commit 047106adcc85e3023da210143a6ab8a55df9e0fc upstream.
Heiko reported a case where a timer interrupt managed to
reference a root_domain structure that was already freed by a
concurrent hot-un-plug operation.
Solve this like the regular sched_domain stuff is also
synchronized, by adding a synchronize_sched() stmt to the free
path, this ensures that a root_domain stays present for any
atomic section that could have observed it.
Reported-by: Heiko Carstens <heiko.carstens@de.ibm.com>
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com>
Cc: Gregory Haskins <ghaskins@novell.com>
Cc: Siddha Suresh B <suresh.b.siddha@intel.com>
LKML-Reference: <1258363873.26714.83.camel@laptop>
commit 6ad4c18884e864cf4c77f9074d3d1816063f99cd upstream.
Since (e761b77: cpu hotplug, sched: Introduce cpu_active_map and redo
sched domain managment) we have cpu_active_mask which is suppose to rule
scheduler migration and load-balancing, except it never (fully) did.
The particular problem being solved here is a crash in try_to_wake_up()
where select_task_rq() ends up selecting an offline cpu because
select_task_rq_fair() trusts the sched_domain tree to reflect the
current state of affairs, similarly select_task_rq_rt() trusts the
root_domain.
However, the sched_domains are updated from CPU_DEAD, which is after the
cpu is taken offline and after stop_machine is done. Therefore it can
race perfectly well with code assuming the domains are right.
Cure this by building the domains from cpu_active_mask on
CPU_DOWN_PREPARE.
LKML-Reference: <new-submission>
Cc: Holger Hoffstätte <holger.hoffstaette@googlemail.com>
sysctl_max_map_count-should-be-non-negative.patch
commit 3e26120cc7c819c97bc07281ca1fb9017cfe9a39 upstream.
It is a mistake that we used 'proc_dointvec', it should be
'proc_dointvec_minmax', as in the original patch.
Signed-off-by: WANG Cong <amwang@redhat.com>
commit 70da2340fbc68e91e701762f785479ab495a0869 upstream.
Jan Engelhardt reported we have this problem:
setting max_map_count to a value large enough results in programs dying at
first try. This is on 2.6.31.6:
15:59 borg:/proc/sys/vm # echo $[1<<31-1] >max_map_count
15:59 borg:/proc/sys/vm # cat max_map_count
1073741824
15:59 borg:/proc/sys/vm # echo $[1<<31] >max_map_count
Killed
This is because we have a chance to make 'max_map_count' negative. but
it's meaningless. Make it only accept non-negative values.
Reported-by: Jan Engelhardt <jengelh@medozas.de>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
commit 6e1415467614e854fee660ff6648bd10fa976e95 upstream.
In NOMMU mode clamp dac_mmap_min_addr to zero to cause the tests on it to be
skipped by the compiler. We do this as the minimum mmap address doesn't make
any sense in NOMMU mode.
mmap_min_addr and round_hint_to_min() can be discarded entirely in NOMMU mode.
Acked-by: Eric Paris <eparis@redhat.com>
Signed-off-by: James Morris <jmorris@namei.org>
commit bb6eddf7676e1c1f3e637aa93c5224488d99036f upstream.
Xiaotian Feng triggered a list corruption in the clock events list on
CPU hotplug and debugged the root cause.
If a CPU registers more than one per cpu clock event device, then only
the active clock event device is removed on CPU_DEAD. The unused
devices are kept in the clock events device list.
On CPU up the clock event devices are registered again, which means
that we list_add an already enqueued list_head. That results in list
corruption.
Resolve this by removing all devices which are associated to the dead
CPU on CPU_DEAD.
Reported-by: Xiaotian Feng <dfeng@redhat.com>
Tested-by: Xiaotian Feng <dfeng@redhat.com>
commit e4f4288842ee12747e10c354d72be7d424c0b627 upstream.
We should skip !SD_LOAD_BALANCE domains.
LKML-Reference: <20091216170517.653578430@chello.nl>
commit e6c8fba7771563b2f3dfb96a78f36ec17e15bdf0 upstream.
Make sure not to access sched_fair fields before verifying it is
indeed a sched_fair task.
LKML-Reference: <20091216170517.577998058@chello.nl>
commit 0f624e7e5625f4c30c836b7a5decfe2553582391 upstream.
