Few of the notifier_chain_register() callers use __init in the definition
of notifier_call. It is incorrect as the function definition should be
available after the initializations (they do not unregister them during
initializations).
This patch fixes all such usages to _not_ have the notifier_call __init
section.
Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com>
Few of the notifier_chain_register() callers use __devinitdata in the
definition of notifier_block data structure. It is incorrect as the
data structure should be available after the initializations (they do
not unregister them during initializations).
This was leading to an oops when notifier_chain_register() call is
invoked for those callback chains after initialization.
This patch fixes all such usages to _not_ have the notifier_block data
structure in the init data section.
* 'for-linus' of git://brick.kernel.dk/data/git/linux-2.6-block:
[PATCH] block/elevator.c: remove unused exports
[PATCH] splice: fix smaller sized splice reads
[PATCH] Don't inherit ->splice_pipe across forks
[patch] cleanup: use blk_queue_stopped
[PATCH] Document online io scheduler switching
In cases where a struct kretprobe's *_handler fields are non-NULL, it is
possible to cause a system crash, due to the possibility of calls ending up
in zombie functions. Documentation clearly states that unused *_handlers
should be set to NULL, but kprobe users sometimes fail to do so.
Fix it by setting the non-relevant fields of the struct kretprobe to NULL.
Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Acked-by: Jim Keniston <jkenisto@us.ibm.com>
It's really task private, so clear that field on fork after copying
task structure.
Signed-off-by: Jens Axboe <axboe@suse.de>
Those also break userland regs like following.
00000000 <sys_chown16>:
0: 0f b7 44 24 0c movzwl 0xc(%esp),%eax
5: 83 ca ff or $0xffffffff,%edx
8: 0f b7 4c 24 08 movzwl 0x8(%esp),%ecx
d: 66 83 f8 ff cmp $0xffffffff,%ax
11: 0f 44 c2 cmove %edx,%eax
14: 66 83 f9 ff cmp $0xffffffff,%cx
18: 0f 45 d1 cmovne %ecx,%edx
1b: 89 44 24 0c mov %eax,0xc(%esp)
1f: 89 54 24 08 mov %edx,0x8(%esp)
23: e9 fc ff ff ff jmp 24 <sys_chown16+0x24>
where the tailcall at the end overwrites the incoming stack-frame.
Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
[ I would _really_ like to have a way to tell gcc about calling
conventions. The "prevent_tail_call()" macro is pretty ugly ]
The function free_pagedir() used by swsusp for freeing its internal data
structures clears the PG_nosave and PG_nosave_free flags for each page
being freed.
However, during resume PG_nosave_free set means that the page in
question is "unsafe" (ie. it will be overwritten in the process of
restoring the saved system state from the image), so it should not be
used for the image data.
Therefore free_pagedir() should not clear PG_nosave_free if it's called
during resume (otherwise "unsafe" pages freed by it may be used for
storing the image data and the data may get corrupted later on).
Acked-by: Pavel Machek <pavel@ucw.cz>
While we can currently walk through thread groups, process groups, and
sessions with just the rcu_read_lock, this opens the door to walking the
entire task list.
We already have all of the other RCU guarantees so there is no cost in
doing this, this should be enough so that proc can stop taking the
tasklist lock during readdir.
prev_task was killed because it has no users, and using it will miss new
tasks when doing an rcu traversal.
Somehow in the midst of dotting i's and crossing t's during
the merge up to rc1 we wound up keeping __put_task_struct_cb
when it should have been killed as it no longer has any users.
Sorry I probably should have caught this while it was
still in the -mm tree.
Having the old code there gets confusing when reading
through the code and trying to understand what is
happening.
Since the last user is removed in -mm, we can now remove this long deprecated
function.
Cc: Pavel Machek <pavel@ucw.cz>
This reverts most of commit 30e0fca6c1d7d26f3f2daa4dd2b12c51dadc778a.
It broke the case of non-leader MT exec when ptraced.
