commit 20878232c52329f92423d27a60e48b6a6389e0dd upstream.
Systems show a minimal load average of 0.00, 0.01, 0.05 even when they
have no load at all.
Uptime and /proc/loadavg on all systems with kernels released during the
last five years up until kernel version 4.6-rc5, show a 5- and 15-minute
minimum loadavg of 0.01 and 0.05 respectively. This should be 0.00 on
idle systems, but the way the kernel calculates this value prevents it
from getting lower than the mentioned values.
Likewise but not as obviously noticeable, a fully loaded system with no
processes waiting, shows a maximum 1/5/15 loadavg of 1.00, 0.99, 0.95
(multiplied by number of cores).
Once the (old) load becomes 93 or higher, it mathematically can never
get lower than 93, even when the active (load) remains 0 forever.
This results in the strange 0.00, 0.01, 0.05 uptime values on idle
systems. Note: 93/2048 = 0.0454..., which rounds up to 0.05.
It is not correct to add a 0.5 rounding (=1024/2048) here, since the
result from this function is fed back into the next iteration again,
so the result of that +0.5 rounding value then gets multiplied by
(2048-2037), and then rounded again, so there is a virtual "ghost"
load created, next to the old and active load terms.
By changing the way the internally kept value is rounded, that internal
value equivalent now can reach 0.00 on idle, and 1.00 on full load. Upon
increasing load, the internally kept load value is rounded up, when the
load is decreasing, the load value is rounded down.
The modified code was tested on nohz=off and nohz kernels. It was tested
on vanilla kernel 4.6-rc5 and on centos 7.1 kernel 3.10.0-327. It was
tested on single, dual, and octal cores system. It was tested on virtual
hosts and bare hardware. No unwanted effects have been observed, and the
problems that the patch intended to fix were indeed gone.
Tested-by: Damien Wyart <damien.wyart@free.fr>
Signed-off-by: Vik Heyndrickx <vik.heyndrickx@veribox.net>
Cc: Doug Smythies <dsmythies@telus.net>
Fixes: 0f004f5a696a ("sched: Cure more NO_HZ load average woes")
Link: http://lkml.kernel.org/r/e8d32bff-d544-7748-72b5-3c86cc71f09f@veribox.net
commit 59643d1535eb220668692a5359de22545af579f6 upstream.
If the size passed to ring_buffer_resize() is greater than MAX_LONG - BUF_PAGE_SIZE
then the DIV_ROUND_UP() will return zero.
Here's the details:
# echo 18014398509481980 > /sys/kernel/debug/tracing/buffer_size_kb
tracing_entries_write() processes this and converts kb to bytes.
18014398509481980 << 10 = 18446744073709547520
and this is passed to ring_buffer_resize() as unsigned long size.
size = DIV_ROUND_UP(size, BUF_PAGE_SIZE);
Where DIV_ROUND_UP(a, b) is (a + b - 1)/b
BUF_PAGE_SIZE is 4080 and here
18446744073709547520 + 4080 - 1 = 18446744073709551599
where 18446744073709551599 is still smaller than 2^64
2^64 - 18446744073709551599 = 17
But now 18446744073709551599 / 4080 = 4521260802379792
and size = size * 4080 = 18446744073709551360
This is checked to make sure its still greater than 2 * 4080,
which it is.
Then we convert to the number of buffer pages needed.
nr_page = DIV_ROUND_UP(size, BUF_PAGE_SIZE)
but this time size is 18446744073709551360 and
2^64 - (18446744073709551360 + 4080 - 1) = -3823
Thus it overflows and the resulting number is less than 4080, which makes
3823 / 4080 = 0
an nr_pages is set to this. As we already checked against the minimum that
nr_pages may be, this causes the logic to fail as well, and we crash the
kernel.
There's no reason to have the two DIV_ROUND_UP() (that's just result of
historical code changes), clean up the code and fix this bug.
Fixes: 83f40318dab00 ("ring-buffer: Make removal of ring buffer pages atomic")
commit 9b94a8fba501f38368aef6ac1b30e7335252a220 upstream.
The size variable to change the ring buffer in ftrace is a long. The
nr_pages used to update the ring buffer based on the size is int. On 64 bit
machines this can cause an overflow problem.
For example, the following will cause the ring buffer to crash:
# cd /sys/kernel/debug/tracing
# echo 10 > buffer_size_kb
# echo 8556384240 > buffer_size_kb
Then you get the warning of:
WARNING: CPU: 1 PID: 318 at kernel/trace/ring_buffer.c:1527 rb_update_pages+0x22f/0x260
Which is:
RB_WARN_ON(cpu_buffer, nr_removed);
Note each ring buffer page holds 4080 bytes.
This is because:
1) 10 causes the ring buffer to have 3 pages.
(10kb requires 3 * 4080 pages to hold)
2) (2^31 / 2^10 + 1) * 4080 = 8556384240
The value written into buffer_size_kb is shifted by 10 and then passed
to ring_buffer_resize(). 8556384240 * 2^10 = 8761737461760
3) The size passed to ring_buffer_resize() is then divided by BUF_PAGE_SIZE
which is 4080. 8761737461760 / 4080 = 2147484672
4) nr_pages is subtracted from the current nr_pages (3) and we get:
2147484669. This value is saved in a signed integer nr_pages_to_update
5) 2147484669 is greater than 2^31 but smaller than 2^32, a signed int
turns into the value of -2147482627
6) As the value is a negative number, in update_pages_handler() it is
negated and passed to rb_remove_pages() and 2147482627 pages will
be removed, which is much larger than 3 and it causes the warning
because not all the pages asked to be removed were removed.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=118001
Fixes: 7a8e76a3829f1 ("tracing: unified trace buffer")
Reported-by: Hao Qin <QEver.cn@gmail.com>
commit 79c9ce57eb2d5f1497546a3946b4ae21b6fdc438 upstream.
Jann reported that the ptrace_may_access() check in
find_lively_task_by_vpid() is racy against exec().
Specifically:
perf_event_open() execve()
ptrace_may_access()
commit_creds()
... if (get_dumpable() != SUID_DUMP_USER)
perf_event_exit_task();
perf_install_in_context()
would result in installing a counter across the creds boundary.
