc: Ingo Molnar <mingo@redhat.com> Cc: stable@vger.kernel.org Fixes: 41a7dd420c57 ("tracing/kprobes: Support ftrace_event_file base multibuffer") Acked-by: Masami Hiramatsu <mhiramat@kernel.org> Reviewed-by: Josh Poimboeuf <jpoimboe@redhat.com> Signed-off-by: Artem Savkov <asavkov@redhat.com> Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-03kthread, tracing: Don't expose half-written comm when creating kthreadsSnild Dolkow
commit 3e536e222f2930534c252c1cc7ae799c725c5ff9 upstream. There is a window for racing when printing directly to task->comm, allowing other threads to see a non-terminated string. The vsnprintf function fills the buffer, counts the truncated chars, then finally writes the \0 at the end. creator other vsnprintf: fill (not terminated) count the rest trace_sched_waking(p): ... memcpy(comm, p->comm, TASK_COMM_LEN) write \0 The consequences depend on how 'other' uses the string. In our case, it was copied into the tracing system's saved cmdlines, a buffer of adjacent TASK_COMM_LEN-byte buffers (note the 'n' where 0 should be): crash-arm64> x/1024s savedcmd->saved_cmdlines | grep 'evenk' 0xffffffd5b3818640: "irq/497-pwr_evenkworker/u16:12" ...and a strcpy out of there would cause stack corruption: [224761.522292] Kernel panic - not syncing: stack-protector: Kernel stack is corrupted in: ffffff9bf9783c78 crash-arm64> kbt | grep 'comm\|trace_print_context' #6 0xffffff9bf9783c78 in trace_print_context+0x18c(+396) comm (char [16]) = "irq/497-pwr_even" crash-arm64> rd 0xffffffd4d0e17d14 8 ffffffd4d0e17d14: 2f71726900000000 5f7277702d373934 ....irq/497-pwr_ ffffffd4d0e17d24: 726f776b6e657665 3a3631752f72656b evenkworker/u16: ffffffd4d0e17d34: f9780248ff003231 cede60e0ffffff9b 12..H.x......`.. ffffffd4d0e17d44: cede60c8ffffffd4 00000fffffffffd4 .....`.......... The workaround in e09e28671 (use strlcpy in __trace_find_cmdline) was likely needed because of this same bug. Solved by vsnprintf:ing to a local buffer, then using set_task_comm(). This way, there won't be a window where comm is not terminated. Link: http://lkml.kernel.org/r/20180726071539.188015-1-snild@sony.com Cc: stable@vger.kernel.org Fixes: bc0c38d139ec7 ("ftrace: latency tracer infrastructure") Reviewed-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Signed-off-by: Snild Dolkow <snild@sony.com> Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-03tracing: Fix possible double free in event_enable_trigger_func()Steven Rostedt (VMware)
commit 15cc78644d0075e76d59476a4467e7143860f660 upstream. There was a case that triggered a double free in event_trigger_callback() due to the called reg() function freeing the trigger_data and then it getting freed again by the error return by the caller. The solution there was to up the trigger_data ref count. Code inspection found that event_enable_trigger_func() has the same issue, but is not as easy to trigger (requires harder to trigger failures). It needs to be solved slightly different as it needs more to clean up when the reg() function fails. Link: http://lkml.kernel.org/r/20180725124008.7008e586@gandalf.local.home Cc: stable@vger.kernel.org Fixes: 7862ad1846e99 ("tracing: Add 'enable_event' and 'disable_event' event trigger commands") Reivewed-by: Masami Hiramatsu <mhiramat@kernel.org> Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-03tracing: Fix double free of event_trigger_dataSteven Rostedt (VMware)
