Observe PM QoS CPU frequency minimum and maximum in addition
to policy settings.
Bug 888312
Change-Id: Ia4f60a1649a9952e02f6847c8add3b2ea5d47524
Reviewed-on: http://git-master/r/72207
Signed-off-by: Antti P Miettinen <amiettinen@nvidia.com>
Reviewed-on: http://git-master/r/75884
Add minimum and maximum CPU frequency as PM QoS parameters.
Bug 888312
Change-Id: I18abddded35a044a6ad8365035e31d1a2213a329
Reviewed-on: http://git-master/r/72206
Reviewed-on: http://git-master/r/75883
Linux 3.1.9
Makefile
Change-Id: I22227ab33ba7ddaba8e6fe049393c58a83d73648
commit 79cfbdfa87e84992d509e6c1648a18e1d7e68c20 upstream.
The CPU hotplug notifications sent out by the _cpu_up() and _cpu_down()
functions depend on the value of the 'tasks_frozen' argument passed to them
(which indicates whether tasks have been frozen or not).
(Examples for such CPU hotplug notifications: CPU_ONLINE, CPU_ONLINE_FROZEN,
CPU_DEAD, CPU_DEAD_FROZEN).
Thus, it is essential that while the callbacks for those notifications are
running, the state of the system with respect to the tasks being frozen or
not remains unchanged, *throughout that duration*. Hence there is a need for
synchronizing the CPU hotplug code with the freezer subsystem.
Since the freezer is involved only in the Suspend/Hibernate call paths, this
patch hooks the CPU hotplug code to the suspend/hibernate notifiers
PM_[SUSPEND|HIBERNATE]_PREPARE and PM_POST_[SUSPEND|HIBERNATE] to prevent
the race between CPU hotplug and freezer, thus ensuring that CPU hotplug
notifications will always be run with the state of the system really being
what the notifications indicate, _throughout_ their execution time.
Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
commit 0d19ea866562e46989412a0676412fa0983c9ce7 upstream.
If we mount a hierarchy with a specified name, the name is unique,
and we can use it to mount the hierarchy without specifying its
set of subsystem names. This feature is documented is
Documentation/cgroups/cgroups.txt section 2.3
Here's an example:
# mount -t cgroup -o cpuset,name=myhier xxx /cgroup1
# mount -t cgroup -o name=myhier xxx /cgroup2
But it was broken by commit 32a8cf235e2f192eb002755076994525cdbaa35a
(cgroup: make the mount options parsing more accurate)
This fixes the regression.
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
commit 8a88951b5878dc475dcd841cefc767e36397d14e upstream.
This is the temporary simple fix for 3.2, we need more changes in this
area.
1. do_signal_stop() assumes that the running untraced thread in the
stopped thread group is not possible. This was our goal but it is
not yet achieved: a stopped-but-resumed tracee can clone the running
thread which can initiate another group-stop.
Remove WARN_ON_ONCE(!current->ptrace).
2. A new thread always starts with ->jobctl = 0. If it is auto-attached
and this group is stopped, __ptrace_unlink() sets JOBCTL_STOP_PENDING
but JOBCTL_STOP_SIGMASK part is zero, this triggers WANR_ON(!signr)
in do_jobctl_trap() if another debugger attaches.
Change __ptrace_unlink() to set the artificial SIGSTOP for report.
Alternatively we could change ptrace_init_task() to copy signr from
current, but this means we can copy it for no reason and hide the
possible similar problems.
Acked-by: Tejun Heo <tj@kernel.org>
Change-Id: I2c60e18b07e8e08c7e3b6cc8288b0e04e18844f7
Reviewed-on: http://git-master/r/74233
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Tested-by: Varun Wadekar <vwadekar@nvidia.com>
commit 50b8d257486a45cba7b65ca978986ed216bbcc10 upstream.
