path: root/kernel
2007-08-22Hibernation: do not try to mark invalid PFNs as nosaveRafael J. Wysocki
On some systems some PFNs reported by the early initialization code as 'nosave' may be invalid. =A0If we try to set the corresponding bits in the hibernation bitmap, BUG_ON() in memory_bm_find_bit() will be triggered and the system won't be able to boot (cf. https://bugzilla.novell.com/show_bug.cgi?id=296242). Prevent this from happening by verifying if the 'nosave' PFNs are valid in mark_nosave_pages(). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-08-15fix oops in __audit_signal_info()Al Viro
Check for audit_signals is misplaced and check for audit_dummy_context() is missing; as the result, if we send signal to auditd from task with NULL ->audit_context while we have audit_signals != 0 we end up with an oops. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-08-09destroy_workqueue() can livelockOleg Nesterov
Pointed out by Michal Schmidt <mschmidt@redhat.com>. The bug was introduced in 2.6.22 by me. cleanup_workqueue_thread() does flush_cpu_workqueue(cwq) in a loop until ->worklist becomes empty. This is live-lockable, a re-niced caller can get CPU after wake_up() and insert a new barrier before the lower-priority cwq->thread has a chance to clear ->current_work. Change cleanup_workqueue_thread() to do flush_cpu_workqueue(cwq) only once. We can rely on the fact that run_workqueue() won't return until it flushes all works. So it is safe to call kthread_stop() after that, the "should stop" request won't be noticed until run_workqueue() returns. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Michal Schmidt <mschmidt@redhat.com> Cc: Srivatsa Vaddagiri <vatsa@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-08-09futex: pass nr_wake2 to futex_wake_opAndreas Schwab
The fourth argument of sys_futex is ignored when op == FUTEX_WAKE_OP, but futex_wake_op expects it as its nr_wake2 parameter. The only user of this operation in glibc is always passing 1, so this bug had no consequences so far. Signed-off-by: Andreas Schwab <schwab@suse.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-08-09Fix leaks on /proc/{*/sched, sched_debug, timer_list, timer_stats}Alexey Dobriyan
On every open/close one struct seq_operations leaks. Kudos to /proc/slab_allocators. Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-08-09Fix leak on /proc/lockdep_statsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-03NTP: remove clock_was_set() call to prevent deadlockThomas Gleixner
The clock_was_set() call in seconds_overflow() which happens only when leap seconds are inserted / deleted is wrong in two aspects: 1. it results in a call to on_each_cpu() with interrupts disabled 2. it is potential deadlock source vs. call_lock in smp_call_function() The only possible side effect of the removal might be, that an absolute CLOCK_REALTIME timer fires 1 second too late, in the rare case of leap second deletion and an absolute CLOCK_REALTIME timer which expires in the affected time frame. It will never fire too early. This was probably observed by the reporter of a June 30th -> July 1st hang: http://lkml.org/lkml/2007/7/3/103 A similar problem was observed by Dave Jones, who provided a screen shot with a lockdep back trace, which allowed to analyse the problem. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-01PM: introduce set_target method in pm_opsRafael J. Wysocki
Commit 52ade9b3b97fd3bea42842a056fe0786c28d0555 changed the suspend code ordering to execute pm_ops->prepare() after the device model per-device .suspend() calls in order to fix some ACPI-related issues. Unfortunately, it broke the at91 platform which assumed that pm_ops->prepare() would be called before suspending devices. at91 used pm_ops->prepare() to get notified of the target system sleep state, so that it could use this information while suspending devices. However, with the current suspend code ordering pm_ops->prepare() is called too late for this purpose. Thus, at91 needs an additional method in 'struct pm_ops' that will be used for notifying the platform of the target system sleep state. Moreover, in the future such a method will also be needed by ACPI. This patch adds the .set_target() method to 'struct pm_ops' and makes the suspend code call it, if implemented, before executing the device model per-device .suspend() calls. It also modifies the at91 code to use pm_ops->set_target() instead of pm_ops->prepare(). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Pavel Machek <pavel@ucw.cz> Cc: Johannes Berg <johannes@sipsolutions.net> Cc: Len Brown <lenb@kernel.org> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-28relayfs: fix overwritesMasami Hiramatsu
