commit 45a5791920ae643eafc02e2eedef1a58e341b736 upstream.
Paul McKenney's review pointed out two problems with the barriers in the
2.6.38 update to the smp call function many code.
First, a barrier that would force the func and info members of data to
be visible before their consumption in the interrupt handler was
missing. This can be solved by adding a smp_wmb between setting the
func and info members and setting setting the cpumask; this will pair
with the existing and required smp_rmb ordering the cpumask read before
the read of refs. This placement avoids the need a second smp_rmb in
the interrupt handler which would be executed on each of the N cpus
executing the call request. (I was thinking this barrier was present
but was not).
Second, the previous write to refs (establishing the zero that we the
interrupt handler was testing from all cpus) was performed by a third
party cpu. This would invoke transitivity which, as a recient or
concurrent addition to memory-barriers.txt now explicitly states, would
require a full smp_mb().
However, we know the cpumask will only be set by one cpu (the data
owner) and any preivous iteration of the mask would have cleared by the
reading cpu. By redundantly writing refs to 0 on the owning cpu before
the smp_wmb, the write to refs will follow the same path as the writes
that set the cpumask, which in turn allows us to keep the barrier in the
interrupt handler a smp_rmb instead of promoting it to a smp_mb (which
will be be executed by N cpus for each of the possible M elements on the
list).
I moved and expanded the comment about our (ab)use of the rcu list
primitives for the concurrent walk earlier into this function. I
considered moving the first two paragraphs to the queue list head and
lock, but felt it would have been too disconected from the code.
Cc: Paul McKinney <paulmck@linux.vnet.ibm.com>
Signed-off-by: Milton Miller <miltonm@bga.com>
commit e6cd1e07a185d5f9b0aa75e020df02d3c1c44940 upstream.
Peter pointed out there was nothing preventing the list_del_rcu in
smp_call_function_interrupt from running before the list_add_rcu in
smp_call_function_many.
Fix this by not setting refs until we have gotten the lock for the list.
Take advantage of the wmb in list_add_rcu to save an explicit additional
one.
I tried to force this race with a udelay before the lock & list_add and
by mixing all 64 online cpus with just 3 random cpus in the mask, but
was unsuccessful. Still, inspection shows a valid race, and the fix is
a extension of the existing protection window in the current code.
Reported-by: Peter Zijlstra <peterz@infradead.org>
commit e75e863dd5c7d96b91ebbd241da5328fc38a78cc upstream.
We have 32-bit variable overflow possibility when multiply in
task_times() and thread_group_times() functions. When the
overflow happens then the scaled utime value becomes erroneously
small and the scaled stime becomes i erroneously big.
Reported here:
https://bugzilla.redhat.com/show_bug.cgi?id=633037
https://bugzilla.kernel.org/show_bug.cgi?id=16559
Reported-by: Michael Chapman <redhat-bugzilla@very.puzzling.org>
Reported-by: Ciriaco Garcia de Celis <sysman@etherpilot.com>
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
Cc: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
LKML-Reference: <20100914143513.GB8415@redhat.com>
commit 950eaaca681c44aab87a46225c9e44f902c080aa upstream.
[ 23.584719]
[ 23.584720] ===================================================
[ 23.585059] [ INFO: suspicious rcu_dereference_check() usage. ]
[ 23.585176] ---------------------------------------------------
[ 23.585176] kernel/pid.c:419 invoked rcu_dereference_check() without protection!
[ 23.585176]
[ 23.585176] other info that might help us debug this:
[ 23.585176]
[ 23.585176]
[ 23.585176] rcu_scheduler_active = 1, debug_locks = 1
[ 23.585176] 1 lock held by rc.sysinit/728:
[ 23.585176] #0: (tasklist_lock){.+.+..}, at: [<ffffffff8104771f>] sys_setpgid+0x5f/0x193
[ 23.585176]
[ 23.585176] stack backtrace:
[ 23.585176] Pid: 728, comm: rc.sysinit Not tainted 2.6.36-rc2 #2
[ 23.585176] Call Trace:
[ 23.585176] [<ffffffff8105b436>] lockdep_rcu_dereference+0x99/0xa2
[ 23.585176] [<ffffffff8104c324>] find_task_by_pid_ns+0x50/0x6a
[ 23.585176] [<ffffffff8104c35b>] find_task_by_vpid+0x1d/0x1f
[ 23.585176] [<ffffffff81047727>] sys_setpgid+0x67/0x193
[ 23.585176] [<ffffffff810029eb>] system_call_fastpath+0x16/0x1b
[ 24.959669] type=1400 audit(1282938522.956:4): avc: denied { module_request } for pid=766 comm="hwclock" kmod="char-major-10-135" scontext=system_u:system_r:hwclock_t:s0 tcontext=system_u:system_r:kernel_t:s0 tclas
It turns out that the setpgid() system call fails to enter an RCU
read-side critical section before doing a PID-to-task_struct translation.
This commit therefore does rcu_read_lock() before the translation, and
also does rcu_read_unlock() after the last use of the returned pointer.
Reported-by: Andrew Morton <akpm@linux-foundation.org>
Cc: Jiri Slaby <jslaby@suse.cz>
commit 068e35eee9ef98eb4cab55181977e24995d273be upstream.
Hardware breakpoints can't be registered within pid namespaces
because tsk->pid is passed rather than the pid in the current
namespace.
(See https://bugzilla.kernel.org/show_bug.cgi?id=17281 )
This is a quick fix demonstrating the problem but is not the
best method of solving the problem since passing pids internally
is not the best way to avoid pid namespace bugs. Subsequent patches
will show a better solution.
Much thanks to Frederic Weisbecker <fweisbec@gmail.com> for doing
the bulk of the work finding this bug.
Reported-by: Robin Green <greenrd@greenrd.org>
Signed-off-by: Matt Helsley <matthltc@us.ibm.com>
Cc: Prasad <prasad@linux.vnet.ibm.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Mahesh Salgaonkar <mahesh@linux.vnet.ibm.com>
LKML-Reference: <f63454af09fb1915717251570423eb9ddd338340.1284407762.git.matthltc@us.ibm.com>
commit f362b73244fb16ea4ae127ced1467dd8adaa7733 upstream.
Using a program like the following:
#include <stdlib.h>
#include <unistd.h>
#include <sys/types.h>
#include <sys/wait.h>
int main() {
id_t id;
siginfo_t infop;
pid_t res;
id = fork();
if (id == 0) { sleep(1); exit(0); }
kill(id, SIGSTOP);
alarm(1);
waitid(P_PID, id, &infop, WCONTINUED);
return 0;
to call waitid() on a stopped process results in access to the child task's
credentials without the RCU read lock being held - which may be replaced in the
meantime - eliciting the following warning:
kernel/exit.c:1460 invoked rcu_dereference_check() without protection!
