path: root/kernel
2007-03-25[PATCH] clocksource: Fix thinko in watchdog selectionThomas Gleixner
The watchdog implementation excludes low res / non continuous clocksources from being selected as a watchdog reference unintentionally. Allow using jiffies/PIT as a watchdog reference as long as no better clocksource is available. This is necessary to detect TSC breakage on systems, which have no pmtimer/hpet. The main goal of the initial patch (preventing to switch to highres/nohz when no reliable fallback clocksource is available) is still guaranteed by the checks in clocksource_watchdog(). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-25[PATCH] dynticks: fix hrtimer rounding error in next_timer_interruptThomas Gleixner
The rework of next_timer_interrupt() fixed the timer wheel bugs, but invented a rounding error versus the next hrtimer event. This is caused by the conversion of the hrtimer internal representation to relative jiffies. This causes bug #8100: http://bugzilla.kernel.org/show_bug.cgi?id=8100 next_timer_interrupt() returns "now" in such a case and causes the code in tick_nohz_stop_sched_tick() to trigger the timer softirq, which is bogus as no timer is due for expiry. This results in an endless context switching between idle and ksoftirqd until a timer is due for expiry. Modify the hrtimer evaluation so that, it returns now + 1, when the conversion results in a delta < 1 jiffie. It's confirmed to resolve bug #8100 Reported-by: Emil Karlson <jkarlson@cc.hut.fi> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-23[PATCH] time: fix formatting in /proc/timer_listJames Morris
Fix the print formatting of three unsigned long fields in /proc/timer_list, which are currently being formatted as signed long. Signed-off-by: James Morris <jmorris@namei.org> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-22[PATCH] lockdep: debug_show_all_locks & debug_show_held_locks vs. debug_locksJarek Poplawski
lockdep's data shouldn't be used when debug_locks == 0 because it's not updated after this, so it's more misleading than helpful. PS: probably lockdep's current-> fields should be reset after it turns debug_locks off: so, after printing a bug report, but before return from exported functions, but there are really a lot of these possibilities (e.g. after DEBUG_LOCKS_WARN_ON), so, something could be missed. (Of course direct use of this fields isn't recommended either.) Reported-by: Folkert van Heusden <folkert@vanheusden.com> Inspired-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Jarek Poplawski <jarkao2@o2.pl> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-22[PATCH] fix extra BIOS invocation during resumePavel Machek
It causes extra moon icons blinking on x60, and breaks at least two other systems. During resume, we do not know that "reboot"/"shutdown" method was used, so we assume "plaform" and call BIOS, anyway... This is 2.6.21 material, and should fix 2 or 3 regressions from 2.6.20. Signed-off-by: Pavel Machek <pavel@suse.cz> Acked-by: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-22[PATCH] swsusp: Fix SNAPSHOT_S2RAM ioctlRafael J. Wysocki
The SNAPSHOT_S2RAM ioctl does not disable the nonboot CPUs before entering the suspend, although it should do this. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-16[PATCH] clockevents: Fix suspend/resume to disk hangsThomas Gleixner
I finally found a dual core box, which survives suspend/resume without crashing in the middle of nowhere. Sigh, I never figured out from the code and the bug reports what's going on. The observed hangs are caused by a stale state transition of the clock event devices, which keeps the RCU synchronization away from completion, when the non boot CPU is brought back up. The suspend/resume in oneshot mode needs the similar care as the periodic mode during suspend to RAM. My assumption that the state transitions during the different shutdown/bringups of s2disk would go through the periodic boot phase and then switch over to highres resp. nohz mode were simply wrong. Add the appropriate suspend / resume handling for the non periodic modes. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-16[PATCH] initialise pi_lock if CONFIG_RT_MUTEXES=NZilvinas Valinskas
