commit 275d7d44d802ef271a42dc87ac091a495ba72fc5 upstream.
Poma (on the way to another bug) reported an assertion triggering:
[<ffffffff81150529>] module_assert_mutex_or_preempt+0x49/0x90
[<ffffffff81150822>] __module_address+0x32/0x150
[<ffffffff81150956>] __module_text_address+0x16/0x70
[<ffffffff81150f19>] symbol_put_addr+0x29/0x40
[<ffffffffa04b77ad>] dvb_frontend_detach+0x7d/0x90 [dvb_core]
Laura Abbott <labbott@redhat.com> produced a patch which lead us to
inspect symbol_put_addr(). This function has a comment claiming it
doesn't need to disable preemption around the module lookup
because it holds a reference to the module it wants to find, which
therefore cannot go away.
This is wrong (and a false optimization too, preempt_disable() is really
rather cheap, and I doubt any of this is on uber critical paths,
otherwise it would've retained a pointer to the actual module anyway and
avoided the second lookup).
While its true that the module cannot go away while we hold a reference
on it, the data structure we do the lookup in very much _CAN_ change
while we do the lookup. Therefore fix the comment and add the
required preempt_disable().
Reported-by: poma <pomidorabelisima@gmail.com>
Fixes: a6e6abd575fc ("module: remove module_text_address()")
commit fe32d3cd5e8eb0f82e459763374aa80797023403 upstream.
These functions check should_resched() before unlocking spinlock/bh-enable:
preempt_count always non-zero => should_resched() always returns false.
cond_resched_lock() worked iff spin_needbreak is set.
This patch adds argument "preempt_offset" to should_resched().
preempt_count offset constants for that:
PREEMPT_DISABLE_OFFSET - offset after preempt_disable()
PREEMPT_LOCK_OFFSET - offset after spin_lock()
SOFTIRQ_DISABLE_OFFSET - offset after local_bh_distable()
SOFTIRQ_LOCK_OFFSET - offset after spin_lock_bh()
Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Cc: Alexander Graf <agraf@suse.de>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: David Vrabel <david.vrabel@citrix.com>
Fixes: bdb438065890 ("sched: Extract the basic add/sub preempt_count modifiers")
Link: http://lkml.kernel.org/r/20150715095204.12246.98268.stgit@buzz
Signed-off-by: Mike Galbraith <efault@gmx.de>
commit 874bbfe600a660cba9c776b3957b1ce393151b76 upstream.
My system keeps crashing with below message. vmstat_update() schedules a delayed
work in current cpu and expects the work runs in the cpu.
schedule_delayed_work() is expected to make delayed work run in local cpu. The
problem is timer can be migrated with NO_HZ. __queue_work() queues work in
timer handler, which could run in a different cpu other than where the delayed
work is scheduled. The end result is the delayed work runs in different cpu.
The patch makes __queue_delayed_work records local cpu earlier. Where the timer
runs doesn't change where the work runs with the change.
[ 28.010131] ------------[ cut here ]------------
[ 28.010609] kernel BUG at ../mm/vmstat.c:1392!
[ 28.011099] invalid opcode: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC KASAN
[ 28.011860] Modules linked in:
[ 28.012245] CPU: 0 PID: 289 Comm: kworker/0:3 Tainted: G W4.3.0-rc3+ #634
[ 28.013065] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.7.5-20140709_153802- 04/01/2014
[ 28.014160] Workqueue: events vmstat_update
[ 28.014571] task: ffff880117682580 ti: ffff8800ba428000 task.ti: ffff8800ba428000
[ 28.015445] RIP: 0010:[<ffffffff8115f921>] [<ffffffff8115f921>]vmstat_update+0x31/0x80
[ 28.016282] RSP: 0018:ffff8800ba42fd80 EFLAGS: 00010297
[ 28.016812] RAX: 0000000000000000 RBX: ffff88011a858dc0 RCX:0000000000000000
[ 28.017585] RDX: ffff880117682580 RSI: ffffffff81f14d8c RDI:ffffffff81f4df8d
[ 28.018366] RBP: ffff8800ba42fd90 R08: 0000000000000001 R09:0000000000000000
[ 28.019169] R10: 0000000000000000 R11: 0000000000000121 R12:ffff8800baa9f640
[ 28.019947] R13: ffff88011a81e340 R14: ffff88011a823700 R15:0000000000000000
[ 28.020071] FS: 0000000000000000(0000) GS:ffff88011a800000(0000)knlGS:0000000000000000
[ 28.020071] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[ 28.020071] CR2: 00007ff6144b01d0 CR3: 00000000b8e93000 CR4:00000000000006f0
[ 28.020071] Stack:
[ 28.020071] ffff88011a858dc0 ffff8800baa9f640 ffff8800ba42fe00ffffffff8106bd88
[ 28.020071] ffffffff8106bd0b 0000000000000096 0000000000000000ffffffff82f9b1e8
[ 28.020071] ffffffff829f0b10 0000000000000000 ffffffff81f18460ffff88011a81e340
[ 28.020071] Call Trace:
[ 28.020071] [<ffffffff8106bd88>] process_one_work+0x1c8/0x540
[ 28.020071] [<ffffffff8106bd0b>] ? process_one_work+0x14b/0x540
[ 28.020071] [<ffffffff8106c214>] worker_thread+0x114/0x460
[ 28.020071] [<ffffffff8106c100>] ? process_one_work+0x540/0x540
[ 28.020071] [<ffffffff81071bf8>] kthread+0xf8/0x110
[ 28.020071] [<ffffffff81071b00>] ?kthread_create_on_node+0x200/0x200
[ 28.020071] [<ffffffff81a6522f>] ret_from_fork+0x3f/0x70
Signed-off-by: Shaohua Li <shli@fb.com>
commit 95c2b17534654829db428f11bcf4297c059a2a7e upstream.
Per-IRQ directories in procfs are created only when a handler is first
added to the irqdesc, not when the irqdesc is created. In the case of
a shared IRQ, multiple tasks can race to create a directory. This
race condition seems to have been present forever, but is easier to
hit with async probing.
Link: http://lkml.kernel.org/r/1443266636.2004.2.camel@decadent.org.uk
commit 95913d97914f44db2b81271c2e2ebd4d2ac2df83 upstream.
So the problem this patch is trying to address is as follows:
CPU0 CPU1
context_switch(A, B)
ttwu(A)
LOCK A->pi_lock
A->on_cpu == 0
finish_task_switch(A)
prev_state = A->state <-.