When I use relayfs with "overwrite" mode, read() still sets incorrect number of consumed bytes. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Acked-by: Tom Zanussi <zanussi@us.ibm.com> Acked-by: David Wilder <dwilder@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-28relay file read: start-pos fixDavid Wilder
Fix a bug in the relay read interface causing the number of consumed bytes to be set incorrectly. Signed-off-by: Tom Zanussi <zanussi@us.ibm.com> Signed-off-by: David Wilder <dwilder@us.ibm.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-24FUTEX: Restore the dropped ERSCH fixThomas Gleixner
The return value of futex_find_get_task() needs to be -ESRCH in case that the search fails. This was part of the original futex fixes and got accidentally dropped, when the futex-tidy-up patch was split out. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Stable Team <stable@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-24audit: fix oops removing watch if audit disabledTony Jones
Removing a watched file will oops if audit is disabled (auditctl -e 0). To reproduce: - auditctl -e 1 - touch /tmp/foo - auditctl -w /tmp/foo - auditctl -e 0 - rm /tmp/foo (or mv) Signed-off-by: Tony Jones <tonyj@suse.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-24sched: fix next_interval determination in idle_balance()Christoph Lameter
The intervals of domains that do not have SD_BALANCE_NEWIDLE must be considered for the calculation of the time of the next balance. Otherwise we may defer rebalancing forever. Siddha also spotted that the conversion of the balance interval to jiffies is missing. Fix that to. From: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> also continue the loop if !(sd->flags & SD_LOAD_BALANCE). Tested-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> It did in fact trigger under all three of mainline, CFS, and -rt including CFS -- see below for a couple of emails from last Friday giving results for these three on the AMD box (where it happened) and on a single-quad NUMA-Q system (where it did not, at least not with such severity). Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-24fix refcounting of nsproxy object when unsharedCedric Le Goater
When a namespace is unshared, a refcount on the previous nsproxy is abusively taken, leading to a memory leak of nsproxy objects. Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Cc: Badari Pulavarty <pbadari@us.ibm.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-21posix-timers: Prevent softirq starvation by small intervals and SIG_IGNThomas Gleixner
posix-timers which deliver an ignored signal are currently rearmed in the timer softirq: This is necessary because the timer needs to be delivered again when SIG_IGN is removed. This is not a problem, when the interval is reasonable. With high resolution timers enabled one might arm a posix timer with a very small interval and ignore the signal. This might lead to a softirq starvation when the interval is so small that the timer is requeued onto the softirq pending list right away. This problem was pointed out by Jan Kiszka. Thanks Jan ! The correct solution would be to stop the timer, when the signal is ignored and rearm it when SIG_IGN is removed. Unfortunately this requires modification in sigaction and involves non trivial sighand locking. It's too late in the release cycle for such a change. For now we just keep the timer running and enforce that the timer only fires every jiffie. This does not break anything as we keep the overrun counter correct. It adds a little inaccuracy to the timer_gettime() interface, but... The more complex change is necessary anyway to fix another short coming of the current implementation, which I discovered while looking at this problem: A pending signal is discarded when SIG_IGN is set. In case that a posixtimer signal is pending then it is discarded as well, but when SIG_IGN is removed later nothing rearms the timer. This is not new, it's that way since posix timers have been merged. So nothing to worry about right now. I have a working solution to fix all of this, but the impact is too large for both stable and 2.6.22. I'm going to send it out for review in the next days. This should go into 2.6.21.stable as well. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Jan Kiszka <jan.kiszka@web.de> Cc: Ulrich Drepper <drepper@redhat.com> Cc: Stable Team <stable@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-18Fix possible runqueue lock starvation in wait_task_inactive()Linus Torvalds
