path: root/kernel
2013-05-19audit: Make testing for a valid loginuid explicit.Eric W. Biederman
commit 780a7654cee8d61819512385e778e4827db4bfbc upstream. audit rule additions containing "-F auid!=4294967295" were failing with EINVAL because of a regression caused by e1760bd. Apparently some userland audit rule sets want to know if loginuid uid has been set and are using a test for auid != 4294967295 to determine that. In practice that is a horrible way to ask if a value has been set, because it relies on subtle implementation details and will break every time the uid implementation in the kernel changes. So add a clean way to test if the audit loginuid has been set, and silently convert the old idiom to the cleaner and more comprehensible new idiom. RGB notes: In upstream, audit_rule_to_entry has been refactored out. This is patch is already upstream in functionally the same form in commit 780a7654cee8d61819512385e778e4827db4bfbc . The decimal constant was cast to unsigned to quiet GCC 4.6 32-bit architecture warnings. Reported-By: Steve Grubb <sgrubb@redhat.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Tested-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Eric Paris <eparis@redhat.com> Backported-by: Richard Guy Briggs <rgb@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19usermodehelper: check subprocess_info->path != NULLOleg Nesterov
commit 264b83c07a84223f0efd0d1db9ccc66d6f88288f upstream. argv_split(empty_or_all_spaces) happily succeeds, it simply returns argc == 0 and argv[0] == NULL. Change call_usermodehelper_exec() to check sub_info->path != NULL to avoid the crash. This is the minimal fix, todo: - perhaps we should change argv_split() to return NULL or change the callers. - kill or justify ->path[0] check - narrow the scope of helper_lock() Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-By: Lucas De Marchi <lucas.demarchi@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19tracing: Fix leaks of filter predsSteven Rostedt (Red Hat)
commit 60705c89460fdc7227f2d153b68b3f34814738a4 upstream. Special preds are created when folding a series of preds that can be done in serial. These are allocated in an ops field of the pred structure. But they were never freed, causing memory leaks. This was discovered using the kmemleak checker: unreferenced object 0xffff8800797fd5e0 (size 32): comm "swapper/0", pid 1, jiffies 4294690605 (age 104.608s) hex dump (first 32 bytes): 00 00 01 00 03 00 05 00 07 00 09 00 0b 00 0d 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ backtrace: [<ffffffff814b52af>] kmemleak_alloc+0x73/0x98 [<ffffffff8111ff84>] kmemleak_alloc_recursive.constprop.42+0x16/0x18 [<ffffffff81120e68>] __kmalloc+0xd7/0x125 [<ffffffff810d47eb>] kcalloc.constprop.24+0x2d/0x2f [<ffffffff810d4896>] fold_pred_tree_cb+0xa9/0xf4 [<ffffffff810d3781>] walk_pred_tree+0x47/0xcc [<ffffffff810d5030>] replace_preds.isra.20+0x6f8/0x72f [<ffffffff810d50b5>] create_filter+0x4e/0x8b [<ffffffff81b1c30d>] ftrace_test_event_filter+0x5a/0x155 [<ffffffff8100028d>] do_one_initcall+0xa0/0x137 [<ffffffff81afbedf>] kernel_init_freeable+0x14d/0x1dc [<ffffffff814b24b7>] kernel_init+0xe/0xdb [<ffffffff814d539c>] ret_from_fork+0x7c/0xb0 [<ffffffffffffffff>] 0xffffffffffffffff Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Cc: Tom Zanussi <tzanussi@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19tick: Cleanup NOHZ per cpu data on cpu downThomas Gleixner
commit 4b0c0f294f60abcdd20994a8341a95c8ac5eeb96 upstream. Prarit reported a crash on CPU offline/online. The reason is that on CPU down the NOHZ related per cpu data of the dead cpu is not cleaned up. If at cpu online an interrupt happens before the per cpu tick device is registered the irq_enter() check potentially sees stale data and dereferences a NULL pointer. Cleanup the data after the cpu is dead. Reported-by: Prarit Bhargava <prarit@redhat.com> Cc: Mike Galbraith <bitbucket@online.de> Link: http://lkml.kernel.org/r/alpine.LFD.2.02.1305031451561.2886@ionos Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19timer: Don't reinitialize the cpu base lock during CPU_UP_PREPARETirupathi Reddy
commit 42a5cf46cd56f46267d2a9fcf2655f4078cd3042 upstream. An inactive timer's base can refer to a offline cpu's base. In the current code, cpu_base's lock is blindly reinitialized each time a CPU is brought up. If a CPU is brought online during the period that another thread is trying to modify an inactive timer on that CPU with holding its timer base lock, then the lock will be reinitialized under its feet. This leads to following SPIN_BUG(). <0> BUG: spinlock already unlocked on CPU#3, kworker/u:3/1466 <0> lock: 0xe3ebe000, .magic: dead4ead, .owner: kworker/u:3/1466, .owner_cpu: 1 <4> [<c0013dc4>] (unwind_backtrace+0x0/0x11c) from [<c026e794>] (do_raw_spin_unlock+0x40/0xcc) <4> [<c026e794>] (do_raw_spin_unlock+0x40/0xcc) from [<c076c160>] (_raw_spin_unlock+0x8/0x30) <4> [<c076c160>] (_raw_spin_unlock+0x8/0x30) from [<c009b858>] (mod_timer+0x294/0x310) <4> [<c009b858>] (mod_timer+0x294/0x310) from [<c00a5e04>] (queue_delayed_work_on+0x104/0x120) <4> [<c00a5e04>] (queue_delayed_work_on+0x104/0x120) from [<c04eae00>] (sdhci_msm_bus_voting+0x88/0x9c) <4> [<c04eae00>] (sdhci_msm_bus_voting+0x88/0x9c) from [<c04d8780>] (sdhci_disable+0x40/0x48) <4> [<c04d8780>] (sdhci_disable+0x40/0x48) from [<c04bf300>] (mmc_release_host+0x4c/0xb0) <4> [<c04bf300>] (mmc_release_host+0x4c/0xb0) from [<c04c7aac>] (mmc_sd_detect+0x90/0xfc) <4> [<c04c7aac>] (mmc_sd_detect+0x90/0xfc) from [<c04c2504>] (mmc_rescan+0x7c/0x2c4) <4> [<c04c2504>] (mmc_rescan+0x7c/0x2c4) from [<c00a6a7c>] (process_one_work+0x27c/0x484) <4> [<c00a6a7c>] (process_one_work+0x27c/0x484) from [<c00a6e94>] (worker_thread+0x210/0x3b0) <4> [<c00a6e94>] (worker_thread+0x210/0x3b0) from [<c00aad9c>] (kthread+0x80/0x8c) <4> [<c00aad9c>] (kthread+0x80/0x8c) from [<c000ea80>] (kernel_thread_exit+0x0/0x8) As an example, this particular crash occurred when CPU #3 is executing mod_timer() on an inactive timer whose base is refered to offlined CPU #2. The code locked the timer_base corresponding to CPU #2. Before it could proceed, CPU #2 came online and reinitialized the spinlock corresponding to its base. Thus now CPU #3 held a lock which was reinitialized. When CPU #3 finally ended up unlocking the old cpu_base corresponding to CPU #2, we hit the above SPIN_BUG(). CPU #0 CPU #3 CPU #2 ------ ------- ------- ..... ...... <Offline> mod_timer() lock_timer_base spin_lock_irqsave(&base->lock) cpu_up(2) ..... ...... init_timers_cpu() .... ..... spin_lock_init(&base->lock) ..... spin_unlock_irqrestore(&base->lock) ...... <spin_bug> Allocation of per_cpu timer vector bases is done only once under "tvec_base_done[]" check. In the current code, spinlock_initialization of base->lock isn't under this check. When a CPU is up each time the base lock is reinitialized. Move base spinlock initialization under the check. Signed-off-by: Tirupathi Reddy <tirupath@codeaurora.org> Link: http://lkml.kernel.org/r/1368520142-4136-1-git-send-email-tirupath@codeaurora.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19time: Revert ALWAYS_USE_PERSISTENT_CLOCK compile time optimizaitonsJohn Stultz
commit b4f711ee03d28f776fd2324fd0bd999cc428e4d2 upstream. Kay Sievers noted that the ALWAYS_USE_PERSISTENT_CLOCK config, which enables some minor compile time optimization to avoid uncessary code in mostly the suspend/resume path could cause problems for userland. In particular, the dependency for RTC_HCTOSYS on !ALWAYS_USE_PERSISTENT_CLOCK, which avoids setting the time twice and simplifies suspend/resume, has the side effect of causing the /sys/class/rtc/rtcN/hctosys flag to always be zero, and this flag is commonly used by udev to setup the /dev/rtc symlink to /dev/rtcN, which can cause pain for older applications. While the udev rules could use some work to be less fragile, breaking userland should strongly be avoided. Additionally the compile time optimizations are fairly minor, and the code being optimized is likely to be reworked in the future, so lets revert this change. Reported-by: Kay Sievers <kay@vrfy.org> Signed-off-by: John Stultz <john.stultz@linaro.org> Cc: Feng Tang <feng.tang@intel.com> Cc: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Link: http://lkml.kernel.org/r/1366828376-18124-1-git-send-email-john.stultz@linaro.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19sched: Avoid prev->stime underflowStanislaw Gruszka
commit 68aa8efcd1ab961e4684ef5af32f72a6ec1911de upstream. Dave Hansen reported strange utime/stime values on his system: https://lkml.org/lkml/2013/4/4/435 This happens because prev->stime value is bigger than rtime value. Root of the problem are non-monotonic rtime values (i.e. current rtime is smaller than previous rtime) and that should be debugged and fixed. But since problem did not manifest itself before commit 62188451f0d63add7ad0cd2a1ae269d600c1663d "cputime: Avoid multiplication overflow on utime scaling", it should be threated as regression, which we can easily fixed on cputime_adjust() function. For now, let's apply this fix, but further work is needed to fix root of the problem. Reported-and-tested-by: Dave Hansen <dave@sr71.net> Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: rostedt@goodmis.org Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Dave Hansen <dave@sr71.net> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1367314507-9728-3-git-send-email-sgruszka@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19sched: Do not account bogus utimeStanislaw Gruszka
commit 772c808a252594692972773f6ee41c289b8e0b2a upstream. Due to rounding in scale_stime(), for big numbers, scaled stime values will grow in chunks. Since rtime grow in jiffies and we calculate utime like below: prev->stime = max(prev->stime, stime); prev->utime = max(prev->utime, rtime - prev->stime); we could erroneously account stime values as utime. To prevent that only update prev->{u,s}time values when they are smaller than current rtime. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: rostedt@goodmis.org Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Dave Hansen <dave@sr71.net> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1367314507-9728-2-git-send-email-sgruszka@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19sched: Avoid cputime scaling overflowStanislaw Gruszka
commit 55eaa7c1f511af5fb6ef808b5328804f4d4e5243 upstream. Here is patch, which adds Linus's cputime scaling algorithm to the kernel. This is a follow up (well, fix) to commit d9a3c9823a2e6a543eb7807fb3d15d8233817ec5 ("sched: Lower chances of cputime scaling overflow") which commit tried to avoid multiplication overflow, but did not guarantee that the overflow would not happen. Linus crated a different algorithm, which completely avoids the multiplication overflow by dropping precision when numbers are big. It was tested by me and it gives good relative error of scaled numbers. Testing method is described here: http://marc.info/?l=linux-kernel&m=136733059505406&w=2 Originally-From: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: rostedt@goodmis.org Cc: Dave Hansen <dave@sr71.net> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20130430151441.GC10465@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19sched: Lower chances of cputime scaling overflowFrederic Weisbecker
