commit 80f1d68ccba70b1060c9c7360ca83da430f66bed upstream.
I noticed that a helper function with argument type ARG_ANYTHING does
not need to have an initialized value (register).
This can worst case lead to unintented stack memory leakage in future
helper functions if they are not carefully designed, or unintended
application behaviour in case the application developer was not careful
enough to match a correct helper function signature in the API.
The underlying issue is that ARG_ANYTHING should actually be split
into two different semantics:
1) ARG_DONTCARE for function arguments that the helper function
does not care about (in other words: the default for unused
function arguments), and
2) ARG_ANYTHING that is an argument actually being used by a
helper function and *guaranteed* to be an initialized register.
The current risk is low: ARG_ANYTHING is only used for the 'flags'
argument (r4) in bpf_map_update_elem() that internally does strict
checking.
Fixes: 17a5267067f3 ("bpf: verifier (add verifier core)")
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Acked-by: Alexei Starovoitov <ast@plumgrid.com>
commit 4cd57f97135840f637431c92380c8da3edbe44ed upstream.
dl_task_timer() may fire on a different rq from where a task was removed
after throttling. Since the call path is:
dl_task_timer() ->
enqueue_task_dl() ->
enqueue_dl_entity() ->
replenish_dl_entity()
and replenish_dl_entity() uses dl_se's rq, we can't use current's rq
in dl_task_timer(), but we need to lock the task's previous one.
Tested-by: Wanpeng Li <wanpeng.li@linux.intel.com>
Signed-off-by: Juri Lelli <juri.lelli@arm.com>
Acked-by: Kirill Tkhai <ktkhai@parallels.com>
Cc: Juri Lelli <juri.lelli@gmail.com>
Fixes: 3960c8c0c789 ("sched: Make dl_task_time() use task_rq_lock()")
Link: http://lkml.kernel.org/r/1427792017-7356-1-git-send-email-juri.lelli@arm.com
commit 84fce9db4d7eaebd6cb2ee30c15da6d4e4daf846 upstream.
There is a problem that trace events are not properly enabled with
boot cmdline. The problem is that if we pass "trace_event=kmem:mm_page_alloc"
to the boot cmdline, it enables all kmem trace events, and not just
the page_alloc event.
This is caused by the parsing mechanism. When we parse the cmdline, the buffer
contents is modified due to tokenization. And, if we use this buffer
again, we will get the wrong result.
Unfortunately, this buffer is be accessed three times to set trace events
properly at boot time. So, we need to handle this situation.
There is already code handling ",", but we need another for ":".
This patch adds it.
Link: http://lkml.kernel.org/r/1429159484-22977-1-git-send-email-iamjoonsoo.kim@lge.com
Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
[ added missing return ret; ]
commit ef99b88b16bee753fa51207abdc58ae660453ec6 upstream.
graph_trace_open() can be called in atomic context from ftrace_dump().
Use GFP_ATOMIC for the memory allocations when that's the case, in order
to avoid the following splat.
BUG: sleeping function called from invalid context at mm/slab.c:2849
in_atomic(): 1, irqs_disabled(): 128, pid: 0, name: swapper/0
Backtrace:
[<8004dc94>] (__might_sleep) from [<801371f4>] (kmem_cache_alloc_trace+0x160/0x238)
r7:87800040 r6:000080d0 r5:810d16e8 r4:000080d0
[<80137094>] (kmem_cache_alloc_trace) from [<800cbd60>] (graph_trace_open+0x30/0xd0)
r10:00000100 r9:809171a8 r8:00008e28 r7:810d16f0 r6:00000001 r5:810d16e8
r4:810d16f0
[<800cbd30>] (graph_trace_open) from [<800c79c4>] (trace_init_global_iter+0x50/0x9c)
r8:00008e28 r7:808c853c r6:00000001 r5:810d16e8 r4:810d16f0 r3:800cbd30
[<800c7974>] (trace_init_global_iter) from [<800c7aa0>] (ftrace_dump+0x90/0x2ec)
r4:810d2580 r3:00000000
[<800c7a10>] (ftrace_dump) from [<80414b2c>] (sysrq_ftrace_dump+0x1c/0x20)
r10:00000100 r9:809171a8 r8:808f6e7c r7:00000001 r6:00000007 r5:0000007a
r4:808d5394
[<80414b10>] (sysrq_ftrace_dump) from [<800169b8>] (return_to_handler+0x0/0x18)
[<80415498>] (__handle_sysrq) from [<800169b8>] (return_to_handler+0x0/0x18)
r8:808c8100 r7:808c8444 r6:00000101 r5:00000010 r4:84eb3210
[<80415668>] (handle_sysrq) from [<800169b8>] (return_to_handler+0x0/0x18)
[<8042a760>] (pl011_int) from [<800169b8>] (return_to_handler+0x0/0x18)
r10:809171bc r9:809171a8 r8:00000001 r7:00000026 r6:808c6000 r5:84f01e60
r4:8454fe00
[<8007782c>] (handle_irq_event_percpu) from [<80077b44>] (handle_irq_event+0x4c/0x6c)
r10:808c7ef0 r9:87283e00 r8:00000001 r7:00000000 r6:8454fe00 r5:84f01e60
r4:84f01e00
[<80077af8>] (handle_irq_event) from [<8007aa28>] (handle_fasteoi_irq+0xf0/0x1ac)
r6:808f52a4 r5:84f01e60 r4:84f01e00 r3:00000000
[<8007a938>] (handle_fasteoi_irq) from [<80076dc0>] (generic_handle_irq+0x3c/0x4c)
r6:00000026 r5:00000000 r4:00000026 r3:8007a938
[<80076d84>] (generic_handle_irq) from [<80077128>] (__handle_domain_irq+0x8c/0xfc)
r4:808c1e38 r3:0000002e
[<8007709c>] (__handle_domain_irq) from [<800087b8>] (gic_handle_irq+0x34/0x6c)
r10:80917748 r9:00000001 r8:88802100 r7:808c7ef0 r6:808c8fb0 r5:00000015
r4:8880210c r3:808c7ef0
[<80008784>] (gic_handle_irq) from [<80014044>] (__irq_svc+0x44/0x7c)
Link: http://lkml.kernel.org/r/1428953721-31349-1-git-send-email-rabin@rab.in
Link: http://lkml.kernel.org/r/1428957012-2319-1-git-send-email-rabin@rab.in
Signed-off-by: Rabin Vincent <rabin@rab.in>
commit b72c186999e689cb0b055ab1c7b3cd8fffbeb5ed upstream.
ptrace_resume() is called when the tracee is still __TASK_TRACED. We set
tracee->exit_code and then wake_up_state() changes tracee->state. If the
tracer's sub-thread does wait() in between, task_stopped_code(ptrace => T)
wrongly looks like another report from tracee.