Miklos Szeredi reported very long pauses (several seconds, sometimes more) on his T60 (with a Core2Duo) which he managed to track down to wait_task_inactive()'s open-coded busy-loop. He observed that an interrupt on one core tries to acquire the runqueue-lock but does not succeed in doing so for a very long time - while wait_task_inactive() on the other core loops waiting for the first core to deschedule a task (which it wont do while spinning in an interrupt handler). This rewrites wait_task_inactive() to do all its waiting optimistically without any locks taken at all, and then just double-check the end result with the proper runqueue lock held over just a very short section. If there were races in the optimistic wait, of a preemption event scheduled the process away, we simply re-synchronize, and start over. So the code now looks like this: repeat: /* Unlocked, optimistic looping! */ rq = task_rq(p); while (task_running(rq, p)) cpu_relax(); /* Get the *real* values */ rq = task_rq_lock(p, &flags); running = task_running(rq, p); array = p->array; task_rq_unlock(rq, &flags); /* Check them.. */ if (unlikely(running)) { cpu_relax(); goto repeat; } /* Preempted away? Yield if so.. */ if (unlikely(array)) { yield(); goto repeat; } Basically, that first "while()" loop is done entirely without any locking at all (and doesn't check for the case where the target process might have been preempted away), and so it's possibly "incorrect", but we don't really care. Both the runqueue used, and the "task_running()" check might be the wrong tests, but they won't oops - they just mean that we could possibly get the wrong results due to lack of locking and exit the loop early in the case of a race condition. So once we've exited the loop, we then get the proper (and careful) rq lock, and check the running/runnable state _safely_. And if it turns out that our quick-and-dirty and unsafe loop was wrong after all, we just go back and try it all again. (The patch also adds a lot of comments, which is the actual bulk of it all, to make it more obvious why we can do these things without holding the locks). Thanks to Miklos for all the testing and tracking it down. Tested-by: Miklos Szeredi <miklos@szeredi.hu> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-18sched: fix SysRq-N (normalize RT tasks)Ingo Molnar
Gene Heskett reported the following problem while testing CFS: SysRq-N is not always effective in normalizing tasks back to SCHED_OTHER. The reason for that turns out to be the following bug: - normalize_rt_tasks() uses for_each_process() to iterate through all tasks in the system. The problem is, this method does not iterate through all tasks, it iterates through all thread groups. The proper mechanism to enumerate over all threads is to use a do_each_thread() + while_each_thread() loop. Reported-by: Gene Heskett <gene.heskett@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-18Fix signalfd interaction with thread-private signalsBenjamin Herrenschmidt
Don't let signalfd dequeue private signals off other threads (in the case of things like SIGILL or SIGSEGV, trying to do so would result in undefined behaviour on who actually gets the signal, since they are force unblocked). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-18Revert "futex_requeue_pi optimization"Thomas Gleixner
This reverts commit d0aa7a70bf03b9de9e995ab272293be1f7937822. It not only introduced user space visible changes to the futex syscall, it is also non-functional and there is no way to fix it proper before the 2.6.22 release. The breakage report ( http://lkml.org/lkml/2007/5/12/17 ) went unanswered, and unfortunately it turned out that the concept is not feasible at all. It violates the rtmutex semantics badly by introducing a virtual owner, which hacks around the coupling of the user-space pi_futex and the kernel internal rt_mutex representation. At the moment the only safe option is to remove it fully as it contains user-space visible changes to broken kernel code, which we do not want to expose in the 2.6.22 release. The patch reverts the original patch mostly 1:1, but contains a couple of trivial manual cleanups which were necessary due to patches, which touched the same area of code later. Verified against the glibc tests and my own PI futex tests. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Ulrich Drepper <drepper@redhat.com> Cc: Pierre Peiffer <pierre.peiffer@bull.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-16swsusp: Fix userland interfaceRafael J. Wysocki
Fix oops caused by 'cat /dev/snapshot', reported by Arkadiusz Miskiewicz, and make it impossible to thaw tasks with the help of the swsusp userland interface while there is a snapshot image ready to save. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-16cpuset: zero malloc - fix for old cpusetsPaul Jackson