commit 1863c387259b629e4ebfb255495f67cd06aa229b upstream. Running the following: # cd /sys/kernel/debug/tracing # echo 500000 > buffer_size_kb [ Or some other number that takes up most of memory ] # echo snapshot > events/sched/sched_switch/trigger Triggers the following bug: ------------[ cut here ]------------ kernel BUG at mm/slub.c:296! invalid opcode: 0000 [#1] SMP DEBUG_PAGEALLOC PTI CPU: 6 PID: 6878 Comm: bash Not tainted 4.18.0-rc6-test+ #1066 Hardware name: Hewlett-Packard HP Compaq Pro 6300 SFF/339A, BIOS K01 v03.03 07/14/2016 RIP: 0010:kfree+0x16c/0x180 Code: 05 41 0f b6 72 51 5b 5d 41 5c 4c 89 d7 e9 ac b3 f8 ff 48 89 d9 48 89 da 41 b8 01 00 00 00 5b 5d 41 5c 4c 89 d6 e9 f4 f3 ff ff <0f> 0b 0f 0b 48 8b 3d d9 d8 f9 00 e9 c1 fe ff ff 0f 1f 40 00 0f 1f RSP: 0018:ffffb654436d3d88 EFLAGS: 00010246 RAX: ffff91a9d50f3d80 RBX: ffff91a9d50f3d80 RCX: ffff91a9d50f3d80 RDX: 00000000000006a4 RSI: ffff91a9de5a60e0 RDI: ffff91a9d9803500 RBP: ffffffff8d267c80 R08: 00000000000260e0 R09: ffffffff8c1a56be R10: fffff0d404543cc0 R11: 0000000000000389 R12: ffffffff8c1a56be R13: ffff91a9d9930e18 R14: ffff91a98c0c2890 R15: ffffffff8d267d00 FS: 00007f363ea64700(0000) GS:ffff91a9de580000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 000055c1cacc8e10 CR3: 00000000d9b46003 CR4: 00000000001606e0 Call Trace: event_trigger_callback+0xee/0x1d0 event_trigger_write+0xfc/0x1a0 __vfs_write+0x33/0x190 ? handle_mm_fault+0x115/0x230 ? _cond_resched+0x16/0x40 vfs_write+0xb0/0x190 ksys_write+0x52/0xc0 do_syscall_64+0x5a/0x160 entry_SYSCALL_64_after_hwframe+0x49/0xbe RIP: 0033:0x7f363e16ab50 Code: 73 01 c3 48 8b 0d 38 83 2c 00 f7 d8 64 89 01 48 83 c8 ff c3 66 0f 1f 44 00 00 83 3d 79 db 2c 00 00 75 10 b8 01 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 31 c3 48 83 ec 08 e8 1e e3 01 00 48 89 04 24 RSP: 002b:00007fff9a4c6378 EFLAGS: 00000246 ORIG_RAX: 0000000000000001 RAX: ffffffffffffffda RBX: 0000000000000009 RCX: 00007f363e16ab50 RDX: 0000000000000009 RSI: 000055c1cacc8e10 RDI: 0000000000000001 RBP: 000055c1cacc8e10 R08: 00007f363e435740 R09: 00007f363ea64700 R10: 0000000000000073 R11: 0000000000000246 R12: 0000000000000009 R13: 0000000000000001 R14: 00007f363e4345e0 R15: 00007f363e4303c0 Modules linked in: ip6table_filter ip6_tables snd_hda_codec_hdmi snd_hda_codec_realtek snd_hda_codec_generic snd_hda_intel snd_hda_codec snd_hwdep snd_hda_core snd_seq snd_seq_device i915 snd_pcm snd_timer i2c_i801 snd soundcore i2c_algo_bit drm_kms_helper 86_pkg_temp_thermal video kvm_intel kvm irqbypass wmi e1000e ---[ end trace d301afa879ddfa25 ]--- The cause is because the register_snapshot_trigger() call failed to allocate the snapshot buffer, and then called unregister_trigger() which freed the data that was passed to it. Then on return to the function that called register_snapshot_trigger(), as it sees it failed to register, it frees the trigger_data again and causes a double free. By calling event_trigger_init() on the trigger_data (which only ups the reference counter for it), and then event_trigger_free() afterward, the trigger_data would not get freed by the registering trigger function as it would only up and lower the ref count for it. If the register trigger function fails, then the event_trigger_free() called after it will free the trigger data normally. Link: http://lkml.kernel.org/r/20180724191331.738eb819@gandalf.local.home Cc: stable@vger.kerne.org Fixes: 93e31ffbf417 ("tracing: Add 'snapshot' event trigger command") Reported-by: Masami Hiramatsu <mhiramat@kernel.org> Reviewed-by: Masami Hiramatsu <mhiramat@kernel.org> Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-17PM / hibernate: Fix oops at snapshot_write()Tetsuo Handa
