[ Upstream commit 3effcb4247e74a51f5d8b775a1ee4abf87cc089a ]
We have been facing some problems with self-suspending constrained
deadline tasks. The main reason is that the original CBS was not
designed for such sort of tasks.
One problem reported by Xunlei Pang takes place when a task
suspends, and then is awakened before the deadline, but so close
to the deadline that its remaining runtime can cause the task
to have an absolute density higher than allowed. In such situation,
the original CBS assumes that the task is facing an early activation,
and so it replenishes the task and set another deadline, one deadline
in the future. This rule works fine for implicit deadline tasks.
Moreover, it allows the system to adapt the period of a task in which
the external event source suffered from a clock drift.
However, this opens the window for bandwidth leakage for constrained
deadline tasks. For instance, a task with the following parameters:
runtime = 5 ms
deadline = 7 ms
[density] = 5 / 7 = 0.71
period = 1000 ms
If the task runs for 1 ms, and then suspends for another 1ms,
it will be awakened with the following parameters:
remaining runtime = 4
laxity = 5
presenting a absolute density of 4 / 5 = 0.80.
In this case, the original CBS would assume the task had an early
wakeup. Then, CBS will reset the runtime, and the absolute deadline will
be postponed by one relative deadline, allowing the task to run.
The problem is that, if the task runs this pattern forever, it will keep
receiving bandwidth, being able to run 1ms every 2ms. Following this
behavior, the task would be able to run 500 ms in 1 sec. Thus running
more than the 5 ms / 1 sec the admission control allowed it to run.
Trying to address the self-suspending case, Luca Abeni, Giuseppe
Lipari, and Juri Lelli [1] revisited the CBS in order to deal with
self-suspending tasks. In the new approach, rather than
replenishing/postponing the absolute deadline, the revised wakeup rule
adjusts the remaining runtime, reducing it to fit into the allowed
density.
A revised version of the idea is:
At a given time t, the maximum absolute density of a task cannot be
higher than its relative density, that is:
runtime / (deadline - t) <= dl_runtime / dl_deadline
Knowing the laxity of a task (deadline - t), it is possible to move
it to the other side of the equality, thus enabling to define max
remaining runtime a task can use within the absolute deadline, without
over-running the allowed density:
runtime = (dl_runtime / dl_deadline) * (deadline - t)
For instance, in our previous example, the task could still run:
runtime = ( 5 / 7 ) * 5
runtime = 3.57 ms
Without causing damage for other deadline tasks. It is note worthy
that the laxity cannot be negative because that would cause a negative
runtime. Thus, this patch depends on the patch:
df8eac8cafce ("sched/deadline: Throttle a constrained deadline task activated after the deadline")
Which throttles a constrained deadline task activated after the
deadline.
Finally, it is also possible to use the revised wakeup rule for
all other tasks, but that would require some more discussions
about pros and cons.
Reported-by: Xunlei Pang <xpang@redhat.com>
Signed-off-by: Daniel Bristot de Oliveira <bristot@redhat.com>
[peterz: replaced dl_is_constrained with dl_is_implicit]
Cc: Juri Lelli <juri.lelli@arm.com>
Cc: Luca Abeni <luca.abeni@santannapisa.it>
Cc: Romulo Silva de Oliveira <romulo.deoliveira@ufsc.br>
Cc: Tommaso Cucinotta <tommaso.cucinotta@sssup.it>
Link: http://lkml.kernel.org/r/5c800ab3a74a168a84ee5f3f84d12a02e11383be.1495803804.git.bristot@redhat.com
[ Upstream commit ba5213ae6b88fb170c4771fef6553f759c7d8cdd ]
Andi was asking about PERF_FORMAT_GROUP vs inherited events, which led
to the discovery of a bug from commit:
3dab77fb1bf8 ("perf: Rework/fix the whole read vs group stuff")
- PERF_SAMPLE_GROUP = 1U << 4,
+ PERF_SAMPLE_READ = 1U << 4,
- if (attr->inherit && (attr->sample_type & PERF_SAMPLE_GROUP))
+ if (attr->inherit && (attr->read_format & PERF_FORMAT_GROUP))
is a clear fail :/
While this changes user visible behaviour; it was previously possible
to create an inherited event with PERF_SAMPLE_READ; this is deemed
acceptible because its results were always incorrect.
Reported-by: Andi Kleen <ak@linux.intel.com>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Cc: Jiri Olsa <jolsa@kernel.org>
Cc: Stephane Eranian <eranian@google.com>
Cc: Vince Weaver <vince@deater.net>
Fixes: 3dab77fb1bf8 ("perf: Rework/fix the whole read vs group stuff")
Link: http://lkml.kernel.org/r/20170530094512.dy2nljns2uq7qa3j@hirez.programming.kicks-ass.net
[ Upstream commit 49dfe2a6779717d9c18395684ee31bdc98b22e53 ]
The CPU hotplug callbacks are not covered by lockdep versus the cpu hotplug
rwsem.
CPU0 CPU1
cpuhp_setup_state(STATE, startup, teardown);
cpus_read_lock();
invoke_callback_on_ap();
kick_hotplug_thread(ap);
wait_for_completion(); hotplug_thread_fn()
lock(m);
do_stuff();
unlock(m);
Lockdep does not know about this dependency and will not trigger on the
following code sequence:
lock(m);
cpus_read_lock();
Add a lockdep map and connect the initiators lock chain with the hotplug
thread lock chain, so potential deadlocks can be detected.
Tested-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Acked-by: Ingo Molnar <mingo@kernel.org>
Cc: Sebastian Siewior <bigeasy@linutronix.de>
Link: http://lkml.kernel.org/r/20170524081549.709375845@linutronix.de
[ Upstream commit 8655d5497735b288f8a9b458bd22e7d1bf95bb61 ]
A customer has reported a soft-lockup when running an intensive
memory stress test, where the trace on multiple CPU's looks like this:
RIP: 0010:[<ffffffff810c53fe>]
[<ffffffff810c53fe>] native_queued_spin_lock_slowpath+0x10e/0x190
Call Trace:
[<ffffffff81182d07>] queued_spin_lock_slowpath+0x7/0xa
[<ffffffff811bc331>] change_protection_range+0x3b1/0x930
[<ffffffff811d4be8>] change_prot_numa+0x18/0x30
[<ffffffff810adefe>] task_numa_work+0x1fe/0x310
[<ffffffff81098322>] task_work_run+0x72/0x90
Further investigation showed that the lock contention here is pmd_lock().
The task_numa_work() function makes sure that only one thread is let to perform
the work in a single scan period (via cmpxchg), but if there's a thread with
mmap_sem locked for writing for several periods, multiple threads in
task_numa_work() can build up a convoy waiting for mmap_sem for read and then
all get unblocked at once.
This patch changes the down_read() to the trylock version, which prevents the
build up. For a workload experiencing mmap_sem contention, it's probably better
to postpone the NUMA balancing work anyway. This seems to have fixed the soft
lockups involving pmd_lock(), which is in line with the convoy theory.
