path: root/kernel
2017-11-15workqueue: Fix NULL pointer dereferenceLi Bin
commit cef572ad9bd7f85035ba8272e5352040e8be0152 upstream. When queue_work() is used in irq (not in task context), there is a potential case that trigger NULL pointer dereference. ---------------------------------------------------------------- worker_thread() |-spin_lock_irq() |-process_one_work() |-worker->current_pwq = pwq |-spin_unlock_irq() |-worker->current_func(work) |-spin_lock_irq() |-worker->current_pwq = NULL |-spin_unlock_irq() //interrupt here |-irq_handler |-__queue_work() //assuming that the wq is draining |-is_chained_work(wq) |-current_wq_worker() //Here, 'current' is the interrupted worker! |-current->current_pwq is NULL here! |-schedule() ---------------------------------------------------------------- Avoid it by checking for task context in current_wq_worker(), and if not in task context, we shouldn't use the 'current' to check the condition. Reported-by: Xiaofei Tan <tanxiaofei@huawei.com> Signed-off-by: Li Bin <huawei.libin@huawei.com> Reviewed-by: Lai Jiangshan <jiangshanlai@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org> Fixes: 8d03ecfe4718 ("workqueue: reimplement is_chained_work() using current_wq_worker()") Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-15sched/core: Add missing update_rq_clock() call in sched_move_task()Peter Zijlstra
[ Upstream commit 1b1d62254df0fe42a711eb71948f915918987790 ] Bug was noticed via this warning: WARNING: CPU: 6 PID: 1 at kernel/sched/sched.h:804 detach_task_cfs_rq+0x8e8/0xb80 rq->clock_update_flags < RQCF_ACT_SKIP Modules linked in: CPU: 6 PID: 1 Comm: systemd Not tainted 4.10.0-rc5-00140-g0874170baf55-dirty #1 Hardware name: Supermicro SYS-4048B-TRFT/X10QBi, BIOS 1.0 04/11/2014 Call Trace: dump_stack+0x4d/0x65 __warn+0xcb/0xf0 warn_slowpath_fmt+0x5f/0x80 detach_task_cfs_rq+0x8e8/0xb80 ? allocate_cgrp_cset_links+0x59/0x80 task_change_group_fair+0x27/0x150 sched_change_group+0x48/0xf0 sched_move_task+0x53/0x150 cpu_cgroup_attach+0x36/0x70 cgroup_taskset_migrate+0x175/0x300 cgroup_migrate+0xab/0xd0 cgroup_attach_task+0xf0/0x190 __cgroup_procs_write+0x1ed/0x2f0 cgroup_procs_write+0x14/0x20 cgroup_file_write+0x3f/0x100 kernfs_fop_write+0x104/0x180 __vfs_write+0x37/0x140 vfs_write+0xb8/0x1b0 SyS_write+0x55/0xc0 do_syscall_64+0x61/0x170 entry_SYSCALL64_slow_path+0x25/0x25 Reported-by: Ingo Molnar <mingo@kernel.org> Reported-by: Borislav Petkov <bp@alien8.de> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-02workqueue: replace pool->manager_arb mutex with a flagTejun Heo
commit 692b48258dda7c302e777d7d5f4217244478f1f6 upstream. Josef reported a HARDIRQ-safe -> HARDIRQ-unsafe lock order detected by lockdep: [ 1270.472259] WARNING: HARDIRQ-safe -> HARDIRQ-unsafe lock order detected [ 1270.472783] 4.14.0-rc1-xfstests-12888-g76833e8 #110 Not tainted [ 1270.473240] ----------------------------------------------------- [ 1270.473710] kworker/u5:2/5157 [HC0[0]:SC0[0]:HE0:SE1] is trying to acquire: [ 1270.474239] (&(&lock->wait_lock)->rlock){+.+.}, at: [<ffffffff8da253d2>] __mutex_unlock_slowpath+0xa2/0x280 [ 1270.474994] [ 1270.474994] and this task is already holding: [ 1270.475440] (&pool->lock/1){-.-.}, at: [<ffffffff8d2992f6>] worker_thread+0x366/0x3c0 [ 1270.476046] which would create a new lock dependency: [ 1270.476436] (&pool->lock/1){-.-.} -> (&(&lock->wait_lock)->rlock){+.+.} [ 1270.476949] [ 1270.476949] but this new dependency connects a HARDIRQ-irq-safe lock: [ 1270.477553] (&pool->lock/1){-.-.} ... [ 1270.488900] to a HARDIRQ-irq-unsafe lock: [ 1270.489327] (&(&lock->wait_lock)->rlock){+.+.} ... [ 1270.494735] Possible interrupt unsafe locking scenario: [ 1270.494735] [ 1270.495250] CPU0 CPU1 [ 1270.495600] ---- ---- [ 1270.495947] lock(&(&lock->wait_lock)->rlock); [ 1270.496295] local_irq_disable(); [ 1270.496753] lock(&pool->lock/1); [ 1270.497205] lock(&(&lock->wait_lock)->rlock); [ 1270.497744] <Interrupt> [ 1270.497948] lock(&pool->lock/1); , which will cause a irq inversion deadlock if the above lock scenario happens. The root cause of this safe -> unsafe lock order is the mutex_unlock(pool->manager_arb) in manage_workers() with pool->lock held. Unlocking mutex while holding an irq spinlock was never safe and this problem has been around forever but it never got noticed because the only time the mutex is usually trylocked while holding irqlock making actual failures very unlikely and lockdep annotation missed the condition until the recent b9c16a0e1f73 ("locking/mutex: Fix lockdep_assert_held() fail"). Using mutex for pool->manager_arb has always been a bit of stretch. It primarily is an mechanism to arbitrate managership between workers which can easily be done with a pool flag. The only reason it became a mutex is that pool destruction path wants to exclude parallel managing operations. This patch replaces the mutex with a new pool flag POOL_MANAGER_ACTIVE and make the destruction path wait for the current manager on a wait queue. v2: Drop unnecessary flag clearing before pool destruction as suggested by Boqun. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Josef Bacik <josef@toxicpanda.com> Reviewed-by: Lai Jiangshan <jiangshanlai@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Boqun Feng <boqun.feng@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-21hrtimer: Catch invalid clockids againMarc Zyngier
[ Upstream commit 336a9cde10d641e70bac67d90ae91b3190c3edca ] commit 82e88ff1ea94 ("hrtimer: Revert CLOCK_MONOTONIC_RAW support") removed unfortunately a sanity check in the hrtimer code which was part of that MONOTONIC_RAW patch series. It would have caught the bogus usage of CLOCK_MONOTONIC_RAW in the wireless code. So bring it back. It is way too easy to take any random clockid and feed it to the hrtimer subsystem. At best, it gets mapped to a monotonic base, but it would be better to just catch illegal values as early as possible. Detect invalid clockids, map them to CLOCK_MONOTONIC and emit a warning. [ tglx: Replaced the BUG by a WARN and gracefully map to CLOCK_MONOTONIC ] Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Cc: Tomasz Nowicki <tn@semihalf.com> Cc: Christoffer Dall <christoffer.dall@linaro.org> Link: http://lkml.kernel.org/r/1452879670-16133-3-git-send-email-marc.zyngier@arm.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-21sched/fair: Update rq clock before changing a task's CPU affinityWanpeng Li
[ Upstream commit a499c3ead88ccf147fc50689e85a530ad923ce36 ] This is triggered during boot when CONFIG_SCHED_DEBUG is enabled: ------------[ cut here ]------------ WARNING: CPU: 6 PID: 81 at kernel/sched/sched.h:812 set_next_entity+0x11d/0x380 rq->clock_update_flags < RQCF_ACT_SKIP CPU: 6 PID: 81 Comm: torture_shuffle Not tainted 4.10.0+ #1 Hardware name: LENOVO ThinkCentre M8500t-N000/SHARKBAY, BIOS FBKTC1AUS 02/16/2016 Call Trace: dump_stack+0x85/0xc2 __warn+0xcb/0xf0 warn_slowpath_fmt+0x5f/0x80 set_next_entity+0x11d/0x380 set_curr_task_fair+0x2b/0x60 do_set_cpus_allowed+0x139/0x180 __set_cpus_allowed_ptr+0x113/0x260 set_cpus_allowed_ptr+0x10/0x20 torture_shuffle+0xfd/0x180 kthread+0x10f/0x150 ? torture_shutdown_init+0x60/0x60 ? kthread_create_on_node+0x60/0x60 ret_from_fork+0x31/0x40 ---[ end trace dd94d92344cea9c6 ]--- The task is running && !queued, so there is no rq clock update before calling set_curr_task(). This patch fixes it by updating rq clock after holding rq->lock/pi_lock just as what other dequeue + put_prev + enqueue + set_curr story does. Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Reviewed-by: Matt Fleming <matt@codeblueprint.co.uk> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1487749975-5994-1-git-send-email-wanpeng.li@hotmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-21locking/lockdep: Add nest_lock integrity testPeter Zijlstra
[ Upstream commit 7fb4a2cea6b18dab56d609530d077f168169ed6b ] Boqun reported that hlock->references can overflow. Add a debug test for that to generate a clear error when this happens. Without this, lockdep is likely to report a mysterious failure on unlock. Reported-by: Boqun Feng <boqun.feng@gmail.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Chris Wilson <chris@chris-wilson.co.uk> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Nicolai Hähnle <Nicolai.Haehnle@amd.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-18rcu: Allow for page faults in NMI handlersPaul E. McKenney
commit 28585a832602747cbfa88ad8934013177a3aae38 upstream. A number of architecture invoke rcu_irq_enter() on exception entry in order to allow RCU read-side critical sections in the exception handler when the exception is from an idle or nohz_full CPU. This works, at least unless the exception happens in an NMI handler. In that case, rcu_nmi_enter() would already have exited the extended quiescent state, which would mean that rcu_irq_enter() would (incorrectly) cause RCU to think that it is again in an extended quiescent state. This will in turn result in lockdep splats in response to later RCU read-side critical sections. This commit therefore causes rcu_irq_enter() and rcu_irq_exit() to take no action if there is an rcu_nmi_enter() in effect, thus avoiding the unscheduled return to RCU quiescent state. This in turn should make the kernel safe for on-demand RCU voyeurism. Link: http://lkml.kernel.org/r/20170922211022.GA18084@linux.vnet.ibm.com Fixes: 0be964be0 ("module: Sanitize RCU usage and locking") Reported-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-12sched/cpuset/pm: Fix cpuset vs. suspend-resume bugsPeter Zijlstra
