path: root/kernel
2006-07-06fix prctl privilege escalation and suid_dumpable (CVE-2006-2451)Greg Kroah-Hartman
Based on a patch from Ernie Petrides During security research, Red Hat discovered a behavioral flaw in core dump handling. A local user could create a program that would cause a core file to be dumped into a directory they would not normally have permissions to write to. This could lead to a denial of service (disk consumption), or allow the local user to gain root privileges. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-29[PATCH] Link error when futexes are disabled on 64bit architecturesAnton Blanchard
From: Anton Blanchard <anton@samba.org> If futexes are disabled we fail to link on ppc64. Signed-off-by: Anton Blanchard <anton@samba.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2006-06-17[PATCH] arm_timer: remove a racy and obsolete PF_EXITING checkOleg Nesterov
arm_timer() checks PF_EXITING to prevent BUG_ON(->exit_state) in run_posix_cpu_timers(). However, for some reason it does so only for CPUCLOCK_PERTHREAD case (which is imho wrong). Also, this check is not reliable, PF_EXITING could be set on another cpu without any locks/barriers just after the check, so it can't prevent from attaching the timer to the exiting task. The previous patch makes this check unneeded. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-17[PATCH] run_posix_cpu_timers: remove a bogus BUG_ON()Oleg Nesterov
do_exit() clears ->it_##clock##_expires, but nothing prevents another cpu to attach the timer to exiting process after that. arm_timer() tries to protect against this race, but the check is racy. After exit_notify() does 'write_unlock_irq(&tasklist_lock)' and before do_exit() calls 'schedule() local timer interrupt can find tsk->exit_state != 0. If that state was EXIT_DEAD (or another cpu does sys_wait4) interrupted task has ->signal == NULL. At this moment exiting task has no pending cpu timers, they were cleanuped in __exit_signal()->posix_cpu_timers_exit{,_group}(), so we can just return from irq. John Stultz recently confirmed this bug, see http://marc.theaimsgroup.com/?l=linux-kernel&m=115015841413687 Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-17[PATCH] check_process_timers: fix possible lockupOleg Nesterov
If the local timer interrupt happens just after do_exit() sets PF_EXITING (and before it clears ->it_xxx_expires) run_posix_cpu_timers() will call check_process_timers() with tasklist_lock + ->siglock held and check_process_timers: t = tsk; do { .... do { t = next_thread(t); } while (unlikely(t->flags & PF_EXITING)); } while (t != tsk); the outer loop will never stop. Actually, the window is bigger. Another process can attach the timer after ->it_xxx_expires was cleared (see the next commit) and the 'if (PF_EXITING)' check in arm_timer() is racy (see the one after that). Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-31[PATCH] hrtimer: export symbolsStephen Hemminger
From: Stephen Hemminger <shemminger@osdl.org> I want to use the hrtimer's in the netem (Network Emulator) qdisc. But the necessary symbols aren't exported for module use. Also needed by SystemTap. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "Stone, Joshua I" <joshua.i.stone@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-21Revert "[PATCH] sched: fix interactive task starvation"Linus Torvalds
This reverts commit 5ce74abe788a26698876e66b9c9ce7e7acc25413 (and its dependent commit 8a5bc075b8d8cf7a87b3f08fad2fba0f5d13295e), because of audio underruns. Reported by Rene Herman <rene.herman@keyaccess.nl>, who also pinpointed the exact cause of the underruns: "Audio underruns galore, with only ogg123 and firefox (browsing the GIT tree online is also a nice trigger by the way). If I back it out, everything is fine for me again." Cc: Rene Herman <rene.herman@keyaccess.nl> Cc: Mike Galbraith <efault@gmx.de> Acked-by: Con Kolivas <kernel@kolivas.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-21[PATCH] Fix a NO_IDLE_HZ timer bugZachary Amsden
Under certain timing conditions, a race during boot occurs where timer ticks are being processed on remote CPUs. The remote timer ticks can increment jiffies, and if this happens during a window when a timeout is very close to expiring but a local tick has not yet been delivered, you can end up with 1) No softirq pending 2) A local timer wheel which is not synced to jiffies 3) No high resolution timer active 4) A local timer which is supposed to fire before the current jiffies value. In this circumstance, the comparison in next_timer_interrupt overflows, because the base of the comparison for high resolution timers is jiffies, but for the softirq timer wheel, it is relative the the current base of the wheel (jiffies_base). Signed-off-by: Zachary Amsden <zach@vmware.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-21[PATCH] cpuset: might_sleep_if check in cpuset_zones_allowedPaul Jackson