I think the bug it was intended to fix was already addressed by commit
788e05a67c343fa22f2ae1d3ca264e7f15c25eaf.
Signed-off-by: Roland McGrath <roland@redhat.com>
Acked-by: Oleg Nesterov <oleg@tv-sign.ru>
Commit e56d090310d7625ecb43a1eeebd479f04affb48b
[PATCH] RCU signal handling
made this BUG_ON() unsafe. This code runs under ->siglock,
while switch_exec_pids() takes tasklist_lock.
Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru>
* 'splice' of git://brick.kernel.dk/data/git/linux-2.6-block:
[PATCH] vfs: add splice_write and splice_read to documentation
[PATCH] Remove sys_ prefix of new syscalls from __NR_sys_*
[PATCH] splice: warning fix
[PATCH] another round of fs/pipe.c cleanups
[PATCH] splice: comment styles
[PATCH] splice: add Ingo as addition copyright holder
[PATCH] splice: unlikely() optimizations
[PATCH] splice: speedups and optimizations
[PATCH] pipe.c/fifo.c code cleanups
[PATCH] get rid of the PIPE_*() macros
[PATCH] splice: speedup __generic_file_splice_read
[PATCH] splice: add direct fd <-> fd splicing support
[PATCH] splice: add optional input and output offsets
[PATCH] introduce a "kernel-internal pipe object" abstraction
[PATCH] splice: be smarter about calling do_page_cache_readahead()
[PATCH] splice: optimize the splice buffer mapping
[PATCH] splice: cleanup __generic_file_splice_read()
[PATCH] splice: only call wake_up_interruptible() when we really have to
[PATCH] splice: potential !page dereference
[PATCH] splice: mark the io page as accessed
Add a cpu_relax() to the hand-coded spinwait in hrtimer_cancel().
Signed-off-by: Joe Korty <joe.korty@ccur.com>
Implement the scheduled unexport of panic_timeout.
We need the boot CPU's tvec_bases[] entry to be initialised super-early in
boot, for early_serial_setup(). That runs within setup_arch(), before even
per-cpu areas are initialised.
The patch changes tvec_bases to use compile-time initialisation, and adds a
separate array `tvec_base_done' to keep track of which CPU has had its
tvec_bases[] entry initialised (because we can no longer use the zeroness of
that tvec_bases[] entry to determine whether it has been initialised).
Thanks to Eugene Surovegin <ebs@ebshome.net> for diagnosing this.
Cc: Eugene Surovegin <ebs@ebshome.net>
Cc: Jan Beulich <jbeulich@novell.com>
up unneeded macros
For some architectures, a few syscalls are not linked in noMMU mode. In
that case, the MMU depending syscalls are needed to be defined as
'cond_syscall'. For example, ARM architecture selectively links sys_mlock
by the mode configuration.
In case of FRV, it has been managed by #ifdef CONFIG_MMU macro in
arch/frv/kernel/entry.S. However these conditional macros are just
duplicates if they were defined as cond_syscall. Compilation test is done
with FRV toolchains for both of MMU and noMMU mode.
Signed-off-by: Hyok S. Choi <hyok.choi@samsung.com>
RT tasks are being awakened on the expired array when expired_starving() is
true, whereas they really should be excluded. Fix.
Signed-off-by: Mike Galbraith <efault@gmx.de>
Cc: Con Kolivas <kernel@kolivas.org>
Fix a starvation problem that occurs when a stream of highly interactive tasks
delay an array switch for extended periods despite EXPIRED_STARVING(rq) being
true. AFAIKT, the only choice is to enqueue awakening tasks on the expired
array in this case.
Without this patch, it can be nearly impossible to remotely login to a busy
server, and interactive shell commands can starve for minutes.
Also, convert the EXPIRED_STARVING macro into an inline function which humans
can understand.