commit 50e76632339d4655859523a39249dd95ee5e93e7 upstream. Cpusets vs. suspend-resume is _completely_ broken. And it got noticed because it now resulted in non-cpuset usage breaking too. On suspend cpuset_cpu_inactive() doesn't call into cpuset_update_active_cpus() because it doesn't want to move tasks about, there is no need, all tasks are frozen and won't run again until after we've resumed everything. But this means that when we finally do call into cpuset_update_active_cpus() after resuming the last frozen cpu in cpuset_cpu_active(), the top_cpuset will not have any difference with the cpu_active_mask and this it will not in fact do _anything_. So the cpuset configuration will not be restored. This was largely hidden because we would unconditionally create identity domains and mobile users would not in fact use cpusets much. And servers what do use cpusets tend to not suspend-resume much. An addition problem is that we'd not in fact wait for the cpuset work to finish before resuming the tasks, allowing spurious migrations outside of the specified domains. Fix the rebuild by introducing cpuset_force_rebuild() and fix the ordering with cpuset_wait_for_hotplug(). Reported-by: Andy Lutomirski <luto@kernel.org> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: <stable@vger.kernel.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rafael J. Wysocki <rjw@rjwysocki.net> Cc: Tejun Heo <tj@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Fixes: deb7aa308ea2 ("cpuset: reorganize CPU / memory hotplug handling") Link: http://lkml.kernel.org/r/20170907091338.orwxrqkbfkki3c24@hirez.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-12ftrace: Fix kmemleak in unregister_ftrace_graphShu Wang
commit 2b0b8499ae75df91455bbeb7491d45affc384fb0 upstream. The trampoline allocated by function tracer was overwriten by function_graph tracer, and caused a memory leak. The save_global_trampoline should have saved the previous trampoline in register_ftrace_graph() and restored it in unregister_ftrace_graph(). But as it is implemented, save_global_trampoline was only used in unregister_ftrace_graph as default value 0, and it overwrote the previous trampoline's value. Causing the previous allocated trampoline to be lost. kmmeleak backtrace: kmemleak_vmalloc+0x77/0xc0 __vmalloc_node_range+0x1b5/0x2c0 module_alloc+0x7c/0xd0 arch_ftrace_update_trampoline+0xb5/0x290 ftrace_startup+0x78/0x210 register_ftrace_function+0x8b/0xd0 function_trace_init+0x4f/0x80 tracing_set_tracer+0xe6/0x170 tracing_set_trace_write+0x90/0xd0 __vfs_write+0x37/0x170 vfs_write+0xb2/0x1b0 SyS_write+0x55/0xc0 do_syscall_64+0x67/0x180 return_from_SYSCALL_64+0x0/0x6a [ Looking further into this, I found that this was left over from when the function and function graph tracers shared the same ftrace_ops. But in commit 5f151b2401 ("ftrace: Fix function_profiler and function tracer together"), the two were separated, and the save_global_trampoline no longer was necessary (and it may have been broken back then too). -- Steven Rostedt ] Link: http://lkml.kernel.org/r/20170912021454.5976-1-shuwang@redhat.com Fixes: 5f151b2401 ("ftrace: Fix function_profiler and function tracer together") Signed-off-by: Shu Wang <shuwang@redhat.com> Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-12bpf: one perf event close won't free bpf program attached by another perf eventYonghong Song
[ Upstream commit ec9dd352d591f0c90402ec67a317c1ed4fb2e638 ] This patch fixes a bug exhibited by the following scenario: 1. fd1 = perf_event_open with attr.config = ID1 2. attach bpf program prog1 to fd1 3. fd2 = perf_event_open with attr.config = ID1 <this will be successful> 4. user program closes fd2 and prog1 is detached from the tracepoint. 5. user program with fd1 does not work properly as tracepoint no output any more. The issue happens at step 4. Multiple perf_event_open can be called successfully, but only one bpf prog pointer in the tp_event. In the current logic, any fd release for the same tp_event will free the tp_event->prog. The fix is to free tp_event->prog only when the closing fd corresponds to the one which registered the program. Signed-off-by: Yonghong Song <yhs@fb.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-12bpf/verifier: reject BPF_ALU64|BPF_ENDEdward Cree
[ Upstream commit e67b8a685c7c984e834e3181ef4619cd7025a136 ] Neither ___bpf_prog_run nor the JITs accept it. Also adds a new test case. Fixes: 17a5267067f3 ("bpf: verifier (add verifier core)") Signed-off-by: Edward Cree <ecree@solarflare.com> Acked-by: Alexei Starovoitov <ast@kernel.org> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-05timer/sysclt: Restrict timer migration sysctl values to 0 and 1Myungho Jung
commit b94bf594cf8ed67cdd0439e70fa939783471597a upstream. timer_migration sysctl acts as a boolean switch, so the allowed values should be restricted to 0 and 1. Add the necessary extra fields to the sysctl table entry to enforce that. [ tglx: Rewrote changelog ] Signed-off-by: Myungho Jung <mhjungk@gmail.com> Link: http://lkml.kernel.org/r/1492640690-3550-1-git-send-email-mhjungk@gmail.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Kazuhiro Hayashi <kazuhiro3.hayashi@toshiba.co.jp> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-05seccomp: fix the usage of get/put_seccomp_filter() in seccomp_get_filter()Oleg Nesterov
commit 66a733ea6b611aecf0119514d2dddab5f9d6c01e upstream. As Chris explains, get_seccomp_filter() and put_seccomp_filter() can end up using different filters. Once we drop ->siglock it is possible for task->seccomp.filter to have been replaced by SECCOMP_FILTER_FLAG_TSYNC. Fixes: f8e529ed941b ("seccomp, ptrace: add support for dumping seccomp filters") Reported-by: Chris Salls <chrissalls5@gmail.com> Signed-off-by: Oleg Nesterov <oleg@redhat.com> [tycho: add __get_seccomp_filter vs. open coding refcount_inc()] Signed-off-by: Tycho Andersen <tycho@docker.com> [kees: tweak commit log] Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-05tracing: Erase irqsoff trace with empty writeBo Yan
commit 8dd33bcb7050dd6f8c1432732f930932c9d3a33e upstream. One convenient way to erase trace is "echo > trace". However, this is currently broken if the current tracer is irqsoff tracer. This is because irqsoff tracer use max_buffer as the default trace buffer. Set the max_buffer as the one to be cleared when it's the trace buffer currently in use. Link: http://lkml.kernel.org/r/1505754215-29411-1-git-send-email-byan@nvidia.com Cc: <mingo@redhat.com> Fixes: 4acd4d00f ("tracing: give easy way to clear trace buffer") Signed-off-by: Bo Yan <byan@nvidia.com> Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-05tracing: Fix trace_pipe behavior for instance tracesTahsin Erdogan
commit 75df6e688ccd517e339a7c422ef7ad73045b18a2 upstream. When reading data from trace_pipe, tracing_wait_pipe() performs a check to see if tracing has been turned off after some data was read. Currently, this check always looks at global trace state, but it should be checking the trace instance where trace_pipe is located at. Because of this bug, cat instances/i1/trace_pipe in the following script will immediately exit instead of waiting for data: cd /sys/kernel/debug/tracing echo 0 > tracing_on mkdir -p instances/i1 echo 1 > instances/i1/tracing_on echo 1 > instances/i1/events/sched/sched_process_exec/enable cat instances/i1/trace_pipe Link: http://lkml.kernel.org/r/20170917102348.1615-1-tahsin@google.com Fixes: 10246fa35d4f ("tracing: give easy way to clear trace buffer") Signed-off-by: Tahsin Erdogan <tahsin@google.com> Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-05genirq: Make sparse_irq_lock protect what it should protectThomas Gleixner
commit 12ac1d0f6c3e95732d144ffa65c8b20fbd9aa462 upstream. for_each_active_irq() iterates the sparse irq allocation bitmap. The caller must hold sparse_irq_lock. Several code pathes expect that an active bit in the sparse bitmap also has a valid interrupt descriptor. Unfortunately that's not true. The (de)allocation is a two step process, which holds the sparse_irq_lock only across the queue/remove from the radix tree and the set/clear in the allocation bitmap. If a iteration locks sparse_irq_lock between the two steps, then it might see an active bit but the corresponding irq descriptor is NULL. If that is dereferenced unconditionally, then the kernel oopses. Of course, all iterator sites could be audited and fixed, but.... There is no reason why the sparse_irq_lock needs to be dropped between the two steps, in fact the code becomes simpler when the mutex is held across both and the semantics become more straight forward, so future problems of missing NULL pointer checks in the iteration are avoided and all existing sites are fixed in one go. Expand the lock held sections so both operations are covered and the bitmap and the radixtree are in sync. Fixes: a05a900a51c7 ("genirq: Make sparse_lock a mutex") Reported-and-tested-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-27tracing: Apply trace_clock changes to instance max bufferBaohong Liu
commit 170b3b1050e28d1ba0700e262f0899ffa4fccc52 upstream. Currently trace_clock timestamps are applied to both regular and max buffers only for global trace. For instance trace, trace_clock timestamps are applied only to regular buffer. But, regular and max buffers can be swapped, for example, following a snapshot. So, for instance trace, bad timestamps can be seen following a snapshot. Let's apply trace_clock timestamps to instance max buffer as well. Link: http://lkml.kernel.org/r/ebdb168d0be042dcdf51f81e696b17fabe3609c1.1504642143.git.tom.zanussi@linux.intel.com Fixes: 277ba0446 ("tracing: Add interface to allow multiple trace buffers") Signed-off-by: Baohong Liu <baohong.liu@intel.com> Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-27tracing: Add barrier to trace_printk() buffer nesting modificationSteven Rostedt (VMware)
