commit 9ec84acee1e221d99dc33237bff5e82839d10cc0 upstream.
We do want to allow lock debugging for GPL-compatible modules
that are not (yet) built in-tree. This was disabled as a
side-effect of commit 2449b8ba0745327c5fa49a8d9acffe03b2eded69
('module,bug: Add TAINT_OOT_MODULE flag for modules not built
in-tree'). Lock debug warnings now include taint flags, so
kernel developers should still be able to deflect warnings
caused by out-of-tree modules.
The TAINT_PROPRIETARY_MODULE flag for non-GPL-compatible modules
will still disable lock debugging.
Cc: Nick Bowler <nbowler@elliptictech.com>
Cc: Dave Jones <davej@redhat.com>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Cc: Debian kernel maintainers <debian-kernel@lists.debian.org>
Cc: Alan Cox <alan@linux.intel.com>
Link: http://lkml.kernel.org/r/1323268258.18450.11.camel@deadeye
commit df754e6af2f237a6c020c0daff55a1a609338e31 upstream.
It's unlikely that TAINT_FIRMWARE_WORKAROUND causes false
lockdep messages, so do not disable lockdep in that case.
We still want to keep lockdep disabled in the
TAINT_OOT_MODULE case:
- bin-only modules can cause various instabilities in
their and in unrelated kernel code
- they are impossible to debug for kernel developers
- they also typically do not have the copyright license
permission to link to the GPL-ed lockdep code.
Suggested-by: Ben Hutchings <ben@decadent.org.uk>
Link: http://lkml.kernel.org/n/tip-xopopjjens57r0i13qnyh2yo@git.kernel.org
commit fe9161db2e6053da21e4649d77bbefaf3030b11d upstream.
In the SNAPSHOT_CREATE_IMAGE ioctl, if the call to hibernation_snapshot()
fails, the frozen tasks are not thawed.
And in the case of success, if we happen to exit due to a successful freezer
test, all tasks (including those of userspace) are thawed, whereas actually
we should have thawed only the kernel threads at that point. Fix both these
issues.
Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
commit 97819a26224f019e73d88bb2fd4eb5a614860461 upstream.
Commit 2aede851ddf08666f68ffc17be446420e9d2a056 (PM / Hibernate: Freeze
kernel threads after preallocating memory) moved the freezing of kernel
threads to hibernation_snapshot() function.
So now, if the call to hibernation_snapshot() returns early due to a
successful hibernation test, the caller has to thaw processes to ensure
that the system gets back to its original state.
But in SNAPSHOT_CREATE_IMAGE hibernation ioctl, the caller does not thaw
processes in case hibernation_snapshot() returned due to a successful
freezer test. Fix this issue. But note we still send the value of 'in_suspend'
(which is now 0) to userspace, because we are not in an error path per-se,
and moreover, the value of in_suspend correctly depicts the situation here.
commit cb297a3e433dbdcf7ad81e0564e7b804c941ff0d upstream.
This issue happens under the following conditions:
1. preemption is off
2. __ARCH_WANT_INTERRUPTS_ON_CTXSW is defined
3. RT scheduling class
4. SMP system
Sequence is as follows:
1.suppose current task is A. start schedule()
2.task A is enqueued pushable task at the entry of schedule()
__schedule
prev = rq->curr;
put_prev_task
put_prev_task_rt
enqueue_pushable_task
4.pick the task B as next task.
next = pick_next_task(rq);
3.rq->curr set to task B and context_switch is started.
rq->curr = next;
4.At the entry of context_swtich, release this cpu's rq->lock.
context_switch
prepare_task_switch
prepare_lock_switch
raw_spin_unlock_irq(&rq->lock);
5.Shortly after rq->lock is released, interrupt is occurred and start IRQ context
6.try_to_wake_up() which called by ISR acquires rq->lock
try_to_wake_up
ttwu_remote
rq = __task_rq_lock(p)
ttwu_do_wakeup(rq, p, wake_flags);
task_woken_rt
7.push_rt_task picks the task A which is enqueued before.
task_woken_rt
push_rt_tasks(rq)
next_task = pick_next_pushable_task(rq)
8.At find_lock_lowest_rq(), If double_lock_balance() returns 0,
lowest_rq can be the remote rq.
