path: root/kernel
2006-02-05[PATCH] sched: only print migration_cost once per bootChuck Ebbert
migration_cost prints after every CPU hotplug event. Make it print only once at boot. Signed-off-by: Chuck Ebbert <76306.1226@compuserve.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-05[PATCH] percpu data: only iterate over possible CPUsEric Dumazet
percpu_data blindly allocates bootmem memory to store NR_CPUS instances of cpudata, instead of allocating memory only for possible cpus. As a preparation for changing that, we need to convert various 0 -> NR_CPUS loops to use for_each_cpu(). (The above only applies to users of asm-generic/percpu.h. powerpc has gone it alone and is presently only allocating memory for present CPUs, so it's currently corrupting memory). Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: James Bottomley <James.Bottomley@steeleye.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Jens Axboe <axboe@suse.de> Cc: Anton Blanchard <anton@samba.org> Acked-by: William Irwin <wli@holomorphy.com> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-03[PATCH] uninline __sigqueue_free()Andrew Morton
Five callsites. I dunno how all this crap got back in there :( Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-03[PATCH] cpuset: fix sparse warningRandy Dunlap
kernel/cpuset.c:644:38: warning: non-ANSI function declaration of function 'cpuset_update_task_memory_state' Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-03[PATCH] Normalize timespec for negative values in ns_to_timespecGeorge Anzinger
- In case of a negative nsec value the result of the division must be normalized. - Remove inline from an exported function. Signed-off-by: George Anzinger <george@wildturkeyranch.net> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-03[PATCH] Tell kallsyms_lookup_name() to ignore type U entriesKeith Owens
When one module exports a function symbol and another module uses that symbol then kallsyms shows the symbol twice. Once from the consumer with a type of 'U' and once from the provider with a type of 't' or 'T'. On most architectures, both entries have the same address so it does not matter which one is returned by kallsyms_lookup_name(). But on architectures with function descriptors, the 'U' entry points to the descriptor, not to the code body, which is not what we want. IA64 # grep -w qla2x00_remove_one /proc/kallsyms a000000208c25ef8 U qla2x00_remove_one [qla2300] <= descriptor a000000208bf44c0 t qla2x00_remove_one [qla2xxx] <= function body Tell kallsyms_lookup_name() to ignore type U entries in modules. Signed-off-by: Keith Owens <kaos@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-03[PATCH] Kprobes: Fix deadlock in function-return probesAnanth N Mavinakayanahalli
When two function-return probes are inserted on kfree()[1] and the second on say, sys_link()[2], and later [2] is unregistered, we have a deadlock as kfree is called with the kretprobe_lock held and the function-return probe on kfree will also try to grab the same lock. However, we can move the kfree() during unregistration to outside the spinlock as we are sure that no instances from the free list will be used after synchronized_sched() returns during the unregistration process. Thanks to Masami Hiramatsu for spotting this. Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-03[PATCH] kernel/kprobes.c: fix a warning #ifndef ARCH_SUPPORTS_KRETPROBESAdrian Bunk
kernel/kprobes.c:353: warning: 'pre_handler_kretprobe' defined but not used Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Acked-by: "Keshavamurthy, Anil S" <anil.s.keshavamurthy@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
2006-02-01[PATCH] zone_reclaim: configurable off node allocation period.Christoph Lameter
Currently the zone_reclaim code has a fixed window of 30 seconds of off node allocations should a local zone have no unused pagecache pages left. Reclaim will be attempted again after this timeout period to avoid repeated useless scans for memory. This is also useful to established sufficiently large off node allocation chunks to relieve the local node. It may be beneficial to adjust that time period for some special situations. For example if memory use was exceeding node capacity one may want to give up for longer periods of time. If memory spikes intermittendly then one may want to shorten the time period to reduce the number of off node allocations. This patch allows just that.... Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] zone_reclaim: minor fixesChristoph Lameter
