This is the 4.9.166 stable release
commit 71492580571467fb7177aade19c18ce7486267f5 upstream.
Tetsuo Handa had reported he saw an incorrect "downgrading a read lock"
warning right after a previous lockdep warning. It is likely that the
previous warning turned off lock debugging causing the lockdep to have
inconsistency states leading to the lock downgrade warning.
Fix that by add a check for debug_locks at the beginning of
__lock_downgrade().
Debugged-by: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp>
Reported-by: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp>
Reported-by: syzbot+53383ae265fb161ef488@syzkaller.appspotmail.com
Signed-off-by: Waiman Long <longman@redhat.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Link: https://lkml.kernel.org/r/1547093005-26085-1-git-send-email-longman@redhat.com
commit 5a07168d8d89b00fe1760120714378175b3ef992 upstream.
The futex code requires that the user space addresses of futexes are 32bit
aligned. sys_futex() checks this in futex_get_keys() but the robust list
code has no alignment check in place.
As a consequence the kernel crashes on architectures with strict alignment
requirements in handle_futex_death() when trying to cmpxchg() on an
unaligned futex address which was retrieved from the robust list.
[ tglx: Rewrote changelog, proper sizeof() based alignement check and add
comment ]
Fixes: 0771dfefc9e5 ("[PATCH] lightweight robust futexes: core")
Signed-off-by: Chen Jie <chenjie6@huawei.com>
Cc: <dvhart@infradead.org>
Cc: <peterz@infradead.org>
Cc: <zengweilin@huawei.com>
Cc: stable@vger.kernel.org
Link: https://lkml.kernel.org/r/1552621478-119787-1-git-send-email-chenjie6@huawei.com
commit 1d1f898df6586c5ea9aeaf349f13089c6fa37903 upstream.
The rcu_gp_kthread_wake() function is invoked when it might be necessary
to wake the RCU grace-period kthread. Because self-wakeups are normally
a useless waste of CPU cycles, if rcu_gp_kthread_wake() is invoked from
this kthread, it naturally refuses to do the wakeup.
Unfortunately, natural though it might be, this heuristic fails when
rcu_gp_kthread_wake() is invoked from an interrupt or softirq handler
that interrupted the grace-period kthread just after the final check of
the wait-event condition but just before the schedule() call. In this
case, a wakeup is required, even though the call to rcu_gp_kthread_wake()
is within the RCU grace-period kthread's context. Failing to provide
this wakeup can result in grace periods failing to start, which in turn
results in out-of-memory conditions.
This race window is quite narrow, but it actually did happen during real
testing. It would of course need to be fixed even if it was strictly
theoretical in nature.
This patch does not Cc stable because it does not apply cleanly to
earlier kernel versions.
Fixes: 48a7639ce80c ("rcu: Make callers awaken grace-period kthread")
Reported-by: "He, Bo" <bo.he@intel.com>
Co-developed-by: "Zhang, Jun" <jun.zhang@intel.com>
Co-developed-by: "He, Bo" <bo.he@intel.com>
Co-developed-by: "xiao, jin" <jin.xiao@intel.com>
Co-developed-by: Bai, Jie A <jie.a.bai@intel.com>
Signed-off: "Zhang, Jun" <jun.zhang@intel.com>
Signed-off: "He, Bo" <bo.he@intel.com>
Signed-off: "xiao, jin" <jin.xiao@intel.com>
Signed-off: Bai, Jie A <jie.a.bai@intel.com>
Signed-off-by: "Zhang, Jun" <jun.zhang@intel.com>
[ paulmck: Switch from !in_softirq() to "!in_interrupt() &&
!in_serving_softirq() to avoid redundant wakeups and to also handle the
interrupt-handler scenario as well as the softirq-handler scenario that
actually occurred in testing. ]
Signed-off-by: Paul E. McKenney <paulmck@linux.ibm.com>
Link: https://lkml.kernel.org/r/CD6925E8781EFD4D8E11882D20FC406D52A11F61@SHSMSX104.ccr.corp.intel.com
commit 8cf7630b29701d364f8df4a50e4f1f5e752b2778 upstream.
This bug has apparently existed since the introduction of this function
in the pre-git era (4500e91754d3 in Thomas Gleixner's history.git,
"[NET]: Add proc_dointvec_userhz_jiffies, use it for proper handling of
neighbour sysctls.").
As a minimal fix we can simply duplicate the corresponding check in
do_proc_dointvec_conv().
Link: http://lkml.kernel.org/r/20190207123426.9202-3-zev@bewilderbeest.net
Signed-off-by: Zev Weiss <zev@bewilderbeest.net>
Cc: Brendan Higgins <brendanhiggins@google.com>
Cc: Iurii Zaikin <yzaikin@google.com>
Cc: Luis Chamberlain <mcgrof@kernel.org>
Cc: <stable@vger.kernel.org> [2.6.2+]
commit e7f0c424d0806b05d6f47be9f202b037eb701707 upstream.
Commit d716ff71dd12 ("tracing: Remove taking of trace_types_lock in
pipe files") use the current tracer instead of the copy in
tracing_open_pipe(), but it forget to remove the freeing sentence in
the error path.
There's an error path that can call kfree(iter->trace) after the iter->trace
was assigned to tr->current_trace, which would be bad to free.
Link: http://lkml.kernel.org/r/1550060946-45984-1-git-send-email-yi.zhang@huawei.com
Fixes: d716ff71dd12 ("tracing: Remove taking of trace_types_lock in pipe files")
Signed-off-by: zhangyi (F) <yi.zhang@huawei.com>
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
commit 9f0bbf3115ca9f91f43b7c74e9ac7d79f47fc6c2 upstream.
Because there may be random garbage beyond a string's null terminator,
it's not correct to copy the the complete character array for use as a
hist trigger key. This results in multiple histogram entries for the
'same' string key.
So, in the case of a string key, use strncpy instead of memcpy to
avoid copying in the extra bytes.