It is quite legitimate for CPUs to be numbered sparsely, meaning
that it possible for an online CPU to have a number which is
greater than the total count of possible CPUs.
Currently find_get_context() has a sanity check on the cpu
number where it checks it against num_possible_cpus(). This
test can fail for a legitimate cpu number if the
cpu_possible_mask is sparsely populated.
This fixes the problem by checking the CPU number against
nr_cpumask_bits instead, since that is the appropriate check to
ensure that the cpu number is same to pass to cpu_isset()
subsequently.
Reported-by: Michael Neuling <mikey@neuling.org>
Tested-by: Michael Neuling <mikey@neuling.org>
Acked-by: Peter Zijlstra <peterz@infradead.org>
LKML-Reference: <20091215084032.GA18661@brick.ozlabs.ibm.com>
commit 722d0172377a5697919b9f7e5beb95165b1dec4e upstream.
get_user_pages() must be called with mmap_sem held.
Cc: Andrew Morton <akpm@linuxfoundation.org>
Cc: Nick Piggin <npiggin@suse.de>
Cc: Darren Hart <dvhltc@us.ibm.com>
LKML-Reference: <20091208121942.GA21298@basil.fritz.box>
commit 4b731d50ff3df6b9141a6c12b088e8eb0109e83c upstream.
commit d8e180dcd5bbbab9cd3ff2e779efcf70692ef541 "bsdacct: switch
credentials for writing to the accounting file" introduced credential
switching during final acct data collecting. However, uid/gid pair
continued to be collected from current which became credentials of who
created acct file, not who exits.
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=14676
Reported-by: Juho K. Juopperi <jkj@kapsi.fi>
Acked-by: Serge Hallyn <serue@us.ibm.com>
Reviewed-by: Michal Schmidt <mschmidt@redhat.com>
commit eae0c9dfb534cb3449888b9601228efa6480fdb5 upstream.
Commit 1b9508f, "Rate-limit newidle" has been confirmed to fix
the netperf UDP loopback regression reported by Alex Shi.
This is a cleanup and a fix:
- moved to a more out of the way spot
- fix to ensure that balancing doesn't try to balance
runqueues which haven't gone online yet, which can
mess up CPU enumeration during boot.
Reported-by: Alex Shi <alex.shi@intel.com>
Reported-by: Zhang, Yanmin <yanmin_zhang@linux.intel.com>
Signed-off-by: Mike Galbraith <efault@gmx.de>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
LKML-Reference: <1257821402.5648.17.camel@marge.simson.net>
commit 1b9508f6831e10d53256825de8904caa22d1ca2c upstream.
Rate limit newidle to migration_cost. It's a win for all
stages of sysbench oltp tests.
commit fd210738f6601d0fb462df9a2fe5a41896ff6a8f upstream.
Ingo Molnar reported:
[ 26.804000] BUG: using smp_processor_id() in preemptible [00000000] code: events/1/10
[ 26.808000] caller is vmstat_update+0x26/0x70
[ 26.812000] Pid: 10, comm: events/1 Not tainted 2.6.32-rc5 #6887
[ 26.816000] Call Trace:
[ 26.820000] [<c1924a24>] ? printk+0x28/0x3c
[ 26.824000] [<c13258a0>] debug_smp_processor_id+0xf0/0x110
[ 26.824000] mount used greatest stack depth: 1464 bytes left
[ 26.828000] [<c111d086>] vmstat_update+0x26/0x70
[ 26.832000] [<c1086418>] worker_thread+0x188/0x310
[ 26.836000] [<c10863b7>] ? worker_thread+0x127/0x310
[ 26.840000] [<c108d310>] ? autoremove_wake_function+0x0/0x60
[ 26.844000] [<c1086290>] ? worker_thread+0x0/0x310
[ 26.848000] [<c108cf0c>] kthread+0x7c/0x90
[ 26.852000] [<c108ce90>] ? kthread+0x0/0x90
[ 26.856000] [<c100c0a7>] kernel_thread_helper+0x7/0x10
[ 26.860000] BUG: using smp_processor_id() in preemptible [00000000] code: events/1/10
[ 26.864000] caller is vmstat_update+0x3c/0x70
Because this commit:
a1f84a3: sched: Check for an idle shared cache in select_task_rq_fair()
broke ->cpus_allowed.