(But,If preemption is on, double_lock_balance always return 1 and it
does't happen.)
push_rt_task
find_lock_lowest_rq
if (double_lock_balance(rq, lowest_rq))..
9.find_lock_lowest_rq return the available rq. task A is migrated to
the remote cpu/rq.
push_rt_task
deactivate_task(rq, next_task, 0);
set_task_cpu(next_task, lowest_rq->cpu);
activate_task(lowest_rq, next_task, 0);
10. But, task A is on irq context at this cpu.
So, task A is scheduled by two cpus at the same time until restore from IRQ.
Task A's stack is corrupted.
To fix it, don't migrate an RT task if it's still running.
Signed-off-by: Chanho Min <chanho.min@lge.com>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Link: http://lkml.kernel.org/r/CAOAMb1BHA=5fm7KTewYyke6u-8DP0iUuJMpgQw54vNeXFsGpoQ@mail.gmail.com
commit 181e9bdef37bfcaa41f3ab6c948a2a0d60a268b5 upstream.
PM / Hibernate: Freeze kernel threads after preallocating memory
introduced a mechanism by which kernel threads were frozen after
the preallocation of hibernate image memory to avoid problems with
frozen kernel threads not responding to memory freeing requests.
However, it overlooked the s2disk code path in which the
SNAPSHOT_CREATE_IMAGE ioctl was run directly after SNAPSHOT_FREE,
which caused freeze_workqueues_begin() to BUG(), because it saw
that worqueues had been already frozen.
Although in principle this issue might be addressed by removing
the relevant BUG_ON() from freeze_workqueues_begin(), that would
reintroduce the very problem that commit 2aede851ddf08666f68ffc17be4
attempted to avoid into that particular code path. For this reason,
to fix the issue at hand, introduce thaw_kernel_threads() and make
the SNAPSHOT_FREE ioctl execute it.
Special thanks to Srivatsa S. Bhat for detailed analysis of the
problem.
Reported-and-tested-by: Jiri Slaby <jslaby@suse.cz>
Acked-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
commit 55ca6140e9bb307efc97a9301a4f501de02a6fd6 upstream.
In function pre_handler_kretprobe(), the allocated kretprobe_instance
object will get leaked if the entry_handler callback returns non-zero.
This may cause all the preallocated kretprobe_instance objects exhausted.
This issue can be reproduced by changing
samples/kprobes/kretprobe_example.c to probe "mutex_unlock". And the fix
is straightforward: just put the allocated kretprobe_instance object back
onto the free_instances list.
[akpm@linux-foundation.org: use raw_spin_lock/unlock]
Signed-off-by: Jiang Liu <jiang.liu@huawei.com>
Acked-by: Jim Keniston <jkenisto@us.ibm.com>
Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com>
commit d496aab567e7e52b3e974c9192a5de6e77dce32c upstream.
Commit ef53d9c5e ("kprobes: improve kretprobe scalability with hashed
locking") introduced a bug where we can potentially leak
kretprobe_instances since we initialize a hlist head after having used
it.
Initialize the hlist head before using it.
Reported by: Jim Keniston <jkenisto@us.ibm.com>
Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: Srinivasa D S <srinivasa@in.ibm.com>
commit c10076c4304083af15a41f6bc5e657e781c1f9a6 upstream.
Tracepoints are disabled for tainted modules, which is usually because the
module is either proprietary or was forced, and we don't want either of them
using kernel tracepoints.
But, a module can also be tainted by being in the staging directory or
compiled out of tree. Either is fine for use with tracepoints, no need
to punish them. I found this out when I noticed that my sample trace event
module, when done out of tree, stopped working.
Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Cc: Ben Hutchings <ben@decadent.org.uk>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
commit 30fb6aa74011dcf595f306ca2727254d708b786e upstream.
Multiple users of the function tracer can register their functions
with the ftrace_ops structure. The accounting within ftrace will
update the counter on each function record that is being traced.
When the ftrace_ops filtering adds or removes functions, the
function records will be updated accordingly if the ftrace_ops is
still registered.
When a ftrace_ops is removed, the counter of the function records,
that the ftrace_ops traces, are decremented. When they reach zero
the functions that they represent are modified to stop calling the
mcount code.
