path: root/kernel
2017-09-02locking/spinlock/debug: Remove spinlock lockup detection codeWaiman Long
commit bc88c10d7e6900916f5e1ba3829d66a9de92b633 upstream. The current spinlock lockup detection code can sometimes produce false positives because of the unfairness of the locking algorithm itself. So the lockup detection code is now removed. Instead, we are relying on the NMI watchdog to detect potential lockup. We won't have lockup detection if the watchdog isn't running. The commented-out read-write lock lockup detection code are also removed. Signed-off-by: Waiman Long <longman@redhat.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1486583208-11038-1-git-send-email-longman@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-02gcov: support GCC 7.1Martin Liska
commit 05384213436ab690c46d9dfec706b80ef8d671ab upstream. Starting from GCC 7.1, __gcov_exit is a new symbol expected to be implemented in a profiling runtime. [akpm@linux-foundation.org: coding-style fixes] [mliska@suse.cz: v2] Link: http://lkml.kernel.org/r/e63a3c59-0149-c97e-4084-20ca8f146b26@suse.cz Link: http://lkml.kernel.org/r/8c4084fa-3885-29fe-5fc4-0d4ca199c785@suse.cz Signed-off-by: Martin Liska <mliska@suse.cz> Acked-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-30timers: Fix excessive granularity of new timers after a nohz idleNicholas Piggin
commit 2fe59f507a65dbd734b990a11ebc7488f6f87a24 upstream. When a timer base is idle, it is forwarded when a new timer is added to ensure that granularity does not become excessive. When not idle, the timer tick is expected to increment the base. However there are several problems: - If an existing timer is modified, the base is forwarded only after the index is calculated. - The base is not forwarded by add_timer_on. - There is a window after a timer is restarted from a nohz idle, after it is marked not-idle and before the timer tick on this CPU, where a timer may be added but the ancient base does not get forwarded. These result in excessive granularity (a 1 jiffy timeout can blow out to 100s of jiffies), which cause the rcu lockup detector to trigger, among other things. Fix this by keeping track of whether the timer base has been idle since it was last run or forwarded, and if so then forward it before adding a new timer. There is still a case where mod_timer optimises the case of a pending timer mod with the same expiry time, where the timer can see excessive granularity relative to the new, shorter interval. A comment is added, but it's not changed because it is an important fastpath for networking. This has been tested and found to fix the RCU softlockup messages. Testing was also done with tracing to measure requested versus achieved wakeup latencies for all non-deferrable timers in an idle system (with no lockup watchdogs running). Wakeup latency relative to absolute latency is calculated (note this suffers from round-up skew at low absolute times) and analysed: max avg std upstream 506.0 1.20 4.68 patched 2.0 1.08 0.15 The bug was noticed due to the lockup detector Kconfig changes dropping it out of people's .configs and resulting in larger base clk skew When the lockup detectors are enabled, no CPU can go idle for longer than 4 seconds, which limits the granularity errors. Sub-optimal timer behaviour is observable on a smaller scale in that case: max avg std upstream 9.0 1.05 0.19 patched 2.0 1.04 0.11 Fixes: Fixes: a683f390b93f ("timers: Forward the wheel clock whenever possible") Signed-off-by: Nicholas Piggin <npiggin@gmail.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Jonathan Cameron <Jonathan.Cameron@huawei.com> Tested-by: David Miller <davem@davemloft.net> Cc: dzickus@redhat.com Cc: sfr@canb.auug.org.au Cc: mpe@ellerman.id.au Cc: Stephen Boyd <sboyd@codeaurora.org> Cc: linuxarm@huawei.com Cc: abdhalee@linux.vnet.ibm.com Cc: John Stultz <john.stultz@linaro.org> Cc: akpm@linux-foundation.org Cc: paulmck@linux.vnet.ibm.com Cc: torvalds@linux-foundation.org Link: http://lkml.kernel.org/r/20170822084348.21436-1-npiggin@gmail.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-30perf/core: Fix group {cpu,task} validationMark Rutland
commit 64aee2a965cf2954a038b5522f11d2cd2f0f8f3e upstream. Regardless of which events form a group, it does not make sense for the events to target different tasks and/or CPUs, as this leaves the group inconsistent and impossible to schedule. The core perf code assumes that these are consistent across (successfully intialised) groups. Core perf code only verifies this when moving SW events into a HW context. Thus, we can violate this requirement for pure SW groups and pure HW groups, unless the relevant PMU driver happens to perform this verification itself. These mismatched groups subsequently wreak havoc elsewhere. For example, we handle watchpoints as SW events, and reserve watchpoint HW on a per-CPU basis at pmu::event_init() time to ensure that any event that is initialised is guaranteed to have a slot at pmu::add() time. However, the core code only checks the group leader's cpu filter (via event_filter_match()), and can thus install follower events onto CPUs violating thier (mismatched) CPU filters, potentially installing them into a CPU without sufficient reserved slots. This can be triggered with the below test case, resulting in warnings from arch backends. #define _GNU_SOURCE #include <linux/hw_breakpoint.h> #include <linux/perf_event.h> #include <sched.h> #include <stdio.h> #include <sys/prctl.h> #include <sys/syscall.h> #include <unistd.h> static int perf_event_open(struct perf_event_attr *attr, pid_t pid, int cpu, int group_fd, unsigned long flags) { return syscall(__NR_perf_event_open, attr, pid, cpu, group_fd, flags); } char watched_char; struct perf_event_attr wp_attr = { .type = PERF_TYPE_BREAKPOINT, .bp_type = HW_BREAKPOINT_RW, .bp_addr = (unsigned long)&watched_char, .bp_len = 1, .size = sizeof(wp_attr), }; int main(int argc, char *argv[]) { int leader, ret; cpu_set_t cpus; /* * Force use of CPU0 to ensure our CPU0-bound events get scheduled. */ CPU_ZERO(&cpus); CPU_SET(0, &cpus); ret = sched_setaffinity(0, sizeof(cpus), &cpus); if (ret) { printf("Unable to set cpu affinity\n"); return 1; } /* open leader event, bound to this task, CPU0 only */ leader = perf_event_open(&wp_attr, 0, 0, -1, 0); if (leader < 0) { printf("Couldn't open leader: %d\n", leader); return 1; } /* * Open a follower event that is bound to the same task, but a * different CPU. This means that the group should never be possible to * schedule. */ ret = perf_event_open(&wp_attr, 0, 1, leader, 0); if (ret < 0) { printf("Couldn't open mismatched follower: %d\n", ret); return 1; } else { printf("Opened leader/follower with mismastched CPUs\n"); } /* * Open as many independent events as we can, all bound to the same * task, CPU0 only. */ do { ret = perf_event_open(&wp_attr, 0, 0, -1, 0); } while (ret >= 0); /* * Force enable/disble all events to trigger the erronoeous * installation of the follower event. */ printf("Opened all events. Toggling..\n"); for (;;) { prctl(PR_TASK_PERF_EVENTS_DISABLE, 0, 0, 0, 0); prctl(PR_TASK_PERF_EVENTS_ENABLE, 0, 0, 0, 0); } return 0; } Fix this by validating this requirement regardless of whether we're moving events. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Zhou Chengming <zhouchengming1@huawei.com> Link: http://lkml.kernel.org/r/1498142498-15758-1-git-send-email-mark.rutland@arm.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-30ftrace: Check for null ret_stack on profile function graph entry functionSteven Rostedt (VMware)
commit a8f0f9e49956a74718874b800251455680085600 upstream. There's a small race when function graph shutsdown and the calling of the registered function graph entry callback. The callback must not reference the task's ret_stack without first checking that it is not NULL. Note, when a ret_stack is allocated for a task, it stays allocated until the task exits. The problem here, is that function_graph is shutdown, and a new task was created, which doesn't have its ret_stack allocated. But since some of the functions are still being traced, the callbacks can still be called. The normal function_graph code handles this, but starting with commit 8861dd303c ("ftrace: Access ret_stack->subtime only in the function profiler") the profiler code references the ret_stack on function entry, but doesn't check if it is NULL first. Link: https://bugzilla.kernel.org/show_bug.cgi?id=196611 Fixes: 8861dd303c ("ftrace: Access ret_stack->subtime only in the function profiler") Reported-by: lilydjwg@gmail.com Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-30tracing: Fix freeing of filter in create_filter() when set_str is falseSteven Rostedt (VMware)
