path: root/kernel
2015-11-01Merge branch 'libnvdimm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm Pull memremap fix from Dan Williams: "The new memremap() api introduced in the 4.3 cycle to unify/replace ioremap_cache() and ioremap_wt() is mishandling the highmem case. This patch has received a build success notification from a 0day-kbuild-robot run and has received an ack from Ard" From the commit message: "The impact of this bug is low for now since the pmem driver is the only user of memremap(), but this is important to fix before more conversions to memremap arrive in 4.4" * 'libnvdimm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm: memremap: fix highmem support
2015-10-28Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module preemption fix from Rusty Russell: "Turns out we should have always been disabling preemption here; someone finally caught it thanks to Peter Z's additional checks" * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: module: Fix locking in symbol_put_addr()
2015-10-26memremap: fix highmem supportDan Williams
Currently memremap checks if the range is "System RAM" and returns the kernel linear address. This is broken for highmem platforms where a range may be "System RAM", but is not part of the kernel linear mapping. Fallback to ioremap_cache() in these cases, to let the arch code attempt to handle it. Note that ARM ioremap will WARN when attempting to remap ram, and in that case the caller needs to be fixed. For this reason, existing ioremap_cache() usages for ARM are already trained to avoid attempts to remap ram. The impact of this bug is low for now since the pmem driver is the only user of memremap(), but this is important to fix before more conversions to memremap arrive in 4.4. Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Reported-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Acked-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2015-10-23Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fixes from Ingo Molnar: "Misc fixes all around the map: an instrumentation fix, a nohz usability fix, a lockdep annotation fix and two task group scheduling fixes" * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched/core: Add missing lockdep_unpin() annotations sched/deadline: Fix migration of SCHED_DEADLINE tasks nohz: Revert "nohz: Set isolcpus when nohz_full is set" sched/fair: Update task group's load_avg after task migration sched/fair: Fix overly small weight for interactive group entities sched, tracing: Stop/start critical timings around the idle=poll idle loop
2015-10-23Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge fixes from Andrew Morton: "9 fixes" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: ocfs2/dlm: unlock lockres spinlock before dlm_lockres_put fault-inject: fix inverted interval/probability values in printk lib/Kconfig.debug: disable -Wframe-larger-than warnings with KASAN=y mm: make sendfile(2) killable thp: use is_zero_pfn() only after pte_present() check mailmap: update Javier Martinez Canillas' email MAINTAINERS: add Sergey as zsmalloc reviewer mm: cma: fix incorrect type conversion for size during dma allocation kmod: don't run async usermode helper as a child of kworker thread
2015-10-23sched/core: Add missing lockdep_unpin() annotationsPeter Zijlstra
Luca and Wanpeng reported two missing annotations that led to false lockdep complaints. Add the missing annotations. Reported-by: Luca Abeni <luca.abeni@unitn.it> Reported-by: Wanpeng Li <wanpeng.li@hotmail.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Juri Lelli <juri.lelli@arm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Fixes: cbce1a686700 ("sched,lockdep: Employ lock pinning") Link: http://lkml.kernel.org/r/20151023095008.GY17308@twins.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-10-23kmod: don't run async usermode helper as a child of kworker threadOleg Nesterov
call_usermodehelper_exec_sync() does fork() + wait() with "unignored" SIGCHLD. What we have missed is that this worker thread can have other children previously forked by call_usermodehelper_exec_work() without UMH_WAIT_PROC. If such a child exits in between it becomes a zombie because auto-reaping only works if SIGCHLD is ignored, and nobody can reap it (unless/until this worker thread exits too). Change the !UMH_WAIT_PROC case to use CLONE_PARENT. Note: this is only first step. All PF_KTHREAD tasks, even created by kernel_thread() should have ->parent == kthreadd by default. Fixes: bb304a5c6fc63d8506c ("kmod: handle UMH_WAIT_PROC from system unbound workqueue") Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Christoph Lameter <cl@linux.com> Cc: Tejun Heo <tj@kernel.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-10-20tracing: Do not allow stack_tracer to record stack in NMISteven Rostedt (Red Hat)
The code in stack tracer should not be executed within an NMI as it grabs spinlocks and stack tracing an NMI gives the possibility of causing a deadlock. Although this is safe on x86_64, because it does not perform stack traces when the task struct stack is not in use (interrupts and NMIs), it may be an issue for NMIs on i386 and other archs that use the same stack as the NMI. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-10-20tracing: Have stack tracer force RCU to be watchingSteven Rostedt (Red Hat)
