path: root/kernel
2015-12-06Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fixes from Thomas Gleixner: "This updates contains the following changes: - Fix a signal handling regression in the bit wait functions. - Avoid false positive warnings in the wakeup path. - Initialize the scheduler root domain properly. - Handle gtime calculations in proc/$PID/stat proper. - Add more documentation for the barriers in try_to_wake_up(). - Fix a subtle race in try_to_wake_up() which might cause a task to be scheduled on two cpus - Compile static helper function only when it is used" * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched/core: Fix an SMP ordering race in try_to_wake_up() vs. schedule() sched/core: Better document the try_to_wake_up() barriers sched/cputime: Fix invalid gtime in proc sched/core: Clear the root_domain cpumasks in init_rootdomain() sched/core: Remove false-positive warning from wake_up_process() sched/wait: Fix signal handling in bit wait helpers sched/rt: Hide the push_irq_work_func() declaration
2015-12-04sched/core: Fix an SMP ordering race in try_to_wake_up() vs. schedule()Peter Zijlstra
Oleg noticed that its possible to falsely observe p->on_cpu == 0 such that we'll prematurely continue with the wakeup and effectively run p on two CPUs at the same time. Even though the overlap is very limited; the task is in the middle of being scheduled out; it could still result in corruption of the scheduler data structures. CPU0 CPU1 set_current_state(...) <preempt_schedule> context_switch(X, Y) prepare_lock_switch(Y) Y->on_cpu = 1; finish_lock_switch(X) store_release(X->on_cpu, 0); try_to_wake_up(X) LOCK(p->pi_lock); t = X->on_cpu; // 0 context_switch(Y, X) prepare_lock_switch(X) X->on_cpu = 1; finish_lock_switch(Y) store_release(Y->on_cpu, 0); </preempt_schedule> schedule(); deactivate_task(X); X->on_rq = 0; if (X->on_rq) // false if (t) while (X->on_cpu) cpu_relax(); context_switch(X, ..) finish_lock_switch(X) store_release(X->on_cpu, 0); Avoid the load of X->on_cpu being hoisted over the X->on_rq load. Reported-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-12-04sched/core: Better document the try_to_wake_up() barriersPeter Zijlstra
Explain how the control dependency and smp_rmb() end up providing ACQUIRE semantics and pair with smp_store_release() in finish_lock_switch(). Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-12-04sched/cputime: Fix invalid gtime in procHiroshi Shimamoto
/proc/stats shows invalid gtime when the thread is running in guest. When vtime accounting is not enabled, we cannot get a valid delta. The delta is calculated with now - tsk->vtime_snap, but tsk->vtime_snap is only updated when vtime accounting is runtime enabled. This patch makes task_gtime() just return gtime without computing the buggy non-existing tickless delta when vtime accounting is not enabled. Use context_tracking_is_enabled() to check if vtime is accounting on some cpu, in which case only we need to check the tickless delta. This way we fix the gtime value regression on machines not running nohz full. The kernel config contains CONFIG_VIRT_CPU_ACCOUNTING_GEN=y and CONFIG_NO_HZ_FULL_ALL=n and boot without nohz_full. I ran and stop a busy loop in VM and see the gtime in host. Dump the 43rd field which shows the gtime in every second: # while :; do awk '{print $3" "$43}' /proc/3955/task/4014/stat; sleep 1; done S 4348 R 7064566 R 7064766 R 7064967 R 7065168 S 4759 S 4759 During running busy loop, it returns large value. After applying this patch, we can see right gtime. # while :; do awk '{print $3" "$43}' /proc/10913/task/10956/stat; sleep 1; done S 5338 R 5365 R 5465 R 5566 R 5666 S 5726 S 5726 Signed-off-by: Hiroshi Shimamoto <h-shimamoto@ct.jp.nec.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: Christoph Lameter <cl@linux.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Luiz Capitulino <lcapitulino@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul E . McKenney <paulmck@linux.vnet.ibm.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1447948054-28668-2-git-send-email-fweisbec@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-12-04sched/core: Clear the root_domain cpumasks in init_rootdomain()Xunlei Pang
root_domain::rto_mask allocated through alloc_cpumask_var() contains garbage data, this may cause problems. For instance, When doing pull_rt_task(), it may do useless iterations if rto_mask retains some extra garbage bits. Worse still, this violates the isolated domain rule for clustered scheduling using cpuset, because the tasks(with all the cpus allowed) belongs to one root domain can be pulled away into another root domain. The patch cleans the garbage by using zalloc_cpumask_var() instead of alloc_cpumask_var() for root_domain::rto_mask allocation, thereby addressing the issues. Do the same thing for root_domain's other cpumask memembers: dlo_mask, span, and online. Signed-off-by: Xunlei Pang <xlpang@redhat.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: <stable@vger.kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1449057179-29321-1-git-send-email-xlpang@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-12-04sched/core: Remove false-positive warning from wake_up_process()Sasha Levin
Because wakeups can (fundamentally) be late, a task might not be in the expected state. Therefore testing against a task's state is racy, and can yield false positives. Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: oleg@redhat.com Fixes: 9067ac85d533 ("wake_up_process() should be never used to wakeup a TASK_STOPPED/TRACED task") Link: http://lkml.kernel.org/r/1448933660-23082-1-git-send-email-sasha.levin@oracle.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-12-04sched/wait: Fix signal handling in bit wait helpersPeter Zijlstra