commit 8b0db1a5bdfcee0dbfa89607672598ae203c9045 upstream. Performing the following task with kmemleak enabled: # cd /sys/kernel/tracing/events/irq/irq_handler_entry/ # echo 'enable_event:kmem:kmalloc:3 if irq >' > trigger # echo 'enable_event:kmem:kmalloc:3 if irq > 31' > trigger # echo scan > /sys/kernel/debug/kmemleak # cat /sys/kernel/debug/kmemleak unreferenced object 0xffff8800b9290308 (size 32): comm "bash", pid 1114, jiffies 4294848451 (age 141.139s) hex dump (first 32 bytes): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ backtrace: [<ffffffff81cef5aa>] kmemleak_alloc+0x4a/0xa0 [<ffffffff81357938>] kmem_cache_alloc_trace+0x158/0x290 [<ffffffff81261c09>] create_filter_start.constprop.28+0x99/0x940 [<ffffffff812639c9>] create_filter+0xa9/0x160 [<ffffffff81263bdc>] create_event_filter+0xc/0x10 [<ffffffff812655e5>] set_trigger_filter+0xe5/0x210 [<ffffffff812660c4>] event_enable_trigger_func+0x324/0x490 [<ffffffff812652e2>] event_trigger_write+0x1a2/0x260 [<ffffffff8138cf87>] __vfs_write+0xd7/0x380 [<ffffffff8138f421>] vfs_write+0x101/0x260 [<ffffffff8139187b>] SyS_write+0xab/0x130 [<ffffffff81cfd501>] entry_SYSCALL_64_fastpath+0x1f/0xbe [<ffffffffffffffff>] 0xffffffffffffffff The function create_filter() is passed a 'filterp' pointer that gets allocated, and if "set_str" is true, it is up to the caller to free it, even on error. The problem is that the pointer is not freed by create_filter() when set_str is false. This is a bug, and it is not up to the caller to free the filter on error if it doesn't care about the string. Link: http://lkml.kernel.org/r/1502705898-27571-2-git-send-email-chuhu@redhat.com Fixes: 38b78eb85 ("tracing: Factorize filter creation") Reported-by: Chunyu Hu <chuhu@redhat.com> Tested-by: Chunyu Hu <chuhu@redhat.com> Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-30tracing: Fix kmemleak in tracing_map_array_free()Chunyu Hu
commit 475bb3c69ab05df2a6ecef6acc2393703d134180 upstream. kmemleak reported the below leak when I was doing clear of the hist trigger. With this patch, the kmeamleak is gone. unreferenced object 0xffff94322b63d760 (size 32): comm "bash", pid 1522, jiffies 4403687962 (age 2442.311s) hex dump (first 32 bytes): 00 01 00 00 04 00 00 00 08 00 00 00 ff 00 00 00 ................ 10 00 00 00 00 00 00 00 80 a8 7a f2 31 94 ff ff ..........z.1... backtrace: [<ffffffff9e96c27a>] kmemleak_alloc+0x4a/0xa0 [<ffffffff9e424cba>] kmem_cache_alloc_trace+0xca/0x1d0 [<ffffffff9e377736>] tracing_map_array_alloc+0x26/0x140 [<ffffffff9e261be0>] kretprobe_trampoline+0x0/0x50 [<ffffffff9e38b935>] create_hist_data+0x535/0x750 [<ffffffff9e38bd47>] event_hist_trigger_func+0x1f7/0x420 [<ffffffff9e38893d>] event_trigger_write+0xfd/0x1a0 [<ffffffff9e44dfc7>] __vfs_write+0x37/0x170 [<ffffffff9e44f552>] vfs_write+0xb2/0x1b0 [<ffffffff9e450b85>] SyS_write+0x55/0xc0 [<ffffffff9e203857>] do_syscall_64+0x67/0x150 [<ffffffff9e977ce7>] return_from_SYSCALL_64+0x0/0x6a [<ffffffffffffffff>] 0xffffffffffffffff unreferenced object 0xffff9431f27aa880 (size 128): comm "bash", pid 1522, jiffies 4403687962 (age 2442.311s) hex dump (first 32 bytes): 00 00 8c 2a 32 94 ff ff 00 f0 8b 2a 32 94 ff ff ...*2......*2... 00 e0 8b 2a 32 94 ff ff 00 d0 8b 2a 32 94 ff ff ...*2......*2... backtrace: [<ffffffff9e96c27a>] kmemleak_alloc+0x4a/0xa0 [<ffffffff9e425348>] __kmalloc+0xe8/0x220 [<ffffffff9e3777c1>] tracing_map_array_alloc+0xb1/0x140 [<ffffffff9e261be0>] kretprobe_trampoline+0x0/0x50 [<ffffffff9e38b935>] create_hist_data+0x535/0x750 [<ffffffff9e38bd47>] event_hist_trigger_func+0x1f7/0x420 [<ffffffff9e38893d>] event_trigger_write+0xfd/0x1a0 [<ffffffff9e44dfc7>] __vfs_write+0x37/0x170 [<ffffffff9e44f552>] vfs_write+0xb2/0x1b0 [<ffffffff9e450b85>] SyS_write+0x55/0xc0 [<ffffffff9e203857>] do_syscall_64+0x67/0x150 [<ffffffff9e977ce7>] return_from_SYSCALL_64+0x0/0x6a [<ffffffffffffffff>] 0xffffffffffffffff Link: http://lkml.kernel.org/r/1502705898-27571-1-git-send-email-chuhu@redhat.com Fixes: 08d43a5fa063 ("tracing: Add lock-free tracing_map") Signed-off-by: Chunyu Hu <chuhu@redhat.com> Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-30tracing: Call clear_boot_tracer() at lateinit_syncSteven Rostedt (VMware)
commit 4bb0f0e73c8c30917d169c4a0f1ac083690c545b upstream. The clear_boot_tracer function is used to reset the default_bootup_tracer string to prevent it from being accessed after boot, as it originally points to init data. But since clear_boot_tracer() is called via the init_lateinit() call, it races with the initcall for registering the hwlat tracer. If someone adds "ftrace=hwlat" to the kernel command line, depending on how the linker sets up the text, the saved command line may be cleared, and the hwlat tracer never is initialized. Simply have the clear_boot_tracer() be called by initcall_lateinit_sync() as that's for tasks to be called after lateinit. Link: https://bugzilla.kernel.org/show_bug.cgi?id=196551 Fixes: e7c15cd8a ("tracing: Added hardware latency tracer") Reported-by: Zamir SUN <sztsian@gmail.com> Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-30fork: fix incorrect fput of ->exe_file causing use-after-freeEric Biggers
commit 2b7e8665b4ff51c034c55df3cff76518d1a9ee3a upstream. Commit 7c051267931a ("mm, fork: make dup_mmap wait for mmap_sem for write killable") made it possible to kill a forking task while it is waiting to acquire its ->mmap_sem for write, in dup_mmap(). However, it was overlooked that this introduced an new error path before a reference is taken on the mm_struct's ->exe_file. Since the ->exe_file of the new mm_struct was already set to the old ->exe_file by the memcpy() in dup_mm(), it was possible for the mmput() in the error path of dup_mm() to drop a reference to ->exe_file which was never taken. This caused the struct file to later be freed prematurely. Fix it by updating mm_init() to NULL out the ->exe_file, in the same place it clears other things like the list of mmaps. This bug was found by syzkaller. It can be reproduced using the following C program: #define _GNU_SOURCE #include <pthread.h> #include <stdlib.h> #include <sys/mman.h> #include <sys/syscall.h> #include <sys/wait.h> #include <unistd.h> static void *mmap_thread(void *_arg) { for (;;) { mmap(NULL, 0x1000000, PROT_READ, MAP_POPULATE|MAP_ANONYMOUS|MAP_PRIVATE, -1, 0); } } static void *fork_thread(void *_arg) { usleep(rand() % 10000); fork(); } int main(void) { fork(); fork(); fork(); for (;;) { if (fork() == 0) { pthread_t t; pthread_create(&t, NULL, mmap_thread, NULL); pthread_create(&t, NULL, fork_thread, NULL); usleep(rand() % 10000); syscall(__NR_exit_group, 0); } wait(NULL); } } No special kernel config options are needed. It usually causes a NULL pointer dereference in __remove_shared_vm_struct() during exit, or in dup_mmap() (which is usually inlined into copy_process()) during fork. Both are due to a vm_area_struct's ->vm_file being used after it's already been freed. Google Bug Id: 64772007 Link: http://lkml.kernel.org/r/20170823211408.31198-1-ebiggers3@gmail.com Fixes: 7c051267931a ("mm, fork: make dup_mmap wait for mmap_sem for write killable") Signed-off-by: Eric Biggers <ebiggers@google.com> Tested-by: Mark Rutland <mark.rutland@arm.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-30bpf/verifier: fix min/max handling in BPF_SUBEdward Cree
[ Upstream commit 9305706c2e808ae59f1eb201867f82f1ddf6d7a6 ] We have to subtract the src max from the dst min, and vice-versa, since (e.g.) the smallest result comes from the largest subtrahend. Fixes: 484611357c19 ("bpf: allow access into map value arrays") Signed-off-by: Edward Cree <ecree@solarflare.com> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-30bpf: fix mixed signed/unsigned derived min/max value boundsDaniel Borkmann
[ Upstream commit 4cabc5b186b5427b9ee5a7495172542af105f02b ] Edward reported that there's an issue in min/max value bounds tracking when signed and unsigned compares both provide hints on limits when having unknown variables. E.g. a program such as the following should have been rejected: 0: (7a) *(u64 *)(r10 -8) = 0 1: (bf) r2 = r10 2: (07) r2 += -8 3: (18) r1 = 0xffff8a94cda93400 5: (85) call bpf_map_lookup_elem#1 6: (15) if r0 == 0x0 goto pc+7 R0=map_value(ks=8,vs=8,id=0),min_value=0,max_value=0 R10=fp 7: (7a) *(u64 *)(r10 -16) = -8 8: (79) r1 = *(u64 *)(r10 -16) 9: (b7) r2 = -1 10: (2d) if r1 > r2 goto pc+3 R0=map_value(ks=8,vs=8,id=0),min_value=0,max_value=0 R1=inv,min_value=0 R2=imm-1,max_value=18446744073709551615,min_align=1 R10=fp 11: (65) if r1 s> 0x1 goto pc+2 R0=map_value(ks=8,vs=8,id=0),min_value=0,max_value=0 R1=inv,min_value=0,max_value=1 R2=imm-1,max_value=18446744073709551615,min_align=1 R10=fp 12: (0f) r0 += r1 13: (72) *(u8 *)(r0 +0) = 0 R0=map_value_adj(ks=8,vs=8,id=0),min_value=0,max_value=1 R1=inv,min_value=0,max_value=1 R2=imm-1,max_value=18446744073709551615,min_align=1 R10=fp 14: (b7) r0 = 0 15: (95) exit What happens is that in the first part ... 8: (79) r1 = *(u64 *)(r10 -16) 9: (b7) r2 = -1 10: (2d) if r1 > r2 goto pc+3 ... r1 carries an unsigned value, and is compared as unsigned against a register carrying an immediate. Verifier deduces in reg_set_min_max() that since the compare is unsigned and operation is greater than (>), that in the fall-through/false case, r1's minimum bound must be 0 and maximum bound must be r2. Latter is larger than the bound and thus max value is reset back to being 'invalid' aka BPF_REGISTER_MAX_RANGE. Thus, r1 state is now 'R1=inv,min_value=0'. The subsequent test ... 