Before, using the gdbus entries in the following hist trigger as an
example:
# echo 'hist:key=comm' > /sys/kernel/debug/tracing/events/sched/sched_waking/trigger
# cat /sys/kernel/debug/tracing/events/sched/sched_waking/hist
{ comm: ImgDecoder #4 } hitcount: 203
{ comm: gmain } hitcount: 213
{ comm: gmain } hitcount: 216
{ comm: StreamTrans #73 } hitcount: 221
{ comm: mozStorage #3 } hitcount: 230
{ comm: gdbus } hitcount: 233
{ comm: StyleThread#5 } hitcount: 253
{ comm: gdbus } hitcount: 256
{ comm: gdbus } hitcount: 260
{ comm: StyleThread#4 } hitcount: 271
# cat /sys/kernel/debug/tracing/events/sched/sched_waking/hist | egrep gdbus | wc -l
51
After:
1
Link: http://lkml.kernel.org/r/50c35ae1267d64eee975b8125e151e600071d4dc.1549309756.git.tom.zanussi@linux.intel.com
Cc: Namhyung Kim <namhyung@kernel.org>
Fixes: 79e577cbce4c4 ("tracing: Support string type key properly")
Signed-off-by: Tom Zanussi <tom.zanussi@linux.intel.com>
commit 38d589f2fd08f1296aea3ce62bebd185125c6d81 upstream.
With the ultimate goal of keeping rt_mutex wait_list and futex_q waiters
consistent it's necessary to split 'rt_mutex_futex_lock()' into finer
parts, such that only the actual blocking can be done without hb->lock
held.
Split split_mutex_finish_proxy_lock() into two parts, one that does the
blocking and one that does remove_waiter() when the lock acquire failed.
When the rtmutex was acquired successfully the waiter can be removed in the
acquisiton path safely, since there is no concurrency on the lock owner.
This means that, except for futex_lock_pi(), all wait_list modifications
are done with both hb->lock and wait_lock held.
[bigeasy@linutronix.de: fix for futex_requeue_pi_signal_restart]
Cc: juri.lelli@arm.com
Cc: bigeasy@linutronix.de
Cc: xlpang@redhat.com
Cc: rostedt@goodmis.org
Cc: mathieu.desnoyers@efficios.com
Cc: jdesfossez@efficios.com
Cc: dvhart@infradead.org
Cc: bristot@redhat.com
Link: http://lkml.kernel.org/r/20170322104152.001659630@infradead.org
Signed-off-by: Zubin Mithra <zsm@chromium.org>
[ Upstream commit 1a51c5da5acc6c188c917ba572eebac5f8793432 ]
The perf_proc_update_handler() handles /proc/sys/kernel/perf_event_max_sample_rate
syctl variable. When the PMU IRQ handler timing monitoring is disabled, i.e,
when /proc/sys/kernel/perf_cpu_time_max_percent is equal to 0 or 100,
then no modification to sysctl_perf_event_sample_rate is allowed to prevent
possible hang from wrong values.
The problem is that the test to prevent modification is made after the
sysctl variable is modified in perf_proc_update_handler().
You get an error:
$ echo 10001 >/proc/sys/kernel/perf_event_max_sample_rate
echo: write error: invalid argument
But the value is still modified causing all sorts of inconsistencies:
$ cat /proc/sys/kernel/perf_event_max_sample_rate
10001
This patch fixes the problem by moving the parsing of the value after
the test.
Committer testing:
# echo 100 > /proc/sys/kernel/perf_cpu_time_max_percent
# echo 10001 > /proc/sys/kernel/perf_event_max_sample_rate
-bash: echo: write error: Invalid argument
# cat /proc/sys/kernel/perf_event_max_sample_rate
10001
Signed-off-by: Stephane Eranian <eranian@google.com>
Reviewed-by: Andi Kleen <ak@linux.intel.com>
Reviewed-by: Jiri Olsa <jolsa@kernel.org>
Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Kan Liang <kan.liang@linux.intel.com>
Link: http://lkml.kernel.org/r/1547169436-6266-1-git-send-email-eranian@google.com
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
[ Upstream commit e158488be27b157802753a59b336142dc0eb0380 ]
Because wake_q_add() can imply an immediate wakeup (cmpxchg failure
case), we must not rely on the wakeup being delayed. However, commit:
e38513905eea ("locking/rwsem: Rework zeroing reader waiter->task")
relies on exactly that behaviour in that the wakeup must not happen
until after we clear waiter->task.
[ peterz: Added changelog. ]
Signed-off-by: Xie Yongji <xieyongji@baidu.com>
Signed-off-by: Zhang Yu <zhangyu31@baidu.com>
Fixes: e38513905eea ("locking/rwsem: Rework zeroing reader waiter->task")
Link: https://lkml.kernel.org/r/1543495830-2644-1-git-send-email-xieyongji@baidu.com
commit 4dbbe2d8e95c351157f292ece067f985c30c7b53 upstream.
This fixes the following clang warning:
kernel/trace/trace.c:3231:12: warning: address of array 'iter->started'
will always evaluate to 'true' [-Wpointer-bool-conversion]
if (iter->started)
Link: http://lkml.kernel.org/r/20170421234110.117075-1-mka@chromium.org
Signed-off-by: Matthias Kaehlcke <mka@chromium.org>
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
commit cf43a757fd49442bc38f76088b70c2299eed2c2f upstream.
In the middle of do_exit() there is there is a call
"ptrace_event(PTRACE_EVENT_EXIT, code);" That call places the process
in TACKED_TRACED aka "(TASK_WAKEKILL | __TASK_TRACED)" and waits for
for the debugger to release the task or SIGKILL to be delivered.
Skipping past dequeue_signal when we know a fatal signal has already
been delivered resulted in SIGKILL remaining pending and
TIF_SIGPENDING remaining set. This in turn caused the
scheduler to not sleep in PTACE_EVENT_EXIT as it figured
a fatal signal was pending. This also caused ptrace_freeze_traced
in ptrace_check_attach to fail because it left a per thread
SIGKILL pending which is what fatal_signal_pending tests for.
This difference in signal state caused strace to report
strace: Exit of unknown pid NNNNN ignored
Therefore update the signal handling state like dequeue_signal
would when removing a per thread SIGKILL, by removing SIGKILL
from the per thread signal mask and clearing TIF_SIGPENDING.
Acked-by: Oleg Nesterov <oleg@redhat.com>
Reported-by: Oleg Nesterov <oleg@redhat.com>
Reported-by: Ivan Delalande <colona@arista.com>
Fixes: 35634ffa1751 ("signal: Always notice exiting tasks")
commit 0722069a5374b904ec1a67f91249f90e1cfae259 upstream.
When printing multiple uprobe arguments as strings the output for the
earlier arguments would also include all later string arguments.
This is best explained in an example:
Consider adding a uprobe to a function receiving two strings as
parameters which is at offset 0xa0 in strlib.so and we want to print
both parameters when the uprobe is hit (on x86_64):
$ echo 'p:func /lib/strlib.so:0xa0 +0(%di):string +0(%si):string' > \
/sys/kernel/debug/tracing/uprobe_events
When the function is called as func("foo", "bar") and we hit the probe,
the trace file shows a line like the following:
[...] func: (0x7f7e683706a0) arg1="foobar" arg2="bar"
Note the extra "bar" printed as part of arg1. This behaviour stacks up
for additional string arguments.