It's too easy to incorrectly call cpuset_zone_allowed() in an atomic context without __GFP_HARDWALL set, and when done, it is not noticed until a tight memory situation forces allocations to be tried outside the current cpuset. Add a 'might_sleep_if()' check, to catch this earlier on, instead of waiting for a similar check in the mutex_lock() code, which is only rarely invoked. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-21[PATCH] cpuset: update cpuset_zones_allowed commentPaul Jackson
Update the kernel/cpuset.c:cpuset_zone_allowed() comment. The rule for when mm/page_alloc.c should call cpuset_zone_allowed() was intended to be: Don't call cpuset_zone_allowed() if you can't sleep, unless you pass in the __GFP_HARDWALL flag set in gfp_flag, which disables the code that might scan up ancestor cpusets and sleep. The explanation of this rule in the comment above cpuset_zone_allowed() was stale, as a result of a restructuring of some __alloc_pages() code in November 2005. Rewrite that comment ... Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-15[PATCH] symbol_put_addr() locks kernelTrent Piepho
Even since a previous patch: Fix race between CONFIG_DEBUG_SLABALLOC and modules Sun, 27 Jun 2004 17:55:19 +0000 (17:55 +0000) http://www.kernel.org/git/?p=linux/kernel/git/torvalds/old-2.6-bkcvs.git;a=commit;h=92b3db26d31cf21b70e3c1eadc56c179506d8fbe The function symbol_put_addr() will deadlock the kernel. symbol_put_addr() would acquire modlist_lock, then while holding the lock call two functions kernel_text_address() and module_text_address() which also try to acquire the same lock. This deadlocks the kernel of course. This patch changes symbol_put_addr() to not acquire the modlist_lock, it doesn't need it since it never looks at the module list directly. Also, it now uses core_kernel_text() instead of kernel_text_address(). The latter has an additional check for addr inside a module, but we don't need to do that since we call module_text_address() (the same function kernel_text_address uses) ourselves. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Cc: Zwane Mwaikambo <zwane@fsmlabs.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-15[PATCH] RCU: introduce rcu_needs_cpu() interfaceHeiko Carstens
With "Paul E. McKenney" <paulmck@us.ibm.com> Introduce rcu_needs_cpu() interface. This can be used to tell if there will be a new rcu batch on a cpu soon by looking at the curlist pointer. This can be used to avoid to enter a tickless idle state where the cpu would miss that a new batch is ready when rcu_start_batch would be called on a different cpu. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-11ptrace_attach: fix possible deadlock schenario with irqsLinus Torvalds
Eric Biederman points out that we can't take the task_lock while holding tasklist_lock for writing, because another CPU that holds the task lock might take an interrupt that then tries to take tasklist_lock for writing. Which would be a nasty deadlock, with one CPU spinning forever in an interrupt handler (although admittedly you need to really work at triggering it ;) Since the ptrace_attach() code is special and very unusual, just make it be extra careful, and use trylock+repeat to avoid the possible deadlock. Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-07Fix ptrace_attach()/ptrace_traceme()/de_thread() raceLinus Torvalds
This holds the task lock (and, for ptrace_attach, the tasklist_lock) over the actual attach event, which closes a race between attacking to a thread that is either doing a PTRACE_TRACEME or getting de-threaded. Thanks to Oleg Nesterov for reminding me about this, and Chris Wright for noticing a lost return value in my first version. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-01[PATCH] Audit Filter PerformanceSteve Grubb
While testing the watch performance, I noticed that selinux_task_ctxid() was creeping into the results more than it should. Investigation showed that the function call was being called whether it was needed or not. The below patch fixes this. Signed-off-by: Steve Grubb <sgrubb@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-05-01[PATCH] Rework of IPC auditingSteve Grubb
1) The audit_ipc_perms() function has been split into two different functions: - audit_ipc_obj() - audit_ipc_set_perm() There's a key shift here... The audit_ipc_obj() collects the uid, gid, mode, and SElinux context label of the current ipc object. This audit_ipc_obj() hook is now found in several places. Most notably, it is hooked in ipcperms(), which is called in various places around the ipc code permforming a MAC check. Additionally there are several places where *checkid() is used to validate that an operation is being performed on a valid object while not necessarily having a nearby ipcperms() call. In these locations, audit_ipc_obj() is called to ensure that the information is captured by the audit system. The audit_set_new_perm() function is called any time the permissions on the ipc object changes. In this case, the NEW permissions are recorded (and note that an audit_ipc_obj() call exists just a few lines before each instance). 2) Support for an AUDIT_IPC_SET_PERM audit message type. This allows for separate auxiliary audit records for normal operations on an IPC object and permissions changes. Note that the same struct audit_aux_data_ipcctl is used and populated, however there are separate audit_log_format statements based on the type of the message. Finally, the AUDIT_IPC block of code in audit_free_aux() was extended to handle aux messages of this new type. No more mem leaks I hope ;-) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-05-01[PATCH] More user space subject labelsSteve Grubb