- If we only reclaim nr_pages then its okay to stay on node. Switch from > to >= for the comparison. - vm_table[] entry for zone_reclaim_mode is a bit screwed up. - Add empty lines around shrink_zone to show that this is the central function to be called. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] swsusp: do not change log level during suspend/resumeRafael J. Wysocki
Prevent the kernel from setting the log level to 10 unconditionally during suspend/resume which was needed in the past for debugging, but generally is undesirable. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] sys_sched_getaffinity() & hotplugJack Steiner
Change sched_getaffinity() so that it returns a bitmap that indicates the legally schedulable cpus that a task is allowed to run on. Without this patch, if CONFIG_HOTPLUG_CPU is enabled, sched_getaffinity() unconditionally returns (at least on IA64) a mask with NR_CPUS bits set. This conveys no useful infornmation except for a kernel compile option. This fixes a breakage we obseved running recent kernels. We have MPI jobs that use sched_getaffinity() to determine where to place their threads. Placing them on non-existant cpus is problematic :-) Signed-off-by: Jack Steiner <steiner@sgi.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Nathan Lynch <ntl@pobox.com> Cc: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] kernel/posix-timers.c: remove do_posix_clock_notimer_create()Adrian Bunk
This function is neither used nor has any real contents. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] hrtimers: set correct initial expiry time for relative SIGEV_NONE timersThomas Gleixner
The expiry time for relative timers with SIGEV_NONE set was never updated to the correct value. Pointed out by George Anzinger. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] hrtimers: add back lost credit linesThomas Gleixner
At some point we added credits to people who actively helped to bring k/hr-timers along. This was lost in the big code revamp. Add it back. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] hrtimers: cleanups and simplificationsGeorge Anzinger
Clean up the interface to hrtimers by changing the init code to pass the mode as well as the clock. This allow the init code to select the correct base and eliminates extra timer re-init code in posix-timers. We also simplify the restart interface nanosleep use. Signed-off-by: George Anzinger <george@mvista.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] hrtimers: fix posix-timer requeue raceakpm@osdl.org
From: Steven Rostedtrostedt@goodmis.org <rostedt@goodmis.org> CPU0 expires a posix-timer and runs the callback function. The signal is queued. After releasing the posix-timer lock and before returning to hrtimer_run_queue CPU0 gets interrupted. CPU1 delivers the queued signal and rearms the timer. CPU0 comes back to hrtimer_run_queue and sets the timer state to expired. The next modification of the timer can result in an oops, because the state information is wrong. Keep track of state = RUNNING and check if the state has been in the return path of hrtimer_run_queue. In case the state has been changed, ignore a restart request and do not touch the state variable. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] hrtimers: fix oldvalue return in setitimerThomas Gleixner
This resolves bugzilla bug#5617. The oldvalue of the timer was read after the timer was cancelled, so the remaining time was always zero. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] hrtimers: fix possible use of NULL pointer in posix-timersThomas Gleixner
Fixup the conversion of posix-timers to hrtimers. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] hrtimers: fixup itimer conversionThomas Gleixner
The itimer conversion removed the locking which protects the timer and variables in the shared signal structure. Steven Rostedt found the problem in the latest -rt patches. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] swsusp: use bytes as image size unitsRafael J. Wysocki
Make swsusp use bytes as the image size units, which is needed for future compatibility. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-31[PATCH] "Fix uidhash_lock <-> RXU deadlock" fixAndrew Morton
I get storms of warnings from local_bh_enable(). Better-tested patches, please. Cc: Ingo Molnar <mingo@elte.hu> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-31[PATCH] rcu_torture_lock deadlock fixIngo Molnar
rcu_torture_lock is used in a softirq-unsafe manner, but it is also taken by rcu_torture_cb(), which may execute in softirq-context, resulting in potential deadlocks. The fix is to acquire rcu_torture_lock in a softirq-safe manner. With this fix applied, the rcu-torture code passes validation. Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Paul E. McKenney <paulmck@us.ibm.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-31[PATCH] fix uidhash_lock <-> RCU deadlockIngo Molnar