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Acked-by: Con Kolivas <kernel@kolivas.org>
It's more efficient for sendfile() emulation. Basically we cache an
internal private pipe and just use that as the intermediate area for
pages. Direct splicing is not available from sys_splice(), it is only
meant to be used for sendfile() emulation.
Additional patch from Ingo Molnar to avoid the PIPE_BUFFERS loop at
exit for the normal fast path.
If the HPET timer is enabled, the clock can drift by ~3 seconds a day.
This is due to the HPET timer not being initialized with the correct
setting (still using PIT count).
If HZ changes, this drift can become even more pronounced.
HPET patch initializes tick_nsec with correct tick_nsec settings for
HPET timer.
Vojtech comments:
"It's not entirely correct (it assumes the HPET ticks totally
exactly), but it's significantly better than assuming the PIT error
there."
Signed-off-by: Andi Kleen <ak@suse.de>
this changes if() BUG(); constructs to BUG_ON() which is
cleaner, contains unlikely() and can better optimized away.
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de>
I was grepping through the code and some `grep ganularity -R .` didn't
catch what I thought. Then looking closer I saw the term "granuality"
used in only four places (in comments) and granularity in many more
places describing the same idea. Some other facts:
dictionary.com does not know such a word
define:granuality on google is not found (and pages for granuality are
mostly related to patches to the kernel)
it has not been discussed as a term on LKML, AFAICS (=Can Search)
To be consistent, I think granularity should be used everywhere.
Signed-off-by: Kalin KOZHUHAROV <kalin@thinrope.net>
The note that SOFTWARE_SUSPEND doesn't need APM is helpful, but nowadays
the information that it doesn't need ACPI, too, is even more helpful.
Wrong error path in dup_fd() - it should return NULL on error,
not an address of already freed memory :/
Triggered by OpenVZ stress test suite.
What is interesting is that it was causing different oopses in RCU like
below:
Call Trace:
[<c013492c>] rcu_do_batch+0x2c/0x80
[<c0134bdd>] rcu_process_callbacks+0x3d/0x70
[<c0126cf3>] tasklet_action+0x73/0xe0
[<c01269aa>] __do_softirq+0x10a/0x130
[<c01058ff>] do_softirq+0x4f/0x60
[<c0113817>] smp_apic_timer_interrupt+0x77/0x110
[<c0103b54>] apic_timer_interrupt+0x1c/0x24
Code: Bad EIP value.
<0>Kernel panic - not syncing: Fatal exception in interrupt
Signed-Off-By: Pavel Emelianov <xemul@sw.ru>
Signed-Off-By: Dmitry Mishin <dim@openvz.org>
Signed-Off-By: Kirill Korotaev <dev@openvz.org>
Signed-Off-By: Linus Torvalds <torvalds@osdl.org>
Simplifies the code, reduces the need for 4 pid hash tables, and makes the
code more capable.
In the discussions I had with Oleg it was felt that to a large extent the
cleanup itself justified the work. With struct pid being dynamically
allocated meant we could create the hash table entry when the pid was
allocated and free the hash table entry when the pid was freed. Instead of
playing with the hash lists when ever a process would attach or detach to a
process.
For myself the fact that it gave what my previous task_ref patch gave for free
with simpler code was a big win. The problem is that if you hold a reference
to struct task_struct you lock in 10K of low memory. If you do that in a user
controllable way like /proc does, with an unprivileged but hostile user space
application with typical resource limits of 1000 fds and 100 processes I can
trigger the OOM killer by consuming all of low memory with task structs, on a
machine wight 1GB of low memory.
If I instead hold a reference to struct pid which holds a pointer to my
task_struct, I don't suffer from that problem because struct pid is 2 orders
of magnitude smaller. In fact struct pid is small enough that most other
kernel data structures dwarf it, so simply limiting the number of referring
data structures is enough to prevent exhaustion of low memory.
This splits the current struct pid into two structures, struct pid and struct
pid_link, and reduces our number of hash tables from PIDTYPE_MAX to just one.
struct pid_link is the per process linkage into the hash tables and lives in
struct task_struct. struct pid is given an indepedent lifetime, and holds
pointers to each of the pid types.