When changes are made, the code is updated via stop_machine() with
a command passed to the function to tell it what to do. There is an
ENABLE and DISABLE command that tells the called function to enable
or disable the functions. But the ENABLE is really a misnomer as it
should just update the records, as records that have been enabled
and now have a count of zero should be disabled.
The DISABLE command is used to disable all functions regardless of
their counter values. This is the big off switch and is not the
complement of the ENABLE command.
To make matters worse, when a ftrace_ops is unregistered and there
is another ftrace_ops registered, neither the DISABLE nor the
ENABLE command are set when calling into the stop_machine() function
and the records will not be updated to match their counter. A command
is passed to that function that will update the mcount code to call
the registered callback directly if it is the only one left. This
means that the ftrace_ops that is still registered will have its callback
called by all functions that have been set for it as well as the ftrace_ops
that was just unregistered.
Here's a way to trigger this bug. Compile the kernel with
CONFIG_FUNCTION_PROFILER set and with CONFIG_FUNCTION_GRAPH not set:
CONFIG_FUNCTION_PROFILER=y
# CONFIG_FUNCTION_GRAPH is not set
This will force the function profiler to use the function tracer instead
of the function graph tracer.
# cd /sys/kernel/debug/tracing
# echo schedule > set_ftrace_filter
# echo function > current_tracer
# cat set_ftrace_filter
schedule
# cat trace
# tracer: nop
# entries-in-buffer/entries-written: 692/68108025 #P:4
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/0:2-909 [000] .... 531.235574: schedule <-worker_thread
<idle>-0 [001] .N.. 531.235575: schedule <-cpu_idle
kworker/0:2-909 [000] .... 531.235597: schedule <-worker_thread
sshd-2563 [001] .... 531.235647: schedule <-schedule_hrtimeout_range_clock
# echo 1 > function_profile_enabled
# echo 0 > function_porfile_enabled
schedule
# cat trace
# tracer: function
# entries-in-buffer/entries-written: 159701/118821262 #P:4
# _-----=> irqs-off
# ||| / delay
<idle>-0 [002] ...1 604.870655: local_touch_nmi <-cpu_idle
<idle>-0 [002] d..1 604.870655: enter_idle <-cpu_idle
<idle>-0 [002] d..1 604.870656: atomic_notifier_call_chain <-enter_idle
<idle>-0 [002] d..1 604.870656: __atomic_notifier_call_chain <-atomic_notifier_call_chain
The same problem could have happened with the trace_probe_ops,
but they are modified with the set_frace_filter file which does the
update at closure of the file.
The simple solution is to change ENABLE to UPDATE and call it every
time an ftrace_ops is unregistered.
Link: http://lkml.kernel.org/r/1323105776-26961-3-git-send-email-jolsa@redhat.com
Signed-off-by: Jiri Olsa <jolsa@redhat.com>
commit 0d19ea866562e46989412a0676412fa0983c9ce7 upstream.
If we mount a hierarchy with a specified name, the name is unique,
and we can use it to mount the hierarchy without specifying its
set of subsystem names. This feature is documented is
Documentation/cgroups/cgroups.txt section 2.3
Here's an example:
# mount -t cgroup -o cpuset,name=myhier xxx /cgroup1
# mount -t cgroup -o name=myhier xxx /cgroup2
But it was broken by commit 32a8cf235e2f192eb002755076994525cdbaa35a
(cgroup: make the mount options parsing more accurate)
This fixes the regression.
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
This is the temporary simple fix for 3.2, we need more changes in this
area.
1. do_signal_stop() assumes that the running untraced thread in the
stopped thread group is not possible. This was our goal but it is
not yet achieved: a stopped-but-resumed tracee can clone the running
thread which can initiate another group-stop.
Remove WARN_ON_ONCE(!current->ptrace).
2. A new thread always starts with ->jobctl = 0. If it is auto-attached
and this group is stopped, __ptrace_unlink() sets JOBCTL_STOP_PENDING
but JOBCTL_STOP_SIGMASK part is zero, this triggers WANR_ON(!signr)
in do_jobctl_trap() if another debugger attaches.
Change __ptrace_unlink() to set the artificial SIGSTOP for report.
Alternatively we could change ptrace_init_task() to copy signr from
current, but this means we can copy it for no reason and hide the
possible similar problems.
