commit 13d60f4b6ab5b702dc8d2ee20999f98a93728aec upstream.
The futex_keys of process shared futexes are generated from the page
offset, the mapping host and the mapping index of the futex user space
address. This should result in an unique identifier for each futex.
Though this is not true when futexes are located in different subpages
of an hugepage. The reason is, that the mapping index for all those
futexes evaluates to the index of the base page of the hugetlbfs
mapping. So a futex at offset 0 of the hugepage mapping and another
one at offset PAGE_SIZE of the same hugepage mapping have identical
futex_keys. This happens because the futex code blindly uses
page->index.
Steps to reproduce the bug:
1. Map a file from hugetlbfs. Initialize pthread_mutex1 at offset 0
and pthread_mutex2 at offset PAGE_SIZE of the hugetlbfs
mapping.
The mutexes must be initialized as PTHREAD_PROCESS_SHARED because
PTHREAD_PROCESS_PRIVATE mutexes are not affected by this issue as
their keys solely depend on the user space address.
2. Lock mutex1 and mutex2
3. Create thread1 and in the thread function lock mutex1, which
results in thread1 blocking on the locked mutex1.
4. Create thread2 and in the thread function lock mutex2, which
results in thread2 blocking on the locked mutex2.
5. Unlock mutex2. Despite the fact that mutex2 got unlocked, thread2
still blocks on mutex2 because the futex_key points to mutex1.
To solve this issue we need to take the normal page index of the page
which contains the futex into account, if the futex is in an hugetlbfs
mapping. In other words, we calculate the normal page mapping index of
the subpage in the hugetlbfs mapping.
Mappings which are not based on hugetlbfs are not affected and still
use page->index.
Thanks to Mel Gorman who provided a patch for adding proper evaluation
functions to the hugetlbfs code to avoid exposing hugetlbfs specific
details to the futex code.
[ tglx: Massaged changelog ]
Signed-off-by: Zhang Yi <zhang.yi20@zte.com.cn>
Reviewed-by: Jiang Biao <jiang.biao2@zte.com.cn>
Tested-by: Ma Chenggong <ma.chenggong@zte.com.cn>
Reviewed-by: 'Mel Gorman' <mgorman@suse.de>
Acked-by: 'Darren Hart' <dvhart@linux.intel.com>
Cc: 'Peter Zijlstra' <peterz@infradead.org>
Link: http://lkml.kernel.org/r/000101ce71a6%24a83c5880%24f8b50980%24@com
Cc: Mike Galbraith <mgalbraith@suse.de>
commit ed5467da0e369e65b247b99eb6403cb79172bcda upstream.
tracing_read_pipe zeros all fields bellow "seq". The declaration contains
a comment about that, but it doesn't help.
The first field is "snapshot", it's true when current open file is
snapshot. Looks obvious, that it should not be zeroed.
The second field is "started". It was converted from cpumask_t to
cpumask_var_t (v2.6.28-4983-g4462344), in other words it was
converted from cpumask to pointer on cpumask.
Currently the reference on "started" memory is lost after the first read
from tracing_read_pipe and a proper object will never be freed.
The "started" is never dereferenced for trace_pipe, because trace_pipe
can't have the TRACE_FILE_ANNOTATE options.
Link: http://lkml.kernel.org/r/1375463803-3085183-1-git-send-email-avagin@openvz.org
Signed-off-by: Andrew Vagin <avagin@openvz.org>
commit 9c5da09d266ca9b32eb16cf940f8161d949c2fe5 upstream.
An rmdir pushes css's ref count to zero. However, if the associated
directory is open at the time, the dentry ref count is non-zero. If
the fd for this directory is then passed into perf_event_open, it
does a css_get(). This bounces the ref count back up from zero. This
is a problem by itself. But what makes it turn into a crash is the
fact that we end up doing an extra dput, since we perform a dput
when css_put sees the ref count go down to zero.
css_tryget() does not fall into that trap. So, we use that instead.
Reproduction test-case for the bug:
#include <unistd.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <linux/unistd.h>
#include <linux/perf_event.h>
#include <string.h>
#include <errno.h>
#include <stdio.h>
#define PERF_FLAG_PID_CGROUP (1U << 2)
int perf_event_open(struct perf_event_attr *hw_event_uptr,
pid_t pid, int cpu, int group_fd, unsigned long flags) {
return syscall(__NR_perf_event_open,hw_event_uptr, pid, cpu,
group_fd, flags);
* Directly poke at the perf_event bug, since it's proving hard to repro
* depending on where in the kernel tree. what moved?
int main(int argc, char **argv)
int fd;
struct perf_event_attr attr;
memset(&attr, 0, sizeof(attr));
attr.exclude_kernel = 1;
attr.size = sizeof(attr);
mkdir("/dev/cgroup/perf_event/blah", 0777);
fd = open("/dev/cgroup/perf_event/blah", O_RDONLY);
perror("open");
rmdir("/dev/cgroup/perf_event/blah");
sleep(2);
perf_event_open(&attr, fd, 0, -1, PERF_FLAG_PID_CGROUP);
perror("perf_event_open");
close(fd);
return 0;
Signed-off-by: Salman Qazi <sqazi@google.com>
Acked-by: Tejun Heo <tj@kernel.org>
Link: http://lkml.kernel.org/r/20120614223108.1025.2503.stgit@dungbeetle.mtv.corp.google.com
Cc: Li Zefan <lizefan@huawei.com>
commit 0231bb5336758426b44ccd798ccd3c5419c95d58 upstream.
When we have group with mixed events (hw/sw) we want to end up
with group leader being in hw context. So if group leader is
initialy sw event, we move all the events under hw context.
The move is done for each event by removing it from its context
and adding it back into proper one. As a part of the removal the
event is automatically disabled, which is not what we want at
this stage of creating groups.
The fix is to initialize event state after removal from sw
context.
This fix resulted from the following discussion:
http://thread.gmane.org/gmane.linux.kernel.perf.user/1144
Reported-by: Andreas Hollmann <hollmann@in.tum.de>
Signed-off-by: Jiri Olsa <jolsa@redhat.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Vince Weaver <vince@deater.net>
Link: http://lkml.kernel.org/r/1359714225-4231-1-git-send-email-jolsa@redhat.com
commit a59f4e079d19464eebb9b06513a1d4f55fdae5ba upstream.
The caller of sched_sliced() should pass se.cfs_rq and se as the
arguments, however in sched_rr_get_interval() we gave it
rq.cfs_rq and se, which made the following computation obviously
wrong.
The change was introduced by commit:
77034937dc45 sched: fix crash in sys_sched_rr_get_interval()
... 5 years ago, while it had been the correct 'cfs_rq_of' before
the commit. The change seems to be irrelevant to the commit
msg, which was to return a 0 timeslice for tasks that are on an
idle runqueue. So I believe that was just a plain typo.
Signed-off-by: Zhu Yanhai <gaoyang.zyh@taobao.com>
Cc: Paul Turner <pjt@google.com>
Link: http://lkml.kernel.org/r/1357621012-15039-1-git-send-email-gaoyang.zyh@taobao.com
[ Since this is an ABI and an old bug, we'll test this via a
slow upstream route, to hopefully discover any app breakage. ]
commit 11034ae9c20f4057a6127fc965906417978e69b2 upstream
Initialization of variable irq_flags and pc was missed when backport
11034ae9c to linux-3.0.y and linux-3.4.y, my fault.
Signed-off-by: zhangwei(Jovi) <jovi.zhangwei@huawei.com>
commit 5ec2481b7b47a4005bb446d176e5d0257400c77d upstream.
smp_call_function_* must not be called from softirq context.
But clock_was_set() which calls on_each_cpu() is called from softirq
context to implement a delayed clock_was_set() for the timer interrupt
handler. Though that almost never gets invoked. A recent change in the
resume code uses the softirq based delayed clock_was_set to support
Xens resume mechanism.
linux-next contains a new warning which warns if smp_call_function_*
is called from softirq context which gets triggered by that Xen
change.