2 locks held by waitid02/22252:
#0: (tasklist_lock){.?.?..}, at: [<ffffffff81061ce5>] do_wait+0xc5/0x310
#1: (&(&sighand->siglock)->rlock){-.-...}, at: [<ffffffff810611da>]
wait_consider_task+0x19a/0xbe0
stack backtrace:
Pid: 22252, comm: waitid02 Not tainted 2.6.35-323cd+ #3
Call Trace:
[<ffffffff81095da4>] lockdep_rcu_dereference+0xa4/0xc0
[<ffffffff81061b31>] wait_consider_task+0xaf1/0xbe0
[<ffffffff81061d15>] do_wait+0xf5/0x310
[<ffffffff810620b6>] sys_waitid+0x86/0x1f0
[<ffffffff8105fce0>] ? child_wait_callback+0x0/0x70
[<ffffffff81003282>] system_call_fastpath+0x16/0x1b
This is fixed by holding the RCU read lock in wait_task_continued() to ensure
that the task's current credentials aren't destroyed between us reading the
cred pointer and us reading the UID from those credentials.
Furthermore, protect wait_task_stopped() in the same way.
We don't need to keep holding the RCU read lock once we've read the UID from
the credentials as holding the RCU read lock doesn't stop the target task from
changing its creds under us - so the credentials may be outdated immediately
after we've read the pointer, lock or no lock.
Signed-off-by: Daniel J Blueman <daniel.blueman@gmail.com>
Acked-by: Oleg Nesterov <oleg@redhat.com>
commit 868baf07b1a259f5f3803c1dc2777b6c358f83cf upstream.
When the fuction graph tracer starts, it needs to make a special
stack for each task to save the real return values of the tasks.
All running tasks have this stack created, as well as any new
tasks.
On CPU hot plug, the new idle task will allocate a stack as well
when init_idle() is called. The problem is that cpu hotplug does
not create a new idle_task. Instead it uses the idle task that
existed when the cpu went down.
ftrace_graph_init_task() will add a new ret_stack to the task
that is given to it. Because a clone will make the task
have a stack of its parent it does not check if the task's
ret_stack is already NULL or not. When the CPU hotplug code
starts a CPU up again, it will allocate a new stack even
though one already existed for it.
The solution is to treat the idle_task specially. In fact, the
function_graph code already does, just not at init_idle().
Instead of using the ftrace_graph_init_task() for the idle task,
which that function expects the task to be a clone, have a
separate ftrace_graph_init_idle_task(). Also, we will create a
per_cpu ret_stack that is used by the idle task. When we call
ftrace_graph_init_idle_task() it will check if the idle task's
ret_stack is NULL, if it is, then it will assign it the per_cpu
ret_stack.
Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Suggested-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
commit b75f38d659e6fc747eda64cb72f3920e29dd44a4 upstream.
Don't forget to release cgroup_mutex if alloc_trial_cpuset() fails.
[akpm@linux-foundation.org: avoid multiple return points]
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
Cc: Paul Menage <menage@google.com>
Acked-by: David Rientjes <rientjes@google.com>
Cc: Miao Xie <miaox@cn.fujitsu.com>
commit 3a142a0672b48a853f00af61f184c7341ac9c99d upstream.
When the per cpu timer is marked CLOCK_EVT_FEAT_C3STOP, then we only
can switch into oneshot mode, when the backup broadcast device
supports oneshot mode as well. Otherwise we would try to switch the
broadcast device into an unsupported mode unconditionally. This went
unnoticed so far as the current available broadcast devices support
oneshot mode. Seth unearthed this problem while debugging and working
around an hpet related BIOS wreckage.
Add the necessary check to tick_is_oneshot_available().
Reported-and-tested-by: Seth Forshee <seth.forshee@canonical.com>
LKML-Reference: <alpine.LFD.2.00.1102252231200.2701@localhost6.localdomain6>
commit 6d83f94db95cfe65d2a6359cccdf61cf087c2598 upstream.
With CONFIG_SHIRQ_DEBUG=y we call a newly installed interrupt handler
in request_threaded_irq().
The original implementation (commit a304e1b8) called the handler
_BEFORE_ it was installed, but that caused problems with handlers
calling disable_irq_nosync(). See commit 377bf1e4.
It's braindead in the first place to call disable_irq_nosync in shared
handlers, but ....
Moving this call after we installed the handler looks innocent, but it
is very subtle broken on SMP.
Interrupt handlers rely on the fact, that the irq core prevents
reentrancy.
Now this debug call violates that promise because we run the handler
w/o the IRQ_INPROGRESS protection - which we cannot apply here because
that would result in a possibly forever masked interrupt line.
A concurrent real hardware interrupt on a different CPU results in
handler reentrancy and can lead to complete wreckage, which was
unfortunately observed in reality and took a fricking long time to
debug.
Leave the code here for now. We want this debug feature, but that's
not easy to fix. We really should get rid of those
disable_irq_nosync() abusers and remove that function completely.
Cc: Anton Vorontsov <avorontsov@ru.mvista.com>
Cc: Arjan van de Ven <arjan@infradead.org>
commit 2e725a065b0153f0c449318da1923a120477633d upstream.
Currently we return 0 in swsusp_alloc() when alloc_image_page() fails.
Fix that. Also remove unneeded "error" variable since the only
useful value of error is -ENOMEM.
[rjw: Fixed up the changelog and changed subject.]
Signed-off-by: Stanislaw Gruszka <stf_xl@wp.pl>
commit fb2b2a1d37f80cc818fd4487b510f4e11816e5e1 upstream.
In prepare_kernel_cred() since 2.6.29, put_cred(new) is called without
assigning new->usage when security_prepare_creds() returned an error. As a
result, memory for new and refcount for new->{user,group_info,tgcred} are
leaked because put_cred(new) won't call __put_cred() unless old->usage == 1.
Fix these leaks by assigning new->usage (and new->subscribers which was added
in 2.6.32) before calling security_prepare_creds().
commit 2edeaa34a6e3f2c43b667f6c4f7b27944b811695 upstream.
In cred_alloc_blank() since 2.6.32, abort_creds(new) is called with
new->security == NULL and new->magic == 0 when security_cred_alloc_blank()
returns an error. As a result, BUG() will be triggered if SELinux is enabled
or CONFIG_DEBUG_CREDENTIALS=y.
If CONFIG_DEBUG_CREDENTIALS=y, BUG() is called from __invalid_creds() because
cred->magic == 0. Failing that, BUG() is called from selinux_cred_free()
because selinux_cred_free() is not expecting cred->security == NULL. This does
not affect smack_cred_free(), tomoyo_cred_free() or apparmor_cred_free().
Fix these bugs by
(1) Set new->magic before calling security_cred_alloc_blank().
(2) Handle null cred->security in creds_are_invalid() and selinux_cred_free().
commit de09a9771a5346029f4d11e4ac886be7f9bfdd75 upstream.
It's possible for get_task_cred() as it currently stands to 'corrupt' a set of
credentials by incrementing their usage count after their replacement by the
task being accessed.
