Switching d_op on a live dentry is racy in general, so avoid it. In this case
it is a negative dentry, which is safer, but there are still concurrent ops
which may be called on d_op in that case (eg. d_revalidate). So in general
a filesystem may not do this. Fix cgroupfs so as not to do this.
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (416 commits)
ARM: DMA: add support for DMA debugging
ARM: PL011: add DMA burst threshold support for ST variants
ARM: PL011: Add support for transmit DMA
ARM: PL011: Ensure IRQs are disabled in UART interrupt handler
ARM: PL011: Separate hardware FIFO size from TTY FIFO size
ARM: PL011: Allow better handling of vendor data
ARM: PL011: Ensure error flags are clear at startup
ARM: PL011: include revision number in boot-time port printk
ARM: vexpress: add sched_clock() for Versatile Express
ARM i.MX53: Make MX53 EVK bootable
ARM i.MX53: Some bug fix about MX53 MSL code
ARM: 6607/1: sa1100: Update platform device registration
ARM: 6606/1: sa1100: Fix platform device registration
ARM i.MX51: rename IPU irqs
ARM i.MX51: Add ipu clock support
ARM: imx/mx27_3ds: Add PMIC support
ARM: DMA: Replace page_to_dma()/dma_to_page() with pfn_to_dma()/dma_to_pfn()
mx51: fix usb clock support
MX51: Add support for usb host 2
arch/arm/plat-mxc/ehci.c: fix errors/typos
'x86-hwmon-for-linus', 'x86-paravirt-for-linus', 'core-locking-for-linus' and 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip
* 'x86-alternatives-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, suspend: Avoid unnecessary smp alternatives switch during suspend/resume
* 'x86-fpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86-64, asm: Use fxsaveq/fxrestorq in more places
* 'x86-hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, hwmon: Add core threshold notification to therm_throt.c
* 'x86-paravirt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, paravirt: Use native_halt on a halt, not native_safe_halt
* 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
locking, lockdep: Convert sprintf_symbol to %pS
* 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
irq: Better struct irqaction layout
* 'x86-security-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
module: Move RO/NX module protection to after ftrace module update
x86: Resume trampoline must be executable
x86: Add RO/NX protection for loadable kernel modules
x86: Add NX protection for kernel data
x86: Fix improper large page preservation
* 'timers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
MAINTAINERS: Update timer related entries
timers: Use this_cpu_read
timerqueue: Make timerqueue_getnext() static inline
hrtimer: fix timerqueue conversion flub
hrtimers: Convert hrtimers to use timerlist infrastructure
timers: Fixup allmodconfig build issue
timers: Rename timerlist infrastructure to timerqueue
timers: Introduce timerlist infrastructure.
hrtimer: Remove stale comment on curr_timer
timer: Warn when del_timer_sync() is called in hardirq context
timer: Del_timer_sync() can be used in softirq context
timer: Make try_to_del_timer_sync() the same on SMP and UP
posix-timers: Annotate lock_timer()
timer: Permit statically-declared work with deferrable timers
time: Use ARRAY_SIZE macro in timecompare.c
timer: Initialize the field slack of timer_list
timer_list: Remove alignment padding on 64 bit when CONFIG_TIMER_STATS
time: Compensate for rounding on odd-frequency clocksources
Fix up trivial conflict in MAINTAINERS
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (30 commits)
sched: Change wait_for_completion_*_timeout() to return a signed long
sched, autogroup: Fix reference leak
sched, autogroup: Fix potential access to freed memory
sched: Remove redundant CONFIG_CGROUP_SCHED ifdef
sched: Fix interactivity bug by charging unaccounted run-time on entity re-weight
sched: Move periodic share updates to entity_tick()
printk: Use this_cpu_{read|write} api on printk_pending
sched: Make pushable_tasks CONFIG_SMP dependant
sched: Add 'autogroup' scheduling feature: automated per session task groups
sched: Fix unregister_fair_sched_group()
sched: Remove unused argument dest_cpu to migrate_task()