WMB |
A->on_cpu = 0; |
UNLOCK rq0->lock |
| context_switch(C, A)
`-- A->state = TASK_DEAD
prev_state == TASK_DEAD
put_task_struct(A)
context_switch(A, C)
A->state == TASK_DEAD
put_task_struct(A)
The argument being that the WMB will allow the load of A->state on CPU0
to cross over and observe CPU1's store of A->state, which will then
result in a double-drop and use-after-free.
Now the comment states (and this was true once upon a long time ago)
that we need to observe A->state while holding rq->lock because that
will order us against the wakeup; however the wakeup will not in fact
acquire (that) rq->lock; it takes A->pi_lock these days.
We can obviously fix this by upgrading the WMB to an MB, but that is
expensive, so we'd rather avoid that.
The alternative this patch takes is: smp_store_release(&A->on_cpu, 0),
which avoids the MB on some archs, but not important ones like ARM.
Reported-by: Oleg Nesterov <oleg@redhat.com>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: manfred@colorfullife.com
Cc: will.deacon@arm.com
Fixes: e4a52bcb9a18 ("sched: Remove rq->lock from the first half of ttwu()")
Link: http://lkml.kernel.org/r/20150929124509.GG3816@twins.programming.kicks-ass.net
commit 12c641ab8270f787dfcce08b5f20ce8b65008096 upstream.
In the logic in the initial commit of unshare made creating a new
thread group for a process, contingent upon creating a new memory
address space for that process. That is wrong. Two separate
processes in different thread groups can share a memory address space
and clone allows creation of such proceses.
This is significant because it was observed that mm_users > 1 does not
mean that a process is multi-threaded, as reading /proc/PID/maps
temporarily increments mm_users, which allows other processes to
(accidentally) interfere with unshare() calls.
Correct the check in check_unshare_flags() to test for
!thread_group_empty() for CLONE_THREAD, CLONE_SIGHAND, and CLONE_VM.
For sighand->count > 1 for CLONE_SIGHAND and CLONE_VM.
For !current_is_single_threaded instead of mm_users > 1 for CLONE_VM.
By using the correct checks in unshare this removes the possibility of
an accidental denial of service attack.
Additionally using the correct checks in unshare ensures that only an
explicit unshare(CLONE_VM) can possibly trigger the slow path of
current_is_single_threaded(). As an explict unshare(CLONE_VM) is
pointless it is not expected there are many applications that make
that call.
Fixes: b2e0d98705e60e45bbb3c0032c48824ad7ae0704 userns: Implement unshare of the user namespace
Reported-by: Ricky Zhou <rickyz@chromium.org>
Reported-by: Kees Cook <keescook@chromium.org>
commit c7999c6f3fed9e383d3131474588f282ae6d56b9 upstream.
I ran the perf fuzzer, which triggered some WARN()s which are due to
trying to stop/restart an event on the wrong CPU.
Use the normal IPI pattern to ensure we run the code on the correct CPU.
Cc: Vince Weaver <vincent.weaver@maine.edu>
Fixes: bad7192b842c ("perf: Fix PERF_EVENT_IOC_PERIOD to force-reset the period")
commit fed66e2cdd4f127a43fd11b8d92a99bdd429528c upstream.
Vince reported that the fasync signal stuff doesn't work proper for
inherited events. So fix that.
Installing fasync allocates memory and sets filp->f_flags |= FASYNC,
which upon the demise of the file descriptor ensures the allocation is
freed and state is updated.
Now for perf, we can have the events stick around for a while after the
original FD is dead because of references from child events. So we
cannot copy the fasync pointer around. We can however consistently use
the parent's fasync, as that will be updated.
Reported-and-Tested-by: Vince Weaver <vincent.weaver@maine.edu>
Cc: Arnaldo Carvalho deMelo <acme@kernel.org>
Cc: eranian@google.com
Link: http://lkml.kernel.org/r/1434011521.1495.71.camel@twins
commit 3c00cb5e68dc719f2fc73a33b1b230aadfcb1309 upstream.
This function can leak kernel stack data when the user siginfo_t has a
positive si_code value. The top 16 bits of si_code descibe which fields
in the siginfo_t union are active, but they are treated inconsistently
between copy_siginfo_from_user32, copy_siginfo_to_user32 and
copy_siginfo_to_user.
copy_siginfo_from_user32 is called from rt_sigqueueinfo and
rt_tgsigqueueinfo in which the user has full control overthe top 16 bits
of si_code.
This fixes the following information leaks:
x86: 8 bytes leaked when sending a signal from a 32-bit process to
itself. This leak grows to 16 bytes if the process uses x32.
(si_code = __SI_CHLD)
x86: 100 bytes leaked when sending a signal from a 32-bit process to
a 64-bit process. (si_code = -1)
sparc: 4 bytes leaked when sending a signal from a 32-bit process to a
64-bit process. (si_code = any)
parsic and s390 have similar bugs, but they are not vulnerable because
rt_[tg]sigqueueinfo have checks that prevent sending a positive si_code
to a different process. These bugs are also fixed for consistency.
Signed-off-by: Amanieu d'Antras <amanieu@gmail.com>
Cc: Chris Metcalf <cmetcalf@ezchip.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
commit 26135022f85105ad725cda103fa069e29e83bd16 upstream.
This function may copy the si_addr_lsb, si_lower and si_upper fields to
user mode when they haven't been initialized, which can leak kernel
stack data to user mode.
Just checking the value of si_code is insufficient because the same
si_code value is shared between multiple signals. This is solved by
checking the value of si_signo in addition to si_code.
commit 75a06189fc508a2acf470b0b12710362ffb2c4b1 upstream.
The resend mechanism happily calls the interrupt handler of interrupts
which are marked IRQ_NESTED_THREAD from softirq context. This can
result in crashes because the interrupt handler is not the proper way
to invoke the device handlers. They must be invoked via
handle_nested_irq.
Prevent the resend even if the interrupt has no valid parent irq
set. Its better to have a lost interrupt than a crashing machine.
Reported-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
commit d194e5d666225b04c7754471df0948f645b6ab3a upstream.
The final version of commit 637241a900cb ("kmsg: honor dmesg_restrict
sysctl on /dev/kmsg") lost few hooks, as result security_syslog() are
processed incorrectly:
- open of /dev/kmsg checks syslog access permissions by using
check_syslog_permissions() where security_syslog() is not called if
dmesg_restrict is set.
- syslog syscall and /proc/kmsg calls do_syslog() where security_syslog
can be executed twice (inside check_syslog_permissions() and then
directly in do_syslog())
With this patch security_syslog() is called once only in all
syslog-related operations regardless of dmesg_restrict value.