This confuses debugger, and since wait_task_stopped() clears ->exit_code
the tracee can miss a signal.
Test-case:
#include <stdio.h>
#include <unistd.h>
#include <sys/wait.h>
#include <sys/ptrace.h>
#include <pthread.h>
#include <assert.h>
int pid;
void *waiter(void *arg)
int stat;
for (;;) {
assert(pid == wait(&stat));
assert(WIFSTOPPED(stat));
if (WSTOPSIG(stat) == SIGHUP)
continue;
assert(WSTOPSIG(stat) == SIGCONT);
printf("ERR! extra/wrong report:%x\n", stat);
int main(void)
pthread_t thread;
pid = fork();
if (!pid) {
assert(ptrace(PTRACE_TRACEME, 0,0,0) == 0);
for (;;)
kill(getpid(), SIGHUP);
assert(pthread_create(&thread, NULL, waiter, NULL) == 0);
for (;;)
ptrace(PTRACE_CONT, pid, 0, SIGCONT);
return 0;
Note for stable: the bug is very old, but without 9899d11f6544 "ptrace:
ensure arch_ptrace/ptrace_request can never race with SIGKILL" the fix
should use lock_task_sighand(child).
Reported-by: Pavel Labath <labath@google.com>
Tested-by: Pavel Labath <labath@google.com>
commit 80a9b64e2c156b6523e7a01f2ba6e5d86e722814 upstream.
It has come to my attention that this_cpu_read/write are horrible on
architectures other than x86. Worse yet, they actually disable
preemption or interrupts! This caused some unexpected tracing results
on ARM.
101.356868: preempt_count_add <-ring_buffer_lock_reserve
101.356870: preempt_count_sub <-ring_buffer_lock_reserve
The ring_buffer_lock_reserve has recursion protection that requires
accessing a per cpu variable. But since preempt_disable() is traced, it
too got traced while accessing the variable that is suppose to prevent
recursion like this.
The generic version of this_cpu_read() and write() are:
#define this_cpu_generic_read(pcp) \
({ typeof(pcp) ret__; \
preempt_disable(); \
ret__ = *this_cpu_ptr(&(pcp)); \
preempt_enable(); \
ret__; \
#define this_cpu_generic_to_op(pcp, val, op) \
do { \
unsigned long flags; \
raw_local_irq_save(flags); \
*__this_cpu_ptr(&(pcp)) op val; \
raw_local_irq_restore(flags); \
} while (0)
Which is unacceptable for locations that know they are within preempt
disabled or interrupt disabled locations.
Paul McKenney stated that __this_cpu_() versions produce much better code on
other architectures than this_cpu_() does, if we know that the call is done in
a preempt disabled location.
I also changed the recursive_unlock() to use two local variables instead
of accessing the per_cpu variable twice.
Link: http://lkml.kernel.org/r/20150317114411.GE3589@linux.vnet.ibm.com
Link: http://lkml.kernel.org/r/20150317104038.312e73d1@gandalf.local.home
Acked-by: Christoph Lameter <cl@linux.com>
Reported-by: Uwe Kleine-Koenig <u.kleine-koenig@pengutronix.de>
Tested-by: Uwe Kleine-Koenig <u.kleine-koenig@pengutronix.de>
commit 0a4e6be9ca17c54817cf814b4b5aa60478c6df27 upstream.
The following point:
2. per-CPU pvclock time info is updated if the
underlying CPU changes.
Is not true anymore since "KVM: x86: update pvclock area conditionally,
on cpu migration".
Add task migration notification back.
Problem noticed by Andy Lutomirski.
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
[ Upstream commit c3de6317d748e23b9e46ba36e10483728d00d144 ]
Due to missing bounds check the DAG pass of the BPF verifier can corrupt
the memory which can cause random crashes during program loading:
[8.449451] BUG: unable to handle kernel paging request at ffffffffffffffff
[8.451293] IP: [<ffffffff811de33d>] kmem_cache_alloc_trace+0x8d/0x2f0
[8.452329] Oops: 0000 [#1] SMP
[8.452329] Call Trace:
[8.452329] [<ffffffff8116cc82>] bpf_check+0x852/0x2000
[8.452329] [<ffffffff8116b7e4>] bpf_prog_load+0x1e4/0x310
[8.452329] [<ffffffff811b190f>] ? might_fault+0x5f/0xb0
[8.452329] [<ffffffff8116c206>] SyS_bpf+0x806/0xa30
Fixes: f1bca824dabb ("bpf: add search pruning optimization to verifier")
Signed-off-by: Alexei Starovoitov <ast@plumgrid.com>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
Pull power management and ACPI fixes from Rafael Wysocki:
"These are stable-candidate fixes of some recently reported issues in
the cpufreq core, cpuidle core, the ACPI cpuidle driver and the
hibernate core.
Specifics:
- Revert a 3.17 hibernate commit that was supposed to fix an issue
related to e820 reserved regions, but broke resume from hibernation
on Lenovo x230 (Rafael J Wysocki).
- Prevent the ACPI cpuidle driver from overwriting the name and
description of the C0 state set by the core when the list of
C-states changes (Thomas Schlichter).