The independent life of struct pid simplifies attach_pid, and detach_pid,
because we are always manipulating the list of pids and not the hash table.
In addition in giving struct pid an indpendent life it makes the concept much
more powerful.
Kernel data structures can now embed a struct pid * instead of a pid_t and
not suffer from pid wrap around problems or from keeping unnecessarily
large amounts of memory allocated.
A big problem with rcu protected data structures that are also reference
counted is that you must jump through several hoops to increase the reference
count. I think someone finally implemented atomic_inc_not_zero(&count) to
automate the common case. Unfortunately this means you must special case the
rcu access case.
When data structures are only visible via rcu in a manner that is not
determined by the reference count on the object (i.e. tasks are visible until
their zombies are reaped) there is a much simpler technique we can employ.
Simply delaying the decrement of the reference count until the rcu interval is
over.
What that means is that the proc code that looks up a task and later
wants to sleep can now do:
rcu_read_lock();
task = find_task_by_pid(some_pid);
if (task) {
get_task_struct(task);
rcu_read_unlock();
The effect on the rest of the kernel is that put_task_struct becomes cheaper
and immediate, and in the case where the task has been reaped it frees the
task immediate instead of unnecessarily waiting an until the rcu interval is
over.
Cleanup of task_struct does not happen when its reference count drops to
zero, instead cleanup happens when release_task is called. Tasks can only
be looked up via rcu before release_task is called. All rcu protected
members of task_struct are freed by release_task.
Therefore we can move call_rcu from put_task_struct into release_task. And
we can modify release_task to not immediately release the reference count
but instead have it call put_task_struct from the function it gives to
call_rcu.
The end result:
- get_task_struct is safe in an rcu context where we have just looked
up the task.
- put_task_struct() simplifies into its old pre rcu self.
This reorganization also makes put_task_struct uncallable from modules as
it is not exported but it does not appear to be called from any modules so
this should not be an issue, and is trivially fixed.
This just got nuked in mainline. Bring it back because Eric's patches use it.
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
The core problem: setsid fails if it is called by init. The effect in 2.6.16
and the earlier kernels that have this problem is that if you do a "ps -j 1 or
ps -ej 1" you will see that init and several of it's children have process
group and session == 0. Instead of process group == session == 1. Despite
init calling setsid.
The reason it fails is that daemonize calls set_special_pids(1,1) on kernel
threads that are launched before /sbin/init is called.
The only remaining effect in that current->signal->leader == 0 for init
instead of 1. And the setsid call fails. No one has noticed because
/sbin/init does not check the return value of setsid.
In 2.4 where we don't have the pidhash table, and daemonize doesn't exist
setsid actually works for init.
I care a lot about pid == 1 not being a special case that we leave broken,
because of the container/jail work that I am doing.
- Carefully allow init (pid == 1) to call setsid despite the kernel using
its session.
- Use find_task_by_pid instead of find_pid because find_pid taking a
pidtype is going away.
The futex timeval is not checked for correctness. The change does not
break existing applications as the timeval is supplied by glibc (and glibc
always passes a correct value), but the glibc-internal tests for this
functionality fail.
Signed-off-by: Thomas Gleixner <tglx@tglx.de>
To increase the strength of SCHED_BATCH as a scheduling hint we can
activate batch tasks on the expired array since by definition they are
latency insensitive tasks.
Signed-off-by: Con Kolivas <kernel@kolivas.org>
On runqueue time is used to elevate priority in schedule().
In the code it currently requeues tasks even if their priority is not
elevated, which would end up placing them at the end of their runqueue
array effectively delaying them instead of improving their priority.
Bug spotted by Mike Galbraith <efault@gmx.de>
This patch removes this requeueing.
Tasks waiting in SLEEP_NONINTERACTIVE state can now get to best priority so
they need to be included in the idle detection code.