RCU task-struct freeing can call free_uid(), which is taking uidhash_lock - while other users of uidhash_lock are softirq-unsafe. The fix is to always take the uidhash_spinlock in a softirq-safe manner. Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Paul E. McKenney <paulmck@us.ibm.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-31[PATCH] Fix boot-time slowdown for measure_migration_costIngo Molnar
This reduces the amount of time the migration cost calculations cost during bootup. Based on numbers by Tony Luck <tony.luck@intel.com>. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2006-01-31Don't try to "validate" a non-existing timeval.Linus Torvalds
settime() with a NULL timeval is silly but legal. Noticed by Dave Jones <davej@redhat.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-24[ACPI] merge 3549 4320 4485 4588 4980 5483 5651 acpica asus fops pnpacpi ↵Len Brown
branches into release Signed-off-by: Len Brown <len.brown@intel.com>
2006-01-18[PATCH] EDAC: atomic scrub operationsAlan Cox
EDAC requires a way to scrub memory if an ECC error is found and the chipset does not do the work automatically. That means rewriting memory locations atomically with respect to all CPUs _and_ bus masters. That means we can't use atomic_add(foo, 0) as it gets optimised for non-SMP This adds a function to include/asm-foo/atomic.h for the platforms currently supported which implements a scrub of a mapped block. It also adjusts a few other files include order where atomic.h is included before types.h as this now causes an error as atomic_scrub uses u32. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] Generic sys_rt_sigsuspend()David Woodhouse
The TIF_RESTORE_SIGMASK flag allows us to have a generic implementation of sys_rt_sigsuspend() instead of duplicating it for each architecture. This provides such an implementation and makes arch/powerpc use it. It also tidies up the ppc32 sys_sigsuspend() to use TIF_RESTORE_SIGMASK. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] fix sched_setscheduler semanticsJason Baron
Currently, a negative policy argument passed into the 'sys_sched_setscheduler()' system call, will return with success. However, the manpage for 'sys_sched_setscheduler' says: EINVAL The scheduling policy is not one of the recognized policies, or the parameter p does not make sense for the policy. Signed-off-by: Jason Baron <jbaron@redhat.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] Zone reclaim: proc overrideChristoph Lameter
proc support for zone reclaim This patch creates a proc entry /proc/sys/vm/zone_reclaim_mode that may be used to override the automatic determination of the zone reclaim made on bootup. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-16[PATCH] kernel/hrtimer.c sparse warning fixIngo Molnar
fix the following sparse warning: kernel/hrtimer.c:665:34: warning: incorrect type in argument 2 (different address spaces) kernel/hrtimer.c:665:34: expected void const *from kernel/hrtimer.c:665:34: got struct timespec [noderef] *<noident><asn:1> kernel/hrtimer.c:664:2: warning: dereference of noderef expression Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-16[PATCH] build kernel/intermodule.c only when requiredAdrian Bunk
Build kernel/intermodule.c only when required. Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-16[PATCH] hrtimer comment tweakJonathan Corbet
Fix a comment which missed an update cycle somewhere. Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
2006-01-14[PATCH] cpuset oom lock fixPaul Jackson
The problem, reported in: http://bugzilla.kernel.org/show_bug.cgi?id=5859 and by various other email messages and lkml posts is that the cpuset hook in the oom (out of memory) code can try to take a cpuset semaphore while holding the tasklist_lock (a spinlock). One must not sleep while holding a spinlock. The fix seems easy enough - move the cpuset semaphore region outside the tasklist_lock region. This required a few lines of mechanism to implement. The oom code where the locking needs to be changed does not have access to the cpuset locks, which are internal to kernel/cpuset.c only. So I provided a couple more cpuset interface routines, available to the rest of the kernel, which simple take and drop the lock needed here (cpusets callback_sem). Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] s390: spinlock fixesMartin Schwidefsky