Signed-off-by: Vlastimil Babka <vbabka@suse.cz>
Acked-by: Mel Gorman <mgorman@techsingularity.net>
Link: http://lkml.kernel.org/r/20170515131316.21909-1-vbabka@suse.cz
[ Upstream commit 36cc2b9222b5106de34085c4dd8635ac67ef5cba ]
We don't set an error code here which means that perf_event_alloc()
returns ERR_PTR(0) (in other words NULL). The callers are not expecting
that and would Oops.
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Vince Weaver <vincent.weaver@maine.edu>
Fixes: 375637bc5249 ("perf/core: Introduce address range filtering")
Link: http://lkml.kernel.org/r/20170522090418.hvs6icgpdo53wkn5@mwanda
[ Upstream commit 88b0193d9418c00340e45e0a913a0813bc6c8c96 ]
Perf can generate and record a user callchain in response to a synchronous
request, such as a tracepoint firing. If this happens under set_fs(KERNEL_DS),
then we can end up walking the user stack (and dereferencing/saving whatever we
find there) without the protections usually afforded by checks such as
access_ok.
Rather than play whack-a-mole with each architecture's stack unwinding
implementation, fix the root of the problem by ensuring that we force USER_DS
when invoking perf_callchain_user from the perf core.
Reported-by: Al Viro <viro@ZenIV.linux.org.uk>
Acked-by: Peter Zijlstra <peterz@infradead.org>
[ Upstream commit 8896c23d2ef803f1883fea73117a435925c2b4c4 ]
alloc_pidmap() advances pid_namespace::last_pid. When first pid
allocation fails, then next created process will have pid 2 and
pid_ns_prepare_proc() won't be called. So, pid_namespace::proc_mnt will
never be initialized (not to mention that there won't be a child
reaper).
I saw crash stack of such case on kernel 3.10:
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: proc_flush_task+0x8f/0x1b0
Call Trace:
release_task+0x3f/0x490
wait_consider_task.part.10+0x7ff/0xb00
do_wait+0x11f/0x280
SyS_wait4+0x7d/0x110
We may fix this by restore of last_pid in 0 or by prohibiting of futher
allocations. Since there was a similar issue in Oleg Nesterov's commit
314a8ad0f18a ("pidns: fix free_pid() to handle the first fork failure").
and it was fixed via prohibiting allocation, let's follow this way, and
do the same.
Link: http://lkml.kernel.org/r/149201021004.4863.6762095011554287922.stgit@localhost.localdomain
Signed-off-by: Kirill Tkhai <ktkhai@virtuozzo.com>
Acked-by: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Andrei Vagin <avagin@virtuozzo.com>
Cc: Andreas Gruenbacher <agruenba@redhat.com>
Cc: Michael Kerrisk <mtk.manpages@googlemail.com>
Cc: Paul Moore <paul@paul-moore.com>
Cc: Eric Biederman <ebiederm@xmission.com>
Cc: Serge Hallyn <serge@hallyn.com>
commit 39290b389ea upstream.
The current "rodata=off" parameter disables read-only kernel mappings
under CONFIG_DEBUG_RODATA:
commit d2aa1acad22f ("mm/init: Add 'rodata=off' boot cmdline parameter
to disable read-only kernel mappings")
This patch is a logical extension to module mappings ie. read-only mappings
at module loading can be disabled even if CONFIG_DEBUG_SET_MODULE_RONX
(mainly for debug use). Please note, however, that it only affects RO/RW
permissions, keeping NX set.
This is the first step to make CONFIG_DEBUG_SET_MODULE_RONX mandatory
(always-on) in the future as CONFIG_DEBUG_RODATA on x86 and arm64.
Suggested-by: and Acked-by: Mark Rutland <mark.rutland@arm.com>
Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
Link: http://lkml.kernel.org/r/20161114061505.15238-1-takahiro.akashi@linaro.org
Signed-off-by: Jessica Yu <jeyu@redhat.com>
Signed-off-by: Alex Shi <alex.shi@linaro.org> [v4.9 backport]
Signed-off-by: Mark Rutland <mark.rutland@arm.com> [v4.9 backport]
Tested-by: Will Deacon <will.deacon@arm.com>
Tested-by: Greg Hackmann <ghackmann@google.com>
commit d170fe7dd992b313d4851ae5ab77ee7a51ed8c72 upstream.
This fixes the following clang warning when CONFIG_CPUMASK_OFFSTACK=n:
kernel/irq/manage.c:839:28: error: address of array
'desc->irq_common_data.affinity' will always evaluate to 'true'
[-Werror,-Wpointer-bool-conversion]
Signed-off-by: Matthias Kaehlcke <mka@chromium.org>
Cc: Grant Grundler <grundler@chromium.org>
Cc: Greg Hackmann <ghackmann@google.com>
Cc: Michael Davidson <md@google.com>
Link: http://lkml.kernel.org/r/20170412182030.83657-2-mka@chromium.org
Cc: Nathan Chancellor <natechancellor@gmail.com>
commit c93f5cf571e7795f97d49ef51b766cf25e328545 upstream.
Fix kprobes to set(recover) RWX bits correctly on trampoline
buffer before releasing it. Releasing readonly page to
module_memfree() crash the kernel.
Without this fix, if kprobes user register a bunch of kprobes
in function body (since kprobes on function entry usually
use ftrace) and unregister it, kernel hits a BUG and crash.
Link: http://lkml.kernel.org/r/149570868652.3518.14120169373590420503.stgit@devbox
Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org>
Fixes: d0381c81c2f7 ("kprobes/x86: Set kprobes pages read-only")
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
Cc: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit f67b15037a7a50c57f72e69a6d59941ad90a0f0f upstream.
Annoyingly, modify_user_hw_breakpoint() unnecessarily complicates the
modification of a breakpoint - simplify it and remove the pointless
local variables.
Also update the stale Docbook while at it.
Cc: <stable@vger.kernel.org>
shared IRQs"
This reverts commit f2596a9808acfd02ce1ee389f0e1c37e64aec5f6 which is
commit 382bd4de61827dbaaf5fb4fb7b1f4be4a86505e7 upstream.
It causes too many problems with the stable tree, and would require too
many other things to be backported, so just revert it.
Reported-by: Guenter Roeck <linux@roeck-us.net>
Cc: Hans de Goede <hdegoede@redhat.com>
Cc: Marc Zyngier <marc.zyngier@arm.com>
Cc: Sasha Levin <alexander.levin@microsoft.com>
commit 0fa4fe85f4724fff89b09741c437cbee9cf8b008 upstream.
The current check statement in BPF syscall will do a capability check
for CAP_SYS_ADMIN before checking sysctl_unprivileged_bpf_disabled. This
code path will trigger unnecessary security hooks on capability checking
and cause false alarms on unprivileged process trying to get CAP_SYS_ADMIN
access. This can be resolved by simply switch the order of the statement
and CAP_SYS_ADMIN is not required anyway if unprivileged bpf syscall is
allowed.
Signed-off-by: Chenbo Feng <fengc@google.com>
Acked-by: Lorenzo Colitti <lorenzo@google.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
commit c5d343b6b7badd1f5fe0873eff2e8d63a193e732 upstream.