- Remove the no longer needed state_count field from struct
cpuidle_device which prevents the list of C-states shown by the
sysfs interface from becoming incorrect when the current number of
them is different from the number of C-states on boot (Bartlomiej
Zolnierkiewicz).
- The cpufreq core updates the policy object of the only online CPU
during system resume to make it reflect the current hardware state,
but it always assumes that CPU to be CPU0 which need not be the
case, so fix the code to avoid that assumption (Viresh Kumar)"
* tag 'pm+acpi-4.0-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
Revert "PM / hibernate: avoid unsafe pages in e820 reserved regions"
cpuidle: ACPI: do not overwrite name and description of C0
cpuidle: remove state_count field from struct cpuidle_device
cpufreq: Schedule work for the first-online CPU on resume
* pm-sleep:
* pm-cpufreq:
* pm-cpuidle:
Merge misc fixes from Andrew Morton:
"Three fixes"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>:
mm: numa: disable change protection for vma(VM_HUGETLB)
include/linux/dmapool.h: declare struct device
mm: move zone lock to a different cache line than order-0 free page lists
Unlike most (all?) other copies from user space, kernel module loading
is almost unlimited in size. So we do a potentially huge
"copy_from_user()" when we copy the module data from user space to the
kernel buffer, which can be a latency concern when preemption is
disabled (or voluntary).
Also, because 'copy_from_user()' clears the tail of the kernel buffer on
failures, even a *failed* copy can end up wasting a lot of time.
Normally neither of these are concerns in real life, but they do trigger
when doing stress-testing with trinity. Running in a VM seems to add
its own overheadm causing trinity module load testing to even trigger
the watchdog.
The simple fix is to just chunk up the module loading, so that it never
tries to copy insanely big areas in one go. That bounds the latency,
and also the amount of (unnecessarily, in this case) cleared memory for
the failure case.
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Currently when a process accesses a hugetlb range protected with
PROTNONE, unexpected COWs are triggered, which finally puts the hugetlb
subsystem into a broken/uncontrollable state, where for example
h->resv_huge_pages is subtracted too much and wraps around to a very
large number, and the free hugepage pool is no longer maintainable.
This patch simply stops changing protection for vma(VM_HUGETLB) to fix
the problem. And this also allows us to avoid useless overhead of minor
faults.
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Suggested-by: Mel Gorman <mgorman@suse.de>
Cc: "Kirill A. Shutemov" <kirill@shutemov.name>
Commit 84c91b7ae07c (PM / hibernate: avoid unsafe pages in e820 reserved
regions) is reported to make resume from hibernation on Lenovo x230
unreliable, so revert it.
We will revisit the issue the commit in question was supposed to fix
in the future.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=96111
Reported-by: rhn <kebuac.rhn@porcupinefactory.org>
Cc: 3.17+ <stable@vger.kernel.org> # 3.17+
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
Pull lazytime fixes from Ted Ts'o:
"This fixes a problem in the lazy time patches, which can cause
frequently updated inods to never have their timestamps updated.
These changes guarantee that no timestamp on disk will be stale by
more than 24 hours"
* tag 'lazytime_fix' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4:
fs: add dirtytime_expire_seconds sysctl
fs: make sure the timestamps for lazytime inodes eventually get written
Pull timer fixes from Ingo Molnar:
"Two clocksource driver fixes, and an idle loop RCU warning fix"
* 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
clocksource/drivers/sun5i: Fix cpufreq interaction with sched_clock()
clocksource/drivers: Fix various !CONFIG_HAS_IOMEM build errors
timers/tick/broadcast-hrtimer: Fix suspicious RCU usage in idle loop
Pull scheduler fix from Ingo Molnar:
"A single sched/rt corner case fix for RLIMIT_RTIME correctness"
* 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
sched: Fix RLIMIT_RTTIME when PI-boosting to RT
Pull perf fix from Ingo Molnar:
"A perf kernel side fix for a fuzzer triggered lockup"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf: Fix irq_work 'tail' recursion
Pull locking fix from Ingo Molnar:
"A module unload lockdep race fix"
* 'locking-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
lockdep: Fix the module unload key range freeing logic
Dave Chinner reported the following on https://lkml.org/lkml/2015/3/1/226
Across the board the 4.0-rc1 numbers are much slower, and the degradation
is far worse when using the large memory footprint configs. Perf points
straight at the cause - this is from 4.0-rc1 on the "-o bhash=101073" config:
- 56.07% 56.07% [kernel] [k] default_send_IPI_mask_sequence_phys
- default_send_IPI_mask_sequence_phys
- 99.99% physflat_send_IPI_mask
- 99.37% native_send_call_func_ipi
smp_call_function_many
- native_flush_tlb_others
- 99.85% flush_tlb_page
ptep_clear_flush
try_to_unmap_one
rmap_walk
try_to_unmap
migrate_pages
migrate_misplaced_page
- handle_mm_fault
- 99.73% __do_page_fault
trace_do_page_fault
do_async_page_fault
+ async_page_fault
0.63% native_send_call_func_single_ipi
generic_exec_single
smp_call_function_single
This is showing excessive migration activity even though excessive
migrations are meant to get throttled. Normally, the scan rate is tuned
on a per-task basis depending on the locality of faults. However, if
migrations fail for any reason then the PTE scanner may scan faster if
the faults continue to be remote. This means there is higher system CPU
overhead and fault trapping at exactly the time we know that migrations
cannot happen. This patch tracks when migration failures occur and
slows the PTE scanner.
Reported-by: Dave Chinner <david@fromorbit.com>
Tested-by: Dave Chinner <david@fromorbit.com>
Cc: Aneesh Kumar <aneesh.kumar@linux.vnet.ibm.com>
The hrtimer mode of broadcast queues hrtimers in the idle entry
path so as to wakeup cpus in deep idle states. The associated
call graph is :
cpuidle_idle_call()
|____ clockevents_notify(CLOCK_EVT_NOTIFY_BROADCAST_ENTER, ....))
|_____tick_broadcast_set_event()
|____clockevents_program_event()
|____bc_set_next()
The hrtimer_{start/cancel} functions call into tracing which uses RCU.