Fix this by moving the delayed clock_was_set() call to a work context.
Reported-and-tested-by: Artem Savkov <artem.savkov@gmail.com>
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Cc: David Vrabel <david.vrabel@citrix.com>
Cc: H. Peter Anvin <hpa@zytor.com>,
Cc: Konrad Wilk <konrad.wilk@oracle.com>
Cc: John Stultz <john.stultz@linaro.org>
Cc: xen-devel@lists.xen.org
Cc: stable@vger.kernel.org
commit 11034ae9c20f4057a6127fc965906417978e69b2 upstream.
All syscall tracing irqs-off tags are wrong, the syscall enter entry doesn't
disable irqs.
[root@jovi tracing]#echo "syscalls:sys_enter_open" > set_event
[root@jovi tracing]# cat trace
# tracer: nop
# entries-in-buffer/entries-written: 13/13 #P:2
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
irqbalance-513 [000] d... 56115.496766: sys_open(filename: 804e1a6, flags: 0, mode: 1b6)
irqbalance-513 [000] d... 56115.497008: sys_open(filename: 804e1bb, flags: 0, mode: 1b6)
sendmail-771 [000] d... 56115.827982: sys_open(filename: b770e6d1, flags: 0, mode: 1b6)
The reason is syscall tracing doesn't record irq_flags into buffer.
The proper display is:
# tracer: nop
# entries-in-buffer/entries-written: 14/14 #P:2
# _-----=> irqs-off
# ||| / delay
irqbalance-514 [001] .... 46.213921: sys_open(filename: 804e1a6, flags: 0, mode: 1b6)
irqbalance-514 [001] .... 46.214160: sys_open(filename: 804e1bb, flags: 0, mode: 1b6)
<...>-920 [001] .... 47.307260: sys_open(filename: 4e82a0c5, flags: 80000, mode: 0)
Link: http://lkml.kernel.org/r/1365564393-10972-3-git-send-email-jovi.zhangwei@huawei.com
Cc: stable@vger.kernel.org # 2.6.35
commit 058ebd0eba3aff16b144eabf4510ed9510e1416e upstream.
Jiri managed to trigger this warning:
[] [ INFO: possible circular locking dependency detected ]
[] 3.10.0+ #228 Tainted: G W
[] p/6613 is trying to acquire lock:
[] (rcu_node_0){..-...}, at: [<ffffffff810ca797>] rcu_read_unlock_special+0xa7/0x250
[] but task is already holding lock:
[] (&ctx->lock){-.-...}, at: [<ffffffff810f2879>] perf_lock_task_context+0xd9/0x2c0
[] which lock already depends on the new lock.
[] the existing dependency chain (in reverse order) is:
[] -> #4 (&ctx->lock){-.-...}:
[] -> #3 (&rq->lock){-.-.-.}:
[] -> #2 (&p->pi_lock){-.-.-.}:
[] -> #1 (&rnp->nocb_gp_wq[1]){......}:
[] -> #0 (rcu_node_0){..-...}:
Paul was quick to explain that due to preemptible RCU we cannot call
rcu_read_unlock() while holding scheduler (or nested) locks when part
of the read side critical section was preemptible.
Therefore solve it by making the entire RCU read side non-preemptible.
Also pull out the retry from under the non-preempt to play nice with RT.
Reported-by: Jiri Olsa <jolsa@redhat.com>
Helped-out-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
commit 06f417968beac6e6b614e17b37d347aa6a6b1d30 upstream.
The '!ctx->is_active' check has a valid scenario, so
there's no need for the warning.
The reason is that there's a time window between the
'ctx->is_active' check in the perf_event_enable() function
and the __perf_event_enable() function having:
- IRQs on
- ctx->lock unlocked
where the task could be killed and 'ctx' deactivated by
perf_event_exit_task(), ending up with the warning below.
So remove the WARN_ON_ONCE() check and add comments to
explain it all.
This addresses the following warning reported by Vince Weaver:
[ 324.983534] ------------[ cut here ]------------
[ 324.984420] WARNING: at kernel/events/core.c:1953 __perf_event_enable+0x187/0x190()
[ 324.984420] Modules linked in:
[ 324.984420] CPU: 19 PID: 2715 Comm: nmi_bug_snb Not tainted 3.10.0+ #246
[ 324.984420] Hardware name: Supermicro X8DTN/X8DTN, BIOS 4.6.3 01/08/2010
[ 324.984420] 0000000000000009 ffff88043fce3ec8 ffffffff8160ea0b ffff88043fce3f00
[ 324.984420] ffffffff81080ff0 ffff8802314fdc00 ffff880231a8f800 ffff88043fcf7860
[ 324.984420] 0000000000000286 ffff880231a8f800 ffff88043fce3f10 ffffffff8108103a
[ 324.984420] Call Trace:
[ 324.984420] <IRQ> [<ffffffff8160ea0b>] dump_stack+0x19/0x1b
[ 324.984420] [<ffffffff81080ff0>] warn_slowpath_common+0x70/0xa0
[ 324.984420] [<ffffffff8108103a>] warn_slowpath_null+0x1a/0x20
[ 324.984420] [<ffffffff81134437>] __perf_event_enable+0x187/0x190
[ 324.984420] [<ffffffff81130030>] remote_function+0x40/0x50
[ 324.984420] [<ffffffff810e51de>] generic_smp_call_function_single_interrupt+0xbe/0x130
[ 324.984420] [<ffffffff81066a47>] smp_call_function_single_interrupt+0x27/0x40
[ 324.984420] [<ffffffff8161fd2f>] call_function_single_interrupt+0x6f/0x80
[ 324.984420] <EOI> [<ffffffff816161a1>] ? _raw_spin_unlock_irqrestore+0x41/0x70
[ 324.984420] [<ffffffff8113799d>] perf_event_exit_task+0x14d/0x210
[ 324.984420] [<ffffffff810acd04>] ? switch_task_namespaces+0x24/0x60
[ 324.984420] [<ffffffff81086946>] do_exit+0x2b6/0xa40
[ 324.984420] [<ffffffff8161615c>] ? _raw_spin_unlock_irq+0x2c/0x30
[ 324.984420] [<ffffffff81087279>] do_group_exit+0x49/0xc0
[ 324.984420] [<ffffffff81096854>] get_signal_to_deliver+0x254/0x620
[ 324.984420] [<ffffffff81043057>] do_signal+0x57/0x5a0
[ 324.984420] [<ffffffff8161a164>] ? __do_page_fault+0x2a4/0x4e0
[ 324.984420] [<ffffffff8161665c>] ? retint_restore_args+0xe/0xe
[ 324.984420] [<ffffffff816166cd>] ? retint_signal+0x11/0x84
[ 324.984420] [<ffffffff81043605>] do_notify_resume+0x65/0x80
[ 324.984420] [<ffffffff81616702>] retint_signal+0x46/0x84
[ 324.984420] ---[ end trace 442ec2f04db3771a ]---
Reported-by: Vince Weaver <vincent.weaver@maine.edu>
Suggested-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Link: http://lkml.kernel.org/r/1373384651-6109-2-git-send-email-jolsa@redhat.com
commit 734df5ab549ca44f40de0f07af1c8803856dfb18 upstream.
Currently when the child context for inherited events is
created, it's based on the pmu object of the first event
of the parent context.
This is wrong for the following scenario:
- HW context having HW and SW event
- HW event got removed (closed)
- SW event stays in HW context as the only event
and its pmu is used to clone the child context
The issue starts when the cpu context object is touched
based on the pmu context object (__get_cpu_context). In
this case the HW context will work with SW cpu context
ending up with following WARN below.
Fixing this by using parent context pmu object to clone
from child context.
