commit 52553ddffad76ccf192d4dd9ce88d5818f57f62a upstream.
Commit fa27271bc8d2("genirq: Fixup poll handling") introduced a
regression that broke irqfixup/irqpoll for some hardware configurations.
Amidst reorganizing 'try_one_irq', that patch removed a test that
checked for 'action->handler' returning IRQ_HANDLED, before acting on
the interrupt. Restoring this test back returns the functionality lost
since 2.6.39. In the current set of tests, after 'action' is set, it
must precede '!action->next' to take effect.
With this and my previous patch to irq/spurious.c, c75d720fca8a, all
IRQ regressions that I have encountered are fixed.
Signed-off-by: Edward Donovan <edward.donovan@numble.net>
Reported-and-tested-by: Rogério Brito <rbrito@ime.usp.br>
BUG 867296
Original-Change-Id: I0bce8d7f8ccba39608b1d00449de9d2e988ee541
Reviewed-on: http://git-master/r/50140
Reviewed-by: Xin Xie <xxie@nvidia.com>
Tested-by: Xin Xie <xxie@nvidia.com>
Rebase-Id: R729f20c7f15b09fbd90295b0ec1ea03ccbeb9ca5
bug 857053
Original-Change-Id: I9ae35026009d2a73e253386661902004d99a25c9
Reviewed-on: http://git-master/r/48349
Reviewed-by: Daniel Solomon <daniels@nvidia.com>
Tested-by: Daniel Solomon <daniels@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Rebase-Id: Rc7feea74d63f9e4a34694e98e3d6e7a92add3421
arch/arm/mach-tegra/Kconfig
arch/arm/mach-tegra/board-ventana.c
drivers/misc/Kconfig
drivers/video/tegra/dc/hdmi.c
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Based on work by George G. Davis <gdavis@mvista.com>.
See http://lwn.net/Articles/390419/
Change-Id: I8df700d20a154e179f8cf6cdfe4015efc5d384f2
Signed-off-by: Juha Tukkinen <jtukkinen@nvidia.com>
Reviewed-on: http://git-master/r/62998
Reviewed-by: Peter De Schrijver <pdeschrijver@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Rebase-Id: R2607a46c8bd1e521abe44a57a5ccf7317333d6c9
Based on work done for LTP in
http://ltp.cvs.sourceforge.net/viewvc/ltp/utils/analysis/gcov-kernel
Patch originates from Motorola kernel team (mkw348@motorola.com).
Change-Id: Ibb2a7c8afd79051e8d6c7fde83f04745be14f5fd
Reviewed-on: http://git-master/r/62997
Rebase-Id: R67557d023bc94fbe900bfc9deef2f5de9955ea43
This module lets subsystem authors prioritize ftrace events
by calling tracelevel_register(...). High priority traces
will be automatically enabled on boot. See tracelevel.h
for more details
Original-Change-Id: If03699e96c598bdcf93b9a9f73918ce7b0c750cb
Reviewed-on: http://git-master/r/40290
Reviewed-by: Alon Farchy <afarchy@nvidia.com>
Tested-by: Alon Farchy <afarchy@nvidia.com>
Reviewed-by: Daniel Willemsen <dwillemsen@nvidia.com>
Rebase-Id: R49f59f81d61907f66fdf892130a1b4dc6575d40e
arch/arm/mm/cache-l2x0.c
drivers/misc/Makefile
Change-Id: I32289676d95a307ea3aa5e78f6c126ca979c0fec
Signed-off-by: Todd Poynor <toddpoynor@google.com>
At times, it is necessary for boards to provide some additional information
as part of panic logs. Provide information on the board hardware as part
of panic logs.
It is safer to print this information at the very end in case something
bad happens as part of the information retrieval itself.
To use this, set global mach_panic_string to an appropriate string in the
board file.
Change-Id: Id12cdda87b0cd2940dd01d52db97e6162f671b4d
Signed-off-by: Nishanth Menon <nm@ti.com>
Use DEBUG_WAKEUP flag to show wakelocks that abort suspend, in
addition to showing wakelocks held during system resume.
