1. The tracee can go from ptrace_stop() to do_signal_stop()
after __ptrace_unlink(p).
2. It is unsafe to __ptrace_unlink(p) while p->parent may wait
for tasklist_lock in ptrace_detach().
Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru>
Cc: Roland McGrath <roland@redhat.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
Clear unblockable signals beforehand.
Pointed out by Linus Torvalds.
sys_signal() forgets to initialize ->sa_mask.
( I suspect arch/ia64/ia32/ia32_signal.c:sys32_signal()
also needs this fix )
Use first_cpu(cpu_possible_map) for the single-thread workqueue case. We
used to hardcode 0, but that broke on systems where !cpu_possible(0) when
workqueue_struct->cpu_workqueue_struct was changed from a static array to
alloc_percpu.
Commit id bce61dd49d6ba7799be2de17c772e4c701558f14 ("Fix hardcoded cpu=0 in
workqueue for per_cpu_ptr() calls") fixed that for Ben's funky sparc64
system, but it regressed my Power5. Offlining cpu 0 oopses upon the next
call to queue_work for a single-thread workqueue, because now we try to
manipulate per_cpu_ptr(wq->cpu_wq, 1), which is uninitialized.
So we need to establish an unchanging "slot" for single-thread workqueues
which will have a valid percpu allocation. Since alloc_percpu keys off of
cpu_possible_map, which must not change after initialization, make this
slot == first_cpu(cpu_possible_map).
Signed-off-by: Nathan Lynch <ntl@pobox.com>
Cc: <stable@kernel.org>
This is a slightly more complete fix for the previous minimal sysctl
string fix. It always terminates the returned string with a NUL, even
if the full result wouldn't fit in the user-supplied buffer.
The returned length is the full untruncated length, so that you can
tell when truncation has occurred.
For the sysctl syscall, if the user wants to get the old value of a
sysctl entry and set a new value for it in the same syscall, the old
value is always overwritten by the new value if the sysctl entry is of
string type and if the user sets its strategy to sysctl_string. This
issue lies in the strategy being run twice if the strategy is set to
sysctl_string, the general strategy sysctl_string always returns 0 if
success.
Such strategy routines as sysctl_jiffies and sysctl_jiffies_ms return 1
because they do read and write for the sysctl entry.
The strategy routine sysctl_string return 0 although it actually read
and write the sysctl entry.
According to my analysis, if a strategy routine do read and write, it
should return 1, if it just does some necessary check but not read and
write, it should return 0, for example sysctl_intvec.
Signed-off-by: Yi Yang <yang.y.yi@gmail.com>
If the string was too long to fit in the user-supplied buffer,
the sysctl layer would zero-terminate it by writing past the
end of the buffer. Don't do that.
Noticed by Yi Yang <yang.y.yi@gmail.com>
Fix a memory ordering problem that occurs on IA64. The "store" to q->lock_ptr
in wake_futex() can become visible before wake_up_all() clears the lock in the
futex_q.
Signed-off-by: Jack Steiner <steiner@sgi.com>
All the work was done to setup the file and maintain the file handles but
the access functions were zeroed out due to the #ifdef. Removing the
#ifdef allows full access to all the parameters when CONFIG_MODULES=n.
akpm: put it back again, but use CONFIG_SYSFS instead.
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
When multiple probes are registered at the same address and if due to some
recursion (probe getting triggered within a probe handler), we skip calling
pre_handlers and just increment nmissed field.
The below patch make sure it walks the list for multiple probes case.
Without the below patch we get incorrect results of nmissed count for
multiple probe case.
Signed-off-by: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com>
For Kprobes critical path is the path from debug break exception handler
till the control reaches kprobes exception code. No probes can be
supported in this path as we will end up in recursion.
This patch prevents this by moving the below function to safe __kprobes
section onto which no probes can be inserted.
kauditd was causing suspends to fail because it refused to freeze. Adding
a try_to_freeze() to its sleep loop solves the issue.
Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
Acked-by: Pavel Machek <pavel@suse.cz>
When registering multiple kprobes at the same address, we leave a small
window where the kprobe hlist will not contain a reference to the
registered kprobe, leading to potentially, a system crash if the breakpoint
is hit on another processor.
Patch below now automically relpace the old kprobe with the new
kprobe from the hash list.
Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cc: "Paul E. McKenney" <paulmck@us.ibm.com>
There are several functions that might seem appropriate for a timestamp:
get_cycles()
current_kernel_time()
do_gettimeofday()
<read jiffies/jiffies_64>
Each has problems with combinations of SMP-safety, low resolution, and
monotonicity. This patch adds a new function that returns a monotonic SMP-safe
timestamp with nanosecond resolution where available.