What happens is that get_task_cred() can race with commit_creds():
TASK_1 TASK_2 RCU_CLEANER
-->get_task_cred(TASK_2)
rcu_read_lock()
__cred = __task_cred(TASK_2)
-->commit_creds()
old_cred = TASK_2->real_cred
TASK_2->real_cred = ...
put_cred(old_cred)
call_rcu(old_cred)
[__cred->usage == 0]
get_cred(__cred)
[__cred->usage == 1]
rcu_read_unlock()
-->put_cred_rcu()
panic()
However, since a tasks credentials are generally not changed very often, we can
reasonably make use of a loop involving reading the creds pointer and using
atomic_inc_not_zero() to attempt to increment it if it hasn't already hit zero.
If successful, we can safely return the credentials in the knowledge that, even
if the task we're accessing has released them, they haven't gone to the RCU
cleanup code.
We then change task_state() in procfs to use get_task_cred() rather than
calling get_cred() on the result of __task_cred(), as that suffers from the
same problem.
Without this change, a BUG_ON in __put_cred() or in put_cred_rcu() can be
tripped when it is noticed that the usage count is not zero as it ought to be,
for example:
kernel BUG at kernel/cred.c:168!
invalid opcode: 0000 [#1] SMP
last sysfs file: /sys/kernel/mm/ksm/run
CPU 0
Pid: 2436, comm: master Not tainted 2.6.33.3-85.fc13.x86_64 #1 0HR330/OptiPlex
745
RIP: 0010:[<ffffffff81069881>] [<ffffffff81069881>] __put_cred+0xc/0x45
RSP: 0018:ffff88019e7e9eb8 EFLAGS: 00010202
RAX: 0000000000000001 RBX: ffff880161514480 RCX: 00000000ffffffff
RDX: 00000000ffffffff RSI: ffff880140c690c0 RDI: ffff880140c690c0
RBP: ffff88019e7e9eb8 R08: 00000000000000d0 R09: 0000000000000000
R10: 0000000000000001 R11: 0000000000000040 R12: ffff880140c690c0
R13: ffff88019e77aea0 R14: 00007fff336b0a5c R15: 0000000000000001
FS: 00007f12f50d97c0(0000) GS:ffff880007400000(0000) knlGS:0000000000000000
CR2: 00007f8f461bc000 CR3: 00000001b26ce000 CR4: 00000000000006f0
Process master (pid: 2436, threadinfo ffff88019e7e8000, task ffff88019e77aea0)
Stack:
ffff88019e7e9ec8 ffffffff810698cd ffff88019e7e9ef8 ffffffff81069b45
<0> ffff880161514180 ffff880161514480 ffff880161514180 0000000000000000
<0> ffff88019e7e9f28 ffffffff8106aace 0000000000000001 0000000000000246
Call Trace:
[<ffffffff810698cd>] put_cred+0x13/0x15
[<ffffffff81069b45>] commit_creds+0x16b/0x175
[<ffffffff8106aace>] set_current_groups+0x47/0x4e
[<ffffffff8106ac89>] sys_setgroups+0xf6/0x105
[<ffffffff81009b02>] system_call_fastpath+0x16/0x1b
Code: 48 8d 71 ff e8 7e 4e 15 00 85 c0 78 0b 8b 75 ec 48 89 df e8 ef 4a 15 00
48 83 c4 18 5b c9 c3 55 8b 07 8b 07 48 89 e5 85 c0 74 04 <0f> 0b eb fe 65 48 8b
04 25 00 cc 00 00 48 3b b8 58 04 00 00 75
RIP [<ffffffff81069881>] __put_cred+0xc/0x45
RSP <ffff88019e7e9eb8>
---[ end trace df391256a100ebdd ]---
Acked-by: Jiri Olsa <jolsa@redhat.com>
commit 6dc19899958e420a931274b94019e267e2396d3e upstream.
I noticed a failure where we hit the following WARN_ON in
generic_smp_call_function_interrupt:
if (!cpumask_test_and_clear_cpu(cpu, data->cpumask))
continue;
data->csd.func(data->csd.info);
refs = atomic_dec_return(&data->refs);
WARN_ON(refs < 0); <-------------------------
We atomically tested and cleared our bit in the cpumask, and yet the
number of cpus left (ie refs) was 0. How can this be?
It turns out commit 54fdade1c3332391948ec43530c02c4794a38172
("generic-ipi: make struct call_function_data lockless") is at fault. It
removes locking from smp_call_function_many and in doing so creates a
rather complicated race.
The problem comes about because:
- The smp_call_function_many interrupt handler walks call_function.queue
without any locking.
- We reuse a percpu data structure in smp_call_function_many.
- We do not wait for any RCU grace period before starting the next
Imagine a scenario where CPU A does two smp_call_functions back to back,
and CPU B does an smp_call_function in between. We concentrate on how CPU
C handles the calls:
CPU A CPU B CPU C CPU D
smp_call_function
walks
call_function.queue sees
data from CPU A on list
smp_call_function
walks
(stale) CPU A on list
smp_call_function int
clears last ref on A
list_del_rcu, unlock
smp_call_function reuses
percpu *data A
data->cpumask sees and
clears bit in cpumask
might be using old or new fn!
decrements refs below 0
set data->refs (too late!)
The important thing to note is since the interrupt handler walks a
potentially stale call_function.queue without any locking, then another
cpu can view the percpu *data structure at any time, even when the owner
is in the process of initialising it.
The following test case hits the WARN_ON 100% of the time on my PowerPC
box (having 128 threads does help :)
#include <linux/module.h>
#include <linux/init.h>
#define ITERATIONS 100
static void do_nothing_ipi(void *dummy)
static void do_ipis(struct work_struct *dummy)
int i;
for (i = 0; i < ITERATIONS; i++)
smp_call_function(do_nothing_ipi, NULL, 1);
printk(KERN_DEBUG "cpu %d finished\n", smp_processor_id());
static struct work_struct work[NR_CPUS];
static int __init testcase_init(void)
int cpu;
for_each_online_cpu(cpu) {
INIT_WORK(&work[cpu], do_ipis);
schedule_work_on(cpu, &work[cpu]);
return 0;
static void __exit testcase_exit(void)
module_init(testcase_init)
module_exit(testcase_exit)
MODULE_LICENSE("GPL");
MODULE_AUTHOR("Anton Blanchard");
I tried to fix it by ordering the read and the write of ->cpumask and
->refs. In doing so I missed a critical case but Paul McKenney was able
to spot my bug thankfully :) To ensure we arent viewing previous
iterations the interrupt handler needs to read ->refs then ->cpumask then
->refs _again_.
Thanks to Milton Miller and Paul McKenney for helping to debug this issue.
[miltonm@bga.com: add WARN_ON and BUG_ON, remove extra read of refs before initial read of mask that doesn't help (also noted by Peter Zijlstra), adjust comments, hopefully clarify scenario ]
[miltonm@bga.com: remove excess tests]
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
commit 01e05e9a90b8f4c3997ae0537e87720eb475e532 upstream.
The wake_up_process() call in ptrace_detach() is spurious and not
interlocked with the tracee state. IOW, the tracee could be running or
sleeping in any place in the kernel by the time wake_up_process() is
called. This can lead to the tracee waking up unexpectedly which can be
dangerous.