The strings are stored in a dynamically growing part of the uprobe
buffer by fetch_store_string() after copying them from userspace via
strncpy_from_user(). The return value of strncpy_from_user() is then
directly used as the required size for the string. However, this does
not take the terminating null byte into account as the documentation
for strncpy_from_user() cleary states that it "[...] returns the
length of the string (not including the trailing NUL)" even though the
null byte will be copied to the destination.
Therefore, subsequent calls to fetch_store_string() will overwrite
the terminating null byte of the most recently fetched string with
the first character of the current string, leading to the
"accumulation" of strings in earlier arguments in the output.
Fix this by incrementing the return value of strncpy_from_user() by
one if we did not hit the maximum buffer size.
Link: http://lkml.kernel.org/r/20190116141629.5752-1-andreas.ziegler@fau.de
Fixes: 5baaa59ef09e ("tracing/probes: Implement 'memory' fetch method for uprobes")
Acked-by: Masami Hiramatsu <mhiramat@kernel.org>
Signed-off-by: Andreas Ziegler <andreas.ziegler@fau.de>
Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org>
commit 81ec3f3c4c4d78f2d3b6689c9816bfbdf7417dbb upstream.
Vince (and later on Ravi) reported crashes in the BTS code during
fuzzing with the following backtrace:
general protection fault: 0000 [#1] SMP PTI
RIP: 0010:perf_prepare_sample+0x8f/0x510
Call Trace:
<IRQ>
? intel_pmu_drain_bts_buffer+0x194/0x230
intel_pmu_drain_bts_buffer+0x160/0x230
? tick_nohz_irq_exit+0x31/0x40
? smp_call_function_single_interrupt+0x48/0xe0
? call_function_single_interrupt+0xf/0x20
? call_function_single_interrupt+0xa/0x20
? x86_schedule_events+0x1a0/0x2f0
? x86_pmu_commit_txn+0xb4/0x100
? find_busiest_group+0x47/0x5d0
? perf_event_set_state.part.42+0x12/0x50
? perf_mux_hrtimer_restart+0x40/0xb0
intel_pmu_disable_event+0xae/0x100
? intel_pmu_disable_event+0xae/0x100
x86_pmu_stop+0x7a/0xb0
x86_pmu_del+0x57/0x120
event_sched_out.isra.101+0x83/0x180
group_sched_out.part.103+0x57/0xe0
ctx_sched_out+0x188/0x240
ctx_resched+0xa8/0xd0
__perf_event_enable+0x193/0x1e0
event_function+0x8e/0xc0
remote_function+0x41/0x50
flush_smp_call_function_queue+0x68/0x100
generic_smp_call_function_single_interrupt+0x13/0x30
smp_call_function_single_interrupt+0x3e/0xe0
</IRQ>
The reason is that while event init code does several checks
for BTS events and prevents several unwanted config bits for
BTS event (like precise_ip), the PERF_EVENT_IOC_PERIOD allows
to create BTS event without those checks being done.
Following sequence will cause the crash:
If we create an 'almost' BTS event with precise_ip and callchains,
and it into a BTS event it will crash the perf_prepare_sample()
function because precise_ip events are expected to come
in with callchain data initialized, but that's not the
case for intel_pmu_drain_bts_buffer() caller.
Adding a check_period callback to be called before the period
is changed via PERF_EVENT_IOC_PERIOD. It will deny the change
if the event would become BTS. Plus adding also the limit_period
check as well.
Reported-by: Vince Weaver <vincent.weaver@maine.edu>
Signed-off-by: Jiri Olsa <jolsa@kernel.org>
Acked-by: Peter Zijlstra <peterz@infradead.org>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com>
Cc: Ravi Bangoria <ravi.bangoria@linux.ibm.com>
Cc: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/r/20190204123532.GA4794@krava
commit 528871b456026e6127d95b1b2bd8e3a003dc1614 upstream.
The following commit:
9dff0aa95a32 ("perf/core: Don't WARN() for impossible ring-buffer sizes")
results in perf recording failures with larger mmap areas:
root@skl:/tmp# perf record -g -a
failed to mmap with 12 (Cannot allocate memory)
The root cause is that the following condition is buggy:
if (order_base_2(size) >= MAX_ORDER)
goto fail;
The problem is that @size is in bytes and MAX_ORDER is in pages,
so the right test is:
if (order_base_2(size) >= PAGE_SHIFT+MAX_ORDER)
goto fail;
Fix it.
Reported-by: "Jin, Yao" <yao.jin@linux.intel.com>
Bisected-by: Borislav Petkov <bp@alien8.de>
Analyzed-by: Peter Zijlstra <peterz@infradead.org>
Cc: Julien Thierry <julien.thierry@arm.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Fixes: 9dff0aa95a32 ("perf/core: Don't WARN() for impossible ring-buffer sizes")
commit 7146db3317c67b517258cb5e1b08af387da0618b upstream.
Recently syzkaller was able to create unkillablle processes by
creating a timer that is delivered as a thread local signal on SIGHUP,
and receiving SIGHUP SA_NODEFERER. Ultimately causing a loop failing
to deliver SIGHUP but always trying.
When the stack overflows delivery of SIGHUP fails and force_sigsegv is
called. Unfortunately because SIGSEGV is numerically higher than
SIGHUP next_signal tries again to deliver a SIGHUP.
From a quality of implementation standpoint attempting to deliver the
timer SIGHUP signal is wrong. We should attempt to deliver the
synchronous SIGSEGV signal we just forced.
We can make that happening in a fairly straight forward manner by
instead of just looking at the signal number we also look at the
si_code. In particular for exceptions (aka synchronous signals) the
si_code is always greater than 0.
That still has the potential to pick up a number of asynchronous
signals as in a few cases the same si_codes that are used
for synchronous signals are also used for asynchronous signals,
and SI_KERNEL is also included in the list of possible si_codes.
Still the heuristic is much better and timer signals are definitely
excluded. Which is enough to prevent all known ways for someone
sending a process signals fast enough to cause unexpected and
arguably incorrect behavior.
Fixes: a27341cd5fcb ("Prioritize synchronous signals over 'normal' signals")
Tested-by: Dmitry Vyukov <dvyukov@google.com>
commit 35634ffa1751b6efd8cf75010b509dcb0263e29b upstream.
failing to deliver SIGHUP but always trying.