Vladimir reported getting RCU stall warnings and bisected it back to commit: 743162013d40 ("sched: Remove proliferation of wait_on_bit() action functions") That commit inadvertently reversed the calls to schedule() and signal_pending(), thereby not handling the case where the signal receives while we sleep. Reported-by: Vladimir Murzin <vladimir.murzin@arm.com> Tested-by: Vladimir Murzin <vladimir.murzin@arm.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: mark.rutland@arm.com Cc: neilb@suse.de Cc: oleg@redhat.com Fixes: 743162013d40 ("sched: Remove proliferation of wait_on_bit() action functions") Fixes: cbbce8220949 ("SCHED: add some "wait..on_bit...timeout()" interfaces.") Link: http://lkml.kernel.org/r/20151201130404.GL3816@twins.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-12-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "A lot of Thanksgiving turkey leftovers accumulated, here goes: 1) Fix bluetooth l2cap_chan object leak, from Johan Hedberg. 2) IDs for some new iwlwifi chips, from Oren Givon. 3) Fix rtlwifi lockups on boot, from Larry Finger. 4) Fix memory leak in fm10k, from Stephen Hemminger. 5) We have a route leak in the ipv6 tunnel infrastructure, fix from Paolo Abeni. 6) Fix buffer pointer handling in arm64 bpf JIT,f rom Zi Shen Lim. 7) Wrong lockdep annotations in tcp md5 support, fix from Eric Dumazet. 8) Work around some middle boxes which prevent proper handling of TCP Fast Open, from Yuchung Cheng. 9) TCP repair can do huge kmalloc() requests, build paged SKBs instead. From Eric Dumazet. 10) Fix msg_controllen overflow in scm_detach_fds, from Daniel Borkmann. 11) Fix device leaks on ipmr table destruction in ipv4 and ipv6, from Nikolay Aleksandrov. 12) Fix use after free in epoll with AF_UNIX sockets, from Rainer Weikusat. 13) Fix double free in VRF code, from Nikolay Aleksandrov. 14) Fix skb leaks on socket receive queue in tipc, from Ying Xue. 15) Fix ifup/ifdown crach in xgene driver, from Iyappan Subramanian. 16) Fix clearing of persistent array maps in bpf, from Daniel Borkmann. 17) In TCP, for the cross-SYN case, we don't initialize tp->copied_seq early enough. From Eric Dumazet. 18) Fix out of bounds accesses in bpf array implementation when updating elements, from Daniel Borkmann. 19) Fill gaps in RCU protection of np->opt in ipv6 stack, from Eric Dumazet. 20) When dumping proxy neigh entries, we have to accomodate NULL device pointers properly, from Konstantin Khlebnikov. 21) SCTP doesn't release all ipv6 socket resources properly, fix from Eric Dumazet. 22) Prevent underflows of sch->q.qlen for multiqueue packet schedulers, also from Eric Dumazet. 23) Fix MAC and unicast list handling in bnxt_en driver, from Jeffrey Huang and Michael Chan. 24) Don't actively scan radar channels, from Antonio Quartulli" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (110 commits) net: phy: reset only targeted phy bnxt_en: Setup uc_list mac filters after resetting the chip. bnxt_en: enforce proper storing of MAC address bnxt_en: Fixed incorrect implementation of ndo_set_mac_address net: lpc_eth: remove irq > NR_IRQS check from probe() net_sched: fix qdisc_tree_decrease_qlen() races openvswitch: fix hangup on vxlan/gre/geneve device deletion ipv4: igmp: Allow removing groups from a removed interface ipv6: sctp: implement sctp_v6_destroy_sock() arm64: bpf: add 'store immediate' instruction ipv6: kill sk_dst_lock ipv6: sctp: add rcu protection around np->opt net/neighbour: fix crash at dumping device-agnostic proxy entries sctp: use GFP_USER for user-controlled kmalloc sctp: convert sack_needed and sack_generation to bits ipv6: add complete rcu protection around np->opt bpf: fix allocation warnings in bpf maps and integer overflow mvebu: dts: enable IP checksum with jumbo frames for Armada 38x on Port0 net: mvneta: enable setting custom TX IP checksum limit net: mvneta: fix error path for building skb ...
2015-12-03Merge tag 'trace-v4.4-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull tracing fix from Steven Rostedt: "During the merge window I added a new file that is used to filter trace events on pids. It filters all events where only tasks with their pid in that file exists. It also handles the sched_switch and sched_wakeup trace events where the current task does not have its pid in the file, but the task either being switched to or awaken does. Unfortunately, I forgot about sched_wakeup_new and sched_waking. Both of these tracepoints use the same class as the sched_wakeup tracepoint, and they too should be included in what gets filtered by the set_event_pid file" * tag 'trace-v4.4-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: tracing: Add sched_wakeup_new and sched_waking tracepoints for pid filter
2015-12-02bpf: fix allocation warnings in bpf maps and integer overflowAlexei Starovoitov
For large map->value_size the user space can trigger memory allocation warnings like: WARNING: CPU: 2 PID: 11122 at mm/page_alloc.c:2989 __alloc_pages_nodemask+0x695/0x14e0() Call Trace: [< inline >] __dump_stack lib/dump_stack.c:15 [<ffffffff82743b56>] dump_stack+0x68/0x92 lib/dump_stack.c:50 [<ffffffff81244ec9>] warn_slowpath_common+0xd9/0x140 kernel/panic.c:460 [<ffffffff812450f9>] warn_slowpath_null+0x29/0x30 kernel/panic.c:493 [< inline >] __alloc_pages_slowpath mm/page_alloc.c:2989 [<ffffffff81554e95>] __alloc_pages_nodemask+0x695/0x14e0 mm/page_alloc.c:3235 [<ffffffff816188fe>] alloc_pages_current+0xee/0x340 mm/mempolicy.c:2055 [< inline >] alloc_pages include/linux/gfp.h:451 [<ffffffff81550706>] alloc_kmem_pages+0x16/0xf0 mm/page_alloc.c:3414 [<ffffffff815a1c89>] kmalloc_order+0x19/0x60 mm/slab_common.c:1007 [<ffffffff815a1cef>] kmalloc_order_trace+0x1f/0xa0 mm/slab_common.c:1018 [< inline >] kmalloc_large include/linux/slab.h:390 [<ffffffff81627784>] __kmalloc+0x234/0x250 mm/slub.c:3525 [< inline >] kmalloc include/linux/slab.h:463 [< inline >] map_update_elem kernel/bpf/syscall.c:288 [< inline >] SYSC_bpf kernel/bpf/syscall.c:744 To avoid never succeeding kmalloc with order >= MAX_ORDER check that elem->value_size and computed elem_size are within limits for both hash and array type maps. Also add __GFP_NOWARN to kmalloc(value_size | elem_size) to avoid OOM warnings. Note kmalloc(key_size) is highly unlikely to trigger OOM, since key_size <= 512, so keep those kmalloc-s as-is. Large value_size can cause integer overflows in elem_size and map.pages formulas, so check for that as well. Fixes: aaac3ba95e4c ("bpf: charge user for creation of BPF maps and programs") Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-12-01bpf, array: fix heap out-of-bounds access when updating elementsDaniel Borkmann
During own review but also reported by Dmitry's syzkaller [1] it has been noticed that we trigger a heap out-of-bounds access on eBPF array maps when updating elements. This happens with each map whose map->value_size (specified during map creation time) is not multiple of 8 bytes. In array_map_alloc(), elem_size is round_up(attr->value_size, 8) and used to align array map slots for faster access. However, in function array_map_update_elem(), we update the element as ... memcpy(array->value + array->elem_size * index, value, array->elem_size); ... where we access 'value' out-of-bounds, since it was allocated from map_update_elem() from syscall side as kmalloc(map->value_size, GFP_USER) and later on copied through copy_from_user(value, uvalue, map->value_size). Thus, up to 7 bytes, we can access out-of-bounds. Same could happen from within an eBPF program, where in worst case we access beyond an eBPF program's designated stack. Since 1be7f75d1668 ("bpf: enable non-root eBPF programs") didn't hit an official release yet, it only affects priviledged users. In case of array_map_lookup_elem(), the verifier prevents eBPF programs from accessing beyond map->value_size through check_map_access(). Also from syscall side map_lookup_elem() only copies map->value_size back to user, so nothing could leak. [1] http://github.com/google/syzkaller Fixes: 28fbcfa08d8e ("bpf: add array type of eBPF maps") Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-12-01tracing: Add sched_wakeup_new and sched_waking tracepoints for pid filterSteven Rostedt (Red Hat)