commit 3d9622c12c8873911f4cc0ccdabd0362c2fca06b upstream. trace_printk() uses 4 buffers, one for each context (normal, softirq, irq and NMI), such that it does not need to worry about one context preempting the other. There's a nesting counter that gets incremented to figure out which buffer to use. If the context gets preempted by another context which calls trace_printk() it will increment the counter and use the next buffer, and restore the counter when it is finished. The problem is that gcc may optimize the modification of the buffer nesting counter and it may not be incremented in memory before the buffer is used. If this happens, and the context gets interrupted by another context, it could pick the same buffer and corrupt the one that is being used. Compiler barriers need to be added after the nesting variable is incremented and before it is decremented to prevent usage of the context buffers by more than one context at the same time. Cc: Andy Lutomirski <luto@kernel.org> Fixes: e2ace00117 ("tracing: Choose static tp_printk buffer by explicit nesting count") Hat-tip-to: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-27ftrace: Fix memleak when unregistering dynamic ops when tracing disabledSteven Rostedt (VMware)
commit edb096e00724f02db5f6ec7900f3bbd465c6c76f upstream. If function tracing is disabled by the user via the function-trace option or the proc sysctl file, and a ftrace_ops that was allocated on the heap is unregistered, then the shutdown code exits out without doing the proper clean up. This was found via kmemleak and running the ftrace selftests, as one of the tests unregisters with function tracing disabled. # cat kmemleak unreferenced object 0xffffffffa0020000 (size 4096): comm "swapper/0", pid 1, jiffies 4294668889 (age 569.209s) hex dump (first 32 bytes): 55 ff 74 24 10 55 48 89 e5 ff 74 24 18 55 48 89 U.t$.UH...t$.UH. e5 48 81 ec a8 00 00 00 48 89 44 24 50 48 89 4c .H......H.D$PH.L backtrace: [<ffffffff81d64665>] kmemleak_vmalloc+0x85/0xf0 [<ffffffff81355631>] __vmalloc_node_range+0x281/0x3e0 [<ffffffff8109697f>] module_alloc+0x4f/0x90 [<ffffffff81091170>] arch_ftrace_update_trampoline+0x160/0x420 [<ffffffff81249947>] ftrace_startup+0xe7/0x300 [<ffffffff81249bd2>] register_ftrace_function+0x72/0x90 [<ffffffff81263786>] trace_selftest_ops+0x204/0x397 [<ffffffff82bb8971>] trace_selftest_startup_function+0x394/0x624 [<ffffffff81263a75>] run_tracer_selftest+0x15c/0x1d7 [<ffffffff82bb83f1>] init_trace_selftests+0x75/0x192 [<ffffffff81002230>] do_one_initcall+0x90/0x1e2 [<ffffffff82b7d620>] kernel_init_freeable+0x350/0x3fe [<ffffffff81d61ec3>] kernel_init+0x13/0x122 [<ffffffff81d72c6a>] ret_from_fork+0x2a/0x40 [<ffffffffffffffff>] 0xffffffffffffffff Fixes: 12cce594fa ("ftrace/x86: Allow !CONFIG_PREEMPT dynamic ops to use allocated trampolines") Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-27ftrace: Fix selftest goto location on errorSteven Rostedt (VMware)
commit 46320a6acc4fb58f04bcf78c4c942cc43b20f986 upstream. In the second iteration of trace_selftest_ops(), the error goto label is wrong in the case where trace_selftest_test_global_cnt is off. In the case of error, it leaks the dynamic ops that was allocated. Fixes: 95950c2e ("ftrace: Add self-tests for multiple function trace users") Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-13locktorture: Fix potential memory leak with rw lock testYang Shi
commit f4dbba591945dc301c302672adefba9e2ec08dc5 upstream. When running locktorture module with the below commands with kmemleak enabled: $ modprobe locktorture torture_type=rw_lock_irq $ rmmod locktorture The below kmemleak got caught: root@10:~# echo scan > /sys/kernel/debug/kmemleak [ 323.197029] kmemleak: 2 new suspected memory leaks (see /sys/kernel/debug/kmemleak) root@10:~# cat /sys/kernel/debug/kmemleak unreferenced object 0xffffffc07592d500 (size 128): comm "modprobe", pid 368, jiffies 4294924118 (age 205.824s) hex dump (first 32 bytes): 00 00 00 00 00 00 00 00 c3 7b 02 00 00 00 00 00 .........{...... 00 00 00 00 00 00 00 00 d7 9b 02 00 00 00 00 00 ................ backtrace: [<ffffff80081e5a88>] create_object+0x110/0x288 [<ffffff80086c6078>] kmemleak_alloc+0x58/0xa0 [<ffffff80081d5acc>] __kmalloc+0x234/0x318 [<ffffff80006fa130>] 0xffffff80006fa130 [<ffffff8008083ae4>] do_one_initcall+0x44/0x138 [<ffffff800817e28c>] do_init_module+0x68/0x1cc [<ffffff800811c848>] load_module+0x1a68/0x22e0 [<ffffff800811d340>] SyS_finit_module+0xe0/0xf0 [<ffffff80080836f0>] el0_svc_naked+0x24/0x28 [<ffffffffffffffff>] 0xffffffffffffffff unreferenced object 0xffffffc07592d480 (size 128): comm "modprobe", pid 368, jiffies 4294924118 (age 205.824s) hex dump (first 32 bytes): 00 00 00 00 00 00 00 00 3b 6f 01 00 00 00 00 00 ........;o...... 00 00 00 00 00 00 00 00 23 6a 01 00 00 00 00 00 ........#j...... backtrace: [<ffffff80081e5a88>] create_object+0x110/0x288 [<ffffff80086c6078>] kmemleak_alloc+0x58/0xa0 [<ffffff80081d5acc>] __kmalloc+0x234/0x318 [<ffffff80006fa22c>] 0xffffff80006fa22c [<ffffff8008083ae4>] do_one_initcall+0x44/0x138 [<ffffff800817e28c>] do_init_module+0x68/0x1cc [<ffffff800811c848>] load_module+0x1a68/0x22e0 [<ffffff800811d340>] SyS_finit_module+0xe0/0xf0 [<ffffff80080836f0>] el0_svc_naked+0x24/0x28 [<ffffffffffffffff>] 0xffffffffffffffff It is because cxt.lwsa and cxt.lrsa don't get freed in module_exit, so free them in lock_torture_cleanup() and free writer_tasks if reader_tasks is failed at memory allocation. Signed-off-by: Yang Shi <yang.shi@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Cc: 石洋 <yang.s@alibaba-inc.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-07cpuset: Fix incorrect memory_pressure control file mappingWaiman Long
commit 1c08c22c874ac88799cab1f78c40f46110274915 upstream. The memory_pressure control file was incorrectly set up without a private value (0, by default). As a result, this control file was treated like memory_migrate on read. By adding back the FILE_MEMORY_PRESSURE private value, the correct memory pressure value will be returned. Signed-off-by: Waiman Long <longman@redhat.com> Signed-off-by: Tejun Heo <tj@kernel.org> Fixes: 7dbdb199d3bf ("cgroup: replace cftype->mode with CFTYPE_WORLD_WRITABLE") Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-07mm, uprobes: fix multiple free of ->uprobes_state.xol_areaEric Biggers
commit 355627f518978b5167256d27492fe0b343aaf2f2 upstream. Commit 7c051267931a ("mm, fork: make dup_mmap wait for mmap_sem for write killable") made it possible to kill a forking task while it is waiting to acquire its ->mmap_sem for write, in dup_mmap(). However, it was overlooked that this introduced an new error path before the new mm_struct's ->uprobes_state.xol_area has been set to NULL after being copied from the old mm_struct by the memcpy in dup_mm(). For a task that has previously hit a uprobe tracepoint, this resulted in the 'struct xol_area' being freed multiple times if the task was killed at just the right time while forking. Fix it by setting ->uprobes_state.xol_area to NULL in mm_init() rather than in uprobe_dup_mmap(). With CONFIG_UPROBE_EVENTS=y, the bug can be reproduced by the same C program given by commit 2b7e8665b4ff ("fork: fix incorrect fput of ->exe_file causing use-after-free"), provided that a uprobe tracepoint has been set on the fork_thread() function. For example: $ gcc reproducer.c -o reproducer -lpthread $ nm reproducer | grep fork_thread 0000000000400719 t fork_thread $ echo "p $PWD/reproducer:0x719" > /sys/kernel/debug/tracing/uprobe_events $ echo 1 > /sys/kernel/debug/tracing/events/uprobes/enable $ ./reproducer Here is the use-after-free reported by KASAN: BUG: KASAN: use-after-free in uprobe_clear_state+0x1c4/0x200 Read of size 8 at addr ffff8800320a8b88 by task reproducer/198 CPU: 1 PID: 198 Comm: reproducer Not tainted 4.13.0-rc7-00015-g36fde05f3fb5 #255 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-20170228_101828-anatol 04/01/2014 Call Trace: dump_stack+0xdb/0x185 print_address_description+0x7e/0x290 kasan_report+0x23b/0x350 __asan_report_load8_noabort+0x19/0x20 uprobe_clear_state+0x1c4/0x200 mmput+0xd6/0x360 do_exit+0x740/0x1670 do_group_exit+0x13f/0x380 get_signal+0x597/0x17d0 do_signal+0x99/0x1df0 exit_to_usermode_loop+0x166/0x1e0 syscall_return_slowpath+0x258/0x2c0 entry_SYSCALL_64_fastpath+0xbc/0xbe ... Allocated by task 199: save_stack_trace+0x1b/0x20 kasan_kmalloc+0xfc/0x180 kmem_cache_alloc_trace+0xf3/0x330 __create_xol_area+0x10f/0x780 uprobe_notify_resume+0x1674/0x2210 exit_to_usermode_loop+0x150/0x1e0 prepare_exit_to_usermode+0x14b/0x180 retint_user+0x8/0x20 Freed by task 199: save_stack_trace+0x1b/0x20 kasan_slab_free+0xa8/0x1a0 kfree+0xba/0x210 uprobe_clear_state+0x151/0x200 mmput+0xd6/0x360 copy_process.part.8+0x605f/0x65d0 _do_fork+0x1a5/0xbd0 SyS_clone+0x19/0x20 do_syscall_64+0x22f/0x660 return_from_SYSCALL_64+0x0/0x7a Note: without KASAN, you may instead see a "Bad page state" message, or simply a general protection fault. Link: http://lkml.kernel.org/r/20170830033303.17927-1-ebiggers3@gmail.com Fixes: 7c051267931a ("mm, fork: make dup_mmap wait for mmap_sem for write killable") Signed-off-by: Eric Biggers <ebiggers@google.com> Reported-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Oleg Nesterov <oleg@redhat.com> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Mark Rutland <mark.rutland@arm.com> Cc: Michal Hocko <mhocko@suse.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-02locking/spinlock/debug: Remove spinlock lockup detection codeWaiman Long