Upon examination it turns out part of the problem is actually most of
the solution. Since 2.5 signal delivery has found all fatal signals,
marked the signal group for death, and queued SIGKILL in every threads
thread queue relying on signal->group_exit_code to preserve the
information of which was the actual fatal signal.
The conversion of all fatal signals to SIGKILL results in the
synchronous signal heuristic in next_signal kicking in and preferring
SIGHUP to SIGKILL. Which is especially problematic as all
fatal signals have already been transformed into SIGKILL.
Instead of dequeueing signals and depending upon SIGKILL to
be the first signal dequeued, first test if the signal group
has already been marked for death. This guarantees that
nothing in the signal queue can prevent a process that needs
to exit from exiting.
Ref: ebf5ebe31d2c ("[PATCH] signal-fixes-2.5.59-A4")
History Tree: https://git.kernel.org/pub/scm/linux/kernel/git/tglx/history.git
commit 9dff0aa95a324e262ffb03f425d00e4751f3294e upstream.
The perf tool uses /proc/sys/kernel/perf_event_mlock_kb to determine how
large its ringbuffer mmap should be. This can be configured to arbitrary
values, which can be larger than the maximum possible allocation from
kmalloc.
When this is configured to a suitably large value (e.g. thanks to the
perf fuzzer), attempting to use perf record triggers a WARN_ON_ONCE() in
__alloc_pages_nodemask():
WARNING: CPU: 2 PID: 5666 at mm/page_alloc.c:4511 __alloc_pages_nodemask+0x3f8/0xbc8
Let's avoid this by checking that the requested allocation is possible
before calling kzalloc.
Reported-by: Julien Thierry <julien.thierry@arm.com>
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Reviewed-by: Julien Thierry <julien.thierry@arm.com>
Link: https://lkml.kernel.org/r/20190110142745.25495-1-mark.rutland@arm.com
[ Upstream commit 09be178400829dddc1189b50a7888495dd26aa84 ]
If the number of input parameters is less than the total parameters, an
EINVAL error will be returned.
For example, we use proc_doulongvec_minmax to pass up to two parameters
with kern_table:
.procname = "monitor_signals",
.data = &monitor_sigs,
.maxlen = 2*sizeof(unsigned long),
.mode = 0644,
.proc_handler = proc_doulongvec_minmax,
Reproduce:
When passing two parameters, it's work normal. But passing only one
parameter, an error "Invalid argument"(EINVAL) is returned.
[root@cl150 ~]# echo 1 2 > /proc/sys/kernel/monitor_signals
[root@cl150 ~]# cat /proc/sys/kernel/monitor_signals
1 2
[root@cl150 ~]# echo 3 > /proc/sys/kernel/monitor_signals
[root@cl150 ~]# echo $?
1
3 2
[root@cl150 ~]#
The following is the result after apply this patch. No error is
returned when the number of input parameters is less than the total
parameters.
1 2
0
3 2
[root@cl150 ~]#
There are three processing functions dealing with digital parameters,
__do_proc_dointvec/__do_proc_douintvec/__do_proc_doulongvec_minmax.
This patch deals with __do_proc_doulongvec_minmax, just as
__do_proc_dointvec does, adding a check for parameters 'left'. In
__do_proc_douintvec, its code implementation explicitly does not support
multiple inputs.
static int __do_proc_douintvec(...){
* Arrays are not supported, keep this simple. *Do not* add
* support for them.
if (vleft != 1) {
*lenp = 0;
return -EINVAL;
So, just __do_proc_doulongvec_minmax has the problem. And most use of
proc_doulongvec_minmax/proc_doulongvec_ms_jiffies_minmax just have one
parameter.
Link: http://lkml.kernel.org/r/1544081775-15720-1-git-send-email-cheng.lin130@zte.com.cn
Signed-off-by: Cheng Lin <cheng.lin130@zte.com.cn>
Acked-by: Luis Chamberlain <mcgrof@kernel.org>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
[ Upstream commit 304ae42739b108305f8d7b3eb3c1aec7c2b643a9 ]
check_hung_uninterruptible_tasks() is currently calling rcu_lock_break()
for every 1024 threads. But check_hung_task() is very slow if printk()
was called, and is very fast otherwise.
If many threads within some 1024 threads called printk(), the RCU grace
period might be extended enough to trigger RCU stall warnings.
Therefore, calling rcu_lock_break() for every some fixed jiffies will be
safer.
Link: http://lkml.kernel.org/r/1544800658-11423-1-git-send-email-penguin-kernel@I-love.SAKURA.ne.jp
Acked-by: Paul E. McKenney <paulmck@linux.ibm.com>
Cc: Petr Mladek <pmladek@suse.com>
Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: "Rafael J. Wysocki" <rafael.j.wysocki@intel.com>
Cc: Vitaly Kuznetsov <vkuznets@redhat.com>
[ Upstream commit ce10a5b3954f2514af726beb78ed8d7350c5e41c ]
tk_core.seq is initialized open coded, but that misses to initialize the
lockdep map when lockdep is enabled. Lockdep splats involving tk_core seq
consequently lack a name and are hard to read.
Use the proper initializer which takes care of the lockdep map
initialization.
[ tglx: Massaged changelog ]
Signed-off-by: Bart Van Assche <bvanassche@acm.org>
Cc: peterz@infradead.org
Cc: tj@kernel.org
Cc: johannes.berg@intel.com
Link: https://lkml.kernel.org/r/20181128234325.110011-12-bvanassche@acm.org
commit 8fb335e078378c8426fabeed1ebee1fbf915690c upstream.
Currently, exit_ptrace() adds all ptraced tasks in a dead list, then
zap_pid_ns_processes() waits on all tasks in a current pidns, and only
then are tasks from the dead list released.
zap_pid_ns_processes() can get stuck on waiting tasks from the dead
list. In this case, we will have one unkillable process with one or
more dead children.
Thanks to Oleg for the advice to release tasks in find_child_reaper().
Link: http://lkml.kernel.org/r/20190110175200.12442-1-avagin@gmail.com
Fixes: 7c8bd2322c7f ("exit: ptrace: shift "reap dead" code from exit_ptrace() to forget_original_parent()")
Signed-off-by: Andrei Vagin <avagin@gmail.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
commit 06489cfbd915ff36c8e36df27f1c2dc60f97ca56 upstream.
Given the fact that devm_memremap_pages() requires a percpu_ref that is
torn down by devm_memremap_pages_release() the current support for mapping
RAM is broken.