Fixes: 637241a900cb ("kmsg: honor dmesg_restrict sysctl on /dev/kmsg")
Signed-off-by: Vasily Averin <vvs@virtuozzo.com>
Cc: Josh Boyer <jwboyer@redhat.com>
Cc: Eric Paris <eparis@redhat.com>
commit fff3b16d2754a061a3549c4307a186423a0128fd upstream.
Many harddisks (mostly WD ones) have firmware problems and take too
long, more than 10 seconds, to resume from suspend. And this often
exceeds the default DPM watchdog timeout (12 seconds), resulting in a
kernel panic out of sudden.
Since most distros just take the default as is, we should give a bit
more safer value. This patch increases the default value from 12
seconds to one minute, which has been confirmed to be long enough for
such problematic disks.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=91921
Fixes: 70fea60d888d (PM / Sleep: Detect device suspend/resume lockup and log event)
commit 6224beb12e190ff11f3c7d4bf50cb2922878f600 upstream.
Fengguang Wu's tests triggered a bug in the branch tracer's start up
test when CONFIG_DEBUG_PREEMPT set. This was because that config
adds some debug logic in the per cpu field, which calls back into
the branch tracer.
The branch tracer has its own recursive checks, but uses a per cpu
variable to implement it. If retrieving the per cpu variable calls
back into the branch tracer, you can see how things will break.
Instead of using a per cpu variable, use the trace_recursion field
of the current task struct. Simply set a bit when entering the
branch tracing and clear it when leaving. If the bit is set on
entry, just don't do the tracing.
There's also the case with lockdep, as the local_irq_save() called
before the recursion can also trigger code that can call back into
the function. Changing that to a raw_local_irq_save() will protect
that as well.
This prevents the recursion and the inevitable crash that follows.
Link: http://lkml.kernel.org/r/20150630141803.GA28071@wfg-t540p.sh.intel.com
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Tested-by: Fengguang Wu <fengguang.wu@intel.com>
commit 6b88f44e161b9ee2a803e5b2b1fbcf4e20e8b980 upstream.
While debugging a WARN_ON() for filtering, I found that it is possible
for the filter string to be referenced after its end. With the filter:
# echo '>' > /sys/kernel/debug/events/ext4/ext4_truncate_exit/filter
The filter_parse() function can call infix_get_op() which calls
infix_advance() that updates the infix filter pointers for the cnt
and tail without checking if the filter is already at the end, which
will put the cnt to zero and the tail beyond the end. The loop then calls
infix_next() that has
ps->infix.cnt--;
return ps->infix.string[ps->infix.tail++];
The cnt will now be below zero, and the tail that is returned is
already passed the end of the filter string. So far the allocation
of the filter string usually has some buffer that is zeroed out, but
if the filter string is of the exact size of the allocated buffer
there's no guarantee that the charater after the nul terminating
character will be zero.
Luckily, only root can write to the filter.
commit b4875bbe7e68f139bd3383828ae8e994a0df6d28 upstream.
When testing the fix for the trace filter, I could not come up with
a scenario where the operand count goes below zero, so I added a
WARN_ON_ONCE(cnt < 0) to the logic. But there is legitimate case
that it can happen (although the filter would be wrong).
That is, a single operation without any operands will hit the path
where the WARN_ON_ONCE() can trigger. Although this is harmless,
and the filter is reported as a error. But instead of spitting out
a warning to the kernel dmesg, just fail nicely and report it via
the proper channels.
Link: http://lkml.kernel.org/r/558C6082.90608@oracle.com
Reported-by: Vince Weaver <vincent.weaver@maine.edu>
Reported-by: Sasha Levin <sasha.levin@oracle.com>
commit 63781394c540dd9e666a6b21d70b64dd52bce76e upstream.
request_any_context_irq() returns a negative value on failure.
It returns either IRQC_IS_HARDIRQ or IRQC_IS_NESTED on success.
So fix testing return value of request_any_context_irq().
Also fixup the return value of devm_request_any_context_irq() to make it
consistent with request_any_context_irq().
Fixes: 0668d3065128 ("genirq: Add devm_request_any_context_irq()")
Signed-off-by: Axel Lin <axel.lin@ingics.com>
Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
Link: http://lkml.kernel.org/r/1431334978.17783.4.camel@ingics.com
commit 6e91f8cb138625be96070b778d9ba71ce520ea7e upstream.
If, at the time __rcu_process_callbacks() is invoked, there are callbacks
in Tiny RCU's callback list, but none of them are ready to be invoked,
the current list-management code will knit the non-ready callbacks out
of the list. This can result in hangs and possibly worse. This commit
therefore inserts a check for there being no callbacks that can be
invoked immediately.
This bug is unlikely to occur -- you have to get a new callback between
the time rcu_sched_qs() or rcu_bh_qs() was called, but before we get to
__rcu_process_callbacks(). It was detected by the addition of RCU-bh
testing to rcutorture, which in turn was instigated by Iftekhar Ahmed's
mutation testing. Although this bug was made much more likely by
915e8a4fe45e (rcu: Remove fastpath from __rcu_process_callbacks()), this
did not cause the bug, but rather made it much more probable. That
said, it takes more than 40 hours of rcutorture testing, on average,
for this bug to appear, so this fix cannot be considered an emergency.
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
commit 2cf30dc180cea808077f003c5116388183e54f9e upstream.
When the following filter is used it causes a warning to trigger:
# cd /sys/kernel/debug/tracing
# echo "((dev==1)blocks==2)" > events/ext4/ext4_truncate_exit/filter
-bash: echo: write error: Invalid argument
# cat events/ext4/ext4_truncate_exit/filter
((dev==1)blocks==2)
parse_error: No error
WARNING: CPU: 2 PID: 1223 at kernel/trace/trace_events_filter.c:1640 replace_preds+0x3c5/0x990()
Modules linked in: bnep lockd grace bluetooth ...