Fixes a bogus lockdep warning which causes lockdep to disable itself. Acked-by: Ingo Molnar <mingo@elte.hu> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-16[PATCH] futex: PI state locking fixIngo Molnar
Testing of -rt by IBM uncovered a locking bug in wake_futex_pi(): the PI state needs to be locked before we access it. Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Chuck Ebbert <cebbert@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-16[PATCH] swsusp: fix suspend when console is in VT_AUTO+KD_GRAPHICS modeAndrew Johnson
When the console is in VT_AUTO+KD_GRAPHICS mode, switching to the SUSPEND_CONSOLE fails, resulting in vt_waitactive() waiting indefinitely or until the task is interrupted. This patch tests if a console switch can occur in set_console() and returns early if a console switch is not possible. [akpm@linux-foundation.org: cleanup] Signed-off-by: Andrew Johnson <ajohnson@intrinsyc.com> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-16[PATCH] hrtimer: fix up unlocked access to wall_to_monotonicThomas Gleixner
commit f4304ab21513b834c8fe3403927c60c2b81a72d7 (HZ free NTP) moved the access to wall_to_monotonic in hrtimer_get_softirq_time() out of the xtime_lock protection. Move it back into the seq_lock section. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-16[PATCH] hrtimer: prevent overrun DoS in hrtimer_forward()Thomas Gleixner
hrtimer_forward() does not check for the possible overflow of timer->expires. This can happen on 64 bit machines with large interval values and results currently in an endless loop in the softirq because the expiry value becomes negative and therefor the timer is expired all the time. Check for this condition and set the expiry value to the max. expiry time in the future. The fix should be applied to stable kernel series as well. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-16[PATCH] swsusp: disable nonboot CPUs before entering platform suspendRafael J. Wysocki
Prevent the WARN_ON() in arch/x86_64/kernel/acpi/sleep.c:init_low_mapping() from triggering by disabling nonboot CPUs before we finally enter the platform suspend. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-16[PATCH] swsusp: Fix resume error path in platform modeRafael J. Wysocki
If swsusp is using the platform mode during the resume and the image cannot be read, the platform mode should be switched off before software_resume() returns. Make it happen. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-14[PATCH] fix deadlock in audit_log_task_context()Al Viro
GFP_KERNEL allocations in non-blocking context; fixed by killing an idiotic use of security_getprocattr(). Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-09Revert "driver core: refcounting fix"Greg Kroah-Hartman
This reverts commit 63ce18cfe685115ff8d341bae4c9204a79043cf0. It was the incorrect fix and causes a reference counting bug whenever any driver module is removed from the system. Mike Galbraith <efault@gmx.de> is looking for the real fix for his problem. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-07Merge master.kernel.org:/pub/scm/linux/kernel/git/lethal/sh-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/lethal/sh-2.6: sh: Kill off I/O cruft for R7780RP. sh: Revert lazy dcache writeback changes. sh: Enable SM501 support for RTS7751R2D. sh: Use L1_CACHE_BYTES for .data.cacheline_aligned. sysctl: Support vdso_enabled sysctl on SH. sh: Fix kernel thread stack corruption with preempt. doc: Add SH to vdso and earlyprintk in kernel-parameters.txt sh: Fix sigmask trampling in signal delivery. sh: Clear UBC when not in use.