Changes:
Split timestamp into separate patch
Moved to kernel/time.c
Renamed to getnstimestamp
Fixed unintended-pointer-arithmetic bug
Signed-off-by: Matt Helsley <matthltc@us.ibm.com>
Accessing nohz_cpu_mask before incrementing rcp->cur is racy. It can cause
tickless idle CPUs to be included in rsp->cpumask, which will extend
graceperiods unnecessarily.
Fix this race. It has been tested using extensions to RCU torture module
that forces various CPUs to become idle.
Signed-off-by: Srivatsa Vaddagiri <vatsa@in.ibm.com>
Cc: Dipankar Sarma <dipankar@in.ibm.com>
While doing some test of RCU torture module, I hit a OOPS in rcu_do_batch,
which was trying to processes callback of a module that was just removed.
This is because we weren't waiting long enough for all callbacks to fire.
Acked-by: "Paul E. McKenney" <paulmck@us.ibm.com>
This introduces a new interface - rcu_barrier() which waits until all
the RCUs queued until this call have been completed.
Reiser4 needs this, because we do more than just freeing memory object
in our RCU callback: we also remove it from the list hanging off
super-block. This means, that before freeing reiser4-specific portion
of super-block (during umount) we have to wait until all pending RCU
callbacks are executed.
The only change of reiser4 made to the original patch, is exporting of
rcu_barrier().
Cc: Hans Reiser <reiser@namesys.com>
Cc: Vladimir V. Saveliev <vs@namesys.com>
When a Kprobes are inserted/removed on a modules, the modules must be ref
counted so as not to allow to unload while probes are registered on that
module.
Without this patch, the probed module is free to unload, and when the
probing module unregister the probe, the kpobes code while trying to
replace the original instruction might crash.
Signed-off-by: Mao Bibo <bibo.mao@intel.com>
Fix swsusp on machines not supporting S4. With recent changes, it is not
possible to trigger it using /sys filesystem. Swsusp does not really need
any support from low-level code, it is possible to reboot or halt at the
end of suspend.
Signed-off-by: Pavel Machek <pavel@suse.cz>
Cc: "Brown, Len" <len.brown@intel.com>
set_page_dirty() will not cope with being handed a page * which is part of
a compound page, but not the master page in that compound page. This case
can occur via access_process_vm() if you attemp to write to another
process's hugepage memory area using ptrace() (causing an oops or hang).
This patch fixes the bug by only calling set_page_dirty() from
access_process_vm() if the page is not a compound page. We already use a
similar fix in bio_set_pages_dirty() for the case of direct io to
hugepages.
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
Acked-by: William Irwin <wli@holomorphy.com>
Move the cpuset_fork() call below the write_unlock_irq call in
kernel/fork.c copy_process().
Since the cpuset-dual-semaphore-locking-overhaul.patch, the cpuset_fork()
routine acquires task_lock(), so cannot be called while holding the
tasklist_lock for write.
Signed-off-by: Paul Jackson <pj@sgi.com>
Tracked this down on an Ultra Enterprise 3000. It's a 6-way machine. Odd
thing about this machine (and it's good for finding bugs like this) is that
the CPU id's are not 0 based. For instance, on my machine the CPU's are
6/7/10/11/14/15.
This caused some NULL pointer dereference in kernel/workqueue.c because for
single_threaded workqueue's, it hardcoded the cpu to 0.
I changed the 0's to any_online_cpu(cpu_online_mask), which cpumask.h
claims is "First cpu in mask". So this fits the same usage.
fix 32bit overflow in timespec_to_sample()
Don't do that - it does GFP_KERNEL allocations, for a start.
(Reported by Guillaume Thouvenin <guillaume.thouvenin@bull.net>)
Acked-by: Matt Helsley <matthltc@us.ibm.com>
There are some callers in cpufreq hotplug notify path that the lowest
function calls lock_cpu_hotplug(). The lock is already held during
cpu_up() and cpu_down() calls when the notify calls are broadcast to
registered clients.
Ideally if possible, we could disable_preempt() at the highest caller and
make sure we dont sleep in the path down in cpufreq->driver_target() calls
but the calls are so intertwined and cumbersome to cleanup.
Hence we consistently use lock_cpu_hotplug() and unlock_cpu_hotplug() in
all places.
- Removed export of cpucontrol semaphore and made it static.
- removed explicit uses of up/down with lock_cpu_hotplug()
so we can keep track of the the callers in same thread context and
just keep refcounts without calling a down() that causes a deadlock.
- Removed current_in_hotplug() uses
- Removed PF_HOTPLUG_CPU in sched.h introduced for the current_in_hotplug()
temporary workaround.