Fix this by wrapping lots of perf_event_open() in cred_guard_mutex.
This should be fine as perf_event_exit_task() is already called with
cred_guard_mutex held, so all perf locks already nest inside it.
Reported-by: Jann Horn <jannh@google.com>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Vince Weaver <vincent.weaver@maine.edu>
Signed-off-by: He Kuang <hekuang@huawei.com>
commit f7c17d26f43d5cc1b7a6b896cd2fa24a079739b9 upstream.
WARNING: CPU: 0 PID: 16 at kernel/workqueue.c:4559 rebind_workers+0x1c0/0x1d0
Modules linked in:
CPU: 0 PID: 16 Comm: cpuhp/0 Not tainted 4.6.0-rc4+ #31
Hardware name: IBM IBM System x3550 M4 Server -[7914IUW]-/00Y8603, BIOS -[D7E128FUS-1.40]- 07/23/2013
0000000000000000 ffff881037babb58 ffffffff8139d885 0000000000000010
0000000000000000 0000000000000000 0000000000000000 ffff881037babba8
ffffffff8108505d ffff881037ba0000 000011cf3e7d6e60 0000000000000046
Call Trace:
dump_stack+0x89/0xd4
__warn+0xfd/0x120
warn_slowpath_null+0x1d/0x20
workqueue_cpu_up_callback+0xf5/0x1d0
notifier_call_chain+0x64/0x90
? trace_hardirqs_on_caller+0xf2/0x220
? notify_prepare+0x80/0x80
__raw_notifier_call_chain+0xe/0x10
__cpu_notify+0x35/0x50
notify_down_prepare+0x5e/0x80
cpuhp_invoke_callback+0x73/0x330
? __schedule+0x33e/0x8a0
cpuhp_down_callbacks+0x51/0xc0
cpuhp_thread_fun+0xc1/0xf0
smpboot_thread_fn+0x159/0x2a0
? smpboot_create_threads+0x80/0x80
kthread+0xef/0x110
? wait_for_completion+0xf0/0x120
? schedule_tail+0x35/0xf0
ret_from_fork+0x22/0x50
? __init_kthread_worker+0x70/0x70
---[ end trace eb12ae47d2382d8f ]---
notify_down_prepare: attempt to take down CPU 0 failed
This bug can be reproduced by below config w/ nohz_full= all cpus:
CONFIG_BOOTPARAM_HOTPLUG_CPU0=y
CONFIG_DEBUG_HOTPLUG_CPU0=y
CONFIG_NO_HZ_FULL=y
As Thomas pointed out:
| If a down prepare callback fails, then DOWN_FAILED is invoked for all
| callbacks which have successfully executed DOWN_PREPARE.
| But, workqueue has actually two notifiers. One which handles
| UP/DOWN_FAILED/ONLINE and one which handles DOWN_PREPARE.
| Now look at the priorities of those callbacks:
| CPU_PRI_WORKQUEUE_UP = 5
| CPU_PRI_WORKQUEUE_DOWN = -5
| So the call order on DOWN_PREPARE is:
| CB 1
| CB ...
| CB workqueue_up() -> Ignores DOWN_PREPARE
| CB ...
| CB X ---> Fails
| So we call up to CB X with DOWN_FAILED
| CB 1
| CB ...
| CB workqueue_up() -> Handles DOWN_FAILED
| CB ...
| CB X-1
| So the problem is that the workqueue stuff handles DOWN_FAILED in the up
| callback, while it should do it in the down callback. Which is not a good idea
| either because it wants to be called early on rollback...
| Brilliant stuff, isn't it? The hotplug rework will solve this problem because
| the callbacks become symetric, but for the existing mess, we need some
| workaround in the workqueue code.
The boot CPU handles housekeeping duty(unbound timers, workqueues,
timekeeping, ...) on behalf of full dynticks CPUs. It must remain
online when nohz full is enabled. There is a priority set to every
notifier_blocks:
workqueue_cpu_up > tick_nohz_cpu_down > workqueue_cpu_down
So tick_nohz_cpu_down callback failed when down prepare cpu 0, and
notifier_blocks behind tick_nohz_cpu_down will not be called any
more, which leads to workers are actually not unbound. Then hotplug
state machine will fallback to undo and online cpu 0 again. Workers
will be rebound unconditionally even if they are not unbound and
trigger the warning in this progress.
This patch fix it by catching !DISASSOCIATED to avoid rebind bound
workers.
Cc: Tejun Heo <tj@kernel.org>
Cc: Lai Jiangshan <jiangshanlai@gmail.com>
Cc: Frédéric Weisbecker <fweisbec@gmail.com>
Suggested-by: Lai Jiangshan <jiangshanlai@gmail.com>
Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com>
commit 9f448cd3cbcec8995935e60b27802ae56aac8cc0 upstream.
When the PMU driver reports a truncated AUX record, it effectively means
that there is no more usable room in the event's AUX buffer (even though
there may still be some room, so that perf_aux_output_begin() doesn't take
action). At this point the consumer still has to be woken up and the event
has to be disabled, otherwise the event will just keep spinning between
perf_aux_output_begin() and perf_aux_output_end() until its context gets
unscheduled.
Again, for cpu-wide events this means never, so once in this condition,
they will be forever losing data.
Fix this by disabling the event and waking up the consumer in case of a
truncated AUX record.
Reported-by: Markus Metzger <markus.t.metzger@intel.com>
Signed-off-by: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@infradead.org>
Cc: vince@deater.net
Link: http://lkml.kernel.org/r/1462886313-13660-3-git-send-email-alexander.shishkin@linux.intel.com
[ Upstream commit 6aff67c85c9e5a4bc99e5211c1bac547936626ca ]
The commit 35578d798400 ("bpf: Implement function bpf_perf_event_read() that get the selected hardware PMU conuter")
introduced clever way to check bpf_helper<->map_type compatibility.
Later on commit a43eec304259 ("bpf: introduce bpf_perf_event_output() helper") adjusted
the logic and inadvertently broke it.
Get rid of the clever bool compare and go back to two-way check
from map and from helper perspective.