CPU: 3 PID: 1223 Comm: bash Tainted: G W 4.1.0-rc3-test+ #450
Hardware name: Hewlett-Packard HP Compaq Pro 6300 SFF/339A, BIOS K01 v02.05 05/07/2012
0000000000000668 ffff8800c106bc98 ffffffff816ed4f9 ffff88011ead0cf0
0000000000000000 ffff8800c106bcd8 ffffffff8107fb07 ffffffff8136b46c
ffff8800c7d81d48 ffff8800d4c2bc00 ffff8800d4d4f920 00000000ffffffea
Call Trace:
[<ffffffff816ed4f9>] dump_stack+0x4c/0x6e
[<ffffffff8107fb07>] warn_slowpath_common+0x97/0xe0
[<ffffffff8136b46c>] ? _kstrtoull+0x2c/0x80
[<ffffffff8107fb6a>] warn_slowpath_null+0x1a/0x20
[<ffffffff81159065>] replace_preds+0x3c5/0x990
[<ffffffff811596b2>] create_filter+0x82/0xb0
[<ffffffff81159944>] apply_event_filter+0xd4/0x180
[<ffffffff81152bbf>] event_filter_write+0x8f/0x120
[<ffffffff811db2a8>] __vfs_write+0x28/0xe0
[<ffffffff811dda43>] ? __sb_start_write+0x53/0xf0
[<ffffffff812e51e0>] ? security_file_permission+0x30/0xc0
[<ffffffff811dc408>] vfs_write+0xb8/0x1b0
[<ffffffff811dc72f>] SyS_write+0x4f/0xb0
[<ffffffff816f5217>] system_call_fastpath+0x12/0x6a
---[ end trace e11028bd95818dcd ]---
Worse yet, reading the error message (the filter again) it says that
there was no error, when there clearly was. The issue is that the
code that checks the input does not check for balanced ops. That is,
having an op between a closed parenthesis and the next token.
This would only cause a warning, and fail out before doing any real
harm, but it should still not caues a warning, and the error reported
should work:
((dev==1)blocks==2)
parse_error: Meaningless filter expression
And give no kernel warning.
Link: http://lkml.kernel.org/r/20150615175025.7e809215@gandalf.local.home
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
[ luis: backported to 3.16:
- unconditionally decrement cnt as the OP_NOT logic was introduced only
by e12c09cf3087 ("tracing: Add NOT to filtering logic") ]
Signed-off-by: Luis Henriques <luis.henriques@canonical.com>
commit 108029323910c5dd1ef8fa2d10da1ce5fbce6e12 upstream.
The producer should be used producer_fifo as its sched_priority,
so correct it.
Link: http://lkml.kernel.org/r/1433923957-67842-1-git-send-email-long.wanglong@huawei.com
Signed-off-by: Wang Long <long.wanglong@huawei.com>
commit 28423ad283d5348793b0c45cc9b1af058e776fd6 upstream.
While debugging an issue with excessive softirq usage, I encountered the
following note in commit 3e339b5dae24a706 ("softirq: Use hotplug thread
infrastructure"):
[ paulmck: Call rcu_note_context_switch() with interrupts enabled. ]
...but despite this note, the patch still calls RCU with IRQs disabled.
This seemingly innocuous change caused a significant regression in softirq
CPU usage on the sending side of a large TCP transfer (~1 GB/s): when
introducing 0.01% packet loss, the softirq usage would jump to around 25%,
spiking as high as 50%. Before the change, the usage would never exceed 5%.
Moving the call to rcu_note_context_switch() after the cond_sched() call,
as it was originally before the hotplug patch, completely eliminated this
problem.
Signed-off-by: Calvin Owens <calvinowens@fb.com>
Signed-off-by: Mike Galbraith <mgalbraith@suse.de>
commit b72c186999e689cb0b055ab1c7b3cd8fffbeb5ed upstream.
ptrace_resume() is called when the tracee is still __TASK_TRACED. We set
tracee->exit_code and then wake_up_state() changes tracee->state. If the
tracer's sub-thread does wait() in between, task_stopped_code(ptrace => T)
wrongly looks like another report from tracee.
This confuses debugger, and since wait_task_stopped() clears ->exit_code
the tracee can miss a signal.
Test-case:
#include <stdio.h>
#include <unistd.h>
#include <sys/wait.h>
#include <sys/ptrace.h>
#include <pthread.h>
#include <assert.h>
int pid;
void *waiter(void *arg)
int stat;
for (;;) {
assert(pid == wait(&stat));
assert(WIFSTOPPED(stat));
if (WSTOPSIG(stat) == SIGHUP)
continue;
assert(WSTOPSIG(stat) == SIGCONT);
printf("ERR! extra/wrong report:%x\n", stat);
int main(void)
pthread_t thread;
pid = fork();
if (!pid) {
assert(ptrace(PTRACE_TRACEME, 0,0,0) == 0);
for (;;)
kill(getpid(), SIGHUP);
assert(pthread_create(&thread, NULL, waiter, NULL) == 0);
for (;;)
ptrace(PTRACE_CONT, pid, 0, SIGCONT);
return 0;
Note for stable: the bug is very old, but without 9899d11f6544 "ptrace:
ensure arch_ptrace/ptrace_request can never race with SIGKILL" the fix
should use lock_task_sighand(child).
Reported-by: Pavel Labath <labath@google.com>
Tested-by: Pavel Labath <labath@google.com>
commit 80a9b64e2c156b6523e7a01f2ba6e5d86e722814 upstream.
It has come to my attention that this_cpu_read/write are horrible on
architectures other than x86. Worse yet, they actually disable
preemption or interrupts! This caused some unexpected tracing results
on ARM.
101.356868: preempt_count_add <-ring_buffer_lock_reserve
101.356870: preempt_count_sub <-ring_buffer_lock_reserve
The ring_buffer_lock_reserve has recursion protection that requires
accessing a per cpu variable. But since preempt_disable() is traced, it
too got traced while accessing the variable that is suppose to prevent
recursion like this.
The generic version of this_cpu_read() and write() are:
#define this_cpu_generic_read(pcp) \
({ typeof(pcp) ret__; \
preempt_disable(); \
ret__ = *this_cpu_ptr(&(pcp)); \
preempt_enable(); \
ret__; \
#define this_cpu_generic_to_op(pcp, val, op) \
do { \
unsigned long flags; \
raw_local_irq_save(flags); \
*__this_cpu_ptr(&(pcp)) op val; \
raw_local_irq_restore(flags); \
} while (0)
Which is unacceptable for locations that know they are within preempt
disabled or interrupt disabled locations.
Paul McKenney stated that __this_cpu_() versions produce much better code on
other architectures than this_cpu_() does, if we know that the call is done in
a preempt disabled location.
I also changed the recursive_unlock() to use two local variables instead
of accessing the per_cpu variable twice.