Tested with insmod of cpufreq_stat.ko, and logical online/offline
to make sure we dont have any hang situations.
Signed-off-by: Ashok Raj <ashok.raj@intel.com>
Cc: Zwane Mwaikambo <zwane@linuxpower.ca>
Cc: Shaohua Li <shaohua.li@intel.com>
Cc: "Siddha, Suresh B" <suresh.b.siddha@intel.com>
If unregister_console() is inadvertently called while no consoles are
registered, it will crash trying to dereference NULL pointer. It is
necessary to fix that because register_console() provides no indication
that it actually registered the console passed in. In fact, it may well
decide not to register it based on various things...
(akpm: It'd be better to make register_console() return something and fix the
callers. All 106 of them...)
The follow_page changes in get_futex_key have left it with two almost
identical blocks, when handling the rare case of a futex in a nonlinear vma.
get_user_pages will itself do that follow_page, and its additional
find_extend_vma is hardly any overhead since the vma is already cached. Let's
just delete the follow_page block and let get_user_pages do it.
Signed-off-by: Hugh Dickins <hugh@veritas.com>
Most of the functions already check. Do the ones that didn't.
Signed-off-by: Matthew Wilcox <matthew@wil.cx>
For copy_one_pte's print_bad_pte to show the task correctly (instead of
"???"), dup_mmap must pass down parent vma rather than child vma.
One issue with the RCU torture test is that the current error flagging can
be lost in dmesg. This patch adds a "SUCCESS"/"FAILURE" string to the line
that flags the end of the test, where it can easily be seen with "dmesg |
tail" at the end of the test. Also adds tests of architecture-specific
memory barriers -- or, more likely, of the RCU torture test itself.
Cc: <vatsa@in.ibm.com>
Signed-off-by: "Paul E. McKenney" <paulmck@us.ibm.com>
Add printk documentation to kernel-api.
Signed-off-by: Martin Waitz <tali@admingilde.org>
It would appear that the timespec normalize code has an off by one error.
Found in three places. Thanks to Ben for spotting.
Signed-off-by: George Anzinger<george@mvista.com>
Sync iocbs have a life cycle that don't need a kioctx. Their retrying, if
any, is done in the context of their owner who has allocated them on the
stack.
The sole user of a sync iocb's ctx reference was aio_complete() checking for
an elevated iocb ref count that could never happen. No path which grabs an
iocb ref has access to sync iocbs.
If we were to implement sync iocb cancelation it would be done by the owner of
the iocb using its on-stack reference.
Removing this chunk from aio_complete allows us to remove the entire kioctx
instance from mm_struct, reducing its size by a third. On a i386 testing box
the slab size went from 768 to 504 bytes and from 5 to 8 per page.
Signed-off-by: Zach Brown <zach.brown@oracle.com>
Acked-by: Benjamin LaHaise <bcrl@kvack.org>
This fixes deadlock of stop_machine() vs. synchronous IPI send. The
problem is that stop_machine() disables interrupts before disabling
preemption on other CPUs. So if another CPU is preempted and then calls
something like flush_tlb_all() it will deadlock with CPU doing
stop_machine() and which can't process IPI due to disabled IRQs.
I changed stop_machine() to do the same things exactly as it does on other
CPUs, i.e. it should disable preemption first on _all_ CPUs including
itself and only after that disable IRQs.
Signed-off-by: Kirill Korotaev <dev@sw.ru>
Cc: "Andrey Savochkin" <saw@sawoct.com>
Make the box usable for interactive work when running the RCU torture test,
by renicing the RCU torture-test threads to +19 by default. Kthreads run
at nice -5 by default.
Acked-by: Paul E. McKenney" <paulmck@us.ibm.com>
This patch reverts commit c33880aaddbbab1ccf36f4457ed1090621f2e39a since
it's not needed anymore. As pointed out by Roland McGrath the real fix
is to deliver all signals before returning to user space.
See http://www.ussg.iu.edu/hypermail/linux/kernel/0509.2/0683.html
A fix for s390 has been merged.
Cc: Linus Torvalds <torvalds@osdl.org>
encapsulates the rest of arch-dependent operations with thread_info access.
Two new helpers - setup_thread_stack() and end_of_stack(). For normal case
the former consists of copying thread_info of parent to new thread_info and
the latter returns pointer immediately past the end of thread_info.
Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk>
Signed-off-by: Roman Zippel <zippel@linux-m68k.org>
new helper - task_thread_info(task). On platforms that have thread_info
allocated separately (i.e. in default case) it simply returns
task->thread_info. m68k wants (and for good reasons) to embed its thread_info
into task_struct. So it will (in later patch) have task_thread_info() of its
own. For now we just add a macro for generic case and convert existing
instances of its body in core kernel to uses of new macro. Obviously safe -
all normal architectures get the same preprocessor output they used to get.