commit fc14eebfc20854a38fd9f1d93a42b1783dad4d17 upstream. syzbot is reporting NULL pointer dereference at snapshot_write() [1]. This is because data->handle is zero-cleared by ioctl(SNAPSHOT_FREE). Fix this by checking data_of(data->handle) != NULL before using it. [1] https://syzkaller.appspot.com/bug?id=828a3c71bd344a6de8b6a31233d51a72099f27fd Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Reported-by: syzbot <syzbot+ae590932da6e45d6564d@syzkaller.appspotmail.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-11tracing: Fix missing return symbol in function_graph outputChangbin Du
commit 1fe4293f4b8de75824935f8d8e9a99c7fc6873da upstream. The function_graph tracer does not show the interrupt return marker for the leaf entry. On leaf entries, we see an unbalanced interrupt marker (the interrupt was entered, but nevern left). Before: 1) | SyS_write() { 1) | __fdget_pos() { 1) 0.061 us | __fget_light(); 1) 0.289 us | } 1) | vfs_write() { 1) 0.049 us | rw_verify_area(); 1) + 15.424 us | __vfs_write(); 1) ==========> | 1) 6.003 us | smp_apic_timer_interrupt(); 1) 0.055 us | __fsnotify_parent(); 1) 0.073 us | fsnotify(); 1) + 23.665 us | } 1) + 24.501 us | } After: 0) | SyS_write() { 0) | __fdget_pos() { 0) 0.052 us | __fget_light(); 0) 0.328 us | } 0) | vfs_write() { 0) 0.057 us | rw_verify_area(); 0) | __vfs_write() { 0) ==========> | 0) 8.548 us | smp_apic_timer_interrupt(); 0) <========== | 0) + 36.507 us | } /* __vfs_write */ 0) 0.049 us | __fsnotify_parent(); 0) 0.066 us | fsnotify(); 0) + 50.064 us | } 0) + 50.952 us | } Link: http://lkml.kernel.org/r/1517413729-20411-1-git-send-email-changbin.du@intel.com Cc: stable@vger.kernel.org Fixes: f8b755ac8e0cc ("tracing/function-graph-tracer: Output arrows signal on hardirq call/return") Signed-off-by: Changbin Du <changbin.du@intel.com> Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03time: Make sure jiffies_to_msecs() preserves non-zero time periodsGeert Uytterhoeven
commit abcbcb80cd09cd40f2089d912764e315459b71f7 upstream. For the common cases where 1000 is a multiple of HZ, or HZ is a multiple of 1000, jiffies_to_msecs() never returns zero when passed a non-zero time period. However, if HZ > 1000 and not an integer multiple of 1000 (e.g. 1024 or 1200, as used on alpha and DECstation), jiffies_to_msecs() may return zero for small non-zero time periods. This may break code that relies on receiving back a non-zero value. jiffies_to_usecs() does not need such a fix: one jiffy can only be less than one µs if HZ > 1000000, and such large values of HZ are already rejected at build time, twice: - include/linux/jiffies.h does #error if HZ >= 12288, - kernel/time/time.c has BUILD_BUG_ON(HZ > USEC_PER_SEC). Broken since forever. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Arnd Bergmann <arnd@arndb.de> Cc: John Stultz <john.stultz@linaro.org> Cc: Stephen Boyd <sboyd@kernel.org> Cc: linux-alpha@vger.kernel.org Cc: linux-mips@linux-mips.org Cc: stable@vger.kernel.org Link: https://lkml.kernel.org/r/20180622143357.7495-1-geert@linux-m68k.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03printk: fix possible reuse of va_list variableTetsuo Handa
commit 988a35f8da1dec5a8cd2788054d1e717be61bf25 upstream. I noticed that there is a possibility that printk_safe_log_store() causes kernel oops because "args" parameter is passed to vsnprintf() again when atomic_cmpxchg() detected that we raced. Fix this by using va_copy(). Link: http://lkml.kernel.org/r/201805112002.GIF21216.OFVHFOMLJtQFSO@I-love.SAKURA.ne.jp Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: dvyukov@google.com Cc: syzkaller@googlegroups.com Cc: fengguang.wu@intel.com Cc: linux-kernel@vger.kernel.org Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Fixes: 42a0bb3f71383b45 ("printk/nmi: generic solution for safe printk in NMI") Cc: 4.7+ <stable@vger.kernel.org> # v4.7+ Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Petr Mladek <pmladek@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-06tracing: Fix crash when freeing instances with event triggersSteven Rostedt (VMware)