Remove useless spin_retry_counter and fix compilation for UP kernels. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] Unlinline a bunch of other functionsArjan van de Ven
Remove the "inline" keyword from a bunch of big functions in the kernel with the goal of shrinking it by 30kb to 40kb Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] sched: add new SCHED_BATCH policyIngo Molnar
Add a new SCHED_BATCH (3) scheduling policy: such tasks are presumed CPU-intensive, and will acquire a constant +5 priority level penalty. Such policy is nice for workloads that are non-interactive, but which do not want to give up their nice levels. The policy is also useful for workloads that want a deterministic scheduling policy without interactivity causing extra preemptions (between that workload's tasks). Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-15correct email address of Manfred SpraulChristian Kujau
I tried to send the forcedeth maintainer an email, but it came back with: "The mail address manfreds@colorfullife.com is not read anymore. Please resent your mail to manfred@ instead of manfreds@." This patch fixes this. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-01-15SOFTWARE_SUSPEND: fix a typo in the dependenciesAdrian Bunk
This patch fixes a typo in the dependencies of SOFTWARE_SUSPEND. This patch is based on a report by Jean-Luc Leger <reiga@dspnet.fr.eu.org>. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Pavel Machek <pavel@ucw.cz>
2006-01-12Merge master.kernel.org:/pub/scm/linux/kernel/git/tglx/hrtimer-2.6Linus Torvalds
2006-01-12[PATCH] sched: filter affine wakeupsakpm@osdl.org
) From: Nick Piggin <nickpiggin@yahoo.com.au> Track the last waker CPU, and only consider wakeup-balancing if there's a match between current waker CPU and the previous waker CPU. This ensures that there is some correlation between two subsequent wakeup events before we move the task. Should help random-wakeup workloads on large SMP systems, by reducing the migration attempts by a factor of nr_cpus. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-12[PATCH] scheduler cache-hot-autodetectakpm@osdl.org
) From: Ingo Molnar <mingo@elte.hu> This is the latest version of the scheduler cache-hot-auto-tune patch. The first problem was that detection time scaled with O(N^2), which is unacceptable on larger SMP and NUMA systems. To solve this: - I've added a 'domain distance' function, which is used to cache measurement results. Each distance is only measured once. This means that e.g. on NUMA distances of 0, 1 and 2 might be measured, on HT distances 0 and 1, and on SMP distance 0 is measured. The code walks the domain tree to determine the distance, so it automatically follows whatever hierarchy an architecture sets up. This cuts down on the boot time significantly and removes the O(N^2) limit. The only assumption is that migration costs can be expressed as a function of domain distance - this covers the overwhelming majority of existing systems, and is a good guess even for more assymetric systems. [ People hacking systems that have assymetries that break this assumption (e.g. different CPU speeds) should experiment a bit with the cpu_distance() function. Adding a ->migration_distance factor to the domain structure would be one possible solution - but lets first see the problem systems, if they exist at all. Lets not overdesign. ] Another problem was that only a single cache-size was used for measuring the cost of migration, and most architectures didnt set that variable up. Furthermore, a single cache-size does not fit NUMA hierarchies with L3 caches and does not fit HT setups, where different CPUs will often have different 'effective cache sizes'. To solve this problem: - Instead of relying on a single cache-size provided by the platform and sticking to it, the code now auto-detects the 'effective migration cost' between two measured CPUs, via iterating through a wide range of cachesizes. The code searches for the maximum migration cost, which occurs when the working set of the test-workload falls just below the 'effective cache size'. I.e. real-life optimized search is done for the maximum migration cost, between two real CPUs. This, amongst other things, has the positive effect hat if e.g. two CPUs share a L2/L3 cache, a different (and accurate) migration cost will be found than between two CPUs on the same system that dont share any caches. (The reliable measurement of migration costs is tricky - see the source for details.) Furthermore i've added various boot-time options to override/tune migration behavior. Firstly, there's a blanket override