Acked-by: Tejun Heo <tj@kernel.org>
Cc: <stable@kernel.org> [3.1]
Test-case:
int main(void)
int pid, status;
pid = fork();
if (!pid) {
for (;;) {
if (!fork())
return 0;
if (waitpid(-1, &status, 0) < 0) {
printf("ERR!! wait: %m\n");
return 0;
assert(ptrace(PTRACE_ATTACH, pid, 0,0) == 0);
assert(waitpid(-1, NULL, 0) == pid);
assert(ptrace(PTRACE_SETOPTIONS, pid, 0,
PTRACE_O_TRACEFORK) == 0);
do {
ptrace(PTRACE_CONT, pid, 0, 0);
pid = waitpid(-1, NULL, 0);
} while (pid > 0);
return 1;
It fails because ->real_parent sees its child in EXIT_DEAD state
while the tracer is going to change the state back to EXIT_ZOMBIE
in wait_task_zombie().
The offending commit is 823b018e which moved the EXIT_DEAD check,
but in fact we should not blame it. The original code was not
correct as well because it didn't take ptrace_reparented() into
account and because we can't really trust ->ptrace.
This patch adds the additional check to close this particular
race but it doesn't solve the whole problem. We simply can't
rely on ->ptrace in this case, it can be cleared if the tracer
is multithreaded by the exiting ->parent.
I think we should kill EXIT_DEAD altogether, we should always
remove the soon-to-be-reaped child from ->children or at least
we should never do the DEAD->ZOMBIE transition. But this is too
complex for 3.2.
Reported-and-tested-by: Denys Vlasenko <vda.linux@googlemail.com>
Tested-by: Lukasz Michalik <lmi@ift.uni.wroc.pl>
Cc: <stable@kernel.org> [3.0+]
vfork parent uninterruptibly and unkillably waits for its child to
exec/exit. This wait is of unbounded length. Ignore such waits
in the hung_task detector.
Signed-off-by: Mandeep Singh Baines <msb@chromium.org>
Reported-by: Sasha Levin <levinsasha928@gmail.com>
LKML-Reference: <1325344394.28904.43.camel@lappy>
Cc: John Kacur <jkacur@redhat.com>
Cc: stable@kernel.org
It was found (by Sasha) that if you use a futex located in the gate
area we get stuck in an uninterruptible infinite loop, much like the
ZERO_PAGE issue.
While looking at this problem, PeterZ realized you'll get into similar
trouble when hitting any install_special_pages() mapping. And are there
still drivers setting up their own special mmaps without page->mapping,
and without special VM or pte flags to make get_user_pages fail?
In most cases, if page->mapping is NULL, we do not need to retry at all:
Linus points out that even /proc/sys/vm/drop_caches poses no problem,
because it ends up using remove_mapping(), which takes care not to
interfere when the page reference count is raised.
But there is still one case which does need a retry: if memory pressure
called shmem_writepage in between get_user_pages_fast dropping page
table lock and our acquiring page lock, then the page gets switched from
filecache to swapcache (and ->mapping set to NULL) whatever the refcount.
Fault it back in to get the page->mapping needed for key->shared.inode.
Cc: stable@vger.kernel.org
This reverts commit de28f25e8244c7353abed8de0c7792f5f883588c.
It results in resume problems for various people. See for example
http://thread.gmane.org/gmane.linux.kernel/1233033
http://thread.gmane.org/gmane.linux.kernel/1233389
http://thread.gmane.org/gmane.linux.kernel/1233159
http://thread.gmane.org/gmane.linux.kernel/1227868/focus=1230877
and the fedora and ubuntu bug reports
https://bugzilla.redhat.com/show_bug.cgi?id=767248
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/904569
which got bisected down to the stable version of this commit.
Reported-by: Jonathan Nieder <jrnieder@gmail.com>
Reported-by: Phil Miller <mille121@illinois.edu>
Reported-by: Philip Langdale <philipl@overt.org>
Reported-by: Tim Gardner <tim.gardner@canonical.com>
Cc: Greg KH <gregkh@suse.de>
Cc: stable@kernel.org # for stable kernels that applied the original
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup
* 'for-3.2-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup:
cgroups: fix a css_set not found bug in cgroup_attach_proc
* 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
time/clocksource: Fix kernel-doc warnings
rtc: m41t80: Workaround broken alarm functionality
rtc: Expire alarms after the time is set.
binary_sysctl() calls sysctl_getname() which allocates from names_cache
slab usin __getname()
The matching function to free the name is __putname(), and not putname()
which should be used only to match getname() allocations.