Link: http://lkml.kernel.org/r/20150317114411.GE3589@linux.vnet.ibm.com
Link: http://lkml.kernel.org/r/20150317104038.312e73d1@gandalf.local.home
Acked-by: Christoph Lameter <cl@linux.com>
Reported-by: Uwe Kleine-Koenig <u.kleine-koenig@pengutronix.de>
Tested-by: Uwe Kleine-Koenig <u.kleine-koenig@pengutronix.de>
commit 946e51f2bf37f1656916eb75bd0742ba33983c28 upstream.
move d_rcu from overlapping d_child to overlapping d_alias
Cc: Ben Hutchings <ben@decadent.org.uk>
[hujianyang: Backported to 3.14 refer to the work of Ben Hutchings in 3.2:
- Apply name changes in all the different places we use d_alias and d_child
- Move the WARN_ON() in __d_free() to d_free() as we don't have dentry_free()]
Signed-off-by: hujianyang <hujianyang@huawei.com>
commit 746db9443ea57fd9c059f62c4bfbf41cf224fe13 upstream.
When non-realtime tasks get priority-inheritance boosted to a realtime
scheduling class, RLIMIT_RTTIME starts to apply to them. However, the
counter used for checking this (the same one used for SCHED_RR
timeslices) was not getting reset. This meant that tasks running with a
non-realtime scheduling class which are repeatedly boosted to a realtime
one, but never block while they are running realtime, eventually hit the
timeout without ever running for a time over the limit. This patch
resets the realtime timeslice counter when un-PI-boosting from an RT to
a non-RT scheduling class.
I have some test code with two threads and a shared PTHREAD_PRIO_INHERIT
mutex which induces priority boosting and spins while boosted that gets
killed by a SIGXCPU on non-fixed kernels but doesn't with this patch
applied. It happens much faster with a CONFIG_PREEMPT_RT kernel, and
does happen eventually with PREEMPT_VOLUNTARY kernels.
Signed-off-by: Brian Silverman <brian@peloton-tech.com>
Cc: austin@peloton-tech.com
Link: http://lkml.kernel.org/r/1424305436-6716-1-git-send-email-brian@peloton-tech.com
commit d525211f9d1be8b523ec7633f080f2116f5ea536 upstream.
Vince reported a watchdog lockup like:
[<ffffffff8115e114>] perf_tp_event+0xc4/0x210
[<ffffffff810b4f8a>] perf_trace_lock+0x12a/0x160
[<ffffffff810b7f10>] lock_release+0x130/0x260
[<ffffffff816c7474>] _raw_spin_unlock_irqrestore+0x24/0x40
[<ffffffff8107bb4d>] do_send_sig_info+0x5d/0x80
[<ffffffff811f69df>] send_sigio_to_task+0x12f/0x1a0
[<ffffffff811f71ce>] send_sigio+0xae/0x100
[<ffffffff811f72b7>] kill_fasync+0x97/0xf0
[<ffffffff8115d0b4>] perf_event_wakeup+0xd4/0xf0
[<ffffffff8115d103>] perf_pending_event+0x33/0x60
[<ffffffff8114e3fc>] irq_work_run_list+0x4c/0x80
[<ffffffff8114e448>] irq_work_run+0x18/0x40
[<ffffffff810196af>] smp_trace_irq_work_interrupt+0x3f/0xc0
[<ffffffff816c99bd>] trace_irq_work_interrupt+0x6d/0x80
Which is caused by an irq_work generating new irq_work and therefore
not allowing forward progress.
This happens because processing the perf irq_work triggers another
perf event (tracepoint stuff) which in turn generates an irq_work ad
infinitum.
Avoid this by raising the recursion counter in the irq_work -- which
effectively disables all software events (including tracepoints) from
actually triggering again.
Cc: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/r/20150219170311.GH21418@twins.programming.kicks-ass.net
commit 283cb41f426b723a0255702b761b0fc5d1b53a81 upstream.
The cpuset.sched_relax_domain_level can control how far we do
immediate load balancing on a system. However, it was found on recent
kernels that echo'ing a value into cpuset.sched_relax_domain_level
did not reduce any immediate load balancing.
The reason this occurred was because the update_domain_attr_tree() traversal
did not update for the "top_cpuset". This resulted in nothing being changed
when modifying the sched_relax_domain_level parameter.
This patch is able to address that problem by having update_domain_attr_tree()
allow updates for the root in the cpuset traversal.
Fixes: fc560a26acce ("cpuset: replace cpuset->stack_list with cpuset_for_each_descendant_pre()")
Signed-off-by: Jason Low <jason.low2@hp.com>
Signed-off-by: Zefan Li <lizefan@huawei.com>
Tested-by: Serge Hallyn <serge.hallyn@canonical.com>
PREEMPT_NONE
commit 8603e1b30027f943cc9c1eef2b291d42c3347af1 upstream.
cancel[_delayed]_work_sync() are implemented using
__cancel_work_timer() which grabs the PENDING bit using
try_to_grab_pending() and then flushes the work item with PENDING set
to prevent the on-going execution of the work item from requeueing
itself.
try_to_grab_pending() can always grab PENDING bit without blocking
except when someone else is doing the above flushing during
cancelation. In that case, try_to_grab_pending() returns -ENOENT. In
this case, __cancel_work_timer() currently invokes flush_work(). The
assumption is that the completion of the work item is what the other
canceling task would be waiting for too and thus waiting for the same
condition and retrying should allow forward progress without excessive
busy looping
Unfortunately, this doesn't work if preemption is disabled or the
latter task has real time priority. Let's say task A just got woken
up from flush_work() by the completion of the target work item. If,
before task A starts executing, task B gets scheduled and invokes
__cancel_work_timer() on the same work item, its try_to_grab_pending()
will return -ENOENT as the work item is still being canceled by task A
and flush_work() will also immediately return false as the work item
is no longer executing. This puts task B in a busy loop possibly
preventing task A from executing and clearing the canceling state on
the work item leading to a hang.
task A task B worker
executing work
set work CANCELING
flush_work()
block for work completion
completion, wakes up A
while (forever) {
-ENOENT as work is being canceled
flush_work()
false as work is no longer executing
This patch removes the possible hang by updating __cancel_work_timer()
to explicitly wait for clearing of CANCELING rather than invoking
flush_work() after try_to_grab_pending() fails with -ENOENT.
Link: http://lkml.kernel.org/g/20150206171156.GA8942@axis.com
v3: bit_waitqueue() can't be used for work items defined in vmalloc
area. Switched to custom wake function which matches the target
work item and exclusive wait and wakeup.
v2: v1 used wake_up() on bit_waitqueue() which leads to NULL deref if
the target bit waitqueue has wait_bit_queue's on it. Use
DEFINE_WAIT_BIT() and __wake_up_bit() instead. Reported by Tomeu
Vizoso.