2007-03-06[PATCH] kconfig: Update swsusp descriptionRafael J. Wysocki
Update the outdated and inaccurate description of the software suspend in Kconfig. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-06[PATCH] Publish rcutorture module parameters via sysfs, read-onlyJosh Triplett
rcutorture's module parameters currently use permissions of 0, so they don't show up in /sys/module/rcutorture/parameters. Change the permissions on all module parameters to world-readable (0444). rcutorture does all of its initialization and thread startup when loaded and relies on the parameters not changing during execution, so they should not permit writing. However, reading seems fine. Signed-off-by: Josh Triplett <josh@freedesktop.org> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-06[PATCH] fix vsyscall settimeofdayDaniel Walker
I've only seen this on x86_64. The vsyscall state only gets updated when a timer interrupts comes in. So if the time is set long before the next timer, there will be a period when a gettimeofday() won't reflect the correct time. I added an explicit update_vsyscall() during the settimeofday(), that way the vsyscall state doesn't get stale. Signed-off-by: Daniel Walker <dwalker@mvista.com> Cc: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-06[PATCH] highres: do not run the TIMER_SOFTIRQ after switching to highres modeThomas Gleixner
The TIMER_SOFTIRQ runs the hrtimers during bootup until a usable clocksource and clock event sources are registered. The switch to high resolution mode happens inside of the TIMER_SOFTIRQ, but runs the softirq afterwards. That way the tick emulation timer, which was set up in the switch to highres might be executed in the softirq context, which is a BUG. The rbtree has not to be touched by the softirq after the highres switch. This BUG was observed by Andres Salomon, who provided the information to debug it. Return early from the softirq, when the switch was sucessful. [dilinger@debian.org: add debug warning] [akpm@linux-foundation.org: make debug warning compile] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Andres Salomon <dilinger@debian.org> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andres Salomon <dilinger@debian.org> Acked-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-06[PATCH] Save/restore periodic tick information over suspend/resumeThomas Gleixner
The programming of periodic tick devices needs to be saved/restored across suspend/resume - otherwise we might end up with a system coming up that relies on getting a PIT (or HPET) interrupt, while those devices default to 'no interrupts' after powerup. (To confuse things it worked to a certain degree on some systems because the lapic gets initialized as a side-effect of SMP bootup.) This suspend / resume thing was dropped unintentionally during the last-minute -mm code reshuffling. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-05[PATCH] timer/hrtimer: take per cpu locks in sane orderHeiko Carstens
Doing something like this on a two cpu system # echo 0 > /sys/devices/system/cpu/cpu0/online # echo 1 > /sys/devices/system/cpu/cpu0/online # echo 0 > /sys/devices/system/cpu/cpu1/online will give me this: ======================================================= [ INFO: possible circular locking dependency detected ] 2.6.21-rc2-g562aa1d4-dirty #7 ------------------------------------------------------- bash/1282 is trying to acquire lock: (&cpu_base->lock_key){.+..}, at: [<000000000005f17e>] hrtimer_cpu_notify+0xc6/0x240 but task is already holding lock: (&cpu_base->lock_key#2){.+..}, at: [<000000000005f174>] hrtimer_cpu_notify+0xbc/0x240 which lock already depends on the new lock. This happens because we have the following code in kernel/hrtimer.c: migrate_hrtimers(int cpu) [...] old_base = &per_cpu(hrtimer_bases, cpu); new_base = &get_cpu_var(hrtimer_bases); [...] spin_lock(&new_base->lock); spin_lock(&old_base->lock); Which means the spinlocks are taken in an order which depends on which cpu gets shut down from which other cpu. Therefore lockdep complains that there might be an ABBA deadlock. Since migrate_hrtimers() gets only called on cpu hotplug it's safe to assume that it isn't executed concurrently on a The same problem exists in kernel/timer.c: migrate_timers(). As pointed out by Christian Borntraeger one possible solution to avoid the locking order complaints would be to make sure that the locks are always taken in the same order. E.g. by taking the lock of the cpu with the lower number first. To achieve this we introduce two new spinlock functions double_spin_lock and double_spin_unlock which lock or unlock two locks in a given order. Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: John Stultz <johnstul@us.ibm.com> Cc: Christian Borntraeger <cborntra@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-05[PATCH] clocksource init adjustments (fix bug #7426)john stultz