The stack tracer was triggering the WARN_ON() in module.c: static void module_assert_mutex_or_preempt(void) { #ifdef CONFIG_LOCKDEP if (unlikely(!debug_locks)) return; WARN_ON(!rcu_read_lock_sched_held() && !lockdep_is_held(&module_mutex)); #endif } The reason is that the stack tracer traces all function calls, and some of those calls happen while exiting or entering user space and idle. Some of these functions are called after RCU had already stopped watching, as RCU does not watch userspace or idle CPUs. If a max stack is hit, then the save_stack_trace() is called, which will check module addresses and call module_assert_mutex_or_preempt(), and then trigger the warning. Sad part is, the warning itself will also do a stack trace and tigger the same warning. That probably should be fixed. The warning was added by 0be964be0d45 "module: Sanitize RCU usage and locking" but this bug has probably been around longer. But it's unlikely to cause much harm, but the new warning causes the system to lock up. Cc: stable@vger.kernel.org # 4.2+ Cc: Peter Zijlstra <peterz@infradead.org> Cc:"Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-10-20sched/deadline: Fix migration of SCHED_DEADLINE tasksLuca Abeni
Commit: 9d5142624256 ("sched/deadline: Reduce rq lock contention by eliminating locking of non-feasible target") broke select_task_rq_dl() and find_lock_later_rq(), because it introduced a comparison between the local task's deadline and dl.earliest_dl.curr of the remote queue. However, if the remote runqueue does not contain any SCHED_DEADLINE task its earliest_dl.curr is 0 (always smaller than the deadline of the local task) and the remote runqueue is not selected for pushing. As a result, if an application creates multiple SCHED_DEADLINE threads, they will never be pushed to runqueues that do not already contain SCHED_DEADLINE tasks. This patch fixes the issue by checking if dl.dl_nr_running == 0. Signed-off-by: Luca Abeni <luca.abeni@unitn.it> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Juri Lelli <juri.lelli@arm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Wanpeng Li <wanpeng.li@linux.intel.com> Fixes: 9d5142624256 ("sched/deadline: Reduce rq lock contention by eliminating locking of non-feasible target") Link: http://lkml.kernel.org/r/1444982781-15608-1-git-send-email-luca.abeni@unitn.it Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-10-20nohz: Revert "nohz: Set isolcpus when nohz_full is set"Frederic Weisbecker
This reverts: 8cb9764fc88b ("nohz: Set isolcpus when nohz_full is set") We assumed that full-nohz users always want scheduler isolation on full dynticks CPUs, therefore we included full-nohz CPUs on cpu_isolated_map. This means that tasks run by default on CPUs outside the nohz_full range unless their affinity is explicity overwritten. This suits pure isolation workloads but when the machine is needed to run common workloads, the available sets of CPUs to run common tasks becomes reduced. We reach an extreme case when CONFIG_NO_HZ_FULL_ALL is enabled as it leaves only CPU 0 for non-isolation tasks, which makes people think that their supercomputer regressed to 90's UP - which is true in a sense. Some full-nohz users appear to be interested in running normal workloads either before or after an isolation workload. Full-nohz isn't optimized toward normal workloads but it's still better than UP performance. We are reaching a limitation in kernel presets here. Lets revert this cpu_isolated_map inclusion and let userspace do its own scheduler isolation using cpusets or explicit affinity settings. Reported-by: Ingo Molnar <mingo@kernel.org> Reported-by: Mike Galbraith <umgwanakikbuti@gmail.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: Christoph Lameter <cl@linux.com> Cc: Dave Jones <davej@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Paul E . McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Link: http://lkml.kernel.org/r/1444663283-30068-1-git-send-email-fweisbec@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-10-20sched/fair: Update task group's load_avg after task migrationYuyang Du
When cfs_rq has cfs_rq->removed_load_avg set (when a task migrates from this cfs_rq), we need to update its contribution to the group's load_avg. This should not increase tg's update too much, because in most cases, the cfs_rq has already decayed its load_avg. Tested-by: Dietmar Eggemann <dietmar.eggemann@arm.com> Signed-off-by: Yuyang Du <yuyang.du@intel.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Acked-by: Dietmar Eggemann <dietmar.eggemann@arm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1444699103-20272-2-git-send-email-yuyang.du@intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-10-20sched/fair: Fix overly small weight for interactive group entitiesYuyang Du