Cc: arjan@infradead.org
LKML-Reference: <1257415066.12867.1.camel@marge.simson.net>
commit a1f84a3ab8e002159498814eaa7e48c33752b04b upstream.
When waking affine, check for an idle shared cache, and if
found, wake to that CPU/sibling instead of the waker's CPU.
This improves pgsql+oltp ramp up by roughly 8%. Possibly more
for other loads, depending on overlap. The trade-off is a
roughly 1% peak downturn if tasks are truly synchronous.
Cc: Arjan van de Ven <arjan@infradead.org>
LKML-Reference: <1256654138.17752.7.camel@marge.simson.net>
commit ec70ccd806111ba3caf596def91a8580138b12db upstream.
In the CONFIG_PERF_USE_VMALLOC case, perf_mmap_data_free() only
schedules the cleanup of the perf_mmap_data struct. In that
case we have to wait until the work has been done before we free
data.
Signed-off-by: Kristian Høgsberg <krh@bitplanet.net>
LKML-Reference: <1259697901-1747-1-git-send-email-krh@bitplanet.net>
commit 59d069eb5ae9b033ed1c124c92e1532c4a958991 upstream.
In current code in perf_swevent_hrtimer(), data.period is not
initialized, The result is obvious wrong:
# ./perf record -f -e cpu-clock make
# ./perf report
# Samples: 1740
# Overhead Command ......
1025422183050275328.00% sh libc-2.9.90.so ...
1025422183050275328.00% perl libperl.so ...
1025422168240043264.00% perl [kernel] ...
1025422030011210752.00% perl [kernel] ...
Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com>
LKML-Reference: <4B14E220.2050107@cn.fujitsu.com>
commit dbe01350fa8ce0c11948ab7d6be71a4d901be151 upstream.
Some variants of gcc are reputed to dislike forward references
to functions declared "inline". Remove the "inline" keyword
from such functions.
Cc: laijs@cn.fujitsu.com
Cc: dipankar@in.ibm.com
Cc: mathieu.desnoyers@polymtl.ca
Cc: josh@joshtriplett.org
Cc: dvhltc@us.ibm.com
Cc: niv@us.ibm.com
Cc: peterz@infradead.org
Cc: rostedt@goodmis.org
Cc: Valdis.Kletnieks@vt.edu
Cc: dhowells@redhat.com
Cc: Benjamin Gilbert <bgilbert@cs.cmu.edu>
LKML-Reference: <12578890422402-git-send-email->
commit 9160306e6f5b68bb64630c9031c517ca1cf463db upstream.
Impose a clear locking design on the note_new_gpnum()
function's use of the ->gpnum counter. This is done by updating
rdp->gpnum only from the corresponding leaf rcu_node structure's
rnp->gpnum field, and even then only under the protection of
that same rcu_node structure's ->lock field. Performance and
scalability are maintained using a form of double-checked
locking, and excessive spinning is avoided by use of the
spin_trylock() function. The use of spin_trylock() is safe due
to the fact that CPUs who fail to acquire this lock will try
again later. The hierarchical nature of the rcu_node data
structure limits contention (which could be limited further if
need be using the RCU_FANOUT kernel parameter).
Without this patch, obscure but quite possible races could
result in a quiescent state that occurred during one grace
period to be accounted to the following grace period, causing
this following grace period to end prematurely. Not good!
Cc: niv@us.ibm.com
LKML-Reference: <12571987492350-git-send-email->
commit d09b62dfa336447c52a5ec9bb88adbc479b0f3b8 upstream.
Impose a clear locking design on the rcu_process_gp_end()
function's use of the ->completed counter. This is done by
creating a ->completed field in the rcu_node structure, which
can safely be accessed under the protection of that structure's
lock. Performance and scalability are maintained by using a
form of double-checked locking, so that rcu_process_gp_end()
only acquires the leaf rcu_node structure's ->lock if a grace
period has recently ended.
This fix reduces rcutorture failure rate by at least two orders
of magnitude under heavy stress with force_quiescent_state()
being invoked artificially often. Without this fix,
unsynchronized access to the ->completed field can cause
rcu_process_gp_end() to advance callbacks whose grace period has
not yet expired. (Bad idea!)
Cc: niv@us.ibm.com
LKML-Reference: <12571987494069-git-send-email->
->completed counter
commit 281d150c5f8892f158747594ab49ce2823fd8b8c upstream.