Test-case:
int main(void)
int pid, status;
pid = fork();
if (!pid) {
for (;;) {
if (!fork())
return 0;
if (waitpid(-1, &status, 0) < 0) {
printf("ERR!! wait: %m\n");
return 0;
assert(ptrace(PTRACE_ATTACH, pid, 0,0) == 0);
assert(waitpid(-1, NULL, 0) == pid);
assert(ptrace(PTRACE_SETOPTIONS, pid, 0,
PTRACE_O_TRACEFORK) == 0);
do {
ptrace(PTRACE_CONT, pid, 0, 0);
pid = waitpid(-1, NULL, 0);
} while (pid > 0);
return 1;
It fails because ->real_parent sees its child in EXIT_DEAD state
while the tracer is going to change the state back to EXIT_ZOMBIE
in wait_task_zombie().
The offending commit is 823b018e which moved the EXIT_DEAD check,
but in fact we should not blame it. The original code was not
correct as well because it didn't take ptrace_reparented() into
account and because we can't really trust ->ptrace.
This patch adds the additional check to close this particular
race but it doesn't solve the whole problem. We simply can't
rely on ->ptrace in this case, it can be cleared if the tracer
is multithreaded by the exiting ->parent.
I think we should kill EXIT_DEAD altogether, we should always
remove the soon-to-be-reaped child from ->children or at least
we should never do the DEAD->ZOMBIE transition. But this is too
complex for 3.2.
Reported-and-tested-by: Denys Vlasenko <vda.linux@googlemail.com>
Tested-by: Lukasz Michalik <lmi@ift.uni.wroc.pl>
Change-Id: I9e83ca1fcff0eee2ea7ef2508de95691a0cdeb0c
Reviewed-on: http://git-master/r/74232
commit f9fab10bbd768b0e5254e53a4a8477a94bfc4b96 upstream.
vfork parent uninterruptibly and unkillably waits for its child to
exec/exit. This wait is of unbounded length. Ignore such waits
in the hung_task detector.
Signed-off-by: Mandeep Singh Baines <msb@chromium.org>
Reported-by: Sasha Levin <levinsasha928@gmail.com>
LKML-Reference: <1325344394.28904.43.camel@lappy>
Cc: John Kacur <jkacur@redhat.com>
Change-Id: I12ed227da1fb7099978c73b65a756caf51a95553
Reviewed-on: http://git-master/r/74230
commit e6780f7243eddb133cc20ec37fa69317c218b709 upstream.
It was found (by Sasha) that if you use a futex located in the gate
area we get stuck in an uninterruptible infinite loop, much like the
ZERO_PAGE issue.
While looking at this problem, PeterZ realized you'll get into similar
trouble when hitting any install_special_pages() mapping. And are there
still drivers setting up their own special mmaps without page->mapping,
and without special VM or pte flags to make get_user_pages fail?
In most cases, if page->mapping is NULL, we do not need to retry at all:
Linus points out that even /proc/sys/vm/drop_caches poses no problem,
because it ends up using remove_mapping(), which takes care not to
interfere when the page reference count is raised.
But there is still one case which does need a retry: if memory pressure
called shmem_writepage in between get_user_pages_fast dropping page
table lock and our acquiring page lock, then the page gets switched from
filecache to swapcache (and ->mapping set to NULL) whatever the refcount.
Fault it back in to get the page->mapping needed for key->shared.inode.
Change-Id: I04a763aed3c611460ef4888d14a1f5101e8373bc
Reviewed-on: http://git-master/r/74198
commit e0197aae59e55c06db172bfbe1a1cdb8c0e1cab3 upstream.
There is a BUG when migrating a PF_EXITING proc. Since css_set_prefetch()
is not called for the PF_EXITING case, find_existing_css_set() will return
NULL inside cgroup_task_migrate() causing a BUG.
This bug is easy to reproduce. Create a zombie and echo its pid to
cgroup.procs.
$ cat zombie.c
\#include <unistd.h>
int main()
if (fork())
pause();
return 0;
We are hitting this bug pretty regularly on ChromeOS.