The wake_up is spurious and should be removed but for now reduce its
toxicity by only waking up if the tracee is in TRACED or STOPPED state.
This bug can possibly be used as an attack vector. I don't think it
will take too much effort to come up with an attack which triggers oops
somewhere. Most sleeps are wrapped in condition test loops and should
be safe but we have quite a number of places where sleep and wakeup
conditions are expected to be interlocked. Although the window of
opportunity is tiny, ptrace can be used by non-privileged users and with
some loading the window can definitely be extended and exploited.
Acked-by: Roland McGrath <roland@redhat.com>
commit e0a70217107e6f9844628120412cb27bb4cea194 upstream.
posix-cpu-timers.c correctly assumes that the dying process does
posix_cpu_timers_exit_group() and removes all !CPUCLOCK_PERTHREAD
timers from signal->cpu_timers list.
But, it also assumes that timer->it.cpu.task is always the group
leader, and thus the dead ->task means the dead thread group.
This is obviously not true after de_thread() changes the leader.
After that almost every posix_cpu_timer_ method has problems.
It is not simple to fix this bug correctly. First of all, I think
that timer->it.cpu should use struct pid instead of task_struct.
Also, the locking should be reworked completely. In particular,
tasklist_lock should not be used at all. This all needs a lot of
nontrivial and hard-to-test changes.
Change __exit_signal() to do posix_cpu_timers_exit_group() when
the old leader dies during exec. This is not the fix, just the
temporary hack to hide the problem for 2.6.37 and stable. IOW,
this is obviously wrong but this is what we currently have anyway:
cpu timers do not work after mt exec.
In theory this change adds another race. The exiting leader can
detach the timers which were attached to the new leader. However,
the window between de_thread() and release_task() is small, we
can pretend that sys_timer_create() was called before de_thread().
commit 364829b1263b44aa60383824e4c1289d83d78ca7 upstream.
The file_ops struct for the "trace" special file defined llseek as seq_lseek().
However, if the file was opened for writing only, seq_open() was not called,
and the seek would dereference a null pointer, file->private_data.
This patch introduces a new wrapper for seq_lseek() which checks if the file
descriptor is opened for reading first. If not, it does nothing.
Signed-off-by: Slava Pestov <slavapestov@google.com>
LKML-Reference: <1290640396-24179-1-git-send-email-slavapestov@google.com>
commit 1497dd1d29c6a53fcd3c80f7ac8d0e0239e7389e upstream.
The user-space hibernation sends a wrong notification after the image
restoration because of thinko for the file flag check. RDONLY
corresponds to hibernation and WRONLY to restoration, confusingly.
commit dbd87b5af055a0cc9bba17795c9a2b0d17795389 upstream.
This fixes a bug as seen on 2.6.32 based kernels where timers got
enqueued on offline cpus.
If a cpu goes offline it might still have pending timers. These will
be migrated during CPU_DEAD handling after the cpu is offline.
However while the cpu is going offline it will schedule the idle task
which will then call tick_nohz_stop_sched_tick().
That function in turn will call get_next_timer_intterupt() to figure
out if the tick of the cpu can be stopped or not. If it turns out that
the next tick is just one jiffy off (delta_jiffies == 1)
tick_nohz_stop_sched_tick() incorrectly assumes that the tick should
not stop and takes an early exit and thus it won't update the load
balancer cpu.
Just afterwards the cpu will be killed and the load balancer cpu could
be the offline cpu.
On 2.6.32 based kernel get_nohz_load_balancer() gets called to decide
on which cpu a timer should be enqueued (see __mod_timer()). Which
leads to the possibility that timers get enqueued on an offline cpu.
These will never expire and can cause a system hang.
This has been observed 2.6.32 kernels. On current kernels
__mod_timer() uses get_nohz_timer_target() which doesn't have that
problem. However there might be other problems because of the too
early exit tick_nohz_stop_sched_tick() in case a cpu goes offline.
The easiest and probably safest fix seems to be to let
get_next_timer_interrupt() just lie and let it say there isn't any
pending timer if the current cpu is offline.
I also thought of moving migrate_[hr]timers() from CPU_DEAD to
CPU_DYING, but seeing that there already have been fixes at least in
the hrtimer code in this area I'm afraid that this could add new
subtle bugs.
LKML-Reference: <20101201091109.GA8984@osiris.boeblingen.de.ibm.com>
commit 61ab25447ad6334a74e32f60efb135a3467223f8 upstream.
This patch fixes a hang observed with 2.6.32 kernels where timers got enqueued
on offline cpus.
printk_needs_cpu() may return 1 if called on offline cpus. When a cpu gets
offlined it schedules the idle process which, before killing its own cpu, will
call tick_nohz_stop_sched_tick(). That function in turn will call
printk_needs_cpu() in order to check if the local tick can be disabled. On
offline cpus this function should naturally return 0 since regardless if the
tick gets disabled or not the cpu will be dead short after. That is besides the
fact that __cpu_disable() should already have made sure that no interrupts on
the offlined cpu will be delivered anyway.
In this case it prevents tick_nohz_stop_sched_tick() to call
select_nohz_load_balancer(). No idea if that really is a problem. However what
made me debug this is that on 2.6.32 the function get_nohz_load_balancer() is
used within __mod_timer() to select a cpu on which a timer gets enqueued. If
printk_needs_cpu() returns 1 then the nohz_load_balancer cpu doesn't get
updated when a cpu gets offlined. It may contain the cpu number of an offline
cpu. In turn timers get enqueued on an offline cpu and not very surprisingly
they never expire and cause system hangs.
This has been observed 2.6.32 kernels. On current kernels __mod_timer() uses
get_nohz_timer_target() which doesn't have that problem. However there might be
other problems because of the too early exit tick_nohz_stop_sched_tick() in
Easiest way to fix this is just to test if the current cpu is offline and call
printk_tick() directly which clears the condition.
Alternatively I tried a cpu hotplug notifier which would clear the condition,
however between calling the notifier function and printk_needs_cpu() something
could have called printk() again and the problem is back again. This seems to
be the safest fix.
LKML-Reference: <20101126120235.406766476@de.ibm.com>
commit 25c9170ed64a6551beefe9315882f754e14486f4 upstream.
Since commit a1afb637(switch /proc/irq/*/spurious to seq_file) all
/proc/irq/XX/spurious files show the information of irq 0.
Current irq_spurious_proc_open() passes on NULL as the 3rd argument,
which is used as an IRQ number in irq_spurious_proc_show(), to the
single_open(). Because of this, all the /proc/irq/XX/spurious file
shows IRQ 0 information regardless of the IRQ number.
To fix the problem, irq_spurious_proc_open() must pass on the
appropreate data (IRQ number) to single_open().
Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com>
Reviewed-by: Yong Zhang <yong.zhang0@gmail.com>
LKML-Reference: <4CF4B778.90604@jp.fujitsu.com>
commit a27341cd5fcb7cf2d2d4726e9f324009f7162c00 upstream.
This makes sure that we pick the synchronous signals caused by a
processor fault over any pending regular asynchronous signals sent to
use by [t]kill().