11: (65) if r1 s> 0x1 goto pc+2 ... is a signed compare of r1 with immediate value 1. Here, verifier deduces in reg_set_min_max() that since the compare is signed this time and operation is greater than (>), that in the fall-through/false case, we can deduce that r1's maximum bound must be 1, meaning with prior test, we result in r1 having the following state: R1=inv,min_value=0,max_value=1. Given that the actual value this holds is -8, the bounds are wrongly deduced. When this is being added to r0 which holds the map_value(_adj) type, then subsequent store access in above case will go through check_mem_access() which invokes check_map_access_adj(), that will then probe whether the map memory is in bounds based on the min_value and max_value as well as access size since the actual unknown value is min_value <= x <= max_value; commit fce366a9dd0d ("bpf, verifier: fix alu ops against map_value{, _adj} register types") provides some more explanation on the semantics. It's worth to note in this context that in the current code, min_value and max_value tracking are used for two things, i) dynamic map value access via check_map_access_adj() and since commit 06c1c049721a ("bpf: allow helpers access to variable memory") ii) also enforced at check_helper_mem_access() when passing a memory address (pointer to packet, map value, stack) and length pair to a helper and the length in this case is an unknown value defining an access range through min_value/max_value in that case. The min_value/max_value tracking is /not/ used in the direct packet access case to track ranges. However, the issue also affects case ii), for example, the following crafted program based on the same principle must be rejected as well: 0: (b7) r2 = 0 1: (bf) r3 = r10 2: (07) r3 += -512 3: (7a) *(u64 *)(r10 -16) = -8 4: (79) r4 = *(u64 *)(r10 -16) 5: (b7) r6 = -1 6: (2d) if r4 > r6 goto pc+5 R1=ctx R2=imm0,min_value=0,max_value=0,min_align=2147483648 R3=fp-512 R4=inv,min_value=0 R6=imm-1,max_value=18446744073709551615,min_align=1 R10=fp 7: (65) if r4 s> 0x1 goto pc+4 R1=ctx R2=imm0,min_value=0,max_value=0,min_align=2147483648 R3=fp-512 R4=inv,min_value=0,max_value=1 R6=imm-1,max_value=18446744073709551615,min_align=1 R10=fp 8: (07) r4 += 1 9: (b7) r5 = 0 10: (6a) *(u16 *)(r10 -512) = 0 11: (85) call bpf_skb_load_bytes#26 12: (b7) r0 = 0 13: (95) exit Meaning, while we initialize the max_value stack slot that the verifier thinks we access in the [1,2] range, in reality we pass -7 as length which is interpreted as u32 in the helper. Thus, this issue is relevant also for the case of helper ranges. Resetting both bounds in check_reg_overflow() in case only one of them exceeds limits is also not enough as similar test can be created that uses values which are within range, thus also here learned min value in r1 is incorrect when mixed with later signed test to create a range: 0: (7a) *(u64 *)(r10 -8) = 0 1: (bf) r2 = r10 2: (07) r2 += -8 3: (18) r1 = 0xffff880ad081fa00 5: (85) call bpf_map_lookup_elem#1 6: (15) if r0 == 0x0 goto pc+7 R0=map_value(ks=8,vs=8,id=0),min_value=0,max_value=0 R10=fp 7: (7a) *(u64 *)(r10 -16) = -8 8: (79) r1 = *(u64 *)(r10 -16) 9: (b7) r2 = 2 10: (3d) if r2 >= r1 goto pc+3 R0=map_value(ks=8,vs=8,id=0),min_value=0,max_value=0 R1=inv,min_value=3 R2=imm2,min_value=2,max_value=2,min_align=2 R10=fp 11: (65) if r1 s> 0x4 goto pc+2 R0=map_value(ks=8,vs=8,id=0),min_value=0,max_value=0 R1=inv,min_value=3,max_value=4 R2=imm2,min_value=2,max_value=2,min_align=2 R10=fp 12: (0f) r0 += r1 13: (72) *(u8 *)(r0 +0) = 0 R0=map_value_adj(ks=8,vs=8,id=0),min_value=3,max_value=4 R1=inv,min_value=3,max_value=4 R2=imm2,min_value=2,max_value=2,min_align=2 R10=fp 14: (b7) r0 = 0 15: (95) exit This leaves us with two options for fixing this: i) to invalidate all prior learned information once we switch signed context, ii) to track min/max signed and unsigned boundaries separately as done in [0]. (Given latter introduces major changes throughout the whole verifier, it's rather net-next material, thus this patch follows option i), meaning we can derive bounds either from only signed tests or only unsigned tests.) There is still the case of adjust_reg_min_max_vals(), where we adjust bounds on ALU operations, meaning programs like the following where boundaries on the reg get mixed in context later on when bounds are merged on the dst reg must get rejected, too: 0: (7a) *(u64 *)(r10 -8) = 0 1: (bf) r2 = r10 2: (07) r2 += -8 3: (18) r1 = 0xffff89b2bf87ce00 5: (85) call bpf_map_lookup_elem#1 6: (15) if r0 == 0x0 goto pc+6 R0=map_value(ks=8,vs=8,id=0),min_value=0,max_value=0 R10=fp 7: (7a) *(u64 *)(r10 -16) = -8 8: (79) r1 = *(u64 *)(r10 -16) 9: (b7) r2 = 2 10: (3d) if r2 >= r1 goto pc+2 R0=map_value(ks=8,vs=8,id=0),min_value=0,max_value=0 R1=inv,min_value=3 R2=imm2,min_value=2,max_value=2,min_align=2 R10=fp 11: (b7) r7 = 1 12: (65) if r7 s> 0x0 goto pc+2 R0=map_value(ks=8,vs=8,id=0),min_value=0,max_value=0 R1=inv,min_value=3 R2=imm2,min_value=2,max_value=2,min_align=2 R7=imm1,max_value=0 R10=fp 13: (b7) r0 = 0 14: (95) exit from 12 to 15: R0=map_value(ks=8,vs=8,id=0),min_value=0,max_value=0 R1=inv,min_value=3 R2=imm2,min_value=2,max_value=2,min_align=2 R7=imm1,min_value=1 R10=fp 15: (0f) r7 += r1 16: (65) if r7 s> 0x4 goto pc+2 R0=map_value(ks=8,vs=8,id=0),min_value=0,max_value=0 R1=inv,min_value=3 R2=imm2,min_value=2,max_value=2,min_align=2 R7=inv,min_value=4,max_value=4 R10=fp 17: (0f) r0 += r7 18: (72) *(u8 *)(r0 +0) = 0 R0=map_value_adj(ks=8,vs=8,id=0),min_value=4,max_value=4 R1=inv,min_value=3 R2=imm2,min_value=2,max_value=2,min_align=2 R7=inv,min_value=4,max_value=4 R10=fp 19: (b7) r0 = 0 20: (95) exit Meaning, in adjust_reg_min_max_vals() we must also reset range values on the dst when src/dst registers have mixed signed/ unsigned derived min/max value bounds with one unbounded value as otherwise they can be added together deducing false boundaries. Once both boundaries are established from either ALU ops or compare operations w/o mixing signed/unsigned insns, then they can safely be added to other regs also having both boundaries established. Adding regs with one unbounded side to a map value where the bounded side has been learned w/o mixing ops is possible, but the resulting map value won't recover from that, meaning such op is considered invalid on the time of actual access. Invalid bounds are set on the dst reg in case i) src reg, or ii) in case dst reg already had them. The only way to recover would be to perform i) ALU ops but only 'add' is allowed on map value types or ii) comparisons, but these are disallowed on pointers in case they span a range. This is fine as only BPF_JEQ and BPF_JNE may be performed on PTR_TO_MAP_VALUE_OR_NULL registers which potentially turn them into PTR_TO_MAP_VALUE type depending on the branch, so only here min/max value cannot be invalidated for them. In terms of state pruning, value_from_signed is considered as well in states_equal() when dealing with adjusted map values. With regards to breaking existing programs, there is a small risk, but use-cases are rather quite narrow where this could occur and mixing compares probably unlikely. Joint work with Josef and Edward. [0] https://lists.iovisor.org/pipermail/iovisor-dev/2017-June/000822.html Fixes: 484611357c19 ("bpf: allow access into map value arrays") Reported-by: Edward Cree <ecree@solarflare.com> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: Edward Cree <ecree@solarflare.com> Signed-off-by: Josef Bacik <jbacik@fb.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-30bpf, verifier: fix alu ops against map_value{, _adj} register typesDaniel Borkmann
[ Upstream commit fce366a9dd0ddc47e7ce05611c266e8574a45116 ] While looking into map_value_adj, I noticed that alu operations directly on the map_value() resp. map_value_adj() register (any alu operation on a map_value() register will turn it into a map_value_adj() typed register) are not sufficiently protected against some of the operations. Two non-exhaustive examples are provided that the verifier needs to reject: i) BPF_AND on r0 (map_value_adj): 0: (bf) r2 = r10 1: (07) r2 += -8 2: (7a) *(u64 *)(r2 +0) = 0 3: (18) r1 = 0xbf842a00 5: (85) call bpf_map_lookup_elem#1 6: (15) if r0 == 0x0 goto pc+2 R0=map_value(ks=8,vs=48,id=0),min_value=0,max_value=0 R10=fp 7: (57) r0 &= 8 8: (7a) *(u64 *)(r0 +0) = 22 R0=map_value_adj(ks=8,vs=48,id=0),min_value=0,max_value=8 R10=fp 9: (95) exit from 6 to 9: R0=inv,min_value=0,max_value=0 R10=fp 9: (95) exit processed 10 insns ii) BPF_ADD in 32 bit mode on r0 (map_value_adj): 0: (bf) r2 = r10 1: (07) r2 += -8 2: (7a) *(u64 *)(r2 +0) = 0 3: (18) r1 = 0xc24eee00 5: (85) call bpf_map_lookup_elem#1 6: (15) if r0 == 0x0 goto pc+2 R0=map_value(ks=8,vs=48,id=0),min_value=0,max_value=0 R10=fp 7: (04) (u32) r0 += (u32) 0 8: (7a) *(u64 *)(r0 +0) = 22 R0=map_value_adj(ks=8,vs=48,id=0),min_value=0,max_value=0 R10=fp 9: (95) exit from 6 to 9: R0=inv,min_value=0,max_value=0 R10=fp 9: (95) exit processed 10 insns Issue is, while min_value / max_value boundaries for the access are adjusted appropriately, we change the pointer value in a way that cannot be sufficiently tracked anymore from its origin. Operations like BPF_{AND,OR,DIV,MUL,etc} on a destination register that is PTR_TO_MAP_VALUE{,_ADJ} was probably unintended, in fact, all the test cases coming with 484611357c19 ("bpf: allow access into map value arrays") perform BPF_ADD only on the destination register that is PTR_TO_MAP_VALUE_ADJ. Only for UNKNOWN_VALUE register types such operations make sense, f.e. with unknown memory content fetched initially from a constant offset from the map value memory into a register. That register is then later tested against lower / upper bounds, so that the verifier can then do the tracking of min_value / max_value, and properly check once that UNKNOWN_VALUE register is added to the destination register with type PTR_TO_MAP_VALUE{,_ADJ}. This is also what the original use-case is solving. Note, tracking on what is being added is done through adjust_reg_min_max_vals() and later access to the map value enforced with these boundaries and the given offset from the insn through check_map_access_adj(). Tests will fail for non-root environment due to prohibited pointer arithmetic, in particular in check_alu_op(), we bail out on the is_pointer_value() check on the dst_reg (which is false in root case as we allow for pointer arithmetic via env->allow_ptr_leaks). Similarly to PTR_TO_PACKET, one way to fix it is to restrict the allowed operations on PTR_TO_MAP_VALUE{,_ADJ} registers to 64 bit mode BPF_ADD. The test_verifier suite runs fine after the patch and it also rejects mentioned test cases. Fixes: 484611357c19 ("bpf: allow access into map value arrays") Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Reviewed-by: Josef Bacik <jbacik@fb.com> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-30bpf: adjust verifier heuristicsDaniel Borkmann