This bug is already fixed by Tejun Heo's cgroup patchset which is
targetted for the next merge window:
https://lkml.org/lkml/2011/11/1/356
I've create a smaller patch here which just fixes this bug so that a
fix can be merged into the current release and stable.
Downstream-Bug-Report: http://crosbug.com/23953
Reviewed-by: Li Zefan <lizf@cn.fujitsu.com>
Cc: containers@lists.linux-foundation.org
Cc: cgroups@vger.kernel.org
Cc: Paul Menage <paul@paulmenage.org>
Cc: Olof Johansson <olofj@chromium.org>
Change-Id: I61bf2d48574d6ce5418b988e9547937c2efdd084
Reviewed-on: http://git-master/r/74185
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
commit 3d3c8f93a237b64580c5c5e138edeb1377e98230 upstream.
binary_sysctl() calls sysctl_getname() which allocates from names_cache
slab usin __getname()
The matching function to free the name is __putname(), and not putname()
which should be used only to match getname() allocations.
This is because when auditing is enabled, putname() calls audit_putname
*instead* (not in addition) to __putname(). Then, if a syscall is in
progress, audit_putname does not release the name - instead, it expects
the name to get released when the syscall completes, but that will happen
only if audit_getname() was called previously, i.e. if the name was
allocated with getname() rather than the naked __getname(). So,
__getname() followed by putname() ends up leaking memory.
Signed-off-by: Michel Lespinasse <walken@google.com>
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
Cc: Eric Paris <eparis@redhat.com>
Change-Id: Ia6c066b0703eeafc61eafdd5addf157ee671bd68
Reviewed-on: http://git-master/r/74175
area.
Test-case:
int main(void)
int pid, status;
pid = fork();
if (!pid) {
for (;;) {
if (!fork())
return 0;
return 0;
do {
} while (pid > 0);
return 1;
complex for 3.2.
ZERO_PAGE issue.
cgroup.procs.
$ cat zombie.c
int main()
if (fork())
pause();
return 0;
Change-Id: I99507d7cfdcee064f808856dc2ce99d806fd864f
commit 3b87487ac5008072f138953b07505a7e3493327f upstream.
This reverts commit de28f25e8244c7353abed8de0c7792f5f883588c.
It results in resume problems for various people. See for example
http://thread.gmane.org/gmane.linux.kernel/1233033
http://thread.gmane.org/gmane.linux.kernel/1233389
http://thread.gmane.org/gmane.linux.kernel/1233159
http://thread.gmane.org/gmane.linux.kernel/1227868/focus=1230877
and the fedora and ubuntu bug reports
https://bugzilla.redhat.com/show_bug.cgi?id=767248
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/904569
which got bisected down to the stable version of this commit.
Reported-by: Jonathan Nieder <jrnieder@gmail.com>
Reported-by: Phil Miller <mille121@illinois.edu>
Reported-by: Philip Langdale <philipl@overt.org>
Reported-by: Tim Gardner <tim.gardner@canonical.com>
CPU0 CPUn
_cpu_up()
__cpu_up()
boostrap()
notify_cpu_starting()
set_cpu_online()
while (!cpu_active())
cpu_relax()
<PREEMPT-out>
smp_call_function(.wait=1)
/* we find cpu_online() is true */
arch_send_call_function_ipi_mask()
/* wait-forever-more */
<PREEMPT-in>
local_irq_enable()
cpu_notify(CPU_ONLINE)
sched_cpu_active()
set_cpu_active()
Now the purpose of cpu_active is mostly with bringing down a cpu, where
we mark it !active to avoid the load-balancer from moving tasks to it
while we tear down the cpu. This is required because we only update the
sched_domain tree after we brought the cpu-down. And this is needed so
that some tasks can still run while we bring it down, we just don't want
new tasks to appear.
On cpu-up however the sched_domain tree doesn't yet include the new cpu,
so its invisible to the load-balancer, regardless of the active state.