mutexes, sched: Introduce arch_mutex_cpu_relax()
sched: Add some clock info to sched_debug
cpu: Remove incorrect BUG_ON
cpu: Remove unused variable
sched: Fix UP build breakage
sched: Make task dump print all 15 chars of proc comm
sched: Update tg->shares after cpu.shares write
sched: Allow update_cfs_load() to update global load
sched: Implement demand based update_cfs_load()
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (146 commits)
tools, perf: Documentation for the power events API
perf: Add calls to suspend trace point
perf script: Make some lists static
perf script: Use the default lost event handler
perf session: Warn about errors when processing pipe events too
perf tools: Fix perf_event.h header usage
perf test: Clarify some error reports in the open syscall test
x86, NMI: Add touch_nmi_watchdog to io_check_error delay
x86: Avoid calling arch_trigger_all_cpu_backtrace() at the same time
x86: Only call smp_processor_id in non-preempt cases
perf timechart: Adjust perf timechart to the new power events
perf: Clean up power events by introducing new, more generic ones
perf: Do not export power_frequency, but power_start event
perf test: Add test for counting open syscalls
perf evsel: Auto allocate resources needed for some methods
perf evsel: Use {cpu,thread}_map to shorten list of parameters
perf tools: Refactor all_tids to hold nr and the map
perf tools: Refactor cpumap to hold nr and the map
perf evsel: Introduce per cpu and per thread open helpers
perf evsel: Steal the counter reading routines from stat
* 'core-futexes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
futex: Add futex_q static initializer
futex: Replace fshared and clockrt with combined flags
futex: Cleanup stale fshared flag interfaces
* 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
rcu: remove unused __list_for_each_rcu() macro
rculist: fix borked __list_for_each_rcu() macro
rcu: reduce __call_rcu()-induced contention on rcu_node structures
rcu: limit rcu_node leaf-level fanout
rcu: fine-tune grace-period begin/end checks
rcu: Keep gpnum and completed fields synchronized
rcu: Stop chasing QS if another CPU did it for us
rcu: increase synchronize_sched_expedited() batching
rcu: Make synchronize_srcu_expedited() fast if running readers
rcu: fix race condition in synchronize_sched_expedited()
rcu: update documentation/comments for Lai's adoption patch
rcu,cleanup: simplify the code when cpu is dying
rcu,cleanup: move synchronize_sched_expedited() out of sched.c
rcu: get rid of obsolete "classic" names in TREE_RCU tracing
rcu: Distinguish between boosting and boosted
rcu: document TINY_RCU and TINY_PREEMPT_RCU tracing.
rcu: add tracing for TINY_RCU and TINY_PREEMPT_RCU
rcu: priority boosting for TINY_PREEMPT_RCU
rcu: move TINY_RCU from softirq to kthread
rcu: add priority-inversion testing to rcutorture
Uses the machine_suspend trace point, called from the
generic kernel suspend_devices_and_enter function.
Signed-off-by: Jean Pihet <j-pihet@ti.com>
Acked-by: Rafael J. Wysocki <rjw@sisk.pl>
Cc: Arjan van de Ven <arjan@linux.intel.com>
CC: Thomas Renninger <trenn@suse.de>
Cc: Len Brown <len.brown@intel.com>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: linux-pm@lists.linux-foundation.org
LKML-Reference: <1294253342-29056-2-git-send-email-j-pihet@ti.com>
arch/arm/mach-vexpress/v2m.c
arch/arm/plat-omap/counter_32k.c
arch/arm/plat-versatile/Makefile
Merge reason: Add the final .37 tree.
wait_for_completion_*_timeout() can return:
0: if the wait timed out
-ve: if the wait was interrupted
+ve: if the completion was completed.
As they currently return an 'unsigned long', the last two cases
are not easily distinguished which can easily result in buggy
code, as is the case for the recently added
wait_for_completion_interruptible_timeout() call in
net/sunrpc/cache.c
So change them both to return 'long'. As MAX_SCHEDULE_TIMEOUT
is LONG_MAX, a large +ve return value should never overflow.
Signed-off-by: NeilBrown <neilb@suse.de>
Cc: J. Bruce Fields <bfields@fieldses.org>
LKML-Reference: <20110105125016.64ccab0e@notabene.brown>
Merge reason: Merge the final .37 tree.
