The scheduler will stop load balancing if the most busy processor contains
processes pinned via processor affinity.
The scheduler currently only does one search for busiest cpu. If it cannot
pull any tasks away from the busiest cpu because they were pinned then the
scheduler goes into a corner and sulks leaving the idle processors idle.
F.e. If you have processor 0 busy running four tasks pinned via taskset,
there are none on processor 1 and one just started two processes on
processor 2 then the scheduler will not move one of the two processes away
from processor 2.
This patch fixes that issue by forcing the scheduler to come out of its
corner and retrying the load balancing by considering other processors for
load balancing.
This patch was originally developed by John Hawkes and discussed at
http://marc.theaimsgroup.com/?l=linux-kernel&m=113901368523205&w=2.
I have removed extraneous material and gone back to equipping struct rq
with the cpu the queue is associated with since this makes the patch much
easier and it is likely that others in the future will have the same
difficulty of figuring out which processor owns which runqueue.
The overhead added through these patches is a single word on the stack if
the kernel is configured to support 32 cpus or less (32 bit). For 32 bit
environments the maximum number of cpus that can be configued is 255 which
would result in the use of 32 bytes additional on the stack. On IA64 up to
1k cpus can be configured which will result in the use of 128 additional
bytes on the stack. The maximum additional cache footprint is one
cacheline. Typically memory use will be much less than a cacheline and the
additional cpumask will be placed on the stack in a cacheline that already
contains other local variable.
Signed-off-by: Christoph Lameter <clameter@sgi.com>
The integer divisions in the timer accounting code can round the result
down to 0. Adding 0 is without effect and the signal delivery stops.
Clamp the division result to minimum 1 to avoid this.
Problem was reported by Seongbae Park <spark@google.com>, who provided
also an inital patch.
Roland sayeth:
I have had some more time to think about the problem, and to reproduce it
using Toyo's test case. For the record, if my understanding of the problem
is correct, this happens only in one very particular case. First, the
expiry time has to be so soon that in cputime_t units (usually 1s/HZ ticks)
it's < nthreads so the division yields zero. Second, it only affects each
thread that is so new that its CPU time accumulation is zero so now+0 is
still zero and ->it_*_expires winds up staying zero. For the VIRT and PROF
clocks when cputime_t is tick granularity (or the SCHED clock on
configurations where sched_clock's value only advances on clock ticks), this
is not hard to arrange with new threads starting up and blocking before they
accumulate a whole tick of CPU time. That's what happens in Toyo's test
case.
Note that in general it is fine for that division to round down to zero,
and set each thread's expiry time to its "now" time. The problem only
arises with thread's whose "now" value is still zero, so that now+0 winds up
0 and is interpreted as "not set" instead of ">= now". So it would be a
sufficient and more precise fix to just use max(ticks, 1) inside the loop
when setting each it_*_expires value.
But, it does no harm to round the division up to one and always advance
every thread's expiry time. If the thread didn't already fire timers for
the expiry time of "now", there is no expectation that it will do so before
the next tick anyway. So I followed Thomas's patch in lifting the max out
of the loops.
This patch also covers the reload cases, which are harder to write a test
for (and I didn't try). I've tested it with Toyo's case and it fixes that.
[toyoa@mvista.com: fix: min_t -> max_t]
Signed-off-by: Roland McGrath <roland@redhat.com>
There is a race between call_usermodehelper_keys, __call_usermodehelper
and wait_for_helper. It should only happen if preemption is enabled or
on a virtualized system.
If the cpu is preempted or put to sleep by the hypervisor in
__call_usermodehelper between the creation of the wait_for_helper
thread and the second check on sub_info->wait, the whole execution
of wait_for_helper including the complete call and the continuation
after the wait_for_completion in call_usermodehelper_keys can have
happened before __call_usermodehelper checks sub_info->wait for the
second time. Since sub_info can already have been clobbered,
sub_info->wait could be zero and complete is called a second time
with an invalid argument. This has happened on s390. It took me only
three days to find out ..