This is because when auditing is enabled, putname() calls audit_putname
*instead* (not in addition) to __putname(). Then, if a syscall is in
progress, audit_putname does not release the name - instead, it expects
the name to get released when the syscall completes, but that will happen
only if audit_getname() was called previously, i.e. if the name was
allocated with getname() rather than the naked __getname(). So,
__getname() followed by putname() ends up leaking memory.
Signed-off-by: Michel Lespinasse <walken@google.com>
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
Cc: Eric Paris <eparis@redhat.com>
Cc: <stable@vger.kernel.org>
Kernels where MAX_NUMNODES > BITS_PER_LONG may temporarily see an empty
nodemask in a tsk's mempolicy if its previous nodemask is remapped onto a
new set of allowed cpuset nodes where the two nodemasks, as a result of
the remap, are now disjoint.
c0ff7453bb5c ("cpuset,mm: fix no node to alloc memory when changing
cpuset's mems") adds get_mems_allowed() to prevent the set of allowed
nodes from changing for a thread. This causes any update to a set of
allowed nodes to stall until put_mems_allowed() is called.
This stall is unncessary, however, if at least one node remains unchanged
in the update to the set of allowed nodes. This was addressed by
89e8a244b97e ("cpusets: avoid looping when storing to mems_allowed if one
node remains set"), but it's still possible that an empty nodemask may be
read from a mempolicy because the old nodemask may be remapped to the new
nodemask during rebind. To prevent this, only avoid the stall if there is
no mempolicy for the thread being changed.
This is a temporary solution until all reads from mempolicy nodemasks can
be guaranteed to not be empty without the get_mems_allowed()
synchronization.
Also moves the check for nodemask intersection inside task_lock() so that
tsk->mems_allowed cannot change. This ensures that nothing can set this
tsk's mems_allowed out from under us and also protects tsk->mempolicy.
Reported-by: Miao Xie <miaox@cn.fujitsu.com>
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Paul Menage <paul@paulmenage.org>
There is a BUG when migrating a PF_EXITING proc. Since css_set_prefetch()
is not called for the PF_EXITING case, find_existing_css_set() will return
NULL inside cgroup_task_migrate() causing a BUG.
This bug is easy to reproduce. Create a zombie and echo its pid to
cgroup.procs.
$ cat zombie.c
\#include <unistd.h>
int main()
if (fork())
pause();
return 0;
We are hitting this bug pretty regularly on ChromeOS.
This bug is already fixed by Tejun Heo's cgroup patchset which is
targetted for the next merge window:
https://lkml.org/lkml/2011/11/1/356
I've create a smaller patch here which just fixes this bug so that a
fix can be merged into the current release and stable.
Downstream-Bug-Report: http://crosbug.com/23953
Reviewed-by: Li Zefan <lizf@cn.fujitsu.com>
Cc: containers@lists.linux-foundation.org
Cc: cgroups@vger.kernel.org
Cc: Olof Johansson <olofj@chromium.org>
Fix various KernelDoc build warnings.
Signed-off-by: Kusanagi Kouichi <slash@ac.auone-net.jp>
Cc: John Stultz <johnstul@us.ibm.com>
Link: http://lkml.kernel.org/r/20111219091320.0D5AF6FC03D@msa105.auone-net.jp
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf events: Fix ring_buffer_wakeup() brown paperbag bug
* 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
sched: Fix select_idle_sibling() regression in selecting an idle SMT sibling
MAINTAINERS: Update tip.git related git trees
Mike Galbraith reported that this recent commit:
commit 4dcfe1025b513c2c1da5bf5586adb0e80148f612
Author: Peter Zijlstra <peterz@infradead.org>
Date: Thu Nov 10 13:01:10 2011 +0100
sched: Avoid SMT siblings in select_idle_sibling() if possible
stopped selecting an idle SMT sibling when there are no idle
cores in a single socket system.