Addresses the following warning reported by Vince Weaver:
[ 2716.472065] ------------[ cut here ]------------
[ 2716.476035] WARNING: at kernel/events/core.c:2122 task_ctx_sched_out+0x3c/0x)
[ 2716.476035] Modules linked in: nfsd auth_rpcgss oid_registry nfs_acl nfs locn
[ 2716.476035] CPU: 0 PID: 3164 Comm: perf_fuzzer Not tainted 3.10.0-rc4 #2
[ 2716.476035] Hardware name: AOpen DE7000/nMCP7ALPx-DE R1.06 Oct.19.2012, BI2
[ 2716.476035] 0000000000000000 ffffffff8102e215 0000000000000000 ffff88011fc18
[ 2716.476035] ffff8801175557f0 0000000000000000 ffff880119fda88c ffffffff810ad
[ 2716.476035] ffff880119fda880 ffffffff810af02a 0000000000000009 ffff880117550
[ 2716.476035] Call Trace:
[ 2716.476035] [<ffffffff8102e215>] ? warn_slowpath_common+0x5b/0x70
[ 2716.476035] [<ffffffff810ab2bd>] ? task_ctx_sched_out+0x3c/0x5f
[ 2716.476035] [<ffffffff810af02a>] ? perf_event_exit_task+0xbf/0x194
[ 2716.476035] [<ffffffff81032a37>] ? do_exit+0x3e7/0x90c
[ 2716.476035] [<ffffffff810cd5ab>] ? __do_fault+0x359/0x394
[ 2716.476035] [<ffffffff81032fe6>] ? do_group_exit+0x66/0x98
[ 2716.476035] [<ffffffff8103dbcd>] ? get_signal_to_deliver+0x479/0x4ad
[ 2716.476035] [<ffffffff810ac05c>] ? __perf_event_task_sched_out+0x230/0x2d1
[ 2716.476035] [<ffffffff8100205d>] ? do_signal+0x3c/0x432
[ 2716.476035] [<ffffffff810abbf9>] ? ctx_sched_in+0x43/0x141
[ 2716.476035] [<ffffffff810ac2ca>] ? perf_event_context_sched_in+0x7a/0x90
[ 2716.476035] [<ffffffff810ac311>] ? __perf_event_task_sched_in+0x31/0x118
[ 2716.476035] [<ffffffff81050dd9>] ? mmdrop+0xd/0x1c
[ 2716.476035] [<ffffffff81051a39>] ? finish_task_switch+0x7d/0xa6
[ 2716.476035] [<ffffffff81002473>] ? do_notify_resume+0x20/0x5d
[ 2716.476035] [<ffffffff813654f5>] ? retint_signal+0x3d/0x78
[ 2716.476035] ---[ end trace 827178d8a5966c3d ]---
Link: http://lkml.kernel.org/r/1373384651-6109-1-git-send-email-jolsa@redhat.com
commit f17a5194859a82afe4164e938b92035b86c55794 upstream.
The irqsoff tracer records the max time that interrupts are disabled.
There are hooks in the assembly code that calls back into the tracer when
interrupts are disabled or enabled.
When they are enabled, the tracer checks if the amount of time they
were disabled is larger than the previous recorded max interrupts off
time. If it is, it creates a snapshot of the currently running trace
to store where the last largest interrupts off time was held and how
it happened.
During testing, this RCU lockdep dump appeared:
[ 1257.829021] ===============================
[ 1257.829021] [ INFO: suspicious RCU usage. ]
[ 1257.829021] 3.10.0-rc1-test+ #171 Tainted: G W
[ 1257.829021] -------------------------------
[ 1257.829021] /home/rostedt/work/git/linux-trace.git/include/linux/rcupdate.h:780 rcu_read_lock() used illegally while idle!
[ 1257.829021]
[ 1257.829021] other info that might help us debug this:
[ 1257.829021]
[ 1257.829021]
[ 1257.829021] RCU used illegally from idle CPU!
[ 1257.829021] rcu_scheduler_active = 1, debug_locks = 0
[ 1257.829021] RCU used illegally from extended quiescent state!
[ 1257.829021] 2 locks held by trace-cmd/4831:
[ 1257.829021] #0: (max_trace_lock){......}, at: [<ffffffff810e2b77>] stop_critical_timing+0x1a3/0x209
[ 1257.829021] #1: (rcu_read_lock){.+.+..}, at: [<ffffffff810dae5a>] __update_max_tr+0x88/0x1ee
[ 1257.829021]
[ 1257.829021] stack backtrace:
[ 1257.829021] CPU: 3 PID: 4831 Comm: trace-cmd Tainted: G W 3.10.0-rc1-test+ #171
[ 1257.829021] Hardware name: To Be Filled By O.E.M. To Be Filled By O.E.M./To be filled by O.E.M., BIOS SDBLI944.86P 05/08/2007
[ 1257.829021] 0000000000000001 ffff880065f49da8 ffffffff8153dd2b ffff880065f49dd8
[ 1257.829021] ffffffff81092a00 ffff88006bd78680 ffff88007add7500 0000000000000003
[ 1257.829021] ffff88006bd78680 ffff880065f49e18 ffffffff810daebf ffffffff810dae5a
[ 1257.829021] Call Trace:
[ 1257.829021] [<ffffffff8153dd2b>] dump_stack+0x19/0x1b
[ 1257.829021] [<ffffffff81092a00>] lockdep_rcu_suspicious+0x109/0x112
[ 1257.829021] [<ffffffff810daebf>] __update_max_tr+0xed/0x1ee
[ 1257.829021] [<ffffffff810dae5a>] ? __update_max_tr+0x88/0x1ee
[ 1257.829021] [<ffffffff811002b9>] ? user_enter+0xfd/0x107
[ 1257.829021] [<ffffffff810dbf85>] update_max_tr_single+0x11d/0x12d
[ 1257.829021] [<ffffffff810e2b15>] stop_critical_timing+0x141/0x209
[ 1257.829021] [<ffffffff8109569a>] ? trace_hardirqs_on+0xd/0xf
[ 1257.829021] [<ffffffff810e3057>] time_hardirqs_on+0x2a/0x2f
[ 1257.829021] [<ffffffff8109550c>] trace_hardirqs_on_caller+0x16/0x197
[ 1257.829021] [<ffffffff8109569a>] trace_hardirqs_on+0xd/0xf
[ 1257.829021] [<ffffffff811002b9>] user_enter+0xfd/0x107
[ 1257.829021] [<ffffffff810029b4>] do_notify_resume+0x92/0x97
[ 1257.829021] [<ffffffff8154bdca>] int_signal+0x12/0x17
What happened was entering into the user code, the interrupts were enabled
and a max interrupts off was recorded. The trace buffer was saved along with
various information about the task: comm, pid, uid, priority, etc.
The uid is recorded with task_uid(tsk). But this is a macro that uses rcu_read_lock()
to retrieve the data, and this happened to happen where RCU is blind (user_enter).
As only the preempt and irqs off tracers can have this happen, and they both
only have the tsk == current, if tsk == current, use current_uid() instead of
task_uid(), as current_uid() does not use RCU as only current can change its uid.
This fixes the RCU suspicious splat.
commit 1f73a9806bdd07a5106409bbcab3884078bd34fe upstream.
When the system switches from periodic to oneshot mode, the broadcast
logic causes a possibility that a CPU which has not yet switched to
oneshot mode puts its own clock event device into oneshot mode without
updating the state and the timer handler.
CPU0 CPU1
per cpu tickdev is in periodic mode
and switched to broadcast
Switch to oneshot mode
tick_broadcast_switch_to_oneshot()
cpumask_copy(tick_oneshot_broacast_mask,
tick_broadcast_mask);
broadcast device mode = oneshot
Timer interrupt
irq_enter()
tick_check_oneshot_broadcast()
dev->set_mode(ONESHOT);
tick_handle_periodic()
if (dev->mode == ONESHOT)
dev->next_event += period;
FAIL.