In Documentation/trace/kprobetrace.txt, it says
@SYM[+|-offs] : Fetch memory at SYM +|- offs (SYM should be a data symbol)
However, the parser doesn't parse minus offset correctly, since
commit 2fba0c8867af ("tracing/kprobes: Fix probe offset to be
unsigned") drops minus ("-") offset support for kprobe probe
address usage.
This fixes the traceprobe_split_symbol_offset() to parse minus
offset again with checking the offset range, and add a minus
offset check in kprobe probe address usage.
Link: http://lkml.kernel.org/r/152129028983.31874.13419301530285775521.stgit@devbox
Cc: Tom Zanussi <tom.zanussi@linux.intel.com>
Cc: Ravi Bangoria <ravi.bangoria@linux.vnet.ibm.com>
Cc: stable@vger.kernel.org
Fixes: 2fba0c8867af ("tracing/kprobes: Fix probe offset to be unsigned")
Acked-by: Namhyung Kim <namhyung@kernel.org>
[ Upstream commit 382bd4de61827dbaaf5fb4fb7b1f4be4a86505e7 ]
When requesting a shared irq with IRQF_TRIGGER_NONE then the irqaction
flags get filled with the trigger type from the irq_data:
if (!(new->flags & IRQF_TRIGGER_MASK))
new->flags |= irqd_get_trigger_type(&desc->irq_data);
On the first setup_irq() the trigger type in irq_data is NONE when the
above code executes, then the irq is started up for the first time and
then the actual trigger type gets established, but that's too late to fix
up new->flags.
When then a second user of the irq requests the irq with IRQF_TRIGGER_NONE
its irqaction's triggertype gets set to the actual trigger type and the
following check fails:
if (!((old->flags ^ new->flags) & IRQF_TRIGGER_MASK))
Resulting in the request_irq failing with -EBUSY even though both
users requested the irq with IRQF_SHARED | IRQF_TRIGGER_NONE
Fix this by comparing the new irqaction's trigger type to the trigger type
stored in the irq_data which correctly reflects the actual trigger type
being used for the irq.
Suggested-by: Thomas Gleixner <tglx@linutronix.de>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
Link: http://lkml.kernel.org/r/20170415100831.17073-1-hdegoede@redhat.com
[ Upstream commit d340266e19ddb70dbd608f9deedcfb35fdb9d419 ]
struct timespec is not y2038 safe on 32 bit machines.
The posix clocks apis use struct timespec directly and through struct
itimerspec.
Replace the posix clock interfaces to use struct timespec64 and struct
itimerspec64 instead. Also fix up their implementations accordingly.
Note that the clock_getres() interface has also been changed to use
timespec64 even though this particular interface is not affected by the
y2038 problem. This helps verification for internal kernel code for y2038
readiness by getting rid of time_t/ timeval/ timespec.
Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com>
Cc: arnd@arndb.de
Cc: y2038@lists.linaro.org
Cc: netdev@vger.kernel.org
Cc: Richard Cochran <richardcochran@gmail.com>
Cc: john.stultz@linaro.org
Link: http://lkml.kernel.org/r/1490555058-4603-3-git-send-email-deepa.kernel@gmail.com
[ Upstream commit 2ce77d16db4240dd2e422fc0a5c26d3e2ec03446 ]
Things can explode for locktorture if the user does combinations
of nwriters_stress=0 nreaders_stress=0. Fix this by not assuming
we always want to torture writer threads.
Reported-by: Jeremy Linton <jeremy.linton@arm.com>
Signed-off-by: Davidlohr Bueso <dbueso@suse.de>
Reviewed-by: Jeremy Linton <jeremy.linton@arm.com>
Tested-by: Jeremy Linton <jeremy.linton@arm.com>
[ Upstream commit a0982dfa03efca6c239c52cabebcea4afb93ea6b ]
The rcutorture test suite occasionally provokes a splat due to invoking
resched_cpu() on an offline CPU:
WARNING: CPU: 2 PID: 8 at /home/paulmck/public_git/linux-rcu/arch/x86/kernel/smp.c:128 native_smp_send_reschedule+0x37/0x40
Modules linked in:
CPU: 2 PID: 8 Comm: rcu_preempt Not tainted 4.14.0-rc4+ #1
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
task: ffff902ede9daf00 task.stack: ffff96c50010c000
RIP: 0010:native_smp_send_reschedule+0x37/0x40
RSP: 0018:ffff96c50010fdb8 EFLAGS: 00010096
RAX: 000000000000002e RBX: ffff902edaab4680 RCX: 0000000000000003
RDX: 0000000080000003 RSI: 0000000000000000 RDI: 00000000ffffffff
RBP: ffff96c50010fdb8 R08: 0000000000000000 R09: 0000000000000001
R10: 0000000000000000 R11: 00000000299f36ae R12: 0000000000000001
R13: ffffffff9de64240 R14: 0000000000000001 R15: ffffffff9de64240
FS: 0000000000000000(0000) GS:ffff902edfc80000(0000) knlGS:0000000000000000
CR2: 00000000f7d4c642 CR3: 000000001e0e2000 CR4: 00000000000006e0
Call Trace:
resched_curr+0x8f/0x1c0
resched_cpu+0x2c/0x40
rcu_implicit_dynticks_qs+0x152/0x220
force_qs_rnp+0x147/0x1d0
? sync_rcu_exp_select_cpus+0x450/0x450
rcu_gp_kthread+0x5a9/0x950
kthread+0x142/0x180
? force_qs_rnp+0x1d0/0x1d0
? kthread_create_on_node+0x40/0x40
ret_from_fork+0x27/0x40
Code: 14 01 0f 92 c0 84 c0 74 14 48 8b 05 14 4f f4 00 be fd 00 00 00 ff 90 a0 00 00 00 5d c3 89 fe 48 c7 c7 38 89 ca 9d e8 e5 56 08 00 <0f> ff 5d c3 0f 1f 44 00 00 8b 05 52 9e 37 02 85 c0 75 38 55 48
---[ end trace 26df9e5df4bba4ac ]---
This splat cannot be generated by expedited grace periods because they
always invoke resched_cpu() on the current CPU, which is good because
expedited grace periods require that resched_cpu() unconditionally
succeed. However, other parts of RCU can tolerate resched_cpu() acting
as a no-op, at least as long as it doesn't happen too often.
This commit therefore makes resched_cpu() invoke resched_curr() only if
the CPU is either online or is the current CPU.