commit bc88c10d7e6900916f5e1ba3829d66a9de92b633 upstream. The current spinlock lockup detection code can sometimes produce false positives because of the unfairness of the locking algorithm itself. So the lockup detection code is now removed. Instead, we are relying on the NMI watchdog to detect potential lockup. We won't have lockup detection if the watchdog isn't running. The commented-out read-write lock lockup detection code are also removed. Signed-off-by: Waiman Long <longman@redhat.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1486583208-11038-1-git-send-email-longman@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-02gcov: support GCC 7.1Martin Liska
commit 05384213436ab690c46d9dfec706b80ef8d671ab upstream. Starting from GCC 7.1, __gcov_exit is a new symbol expected to be implemented in a profiling runtime. [akpm@linux-foundation.org: coding-style fixes] [mliska@suse.cz: v2] Link: http://lkml.kernel.org/r/e63a3c59-0149-c97e-4084-20ca8f146b26@suse.cz Link: http://lkml.kernel.org/r/8c4084fa-3885-29fe-5fc4-0d4ca199c785@suse.cz Signed-off-by: Martin Liska <mliska@suse.cz> Acked-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-30timers: Fix excessive granularity of new timers after a nohz idleNicholas Piggin
commit 2fe59f507a65dbd734b990a11ebc7488f6f87a24 upstream. When a timer base is idle, it is forwarded when a new timer is added to ensure that granularity does not become excessive. When not idle, the timer tick is expected to increment the base. However there are several problems: - If an existing timer is modified, the base is forwarded only after the index is calculated. - The base is not forwarded by add_timer_on. - There is a window after a timer is restarted from a nohz idle, after it is marked not-idle and before the timer tick on this CPU, where a timer may be added but the ancient base does not get forwarded. These result in excessive granularity (a 1 jiffy timeout can blow out to 100s of jiffies), which cause the rcu lockup detector to trigger, among other things. Fix this by keeping track of whether the timer base has been idle since it was last run or forwarded, and if so then forward it before adding a new timer. There is still a case where mod_timer optimises the case of a pending timer mod with the same expiry time, where the timer can see excessive granularity relative to the new, shorter interval. A comment is added, but it's not changed because it is an important fastpath for networking. This has been tested and found to fix the RCU softlockup messages. Testing was also done with tracing to measure requested versus achieved wakeup latencies for all non-deferrable timers in an idle system (with no lockup watchdogs running). Wakeup latency relative to absolute latency is calculated (note this suffers from round-up skew at low absolute times) and analysed: max avg std upstream 506.0 1.20 4.68 patched 2.0 1.08 0.15 The bug was noticed due to the lockup detector Kconfig changes dropping it out of people's .configs and resulting in larger base clk skew When the lockup detectors are enabled, no CPU can go idle for longer than 4 seconds, which limits the granularity errors. Sub-optimal timer behaviour is observable on a smaller scale in that case: max avg std upstream 9.0 1.05 0.19 patched 2.0 1.04 0.11 Fixes: Fixes: a683f390b93f ("timers: Forward the wheel clock whenever possible") Signed-off-by: Nicholas Piggin <npiggin@gmail.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Jonathan Cameron <Jonathan.Cameron@huawei.com> Tested-by: David Miller <davem@davemloft.net> Cc: dzickus@redhat.com Cc: sfr@canb.auug.org.au Cc: mpe@ellerman.id.au Cc: Stephen Boyd <sboyd@codeaurora.org> Cc: linuxarm@huawei.com Cc: abdhalee@linux.vnet.ibm.com Cc: John Stultz <john.stultz@linaro.org> Cc: akpm@linux-foundation.org Cc: paulmck@linux.vnet.ibm.com Cc: torvalds@linux-foundation.org Link: http://lkml.kernel.org/r/20170822084348.21436-1-npiggin@gmail.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-30perf/core: Fix group {cpu,task} validationMark Rutland
commit 64aee2a965cf2954a038b5522f11d2cd2f0f8f3e upstream. Regardless of which events form a group, it does not make sense for the events to target different tasks and/or CPUs, as this leaves the group inconsistent and impossible to schedule. The core perf code assumes that these are consistent across (successfully intialised) groups. Core perf code only verifies this when moving SW events into a HW context. Thus, we can violate this requirement for pure SW groups and pure HW groups, unless the relevant PMU driver happens to perform this verification itself. These mismatched groups subsequently wreak havoc elsewhere. For example, we handle watchpoints as SW events, and reserve watchpoint HW on a per-CPU basis at pmu::event_init() time to ensure that any event that is initialised is guaranteed to have a slot at pmu::add() time. However, the core code only checks the group leader's cpu filter (via event_filter_match()), and can thus install follower events onto CPUs violating thier (mismatched) CPU filters, potentially installing them into a CPU without sufficient reserved slots. This can be triggered with the below test case, resulting in warnings from arch backends. #define _GNU_SOURCE #include <linux/hw_breakpoint.h> #include <linux/perf_event.h> #include <sched.h> #include <stdio.h> #include <sys/prctl.h> #include <sys/syscall.h> #include <unistd.h> static int perf_event_open(struct perf_event_attr *attr, pid_t pid, int cpu, int group_fd, unsigned long flags) { return syscall(__NR_perf_event_open, attr, pid, cpu, group_fd, flags); } char watched_char; struct perf_event_attr wp_attr = { .type = PERF_TYPE_BREAKPOINT, .bp_type = HW_BREAKPOINT_RW, .bp_addr = (unsigned long)&watched_char, .bp_len = 1, .size = sizeof(wp_attr), }; int main(int argc, char *argv[]) { int leader, ret; cpu_set_t cpus; /* * Force use of CPU0 to ensure our CPU0-bound events get scheduled. */ CPU_ZERO(&cpus); CPU_SET(0, &cpus); ret = sched_setaffinity(0, sizeof(cpus), &cpus); if (ret) { printf("Unable to set cpu affinity\n"); return 1; } /* open leader event, bound to this task, CPU0 only */ leader = perf_event_open(&wp_attr, 0, 0, -1, 0); if (leader < 0) { printf("Couldn't open leader: %d\n", leader); return 1; } /* * Open a follower event that is bound to the same task, but a * different CPU. This means that the group should never be possible to * schedule. */ ret = perf_event_open(&wp_attr, 0, 1, leader, 0); if (ret < 0) { printf("Couldn't open mismatched follower: %d\n", ret); return 1; } else { printf("Opened leader/follower with mismastched CPUs\n"); } /* * Open as many independent events as we can, all bound to the same * task, CPU0 only. */ do { ret = perf_event_open(&wp_attr, 0, 0, -1, 0); } while (ret >= 0); /* * Force enable/disble all events to trigger the erronoeous * installation of the follower event. */ printf("Opened all events. Toggling..\n"); for (;;) { prctl(PR_TASK_PERF_EVENTS_DISABLE, 0, 0, 0, 0); prctl(PR_TASK_PERF_EVENTS_ENABLE, 0, 0, 0, 0); } return 0; } Fix this by validating this requirement regardless of whether we're moving events. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Zhou Chengming <zhouchengming1@huawei.com> Link: http://lkml.kernel.org/r/1498142498-15758-1-git-send-email-mark.rutland@arm.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-30ftrace: Check for null ret_stack on profile function graph entry functionSteven Rostedt (VMware)
commit a8f0f9e49956a74718874b800251455680085600 upstream. There's a small race when function graph shutsdown and the calling of the registered function graph entry callback. The callback must not reference the task's ret_stack without first checking that it is not NULL. Note, when a ret_stack is allocated for a task, it stays allocated until the task exits. The problem here, is that function_graph is shutdown, and a new task was created, which doesn't have its ret_stack allocated. But since some of the functions are still being traced, the callbacks can still be called. The normal function_graph code handles this, but starting with commit 8861dd303c ("ftrace: Access ret_stack->subtime only in the function profiler") the profiler code references the ret_stack on function entry, but doesn't check if it is NULL first. Link: https://bugzilla.kernel.org/show_bug.cgi?id=196611 Fixes: 8861dd303c ("ftrace: Access ret_stack->subtime only in the function profiler") Reported-by: lilydjwg@gmail.com Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-30tracing: Fix freeing of filter in create_filter() when set_str is falseSteven Rostedt (VMware)