Impose a clear locking design on non-NO_HZ handling of the
->completed counter. This increases the distance between the
RCU and the CPU-hotplug mechanisms.
Cc: niv@us.ibm.com
LKML-Reference: <12571987491353-git-send-email->
On the parisc architecture we face for each and every loaded kernel module
this kernel "badness warning":
sysfs: cannot create duplicate filename '/module/ac97_bus/sections/.text'
Badness at fs/sysfs/dir.c:487
Reason for that is, that on parisc all kernel modules do have multiple
.text sections due to the usage of the -ffunction-sections compiler flag
which is needed to reach all jump targets on this platform.
An objdump on such a kernel module gives:
Sections:
Idx Name Size VMA LMA File off Algn
0 .note.gnu.build-id 00000024 00000000 00000000 00000034 2**2
CONTENTS, ALLOC, LOAD, READONLY, DATA
1 .text 00000000 00000000 00000000 00000058 2**0
CONTENTS, ALLOC, LOAD, READONLY, CODE
2 .text.ac97_bus_match 0000001c 00000000 00000000 00000058 2**2
3 .text 00000000 00000000 00000000 000000d4 2**0
Since the .text sections are empty (size of 0 bytes) and won't be
loaded by the kernel module loader anyway, I don't see a reason
why such sections need to be listed under
/sys/module/<module_name>/sections/<section_name> either.
The attached patch does solve this issue by not exporting section
names which are empty.
This fixes bugzilla http://bugzilla.kernel.org/show_bug.cgi?id=14703
Signed-off-by: Helge Deller <deller@gmx.de>
CC: rusty@rustcorp.com.au
CC: akpm@linux-foundation.org
CC: James.Bottomley@HansenPartnership.com
CC: roland@redhat.com
CC: dave@hiauly1.hia.nrc.ca
Move slow_work's debugging proc file to debugfs.
Requested-and-acked-by: Ingo Molnar <mingo@elte.hu>
Commits 3d7a641 ("SLOW_WORK: Wait for outstanding work items belonging to a
module to clear") introduced some code to make sure that all of a module's
slow-work items were complete before that module was removed, and commit
3bde31a ("SLOW_WORK: Allow a requeueable work item to sleep till the thread is
needed") further extended that, breaking it in the process if CONFIG_MODULES=n:
CC kernel/slow-work.o
kernel/slow-work.c: In function 'slow_work_execute':
kernel/slow-work.c:313: error: 'slow_work_thread_processing' undeclared (first use in this function)
kernel/slow-work.c:313: error: (Each undeclared identifier is reported only once
kernel/slow-work.c:313: error: for each function it appears in.)
kernel/slow-work.c: In function 'slow_work_wait_for_items':
kernel/slow-work.c:950: error: 'slow_work_unreg_sync_lock' undeclared (first use in this function)
kernel/slow-work.c:951: error: 'slow_work_unreg_wq' undeclared (first use in this function)
kernel/slow-work.c:961: error: 'slow_work_unreg_work_item' undeclared (first use in this function)
kernel/slow-work.c:974: error: 'slow_work_unreg_module' undeclared (first use in this function)
kernel/slow-work.c:977: error: 'slow_work_thread_processing' undeclared (first use in this function)
make[1]: *** [kernel/slow-work.o] Error 1
Fix this by:
(1) Extracting the bits of slow_work_execute() that are contingent on
CONFIG_MODULES, and the bits that should be, into inline functions and
placing them into the #ifdef'd section that defines the relevant variables
and adding stubs for moduleless kernels. This allows the removal of some
#ifdefs.
(2) #ifdef'ing out the contents of slow_work_wait_for_items() in moduleless
kernels.
The four functions related to handling module unloading synchronisation (and
their associated variables) could be offloaded into a separate .c file, but
each function is only used once and three of them are tiny, so doing so would
prevent them from being inlined.
Reported-by: Ingo Molnar <mingo@elte.hu>
Add a function to allow a requeueable work item to sleep till the thread
processing it is needed by the slow-work facility to perform other work.
Sometimes a work item can't progress immediately, but must wait for the
completion of another work item that's currently being processed by another
slow-work thread.
In some circumstances, the waiting item could instead - theoretically - put
itself back on the queue and yield its thread back to the slow-work facility,
thus waiting till it gets processing time again before attempting to progress.
This would allow other work items processing time on that thread.