[ Upstream commit 2fe2582649aa2355f79acddb86bd4d6c5363eb63 ]
rt_mutex_lock() which needs to boost the priority of a task currently
sitting on a runqueue that belongs to an offline CPU:
WARNING: CPU: 0 PID: 12 at /home/paulmck/public_git/linux-rcu/arch/x86/kernel/smp.c:128 native_smp_send_reschedule+0x37/0x40
Modules linked in:
CPU: 0 PID: 12 Comm: rcub/7 Not tainted 4.14.0-rc4+ #1
task: ffff9ed3de5f8cc0 task.stack: ffffbbf80012c000
RSP: 0018:ffffbbf80012fd10 EFLAGS: 00010082
RAX: 000000000000002f RBX: ffff9ed3dd9cb300 RCX: 0000000000000004
RDX: 0000000080000004 RSI: 0000000000000086 RDI: 00000000ffffffff
RBP: ffffbbf80012fd10 R08: 000000000009da7a R09: 0000000000007b9d
R10: 0000000000000001 R11: ffffffffbb57c2cd R12: 000000000000000d
R13: ffff9ed3de5f8cc0 R14: 0000000000000061 R15: ffff9ed3ded59200
FS: 0000000000000000(0000) GS:ffff9ed3dea00000(0000) knlGS:0000000000000000
CR2: 00000000080686f0 CR3: 000000001b9e0000 CR4: 00000000000006f0
Call Trace:
resched_curr+0x61/0xd0
switched_to_rt+0x8f/0xa0
rt_mutex_setprio+0x25c/0x410
task_blocks_on_rt_mutex+0x1b3/0x1f0
rt_mutex_slowlock+0xa9/0x1e0
rt_mutex_lock+0x29/0x30
rcu_boost_kthread+0x127/0x3c0
kthread+0x104/0x140
? rcu_report_unblock_qs_rnp+0x90/0x90
ret_from_fork+0x22/0x30
Code: f0 00 0f 92 c0 84 c0 74 14 48 8b 05 34 74 c5 00 be fd 00 00 00 ff 90 a0 00 00 00 5d c3 89 fe 48 c7 c7 a0 c6 fc b9 e8 d5 b5 06 00 <0f> ff 5d c3 0f 1f 44 00 00 8b 05 a2 d1 13 02 85 c0 75 38 55 48
But the target task's priority has already been adjusted, so the only
purpose of switched_to_rt() invoking resched_curr() is to wake up the
CPU running some task that needs to be preempted by the boosted task.
But the CPU is offline, which presumably means that the task must be
migrated to some other CPU, and that this other CPU will undertake any
needed preemption at the time of migration. Because the runqueue lock
is held when resched_curr() is invoked, we know that the boosted task
cannot go anywhere, so it is not necessary to invoke resched_curr()
in this particular case.
This commit therefore makes switched_to_rt() refrain from invoking
resched_curr() when the target CPU is offline.
[ Upstream commit 257ab443118bffc7fdcef38f49cf59be68a3e362 ]
Some console drivers code calls console_conditional_schedule()
that looks at @console_may_schedule. The value must be cleared
when the drivers are called from console_unlock() with
interrupts disabled. But rescheduling is fine when the same
code is called, for example, from tty operations where the
console semaphore is taken via console_lock().
This is why @console_may_schedule is cleared before calling console
drivers. The original value is stored to decide if we could sleep
between lines.
Now, @console_may_schedule is not cleared when we call
console_trylock() and jump back to the "again" goto label.
This has become a problem, since the commit 6b97a20d3a7909daa066
("printk: set may_schedule for some of console_trylock() callers").
@console_may_schedule might get enabled now.
There is also the opposite problem. console_lock() can be called
only from preemptive context. It can always enable scheduling in
the console code. But console_trylock() is not able to detect it
when CONFIG_PREEMPT_COUNT is disabled. Therefore we should use the
original @console_may_schedule value after re-acquiring
the console semaphore in console_unlock().
This patch solves both problems by moving the "again" goto label.
Alternative solution was to clear and restore the value around
call_console_drivers(). Then console_conditional_schedule() could
be used also inside console_unlock(). But there was a potential race
with console_flush_on_panic() as reported by Sergey Senozhatsky.
That function should be called only where there is only one CPU
and with interrupts disabled. But better be on the safe side
because stopping CPUs might fail.
Fixes: 6b97a20d3a7909 ("printk: set may_schedule for some of console_trylock() callers")
Link: http://lkml.kernel.org/r/1490372045-22288-1-git-send-email-pmladek@suse.com
Suggested-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Cc: Jiri Slaby <jslaby@suse.cz>
Cc: linux-fbdev@vger.kernel.org
Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Signed-off-by: Petr Mladek <pmladek@suse.com>
[ Upstream commit e0aad5b44ff5d28ac1d6ae70cdf84ca228e889dc ]
rt_mutex_waiter::prio is a copy of task_struct::prio which is updated
during the PI chain walk, such that the PI chain order isn't messed up
by (asynchronous) task state updates.
Currently rt_mutex_waiter_less() uses task state for deadline tasks;
this is broken, since the task state can, as said above, change
asynchronously, causing the RB tree order to change without actual
tree update -> FAIL.
Fix this by also copying the deadline into the rt_mutex_waiter state
and updating it along with its prio field.
Ideally we would also force PI chain updates whenever DL tasks update
their deadline parameter, but for first approximation this is less
broken than it was.
Cc: juri.lelli@arm.com
Cc: bigeasy@linutronix.de
Cc: xlpang@redhat.com
Cc: rostedt@goodmis.org
Cc: mathieu.desnoyers@efficios.com
Cc: jdesfossez@efficios.com
Cc: bristot@redhat.com
Link: http://lkml.kernel.org/r/20170323150216.403992539@infradead.org
[ Upstream commit 2ed2b8621be2708c0f6d61fe9841e9ad8b9753f0 ]
commit bbeddf52adc1 ("printk: move braille console support into
separate braille.[ch] files") introduced _braille_console_setup()
to outline the braille initialization code. There was however some
confusion over the value it was supposed to return. commit 2cfe6c4ac7ee
("printk: Fix return of braille_register_console()") tried to fix it
but failed to.
This fixes and documents the returned value according to the use
in printk.c: non-zero return means a parsing error, and thus this
console configuration should be ignored.
Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org>
Cc: Aleksey Makarov <aleksey.makarov@linaro.org>
Cc: Joe Perches <joe@perches.com>
Cc: Ming Lei <ming.lei@canonical.com>
Acked-by: Petr Mladek <pmladek@suse.com>
[ Upstream commit 0107042768658fea9f5f5a9c00b1c90f5dab6a06 ]
On systems with a large number of CPUs, running sysrq-<q> can cause
watchdog timeouts. There are two slow sections of code in the sysrq-<q>
path in timer_list.c.
1. print_active_timers() - This function is called by print_cpu() and
contains a slow goto loop. On a machine with hundreds of CPUs, this
loop took approximately 100ms for the first CPU in a NUMA node.
(Subsequent CPUs in the same node ran much quicker.) The total time
to print all of the CPUs is ultimately long enough to trigger the
soft lockup watchdog.
2. print_tickdevice() - This function outputs a large amount of textual
information. This function also took approximately 100ms per CPU.
Since sysrq-<q> is not a performance critical path, there should be no
harm in touching the nmi watchdog in both slow sections above. Touching
it in just one location was insufficient on systems with hundreds of
CPUs as occasional timeouts were still observed during testing.
This issue was observed on an Oracle T7 machine with 128 CPUs, but I
anticipate it may affect other systems with similarly large numbers of
CPUs.