Thanks to Arnd Bergmann for his help to spot this bug.
Kenneth Lee also sent the same patch independently.
This patch adds a barrier() in futex unqueue_me to avoid aliasing of two
pointers.
On my s390x system I saw the following oops:
Unable to handle kernel pointer dereference at virtual kernel address
0000000000000000
Oops: 0004 [#1]
CPU: 0 Not tainted
Process mytool (pid: 13613, task: 000000003ecb6ac0, ksp: 00000000366bdbd8)
Krnl PSW : 0704d00180000000 00000000003c9ac2 (_spin_lock+0xe/0x30)
Krnl GPRS: 00000000ffffffff 000000003ecb6ac0 0000000000000000 0700000000000000
0000000000000000 0000000000000000 000001fe00002028 00000000000c091f
000001fe00002054 000001fe00002054 0000000000000000 00000000366bddc0
00000000005ef8c0 00000000003d00e8 0000000000144f91 00000000366bdcb8
Krnl Code: ba 4e 20 00 12 44 b9 16 00 3e a7 84 00 08 e3 e0 f0 88 00 04
Call Trace:
([<0000000000144f90>] unqueue_me+0x40/0xe4)
[<0000000000145a0c>] do_futex+0x33c/0xc40
[<000000000014643e>] sys_futex+0x12e/0x144
[<000000000010bb00>] sysc_noemu+0x10/0x16
[<000002000003741c>] 0x2000003741c
The code in question is:
static int unqueue_me(struct futex_q *q)
int ret = 0;
spinlock_t *lock_ptr;
/* In the common case we don't take the spinlock, which is nice. */
retry:
lock_ptr = q->lock_ptr;
if (lock_ptr != 0) {
spin_lock(lock_ptr);
* q->lock_ptr can change between reading it and
* spin_lock(), causing us to take the wrong lock. This
* corrects the race condition.
and my compiler (gcc 4.1.0) makes the following out of it:
00000000000003c8 <unqueue_me>:
3c8: eb bf f0 70 00 24 stmg %r11,%r15,112(%r15)
3ce: c0 d0 00 00 00 00 larl %r13,3ce <unqueue_me+0x6>
3d0: R_390_PC32DBL .rodata+0x2a
3d4: a7 f1 1e 00 tml %r15,7680
3d8: a7 84 00 01 je 3da <unqueue_me+0x12>
3dc: b9 04 00 ef lgr %r14,%r15
3e0: a7 fb ff d0 aghi %r15,-48
3e4: b9 04 00 b2 lgr %r11,%r2
3e8: e3 e0 f0 98 00 24 stg %r14,152(%r15)
3ee: e3 c0 b0 28 00 04 lg %r12,40(%r11)
/* write q->lock_ptr in r12 */
3f4: b9 02 00 cc ltgr %r12,%r12
3f8: a7 84 00 4b je 48e <unqueue_me+0xc6>
/* if r12 is zero then jump over the code.... */
3fc: e3 20 b0 28 00 04 lg %r2,40(%r11)
/* write q->lock_ptr in r2 */
402: c0 e5 00 00 00 00 brasl %r14,402 <unqueue_me+0x3a>
404: R_390_PC32DBL _spin_lock+0x2
/* use r2 as parameter for spin_lock */
So the code becomes more or less:
if (q->lock_ptr != 0) spin_lock(q->lock_ptr)
instead of
if (lock_ptr != 0) spin_lock(lock_ptr)
Which caused the oops from above.