However, this only works if there is something on the queue for it to queue
behind - otherwise it will just get a thread again immediately, and will end
up cycling between the queue and the thread, eating up valuable CPU time.
So, slow_work_sleep_till_thread_needed() is provided such that an item can put
itself on a wait queue that will wake it up when the event it is actually
interested in occurs, then call this function in lieu of calling schedule().
This function will then sleep until either the item's event occurs or another
work item appears on the queue. If another work item is queued, but the
item's event hasn't occurred, then the work item should requeue itself and
yield the thread back to the slow-work facility by returning.
This can be used by CacheFiles for an object that is being created on one
thread to wait for an object being deleted on another thread where there is
nothing on the queue for the creation to go and wait behind. As soon as an
item appears on the queue that could be given thread time instead, CacheFiles
can stick the creating object back on the queue and return to the slow-work
facility - assuming the object deletion didn't also complete.
Allow the executing and queued work items to be viewed through a /proc file
for debugging purposes. The contents look something like the following:
THR PID ITEM ADDR FL MARK DESC
0 3005 ffff880023f52348 a 952ms FSC: OBJ17d3: LOOK
1 3006 ffff880024e33668 2 160ms FSC: OBJ17e5 OP60d3b: Write1/Store fl=2
2 3165 ffff8800296dd180 a 424ms FSC: OBJ17e4: LOOK
3 4089 ffff8800262c8d78 a 212ms FSC: OBJ17ea: CRTN
4 4090 ffff88002792bed8 2 388ms FSC: OBJ17e8 OP60d36: Write1/Store fl=2
5 4092 ffff88002a0ef308 2 388ms FSC: OBJ17e7 OP60d2e: Write1/Store fl=2
6 4094 ffff88002abaf4b8 2 132ms FSC: OBJ17e2 OP60d4e: Write1/Store fl=2
7 4095 ffff88002bb188e0 a 388ms FSC: OBJ17e9: CRTN
vsq - ffff880023d99668 1 308ms FSC: OBJ17e0 OP60f91: Write1/EnQ fl=2
vsq - ffff8800295d1740 1 212ms FSC: OBJ16be OP4d4b6: Write1/EnQ fl=2
vsq - ffff880025ba3308 1 160ms FSC: OBJ179a OP58dec: Write1/EnQ fl=2
vsq - ffff880024ec83e0 1 160ms FSC: OBJ17ae OP599f2: Write1/EnQ fl=2
vsq - ffff880026618e00 1 160ms FSC: OBJ17e6 OP60d33: Write1/EnQ fl=2
vsq - ffff880025a2a4b8 1 132ms FSC: OBJ16a2 OP4d583: Write1/EnQ fl=2
vsq - ffff880023cbe6d8 9 212ms FSC: OBJ17eb: LOOK
vsq - ffff880024d37590 9 212ms FSC: OBJ17ec: LOOK
vsq - ffff880027746cb0 9 212ms FSC: OBJ17ed: LOOK
vsq - ffff880024d37ae8 9 212ms FSC: OBJ17ee: LOOK
vsq - ffff880024d37cb0 9 212ms FSC: OBJ17ef: LOOK
vsq - ffff880025036550 9 212ms FSC: OBJ17f0: LOOK
vsq - ffff8800250368e0 9 212ms FSC: OBJ17f1: LOOK
vsq - ffff880025036aa8 9 212ms FSC: OBJ17f2: LOOK
In the 'THR' column, executing items show the thread they're occupying and
queued threads indicate which queue they're on. 'PID' shows the process ID of
a slow-work thread that's executing something. 'FL' shows the work item flags.
'MARK' indicates how long since an item was queued or began executing. Lastly,
the 'DESC' column permits the owner of an item to give some information.
This adds support for starting slow work with a delay, similar
to the functionality we have for workqueues.
Add support for cancellation of queued slow work and delayed slow work items.
The cancellation functions will wait for items that are pending or undergoing
execution to be discarded by the slow work facility.
Attempting to enqueue work that is in the process of being cancelled will
result in ECANCELED.
Make the ability for the slow-work facility to take references on a work item
optional as not everyone requires this.
Even the internal slow-work stubs them out, so those can be got rid of too.
Wait for outstanding slow work items belonging to a module to clear when
unregistering that module as a user of the facility. This prevents the put_ref
code of a work item from being taken away before it returns.