Reported-by: Rabin Vincent <rabin.vincent@axis.com>
Cc: Tomeu Vizoso <tomeu.vizoso@gmail.com>
Tested-by: Jesper Nilsson <jesper.nilsson@axis.com>
Tested-by: Rabin Vincent <rabin.vincent@axis.com>
commit 30a22c215a0007603ffc08021f2e8b64018517dd upstream.
commit 6ae9200f2cab7 ("enlarge console.name") increased the storage
for the console name to 16 bytes, but not the corresponding
struct console_cmdline::name storage. Console names longer than
8 bytes cause read beyond end-of-string and failure to match
console; I'm not sure if there are other unexpected consequences.
Signed-off-by: Peter Hurley <peter@hurleysoftware.com>
commit 29183a70b0b828500816bd794b3fe192fce89f73 upstream.
Additional validation of adjtimex freq values to avoid
potential multiplication overflows were added in commit
5e5aeb4367b (time: adjtimex: Validate the ADJ_FREQUENCY values)
Unfortunately the patch used LONG_MAX/MIN instead of
LLONG_MAX/MIN, which was fine on 64-bit systems, but being
much smaller on 32-bit systems caused false positives
resulting in most direct frequency adjustments to fail w/
EINVAL.
ntpd only does direct frequency adjustments at startup, so
the issue was not as easily observed there, but other time
sync applications like ptpd and chrony were more effected by
the bug.
See bugs:
https://bugzilla.kernel.org/show_bug.cgi?id=92481
https://bugzilla.redhat.com/show_bug.cgi?id=1188074
This patch changes the checks to use LLONG_MAX for
clarity, and additionally the checks are disabled
on 32-bit systems since LLONG_MAX/PPM_SCALE is always
larger then the 32-bit long freq value, so multiplication
overflows aren't possible there.
Reported-by: Josh Boyer <jwboyer@fedoraproject.org>
Reported-by: George Joseph <george.joseph@fairview5.com>
Tested-by: George Joseph <george.joseph@fairview5.com>
Signed-off-by: John Stultz <john.stultz@linaro.org>
Cc: Sasha Levin <sasha.levin@oracle.com>
Link: http://lkml.kernel.org/r/1423553436-29747-1-git-send-email-john.stultz@linaro.org
[ Prettified the changelog and the comments a bit. ]
commit 146755923262037fc4c54abc28c04b1103f3cc51 upstream.
The output of KDB 'summary' command should report MemTotal, MemFree
and Buffers output in kB. Current codes report in unit of pages.
A define of K(x) as
is defined in the code, but not used.
This patch would apply the define to convert the values to kB.
Please include me on Cc on replies. I do not subscribe to linux-kernel.
Signed-off-by: Jay Lan <jlan@sgi.com>
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
commit 7215853e985a4bef1a6c14e00e89dfec84f1e457 upstream.
Commit 6edb2a8a385f0cdef51dae37ff23e74d76d8a6ce introduced
an array map_pages that contains the addresses returned by
kmap_atomic. However, when unmapping those pages, map_pages[0]
is unmapped before map_pages[1], breaking the nesting requirement
as specified in the documentation for kmap_atomic/kunmap_atomic.
This was caught by the highmem debug code present in kunmap_atomic.
Fix the loop to do the unmapping properly.
Link: http://lkml.kernel.org/r/1418871056-6614-1-git-send-email-markivx@codeaurora.org
Reported-by: Lime Yang <limey@codeaurora.org>
Signed-off-by: Vikram Mulukutla <markivx@codeaurora.org>
commit 4bee96860a65c3a62d332edac331b3cf936ba3ad upstream.
The following race exists in the smpboot percpu threads management:
CPU0 CPU1
cpu_up(2)
get_online_cpus();
smpboot_create_threads(2);
smpboot_register_percpu_thread();
for_each_online_cpu();
__smpboot_create_thread();
__cpu_up(2);
This results in a missing per cpu thread for the newly onlined cpu2 and
in a NULL pointer dereference on a consecutive offline of that cpu.
Proctect smpboot_register_percpu_thread() with get_online_cpus() to
prevent that.
[ tglx: Massaged changelog and removed the change in
smpboot_unregister_percpu_thread() because that's an
optimization and therefor not stable material. ]
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/1406777421-12830-1-git-send-email-laijs@cn.fujitsu.com
commit 29187a9eeaf362d8422e62e17a22a6e115277a49 upstream.
A worker_pool's forward progress is guaranteed by the fact that the
last idle worker assumes the manager role to create more workers and
summon the rescuers if creating workers doesn't succeed in timely
manner before proceeding to execute work items.
This manager role is implemented in manage_workers(), which indicates
whether the worker may proceed to work item execution with its return
value. This is necessary because multiple workers may contend for the
manager role, and, if there already is a manager, others should
proceed to work item execution.
Unfortunately, the function also indicates that the worker may proceed
to work item execution if need_to_create_worker() is false at the head
of the function. need_to_create_worker() tests the following
conditions.
pending work items && !nr_running && !nr_idle
The first and third conditions are protected by pool->lock and thus
won't change while holding pool->lock; however, nr_running can change
asynchronously as other workers block and resume and while it's likely
to be zero, as someone woke this worker up in the first place, some
other workers could have become runnable inbetween making it non-zero.
If this happens, manage_worker() could return false even with zero
nr_idle making the worker, the last idle one, proceed to execute work
items. If then all workers of the pool end up blocking on a resource
which can only be released by a work item which is pending on that
pool, the whole pool can deadlock as there's no one to create more
workers or summon the rescuers.
This patch fixes the problem by removing the early exit condition from
maybe_create_worker() and making manage_workers() return false iff
there's already another manager, which ensures that the last worker
doesn't start executing work items.
We can leave the early exit condition alone and just ignore the return
value but the only reason it was put there is because the
manage_workers() used to perform both creations and destructions of
workers and thus the function may be invoked while the pool is trying
to reduce the number of workers. Now that manage_workers() is called
only when more workers are needed, the only case this early exit
condition is triggered is rare race conditions rendering it pointless.
Tested with simulated workload and modified workqueue code which
trigger the pool deadlock reliably without this patch.
tj: Updated to v3.14 where manage_workers() is responsible not only
for creating more workers but also destroying surplus ones.
maybe_create_worker() needs to keep its early exit condition to
avoid creating a new worker when manage_workers() is called to
destroy surplus ones. Other than that, the adaptabion is
straight-forward. Both maybe_{create|destroy}_worker() functions
are converted to return void and manage_workers() returns %false
iff it lost manager arbitration.