Intent of the select_idle_sibling() was to fallback to an idle
SMT sibling, if it fails to identify an idle core. But this
fallback was not happening on systems where all the scheduler
domains had `SD_SHARE_PKG_RESOURCES' flag set.
Fix it. Slightly bigger patch of cleaning all these goto's etc
is queued up for the next release.
Reported-by: Mike Galbraith <efault@gmx.de>
Reported-by: Alex Shi <alex.shi@intel.com>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Link: http://lkml.kernel.org/r/1323978421.1984.244.camel@sbsiddha-desk.sc.intel.com
Commit 10c6db11 ("perf: Fix loss of notification with multi-event")
seems to unconditionally dereference event->rb in the wakeup handler,
this is wrong, there might not be a buffer attached.
Link: http://lkml.kernel.org/r/20111213152651.GP20297@mudshark.cambridge.arm.com
[ minor edits ]
perf: Do no try to schedule task events if there are none
lockdep, kmemcheck: Annotate ->lock in lockdep_init_map()
perf header: Use event_name() to get an event name
perf stat: Failure with "Operation not supported"
In order to safely dereference current->real_parent inside an
rcu_read_lock, we need an rcu_dereference.
Cc: Pavel Emelyanov <xemul@openvz.org>
Commit 4f2a8d3cf5e ("printk: Fix console_sem vs logbuf_lock unlock race")
introduced another silly bug where we would want to acquire an already
held lock. Avoid this.
Reported-by: Andrea Arcangeli <aarcange@redhat.com>
alarmtimers: Fix time comparison
ptp: Fix clock_getres() implementation
perf_event_sched_in() shouldn't try to schedule task events if there
are none otherwise task's ctx->is_active will be set and will not be
cleared during sched_out. This will prevent newly added events from
being scheduled into the task context.
Fixes a boo-boo in commit 1d5f003f5a9 ("perf: Do not set task_ctx
pointer in cpuctx if there are no events in the context").
Signed-off-by: Gleb Natapov <gleb@redhat.com>
Link: http://lkml.kernel.org/r/20111122140821.GF2557@redhat.com
ftrace: Fix hash record accounting bug
perf: Fix parsing of __print_flags() in TP_printk()
jump_label: jump_label_inc may return before the code is patched
ftrace: Remove force undef config value left for testing
tracing: Restore system filter behavior
tracing: fix event_subsystem ref counting
Since commit f59de89 ("lockdep: Clear whole lockdep_map on initialization"),
lockdep_init_map() will clear all the struct. But it will break
lock_set_class()/lock_set_subclass(). A typical race condition
is like below:
CPU A CPU B
lock_set_subclass(lockA);
lock_set_class(lockA);
lockdep_init_map(lockA);
/* lockA->name is cleared */
memset(lockA);
__lock_acquire(lockA);
/* lockA->class_cache[] is cleared */
register_lock_class(lockA);
look_up_lock_class(lockA);
WARN_ON_ONCE(class->name !=
lock->name);
lock->name = name;
So restore to what we have done before commit f59de89 but annotate
->lock with kmemcheck_mark_initialized() to suppress the kmemcheck
warning reported in commit f59de89.
Reported-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Reported-by: Borislav Petkov <bp@alien8.de>
Suggested-by: Vegard Nossum <vegard.nossum@gmail.com>
Signed-off-by: Yong Zhang <yong.zhang0@gmail.com>
Cc: Tejun Heo <tj@kernel.org>
Link: http://lkml.kernel.org/r/20111109080451.GB8124@zhy
The expiry function compares the timer against current time and does
not expire the timer when the expiry time is >= now. That's wrong. If
the timer is set for now, then it must expire.
Make the condition expiry > now for breaking out the loop.