But it is not legal to call into RCU in cpuidle because it is one of the
quiescent states. Hence protect this region with RCU_NONIDLE which informs
RCU that the cpu is momentarily non-idle.
As an aside it is helpful to point out that the clock event device that is
programmed here is not a per-cpu clock device; it is a
pseudo clock device, used by the broadcast framework alone.
The per-cpu clock device programming never goes through bc_set_next().
Signed-off-by: Preeti U Murthy <preeti@linux.vnet.ibm.com>
Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: linuxppc-dev@ozlabs.org
Cc: mpe@ellerman.id.au
Cc: tglx@linutronix.de
Link: http://lkml.kernel.org/r/20150318104705.17763.56668.stgit@preeti.in.ibm.com
Module unload calls lockdep_free_key_range(), which removes entries
from the data structures. Most of the lockdep code OTOH assumes the
data structures are append only; in specific see the comments in
add_lock_to_list() and look_up_lock_class().
Clearly this has only worked by accident; make it work proper. The
actual scenario to make it go boom would involve the memory freed by
the module unlock being re-allocated and re-used for a lock inside of
a rcu-sched grace period. This is a very unlikely scenario, still
better plug the hole.
Use RCU list iteration in all places and ammend the comments.
Change lockdep_free_key_range() to issue a sync_sched() between
removal from the lists and returning -- which results in the memory
being freed. Further ensure the callers are placed correctly and
comment the requirements.
Cc: Andrey Tsyvarev <tsyvarev@ispras.ru>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
When non-realtime tasks get priority-inheritance boosted to a realtime
scheduling class, RLIMIT_RTTIME starts to apply to them. However, the
counter used for checking this (the same one used for SCHED_RR
timeslices) was not getting reset. This meant that tasks running with a
non-realtime scheduling class which are repeatedly boosted to a realtime
one, but never block while they are running realtime, eventually hit the
timeout without ever running for a time over the limit. This patch
resets the realtime timeslice counter when un-PI-boosting from an RT to
a non-RT scheduling class.
I have some test code with two threads and a shared PTHREAD_PRIO_INHERIT
mutex which induces priority boosting and spins while boosted that gets
killed by a SIGXCPU on non-fixed kernels but doesn't with this patch
applied. It happens much faster with a CONFIG_PREEMPT_RT kernel, and
does happen eventually with PREEMPT_VOLUNTARY kernels.
Signed-off-by: Brian Silverman <brian@peloton-tech.com>
Cc: austin@peloton-tech.com
Cc: <stable@vger.kernel.org>
Link: http://lkml.kernel.org/r/1424305436-6716-1-git-send-email-brian@peloton-tech.com
Vince reported a watchdog lockup like:
[<ffffffff8115e114>] perf_tp_event+0xc4/0x210
[<ffffffff810b4f8a>] perf_trace_lock+0x12a/0x160
[<ffffffff810b7f10>] lock_release+0x130/0x260
[<ffffffff816c7474>] _raw_spin_unlock_irqrestore+0x24/0x40
[<ffffffff8107bb4d>] do_send_sig_info+0x5d/0x80
[<ffffffff811f69df>] send_sigio_to_task+0x12f/0x1a0
[<ffffffff811f71ce>] send_sigio+0xae/0x100
[<ffffffff811f72b7>] kill_fasync+0x97/0xf0
[<ffffffff8115d0b4>] perf_event_wakeup+0xd4/0xf0
[<ffffffff8115d103>] perf_pending_event+0x33/0x60
[<ffffffff8114e3fc>] irq_work_run_list+0x4c/0x80
[<ffffffff8114e448>] irq_work_run+0x18/0x40
[<ffffffff810196af>] smp_trace_irq_work_interrupt+0x3f/0xc0
[<ffffffff816c99bd>] trace_irq_work_interrupt+0x6d/0x80
Which is caused by an irq_work generating new irq_work and therefore
not allowing forward progress.
This happens because processing the perf irq_work triggers another
perf event (tracepoint stuff) which in turn generates an irq_work ad
infinitum.
Avoid this by raising the recursion counter in the irq_work -- which
effectively disables all software events (including tracepoints) from
actually triggering again.
Reported-by: Vince Weaver <vincent.weaver@maine.edu>
Tested-by: Vince Weaver <vincent.weaver@maine.edu>
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Cc: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/r/20150219170311.GH21418@twins.programming.kicks-ass.net
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/livepatching
Pull livepatching fix from Jiri Kosina:
- fix for potential race with module loading, from Petr Mladek.
The race is very unlikely to be seen in real world and has been found
by code inspection, but should be fixed for 4.0 anyway.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/livepatching:
livepatch: Fix subtle race with coming and going modules
Pull perf and timer fixes from Ingo Molnar:
"Two small perf fixes:
- kernel side context leak fix
- tooling crash fix
And two clocksource driver fixes"
perf: Fix context leak in put_event()
perf annotate: Fix fallback to unparsed disassembler line
clockevents: sun5i: Fix setup_irq init sequence
clocksource: efm32: Fix a NULL pointer dereference
Add a tuning knob so we can adjust the dirtytime expiration timeout,
which is very useful for testing lazytime.
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
There is a notifier that handles live patches for coming and going modules.
It takes klp_mutex lock to avoid races with coming and going patches but
it does not keep the lock all the time. Therefore the following races are
possible:
1. The notifier is called sometime in STATE_MODULE_COMING. The module
is visible by find_module() in this state all the time. It means that
new patch can be registered and enabled even before the notifier is
called. It might create wrong order of stacked patches, see below
for an example.
2. New patch could still see the module in the GOING state even after
the notifier has been called. It will try to initialize the related
object structures but the module could disappear at any time. There
will stay mess in the structures. It might even cause an invalid
memory access.