commit 86b389ff22bd6ad8fd3cb98e41cd271886c6d023 upstream. If a instance has an event trigger enabled when it is freed, it could cause an access of free memory. Here's the case that crashes: # cd /sys/kernel/tracing # mkdir instances/foo # echo snapshot > instances/foo/events/initcall/initcall_start/trigger # rmdir instances/foo Would produce: general protection fault: 0000 [#1] PREEMPT SMP PTI Modules linked in: tun bridge ... CPU: 5 PID: 6203 Comm: rmdir Tainted: G W 4.17.0-rc4-test+ #933 Hardware name: Hewlett-Packard HP Compaq Pro 6300 SFF/339A, BIOS K01 v03.03 07/14/2016 RIP: 0010:clear_event_triggers+0x3b/0x70 RSP: 0018:ffffc90003783de0 EFLAGS: 00010286 RAX: 0000000000000000 RBX: 6b6b6b6b6b6b6b2b RCX: 0000000000000000 RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffff8800c7130ba0 RBP: ffffc90003783e00 R08: ffff8801131993f8 R09: 0000000100230016 R10: ffffc90003783d80 R11: 0000000000000000 R12: ffff8800c7130ba0 R13: ffff8800c7130bd8 R14: ffff8800cc093768 R15: 00000000ffffff9c FS: 00007f6f4aa86700(0000) GS:ffff88011eb40000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 00007f6f4a5aed60 CR3: 00000000cd552001 CR4: 00000000001606e0 Call Trace: event_trace_del_tracer+0x2a/0xc5 instance_rmdir+0x15c/0x200 tracefs_syscall_rmdir+0x52/0x90 vfs_rmdir+0xdb/0x160 do_rmdir+0x16d/0x1c0 __x64_sys_rmdir+0x17/0x20 do_syscall_64+0x55/0x1a0 entry_SYSCALL_64_after_hwframe+0x49/0xbe This was due to the call the clears out the triggers when an instance is being deleted not removing the trigger from the link list. Cc: stable@vger.kernel.org Fixes: 85f2b08268c01 ("tracing: Add basic event trigger framework") Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-05objtool, x86: Add several functions and files to the objtool whitelistJosh Poimboeuf
commit c207aee48037abca71c669cbec407b9891965c34 upstream. In preparation for an objtool rewrite which will have broader checks, whitelist functions and files which cause problems because they do unusual things with the stack. These whitelists serve as a TODO list for which functions and files don't yet have undwarf unwinder coverage. Eventually most of the whitelists can be removed in favor of manual CFI hint annotations or objtool improvements. Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Jiri Slaby <jslaby@suse.cz> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: live-patching@vger.kernel.org Link: http://lkml.kernel.org/r/7f934a5d707a574bda33ea282e9478e627fb1829.1498659915.git.jpoimboe@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30kdb: make "mdr" command repeatRandy Dunlap
[ Upstream commit 1e0ce03bf142454f38a5fc050bf4fd698d2d36d8 ] The "mdr" command should repeat (continue) when only Enter/Return is pressed, so make it do so. Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Cc: Daniel Thompson <daniel.thompson@linaro.org> Cc: Jason Wessel <jason.wessel@windriver.com> Cc: kgdb-bugreport@lists.sourceforge.net Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30rcu: Call touch_nmi_watchdog() while printing stall warningsTejun Heo
[ Upstream commit 3caa973b7a260e7a2a69edc94c300ab9c65148c3 ] When RCU stall warning triggers, it can print out a lot of messages while holding spinlocks. If the console device is slow (e.g. an actual or IPMI serial console), it may end up triggering NMI hard lockup watchdog like the following.