Support for remapping "System RAM" has been broken since the beginning and
there is no existing user of this this code path, so just kill the support
and make it an explicit error.
This cleanup also simplifies a follow-on patch to fix the error path when
setting a devm release action for devm_memremap_pages_release() fails.
Link: http://lkml.kernel.org/r/154275557997.76910.14689813630968180480.stgit@dwillia2-desk3.amr.corp.intel.com
Reviewed-by: "Jérôme Glisse" <jglisse@redhat.com>
Reviewed-by: Logan Gunthorpe <logang@deltatee.com>
Cc: Balbir Singh <bsingharora@gmail.com>
Cc: Michal Hocko <mhocko@suse.com>
commit 808153e1187fa77ac7d7dad261ff476888dcf398 upstream.
devm_memremap_pages() is a facility that can create struct page entries
for any arbitrary range and give drivers the ability to subvert core
aspects of page management.
Specifically the facility is tightly integrated with the kernel's memory
hotplug functionality. It injects an altmap argument deep into the
architecture specific vmemmap implementation to allow allocating from
specific reserved pages, and it has Linux specific assumptions about page
structure reference counting relative to get_user_pages() and
get_user_pages_fast(). It was an oversight and a mistake that this was
not marked EXPORT_SYMBOL_GPL from the outset.
Again, devm_memremap_pagex() exposes and relies upon core kernel internal
assumptions and will continue to evolve along with 'struct page', memory
hotplug, and support for new memory types / topologies. Only an in-kernel
GPL-only driver is expected to keep up with this ongoing evolution. This
interface, and functionality derived from this interface, is not suitable
for kernel-external drivers.
Link: http://lkml.kernel.org/r/154275557457.76910.16923571232582744134.stgit@dwillia2-desk3.amr.corp.intel.com
Cc: "Jérôme Glisse" <jglisse@redhat.com>
Cc: Logan Gunthorpe <logang@deltatee.com>
commit 7b55851367136b1efd84d98fea81ba57a98304cf upstream.
This changes the fork(2) syscall to record the process start_time after
initializing the basic task structure but still before making the new
process visible to user-space.
Technically, we could record the start_time anytime during fork(2). But
this might lead to scenarios where a start_time is recorded long before
a process becomes visible to user-space. For instance, with
userfaultfd(2) and TLS, user-space can delay the execution of fork(2)
for an indefinite amount of time (and will, if this causes network
access, or similar).
By recording the start_time late, it much closer reflects the point in
time where the process becomes live and can be observed by other
processes.
Lastly, this makes it much harder for user-space to predict and control
the start_time they get assigned. Previously, user-space could fork a
process and stall it in copy_thread_tls() before its pid is allocated,
but after its start_time is recorded. This can be misused to later-on
cycle through PIDs and resume the stalled fork(2) yielding a process
that has the same pid and start_time as a process that existed before.
This can be used to circumvent security systems that identify processes
by their pid+start_time combination.
Even though user-space was always aware that start_time recording is
flaky (but several projects are known to still rely on start_time-based
identification), changing the start_time to be recorded late will help
mitigate existing attacks and make it much harder for user-space to
control the start_time a process gets assigned.
Reported-by: Jann Horn <jannh@google.com>
Signed-off-by: Tom Gundersen <teg@jklm.no>
Signed-off-by: David Herrmann <dh.herrmann@gmail.com>
commit c7c3f05e341a9a2bd1a92993d4f996cfd6e7348e upstream.
From printk()/serial console point of view panic() is special, because
it may force CPU to re-enter printk() or/and serial console driver.
Therefore, some of serial consoles drivers are re-entrant. E.g. 8250:
serial8250_console_write()
if (port->sysrq)
locked = 0;
else if (oops_in_progress)
locked = spin_trylock_irqsave(&port->lock, flags);
else
spin_lock_irqsave(&port->lock, flags);
panic() does set oops_in_progress via bust_spinlocks(1), so in theory
we should be able to re-enter serial console driver from panic():
CPU0
<NMI>
uart_console_write()
serial8250_console_write() // if (oops_in_progress)
// spin_trylock_irqsave()
call_console_drivers()
console_unlock()
console_flush_on_panic()
bust_spinlocks(1) // oops_in_progress++
panic()
<NMI/>
spin_lock_irqsave(&port->lock, flags) // spin_lock_irqsave()
console_unlock()
printk()
However, this does not happen and we deadlock in serial console on
port->lock spinlock. And the problem is that console_flush_on_panic()
called after bust_spinlocks(0):
void panic(const char *fmt, ...)
bust_spinlocks(1);
bust_spinlocks(0);
console_flush_on_panic();
bust_spinlocks(0) decrements oops_in_progress, so oops_in_progress
can go back to zero. Thus even re-entrant console drivers will simply
spin on port->lock spinlock. Given that port->lock may already be
locked either by a stopped CPU, or by the very same CPU we execute
panic() on (for instance, NMI panic() on printing CPU) the system
deadlocks and does not reboot.
Fix this by removing bust_spinlocks(0), so oops_in_progress is always
set in panic() now and, thus, re-entrant console drivers will trylock
the port->lock instead of spinning on it forever, when we call them
from console_flush_on_panic().
Link: http://lkml.kernel.org/r/20181025101036.6823-1-sergey.senozhatsky@gmail.com
Cc: Daniel Wang <wonderfly@google.com>
Cc: Alan Cox <gnomes@lxorguk.ukuu.org.uk>
Cc: Jiri Slaby <jslaby@suse.com>
Cc: Peter Feiner <pfeiner@google.com>
Cc: linux-serial@vger.kernel.org
Cc: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com>
Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Signed-off-by: Petr Mladek <pmladek@suse.com>
[ Upstream commit c3494801cd1785e2c25f1a5735fa19ddcf9665da ]
Malicious user space may try to force the verifier to use as much cpu
time and memory as possible. Hence check for pending signals
while verifying the program.
Note that suspend of sys_bpf(PROG_LOAD) syscall will lead to EAGAIN,
since the kernel has to release the resources used for program verification.
Reported-by: Anatoly Trosinenko <anatoly.trosinenko@gmail.com>
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
Acked-by: Edward Cree <ecree@solarflare.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
commit 7aa54be2976550f17c11a1c3e3630002dea39303 upstream.
On x86 we cannot do fetch_or() with a single instruction and thus end up
using a cmpxchg loop, this reduces determinism. Replace the fetch_or()
with a composite operation: tas-pending + load.