This is not strictly required semantics, but it makes it _much_ easier
for programs like Wine that expect to find the fault information in the
signal stack.
Without this, if a non-synchronous signal gets picked first, the delayed
asynchronous signal will have its signal context pointing to the new
signal invocation, rather than the instruction that caused the SIGSEGV
or SIGBUS in the first place.
This is not all that pretty, and we're discussing making the synchronous
signals more explicit rather than have these kinds of implicit
preferences of SIGSEGV and friends. See for example
http://bugzilla.kernel.org/show_bug.cgi?id=15395
for some of the discussion. But in the meantime this is a simple and
fairly straightforward work-around, and the whole
if (x & Y)
x &= Y;
thing can be compiled into (and gcc does do it) just three instructions:
movq %rdx, %rax
andl $Y, %eax
cmovne %rax, %rdx
so it is at least a simple solution to a subtle issue.
Reported-and-tested-by: Pavel Vilim <wylda@volny.cz>
commit c41d68a513c71e35a14f66d71782d27a79a81ea6 upstream.
compat_alloc_user_space() expects the caller to independently call
access_ok() to verify the returned area. A missing call could
introduce problems on some architectures.
This patch incorporates the access_ok() check into
compat_alloc_user_space() and also adds a sanity check on the length.
The existing compat_alloc_user_space() implementations are renamed
arch_compat_alloc_user_space() and are used as part of the
implementation of the new global function.
This patch assumes NULL will cause __get_user()/__put_user() to either
fail or access userspace on all architectures. This should be
followed by checking the return value of compat_access_user_space()
for NULL in the callers, at which time the access_ok() in the callers
can also be removed.
Reported-by: Ben Hawkes <hawkes@sota.gen.nz>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Acked-by: Chris Metcalf <cmetcalf@tilera.com>
Acked-by: Tony Luck <tony.luck@intel.com>
Cc: Helge Deller <deller@gmx.de>
Cc: James Bottomley <jejb@parisc-linux.org>
Cc: Kyle McMartin <kyle@mcmartin.ca>
commit 33dd94ae1ccbfb7bf0fb6c692bc3d1c4269e6177 upstream.
If a user manages to trigger an oops with fs set to KERNEL_DS, fs is not
otherwise reset before do_exit(). do_exit may later (via mm_release in
fork.c) do a put_user to a user-controlled address, potentially allowing
a user to leverage an oops into a controlled write into kernel memory.
This is only triggerable in the presence of another bug, but this
potentially turns a lot of DoS bugs into privilege escalations, so it's
worth fixing. I have proof-of-concept code which uses this bug along
with CVE-2010-3849 to write a zero to an arbitrary kernel address, so
I've tested that this is not theoretical.
A more logical place to put this fix might be when we know an oops has
occurred, before we call do_exit(), but that would involve changing
every architecture, in multiple places.
Let's just stick it in do_exit instead.
[akpm@linux-foundation.org: update code comment]
Signed-off-by: Nelson Elhage <nelhage@ksplice.com>
commit 38715258aa2e8cd94bd4aafadc544e5104efd551 upstream.
Per task latencytop accumulator prematurely terminates due to erroneous
placement of latency_record_count. It should be incremented whenever a
new record is allocated instead of increment on every latencytop event.
Also fix search iterator to only search known record events instead of
blindly searching all pre-allocated space.
Signed-off-by: Ken Chen <kenchen@google.com>
Reviewed-by: Arjan van de Ven <arjan@infradead.org>
commit 7ada876a8703f23befbb20a7465a702ee39b1704 upstream.
futex_wait() is leaking key references due to futex_wait_setup()
acquiring an additional reference via the queue_lock() routine. The
nested key ref-counting has been masking bugs and complicating code
analysis. queue_lock() is only called with a previously ref-counted
key, so remove the additional ref-counting from the queue_(un)lock()
functions.
Also futex_wait_requeue_pi() drops one key reference too many in
unqueue_me_pi(). Remove the key reference handling from
unqueue_me_pi(). This was paired with a queue_lock() in
futex_lock_pi(), so the count remains unchanged.
Document remaining nested key ref-counting sites.
Signed-off-by: Darren Hart <dvhart@linux.intel.com>
Reported-and-tested-by: Matthieu Fertré<matthieu.fertre@kerlabs.com>
Reported-by: Louis Rilling<louis.rilling@kerlabs.com>
Cc: John Kacur <jkacur@redhat.com>
LKML-Reference: <4CBB17A8.70401@linux.intel.com>
commit 7740191cd909b75d75685fb08a5d1f54b8a9d28b upstream.
Fix incorrect handling of the following case:
INTERACTIVE
INTERACTIVE_SOMETHING_ELSE
The comparison only checks up to each element's length.
Changelog since v1:
- Embellish using some Rostedtisms.
[ mingo: ^^ == smaller and cleaner ]
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Reviewed-by: Steven Rostedt <rostedt@goodmis.org>
Cc: Tony Lindgren <tony@atomide.com>
LKML-Reference: <20100913214700.GB16118@Krystal>
commit f13d4f979c518119bba5439dd2364d76d31dcd3f upstream.
The race is described as follows:
CPU X CPU Y
remove_hrtimer
// state & QUEUED == 0
timer->state = CALLBACK
unlock timer base
timer->f(n) //very long
hrtimer_start
lock timer base
remove_hrtimer // no effect
hrtimer_enqueue
timer->state = CALLBACK |
QUEUED
unlock timer base
hrtimer_start
lock timer base
remove_hrtimer
mode = INACTIVE
// CALLBACK bit lost!
switch_hrtimer_base
CALLBACK bit not set:
timer->base
changes to a
different CPU.
lock this CPU's timer base
The bug was introduced with commit ca109491f (hrtimer: removing all ur
callback modes) in 2.6.29
[ tglx: Feed new state via local variable and add a comment. ]
Signed-off-by: Salman Qazi <sqazi@google.com>
Cc: akpm@linux-foundation.org
LKML-Reference: <20101012142351.8485.21823.stgit@dungbeetle.mtv.corp.google.com>
commit d01343244abdedd18303d0323b518ed9cdcb1988 upstream.
Time stamps for the ring buffer are created by the difference between
two events. Each page of the ring buffer holds a full 64 bit timestamp.
Each event has a 27 bit delta stamp from the last event. The unit of time
is nanoseconds, so 27 bits can hold ~134 milliseconds. If two events
happen more than 134 milliseconds apart, a time extend is inserted
to add more bits for the delta. The time extend has 59 bits, which
is good for ~18 years.
Currently the time extend is committed separately from the event.
If an event is discarded before it is committed, due to filtering,
the time extend still exists. If all events are being filtered, then
after ~134 milliseconds a new time extend will be added to the buffer.
This can only happen till the end of the page. Since each page holds
a full timestamp, there is no reason to add a time extend to the
beginning of a page. Time extends can only fill a page that has actual
data at the beginning, so there is no fear that time extends will fill
more than a page without any data.