commit d9a3c9823a2e6a543eb7807fb3d15d8233817ec5 upstream. Some users have reported that after running a process with hundreds of threads on intensive CPU-bound loads, the cputime of the group started to freeze after a few days. This is due to how we scale the tick-based cputime against the scheduler precise execution time value. We add the values of all threads in the group and we multiply that against the sum of the scheduler exec runtime of the whole group. This easily overflows after a few days/weeks of execution. A proposed solution to solve this was to compute that multiplication on stime instead of utime: 62188451f0d63add7ad0cd2a1ae269d600c1663d ("cputime: Avoid multiplication overflow on utime scaling") The rationale behind that was that it's easy for a thread to spend most of its time in userspace under intensive CPU-bound workload but it's much harder to do CPU-bound intensive long run in the kernel. This postulate got defeated when a user recently reported he was still seeing cputime freezes after the above patch. The workload that triggers this issue relates to intensive networking workloads where most of the cputime is consumed in the kernel. To reduce much more the opportunities for multiplication overflow, lets reduce the multiplication factors to the remainders of the division between sched exec runtime and cputime. Assuming the difference between these shouldn't ever be that large, it could work on many situations. This gets the same results as in the upstream scaling code except for a small difference: the upstream code always rounds the results to the nearest integer not greater to what would be the precise result. The new code rounds to the nearest integer either greater or not greater. In practice this difference probably shouldn't matter but it's worth mentioning. If this solution appears not to be enough in the end, we'll need to partly revert back to the behaviour prior to commit 0cf55e1ec08bb5a22e068309e2d8ba1180ab4239 ("sched, cputime: Introduce thread_group_times()") Back then, the scaling was done on exit() time before adding the cputime of an exiting thread to the signal struct. And then we'll need to scale one-by-one the live threads cputime in thread_group_cputime(). The drawback may be a slightly slower code on exit time. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Stanislaw Gruszka <sgruszka@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Acked-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11kernel/audit_tree.c: tree will leak memory when failure occurs in ↵Chen Gang
audit_trim_trees() commit 12b2f117f3bf738c1a00a6f64393f1953a740bd4 upstream. audit_trim_trees() calls get_tree(). If a failure occurs we must call put_tree(). [akpm@linux-foundation.org: run put_tree() before mutex_lock() for small scalability improvement] Signed-off-by: Chen Gang <gang.chen@asianux.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Eric Paris <eparis@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11tracing: Fix ftrace_dump()Steven Rostedt (Red Hat)
commit 7fe70b579c9e3daba71635e31b6189394e7b79d3 upstream. ftrace_dump() had a lot of issues. What ftrace_dump() does, is when ftrace_dump_on_oops is set (via a kernel parameter or sysctl), it will dump out the ftrace buffers to the console when either a oops, panic, or a sysrq-z occurs. This was written a long time ago when ftrace was fragile to recursion. But it wasn't written well even for that. There's a possible deadlock that can occur if a ftrace_dump() is happening and an NMI triggers another dump. This is because it grabs a lock before checking if the dump ran. It also totally disables ftrace, and tracing for no good reasons. As the ring_buffer now checks if it is read via a oops or NMI, where there's a chance that the buffer gets corrupted, it will disable itself. No need to have ftrace_dump() do the same. ftrace_dump() is now cleaned up where it uses an atomic counter to make sure only one dump happens at a time. A simple atomic_inc_return() is enough that is needed for both other CPUs and NMIs. No need for a spinlock, as if one CPU is running the dump, no other CPU needs to do it too. The tracing_on variable is turned off and not turned on. The original code did this, but it wasn't pretty. By just disabling this variable we get the result of not seeing traces that happen between crashes. For sysrq-z, it doesn't get turned on, but the user can always write a '1' to the tracing_on file. If they are using sysrq-z, then they should know about tracing_on. The new code is much easier to read and less error prone. No more deadlock possibility when an NMI triggers here. Reported-by: zhangwei(Jovi) <jovi.zhangwei@huawei.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-11MODSIGN: do not send garbage to stderr when enabling modules signatureDavid Cohen
commit 07c449bbc6aa514098c4f12c7b04180cec2417c6 upstream. When compiling kernel with -jN (N > 1), all warning/error messages printed while openssl is generating key pair may get mixed dots and other symbols openssl sends to stderr. This patch makes sure openssl logs go to default stdout. Example of the garbage on stderr: crypto/anubis.c:581: warning: ‘inter’ is used uninitialized in this function Generating a 4096 bit RSA private key ......... drivers/gpu/drm/i915/i915_gem_gtt.c: In function ‘gen6_ggtt_insert_entries’: drivers/gpu/drm/i915/i915_gem_gtt.c:440: warning: ‘addr’ may be used uninitialized in this function .net/mac80211/tx.c: In function ‘ieee80211_subif_start_xmit’: net/mac80211/tx.c:1780: warning: ‘chanctx_conf’ may be used uninitialized in this function ..drivers/isdn/hardware/mISDN/hfcpci.c: In function ‘hfcpci_softirq’: .....drivers/isdn/hardware/mISDN/hfcpci.c:2298: warning: ignoring return value of ‘driver_for_each_device’, declared with attribute warn_unused_result Signed-off-by: David Cohen <david.a.cohen@intel.com> Reviewed-by: mark gross <mark.gross@intel.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-07rcutrace: single_open() leaksAl Viro