After adding a barrier gcc creates code without this problem:
[...] (the same)
3f8: b9 04 00 2c lgr %r2,%r12
3fc: a7 84 00 48 je 48c <unqueue_me+0xc4>
400: c0 e5 00 00 00 00 brasl %r14,400 <unqueue_me+0x38>
402: R_390_PC32DBL _spin_lock+0x2
As a general note, this code of unqueue_me seems a bit fishy. The retry logic
of unqueue_me only works if we can guarantee, that the original value of
q->lock_ptr is always a spinlock (Otherwise we overwrite kernel memory). We
know that q->lock_ptr can change. I dont know what happens with the original
spinlock, as I am not an expert with the futex code.
Signed-off-by: Christian Borntraeger <borntrae@de.ibm.com>
Acked-by: Ingo Molnar <mingo@redhat.com>
Remove SWSUSP_ENCRYPT config option; it is no longer implemented.
Signed-off-by: Pavel Machek <pavel@suse.cz>
Based on a patch from Ernie Petrides
During security research, Red Hat discovered a behavioral flaw in core
dump handling. A local user could create a program that would cause a
core file to be dumped into a directory they would not normally have
permissions to write to. This could lead to a denial of service (disk
consumption), or allow the local user to gain root privileges.
do_exit() clears ->it_##clock##_expires, but nothing prevents
another cpu to attach the timer to exiting process after that.
arm_timer() tries to protect against this race, but the check
is racy.
After exit_notify() does 'write_unlock_irq(&tasklist_lock)' and
before do_exit() calls 'schedule() local timer interrupt can find
tsk->exit_state != 0. If that state was EXIT_DEAD (or another cpu
does sys_wait4) interrupted task has ->signal == NULL.
At this moment exiting task has no pending cpu timers, they were
cleanuped in __exit_signal()->posix_cpu_timers_exit{,_group}(),
so we can just return from irq.
John Stultz recently confirmed this bug, see
http://marc.theaimsgroup.com/?l=linux-kernel&m=115015841413687
Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
If the local timer interrupt happens just after do_exit() sets PF_EXITING
(and before it clears ->it_xxx_expires) run_posix_cpu_timers() will call
check_process_timers() with tasklist_lock + ->siglock held and
check_process_timers:
t = tsk;
do {
do {
t = next_thread(t);
} while (unlikely(t->flags & PF_EXITING));
} while (t != tsk);
the outer loop will never stop.
Actually, the window is bigger. Another process can attach the timer
after ->it_xxx_expires was cleared (see the next commit) and the 'if
(PF_EXITING)' check in arm_timer() is racy (see the one after that).
Eric Biederman points out that we can't take the task_lock while holding
tasklist_lock for writing, because another CPU that holds the task lock
might take an interrupt that then tries to take tasklist_lock for writing.
Which would be a nasty deadlock, with one CPU spinning forever in an
interrupt handler (although admittedly you need to really work at
triggering it ;)
Since the ptrace_attach() code is special and very unusual, just make it
be extra careful, and use trylock+repeat to avoid the possible deadlock.
Cc: Oleg Nesterov <oleg@tv-sign.ru>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Roland McGrath <roland@redhat.com>
This holds the task lock (and, for ptrace_attach, the tasklist_lock)
over the actual attach event, which closes a race between attacking to a
thread that is either doing a PTRACE_TRACEME or getting de-threaded.
Thanks to Oleg Nesterov for reminding me about this, and Chris Wright
for noticing a lost return value in my first version.
hi,
The motivation behind the patch below was to address messages in
/var/log/messages such as:
Jan 31 10:54:15 mets kernel: audit(:0): major=252 name_count=0: freeing
multiple contexts (1)
Jan 31 10:54:15 mets kernel: audit(:0): major=113 name_count=0: freeing
multiple contexts (2)
I can reproduce by running 'get-edid' from:
http://john.fremlin.de/programs/linux/read-edid/.
These messages come about in the log b/c the vm86 calls do not exit via
the normal system call exit paths and thus do not call
'audit_syscall_exit'. The next system call will then free the context for
itself and for the vm86 context, thus generating the above messages. This
patch addresses the issue by simply adding a call to 'audit_syscall_exit'
from the vm86 code.