[ Upstream commit 3c2ce60bdd3d57051bf85615deec04a694473840 ] Current limits with regards to processing program paths do not really reflect today's needs anymore due to programs becoming more complex and verifier smarter, keeping track of more data such as const ALU operations, alignment tracking, spilling of PTR_TO_MAP_VALUE_ADJ registers, and other features allowing for smarter matching of what LLVM generates. This also comes with the side-effect that we result in fewer opportunities to prune search states and thus often need to do more work to prove safety than in the past due to different register states and stack layout where we mismatch. Generally, it's quite hard to determine what caused a sudden increase in complexity, it could be caused by something as trivial as a single branch somewhere at the beginning of the program where LLVM assigned a stack slot that is marked differently throughout other branches and thus causing a mismatch, where verifier then needs to prove safety for the whole rest of the program. Subsequently, programs with even less than half the insn size limit can get rejected. We noticed that while some programs load fine under pre 4.11, they get rejected due to hitting limits on more recent kernels. We saw that in the vast majority of cases (90+%) pruning failed due to register mismatches. In case of stack mismatches, majority of cases failed due to different stack slot types (invalid, spill, misc) rather than differences in spilled registers. This patch makes pruning more aggressive by also adding markers that sit at conditional jumps as well. Currently, we only mark jump targets for pruning. For example in direct packet access, these are usually error paths where we bail out. We found that adding these markers, it can reduce number of processed insns by up to 30%. Another option is to ignore reg->id in probing PTR_TO_MAP_VALUE_OR_NULL registers, which can help pruning slightly as well by up to 7% observed complexity reduction as stand-alone. Meaning, if a previous path with register type PTR_TO_MAP_VALUE_OR_NULL for map X was found to be safe, then in the current state a PTR_TO_MAP_VALUE_OR_NULL register for the same map X must be safe as well. Last but not least the patch also adds a scheduling point and bumps the current limit for instructions to be processed to a more adequate value. Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-30bpf, verifier: add additional patterns to evaluate_reg_imm_aluJohn Fastabend
[ Upstream commit 43188702b3d98d2792969a3377a30957f05695e6 ] Currently the verifier does not track imm across alu operations when the source register is of unknown type. This adds additional pattern matching to catch this and track imm. We've seen LLVM generating this pattern while working on cilium. Signed-off-by: John Fastabend <john.fastabend@gmail.com> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-30bpf: fix bpf_trace_printk on 32 bit archsDaniel Borkmann
[ Upstream commit 88a5c690b66110ad255380d8f629c629cf6ca559 ] James reported that on MIPS32 bpf_trace_printk() is currently broken while MIPS64 works fine: bpf_trace_printk() uses conditional operators to attempt to pass different types to __trace_printk() depending on the format operators. This doesn't work as intended on 32-bit architectures where u32 and long are passed differently to u64, since the result of C conditional operators follows the "usual arithmetic conversions" rules, such that the values passed to __trace_printk() will always be u64 [causing issues later in the va_list handling for vscnprintf()]. For example the samples/bpf/tracex5 test printed lines like below on MIPS32, where the fd and buf have come from the u64 fd argument, and the size from the buf argument: [...] 1180.941542: 0x00000001: write(fd=1, buf= (null), size=6258688) Instead of this: [...] 1625.616026: 0x00000001: write(fd=1, buf=009e4000, size=512) One way to get it working is to expand various combinations of argument types into 8 different combinations for 32 bit and 64 bit kernels. Fix tested by James on MIPS32 and MIPS64 as well that it resolves the issue. Fixes: 9c959c863f82 ("tracing: Allow BPF programs to call bpf_trace_printk()") Reported-by: James Hogan <james.hogan@imgtec.com> Tested-by: James Hogan <james.hogan@imgtec.com> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-24pids: make task_tgid_nr_ns() safeOleg Nesterov
commit dd1c1f2f2028a7b851f701fc6a8ebe39dcb95e7c upstream. This was reported many times, and this was even mentioned in commit 52ee2dfdd4f5 ("pids: refactor vnr/nr_ns helpers to make them safe") but somehow nobody bothered to fix the obvious problem: task_tgid_nr_ns() is not safe because task->group_leader points to nowhere after the exiting task passes exit_notify(), rcu_read_lock() can not help. We really need to change __unhash_process() to nullify group_leader, parent, and real_parent, but this needs some cleanups. Until then we can turn task_tgid_nr_ns() into another user of __task_pid_nr_ns() and fix the problem. Reported-by: Troy Kensinger <tkensinger@google.com> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-24genirq/ipi: Fixup checks against nr_cpu_idsAlexey Dobriyan
commit 8fbbe2d7cc478d1544f41f2271787c993c23a4f6 upstream. Valid CPU ids are [0, nr_cpu_ids-1] inclusive. Fixes: 3b8e29a82dd1 ("genirq: Implement ipi_send_mask/single()") Fixes: f9bce791ae2a ("genirq: Add a new function to get IPI reverse mapping") Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20170819095751.GB27864@avx2 Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-24genirq: Restore trigger settings in irq_modify_status()Marc Zyngier
commit e8f241893dfbbebe2813c01eac54f263e6a5e59c upstream. irq_modify_status starts by clearing the trigger settings from irq_data before applying the new settings, but doesn't restore them, leaving them to IRQ_TYPE_NONE. That's pretty confusing to the potential request_irq() that could follow. Instead, snapshot the settings before clearing them, and restore them if the irq_modify_status() invocation was not changing the trigger. Fixes: 1e2a7d78499e ("irqdomain: Don't set type when mapping an IRQ") Reported-and-tested-by: jeffy <jeffy.chen@rock-chips.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Jon Hunter <jonathanh@nvidia.com> Link: http://lkml.kernel.org/r/20170818095345.12378-1-marc.zyngier@arm.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-24audit: Fix use after free in audit_remove_watch_rule()Jan Kara
commit d76036ab47eafa6ce52b69482e91ca3ba337d6d6 upstream. audit_remove_watch_rule() drops watch's reference to parent but then continues to work with it. That is not safe as parent can get freed once we drop our reference. The following is a trivial reproducer: mount -o loop image /mnt touch /mnt/file auditctl -w /mnt/file -p wax umount /mnt auditctl -D <crash in fsnotify_destroy_mark()> Grab our own reference in audit_remove_watch_rule() earlier to make sure mark does not get freed under us. Reported-by: Tony Jones <tonyj@suse.de> Signed-off-by: Jan Kara <jack@suse.cz> Tested-by: Tony Jones <tonyj@suse.de> Signed-off-by: Paul Moore <paul@paul-moore.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-16futex: Remove unnecessary warning from get_futex_keyMel Gorman