commit 7ee2b9e56495c56dcaffa2bab19b39451d9fdc8a upstream. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-07clockevents: Set dummy handler on CPU_DEAD shutdownThomas Gleixner
commit 6f7a05d7018de222e40ca003721037a530979974 upstream. Vitaliy reported that a per cpu HPET timer interrupt crashes the system during hibernation. What happens is that the per cpu HPET timer gets shut down when the nonboot cpus are stopped. When the nonboot cpus are onlined again the HPET code sets up the MSI interrupt which fires before the clock event device is registered. The event handler is still set to hrtimer_interrupt, which then crashes the machine due to highres mode not being active. See http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=700333 There is no real good way to avoid that in the HPET code. The HPET code alrady has a mechanism to detect spurious interrupts when event handler == NULL for a similar reason. We can handle that in the clockevent/tick layer and replace the previous functional handler with a dummy handler like we do in tick_setup_new_device(). The original clockevents code did this in clockevents_exchange_device(), but that got removed by commit 7c1e76897 (clockevents: prevent clockevent event_handler ending up handler_noop) which forgot to fix it up in tick_shutdown(). Same issue with the broadcast device. Reported-by: Vitaliy Fillipov <vitalif@yourcmc.ru> Cc: Ben Hutchings <ben@decadent.org.uk> Cc: 700333@bugs.debian.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-07cgroup: fix broken file xattrsLi Zefan
commit 712317ad97f41e738e1a19aa0a6392a78a84094e upstream. We should store file xattrs in struct cfent instead of struct cftype, because cftype is a type while cfent is object instance of cftype. For example each cgroup has a tasks file, and each tasks file is associated with a uniq cfent, but all those files share the same struct cftype. Alexey Kodanev reported a crash, which can be reproduced: # mount -t cgroup -o xattr /sys/fs/cgroup # mkdir /sys/fs/cgroup/test # setfattr -n trusted.value -v test_value /sys/fs/cgroup/tasks # rmdir /sys/fs/cgroup/test # umount /sys/fs/cgroup oops! In this case, simple_xattrs_free() will free the same struct simple_xattrs twice. tj: Dropped unused local variable @cft from cgroup_diput(). Reported-by: Alexey Kodanev <alexey.kodanev@oracle.com> Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-07cgroup: fix an off-by-one bug which may trigger BUG_ON()Li Zefan
commit 3ac1707a13a3da9cfc8f242a15b2fae6df2c5f88 upstream. The 3rd parameter of flex_array_prealloc() is the number of elements, not the index of the last element. The effect of the bug is, when opening cgroup.procs, a flex array will be allocated and all elements of the array is allocated with GFP_KERNEL flag, but the last one is GFP_ATOMIC, and if we fail to allocate memory for it, it'll trigger a BUG_ON(). Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-07hrtimer: Add expiry time overflow check in hrtimer_interruptPrarit Bhargava
commit 8f294b5a139ee4b75e890ad5b443c93d1e558a8b upstream. The settimeofday01 test in the LTP testsuite effectively does gettimeofday(current time); settimeofday(Jan 1, 1970 + 100 seconds); settimeofday(current time); This test causes a stack trace to be displayed on the console during the setting of timeofday to Jan 1, 1970 + 100 seconds: [ 131.066751] ------------[ cut here ]------------ [ 131.096448] WARNING: at kernel/time/clockevents.c:209 clockevents_program_event+0x135/0x140() [ 131.104935] Hardware name: Dinar [ 131.108150] Modules linked in: sg nfsv3 nfs_acl nfsv4 auth_rpcgss nfs dns_resolver fscache lockd sunrpc nf_conntrack_netbios_ns nf_conntrack_broadcast ipt_MASQUERADE ip6table_mangle ip6t_REJECT nf_conntrack_ipv6 nf_defrag_ipv6 iptable_nat nf_nat_ipv4 nf_nat iptable_mangle ipt_REJECT nf_conntrack_ipv4 nf_defrag_ipv4 xt_conntrack nf_conntrack ebtable_filter ebtables ip6table_filter ip6_tables iptable_filter ip_tables kvm_amd kvm sp5100_tco bnx2 i2c_piix4 crc32c_intel k10temp fam15h_power ghash_clmulni_intel amd64_edac_mod pcspkr serio_raw edac_mce_amd edac_core microcode xfs libcrc32c sr_mod sd_mod cdrom ata_generic crc_t10dif pata_acpi radeon i2c_algo_bit drm_kms_helper ttm drm ahci pata_atiixp libahci libata usb_storage i2c_core dm_mirror dm_region_hash dm_log dm_mod [ 131.176784] Pid: 0, comm: swapper/28 Not tainted 3.8.0+ #6 [ 131.182248] Call Trace: [ 131.184684] <IRQ> [<ffffffff810612af>] warn_slowpath_common+0x7f/0xc0 [ 131.191312] [<ffffffff8106130a>] warn_slowpath_null+0x1a/0x20 [ 131.197131] [<ffffffff810b9fd5>] clockevents_program_event+0x135/0x140 [ 131.203721] [<ffffffff810bb584>] tick_program_event+0x24/0x30 [ 131.209534] [<ffffffff81089ab1>] hrtimer_interrupt+0x131/0x230 [ 131.215437] [<ffffffff814b9600>] ? cpufreq_p4_target+0x130/0x130 [ 131.221509] [<ffffffff81619119>] smp_apic_timer_interrupt+0x69/0x99 [ 131.227839] [<ffffffff8161805d>] apic_timer_interrupt+0x6d/0x80 [ 131.233816] <EOI> [<ffffffff81099745>] ? sched_clock_cpu+0xc5/0x120 [ 131.240267] [<ffffffff814b9ff0>] ? cpuidle_wrap_enter+0x50/0xa0 [ 131.246252] [<ffffffff814b9fe9>] ? cpuidle_wrap_enter+0x49/0xa0 [ 131.252238] [<ffffffff814ba050>] cpuidle_enter_tk+0x10/0x20 [ 131.257877] [<ffffffff814b9c89>] cpuidle_idle_call+0xa9/0x260 [ 131.263692] [<ffffffff8101c42f>] cpu_idle+0xaf/0x120 [ 131.268727] [<ffffffff815f8971>] start_secondary+0x255/0x257 [ 131.274449] ---[ end trace 1151a50552231615 ]--- When we change the system time to a low value like this, the value of timekeeper->offs_real will be a negative value. It seems that the WARN occurs because an hrtimer has been started in the time between the releasing of the timekeeper lock and the IPI call (via a call to on_each_cpu) in clock_was_set() in the do_settimeofday() code. The end result is that a REALTIME_CLOCK timer has been added with softexpires = expires = KTIME_MAX. The hrtimer_interrupt() fires/is called and the loop at kernel/hrtimer.c:1289 is executed. In this loop the code subtracts the clock base's offset (which was set to timekeeper->offs_real in do_settimeofday()) from the current hrtimer_cpu_base->expiry value (which was KTIME_MAX): KTIME_MAX - (a negative value) = overflow A simple check for an overflow can resolve this problem. Using KTIME_MAX instead of the overflow value will result in the hrtimer function being run, and the reprogramming of the timer after that. Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Prarit Bhargava <prarit@redhat.com> [jstultz: Tweaked commit subject] Signed-off-by: John Stultz <john.stultz@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-07hrtimer: Fix ktime_add_ns() overflow on 32bit architecturesDavid Engraf