So instead of setting the active state after we boot the new cpu (and
consequently having to wait for it before enabling interrupts) set the
cpu active before we set it online and avoid the whole mess.
Bug 916986
Original Patch: https://lkml.org/lkml/2011/12/15/255
Change-Id: Ia1c07bdc1b3eb07a7cd4d69756fa7bec509c9400
Reported-by: Stepan Moskovchenko <stepanm@codeaurora.org>
Reviewed-on: http://git-master/r/72130
Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Bug 894200
Change-Id: Ieb009a13c6ef9bca2388e234eb973d65a4e3a58b
Signed-off-by: Alex Frid <afrid@nvidia.com>
Reviewed-on: http://git-master/r/71034
- Replace class ID #define with enumeration
- Loop through PM QoS objects during initialization (rather than
initializing them one-by-one)
Change-Id: I185b700b52c752c62e7550fe739adc498fc989ef
Reviewed-on: http://git-master/r/70603
Reviewed-by: Antti Miettinen <amiettinen@nvidia.com>
Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Add a new module that will dump the contents of the ftrace ring buffer.
Data is compressed and can be in ascii or binary form. Data will
automatically dump on kernel panic to console. Data can be dumped by
reading /proc/tracedump. See tracedump.h for details.
Change-Id: I7b7afc3def0b88629dd120d17e43858306a8f357
Signed-off-by: Liang Cheng <licheng@nvidia.com>
Reviewed-on: http://git-master/r/69494
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
commit a33caeb118198286309859f014c0662f3ed54ed4 upstream.
Since commit f59de89 ("lockdep: Clear whole lockdep_map on initialization"),
lockdep_init_map() will clear all the struct. But it will break
lock_set_class()/lock_set_subclass(). A typical race condition
is like below:
CPU A CPU B
lock_set_subclass(lockA);
lock_set_class(lockA);
lockdep_init_map(lockA);
/* lockA->name is cleared */
memset(lockA);
__lock_acquire(lockA);
/* lockA->class_cache[] is cleared */
register_lock_class(lockA);
look_up_lock_class(lockA);
WARN_ON_ONCE(class->name !=
lock->name);
lock->name = name;
So restore to what we have done before commit f59de89 but annotate
->lock with kmemcheck_mark_initialized() to suppress the kmemcheck
warning reported in commit f59de89.
Reported-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Reported-by: Borislav Petkov <bp@alien8.de>
Suggested-by: Vegard Nossum <vegard.nossum@gmail.com>
Signed-off-by: Yong Zhang <yong.zhang0@gmail.com>
Cc: Tejun Heo <tj@kernel.org>
Link: http://lkml.kernel.org/r/20111109080451.GB8124@zhy
commit c9c024b3f3e07d087974db4c0dc46217fff3a6c0 upstream.
The expiry function compares the timer against current time and does
not expire the timer when the expiry time is >= now. That's wrong. If
the timer is set for now, then it must expire.
Make the condition expiry > now for breaking out the loop.
Acked-by: John Stultz <john.stultz@linaro.org>
arch/arm/Kconfig
Change-Id: If8aaaf3efcbbf6c9017b38efb6d76ef933f147fa
commit de28f25e8244c7353abed8de0c7792f5f883588c upstream.
If a device is shutdown, then there might be a pending interrupt,
which will be processed after we reenable interrupts, which causes the
original handler to be run. If the old handler is the (broadcast)
periodic handler the shutdown state might hang the kernel completely.
commit b1f919664d04a8d0ba29cb76673c7ca3325a2006 upstream.
In order to leave a margin of 12.5% we should >> 3 not >> 5.
Signed-off-by: Yang Honggang (Joseph) <eagle.rtlinux@gmail.com>
[jstultz: Modified commit subject]
Signed-off-by: John Stultz <john.stultz@linaro.org>
commit bbbf7af4bf8fc69bc751818cf30521080fa47dcb upstream.