commit 48fb6f4db940e92cfb16cd878cddd59ea6120d06 upstream. Commit 65d8fc777f6d ("futex: Remove requirement for lock_page() in get_futex_key()") removed an unnecessary lock_page() with the side-effect that page->mapping needed to be treated very carefully. Two defensive warnings were added in case any assumption was missed and the first warning assumed a correct application would not alter a mapping backing a futex key. Since merging, it has not triggered for any unexpected case but Mark Rutland reported the following bug triggering due to the first warning. kernel BUG at kernel/futex.c:679! Internal error: Oops - BUG: 0 [#1] PREEMPT SMP Modules linked in: CPU: 0 PID: 3695 Comm: syz-executor1 Not tainted 4.13.0-rc3-00020-g307fec773ba3 #3 Hardware name: linux,dummy-virt (DT) task: ffff80001e271780 task.stack: ffff000010908000 PC is at get_futex_key+0x6a4/0xcf0 kernel/futex.c:679 LR is at get_futex_key+0x6a4/0xcf0 kernel/futex.c:679 pc : [<ffff00000821ac14>] lr : [<ffff00000821ac14>] pstate: 80000145 The fact that it's a bug instead of a warning was due to an unrelated arm64 problem, but the warning itself triggered because the underlying mapping changed. This is an application issue but from a kernel perspective it's a recoverable situation and the warning is unnecessary so this patch removes the warning. The warning may potentially be triggered with the following test program from Mark although it may be necessary to adjust NR_FUTEX_THREADS to be a value smaller than the number of CPUs in the system. #include <linux/futex.h> #include <pthread.h> #include <stdio.h> #include <stdlib.h> #include <sys/mman.h> #include <sys/syscall.h> #include <sys/time.h> #include <unistd.h> #define NR_FUTEX_THREADS 16 pthread_t threads[NR_FUTEX_THREADS]; void *mem; #define MEM_PROT (PROT_READ | PROT_WRITE) #define MEM_SIZE 65536 static int futex_wrapper(int *uaddr, int op, int val, const struct timespec *timeout, int *uaddr2, int val3) { syscall(SYS_futex, uaddr, op, val, timeout, uaddr2, val3); } void *poll_futex(void *unused) { for (;;) { futex_wrapper(mem, FUTEX_CMP_REQUEUE_PI, 1, NULL, mem + 4, 1); } } int main(int argc, char *argv[]) { int i; mem = mmap(NULL, MEM_SIZE, MEM_PROT, MAP_SHARED | MAP_ANONYMOUS, -1, 0); printf("Mapping @ %p\n", mem); printf("Creating futex threads...\n"); for (i = 0; i < NR_FUTEX_THREADS; i++) pthread_create(&threads[i], NULL, poll_futex, NULL); printf("Flipping mapping...\n"); for (;;) { mmap(mem, MEM_SIZE, MEM_PROT, MAP_FIXED | MAP_SHARED | MAP_ANONYMOUS, -1, 0); } return 0; } Reported-and-tested-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-11workqueue: implicit ordered attribute should be overridableTejun Heo
commit 0a94efb5acbb6980d7c9ab604372d93cd507e4d8 upstream. 5c0338c68706 ("workqueue: restore WQ_UNBOUND/max_active==1 to be ordered") automatically enabled ordered attribute for unbound workqueues w/ max_active == 1. Because ordered workqueues reject max_active and some attribute changes, this implicit ordered mode broke cases where the user creates an unbound workqueue w/ max_active == 1 and later explicitly changes the related attributes. This patch distinguishes explicit and implicit ordered setting and overrides from attribute changes if implict. Signed-off-by: Tejun Heo <tj@kernel.org> Fixes: 5c0338c68706 ("workqueue: restore WQ_UNBOUND/max_active==1 to be ordered") Cc: Holger Hoffstätte <holger@applied-asynchrony.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-11signal: protect SIGNAL_UNKILLABLE from unintentional clearing.Jamie Iles
[ Upstream commit 2d39b3cd34e6d323720d4c61bd714f5ae202c022 ] Since commit 00cd5c37afd5 ("ptrace: permit ptracing of /sbin/init") we can now trace init processes. init is initially protected with SIGNAL_UNKILLABLE which will prevent fatal signals such as SIGSTOP, but there are a number of paths during tracing where SIGNAL_UNKILLABLE can be implicitly cleared. This can result in init becoming stoppable/killable after tracing. For example, running: while true; do kill -STOP 1; done & strace -p 1 and then stopping strace and the kill loop will result in init being left in state TASK_STOPPED. Sending SIGCONT to init will resume it, but init will now respond to future SIGSTOP signals rather than ignoring them. Make sure that when setting SIGNAL_STOP_CONTINUED/SIGNAL_STOP_STOPPED that we don't clear SIGNAL_UNKILLABLE. Link: http://lkml.kernel.org/r/20170104122017.25047-1-jamie.iles@oracle.com Signed-off-by: Jamie Iles <jamie.iles@oracle.com> Acked-by: Oleg Nesterov <oleg@redhat.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Ingo Molnar <mingo@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-11timers: Fix overflow in get_next_timer_interruptMatija Glavinic Pecotic
commit 34f41c0316ed52b0b44542491d89278efdaa70e4 upstream. For e.g. HZ=100, timer being 430 jiffies in the future, and 32 bit unsigned int, there is an overflow on unsigned int right-hand side of the expression which results with wrong values being returned. Type cast the multiplier to 64bit to avoid that issue. Fixes: 46c8f0b077a8 ("timers: Fix get_next_timer_interrupt() computation") Signed-off-by: Matija Glavinic Pecotic <matija.glavinic-pecotic.ext@nokia.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Alexander Sverdlin <alexander.sverdlin@nokia.com> Cc: khilman@baylibre.com Cc: akpm@linux-foundation.org Link: http://lkml.kernel.org/r/a7900f04-2a21-c9fd-67be-ab334d459ee5@nokia.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-11cpuset: fix a deadlock due to incomplete patching of cpusets_enabled()Dima Zavin
commit 89affbf5d9ebb15c6460596822e8857ea2f9e735 upstream. In codepaths that use the begin/retry interface for reading mems_allowed_seq with irqs disabled, there exists a race condition that stalls the patch process after only modifying a subset of the static_branch call sites. This problem manifested itself as a deadlock in the slub allocator, inside get_any_partial. The loop reads mems_allowed_seq value (via read_mems_allowed_begin), performs the defrag operation, and then verifies the consistency of mem_allowed via the read_mems_allowed_retry and the cookie returned by xxx_begin. The issue here is that both begin and retry first check if cpusets are enabled via cpusets_enabled() static branch. This branch can be rewritted dynamically (via cpuset_inc) if a new cpuset is created. The x86 jump label code fully synchronizes across all CPUs for every entry it rewrites. If it rewrites only one of the callsites (specifically the one in read_mems_allowed_retry) and then waits for the smp_call_function(do_sync_core) to complete while a CPU is inside the begin/retry section with IRQs off and the mems_allowed value is changed, we can hang. This is because begin() will always return 0 (since it wasn't patched yet) while retry() will test the 0 against the actual value of the seq counter. The fix is to use two different static keys: one for begin (pre_enable_key) and one for retry (enable_key). In cpuset_inc(), we first bump the pre_enable key to ensure that cpuset_mems_allowed_begin() always return a valid seqcount if are enabling cpusets. Similarly, when disabling cpusets via cpuset_dec(), we first ensure that callers of cpuset_mems_allowed_retry() will start ignoring the seqcount value before we let cpuset_mems_allowed_begin() return 0. The relevant stack traces of the two stuck threads: CPU: 1 PID: 1415 Comm: mkdir Tainted: G L 4.9.36-00104-g540c51286237 #4 Hardware name: Default string Default string/Hardware, BIOS 4.29.1-20170526215256 05/26/2017 task: ffff8817f9c28000 task.stack: ffffc9000ffa4000 RIP: smp_call_function_many+0x1f9/0x260 Call Trace: smp_call_function+0x3b/0x70 on_each_cpu+0x2f/0x90 text_poke_bp+0x87/0xd0 arch_jump_label_transform+0x93/0x100 __jump_label_update+0x77/0x90 jump_label_update+0xaa/0xc0 static_key_slow_inc+0x9e/0xb0 cpuset_css_online+0x70/0x2e0 online_css+0x2c/0xa0 cgroup_apply_control_enable+0x27f/0x3d0 cgroup_mkdir+0x2b7/0x420 kernfs_iop_mkdir+0x5a/0x80 vfs_mkdir+0xf6/0x1a0 SyS_mkdir+0xb7/0xe0 entry_SYSCALL_64_fastpath+0x18/0xad ... CPU: 2 PID: 1 Comm: init Tainted: G L 4.9.36-00104-g540c51286237 #4 Hardware name: Default string Default string/Hardware, BIOS 4.29.1-20170526215256 05/26/2017 task: ffff8818087c0000 task.stack: ffffc90000030000 RIP: int3+0x39/0x70 Call Trace: <#DB> ? ___slab_alloc+0x28b/0x5a0 <EOE> ? copy_process.part.40+0xf7/0x1de0 __slab_alloc.isra.80+0x54/0x90 copy_process.part.40+0xf7/0x1de0 copy_process.part.40+0xf7/0x1de0 kmem_cache_alloc_node+0x8a/0x280 copy_process.part.40+0xf7/0x1de0 _do_fork+0xe7/0x6c0 _raw_spin_unlock_irq+0x2d/0x60 trace_hardirqs_on_caller+0x136/0x1d0 entry_SYSCALL_64_fastpath+0x5/0xad do_syscall_64+0x27/0x350 SyS_clone+0x19/0x20 do_syscall_64+0x60/0x350 entry_SYSCALL64_slow_path+0x25/0x25 Link: http://lkml.kernel.org/r/20170731040113.14197-1-dmitriyz@waymo.com Fixes: 46e700abc44c ("mm, page_alloc: remove unnecessary taking of a seqlock when cpusets are disabled") Signed-off-by: Dima Zavin <dmitriyz@waymo.com> Reported-by: Cliff Spradlin <cspradlin@waymo.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Christopher Lameter <cl@linux.com> Cc: Li Zefan <lizefan@huawei.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Mel Gorman <mgorman@techsingularity.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-11workqueue: restore WQ_UNBOUND/max_active==1 to be orderedTejun Heo
commit 5c0338c68706be53b3dc472e4308961c36e4ece1 upstream. The combination of WQ_UNBOUND and max_active == 1 used to imply ordered execution. After NUMA affinity 4c16bd327c74 ("workqueue: implement NUMA affinity for unbound workqueues"), this is no longer true due to per-node worker pools. While the right way to create an ordered workqueue is alloc_ordered_workqueue(), the documentation has been misleading for a long time and people do use WQ_UNBOUND and max_active == 1 for ordered workqueues which can lead to subtle bugs which are very difficult to trigger. It's unlikely that we'd see noticeable performance impact by enforcing ordering on WQ_UNBOUND / max_active == 1 workqueues. Let's automatically set __WQ_ORDERED for those workqueues. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Christoph Hellwig <hch@infradead.org> Reported-by: Alexei Potashnik <alexei@purestorage.com> Fixes: 4c16bd327c74 ("workqueue: implement NUMA affinity for unbound workqueues") Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-11cgroup: fix error return value from cgroup_subtree_control()Tejun Heo