When reading an event, a loop is made to skip over time extends
since they are only used to maintain the time stamp and are never
given to the caller. As a paranoid check to prevent the loop running
forever, with the knowledge that time extends may only fill a page,
a check is made that tests the iteration of the loop, and if the
iteration is more than the number of time extends that can fit in a page
a warning is printed and the ring buffer is disabled (all of ftrace
is also disabled with it).
There is another event type that is called a TIMESTAMP which can
hold 64 bits of data in the theoretical case that two events happen
18 years apart. This code has not been implemented, but the name
of this event exists, as well as the structure for it. The
size of a TIMESTAMP is 16 bytes, where as a time extend is only
8 bytes. The macro used to calculate how many time extends can fit on
a page used the TIMESTAMP size instead of the time extend size
cutting the amount in half.
The following test case can easily trigger the warning since we only
need to have half the page filled with time extends to trigger the
warning:
# cd /sys/kernel/debug/tracing/
# echo function > current_tracer
# echo 'common_pid < 0' > events/ftrace/function/filter
# echo > trace
# echo 1 > trace_marker
# sleep 120
# cat trace
Enabling the function tracer and then setting the filter to only trace
functions where the process id is negative (no events), then clearing
the trace buffer to ensure that we have nothing in the buffer,
then write to trace_marker to add an event to the beginning of a page,
sleep for 2 minutes (only 35 seconds is probably needed, but this
guarantees the bug), and then finally reading the trace which will
trigger the bug.
This patch fixes the typo and prevents the false positive of that warning.
Reported-by: Hans J. Koch <hjk@linutronix.de>
Tested-by: Hans J. Koch <hjk@linutronix.de>
commit 7a0ea09ad5352efce8fe79ed853150449903b9f5 upstream.
futex_find_get_task is currently used (through lookup_pi_state) from two
contexts, futex_requeue and futex_lock_pi_atomic. None of the paths
looks it needs the credentials check, though. Different (e)uids
shouldn't matter at all because the only thing that is important for
shared futex is the accessibility of the shared memory.
The credentail check results in glibc assert failure or process hang (if
glibc is compiled without assert support) for shared robust pthread
mutex with priority inheritance if a process tries to lock already held
lock owned by a process with a different euid:
pthread_mutex_lock.c:312: __pthread_mutex_lock_full: Assertion `(-(e)) != 3 || !robust' failed.
The problem is that futex_lock_pi_atomic which is called when we try to
lock already held lock checks the current holder (tid is stored in the
futex value) to get the PI state. It uses lookup_pi_state which in turn
gets task struct from futex_find_get_task. ESRCH is returned either
when the task is not found or if credentials check fails.
futex_lock_pi_atomic simply returns if it gets ESRCH. glibc code,
however, doesn't expect that robust lock returns with ESRCH because it
should get either success or owner died.
Acked-by: Darren Hart <dvhltc@us.ibm.com>
Cc: Nick Piggin <npiggin@suse.de>
Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
commit 4673247562e39a17e09440fa1400819522ccd446 upstream.
The set_type() function can change the chip implementation when the
trigger mode changes. That might result in using an non-initialized
irq chip when called from __setup_irq() or when called via
set_irq_type() on an already enabled irq.
The set_irq_type() function should not be called on an enabled irq,
but because we forgot to put a check into it, we have a bunch of users
which grew the habit of doing that and it never blew up as the
function is serialized via desc->lock against all users of desc->chip
and they never hit the non-initialized irq chip issue.
The easy fix for the __setup_irq() issue would be to move the
irq_chip_set_defaults(desc->chip) call after the trigger setting to
make sure that a chip change is covered.
But as we have already users, which do the type setting after
request_irq(), the safe fix for now is to call irq_chip_set_defaults()
from __irq_set_trigger() when desc->set_type() changed the irq chip.
It needs a deeper analysis whether we should refuse to change the chip
on an already enabled irq, but that'd be a large scale change to fix
all the existing users. So that's neither stable nor 2.6.35 material.
Reported-by: Esben Haabendal <eha@doredevelopment.dk>
Cc: linuxppc-dev <linuxppc-dev@ozlabs.org>
commit 3c93717cfa51316e4dbb471e7c0f9d243359d5f8 upstream.
Commit e70971591 ("sched: Optimize unused cgroup configuration") introduced
an imbalanced scheduling bug.
If we do not use CGROUP, function update_h_load won't update h_load. When the
system has a large number of tasks far more than logical CPU number, the
incorrect cfs_rq[cpu]->h_load value will cause load_balance() to pull too
many tasks to the local CPU from the busiest CPU. So the busiest CPU keeps
going in a round robin. That will hurt performance.
The issue was found originally by a scientific calculation workload that
developed by Yanmin. With that commit, the workload performance drops
about 40%.
CPU before after
00 : 2 : 7
01 : 1 : 7
02 : 11 : 6
03 : 12 : 7
04 : 6 : 6
05 : 11 : 7
06 : 10 : 6
07 : 12 : 7
08 : 11 : 6
09 : 12 : 6
10 : 1 : 6
11 : 1 : 6
12 : 6 : 6
13 : 2 : 6
14 : 2 : 6
15 : 1 : 6
Reviewed-by: Yanmin zhang <yanmin.zhang@intel.com>
Signed-off-by: Alex Shi <alex.shi@intel.com>
LKML-Reference: <1276754893.9452.5442.camel@debian>
commit 0d98bb2656e9bd2dfda2d089db1fe1dbdab41504 upstream.
GCC 4.4.1 on ARM has been observed to replace the while loop in
sched_avg_update with a call to uldivmod, resulting in the
following build failure at link-time:
kernel/built-in.o: In function `sched_avg_update':
kernel/sched.c:1261: undefined reference to `__aeabi_uldivmod'
make: *** [.tmp_vmlinux1] Error 1
This patch introduces a fake data hazard to the loop body to
prevent the compiler optimising the loop away.
Acked-by: Peter Zijlstra <peterz@infradead.org>
commit b82bab4bbe9efa7bc7177fc20620fff19bd95484 upstream.
The command
echo "file ec.c +p" >/sys/kernel/debug/dynamic_debug/control
causes an oops.
Move the call to ddebug_remove_module() down into free_module(). In this
way it should be called from all error paths. Currently, we are missing
the remove if the module init routine fails.
Signed-off-by: Jason Baron <jbaron@redhat.com>
Reported-by: Thomas Renninger <trenn@suse.de>
Tested-by: Thomas Renninger <trenn@suse.de>
commit 7e53bd42d14c75192b99674c40fcc359392da59d upstream.
At the beginning, access to the ring buffer was fully serialized
by trace_types_lock. Patch d7350c3f4569 gives more freedom to readers,
and patch b04cc6b1f6 adds code to protect trace_pipe and cpu#/trace_pipe.
But actually it is not enough, ring buffer readers are not always
read-only, they may consume data.
This patch makes accesses to trace, trace_pipe, trace_pipe_raw
cpu#/trace, cpu#/trace_pipe and cpu#/trace_pipe_raw serialized.
And removes tracing_reader_cpumask which is used to protect trace_pipe.
Details:
Ring buffer serializes readers, but it is low level protection.