Besides fixing the above error messages the patch also now allows vm86
system calls to become auditable. This is useful since strace does not
appear to properly record the return values from sys_vm86.
I think this patch is also a step in the right direction in terms of
cleaning up some core auditing code. If we can correct any other paths
that do not properly call the audit exit and entries points, then we can
also eliminate the notion of context chaining.
I've tested this patch by verifying that the log messages no longer
appear, and that the audit records for sys_vm86 appear to be correct.
Also, 'read_edid' produces itentical output.
thanks,
-Jason
Signed-off-by: Jason Baron <jbaron@redhat.com>
Those also break userland regs like following.
00000000 <sys_chown16>:
0: 0f b7 44 24 0c movzwl 0xc(%esp),%eax
5: 83 ca ff or $0xffffffff,%edx
8: 0f b7 4c 24 08 movzwl 0x8(%esp),%ecx
d: 66 83 f8 ff cmp $0xffffffff,%ax
11: 0f 44 c2 cmove %edx,%eax
14: 66 83 f9 ff cmp $0xffffffff,%cx
18: 0f 45 d1 cmovne %ecx,%edx
1b: 89 44 24 0c mov %eax,0xc(%esp)
1f: 89 54 24 08 mov %edx,0x8(%esp)
23: e9 fc ff ff ff jmp 24 <sys_chown16+0x24>
where the tailcall at the end overwrites the incoming stack-frame.
Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
This reverts most of commit 30e0fca6c1d7d26f3f2daa4dd2b12c51dadc778a.
It broke the case of non-leader MT exec when ptraced.
I think the bug it was intended to fix was already addressed by commit
788e05a67c343fa22f2ae1d3ca264e7f15c25eaf.
strace /bin/bash misbehaves after resume; this fixes it.
(akpm: it's scary calling refrigerator() in state TASK_TRACED, but it seems to
do the right thing).
At present the kernel doesn't honour an attempt to set RLIMIT_CPU to zero
seconds. But the spec says it should, and that's what 2.4.x does.
Fixing this for real would involve some complexity (such as adding a new
it-has-been-set flag to the task_struct, and testing that everwhere, instead
of overloading the value of it_prof_expires).
Given that a 2.4 kernel won't actually send the signal until one second has
expired anyway, let's just handle this case by treating the caller's
zero-seconds as one second.
Cc: Ulrich Weigand <uweigand@de.ibm.com>
Cc: Cliff Wickman <cpw@sgi.com>
made this BUG_ON() unsafe. This code runs under ->siglock,
while switch_exec_pids() takes tasklist_lock.
If the change of personality does not lead to change of exec domain,
__set_personality() returned without releasing the module reference
acquired by lookup_exec_domain().
This patch was already included in Linus' tree.
Signed-off-by: Sergey Vlasov <vsu@altlinux.ru>
Wrong error path in dup_fd() - it should return NULL on error,
not an address of already freed memory :/
Triggered by OpenVZ stress test suite.
What is interesting is that it was causing different oopses in RCU like
below:
Call Trace:
[<c013492c>] rcu_do_batch+0x2c/0x80
[<c0134bdd>] rcu_process_callbacks+0x3d/0x70
[<c0126cf3>] tasklet_action+0x73/0xe0
[<c01269aa>] __do_softirq+0x10a/0x130
[<c01058ff>] do_softirq+0x4f/0x60
[<c0113817>] smp_apic_timer_interrupt+0x77/0x110
[<c0103b54>] apic_timer_interrupt+0x1c/0x24
Code: Bad EIP value.
<0>Kernel panic - not syncing: Fatal exception in interrupt
Signed-Off-By: Pavel Emelianov <xemul@sw.ru>
Signed-Off-By: Dmitry Mishin <dim@openvz.org>
Signed-Off-By: Kirill Korotaev <dev@openvz.org>
Signed-Off-By: Linus Torvalds <torvalds@osdl.org>
We have noticed lockups during boot when stress testing kexec on ppc64.