The cgroup exit mess also uncovered a struct autogroup reference leak.
copy_process() was simply freeing vs putting the signal_struct,
stranding a reference.
Signed-off-by: Mike Galbraith <efault@gmx.de>
LKML-Reference: <1293784350.6839.2.camel@marge.simson.net>
Oleg pointed out that the /proc interface kref_get() useage may race with
the final put during autogroup_move_group(). A signal->autogroup assignment
may be in flight when the /proc interface dereference, leaving them taking
a reference to an already dead group.
Reported-by: Oleg Nesterov <oleg@redhat.com>
LKML-Reference: <1292508592.5940.28.camel@maggy.simson.net>
CONFIG_[FAIR|RT]_GROUP_SCHED always means CONFIG_CGROUP_SCHED
Signed-off-by: Yong Zhang <yong.zhang0@gmail.com>
LKML-Reference: <1293803938-8157-1-git-send-email-yong.zhang0@gmail.com>
Add these new power trace events:
power:cpu_idle
power:cpu_frequency
power:machine_suspend
The old C-state/idle accounting events:
power:power_start
power:power_end
Have now a replacement (but we are still keeping the old
tracepoints for compatibility):
power:cpu_idle
and
power:power_frequency
is replaced with:
power:cpu_frequency
power:machine_suspend is newly introduced.
Jean Pihet has a patch integrated into the generic layer
(kernel/power/suspend.c) which will make use of it.
the type= field got removed from both, it was never
used and the type is differed by the event type itself.
perf timechart userspace tool gets adjusted in a separate patch.
Signed-off-by: Thomas Renninger <trenn@suse.de>
Acked-by: Arjan van de Ven <arjan@linux.intel.com>
Acked-by: Jean Pihet <jean.pihet@newoldbits.com>
Cc: rjw@sisk.pl
LKML-Reference: <1294073445-14812-3-git-send-email-trenn@suse.de>
LKML-Reference: <1290072314-31155-2-git-send-email-trenn@suse.de>
power_frequency moved to drivers/cpufreq/cpufreq.c which has
to be compiled in, no need to export it.
intel_idle can a be module though...
Cc: Jean Pihet <j-pihet@ti.com>
Cc: rjw@sisk.pl
LKML-Reference: <1294073445-14812-2-git-send-email-trenn@suse.de>
Merge reason: pick up latest -rc.
The error message 'NMI watchdog failed to create perf event...'
does not make it clear that this is a fatal error for the
watchdog. It also currently prints the error value as a
pointer, rather than extracting the error code with PTR_ERR().
Fix that.
Add a note to the description of the 'nowatchdog' kernel
parameter to associate it with this message.
Reported-by: Cesare Leonardi <celeonar@gmail.com>
Cc: 599368@bugs.debian.org
Cc: 608138@bugs.debian.org
Cc: Don Zickus <dzickus@redhat.com>
Cc: <stable@kernel.org> # .37.x and later
LKML-Reference: <1294009362.3167.126.camel@localhost>
When racing on adding into user cache, the new allocated from mm slab
is freed without putting user namespace.
Since the user namespace is already operated by getting, putting has
to be issued.
Signed-off-by: Hillf Danton <dhillf@gmail.com>
Acked-by: Serge Hallyn <serge@hallyn.com>
Cc: stable@kernel.org
* 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
ring_buffer: Off-by-one and duplicate events in ring_buffer_read_page
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu:
percpu: print out alloc information with KERN_DEBUG instead of KERN_INFO
kthread_work: make lockdep happy
To avoid confusion with the meaning and return value of
pm_check_wakeup_events() replace it with pm_wakeup_pending() that
will work the other way around (ie. return true when system-wide
power transition should be aborted).
When hibernation failed due to an error in swsusp_write() called by
hibernate(), it skips calling "power_down()" and returns. When
hibernate() is called again (probably after fixing up so that
swsusp_write() wouldn't fail again), before "in_suspend = 1" of
create_image is called, in_suspend should be 0. However, because
hibernate() did not reset "in_suspend" after a failure, it's already 1.
This patch fixes such inconsistency of "in_suspend" value.
Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com>
Because hibernate calls hibernation_ops->leave() without checking
whether hibernation_ops->leave is NULL or not, hiberantion_set_ops
should WARN_ON if hibernation_ops->leave is NULL.
This patch added one more condition to check hibernation_ops->leave.
Acked-by: Pavel Machek <pavel@ucw.cz>
After calling freeze_task(), try_to_freeze_tasks() see whether the
task is stopped or traced and if so, considers it to be frozen;
however, nothing guarantees that either the task being frozen sees
TIF_FREEZE or the freezer sees TASK_STOPPED -> TASK_RUNNING
transition. The task being frozen may wake up and not see TIF_FREEZE
while the freezer fails to notice the transition and believes the task
is still stopped.
This patch fixes the race by making freeze_task() always go through
fake_signal_wake_up() for applicable tasks. The function goes through
the target task's scheduler lock and thus guarantees that either the
target sees TIF_FREEZE or try_to_freeze_task() sees TASK_RUNNING.
Use the ccflags-$ flag instead of EXTRA_CFLAGS because EXTRA_CFLAGS is
deprecated and should now be switched. According to
(documentation/kbuild/makefiles.txt).
Signed-off-by: Tracey Dent <tdent48227@gmail.com>
Fix two related problems in the event-copying loop of
ring_buffer_read_page.
The loop condition for copying events is off-by-one.
"len" is the remaining space in the caller-supplied page.
"size" is the size of the next event (or two events).
If len == size, then there is just enough space for the next event.
size was set to rb_event_ts_length, which may include the size of two
events if the first event is a time-extend, in order to assure time-
extends are kept together with the event after it. However,
rb_advance_reader always advances by one event. This would result in the
event after any time-extend being duplicated. Instead, get the size of
a single event for the memcpy, but use rb_event_ts_length for the loop
condition.
Signed-off-by: David Sharp <dhsharp@google.com>
LKML-Reference: <1293064704-8101-1-git-send-email-dhsharp@google.com>
LKML-Reference: <AANLkTin7nLrRPc9qGjdjHbeVDDWiJjAiYyb-L=gH85bx@mail.gmail.com>
The commit:
84e1c6bb38eb318e456558b610396d9f1afaabf0
Broke the function tracer with this output:
WARNING: at kernel/trace/ftrace.c:1014 ftrace_bug+0x114/0x171()
Hardware name: Precision WorkStation 470
Modules linked in: i2c_core(+)
Pid: 86, comm: modprobe Not tainted 2.6.37-rc2+ #68
Call Trace:
[<ffffffff8104e957>] warn_slowpath_common+0x85/0x9d
[<ffffffffa00026db>] ? __process_new_adapter+0x7/0x34 [i2c_core]
[<ffffffff8104e989>] warn_slowpath_null+0x1a/0x1c
[<ffffffff810a9dfe>] ftrace_bug+0x114/0x171
[<ffffffff810aa0db>] ftrace_process_locs+0x1ae/0x274
[<ffffffff810aa29e>] ftrace_module_notify+0x39/0x44
[<ffffffff814405cf>] notifier_call_chain+0x37/0x63
[<ffffffff8106e054>] __blocking_notifier_call_chain+0x46/0x5b
[<ffffffff8106e07d>] blocking_notifier_call_chain+0x14/0x16
[<ffffffff8107ffde>] sys_init_module+0x73/0x1f3
[<ffffffff8100acf2>] system_call_fastpath+0x16/0x1b
---[ end trace 2aff4f4ca53ec746 ]---
ftrace faulted on writing [<ffffffffa00026db>]
The cause was that the module text was set to read only before ftrace
could convert the calls to mcount to nops. Thus, the conversions failed
due to not being able to write to the text locations.
The simple fix is to move setting the module to read only after the
module notifiers are called (where ftrace sets the module mcounts to nops).