Signed-off-by: Tom Hromatka <tom.hromatka@oracle.com>
Reviewed-by: Rob Gardner <rob.gardner@oracle.com>
Signed-off-by: John Stultz <john.stultz@linaro.org>
[ Upstream commit 1b8955bc5ac575009835e371ae55e7f3af2197a9 ]
The scheduler clock framework may not use the correct timeout for the clock
wrap. This happens when a new clock driver calls sched_clock_register()
after the kernel called sched_clock_postinit(). In this case the clock wrap
timeout is too long thus sched_clock_poll() is called too late and the clock
already wrapped.
On my ARM system the scheduler was no longer scheduling any other task than
the idle task because the sched_clock() wrapped.
Signed-off-by: David Engraf <david.engraf@sysgo.com>
commit 27d4ee03078aba88c5e07dcc4917e8d01d046f38 upstream.
Introduce a helper to retrieve the current task's work struct if it is
a workqueue worker.
This allows us to fix a long-standing deadlock in several DRM drivers
wherein the ->runtime_suspend callback waits for a specific worker to
finish and that worker in turn calls a function which waits for runtime
suspend to finish. That function is invoked from multiple call sites
and waiting for runtime suspend to finish is the correct thing to do
except if it's executing in the context of the worker.
Cc: Lai Jiangshan <jiangshanlai@gmail.com>
Cc: Dave Airlie <airlied@redhat.com>
Cc: Ben Skeggs <bskeggs@redhat.com>
Cc: Alex Deucher <alexander.deucher@amd.com>
Acked-by: Tejun Heo <tj@kernel.org>
Reviewed-by: Lyude Paul <lyude@redhat.com>
Signed-off-by: Lukas Wunner <lukas@wunner.de>
Link: https://patchwork.freedesktop.org/patch/msgid/2d8f603074131eb87e588d2b803a71765bd3a2fd.1518338788.git.lukas@wunner.de
[ upstream commit 32fff239de37ef226d5b66329dd133f64d63b22d ]
syszbot managed to trigger RCU detected stalls in
bpf_array_free_percpu()
It takes time to allocate a huge percpu map, but even more time to free
it.
Since we run in process context, use cond_resched() to yield cpu if
needed.
Fixes: a10423b87a7e ("bpf: introduce BPF_MAP_TYPE_PERCPU_ARRAY map")
Reported-by: syzbot <syzkaller@googlegroups.com>
[ upstream commit 9c2d63b843a5c8a8d0559cc067b5398aa5ec3ffc ]
syzkaller recently triggered OOM during percpu map allocation;
while there is work in progress by Dennis Zhou to add __GFP_NORETRY
semantics for percpu allocator under pressure, there seems also a
missing bpf_map_precharge_memlock() check in array map allocation.
Given today the actual bpf_map_charge_memlock() happens after the
find_and_alloc_map() in syscall path, the bpf_map_precharge_memlock()
is there to bail out early before we go and do the map setup work
when we find that we hit the limits anyway. Therefore add this for
array map as well.
Fixes: 6c9059817432 ("bpf: pre-allocate hash map elements")
Reported-by: syzbot+adb03f3f0bb57ce3acda@syzkaller.appspotmail.com
Cc: Dennis Zhou <dennisszhou@gmail.com>
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
[ upstream commit a316338cb71a3260201490e615f2f6d5c0d8fb2c ]
trie_alloc() always needs to have BPF_F_NO_PREALLOC passed in via
attr->map_flags, since it does not support preallocation yet. We
check the flag, but we never copy the flag into trie->map.map_flags,
which is later on exposed into fdinfo and used by loaders such as
iproute2. Latter uses this in bpf_map_selfcheck_pinned() to test
whether a pinned map has the same spec as the one from the BPF obj
file and if not, bails out, which is currently the case for lpm
since it exposes always 0 as flags.
Also copy over flags in array_map_alloc() and stack_map_alloc().
They always have to be 0 right now, but we should make sure to not
miss to copy them over at a later point in time when we add actual
flags for them to use.
Fixes: b95a5c4db09b ("bpf: add a longest prefix match trie map implementation")
Reported-by: Jarno Rajahalme <jarno@covalent.io>
Acked-by: Alexei Starovoitov <ast@kernel.org>
commit c52232a49e203a65a6e1a670cd5262f59e9364a0 upstream.
On CPU hotunplug the enqueued timers of the unplugged CPU are migrated to a
live CPU. This happens from the control thread which initiated the unplug.
If the CPU on which the control thread runs came out from a longer idle
period then the base clock of that CPU might be stale because the control
thread runs prior to any event which forwards the clock.
In such a case the timers from the unplugged CPU are queued on the live CPU
based on the stale clock which can cause large delays due to increased
granularity of the outer timer wheels which are far away from base:;clock.
But there is a worse problem than that. The following sequence of events
illustrates it:
- CPU0 timer1 is queued expires = 59969 and base->clk = 59131.
The timer is queued at wheel level 2, with resulting expiry time = 60032
(due to level granularity).
- CPU1 enters idle @60007, with next timer expiry @60020.
- CPU0 is hotplugged at @60009
- CPU1 exits idle and runs the control thread which migrates the
timers from CPU0
timer1 is now queued in level 0 for immediate handling in the next
softirq because the requested expiry time 59969 is before CPU1 base->clk
60007
- CPU1 runs code which forwards the base clock which succeeds because the
next expiring timer. which was collected at idle entry time is still set
to 60020.
So it forwards beyond 60007 and therefore misses to expire the migrated
timer1. That timer gets expired when the wheel wraps around again, which
takes between 63 and 630ms depending on the HZ setting.
Address both problems by invoking forward_timer_base() for the control CPUs
timer base. All other places, which might run into a similar problem
(mod_timer()/add_timer_on()) already invoke forward_timer_base() to avoid
that.
[ tglx: Massaged comment and changelog ]
Fixes: a683f390b93f ("timers: Forward the wheel clock whenever possible")
Co-developed-by: Neeraj Upadhyay <neeraju@codeaurora.org>
Signed-off-by: Neeraj Upadhyay <neeraju@codeaurora.org>
Signed-off-by: Lingutla Chandrasekhar <clingutla@codeaurora.org>
Cc: Anna-Maria Gleixner <anna-maria@linutronix.de>
Cc: linux-arm-msm@vger.kernel.org
Link: https://lkml.kernel.org/r/20180118115022.6368-1-clingutla@codeaurora.org
[ Upstream commit 11bca0a83f83f6093d816295668e74ef24595944 ]
An interrupt storm on a bad interrupt will cause the kernel
log to be clogged.