Commit: 9d89c257dfb9 ("sched/fair: Rewrite runnable load and utilization average tracking") led to an overly small weight for interactive group entities. The bad case can be easily reproduced when a number of CPU hogs compete for the CPUs at the same time (thanks to Mike). This is largly because the task group's load average tracking cross CPUs lags behind the real changes. To fix this we accelerate the group share distribution process by using the load.weight of the cfs_rq. This may increase the entire group's share, but we have to do so to protect the (fragile) interactive tasks, especially from CPU hogs. Reported-by: Mike Galbraith <umgwanakikbuti@gmail.com> Tested-by: Dietmar Eggemann <dietmar.eggemann@arm.com> Tested-by: Mike Galbraith <umgwanakikbuti@gmail.com> Signed-off-by: Yuyang Du <yuyang.du@intel.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Acked-by: Dietmar Eggemann <dietmar.eggemann@arm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1444699103-20272-1-git-send-email-yuyang.du@intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-10-17Merge branches 'irq-urgent-for-linus' and 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq/timer fixes from Thomas Gleixner: "irq: a fix for the new hierarchical MSI interrupt handling which unbreaks PCI=n configurations. timers: a fix for the new hrtimer clock offset update mechanism to ensure that the boot time offset is respected" * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: genirq/msi: Do not use pci_msi_[un]mask_irq as default methods * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: timekeeping: Increment clock_was_set_seq in timekeeping_init()
2015-10-16timekeeping: Increment clock_was_set_seq in timekeeping_init()Thomas Gleixner
timekeeping_init() can set the wall time offset, so we need to increment the clock_was_set_seq counter. That way hrtimers will pick up the early offset immediately. Otherwise on a machine which does not set wall time later in the boot process the hrtimer offset is stale at 0 and wall time timers are going to expire with a delay of 45 years. Fixes: 868a3e915f7f "hrtimer: Make offset update smarter" Reported-and-tested-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Stefan Liebler <stli@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: John Stultz <john.stultz@linaro.org>
2015-10-16genirq/msi: Do not use pci_msi_[un]mask_irq as default methodsMarc Zyngier
When we create a generic MSI domain, that MSI_FLAG_USE_DEF_CHIP_OPS is set, and that any of .mask or .unmask are NULL in the irq_chip structure, we set them to pci_msi_[un]mask_irq. This is a bad idea for at least two reasons: - PCI_MSI might not be selected, kernel fails to build (yes, this is legitimate, at least on arm64!) - This may not be a PCI/MSI domain at all (platform MSI, for example) Either way, this looks wrong. Move the overriding of mask/unmask to the PCI counterpart, and panic is any of these two methods is not set in the core code (they really should be present). Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Cc: Jiang Liu <jiang.liu@linux.intel.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Link: http://lkml.kernel.org/r/1444760085-27857-1-git-send-email-marc.zyngier@arm.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-10-15Merge branch 'for-4.3-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq Pull workqueue fixlet from Tejun Heo: "Single patch to make delayed work always be queued on the local CPU" This is not actually something we should guarantee, but it's something we by accident have historically done, and at least one call site has grown to depend on it. I'm going to fix that known broken callsite, but in the meantime this makes the accidental behavior be explicit, just in case there are other cases that might depend on it. * 'for-4.3-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: workqueue: make sure delayed work run in local cpu
2015-10-12sched, tracing: Stop/start critical timings around the idle=poll idle loopDaniel Bristot de Oliveira
When using idle=poll, the preemptoff tracer is always showing the idle task as the culprit for long latencies. That happens because critical timings are not stopped before idle loop. This patch stops critical timings before entering the idle loop, starting it again after the idle loop. This problem does not affect the irqsoff tracer because interruptions are enabled before entering the idle loop. Signed-off-by: Daniel Bristot de Oliveira <bristot@redhat.com> Reviewed-by: Luis Claudio R. Goncalves <lgoncalv@redhat.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/10fc3705874aef11dbe152a068b591a7be1899b4.1444314899.git.bristot@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-10-11Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fix from Thomas Gleixner: "Fix a long standing state race in finish_task_switch()" * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched/core: Fix TASK_DEAD race in finish_task_switch()
2015-10-09genirq: Fix handle_bad_irq kerneldoc commentArnd Bergmann