The set_event_pid filter relies on attaching to the sched_switch and sched_wakeup tracepoints to see if it should filter the tracing on schedule tracepoints. By adding the callbacks to sched_wakeup, pids in the set_event_pid file will trace the wakeups of those tasks with those pids. But sched_wakeup_new and sched_waking were missed. These two should also be traced. Luckily, these tracepoints share the same class as sched_wakeup which means they can use the same pre and post callbacks as sched_wakeup does. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-11-30Merge tag 'trace-v4.4-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull tracing fixes from Steven Rostedt: "I found two minor bugs while doing development on the ring buffer code. The first is something that's been there since its creation. If a reader reads a page out of the ring buffer before there's any events on it, it can get an out of date timestamp for that event. It may be off by a few microseconds, more if the first event gets discarded. The fix was to only update the reader time stamp when it actually sees an event on the page, instead of just reading the timestamp from the page even if it has no events on it. That timestamp is still volatile until an event is present. The second bug is more recent. Instead of passing around parameters a descriptor was made and the parameters are passed via a single descriptor. This simplified the code a bit. But there was one place that expected the parameter to be passed by value not reference (which a descriptor now does). And it added to the length of the event, which may be ignored later, but the length should not have been increased. The only real problem with this bug is that it may allocate more than was needed for the event" * tag 'trace-v4.4-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: ring-buffer: Put back the length if crossed page with add_timestamp ring-buffer: Update read stamp with first real commit on page
2015-11-25bpf: fix clearing on persistent program array mapsDaniel Borkmann
Currently, when having map file descriptors pointing to program arrays, there's still the issue that we unconditionally flush program array contents via bpf_fd_array_map_clear() in bpf_map_release(). This happens when such a file descriptor is released and is independent of the map's refcount. Having this flush independent of the refcount is for a reason: there can be arbitrary complex dependency chains among tail calls, also circular ones (direct or indirect, nesting limit determined during runtime), and we need to make sure that the map drops all references to eBPF programs it holds, so that the map's refcount can eventually drop to zero and initiate its freeing. Btw, a walk of the whole dependency graph would not be possible for various reasons, one being complexity and another one inconsistency, i.e. new programs can be added to parts of the graph at any time, so there's no guaranteed consistent state for the time of such a walk. Now, the program array pinning itself works, but the issue is that each derived file descriptor on close would nevertheless call unconditionally into bpf_fd_array_map_clear(). Instead, keep track of users and postpone this flush until the last reference to a user is dropped. As this only concerns a subset of references (f.e. a prog array could hold a program that itself has reference on the prog array holding it, etc), we need to track them separately. Short analysis on the refcounting: on map creation time usercnt will be one, so there's no change in behaviour for bpf_map_release(), if unpinned. If we already fail in map_create(), we are immediately freed, and no file descriptor has been made public yet. In bpf_obj_pin_user(), we need to probe for a possible map in bpf_fd_probe_obj() already with a usercnt reference, so before we drop the reference on the fd with fdput(). Therefore, if actual pinning fails, we need to drop that reference again in bpf_any_put(), otherwise we keep holding it. When last reference drops on the inode, the bpf_any_put() in bpf_evict_inode() will take care of dropping the usercnt again. In the bpf_obj_get_user() case, the bpf_any_get() will grab a reference on the usercnt, still at a time when we have the reference on the path. Should we later on fail to grab a new file descriptor, bpf_any_put() will drop it, otherwise we hold it until bpf_map_release() time. Joint work with Alexei. Fixes: b2197755b263 ("bpf: add support for persistent maps/progs") Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-24pidns: fix NULL dereference in __task_pid_nr_ns()Eric Dumazet
I got a crash during a "perf top" session that was caused by a race in __task_pid_nr_ns() : pid_nr_ns() was inlined, but apparently compiler chose to read task->pids[type].pid twice, and the pid->level dereference crashed because we got a NULL pointer at the second read : if (pid && ns->level <= pid->level) { // CRASH Just use RCU API properly to solve this race, and not worry about "perf top" crashing hosts :( get_task_pid() can benefit from same fix. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-24ring-buffer: Put back the length if crossed page with add_timestampSteven Rostedt (Red Hat)
Commit fcc742eaad7c "ring-buffer: Add event descriptor to simplify passing data" added a descriptor that holds various data instead of passing around several variables through parameters. The problem was that one of the parameters was modified in a function and the code was designed not to have an effect on that modified parameter. Now that the parameter is a descriptor and any modifications to it are non-volatile, the size of the data could be unnecessarily expanded. Remove the extra space added if a timestamp was added and the event went across the page. Cc: stable@vger.kernel.org # 4.3+ Fixes: fcc742eaad7c "ring-buffer: Add event descriptor to simplify passing data" Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-11-24ring-buffer: Update read stamp with first real commit on pageSteven Rostedt (Red Hat)