commit 8b0db1a5bdfcee0dbfa89607672598ae203c9045 upstream. Performing the following task with kmemleak enabled: # cd /sys/kernel/tracing/events/irq/irq_handler_entry/ # echo 'enable_event:kmem:kmalloc:3 if irq >' > trigger # echo 'enable_event:kmem:kmalloc:3 if irq > 31' > trigger # echo scan > /sys/kernel/debug/kmemleak # cat /sys/kernel/debug/kmemleak unreferenced object 0xffff8800b9290308 (size 32): comm "bash", pid 1114, jiffies 4294848451 (age 141.139s) hex dump (first 32 bytes): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ backtrace: [<ffffffff81cef5aa>] kmemleak_alloc+0x4a/0xa0 [<ffffffff81357938>] kmem_cache_alloc_trace+0x158/0x290 [<ffffffff81261c09>] create_filter_start.constprop.28+0x99/0x940 [<ffffffff812639c9>] create_filter+0xa9/0x160 [<ffffffff81263bdc>] create_event_filter+0xc/0x10 [<ffffffff812655e5>] set_trigger_filter+0xe5/0x210 [<ffffffff812660c4>] event_enable_trigger_func+0x324/0x490 [<ffffffff812652e2>] event_trigger_write+0x1a2/0x260 [<ffffffff8138cf87>] __vfs_write+0xd7/0x380 [<ffffffff8138f421>] vfs_write+0x101/0x260 [<ffffffff8139187b>] SyS_write+0xab/0x130 [<ffffffff81cfd501>] entry_SYSCALL_64_fastpath+0x1f/0xbe [<ffffffffffffffff>] 0xffffffffffffffff The function create_filter() is passed a 'filterp' pointer that gets allocated, and if "set_str" is true, it is up to the caller to free it, even on error. The problem is that the pointer is not freed by create_filter() when set_str is false. This is a bug, and it is not up to the caller to free the filter on error if it doesn't care about the string. Link: http://lkml.kernel.org/r/1502705898-27571-2-git-send-email-chuhu@redhat.com Fixes: 38b78eb85 ("tracing: Factorize filter creation") Reported-by: Chunyu Hu <chuhu@redhat.com> Tested-by: Chunyu Hu <chuhu@redhat.com> Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-30tracing: Fix kmemleak in tracing_map_array_free()Chunyu Hu
commit 475bb3c69ab05df2a6ecef6acc2393703d134180 upstream. kmemleak reported the below leak when I was doing clear of the hist trigger. With this patch, the kmeamleak is gone. unreferenced object 0xffff94322b63d760 (size 32): comm "bash", pid 1522, jiffies 4403687962 (age 2442.311s) hex dump (first 32 bytes): 00 01 00 00 04 00 00 00 08 00 00 00 ff 00 00 00 ................ 10 00 00 00 00 00 00 00 80 a8 7a f2 31 94 ff ff ..........z.1... backtrace: [<ffffffff9e96c27a>] kmemleak_alloc+0x4a/0xa0 [<ffffffff9e424cba>] kmem_cache_alloc_trace+0xca/0x1d0 [<ffffffff9e377736>] tracing_map_array_alloc+0x26/0x140 [<ffffffff9e261be0>] kretprobe_trampoline+0x0/0x50 [<ffffffff9e38b935>] create_hist_data+0x535/0x750 [<ffffffff9e38bd47>] event_hist_trigger_func+0x1f7/0x420 [<ffffffff9e38893d>] event_trigger_write+0xfd/0x1a0 [<ffffffff9e44dfc7>] __vfs_write+0x37/0x170 [<ffffffff9e44f552>] vfs_write+0xb2/0x1b0 [<ffffffff9e450b85>] SyS_write+0x55/0xc0 [<ffffffff9e203857>] do_syscall_64+0x67/0x150 [<ffffffff9e977ce7>] return_from_SYSCALL_64+0x0/0x6a [<ffffffffffffffff>] 0xffffffffffffffff unreferenced object 0xffff9431f27aa880 (size 128): comm "bash", pid 1522, jiffies 4403687962 (age 2442.311s) hex dump (first 32 bytes): 00 00 8c 2a 32 94 ff ff 00 f0 8b 2a 32 94 ff ff ...*2......*2... 00 e0 8b 2a 32 94 ff ff 00 d0 8b 2a 32 94 ff ff ...*2......*2... backtrace: [<ffffffff9e96c27a>] kmemleak_alloc+0x4a/0xa0 [<ffffffff9e425348>] __kmalloc+0xe8/0x220 [<ffffffff9e3777c1>] tracing_map_array_alloc+0xb1/0x140 [<ffffffff9e261be0>] kretprobe_trampoline+0x0/0x50 [<ffffffff9e38b935>] create_hist_data+0x535/0x750 [<ffffffff9e38bd47>] event_hist_trigger_func+0x1f7/0x420 [<ffffffff9e38893d>] event_trigger_write+0xfd/0x1a0 [<ffffffff9e44dfc7>] __vfs_write+0x37/0x170 [<ffffffff9e44f552>] vfs_write+0xb2/0x1b0 [<ffffffff9e450b85>] SyS_write+0x55/0xc0 [<ffffffff9e203857>] do_syscall_64+0x67/0x150 [<ffffffff9e977ce7>] return_from_SYSCALL_64+0x0/0x6a [<ffffffffffffffff>] 0xffffffffffffffff Link: http://lkml.kernel.org/r/1502705898-27571-1-git-send-email-chuhu@redhat.com Fixes: 08d43a5fa063 ("tracing: Add lock-free tracing_map") Signed-off-by: Chunyu Hu <chuhu@redhat.com> Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-30tracing: Call clear_boot_tracer() at lateinit_syncSteven Rostedt (VMware)
commit 4bb0f0e73c8c30917d169c4a0f1ac083690c545b upstream. The clear_boot_tracer function is used to reset the default_bootup_tracer string to prevent it from being accessed after boot, as it originally points to init data. But since clear_boot_tracer() is called via the init_lateinit() call, it races with the initcall for registering the hwlat tracer. If someone adds "ftrace=hwlat" to the kernel command line, depending on how the linker sets up the text, the saved command line may be cleared, and the hwlat tracer never is initialized. Simply have the clear_boot_tracer() be called by initcall_lateinit_sync() as that's for tasks to be called after lateinit. Link: https://bugzilla.kernel.org/show_bug.cgi?id=196551 Fixes: e7c15cd8a ("tracing: Added hardware latency tracer") Reported-by: Zamir SUN <sztsian@gmail.com> Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-30fork: fix incorrect fput of ->exe_file causing use-after-freeEric Biggers
commit 2b7e8665b4ff51c034c55df3cff76518d1a9ee3a upstream. Commit 7c051267931a ("mm, fork: make dup_mmap wait for mmap_sem for write killable") made it possible to kill a forking task while it is waiting to acquire its ->mmap_sem for write, in dup_mmap(). However, it was overlooked that this introduced an new error path before a reference is taken on the mm_struct's ->exe_file. Since the ->exe_file of the new mm_struct was already set to the old ->exe_file by the memcpy() in dup_mm(), it was possible for the mmput() in the error path of dup_mm() to drop a reference to ->exe_file which was never taken. This caused the struct file to later be freed prematurely. Fix it by updating mm_init() to NULL out the ->exe_file, in the same place it clears other things like the list of mmaps. This bug was found by syzkaller. It can be reproduced using the following C program: #define _GNU_SOURCE #include <pthread.h> #include <stdlib.h> #include <sys/mman.h> #include <sys/syscall.h> #include <sys/wait.h> #include <unistd.h> static void *mmap_thread(void *_arg) { for (;;) { mmap(NULL, 0x1000000, PROT_READ, MAP_POPULATE|MAP_ANONYMOUS|MAP_PRIVATE, -1, 0); } } static void *fork_thread(void *_arg) { usleep(rand() % 10000); fork(); } int main(void) { fork(); fork(); fork(); for (;;) { if (fork() == 0) { pthread_t t; pthread_create(&t, NULL, mmap_thread, NULL); pthread_create(&t, NULL, fork_thread, NULL); usleep(rand() % 10000); syscall(__NR_exit_group, 0); } wait(NULL); } } No special kernel config options are needed. It usually causes a NULL pointer dereference in __remove_shared_vm_struct() during exit, or in dup_mmap() (which is usually inlined into copy_process()) during fork. Both are due to a vm_area_struct's ->vm_file being used after it's already been freed. Google Bug Id: 64772007 Link: http://lkml.kernel.org/r/20170823211408.31198-1-ebiggers3@gmail.com Fixes: 7c051267931a ("mm, fork: make dup_mmap wait for mmap_sem for write killable") Signed-off-by: Eric Biggers <ebiggers@google.com> Tested-by: Mark Rutland <mark.rutland@arm.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-30bpf/verifier: fix min/max handling in BPF_SUBEdward Cree
[ Upstream commit 9305706c2e808ae59f1eb201867f82f1ddf6d7a6 ] We have to subtract the src max from the dst min, and vice-versa, since (e.g.) the smallest result comes from the largest subtrahend. Fixes: 484611357c19 ("bpf: allow access into map value arrays") Signed-off-by: Edward Cree <ecree@solarflare.com> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-30bpf: fix mixed signed/unsigned derived min/max value boundsDaniel Borkmann
[ Upstream commit 4cabc5b186b5427b9ee5a7495172542af105f02b ] Edward reported that there's an issue in min/max value bounds tracking when signed and unsigned compares both provide hints on limits when having unknown variables. E.g. a program such as the following should have been rejected: 0: (7a) *(u64 *)(r10 -8) = 0 1: (bf) r2 = r10 2: (07) r2 += -8 3: (18) r1 = 0xffff8a94cda93400 5: (85) call bpf_map_lookup_elem#1 6: (15) if r0 == 0x0 goto pc+7 R0=map_value(ks=8,vs=8,id=0),min_value=0,max_value=0 R10=fp 7: (7a) *(u64 *)(r10 -16) = -8 8: (79) r1 = *(u64 *)(r10 -16) 9: (b7) r2 = -1 10: (2d) if r1 > r2 goto pc+3 R0=map_value(ks=8,vs=8,id=0),min_value=0,max_value=0 R1=inv,min_value=0 R2=imm-1,max_value=18446744073709551615,min_align=1 R10=fp 11: (65) if r1 s> 0x1 goto pc+2 R0=map_value(ks=8,vs=8,id=0),min_value=0,max_value=0 R1=inv,min_value=0,max_value=1 R2=imm-1,max_value=18446744073709551615,min_align=1 R10=fp 12: (0f) r0 += r1 13: (72) *(u8 *)(r0 +0) = 0 R0=map_value_adj(ks=8,vs=8,id=0),min_value=0,max_value=1 R1=inv,min_value=0,max_value=1 R2=imm-1,max_value=18446744073709551615,min_align=1 R10=fp 14: (b7) r0 = 0 15: (95) exit What happens is that in the first part ... 8: (79) r1 = *(u64 *)(r10 -16) 9: (b7) r2 = -1 10: (2d) if r1 > r2 goto pc+3 ... r1 carries an unsigned value, and is compared as unsigned against a register carrying an immediate. Verifier deduces in reg_set_min_max() that since the compare is unsigned and operation is greater than (>), that in the fall-through/false case, r1's minimum bound must be 0 and maximum bound must be r2. Latter is larger than the bound and thus max value is reset back to being 'invalid' aka BPF_REGISTER_MAX_RANGE. Thus, r1 state is now 'R1=inv,min_value=0'. The subsequent test ... 