for autodetection: migration_cost=1000,2000,3000 will override the depth 0/1/2 values with 1msec/2msec/3msec values. Secondly, there's a global factor that can be used to increase (or decrease) the autodetected values: migration_factor=120 will increase the autodetected values by 20%. This option is useful to tune things in a workload-dependent way - e.g. if a workload is cache-insensitive then CPU utilization can be maximized by specifying migration_factor=0. I've tested the autodetection code quite extensively on x86, on 3 P3/Xeon/2MB, and the autodetected values look pretty good: Dual Celeron (128K L2 cache): --------------------- migration cost matrix (max_cache_size: 131072, cpu: 467 MHz): --------------------- [00] [01] [00]: - 1.7(1) [01]: 1.7(1) - --------------------- cacheflush times [2]: 0.0 (0) 1.7 (1784008) --------------------- Here the slow memory subsystem dominates system performance, and even though caches are small, the migration cost is 1.7 msecs. Dual HT P4 (512K L2 cache): --------------------- migration cost matrix (max_cache_size: 524288, cpu: 2379 MHz): --------------------- [00] [01] [02] [03] [00]: - 0.4(1) 0.0(0) 0.4(1) [01]: 0.4(1) - 0.4(1) 0.0(0) [02]: 0.0(0) 0.4(1) - 0.4(1) [03]: 0.4(1) 0.0(0) 0.4(1) - --------------------- cacheflush times [2]: 0.0 (33900) 0.4 (448514) --------------------- Here it can be seen that there is no migration cost between two HT siblings (CPU#0/2 and CPU#1/3 are separate physical CPUs). A fast memory system makes inter-physical-CPU migration pretty cheap: 0.4 msecs. 8-way P3/Xeon [2MB L2 cache]: --------------------- migration cost matrix (max_cache_size: 2097152, cpu: 700 MHz): --------------------- [00] [01] [02] [03] [04] [05] [06] [07] [00]: - 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) [01]: 19.2(1) - 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) [02]: 19.2(1) 19.2(1) - 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) [03]: 19.2(1) 19.2(1) 19.2(1) - 19.2(1) 19.2(1) 19.2(1) 19.2(1) [04]: 19.2(1) 19.2(1) 19.2(1) 19.2(1) - 19.2(1) 19.2(1) 19.2(1) [05]: 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) - 19.2(1) 19.2(1) [06]: 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) - 19.2(1) [07]: 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) - --------------------- cacheflush times [2]: 0.0 (0) 19.2 (19281756) --------------------- This one has huge caches and a relatively slow memory subsystem - so the migration cost is 19 msecs. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Ken Chen <kenneth.w.chen@intel.com> Cc: <wilder@us.ibm.com> Signed-off-by: John Hawkes <hawkes@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-12[hrtimer] Enforce resolution as lower limit of intervalsThomas Gleixner
Roman Zippel pointed out that the missing lower limit of intervals leads to an accounting error in the overrun count. Enforce the lower limit of intervals to resolution in the timer forwarding code. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-01-12[hrtimer] Change resolution storage to ktime_t formatThomas Gleixner
Change the storage format of the per base resolution to ktime_t to make it easier accessible in the hrtimers code. Change the resolution from (NSEC_PER_SEC/HZ) to TICK_NSEC as Roman pointed out. TICK_NSEC is closer to the real resolution. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-01-12[hrtimer] Remove listhead from hrtimer structThomas Gleixner
The list_head in the hrtimer structure was introduced for easy access to the first timer with the further extensions of real high resolution timers in mind, but it turned out in the course of development that it is not necessary for the standard use case. Remove the list head and access the first expiry timer by a datafield in the timer base. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2006-01-11[PATCH] x86_64: Inclusion of ScaleMP vSMP architecture patches - vsmp_alignRavikiran G Thirumalai
vSMP specific alignment patch to 1. Define INTERNODE_CACHE_SHIFT for vSMP 2. Use this for alignment of critical structures 3. Use INTERNODE_CACHE_SHIFT for ARCH_MIN_TASKALIGN, and let the slab align task_struct allocations to the internode cacheline size 4. Introduce and use ARCH_MIN_MMSTRUCT_ALIGN for mm_struct slab allocations. Signed-off-by: Ravikiran Thirumalai <kiran@scalemp.com> Signed-off-by: Shai Fultheim <shai@scalemp.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11[PATCH] x86_64: Make the cpu_*_maps in kernel/sched.c read mostlyAndi Kleen
They are referred to often so avoid potential false sharing for them. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