2018-05-30audit: return on memory error to avoid null pointer dereferenceRichard Guy Briggs
[ Upstream commit 23138ead270045f1b3e912e667967b6094244999 ] If there is a memory allocation error when trying to change an audit kernel feature value, the ignored allocation error will trigger a NULL pointer dereference oops on subsequent use of that pointer. Return instead. Passes audit-testsuite. See: https://github.com/linux-audit/audit-kernel/issues/76 Signed-off-by: Richard Guy Briggs <rgb@redhat.com> [PM: not necessary (other funcs check for NULL), but a good practice] Signed-off-by: Paul Moore <paul@paul-moore.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30perf/core: Fix perf_output_read_group()Peter Zijlstra
[ Upstream commit 9e5b127d6f33468143d90c8a45ca12410e4c3fa7 ] Mark reported his arm64 perf fuzzer runs sometimes splat like: armv8pmu_read_counter+0x1e8/0x2d8 armpmu_event_update+0x8c/0x188 armpmu_read+0xc/0x18 perf_output_read+0x550/0x11e8 perf_event_read_event+0x1d0/0x248 perf_event_exit_task+0x468/0xbb8 do_exit+0x690/0x1310 do_group_exit+0xd0/0x2b0 get_signal+0x2e8/0x17a8 do_signal+0x144/0x4f8 do_notify_resume+0x148/0x1e8 work_pending+0x8/0x14 which asserts that we only call pmu::read() on ACTIVE events. The above callchain does: perf_event_exit_task() perf_event_exit_task_context() task_ctx_sched_out() // INACTIVE perf_event_exit_event() perf_event_set_state(EXIT) // EXIT sync_child_event() perf_event_read_event() perf_output_read() perf_output_read_group() leader->pmu->read() Which results in doing a pmu::read() on an !ACTIVE event. I _think_ this is 'new' since we added attr.inherit_stat, which added the perf_event_read_event() to the exit path, without that perf_event_read_output() would only trigger from samples and for @event to trigger a sample, it's leader _must_ be ACTIVE too. Still, adding this check makes it consistent with the @sub case for the siblings. Reported-and-Tested-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Stephane Eranian <eranian@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Vince Weaver <vincent.weaver@maine.edu> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30sched/rt: Fix rq->clock_update_flags < RQCF_ACT_SKIP warningDavidlohr Bueso
[ Upstream commit d29a20645d5e929aa7e8616f28e5d8e1c49263ec ] While running rt-tests' pi_stress program I got the following splat: rq->clock_update_flags < RQCF_ACT_SKIP WARNING: CPU: 27 PID: 0 at kernel/sched/sched.h:960 assert_clock_updated.isra.38.part.39+0x13/0x20 [...] <IRQ> enqueue_top_rt_rq+0xf4/0x150 ? cpufreq_dbs_governor_start+0x170/0x170 sched_rt_rq_enqueue+0x65/0x80 sched_rt_period_timer+0x156/0x360 ? sched_rt_rq_enqueue+0x80/0x80 __hrtimer_run_queues+0xfa/0x260 hrtimer_interrupt+0xcb/0x220 smp_apic_timer_interrupt+0x62/0x120 apic_timer_interrupt+0xf/0x20 </IRQ> [...] do_idle+0x183/0x1e0 cpu_startup_entry+0x5f/0x70 start_secondary+0x192/0x1d0 secondary_startup_64+0xa5/0xb0 We can get rid of it be the "traditional" means of adding an update_rq_clock() call after acquiring the rq->lock in do_sched_rt_period_timer(). The case for the RT task throttling (which this workload also hits) can be ignored in that the skip_update call is actually bogus and quite the contrary (the request bits are removed/reverted). By setting RQCF_UPDATED we really don't care if the skip is happening or not and will therefore make the assert_clock_updated() check happy. Signed-off-by: Davidlohr Bueso <dbueso@suse.de> Reviewed-by: Matt Fleming <matt@codeblueprint.co.uk> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: dave@stgolabs.net Cc: linux-kernel@vger.kernel.org Cc: rostedt@goodmis.org Link: http://lkml.kernel.org/r/20180402164954.16255-1-dave@stgolabs.net Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30perf/cgroup: Fix child event counting bugSong Liu