Fixes: a43eec304259 ("bpf: introduce bpf_perf_event_output() helper")
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
[ Upstream commit 92117d8443bc5afacc8d5ba82e541946310f106e ]
On a system with >32Gbyte of phyiscal memory and infinite RLIMIT_MEMLOCK,
the malicious application may overflow 32-bit bpf program refcnt.
It's also possible to overflow map refcnt on 1Tb system.
Impose 32k hard limit which means that the same bpf program or
map cannot be shared by more than 32k processes.
Fixes: 1be7f75d1668 ("bpf: enable non-root eBPF programs")
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
[ Upstream commit 8358b02bf67d3a5d8a825070e1aa73f25fb2e4c7 ]
When bpf(BPF_PROG_LOAD, ...) was invoked with a BPF program whose bytecode
references a non-map file descriptor as a map file descriptor, the error
handling code called fdput() twice instead of once (in __bpf_map_get() and
in replace_map_fd_with_map_ptr()). If the file descriptor table of the
current task is shared, this causes f_count to be decremented too much,
allowing the struct file to be freed while it is still in use
(use-after-free). This can be exploited to gain root privileges by an
unprivileged user.
This bug was introduced in
commit 0246e64d9a5f ("bpf: handle pseudo BPF_LD_IMM64 insn"), but is only
exploitable since
commit 1be7f75d1668 ("bpf: enable non-root eBPF programs") because
previously, CAP_SYS_ADMIN was required to reach the vulnerable code.
(posted publicly according to request by maintainer)
Signed-off-by: Jann Horn <jannh@google.com>
Acked-by: Alexei Starovoitov <ast@kernel.org>
[ Upstream commit d82bccc69041a51f7b7b9b4a36db0772f4cdba21 ]
verifier must check for reserved size bits in instruction opcode and
reject BPF_LD | BPF_ABS | BPF_DW and BPF_LD | BPF_IND | BPF_DW instructions,
otherwise interpreter will WARN_RATELIMIT on them during execution.
Fixes: ddd872bc3098 ("bpf: verifier: add checks for BPF_ABS | BPF_IND instructions")
commit 854145e0a8e9a05f7366d240e2f99d9c1ca6d6dd upstream.
Currently register functions for events will be called
through the 'reg' field of event class directly without
any check when seting up triggers.
Triggers for events that don't support register through
debug fs (events under events/ftrace are for trace-cmd to
read event format, and most of them don't have a register
function except events/ftrace/functionx) can't be enabled
at all, and an oops will be hit when setting up trigger
for those events, so just not creating them is an easy way
to avoid the oops.
Link: http://lkml.kernel.org/r/1462275274-3911-1-git-send-email-chuhu@redhat.com
Fixes: 85f2b08268c01 ("tracing: Add basic event trigger framework")
Signed-off-by: Chunyu Hu <chuhu@redhat.com>
commit 920c720aa5aa3900a7f1689228fdfc2580a91e7e upstream.
Similar to commit b4b29f94856a ("locking/osq: Fix ordering of node
initialisation in osq_lock") the use of xchg_acquire() is
fundamentally broken with MCS like constructs.
Furthermore, it turns out we rely on the global transitivity of this
operation because the unlock path observes the pointer with a
READ_ONCE(), not an smp_load_acquire().
This is non-critical because the MCS code isn't actually used and
mostly serves as documentation, a stepping stone to the more complex
things we've build on top of the idea.
Reported-by: Andrea Parri <parri.andrea@gmail.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Fixes: 3552a07a9c4a ("locking/mcs: Use acquire/release semantics")
commit 8bb5ef79bc0f4016ecf79e8dce6096a3c63603e4 upstream.
There are three subsystem callbacks in css shutdown path -
css_offline(), css_released() and css_free(). Except for
css_released(), cgroup core didn't guarantee the order of invocation.
css_offline() or css_free() could be called on a parent css before its
children. This behavior is unexpected and led to bugs in cpu and
memory controller.
The previous patch updated ordering for css_offline() which fixes the
cpu controller issue. While there currently isn't a known bug caused
by misordering of css_free() invocations, let's fix it too for
consistency.
css_free() ordering can be trivially fixed by moving putting of the
parent css below css_free() invocation.
cgroup_subsys->post_attach callback
commit 5cf1cacb49aee39c3e02ae87068fc3c6430659b0 upstream.
Since e93ad19d0564 ("cpuset: make mm migration asynchronous"), cpuset
kicks off asynchronous NUMA node migration if necessary during task
migration and flushes it from cpuset_post_attach_flush() which is
called at the end of __cgroup_procs_write(). This is to avoid
performing migration with cgroup_threadgroup_rwsem write-locked which
can lead to deadlock through dependency on kworker creation.
memcg has a similar issue with charge moving, so let's convert it to
an official callback rather than the current one-off cpuset specific
function. This patch adds cgroup_subsys->post_attach callback and
makes cpuset register cpuset_post_attach_flush() as its ->post_attach.
The conversion is mostly one-to-one except that the new callback is
called under cgroup_mutex. This is to guarantee that no other
migration operations are started before ->post_attach callbacks are
finished. cgroup_mutex is one of the outermost mutex in the system
and has never been and shouldn't be a problem. We can add specialized
synchronization around __cgroup_procs_write() but I don't think
there's any noticeable benefit.
Cc: Li Zefan <lizefan@huawei.com>
Cc: Michal Hocko <mhocko@kernel.org>
commit 346c09f80459a3ad97df1816d6d606169a51001a upstream.
The bug in a workqueue leads to a stalled IO request in MQ ctx->rq_list
with the following backtrace:
[ 601.347452] INFO: task kworker/u129:5:1636 blocked for more than 120 seconds.