This patch solves the problem by adding a boolean variable into struct module.
The value is true after the coming and before the going handler is called.
New patches need to be applied when the value is true and they need to ignore
the module when the value is false.
Note that we need to know state of all modules on the system. The races are
related to new patches. Therefore we do not know what modules will get
patched.
Also note that we could not simply ignore going modules. The code from the
module could be called even in the GOING state until mod->exit() finishes.
If we start supporting patches with semantic changes between function
calls, we need to apply new patches to any still usable code.
See below for an example.
Finally note that the patch solves only the situation when a new patch is
registered. There are no such problems when the patch is being removed.
It does not matter who disable the patch first, whether the normal
disable_patch() or the module notifier. There is nothing to do
once the patch is disabled.
Alternative solutions:
+ reject new patches when a patched module is coming or going; this is ugly
+ wait with adding new patch until the module leaves the COMING and GOING
states; this might be dangerous and complicated; we would need to release
kgr_lock in the middle of the patch registration to avoid a deadlock
with the coming and going handlers; also we might need a waitqueue for
each module which seems to be even bigger overhead than the boolean
+ stop modules from entering COMING and GOING states; wait until modules
leave these states when they are already there; looks complicated; we would
need to ignore the module that asked to stop the others to avoid a deadlock;
also it is unclear what to do when two modules asked to stop others and
both are in COMING state (situation when two new patches are applied)
+ always register/enable new patches and fix up the potential mess (registered
patches order) in klp_module_init(); this is nasty and prone to regressions
in the future development
+ add another MODULE_STATE where the kallsyms are visible but the module is not
used yet; this looks too complex; the module states are checked on "many"
locations
Example of patch stacking breakage:
The notifier could _not_ _simply_ ignore already initialized module objects.
For example, let's have three patches (P1, P2, P3) for functions a() and b()
where a() is from vmcore and b() is from a module M. Something like:
a() b()
P1 a1() b1()
P2 a2() b2()
P3 a3() b3(3)
If you load the module M after all patches are registered and enabled.
The ftrace ops for function a() and b() has listed the functions in this
order:
ops_a->func_stack -> list(a3,a2,a1)
ops_b->func_stack -> list(b3,b2,b1)
, so the pointer to b3() is the first and will be used.
Then you might have the following scenario. Let's start with state when patches
P1 and P2 are registered and enabled but the module M is not loaded. Then ftrace
ops for b() does not exist. Then we get into the following race:
CPU0 CPU1
load_module(M)
complete_formation()
mod->state = MODULE_STATE_COMING;
mutex_unlock(&module_mutex);
klp_register_patch(P3);
klp_enable_patch(P3);
# STATE 1
klp_module_notify(M)
klp_module_notify_coming(P1);
klp_module_notify_coming(P2);
klp_module_notify_coming(P3);
# STATE 2
The ftrace ops for a() and b() then looks:
STATE1:
ops_a->func_stack -> list(a3,a2,a1);
ops_b->func_stack -> list(b3);
STATE2:
ops_b->func_stack -> list(b2,b1,b3);
therefore, b2() is used for the module but a3() is used for vmcore
because they were the last added.
Example of the race with going modules:
CPU0 CPU1
delete_module() #SYSCALL
try_stop_module()
mod->state = MODULE_STATE_GOING;
klp_register_patch()
klp_enable_patch()
#save place to switch universe
b() # from module that is going
a() # from core (patched)
mod->exit();
Note that the function b() can be called until we call mod->exit().
If we do not apply patch against b() because it is in MODULE_STATE_GOING,
it will call patched a() with modified semantic and things might get wrong.
[jpoimboe@redhat.com: use one boolean instead of two]
Signed-off-by: Petr Mladek <pmladek@suse.cz>
Acked-by: Josh Poimboeuf <jpoimboe@redhat.com>
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
Commit:
a83fe28e2e45 ("perf: Fix put_event() ctx lock")
changed the locking logic in put_event() by replacing mutex_lock_nested()
with perf_event_ctx_lock_nested(), but didn't fix the subsequent
mutex_unlock() with a correct counterpart, perf_event_ctx_unlock().
Contexts are thus leaked as a result of incremented refcount
in perf_event_ctx_lock_nested().
Signed-off-by: Leon Yu <chianglungyu@gmail.com>
Fixes: a83fe28e2e45 ("perf: Fix put_event() ctx lock")
Link: http://lkml.kernel.org/r/1424954613-5034-1-git-send-email-chianglungyu@gmail.com
Current approach in handling shadow memory for modules is broken.
Shadow memory could be freed only after memory shadow corresponds it is no
longer used. vfree() called from interrupt context could use memory its
freeing to store 'struct llist_node' in it:
void vfree(const void *addr)
if (unlikely(in_interrupt())) {
struct vfree_deferred *p = this_cpu_ptr(&vfree_deferred);
if (llist_add((struct llist_node *)addr, &p->list))
schedule_work(&p->wq);
Later this list node used in free_work() which actually frees memory.
Currently module_memfree() called in interrupt context will free shadow
before freeing module's memory which could provoke kernel crash.
So shadow memory should be freed after module's memory. However, such
deallocation order could race with kasan_module_alloc() in module_alloc().
Free shadow right before releasing vm area. At this point vfree()'d
memory is not used anymore and yet not available for other allocations.
New VM_KASAN flag used to indicate that vm area has dynamically allocated
shadow memory so kasan frees shadow only if it was previously allocated.
Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace
Pull seq-buf/ftrace fixes from Steven Rostedt:
"This includes fixes for seq_buf_bprintf() truncation issue. It also
contains fixes to ftrace when /proc/sys/kernel/ftrace_enabled and
function tracing are started. Doing the following causes some issues:
# echo 0 > /proc/sys/kernel/ftrace_enabled
# echo function_graph > /sys/kernel/debug/tracing/current_tracer
# echo 1 > /proc/sys/kernel/ftrace_enabled
# echo nop > /sys/kernel/debug/tracing/current_tracer
As well as with function tracing too. Pratyush Anand first reported
this issue to me and supplied a patch. When I tested this on my x86
test box, it caused thousands of backtraces and warnings to appear in
dmesg, which also caused a denial of service (a warning for every
function that was listed). I applied Pratyush's patch but it did not
fix the issue for me. I looked into it and found a slight problem
with trampoline accounting. I fixed it and sent Pratyush a patch, but
he said that it did not fix the issue for him.
I later learned tha Pratyush was using an ARM64 server, and when I
tested on my ARM board, I was able to reproduce the same issue as
Pratyush. After applying his patch, it fixed the problem. The above
test uncovered two different bugs, one in x86 and one in ARM and
ARM64. As this looked like it would affect PowerPC, I tested it on my
PPC64 box. It too broke, but neither the patch that fixed ARM or x86
fixed this box (the changes were all in generic code!). The above
test, uncovered two more bugs that affected PowerPC. Again, the
changes were only done to generic code. It's the way the arch code
expected things to be done that was different between the archs. Some
where more sensitive than others.
The rest of this series fixes the PPC bugs as well"
* tag 'trace-fixes-v4.0-rc2-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace:
ftrace: Fix ftrace enable ordering of sysctl ftrace_enabled
ftrace: Fix en(dis)able graph caller when en(dis)abling record via sysctl
ftrace: Clear REGS_EN and TRAMP_EN flags on disabling record via sysctl
seq_buf: Fix seq_buf_bprintf() truncation
seq_buf: Fix seq_buf_vprintf() truncation
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup
Pull cgroup fixes from Tejun Heo:
"The cgroup iteration update two years ago and the recent cpuset
restructuring introduced regressions in subset of cpuset
configurations. Three patches to fix them.
All are marked for -stable"
* 'for-4.0-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup:
cpuset: Fix cpuset sched_relax_domain_level
cpuset: fix a warning when clearing configured masks in old hierarchy
cpuset: initialize effective masks when clone_children is enabled
git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq
Pull workqueue fix from Tejun Heo:
"One fix patch for a subtle livelock condition which can happen on
PREEMPT_NONE kernels involving two racing cancel_work calls. Whoever
comes in the second has to wait for the previous one to finish. This
was implemented by making the later one block for the same condition
that the former would be (work item completion) and then loop and
retest; unfortunately, depending on the wake up order, the later one
could lock out the former one to finish by busy looping on the cpu.
This is fixed by implementing explicit wait mechanism. Work item
might not belong anywhere at this point and there's remote possibility
of thundering herd problem. I originally tried to use bit_waitqueue
but it didn't work for static work items on modules. It's currently
using single wait queue with filtering wake up function and exclusive
wakeup. If this ever becomes a problem, which is not very likely, we
can try to figure out a way to piggy back on bit_waitqueue"
* 'for-4.0-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq:
workqueue: fix hang involving racing cancel[_delayed]_work_sync()'s for PREEMPT_NONE
Some archs (specifically PowerPC), are sensitive with the ordering of
the enabling of the calls to function tracing and setting of the
function to use to be traced.
That is, update_ftrace_function() sets what function the ftrace_caller
trampoline should call. Some archs require this to be set before
calling ftrace_run_update_code().
Another bug was discovered, that ftrace_startup_sysctl() called
ftrace_run_update_code() directly. If the function the ftrace_caller
trampoline changes, then it will not be updated. Instead a call
to ftrace_startup_enable() should be called because it tests to see
if the callback changed since the code was disabled, and will
tell the arch to update appropriately. Most archs do not need this
notification, but PowerPC does.
The problem could be seen by the following commands:
# echo function > /sys/kernel/debug/tracing/current_tracer
# cat /sys/kernel/debug/tracing/trace
The trace will show that function tracing was not active.
Cc: stable@vger.kernel.org # 2.6.27+
When ftrace is enabled globally through the proc interface, we must check if
ftrace_graph_active is set. If it is set, then we should also pass the
FTRACE_START_FUNC_RET command to ftrace_run_update_code(). Similarly, when
ftrace is disabled globally through the proc interface, we must check if
FTRACE_STOP_FUNC_RET command to ftrace_run_update_code().
Consider the following situation.
After this ftrace_enabled = 0.
Since ftrace_enabled = 0, ftrace_enable_ftrace_graph_caller() is never
called.
Now ftrace_enabled will be set to true, but still
ftrace_enable_ftrace_graph_caller() will not be called, which is not
desired.
Further if we execute the following after this:
Now since ftrace_enabled is set it will call
ftrace_disable_ftrace_graph_caller(), which causes a kernel warning on
the ARM platform.
On the ARM platform, when ftrace_enable_ftrace_graph_caller() is called,
it checks whether the old instruction is a nop or not. If it's not a nop,
then it returns an error. If it is a nop then it replaces instruction at
that address with a branch to ftrace_graph_caller.
ftrace_disable_ftrace_graph_caller() behaves just the opposite. Therefore,
if generic ftrace code ever calls either ftrace_enable_ftrace_graph_caller()
or ftrace_disable_ftrace_graph_caller() consecutively two times in a row,
then it will return an error, which will cause the generic ftrace code to
raise a warning.
Note, x86 does not have an issue with this because the architecture
specific code for ftrace_enable_ftrace_graph_caller() and
ftrace_disable_ftrace_graph_caller() does not check the previous state,
and calling either of these functions twice in a row has no ill effect.
Link: http://lkml.kernel.org/r/e4fbe64cdac0dd0e86a3bf914b0f83c0b419f146.1425666454.git.panand@redhat.com
Cc: stable@vger.kernel.org # 2.6.31+
Signed-off-by: Pratyush Anand <panand@redhat.com>
removed extra if (ftrace_start_up) and defined ftrace_graph_active as 0
if CONFIG_FUNCTION_GRAPH_TRACER is not set.