A recent cleanup removed the 'irq' parameter from many functions, but left the documentation for this in place for at least one function. This removes it. Fixes: bd0b9ac405e1 ("genirq: Remove irq argument from irq flow handlers") Reported-by: kbuild test robot <lkp@intel.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Grygorii Strashko <grygorii.strashko@ti.com> Cc: Tony Lindgren <tony@atomide.com> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: kbuild-all@01.org Cc: Austin Schuh <austin@peloton-tech.com> Cc: Santosh Shilimkar <ssantosh@kernel.org> Cc: linux-arm-kernel@lists.infradead.org Link: http://lkml.kernel.org/r/5400000.cD19rmgWjV@wuerfel Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-10-09genirq: Export handle_bad_irqArnd Bergmann
A cleanup of the omap gpio driver introduced a use of the handle_bad_irq() function in a device driver that can be a loadable module. This broke the ARM allmodconfig build: ERROR: "handle_bad_irq" [drivers/gpio/gpio-omap.ko] undefined! This patch exports the handle_bad_irq symbol in order to allow the use in modules. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Grygorii Strashko <grygorii.strashko@ti.com> Cc: Santosh Shilimkar <ssantosh@kernel.org> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Austin Schuh <austin@peloton-tech.com> Cc: Tony Lindgren <tony@atomide.com> Cc: linux-arm-kernel@lists.infradead.org Link: http://lkml.kernel.org/r/5847725.4IBopItaOr@wuerfel Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-10-06sched/core: Fix TASK_DEAD race in finish_task_switch()Peter Zijlstra
So the problem this patch is trying to address is as follows: CPU0 CPU1 context_switch(A, B) ttwu(A) LOCK A->pi_lock A->on_cpu == 0 finish_task_switch(A) prev_state = A->state <-. WMB | A->on_cpu = 0; | UNLOCK rq0->lock | | context_switch(C, A) `-- A->state = TASK_DEAD prev_state == TASK_DEAD put_task_struct(A) context_switch(A, C) finish_task_switch(A) A->state == TASK_DEAD put_task_struct(A) The argument being that the WMB will allow the load of A->state on CPU0 to cross over and observe CPU1's store of A->state, which will then result in a double-drop and use-after-free. Now the comment states (and this was true once upon a long time ago) that we need to observe A->state while holding rq->lock because that will order us against the wakeup; however the wakeup will not in fact acquire (that) rq->lock; it takes A->pi_lock these days. We can obviously fix this by upgrading the WMB to an MB, but that is expensive, so we'd rather avoid that. The alternative this patch takes is: smp_store_release(&A->on_cpu, 0), which avoids the MB on some archs, but not important ones like ARM. Reported-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: <stable@vger.kernel.org> # v3.1+ Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Cc: manfred@colorfullife.com Cc: will.deacon@arm.com Fixes: e4a52bcb9a18 ("sched: Remove rq->lock from the first half of ttwu()") Link: http://lkml.kernel.org/r/20150929124509.GG3816@twins.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-10-04Merge branch 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq fixes from Thomas Gleixner: "This update contains: - Fix for a long standing race affecting /proc/irq/NNN - One line fix for ARM GICV3-ITS counting the wrong data - Warning silencing in ARM GICV3-ITS. Another GCC trying to be overly clever issue" * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: irqchip/gic-v3-its: Count additional LPIs for the aliased devices irqchip/gic-v3-its: Silence warning when its_lpi_alloc_chunks gets inlined genirq: Fix race in register_irq_proc()
2015-10-03Merge branch 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer fixes from Ingo Molnar: "An abs64() fix in the watchdog driver, and two clocksource driver NO_IRQ assumption fixes" * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: clocksource: Fix abs() usage w/ 64bit values clocksource/drivers/keystone: Fix bad NO_IRQ usage clocksource/drivers/rockchip: Fix bad NO_IRQ usage
2015-10-02clocksource: Fix abs() usage w/ 64bit valuesJohn Stultz
This patch fixes one cases where abs() was being used with 64-bit nanosecond values, where the result may be capped at 32-bits. This potentially could cause watchdog false negatives on 32-bit systems, so this patch addresses the issue by using abs64(). Signed-off-by: John Stultz <john.stultz@linaro.org> Cc: Prarit Bhargava <prarit@redhat.com> Cc: Richard Cochran <richardcochran@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: stable@vger.kernel.org Link: http://lkml.kernel.org/r/1442279124-7309-2-git-send-email-john.stultz@linaro.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-10-01genirq: Fix race in register_irq_proc()Ben Hutchings
Per-IRQ directories in procfs are created only when a handler is first added to the irqdesc, not when the irqdesc is created. In the case of a shared IRQ, multiple tasks can race to create a directory. This race condition seems to have been present forever, but is easier to hit with async probing. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Link: http://lkml.kernel.org/r/1443266636.2004.2.camel@decadent.org.uk Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: stable@vger.kernel.org
2015-09-30workqueue: make sure delayed work run in local cpuShaohua Li