[ 601.347574] Tainted: G O 4.4.5-1-storage+ #6
[ 601.347651] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 601.348142] kworker/u129:5 D ffff880803077988 0 1636 2 0x00000000
[ 601.348519] Workqueue: ibnbd_server_fileio_wq ibnbd_dev_file_submit_io_worker [ibnbd_server]
[ 601.348999] ffff880803077988 ffff88080466b900 ffff8808033f9c80 ffff880803078000
[ 601.349662] ffff880807c95000 7fffffffffffffff ffffffff815b0920 ffff880803077ad0
[ 601.350333] ffff8808030779a0 ffffffff815b01d5 0000000000000000 ffff880803077a38
[ 601.350965] Call Trace:
[ 601.351203] [<ffffffff815b0920>] ? bit_wait+0x60/0x60
[ 601.351444] [<ffffffff815b01d5>] schedule+0x35/0x80
[ 601.351709] [<ffffffff815b2dd2>] schedule_timeout+0x192/0x230
[ 601.351958] [<ffffffff812d43f7>] ? blk_flush_plug_list+0xc7/0x220
[ 601.352208] [<ffffffff810bd737>] ? ktime_get+0x37/0xa0
[ 601.352446] [<ffffffff815b0920>] ? bit_wait+0x60/0x60
[ 601.352688] [<ffffffff815af784>] io_schedule_timeout+0xa4/0x110
[ 601.352951] [<ffffffff815b3a4e>] ? _raw_spin_unlock_irqrestore+0xe/0x10
[ 601.353196] [<ffffffff815b093b>] bit_wait_io+0x1b/0x70
[ 601.353440] [<ffffffff815b056d>] __wait_on_bit+0x5d/0x90
[ 601.353689] [<ffffffff81127bd0>] wait_on_page_bit+0xc0/0xd0
[ 601.353958] [<ffffffff81096db0>] ? autoremove_wake_function+0x40/0x40
[ 601.354200] [<ffffffff81127cc4>] __filemap_fdatawait_range+0xe4/0x140
[ 601.354441] [<ffffffff81127d34>] filemap_fdatawait_range+0x14/0x30
[ 601.354688] [<ffffffff81129a9f>] filemap_write_and_wait_range+0x3f/0x70
[ 601.354932] [<ffffffff811ced3b>] blkdev_fsync+0x1b/0x50
[ 601.355193] [<ffffffff811c82d9>] vfs_fsync_range+0x49/0xa0
[ 601.355432] [<ffffffff811cf45a>] blkdev_write_iter+0xca/0x100
[ 601.355679] [<ffffffff81197b1a>] __vfs_write+0xaa/0xe0
[ 601.355925] [<ffffffff81198379>] vfs_write+0xa9/0x1a0
[ 601.356164] [<ffffffff811c59d8>] kernel_write+0x38/0x50
The underlying device is a null_blk, with default parameters:
queue_mode = MQ
submit_queues = 1
Verification that nullb0 has something inflight:
root@pserver8:~# cat /sys/block/nullb0/inflight
0 1
root@pserver8:~# find /sys/block/nullb0/mq/0/cpu* -name rq_list -print -exec cat {} \;
/sys/block/nullb0/mq/0/cpu2/rq_list
CTX pending:
ffff8838038e2400
During debug it became clear that stalled request is always inserted in
the rq_list from the following path:
save_stack_trace_tsk + 34
blk_mq_insert_requests + 231
blk_mq_flush_plug_list + 281
blk_flush_plug_list + 199
wait_on_page_bit + 192
__filemap_fdatawait_range + 228
filemap_fdatawait_range + 20
filemap_write_and_wait_range + 63
blkdev_fsync + 27
vfs_fsync_range + 73
blkdev_write_iter + 202
__vfs_write + 170
vfs_write + 169
kernel_write + 56
So blk_flush_plug_list() was called with from_schedule == true.
If from_schedule is true, that means that finally blk_mq_insert_requests()
offloads execution of __blk_mq_run_hw_queue() and uses kblockd workqueue,
i.e. it calls kblockd_schedule_delayed_work_on().
That means, that we race with another CPU, which is about to execute
__blk_mq_run_hw_queue() work.
Further debugging shows the following traces from different CPUs:
CPU#0 CPU#1
reqeust A inserted
STORE hctx->ctx_map[0] bit marked
kblockd_schedule...() returns 1
<schedule to kblockd workqueue>
request B inserted
STORE hctx->ctx_map[1] bit marked
kblockd_schedule...() returns 0
*** WORK PENDING bit is cleared ***
flush_busy_ctxs() is executed, but
bit 1, set by CPU#1, is not observed
As a result request B pended forever.
This behaviour can be explained by speculative LOAD of hctx->ctx_map on
CPU#0, which is reordered with clear of PENDING bit and executed _before_
actual STORE of bit 1 on CPU#1.
The proper fix is an explicit full barrier <mfence>, which guarantees
that clear of PENDING bit is to be executed before all possible
speculative LOADS or STORES inside actual work function.
Signed-off-by: Roman Pen <roman.penyaev@profitbricks.com>
Cc: Gioh Kim <gi-oh.kim@profitbricks.com>
Cc: Michael Wang <yun.wang@profitbricks.com>
Cc: linux-block@vger.kernel.org
commit fe1bce9e2107ba3a8faffe572483b6974201a0e6 upstream.
Otherwise an incoming waker on the dest hash bucket can miss
the waiter adding itself to the plist during the lockless
check optimization (small window but still the correct way
of doing this); similarly to the decrement counterpart.
Suggested-by: Peter Zijlstra <peterz@infradead.org>
Signed-off-by: Davidlohr Bueso <dbueso@suse.de>
Cc: Davidlohr Bueso <dave@stgolabs.net>
Cc: bigeasy@linutronix.de
Cc: dvhart@infradead.org
Link: http://lkml.kernel.org/r/1461208164-29150-1-git-send-email-dave@stgolabs.net
commit 89e9e66ba1b3bde9d8ea90566c2aee20697ad681 upstream.
If userspace calls UNLOCK_PI unconditionally without trying the TID -> 0
transition in user space first then the user space value might not have the
waiters bit set. This opens the following race:
CPU0 CPU1
uval = get_user(futex)
lock(hb)
lock(hb)
futex |= FUTEX_WAITERS
unlock(hb)
cmpxchg(futex, uval, newval)
So the cmpxchg fails and returns -EINVAL to user space, which is wrong because
the futex value is valid.
To handle this (yes, yet another) corner case gracefully, check for a flag
change and retry.