Two cpus would deadlock in scheduler code trying to grab already taken
spinlocks.
The double_rq_lock code uses the address of the runqueue to order the
taking of multiple locks. This address is a per cpu variable:
if (rq1 < rq2) {
spin_lock(&rq1->lock);
spin_lock(&rq2->lock);
} else {
On the other hand, the code in wake_sleeping_dependent uses the cpu id
order to grab locks:
for_each_cpu_mask(i, sibling_map)
spin_lock(&cpu_rq(i)->lock);
This means we rely on the address of per cpu data increasing as cpu ids
increase. While this will be true for the generic percpu implementation it
may not be true for arch specific implementations.
One way to solve this is to always take runqueues in cpu id order. To do
this we add a cpu variable to the runqueue and check it in the
double runqueue locking functions.
sys_unshare() does mmput(new_mm). This is not enough if we have
mm->core_waiters.
This patch is a temporary fix for soon to be released 2.6.16.
[ Checked with Uli: "I'm not planning to use unshare(CLONE_VM). It's
not needed for any functionality planned so far. What we (as in Red
Hat) need unshare() for now is the filesystem side." ]
When the posix-timer signal is ignored then the timer is rearmed by the
callback function. The requeue pending accounting has to be fixed up else
the state might be wrong.
Signed-off-by: Roman Zippel <zippel@linux-m68k.org>
The pointer to the current time interpolator and the current list of time
interpolators are typically only changed during bootup. Adding
__read_mostly takes them away from possibly hot cachelines.
The sighand pointer only needs the rcu_read_lock on the
read side. So only depending on task_lock protection
when setting this pointer is not enough. We also need
a memory barrier to ensure the initialization is seen first.
Use rcu_assign_pointer as it does this for us, and clearly
documents that we are setting an rcu readable pointer.
Acked-by: Paul E. McKenney <paulmck@us.ibm.com>
This patch fixes alternate signal stack corruption among cloned threads
with CLONE_SIGHAND (and CLONE_VM) for linux-2.6.16-rc6.
The value of alternate signal stack is currently inherited after a call of
clone(... CLONE_SIGHAND | CLONE_VM). But if sigaltstack is set by a
parent thread, and then if multiple cloned child threads (+ parent threads)
call signal handler at the same time, some threads may be conflicted -
because they share to use the same alternative signal stack region.
Finally they get sigsegv. It's an undesirable race condition. Note that
child threads created from NPTL pthread_create() also hit this conflict
when the parent thread uses sigaltstack, without my patch.
To fix this problem, this patch clears the child threads' sigaltstack
information like exec(). This behavior follows the SUSv3 specification.
In SUSv3, pthread_create() says "The alternate stack shall not be inherited
(when new threads are initialized)". It means that sigaltstack should be
cleared when sigaltstack memory space is shared by cloned threads with
CLONE_SIGHAND.
Note that I chose "if (clone_flags & CLONE_SIGHAND)" line because:
- If clone_flags line is not existed, fork() does not inherit sigaltstack.
- CLONE_VM is another choice, but vfork() does not inherit sigaltstack.
- CLONE_SIGHAND implies CLONE_VM, and it looks suitable.
- CLONE_THREAD is another candidate, and includes CLONE_SIGHAND + CLONE_VM,
but this flag has a bit different semantics.
I decided to use CLONE_SIGHAND.
[ Changed to test for CLONE_VM && !CLONE_VFORK after discussion --Linus ]
Signed-off-by: GOTO Masanori <gotom@sanori.org>
Acked-by: Linus Torvalds <torvalds@osdl.org>
Cc: Ulrich Drepper <drepper@redhat.com>
Cc: Jakub Jelinek <jakub@redhat.com>
The patch '[PATCH] RCU signal handling' [1] added an export for
__put_task_struct_cb, a put_task_struct helper newly introduced in that
patch. But the put_task_struct couldn't be used modular previously as
__put_task_struct wasn't exported. There are not callers of it in modular
code, and it shouldn't be exported because we don't want drivers to hold
references to task_structs.