[ Upstream commit c917e0f259908e75bd2a65877e25f9d90c22c848 ] When a perf_event is attached to parent cgroup, it should count events for all children cgroups: parent_group <---- perf_event \ - child_group <---- process(es) However, in our tests, we found this perf_event cannot report reliable results. Here is an example case: # create cgroups mkdir -p /sys/fs/cgroup/p/c # start perf for parent group perf stat -e instructions -G "p" # on another console, run test process in child cgroup: stressapptest -s 2 -M 1000 & echo $! > /sys/fs/cgroup/p/c/cgroup.procs # after the test process is done, stop perf in the first console shows <not counted> instructions p The instruction should not be "not counted" as the process runs in the child cgroup. We found this is because perf_event->cgrp and cpuctx->cgrp are not identical, thus perf_event->cgrp are not updated properly. This patch fixes this by updating perf_cgroup properly for ancestor cgroup(s). Reported-by: Ephraim Park <ephiepark@fb.com> Signed-off-by: Song Liu <songliubraving@fb.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: <jolsa@redhat.com> Cc: <kernel-team@fb.com> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Vince Weaver <vincent.weaver@maine.edu> Link: http://lkml.kernel.org/r/20180312165943.1057894-1-songliubraving@fb.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30workqueue: use put_device() instead of kfree()Arvind Yadav
[ Upstream commit 537f4146c53c95aac977852b371bafb9c6755ee1 ] Never directly free @dev after calling device_register(), even if it returned an error! Always use put_device() to give up the reference initialized in this function instead. Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30kernel/relay.c: limit kmalloc size to KMALLOC_MAX_SIZEDavid Rientjes
[ Upstream commit 88913bd8ea2a75d7e460a4bed5f75e1c32660d7e ] chan->n_subbufs is set by the user and relay_create_buf() does a kmalloc() of chan->n_subbufs * sizeof(size_t *). kmalloc_slab() will generate a warning when this fails if chan->subbufs * sizeof(size_t *) > KMALLOC_MAX_SIZE. Limit chan->n_subbufs to the maximum allowed kmalloc() size. Link: http://lkml.kernel.org/r/alpine.DEB.2.10.1802061216100.122576@chino.kir.corp.google.com Fixes: f6302f1bcd75 ("relay: prevent integer overflow in relay_open()") Signed-off-by: David Rientjes <rientjes@google.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Jens Axboe <axboe@kernel.dk> Cc: Dave Jiang <dave.jiang@intel.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30locking/qspinlock: Ensure node->count is updated before initialising nodeWill Deacon
[ Upstream commit 11dc13224c975efcec96647a4768a6f1bb7a19a8 ] When queuing on the qspinlock, the count field for the current CPU's head node is incremented. This needn't be atomic because locking in e.g. IRQ context is balanced and so an IRQ will return with node->count as it found it. However, the compiler could in theory reorder the initialisation of node[idx] before the increment of the head node->count, causing an IRQ to overwrite the initialised node and potentially corrupt the lock state. Avoid the potential for this harmful compiler reordering by placing a barrier() between the increment of the head node->count and the subsequent node initialisation. Signed-off-by: Will Deacon <will.deacon@arm.com> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1518528177-19169-3-git-send-email-will.deacon@arm.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30x86/power: Fix swsusp_arch_resume prototypeArnd Bergmann
[ Upstream commit 328008a72d38b5bde6491e463405c34a81a65d3e ] The declaration for swsusp_arch_resume marks it as 'asmlinkage', but the definition in x86-32 does not, and it fails to include the header with the declaration. This leads to a warning when building with link-time-optimizations: kernel/power/power.h:108:23: error: type of 'swsusp_arch_resume' does not match original declaration [-Werror=lto-type-mismatch] extern asmlinkage int swsusp_arch_resume(void); ^ arch/x86/power/hibernate_32.c:148:0: note: 'swsusp_arch_resume' was previously declared here int swsusp_arch_resume(void) This moves the declaration into a globally visible header file and fixes up both x86 definitions to match it. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Len Brown <len.brown@intel.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Nicolas Pitre <nico@linaro.org> Cc: linux-pm@vger.kernel.org Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net> Cc: Pavel Machek <pavel@ucw.cz> Cc: Bart Van Assche <bart.vanassche@wdc.com> Link: https://lkml.kernel.org/r/20180202145634.200291-2-arnd@arndb.de Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30kernel/signal.c: avoid undefined behaviour in kill_something_infozhongjiang