[ tglx: Massaged changelog and slightly reworked implementation ]
Fixes: ccf9e6a80d9e ("futex: Make unlock_pi more robust")
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Cc: Darren Hart <dvhart@linux.intel.com>
Link: http://lkml.kernel.org/r/1460723739-5195-1-git-send-email-bigeasy@linutronix.de
commit 2f5177f0fd7e531b26d54633be62d1d4cb94621c upstream.
The CPU controller hasn't kept up with the various changes in the whole
cgroup initialization / destruction sequence, and commit:
2e91fa7f6d45 ("cgroup: keep zombies associated with their original cgroups")
caused it to explode.
The reason for this is that zombies do not inhibit css_offline() from
being called, but do stall css_released(). Now we tear down the cfs_rq
structures on css_offline() but zombies can run after that, leading to
use-after-free issues.
The solution is to move the tear-down to css_released(), which
guarantees nobody (including no zombies) is still using our cgroup.
Furthermore, a few simple cleanups are possible too. There doesn't
appear to be any point to us using css_online() (anymore?) so fold that
in css_alloc().
And since cgroup code guarantees an RCU grace period between
css_released() and css_free() we can forgo using call_rcu() and free the
stuff immediately.
Suggested-by: Tejun Heo <tj@kernel.org>
Reported-by: Kazuki Yamaguchi <k@rhe.jp>
Reported-by: Niklas Cassel <niklas.cassel@axis.com>
Tested-by: Niklas Cassel <niklas.cassel@axis.com>
Acked-by: Tejun Heo <tj@kernel.org>
Fixes: 2e91fa7f6d45 ("cgroup: keep zombies associated with their original cgroups")
Link: http://lkml.kernel.org/r/20160316152245.GY6344@twins.programming.kicks-ass.net
commit 28a967c3a2f99fa3b5f762f25cb2a319d933571b upstream.
Because event_sched_out() checks event->pending_disable _before_
actually disabling the event, it can happen that the event fires after
it checks but before it gets disabled.
This would leave event->pending_disable set and the queued irq_work
will try and process it.
However, if the event trigger was during schedule(), the event might
have been de-scheduled by the time the irq_work runs, and
perf_event_disable_local() will fail.
Fix this by checking event->pending_disable _after_ we call
event->pmu->del(). This depends on the latter being a compiler
barrier, such that the compiler does not lift the load and re-creates
the problem.
Tested-by: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Reviewed-by: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: dvyukov@google.com
Cc: eranian@google.com
Cc: oleg@redhat.com
Cc: panand@redhat.com
Cc: sasha.levin@oracle.com
Link: http://lkml.kernel.org/r/20160224174948.040469884@infradead.org
commit 130056275ade730e7a79c110212c8815202773ee upstream.
In case of: err_file: fput(event_file), we'll end up calling
perf_release() which in turn will free the event.
Do not then free the event _again_.
Cc: oleg@redhat.com
Link: http://lkml.kernel.org/r/20160224174947.697350349@infradead.org
[ Upstream commit cdc4e47da8f4c32eeb6b2061a8a834f4362a12b7 ]
Lots of places in the kernel use memcpy(buf, comm, TASK_COMM_LEN); but
the result is typically passed to print("%s", buf) and extra bytes
after zero don't cause any harm.
In bpf the result of bpf_get_current_comm() is used as the part of
map key and was causing spurious hash map mismatches.
Use strlcpy() to guarantee zero-terminated string.
bpf verifier checks that output buffer is zero-initialized,
so even for short task names the output buffer don't have junk bytes.
Note it's not a security concern, since kprobe+bpf is root only.
Fixes: ffeedafbf023 ("bpf: introduce current->pid, tgid, uid, gid, comm accessors")
Reported-by: Tobias Waldekranz <tobias@waldekranz.com>
commit e9532e69b8d1d1284e8ecf8d2586de34aec61244 upstream.
On CPU hotplug the steal time accounting can keep a stale rq->prev_steal_time
value over CPU down and up. So after the CPU comes up again the delta
calculation in steal_account_process_tick() wreckages itself due to the
unsigned math:
u64 steal = paravirt_steal_clock(smp_processor_id());
steal -= this_rq()->prev_steal_time;
So if steal is smaller than rq->prev_steal_time we end up with an insane large
value which then gets added to rq->prev_steal_time, resulting in a permanent
wreckage of the accounting. As a consequence the per CPU stats in /proc/stat
become stale.
Nice trick to tell the world how idle the system is (100%) while the CPU is
100% busy running tasks. Though we prefer realistic numbers.
None of the accounting values which use a previous value to account for
fractions is reset at CPU hotplug time. update_rq_clock_task() has a sanity
check for prev_irq_time and prev_steal_time_rq, but that sanity check solely
deals with clock warps and limits the /proc/stat visible wreckage. The
prev_time values are still wrong.
Solution is simple: Reset rq->prev_*_time when the CPU is plugged in again.
Cc: Glauber Costa <glommer@parallels.com>
Fixes: commit 095c0aa83e52 "sched: adjust scheduler cpu power for stolen time"
Fixes: commit aa483808516c "sched: Remove irq time from available CPU power"
Fixes: commit e6e6685accfa "KVM guest: Steal time accounting"
Link: http://lkml.kernel.org/r/alpine.DEB.2.11.1603041539490.3686@nanos
commit 276142730c39c9839465a36a90e5674a8c34e839 upstream.
When suspending to RAM, waking up and later suspending to disk,
we gratuitously runtime resume devices after the thaw phase.
This does not occur if we always suspend to RAM or always to disk.
pm_complete_with_resume_check(), which gets called from
pci_pm_complete() among others, schedules a runtime resume
if PM_SUSPEND_FLAG_FW_RESUME is set. The flag is set during
a suspend-to-RAM cycle. It is cleared at the beginning of
the suspend-to-RAM cycle but not afterwards and it is not
cleared during a suspend-to-disk cycle at all. Fix it.
Fixes: ef25ba047601 (PM / sleep: Add flags to indicate platform firmware involvement)
Signed-off-by: Lukas Wunner <lukas@wunner.de>
commit 3debb0a9ddb16526de8b456491b7db60114f7b5e upstream.