When /proc/sys/kernel/ftrace_enabled is set to zero, all function
tracing is disabled. But the records that represent the functions
still hold information about the ftrace_ops that are hooked to them.
ftrace_ops may request "REGS" (have a full set of pt_regs passed to
the callback), or "TRAMP" (the ops has its own trampoline to use).
When the record is updated to represent the state of the ops hooked
to it, it sets "REGS_EN" and/or "TRAMP_EN" to state that the callback
points to the correct trampoline (REGS has its own trampoline).
When ftrace_enabled is set to zero, all ftrace locations are a nop,
so they do not point to any trampoline. But the _EN flags are still
set. This can cause the accounting to go wrong when ftrace_enabled
is cleared and an ops that has a trampoline is registered or unregistered.
For example, the following will cause ftrace to crash:
As function_graph uses a trampoline, when ftrace_enabled is set to zero
the updates to the record are not done. When enabling function_graph
again, the record will still have the TRAMP_EN flag set, and it will
look for an op that has a trampoline other than the function_graph
ops, and fail to find one.
Cc: stable@vger.kernel.org # 3.17+
Reported-by: Pratyush Anand <panand@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull tty/serial fixes from Greg KH:
"Here are some tty and serial driver fixes for 4.0-rc3.
Along with the atime fix that you know about, here are some other
serial driver bugfixes as well. Most notable is a wait_until_sent
bugfix that was traced back to being around since before 2.6.12 that
Johan has fixed up.
All have been in linux-next successfully"
* tag 'tty-4.0-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty:
TTY: fix tty_wait_until_sent maximum timeout
TTY: fix tty_wait_until_sent on 64-bit machines
USB: serial: fix infinite wait_until_sent timeout
TTY: bfin_jtag_comm: remove incorrect wait_until_sent operation
net: irda: fix wait_until_sent poll timeout
serial: uapi: Declare all userspace-visible io types
serial: core: Fix iotype userspace breakage
serial: sprd: Fix missing spin_unlock in sprd_handle_irq()
console: Fix console name size mismatch
tty: fix up atime/mtime mess, take four
serial: 8250_dw: Fix get_mctrl behaviour
serial:8250:8250_pci: delete unneeded quirk entries
serial:8250:8250_pci: fix redundant entry report for WCH_CH352_2S
Change email address for 8250_pci
serial: 8250: Revert "tty: serial: 8250_core: read only RX if there is something in the FIFO"
Revert "tty/serial: of_serial: add DT alias ID handling"
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull arm64 fixes from Catalin Marinas:
"arm64 and generic kernel/module.c (acked by Rusty) fixes for
CONFIG_DEBUG_SET_MODULE_RONX"
* tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux:
kernel/module.c: Update debug alignment after symtable generation
arm64: Don't use is_module_addr in setting page attributes
commit 6ae9200f2cab7 ("enlarge console.name") increased the storage
for the console name to 16 bytes, but not the corresponding
struct console_cmdline::name storage. Console names longer than
8 bytes cause read beyond end-of-string and failure to match
console; I'm not sure if there are other unexpected consequences.
Cc: <stable@vger.kernel.org> # 2.6.22+
Signed-off-by: Peter Hurley <peter@hurleysoftware.com>
"Fix an RCU unlock misplacement in live patching infrastructure, from
Peter Zijlstra"
livepatch: fix RCU usage in klp_find_external_symbol()
When CONFIG_DEBUG_SET_MODULE_RONX is enabled, the sizes of
module sections are aligned up so appropriate permissions can
be applied. Adjusting for the symbol table may cause them to
become unaligned. Make sure to re-align the sizes afterward.
Signed-off-by: Laura Abbott <lauraa@codeaurora.org>
* irq-pm:
genirq / PM: describe IRQF_COND_SUSPEND
tty: serial: atmel: rework interrupt and wakeup handling
watchdog: at91sam9: request the irq with IRQF_NO_SUSPEND
clk: at91: implement suspend/resume for the PMC irqchip
rtc: at91rm9200: rework wakeup and interrupt handling
rtc: at91sam9: rework wakeup and interrupt handling
PM / wakeup: export pm_system_wakeup symbol
genirq / PM: Add flag for shared NO_SUSPEND interrupt lines
genirq / PM: better describe IRQF_NO_SUSPEND semantics
* suspend-to-idle:
cpuidle / sleep: Use broadcast timer for states that stop local timer
cpuidle: Clean up fallback handling in cpuidle_idle_call()
cpuidle / sleep: Do sanity checks in cpuidle_enter_freeze() too
idle / sleep: Avoid excessive disabling and enabling interrupts
Commit 381063133246 (PM / sleep: Re-implement suspend-to-idle handling)
overlooked the fact that entering some sufficiently deep idle states
by CPUs may cause their local timers to stop and in those cases it
is necessary to switch over to a broadcast timer prior to entering
the idle state. If the cpuidle driver in use does not provide
the new ->enter_freeze callback for any of the idle states, that
problem affects suspend-to-idle too, but it is not taken into account
after the changes made by commit 381063133246.
Fix that by changing the definition of cpuidle_enter_freeze() and
re-arranging of the code in cpuidle_idle_call(), so the former does
not call cpuidle_enter() any more and the fallback case is handled
by cpuidle_idle_call() directly.