We fail, because dev->next_event contains KTIME_MAX, if the device was
in periodic mode before the uncontrolled switch to oneshot happened.
We must copy the broadcast bits over to the oneshot mask, because
otherwise a CPU which relies on the broadcast would not been woken up
anymore after the broadcast device switched to oneshot mode.
So we need to verify in tick_check_oneshot_broadcast() whether the CPU
has already switched to oneshot mode. If not, leave the device
untouched and let the CPU switch controlled into oneshot mode.
This is a long standing bug, which was never noticed, because the main
user of the broadcast x86 cannot run into that scenario, AFAICT. The
nonarchitected timer mess of ARM creates a gazillion of differently
broken abominations which trigger the shortcomings of that broadcast
code, which better had never been necessary in the first place.
Reported-and-tested-by: Stehle Vincent-B46079 <B46079@freescale.com>
Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
Cc: John Stultz <john.stultz@linaro.org>,
Cc: Mark Rutland <mark.rutland@arm.com>
Link: http://lkml.kernel.org/r/alpine.DEB.2.02.1307012153060.4013@ionos.tec.linutronix.de
commit 9e04d3804d3ac97d8c03a41d78d0f0674b5d01e1 upstream.
Direct compare of jiffies related values does not work in the wrap
around case. Replace it with time_is_after_jiffies().
Signed-off-by: Bart Van Assche <bvanassche@acm.org>
Cc: Arjan van de Ven <arjan@infradead.org>
Link: http://lkml.kernel.org/r/519BC066.5080600@acm.org
commit 2779db8d37d4b542d9ca2575f5f178dbeaca6c86 upstream.
Commit 02725e7471b8 ('genirq: Use irq_get/put functions'),
inadvertently changed can_request_irq() to return 0 for IRQs that have
no action. This causes pcibios_lookup_irq() to select only IRQs that
already have an action with IRQF_SHARED set, or to fail if there are
none. Change can_request_irq() to return 1 for IRQs that have no
action (if the first two conditions are met).
Reported-by: Bjarni Ingi Gislason <bjarniig@rhi.hi.is>
Tested-by: Bjarni Ingi Gislason <bjarniig@rhi.hi.is> (against 3.2)
Cc: 709647@bugs.debian.org
Link: http://bugs.debian.org/709647
Link: http://lkml.kernel.org/r/1372383630.23847.40.camel@deadeye.wl.decadent.org.uk
commit c790b0ad23f427c7522ffed264706238c57c007e upstream.
fetch_bp_busy_slots() and toggle_bp_slot() use
for_each_online_cpu(), this is obviously wrong wrt cpu_up() or
cpu_down(), we can over/under account the per-cpu numbers.
For example:
# echo 0 >> /sys/devices/system/cpu/cpu1/online
# perf record -e mem:0x10 -p 1 &
# echo 1 >> /sys/devices/system/cpu/cpu1/online
# perf record -e mem:0x10,mem:0x10,mem:0x10,mem:0x10 -C1 -a &
# taskset -p 0x2 1
triggers the same WARN_ONCE("Can't find any breakpoint slot") in
arch_install_hw_breakpoint().
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
Link: http://lkml.kernel.org/r/20130620155009.GA6327@redhat.com
commit 7f49ef69db6bbf756c0abca7e9b65b32e999eec8 upstream.
As ftrace_filter_lseek is now used with ftrace_pid_fops, it needs to
be moved out of the #ifdef CONFIG_DYNAMIC_FTRACE section as the
ftrace_pid_fops is defined when DYNAMIC_FTRACE is not.
[ lizf: adjust context ]
Signed-off-by: Li Zefan <lizefan@huawei.com>
commit 6a76f8c0ab19f215af2a3442870eeb5f0e81998d upstream.
Currently set_ftrace_pid and set_graph_function files use seq_lseek
for their fops. However seq_open() is called only for FMODE_READ in
the fops->open() so that if an user tries to seek one of those file
when she open it for writing, it sees NULL seq_file and then panic.
It can be easily reproduced with following command:
$ cd /sys/kernel/debug/tracing
$ echo 1234 | sudo tee -a set_ftrace_pid
In this example, GNU coreutils' tee opens the file with fopen(, "a")
and then the fopen() internally calls lseek().
Link:
http://lkml.kernel.org/r/1365663302-2170-1-git-send-email-namhyung@kernel.org
Signed-off-by: Namhyung Kim <namhyung@kernel.org>
Cc: Namhyung Kim <namhyung.kim@lge.com>
commit 264b83c07a84223f0efd0d1db9ccc66d6f88288f upstream.
argv_split(empty_or_all_spaces) happily succeeds, it simply returns
argc == 0 and argv[0] == NULL. Change call_usermodehelper_exec() to
check sub_info->path != NULL to avoid the crash.
This is the minimal fix, todo:
- perhaps we should change argv_split() to return NULL or change the
callers.
- kill or justify ->path[0] check
- narrow the scope of helper_lock()
Acked-By: Lucas De Marchi <lucas.demarchi@intel.com>
commit 4b0c0f294f60abcdd20994a8341a95c8ac5eeb96 upstream.
Prarit reported a crash on CPU offline/online. The reason is that on
CPU down the NOHZ related per cpu data of the dead cpu is not cleaned
up. If at cpu online an interrupt happens before the per cpu tick
device is registered the irq_enter() check potentially sees stale data
and dereferences a NULL pointer.
Cleanup the data after the cpu is dead.
Reported-by: Prarit Bhargava <prarit@redhat.com>
Cc: Mike Galbraith <bitbucket@online.de>
Link: http://lkml.kernel.org/r/alpine.LFD.2.02.1305031451561.2886@ionos
commit 42a5cf46cd56f46267d2a9fcf2655f4078cd3042 upstream.
An inactive timer's base can refer to a offline cpu's base.
In the current code, cpu_base's lock is blindly reinitialized each
time a CPU is brought up. If a CPU is brought online during the period
that another thread is trying to modify an inactive timer on that CPU
with holding its timer base lock, then the lock will be reinitialized
under its feet. This leads to following SPIN_BUG().
<0> BUG: spinlock already unlocked on CPU#3, kworker/u:3/1466
<0> lock: 0xe3ebe000, .magic: dead4ead, .owner: kworker/u:3/1466, .owner_cpu: 1
<4> [<c0013dc4>] (unwind_backtrace+0x0/0x11c) from [<c026e794>] (do_raw_spin_unlock+0x40/0xcc)
<4> [<c026e794>] (do_raw_spin_unlock+0x40/0xcc) from [<c076c160>] (_raw_spin_unlock+0x8/0x30)
<4> [<c076c160>] (_raw_spin_unlock+0x8/0x30) from [<c009b858>] (mod_timer+0x294/0x310)
<4> [<c009b858>] (mod_timer+0x294/0x310) from [<c00a5e04>] (queue_delayed_work_on+0x104/0x120)
<4> [<c00a5e04>] (queue_delayed_work_on+0x104/0x120) from [<c04eae00>] (sdhci_msm_bus_voting+0x88/0x9c)
<4> [<c04eae00>] (sdhci_msm_bus_voting+0x88/0x9c) from [<c04d8780>] (sdhci_disable+0x40/0x48)
<4> [<c04d8780>] (sdhci_disable+0x40/0x48) from [<c04bf300>] (mmc_release_host+0x4c/0xb0)
<4> [<c04bf300>] (mmc_release_host+0x4c/0xb0) from [<c04c7aac>] (mmc_sd_detect+0x90/0xfc)
<4> [<c04c7aac>] (mmc_sd_detect+0x90/0xfc) from [<c04c2504>] (mmc_rescan+0x7c/0x2c4)
<4> [<c04c2504>] (mmc_rescan+0x7c/0x2c4) from [<c00a6a7c>] (process_one_work+0x27c/0x484)
<4> [<c00a6a7c>] (process_one_work+0x27c/0x484) from [<c00a6e94>] (worker_thread+0x210/0x3b0)
<4> [<c00a6e94>] (worker_thread+0x210/0x3b0) from [<c00aad9c>] (kthread+0x80/0x8c)
<4> [<c00aad9c>] (kthread+0x80/0x8c) from [<c000ea80>] (kernel_thread_exit+0x0/0x8)
As an example, this particular crash occurred when CPU #3 is executing
mod_timer() on an inactive timer whose base is refered to offlined CPU
#2. The code locked the timer_base corresponding to CPU #2. Before it
could proceed, CPU #2 came online and reinitialized the spinlock
corresponding to its base. Thus now CPU #3 held a lock which was
reinitialized. When CPU #3 finally ended up unlocking the old cpu_base
corresponding to CPU #2, we hit the above SPIN_BUG().