The trace_printk() code will allocate extra buffers if the compile detects
that a trace_printk() is used. To do this, the format of the trace_printk()
is saved to the __trace_printk_fmt section, and if that section is bigger
than zero, the buffers are allocated (along with a message that this has
happened).
If trace_printk() uses a format that is not a constant, and thus something
not guaranteed to be around when the print happens, the compiler optimizes
the fmt out, as it is not used, and the __trace_printk_fmt section is not
filled. This means the kernel will not allocate the special buffers needed
for the trace_printk() and the trace_printk() will not write anything to the
tracing buffer.
Adding a "__used" to the variable in the __trace_printk_fmt section will
keep it around, even though it is set to NULL. This will keep the string
from being printed in the debugfs/tracing/printk_formats section as it is
not needed.
Reported-by: Vlastimil Babka <vbabka@suse.cz>
Fixes: 07d777fe8c398 "tracing: Add percpu buffers for trace_printk()"
commit a29054d9478d0435ab01b7544da4f674ab13f533 upstream.
If tracing contains data and the trace_pipe file is read with sendfile(),
then it can trigger a NULL pointer dereference and various BUG_ON within the
VM code.
There's a patch to fix this in the splice_to_pipe() code, but it's also a
good idea to not let that happen from trace_pipe either.
Link: http://lkml.kernel.org/r/1457641146-9068-1-git-send-email-rabin@rab.in
Reported-by: Rabin Vincent <rabin.vincent@gmail.com>
commit cb86e05390debcc084cfdb0a71ed4c5dbbec517d upstream.
Joel Fernandes reported that the function tracing of preempt disabled
sections was not being reported when running either the preemptirqsoff or
preemptoff tracers. This was due to the fact that the function tracer
callback for those tracers checked if irqs were disabled before tracing. But
this fails when we want to trace preempt off locations as well.
Joel explained that he wanted to see funcitons where interrupts are enabled
but preemption was disabled. The expected output he wanted:
<...>-2265 1d.h1 3419us : preempt_count_sub <-irq_exit
<...>-2265 1d..1 3419us : __do_softirq <-irq_exit
<...>-2265 1d..1 3419us : msecs_to_jiffies <-__do_softirq
<...>-2265 1d..1 3420us : irqtime_account_irq <-__do_softirq
<...>-2265 1d..1 3420us : __local_bh_disable_ip <-__do_softirq
<...>-2265 1..s1 3421us : run_timer_softirq <-__do_softirq
<...>-2265 1..s1 3421us : hrtimer_run_pending <-run_timer_softirq
<...>-2265 1..s1 3421us : _raw_spin_lock_irq <-run_timer_softirq
<...>-2265 1d.s1 3422us : preempt_count_add <-_raw_spin_lock_irq
<...>-2265 1d.s2 3422us : _raw_spin_unlock_irq <-run_timer_softirq
<...>-2265 1..s2 3422us : preempt_count_sub <-_raw_spin_unlock_irq
<...>-2265 1..s1 3423us : rcu_bh_qs <-__do_softirq
<...>-2265 1d.s1 3423us : irqtime_account_irq <-__do_softirq
<...>-2265 1d.s1 3423us : __local_bh_enable <-__do_softirq
There's a comment saying that the irq disabled check is because there's a
possible race that tracing_cpu may be set when the function is executed. But
I don't remember that race. For now, I added a check for preemption being
enabled too to not record the function, as there would be no race if that
was the case. I need to re-investigate this, as I'm now thinking that the
tracing_cpu will always be correct. But no harm in keeping the check for
now, except for the slight performance hit.
Link: http://lkml.kernel.org/r/1457770386-88717-1-git-send-email-agnel.joel@gmail.com
Fixes: 5e6d2b9cfa3a "tracing: Use one prologue for the preempt irqs off tracer function tracers"
Reported-by: Joel Fernandes <agnel.joel@gmail.com>
commit 378c6520e7d29280f400ef2ceaf155c86f05a71a upstream.
This commit fixes the following security hole affecting systems where
all of the following conditions are fulfilled:
- The fs.suid_dumpable sysctl is set to 2.
- The kernel.core_pattern sysctl's value starts with "/". (Systems
where kernel.core_pattern starts with "|/" are not affected.)
- Unprivileged user namespace creation is permitted. (This is
true on Linux >=3.8, but some distributions disallow it by
default using a distro patch.)
Under these conditions, if a program executes under secure exec rules,
causing it to run with the SUID_DUMP_ROOT flag, then unshares its user
namespace, changes its root directory and crashes, the coredump will be
written using fsuid=0 and a path derived from kernel.core_pattern - but
this path is interpreted relative to the root directory of the process,
allowing the attacker to control where a coredump will be written with
root privileges.
To fix the security issue, always interpret core_pattern for dumps that
are written under SUID_DUMP_ROOT relative to the root directory of init.
Signed-off-by: Jann Horn <jann@thejh.net>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
commit 2b021cbf3cb6208f0d40fd2f1869f237934340ed upstream.
Before 2e91fa7f6d45 ("cgroup: keep zombies associated with their
original cgroups"), all dead tasks were associated with init_css_set.
If a zombie task is requested for migration, while migration prep
operations would still be performed on init_css_set, the actual
migration would ignore zombie tasks. As init_css_set is always valid,
this worked fine.
However, after 2e91fa7f6d45, zombie tasks stay with the css_set it was
associated with at the time of death. Let's say a task T associated
with cgroup A on hierarchy H-1 and cgroup B on hiearchy H-2. After T
becomes a zombie, it would still remain associated with A and B. If A
only contains zombie tasks, it can be removed. On removal, A gets
marked offline but stays pinned until all zombies are drained. At
this point, if migration is initiated on T to a cgroup C on hierarchy
H-2, migration path would try to prepare T's css_set for migration and
trigger the following.