Using two instructions of course opens a window we previously did not
have. Consider the scenario:
CPU0 CPU1 CPU2
1) lock
trylock -> (0,0,1)
2) lock
trylock /* fail */
3) unlock -> (0,0,0)
4) lock
trylock -> (0,0,1)
5) tas-pending -> (0,1,1)
load-val <- (0,1,0) from 3
6) clear-pending-set-locked -> (0,0,1)
FAIL: _2_ owners
where 5) is our new composite operation. When we consider each part of
the qspinlock state as a separate variable (as we can when
_Q_PENDING_BITS == 8) then the above is entirely possible, because
tas-pending will only RmW the pending byte, so the later load is able
to observe prior tail and lock state (but not earlier than its own
trylock, which operates on the whole word, due to coherence).
To avoid this we need 2 things:
- the load must come after the tas-pending (obviously, otherwise it
can trivially observe prior state).
- the tas-pending must be a full word RmW instruction, it cannot be an XCHGB for
example, such that we cannot observe other state prior to setting
pending.
On x86 we can realize this by using "LOCK BTS m32, r32" for
tas-pending followed by a regular load.
Note that observing later state is not a problem:
- if we fail to observe a later unlock, we'll simply spin-wait for
that store to become visible.
- if we observe a later xchg_tail(), there is no difference from that
xchg_tail() having taken place before the tas-pending.
Suggested-by: Will Deacon <will.deacon@arm.com>
Reported-by: Thomas Gleixner <tglx@linutronix.de>
Reviewed-by: Will Deacon <will.deacon@arm.com>
Cc: andrea.parri@amarulasolutions.com
Cc: longman@redhat.com
Fixes: 59fb586b4a07 ("locking/qspinlock: Remove unbounded cmpxchg() loop from locking slowpath")
Link: https://lkml.kernel.org/r/20181003130957.183726335@infradead.org
[bigeasy: GEN_BINARY_RMWcc macro redo]
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
commit 53bf57fab7321fb42b703056a4c80fc9d986d170 upstream.
Flip the branch condition after atomic_fetch_or_acquire(_Q_PENDING_VAL)
such that we loose the indent. This also result in a more natural code
flow IMO.
Acked-by: Will Deacon <will.deacon@arm.com>
Link: https://lkml.kernel.org/r/20181003130257.156322446@infradead.org
commit c61da58d8a9ba9238250a548f00826eaf44af0f7 upstream.
When a queued locker reaches the head of the queue, it claims the lock
by setting _Q_LOCKED_VAL in the lockword. If there isn't contention, it
must also clear the tail as part of this operation so that subsequent
lockers can avoid taking the slowpath altogether.
Currently this is expressed as a cmpxchg() loop that practically only
runs up to two iterations. This is confusing to the reader and unhelpful
to the compiler. Rewrite the cmpxchg() loop without the loop, so that a
failed cmpxchg() implies that there is contention and we just need to
write to _Q_LOCKED_VAL without considering the rest of the lockword.
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Acked-by: Waiman Long <longman@redhat.com>
Cc: boqun.feng@gmail.com
Cc: paulmck@linux.vnet.ibm.com
Link: http://lkml.kernel.org/r/1524738868-31318-7-git-send-email-will.deacon@arm.com
commit 3bea9adc96842b8a7345c7fb202c16ae9c8d5b25 upstream.
The native clear_pending() function is identical to the PV version, so the
latter can simply be removed.
This fixes the build for systems with >= 16K CPUs using the PV lock implementation.
Reported-by: Waiman Long <longman@redhat.com>
Link: http://lkml.kernel.org/r/20180427101619.GB21705@arm.com
commit 59fb586b4a07b4e1a0ee577140ab4842ba451acd upstream.
The qspinlock locking slowpath utilises a "pending" bit as a simple form
of an embedded test-and-set lock that can avoid the overhead of explicit
queuing in cases where the lock is held but uncontended. This bit is
managed using a cmpxchg() loop which tries to transition the uncontended
lock word from (0,0,0) -> (0,0,1) or (0,0,1) -> (0,1,1).
Unfortunately, the cmpxchg() loop is unbounded and lockers can be starved
indefinitely if the lock word is seen to oscillate between unlocked
(0,0,0) and locked (0,0,1). This could happen if concurrent lockers are
able to take the lock in the cmpxchg() loop without queuing and pass it
around amongst themselves.
This patch fixes the problem by unconditionally setting _Q_PENDING_VAL
using atomic_fetch_or, and then inspecting the old value to see whether
we need to spin on the current lock owner, or whether we now effectively
hold the lock. The tricky scenario is when concurrent lockers end up
queuing on the lock and the lock becomes available, causing us to see
a lockword of (n,0,0). With pending now set, simply queuing could lead
to deadlock as the head of the queue may not have observed the pending
flag being cleared. Conversely, if the head of the queue did observe
pending being cleared, then it could transition the lock from (n,0,0) ->
(0,0,1) meaning that any attempt to "undo" our setting of the pending
bit could race with a concurrent locker trying to set it.
We handle this race by preserving the pending bit when taking the lock
after reaching the head of the queue and leaving the tail entry intact
if we saw pending set, because we know that the tail is going to be
updated shortly.
Link: http://lkml.kernel.org/r/1524738868-31318-6-git-send-email-will.deacon@arm.com
commit 625e88be1f41b53cec55827c984e4a89ea8ee9f9 upstream.
'struct __qspinlock' provides a handy union of fields so that
subcomponents of the lockword can be accessed by name, without having to
manage shifts and masks explicitly and take endianness into account.
This is useful in qspinlock.h and also potentially in arch headers, so
move the 'struct __qspinlock' into 'struct qspinlock' and kill the extra
definition.
Acked-by: Boqun Feng <boqun.feng@gmail.com>
Link: http://lkml.kernel.org/r/1524738868-31318-3-git-send-email-will.deacon@arm.com
commit 6512276d97b160d90b53285bd06f7f201459a7e3 upstream.
If a locker taking the qspinlock slowpath reads a lock value indicating
that only the pending bit is set, then it will spin whilst the
concurrent pending->locked transition takes effect.
Unfortunately, there is no guarantee that such a transition will ever be
observed since concurrent lockers could continuously set pending and
hand over the lock amongst themselves, leading to starvation. Whilst
this would probably resolve in practice, it means that it is not
possible to prove liveness properties about the lock and means that lock
acquisition time is unbounded.
Rather than removing the pending->locked spinning from the slowpath
altogether (which has been shown to heavily penalise a 2-threaded
locking stress test on x86), this patch replaces the explicit spinning
with a call to atomic_cond_read_relaxed and allows the architecture to
provide a bound on the number of spins. For architectures that can
respond to changes in cacheline state in their smp_cond_load implementation,
it should be sufficient to use the default bound of 1.