commit 51fd36f3fad8447c487137ae26b9d0b3ce77bb25 upstream. One can trigger an overflow when using ktime_add_ns() on a 32bit architecture not supporting CONFIG_KTIME_SCALAR. When passing a very high value for u64 nsec, e.g. 7881299347898368000 the do_div() function converts this value to seconds (7881299347) which is still to high to pass to the ktime_set() function as long. The result in is a negative value. The problem on my system occurs in the tick-sched.c, tick_nohz_stop_sched_tick() when time_delta is set to timekeeping_max_deferment(). The check for time_delta < KTIME_MAX is valid, thus ktime_add_ns() is called with a too large value resulting in a negative expire value. This leads to an endless loop in the ticker code: time_delta: 7881299347898368000 expires = ktime_add_ns(last_update, time_delta) expires: negative value This fix caps the value to KTIME_MAX. This error doesn't occurs on 64bit or architectures supporting CONFIG_KTIME_SCALAR (e.g. ARM, x86-32). Signed-off-by: David Engraf <david.engraf@sysgo.com> [jstultz: Minor tweaks to commit message & header] Signed-off-by: John Stultz <john.stultz@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-07tracing: Reset ftrace_graph_filter_enabled if count is zeroNamhyung Kim
commit 9f50afccfdc15d95d7331acddcb0f7703df089ae upstream. The ftrace_graph_count can be decreased with a "!" pattern, so that the enabled flag should be updated too. Link: http://lkml.kernel.org/r/1365663698-2413-1-git-send-email-namhyung@kernel.org Signed-off-by: Namhyung Kim <namhyung@kernel.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung.kim@lge.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-07tracing: Check return value of tracing_init_dentry()Namhyung Kim
commit ed6f1c996bfe4b6e520cf7a74b51cd6988d84420 upstream. Check return value and bail out if it's NULL. Link: http://lkml.kernel.org/r/1365553093-10180-2-git-send-email-namhyung@kernel.org Signed-off-by: Namhyung Kim <namhyung@kernel.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-07tracing: Fix off-by-one on allocating stat->pagesNamhyung Kim
commit 39e30cd1537937d3c00ef87e865324e981434e5b upstream. The first page was allocated separately, so no need to start from 0. Link: http://lkml.kernel.org/r/1364820385-32027-2-git-send-email-namhyung@kernel.org Signed-off-by: Namhyung Kim <namhyung@kernel.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-07tracing: Remove most or all of stack tracer stack size from stack_max_sizeSteven Rostedt (Red Hat)
commit 4df297129f622bdc18935c856f42b9ddd18f9f28 upstream. Currently, the depth reported in the stack tracer stack_trace file does not match the stack_max_size file. This is because the stack_max_size includes the overhead of stack tracer itself while the depth does not. The first time a max is triggered, a calculation is not performed that figures out the overhead of the stack tracer and subtracts it from the stack_max_size variable. The overhead is stored and is subtracted from the reported stack size for comparing for a new max. Now the stack_max_size corresponds to the reported depth: # cat stack_max_size 4640 # cat stack_trace Depth Size Location (48 entries) ----- ---- -------- 0) 4640 32 _raw_spin_lock+0x18/0x24 1) 4608 112 ____cache_alloc+0xb7/0x22d 2) 4496 80 kmem_cache_alloc+0x63/0x12f 3) 4416 16 mempool_alloc_slab+0x15/0x17 [...] While testing against and older gcc on x86 that uses mcount instead of fentry, I found that pasing in ip + MCOUNT_INSN_SIZE let the stack trace show one more function deep which was missing before. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-07tracing: Fix stack tracer with fentry useSteven Rostedt (Red Hat)
commit d4ecbfc49b4b1d4b597fb5ba9e4fa25d62f105c5 upstream. When gcc 4.6 on x86 is used, the function tracer will use the new option -mfentry which does a call to "fentry" at every function instead of "mcount". The significance of this is that fentry is called as the first operation of the function instead of the mcount usage of being called after the stack. This causes the stack tracer to show some bogus results for the size of the last function traced, as well as showing "ftrace_call" instead of the function. This is due to the stack frame not being set up by the function that is about to be traced. # cat stack_trace Depth Size Location (48 entries) ----- ---- -------- 0) 4824 216 ftrace_call+0x5/0x2f 1) 4608 112 ____cache_alloc+0xb7/0x22d 2) 4496 80 kmem_cache_alloc+0x63/0x12f The 216 size for ftrace_call includes both the ftrace_call stack (which includes the saving of registers it does), as well as the stack size of the parent. To fix this, if CC_USING_FENTRY is defined, then the stack_tracer will reserve the first item in stack_dump_trace[] array when calling save_stack_trace(), and it will fill it in with the parent ip. Then the code will look for the parent pointer on the stack and give the real size of the parent's stack pointer: # cat stack_trace Depth Size Location (14 entries) ----- ---- -------- 0) 2640 48 update_group_power+0x26/0x187 1) 2592 224 update_sd_lb_stats+0x2a5/0x4ac 2) 2368 160 find_busiest_group+0x31/0x1f1 3) 2208 256 load_balance+0xd9/0x662 I'm Cc'ing stable, although it's not urgent, as it only shows bogus size for item #0, the rest of the trace is legit. It should still be corrected in previous stable releases. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-07tracing: Use stack of calling function for stack tracerSteven Rostedt (Red Hat)