Do not update the read stamp after swapping out the reader page from the write buffer. If the reader page is swapped out of the buffer before an event is written to it, then the read_stamp may get an out of date timestamp, as the page timestamp is updated on the first commit to that page. rb_get_reader_page() only returns a page if it has an event on it, otherwise it will return NULL. At that point, check if the page being returned has events and has not been read yet. Then at that point update the read_stamp to match the time stamp of the reader page. Cc: stable@vger.kernel.org # 2.6.30+ Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-11-23sched/rt: Hide the push_irq_work_func() declarationArnd Bergmann
The push_irq_work_func() function is conditionally defined only when both CONFIG_SMP and HAVE_RT_PUSH_IPI are defined, but the forward declaration remains visibile without HAVE_RT_PUSH_IPI, causing a gcc warning in ARM64 allnoconfig: kernel/sched/rt.c:68:13: warning: 'push_irq_work_func' declared 'static' but never defined [-Wunused-function] This changes the code to use the same condition for both the declaration and the function definition, which gets rid of the warning. As Peter Zijlstra, we can possibly get rid of the whole HAVE_RT_PUSH_IPI thing after: 8053871d0f7f ("smp: Fix smp_call_function_single_async() locking") Until that is done, this patch can be used to avoid the warning. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Fixes: b6366f048e0c ("sched/rt: Use IPI to trigger RT task push migration instead of pulling") Link: http://lkml.kernel.org/r/3828565.oKfGk7yNIT@wuerfel Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-11-20kernel/panic.c: turn off locks debug before releasing console lockVitaly Kuznetsov
Commit 08d78658f393 ("panic: release stale console lock to always get the logbuf printed out") introduced an unwanted bad unlock balance report when panic() is called directly and not from OOPS (e.g. from out_of_memory()). The difference is that in case of OOPS we disable locks debug in oops_enter() and on direct panic call nobody does that. Fixes: 08d78658f393 ("panic: release stale console lock to always get the logbuf printed out") Reported-by: kernel test robot <ying.huang@linux.intel.com> Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com> Cc: HATAYAMA Daisuke <d.hatayama@jp.fujitsu.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Baoquan He <bhe@redhat.com> Cc: Prarit Bhargava <prarit@redhat.com> Cc: Xie XiuQi <xiexiuqi@huawei.com> Cc: Seth Jennings <sjenning@redhat.com> Cc: "K. Y. Srinivasan" <kys@microsoft.com> Cc: Jan Kara <jack@suse.cz> Cc: Petr Mladek <pmladek@suse.cz> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-20kernel/signal.c: unexport sigsuspend()Richard Weinberger
sigsuspend() is nowhere used except in signal.c itself, so we can mark it static do not pollute the global namespace. But this patch is more than a boring cleanup patch, it fixes a real issue on UserModeLinux. UML has a special console driver to display ttys using xterm, or other terminal emulators, on the host side. Vegard reported that sometimes UML is unable to spawn a xterm and he's facing the following warning: WARNING: CPU: 0 PID: 908 at include/linux/thread_info.h:128 sigsuspend+0xab/0xc0() It turned out that this warning makes absolutely no sense as the UML xterm code calls sigsuspend() on the host side, at least it tries. But as the kernel itself offers a sigsuspend() symbol the linker choose this one instead of the glibc wrapper. Interestingly this code used to work since ever but always blocked signals on the wrong side. Some recent kernel change made the WARN_ON() trigger and uncovered the bug. It is a wonderful example of how much works by chance on computers. :-) Fixes: 68f3f16d9ad0f1 ("new helper: sigsuspend()") Signed-off-by: Richard Weinberger <richard@nod.at> Reported-by: Vegard Nossum <vegard.nossum@oracle.com> Tested-by: Vegard Nossum <vegard.nossum@oracle.com> Acked-by: Oleg Nesterov <oleg@redhat.com> Cc: <stable@vger.kernel.org> [3.5+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/livepatching Pull livepatching fix from Jiri Kosina: "A fix for module handling in case kASLR has been enabled, from Zhou Chengming" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/livepatching: livepatch: x86: fix relocation computation with kASLR
2015-11-15Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf updates from Thomas Gleixner: "Mostly updates to the perf tool plus two fixes to the kernel core code: - Handle tracepoint filters correctly for inherited events (Peter Zijlstra) - Prevent a deadlock in perf_lock_task_context (Paul McKenney) - Add missing newlines to some pr_err() calls (Arnaldo Carvalho de Melo) - Print full source file paths when using 'perf annotate --print-line --full-paths' (Michael Petlan) - Fix 'perf probe -d' when just one out of uprobes and kprobes is enabled (Wang Nan) - Add compiler.h to list.h to fix 'make perf-tar-src-pkg' generated tarballs, i.e. out of tree building (Arnaldo Carvalho de Melo) - Add the llvm-src-base.c and llvm-src-kbuild.c files, generated by the 'perf test' LLVM entries, when running it in-tree, to .gitignore (Yunlong Song) - libbpf error reporting improvements, using a strerror interface to more precisely tell the user about problems with the provided scriptlet, be it in C or as a ready made object file (Wang Nan) - Do not be case sensitive when searching for matching 'perf test' entries (Arnaldo Carvalho de Melo) - Inform the user about objdump failures in 'perf annotate' (Andi Kleen) - Improve the LLVM 'perf test' entry, introduce a new ones for BPF and kbuild tests to check the environment used by clang to compile .c scriptlets (Wang Nan)" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (32 commits) perf/x86/intel/rapl: Remove the unused RAPL_EVENT_DESC() macro tools include: Add compiler.h to list.h perf probe: Verify parameters in two functions perf session: Add missing newlines to some pr_err() calls perf annotate: Support full source file paths for srcline fix perf test: Add llvm-src-base.c and llvm-src-kbuild.c to .gitignore perf: Fix inherited events vs. tracepoint filters perf: Disable IRQs across RCU RS CS that acquires scheduler lock perf test: Do not be case sensitive when searching for matching tests perf test: Add 'perf test BPF' perf test: Enhance the LLVM tests: add kbuild test perf test: Enhance the LLVM test: update basic BPF test program perf bpf: Improve BPF related error messages perf tools: Make fetch_kernel_version() publicly available bpf tools: Add new API bpf_object__get_kversion() bpf tools: Improve libbpf error reporting perf probe: Cleanup find_perf_probe_point_from_map to reduce redundancy perf annotate: Inform the user about objdump failures in --stdio perf stat: Make stat options global perf sched latency: Fix thread pid reuse issue ...