commit 3c74541777302eec43a0d1327c4d58b8659a776b upstream. While refactoring, f7b2814bb9b6 ("cgroup: factor out cgroup_{apply|finalize}_control() from cgroup_subtree_control_write()") broke error return value from the function. The return value from the last operation is always overridden to zero. Fix it. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-11cgroup: create dfl_root files on subsys registrationTejun Heo
commit 7af608e4f9530372aec6e940552bf76595f2e265 upstream. On subsystem registration, css_populate_dir() is not called on the new root css, so the interface files for the subsystem on cgrp_dfl_root aren't created on registration. This is a residue from the days when cgrp_dfl_root was used only as the parking spot for unused subsystems, which no longer is true as it's used as the root for cgroup2. This is often fine as later operations tend to create them as a part of mount (cgroup1) or subtree_control operations (cgroup2); however, it's not difficult to mount cgroup2 with the controller interface files missing as Waiman found out. Fix it by invoking css_populate_dir() on the root css on subsys registration. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-and-tested-by: Waiman Long <longman@redhat.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-06sched/cgroup: Move sched_online_group() back into css_online() to fix crashKonstantin Khlebnikov
commit 96b777452d8881480fd5be50112f791c17db4b6b upstream. Commit: 2f5177f0fd7e ("sched/cgroup: Fix/cleanup cgroup teardown/init") .. moved sched_online_group() from css_online() to css_alloc(). It exposes half-baked task group into global lists before initializing generic cgroup stuff. LTP testcase (third in cgroup_regression_test) written for testing similar race in kernels 2.6.26-2.6.28 easily triggers this oops: BUG: unable to handle kernel NULL pointer dereference at 0000000000000008 IP: kernfs_path_from_node_locked+0x260/0x320 CPU: 1 PID: 30346 Comm: cat Not tainted 4.10.0-rc5-test #4 Call Trace: ? kernfs_path_from_node+0x4f/0x60 kernfs_path_from_node+0x3e/0x60 print_rt_rq+0x44/0x2b0 print_rt_stats+0x7a/0xd0 print_cpu+0x2fc/0xe80 ? __might_sleep+0x4a/0x80 sched_debug_show+0x17/0x30 seq_read+0xf2/0x3b0 proc_reg_read+0x42/0x70 __vfs_read+0x28/0x130 ? security_file_permission+0x9b/0xc0 ? rw_verify_area+0x4e/0xb0 vfs_read+0xa5/0x170 SyS_read+0x46/0xa0 entry_SYSCALL_64_fastpath+0x1e/0xad Here the task group is already linked into the global RCU-protected 'task_groups' list, but the css->cgroup pointer is still NULL. This patch reverts this chunk and moves online back to css_online(). Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Tejun Heo <tj@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Fixes: 2f5177f0fd7e ("sched/cgroup: Fix/cleanup cgroup teardown/init") Link: http://lkml.kernel.org/r/148655324740.424917.5302984537258726349.stgit@buzz Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Matt Fleming <matt@codeblueprint.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-06smp/hotplug: Replace BUG_ON and react usefulThomas Gleixner
commit dea1d0f5f1284e3defee4b8484d9fc230686cd42 upstream. The move of the unpark functions to the control thread moved the BUG_ON() there as well. While it made some sense in the idle thread of the upcoming CPU, it's bogus to crash the control thread on the already online CPU, especially as the function has a return value and the callsite is prepared to handle an error return. Replace it with a WARN_ON_ONCE() and return a proper error code. Fixes: 9cd4f1a4e7a8 ("smp/hotplug: Move unparking of percpu threads to the control CPU") Rightfully-ranted-at-by: Linux Torvalds <torvalds@linux-foundation.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-06smp/hotplug: Move unparking of percpu threads to the control CPUThomas Gleixner
commit 9cd4f1a4e7a858849e889a081a99adff83e08e4c upstream. Vikram reported the following backtrace: BUG: scheduling while atomic: swapper/7/0/0x00000002 CPU: 7 PID: 0 Comm: swapper/7 Not tainted 4.9.32-perf+ #680 schedule schedule_hrtimeout_range_clock schedule_hrtimeout wait_task_inactive __kthread_bind_mask __kthread_bind __kthread_unpark kthread_unpark cpuhp_online_idle cpu_startup_entry secondary_start_kernel He analyzed correctly that a parked cpu hotplug thread of an offlined CPU was still on the runqueue when the CPU came back online and tried to unpark it. This causes the thread which invoked kthread_unpark() to call wait_task_inactive() and subsequently schedule() with preemption disabled. His proposed workaround was to "make sure" that a parked thread has scheduled out when the CPU goes offline, so the situation cannot happen. But that's still wrong because the root cause is not the fact that the percpu thread is still on the runqueue and neither that preemption is disabled, which could be simply solved by enabling preemption before calling kthread_unpark(). The real issue is that the calling thread is the idle task of the upcoming CPU, which is not supposed to call anything which might sleep. The moron, who wrote that code, missed completely that kthread_unpark() might end up in schedule(). The solution is simpler than expected. The thread which controls the hotplug operation is waiting for the CPU to call complete() on the hotplug state completion. So the idle task of the upcoming CPU can set its state to CPUHP_AP_ONLINE_IDLE and invoke complete(). This in turn wakes the control task on a different CPU, which then can safely do the unpark and kick the now unparked hotplug thread of the upcoming CPU to complete the bringup to the final target state. Control CPU AP bringup_cpu(); __cpu_up() ------------> bringup_ap(); bringup_wait_for_ap() wait_for_completion(); cpuhp_online_idle(); <------------ complete(); unpark(AP->stopper); unpark(AP->hotplugthread); while(1) do_idle(); kick(AP->hotplugthread); wait_for_completion(); hotplug_thread() run_online_callbacks(); complete(); Fixes: 8df3e07e7f21 ("cpu/hotplug: Let upcoming cpu bring itself fully up") Reported-by: Vikram Mulukutla <markivx@codeaurora.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Sebastian Sewior <bigeasy@linutronix.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Tejun Heo <tj@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/r/alpine.DEB.2.20.1707042218020.2131@nanos Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-27alarmtimer: don't rate limit one-shot timersGreg Hackmann
Commit ff86bf0c65f1 ("alarmtimer: Rate limit periodic intervals") sets a minimum bound on the alarm timer interval. This minimum bound shouldn't be applied if the interval is 0. Otherwise, one-shot timers will be converted into periodic ones. Fixes: ff86bf0c65f1 ("alarmtimer: Rate limit periodic intervals") Reported-by: Ben Fennema <fennema@google.com> Signed-off-by: Greg Hackmann <ghackmann@google.com> Cc: stable@vger.kernel.org Cc: John Stultz <john.stultz@linaro.org> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-27tracing: Fix kmemleak in instance_rmdirChunyu Hu
commit db9108e054700c96322b0f0028546aa4e643cf0b upstream. Hit the kmemleak when executing instance_rmdir, it forgot releasing mem of tracing_cpumask. With this fix, the warn does not appear any more. unreferenced object 0xffff93a8dfaa7c18 (size 8): comm "mkdir", pid 1436, jiffies 4294763622 (age 9134.308s) hex dump (first 8 bytes): ff ff ff ff ff ff ff ff ........ backtrace: [<ffffffff88b6567a>] kmemleak_alloc+0x4a/0xa0 [<ffffffff8861ea41>] __kmalloc_node+0xf1/0x280 [<ffffffff88b505d3>] alloc_cpumask_var_node+0x23/0x30 [<ffffffff88b5060e>] alloc_cpumask_var+0xe/0x10 [<ffffffff88571ab0>] instance_mkdir+0x90/0x240 [<ffffffff886e5100>] tracefs_syscall_mkdir+0x40/0x70 [<ffffffff886565c9>] vfs_mkdir+0x109/0x1b0 [<ffffffff8865b1d0>] SyS_mkdir+0xd0/0x100 [<ffffffff88403857>] do_syscall_64+0x67/0x150 [<ffffffff88b710e7>] return_from_SYSCALL_64+0x0/0x6a [<ffffffffffffffff>] 0xffffffffffffffff Link: http://lkml.kernel.org/r/1500546969-12594-1-git-send-email-chuhu@redhat.com Fixes: ccfe9e42e451 ("tracing: Make tracing_cpumask available for all instances") Signed-off-by: Chunyu Hu <chuhu@redhat.com> Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-27Revert "perf/core: Drop kernel samples even though :u is specified"Ingo Molnar
commit 6a8a75f3235724c5941a33e287b2f98966ad14c5 upstream. This reverts commit cc1582c231ea041fbc68861dfaf957eaf902b829. This commit introduced a regression that broke rr-project, which uses sampling events to receive a signal on overflow (but does not care about the contents of the sample). These signals are critical to the correct operation of rr. There's been some back and forth about how to fix it - but to not keep applications in limbo queue up a revert. Reported-by: Kyle Huey <me@kylehuey.com> Acked-by: Kyle Huey <me@kylehuey.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Jin Yao <yao.jin@linux.intel.com> Cc: Vince Weaver <vincent.weaver@maine.edu> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Will Deacon <will.deacon@arm.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Stephane Eranian <eranian@google.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/20170628105600.GC5981@leverpostej Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-27ftrace: Fix uninitialized variable in match_records()Dan Carpenter