My system keeps crashing with below message. vmstat_update() schedules a delayed work in current cpu and expects the work runs in the cpu. schedule_delayed_work() is expected to make delayed work run in local cpu. The problem is timer can be migrated with NO_HZ. __queue_work() queues work in timer handler, which could run in a different cpu other than where the delayed work is scheduled. The end result is the delayed work runs in different cpu. The patch makes __queue_delayed_work records local cpu earlier. Where the timer runs doesn't change where the work runs with the change. [ 28.010131] ------------[ cut here ]------------ [ 28.010609] kernel BUG at ../mm/vmstat.c:1392! [ 28.011099] invalid opcode: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC KASAN [ 28.011860] Modules linked in: [ 28.012245] CPU: 0 PID: 289 Comm: kworker/0:3 Tainted: G W4.3.0-rc3+ #634 [ 28.013065] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.7.5-20140709_153802- 04/01/2014 [ 28.014160] Workqueue: events vmstat_update [ 28.014571] task: ffff880117682580 ti: ffff8800ba428000 task.ti: ffff8800ba428000 [ 28.015445] RIP: 0010:[<ffffffff8115f921>] [<ffffffff8115f921>]vmstat_update+0x31/0x80 [ 28.016282] RSP: 0018:ffff8800ba42fd80 EFLAGS: 00010297 [ 28.016812] RAX: 0000000000000000 RBX: ffff88011a858dc0 RCX:0000000000000000 [ 28.017585] RDX: ffff880117682580 RSI: ffffffff81f14d8c RDI:ffffffff81f4df8d [ 28.018366] RBP: ffff8800ba42fd90 R08: 0000000000000001 R09:0000000000000000 [ 28.019169] R10: 0000000000000000 R11: 0000000000000121 R12:ffff8800baa9f640 [ 28.019947] R13: ffff88011a81e340 R14: ffff88011a823700 R15:0000000000000000 [ 28.020071] FS: 0000000000000000(0000) GS:ffff88011a800000(0000)knlGS:0000000000000000 [ 28.020071] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [ 28.020071] CR2: 00007ff6144b01d0 CR3: 00000000b8e93000 CR4:00000000000006f0 [ 28.020071] Stack: [ 28.020071] ffff88011a858dc0 ffff8800baa9f640 ffff8800ba42fe00ffffffff8106bd88 [ 28.020071] ffffffff8106bd0b 0000000000000096 0000000000000000ffffffff82f9b1e8 [ 28.020071] ffffffff829f0b10 0000000000000000 ffffffff81f18460ffff88011a81e340 [ 28.020071] Call Trace: [ 28.020071] [<ffffffff8106bd88>] process_one_work+0x1c8/0x540 [ 28.020071] [<ffffffff8106bd0b>] ? process_one_work+0x14b/0x540 [ 28.020071] [<ffffffff8106c214>] worker_thread+0x114/0x460 [ 28.020071] [<ffffffff8106c100>] ? process_one_work+0x540/0x540 [ 28.020071] [<ffffffff81071bf8>] kthread+0xf8/0x110 [ 28.020071] [<ffffffff81071b00>] ?kthread_create_on_node+0x200/0x200 [ 28.020071] [<ffffffff81a6522f>] ret_from_fork+0x3f/0x70 [ 28.020071] [<ffffffff81071b00>] ?kthread_create_on_node+0x200/0x200 Signed-off-by: Shaohua Li <shli@fb.com> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: stable@vger.kernel.org # v2.6.31+
2015-09-30Merge branch 'core-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull RCU fixes from Ingo Molnar: "Two RCU fixes: - work around bug with recent GCC versions. - fix false positive lockdep splat" * 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: rcu: Suppress lockdep false positive for rcp->exp_funnel_mutex rcu: Change _wait_rcu_gp() to work around GCC bug 67055
2015-09-28Merge branch 'for-mingo' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-rcu into core/urgent Pull RCU fixes from Paul E. McKenney, for two regressions introduced in this merge window: - Fix bug with recent GCCs. - Fix false positive lockdep splat. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-09-27Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Thomas Gleixner: "Another pile of fixes for perf: - Plug overflows and races in the core code - Sanitize the flow of the perf syscall so we error out before handling the more complex and hard to undo setups - Improve and fix Broadwell and Skylake hardware support - Revert a fix which broke what it tried to fix in perf tools - A couple of smaller fixes in various places of perf tools" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf tools: Fix copying of /proc/kcore perf intel-pt: Remove no_force_psb from documentation perf probe: Use existing routine to look for a kernel module by dso->short_name perf/x86: Change test_aperfmperf() and test_intel() to static tools lib traceevent: Fix string handling in heterogeneous arch environments perf record: Avoid infinite loop at buildid processing with no samples perf: Fix races in computing the header sizes perf: Fix u16 overflows perf: Restructure perf syscall point of no return perf/x86/intel: Fix Skylake FRONTEND MSR extrareg mask perf/x86/intel/pebs: Add PEBS frontend profiling for Skylake perf/x86/intel: Make the CYCLE_ACTIVITY.* constraint on Broadwell more specific perf tools: Bool functions shouldn't return -1 tools build: Add test for presence of __get_cpuid() gcc builtin tools build: Add test for presence of numa_num_possible_cpus() in libnuma Revert "perf symbols: Fix mismatched declarations for elf_getphdrnum" perf stat: Fix per-pkg event reporting bug
2015-09-27Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fix from Thomas Gleixner: "A single bug fix for the scheduler to prevent dequeueing of the idle task when setting the cpus allowed mask" * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched: Fix crash trying to dequeue/enqueue the idle thread