We watch for tasks that sleep extended periods and don't allow one single
prolonged sleep period from elevating priority to maximum bonus to prevent cpu
bound tasks from getting high priority with single long sleeps. There is a
bug in the current code that also penalises tasks that already have high
priority. Correct that bug.
Alterations to the pipe code in the kernel made it possible for relative
starvation to occur with tasks that slept waiting on a pipe getting unfair
priority bonuses even if they were otherwise fully cpu bound so the
TASK_NONINTERACTIVE flag was introduced which prevented any change to
sleep_avg while sleeping waiting on a pipe. This change also leads to the
converse though, preventing any priority boost from occurring in truly
interactive tasks that wait on pipes.
Convert the TASK_NONINTERACTIVE flag to set sleep_type to SLEEP_NONINTERACTIVE
which will allow a linear bonus to priority based on sleep time thus allowing
interactive tasks to get high priority if they sleep enough.
The activated flag in task_struct is used to track different sleep types and
its usage is somewhat obfuscated. Convert the variable to an enum with more
descriptive names without altering the function.
Currently, count_active_tasks() calls both nr_running() &
nr_interruptible(). Each of these functions does a "for_each_cpu" & reads
values from the runqueue of each cpu. Although this is not a lot of
instructions, each runqueue may be located on different node. Depending on
the architecture, a unique TLB entry may be required to access each
runqueue.
Since there may be more runqueues than cpu TLB entries, a scan of all
runqueues can trash the TLB. Each memory reference incurs a TLB miss &
refill.
In addition, the runqueue cacheline that contains nr_running &
nr_uninterruptible may be evicted from the cache between the two passes.
This causes unnecessary cache misses.
Combining nr_running() & nr_interruptible() into a single function
substantially reduces the TLB & cache misses on large systems. This should
have no measureable effect on smaller systems.
On a 128p IA64 system running a memory stress workload, the new function
reduced the overhead of calc_load() from 605 usec/call to 324 usec/call.
Signed-off-by: Jack Steiner <steiner@sgi.com>
run_hrtimer_queue()
It seems that run_hrtimer_queue() is calling get_softirq_time() more
often than it needs to.
With this patch, it only calls get_softirq_time() if there's a
pending timer.
Signed-off-by: Dimitri Sivanich <sivanich@sgi.com>
Replace the nanosleep private sleeper functionality by the generic hrtimer
sleeper.
The removal of the data field in the hrtimer structure enforces the
embedding of the timer into another data structure. nanosleep now uses a
private implementation of the most common used timer callback function
(simple task wakeup).
In order to avoid the reimplentation of such functionality all over the
place a generic hrtimer_sleeper functionality is created.
One of the LEDs driver files wants to use this.
Probably drivers/mtd/maps/ipaq-flash.c wants to convert as well - right now
it'll be tainting the kernel.
Cc: John Bowler <jbowler@acm.org>
Cc: "'Richard Purdie'" <rpurdie@rpsys.net>
Fix memory migration so that it works regardless of what cpuset the invoking
task is in.
If a task invoked a memory migration, by doing one of:
1) writing a different nodemask to a cpuset 'mems' file, or
2) writing a tasks pid to a different cpuset's 'tasks' file,
where the cpuset had its 'memory_migrate' option turned on, then the
allocation of the new pages for the migrated task(s) was constrained
by the invoking tasks cpuset.
If this task wasn't in a cpuset that allowed the requested memory nodes, the
memory migration would happen to some other nodes that were in that invoking
tasks cpuset. This was usually surprising and puzzling behaviour: Why didn't
the pages move? Why did the pages move -there-?
To fix this, temporarilly change the invoking tasks 'mems_allowed' task_struct
field to the nodes the migrating tasks is moving to, so that new pages can be
allocated there.
Signed-off-by: Paul Jackson <pj@sgi.com>
Acked-by: Christoph Lameter <clameter@sgi.com>