commit 2e028c4fe12907f226b8221815f16c2486ad3aa7 upstream. My static checker complains that if "func" is NULL then "clear_filter" is uninitialized. This seems like it could be true, although it's possible something subtle is happening that I haven't seen. kernel/trace/ftrace.c:3844 match_records() error: uninitialized symbol 'clear_filter'. Link: http://lkml.kernel.org/r/20170712073556.h6tkpjcdzjaozozs@mwanda Fixes: f0a3b154bd7 ("ftrace: Clarify code for mod command") Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-21tracing: Use SOFTIRQ_OFFSET for softirq dectection for more accurate resultsPavankumar Kondeti
commit c59f29cb144a6a0dfac16ede9dc8eafc02dc56ca upstream. The 's' flag is supposed to indicate that a softirq is running. This can be detected by testing the preempt_count with SOFTIRQ_OFFSET. The current code tests the preempt_count with SOFTIRQ_MASK, which would be true even when softirqs are disabled but not serving a softirq. Link: http://lkml.kernel.org/r/1481300417-3564-1-git-send-email-pkondeti@codeaurora.org Signed-off-by: Pavankumar Kondeti <pkondeti@codeaurora.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Amit Pundir <amit.pundir@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-21sched/topology: Fix overlapping sched_group_maskPeter Zijlstra
commit 73bb059f9b8a00c5e1bf2f7ca83138c05d05e600 upstream. The point of sched_group_mask is to select those CPUs from sched_group_cpus that can actually arrive at this balance domain. The current code gets it wrong, as can be readily demonstrated with a topology like: node 0 1 2 3 0: 10 20 30 20 1: 20 10 20 30 2: 30 20 10 20 3: 20 30 20 10 Where (for example) domain 1 on CPU1 ends up with a mask that includes CPU0: [] CPU1 attaching sched-domain: [] domain 0: span 0-2 level NUMA [] groups: 1 (mask: 1), 2, 0 [] domain 1: span 0-3 level NUMA [] groups: 0-2 (mask: 0-2) (cpu_capacity: 3072), 0,2-3 (cpu_capacity: 3072) This causes sched_balance_cpu() to compute the wrong CPU and consequently should_we_balance() will terminate early resulting in missed load-balance opportunities. The fixed topology looks like: [] CPU1 attaching sched-domain: [] domain 0: span 0-2 level NUMA [] groups: 1 (mask: 1), 2, 0 [] domain 1: span 0-3 level NUMA [] groups: 0-2 (mask: 1) (cpu_capacity: 3072), 0,2-3 (cpu_capacity: 3072) (note: this relies on OVERLAP domains to always have children, this is true because the regular topology domains are still here -- this is before degenerate trimming) Debugged-by: Lauro Ramos Venancio <lvenanci@redhat.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Fixes: e3589f6c81e4 ("sched: Allow for overlapping sched_domain spans") Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-21sched/topology: Optimize build_group_mask()Lauro Ramos Venancio
commit f32d782e31bf079f600dcec126ed117b0577e85c upstream. The group mask is always used in intersection with the group CPUs. So, when building the group mask, we don't have to care about CPUs that are not part of the group. Signed-off-by: Lauro Ramos Venancio <lvenanci@redhat.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: lwang@redhat.com Cc: riel@redhat.com Link: http://lkml.kernel.org/r/1492717903-5195-2-git-send-email-lvenanci@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-21sched/topology: Fix building of overlapping sched-groupsPeter Zijlstra
commit 0372dd2736e02672ac6e189c31f7d8c02ad543cd upstream. When building the overlapping groups, we very obviously should start with the previous domain of _this_ @cpu, not CPU-0. This can be readily demonstrated with a topology like: node 0 1 2 3 0: 10 20 30 20 1: 20 10 20 30 2: 30 20 10 20 3: 20 30 20 10 Where (for example) CPU1 ends up generating the following nonsensical groups: [] CPU1 attaching sched-domain: [] domain 0: span 0-2 level NUMA [] groups: 1 2 0 [] domain 1: span 0-3 level NUMA [] groups: 1-3 (cpu_capacity = 3072) 0-1,3 (cpu_capacity = 3072) Where the fact that domain 1 doesn't include a group with span 0-2 is the obvious fail. With patch this looks like: [] CPU1 attaching sched-domain: [] domain 0: span 0-2 level NUMA [] groups: 1 0 2 [] domain 1: span 0-3 level NUMA [] groups: 0-2 (cpu_capacity = 3072) 0,2-3 (cpu_capacity = 3072) Debugged-by: Lauro Ramos Venancio <lvenanci@redhat.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Fixes: e3589f6c81e4 ("sched: Allow for overlapping sched_domain spans") Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-21sched/fair, cpumask: Export for_each_cpu_wrap()Peter Zijlstra
commit c6508a39640b9a27fc2bc10cb708152672c82045 upstream. commit c743f0a5c50f2fcbc628526279cfa24f3dabe182 upstream. More users for for_each_cpu_wrap() have appeared. Promote the construct to generic cpumask interface. The implementation is slightly modified to reduce arguments. Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Lauro Ramos Venancio <lvenanci@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: lwang@redhat.com Link: http://lkml.kernel.org/r/20170414122005.o35me2h5nowqkxbv@hirez.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-21Revert "sched/core: Optimize SCHED_SMT"Greg Kroah-Hartman
This reverts commit 1b568f0aabf280555125bc7cefc08321ff0ebaba. For the 4.9 kernel tree, this patch causes scheduler regressions. It is fixed in newer kernels with a large number of individual patches, the sum of which is too big for the stable kernel tree. Ingo recommended just reverting the single patch for this tree, as it's much simpler. Reported-by: Ben Guthro <ben@guthro.net> Cc: Ingo Molnar <mingo@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-21rcu: Add memory barriers for NOCB leader wakeupPaul E. McKenney
commit 6b5fc3a1331810db407c9e0e673dc1837afdc9d0 upstream. Wait/wakeup operations do not guarantee ordering on their own. Instead, either locking or memory barriers are required. This commit therefore adds memory barriers to wake_nocb_leader() and nocb_leader_wait(). Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Tested-by: Krister Johansen <kjlx@templeofstupid.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-21kernel/extable.c: mark core_kernel_text notraceMarcin Nowakowski
commit c0d80ddab89916273cb97114889d3f337bc370ae upstream. core_kernel_text is used by MIPS in its function graph trace processing, so having this method traced leads to an infinite set of recursive calls such as: Call Trace: ftrace_return_to_handler+0x50/0x128 core_kernel_text+0x10/0x1b8 prepare_ftrace_return+0x6c/0x114 ftrace_graph_caller+0x20/0x44 return_to_handler+0x10/0x30 return_to_handler+0x0/0x30 return_to_handler+0x0/0x30 ftrace_ops_no_ops+0x114/0x1bc core_kernel_text+0x10/0x1b8 core_kernel_text+0x10/0x1b8 core_kernel_text+0x10/0x1b8 ftrace_ops_no_ops+0x114/0x1bc core_kernel_text+0x10/0x1b8 prepare_ftrace_return+0x6c/0x114 ftrace_graph_caller+0x20/0x44 (...) Mark the function notrace to avoid it being traced. Link: http://lkml.kernel.org/r/1498028607-6765-1-git-send-email-marcin.nowakowski@imgtec.com Signed-off-by: Marcin Nowakowski <marcin.nowakowski@imgtec.com> Reviewed-by: Masami Hiramatsu <mhiramat@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Meyer <thomas@m3y3r.de> Cc: Ingo Molnar <mingo@kernel.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Daniel Borkmann <daniel@iogearbox.net> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-21bpf: prevent leaking pointer via xadd on unpriviledgedDaniel Borkmann
commit 6bdf6abc56b53103324dfd270a86580306e1a232 upstream. Leaking kernel addresses on unpriviledged is generally disallowed, for example, verifier rejects the following: 0: (b7) r0 = 0 1: (18) r2 = 0xffff897e82304400 3: (7b) *(u64 *)(r1 +48) = r2 R2 leaks addr into ctx Doing pointer arithmetic on them is also forbidden, so that they don't turn into unknown value and then get leaked out. However, there's xadd as a special case, where we don't check the src reg for being a pointer register, e.g. the following will pass: 0: (b7) r0 = 0 1: (7b) *(u64 *)(r1 +48) = r0 2: (18) r2 = 0xffff897e82304400 ; map 4: (db) lock *(u64 *)(r1 +48) += r2 5: (95) exit We could store the pointer into skb->cb, loose the type context, and then read it out from there again to leak it eventually out of a map value. Or more easily in a different variant, too: 0: (bf) r6 = r1 1: (7a) *(u64 *)(r10 -8) = 0 2: (bf) r2 = r10 3: (07) r2 += -8 4: (18) r1 = 0x0 6: (85) call bpf_map_lookup_elem#1 7: (15) if r0 == 0x0 goto pc+3 R0=map_value(ks=8,vs=8,id=0),min_value=0,max_value=0 R6=ctx R10=fp 8: (b7) r3 = 0 9: (7b) *(u64 *)(r0 +0) = r3 10: (db) lock *(u64 *)(r0 +0) += r6 11: (b7) r0 = 0 12: (95) exit from 7 to 11: R0=inv,min_value=0,max_value=0 R6=ctx R10=fp 11: (b7) r0 = 0 12: (95) exit Prevent this by checking xadd src reg for pointer types. Also add a couple of test cases related to this. Fixes: 1be7f75d1668 ("bpf: enable non-root eBPF programs") Fixes: 17a5267067f3 ("bpf: verifier (add verifier core)") Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Alexei Starovoitov <ast@kernel.org> Acked-by: Martin KaFai Lau <kafai@fb.com> Acked-by: Edward Cree <ecree@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-15locking/rwsem-spinlock: Fix EINTR branch in __down_write_common()Kirill Tkhai