2015-09-27Merge branch 'locking-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull locking fix from Thomas Gleixner: "A single bugfix for lockdep to preserve the pinning counter when rebuilding the lock stack" * 'locking-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: locking/lockdep: Fix hlock->pin_count reset on lock stack rebuilds
2015-09-23locking/lockdep: Fix hlock->pin_count reset on lock stack rebuildsPeter Zijlstra
Various people reported hitting the "unpinning an unpinned lock" warning. As it turns out there are 2 places where we take a lock out of the middle of a stack, and in those cases it would fail to preserve the pin_count when rebuilding the lock stack. Reported-by: Sasha Levin <sasha.levin@oracle.com> Reported-by: Tim Spriggs <tspriggs@apple.com> Tested-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: davej@codemonkey.org.uk Link: http://lkml.kernel.org/r/20150916141040.GA11639@twins.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-09-22userfaultfd: revert "userfaultfd: waitqueue: add nr wake parameter to ↵Andrea Arcangeli
__wake_up_locked_key" This reverts commit 51360155eccb907ff8635bd10fc7de876408c2e0 and adapts fs/userfaultfd.c to use the old version of that function. It didn't look robust to call __wake_up_common with "nr == 1" when we absolutely require wakeall semantics, but we've full control of what we insert in the two waitqueue heads of the blocked userfaults. No exclusive waitqueue risks to be inserted into those two waitqueue heads so we can as well stick to "nr == 1" of the old code and we can rely purely on the fact no waitqueue inserted in one of the two waitqueue heads we must enforce as wakeall, has wait->flags WQ_FLAG_EXCLUSIVE set. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Cc: Dr. David Alan Gilbert <dgilbert@redhat.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Shuah Khan <shuahkh@osg.samsung.com> Cc: Thierry Reding <treding@nvidia.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-21Merge branch 'for-4.3-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup fixes from Tejun Heo: "The threadgroup locking changes which went in during 4.2 devel cycle added write locking of a percpu_rwsem in cgroup task migration path; unfortunately, that involved expedited rcu syncing which turned out to be too slow and heavy for certain workloads. The patchset which is dependent on this one didn't get committed during that devel cycle, so these two patches can be reverted safely. Oleg reworked percpu_rwsem for 4.4 so that the writer path is a lot lighter. The reported issue goes away with Oleg's reworked percpu_rwsem and I'll reapply these patches on the for-4.4 branch so that they can land together with Oleg's changes" * 'for-4.3-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: Revert "sched, cgroup: replace signal_struct->group_rwsem with a global percpu_rwsem" Revert "cgroup: simplify threadgroup locking"
2015-09-20rcu: Suppress lockdep false positive for rcp->exp_funnel_mutexPaul E. McKenney
In kernels built with CONFIG_PREEMPT=y, synchronize_rcu_expedited() invokes synchronize_sched_expedited() while holding RCU-preempt's root rcu_node structure's ->exp_funnel_mutex, which is acquired after the rcu_data structure's ->exp_funnel_mutex. The first thing that synchronize_sched_expedited() will do is acquire RCU-sched's rcu_data structure's ->exp_funnel_mutex. There is no danger of an actual deadlock because the locking order is always from RCU-preempt's expedited mutexes to those of RCU-sched. Unfortunately, lockdep considers both rcu_data structures' ->exp_funnel_mutex to be in the same lock class and therefore reports a deadlock cycle. This commit silences this false positive by placing RCU-sched's rcu_data structures' ->exp_funnel_mutex locks into their own lock class. Reported-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2015-09-18Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM fixes from Paolo Bonzini: "Mostly stable material, a lot of ARM fixes" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (22 commits) sched: access local runqueue directly in single_task_running arm/arm64: KVM: Remove 'config KVM_ARM_MAX_VCPUS' arm64: KVM: Remove all traces of the ThumbEE registers arm: KVM: Disable virtual timer even if the guest is not using it arm64: KVM: Disable virtual timer even if the guest is not using it arm/arm64: KVM: vgic: Check for !irqchip_in_kernel() when mapping resources KVM: s390: Replace incorrect atomic_or with atomic_andnot arm: KVM: Fix incorrect device to IPA mapping arm64: KVM: Fix user access for debug registers KVM: vmx: fix VPID is 0000H in non-root operation KVM: add halt_attempted_poll to VCPU stats kvm: fix zero length mmio searching kvm: fix double free for fast mmio eventfd kvm: factor out core eventfd assign/deassign logic kvm: don't try to register to KVM_FAST_MMIO_BUS for non mmio eventfd KVM: make the declaration of functions within 80 characters KVM: arm64: add workaround for Cortex-A57 erratum #852523 KVM: fix polling for guest halt continued even if disable it arm/arm64: KVM: Fix PSCI affinity info return value for non valid cores arm64: KVM: set {v,}TCR_EL2 RES1 bits ...