commit 87889501d0adfae10e3b0f0e6f2d7536eed9ae84 upstream. Use the stack of stack_trace_call() instead of check_stack() as the test pointer for max stack size. It makes it a bit cleaner and a little more accurate. Adding stable, as a later fix depends on this patch. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-27Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fix from Ingo Molnar: "This fix adds missing RCU read protection" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: events: Protect access via task_subsys_state_check()
2013-04-22kernel/hz.bc: ignore.Rusty Russell
Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-21Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "Misc fixes" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf/x86: Fix offcore_rsp valid mask for SNB/IVB perf: Treat attr.config as u64 in perf_swevent_init()
2013-04-21events: Protect access via task_subsys_state_check()Paul E. McKenney
The following RCU splat indicates lack of RCU protection: [ 953.267649] =============================== [ 953.267652] [ INFO: suspicious RCU usage. ] [ 953.267657] 3.9.0-0.rc6.git2.4.fc19.ppc64p7 #1 Not tainted [ 953.267661] ------------------------------- [ 953.267664] include/linux/cgroup.h:534 suspicious rcu_dereference_check() usage! [ 953.267669] [ 953.267669] other info that might help us debug this: [ 953.267669] [ 953.267675] [ 953.267675] rcu_scheduler_active = 1, debug_locks = 0 [ 953.267680] 1 lock held by glxgears/1289: [ 953.267683] #0: (&sig->cred_guard_mutex){+.+.+.}, at: [<c00000000027f884>] .prepare_bprm_creds+0x34/0xa0 [ 953.267700] [ 953.267700] stack backtrace: [ 953.267704] Call Trace: [ 953.267709] [c0000001f0d1b6e0] [c000000000016e30] .show_stack+0x130/0x200 (unreliable) [ 953.267717] [c0000001f0d1b7b0] [c0000000001267f8] .lockdep_rcu_suspicious+0x138/0x180 [ 953.267724] [c0000001f0d1b840] [c0000000001d43a4] .perf_event_comm+0x4c4/0x690 [ 953.267731] [c0000001f0d1b950] [c00000000027f6e4] .set_task_comm+0x84/0x1f0 [ 953.267737] [c0000001f0d1b9f0] [c000000000280414] .setup_new_exec+0x94/0x220 [ 953.267744] [c0000001f0d1ba70] [c0000000002f665c] .load_elf_binary+0x58c/0x19b0 ... This commit therefore adds the required RCU read-side critical section to perf_event_comm(). Reported-by: Adam Jackson <ajax@redhat.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: a.p.zijlstra@chello.nl Cc: paulus@samba.org Cc: acme@ghostprotocols.net Link: http://lkml.kernel.org/r/20130419190124.GA8638@linux.vnet.ibm.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Tested-by: Gustavo Luiz Duarte <gusld@br.ibm.com>
2013-04-20Merge branch 'x86-kdump-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull kdump fixes from Peter Anvin: "The kexec/kdump people have found several problems with the support for loading over 4 GiB that was introduced in this merge cycle. This is partly due to a number of design problems inherent in the way the various pieces of kdump fit together (it is pretty horrifically manual in many places.) After a *lot* of iterations this is the patchset that was agreed upon, but of course it is now very late in the cycle. However, because it changes both the syntax and semantics of the crashkernel option, it would be desirable to avoid a stable release with the broken interfaces." I'm not happy with the timing, since originally the plan was to release the final 3.9 tomorrow. But apparently I'm doing an -rc8 instead... * 'x86-kdump-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: kexec: use Crash kernel for Crash kernel low x86, kdump: Change crashkernel_high/low= to crashkernel=,high/low x86, kdump: Retore crashkernel= to allocate under 896M x86, kdump: Set crashkernel_low automatically
2013-04-18Merge branch 'userns-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/luto/linux Pull user-namespace fixes from Andy Lutomirski. * 'userns-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/luto/linux: userns: Changing any namespace id mappings should require privileges userns: Check uid_map's opener's fsuid, not the current fsuid userns: Don't let unprivileged users trick privileged users into setting the id_map
2013-04-18Revert "block: add missing block_bio_complete() tracepoint"Linus Torvalds
This reverts commit 3a366e614d0837d9fc23f78cdb1a1186ebc3387f. Wanlong Gao reports that it causes a kernel panic on his machine several minutes after boot. Reverting it removes the panic. Jens says: "It's not quite clear why that is yet, so I think we should just revert the commit for 3.9 final (which I'm assuming is pretty close). The wifi is crap at the LSF hotel, so sending this email instead of queueing up a revert and pull request." Reported-by: Wanlong Gao <gaowanlong@cn.fujitsu.com> Requested-by: Jens Axboe <axboe@kernel.dk> Cc: Tejun Heo <tj@kernel.org> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-18kprobes: Fix a double lock bug of kprobe_mutexMasami Hiramatsu
Fix a double locking bug caused when debug.kprobe-optimization=0. While the proc_kprobes_optimization_handler locks kprobe_mutex, wait_for_kprobe_optimizer locks it again and that causes a double lock. To fix the bug, this introduces different mutex for protecting sysctl parameter and locks it in proc_kprobes_optimization_handler. Of course, since we need to lock kprobe_mutex when touching kprobes resources, that is done in *optimize_all_kprobes(). This bug was introduced by commit ad72b3bea744 ("kprobes: fix wait_for_kprobe_optimizer()") Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Tejun Heo <tj@kernel.org> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-17kernel/signal.c: stop info leak via the tkill and the tgkill syscallsEmese Revfy