WARNING: CPU: 0 PID: 1576 at kernel/cgroup.c:474 cgroup_get+0x121/0x160()
CPU: 0 PID: 1576 Comm: bash Not tainted 4.4.0-work+ #289
Call Trace:
[<ffffffff8127e63c>] dump_stack+0x4e/0x82
[<ffffffff810445e8>] warn_slowpath_common+0x78/0xb0
[<ffffffff810446d5>] warn_slowpath_null+0x15/0x20
[<ffffffff810c33e1>] cgroup_get+0x121/0x160
[<ffffffff810c349b>] link_css_set+0x7b/0x90
[<ffffffff810c4fbc>] find_css_set+0x3bc/0x5e0
[<ffffffff810c5269>] cgroup_migrate_prepare_dst+0x89/0x1f0
[<ffffffff810c7547>] cgroup_attach_task+0x157/0x230
[<ffffffff810c7a17>] __cgroup_procs_write+0x2b7/0x470
[<ffffffff810c7bdc>] cgroup_tasks_write+0xc/0x10
[<ffffffff810c4790>] cgroup_file_write+0x30/0x1b0
[<ffffffff811c68fc>] kernfs_fop_write+0x13c/0x180
[<ffffffff81151673>] __vfs_write+0x23/0xe0
[<ffffffff81152494>] vfs_write+0xa4/0x1a0
[<ffffffff811532d4>] SyS_write+0x44/0xa0
[<ffffffff814af2d7>] entry_SYSCALL_64_fastpath+0x12/0x6f
It doesn't make sense to prepare migration for css_sets pointing to
dead cgroups as they are guaranteed to contain only zombies which are
ignored later during migration. This patch makes cgroup destruction
path mark all affected css_sets as dead and updates the migration path
to ignore them during preparation.
commit a1ee1932aa6bea0bb074f5e3ced112664e4637ed upstream.
While working on a script to restore all sysctl params before a series of
tests I found that writing any value into the
/proc/sys/kernel/{nmi_watchdog,soft_watchdog,watchdog,watchdog_thresh}
causes them to call proc_watchdog_update().
NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
There doesn't appear to be a reason for doing this work every time a write
occurs, so only do it when the values change.
Signed-off-by: Josh Hunt <johunt@akamai.com>
Acked-by: Don Zickus <dzickus@redhat.com>
Reviewed-by: Aaron Tomlin <atomlin@redhat.com>
Cc: Ulrich Obergfell <uobergfe@redhat.com>
commit f9c904b7613b8b4c85b10cd6b33ad41b2843fa9d upstream.
The callers of steal_account_process_tick() expect it to return
whether a jiffy should be considered stolen or not.
Currently the return value of steal_account_process_tick() is in
units of cputime, which vary between either jiffies or nsecs
depending on CONFIG_VIRT_CPU_ACCOUNTING_GEN.
If cputime has nsecs granularity and there is a tiny amount of
stolen time (a few nsecs, say) then we will consider the entire
tick stolen and will not account the tick on user/system/idle,
causing /proc/stats to show invalid data.
The fix is to change steal_account_process_tick() to accumulate
the stolen time and only account it once it's worth a jiffy.
(Thanks to Frederic Weisbecker for suggestions to fix a bug in my
first version of the patch.)
Signed-off-by: Chris Friesen <chris.friesen@windriver.com>
Link: http://lkml.kernel.org/r/56DBBDB8.40305@mail.usask.ca
commit 927a5570855836e5d5859a80ce7e91e963545e8f upstream.
The error path in perf_event_open() is such that asking for a sampling
event on a PMU that doesn't generate interrupts will end up in dropping
the perf_sched_count even though it hasn't been incremented for this
event yet.
Given a sufficient amount of these calls, we'll end up disabling
scheduler's jump label even though we'd still have active events in the
system, thereby facilitating the arrival of the infernal regions upon us.
I'm fixing this by moving account_event() inside perf_event_alloc().
Link: http://lkml.kernel.org/r/1456917854-29427-1-git-send-email-alexander.shishkin@linux.intel.com
commit 8244062ef1e54502ef55f54cced659913f244c3e upstream.
For CONFIG_KALLSYMS, we keep two symbol tables and two string tables.
There's one full copy, marked SHF_ALLOC and laid out at the end of the
module's init section. There's also a cut-down version that only
contains core symbols and strings, and lives in the module's core
section.
After module init (and before we free the module memory), we switch
the mod->symtab, mod->num_symtab and mod->strtab to point to the core
versions. We do this under the module_mutex.
However, kallsyms doesn't take the module_mutex: it uses
preempt_disable() and rcu tricks to walk through the modules, because
it's used in the oops path. It's also used in /proc/kallsyms.
There's nothing atomic about the change of these variables, so we can
get the old (larger!) num_symtab and the new symtab pointer; in fact
this is what I saw when trying to reproduce.
By grouping these variables together, we can use a
carefully-dereferenced pointer to ensure we always get one or the
other (the free of the module init section is already done in an RCU
callback, so that's safe). We allocate the init one at the end of the
module init section, and keep the core one inside the struct module
itself (it could also have been allocated at the end of the module
core, but that's probably overkill).
[ Rebased for 4.4-stable and older, because the following changes aren't
in the older trees:
- e0224418516b4d8a6c2160574bac18447c354ef0: adds arg to is_core_symbol
- 7523e4dc5057e157212b4741abd6256e03404cf1: module_init/module_core/init_size/core_size
become init_layout.base/core_layout.base/init_layout.size/core_layout.size.
Reported-by: Weilong Chen <chenweilong@huawei.com>
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=111541
Cc: stable@kernel.org
commit e57cbaf0eb006eaa207395f3bfd7ce52c1b5539c upstream.
Commit 9f61668073a8d "tracing: Allow triggers to filter for CPU ids and
process names" added a 'comm' filter that will filter events based on the
current tasks struct 'comm'. But this now hides the ability to filter events
that have a 'comm' field too. For example, sched_migrate_task trace event.
That has a 'comm' field of the task to be migrated.
echo 'comm == "bash"' > events/sched_migrate_task/filter
will now filter all sched_migrate_task events for tasks named "bash" that
migrates other tasks (in interrupt context), instead of seeing when "bash"
itself gets migrated.
This fix requires a couple of changes.
1) Change the look up order for filter predicates to look at the events
fields before looking at the generic filters.
2) Instead of basing the filter function off of the "comm" name, have the
generic "comm" filter have its own filter_type (FILTER_COMM). Test
against the type instead of the name to assign the filter function.