This patch resolves the issue found here: http://bugme.osdl.org/show_bug.cgi?id=7426 The basic summary is: Currently we register most of i386/x86_64 clocksources at module_init time. Then we enable clocksource selection at late_initcall time. This causes some problems for drivers that use gettimeofday for init calibration routines (specifically the es1968 driver in this case), where durring module_init, the only clocksource available is the low-res jiffies clocksource. This may cause slight calibration errors, due to the small sampling time used. It should be noted that drivers that require fine grained time may not function on architectures that do not have better then jiffies resolution timekeeping (there are a few). However, this does not discount the reasonable need for such fine-grained timekeeping at init time. Thus the solution here is to register clocksources earlier (ideally when the hardware is being initialized), and then we enable clocksource selection at fs_initcall (before device_initcall). This patch should probably get some testing time in -mm, since clocksource selection is one of the most important issues for correct timekeeping, and I've only been able to test this on a few of my own boxes. Signed-off-by: John Stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-05[PATCH] sched: remove SMT niceCon Kolivas
Remove the SMT-nice feature which idles sibling cpus on SMT cpus to facilitiate nice working properly where cpu power is shared. The idling of cpus in the presence of runnable tasks is considered too fragile, easy to break with outside code, and the complexity of managing this system if an architecture comes along with many logical cores sharing cpu power will be unworkable. Remove the associated per_cpu_gain variable in sched_domains used only by this code. Also: The reason is that with dynticks enabled, this code breaks without yet further tweaks so dynticks brought on the rapid demise of this code. So either we tweak this code or kill it off entirely. It was Ingo's preference to kill it off. Either way this needs to happen for 2.6.21 since dynticks has gone in. Signed-off-by: Con Kolivas <kernel@kolivas.org> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-05sysctl: Support vdso_enabled sysctl on SH.Paul Mundt
All of the logic for this was already in place, we just hadn't wired it up in the sysctl table. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-03-01[PATCH] sched: fix SMT scheduler bugIngo Molnar
The SMT scheduler incorrectly skips kernel threads even if they are runnable (but they are preempted by a higher-prio user-space task which got SMT-delayed by an even higher-priority task running on a sibling CPU). Fix this for now by only doing the SMT-nice optimization if the to-be-delayed task is the only runnable task. (This should cover most of the real-life cases anyway.) This bug has been in the SMT scheduler since 2.6.17 or so, but has only been noticed now by the active check in the dynticks code. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-01[PATCH] fix section mismatch warning in lockdepSam Ravnborg
lockdep_init() is marked __init but used in several places outside __init code. This causes following warnings: $ scripts/mod/modpost kernel/lockdep.o WARNING: kernel/built-in.o - Section mismatch: reference to .init.text:lockdep_init from .text.lockdep_init_map after 'lockdep_init_map' (at offset 0x105) WARNING: kernel/built-in.o - Section mismatch: reference to .init.text:lockdep_init from .text.lockdep_reset_lock after 'lockdep_reset_lock' (at offset 0x35) WARNING: kernel/built-in.o - Section mismatch: reference to .init.text:lockdep_init from .text.__lock_acquire after '__lock_acquire' (at offset 0xb2) The warnings are less obviously due to heavy inlining by gcc - this is not altered. Fix the section mismatch warnings by removing the __init marking, which seems obviously wrong. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-01[PATCH] fix the SYSCTL=n compilationAdrian Bunk
/home/bunk/linux/kernel-2.6/linux-2.6.20-mm2/kernel/sysctl.c:1411: error: conflicting types for 'register_sysctl_table' /home/bunk/linux/kernel-2.6/linux-2.6.20-mm2/include/linux/sysctl.h:1042: error: previous declaration of 'register_sysctl_table' was here make[2]: *** [kernel/sysctl.o] Error 1 Caused by commit 0b4d414714f0d2f922d39424b0c5c82ad900a381. Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-01[PATCH] Fix posix-cpu-timer breakage caused by stale p->last_ran valueThomas Gleixner