Acked-by: John Stultz <john.stultz@linaro.org>
perf, x86: Force IBS LVT offset assignment for family 10h
perf, x86: Disable PEBS on SandyBridge chips
trace_events_filter: Use rcu_assign_pointer() when setting ftrace_event_call->filter
perf session: Fix crash with invalid CPU list
perf python: Fix undefined symbol problem
perf/x86: Enable raw event access to Intel offcore events
perf: Don't use -ENOSPC for out of PMU resources
perf: Do not set task_ctx pointer in cpuctx if there are no events in the context
perf/x86: Fix PEBS instruction unwind
oprofile, x86: Fix crash when unloading module (nmi timer mode)
oprofile: Fix crash when unloading module (hr timer mode)
clockevents: Set noop handler in clockevents_exchange_device()
tick-broadcast: Stop active broadcast device when replacing it
clocksource: Fix bug with max_deferment margin calculation
rtc: Fix some bugs that allowed accumulating time drift in suspend/resume
rtc: Disable the alarm in the hardware
* 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
slab, lockdep: Fix silly bug
* 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
genirq: Fix race condition when stopping the irq thread
sched, x86: Avoid unnecessary overflow in sched_clock
sched: Fix buglet in return_cfs_rq_runtime()
sched: Set the command name of the idle tasks in SMP kernels
sched, rt: Provide means of disabling cross-cpu bandwidth sharing
sched: Document wait_for_completion_*() return values
sched_fair: Fix a typo in the comment describing update_sd_lb_stats
sched: Add a comment to effective_load() since it's a pain
If the set_ftrace_filter is cleared by writing just whitespace to
it, then the filter hash refcounts will be decremented but not
updated. This causes two bugs:
1) No functions will be enabled for tracing when they all should be
2) If the users clears the set_ftrace_filter twice, it will crash ftrace:
WARNING: at /home/rostedt/work/git/linux-trace.git/kernel/trace/ftrace.c:1384 __ftrace_hash_rec_update.part.27+0x157/0x1a7()
Modules linked in:
Pid: 2330, comm: bash Not tainted 3.1.0-test+ #32
Call Trace:
[<ffffffff81051828>] warn_slowpath_common+0x83/0x9b
[<ffffffff8105185a>] warn_slowpath_null+0x1a/0x1c
[<ffffffff810ba362>] __ftrace_hash_rec_update.part.27+0x157/0x1a7
[<ffffffff810ba6e8>] ? ftrace_regex_release+0xa7/0x10f
[<ffffffff8111bdfe>] ? kfree+0xe5/0x115
[<ffffffff810ba51e>] ftrace_hash_move+0x2e/0x151
[<ffffffff810ba6fb>] ftrace_regex_release+0xba/0x10f
[<ffffffff8112e49a>] fput+0xfd/0x1c2
[<ffffffff8112b54c>] filp_close+0x6d/0x78
[<ffffffff8113a92d>] sys_dup3+0x197/0x1c1
[<ffffffff8113a9a6>] sys_dup2+0x4f/0x54
[<ffffffff8150cac2>] system_call_fastpath+0x16/0x1b
---[ end trace 77a3a7ee73794a02 ]---
Link: http://lkml.kernel.org/r/20111101141420.GA4918@debian
Reported-by: Rabin Vincent <rabin@rab.in>
If cpu A calls jump_label_inc() just after atomic_add_return() is
called by cpu B, atomic_inc_not_zero() will return value greater then
zero and jump_label_inc() will return to a caller before jump_label_update()
finishes its job on cpu B.
Link: http://lkml.kernel.org/r/20111018175551.GH17571@redhat.com
Acked-by: Jason Baron <jbaron@redhat.com>
A forced undef of a config value was used for testing and was
accidently left in during the final commit. This causes x86 to
run slower than needed while running function tracing as well
as causes the function graph selftest to fail when DYNMAIC_FTRACE
is not set. This is because the code in MCOUNT expects the ftrace
code to be processed with the config value set that happened to
be forced not set.
The forced config option was left in by:
commit 6331c28c962561aee59e5a493b7556a4bb585957
ftrace: Fix dynamic selftest failure on some archs
Link: http://lkml.kernel.org/r/20111102150255.GA6973@debian
Though not all events have field 'prev_pid', it was allowed to do this:
# echo 'prev_pid == 100' > events/sched/filter
but commit 75b8e98263fdb0bfbdeba60d4db463259f1fe8a2 (tracing/filter: Swap
entire filter of events) broke it without any reason.
Link: http://lkml.kernel.org/r/4EAF46CF.8040408@cn.fujitsu.com
Fix a bug introduced by e9dbfae5, which prevents event_subsystem from
ever being released.
Ref_count was added to keep track of subsystem users, not for counting
events. Subsystem is created with ref_count = 1, so there is no need to
increment it for every event, we have nr_events for that. Fix this by
touching ref_count only when we actually have a new user -
subsystem_open().