This patch removes the export and folds __put_task_struct into
__put_task_struct_cb as there's no other caller.
[1] http://www2.kernel.org/git/gitweb.cgi?p=linux/kernel/git/torvalds/linux-2.6.git;a=commit;h=e56d090310d7625ecb43a1eeebd479f04affb48b
I have benchmarked this on an x86_64 NUMA system and see no significant
performance difference on kernbench. Tested on both x86_64 and powerpc.
The way we do file struct accounting is not very suitable for batched
freeing. For scalability reasons, file accounting was
constructor/destructor based. This meant that nr_files was decremented
only when the object was removed from the slab cache. This is susceptible
to slab fragmentation. With RCU based file structure, consequent batched
freeing and a test program like Serge's, we just speed this up and end up
with a very fragmented slab -
llm22:~ # cat /proc/sys/fs/file-nr
587730 0 758844
At the same time, I see only a 2000+ objects in filp cache. The following
patch I fixes this problem.
This patch changes the file counting by removing the filp_count_lock.
Instead we use a separate percpu counter, nr_files, for now and all
accesses to it are through get_nr_files() api. In the sysctl handler for
nr_files, we populate files_stat.nr_files before returning to user.
Counting files as an when they are created and destroyed (as opposed to
inside slab) allows us to correctly count open files with RCU.
Signed-off-by: Dipankar Sarma <dipankar@in.ibm.com>
Cc: "Paul E. McKenney" <paulmck@us.ibm.com>
This patch adds new tunables for RCU queue and finished batches. There are
two types of controls - number of completed RCU updates invoked in a batch
(blimit) and monitoring for high rate of incoming RCUs on a cpu (qhimark,
qlowmark).
By default, the per-cpu batch limit is set to a small value. If the input
RCU rate exceeds the high watermark, we do two things - force quiescent
state on all cpus and set the batch limit of the CPU to INTMAX. Setting
batch limit to INTMAX forces all finished RCUs to be processed in one shot.
If we have more than INTMAX RCUs queued up, then we have bigger problems
anyway. Once the incoming queued RCUs fall below the low watermark, the
batch limit is set to the default.
Idle threads should have a sane ->timestamp value, to avoid init kernel
thread(s) from inheriting it and causing miscalculations in
try_to_wake_up().
Reported-by: Mike Galbraith <efault@gmx.de>.
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Add a compiler barrier so that we don't read jiffies before updating
jiffies_64.
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
Also from Thomas Gleixner <tglx@linutronix.de>
Function next_timer_interrupt() got broken with a recent patch
6ba1b91213e81aa92b5cf7539f7d2a94ff54947c as sys_nanosleep() was moved to
hrtimer. This broke things as next_timer_interrupt() did not check hrtimer
tree for next event.
Function next_timer_interrupt() is needed with dyntick (CONFIG_NO_IDLE_HZ,
VST) implementations, as the system can be in idle when next hrtimer event
was supposed to happen. At least ARM and S390 currently use
next_timer_interrupt().
Just to be safe, we should not trigger a conditional reschedule during
the early boot sequence. We've historically done some questionable
early on, and the safety warnings in __might_sleep() are generally
turned off during that period, so there might be problems lurking.
This affects CONFIG_PREEMPT_VOLUNTARY, which takes over might_sleep() to
cause a voluntary conditional reschedule.
On some platforms readq performs additional work to make sure I/O is done
in a coherent way. This is not needed for time retrieval as done by the
time interpolator. So we can use readq_relaxed instead which will improve
performance.
It affects sparc64 and ia64 only. Apparently it makes a significant
difference on ia64.
Cc: john stultz <johnstul@us.ibm.com>
acpi_video_flags variable is unsigned long, so it should be set as such.