The cpuset code to present a list of tasks using a cpuset to user space could write to an array that it had kmalloc'd, after a kmalloc request of zero size. The problem was that the code didn't check for writes past the allocated end of the array until -after- the first write. This is a race condition that is likely rare -- it would only show up if a cpuset went from being empty to having a task in it, during the brief time between the allocation and the first write. Prior to roughly 2.6.22 kernels, this was also a benign problem, because a zero kmalloc returned a few usable bytes anyway, and no harm was done with the bogus write. With the 2.6.22 kernel changes to make issue a warning if code tries to write to the location returned from a zero size allocation, this problem is no longer benign. This cpuset code would occassionally trigger that warning. The fix is trivial -- check before storing into the array, not after, whether the array is big enough to hold the store. Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: "Serge E. Hallyn" <serue@us.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Kirill Korotaev <dev@openvz.org> Cc: Paul Menage <menage@google.com> Cc: Srivatsa Vaddagiri <vatsa@in.ibm.com> Cc: Christoph Lameter <clameter@sgi.com> Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-08pi-futex: fix exit races and locking problemsAlexey Kuznetsov
1. New entries can be added to tsk->pi_state_list after task completed exit_pi_state_list(). The result is memory leakage and deadlocks. 2. handle_mm_fault() is called under spinlock. The result is obvious. 3. results in self-inflicted deadlock inside glibc. Sometimes futex_lock_pi returns -ESRCH, when it is not expected and glibc enters to for(;;) sleep() to simulate deadlock. This problem is quite obvious and I think the patch is right. Though it looks like each "if" in futex_lock_pi() got some stupid special case "else if". :-) 4. sometimes futex_lock_pi() returns -EDEADLK, when nobody has the lock. The reason is also obvious (see comment in the patch), but correct fix is far beyond my comprehension. I guess someone already saw this, the chunk: if (rt_mutex_trylock(&q.pi_state->pi_mutex)) ret = 0; is obviously from the same opera. But it does not work, because the rtmutex is really taken at this point: wake_futex_pi() of previous owner reassigned it to us. My fix works. But it looks very stupid. I would think about removal of shift of ownership in wake_futex_pi() and making all the work in context of process taking lock. From: Thomas Gleixner <tglx@linutronix.de> Fix 1) Avoid the tasklist lock variant of the exit race fix by adding an additional state transition to the exit code. This fixes also the issue, when a task with recursive segfaults is not able to release the futexes. Fix 2) Cleanup the lookup_pi_state() failure path and solve the -ESRCH problem finally. Fix 3) Solve the fixup_pi_state_owner() problem which needs to do the fixup in the lock protected section by using the in_atomic userspace access functions. This removes also the ugly lock drop / unqueue inside of fixup_pi_state() Fix 4) Fix a stale lock in the error path of futex_wake_pi() Added some error checks for verification. The -EDEADLK problem is solved by the rtmutex fixups. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Ulrich Drepper <drepper@redhat.com> Cc: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-08rt-mutex: fix chain walk early wakeup bugThomas Gleixner
Alexey Kuznetsov found some problems in the pi-futex code. One of the root causes is: When a wakeup happens, we do not to stop the chain walk so we follow a not longer relevant locking chain. Drop out when this happens. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Cc: Ulrich Drepper <drepper@redhat.com> Cc: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-08rt-mutex: fix stale return valueThomas Gleixner
Alexey Kuznetsov found some problems in the pi-futex code. The major problem is a stale return value in rt_mutex_slowlock(): When the pi chain walk returns -EDEADLK, but the waiter was woken up during the phases where the locks were dropped, the rtmutex could be acquired, but due to the stale return value -EDEADLK returned to the caller. Reset the return value in the retry path. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Cc: Ulrich Drepper <drepper@redhat.com> Cc: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-07Restrict clearing TIF_SIGPENDINGRoland McGrath
This patch should get a few birds. It prevents sigaction calls from clearing TIF_SIGPENDING in other threads, which could leak -ERESTART*. And It fixes ptrace_stop not to clear it, which done at the syscall exit stop could leak -ERESTART*. It probably removes the harm from signalfd, at least assuming it never calls dequeue_signal on kernel threads that might have used block_all_signals. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Satoru Takeuchi <takeuchi_satoru@jp.fujitsu.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-01timer stats: speedupsIngo Molnar