Hi, The patch below builds upon the patch sent earlier and adds subject label to all audit events generated via the netlink interface. It also cleans up a few other minor things. Signed-off-by: Steve Grubb <sgrubb@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-05-01[PATCH] Reworked patch for labels on user space messagesSteve Grubb
The below patch should be applied after the inode and ipc sid patches. This patch is a reworking of Tim's patch that has been updated to match the inode and ipc patches since its similar. [updated: > Stephen Smalley also wanted to change a variable from isec to tsec in the > user sid patch. ] Signed-off-by: Steve Grubb <sgrubb@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-05-01[PATCH] change lspp ipc auditingSteve Grubb
Hi, The patch below converts IPC auditing to collect sid's and convert to context string only if it needs to output an audit record. This patch depends on the inode audit change patch already being applied. Signed-off-by: Steve Grubb <sgrubb@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-05-01[PATCH] audit inode patchSteve Grubb
Previously, we were gathering the context instead of the sid. Now in this patch, we gather just the sid and convert to context only if an audit event is being output. This patch brings the performance hit from 146% down to 23% Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-05-01[PATCH] support for context based audit filtering, part 2Darrel Goeddel
This patch provides the ability to filter audit messages based on the elements of the process' SELinux context (user, role, type, mls sensitivity, and mls clearance). It uses the new interfaces from selinux to opaquely store information related to the selinux context and to filter based on that information. It also uses the callback mechanism provided by selinux to refresh the information when a new policy is loaded. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-05-01[PATCH] no need to wank with task_lock() and pinning task down in ↵Al Viro
audit_syscall_exit() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-05-01[PATCH] drop task argument of audit_syscall_{entry,exit}Al Viro
... it's always current, and that's a good thing - allows simpler locking. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-05-01[PATCH] drop gfp_mask in audit_log_exit()Al Viro
now we can do that - all callers are process-synchronous and do not hold any locks. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-05-01[PATCH] move call of audit_free() into do_exit()Al Viro
2006-05-01[PATCH] deal with deadlocks in audit_free()Al Viro
Don't assume that audit_log_exit() et.al. are called for the context of current; pass task explictly. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-04-28[PATCH] request_irq(): remove warnings from irq probingAndrew Morton
- Add new SA_PROBEIRQ which suppresses the new sharing-mismatch warning. Some drivers like to use request_irq() to find an unused interrupt slot. - Use it in i82365.c - Kill unused SA_PROBE. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-28[PATCH] off-by-1 in kernel/power/main.cdean gaudet
There's an off-by-1 in kernel/power/main.c:state_store() ... if your kernel just happens to have some non-zero data at pm_states[PM_SUSPEND_MAX] (i.e. one past the end of the array) then it'll let you write anything you want to /sys/power/state and in response the box will enter S5. Signed-off-by: dean gaudet <dean@arctic.org> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-26[PATCH] Remove __devinit and __cpuinit from notifier_call definitionsChandra Seetharaman
Few of the notifier_chain_register() callers use __init in the definition of notifier_call. It is incorrect as the function definition should be available after the initializations (they do not unregister them during initializations). This patch fixes all such usages to _not_ have the notifier_call __init section. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-26[PATCH] Remove __devinitdata from notifier block definitionsChandra Seetharaman