2015-09-18Merge branch 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq updates from Thomas Gleixner: "This is a rather large update post rc1 due to the final steps of cleanups and API changes which had to wait for the preparatory patches to hit your tree. - Regression fixes for ARM GIC irqchips - Regression fixes and lockdep anotations for renesas irq chips - The leftovers of the cleanup and preparatory patches which have been ignored by maintainers - Final conversions of the newly merged users of obsolete APIs - Final removal of obsolete APIs - Final removal of ARM artifacts which had been introduced during the conversion of ARM to the generic interrupt code. - Final split of the irq_data into chip specific and common data to reflect the needs of hierarchical irq domains. - Treewide removal of the first argument of interrupt flow handlers, i.e. the irq number, which is not used by the majority of handlers and simple to retrieve from the other argument the irq descriptor. - A few comment updates and build warning fixes" * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (40 commits) arm64: Remove ununsed set_irq_flags ARM: Remove ununsed set_irq_flags sh: Kill off set_irq_flags usage irqchip: Kill off set_irq_flags usage gpu/drm: Kill off set_irq_flags usage genirq: Remove irq argument from irq flow handlers genirq: Move field 'msi_desc' from irq_data into irq_common_data genirq: Move field 'affinity' from irq_data into irq_common_data genirq: Move field 'handler_data' from irq_data into irq_common_data genirq: Move field 'node' from irq_data into irq_common_data irqchip/gic-v3: Use IRQD_FORWARDED_TO_VCPU flag irqchip/gic: Use IRQD_FORWARDED_TO_VCPU flag genirq: Provide IRQD_FORWARDED_TO_VCPU status flag genirq: Simplify irq_data_to_desc() genirq: Remove __irq_set_handler_locked() pinctrl/pistachio: Use irq_set_handler_locked gpio: vf610: Use irq_set_handler_locked powerpc/mpc8xx: Use irq_set_handler_locked() powerpc/ipic: Use irq_set_handler_locked() powerpc/cpm2: Use irq_set_handler_locked() ...
2015-09-18sched: access local runqueue directly in single_task_runningDominik Dingel
Commit 2ee507c47293 ("sched: Add function single_task_running to let a task check if it is the only task running on a cpu") referenced the current runqueue with the smp_processor_id. When CONFIG_DEBUG_PREEMPT is enabled, that is only allowed if preemption is disabled or the currrent task is bound to the local cpu (e.g. kernel worker). With commit f78195129963 ("kvm: add halt_poll_ns module parameter") KVM calls single_task_running. If CONFIG_DEBUG_PREEMPT is enabled that generates a lot of kernel messages. To avoid adding preemption in that cases, as it would limit the usefulness, we change single_task_running to access directly the cpu local runqueue. Cc: Tim Chen <tim.c.chen@linux.intel.com> Suggested-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: <stable@vger.kernel.org> Fixes: 2ee507c472939db4b146d545352b8a7c79ef47f8 Signed-off-by: Dominik Dingel <dingel@linux.vnet.ibm.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2015-09-18perf: Fix races in computing the header sizesPeter Zijlstra
There are two races with the current code: - Another event can join the group and compute a larger header_size concurrently, if the smaller store wins we'll have an incorrect header_size set. - We compute the header_size after the event becomes active, therefore its possible to use the size before its computed. Remedy the first by moving the computation inside the ctx::mutex lock, and the second by placing it _before_ perf_install_in_context(). Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-09-18perf: Fix u16 overflowsPeter Zijlstra
Vince reported that its possible to overflow the various size fields and get weird stuff if you stick too many events in a group. Put a lid on this by requiring the fixed record size not exceed 16k. This is still a fair amount of events (silly amount really) and leaves plenty room for callchains and stack dwarves while also avoiding overflowing the u16 variables. Reported-by: Vince Weaver <vincent.weaver@maine.edu> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-09-18perf: Restructure perf syscall point of no returnPeter Zijlstra
The exclusive_event_installable() stuff only works because its exclusive with the grouping bits. Rework the code such that there is a sane place to error out before we go do things we cannot undo. Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-09-18sched: Fix crash trying to dequeue/enqueue the idle threadPeter Zijlstra