2015-11-15Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fix from Thomas Gleixner: "A single fix to prevent math underflow in the numa balancing code" * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched/numa: Fix math underflow in task_tick_numa()
2015-11-15Merge branches 'irq-urgent-for-linus' and 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq and timer fixes from Thomas Gleixner: - An irq regression fix to restore the wakeup behaviour of chained interrupts. - A timer fix for a long standing race versus timers scheduled on a target cpu which got exposed by recent changes in the workqueue implementation. * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: genirq/PM: Restore system wake up from chained interrupts * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: timers: Use proper base migration in add_timer_on()
2015-11-12Merge tag 'trace-v4.4-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull trace cleanups from Steven Rostedt: "This contains three more clean up patches. One patch is needed to make tracing work without debugfs now that tracing uses its own tracefs. The second is removing an unused variable. The third is fixing a warning about unused variables when MAX_TRACER is not configured. Note, this warning shows up in gcc 6.0, but does not show up in gcc 4.9, as it seems that gcc does not complain about constants not being used" * tag 'trace-v4.4-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: tracing: #ifdef out uses of max trace when CONFIG_TRACER_MAX_TRACE is not set tracing: Remove unused ftrace_cpu_disabled per cpu variable tracing: Make tracing work when debugfs is not configured in
2015-11-12Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull second batch of kvm updates from Paolo Bonzini: "Four changes: - x86: work around two nasty cases where a benign exception occurs while another is being delivered. The endless stream of exceptions causes an infinite loop in the processor, which not even NMIs or SMIs can interrupt; in the virt case, there is no possibility to exit to the host either. - x86: support for Skylake per-guest TSC rate. Long supported by AMD, the patches mostly move things from there to common arch/x86/kvm/ code. - generic: remove local_irq_save/restore from the guest entry and exit paths when context tracking is enabled. The patches are a few months old, but we discussed them again at kernel summit. Andy will pick up from here and, in 4.5, try to remove it from the user entry/exit paths. - PPC: Two bug fixes, see merge commit 370289756becc for details" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (21 commits) KVM: x86: rename update_db_bp_intercept to update_bp_intercept KVM: svm: unconditionally intercept #DB KVM: x86: work around infinite loop in microcode when #AC is delivered context_tracking: avoid irq_save/irq_restore on guest entry and exit context_tracking: remove duplicate enabled check KVM: VMX: Dump TSC multiplier in dump_vmcs() KVM: VMX: Use a scaled host TSC for guest readings of MSR_IA32_TSC KVM: VMX: Setup TSC scaling ratio when a vcpu is loaded KVM: VMX: Enable and initialize VMX TSC scaling KVM: x86: Use the correct vcpu's TSC rate to compute time scale KVM: x86: Move TSC scaling logic out of call-back read_l1_tsc() KVM: x86: Move TSC scaling logic out of call-back adjust_tsc_offset() KVM: x86: Replace call-back compute_tsc_offset() with a common function KVM: x86: Replace call-back set_tsc_khz() with a common function KVM: x86: Add a common TSC scaling function KVM: x86: Add a common TSC scaling ratio field in kvm_vcpu_arch KVM: x86: Collect information for setting TSC scaling ratio KVM: x86: declare a few variables as __read_mostly KVM: x86: merge handle_mmio_page_fault and handle_mmio_page_fault_common KVM: PPC: Book3S HV: Don't dynamically split core when already split ...
2015-11-11livepatch: x86: fix relocation computation with kASLRZhou Chengming
With kASLR enabled, old_addr provided by patch module is being shifted accrodingly so that the symbol lookups work. To have module relocations handled properly as well, the same transformation needs to be perfomed on relocation address information. [jkosina@suse.cz: extended / reworded changelog a bit] Reported-by: Cyril B. <cbay@alwaysdata.com> Signed-off-by: Zhou Chengming <zhouchengming1@huawei.com> Acked-by: Josh Poimboeuf <jpoimboe@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2015-11-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Fix null deref in xt_TEE netfilter module, from Eric Dumazet. 2) Several spots need to get to the original listner for SYN-ACK packets, most spots got this ok but some were not. Whilst covering the remaining cases, create a helper to do this. From Eric Dumazet. 3) Missiing check of return value from alloc_netdev() in CAIF SPI code, from Rasmus Villemoes. 4) Don't sleep while != TASK_RUNNING in macvtap, from Vlad Yasevich. 5) Use after free in mvneta driver, from Justin Maggard. 6) Fix race on dst->flags access in dst_release(), from Eric Dumazet. 7) Add missing ZLIB_INFLATE dependency for new qed driver. From Arnd Bergmann. 8) Fix multicast getsockopt deadlock, from WANG Cong. 9) Fix deadlock in btusb, from Kuba Pawlak. 10) Some ipv6_add_dev() failure paths were not cleaning up the SNMP6 counter state. From Sabrina Dubroca. 11) Fix packet_bind() race, which can cause lost notifications, from Francesco Ruggeri. 12) Fix MAC restoration in qlcnic driver during bonding mode changes, from Jarod Wilson. 13) Revert bridging forward delay change which broke libvirt and other userspace things, from Vlad Yasevich. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (65 commits) Revert "bridge: Allow forward delay to be cfgd when STP enabled" bpf_trace: Make dependent on PERF_EVENTS qed: select ZLIB_INFLATE net: fix a race in dst_release() net: mvneta: Fix memory use after free. net: Documentation: Fix default value tcp_limit_output_bytes macvtap: Resolve possible __might_sleep warning in macvtap_do_read() mvneta: add FIXED_PHY dependency net: caif: check return value of alloc_netdev net: hisilicon: NET_VENDOR_HISILICON should depend on HAS_DMA drivers: net: xgene: fix RGMII 10/100Mb mode netfilter: nft_meta: use skb_to_full_sk() helper net_sched: em_meta: use skb_to_full_sk() helper sched: cls_flow: use skb_to_full_sk() helper netfilter: xt_owner: use skb_to_full_sk() helper smack: use skb_to_full_sk() helper net: add skb_to_full_sk() helper and use it in selinux_netlbl_skbuff_setsid() bpf: doc: correct arch list for supported eBPF JIT dwc_eth_qos: Delete an unnecessary check before the function call "of_node_put" bonding: fix panic on non-ARPHRD_ETHER enslave failure ...