Reported-by: Eric Sandeen <sandeen@sandeen.net>
Link: http://lkml.kernel.org/g/54B019F4.8030009@sandeen.net
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
commit 664eeddeef6539247691197c1ac124d4aa872ab6 upstream.
If cpusets are not in use then we still check a global variable on every
page allocation. Use jump labels to avoid the overhead.
Cc: Jan Kara <jack@suse.cz>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
commit 5e5aeb4367b450a28f447f6d5ab57d8f2ab16a5f upstream.
Verify that the frequency value from userspace is valid and makes sense.
Unverified values can cause overflows later on.
[jstultz: Fix up bug for negative values and drop redunent cap check]
commit 6ada1fc0e1c4775de0e043e1bd3ae9d065491aa5 upstream.
An unvalidated user input is multiplied by a constant, which can result in
an undefined behaviour for large values. While this is validated later,
we should avoid triggering undefined behaviour.
[jstultz: include trivial milisecond->microsecond correction noticed
by Andy]
commit c291ee622165cb2c8d4e7af63fffd499354a23be upstream.
Since the rework of the sparse interrupt code to actually free the
unused interrupt descriptors there exists a race between the /proc
interfaces to the irq subsystem and the code which frees the interrupt
descriptor.
CPU0 CPU1
show_interrupts()
desc = irq_to_desc(X);
free_desc(desc)
remove_from_radix_tree();
kfree(desc);
raw_spinlock_irq(&desc->lock);
/proc/interrupts is the only interface which can actively corrupt
kernel memory via the lock access. /proc/stat can only read from freed
memory. Extremly hard to trigger, but possible.
The interfaces in /proc/irq/N/ are not affected by this because the
removal of the proc file is serialized in procfs against concurrent
readers/writers. The removal happens before the descriptor is freed.
For architectures which have CONFIG_SPARSE_IRQ=n this is a non issue
as the descriptor is never freed. It's merely cleared out with the irq
descriptor lock held. So any concurrent proc access will either see
the old correct value or the cleared out ones.
Protect the lookup and access to the irq descriptor in
show_interrupts() with the sparse_irq_lock.
Provide kstat_irqs_usr() which is protecting the lookup and access
with sparse_irq_lock and switch /proc/stat to use it.
Document the existing kstat_irqs interfaces so it's clear that the
caller needs to take care about protection. The users of these
interfaces are either not affected due to SPARSE_IRQ=n or already
protected against removal.
Fixes: 1f5a5b87f78f "genirq: Implement a sane sparse_irq allocator"
commit a5fd9733a30d18d7ac23f17080e7e07bb3205b69 upstream.
commit 4dbd27711cd9 "tick: export nohz tick idle symbols for module
use" was merged via the thermal tree without an explicit ack from the
relevant maintainers.
The exports are abused by the intel powerclamp driver which implements
a fake idle state from a sched FIFO task. This causes all kinds of
wreckage in the NOHZ core code which rightfully assumes that
tick_nohz_idle_enter/exit() are only called from the idle task itself.
Recent changes in the NOHZ core lead to a failure of the powerclamp
driver and now people try to hack completely broken and backwards
workarounds into the NOHZ core code. This is completely unacceptable
and just papers over the real problem. There are way more subtle
issues lurking around the corner.
The real solution is to fix the powerclamp driver by rewriting it with
a sane concept, but that's beyond the scope of this.
So the only solution for now is to remove the calls into the core NOHZ
code from the powerclamp trainwreck along with the exports.
Fixes: d6d71ee4a14a "PM: Introduce Intel PowerClamp Driver"
Cc: Preeti U Murthy <preeti@linux.vnet.ibm.com>
Cc: Viresh Kumar <viresh.kumar@linaro.org>
Cc: Fengguang Wu <fengguang.wu@intel.com>
Cc: Frederic Weisbecker <frederic@kernel.org>
Cc: Pan Jacob jun <jacob.jun.pan@intel.com>
Cc: LKP <lkp@01.org>
Cc: Zhang Rui <rui.zhang@intel.com>
Link: http://lkml.kernel.org/r/alpine.DEB.2.11.1412181110110.17382@nanos
commit 9fc81d87420d0d3fd62d5e5529972c0ad9eab9cc upstream.
We allow PMU driver to change the cpu on which the event
should be installed to. This happened in patch:
e2d37cd213dc ("perf: Allow the PMU driver to choose the CPU on which to install events")
This patch also forces all the group members to follow
the currently opened events cpu if the group happened
to be moved.
This and the change of event->cpu in perf_install_in_context()
function introduced in:
0cda4c023132 ("perf: Introduce perf_pmu_migrate_context()")
forces group members to change their event->cpu,
if the currently-opened-event's PMU changed the cpu
and there is a group move.
Above behaviour causes problem for breakpoint events,
which uses event->cpu to touch cpu specific data for
breakpoints accounting. By changing event->cpu, some
breakpoints slots were wrongly accounted for given
cpu.
Vinces's perf fuzzer hit this issue and caused following
WARN on my setup:
WARNING: CPU: 0 PID: 20214 at arch/x86/kernel/hw_breakpoint.c:119 arch_install_hw_breakpoint+0x142/0x150()
Can't find any breakpoint slot
This patch changes the group moving code to keep the event's
original cpu.
Reported-by: Vince Weaver <vince@deater.net>
Signed-off-by: Jiri Olsa <jolsa@redhat.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Vince Weaver <vince@deater.net>
Cc: Yan, Zheng <zheng.z.yan@intel.com>
Link: http://lkml.kernel.org/r/1418243031-20367-3-git-send-email-jolsa@kernel.org
commit 269ad8015a6b2bb1cf9e684da4921eb6fa0a0c88 upstream.
The dl_runtime_exceeded() function is supposed to ckeck if
a SCHED_DEADLINE task must be throttled, by checking if its
current runtime is <= 0. However, it also checks if the
scheduling deadline has been missed (the current time is
larger than the current scheduling deadline), further
decreasing the runtime if this happens.
This "double accounting" is wrong:
- In case of partitioned scheduling (or single CPU), this
happens if task_tick_dl() has been called later than expected
(due to small HZ values). In this case, the current runtime is
also negative, and replenish_dl_entity() can take care of the
deadline miss by recharging the current runtime to a value smaller
than dl_runtime
- In case of global scheduling on multiple CPUs, scheduling
deadlines can be missed even if the task did not consume more
runtime than expected, hence penalizing the task is wrong
This patch fix this problem by throttling a SCHED_DEADLINE task
only when its runtime becomes negative, and not modifying the runtime
Signed-off-by: Luca Abeni <luca.abeni@unitn.it>
Acked-by: Juri Lelli <juri.lelli@gmail.com>
Cc: Dario Faggioli <raistlin@linux.it>
Link: http://lkml.kernel.org/r/1418813432-20797-3-git-send-email-luca.abeni@unitn.it
commit 6a503c3be937d275113b702e0421e5b0720abe8a upstream.