Reported-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-2.6-rcu into core/rcu
The taskstats structure is internally aligned on 8 byte boundaries but the
layout of the aggregrate reply, with two NLA headers and the pid (each 4
bytes), actually force the entire structure to be unaligned. This causes
the kernel to issue unaligned access warnings on some architectures like
ia64. Unfortunately, some software out there doesn't properly unroll the
NLA packet and assumes that the start of the taskstats structure will
always be 20 bytes from the start of the netlink payload. Aligning the
start of the taskstats structure breaks this software, which we don't
want. So, for now the alignment only happens on architectures that
require it and those users will have to update to fixed versions of those
packages. Space is reserved in the packet only when needed. This ifdef
should be removed in several years e.g. 2012 once we can be confident
that fixed versions are installed on most systems. We add the padding
before the aggregate since the aggregate is already a defined type.
Commit 85893120 ("delayacct: align to 8 byte boundary on 64-bit systems")
previously addressed the alignment issues by padding out the pid field.
This was supposed to be a compatible change but the circumstances
described above mean that it wasn't. This patch backs out that change,
since it was a hack, and introduces a new NULL attribute type to provide
the padding. Padding the response with 4 bytes avoids allocating an
aligned taskstats structure and copying it back. Since the structure
weighs in at 328 bytes, it's too big to do it on the stack.
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
Reported-by: Brian Rogers <brian@xyzw.org>
Cc: Jeff Mahoney <jeffm@suse.com>
Cc: Guillaume Chazarain <guichaz@gmail.com>
Cc: Balbir Singh <balbir@in.ibm.com>
Russell King reports:
| On the ARM dev boards, we have a 32-bit counter running at 24MHz. Calling
| clocks_calc_mult_shift(&mult, &shift, 24MHz, NSEC_PER_SEC, 60) gives
| us a multiplier of 2796202666 and a shift of 26.
| Over a large counter delta, this produces an error - lets take a count
| from 362976315 to 4280663372:
| (4280663372-362976315) * 2796202666 / 2^26 - (4280663372-362976315) * (1000/24)
| => -38.91872422891230269990
| Can we do better?
| (4280663372-362976315) * 2796202667 / 2^26 - (4280663372-362976315) * (1000/24)
| 19.45936211449532822051
| which is about twice as good as the 2796202666 multiplier.
| Looking at the equivalent divisions obtained, 2796202666 / 2^26 gives
| 41.66666665673255920410ns per tick, whereas 2796202667 / 2^26 gives
| 41.66666667163372039794ns. The actual value wanted is 1000/24 =
| 41.66666666666666666666ns.
Fix this by ensuring we round to nearest when calculating the
multiplier.
Signed-off-by: John Stultz <john.stultz@linaro.org>
Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Tested-by: Will Deacon <will.deacon@arm.com>
Tested-by: Mikael Pettersson <mikpe@it.uu.se>
Tested-by: Eric Miao <eric.y.miao@gmail.com>
Tested-by: Olof Johansson <olof@lixom.net>
Tested-by: Jamie Iles <jamie@jamieiles.com>
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
MAINTAINERS
arch/arm/mach-omap2/pm24xx.c
drivers/scsi/bfa/bfa_fcpim.c
Needed to update to apply fixes for which the old branch was too
outdated.
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into perf/core
Merge reason: Pick up the latest -rc.
spinlock in kthread_worker and wait_queue_head in kthread_work both
should be lockdep sensible, so change the interface to make it
suiltable for CONFIG_LOCKDEP.
tj: comment update
Reported-by: Nicolas <nicolas.mailhot@laposte.net>
Signed-off-by: Andy Walls <awalls@md.metrocast.net>
Tested-by: Andy Walls <awalls@md.metrocast.net>
Cc: Tejun Heo <tj@kernel.org>
Currently, destroy_workqueue() makes the workqueue deny all new
queueing by setting WQ_DYING and flushes the workqueue once before
proceeding with destruction; however, there are cases where work items
queue more related work items. Currently, such users need to
explicitly flush the workqueue multiple times depending on the
possible depth of such chained queueing.
This patch updates the queueing path such that a work item can queue
further work items on the same workqueue even when WQ_DYING is set.
The flush on destruction is automatically retried until the workqueue
is empty. This guarantees that the workqueue is empty on destruction
while allowing chained queueing.
The flush retry logic whines if it takes too many retries to drain the
workqueue.