2015-11-10bpf_trace: Make dependent on PERF_EVENTSSteven Rostedt
Arnd Bergmann reported: In my ARM randconfig tests, I'm getting a build error for newly added code in bpf_perf_event_read and bpf_perf_event_output whenever CONFIG_PERF_EVENTS is disabled: kernel/trace/bpf_trace.c: In function 'bpf_perf_event_read': kernel/trace/bpf_trace.c:203:11: error: 'struct perf_event' has no member named 'oncpu' if (event->oncpu != smp_processor_id() || ^ kernel/trace/bpf_trace.c:204:11: error: 'struct perf_event' has no member named 'pmu' event->pmu->count) This can happen when UPROBE_EVENT is enabled but KPROBE_EVENT is disabled. I'm not sure if that is a configuration we care about, otherwise we could prevent this case from occuring by adding Kconfig dependencies. Looking at this further, it's really that UPROBE_EVENT enables PERF_EVENTS. By just having BPF_EVENTS depend on PERF_EVENTS, then all is fine. Link: http://lkml.kernel.org/r/4525348.Aq9YoXkChv@wuerfel Reported-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-10Merge tag 'libnvdimm-for-4.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm Pull libnvdimm updates from Dan Williams: "Outside of the new ACPI-NFIT hot-add support this pull request is more notable for what it does not contain, than what it does. There were a handful of development topics this cycle, dax get_user_pages, dax fsync, and raw block dax, that need more more iteration and will wait for 4.5. The patches to make devm and the pmem driver NUMA aware have been in -next for several weeks. The hot-add support has not, but is contained to the NFIT driver and is passing unit tests. The coredump support is straightforward and was looked over by Jeff. All of it has received a 0day build success notification across 107 configs. Summary: - Add support for the ACPI 6.0 NFIT hot add mechanism to process updates of the NFIT at runtime. - Teach the coredump implementation how to filter out DAX mappings. - Introduce NUMA hints for allocations made by the pmem driver, and as a side effect all devm allocations now hint their NUMA node by default" * tag 'libnvdimm-for-4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm: coredump: add DAX filtering for FDPIC ELF coredumps coredump: add DAX filtering for ELF coredumps acpi: nfit: Add support for hot-add nfit: in acpi_nfit_init, break on a 0-length table pmem, memremap: convert to numa aware allocations devm_memremap_pages: use numa_mem_id devm: make allocations numa aware by default devm_memremap: convert to return ERR_PTR devm_memunmap: use devres_release() pmem: kill memremap_pmem() x86, mm: quiet arch_add_memory()
2015-11-10tracing: #ifdef out uses of max trace when CONFIG_TRACER_MAX_TRACE is not setChen Gang
tracing_max_lat_fops is used only when TRACER_MAX_TRACE enabled, so also swith the related code. The related warning with defconfig under x86_64: CC kernel/trace/trace.o kernel/trace/trace.c:5466:37: warning: ‘tracing_max_lat_fops’ defined but not used [-Wunused-const-variable] static const struct file_operations tracing_max_lat_fops = { Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-11-10genirq/PM: Restore system wake up from chained interruptsGrygorii Strashko
Commit e509bd7da149 ("genirq: Allow migration of chained interrupts by installing default action") breaks PCS wake up IRQ behaviour on TI OMAP based platforms (dra7-evm). TI OMAP IRQ wake up configuration: GIC-irqchip->PCM_IRQ |- omap_prcm_register_chain_handler |- PRCM-irqchip -> PRCM_IO_IRQ |- pcs_irq_chain_handler |- pinctrl-irqchip -> PCS_uart1_wakeup_irq This happens because IRQ PM code (irq/pm.c) is expected to ignore chained interrupts by default: static bool suspend_device_irq(struct irq_desc *desc) { if (!desc->action || desc->no_suspend_depth) return false; - it's expected !desc->action = true for chained interrupts; but, after above change, all chained interrupt descriptors will have default action handler installed - chained_action. As result, chained interrupts will be silently disabled during system suspend. Hence, fix it by introducing helper function irq_desc_is_chained() and use it in suspend_device_irq() for chained interrupts identification and skip them, once detected. Fixes: e509bd7da149 ("genirq: Allow migration of chained interrupts..") Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com> Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com> Cc: Tony Lindgren <tony@atomide.com> Cc: <nsekhar@ti.com> Cc: <linux-arm-kernel@lists.infradead.org> Cc: Tony Lindgren <tony@atomide.com> Link: http://lkml.kernel.org/r/1447149492-20699-1-git-send-email-grygorii.strashko@ti.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-11-10context_tracking: avoid irq_save/irq_restore on guest entry and exitPaolo Bonzini
guest_enter and guest_exit must be called with interrupts disabled, since they take the vtime_seqlock with write_seq{lock,unlock}. Therefore, it is not necessary to check for exceptions, nor to save/restore the IRQ state, when context tracking functions are called by guest_enter and guest_exit. Split the body of context_tracking_entry and context_tracking_exit out to __-prefixed functions, and use them from KVM. Rik van Riel has measured this to speed up a tight vmentry/vmexit loop by about 2%. Cc: Andy Lutomirski <luto@kernel.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Rik van Riel <riel@redhat.com> Tested-by: Rik van Riel <riel@redhat.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2015-11-10context_tracking: remove duplicate enabled checkPaolo Bonzini
All calls to context_tracking_enter and context_tracking_exit are already checking context_tracking_is_enabled, except the context_tracking_user_enter and context_tracking_user_exit functions left in for the benefit of assembly calls. Pull the check up to those functions, by making them simple wrappers around the user_enter and user_exit inline functions. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Rik van Riel <riel@redhat.com> Tested-by: Rik van Riel <riel@redhat.com> Acked-by: Andy Lutomirski <luto@kernel.org> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2015-11-09Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge third patch-bomb from Andrew Morton: "We're pretty much done over here - I'm still waiting for a nouveau merge so I can cleanly finish up Christoph's dma-mapping rework. - bunch of small misc stuff - fold abs64() into abs(), remove abs64() - new_valid_dev() cleanups - binfmt_elf_fdpic feature work" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (24 commits) fs/binfmt_elf_fdpic.c: provide NOMMU loader for regular ELF binaries fs/stat.c: remove unnecessary new_valid_dev() check fs/reiserfs/namei.c: remove unnecessary new_valid_dev() check fs/nilfs2/namei.c: remove unnecessary new_valid_dev() check fs/ncpfs/dir.c: remove unnecessary new_valid_dev() check fs/jfs: remove unnecessary new_valid_dev() checks fs/hpfs/namei.c: remove unnecessary new_valid_dev() check fs/f2fs/namei.c: remove unnecessary new_valid_dev() check fs/ext2/namei.c: remove unnecessary new_valid_dev() check fs/exofs/namei.c: remove unnecessary new_valid_dev() check fs/btrfs/inode.c: remove unnecessary new_valid_dev() check fs/9p: remove unnecessary new_valid_dev() checks include/linux/kdev_t.h: old/new_valid_dev() can return bool include/linux/kdev_t.h: remove unused huge_valid_dev() kmap_atomic_to_page() has no users, remove it drivers/scsi/cxgbi: fix build with EXTRA_CFLAGS dma: remove external references to dma_supported Documentation/sysctl/vm.txt: fix misleading code reference of overcommit_memory remove abs64() kernel.h: make abs() work with 64-bit types ...