Suggested-by: Waiman Long <longman@redhat.com>
Link: http://lkml.kernel.org/r/1524738868-31318-4-git-send-email-will.deacon@arm.com
commit 95bcade33a8af38755c9b0636e36a36ad3789fe6 upstream.
When a locker ends up queuing on the qspinlock locking slowpath, we
initialise the relevant mcs node and publish it indirectly by updating
the tail portion of the lock word using xchg_tail. If we find that there
was a pre-existing locker in the queue, we subsequently update their
->next field to point at our node so that we are notified when it's our
turn to take the lock.
This can be roughly illustrated as follows:
/* Initialise the fields in node and encode a pointer to node in tail */
tail = initialise_node(node);
* Exchange tail into the lockword using an atomic read-modify-write
* operation with release semantics
old = xchg_tail(lock, tail);
/* If there was a pre-existing waiter ... */
if (old & _Q_TAIL_MASK) {
prev = decode_tail(old);
smp_read_barrier_depends();
/* ... then update their ->next field to point to node.
WRITE_ONCE(prev->next, node);
The conditional update of prev->next therefore relies on the address
dependency from the result of xchg_tail ensuring order against the
prior initialisation of node. However, since the release semantics of
the xchg_tail operation apply only to the write portion of the RmW,
then this ordering is not guaranteed and it is possible for the CPU
to return old before the writes to node have been published, consequently
allowing us to point prev->next to an uninitialised node.
This patch fixes the problem by making the update of prev->next a RELEASE
operation, which also removes the reliance on dependency ordering.
Link: http://lkml.kernel.org/r/1518528177-19169-2-git-send-email-will.deacon@arm.com
commit 548095dea63ffc016d39c35b32c628d033638aca upstream.
Queued spinlocks are not used by DEC Alpha, and furthermore operations
such as READ_ONCE() and release/relaxed RMW atomics are being changed
to imply smp_read_barrier_depends(). This commit therefore removes the
now-redundant smp_read_barrier_depends() from queued_spin_lock_slowpath(),
and adjusts the comments accordingly.
commit 2840f84f74035e5a535959d5f17269c69fa6edc5 upstream.
The following commands will cause a memory leak:
# cd /sys/kernel/tracing
# mkdir instances/foo
# echo schedule > instance/foo/set_ftrace_filter
# rmdir instances/foo
The reason is that the hashes that hold the filters to set_ftrace_filter and
set_ftrace_notrace are not freed if they contain any data on the instance
and the instance is removed.
Found by kmemleak detector.
Fixes: 591dffdade9f ("ftrace: Allow for function tracing instance to filter functions")
commit 3cec638b3d793b7cacdec5b8072364b41caeb0e1 upstream.
When create_event_filter() fails in set_trigger_filter(), the filter may
still be allocated and needs to be freed. The caller expects the
data->filter to be updated with the new filter, even if the new filter
failed (we could add an error message by setting set_str parameter of
create_event_filter(), but that's another update).
But because the error would just exit, filter was left hanging and
nothing could free it.
Fixes: bac5fb97a173a ("tracing: Add and use generic set_trigger_filter() implementation")
Reviewed-by: Tom Zanussi <tom.zanussi@linux.intel.com>
[ Upstream commit 8e7df2b5b7f245c9bd11064712db5cb69044a362 ]
While it uses %pK, there's still few reasons to read this file
as non-root.
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
commit 22839869f21ab3850fbbac9b425ccc4c0023926f upstream.
The sigaltstack(2) system call fails with -ENOMEM if the new alternative
signal stack is found to be smaller than SIGMINSTKSZ. On architectures
such as arm64, where the native value for SIGMINSTKSZ is larger than
the compat value, this can result in an unexpected error being reported
to a compat task. See, for example:
https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=904385
This patch fixes the problem by extending do_sigaltstack to take the
minimum signal stack size as an additional parameter, allowing the
native and compat system call entry code to pass in their respective
values. COMPAT_SIGMINSTKSZ is just defined as SIGMINSTKSZ if it has not
been defined by the architecture.
Cc: Dominik Brodowski <linux@dominikbrodowski.net>
Reported-by: Steve McIntyre <steve.mcintyre@arm.com>
Tested-by: Steve McIntyre <93sam@debian.org>
[signal: Fix up cherry-pick conflicts for 22839869f21a]
Signed-off-by: Steve McIntyre <93sam@debian.org>
[ Upstream commit 1efb6ee3edea57f57f9fb05dba8dcb3f7333f61f ]
A format string consisting of "%p" or "%s" followed by an invalid
specifier (e.g. "%p%\n" or "%s%") could pass the check which
would make format_decode (lib/vsprintf.c) to warn.
Fixes: 9c959c863f82 ("tracing: Allow BPF programs to call bpf_trace_printk()")
Reported-by: syzbot+1ec5c5ec949c4adaa0c4@syzkaller.appspotmail.com
Signed-off-by: Martynas Pumputis <m@lambda.lt>
This is the 4.9.144 stable release
commit af86ca4e3088fe5eacf2f7e58c01fa68ca067672 upstream.
Detect code patterns where malicious 'speculative store bypass' can be used
and sanitize such patterns.
39: (bf) r3 = r10
40: (07) r3 += -216
41: (79) r8 = *(u64 *)(r7 +0) // slow read
42: (7a) *(u64 *)(r10 -72) = 0 // verifier inserts this instruction
43: (7b) *(u64 *)(r8 +0) = r3 // this store becomes slow due to r8
44: (79) r1 = *(u64 *)(r6 +0) // cpu speculatively executes this load
45: (71) r2 = *(u8 *)(r1 +0) // speculatively arbitrary 'load byte'
// is now sanitized
Above code after x86 JIT becomes:
e5: mov %rbp,%rdx
e8: add $0xffffffffffffff28,%rdx
ef: mov 0x0(%r13),%r14
f3: movq $0x0,-0x48(%rbp)
fb: mov %rdx,0x0(%r14)
ff: mov 0x0(%rbx),%rdi
103: movzbq 0x0(%rdi),%rsi
[bwh: Backported to 4.9:
- Add bpf_verifier_env parameter to check_stack_write()
- Look up stack slot_types with state->stack_slot_type[] rather than
state->stack[].slot_type[]
- Drop bpf_verifier_env argument to verbose()
- Adjust context]
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
Extracted from commit 31fd85816dbe "bpf: permits narrower load from
bpf program context fields".