CPU #0 CPU #3 CPU #2
..... ...... <Offline>
mod_timer()
lock_timer_base
spin_lock_irqsave(&base->lock)
cpu_up(2) ..... ......
init_timers_cpu()
.... ..... spin_lock_init(&base->lock)
..... spin_unlock_irqrestore(&base->lock) ......
<spin_bug>
Allocation of per_cpu timer vector bases is done only once under
"tvec_base_done[]" check. In the current code, spinlock_initialization
of base->lock isn't under this check. When a CPU is up each time the
base lock is reinitialized. Move base spinlock initialization under
the check.
Signed-off-by: Tirupathi Reddy <tirupath@codeaurora.org>
Link: http://lkml.kernel.org/r/1368520142-4136-1-git-send-email-tirupath@codeaurora.org
audit_trim_trees()
commit 12b2f117f3bf738c1a00a6f64393f1953a740bd4 upstream.
audit_trim_trees() calls get_tree(). If a failure occurs we must call
put_tree().
[akpm@linux-foundation.org: run put_tree() before mutex_lock() for small scalability improvement]
Signed-off-by: Chen Gang <gang.chen@asianux.com>
Cc: Eric Paris <eparis@redhat.com>
Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com>
commit 7fe70b579c9e3daba71635e31b6189394e7b79d3 upstream.
ftrace_dump() had a lot of issues. What ftrace_dump() does, is when
ftrace_dump_on_oops is set (via a kernel parameter or sysctl), it
will dump out the ftrace buffers to the console when either a oops,
panic, or a sysrq-z occurs.
This was written a long time ago when ftrace was fragile to recursion.
But it wasn't written well even for that.
There's a possible deadlock that can occur if a ftrace_dump() is happening
and an NMI triggers another dump. This is because it grabs a lock
before checking if the dump ran.
It also totally disables ftrace, and tracing for no good reasons.
As the ring_buffer now checks if it is read via a oops or NMI, where
there's a chance that the buffer gets corrupted, it will disable
itself. No need to have ftrace_dump() do the same.
ftrace_dump() is now cleaned up where it uses an atomic counter to
make sure only one dump happens at a time. A simple atomic_inc_return()
is enough that is needed for both other CPUs and NMIs. No need for
a spinlock, as if one CPU is running the dump, no other CPU needs
to do it too.
The tracing_on variable is turned off and not turned on. The original
code did this, but it wasn't pretty. By just disabling this variable
we get the result of not seeing traces that happen between crashes.
For sysrq-z, it doesn't get turned on, but the user can always write
a '1' to the tracing_on file. If they are using sysrq-z, then they should
know about tracing_on.
The new code is much easier to read and less error prone. No more
deadlock possibility when an NMI triggers here.
Reported-by: zhangwei(Jovi) <jovi.zhangwei@huawei.com>
commit 6f7a05d7018de222e40ca003721037a530979974 upstream.
Vitaliy reported that a per cpu HPET timer interrupt crashes the
system during hibernation. What happens is that the per cpu HPET timer
gets shut down when the nonboot cpus are stopped. When the nonboot
cpus are onlined again the HPET code sets up the MSI interrupt which
fires before the clock event device is registered. The event handler
is still set to hrtimer_interrupt, which then crashes the machine due
to highres mode not being active.
See http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=700333
There is no real good way to avoid that in the HPET code. The HPET
code alrady has a mechanism to detect spurious interrupts when event
handler == NULL for a similar reason.
We can handle that in the clockevent/tick layer and replace the
previous functional handler with a dummy handler like we do in
tick_setup_new_device().
The original clockevents code did this in clockevents_exchange_device(),
but that got removed by commit 7c1e76897 (clockevents: prevent
clockevent event_handler ending up handler_noop) which forgot to fix
it up in tick_shutdown(). Same issue with the broadcast device.
Reported-by: Vitaliy Fillipov <vitalif@yourcmc.ru>
Cc: Ben Hutchings <ben@decadent.org.uk>
Cc: 700333@bugs.debian.org
commit 3ac1707a13a3da9cfc8f242a15b2fae6df2c5f88 upstream.
The 3rd parameter of flex_array_prealloc() is the number of elements,
not the index of the last element.
The effect of the bug is, when opening cgroup.procs, a flex array will
be allocated and all elements of the array is allocated with
GFP_KERNEL flag, but the last one is GFP_ATOMIC, and if we fail to
allocate memory for it, it'll trigger a BUG_ON().
commit 8f294b5a139ee4b75e890ad5b443c93d1e558a8b upstream.
The settimeofday01 test in the LTP testsuite effectively does
gettimeofday(current time);
settimeofday(Jan 1, 1970 + 100 seconds);
settimeofday(current time);
This test causes a stack trace to be displayed on the console during the
setting of timeofday to Jan 1, 1970 + 100 seconds:
[ 131.066751] ------------[ cut here ]------------
[ 131.096448] WARNING: at kernel/time/clockevents.c:209 clockevents_program_event+0x135/0x140()
[ 131.104935] Hardware name: Dinar
[ 131.108150] Modules linked in: sg nfsv3 nfs_acl nfsv4 auth_rpcgss nfs dns_resolver fscache lockd sunrpc nf_conntrack_netbios_ns nf_conntrack_broadcast ipt_MASQUERADE ip6table_mangle ip6t_REJECT nf_conntrack_ipv6 nf_defrag_ipv6 iptable_nat nf_nat_ipv4 nf_nat iptable_mangle ipt_REJECT nf_conntrack_ipv4 nf_defrag_ipv4 xt_conntrack nf_conntrack ebtable_filter ebtables ip6table_filter ip6_tables iptable_filter ip_tables kvm_amd kvm sp5100_tco bnx2 i2c_piix4 crc32c_intel k10temp fam15h_power ghash_clmulni_intel amd64_edac_mod pcspkr serio_raw edac_mce_amd edac_core microcode xfs libcrc32c sr_mod sd_mod cdrom ata_generic crc_t10dif pata_acpi radeon i2c_algo_bit drm_kms_helper ttm drm ahci pata_atiixp libahci libata usb_storage i2c_core dm_mirror dm_region_hash dm_log dm_mod
[ 131.176784] Pid: 0, comm: swapper/28 Not tainted 3.8.0+ #6
[ 131.182248] Call Trace:
[ 131.184684] <IRQ> [<ffffffff810612af>] warn_slowpath_common+0x7f/0xc0
[ 131.191312] [<ffffffff8106130a>] warn_slowpath_null+0x1a/0x20
[ 131.197131] [<ffffffff810b9fd5>] clockevents_program_event+0x135/0x140
[ 131.203721] [<ffffffff810bb584>] tick_program_event+0x24/0x30
[ 131.209534] [<ffffffff81089ab1>] hrtimer_interrupt+0x131/0x230
[ 131.215437] [<ffffffff814b9600>] ? cpufreq_p4_target+0x130/0x130
[ 131.221509] [<ffffffff81619119>] smp_apic_timer_interrupt+0x69/0x99
[ 131.227839] [<ffffffff8161805d>] apic_timer_interrupt+0x6d/0x80
[ 131.233816] <EOI> [<ffffffff81099745>] ? sched_clock_cpu+0xc5/0x120
[ 131.240267] [<ffffffff814b9ff0>] ? cpuidle_wrap_enter+0x50/0xa0
[ 131.246252] [<ffffffff814b9fe9>] ? cpuidle_wrap_enter+0x49/0xa0
[ 131.252238] [<ffffffff814ba050>] cpuidle_enter_tk+0x10/0x20
[ 131.257877] [<ffffffff814b9c89>] cpuidle_idle_call+0xa9/0x260
[ 131.263692] [<ffffffff8101c42f>] cpu_idle+0xaf/0x120
[ 131.268727] [<ffffffff815f8971>] start_secondary+0x255/0x257
[ 131.274449] ---[ end trace 1151a50552231615 ]---
When we change the system time to a low value like this, the value of
timekeeper->offs_real will be a negative value.