If cpu A calls jump_label_inc() just after atomic_add_return() is
called by cpu B, atomic_inc_not_zero() will return value greater then
zero and jump_label_inc() will return to a caller before jump_label_update()
finishes its job on cpu B.
Link: http://lkml.kernel.org/r/20111018175551.GH17571@redhat.com
Acked-by: Jason Baron <jbaron@redhat.com>
Signed-off-by: Gleb Natapov <gleb@redhat.com>
commit c1be84309c58b1e7c6d626e28fba41a22b364c3d upstream.
When a better rated broadcast device is installed, then the current
active device is not disabled, which results in two running broadcast
devices.
commit cb59974742aea24adf6637eb0c4b8e7b48bca6fb upstream.
Fix a bug introduced by e9dbfae5, which prevents event_subsystem from
ever being released.
Ref_count was added to keep track of subsystem users, not for counting
events. Subsystem is created with ref_count = 1, so there is no need to
increment it for every event, we have nr_events for that. Fix this by
touching ref_count only when we actually have a new user -
subsystem_open().
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
Link: http://lkml.kernel.org/r/1320052062-7846-1-git-send-email-idryomov@gmail.com
ftrace_event_call->filter
commit d3d9acf646679c1981032b0985b386d12fccc60c upstream.
ftrace_event_call->filter is sched RCU protected but didn't use
rcu_assign_pointer(). Use it.
TODO: Add proper __rcu annotation to call->filter and all its users.
-v2: Use RCU_INIT_POINTER() for %NULL clearing as suggested by Eric.
Link: http://lkml.kernel.org/r/20111123164949.GA29639@google.com
Cc: Jiri Olsa <jolsa@redhat.com>
commit c7c6ec8becaf742b223c7b491f4893014be23a07 upstream.
A forced undef of a config value was used for testing and was
accidently left in during the final commit. This causes x86 to
run slower than needed while running function tracing as well
as causes the function graph selftest to fail when DYNMAIC_FTRACE
is not set. This is because the code in MCOUNT expects the ftrace
code to be processed with the config value set that happened to
be forced not set.
The forced config option was left in by:
commit 6331c28c962561aee59e5a493b7556a4bb585957
ftrace: Fix dynamic selftest failure on some archs
Link: http://lkml.kernel.org/r/20111102150255.GA6973@debian
Reported-by: Rabin Vincent <rabin@rab.in>
commit 550acb19269d65f32e9ac4ddb26c2b2070e37f1c upstream.
In irq_wait_for_interrupt(), the should_stop member is verified before
setting the task's state to TASK_INTERRUPTIBLE and calling schedule().
In case kthread_stop sets should_stop and wakes up the process after
should_stop is checked by the irq thread but before the task's state
is changed, the irq thread might never exit:
kthread_stop irq_wait_for_interrupt
... while (!kthread_should_stop()) {
kthread->should_stop = 1;
wake_up_process(k);
wait_for_completion(&kthread->exited);
set_current_state(TASK_INTERRUPTIBLE);
schedule();
Fix this by checking if the thread should stop after modifying the
task's state.
[ tglx: Simplified it a bit ]
Signed-off-by: Ido Yariv <ido@wizery.com>
Link: http://lkml.kernel.org/r/1322740508-22640-1-git-send-email-ido@wizery.com
commit d65670a78cdbfae94f20a9e05ec705871d7cdf2b upstream.
For some frequencies, the clocks_calc_mult_shift() function will
unfortunately select mult values very close to 0xffffffff. This
has the potential to overflow when NTP adjusts the clock, adding
to the mult value.