Make timer-stats have almost zero overhead when enabled in the config but not used. (this way distros can enable it more easily) Also update the documentation about overhead of timer_stats - it was written for the first version which had a global lock and a linear list walk based lookup ;-) Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-01timer statistics: fix raceBjorn Steinbrink
Fix two races in the timer stats lookup code. One by ensuring that the initialization of a new entry is finished upon insertion of that entry. The other by cleaning up the hash table when the entries array is cleared, so that we don't have any "pre-inserted" entries. Thanks to Eric Dumazet for reminding me of the memory barriers. Signed-off-by: Bjorn Steinbrink <B.Steinbrink@gmx.de> Signed-off-by: Ian Kumlien <pomac@vapor.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Eric Dumazet <dada1@cosmosbay.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-01fix compat futex code for private futexesUlrich Drepper
When the private futex support was added the compat code wasn't changed. The result is that code using compat code which fail, e.g., because the timeout values are not correctly passed. The following patch should fix that. Signed-off-by: Ulrich Drepper <drepper@redhat.com> Cc: Eric Dumazet <dada1@cosmosbay.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-30fix possible null ptr deref in kallsyms_lookupKyle McMartin
ugh, this function gets called by our unwinder. recursive backtrace for the win... bisection to find this one was "fun." Signed-off-by: Kyle McMartin <kyle@parisc-linux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-29NOHZ: prevent multiplication overflow - stop timer for huge timeoutsThomas Gleixner
get_next_timer_interrupt() returns a delta of (LONG_MAX > 1) in case there is no timer pending. On 64 bit machines this results in a multiplication overflow in tick_nohz_stop_sched_tick(). Reported by: Dave Miller <davem@davemloft.net> Make the return value a constant and limit the return value to a 32 bit value. When the max timeout value is returned, we can safely stop the tick timer device. The max jiffies delta results in a 12 days timeout for HZ=1000. In the long term the get_next_timer_interrupt() code needs to be reworked to return ktime instead of jiffies, but we have to wait until the last users of the original NO_IDLE_HZ code are converted. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-24Fix crash with irqpoll due to the IRQF_IRQPOLL flag testingLinus Torvalds
With irqpoll enabled, trying to test the IRQF_IRQPOLL flag in the actions would cause a NULL pointer dereference if no action was installed (for example, the driver might have been unloaded with interrupts still pending). So be a bit more careful about testing the flag by making sure to test for that case. (The actual _change_ is trivial, the patch is more than a one-liner because I rewrote the testing to also be much more readable. Original (discarded) bugfix by Bernhard Walle. Cc: Bernhard Walle <bwalle@suse.de> Tested-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-23Prevent going idle with softirq pendingThomas Gleixner
The NOHZ patch contains a check for softirqs pending when a CPU goes idle. The BUG is unrelated to NOHZ, it just was made visible by the NOHZ patch. The BUG showed up mainly on P4 / hyperthreading enabled machines which lead the investigations into the wrong direction in the first place. The real cause is in cond_resched_softirq(): cond_resched_softirq() is enabling softirqs without invoking the softirq daemon when softirqs are pending. This leads to the warning message in the NOHZ idle code: t1 runs softirq disabled code on CPU#0 interrupt happens, softirq is raised, but deferred (softirqs disabled) t1 calls cond_resched_softirq() enables softirqs via _local_bh_enable() calls schedule() t2 runs t1 is migrated to CPU#1 t2 is done and invokes idle() NOHZ detects the pending softirq Fix: change _local_bh_enable() to local_bh_enable() so the softirq daemon is invoked. Thanks to Anant Nitya for debugging this with great patience ! Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-23power: Fix sizeof(PAGE_SIZE) typoOGAWA Hirofumi
Fix sizeof(PAGE_SIZE) typo. It should be just PAGE_SIZE for zeroing the swsusp_header. Signed-off-by: OGAWA Hirofumi <hogawa@miraclelinux.com> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Pavel Machek <pavel@ucw.cz> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-23simplify cleanup_workqueue_thread()Oleg Nesterov