This fixes a kernel memory contents leak via the tkill and tgkill syscalls for compat processes. This is visible in the siginfo_t->_sifields._rt.si_sigval.sival_ptr field when handling signals delivered from tkill. The place of the infoleak: int copy_siginfo_to_user32(compat_siginfo_t __user *to, siginfo_t *from) { ... put_user_ex(ptr_to_compat(from->si_ptr), &to->si_ptr); ... } Signed-off-by: Emese Revfy <re.emese@gmail.com> Reviewed-by: PaX Team <pageexec@freemail.hu> Signed-off-by: Kees Cook <keescook@chromium.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Oleg Nesterov <oleg@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Serge Hallyn <serge.hallyn@canonical.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-17kexec: use Crash kernel for Crash kernel lowYinghai Lu
We can extend kexec-tools to support multiple "Crash kernel" in /proc/iomem instead. So we can use "Crash kernel" instead of "Crash kernel low" in /proc/iomem. Suggested-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Link: http://lkml.kernel.org/r/1366089828-19692-3-git-send-email-yinghai@kernel.org Acked-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2013-04-17x86, kdump: Change crashkernel_high/low= to crashkernel=,high/lowYinghai Lu
Per hpa, use crashkernel=X,high crashkernel=Y,low instead of crashkernel_hign=X crashkernel_low=Y. As that could be extensible. -v2: according to Vivek, change delimiter to ; -v3: let hign and low only handle simple form and it conforms to description in kernel-parameters.txt still keep crashkernel=X override any crashkernel=X,high crashkernel=Y,low -v4: update get_last_crashkernel returning and add more strict checking in parse_crashkernel_simple() found by HATAYAMA. -v5: Change delimiter back to , according to HPA. also separate parse_suffix from parse_simper according to vivek. so we can avoid @pos in that path. -v6: Tight the checking about crashkernel=X,highblahblah,high found by HTYAYAMA. Cc: HATAYAMA Daisuke <d.hatayama@jp.fujitsu.com> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Link: http://lkml.kernel.org/r/1366089828-19692-5-git-send-email-yinghai@kernel.org Acked-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2013-04-17x86, kdump: Retore crashkernel= to allocate under 896MYinghai Lu
Vivek found old kexec-tools does not work new kernel anymore. So change back crashkernel= back to old behavoir, and add crashkernel_high= to let user decide if buffer could be above 4G, and also new kexec-tools will be needed. -v2: let crashkernel=X override crashkernel_high= update description about _high will be ignored by crashkernel=X -v3: update description about kernel-parameters.txt according to Vivek. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Link: http://lkml.kernel.org/r/1366089828-19692-4-git-send-email-yinghai@kernel.org Acked-by: Vivek Goyal <vgoyal@redhat.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2013-04-15Merge branches 'timers-urgent-for-linus', 'irq-urgent-for-linus' and ↵Linus Torvalds
'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull {timer,irq,core} fixes from Thomas Gleixner: - timer: bug fix for a cpu hotplug race. - irq: single bugfix for a wrong return value, which prevents the calling function to invoke the software fallback. - core: bugfix which plugs two race confitions which can cause hotplug per cpu threads to end up on the wrong cpu. * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: hrtimer: Don't reinitialize a cpu_base lock on CPU_UP * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: irqchip: gic: fix irq_trigger return * 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: kthread: Prevent unpark race which puts threads on the wrong cpu
2013-04-15perf: Treat attr.config as u64 in perf_swevent_init()Tommi Rantala
Trinity discovered that we fail to check all 64 bits of attr.config passed by user space, resulting to out-of-bounds access of the perf_swevent_enabled array in sw_perf_event_destroy(). Introduced in commit b0a873ebb ("perf: Register PMU implementations"). Signed-off-by: Tommi Rantala <tt.rantala@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: davej@redhat.com Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Link: http://lkml.kernel.org/r/1365882554-30259-1-git-send-email-tt.rantala@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-04-14userns: Changing any namespace id mappings should require privilegesAndy Lutomirski
Changing uid/gid/projid mappings doesn't change your id within the namespace; it reconfigures the namespace. Unprivileged programs should *not* be able to write these files. (We're also checking the privileges on the wrong task.) Given the write-once nature of these files and the other security checks, this is likely impossible to usefully exploit. Signed-off-by: Andy Lutomirski <luto@amacapital.net>
2013-04-14userns: Check uid_map's opener's fsuid, not the current fsuidAndy Lutomirski
2013-04-14userns: Don't let unprivileged users trick privileged users into setting the ↵Eric W. Biederman
id_map When we require privilege for setting /proc/<pid>/uid_map or /proc/<pid>/gid_map no longer allow an unprivileged user to open the file and pass it to a privileged program to write to the file. Instead when privilege is required require both the opener and the writer to have the necessary capabilities. I have tested this code and verified that setting /proc/<pid>/uid_map fails when an unprivileged user opens the file and a privielged user attempts to set the mapping, that unprivileged users can still map their own id, and that a privileged users can still setup an arbitrary mapping. Reported-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andy Lutomirski <luto@amacapital.net>