Sasha reports that his virtual machine tries to schedule the idle thread since commit 6c37067e2786 ("sched: Change the sched_class::set_cpus_allowed() calling context"). Hit trace shows this happening from idle_thread_get()->init_idle(), which is the _second_ init_idle() invocation on that task_struct, the first being done through idle_init()->fork_idle(). (this code is insane...) Because we call init_idle() twice in a row, its ->sched_class == &idle_sched_class and ->on_rq = TASK_ON_RQ_QUEUED. This means do_set_cpus_allowed() think we're queued and will call dequeue_task(), which is implemented with BUG() for the idle class, seeing how dequeueing the idle task is a daft thing. Aside of the whole insanity of calling init_idle() _twice_, change the code to call set_cpus_allowed_common() instead as this is 'obviously' before the idle task gets ran etc.. Reported-by: Sasha Levin <sasha.levin@oracle.com> Tested-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Fixes: 6c37067e2786 ("sched: Change the sched_class::set_cpus_allowed() calling context") Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-09-17Merge branch 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer fixes from Ingo Molnar: "A fix for an abs()/abs64() bug that caused too slow NTP convergence on 32-bit kernels, plus a removal of an obsolete clockevents driver facility after all users got converted during the merge window" * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: clockevents: Remove unused set_mode() callback time: Fix timekeeping_freqadjust()'s incorrect use of abs() instead of abs64()
2015-09-17Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fixes from Ingo Molnar: "A migrate_tasks() locking fix, and a late-coming nohz change plus a nohz debug check" * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched: 'Annotate' migrate_tasks() nohz: Assert existing housekeepers when nohz full enabled nohz: Affine unpinned timers to housekeepers
2015-09-17Merge branch 'locking-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull locking fixes from Ingo Molnar: "Spinlock performance regression fix, plus documentation fixes" * 'locking-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: locking/static_keys: Fix up the static keys documentation locking/qspinlock/x86: Only emit the test-and-set fallback when building guest support locking/qspinlock/x86: Fix performance regression under unaccelerated VMs locking/static_keys: Fix a silly typo
2015-09-16Revert "sched, cgroup: replace signal_struct->group_rwsem with a global ↵Tejun Heo
percpu_rwsem" This reverts commit d59cfc09c32a2ae31f1c3bc2983a0cd79afb3f14. d59cfc09c32a ("sched, cgroup: replace signal_struct->group_rwsem with a global percpu_rwsem") and b5ba75b5fc0e ("cgroup: simplify threadgroup locking") changed how cgroup synchronizes against task fork and exits so that it uses global percpu_rwsem instead of per-process rwsem; unfortunately, the write [un]lock paths of percpu_rwsem always involve synchronize_rcu_expedited() which turned out to be too expensive. Improvements for percpu_rwsem are scheduled to be merged in the coming v4.4-rc1 merge window which alleviates this issue. For now, revert the two commits to restore per-process rwsem. They will be re-applied for the v4.4-rc1 merge window. Signed-off-by: Tejun Heo <tj@kernel.org> Link: http://lkml.kernel.org/g/55F8097A.7000206@de.ibm.com Reported-by: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: stable@vger.kernel.org # v4.2+
2015-09-16Revert "cgroup: simplify threadgroup locking"Tejun Heo
This reverts commit b5ba75b5fc0e8404e2c50cb68f39bb6a53fc916f. d59cfc09c32a ("sched, cgroup: replace signal_struct->group_rwsem with a global percpu_rwsem") and b5ba75b5fc0e ("cgroup: simplify threadgroup locking") changed how cgroup synchronizes against task fork and exits so that it uses global percpu_rwsem instead of per-process rwsem; unfortunately, the write [un]lock paths of percpu_rwsem always involve synchronize_rcu_expedited() which turned out to be too expensive. Improvements for percpu_rwsem are scheduled to be merged in the coming v4.4-rc1 merge window which alleviates this issue. For now, revert the two commits to restore per-process rwsem. They will be re-applied for the v4.4-rc1 merge window. Signed-off-by: Tejun Heo <tj@kernel.org> Link: http://lkml.kernel.org/g/55F8097A.7000206@de.ibm.com Reported-by: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: stable@vger.kernel.org # v4.2+
2015-09-16genirq: Remove irq argument from irq flow handlersThomas Gleixner
Most interrupt flow handlers do not use the irq argument. Those few which use it can retrieve the irq number from the irq descriptor. Remove the argument. Search and replace was done with coccinelle and some extra helper scripts around it. Thanks to Julia for her help! Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Julia Lawall <Julia.Lawall@lip6.fr> Cc: Jiang Liu <jiang.liu@linux.intel.com>
2015-09-16genirq: Move field 'msi_desc' from irq_data into irq_common_dataJiang Liu
MSI descriptors are per-irq instead of per irqchip, so move it into struct irq_common_data. Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Jason Cooper <jason@lakedaemon.net> Cc: Kevin Cernekee <cernekee@gmail.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Marc Zyngier <marc.zyngier@arm.com> Link: http://lkml.kernel.org/r/1433145945-789-35-git-send-email-jiang.liu@linux.intel.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