It is wrong to acquire the semaphore and then return from
cpuset_zone_allowed without releasing it.
Signed-off-by: Bob Picco <bob.picco@hp.com>
Acked-by: Paul Jackson <pj@sgi.com>
When ptrace_attach fails we need to drop the task_struct reference.
Since few people need the support anymore, this moves the legacy
pm_xxx functions to CONFIG_PM_LEGACY, and include/linux/pm_legacy.h.
Revert: b26b9bc58263acda274f82a9dde8b6d96559878a
If a task is being traced we never auto-reap it even if it might look
like its parent doesn't care. The tracer obviously _does_ care.
recalc_task_prio() is called from activate_task() to calculate dynamic
priority and interactive credit for the activating task. For real-time
scheduling process, all that dynamic calculation is thrown away at the end
because rt priority is fixed. Patch to optimize recalc_task_prio() away
for rt processes.
Signed-off-by: Ken Chen <kenneth.w.chen@intel.com>
Cc: Nick Piggin <piggin@cyberone.com.au>
Cc: Con Kolivas <kernel@kolivas.org>
Before we did CLONE_THREAD, the way to check whether we were attaching
to ourselves was to just check "current == task", but with CLONE_THREAD
we should check that the thread group ID matches instead.
Make some changes to the NEED_RESCHED and POLLING_NRFLAG to reduce
confusion, and make their semantics rigid. Improves efficiency of
resched_task and some cpu_idle routines.
* In resched_task:
- TIF_NEED_RESCHED is only cleared with the task's runqueue lock held,
and as we hold it during resched_task, then there is no need for an
atomic test and set there. The only other time this should be set is
when the task's quantum expires, in the timer interrupt - this is
protected against because the rq lock is irq-safe.
- If TIF_NEED_RESCHED is set, then we don't need to do anything. It
won't get unset until the task get's schedule()d off.
- If we are running on the same CPU as the task we resched, then set
TIF_NEED_RESCHED and no further action is required.
- If we are running on another CPU, and TIF_POLLING_NRFLAG is *not* set
after TIF_NEED_RESCHED has been set, then we need to send an IPI.
Using these rules, we are able to remove the test and set operation in
resched_task, and make clear the previously vague semantics of
POLLING_NRFLAG.
* In idle routines:
- Enter cpu_idle with preempt disabled. When the need_resched() condition
becomes true, explicitly call schedule(). This makes things a bit clearer
(IMO), but haven't updated all architectures yet.
- Many do a test and clear of TIF_NEED_RESCHED for some reason. According
to the resched_task rules, this isn't needed (and actually breaks the
assumption that TIF_NEED_RESCHED is only cleared with the runqueue lock
held). So remove that. Generally one less locked memory op when switching
to the idle thread.
- Many idle routines clear TIF_POLLING_NRFLAG, and only set it in the inner
most polling idle loops. The above resched_task semantics allow it to be
set until before the last time need_resched() is checked before going into
a halt requiring interrupt wakeup.
Many idle routines simply never enter such a halt, and so POLLING_NRFLAG
can be always left set, completely eliminating resched IPIs when rescheduling
the idle task.
POLLING_NRFLAG width can be increased, to reduce the chance of resched IPIs.
Signed-off-by: Nick Piggin <npiggin@suse.de>
The intermittent scheduling of the migration thread at ultra high priority
makes the smp nice handling see that runqueue as being heavily loaded. The
migration thread itself actually handles the balancing so its influence on
priority balancing should be ignored.
Signed-off-by: Con Kolivas <kernel@kolivas.org>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
The priority biasing was off by mutliplying the total load by the total
priority bias and this ruins the ratio of loads between runqueues. This
patch should correct the ratios of loads between runqueues to be proportional
to overall load. -2nd attempt.
This patch fixes a divide-by-zero error that I hit on a two-way i386
machine. rq->nr_running is tested to be non-zero, but may change by the
time it is used in the division. Saving the value to a local variable
ensures that the same value that is checked is used in the division.
Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
To intensify the 'nice' support across physical cpus on SMP we can bias the
loads on idle rebalancing. To prevent idle rebalance from trying to pull tasks
from queues that appear heavily loaded we only bias the load if there is more
than one task running.
Add some minor micro-optimisations and have only one return from __source_load
and __target_load functions.
Fix the fact that target_load was not biased by priority when type == 0.
Real time tasks' effect on prio_bias should be based on their real time
priority level instead of their static_prio which is based on nice.