This patch adds a clocksource.maxadj value, which provides
an approximation of an 11% adjustment(NTP limits adjustments to
500ppm and the tick adjustment is limited to 10%), which could
be made to the clocksource.mult value. This is then used to both
check that the current mult value won't overflow/underflow, as
well as warning us if the timekeeping_adjust() code pushes over
that 11% boundary.
v2: Fix max_adjustment calculation, and improve WARN_ONCE
messages.
v3: Don't warn before maxadj has actually been set
CC: Yong Zhang <yong.zhang0@gmail.com>
CC: David Daney <ddaney.cavm@gmail.com>
CC: Thomas Gleixner <tglx@linutronix.de>
CC: Chen Jie <chenj@lemote.com>
CC: zhangfx <zhangfx@lemote.com>
Reported-by: Chen Jie <chenj@lemote.com>
Reported-by: zhangfx <zhangfx@lemote.com>
Tested-by: Yong Zhang <yong.zhang0@gmail.com>
commit 27c9cd7e601632b3794e1c3344d37b86917ffb43 upstream.
__remove_hrtimer() attempts to reprogram the clockevent device when
the timer being removed is the next to expire. However,
__remove_hrtimer() reprograms the clockevent *before* removing the
timer from the timerqueue and thus when hrtimer_force_reprogram()
finds the next timer to expire it finds the timer we're trying to
remove.
This is especially noticeable when the system switches to NOHz mode
and the system tick is removed. The timer tick is removed from the
system but the clockevent is programmed to wakeup in another HZ
anyway.
Silence the extra wakeup by removing the timer from the timerqueue
before calling hrtimer_force_reprogram() so that we actually program
the clockevent for the next timer to expire.
This was broken by 998adc3 "hrtimers: Convert hrtimers to use
timerlist infrastructure".
Signed-off-by: Jeff Ohlstein <johlstei@codeaurora.org>
Link: http://lkml.kernel.org/r/1321660030-8520-1-git-send-email-johlstei@codeaurora.org
commit d004e024058a0eaca097513ce62cbcf978913e0a upstream.
ktime_get and ktime_get_ts were calling timekeeping_get_ns()
but later they were not calling arch_gettimeoffset() so architectures
using this mechanism returned 0 ns when calling these functions.
This happened for example when running Busybox's ping which calls
syscall(__NR_clock_gettime, CLOCK_MONOTONIC, ts) which eventually
calls ktime_get. As a result the returned ping travel time was zero.
Signed-off-by: Hector Palacios <hector.palacios@digi.com>
commit 884a45d964dd395eda945842afff5e16bcaedf56 upstream.
2d3cbf8b (cgroup_freezer: update_freezer_state() does incorrect state
transitions) removed is_task_frozen_enough and replaced it with a simple
frozen call. This, however, breaks freezing for a group with stopped tasks
because those cannot be frozen and so the group remains in CGROUP_FREEZING
state (update_if_frozen doesn't count stopped tasks) and never reaches
CGROUP_FROZEN.
Let's add is_task_frozen_enough back and use it at the original locations
(update_if_frozen and try_to_freeze_cgroup). Semantically we consider
stopped tasks as frozen enough so we should consider both cases when
testing frozen tasks.
Testcase:
mkdir /dev/freezer
mount -t cgroup -o freezer none /dev/freezer
mkdir /dev/freezer/foo
sleep 1h &
pid=$!
kill -STOP $pid
echo $pid > /dev/freezer/foo/tasks
echo FROZEN > /dev/freezer/foo/freezer.state
while true
do
cat /dev/freezer/foo/freezer.state
[ "`cat /dev/freezer/foo/freezer.state`" = "FROZEN" ] && break
sleep 1
done
echo OK
Acked-by: Li Zefan <lizf@cn.fujitsu.com>
Cc: Tomasz Buchert <tomasz.buchert@inria.fr>
Signed-off-by: Tejun Heo <htejun@gmail.com>
commit 52553ddffad76ccf192d4dd9ce88d5818f57f62a upstream.
Commit fa27271bc8d2("genirq: Fixup poll handling") introduced a
regression that broke irqfixup/irqpoll for some hardware configurations.
Amidst reorganizing 'try_one_irq', that patch removed a test that
checked for 'action->handler' returning IRQ_HANDLED, before acting on
the interrupt. Restoring this test back returns the functionality lost
since 2.6.39. In the current set of tests, after 'action' is set, it
must precede '!action->next' to take effect.