[ 60.089234] ->handle_irq(): ffffffffbe2f803f,
[ 60.090455] 0xffffffffbf2af380
[ 60.090510] handle_bad_irq+0x0/0x2e5
[ 60.090522] ->irq_data.chip(): ffffffffbf2af380,
[ 60.090553] IRQ_NOPROBE set
[ 60.090584] ->handle_irq(): ffffffffbe2f803f,
[ 60.090590] handle_bad_irq+0x0/0x2e5
[ 60.090596] ->irq_data.chip(): ffffffffbf2af380,
[ 60.090602] 0xffffffffbf2af380
[ 60.090608] ->action(): (null)
[ 60.090779] handle_bad_irq+0x0/0x2e5
This was seen when running an upstream kernel on Acer Chromebook R11. The
system was unstable as result.
Guard the log message with __printk_ratelimit to reduce the impact. This
won't prevent the interrupt storm from happening, but at least the system
remains stable.
Cc: Dmitry Torokhov <dtor@chromium.org>
Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Cc: Mika Westerberg <mika.westerberg@linux.intel.com>
Link: https://bugzilla.kernel.org/show_bug.cgi?id=197953
Link: https://lkml.kernel.org/r/1512234784-21038-1-git-send-email-linux@roeck-us.net
commit 48d0c9becc7f3c66874c100c126459a9da0fdced upstream.
The POSIX specification defines that relative CLOCK_REALTIME timers are not
affected by clock modifications. Those timers have to use CLOCK_MONOTONIC
to ensure POSIX compliance.
The introduction of the additional HRTIMER_MODE_PINNED mode broke this
requirement for pinned timers.
There is no user space visible impact because user space timers are not
using pinned mode, but for consistency reasons this needs to be fixed.
Check whether the mode has the HRTIMER_MODE_REL bit set instead of
comparing with HRTIMER_MODE_ABS.
Signed-off-by: Anna-Maria Gleixner <anna-maria@linutronix.de>
Cc: John Stultz <john.stultz@linaro.org>
Cc: keescook@chromium.org
Fixes: 597d0275736d ("timers: Framework for identifying pinned timers")
Link: http://lkml.kernel.org/r/20171221104205.7269-7-anna-maria@linutronix.de
commit 77dd66a3c67c93ab401ccc15efff25578be281fd upstream.
If devm_memremap_pages() detects a collision while adding entries
to the radix-tree, we call pgmap_radix_release(). Unfortunately,
the function removes *all* entries for the range -- including the
entries that caused the collision in the first place.
Modify pgmap_radix_release() to take an additional argument to
indicate where to stop, so that only newly added entries are removed
from the tree.
Fixes: 9476df7d80df ("mm: introduce find_dev_pagemap()")
Signed-off-by: Jan H. Schönherr <jschoenh@amazon.de>
commit a77660d231f8b3d84fd23ed482e0964f7aa546d6 upstream.
Currently KCOV_ENABLE does not check if the current task is already
associated with another kcov descriptor. As the result it is possible
to associate a single task with more than one kcov descriptor, which
later leads to a memory leak of the old descriptor. This relation is
really meant to be one-to-one (task has only one back link).
Extend validation to detect such misuse.
Link: http://lkml.kernel.org/r/20180122082520.15716-1-dvyukov@google.com
Fixes: 5c9a8750a640 ("kernel: add kcov code coverage")
Signed-off-by: Dmitry Vyukov <dvyukov@google.com>
Reported-by: Shankara Pailoor <sp3485@columbia.edu>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: syzbot <syzkaller@googlegroups.com>
commit a6da0024ffc19e0d47712bb5ca4fd083f76b07df upstream.
We need to ensure that tracepoints are registered and unregistered
with the users of them. The existing atomic count isn't enough for
that. Add a lock around the tracepoints, so we serialize access
to them.
This fixes cases where we have multiple users setting up and
tearing down tracepoints, like this:
CPU: 0 PID: 2995 Comm: syzkaller857118 Not tainted
4.14.0-rc5-next-20171018+ #36
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS
Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:16 [inline]
dump_stack+0x194/0x257 lib/dump_stack.c:52
panic+0x1e4/0x41c kernel/panic.c:183
__warn+0x1c4/0x1e0 kernel/panic.c:546
report_bug+0x211/0x2d0 lib/bug.c:183
fixup_bug+0x40/0x90 arch/x86/kernel/traps.c:177
do_trap_no_signal arch/x86/kernel/traps.c:211 [inline]
do_trap+0x260/0x390 arch/x86/kernel/traps.c:260
do_error_trap+0x120/0x390 arch/x86/kernel/traps.c:297
do_invalid_op+0x1b/0x20 arch/x86/kernel/traps.c:310
invalid_op+0x18/0x20 arch/x86/entry/entry_64.S:905
RIP: 0010:tracepoint_add_func kernel/tracepoint.c:210 [inline]
RIP: 0010:tracepoint_probe_register_prio+0x397/0x9a0 kernel/tracepoint.c:283
RSP: 0018:ffff8801d1d1f6c0 EFLAGS: 00010293
RAX: ffff8801d22e8540 RBX: 00000000ffffffef RCX: ffffffff81710f07
RDX: 0000000000000000 RSI: ffffffff85b679c0 RDI: ffff8801d5f19818
RBP: ffff8801d1d1f7c8 R08: ffffffff81710c10 R09: 0000000000000004
R10: ffff8801d1d1f6b0 R11: 0000000000000003 R12: ffffffff817597f0
R13: 0000000000000000 R14: 00000000ffffffff R15: ffff8801d1d1f7a0
tracepoint_probe_register+0x2a/0x40 kernel/tracepoint.c:304
register_trace_block_rq_insert include/trace/events/block.h:191 [inline]
blk_register_tracepoints+0x1e/0x2f0 kernel/trace/blktrace.c:1043
do_blk_trace_setup+0xa10/0xcf0 kernel/trace/blktrace.c:542
blk_trace_setup+0xbd/0x180 kernel/trace/blktrace.c:564
sg_ioctl+0xc71/0x2d90 drivers/scsi/sg.c:1089
vfs_ioctl fs/ioctl.c:45 [inline]
do_vfs_ioctl+0x1b1/0x1520 fs/ioctl.c:685
SYSC_ioctl fs/ioctl.c:700 [inline]
SyS_ioctl+0x8f/0xc0 fs/ioctl.c:691
entry_SYSCALL_64_fastpath+0x1f/0xbe
RIP: 0033:0x444339
RSP: 002b:00007ffe05bb5b18 EFLAGS: 00000206 ORIG_RAX: 0000000000000010
RAX: ffffffffffffffda RBX: 00000000006d66c0 RCX: 0000000000444339
RDX: 000000002084cf90 RSI: 00000000c0481273 RDI: 0000000000000009
RBP: 0000000000000082 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000206 R12: ffffffffffffffff
R13: 00000000c0481273 R14: 0000000000000000 R15: 0000000000000000
since we can now run these in parallel. Ensure that the exported helpers
for doing this are grabbing the queue trace mutex.
Reported-by: Steven Rostedt <rostedt@goodmis.org>
Tested-by: Dmitry Vyukov <dvyukov@google.com>
commit 10a0cd6e4932b5078215b1ec2c896597eec0eff9 upstream.
The functions devm_memremap_pages() and devm_memremap_pages_release() use
different ways to calculate the section-aligned amount of memory. The
latter function may use an incorrect size if the memory region is small
but straddles a section border.