commit 4ea77014af0d6205b05503d1c7aac6eace11d473 upstream. When running kill(72057458746458112, 0) in userspace I hit the following issue. UBSAN: Undefined behaviour in kernel/signal.c:1462:11 negation of -2147483648 cannot be represented in type 'int': CPU: 226 PID: 9849 Comm: test Tainted: G B ---- ------- 3.10.0-327.53.58.70.x86_64_ubsan+ #116 Hardware name: Huawei Technologies Co., Ltd. RH8100 V3/BC61PBIA, BIOS BLHSV028 11/11/2014 Call Trace: dump_stack+0x19/0x1b ubsan_epilogue+0xd/0x50 __ubsan_handle_negate_overflow+0x109/0x14e SYSC_kill+0x43e/0x4d0 SyS_kill+0xe/0x10 system_call_fastpath+0x16/0x1b Add code to avoid the UBSAN detection. [akpm@linux-foundation.org: tweak comment] Link: http://lkml.kernel.org/r/1496670008-59084-1-git-send-email-zhongjiang@huawei.com Signed-off-by: zhongjiang <zhongjiang@huawei.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Michal Hocko <mhocko@kernel.org> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Xishi Qiu <qiuxishi@huawei.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30kernel/sys.c: fix potential Spectre v1 issueGustavo A. R. Silva
commit 23d6aef74da86a33fa6bb75f79565e0a16ee97c2 upstream. `resource' can be controlled by user-space, hence leading to a potential exploitation of the Spectre variant 1 vulnerability. This issue was detected with the help of Smatch: kernel/sys.c:1474 __do_compat_sys_old_getrlimit() warn: potential spectre issue 'get_current()->signal->rlim' (local cap) kernel/sys.c:1455 __do_sys_old_getrlimit() warn: potential spectre issue 'get_current()->signal->rlim' (local cap) Fix this by sanitizing *resource* before using it to index current->signal->rlim Notice that given that speculation windows are large, the policy is to kill the speculation on the first load and not worry if it can be completed with a dependent load/store [1]. [1] https://marc.info/?l=linux-kernel&m=152449131114778&w=2 Link: http://lkml.kernel.org/r/20180515030038.GA11822@embeddedor.com Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com> Reviewed-by: Andrew Morton <akpm@linux-foundation.org> Cc: Alexei Starovoitov <ast@kernel.org> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22seccomp: Move speculation migitation control to arch codeThomas Gleixner
commit 8bf37d8c067bb7eb8e7c381bdadf9bd89182b6bc upstream The migitation control is simpler to implement in architecture code as it avoids the extra function call to check the mode. Aside of that having an explicit seccomp enabled mode in the architecture mitigations would require even more workarounds. Move it into architecture code and provide a weak function in the seccomp code. Remove the 'which' argument as this allows the architecture to decide which mitigations are relevant for seccomp. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22seccomp: Add filter flag to opt-out of SSB mitigationKees Cook
commit 00a02d0c502a06d15e07b857f8ff921e3e402675 upstream If a seccomp user is not interested in Speculative Store Bypass mitigation by default, it can set the new SECCOMP_FILTER_FLAG_SPEC_ALLOW flag when adding filters. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22seccomp: Use PR_SPEC_FORCE_DISABLEThomas Gleixner
commit b849a812f7eb92e96d1c8239b06581b2cfd8b275 upstream Use PR_SPEC_FORCE_DISABLE in seccomp() because seccomp does not allow to widen restrictions. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-22seccomp: Enable speculation flaw mitigationsKees Cook
commit 5c3070890d06ff82eecb808d02d2ca39169533ef upstream When speculation flaw mitigations are opt-in (via prctl), using seccomp will automatically opt-in to these protections, since using seccomp indicates at least some level of sandboxing is desired. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