With this and my previous patch to irq/spurious.c, c75d720fca8a, all
IRQ regressions that I have encountered are fixed.
Signed-off-by: Edward Donovan <edward.donovan@numble.net>
Reported-and-tested-by: Rogério Brito <rbrito@ime.usp.br>
BUG 867296
Original-Change-Id: I0bce8d7f8ccba39608b1d00449de9d2e988ee541
Reviewed-on: http://git-master/r/50140
Reviewed-by: Xin Xie <xxie@nvidia.com>
Tested-by: Xin Xie <xxie@nvidia.com>
Rebase-Id: R729f20c7f15b09fbd90295b0ec1ea03ccbeb9ca5
bug 857053
Original-Change-Id: I9ae35026009d2a73e253386661902004d99a25c9
Reviewed-on: http://git-master/r/48349
Reviewed-by: Daniel Solomon <daniels@nvidia.com>
Tested-by: Daniel Solomon <daniels@nvidia.com>
Rebase-Id: Rc7feea74d63f9e4a34694e98e3d6e7a92add3421
arch/arm/mach-tegra/Kconfig
arch/arm/mach-tegra/board-ventana.c
drivers/misc/Kconfig
drivers/video/tegra/dc/hdmi.c
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Based on work by George G. Davis <gdavis@mvista.com>.
See http://lwn.net/Articles/390419/
Change-Id: I8df700d20a154e179f8cf6cdfe4015efc5d384f2
Signed-off-by: Juha Tukkinen <jtukkinen@nvidia.com>
Reviewed-on: http://git-master/r/62998
Reviewed-by: Peter De Schrijver <pdeschrijver@nvidia.com>
Rebase-Id: R2607a46c8bd1e521abe44a57a5ccf7317333d6c9
Based on work done for LTP in
http://ltp.cvs.sourceforge.net/viewvc/ltp/utils/analysis/gcov-kernel
Patch originates from Motorola kernel team (mkw348@motorola.com).
Change-Id: Ibb2a7c8afd79051e8d6c7fde83f04745be14f5fd
Reviewed-on: http://git-master/r/62997
Rebase-Id: R67557d023bc94fbe900bfc9deef2f5de9955ea43
This module lets subsystem authors prioritize ftrace events
by calling tracelevel_register(...). High priority traces
will be automatically enabled on boot. See tracelevel.h
for more details
Original-Change-Id: If03699e96c598bdcf93b9a9f73918ce7b0c750cb
Reviewed-on: http://git-master/r/40290
Reviewed-by: Alon Farchy <afarchy@nvidia.com>
Tested-by: Alon Farchy <afarchy@nvidia.com>
Reviewed-by: Daniel Willemsen <dwillemsen@nvidia.com>
Rebase-Id: R49f59f81d61907f66fdf892130a1b4dc6575d40e
arch/arm/mm/cache-l2x0.c
drivers/misc/Makefile
Change-Id: I32289676d95a307ea3aa5e78f6c126ca979c0fec
Signed-off-by: Todd Poynor <toddpoynor@google.com>
At times, it is necessary for boards to provide some additional information
as part of panic logs. Provide information on the board hardware as part
of panic logs.
It is safer to print this information at the very end in case something
bad happens as part of the information retrieval itself.
To use this, set global mach_panic_string to an appropriate string in the
board file.
Change-Id: Id12cdda87b0cd2940dd01d52db97e6162f671b4d
Signed-off-by: Nishanth Menon <nm@ti.com>
Use DEBUG_WAKEUP flag to show wakelocks that abort suspend, in
addition to showing wakelocks held during system resume.
DEBUG_WAKEUP is enabled by default.
Change-Id: If6fa68e8afbc482a5300ffab2964694b02b34f41
If the wakelock driver aborts suspend due to an already-held
wakelock, don't report the next wakelock held as the "wake up
wakelock".
Change-Id: I582ffbb87a3c361739a77d839a0c62921cff11a6