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
Link: http://lkml.kernel.org/r/1320052062-7846-1-git-send-email-idryomov@gmail.com
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace into perf/urgent
When you do:
$ perf record -e cycles,cycles,cycles noploop 10
You expect about 10,000 samples for each event, i.e., 10s at
1000samples/sec. However, this is not what's happening. You
get much fewer samples, maybe 3700 samples/event:
$ perf report -D | tail -15
Aggregated stats:
TOTAL events: 10998
MMAP events: 66
COMM events: 2
SAMPLE events: 10930
cycles stats:
TOTAL events: 3644
SAMPLE events: 3644
cycles stats:
TOTAL events: 3642
SAMPLE events: 3642
cycles stats:
TOTAL events: 3644
SAMPLE events: 3644
On a Intel Nehalem or even AMD64, there are 4 counters capable
of measuring cycles, so there is plenty of space to measure those
events without multiplexing (even with the NMI watchdog active).
And even with multiplexing, we'd expect roughly the same number
of samples per event.
The root of the problem was that when the event that caused the buffer
to become full was not the first event passed on the cmdline, the user
notification would get lost. The notification was sent to the file
descriptor of the overflowed event but the perf tool was not polling
on it. The perf tool aggregates all samples into a single buffer,
i.e., the buffer of the first event. Consequently, it assumes
notifications for any event will come via that descriptor.
The seemingly straight forward solution of moving the waitq into the
ringbuffer object doesn't work because of life-time issues. One could
perf_event_set_output() on a fd that you're also blocking on and cause
the old rb object to be freed while its waitq would still be
referenced by the blocked thread -> FAIL.
Therefore link all events to the ringbuffer and broadcast the wakeup
from the ringbuffer object to all possible events that could be waited
upon. This is rather ugly, and we're open to better solutions but it
works for now.
Reported-by: Stephane Eranian <eranian@google.com>
Finished-by: Stephane Eranian <eranian@google.com>
Reviewed-by: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/r/20111126014731.GA7030@quad
If a device is shutdown, then there might be a pending interrupt,
which will be processed after we reenable interrupts, which causes the
original handler to be run. If the old handler is the (broadcast)
periodic handler the shutdown state might hang the kernel completely.
When a better rated broadcast device is installed, then the current
active device is not disabled, which results in two running broadcast
devices.
In irq_wait_for_interrupt(), the should_stop member is verified before
setting the task's state to TASK_INTERRUPTIBLE and calling schedule().
In case kthread_stop sets should_stop and wakes up the process after
should_stop is checked by the irq thread but before the task's state
is changed, the irq thread might never exit:
kthread_stop irq_wait_for_interrupt
... while (!kthread_should_stop()) {
kthread->should_stop = 1;
wake_up_process(k);
wait_for_completion(&kthread->exited);
set_current_state(TASK_INTERRUPTIBLE);
schedule();
Fix this by checking if the thread should stop after modifying the
task's state.
[ tglx: Simplified it a bit ]
Signed-off-by: Ido Yariv <ido@wizery.com>
Link: http://lkml.kernel.org/r/1322740508-22640-1-git-send-email-ido@wizery.com
ftrace_event_call->filter is sched RCU protected but didn't use
rcu_assign_pointer(). Use it.
TODO: Add proper __rcu annotation to call->filter and all its users.
-v2: Use RCU_INIT_POINTER() for %NULL clearing as suggested by Eric.
Link: http://lkml.kernel.org/r/20111123164949.GA29639@google.com
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: stable@kernel.org # (2.6.39+)
In order to leave a margin of 12.5% we should >> 3 not >> 5.
CC: stable@kernel.org
Signed-off-by: Yang Honggang (Joseph) <eagle.rtlinux@gmail.com>
[jstultz: Modified commit subject]
Signed-off-by: John Stultz <john.stultz@linaro.org>
* 'pm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
PM: Update comments describing device power management callbacks
PM / Sleep: Update documentation related to system wakeup
PM / Runtime: Make documentation follow the new behavior of irq_safe
PM / Sleep: Correct inaccurate information in devices.txt
PM / Domains: Document how PM domains are used by the PM core
PM / Hibernate: Do not leak memory in error/test code paths