11: (65) if r1 s> 0x1 goto pc+2 ... is a signed compare of r1 with immediate value 1. Here, verifier deduces in reg_set_min_max() that since the compare is signed this time and operation is greater than (>), that in the fall-through/false case, we can deduce that r1's maximum bound must be 1, meaning with prior test, we result in r1 having the following state: R1=inv,min_value=0,max_value=1. Given that the actual value this holds is -8, the bounds are wrongly deduced. When this is being added to r0 which holds the map_value(_adj) type, then subsequent store access in above case will go through check_mem_access() which invokes check_map_access_adj(), that will then probe whether the map memory is in bounds based on the min_value and max_value as well as access size since the actual unknown value is min_value <= x <= max_value; commit fce366a9dd0d ("bpf, verifier: fix alu ops against map_value{, _adj} register types") provides some more explanation on the semantics. It's worth to note in this context that in the current code, min_value and max_value tracking are used for two things, i) dynamic map value access via check_map_access_adj() and since commit 06c1c049721a ("bpf: allow helpers access to variable memory") ii) also enforced at check_helper_mem_access() when passing a memory address (pointer to packet, map value, stack) and length pair to a helper and the length in this case is an unknown value defining an access range through min_value/max_value in that case. The min_value/max_value tracking is /not/ used in the direct packet access case to track ranges. However, the issue also affects case ii), for example, the following crafted program based on the same principle must be rejected as well: 0: (b7) r2 = 0 1: (bf) r3 = r10 2: (07) r3 += -512 3: (7a) *(u64 *)(r10 -16) = -8 4: (79) r4 = *(u64 *)(r10 -16) 5: (b7) r6 = -1 6: (2d) if r4 > r6 goto pc+5 R1=ctx R2=imm0,min_value=0,max_value=0,min_align=2147483648 R3=fp-512 R4=inv,min_value=0 R6=imm-1,max_value=18446744073709551615,min_align=1 R10=fp 7: (65) if r4 s> 0x1 goto pc+4 R1=ctx R2=imm0,min_value=0,max_value=0,min_align=2147483648 R3=fp-512 R4=inv,min_value=0,max_value=1 R6=imm-1,max_value=18446744073709551615,min_align=1 R10=fp 8: (07) r4 += 1 9: (b7) r5 = 0 10: (6a) *(u16 *)(r10 -512) = 0 11: (85) call bpf_skb_load_bytes#26 12: (b7) r0 = 0 13: (95) exit Meaning, while we initialize the max_value stack slot that the verifier thinks we access in the [1,2] range, in reality we pass -7 as length which is interpreted as u32 in the helper. Thus, this issue is relevant also for the case of helper ranges. Resetting both bounds in check_reg_overflow() in case only one of them exceeds limits is also not enough as similar test can be created that uses values which are within range, thus also here learned min value in r1 is incorrect when mixed with later signed test to create a range: 0: (7a) *(u64 *)(r10 -8) = 0 1: (bf) r2 = r10 2: (07) r2 += -8 3: (18) r1 = 0xffff880ad081fa00 5: (85) call bpf_map_lookup_elem#1 6: (15) if r0 == 0x0 goto pc+7 R0=map_value(ks=8,vs=8,id=0),min_value=0,max_value=0 R10=fp 7: (7a) *(u64 *)(r10 -16) = -8 8: (79) r1 = *(u64 *)(r10 -16) 9: (b7) r2 = 2 10: (3d) if r2 >= r1 goto pc+3 R0=map_value(ks=8,vs=8,id=0),min_value=0,max_value=0 R1=inv,min_value=3 R2=imm2,min_value=2,max_value=2,min_align=2 R10=fp 11: (65) if r1 s> 0x4 goto pc+2 R0=map_value(ks=8,vs=8,id=0),min_value=0,max_value=0 R1=inv,min_value=3,max_value=4 R2=imm2,min_value=2,max_value=2,min_align=2 R10=fp 12: (0f) r0 += r1 13: (72) *(u8 *)(r0 +0) = 0 R0=map_value_adj(ks=8,vs=8,id=0),min_value=3,max_value=4 R1=inv,min_value=3,max_value=4 R2=imm2,min_value=2,max_value=2,min_align=2 R10=fp 14: (b7) r0 = 0 15: (95) exit This leaves us with two options for fixing this: i) to invalidate all prior learned information once we switch signed context, ii) to track min/max signed and unsigned boundaries separately as done in [0]. (Given latter introduces major changes throughout the whole verifier, it's rather net-next material, thus this patch follows option i), meaning we can derive bounds either from only signed tests or only unsigned tests.) There is still the case of adjust_reg_min_max_vals(), where we adjust bounds on ALU operations, meaning programs like the following where boundaries on the reg get mixed in context later on when bounds are merged on the dst reg must get rejected, too: 0: (7a) *(u64 *)(r10 -8) = 0 1: (bf) r2 = r10 2: (07) r2 += -8 3: (18) r1 = 0xffff89b2bf87ce00 5: (85) call bpf_map_lookup_elem#1 6: (15) if r0 == 0x0 goto pc+6 R0=map_value(ks=8,vs=8,id=0),min_value=0,max_value=0 R10=fp 7: (7a) *(u64 *)(r10 -16) = -8 8: (79) r1 = *(u64 *)(r10 -16) 9: (b7) r2 = 2 10: (3d) if r2 >= r1 goto pc+2 R0=map_value(ks=8,vs=8,id=0),min_value=0,max_value=0 R1=inv,min_value=3 R2=imm2,min_value=2,max_value=2,min_align=2 R10=fp 11: (b7) r7 = 1 12: (65) if r7 s> 0x0 goto pc+2 R0=map_value(ks=8,vs=8,id=0),min_value=0,max_value=0 R1=inv,min_value=3 R2=imm2,min_value=2,max_value=2,min_align=2 R7=imm1,max_value=0 R10=fp 13: (b7) r0 = 0 14: (95) exit from 12 to 15: R0=map_value(ks=8,vs=8,id=0),min_value=0,max_value=0 R1=inv,min_value=3 R2=imm2,min_value=2,max_value=2,min_align=2 R7=imm1,min_value=1 R10=fp 15: (0f) r7 += r1 16: (65) if r7 s> 0x4 goto pc+2 R0=map_value(ks=8,vs=8,id=0),min_value=0,max_value=0 R1=inv,min_value=3 R2=imm2,min_value=2,max_value=2,min_align=2 R7=inv,min_value=4,max_value=4 R10=fp 17: (0f) r0 += r7 18: (72) *(u8 *)(r0 +0) = 0 R0=map_value_adj(ks=8,vs=8,id=0),min_value=4,max_value=4 R1=inv,min_value=3 R2=imm2,min_value=2,max_value=2,min_align=2 R7=inv,min_value=4,max_value=4 R10=fp 19: (b7) r0 = 0 20: (95) exit Meaning, in adjust_reg_min_max_vals() we must also reset range values on the dst when src/dst registers have mixed signed/ unsigned derived min/max value bounds with one unbounded value as otherwise they can be added together deducing false boundaries. Once both boundaries are established from either ALU ops or compare operations w/o mixing signed/unsigned insns, then they can safely be added to other regs also having both boundaries established. Adding regs with one unbounded side to a map value where the bounded side has been learned w/o mixing ops is possible, but the resulting map value won't recover from that, meaning such op is considered invalid on the time of actual access. Invalid bounds are set on the dst reg in case i) src reg, or ii) in case dst reg already had them. The only way to recover would be to perform i) ALU ops but only 'add' is allowed on map value types or ii) comparisons, but these are disallowed on pointers in case they span a range. This is fine as only BPF_JEQ and BPF_JNE may be performed on PTR_TO_MAP_VALUE_OR_NULL registers which potentially turn them into PTR_TO_MAP_VALUE type depending on the branch, so only here min/max value cannot be invalidated for them. In terms of state pruning, value_from_signed is considered as well in states_equal() when dealing with adjusted map values. With regards to breaking existing programs, there is a small risk, but use-cases are rather quite narrow where this could occur and mixing compares probably unlikely. Joint work with Josef and Edward. [0] https://lists.iovisor.org/pipermail/iovisor-dev/2017-June/000822.html Fixes: 484611357c19 ("bpf: allow access into map value arrays") Reported-by: Edward Cree <ecree@solarflare.com> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: Edward Cree <ecree@solarflare.com> Signed-off-by: Josef Bacik <jbacik@fb.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-30bpf, verifier: fix alu ops against map_value{, _adj} register typesDaniel Borkmann
[ Upstream commit fce366a9dd0ddc47e7ce05611c266e8574a45116 ] While looking into map_value_adj, I noticed that alu operations directly on the map_value() resp. map_value_adj() register (any alu operation on a map_value() register will turn it into a map_value_adj() typed register) are not sufficiently protected against some of the operations. Two non-exhaustive examples are provided that the verifier needs to reject: i) BPF_AND on r0 (map_value_adj): 0: (bf) r2 = r10 1: (07) r2 += -8 2: (7a) *(u64 *)(r2 +0) = 0 3: (18) r1 = 0xbf842a00 5: (85) call bpf_map_lookup_elem#1 6: (15) if r0 == 0x0 goto pc+2 R0=map_value(ks=8,vs=48,id=0),min_value=0,max_value=0 R10=fp 7: (57) r0 &= 8 8: (7a) *(u64 *)(r0 +0) = 22 R0=map_value_adj(ks=8,vs=48,id=0),min_value=0,max_value=8 R10=fp 9: (95) exit from 6 to 9: R0=inv,min_value=0,max_value=0 R10=fp 9: (95) exit processed 10 insns ii) BPF_ADD in 32 bit mode on r0 (map_value_adj): 0: (bf) r2 = r10 1: (07) r2 += -8 2: (7a) *(u64 *)(r2 +0) = 0 3: (18) r1 = 0xc24eee00 5: (85) call bpf_map_lookup_elem#1 6: (15) if r0 == 0x0 goto pc+2 R0=map_value(ks=8,vs=48,id=0),min_value=0,max_value=0 R10=fp 7: (04) (u32) r0 += (u32) 0 8: (7a) *(u64 *)(r0 +0) = 22 R0=map_value_adj(ks=8,vs=48,id=0),min_value=0,max_value=0 R10=fp 9: (95) exit from 6 to 9: R0=inv,min_value=0,max_value=0 R10=fp 9: (95) exit processed 10 insns Issue is, while min_value / max_value boundaries for the access are adjusted appropriately, we change the pointer value in a way that cannot be sufficiently tracked anymore from its origin. Operations like BPF_{AND,OR,DIV,MUL,etc} on a destination register that is PTR_TO_MAP_VALUE{,_ADJ} was probably unintended, in fact, all the test cases coming with 484611357c19 ("bpf: allow access into map value arrays") perform BPF_ADD only on the destination register that is PTR_TO_MAP_VALUE_ADJ. Only for UNKNOWN_VALUE register types such operations make sense, f.e. with unknown memory content fetched initially from a constant offset from the map value memory into a register. That register is then later tested against lower / upper bounds, so that the verifier can then do the tracking of min_value / max_value, and properly check once that UNKNOWN_VALUE register is added to the destination register with type PTR_TO_MAP_VALUE{,_ADJ}. This is also what the original use-case is solving. Note, tracking on what is being added is done through adjust_reg_min_max_vals() and later access to the map value enforced with these boundaries and the given offset from the insn through check_map_access_adj(). Tests will fail for non-root environment due to prohibited pointer arithmetic, in particular in check_alu_op(), we bail out on the is_pointer_value() check on the dst_reg (which is false in root case as we allow for pointer arithmetic via env->allow_ptr_leaks). Similarly to PTR_TO_PACKET, one way to fix it is to restrict the allowed operations on PTR_TO_MAP_VALUE{,_ADJ} registers to 64 bit mode BPF_ADD. The test_verifier suite runs fine after the patch and it also rejects mentioned test cases. Fixes: 484611357c19 ("bpf: allow access into map value arrays") Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Reviewed-by: Josef Bacik <jbacik@fb.com> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-30bpf: adjust verifier heuristicsDaniel Borkmann