Commit 65a64464349883891e21e74af16c05d6e1eeb4e9 ("HWPOISON: Allow
schedule_on_each_cpu() from keventd") which allows schedule_on_each_cpu()
to be called from keventd added a race condition. schedule_on_each_cpu()
may race with cpu hotplug and end up executing the function twice on a
cpu.
Fix it by moving direct execution into the section protected with
get/put_online_cpus(). While at it, update code such that direct
execution is done after works have been scheduled for all other cpus and
drop unnecessary cpu != orig test from flush loop.
Acked-by: Oleg Nesterov <oleg@redhat.com>
* 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
highmem: Fix debug_kmap_atomic() to also handle KM_IRQ_PTE, KM_NMI, and KM_NMI_PTE
highmem: Fix race in debug_kmap_atomic() which could cause warn_count to underflow
rcu: Fix long-grace-period race between forcing and initialization
uids: Prevent tear down race
* 'irq-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
genirq: try_one_irq() must be called with irq disabled
root_task_group_empty is used only with FAIR_GROUP_SCHED
so if we use other scheduler options we get:
kernel/sched.c:314: warning: 'root_task_group_empty' defined but not used
So move CONFIG_FAIR_GROUP_SCHED up that it covers
root_task_group_empty().
Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org>
LKML-Reference: <20091026192414.GB5321@lenovo>
Fix variable name in sched.c kernel-doc notation.
Fixes this DocBook warning:
Warning(kernel/sched.c:2008): No description found for parameter
'p' Warning(kernel/sched.c:2008): Excess function parameter 'k'
description in 'kthread_bind'
LKML-Reference: <4AF4B1BC.8020604@oracle.com>
Prarit reported:
[ INFO: inconsistent lock state ]
2.6.32-rc5 #1
inconsistent {IN-HARDIRQ-W} -> {HARDIRQ-ON-W} usage.
swapper/0 [HC0[0]:SC1[1]:HE1:SE0] takes:
(&irq_desc_lock_class){?.-...}, at: [<ffffffff810c264e>] try_one_irq+0x32/0x138
{IN-HARDIRQ-W} state was registered at:
[<ffffffff81095160>] __lock_acquire+0x2fc/0xd5d
[<ffffffff81095cb4>] lock_acquire+0xf3/0x12d
[<ffffffff814cdadd>] _spin_lock+0x40/0x89
[<ffffffff810c3389>] handle_level_irq+0x30/0x105
[<ffffffff81014e0e>] handle_irq+0x95/0xb7
[<ffffffff810141bd>] do_IRQ+0x6a/0xe0
[<ffffffff81012813>] ret_from_intr+0x0/0x16
irq event stamp: 195096
hardirqs last enabled at (195096): [<ffffffff814cd7f7>] _spin_unlock_irq+0x3a/0x5c
hardirqs last disabled at (195095): [<ffffffff814cdbdd>] _spin_lock_irq+0x29/0x95
softirqs last enabled at (195088): [<ffffffff81068c92>] __do_softirq+0x1c1/0x1ef
softirqs last disabled at (195093): [<ffffffff8101304c>] call_softirq+0x1c/0x30
1 lock held by swapper/0:
#0: (kernel/irq/spurious.c:21){+.-...}, at: [<ffffffff81070cf2>]
run_timer_softirq+0x1a9/0x315
stack backtrace:
Pid: 0, comm: swapper Not tainted 2.6.32-rc5 #1
Call Trace:
<IRQ> [<ffffffff81093e94>] valid_state+0x187/0x1ae
[<ffffffff81093fe4>] mark_lock+0x129/0x253
[<ffffffff810951d4>] __lock_acquire+0x370/0xd5d
[<ffffffff810c2795>] poll_all_shared_irqs+0x41/0x6d
[<ffffffff810c27dd>] poll_spurious_irqs+0x1c/0x49
[<ffffffff81070d82>] run_timer_softirq+0x239/0x315
[<ffffffff81068bd3>] __do_softirq+0x102/0x1ef
[<ffffffff81014b65>] do_softirq+0x59/0xca
[<ffffffff810686ad>] irq_exit+0x58/0xae
[<ffffffff81029b84>] smp_apic_timer_interrupt+0x94/0xba
[<ffffffff81012a33>] apic_timer_interrupt+0x13/0x20
The reason is that try_one_irq() is called from hardirq context with
interrupts disabled and from softirq context (poll_all_shared_irqs())
with interrupts enabled.