2015-11-09Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module updates from Rusty Russell: "Nothing exciting, minor tweaks and cleanups" * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: scripts: [modpost] add new sections to white list modpost: Add flag -E for making section mismatches fatal params: don't ignore the rest of cmdline if parse_one() fails modpost: abort if a module symbol is too long
2015-11-09remove abs64()Andrew Morton
Switch everything to the new and more capable implementation of abs(). Mainly to give the new abs() a bit of a workout. Cc: Michal Nazarewicz <mina86@mina86.com> Cc: John Stultz <john.stultz@linaro.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-09Merge branch 'for-4.4/hotplug' into libnvdimm-for-nextDan Williams
2015-11-09sched/numa: Fix math underflow in task_tick_numa()Rik van Riel
The NUMA balancing code implements delays in scanning by advancing curr->node_stamp beyond curr->se.sum_exec_runtime. With unsigned math, that creates an underflow, which results in task_numa_work being queued all the time, even when we don't want to. Avoiding the math underflow makes it possible to reduce CPU overhead in the NUMA balancing code. Reported-and-tested-by: Jan Stancek <jstancek@redhat.com> Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: mgorman@suse.de Link: http://lkml.kernel.org/r/1446756983-28173-2-git-send-email-riel@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-11-09perf: Fix inherited events vs. tracepoint filtersPeter Zijlstra
Arnaldo reported that tracepoint filters seem to misbehave (ie. not apply) on inherited events. The fix is obvious; filters are only set on the actual (parent) event, use the normal pattern of using this parent event for filters. This is safe because each child event has a reference to it. Reported-by: Arnaldo Carvalho de Melo <acme@kernel.org> Tested-by: Arnaldo Carvalho de Melo <acme@kernel.org> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Wang Nan <wangnan0@huawei.com> Cc: stable@vger.kernel.org Link: http://lkml.kernel.org/r/20151102095051.GN17308@twins.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-11-09perf: Disable IRQs across RCU RS CS that acquires scheduler lockPaul E. McKenney
The perf_lock_task_context() function disables preemption across its RCU read-side critical section because that critical section acquires a scheduler lock. If there was a preemption during that RCU read-side critical section, the rcu_read_unlock() could attempt to acquire scheduler locks, resulting in deadlock. However, recent optimizations to expedited grace periods mean that IPI handlers that execute during preemptible RCU read-side critical sections can now cause the subsequent rcu_read_unlock() to acquire scheduler locks. Disabling preemption does nothiing to prevent these IPI handlers from executing, so these optimizations introduced a deadlock. In theory, this deadlock could be avoided by pulling all wakeups and printk()s out from rnp->lock critical sections, but in practice this would re-introduce some RCU CPU stall warning bugs. Given that acquiring scheduler locks entails disabling interrupts, these deadlocks can be avoided by disabling interrupts (instead of disabling preemption) across any RCU read-side critical that acquires scheduler locks and holds them across the rcu_read_unlock(). This commit therefore makes this change for perf_lock_task_context(). Reported-by: Dave Jones <davej@codemonkey.org.uk> Reported-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Stephane Eranian <eranian@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20151104134838.GR29027@linux.vnet.ibm.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-11-07Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge second patch-bomb from Andrew Morton: - most of the rest of MM - procfs - lib/ updates - printk updates - bitops infrastructure tweaks - checkpatch updates - nilfs2 update - signals - various other misc bits: coredump, seqfile, kexec, pidns, zlib, ipc, dma-debug, dma-mapping, ... * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (102 commits) ipc,msg: drop dst nil validation in copy_msg include/linux/zutil.h: fix usage example of zlib_adler32() panic: release stale console lock to always get the logbuf printed out dma-debug: check nents in dma_sync_sg* dma-mapping: tidy up dma_parms default handling pidns: fix set/getpriority and ioprio_set/get in PRIO_USER mode kexec: use file name as the output message prefix fs, seqfile: always allow oom killer seq_file: reuse string_escape_str() fs/seq_file: use seq_* helpers in seq_hex_dump() coredump: change zap_threads() and zap_process() to use for_each_thread() coredump: ensure all coredumping tasks have SIGNAL_GROUP_COREDUMP signal: remove jffs2_garbage_collect_thread()->allow_signal(SIGCONT) signal: introduce kernel_signal_stop() to fix jffs2_garbage_collect_thread() signal: turn dequeue_signal_lock() into kernel_dequeue_signal() signals: kill block_all_signals() and unblock_all_signals() nilfs2: fix gcc uninitialized-variable warnings in powerpc build nilfs2: fix gcc unused-but-set-variable warnings MAINTAINERS: nilfs2: add header file for tracing nilfs2: add tracepoints for analyzing reading and writing metadata files ...