The validity of the events (which returns by ring_buffer_peek() ..etc)
are not protected by ring buffer.
The content of events may become garbage if we allow another process to consume
these events concurrently:
A) the page of the consumed events may become a normal page
(not reader page) in ring buffer, and this page will be rewritten
by the events producer.
B) The page of the consumed events may become a page for splice_read,
and this page will be returned to system.
This patch adds trace_access_lock() and trace_access_unlock() primitives.
These primitives allow multi process access to different cpu ring buffers
concurrently.
These primitives don't distinguish read-only and read-consume access.
Multi read-only access is also serialized.
And we don't use these primitives when we open files,
we only use them when we read files.
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
LKML-Reference: <4B447D52.1050602@cn.fujitsu.com>
commit f6ab91add6355e231e1c47897027b2a6ee4fa268 upstream.
Frederic reported that frequency driven swevents didn't work properly
and even caused a division-by-zero error.
It turns out there are two bugs, the division-by-zero comes from a
failure to deal with that in perf_calculate_period().
The other was more interesting and turned out to be a wrong comparison
in perf_adjust_period(). The comparison was between an s64 and u64 and
got implicitly converted to an unsigned comparison. The problem is
that period_left is typically < 0, so it ended up being always true.
Cure this by making the local period variables s64.
Reported-by: Frederic Weisbecker <fweisbec@gmail.com>
Tested-by: Frederic Weisbecker <fweisbec@gmail.com>
LKML-Reference: <new-submission>
commit 065add3941bdca54fe04ed3471a96bce9af88793 upstream.
Andrew Tridgell reports that aio_read(SIGEV_SIGNAL) can fail if the
notification from the helper thread races with setresuid(), see
http://samba.org/~tridge/junkcode/aio_uid.c
This happens because check_kill_permission() doesn't permit sending a
signal to the task with the different cred->xids. But there is not any
security reason to check ->cred's when the task sends a signal (private or
group-wide) to its sub-thread. Whatever we do, any thread can bypass all
security checks and send SIGKILL to all threads, or it can block a signal
SIG and do kill(gettid(), SIG) to deliver this signal to another
sub-thread. Not to mention that CLONE_THREAD implies CLONE_VM.
Change check_kill_permission() to avoid the credentials check when the
sender and the target are from the same thread group.
Also, move "cred = current_cred()" down to avoid calling get_current()
twice.
Note: David Howells pointed out we could relax this even more, the
CLONE_SIGHAND (without CLONE_THREAD) case probably does not need
these checks too.
Roland said:
: The glibc (libpthread) that does set*id across threads has
: been in use for a while (2.3.4?), probably in distro's using kernels as old
: or older than any active -stable streams. In the race in question, this
: kernel bug is breaking valid POSIX application expectations.
Reported-by: Andrew Tridgell <tridge@samba.org>
Cc: Eric Paris <eparis@parisplace.org>
Cc: Jakub Jelinek <jakub@redhat.com>
Cc: Roland McGrath <roland@redhat.com>
Cc: Stephen Smalley <sds@tycho.nsa.gov>
commit fd6be105b883244127a734ac9f14ae94a022dcc0 upstream.
Currently, we can hit a nasty case with optimistic
spinning on mutexes:
CPU A tries to take a mutex, while holding the BKL
CPU B tried to take the BLK while holding the mutex
This looks like a AB-BA scenario but in practice, is
allowed and happens due to the auto-release on
schedule() nature of the BKL.
In that case, the optimistic spinning code can get us
into a situation where instead of going to sleep, A
will spin waiting for B who is spinning waiting for
A, and the only way out of that loop is the
need_resched() test in mutex_spin_on_owner().
This patch fixes it by completely disabling spinning
if we own the BKL. This adds one more detail to the
extensive list of reasons why it's a bad idea for
kernel code to be holding the BKL.
Signed-off-by: Tony Breeds <tony@bakeyournoodle.com>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
LKML-Reference: <20100519054636.GC12389@ozlabs.org>
[ added an unlikely() attribute to the branch ]
commit fa9dc265ace9774e62f0e31108e5f47911124bda upstream.
Commit a45185d2d "cpumask: convert kernel/compat.c" broke libnuma, which
abuses sched_getaffinity to find out NR_CPUS in order to parse
/sys/devices/system/node/node*/cpumap.
On NUMA systems with less than 32 possibly CPUs, the current
compat_sys_sched_getaffinity now returns '4' instead of the actual
NR_CPUS/8, which makes libnuma bail out when parsing the cpumap.
The libnuma call sched_getaffinity(0, bitmap, 4096) at first. It mean
the libnuma expect the return value of sched_getaffinity() is either len
argument or NR_CPUS. But it doesn't expect to return nr_cpu_ids.
Strictly speaking, userland requirement are
1) Glibc assume the return value mean the lengh of initialized
of mask argument. E.g. if sched_getaffinity(1024) return 128,
glibc make zero fill rest 896 byte.
2) Libnuma assume the return value can be used to guess NR_CPUS
in kernel. It assume len-arg<NR_CPUS makes -EINVAL. But
it try len=4096 at first and 4096 is always bigger than
NR_CPUS. Then, if we remove strange min_length normalization,
we never hit -EINVAL case.
sched_getaffinity() already solved this issue. This patch adapts
compat_sys_sched_getaffinity() to match the non-compat case.
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
Reported-by: Ken Werner <ken.werner@web.de>
commit 45e0fffc8a7778282e6a1514a6ae3e7ae6545111 upstream.
Move CLOCK_DISPATCH(which_clock, timer_create, (new_timer)) after all
posible EFAULT erros.
*_timer_create may allocate/get resources.
(for example posix_cpu_timer_create does get_task_struct)
[ tglx: fold the remove crappy comment patch into this ]
Signed-off-by: Andrey Vagin <avagin@openvz.org>
Cc: Oleg Nesterov <oleg@tv-sign.ru>
Cc: Pavel Emelyanov <xemul@openvz.org>
Reviewed-by: Stanislaw Gruszka <sgruszka@redhat.com>
commit ea635c64e007061f6468ece5cc9cc62d41d4ecf2 upstream.
once anon_inode_getfd() is called, you can't expect *anything* about
struct file that descriptor points to - another thread might be doing
whatever it likes with descriptor table at that point.
commit 16a2164bb03612efe79a76c73da6da44445b9287 upstream.
If the kernel is large or the profiling step small, /proc/profile
leaks data and readprofile shows silly stats, until readprofile -r
has reset the buffer: clear the prof_buffer when it is vmalloc()ed.
commit 34441427aab4bdb3069a4ffcda69a99357abcb2e upstream.
Originally, commit d899bf7b ("procfs: provide stack information for
threads") attempted to introduce a new feature for showing where the
threadstack was located and how many pages are being utilized by the
stack.
Commit c44972f1 ("procfs: disable per-task stack usage on NOMMU") was
applied to fix the NO_MMU case.
Commit 89240ba0 ("x86, fs: Fix x86 procfs stack information for threads on
64-bit") was applied to fix a bug in ia32 executables being loaded.