This actually matters on x86-64.
Signed-off-by: Stefan Seyfried <seife@suse.de>
Cc: "Brown, Len" <len.brown@intel.com>
Cc: Andi Kleen <ak@muc.de>
Allow sysadmin to disable all warnings about userland apps
making unaligned accesses by using:
# echo 1 > /proc/sys/kernel/ignore-unaligned-usertrap
Rather than having to use prctl on a process by process basis.
Default behaivour leaves the warnings enabled.
Signed-off-by: Jes Sorensen <jes@sgi.com>
Signed-off-by: Tony Luck <tony.luck@intel.com>
In daemonize() a new thread gets cleaned up and 'merged' with init_task.
The current fs_struct is handled there, but not the current namespace.
This adds the namespace part.
[ Eric Biederman pointed out the namespace wrappers, and also notes that
we can't ever count on using our parents namespace because we already
have called exit_fs(), which is the only way to the namespace from a
process. ]
Signed-off-by: Björn Steinbrink <B.Steinbrink@gmx.de>
Acked-by: Eric Biederman <ebiederm@xmission.com>
git://git.kernel.org/pub/scm/linux/kernel/git/viro/bird
The compat syscalls are added to sys_ni.c since they are not defined if the
above CONFIG options are off. Also, nfs would not build with CONFIG_SYSCTL
off.
Noticed by Arthur Othieno.
Cc: Trond Myklebust <trond.myklebust@fys.uio.no>
Signed-off-by: Luke Yang <luke.adi@gmail.com>
Currently, acpi video options can only be set on kernel command line. That's
little inflexible; I'd like userland s2ram application that just works, and
modifying kernel command line according to whitelist is not fun. It is better
to just allow s2ram application to set video options just before suspend
(according to the whitelist).
This implements sysctl to allow setting suspend video options without reboot.
(akpm: Documentation updates for this new sysctl are pending..)
Cc: "Antonino A. Daplas" <adaplas@pol.net>
audit_log_exit() is called from atomic contexts and gets explicit
gfp_mask argument; it should use it for all allocations rather
than doing some with gfp_mask and some with GFP_KERNEL.
Restore the compatibility with the older code and make it possible to
suspend if the kernel command line doesn't contain the "resume=" argument
Cc: Pavel Machek <pavel@ucw.cz>
Heiko Carstens <heiko.carstens@de.ibm.com> wrote:
The boot sequence on s390 sometimes takes ages and we spend a very long
time (up to one or two minutes) in calibrate_migration_costs. The time
spent there differs from boot to boot. Also the calculated costs differ
a lot. I've seen differences by up to a factor of 15 (yes, factor not
percent). Also I doubt that making these measurements make much sense on
a completely virtualized architecture where you cannot tell how much cpu
time you will get anyway.
So introduce the CONFIG_DEFAULT_MIGRATION_COST method for an architecture
to set the scheduler migration costs. This turns off automatic detection
of migration costs. Makes sense on virtual platforms, where migration
costs are hard to measure accurately.
This provides an interface for arch code to find out how many
nanoseconds are going to be added on to xtime by the next call to
do_timer. The value returned is a fixed-point number in 52.12 format
in nanoseconds. The reason for this format is that it gives the
full precision that the timekeeping code is using internally.
The motivation for this is to fix a problem that has arisen on 32-bit
powerpc in that the value returned by do_gettimeofday drifts apart
from xtime if NTP is being used. PowerPC is now using a lockless
do_gettimeofday based on reading the timebase register and performing
some simple arithmetic. (This method of getting the time is also
exported to userspace via the VDSO.) However, the factor and offset
it uses were calculated based on the nominal tick length and weren't
being adjusted when NTP varied the tick length.