Few of the notifier_chain_register() callers use __devinitdata in the definition of notifier_block data structure. It is incorrect as the data structure should be available after the initializations (they do not unregister them during initializations). This was leading to an oops when notifier_chain_register() call is invoked for those callback chains after initialization. This patch fixes all such usages to _not_ have the notifier_block data structure in the init data section. Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-20Merge branch 'for-linus' of git://brick.kernel.dk/data/git/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://brick.kernel.dk/data/git/linux-2.6-block: [PATCH] block/elevator.c: remove unused exports [PATCH] splice: fix smaller sized splice reads [PATCH] Don't inherit ->splice_pipe across forks [patch] cleanup: use blk_queue_stopped [PATCH] Document online io scheduler switching
2006-04-20[PATCH] kprobes: NULL out non-relevant fields in struct kretprobeAnanth N Mavinakayanahalli
In cases where a struct kretprobe's *_handler fields are non-NULL, it is possible to cause a system crash, due to the possibility of calls ending up in zombie functions. Documentation clearly states that unused *_handlers should be set to NULL, but kprobe users sometimes fail to do so. Fix it by setting the non-relevant fields of the struct kretprobe to NULL. Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Acked-by: Jim Keniston <jkenisto@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-20[PATCH] Don't inherit ->splice_pipe across forksJens Axboe
It's really task private, so clear that field on fork after copying task structure. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-04-19[PATCH] Add more prevent_tail_call()OGAWA Hirofumi
Those also break userland regs like following. 00000000 <sys_chown16>: 0: 0f b7 44 24 0c movzwl 0xc(%esp),%eax 5: 83 ca ff or $0xffffffff,%edx 8: 0f b7 4c 24 08 movzwl 0x8(%esp),%ecx d: 66 83 f8 ff cmp $0xffffffff,%ax 11: 0f 44 c2 cmove %edx,%eax 14: 66 83 f9 ff cmp $0xffffffff,%cx 18: 0f 45 d1 cmovne %ecx,%edx 1b: 89 44 24 0c mov %eax,0xc(%esp) 1f: 89 54 24 08 mov %edx,0x8(%esp) 23: e9 fc ff ff ff jmp 24 <sys_chown16+0x24> where the tailcall at the end overwrites the incoming stack-frame. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> [ I would _really_ like to have a way to tell gcc about calling conventions. The "prevent_tail_call()" macro is pretty ugly ] Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-19[PATCH] swsusp: prevent possible image corruption on resumeRafael J. Wysocki
The function free_pagedir() used by swsusp for freeing its internal data structures clears the PG_nosave and PG_nosave_free flags for each page being freed. However, during resume PG_nosave_free set means that the page in question is "unsafe" (ie. it will be overwritten in the process of restoring the saved system state from the image), so it should not be used for the image data. Therefore free_pagedir() should not clear PG_nosave_free if it's called during resume (otherwise "unsafe" pages freed by it may be used for storing the image data and the data may get corrupted later on). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-19[PATCH] task: Make task list manipulations RCU safeEric W. Biederman
While we can currently walk through thread groups, process groups, and sessions with just the rcu_read_lock, this opens the door to walking the entire task list. We already have all of the other RCU guarantees so there is no cost in doing this, this should be enough so that proc can stop taking the tasklist lock during readdir. prev_task was killed because it has no users, and using it will miss new tasks when doing an rcu traversal. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-14[PATCH] kill unushed __put_task_struct_cbEric W. Biederman
Somehow in the midst of dotting i's and crossing t's during the merge up to rc1 we wound up keeping __put_task_struct_cb when it should have been killed as it no longer has any users. Sorry I probably should have caught this while it was still in the -mm tree. Having the old code there gets confusing when reading through the code and trying to understand what is happening. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-14[PATCH] remove kernel/power/pm.c:pm_unregister()Adrian Bunk
Since the last user is removed in -mm, we can now remove this long deprecated function. Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-14[PATCH] fix non-leader exec under ptraceRoland McGrath
This reverts most of commit 30e0fca6c1d7d26f3f2daa4dd2b12c51dadc778a. It broke the case of non-leader MT exec when ptraced. I think the bug it was intended to fix was already addressed by commit 788e05a67c343fa22f2ae1d3ca264e7f15c25eaf. Signed-off-by: Roland McGrath <roland@redhat.com> Acked-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] __group_complete_signal: remove bogus BUG_ONOleg Nesterov
Commit e56d090310d7625ecb43a1eeebd479f04affb48b [PATCH] RCU signal handling made this BUG_ON() unsafe. This code runs under ->siglock, while switch_exec_pids() takes tasklist_lock. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11Merge branch 'splice' of git://brick.kernel.dk/data/git/linux-2.6-blockLinus Torvalds