Use the same code for both.
Fixes: 5f29a77cd957 ("mm: fix mixed zone detection in devm_memremap_pages")
commit 7b6586562708d2b3a04fe49f217ddbadbbbb0546 upstream.
__unregister_ftrace_function_probe() will incorrectly parse the glob filter
because it resets the search variable that was setup by filter_parse_regex().
Al Viro reported this:
After that call of filter_parse_regex() we could have func_g.search not
equal to glob only if glob started with '!' or '*'. In the former case
we would've buggered off with -EINVAL (not = 1). In the latter we
would've set func_g.search equal to glob + 1, calculated the length of
that thing in func_g.len and proceeded to reset func_g.search back to
glob.
Suppose the glob is e.g. *foo*. We end up with
func_g.type = MATCH_MIDDLE_ONLY;
func_g.len = 3;
func_g.search = "*foo";
Feeding that to ftrace_match_record() will not do anything sane - we
will be looking for names containing "*foo" (->len is ignored for that
one).
Link: http://lkml.kernel.org/r/20180127031706.GE13338@ZenIV.linux.org.uk
Fixes: 3ba009297149f ("ftrace: Introduce ftrace_glob structure")
Reviewed-by: Dmitry Safonov <0x7f454c46@gmail.com>
Reviewed-by: Masami Hiramatsu <mhiramat@kernel.org>
commit a1be1f3931bfe0a42b46fef77a04593c2b136e7f upstream.
This reverts commit ba62bafe942b ("kernel/relay.c: fix potential memory leak").
This commit introduced a double free bug, because 'chan' is already
freed by the line:
kref_put(&chan->kref, relay_destroy_channel);
This bug was found by syzkaller, using the BLKTRACESETUP ioctl.
Link: http://lkml.kernel.org/r/20180127004759.101823-1-ebiggers3@gmail.com
Fixes: ba62bafe942b ("kernel/relay.c: fix potential memory leak")
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
Cc: Zhouyi Zhou <yizhouzhou@ict.ac.cn>
commit 4f7e988e63e336827f4150de48163bed05d653bd upstream.
This reverts commit 92266d6ef60c ("async: simplify lowest_in_progress()")
which was simply wrong: In the case where domain is NULL, we now use the
wrong offsetof() in the list_first_entry macro, so we don't actually
fetch the ->cookie value, but rather the eight bytes located
sizeof(struct list_head) further into the struct async_entry.
On 64 bit, that's the data member, while on 32 bit, that's a u64 built
from func and data in some order.
I think the bug happens to be harmless in practice: It obviously only
affects callers which pass a NULL domain, and AFAICT the only such
caller is
async_synchronize_full() ->
async_synchronize_full_domain(NULL) ->
async_synchronize_cookie_domain(ASYNC_COOKIE_MAX, NULL)
and the ASYNC_COOKIE_MAX means that in practice we end up waiting for
the async_global_pending list to be empty - but it would break if
somebody happened to pass (void*)-1 as the data element to
async_schedule, and of course also if somebody ever does a
async_synchronize_cookie_domain(, NULL) with a "finite" cookie value.
Maybe the "harmless in practice" means this isn't -stable material. But
I'm not completely confident my quick git grep'ing is enough, and there
might be affected code in one of the earlier kernels that has since been
removed, so I'll leave the decision to the stable guys.
Link: http://lkml.kernel.org/r/20171128104938.3921-1-linux@rasmusvillemoes.dk
Fixes: 92266d6ef60c "async: simplify lowest_in_progress()"
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: Adam Wallis <awallis@codeaurora.org>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
commit 364f56653708ba8bcdefd4f0da2a42904baa8eeb upstream.
When issuing an IPI RT push, where an IPI is sent to each CPU that has more
than one RT task scheduled on it, it references the root domain's rto_mask,
that contains all the CPUs within the root domain that has more than one RT
task in the runable state. The problem is, after the IPIs are initiated, the
rq->lock is released. This means that the root domain that is associated to
the run queue could be freed while the IPIs are going around.
Add a sched_get_rd() and a sched_put_rd() that will increment and decrement
the root domain's ref count respectively. This way when initiating the IPIs,
the scheduler will up the root domain's ref count before releasing the
rq->lock, ensuring that the root domain does not go away until the IPI round
is complete.
Reported-by: Pavan Kondeti <pkondeti@codeaurora.org>
Fixes: 4bdced5c9a292 ("sched/rt: Simplify the IPI based RT balancing logic")
Link: http://lkml.kernel.org/r/CAEU1=PkiHO35Dzna8EQqNSKW1fr1y1zRQ5y66X117MG06sQtNA@mail.gmail.com
commit ad0f1d9d65938aec72a698116cd73a980916895e upstream.
When the rto_push_irq_work_func() is called, it looks at the RT overloaded
bitmask in the root domain via the runqueue (rq->rd). The problem is that
during CPU up and down, nothing here stops rq->rd from changing between
taking the rq->rd->rto_lock and releasing it. That means the lock that is
released is not the same lock that was taken.
Instead of using this_rq()->rd to get the root domain, as the irq work is
part of the root domain, we can simply get the root domain from the irq work
that is passed to the routine:
container_of(work, struct root_domain, rto_push_work)
This keeps the root domain consistent.
commit cef31d9af908243421258f1df35a4a644604efbe upstream.
timer_create() specifies via sigevent->sigev_notify the signal delivery for
the new timer. The valid modes are SIGEV_NONE, SIGEV_SIGNAL, SIGEV_THREAD
and (SIGEV_SIGNAL | SIGEV_THREAD_ID).
The sanity check in good_sigevent() is only checking the valid combination
for the SIGEV_THREAD_ID bit, i.e. SIGEV_SIGNAL, but if SIGEV_THREAD_ID is
not set it accepts any random value.
This has no real effects on the posix timer and signal delivery code, but
it affects show_timer() which handles the output of /proc/$PID/timers. That
function uses a string array to pretty print sigev_notify. The access to
that array has no bound checks, so random sigev_notify cause access beyond
the array bounds.
Add proper checks for the valid notify modes and remove the SIGEV_THREAD_ID
masking from various code pathes as SIGEV_NONE can never be set in
combination with SIGEV_THREAD_ID.
Reported-by: Eric Biggers <ebiggers3@gmail.com>
Reported-by: Alexey Dobriyan <adobriyan@gmail.com>
(cherry picked from commit caf7501a1b4ec964190f31f9c3f163de252273b8)
There's a risk that a kernel which has full retpoline mitigations becomes
vulnerable when a module gets loaded that hasn't been compiled with the
right compiler or the right option.
To enable detection of that mismatch at module load time, add a module info
string "retpoline" at build time when the module was compiled with
retpoline support. This only covers compiled C source, but assembler source
or prebuilt object files are not checked.
If a retpoline enabled kernel detects a non retpoline protected module at
load time, print a warning and report it in the sysfs vulnerability file.