Note that 64-bit powerpc has had the lockless do_gettimeofday for a
long time now. It also had an extremely hairy routine that got called
from the 32-bit compat routine for adjtimex, which adjusted the
factor and offset according to what it thought the timekeeping code
was going to do. Not only was this only called if a 32-bit task did
adjtimex (i.e. not if a 64-bit task did adjtimex), it was also
duplicating computations from kernel/timer.c and it wasn't clear that
it was (still) correct.
The simple solution is to ask the timekeeping code how long the
current jiffy will be on each timer interrupt, after calling
do_timer. If this jiffy will be a different length from the last one,
we then need to compute new values for the factor and offset used in
the lockless do_gettimeofday. In this way we can keep xtime and
do_gettimeofday in sync, even when NTP is varying the tick length.
Note that when adjtimex varies the tick length, it almost always
introduces the variation from the next tick on. The only case I could
see where adjtimex would vary the length of the current tick is when
an old-style adjtime adjustment is being cancelled. (It's not clear
to me why the adjustment has to be cancelled immediately rather than
from the next tick on.) Thus I don't see any real need for a hook in
adjtimex; the rare case of an old-style adjustment being cancelled can
be fixed up at the next tick.
Acked-by: john stultz <johnstul@us.ibm.com>
AMD SimNow!'s JIT doesn't like them at all in the guest. For distribution
installation it's easiest if it's a boot time option.
Also I moved the variable to a more appropiate place and make
it independent from sysctl
And marked __read_mostly which it is.
Signed-off-by: Andi Kleen <ak@suse.de>
I get about 88 squillion of these when suspending an old ad450nx server.
Cc: Pavel Roskin <proski@gnu.org>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Fix a latent bug in cpuset_exit() handling. If a task tried to allocate
memory after calling cpuset_exit(), it oops'd in
cpuset_update_task_memory_state() on a NULL cpuset pointer.
So set the exiting tasks cpuset to the root cpuset instead of to NULL.
A distro kernel hit this with an added kernel package that had just such a
hook (allocating memory) in the exit code path.
Signed-off-by: Paul Jackson <pj@sgi.com>
1. The tracee can go from ptrace_stop() to do_signal_stop()
after __ptrace_unlink(p).
2. It is unsafe to __ptrace_unlink(p) while p->parent may wait
for tasklist_lock in ptrace_detach().
copy_process:
attach_pid(p, PIDTYPE_PID, p->pid);
attach_pid(p, PIDTYPE_TGID, p->tgid);
What if kill_proc_info(p->pid) happens in between?
copy_process() holds current->sighand.siglock, so we are safe
in CLONE_THREAD case, because current->sighand == p->sighand.
Otherwise, p->sighand is unlocked, the new process is already
visible to the find_task_by_pid(), but have a copy of parent's
'struct pid' in ->pids[PIDTYPE_TGID].
This means that __group_complete_signal() may hang while doing
do ... while (next_thread() != p)
We can solve this problem if we reverse these 2 attach_pid()s:
attach_pid() does wmb()
group_send_sig_info() calls spin_lock(), which
provides a read barrier. // Yes ?
I don't think we can hit this race in practice, but still.
There is a window after copy_process() unlocks ->sighand.siglock
and before it adds the new thread to the thread list.
In that window __group_complete_signal(SIGKILL) will not see the
new thread yet, so this thread will start running while the whole
thread group was supposed to exit.
I beleive we have another good reason to place attach_pid(PID/TGID)
under ->sighand.siglock. We can do the same for
release_task()->__unhash_process()
de_thread()->switch_exec_pids()
After that we don't need tasklist_lock to iterate over the thread
list, and we can simplify things, see for example do_sigaction()
or sys_times().
CONFIG_TIME_LOW_RES is a temporary way for architectures to signal that
they simply return xtime in do_gettimeoffset(). In this corner-case we
want to round up by resolution when starting a relative timer, to avoid
short timeouts. This will go away with the GTOD framework.
Cc: Roman Zippel <zippel@linux-m68k.org>