Disable interrupts before calling it from poll_all_shared_irqs().
Reported-and-tested-by: Prarit Bhargava <prarit@redhat.com>
Signed-off-by: Yong Zhang <yong.zhang0@gmail.com>
LKML-Reference: <1257563773-4620-1-git-send-email-yong.zhang0@gmail.com>
* 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
sched: Fix kthread_bind() by moving the body of kthread_bind() to sched.c
sched: Disable SD_PREFER_LOCAL at node level
sched: Fix boot crash by zalloc()ing most of the cpu masks
sched: Strengthen buddies and mitigate buddy induced latencies
* 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
ftrace: Fix unmatched locking in ftrace_regex_write()
ring-buffer: Synchronize resizing buffer with reader lock
When a command is passed to the set_ftrace_filter, then
the ftrace_regex_lock is still held going back to user space.
# echo 'do_open : foo' > set_ftrace_filter
(still holding ftrace_regex_lock when returning to user space!)
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
LKML-Reference: <4AEF7F8A.3080300@cn.fujitsu.com>
We got a sudden panic when we reduced the size of the
ringbuffer.
We can reproduce the panic by the following steps:
echo 1 > events/sched/enable
cat trace_pipe > /dev/null &
while ((1))
do
echo 12000 > buffer_size_kb
echo 512 > buffer_size_kb
done
(not more than 5 seconds, panic ...)
Reported-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
LKML-Reference: <4AF01735.9060409@cn.fujitsu.com>
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6
* 'pm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6:
PM: Remove some debug messages producing too much noise
PM: Fix warning on suspend errors
PM / Hibernate: Add newline to load_image() fail path
PM / Hibernate: Fix error handling in save_image()
PM / Hibernate: Fix blkdev refleaks
PM / yenta: Split resume into early and late parts (rev. 4)
nr_processes() returns the sum of the per cpu counter process_counts for
all online CPUs. This counter is incremented for the current CPU on
fork() and decremented for the current CPU on exit(). Since a process
does not necessarily fork and exit on the same CPU the process_count for
an individual CPU can be either positive or negative and effectively has
no meaning in isolation.
Therefore calculating the sum of process_counts over only the online
CPUs omits the processes which were started or stopped on any CPU which
has since been unplugged. Only the sum of process_counts across all
possible CPUs has meaning.
The only caller of nr_processes() is proc_root_getattr() which
calculates the number of links to /proc as
stat->nlink = proc_root.nlink + nr_processes();
You don't have to be all that unlucky for the nr_processes() to return a
negative value leading to a negative number of links (or rather, an
apparently enormous number of links). If this happens then you can get
failures where things like "ls /proc" start to fail because they got an
-EOVERFLOW from some stat() call.
Example with some debugging inserted to show what goes on:
# ps haux|wc -l
nr_processes: CPU0: 90
nr_processes: CPU1: 1030
nr_processes: CPU2: -900
nr_processes: CPU3: -136
nr_processes: TOTAL: 84
proc_root_getattr. nlink 12 + nr_processes() 84 = 96
84
# echo 0 >/sys/devices/system/cpu/cpu1/online
# ps haux|wc -l
nr_processes: CPU0: 85
nr_processes: CPU2: -901
nr_processes: CPU3: -137
nr_processes: TOTAL: -953
proc_root_getattr. nlink 12 + nr_processes() -953 = -941
75
# stat /proc/
nr_processes: CPU0: 84
nr_processes: TOTAL: -954
proc_root_getattr. nlink 12 + nr_processes() -954 = -942
File: `/proc/'
Size: 0 Blocks: 0 IO Block: 1024 directory
Device: 3h/3d Inode: 1 Links: 4294966354
Access: (0555/dr-xr-xr-x) Uid: ( 0/ root) Gid: ( 0/ root)
Access: 2009-11-03 09:06:55.000000000 +0000
Modify: 2009-11-03 09:06:55.000000000 +0000
Change: 2009-11-03 09:06:55.000000000 +0000
I'm not 100% convinced that the per_cpu regions remain valid for offline
CPUs, although my testing suggests that they do. If not then I think the
correct solution would be to aggregate the process_count for a given CPU
into a global base value in cpu_down().