Commit 9ebd4eba7 ("procfs: fix /proc/<pid>/stat stack pointer for kernel
threads") was applied to fix a bug which had kernel threads printing a
userland stack address.
Commit 1306d603f ('proc: partially revert "procfs: provide stack
information for threads"') was then applied to revert the stack pages
being used to solve a significant performance regression.
This patch nearly undoes the effect of all these patches.
The reason for reverting these is it provides an unusable value in
field 28. For x86_64, a fork will result in the task->stack_start
value being updated to the current user top of stack and not the stack
start address. This unpredictability of the stack_start value makes
it worthless. That includes the intended use of showing how much stack
space a thread has.
Other architectures will get different values. As an example, ia64
gets 0. The do_fork() and copy_process() functions appear to treat the
stack_start and stack_size parameters as architecture specific.
I only partially reverted c44972f1 ("procfs: disable per-task stack usage
on NOMMU") . If I had completely reverted it, I would have had to change
mm/Makefile only build pagewalk.o when CONFIG_PROC_PAGE_MONITOR is
configured. Since I could not test the builds without significant effort,
I decided to not change mm/Makefile.
I only partially reverted 89240ba0 ("x86, fs: Fix x86 procfs stack
information for threads on 64-bit") . I left the KSTK_ESP() change in
place as that seemed worthwhile.
Signed-off-by: Robin Holt <holt@sgi.com>
Cc: Stefani Seibold <stefani@seibold.net>
commit e134d200d57d43b171dcb0b55c178a1a0c7db14a upstream.
creds_are_invalid() reads both cred->usage and cred->subscribers and then
compares them to make sure the number of processes subscribed to a cred struct
never exceeds the refcount of that cred struct.
The problem is that this can cause a race with both copy_creds() and
exit_creds() as the two counters, whilst they are of atomic_t type, are only
atomic with respect to themselves, and not atomic with respect to each other.
This means that if creds_are_invalid() can read the values on one CPU whilst
they're being modified on another CPU, and so can observe an evolving state in
which the subscribers count now is greater than the usage count a moment
before.
Switching the order in which the counts are read cannot help, so the thing to
do is to remove that particular check.
I had considered rechecking the values to see if they're in flux if the test
fails, but I can't guarantee they won't appear the same, even if they've
changed several times in the meantime.
Note that this can only happen if CONFIG_DEBUG_CREDENTIALS is enabled.
The problem is only likely to occur with multithreaded programs, and can be
tested by the tst-eintr1 program from glibc's "make check". The symptoms look
like:
CRED: Invalid credentials
CRED: At include/linux/cred.h:240
CRED: Specified credentials: ffff88003dda5878 [real][eff]
CRED: ->magic=43736564, put_addr=(null)
CRED: ->usage=766, subscr=766
CRED: ->*uid = { 0,0,0,0 }
CRED: ->*gid = { 0,0,0,0 }
CRED: ->security is ffff88003d72f538
CRED: ->security {359, 359}
kernel BUG at kernel/cred.c:850!
RIP: 0010:[<ffffffff81049889>] [<ffffffff81049889>] __invalid_creds+0x4e/0x52
Call Trace:
[<ffffffff8104a37b>] copy_creds+0x6b/0x23f
Note the ->usage=766 and subscr=766. The values appear the same because
they've been re-read since the check was made.
Reported-by: Roland McGrath <roland@redhat.com>
Signed-off-by: James Morris <jmorris@namei.org>
commit 048c852051d2bd5da54a4488bc1f16b0fc74c695 upstream.
perf_event_open() kfrees event after init failure which doesn't
release all resources allocated by perf_event_alloc(). Use
free_event() instead.
Cc: Paul Mackerras <paulus@au1.ibm.com>
LKML-Reference: <4BDBE237.1040809@kernel.org>
commit 8bc037fb89bb3104b9ae290d18c877624cd7d9cc upstream.
Using the proper type fixes the following compiler warning:
kernel/sched.c:4850: warning: comparison of distinct pointer types lacks a cast
Cc: torvalds@linux-foundation.org
Cc: travis@sgi.com
Cc: peterz@infradead.org
Cc: drepper@redhat.com
Cc: rja@sgi.com
Cc: sharyath@in.ibm.com
Cc: steiner@sgi.com
LKML-Reference: <20100317090046.4C79.A69D9226@jp.fujitsu.com>
The mainline kernel as of 2.6.34-rc5 is not affected by this problem because
commit 10fad5e46f6c7bdfb01b1a012380a38e3c6ab346 fixed it by refactoring.
lockdep fix incorrect percpu usage
Should use per_cpu_ptr() to obfuscate the per cpu pointers (RELOC_HIDE is needed
for per cpu pointers).
git blame points to commit:
lockdep.c: commit 8e18257d29238311e82085152741f0c3aa18b74d
But it's really just moving the code around. But it's enough to say that the
problems appeared before Jul 19 01:48:54 2007, which brings us back to 2.6.23.
It should be applied to stable 2.6.23.x to 2.6.33.x (or whichever of these
stable branches are still maintained).
(tested on 2.6.33.1 x86_64)
CC: Randy Dunlap <randy.dunlap@oracle.com>
CC: Eric Dumazet <dada1@cosmosbay.com>
CC: Rusty Russell <rusty@rustcorp.com.au>
CC: Peter Zijlstra <a.p.zijlstra@chello.nl>
CC: Tejun Heo <tj@kernel.org>
CC: Ingo Molnar <mingo@elte.hu>
CC: Andrew Morton <akpm@linux-foundation.org>
CC: Linus Torvalds <torvalds@linux-foundation.org>
CC: Greg Kroah-Hartman <gregkh@suse.de>
CC: Steven Rostedt <rostedt@goodmis.org>
Mainline does not need this fix, as commit
259354deaaf03d49a02dbb9975d6ec2a54675672 fixed the problem by refactoring.
Introduced by commit:
module.c: commit 6b588c18f8dacfa6d7957c33c5ff832096e752d3
This patch should be queued for the stable branch, for kernels 2.6.29.x to
2.6.33.x. (tested on 2.6.33.1 x86_64)
commit 84fba5ec91f11c0efb27d0ed6098f7447491f0df upstream.
taskset on 2.6.34-rc3 fails on one of my ppc64 test boxes with
the following error:
sched_getaffinity(0, 16, 0x10029650030) = -1 EINVAL (Invalid argument)
This box has 128 threads and 16 bytes is enough to cover it.
Commit cd3d8031eb4311e516329aee03c79a08333141f1 (sched:
sched_getaffinity(): Allow less than NR_CPUS length) is
comparing this 16 bytes agains nr_cpu_ids.
Fix it by comparing nr_cpu_ids to the number of bits in the
cpumask we pass in.
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Cc: Sharyathi Nagesh <sharyath@in.ibm.com>
Cc: Ulrich Drepper <drepper@redhat.com>
Cc: Jack Steiner <steiner@sgi.com>
Cc: Russ Anderson <rja@sgi.com>
Cc: Mike Travis <travis@sgi.com>
LKML-Reference: <20100406070218.GM5594@kryten>