commit a0c4acd2c220376b4e9690e75782d0c0afdaab9f upstream. If a writer could been woken up, the above branch if (sem->count == 0) break; would have moved us to taking the sem. So, it's not the time to wake a writer now, and only readers are allowed now. Thus, 0 must be passed to __rwsem_do_wake(). Next, __rwsem_do_wake() wakes readers unconditionally. But we mustn't do that if the sem is owned by writer in the moment. Otherwise, writer and reader own the sem the same time, which leads to memory corruption in callers. rwsem-xadd.c does not need that, as: 1) the similar check is made lockless there, 2) in __rwsem_mark_wake::try_reader_grant we test, that sem is not owned by writer. Signed-off-by: Kirill Tkhai <ktkhai@virtuozzo.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Niklas Cassel <niklas.cassel@axis.com> Cc: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Fixes: 17fcbd590d0c "locking/rwsem: Fix down_write_killable() for CONFIG_RWSEM_GENERIC_SPINLOCK=y" Link: http://lkml.kernel.org/r/149762063282.19811.9129615532201147826.stgit@localhost.localdomain Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-12sysctl: report EINVAL if value is larger than UINT_MAX for proc_douintvecLiping Zhang
commit 425fffd886bae3d127a08fa6a17f2e31e24ed7ff upstream. Currently, inputting the following command will succeed but actually the value will be truncated: # echo 0x12ffffffff > /proc/sys/net/ipv4/tcp_notsent_lowat This is not friendly to the user, so instead, we should report error when the value is larger than UINT_MAX. Fixes: e7d316a02f68 ("sysctl: handle error writing UINT_MAX to u32 fields") Signed-off-by: Liping Zhang <zlpnobody@gmail.com> Cc: Subash Abhinov Kasiviswanathan <subashab@codeaurora.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-12sysctl: don't print negative flag for proc_douintvecLiping Zhang
commit 5380e5644afbba9e3d229c36771134976f05c91e upstream. I saw some very confusing sysctl output on my system: # cat /proc/sys/net/core/xfrm_aevent_rseqth -2 # cat /proc/sys/net/core/xfrm_aevent_etime -10 # cat /proc/sys/net/ipv4/tcp_notsent_lowat -4294967295 Because we forget to set the *negp flag in proc_douintvec, so it will become a garbage value. Since the value related to proc_douintvec is always an unsigned integer, so we can set *negp to false explictily to fix this issue. Fixes: e7d316a02f68 ("sysctl: handle error writing UINT_MAX to u32 fields") Signed-off-by: Liping Zhang <zlpnobody@gmail.com> Cc: Subash Abhinov Kasiviswanathan <subashab@codeaurora.org> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-12tracing/kprobes: Allow to create probe with a module name starting with a digitSabrina Dubroca
commit 9e52b32567126fe146f198971364f68d3bc5233f upstream. Always try to parse an address, since kstrtoul() will safely fail when given a symbol as input. If that fails (which will be the case for a symbol), try to parse a symbol instead. This allows creating a probe such as: p:probe/vlan_gro_receive 8021q:vlan_gro_receive+0 Which is necessary for this command to work: perf probe -m 8021q -a vlan_gro_receive Link: http://lkml.kernel.org/r/fd72d666f45b114e2c5b9cf7e27b91de1ec966f1.1498122881.git.sd@queasysnail.net Fixes: 413d37d1e ("tracing: Add kprobe-based event tracer") Acked-by: Masami Hiramatsu <mhiramat@kernel.org> Signed-off-by: Sabrina Dubroca <sd@queasysnail.net> Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05sched/loadavg: Avoid loadavg spikes caused by delayed NO_HZ accountingMatt Fleming
commit 6e5f32f7a43f45ee55c401c0b9585eb01f9629a8 upstream. If we crossed a sample window while in NO_HZ we will add LOAD_FREQ to the pending sample window time on exit, setting the next update not one window into the future, but two. This situation on exiting NO_HZ is described by: this_rq->calc_load_update < jiffies < calc_load_update In this scenario, what we should be doing is: this_rq->calc_load_update = calc_load_update [ next window ] But what we actually do is: this_rq->calc_load_update = calc_load_update + LOAD_FREQ [ next+1 window ] This has the effect of delaying load average updates for potentially up to ~9seconds. This can result in huge spikes in the load average values due to per-cpu uninterruptible task counts being out of sync when accumulated across all CPUs. It's safe to update the per-cpu active count if we wake between sample windows because any load that we left in 'calc_load_idle' will have been zero'd when the idle load was folded in calc_global_load(). This issue is easy to reproduce before, commit 9d89c257dfb9 ("sched/fair: Rewrite runnable load and utilization average tracking") just by forking short-lived process pipelines built from ps(1) and grep(1) in a loop. I'm unable to reproduce the spikes after that commit, but the bug still seems to be present from code review. Signed-off-by: Matt Fleming <matt@codeblueprint.co.uk> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Mike Galbraith <umgwanakikbuti@gmail.com> Cc: Morten Rasmussen <morten.rasmussen@arm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Vincent Guittot <vincent.guittot@linaro.org> Fixes: commit 5167e8d ("sched/nohz: Rewrite and fix load-avg computation -- again") Link: http://lkml.kernel.org/r/20170217120731.11868-2-matt@codeblueprint.co.uk Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05perf/core: Fix sys_perf_event_open() vs. hotplugPeter Zijlstra
[ Upstream commit 63cae12bce9861cec309798d34701cf3da20bc71 ] There is problem with installing an event in a task that is 'stuck' on an offline CPU. Blocked tasks are not dis-assosciated from offlined CPUs, after all, a blocked task doesn't run and doesn't require a CPU etc.. Only on wakeup do we ammend the situation and place the task on a available CPU. If we hit such a task with perf_install_in_context() we'll loop until either that task wakes up or the CPU comes back online, if the task waking depends on the event being installed, we're stuck. While looking into this issue, I also spotted another problem, if we hit a task with perf_install_in_context() that is in the middle of being migrated, that is we observe the old CPU before sending the IPI, but run the IPI (on the old CPU) while the task is already running on the new CPU, things also go sideways. Rework things to rely on task_curr() -- outside of rq->lock -- which is rather tricky. Imagine the following scenario where we're trying to install the first event into our task 't': CPU0 CPU1 CPU2 (current == t) t->perf_event_ctxp[] = ctx; smp_mb(); cpu = task_cpu(t); switch(t, n); migrate(t, 2); switch(p, t); ctx = t->perf_event_ctxp[]; // must not be NULL smp_function_call(cpu, ..); generic_exec_single() func(); spin_lock(ctx->lock); if (task_curr(t)) // false add_event_to_ctx(); spin_unlock(ctx->lock); perf_event_context_sched_in(); spin_lock(ctx->lock); // sees event So its CPU0's store of t->perf_event_ctxp[] that must not go 'missing'. Because if CPU2's load of that variable were to observe NULL, it would not try to schedule the ctx and we'd have a task running without its counter, which would be 'bad'. As long as we observe !NULL, we'll acquire ctx->lock. If we acquire it first and not see the event yet, then CPU0 must observe task_curr() and retry. If the install happens first, then we must see the event on sched-in and all is well. I think we can translate the first part (until the 'must not be NULL') of the scenario to a litmus test like: C C-peterz { } P0(int *x, int *y) { int r1; WRITE_ONCE(*x, 1); smp_mb(); r1 = READ_ONCE(*y); } P1(int *y, int *z) { WRITE_ONCE(*y, 1); smp_store_release(z, 1); } P2(int *x, int *z) { int r1; int r2; r1 = smp_load_acquire(z); smp_mb(); r2 = READ_ONCE(*x); } exists (0:r1=0 /\ 2:r1=1 /\ 2:r2=0) Where: x is perf_event_ctxp[], y is our tasks's CPU, and z is our task being placed on the rq of CPU2. The P0 smp_mb() is the one added by this patch, ordering the store to perf_event_ctxp[] from find_get_context() and the load of task_cpu() in task_function_call(). The smp_store_release/smp_load_acquire model the RCpc locking of the rq->lock and the smp_mb() of P2 is the context switch switching from whatever CPU2 was running to our task 't'. This litmus test evaluates into: Test C-peterz Allowed States 7 0:r1=0; 2:r1=0; 2:r2=0; 0:r1=0; 2:r1=0; 2:r2=1; 0:r1=0; 2:r1=1; 2:r2=1; 0:r1=1; 2:r1=0; 2:r2=0; 0:r1=1; 2:r1=0; 2:r2=1; 0:r1=1; 2:r1=1; 2:r2=0; 0:r1=1; 2:r1=1; 2:r2=1; No Witnesses Positive: 0 Negative: 7 Condition exists (0:r1=0 /\ 2:r1=1 /\ 2:r2=0) Observation C-peterz Never 0 7 Hash=e427f41d9146b2a5445101d3e2fcaa34 And the strong and weak model agree. Reported-by: Mark Rutland <mark.rutland@arm.com> Tested-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: Stephane Eranian <eranian@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Vince Weaver <vincent.weaver@maine.edu> Cc: Will Deacon <will.deacon@arm.com> Cc: jeremy.linton@arm.com Link: http://lkml.kernel.org/r/20161209135900.GU3174@twins.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-05kernel/panic.c: add missing \nJiri Slaby
[ Upstream commit ff7a28a074ccbea999dadbb58c46212cf90984c6 ] When a system panics, the "Rebooting in X seconds.." message is never printed because it lacks a new line. Fix it. Link: http://lkml.kernel.org/r/20170119114751.2724-1-jslaby@suse.cz Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