Fixes: 381063133246 (PM / sleep: Re-implement suspend-to-idle handling)
Reported-and-tested-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
PREEMPT_NONE
cancel[_delayed]_work_sync() are implemented using
__cancel_work_timer() which grabs the PENDING bit using
try_to_grab_pending() and then flushes the work item with PENDING set
to prevent the on-going execution of the work item from requeueing
itself.
try_to_grab_pending() can always grab PENDING bit without blocking
except when someone else is doing the above flushing during
cancelation. In that case, try_to_grab_pending() returns -ENOENT. In
this case, __cancel_work_timer() currently invokes flush_work(). The
assumption is that the completion of the work item is what the other
canceling task would be waiting for too and thus waiting for the same
condition and retrying should allow forward progress without excessive
busy looping
Unfortunately, this doesn't work if preemption is disabled or the
latter task has real time priority. Let's say task A just got woken
up from flush_work() by the completion of the target work item. If,
before task A starts executing, task B gets scheduled and invokes
__cancel_work_timer() on the same work item, its try_to_grab_pending()
will return -ENOENT as the work item is still being canceled by task A
and flush_work() will also immediately return false as the work item
is no longer executing. This puts task B in a busy loop possibly
preventing task A from executing and clearing the canceling state on
the work item leading to a hang.
task A task B worker
executing work
set work CANCELING
flush_work()
block for work completion
completion, wakes up A
while (forever) {
-ENOENT as work is being canceled
flush_work()
false as work is no longer executing
This patch removes the possible hang by updating __cancel_work_timer()
to explicitly wait for clearing of CANCELING rather than invoking
flush_work() after try_to_grab_pending() fails with -ENOENT.
Link: http://lkml.kernel.org/g/20150206171156.GA8942@axis.com
v3: bit_waitqueue() can't be used for work items defined in vmalloc
area. Switched to custom wake function which matches the target
work item and exclusive wait and wakeup.
v2: v1 used wake_up() on bit_waitqueue() which leads to NULL deref if
the target bit waitqueue has wait_bit_queue's on it. Use
DEFINE_WAIT_BIT() and __wake_up_bit() instead. Reported by Tomeu
Vizoso.
Reported-by: Rabin Vincent <rabin.vincent@axis.com>
Cc: Tomeu Vizoso <tomeu.vizoso@gmail.com>
Tested-by: Jesper Nilsson <jesper.nilsson@axis.com>
Tested-by: Rabin Vincent <rabin.vincent@axis.com>
It currently is required that all users of NO_SUSPEND interrupt
lines pass the IRQF_NO_SUSPEND flag when requesting the IRQ or the
WARN_ON_ONCE() in irq_pm_install_action() will trigger. That is
done to warn about situations in which unprepared interrupt handlers
may be run unnecessarily for suspended devices and may attempt to
access those devices by mistake. However, it may cause drivers
that have no technical reasons for using IRQF_NO_SUSPEND to set
that flag just because they happen to share the interrupt line
with something like a timer.
Moreover, the generic handling of wakeup interrupts introduced by
commit 9ce7a25849e8 (genirq: Simplify wakeup mechanism) only works
for IRQs without any NO_SUSPEND users, so the drivers of wakeup
devices needing to use shared NO_SUSPEND interrupt lines for
signaling system wakeup generally have to detect wakeup in their
interrupt handlers. Thus if they happen to share an interrupt line
with a NO_SUSPEND user, they also need to request that their
interrupt handlers be run after suspend_device_irqs().
In both cases the reason for using IRQF_NO_SUSPEND is not because
the driver in question has a genuine need to run its interrupt
handler after suspend_device_irqs(), but because it happens to
share the line with some other NO_SUSPEND user. Otherwise, the
driver would do without IRQF_NO_SUSPEND just fine.
To make it possible to specify that condition explicitly, introduce
a new IRQ action handler flag for shared IRQs, IRQF_COND_SUSPEND,
that, when set, will indicate to the IRQ core that the interrupt
user is generally fine with suspending the IRQ, but it also can
tolerate handler invocations after suspend_device_irqs() and, in
particular, it is capable of detecting system wakeup and triggering
it as appropriate from its interrupt handler.
That will allow us to work around a problem with a shared timer
interrupt line on at91 platforms.
Link: http://marc.info/?l=linux-kernel&m=142252777602084&w=2
Link: http://marc.info/?t=142252775300011&r=1&w=2
Link: https://lkml.org/lkml/2014/12/15/552
Reported-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Acked-by: Mark Rutland <mark.rutland@arm.com>
While one must hold RCU-sched (aka. preempt_disable) for find_symbol()
one must equally hold it over the use of the object returned.
The moment you release the RCU-sched read lock, the object can be dead
and gone.
[jkosina@suse.cz: change subject line to be aligned with other patches]
Cc: Seth Jennings <sjenning@redhat.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: Miroslav Benes <mbenes@suse.cz>
Cc: Petr Mladek <pmladek@suse.cz>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Reviewed-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Move the fallback code path in cpuidle_idle_call() to the end of the
function to avoid jumping to a label in an if () branch.
The cpuset.sched_relax_domain_level can control how far we do
immediate load balancing on a system. However, it was found on recent
kernels that echo'ing a value into cpuset.sched_relax_domain_level
did not reduce any immediate load balancing.
The reason this occurred was because the update_domain_attr_tree() traversal
did not update for the "top_cpuset". This resulted in nothing being changed
when modifying the sched_relax_domain_level parameter.
This patch is able to address that problem by having update_domain_attr_tree()
allow updates for the root in the cpuset traversal.
Fixes: fc560a26acce ("cpuset: replace cpuset->stack_list with cpuset_for_each_descendant_pre()")
Cc: <stable@vger.kernel.org> # 3.9+
Signed-off-by: Jason Low <jason.low2@hp.com>
Signed-off-by: Zefan Li <lizefan@huawei.com>
Tested-by: Serge Hallyn <serge.hallyn@canonical.com>
When we clear cpuset.cpus, cpuset.effective_cpus won't be cleared:
# mount -t cgroup -o cpuset xxx /mnt
# mkdir /mnt/tmp
# echo 0 > /mnt/tmp/cpuset.cpus
# echo > /mnt/tmp/cpuset.cpus
# cat cpuset.cpus
# cat cpuset.effective_cpus
0-15
And a kernel warning in update_cpumasks_hier() is triggered:
WARNING: CPU: 0 PID: 4028 at kernel/cpuset.c:894 update_cpumasks_hier+0x471/0x650()
Cc: <stable@vger.kernel.org> # 3.17+