Problem description at: http://bugzilla.kernel.org/show_bug.cgi?id=8048 Commit b18ec80396834497933d77b81ec0918519f4e2a7 [PATCH] sched: improve migration accuracy optimized the scheduler time calculations, but broke posix-cpu-timers. The problem is that the p->last_ran value is not updated after a context switch. So a subsequent call to current_sched_time() calculates with a stale p->last_ran value, i.e. accounts the full time, which the task was scheduled away. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-01[PATCH] kernel-doc fixes for 2.6.20-git15 (non-drivers)Randy Dunlap
Fix kernel-doc warnings in 2.6.20-git15 (lib/, mm/, kernel/, include/). Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-01[PATCH] update timekeeping_is_continuous commentDaniel Walker
Signed-off-by: Daniel Walker <dwalker@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-26Merge master.kernel.org:/pub/scm/linux/kernel/git/kyle/parisc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/kyle/parisc-2.6: (78 commits) [PARISC] Use symbolic last syscall in __NR_Linux_syscalls [PARISC] Add missing statfs64 and fstatfs64 syscalls Revert "[PARISC] Optimize TLB flush on SMP systems" [PARISC] Compat signal fixes for 64-bit parisc [PARISC] Reorder syscalls to match unistd.h Revert "[PATCH] make kernel/signal.c:kill_proc_info() static" [PARISC] fix sys_rt_sigqueueinfo [PARISC] fix section mismatch warnings in harmony sound driver [PARISC] do not export get_register/set_register [PARISC] add ENTRY()/ENDPROC() and simplify assembly of HP/UX emulation code [PARISC] convert to use CONFIG_64BIT instead of __LP64__ [PARISC] use CONFIG_64BIT instead of __LP64__ [PARISC] add ASM_EXCEPTIONTABLE_ENTRY() macro [PARISC] more ENTRY(), ENDPROC(), END() conversions [PARISC] fix ENTRY() and ENDPROC() for 64bit-parisc [PARISC] Fixes /proc/cpuinfo cache output on B160L [PARISC] implement standard ENTRY(), END() and ENDPROC() [PARISC] kill ENTRY_SYS_CPUS [PARISC] clean up debugging printks in smp.c [PARISC] factor syscall_restart code out of do_signal ... Fix conflict in include/linux/sched.h due to kill_proc_info() being made publicly available to PARISC again.
2007-02-26Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/tick-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/tick-2.6: [TICK] tick-common: Fix one-shot handling in tick_handle_periodic(). [TIME] tick-sched: Add missing asm/irq_regs.h include.
2007-02-26Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/driver-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/driver-2.6: Revert "Driver core: let request_module() send a /sys/modules/kmod/-uevent" Driver core: fix error by cleanup up symlinks properly make kernel/kmod.c:kmod_mk static power management: fix struct layout and docs power management: no valid states w/o pm_ops Driver core: more fallout from class_device changes for pcmcia sysfs: move struct sysfs_dirent to private header driver core: refcounting fix Driver core: remove class_device_rename
2007-02-26[TICK] tick-common: Fix one-shot handling in tick_handle_periodic().David S. Miller
When clockevents_program_event() is given an expire time in the past, it does not update dev->next_event, so this looping code would loop forever once the first in-the-past expiration time was used. Keep advancing "next" locally to fix this bug. Acked-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-26[TIME] tick-sched: Add missing asm/irq_regs.h include.David S. Miller
2007-02-26[PATCH] genirq: Mask irqs when migrating them.Eric W. Biederman
move_native_irqs tries to do the right thing when migrating irqs by disabling them. However disabling them is a software logical thing, not a hardware thing. This has always been a little flaky and after Ingo's latest round of changes it is guaranteed to not mask the apic. So this patch fixes move_native_irq to directly call the mask and unmask chip methods to guarantee that we mask the irq when we are migrating it. We must do this as it is required by all code that call into the path. Since we don't know the masked status when IRQ_DISABLED is set so we will not be able to restore it. The patch makes the code just give up and trying again the next time this routing is called. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-23Revert "Driver core: let request_module() send a /sys/modules/kmod/-uevent"Greg Kroah-Hartman
This reverts commit c353c3fb0700a3c17ea2b0237710a184232ccd7f. It turns out that we end up with a loop trying to load the unix module and calling netfilter to do that. Will redo the patch later to not have this loop. Acked-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-23make kernel/kmod.c:kmod_mk staticAdrian Bunk
This patch makes the needlessly global struct kmod_mk static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-23power management: no valid states w/o pm_opsJohannes Berg