* 'splice' of git://brick.kernel.dk/data/git/linux-2.6-block: [PATCH] vfs: add splice_write and splice_read to documentation [PATCH] Remove sys_ prefix of new syscalls from __NR_sys_* [PATCH] splice: warning fix [PATCH] another round of fs/pipe.c cleanups [PATCH] splice: comment styles [PATCH] splice: add Ingo as addition copyright holder [PATCH] splice: unlikely() optimizations [PATCH] splice: speedups and optimizations [PATCH] pipe.c/fifo.c code cleanups [PATCH] get rid of the PIPE_*() macros [PATCH] splice: speedup __generic_file_splice_read [PATCH] splice: add direct fd <-> fd splicing support [PATCH] splice: add optional input and output offsets [PATCH] introduce a "kernel-internal pipe object" abstraction [PATCH] splice: be smarter about calling do_page_cache_readahead() [PATCH] splice: optimize the splice buffer mapping [PATCH] splice: cleanup __generic_file_splice_read() [PATCH] splice: only call wake_up_interruptible() when we really have to [PATCH] splice: potential !page dereference [PATCH] splice: mark the io page as accessed
2006-04-11[PATCH] add cpu_relax to hrtimer_cancelJoe Korty
Add a cpu_relax() to the hand-coded spinwait in hrtimer_cancel(). Signed-off-by: Joe Korty <joe.korty@ccur.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] build kernel/irq/migration.c only if CONFIG_GENERIC_PENDING_IRQ is setChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] the scheduled unexport of panic_timeoutAdrian Bunk
Implement the scheduled unexport of panic_timeout. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] timer initialisation fixAndrew Morton
We need the boot CPU's tvec_bases[] entry to be initialised super-early in boot, for early_serial_setup(). That runs within setup_arch(), before even per-cpu areas are initialised. The patch changes tvec_bases to use compile-time initialisation, and adds a separate array `tvec_base_done' to keep track of which CPU has had its tvec_bases[] entry initialised (because we can no longer use the zeroness of that tvec_bases[] entry to determine whether it has been initialised). Thanks to Eugene Surovegin <ebs@ebshome.net> for diagnosing this. Cc: Eugene Surovegin <ebs@ebshome.net> Cc: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] frv: define MMU mode specific syscalls as 'cond_syscall' and clean ↵Hyok S. Choi
up unneeded macros For some architectures, a few syscalls are not linked in noMMU mode. In that case, the MMU depending syscalls are needed to be defined as 'cond_syscall'. For example, ARM architecture selectively links sys_mlock by the mode configuration. In case of FRV, it has been managed by #ifdef CONFIG_MMU macro in arch/frv/kernel/entry.S. However these conditional macros are just duplicates if they were defined as cond_syscall. Compilation test is done with FRV toolchains for both of MMU and noMMU mode. Signed-off-by: Hyok S. Choi <hyok.choi@samsung.com> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] sched: don't awaken RT tasks on expired arrayMike Galbraith
RT tasks are being awakened on the expired array when expired_starving() is true, whereas they really should be excluded. Fix. Signed-off-by: Mike Galbraith <efault@gmx.de> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Con Kolivas <kernel@kolivas.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] sched: fix interactive task starvationMike Galbraith
Fix a starvation problem that occurs when a stream of highly interactive tasks delay an array switch for extended periods despite EXPIRED_STARVING(rq) being true. AFAIKT, the only choice is to enqueue awakening tasks on the expired array in this case. Without this patch, it can be nearly impossible to remotely login to a busy server, and interactive shell commands can starve for minutes. Also, convert the EXPIRED_STARVING macro into an inline function which humans can understand. Signed-off-by: Mike Galbraith <efault@gmx.de> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Acked-by: Con Kolivas <kernel@kolivas.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] splice: add direct fd <-> fd splicing supportJens Axboe
It's more efficient for sendfile() emulation. Basically we cache an internal private pipe and just use that as the intermediate area for pages. Direct splicing is not available from sys_splice(), it is only meant to be used for sendfile() emulation. Additional patch from Ingo Molnar to avoid the PIPE_BUFFERS loop at exit for the normal fast path. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-04-09[PATCH] x86_64: Fix drift with HPET timer enabledJordan Hargrave
If the HPET timer is enabled, the clock can drift by ~3 seconds a day. This is due to the HPET timer not being initialized with the correct setting (still using PIT count). If HZ changes, this drift can become even more pronounced. HPET patch initializes tick_nsec with correct tick_nsec settings for HPET timer. Vojtech comments: "It's not entirely correct (it assumes the HPET ticks totally exactly), but it's significantly better than assuming the PIT error there." Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