2013-04-14Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fixes from Ingo Molnar: "Misc fixlets" * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched/cputime: Fix accounting on multi-threaded processes sched/debug: Fix sd->*_idx limit range avoiding overflow sched_clock: Prevent 64bit inatomicity on 32bit systems sched: Convert BUG_ON()s in try_to_wake_up_local() to WARN_ON_ONCE()s
2013-04-14Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "Misc fixlets" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf: Fix error return code ftrace: Fix strncpy() use, use strlcpy() instead of strncpy() perf: Fix strncpy() use, use strlcpy() instead of strncpy() perf: Fix strncpy() use, always make sure it's NUL terminated perf: Fix ring_buffer perf_output_space() boundary calculation perf/x86: Fix uninitialized pt_regs in intel_pmu_drain_bts_buffer()
2013-04-14Merge tag 'trace-fixes-v3.9-rc-v3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull ftrace fixes from Steven Rostedt: "Namhyung Kim found and fixed a bug that can crash the kernel by simply doing: echo 1234 | tee -a /sys/kernel/debug/tracing/set_ftrace_pid Luckily, this can only be done by root, but still is a nasty bug." * tag 'trace-fixes-v3.9-rc-v3' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: ftrace: Move ftrace_filter_lseek out of CONFIG_DYNAMIC_FTRACE section tracing: Fix possible NULL pointer dereferences
2013-04-14Add file_ns_capable() helper function for open-time capability checkingLinus Torvalds
Nothing is using it yet, but this will allow us to delay the open-time checks to use time, without breaking the normal UNIX permission semantics where permissions are determined by the opener (and the file descriptor can then be passed to a different process, or the process can drop capabilities). Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-12ftrace: Move ftrace_filter_lseek out of CONFIG_DYNAMIC_FTRACE sectionSteven Rostedt (Red Hat)
As ftrace_filter_lseek is now used with ftrace_pid_fops, it needs to be moved out of the #ifdef CONFIG_DYNAMIC_FTRACE section as the ftrace_pid_fops is defined when DYNAMIC_FTRACE is not. Cc: stable@vger.kernel.org Cc: Namhyung Kim <namhyung@kernel.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2013-04-12tracing: Fix possible NULL pointer dereferencesNamhyung Kim
Currently set_ftrace_pid and set_graph_function files use seq_lseek for their fops. However seq_open() is called only for FMODE_READ in the fops->open() so that if an user tries to seek one of those file when she open it for writing, it sees NULL seq_file and then panic. It can be easily reproduced with following command: $ cd /sys/kernel/debug/tracing $ echo 1234 | sudo tee -a set_ftrace_pid In this example, GNU coreutils' tee opens the file with fopen(, "a") and then the fopen() internally calls lseek(). Link: http://lkml.kernel.org/r/1365663302-2170-1-git-send-email-namhyung@kernel.org Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: stable@vger.kernel.org Signed-off-by: Namhyung Kim <namhyung@kernel.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2013-04-12kthread: Prevent unpark race which puts threads on the wrong cpuThomas Gleixner
The smpboot threads rely on the park/unpark mechanism which binds per cpu threads on a particular core. Though the functionality is racy: CPU0 CPU1 CPU2 unpark(T) wake_up_process(T) clear(SHOULD_PARK) T runs leave parkme() due to !SHOULD_PARK bind_to(CPU2) BUG_ON(wrong CPU) We cannot let the tasks move themself to the target CPU as one of those tasks is actually the migration thread itself, which requires that it starts running on the target cpu right away. The solution to this problem is to prevent wakeups in park mode which are not from unpark(). That way we can guarantee that the association of the task to the target cpu is working correctly. Add a new task state (TASK_PARKED) which prevents other wakeups and use this state explicitly for the unpark wakeup. Peter noticed: Also, since the task state is visible to userspace and all the parked tasks are still in the PID space, its a good hint in ps and friends that these tasks aren't really there for the moment. The migration thread has another related issue. CPU0 CPU1 Bring up CPU2 create_thread(T) park(T) wait_for_completion() parkme() complete() sched_set_stop_task() schedule(TASK_PARKED) The sched_set_stop_task() call is issued while the task is on the runqueue of CPU1 and that confuses the hell out of the stop_task class on that cpu. So we need the same synchronizaion before sched_set_stop_task(). Reported-by: Dave Jones <davej@redhat.com> Reported-and-tested-by: Dave Hansen <dave@sr71.net> Reported-and-tested-by: Borislav Petkov <bp@alien8.de> Acked-by: Peter Ziljstra <peterz@infradead.org> Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: dhillf@gmail.com Cc: Ingo Molnar <mingo@kernel.org> Cc: stable@vger.kernel.org Link: http://lkml.kernel.org/r/alpine.LFD.2.02.1304091635430.21884@ionos Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-04-12perf: Fix error return codeWei Yongjun
Fix to return -ENOMEM in the allocation error case instead of 0 (if pmu_bus_running == 1), as done elsewhere in this function. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Cc: a.p.zijlstra@chello.nl Cc: paulus@samba.org Cc: acme@ghostprotocols.net Link: http://lkml.kernel.org/r/CAPgLHd8j_fWcgqe%3DKLWjpBj%2B%3Do0Pw6Z-SEq%3DNTPU08c2w1tngQ@mail.gmail.com [ Tweaked the error code setting placement and the changelog. ] Signed-off-by: Ingo Molnar <mingo@kernel.org>