Change /sys/power/state to not advertise any valid states (except for disk if SOFTWARE_SUSPEND is enabled) when no pm_ops have been set so userspace can easily discover what states should be available. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Cc: Rafael J. Wysocki <rjw@sisk.pl> Cc: Pavel Macheck <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-23driver core: refcounting fixMike Galbraith
Fix a reference counting bug exposed by commit 725522b5453dd680412f2b6463a988e4fd148757. If driver.mod_name exists, we take a reference in module_add_driver(), and never release it. Undo that reference in module_remove_driver(). Signed-off-by: Mike Galbraith <efault@gmx.de> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-20[PATCH] lockdep: debug_locks check after check_chain_keyJarek Poplawski
In __lock_acquire check_chain_key can turn off debug_locks, so check is needed to assure proper return code. Signed-off-by: Jarek Poplawski <jarkao2@o2.pl> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-20[PATCH] kprobes: list all active probes in the systemSrinivasa Ds
This patch lists all active probes in the system by scanning through kprobe_table[]. It takes care of aggregate handlers and prints the type of the probe. Letter "k" for kprobes, "j" for jprobes, "r" for kretprobes. It also lists address of the instruction,its symbolic name(function name + offset) and the module name. One can access this file through /sys/kernel/debug/kprobes/list. Output looks like this ===================== llm40:~/a # cat /sys/kernel/debug/kprobes/list c0169ae3 r sys_read+0x0 c0169ae3 k sys_read+0x0 c01694c8 k vfs_write+0x0 c0167d20 r sys_open+0x0 f8e658a6 k reiserfs_delete_inode+0x0 reiserfs c0120f4a k do_fork+0x0 c0120f4a j do_fork+0x0 c0169b4a r sys_write+0x0 c0169b4a k sys_write+0x0 c0169622 r vfs_read+0x0 ================================= [akpm@linux-foundation.org: cleanup] [ananth@in.ibm.com: sparc build fix] Signed-off-by: Srinivasa DS <srinivasa@in.ibm.com> Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-19[PATCH] NOHZ: Produce debug output instead of a BUG()Thomas Gleixner
The BUG_ON() in tick_nohz_stop_sched_tick() triggers on some boxen. Remove the BUG_ON and print information about the pending softirq to allow better debugging of the problem. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-19[PATCH] NOHZ: Fix RCU handlingIngo Molnar
When a CPU is needed for RCU the tick has to continue even when it was stopped before. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-19Merge branch 'audit.b37' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit-current * 'audit.b37' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit-current: [PATCH] AUDIT_FD_PAIR [PATCH] audit config lockdown [PATCH] minor update to rule add/delete messages (ver 2)
2007-02-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: (25 commits) Documentation/kernel-docs.txt update. arch/cris: typo in KERN_INFO Storage class should be before const qualifier kernel/printk.c: comment fix update I/O sched Kconfig help texts - CFQ is now default, not AS. Remove duplicate listing of Cris arch from README kbuild: more doc. cleanups doc: make doc. for maxcpus= more visible drivers/net/eexpress.c: remove duplicate comment add a help text for BLK_DEV_GENERIC correct a dead URL in the IP_MULTICAST help text fix the BAYCOM_SER_HDX help text fix SCSI_SCAN_ASYNC help text trivial documentation patch for platform.txt Fix typos concerning hierarchy Fix comment typo "spin_lock_irqrestore". Fix misspellings of "agressive". drivers/scsi/a100u2w.c: trivial typo patch Correct trivial typo in log2.h. Remove useless FIND_FIRST_BIT() macro from cardbus.c. ...
2007-02-17[PATCH] AUDIT_FD_PAIRAl Viro
Provide an audit record of the descriptor pair returned by pipe() and socketpair(). Rewritten from the original posted to linux-audit by John D. Ramsdell <ramsdell@mitre.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2007-02-17[PATCH] audit config lockdownSteve Grubb
The following patch adds a new mode to the audit system. It uses the audit_enabled config option to introduce the idea of audit enabled, but configuration is immutable. Any attempt to change the configuration while in this mode is audited. To change the audit rules, you'd need to reboot the machine. To use this option, you'd need a modified version of auditctl and use "-e 2". This is intended to go at the end of the audit.rules file for people that want an immutable configuration. This patch also adds "res=" to a number of configuration commands that did not have it before. Signed-off-by: Steve Grubb <sgrubb@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