DEBUG_WAKEUP is enabled by default.
Change-Id: If6fa68e8afbc482a5300ffab2964694b02b34f41
If the wakelock driver aborts suspend due to an already-held
wakelock, don't report the next wakelock held as the "wake up
wakelock".
Change-Id: I582ffbb87a3c361739a77d839a0c62921cff11a6
The IRQ name has moved to the struct irqaction list (so print
first action's name).
Change-Id: I65a627457f9abaf7c1dcc32d8814243ba2ff4717
when enabled, prints out the function of each handler as they are called
Change-Id: I5ed251867e0e3aa3cd05f030ff3579808cedd0c2
Signed-off-by: Erik Gilling <konkers@android.com>
Prints the time spent in suspend in the kernel log, and
keeps statistics on the time spent in suspend in
/sys/kernel/debug/suspend_time
Change-Id: Ia6b9ebe4baa0f7f5cd211c6a4f7e813aefd3fa1d
Signed-off-by: Colin Cross <ccross@android.com>
Move the x86_64 idle notifiers originally by Andi Kleen and Venkatesh
Pallipadi to generic.
Change-Id: Idf29cda15be151f494ff245933c12462643388d5
Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Rather than using explicit euid == 0 checks when trying to move
tasks into a cgroup via CFS, move permission checks into each
specific cgroup subsystem. If a subsystem does not specify a
'allow_attach' handler, then we fall back to doing our checks
the old way.
Use the 'allow_attach' handler for the 'cpu' cgroup to allow
non-root processes to add arbitrary processes to a 'cpu' cgroup
if it has the CAP_SYS_NICE capability set.
This version of the patch adds a 'allow_attach' handler instead
of reusing the 'can_attach' handler. If the 'can_attach' handler
is reused, a new cgroup that implements 'can_attach' but not
the permission checks could end up with no permission checks
at all.
Change-Id: Icfa950aa9321d1ceba362061d32dc7dfa2c64f0c
Original-Author: San Mehat <san@google.com>
This reverts commit 1d38bc7d0523af2233b4280e2aeab34c6a076665.
Change-Id: I2c5066b696cbdd5ca117ed74718bcb7e70e878e7
kernel/time/alarmtimer.c conflicts with drivers/rtc/alarm.c,
disable it for now.
Change-Id: I6cdb3b885828d45836a54971adf16143039b0a0e
- CPU_DYING should not be handled in sleepable context
Signed-off-by: Minho Ban <mhban@samsung.com>
get_expired_time
Change-Id: I6ebe6b954b2ff328d46898d683650dafb9c4fe74
Change-Id: I36f90735c75fb7c7ab1084775ec0d0ab02336e6e
synchronize_rcu can be very expensive, averaging 100 ms in
some cases. In cgroup_attach_task, it is used to prevent
a task->cgroups pointer dereferenced in an RCU read side
critical section from being invalidated, by delaying the
call to put_css_set until after an RCU grace period.
To avoid the call to synchronize_rcu, make the put_css_set
call rcu-safe by moving the deletion of the css_set links
into free_css_set_work, scheduled by the rcu callback
free_css_set_rcu.
The decrement of the cgroup refcount is no longer
synchronous with the call to put_css_set, which can result
in the cgroup refcount staying positive after the last call
to cgroup_attach_task returns. To allow the cgroup to be
deleted with cgroup_rmdir synchronously after
cgroup_attach_task, have rmdir check the refcount of all
associated css_sets. If cgroup_rmdir is called on a cgroup
for which the css_sets all have refcount zero but the
cgroup refcount is nonzero, reuse the rmdir waitqueue to
block the rmdir until free_css_set_work is called.
Changes the meaning of CGRP_RELEASABLE to be set on any cgroup
that has ever had a task or cgroup in it, or had css_get called
on it. The bit is set in cgroup_attach_task, cgroup_create,
and __css_get. It is not necessary to set the bit in
cgroup_fork, as the task is either in the root cgroup, in
which can never be released, or the task it was forked from
already set the bit in croup_attach_task.
wall_to_monotonic
Change-Id: I9e9c3b923bf9a22ffd48f80a72050289496e57d8
Change-Id: I21366ace371d1b8f4684ddbe4ea8d555a926ac21
Signed-off-by: Colin Cross <ccross@google.com>
Platform must register cpu power function that return power in
milliWatt seconds.