2015-11-07tracing: Remove unused ftrace_cpu_disabled per cpu variableDmitry Safonov
Since the ring buffer is lockless, there is no need to disable ftrace on CPU. And no one doing so: after commit 68179686ac67cb ("tracing: Remove ftrace_disable/enable_cpu()") ftrace_cpu_disabled stays the same after initialization, nothing changes it. ftrace_cpu_disabled shouldn't be used by any external module since it disables only function and graph_function tracers but not any other tracer. Link: http://lkml.kernel.org/r/1446836846-22239-1-git-send-email-0x7f454c46@gmail.com Signed-off-by: Dmitry Safonov <0x7f454c46@gmail.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-11-06panic: release stale console lock to always get the logbuf printed outVitaly Kuznetsov
In some cases we may end up killing the CPU holding the console lock while still having valuable data in logbuf. E.g. I'm observing the following: - A crash is happening on one CPU and console_unlock() is being called on some other. - console_unlock() tries to print out the buffer before releasing the lock and on slow console it takes time. - in the meanwhile crashing CPU does lots of printk()-s with valuable data (which go to the logbuf) and sends IPIs to all other CPUs. - console_unlock() finishes printing previous chunk and enables interrupts before trying to print out the rest, the CPU catches the IPI and never releases console lock. This is not the only possible case: in VT/fb subsystems we have many other console_lock()/console_unlock() users. Non-masked interrupts (or receiving NMI in case of extreme slowness) will have the same result. Getting the whole console buffer printed out on crash should be top priority. [akpm@linux-foundation.org: tweak comment text] Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com> Cc: HATAYAMA Daisuke <d.hatayama@jp.fujitsu.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Baoquan He <bhe@redhat.com> Cc: Prarit Bhargava <prarit@redhat.com> Cc: Xie XiuQi <xiexiuqi@huawei.com> Cc: Seth Jennings <sjenning@redhat.com> Cc: "K. Y. Srinivasan" <kys@microsoft.com> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06pidns: fix set/getpriority and ioprio_set/get in PRIO_USER modeBen Segall
setpriority(PRIO_USER, 0, x) will change the priority of tasks outside of the current pid namespace. This is in contrast to both the other modes of setpriority and the example of kill(-1). Fix this. getpriority and ioprio have the same failure mode, fix them too. Eric said: : After some more thinking about it this patch sounds justifiable. : : My goal with namespaces is not to build perfect isolation mechanisms : as that can get into ill defined territory, but to build well defined : mechanisms. And to handle the corner cases so you can use only : a single namespace with well defined results. : : In this case you have found the two interfaces I am aware of that : identify processes by uid instead of by pid. Which quite frankly is : weird. Unfortunately the weird unexpected cases are hard to handle : in the usual way. : : I was hoping for a little more information. Changes like this one we : have to be careful of because someone might be depending on the current : behavior. I don't think they are and I do think this make sense as part : of the pid namespace. Signed-off-by: Ben Segall <bsegall@google.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Ambrose Feinstein <ambrose@google.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06kexec: use file name as the output message prefixMinfei Huang
kexec output message misses the prefix "kexec", when Dave Young split the kexec code. Now, we use file name as the output message prefix. Currently, the format of output message: [ 140.290795] SYSC_kexec_load: hello, world [ 140.291534] kexec: sanity_check_segment_list: hello, world Ideally, the format of output message: [ 30.791503] kexec: SYSC_kexec_load, Hello, world [ 79.182752] kexec_core: sanity_check_segment_list, Hello, world Remove the custom prefix "kexec" in output message. Signed-off-by: Minfei Huang <mnfhuang@gmail.com> Acked-by: Dave Young <dyoung@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06coredump: ensure all coredumping tasks have SIGNAL_GROUP_COREDUMPOleg Nesterov
task_will_free_mem() is wrong in many ways, and in particular the SIGNAL_GROUP_COREDUMP check is not reliable: a task can participate in the coredumping without SIGNAL_GROUP_COREDUMP bit set. change zap_threads() paths to always set SIGNAL_GROUP_COREDUMP even if other CLONE_VM processes can't react to SIGKILL. Fortunately, at least oom-kill case if fine; it kills all tasks sharing the same mm, so it should also kill the process which actually dumps the core. The change in prepare_signal() is not strictly necessary, it just ensures that the patch does not bring another subtle behavioural change. But it reminds us that this SIGNAL_GROUP_EXIT/COREDUMP case needs more changes. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: David Rientjes <rientjes@google.com> Cc: Kyle Walker <kwalker@redhat.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Stanislav Kozina <skozina@redhat.com> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06signals: kill block_all_signals() and unblock_all_signals()Oleg Nesterov
It is hardly possible to enumerate all problems with block_all_signals() and unblock_all_signals(). Just for example, 1. block_all_signals(SIGSTOP/etc) simply can't help if the caller is multithreaded. Another thread can dequeue the signal and force the group stop. 2. Even is the caller is single-threaded, it will "stop" anyway. It will not sleep, but it will spin in kernel space until SIGCONT or SIGKILL. And a lot more. In short, this interface doesn't work at all, at least the last 10+ years. Daniel said: Yeah the only times I played around with the DRM_LOCK stuff was when old drivers accidentally deadlocked - my impression is that the entire DRM_LOCK thing was never really tested properly ;-) Hence I'm all for purging where this leaks out of the drm subsystem. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> Acked-by: Dave Airlie <airlied@redhat.com> Cc: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06printk: prevent userland from spoofing kernel messagesMathias Krause
The following statement of ABI/testing/dev-kmsg is not quite right: It is not possible to inject messages from userspace with the facility number LOG_KERN (0), to make sure that the origin of the messages can always be reliably determined. Userland actually can inject messages with a facility of 0 by abusing the fact that the facility is stored in a u8 data type. By using a facility which is a multiple of 256 the assignment of msg->facility in log_store() implicitly truncates it to 0, i.e. LOG_KERN, allowing users of /dev/kmsg to spoof kernel messages as shown below: The following call... # printf '<%d>Kernel panic - not syncing: beer empty\n' 0 >/dev/kmsg ...leads to the following log entry (dmesg -x | tail -n 1): user :emerg : [ 66.137758] Kernel panic - not syncing: beer empty However, this call... # printf '<%d>Kernel panic - not syncing: beer empty\n' 0x800 >/dev/kmsg ...leads to the slightly different log entry (note the kernel facility): kern :emerg : [ 74.177343] Kernel panic - not syncing: beer empty Fix that by limiting the user provided facility to 8 bit right from the beginning and catch the truncation early. Fixes: 7ff9554bb578 ("printk: convert byte-buffer to variable-length...") Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Petr Mladek <pmladek@suse.cz> Cc: Alex Elder <elder@linaro.org> Cc: Joe Perches <joe@perches.com> Cc: Kay Sievers <kay@vrfy.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-06module: export param_free_charp()Dan Streetman
Change the param_free_charp() function from static to exported. It is used by zswap in the next patch ("zswap: use charp for zswap param strings"). Signed-off-by: Dan Streetman <ddstreet@ieee.org> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Seth Jennings <sjennings@variantweb.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