It seems that the WARN occurs because an hrtimer has been started in the time
between the releasing of the timekeeper lock and the IPI call (via a call to
on_each_cpu) in clock_was_set() in the do_settimeofday() code. The end result
is that a REALTIME_CLOCK timer has been added with softexpires = expires =
KTIME_MAX. The hrtimer_interrupt() fires/is called and the loop at
kernel/hrtimer.c:1289 is executed. In this loop the code subtracts the
clock base's offset (which was set to timekeeper->offs_real in
do_settimeofday()) from the current hrtimer_cpu_base->expiry value (which
was KTIME_MAX):
KTIME_MAX - (a negative value) = overflow
A simple check for an overflow can resolve this problem. Using KTIME_MAX
instead of the overflow value will result in the hrtimer function being run,
and the reprogramming of the timer after that.
Signed-off-by: Prarit Bhargava <prarit@redhat.com>
[jstultz: Tweaked commit subject]
Signed-off-by: John Stultz <john.stultz@linaro.org>
commit 51fd36f3fad8447c487137ae26b9d0b3ce77bb25 upstream.
One can trigger an overflow when using ktime_add_ns() on a 32bit
architecture not supporting CONFIG_KTIME_SCALAR.
When passing a very high value for u64 nsec, e.g. 7881299347898368000
the do_div() function converts this value to seconds (7881299347) which
is still to high to pass to the ktime_set() function as long. The result
in is a negative value.
The problem on my system occurs in the tick-sched.c,
tick_nohz_stop_sched_tick() when time_delta is set to
timekeeping_max_deferment(). The check for time_delta < KTIME_MAX is
valid, thus ktime_add_ns() is called with a too large value resulting in
a negative expire value. This leads to an endless loop in the ticker code:
time_delta: 7881299347898368000
expires = ktime_add_ns(last_update, time_delta)
expires: negative value
This fix caps the value to KTIME_MAX.
This error doesn't occurs on 64bit or architectures supporting
CONFIG_KTIME_SCALAR (e.g. ARM, x86-32).
Signed-off-by: David Engraf <david.engraf@sysgo.com>
[jstultz: Minor tweaks to commit message & header]
commit 9f50afccfdc15d95d7331acddcb0f7703df089ae upstream.
The ftrace_graph_count can be decreased with a "!" pattern, so that
the enabled flag should be updated too.
Link: http://lkml.kernel.org/r/1365663698-2413-1-git-send-email-namhyung@kernel.org
commit ed6f1c996bfe4b6e520cf7a74b51cd6988d84420 upstream.
Check return value and bail out if it's NULL.
Link: http://lkml.kernel.org/r/1365553093-10180-2-git-send-email-namhyung@kernel.org
commit 39e30cd1537937d3c00ef87e865324e981434e5b upstream.
The first page was allocated separately, so no need to start from 0.
Link: http://lkml.kernel.org/r/1364820385-32027-2-git-send-email-namhyung@kernel.org
commit 4df297129f622bdc18935c856f42b9ddd18f9f28 upstream.
Currently, the depth reported in the stack tracer stack_trace file
does not match the stack_max_size file. This is because the stack_max_size
includes the overhead of stack tracer itself while the depth does not.
The first time a max is triggered, a calculation is not performed that
figures out the overhead of the stack tracer and subtracts it from
the stack_max_size variable. The overhead is stored and is subtracted
from the reported stack size for comparing for a new max.
Now the stack_max_size corresponds to the reported depth:
# cat stack_max_size
4640
# cat stack_trace
Depth Size Location (48 entries)
0) 4640 32 _raw_spin_lock+0x18/0x24
1) 4608 112 ____cache_alloc+0xb7/0x22d
2) 4496 80 kmem_cache_alloc+0x63/0x12f
3) 4416 16 mempool_alloc_slab+0x15/0x17
While testing against and older gcc on x86 that uses mcount instead
of fentry, I found that pasing in ip + MCOUNT_INSN_SIZE let the
stack trace show one more function deep which was missing before.
commit d4ecbfc49b4b1d4b597fb5ba9e4fa25d62f105c5 upstream.
When gcc 4.6 on x86 is used, the function tracer will use the new
option -mfentry which does a call to "fentry" at every function
instead of "mcount". The significance of this is that fentry is
called as the first operation of the function instead of the mcount
usage of being called after the stack.
This causes the stack tracer to show some bogus results for the size
of the last function traced, as well as showing "ftrace_call" instead
of the function. This is due to the stack frame not being set up
by the function that is about to be traced.
# cat stack_trace
0) 4824 216 ftrace_call+0x5/0x2f
The 216 size for ftrace_call includes both the ftrace_call stack
(which includes the saving of registers it does), as well as the
stack size of the parent.
To fix this, if CC_USING_FENTRY is defined, then the stack_tracer
will reserve the first item in stack_dump_trace[] array when
calling save_stack_trace(), and it will fill it in with the parent ip.
Then the code will look for the parent pointer on the stack and
give the real size of the parent's stack pointer:
# cat stack_trace
Depth Size Location (14 entries)
0) 2640 48 update_group_power+0x26/0x187
1) 2592 224 update_sd_lb_stats+0x2a5/0x4ac
2) 2368 160 find_busiest_group+0x31/0x1f1
3) 2208 256 load_balance+0xd9/0x662
I'm Cc'ing stable, although it's not urgent, as it only shows bogus
size for item #0, the rest of the trace is legit. It should still be
corrected in previous stable releases.
commit 87889501d0adfae10e3b0f0e6f2d7536eed9ae84 upstream.
Use the stack of stack_trace_call() instead of check_stack() as
the test pointer for max stack size. It makes it a bit cleaner
and a little more accurate.
Adding stable, as a later fix depends on this patch.
commit 8176cced706b5e5d15887584150764894e94e02f upstream.
Trinity discovered that we fail to check all 64 bits of
attr.config passed by user space, resulting to out-of-bounds
access of the perf_swevent_enabled array in
sw_perf_event_destroy().
Introduced in commit b0a873ebb ("perf: Register PMU
implementations").
Signed-off-by: Tommi Rantala <tt.rantala@gmail.com>
Cc: davej@redhat.com
Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Link: http://lkml.kernel.org/r/1365882554-30259-1-git-send-email-tt.rantala@gmail.com
commit 383efcd00053ec40023010ce5034bd702e7ab373 upstream.
try_to_wake_up_local() should only be invoked to wake up another
task in the same runqueue and BUG_ON()s are used to enforce the
rule. Missing try_to_wake_up_local() can stall workqueue
execution but such stalls are likely to be finite either by
another work item being queued or the one blocked getting
unblocked. There's no reason to trigger BUG while holding rq
lock crashing the whole system.
Convert BUG_ON()s in try_to_wake_up_local() to WARN_ON_ONCE()s.