Cc: Daniel Borkmann <daniel@iogearbox.net>
Cc: Alexei Starovoitov <ast@kernel.org>
Extracted from commit dc503a8ad984 "bpf/verifier: track liveness for
pruning".
commit 09d3f015d1e1b4fee7e9bbdcf54201d239393391 upstream.
Commit:
142b18ddc8143 ("uprobes: Fix handle_swbp() vs unregister() + register() race")
added the UPROBE_COPY_INSN flag, and corresponding smp_wmb() and smp_rmb()
memory barriers, to ensure that handle_swbp() uses fully-initialized
uprobes only.
However, the smp_rmb() is mis-placed: this barrier should be placed
after handle_swbp() has tested for the flag, thus guaranteeing that
(program-order) subsequent loads from the uprobe can see the initial
stores performed by prepare_uprobe().
Move the smp_rmb() accordingly. Also amend the comments associated
to the two memory barriers to indicate their actual locations.
Signed-off-by: Andrea Parri <andrea.parri@amarulasolutions.com>
Cc: Vince Weaver <vincent.weaver@maine.edu>
Cc: stable@kernel.org
Fixes: 142b18ddc8143 ("uprobes: Fix handle_swbp() vs unregister() + register() race")
Link: http://lkml.kernel.org/r/20181122161031.15179-1-andrea.parri@amarulasolutions.com
commit 2cf2f0d5b91fd1b06a6ae260462fc7945ea84add upstream.
gcc discovered that the memcpy() arguments in kdbnearsym() overlap, so
we should really use memmove(), which is defined to handle that correctly:
In function 'memcpy',
inlined from 'kdbnearsym' at /git/arm-soc/kernel/debug/kdb/kdb_support.c:132:4:
/git/arm-soc/include/linux/string.h:353:9: error: '__builtin_memcpy' accessing 792 bytes at offsets 0 and 8 overlaps 784 bytes at offset 8 [-Werror=restrict]
return __builtin_memcpy(p, q, size);
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
commit 30aba6656f61ed44cba445a3c0d38b296fa9e8f5 upstream.
Disallows open of FIFOs or regular files not owned by the user in world
writable sticky directories, unless the owner is the same as that of the
directory or the file is opened without the O_CREAT flag. The purpose
is to make data spoofing attacks harder. This protection can be turned
on and off separately for FIFOs and regular files via sysctl, just like
the symlinks/hardlinks protection. This patch is based on Openwall's
"HARDEN_FIFO" feature by Solar Designer.
This is a brief list of old vulnerabilities that could have been prevented
by this feature, some of them even allow for privilege escalation:
CVE-2000-1134
CVE-2007-3852
CVE-2008-0525
CVE-2009-0416
CVE-2011-4834
CVE-2015-1838
CVE-2015-7442
CVE-2016-7489
This list is not meant to be complete. It's difficult to track down all
vulnerabilities of this kind because they were often reported without any
mention of this particular attack vector. In fact, before
hardlinks/symlinks restrictions, fifos/regular files weren't the favorite
vehicle to exploit them.
[s.mesoraca16@gmail.com: fix bug reported by Dan Carpenter]
Link: https://lkml.kernel.org/r/20180426081456.GA7060@mwanda
Link: http://lkml.kernel.org/r/1524829819-11275-1-git-send-email-s.mesoraca16@gmail.com
[keescook@chromium.org: drop pr_warn_ratelimited() in favor of audit changes in the future]
[keescook@chromium.org: adjust commit subjet]
Link: http://lkml.kernel.org/r/20180416175918.GA13494@beast
Signed-off-by: Salvatore Mesoraca <s.mesoraca16@gmail.com>
Suggested-by: Solar Designer <solar@openwall.com>
Suggested-by: Kees Cook <keescook@chromium.org>
Cc: Dan Carpenter <dan.carpenter@oracle.com>
Cc: Loic <hackurx@opensec.fr>
commit 896bbb2522587e3b8eb2a0d204d43ccc1042a00d upstream.
When priority inheritance was added back in 2.6.18 to sched_setscheduler(), it
added a path to taking an rt-mutex wait_lock, which is not IRQ safe. As PI
is not a common occurrence, lockdep will likely never trigger if
sched_setscheduler was called from interrupt context. A BUG_ON() was added
to trigger if __sched_setscheduler() was ever called from interrupt context
because there was a possibility to take the wait_lock.
Today the wait_lock is irq safe, but the path to taking it in
sched_setscheduler() is the same as the path to taking it from normal
context. The wait_lock is taken with raw_spin_lock_irq() and released with
raw_spin_unlock_irq() which will indiscriminately enable interrupts,
which would be bad in interrupt context.
The problem is that normalize_rt_tasks, which is called by triggering the
sysrq nice-all-RT-tasks was changed to call __sched_setscheduler(), and this
is done from interrupt context!
Now __sched_setscheduler() takes a "pi" parameter that is used to know if
the priority inheritance should be called or not. As the BUG_ON() only cares
about calling the PI code, it should only bug if called from interrupt
context with the "pi" parameter set to true.
Reported-by: Laurent Dufour <ldufour@linux.vnet.ibm.com>
Tested-by: Laurent Dufour <ldufour@linux.vnet.ibm.com>
Cc: Andrew Morton <akpm@osdl.org>
Fixes: dbc7f069b93a ("sched: Use replace normalize_task() with __sched_setscheduler()")
Link: http://lkml.kernel.org/r/20170308124654.10e598f2@gandalf.local.home
[ Upstream commit c2b94c72d93d0929f48157eef128c4f9d2e603ce ]
gcc 8.1.0 warns with:
kernel/debug/kdb/kdb_support.c: In function ‘kallsyms_symbol_next’:
kernel/debug/kdb/kdb_support.c:239:4: warning: ‘strncpy’ specified bound depends on the length of the source argument [-Wstringop-overflow=]
strncpy(prefix_name, name, strlen(name)+1);
kernel/debug/kdb/kdb_support.c:239:31: note: length computed here
Use strscpy() with the destination buffer size, and use ellipses when
displaying truncated symbols.
v2: Use strscpy()
Signed-off-by: Prarit Bhargava <prarit@redhat.com>
Cc: Jonathan Toppins <jtoppins@redhat.com>
Cc: Jason Wessel <jason.wessel@windriver.com>
Cc: Daniel Thompson <daniel.thompson@linaro.org>
Cc: kgdb-bugreport@lists.sourceforge.net
Reviewed-by: Daniel Thompson <daniel.thompson@linaro.org>
Signed-off-by: Daniel Thompson <daniel.thompson@linaro.org>