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
* 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
sched: Remove debugging check
Linus reported that the new warning introduced by commit f26f9aff6aaf
"Sched: fix skip_clock_update optimization" triggers. The need_resched
flag can be set by other CPUs asynchronously so this debug check is
bogus - remove it.
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
LKML-Reference: <AANLkTinJ8hAG1TpyC+CSYPR47p48+1=E7fiC45hMXT_1@mail.gmail.com>
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86-32: Make sure we can map all of lowmem if we need to
x86, vt-d: Handle previous faults after enabling fault handling
x86: Enable the intr-remap fault handling after local APIC setup
x86, vt-d: Fix the vt-d fault handling irq migration in the x2apic mode
x86, vt-d: Quirk for masking vtd spec errors to platform error handling logic
x86, xsave: Use alloc_bootmem_align() instead of alloc_bootmem()
bootmem: Add alloc_bootmem_align()
x86, gcc-4.6: Use gcc -m options when building vdso
x86: HPET: Chose a paranoid safe value for the ETIME check
x86: io_apic: Avoid unused variable warning when CONFIG_GENERIC_PENDING_IRQ=n
perf: Fix off by one in perf_swevent_init()
perf: Fix duplicate events with multiple-pmu vs software events
ftrace: Have recordmcount honor endianness in fn_ELF_R_INFO
scripts/tags.sh: Add magic for trace-events
tracing: Fix panic when lseek() called on "trace" opened for writing
sched: Fix the irqtime code for 32bit
sched: Fix the irqtime code to deal with u64 wraps
nohz: Fix get_next_timer_interrupt() vs cpu hotplug
sched: Cure more NO_HZ load average woes
re-weight
Mike Galbraith reported poor interactivity[*] when the new shares distribution
code was combined with autogroups.
The root cause turns out to be a mis-ordering of accounting accrued execution
time and shares updates. Since update_curr() is issued hierarchically,
updating the parent entity weights to reflect child enqueue/dequeue results in
the parent's unaccounted execution time then being accrued (vs vruntime) at the
new weight as opposed to the weight present at accumulation.
While this doesn't have much effect on processes with timeslices that cross a
tick, it is particularly problematic for an interactive process (e.g. Xorg)
which incurs many (tiny) timeslices. In this scenario almost all updates are
at dequeue which can result in significant fairness perturbation (especially if
it is the only thread, resulting in potential {tg->shares, MIN_SHARES}
transitions).
Correct this by ensuring unaccounted time is accumulated prior to manipulating
an entity's weight.
[*] http://xkcd.com/619/ is perversely Nostradamian here.
Signed-off-by: Paul Turner <pjt@google.com>
LKML-Reference: <20101216031038.159704378@google.com>
Long running entities that do not block (dequeue) require periodic updates to
maintain accurate share values. (Note: group entities with several threads are
quite likely to be non-blocking in many circumstances).
By virtue of being long-running however, we will see entity ticks (otherwise
the required update occurs in dequeue/put and we are done). Thus we can move
the detection (and associated work) for these updates into the periodic path.
This restores the 'atomicity' of update_curr() with respect to accounting.
LKML-Reference: <20101216031038.067028969@google.com>
Merge reason: Update to the latest -rc.
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6:
x86: avoid high BIOS area when allocating address space
x86: avoid E820 regions when allocating address space
x86: avoid low BIOS area when allocating address space
resources: add arch hook for preventing allocation in reserved areas
Revert "resources: support allocating space within a region from the top down"
Revert "PCI: allocate bus resources from the top down"
Revert "x86/PCI: allocate space from the end of a region, not the beginning"
Revert "x86: allocate space within a region top-down"
Revert "PCI: fix pci_bus_alloc_resource() hang, prefer positive decode"
PCI: Update MCP55 quirk to not affect non HyperTransport variants
The irq work queue is a per cpu object and it is sufficient for
synchronization if per cpu atomics are used. Doing so simplifies
the code and reduces the overhead of the code.
Before:
christoph@linux-2.6$ size kernel/irq_work.o
451 8 1 460 1cc kernel/irq_work.o
After:
438 8 1 447 1bf kernel/irq_work.o
Signed-off-by: Christoph Lameter <cl@linux.com>