This bug appears to pre-date the transition to git and it looks like it
may even have been present in linux-2.6.0-test7-bk3 since it looks like
the code Rusty patched in http://lwn.net/Articles/64773/ was already
wrong.
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
Finish a line by \n when load_image fails in the middle of loading.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Acked-by: Pavel Machek <pavel@ucw.cz>
There are too many retval variables in save_image(). Thus error return
value from snapshot_read_next() may be ignored and only part of the
snapshot (successfully) written.
Remove 'error' variable, invert the condition in the do-while loop
and convert the loop to use only 'ret' variable.
Switch the rest of the function to consider only 'ret'.
Also make sure we end printed line by \n if an error occurs.
While cruising through the swsusp code I found few blkdev reference
leaks of resume_bdev.
swsusp_read: remove blkdev_put altogether. Some fail paths do
not do that.
swsusp_check: make sure we always put a reference on fail paths
software_resume: all fail paths between swsusp_check and swsusp_read
omit swsusp_close. Add it in those cases. And since
swsusp_read doesn't drop the reference anymore, do
it here unconditionally.
[rjw: Fixed a small coding style issue.]
Eric Paris reported that commit
f685ceacab07d3f6c236f04803e2f2f0dbcc5afb causes boot time
PREEMPT_DEBUG complaints.
[ 4.590699] BUG: using smp_processor_id() in preemptible [00000000] code: rmmod/1314
[ 4.593043] caller is task_hot+0x86/0xd0
Since kthread_bind() messes with scheduler internals, move the
body to sched.c, and lock the runqueue.
Reported-by: Eric Paris <eparis@redhat.com>
Tested-by: Eric Paris <eparis@redhat.com>
LKML-Reference: <1256813310.7574.3.camel@marge.simson.net>
[ v2: fix !SMP build and clean up ]
futex: Fix spurious wakeup for requeue_pi really
* 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
perf tools: Remove -Wcast-align
perf tools: Fix compatibility with libelf 0.8 and autodetect
perf events: Don't generate events for the idle task when exclude_idle is set
perf events: Fix swevent hrtimer sampling by keeping track of remaining time when enabling/disabling swevent hrtimers
tracing: Remove cpu arg from the rb_time_stamp() function
tracing: Fix comment typo and documentation example
tracing: Fix trace_seq_printf() return value
tracing: Update *ppos instead of filp->f_pos
Very long RCU read-side critical sections (50 milliseconds or
so) can cause a race between force_quiescent_state() and
rcu_start_gp() as follows on kernel builds with multi-level
rcu_node hierarchies:
1. CPU 0 calls force_quiescent_state(), sees that there is a
grace period in progress, and acquires ->fsqlock.
2. CPU 1 detects the end of the grace period, and so
cpu_quiet_msk_finish() sets rsp->completed to rsp->gpnum.
This operation is carried out under the root rnp->lock,
but CPU 0 has not yet acquired that lock. Note that
rsp->signaled is still RCU_SAVE_DYNTICK from the last
grace period.
3. CPU 1 calls rcu_start_gp(), but no one wants a new grace
period, so it drops the root rnp->lock and returns.
4. CPU 0 acquires the root rnp->lock and picks up rsp->completed
and rsp->signaled, then drops rnp->lock. It then enters the
RCU_SAVE_DYNTICK leg of the switch statement.
5. CPU 2 invokes call_rcu(), and now needs a new grace period.
It calls rcu_start_gp(), which acquires the root rnp->lock, sets
rsp->signaled to RCU_GP_INIT (too bad that CPU 0 is already in
the RCU_SAVE_DYNTICK leg of the switch statement!) and starts
initializing the rcu_node hierarchy. If there are multiple
levels to the hierarchy, it will drop the root rnp->lock and
initialize the lower levels of the hierarchy.
6. CPU 0 notes that rsp->completed has not changed, which permits
both CPU 2 and CPU 0 to try updating it concurrently. If CPU 0's
update prevails, later calls to force_quiescent_state() can
count old quiescent states against the new grace period, which
can in turn result in premature ending of grace periods.
Not good.
This patch adds an RCU_GP_IDLE state for rsp->signaled that is
set initially at boot time and any time a grace period ends.
This prevents CPU 0 from getting into the workings of
force_quiescent_state() in step 4. Additional locking and
checks prevent the concurrent update of rsp->signaled in step 6.
Cc: niv@us.ibm.com
LKML-Reference: <1256742889199-git-send-email->