Change-Id: I1caa0335e316c352eee3b1ddf326fcd4942bcbe8
Signed-off-by: Mike Chan <mike@android.com>
Introduce new platform callback hooks for cpuacct for tracking CPU frequencies
Not all platforms / architectures have a set CPU_FREQ_TABLE defined
for CPU transition speeds. In order to track time spent in at various
CPU frequencies, we enable platform callbacks from cpuacct for this accounting.
Architectures that support overclock boosting, or don't have pre-defined
frequency tables can implement their own bucketing system that makes sense
given their cpufreq scaling abilities.
New file:
cpuacct.cpufreq reports the CPU time (in nanoseconds) spent at each CPU
frequency.
Change-Id: I10a80b3162e6fff3a8a2f74dd6bb37e88b12ba96
This patch adds a notifier which can be used by subsystems that may
be interested in when a task has completely died and is about to
have it's last resource freed.
The Android lowmemory killer uses this to determine when a task
it has killed has finally given up its goods.
Signed-off-by: San Mehat <san@google.com>
When DEBUG_SUSPEND is enabled print active wakelocks when we check
if there are any active wakelocks.
In print_active_locks(), print expired wakelocks if DEBUG_EXPIRE is enabled
Change-Id: Ib1cb795555e71ff23143a2bac7c8a58cbce16547
If idx was non-zero and the log had wrapped, len did not get truncated
to stop at the last byte written to the log.
This reverts commit acff181d3574244e651913df77332e897b88bff4.
'can_attach' handler, then we fall back to doing our checks the old way.
This way non-root processes can add arbitrary processes to
a cgroup if all the registered subsystems on that cgroup agree.
Also change explicit euid == 0 check to CAP_SYS_ADMIN
Rather than signaling a full update of the display from userspace via a
console switch, this patch introduces 2 files int /sys/power,
wait_for_fb_sleep and wait_for_fb_wake. Reading these files will block
until the requested state has been entered. When a read from
wait_for_fb_sleep returns userspace should stop drawing. When
wait_for_fb_wake returns, it should do a full update. If either are called
when the fb driver is already in the requested state, they will return
immediately.
Signed-off-by: Rebecca Schultz <rschultz@google.com>
Signed-off-by: Arve Hjønnevåg <arve@android.com>
vt_waitactive now needs a 1 based console number
Change-Id: I07ab9a3773c93d67c09d928c8d5494ce823ffa2e
try_to_freeze_tasks after less than one second
Change-Id: Ib2976e5b97a5ee4ec9abd4d4443584d9257d0941
Avoids a problem where the device sometimes hangs for 20 seconds
before the screen is turned on.
This adds /sys/power/wake_lock and /sys/power/wake_unlock.
Writing a string to wake_lock creates a wake lock the
first time is sees a string and locks it. Optionally, the
string can be followed by a timeout.
To unlock the wake lock, write the same string to wake_unlock.
Change-Id: I66c6e3fe6487d17f9c2fafde1174042e57d15cd7
If EARLYSUSPEND is enabled then writes to /sys/power/state no longer
blocks, and the kernel will try to enter the requested state every
time no wakelocks are held. Write "on" to resume normal operation.
of stats.
Change-Id: I42ed8bea639684f7a8a95b2057516764075c6b01
Change-Id: Ic944e3b3d3bc53eddc6fd0963565fd072cac373c
PM: wakelock: Replace expire work with a timer
The expire work function did not work in the normal case.
This allows detection of init bugs in built-in drivers.
By default the kernel tries to keep half as much memory free at each
order as it does for one order below. This can be too agressive when
running without swap.
Change-Id: I5efc1a0b50f41ff3ac71e92d2efd175dedd54ead
Makes low-level printk work.