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Link: http://lkml.kernel.org/r/20130318192234.GD3042@htj.dyndns.org
commit b9e146d8eb3b9ecae5086d373b50fa0c1f3e7f0f upstream.
This fixes a kernel memory contents leak via the tkill and tgkill syscalls
for compat processes.
This is visible in the siginfo_t->_sifields._rt.si_sigval.sival_ptr field
when handling signals delivered from tkill.
The place of the infoleak:
int copy_siginfo_to_user32(compat_siginfo_t __user *to, siginfo_t *from)
put_user_ex(ptr_to_compat(from->si_ptr), &to->si_ptr);
Signed-off-by: Emese Revfy <re.emese@gmail.com>
Reviewed-by: PaX Team <pageexec@freemail.hu>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Serge Hallyn <serge.hallyn@canonical.com>
commit 84cc8fd2fe65866e49d70b38b3fdf7219dd92fe0 upstream.
The current code makes the assumption that a cpu_base lock won't be
held if the CPU corresponding to that cpu_base is offline, which isn't
always true.
If a hrtimer is not queued, then it will not be migrated by
migrate_hrtimers() when a CPU is offlined. Therefore, the hrtimer's
cpu_base may still point to a CPU which has subsequently gone offline
if the timer wasn't enqueued at the time the CPU went down.
Normally this wouldn't be a problem, but a cpu_base's lock is blindly
reinitialized each time a CPU is brought up. If a CPU is brought
online during the period that another thread is performing a hrtimer
operation on a stale hrtimer, then the lock will be reinitialized
under its feet, and a SPIN_BUG() like the following will be observed:
<0>[ 28.082085] BUG: spinlock already unlocked on CPU#0, swapper/0/0
<0>[ 28.087078] lock: 0xc4780b40, value 0x0 .magic: dead4ead, .owner: <none>/-1, .owner_cpu: -1
<4>[ 42.451150] [<c0014398>] (unwind_backtrace+0x0/0x120) from [<c0269220>] (do_raw_spin_unlock+0x44/0xdc)
<4>[ 42.460430] [<c0269220>] (do_raw_spin_unlock+0x44/0xdc) from [<c071b5bc>] (_raw_spin_unlock+0x8/0x30)
<4>[ 42.469632] [<c071b5bc>] (_raw_spin_unlock+0x8/0x30) from [<c00a9ce0>] (__hrtimer_start_range_ns+0x1e4/0x4f8)
<4>[ 42.479521] [<c00a9ce0>] (__hrtimer_start_range_ns+0x1e4/0x4f8) from [<c00aa014>] (hrtimer_start+0x20/0x28)
<4>[ 42.489247] [<c00aa014>] (hrtimer_start+0x20/0x28) from [<c00e6190>] (rcu_idle_enter_common+0x1ac/0x320)
<4>[ 42.498709] [<c00e6190>] (rcu_idle_enter_common+0x1ac/0x320) from [<c00e6440>] (rcu_idle_enter+0xa0/0xb8)
<4>[ 42.508259] [<c00e6440>] (rcu_idle_enter+0xa0/0xb8) from [<c000f268>] (cpu_idle+0x24/0xf0)
<4>[ 42.516503] [<c000f268>] (cpu_idle+0x24/0xf0) from [<c06ed3c0>] (rest_init+0x88/0xa0)
<4>[ 42.524319] [<c06ed3c0>] (rest_init+0x88/0xa0) from [<c0c00978>] (start_kernel+0x3d0/0x434)
As an example, this particular crash occurred when hrtimer_start() was
executed on CPU #0. The code locked the hrtimer's current cpu_base
corresponding to CPU #1. CPU #0 then tried to switch the hrtimer's
cpu_base to an optimal CPU which was online. In this case, it selected
the cpu_base corresponding to CPU #3.
Before it could proceed, CPU #1 came online and reinitialized the
spinlock corresponding to its cpu_base. Thus now CPU #0 held a lock
which was reinitialized. When CPU #0 finally ended up unlocking the
old cpu_base corresponding to CPU #1 so that it could switch to CPU
#3, we hit this SPIN_BUG() above while in switch_hrtimer_base().
CPU #0 CPU #1
... <offline>
hrtimer_start()
lock_hrtimer_base(base #1)
... init_hrtimers_cpu()
switch_hrtimer_base() ...
... raw_spin_lock_init(&cpu_base->lock)
raw_spin_unlock(&cpu_base->lock) ...
<spin_bug>
Solve this by statically initializing the lock.
Signed-off-by: Michael Bohan <mbohan@codeaurora.org>
Link: http://lkml.kernel.org/r/1363745965-23475-1-git-send-email-mbohan@codeaurora.org
commit a1cbcaa9ea87b87a96b9fc465951dcf36e459ca2 upstream.
The sched_clock_remote() implementation has the following inatomicity
problem on 32bit systems when accessing the remote scd->clock, which
is a 64bit value.
CPU0 CPU1
sched_clock_local() sched_clock_remote(CPU0)
remote_clock = scd[CPU0]->clock
read_low32bit(scd[CPU0]->clock)
cmpxchg64(scd->clock,...)
read_high32bit(scd[CPU0]->clock)
While the update of scd->clock is using an atomic64 mechanism, the
readout on the remote cpu is not, which can cause completely bogus
readouts.
It is a quite rare problem, because it requires the update to hit the
narrow race window between the low/high readout and the update must go
across the 32bit boundary.
The resulting misbehaviour is, that CPU1 will see the sched_clock on
CPU1 ~4 seconds ahead of it's own and update CPU1s sched_clock value
to this bogus timestamp. This stays that way due to the clamping
implementation for about 4 seconds until the synchronization with
CLOCK_MONOTONIC undoes the problem.
The issue is hard to observe, because it might only result in a less
accurate SCHED_OTHER timeslicing behaviour. To create observable
damage on realtime scheduling classes, it is necessary that the bogus
update of CPU1 sched_clock happens in the context of an realtime
thread, which then gets charged 4 seconds of RT runtime, which results
in the RT throttler mechanism to trigger and prevent scheduling of RT
tasks for a little less than 4 seconds. So this is quite unlikely as
well.
The issue was quite hard to decode as the reproduction time is between
2 days and 3 weeks and intrusive tracing makes it less likely, but the
following trace recorded with trace_clock=global, which uses
sched_clock_local(), gave the final hint:
<idle>-0 0d..30 400269.477150: hrtimer_cancel: hrtimer=0xf7061e80
<idle>-0 0d..30 400269.477151: hrtimer_start: hrtimer=0xf7061e80 ...
irq/20-S-587 1d..32 400273.772118: sched_wakeup: comm= ... target_cpu=0
<idle>-0 0dN.30 400273.772118: hrtimer_cancel: hrtimer=0xf7061e80
What happens is that CPU0 goes idle and invokes
sched_clock_idle_sleep_event() which invokes sched_clock_local() and
CPU1 runs a remote wakeup for CPU0 at the same time, which invokes
sched_remote_clock(). The time jump gets propagated to CPU0 via
sched_remote_clock() and stays stale on both cores for ~4 seconds.
There are only two other possibilities, which could cause a stale
sched clock:
1) ktime_get() which reads out CLOCK_MONOTONIC returns a sporadic
wrong value.
2) sched_clock() which reads the TSC returns a sporadic wrong value.
#1 can be excluded because sched_clock would continue to increase for
one jiffy and then go stale.
#2 can be excluded because it would not make the clock jump
forward. It would just result in a stale sched_clock for one jiffy.
After quite some brain twisting and finding the same pattern on other
traces, sched_clock_remote() remained the only place which could cause
such a problem and as explained above it's indeed racy on 32bit
systems.
So while on 64bit systems the readout is atomic, we need to verify the
remote readout on 32bit machines. We need to protect the local->clock
readout in sched_clock_remote() on 32bit as well because an NMI could
hit between the low and the high readout, call sched_clock_local() and
modify local->clock.