[ Upstream commit 3c2ce60bdd3d57051bf85615deec04a694473840 ] Current limits with regards to processing program paths do not really reflect today's needs anymore due to programs becoming more complex and verifier smarter, keeping track of more data such as const ALU operations, alignment tracking, spilling of PTR_TO_MAP_VALUE_ADJ registers, and other features allowing for smarter matching of what LLVM generates. This also comes with the side-effect that we result in fewer opportunities to prune search states and thus often need to do more work to prove safety than in the past due to different register states and stack layout where we mismatch. Generally, it's quite hard to determine what caused a sudden increase in complexity, it could be caused by something as trivial as a single branch somewhere at the beginning of the program where LLVM assigned a stack slot that is marked differently throughout other branches and thus causing a mismatch, where verifier then needs to prove safety for the whole rest of the program. Subsequently, programs with even less than half the insn size limit can get rejected. We noticed that while some programs load fine under pre 4.11, they get rejected due to hitting limits on more recent kernels. We saw that in the vast majority of cases (90+%) pruning failed due to register mismatches. In case of stack mismatches, majority of cases failed due to different stack slot types (invalid, spill, misc) rather than differences in spilled registers. This patch makes pruning more aggressive by also adding markers that sit at conditional jumps as well. Currently, we only mark jump targets for pruning. For example in direct packet access, these are usually error paths where we bail out. We found that adding these markers, it can reduce number of processed insns by up to 30%. Another option is to ignore reg->id in probing PTR_TO_MAP_VALUE_OR_NULL registers, which can help pruning slightly as well by up to 7% observed complexity reduction as stand-alone. Meaning, if a previous path with register type PTR_TO_MAP_VALUE_OR_NULL for map X was found to be safe, then in the current state a PTR_TO_MAP_VALUE_OR_NULL register for the same map X must be safe as well. Last but not least the patch also adds a scheduling point and bumps the current limit for instructions to be processed to a more adequate value. Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-30bpf, verifier: add additional patterns to evaluate_reg_imm_aluJohn Fastabend
[ Upstream commit 43188702b3d98d2792969a3377a30957f05695e6 ] Currently the verifier does not track imm across alu operations when the source register is of unknown type. This adds additional pattern matching to catch this and track imm. We've seen LLVM generating this pattern while working on cilium. Signed-off-by: John Fastabend <john.fastabend@gmail.com> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-30bpf: fix bpf_trace_printk on 32 bit archsDaniel Borkmann
[ Upstream commit 88a5c690b66110ad255380d8f629c629cf6ca559 ] James reported that on MIPS32 bpf_trace_printk() is currently broken while MIPS64 works fine: bpf_trace_printk() uses conditional operators to attempt to pass different types to __trace_printk() depending on the format operators. This doesn't work as intended on 32-bit architectures where u32 and long are passed differently to u64, since the result of C conditional operators follows the "usual arithmetic conversions" rules, such that the values passed to __trace_printk() will always be u64 [causing issues later in the va_list handling for vscnprintf()]. For example the samples/bpf/tracex5 test printed lines like below on MIPS32, where the fd and buf have come from the u64 fd argument, and the size from the buf argument: [...] 1180.941542: 0x00000001: write(fd=1, buf= (null), size=6258688) Instead of this: [...] 1625.616026: 0x00000001: write(fd=1, buf=009e4000, size=512) One way to get it working is to expand various combinations of argument types into 8 different combinations for 32 bit and 64 bit kernels. Fix tested by James on MIPS32 and MIPS64 as well that it resolves the issue. Fixes: 9c959c863f82 ("tracing: Allow BPF programs to call bpf_trace_printk()") Reported-by: James Hogan <james.hogan@imgtec.com> Tested-by: James Hogan <james.hogan@imgtec.com> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-24pids: make task_tgid_nr_ns() safeOleg Nesterov
commit dd1c1f2f2028a7b851f701fc6a8ebe39dcb95e7c upstream. This was reported many times, and this was even mentioned in commit 52ee2dfdd4f5 ("pids: refactor vnr/nr_ns helpers to make them safe") but somehow nobody bothered to fix the obvious problem: task_tgid_nr_ns() is not safe because task->group_leader points to nowhere after the exiting task passes exit_notify(), rcu_read_lock() can not help. We really need to change __unhash_process() to nullify group_leader, parent, and real_parent, but this needs some cleanups. Until then we can turn task_tgid_nr_ns() into another user of __task_pid_nr_ns() and fix the problem. Reported-by: Troy Kensinger <tkensinger@google.com> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-24genirq/ipi: Fixup checks against nr_cpu_idsAlexey Dobriyan
commit 8fbbe2d7cc478d1544f41f2271787c993c23a4f6 upstream. Valid CPU ids are [0, nr_cpu_ids-1] inclusive. Fixes: 3b8e29a82dd1 ("genirq: Implement ipi_send_mask/single()") Fixes: f9bce791ae2a ("genirq: Add a new function to get IPI reverse mapping") Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20170819095751.GB27864@avx2 Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-24genirq: Restore trigger settings in irq_modify_status()Marc Zyngier
commit e8f241893dfbbebe2813c01eac54f263e6a5e59c upstream. irq_modify_status starts by clearing the trigger settings from irq_data before applying the new settings, but doesn't restore them, leaving them to IRQ_TYPE_NONE. That's pretty confusing to the potential request_irq() that could follow. Instead, snapshot the settings before clearing them, and restore them if the irq_modify_status() invocation was not changing the trigger. Fixes: 1e2a7d78499e ("irqdomain: Don't set type when mapping an IRQ") Reported-and-tested-by: jeffy <jeffy.chen@rock-chips.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Jon Hunter <jonathanh@nvidia.com> Link: http://lkml.kernel.org/r/20170818095345.12378-1-marc.zyngier@arm.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-24audit: Fix use after free in audit_remove_watch_rule()Jan Kara
commit d76036ab47eafa6ce52b69482e91ca3ba337d6d6 upstream. audit_remove_watch_rule() drops watch's reference to parent but then continues to work with it. That is not safe as parent can get freed once we drop our reference. The following is a trivial reproducer: mount -o loop image /mnt touch /mnt/file auditctl -w /mnt/file -p wax umount /mnt auditctl -D <crash in fsnotify_destroy_mark()> Grab our own reference in audit_remove_watch_rule() earlier to make sure mark does not get freed under us. Reported-by: Tony Jones <tonyj@suse.de> Signed-off-by: Jan Kara <jack@suse.cz> Tested-by: Tony Jones <tonyj@suse.de> Signed-off-by: Paul Moore <paul@paul-moore.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-16futex: Remove unnecessary warning from get_futex_keyMel Gorman
commit 48fb6f4db940e92cfb16cd878cddd59ea6120d06 upstream. Commit 65d8fc777f6d ("futex: Remove requirement for lock_page() in get_futex_key()") removed an unnecessary lock_page() with the side-effect that page->mapping needed to be treated very carefully. Two defensive warnings were added in case any assumption was missed and the first warning assumed a correct application would not alter a mapping backing a futex key. Since merging, it has not triggered for any unexpected case but Mark Rutland reported the following bug triggering due to the first warning. kernel BUG at kernel/futex.c:679! Internal error: Oops - BUG: 0 [#1] PREEMPT SMP Modules linked in: CPU: 0 PID: 3695 Comm: syz-executor1 Not tainted 4.13.0-rc3-00020-g307fec773ba3 #3 Hardware name: linux,dummy-virt (DT) task: ffff80001e271780 task.stack: ffff000010908000 PC is at get_futex_key+0x6a4/0xcf0 kernel/futex.c:679 LR is at get_futex_key+0x6a4/0xcf0 kernel/futex.c:679 pc : [<ffff00000821ac14>] lr : [<ffff00000821ac14>] pstate: 80000145 The fact that it's a bug instead of a warning was due to an unrelated arm64 problem, but the warning itself triggered because the underlying mapping changed. This is an application issue but from a kernel perspective it's a recoverable situation and the warning is unnecessary so this patch removes the warning. The warning may potentially be triggered with the following test program from Mark although it may be necessary to adjust NR_FUTEX_THREADS to be a value smaller than the number of CPUs in the system. #include <linux/futex.h> #include <pthread.h> #include <stdio.h> #include <stdlib.h> #include <sys/mman.h> #include <sys/syscall.h> #include <sys/time.h> #include <unistd.h> #define NR_FUTEX_THREADS 16 pthread_t threads[NR_FUTEX_THREADS]; void *mem; #define MEM_PROT (PROT_READ | PROT_WRITE) #define MEM_SIZE 65536 static int futex_wrapper(int *uaddr, int op, int val, const struct timespec *timeout, int *uaddr2, int val3) { syscall(SYS_futex, uaddr, op, val, timeout, uaddr2, val3); } void *poll_futex(void *unused) { for (;;) { futex_wrapper(mem, FUTEX_CMP_REQUEUE_PI, 1, NULL, mem + 4, 1); } } int main(int argc, char *argv[]) { int i; mem = mmap(NULL, MEM_SIZE, MEM_PROT, MAP_SHARED | MAP_ANONYMOUS, -1, 0); printf("Mapping @ %p\n", mem); printf("Creating futex threads...\n"); for (i = 0; i < NR_FUTEX_THREADS; i++) pthread_create(&threads[i], NULL, poll_futex, NULL); printf("Flipping mapping...\n"); for (;;) { mmap(mem, MEM_SIZE, MEM_PROT, MAP_FIXED | MAP_SHARED | MAP_ANONYMOUS, -1, 0); } return 0; } Reported-and-tested-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-11workqueue: implicit ordered attribute should be overridableTejun Heo