cleanup_workqueue_thread() and cwq_should_stop() are overcomplicated. Convert the code to use kthread_should_stop/kthread_stop as was suggested by Gautham and Srivatsa. In particular this patch removes the (unlikely) busy-wait loop from the exit path, it was a temporary and ugly kludge (if not a bug). Note: the current code was designed to solve another old problem: work->func can't share locks with hotplug callbacks. I think this could be done, see http://marc.info/?l=linux-kernel&m=116905366428633 but this needs some more complications to preserve CPU affinity of cwq->thread during cpu_up(). A freezer-based hotplug looks more appealing. [akpm@linux-foundation.org: make it more tolerant of gcc borkenness] Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Zilvinas Valinskas <zilvinas@wilibox.com> Cc: Gautham R Shenoy <ego@in.ibm.com> Cc: Srivatsa Vaddagiri <vatsa@in.ibm.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-23recalc_sigpending_tsk fixesRoland McGrath
Steve Hawkes discovered a problem where recalc_sigpending_tsk was called in do_sigaction but no signal_wake_up call was made, preventing later signals from waking up blocked threads with TIF_SIGPENDING already set. In fact, the few other calls to recalc_sigpending_tsk outside the signals code are also subject to this problem in other race conditions. This change makes recalc_sigpending_tsk private to the signals code. It changes the outside calls, as well as do_sigaction, to use the new recalc_sigpending_and_wake instead. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: <Steve.Hawkes@motorola.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-23NOHZ: Rate limit the local softirq pending warning outputThomas Gleixner
The warning in the NOHZ code, which triggers when a CPU goes idle with softirqs pending can fill up the logs quite quickly. Rate limit the output until we found the root cause of that problem. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-23Ignore bogus ACPI info for offline CPUsThomas Gleixner
Booting a SMP kernel with maxcpus=1 on a SMP system leads to a hard hang, because ACPI ignores the maxcpus setting and sends timer broadcast info for the offline CPUs. This results in a stuck for ever call to smp_call_function_single() on an offline CPU. Ignore the bogus information and print a kernel error to remind ACPI folks to fix it. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-23freezer: move frozen_process() to kernel/power/process.cGautham R Shenoy
Other than refrigerator, no one else calls frozen_process(). So move it from include/linux/freezer.h to kernel/power/process.c. Also, since a task can be marked as frozen by itself, we don't need to pass the (struct task_struct *p) parameter to frozen_process(). Signed-off-by: Gautham R Shenoy <ego@in.ibm.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Pavel Machek <pavel@ucw.cz> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-23freezer: fix kthread_create vs freezer theoretical raceOleg Nesterov
kthread() sleeps in TASK_INTERRUPTIBLE state waiting for the first wakeup. In theory, this wakeup may come from freeze_process()->signal_wake_up(), so the task can disappear even before kthread_create() sets its ->comm. Change kthread() to use TASK_UNINTERRUPTIBLE. [akpm@linux-foundation.org: s/BUG_ON/WARN_ON+recover] Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Gautham R Shenoy <ego@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-23freezer: take kernel_execve into considerationRafael J. Wysocki
Kernel threads can become userland processes by calling kernel_execve(). In particular, this may happen right after the try_to_freeze_tasks() called with FREEZER_USER_SPACE has returned, so try_to_freeze_tasks() needs to take userspace processes into consideration even if it is called with FREEZER_KERNEL_THREADS. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: Gautham R Shenoy <ego@in.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-23freezer: fix vfork problemRafael J. Wysocki
Currently try_to_freeze_tasks() has to wait until all of the vforked processes exit and for this reason every user can make it fail. To fix this problem we can introduce the additional process flag PF_FREEZER_SKIP to be used by tasks that do not want to be counted as freezable by the freezer and want to have TIF_FREEZE set nevertheless. Then, this flag can be set by tasks using sys_vfork() before they call wait_for_completion(&vfork) and cleared after they have woken up. After clearing it, the tasks should call try_to_freeze() as soon as possible. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Gautham R Shenoy <ego@in.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Pavel Machek <pavel@ucw.cz> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-23freezer: close potential race between refrigerator and thaw_tasksRafael J. Wysocki