Thanks to Siegfried Wulsch for bearing with my debug requests and
going through the tedious tasks of running a bunch of reproducer
systems to generate the debug information which let me decode the
issue.
Reported-by: Siegfried Wulsch <Siegfried.Wulsch@rovema.de>
Acked-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/alpine.LFD.2.02.1304051544160.21884@ionos
commit 6f389a8f1dd22a24f3d9afc2812b30d639e94625 upstream.
As commit 40dc166c (PM / Core: Introduce struct syscore_ops for core
subsystems PM) say, syscore_ops operations should be carried with one
CPU on-line and interrupts disabled. However, after commit f96972f2d
(kernel/sys.c: call disable_nonboot_cpus() in kernel_restart()),
syscore_shutdown() is called before disable_nonboot_cpus(), so break
the rules. We have a MIPS machine with a 8259A PIC, and there is an
external timer (HPET) linked at 8259A. Since 8259A has been shutdown
too early (by syscore_shutdown()), disable_nonboot_cpus() runs without
timer interrupt, so it hangs and reboot fails. This patch call
syscore_shutdown() a little later (after disable_nonboot_cpus()) to
avoid reboot failure, this is the same way as poweroff does.
For consistency, add disable_nonboot_cpus() to kernel_halt().
Signed-off-by: Huacai Chen <chenhc@lemote.com>
commit 83e03b3fe4daffdebbb42151d5410d730ae50bd1 upstream.
On the failure path, stat->start and stat->pages will refer same page.
So it'll attempt to free the same page again and get kernel panic.
Link: http://lkml.kernel.org/r/1364820385-32027-1-git-send-email-namhyung@kernel.org
commit 5000c418840b309251c5887f0b56503aae30f84c upstream.
If we reenable ftrace via syctl, we currently set ftrace_trace_function
based on the previous simplistic algorithm. This is inconsistent with
what update_ftrace_function does. So better call that helper instead.
Link: http://lkml.kernel.org/r/5151D26F.1070702@siemens.com
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
commit 613f04a0f51e6e68ac6fe571ab79da3c0a5eb4da upstream.
The latency tracers require the buffers to be in overwrite mode,
otherwise they get screwed up. Force the buffers to stay in overwrite
mode when latency tracers are enabled.
Added a flag_changed() method to the tracer structure to allow
the tracers to see what flags are being changed, and also be able
to prevent the change from happing.
[Backported for 3.4-stable. Re-added current_trace NULL checks; removed
allocated_snapshot field; adapted to tracing_trace_options_write without
trace_set_options.]
Signed-off-by: Lingzhu Xiang <lxiang@redhat.com>
Reviewed-by: CAI Qian <caiqian@redhat.com>
commit 69d34da2984c95b33ea21518227e1f9470f11d95 upstream.
Seems that the tracer flags have never been protected from
synchronous writes. Luckily, admins don't usually modify the
tracing flags via two different tasks. But if scripts were to
be used to modify them, then they could get corrupted.
Move the trace_types_lock that protects against tracers changing
to also protect the flags being set.
[Backported for 3.4, 3.0-stable. Moved return to after unlock.]
commit 522cff142d7d2f9230839c9e1f21a4d8bcc22a4a upstream.
__ARCH_HAS_SA_RESTORER is the preferred conditional for use in 3.9 and
later kernels, per Kees.
Cc: Emese Revfy <re.emese@gmail.com>
Cc: PaX Team <pageexec@freemail.hu>
Cc: Julien Tinnes <jln@google.com>
commit a7dc19b8652c862d5b7c4d2339bd3c428bd29c4a upstream.
Currently tick_check_broadcast_device doesn't reject clock_event_devices
with CLOCK_EVT_FEAT_DUMMY, and may select them in preference to real
hardware if they have a higher rating value. In this situation, the
dummy timer is responsible for broadcasting to itself, and the core
clockevents code may attempt to call non-existent callbacks for
programming the dummy, eventually leading to a panic.
This patch makes tick_check_broadcast_device always reject dummy timers,
preventing this problem.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Cc: Jon Medhurst (Tixy) <tixy@linaro.org>
commit 740466bc89ad8bd5afcc8de220f715f62b21e365 upstream.
Because function tracing is very invasive, and can even trace
calls to rcu_read_lock(), RCU access in function tracing is done
with preempt_disable_notrace(). This requires a synchronize_sched()
for updates and not a synchronize_rcu().
Function probes (traceon, traceoff, etc) must be freed after
a synchronize_sched() after its entry has been removed from the
hash. But call_rcu() is used. Fix this by using call_rcu_sched().
Also fix the usage to use hlist_del_rcu() instead of hlist_del().
Cc: Paul McKenney <paulmck@linux.vnet.ibm.com>
commit 2721e72dd10f71a3ba90f59781becf02638aa0d9 upstream.
Although the swap is wrapped with a spin_lock, the assignment
of the temp buffer used to swap is not within that lock.
It needs to be moved into that lock, otherwise two swaps
happening on two different CPUs, can end up using the wrong
temp buffer to assign in the swap.
Luckily, all current callers of the swap function appear to have
their own locks. But in case something is added that allows two
different callers to call the swap, then there's a chance that
this race can trigger and corrupt the buffers.
New code is coming soon that will allow for this race to trigger.
I've Cc'd stable, so this bug will not show up if someone backports
one of the changes that can trigger this bug.
commit 2ca39528c01a933f6689cd6505ce65bd6d68a530 upstream.
When the new signal handlers are set up, the location of sa_restorer is
not cleared, leaking a parent process's address space location to
children. This allows for a potential bypass of the parent's ASLR by
examining the sa_restorer value returned when calling sigaction().
Based on what should be considered "secret" about addresses, it only
matters across the exec not the fork (since the VMAs haven't changed
until the exec). But since exec sets SIG_DFL and keeps sa_restorer,
this is where it should be fixed.
Given the few uses of sa_restorer, a "set" function was not written
since this would be the only use. Instead, we use
__ARCH_HAS_SA_RESTORER, as already done in other places.
Example of the leak before applying this patch:
$ cat /proc/$$/maps
7fb9f3083000-7fb9f3238000 r-xp 00000000 fd:01 404469 .../libc-2.15.so
$ ./leak
7f278bc74000-7f278be29000 r-xp 00000000 fd:01 404469 .../libc-2.15.so
1 0 (nil) 0x7fb9f30b94a0
2 4000000 (nil) 0x7f278bcaa4a0
3 4000000 (nil) 0x7f278bcaa4a0
4 0 (nil) 0x7fb9f30b94a0
[akpm@linux-foundation.org: use SA_RESTORER for backportability]
Reported-by: Emese Revfy <re.emese@gmail.com>
commit db05021d49a994ee40a9735d9c3cb0060c9babb8 upstream.
The prompt to enable DYNAMIC_FTRACE (the ability to nop and
enable function tracing at run time) had a confusing statement:
"enable/disable ftrace tracepoints dynamically"
This was written before tracepoints were added to the kernel,
but now that tracepoints have been added, this is very confusing
and has confused people enough to give wrong information during
presentations.
Not only that, I looked at the help text, and it still references
that dreaded daemon that use to wake up once a second to update
the nop locations and brick NICs, that hasn't been around for over
five years.
Time to bring the text up to the current decade.
Reported-by: Ezequiel Garcia <elezegarcia@gmail.com>
commit 71b5707e119653039e6e95213f00479668c79b75 upstream.
In cgroup_exit() put_css_set_taskexit() is called without any lock,
which might lead to accessing a freed cgroup:
thread1 thread2
exit()
cgroup_exit()
atomic_dec(cgrp->count);
rmdir();
/* not safe !! */
check_for_release(cgrp);
rcu_read_lock() can be used to make sure the cgroup is alive.