commit 0a94efb5acbb6980d7c9ab604372d93cd507e4d8 upstream. 5c0338c68706 ("workqueue: restore WQ_UNBOUND/max_active==1 to be ordered") automatically enabled ordered attribute for unbound workqueues w/ max_active == 1. Because ordered workqueues reject max_active and some attribute changes, this implicit ordered mode broke cases where the user creates an unbound workqueue w/ max_active == 1 and later explicitly changes the related attributes. This patch distinguishes explicit and implicit ordered setting and overrides from attribute changes if implict. Signed-off-by: Tejun Heo <tj@kernel.org> Fixes: 5c0338c68706 ("workqueue: restore WQ_UNBOUND/max_active==1 to be ordered") Cc: Holger Hoffstätte <holger@applied-asynchrony.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-11signal: protect SIGNAL_UNKILLABLE from unintentional clearing.Jamie Iles
[ Upstream commit 2d39b3cd34e6d323720d4c61bd714f5ae202c022 ] Since commit 00cd5c37afd5 ("ptrace: permit ptracing of /sbin/init") we can now trace init processes. init is initially protected with SIGNAL_UNKILLABLE which will prevent fatal signals such as SIGSTOP, but there are a number of paths during tracing where SIGNAL_UNKILLABLE can be implicitly cleared. This can result in init becoming stoppable/killable after tracing. For example, running: while true; do kill -STOP 1; done & strace -p 1 and then stopping strace and the kill loop will result in init being left in state TASK_STOPPED. Sending SIGCONT to init will resume it, but init will now respond to future SIGSTOP signals rather than ignoring them. Make sure that when setting SIGNAL_STOP_CONTINUED/SIGNAL_STOP_STOPPED that we don't clear SIGNAL_UNKILLABLE. Link: http://lkml.kernel.org/r/20170104122017.25047-1-jamie.iles@oracle.com Signed-off-by: Jamie Iles <jamie.iles@oracle.com> Acked-by: Oleg Nesterov <oleg@redhat.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Ingo Molnar <mingo@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-11timers: Fix overflow in get_next_timer_interruptMatija Glavinic Pecotic
commit 34f41c0316ed52b0b44542491d89278efdaa70e4 upstream. For e.g. HZ=100, timer being 430 jiffies in the future, and 32 bit unsigned int, there is an overflow on unsigned int right-hand side of the expression which results with wrong values being returned. Type cast the multiplier to 64bit to avoid that issue. Fixes: 46c8f0b077a8 ("timers: Fix get_next_timer_interrupt() computation") Signed-off-by: Matija Glavinic Pecotic <matija.glavinic-pecotic.ext@nokia.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Alexander Sverdlin <alexander.sverdlin@nokia.com> Cc: khilman@baylibre.com Cc: akpm@linux-foundation.org Link: http://lkml.kernel.org/r/a7900f04-2a21-c9fd-67be-ab334d459ee5@nokia.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-11cpuset: fix a deadlock due to incomplete patching of cpusets_enabled()Dima Zavin
commit 89affbf5d9ebb15c6460596822e8857ea2f9e735 upstream. In codepaths that use the begin/retry interface for reading mems_allowed_seq with irqs disabled, there exists a race condition that stalls the patch process after only modifying a subset of the static_branch call sites. This problem manifested itself as a deadlock in the slub allocator, inside get_any_partial. The loop reads mems_allowed_seq value (via read_mems_allowed_begin), performs the defrag operation, and then verifies the consistency of mem_allowed via the read_mems_allowed_retry and the cookie returned by xxx_begin. The issue here is that both begin and retry first check if cpusets are enabled via cpusets_enabled() static branch. This branch can be rewritted dynamically (via cpuset_inc) if a new cpuset is created. The x86 jump label code fully synchronizes across all CPUs for every entry it rewrites. If it rewrites only one of the callsites (specifically the one in read_mems_allowed_retry) and then waits for the smp_call_function(do_sync_core) to complete while a CPU is inside the begin/retry section with IRQs off and the mems_allowed value is changed, we can hang. This is because begin() will always return 0 (since it wasn't patched yet) while retry() will test the 0 against the actual value of the seq counter. The fix is to use two different static keys: one for begin (pre_enable_key) and one for retry (enable_key). In cpuset_inc(), we first bump the pre_enable key to ensure that cpuset_mems_allowed_begin() always return a valid seqcount if are enabling cpusets. Similarly, when disabling cpusets via cpuset_dec(), we first ensure that callers of cpuset_mems_allowed_retry() will start ignoring the seqcount value before we let cpuset_mems_allowed_begin() return 0. The relevant stack traces of the two stuck threads: CPU: 1 PID: 1415 Comm: mkdir Tainted: G L 4.9.36-00104-g540c51286237 #4 Hardware name: Default string Default string/Hardware, BIOS 4.29.1-20170526215256 05/26/2017 task: ffff8817f9c28000 task.stack: ffffc9000ffa4000 RIP: smp_call_function_many+0x1f9/0x260 Call Trace: smp_call_function+0x3b/0x70 on_each_cpu+0x2f/0x90 text_poke_bp+0x87/0xd0 arch_jump_label_transform+0x93/0x100 __jump_label_update+0x77/0x90 jump_label_update+0xaa/0xc0 static_key_slow_inc+0x9e/0xb0 cpuset_css_online+0x70/0x2e0 online_css+0x2c/0xa0 cgroup_apply_control_enable+0x27f/0x3d0 cgroup_mkdir+0x2b7/0x420 kernfs_iop_mkdir+0x5a/0x80 vfs_mkdir+0xf6/0x1a0 SyS_mkdir+0xb7/0xe0 entry_SYSCALL_64_fastpath+0x18/0xad ... CPU: 2 PID: 1 Comm: init Tainted: G L 4.9.36-00104-g540c51286237 #4 Hardware name: Default string Default string/Hardware, BIOS 4.29.1-20170526215256 05/26/2017 task: ffff8818087c0000 task.stack: ffffc90000030000 RIP: int3+0x39/0x70 Call Trace: <#DB> ? ___slab_alloc+0x28b/0x5a0 <EOE> ? copy_process.part.40+0xf7/0x1de0 __slab_alloc.isra.80+0x54/0x90 copy_process.part.40+0xf7/0x1de0 copy_process.part.40+0xf7/0x1de0 kmem_cache_alloc_node+0x8a/0x280 copy_process.part.40+0xf7/0x1de0 _do_fork+0xe7/0x6c0 _raw_spin_unlock_irq+0x2d/0x60 trace_hardirqs_on_caller+0x136/0x1d0 entry_SYSCALL_64_fastpath+0x5/0xad do_syscall_64+0x27/0x350 SyS_clone+0x19/0x20 do_syscall_64+0x60/0x350 entry_SYSCALL64_slow_path+0x25/0x25 Link: http://lkml.kernel.org/r/20170731040113.14197-1-dmitriyz@waymo.com Fixes: 46e700abc44c ("mm, page_alloc: remove unnecessary taking of a seqlock when cpusets are disabled") Signed-off-by: Dima Zavin <dmitriyz@waymo.com> Reported-by: Cliff Spradlin <cspradlin@waymo.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Christopher Lameter <cl@linux.com> Cc: Li Zefan <lizefan@huawei.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Mel Gorman <mgorman@techsingularity.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-11workqueue: restore WQ_UNBOUND/max_active==1 to be orderedTejun Heo
commit 5c0338c68706be53b3dc472e4308961c36e4ece1 upstream. The combination of WQ_UNBOUND and max_active == 1 used to imply ordered execution. After NUMA affinity 4c16bd327c74 ("workqueue: implement NUMA affinity for unbound workqueues"), this is no longer true due to per-node worker pools. While the right way to create an ordered workqueue is alloc_ordered_workqueue(), the documentation has been misleading for a long time and people do use WQ_UNBOUND and max_active == 1 for ordered workqueues which can lead to subtle bugs which are very difficult to trigger. It's unlikely that we'd see noticeable performance impact by enforcing ordering on WQ_UNBOUND / max_active == 1 workqueues. Let's automatically set __WQ_ORDERED for those workqueues. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Christoph Hellwig <hch@infradead.org> Reported-by: Alexei Potashnik <alexei@purestorage.com> Fixes: 4c16bd327c74 ("workqueue: implement NUMA affinity for unbound workqueues") Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-11cgroup: fix error return value from cgroup_subtree_control()Tejun Heo
commit 3c74541777302eec43a0d1327c4d58b8659a776b upstream. While refactoring, f7b2814bb9b6 ("cgroup: factor out cgroup_{apply|finalize}_control() from cgroup_subtree_control_write()") broke error return value from the function. The return value from the last operation is always overridden to zero. Fix it. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-11cgroup: create dfl_root files on subsys registrationTejun Heo
commit 7af608e4f9530372aec6e940552bf76595f2e265 upstream. On subsystem registration, css_populate_dir() is not called on the new root css, so the interface files for the subsystem on cgrp_dfl_root aren't created on registration. This is a residue from the days when cgrp_dfl_root was used only as the parking spot for unused subsystems, which no longer is true as it's used as the root for cgroup2. This is often fine as later operations tend to create them as a part of mount (cgroup1) or subtree_control operations (cgroup2); however, it's not difficult to mount cgroup2 with the controller interface files missing as Waiman found out. Fix it by invoking css_populate_dir() on the root css on subsys registration. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-and-tested-by: Waiman Long <longman@redhat.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