If the freezing of tasks fails and a task is preempted in refrigerator() before calling frozen_process(), then thaw_tasks() may run before this task is frozen. In that case the task will freeze and no one will thaw it. To fix this race we can call freezing(current) in refrigerator() along with frozen_process(current) under the task_lock() which also should be taken in the error path of try_to_freeze_tasks() as well as in thaw_process(). Moreover, if thaw_process() additionally clears TIF_FREEZE for tasks that are not frozen, we can be sure that all tasks are thawed and there are no pending "freeze" requests after thaw_tasks() has run. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: Gautham R Shenoy <ego@in.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-21Detach sched.h from mm.hAlexey Dobriyan
First thing mm.h does is including sched.h solely for can_do_mlock() inline function which has "current" dereference inside. By dealing with can_do_mlock() mm.h can be detached from sched.h which is good. See below, why. This patch a) removes unconditional inclusion of sched.h from mm.h b) makes can_do_mlock() normal function in mm/mlock.c c) exports can_do_mlock() to not break compilation d) adds sched.h inclusions back to files that were getting it indirectly. e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were getting them indirectly Net result is: a) mm.h users would get less code to open, read, preprocess, parse, ... if they don't need sched.h b) sched.h stops being dependency for significant number of files: on x86_64 allmodconfig touching sched.h results in recompile of 4083 files, after patch it's only 3744 (-8.3%). Cross-compile tested on all arm defconfigs, all mips defconfigs, all powerpc defconfigs, alpha alpha-up arm i386 i386-up i386-defconfig i386-allnoconfig ia64 ia64-up m68k mips parisc parisc-up powerpc powerpc-up s390 s390-up sparc sparc-up sparc64 sparc64-up um-x86_64 x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig as well as my two usual configs. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-17swsusp: fix sysfs interfaceRafael J. Wysocki
The sysfs files /sys/power/disk and /sys/power/state do not work as documented, since they allow the user to write only a few initial characters of the input string to trigger the option (eg. 'echo pl > /sys/power/disk' activates the platform mode of hibernation). Fix it. Special thanks to Peter Moulder <Peter.Moulder@infotech.monash.edu.au> for pointing out the problem. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-17make sysctl/kernel/core_pattern and fs/exec.c agree on maximum core filename ↵Dan Aloni
size Make sysctl/kernel/core_pattern and fs/exec.c agree on maximum core filename size and change it to 128, so that extensive patterns such as '/local/cores/%e-%h-%s-%t-%p.core' won't result in truncated filename generation. Signed-off-by: Dan Aloni <da-x@monatomic.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-16Fix ACPI suspend / device suspend ordering problemLinus Torvalds
In commit e3c7db621bed4afb8e231cb005057f2feb5db557 we fixed the resume ordering, so that the ACPI low-level resume code was called before the actual driver resume was called. However, that broke the nesting logic of suspend and resume, and we continued to suspend the devices _after_ we the ACPI device suspend code was called. That resulted in us saving PCI state for devices that had already been changed by ACPI, and in some cases disabled entirely (causing the PCI save_state to be all-ones). Which in turn caused the wrong state to be written back on resume. This moves the ACPI device suspend to after the device model per-device suspend() calls. This fixes the bogus state save. Thanks to Lukáš Hejtmánek for testing. Acked-by: Lukas Hejtmanek <xhejtman@ics.muni.cz> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Len Brown <len.brown@intel.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Greg KH <greg@kroah.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-15audit_match_signal() and friends are used only if CONFIG_AUDITSYSCALL is setAl Viro
2007-05-15clocksource: fix lock order in the resume pathThomas Gleixner
lockdep complains about the lock nesting of clocksource and watchdog lock in the resume path. Change the resume marker to a bit operation and remove the lock from this path. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-14timekeeping fix patch got mis-appliedThomas Gleixner
The time keeping code move to kernel/time/timekeeping.c broke the clocksource resume logic patch, which got applied to the old file by a fuzzy application. Fix it up and move the clocksource_resume() call to the appropriate place. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> [ tssk, tssk, everybody should use --fuzz=0 ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