[ tglx: Massaged changelog ]
Cc: gregkh@linuxfoundation.org
Cc: torvalds@linux-foundation.org
Cc: jeyu@kernel.org
Cc: arjan@linux.intel.com
Link: https://lkml.kernel.org/r/20180125235028.31211-1-andi@firstfloor.org
Signed-off-by: David Woodhouse <dwmw@amazon.co.uk>
[ upstream commit f37a8cb84cce18762e8f86a70bd6a49a66ab964c ]
Alexei found that verifier does not reject stores into context
via BPF_ST instead of BPF_STX. And while looking at it, we
also should not allow XADD variant of BPF_STX.
The context rewriter is only assuming either BPF_LDX_MEM- or
BPF_STX_MEM-type operations, thus reject anything other than
that so that assumptions in the rewriter properly hold. Add
test cases as well for BPF selftests.
Fixes: d691f9e8d440 ("bpf: allow programs to write to certain skb fields")
Reported-by: Alexei Starovoitov <ast@kernel.org>
[ upstream commit 68fda450a7df51cff9e5a4d4a4d9d0d5f2589153 ]
due to some JITs doing if (src_reg == 0) check in 64-bit mode
for div/mod operations mask upper 32-bits of src register
before doing the check
Fixes: 622582786c9e ("net: filter: x86: internal BPF JIT")
Fixes: 7a12b5031c6b ("sparc64: Add eBPF JIT.")
Reported-by: syzbot+48340bb518e88849e2e3@syzkaller.appspotmail.com
[ upstream commit c366287ebd698ef5e3de300d90cd62ee9ee7373e ]
Divides by zero are not nice, lets avoid them if possible.
Also do_div() seems not needed when dealing with 32bit operands,
but this seems a minor detail.
Fixes: bd4cf0ed331a ("net: filter: rework/optimize internal BPF interpreter's instruction set")
[ upstream commit 7891a87efc7116590eaba57acc3c422487802c6f ]
The following snippet was throwing an 'unknown opcode cc' warning
in BPF interpreter:
0: (18) r0 = 0x0
2: (7b) *(u64 *)(r10 -16) = r0
3: (cc) (u32) r0 s>>= (u32) r0
4: (95) exit
Although a number of JITs do support BPF_ALU | BPF_ARSH | BPF_{K,X}
generation, not all of them do and interpreter does neither. We can
leave existing ones and implement it later in bpf-next for the
remaining ones, but reject this properly in verifier for the time
being.
Fixes: 17a5267067f3 ("bpf: verifier (add verifier core)")
Reported-by: syzbot+93c4904c5c70348a6890@syzkaller.appspotmail.com
[ upstream commit 290af86629b25ffd1ed6232c4e9107da031705cb ]
The BPF interpreter has been used as part of the spectre 2 attack CVE-2017-5715.
A quote from goolge project zero blog:
"At this point, it would normally be necessary to locate gadgets in
the host kernel code that can be used to actually leak data by reading
from an attacker-controlled location, shifting and masking the result
appropriately and then using the result of that as offset to an
attacker-controlled address for a load. But piecing gadgets together
and figuring out which ones work in a speculation context seems annoying.
So instead, we decided to use the eBPF interpreter, which is built into
the host kernel - while there is no legitimate way to invoke it from inside
a VM, the presence of the code in the host kernel's text section is sufficient
to make it usable for the attack, just like with ordinary ROP gadgets."
To make attacker job harder introduce BPF_JIT_ALWAYS_ON config
option that removes interpreter from the kernel in favor of JIT-only mode.
So far eBPF JIT is supported by:
x64, arm64, arm32, sparc64, s390, powerpc64, mips64
The start of JITed program is randomized and code page is marked as read-only.
In addition "constant blinding" can be turned on with net.core.bpf_jit_harden
v2->v3:
- move __bpf_prog_ret0 under ifdef (Daniel)
v1->v2:
- fix init order, test_bpf and cBPF (Daniel's feedback)
- fix offloaded bpf (Jakub's feedback)
- add 'return 0' dummy in case something can invoke prog->bpf_func
- retarget bpf tree. For bpf-next the patch would need one extra hunk.
It will be sent when the trees are merged back to net-next
Considered doing:
int bpf_jit_enable __read_mostly = BPF_EBPF_JIT_DEFAULT;
but it seems better to land the patch as-is and in bpf-next remove
bpf_jit_enable global variable from all JITs, consolidate in one place
and remove this jit_init() function.
[ upstream commit 90caccdd8cc0215705f18b92771b449b01e2474a ]
- bpf prog_array just like all other types of bpf array accepts 32-bit index.
Clarify that in the comment.
- fix x64 JIT of bpf_tail_call which was incorrectly loading 8 instead of 4 bytes
- tighten corresponding check in the interpreter to stay consistent
The JIT bug can be triggered after introduction of BPF_F_NUMA_NODE flag
in commit 96eabe7a40aa in 4.14. Before that the map_flags would stay zero and
though JIT code is wrong it will check bounds correctly.
Hence two fixes tags. All other JITs don't have this problem.
Fixes: 96eabe7a40aa ("bpf: Allow selecting numa node during map creation")
Fixes: b52f00e6a715 ("x86: bpf_jit: implement bpf_tail_call() helper")
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
Acked-by: Martin KaFai Lau <kafai@fb.com>
Reviewed-by: Eric Dumazet <edumazet@google.com>
commit d5421ea43d30701e03cadc56a38854c36a8b4433 upstream.
The hrtimer interrupt code contains a hang detection and mitigation
mechanism, which prevents that a long delayed hrtimer interrupt causes a
continous retriggering of interrupts which prevent the system from making
progress. If a hang is detected then the timer hardware is programmed with
a certain delay into the future and a flag is set in the hrtimer cpu base
which prevents newly enqueued timers from reprogramming the timer hardware
prior to the chosen delay. The subsequent hrtimer interrupt after the delay
clears the flag and resumes normal operation.
If such a hang happens in the last hrtimer interrupt before a CPU is
unplugged then the hang_detected flag is set and stays that way when the
CPU is plugged in again. At that point the timer hardware is not armed and
it cannot be armed because the hang_detected flag is still active, so
nothing clears that flag. As a consequence the CPU does not receive hrtimer
interrupts and no timers expire on that CPU which results in RCU stalls and
other malfunctions.
Clear the flag along with some other less critical members of the hrtimer
cpu base to ensure starting from a clean state when a CPU is plugged in.
Thanks to Paul, Sebastian and Anna-Maria for their help to get down to the
root cause of that hard to reproduce heisenbug. Once understood it's
trivial and certainly justifies a brown paperbag.
Fixes: 41d2e4949377 ("hrtimer: Tune hrtimer_interrupt hang logic")
Reported-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Sebastian Sewior <bigeasy@linutronix.de>
Link: https://lkml.kernel.org/r/alpine.DEB.2.20.1801261447590.2067@nanos
commit 62635ea8c18f0f62df4cc58379e4f1d33afd5801 upstream.
show_workqueue_state() can print out a lot of messages while being in
atomic context, e.g. sysrq-t -> show_workqueue_state(). If the console
device is slow it may end up triggering NMI hard lockup watchdog.
Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