According to global EDF, tasks should be migrated between runqueues
without checking if their scheduling deadlines and runtimes are valid.
However, SCHED_DEADLINE currently performs such a check:
a migration happens doing:
deactivate_task(rq, next_task, 0);
set_task_cpu(next_task, later_rq->cpu);
activate_task(later_rq, next_task, 0);
which ends up calling dequeue_task_dl(), setting the new CPU, and then
calling enqueue_task_dl().
enqueue_task_dl() then calls enqueue_dl_entity(), which calls
update_dl_entity(), which can modify scheduling deadline and runtime,
breaking global EDF scheduling.
As a result, some of the properties of global EDF are not respected:
for example, a taskset {(30, 80), (40, 80), (120, 170)} scheduled on
two cores can have unbounded response times for the third task even
if 30/80+40/80+120/170 = 1.5809 < 2
This can be fixed by invoking update_dl_entity() only in case of
wakeup, or if this is a new SCHED_DEADLINE task.
Link: http://lkml.kernel.org/r/1418813432-20797-2-git-send-email-luca.abeni@unitn.it
commit 24c037ebf5723d4d9ab0996433cee4f96c292a4d upstream.
alloc_pid() does get_pid_ns() beforehand but forgets to put_pid_ns() if it
fails because disable_pid_allocation() was called by the exiting
child_reaper.
We could simply move get_pid_ns() down to successful return, but this fix
tries to be as trivial as possible.
Reviewed-by: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Aaron Tomlin <atomlin@redhat.com>
Cc: Pavel Emelyanov <xemul@parallels.com>
Cc: Serge Hallyn <serge.hallyn@ubuntu.com>
Cc: Sterling Alexander <stalexan@redhat.com>
commit 041d7b98ffe59c59fdd639931dea7d74f9aa9a59 upstream.
A regression was caused by commit 780a7654cee8:
audit: Make testing for a valid loginuid explicit.
(which in turn attempted to fix a regression caused by e1760bd)
When audit_krule_to_data() fills in the rules to get a listing, there was a
missing clause to convert back from AUDIT_LOGINUID_SET to AUDIT_LOGINUID.
This broke userspace by not returning the same information that was sent and
expected.
The rule:
auditctl -a exit,never -F auid=-1
gives:
auditctl -l
LIST_RULES: exit,never f24=0 syscall=all
when it should give:
LIST_RULES: exit,never auid=-1 (0xffffffff) syscall=all
Tag it so that it is reported the same way it was set. Create a new
private flags audit_krule field (pflags) to store it that won't interact with
the public one from the API.
Signed-off-by: Richard Guy Briggs <rgb@redhat.com>
Signed-off-by: Paul Moore <pmoore@redhat.com>
commit 66d2f338ee4c449396b6f99f5e75cd18eb6df272 upstream.
Now that setgroups can be disabled and not reenabled, setting gid_map
without privielge can now be enabled when setgroups is disabled.
This restores most of the functionality that was lost when unprivileged
setting of gid_map was removed. Applications that use this functionality
will need to check to see if they use setgroups or init_groups, and if they
don't they can be fixed by simply disabling setgroups before writing to
gid_map.
Reviewed-by: Andy Lutomirski <luto@amacapital.net>
commit 9cc46516ddf497ea16e8d7cb986ae03a0f6b92f8 upstream.
- Expose the knob to user space through a proc file /proc/<pid>/setgroups
A value of "deny" means the setgroups system call is disabled in the
current processes user namespace and can not be enabled in the
future in this user namespace.
A value of "allow" means the segtoups system call is enabled.
- Descendant user namespaces inherit the value of setgroups from
their parents.
- A proc file is used (instead of a sysctl) as sysctls currently do
not allow checking the permissions at open time.
- Writing to the proc file is restricted to before the gid_map
for the user namespace is set.
This ensures that disabling setgroups at a user namespace
level will never remove the ability to call setgroups
from a process that already has that ability.
A process may opt in to the setgroups disable for itself by
creating, entering and configuring a user namespace or by calling
setns on an existing user namespace with setgroups disabled.
Processes without privileges already can not call setgroups so this
is a noop. Prodcess with privilege become processes without
privilege when entering a user namespace and as with any other path
to dropping privilege they would not have the ability to call
setgroups. So this remains within the bounds of what is possible
without a knob to disable setgroups permanently in a user namespace.
commit f0d62aec931e4ae3333c797d346dc4f188f454ba upstream.
Generalize id_map_mutex so it can be used for more state of a user namespace.
commit f95d7918bd1e724675de4940039f2865e5eec5fe upstream.
If you did not create the user namespace and are allowed
to write to uid_map or gid_map you should already have the necessary
privilege in the parent user namespace to establish any mapping
you want so this will not affect userspace in practice.
Limiting unprivileged uid mapping establishment to the creator of the
user namespace makes it easier to verify all credentials obtained with
the uid mapping can be obtained without the uid mapping without
privilege.
Limiting unprivileged gid mapping establishment (which is temporarily
absent) to the creator of the user namespace also ensures that the
combination of uid and gid can already be obtained without privilege.
This is part of the fix for CVE-2014-8989.
commit 80dd00a23784b384ccea049bfb3f259d3f973b9d upstream.
setresuid allows the euid to be set to any of uid, euid, suid, and
fsuid. Therefor it is safe to allow an unprivileged user to map
their euid and use CAP_SETUID privileged with exactly that uid,
as no new credentials can be obtained.
I can not find a combination of existing system calls that allows setting
uid, euid, suid, and fsuid from the fsuid making the previous use
of fsuid for allowing unprivileged mappings a bug.
This is part of a fix for CVE-2014-8989.
commit be7c6dba2332cef0677fbabb606e279ae76652c3 upstream.
As any gid mapping will allow and must allow for backwards
compatibility dropping groups don't allow any gid mappings to be
established without CAP_SETGID in the parent user namespace.
For a small class of applications this change breaks userspace
and removes useful functionality. This small class of applications
includes tools/testing/selftests/mount/unprivilged-remount-test.c
Most of the removed functionality will be added back with the addition
of a one way knob to disable setgroups. Once setgroups is disabled
setting the gid_map becomes as safe as setting the uid_map.
For more common applications that set the uid_map and the gid_map
with privilege this change will have no affect.