3) Add a new "COMM" filter that works just like "comm" but will filter based
on the current task, even if the trace event contains a "comm" field.
Do the same for "cpu" field, adding a FILTER_CPU and a filter "CPU".
Fixes: 9f61668073a8d "tracing: Allow triggers to filter for CPU ids and process names"
Reported-by: Matt Fleming <matt@codeblueprint.co.uk>
commit 59ceeaaf355fa0fb16558ef7c24413c804932ada upstream.
In __request_region, if a conflict with a BUSY and MUXED resource is
detected, then the caller goes to sleep and waits for the resource to be
released. A pointer on the conflicting resource is kept. At wake-up
this pointer is used as a parent to retry to request the region.
A first problem is that this pointer might well be invalid (if for
example the conflicting resource have already been freed). Another
problem is that the next call to __request_region() fails to detect a
remaining conflict. The previously conflicting resource is passed as a
parameter and __request_region() will look for a conflict among the
children of this resource and not at the resource itself. It is likely
to succeed anyway, even if there is still a conflict.
Instead, the parent of the conflicting resource should be passed to
__request_region().
As a fix, this patch doesn't update the parent resource pointer in the
case we have to wait for a muxed region right after.
Reported-and-tested-by: Vincent Pelletier <plr.vincent@gmail.com>
Signed-off-by: Simon Guinot <simon.guinot@sequanux.org>
Tested-by: Vincent Donnefort <vdonnefort@gmail.com>
commit d045437a169f899dfb0f6f7ede24cc042543ced9 upstream.
The ftrace:function event is only displayed for parsing the function tracer
data. It is not used to enable function tracing, and does not include an
"enable" file in its event directory.
Originally, this event was kept separate from other events because it did
not have a ->reg parameter. But perf added a "reg" parameter for its use
which caused issues, because it made the event available to functions where
it was not compatible for.
Commit 9b63776fa3ca9 "tracing: Do not enable function event with enable"
added a TRACE_EVENT_FL_IGNORE_ENABLE flag that prevented the function event
from being enabled by normal trace events. But this commit missed keeping
the function event from being displayed by the "available_events" directory,
which is used to show what events can be enabled by set_event.
One documented way to enable all events is to:
cat available_events > set_event
But because the function event is displayed in the available_events, this
now causes an INVALID error:
cat: write error: Invalid argument
Reported-by: Chunyu Hu <chuhu@redhat.com>
Fixes: 9b63776fa3ca9 "tracing: Do not enable function event with enable"
commit aa226ff4a1ce79f229c6b7a4c0a14e17fececd01 upstream.
memory controller.
This patch updates offline path so that a parent css is never offlined
before its children. Each css keeps online_cnt which reaches zero iff
itself and all its children are offline and offline_css() is invoked
only after online_cnt reaches zero.
This fixes the memory controller bug and allows the fix for cpu
controller.
Reported-and-tested-by: Christian Borntraeger <borntraeger@de.ibm.com>
Reported-by: Brian Christiansen <brian.o.christiansen@gmail.com>
Link: http://lkml.kernel.org/g/5698A023.9070703@de.ibm.com
Link: http://lkml.kernel.org/g/CAKB58ikDkzc8REt31WBkD99+hxNzjK4+FBmhkgS+NVrC9vjMSg@mail.gmail.com
commit e93ad19d05648397ef3bcb838d26aec06c245dc0 upstream.
If "cpuset.memory_migrate" is set, when a process is moved from one
cpuset to another with a different memory node mask, pages in used by
the process are migrated to the new set of nodes. This was performed
synchronously in the ->attach() callback, which is synchronized
against process management. Recently, the synchronization was changed
from per-process rwsem to global percpu rwsem for simplicity and
optimization.
Combined with the synchronous mm migration, this led to deadlocks
because mm migration could schedule a work item which may in turn try
to create a new worker blocking on the process management lock held
from cgroup process migration path.
This heavy an operation shouldn't be performed synchronously from that
deep inside cgroup migration in the first place. This patch punts the
actual migration to an ordered workqueue and updates cgroup process
migration and cpuset config update paths to flush the workqueue after
all locks are released. This way, the operations still seem
synchronous to userland without entangling mm migration with process
management synchronization. CPU hotplug can also invoke mm migration
but there's no reason for it to wait for mm migrations and thus
doesn't synchronize against their completions.
commit 041bd12e272c53a35c54c13875839bcb98c999ce upstream.
This reverts commit 874bbfe600a660cba9c776b3957b1ce393151b76.
Workqueue used to implicity guarantee that work items queued without
explicit CPU specified are put on the local CPU. Recent changes in
timer broke the guarantee and led to vmstat breakage which was fixed
by 176bed1de5bf ("vmstat: explicitly schedule per-cpu work on the CPU
we need it to run on").
vmstat is the most likely to expose the issue and it's quite possible
that there are other similar problems which are a lot more difficult
to trigger. As a preventive measure, 874bbfe600a6 ("workqueue: make
sure delayed work run in local cpu") was applied to restore the local
CPU guarnatee. Unfortunately, the change exposed a bug in timer code
which got fixed by 22b886dd1018 ("timers: Use proper base migration in
add_timer_on()"). Due to code restructuring, the commit couldn't be
backported beyond certain point and stable kernels which only had
874bbfe600a6 started crashing.
The local CPU guarantee was accidental more than anything else and we
want to get rid of it anyway. As, with the vmstat case fixed,
874bbfe600a6 is causing more problems than it's fixing, it has been
decided to take the chance and officially break the guarantee by
reverting the commit. A debug feature will be added to force foreign
CPU assignment to expose cases relying on the guarantee and fixes for
the individual cases will be backported to stable as necessary.
Fixes: 874bbfe600a6 ("workqueue: make sure delayed work run in local cpu")
Link: http://lkml.kernel.org/g/20160120211926.GJ10810@quack.suse.cz
Cc: Mike Galbraith <umgwanakikbuti@gmail.com>
Cc: Henrique de Moraes Holschuh <hmh@hmh.eng.br>
Cc: Daniel Bilik <daniel.bilik@neosystem.cz>
Cc: Jan Kara <jack@suse.cz>
Cc: Shaohua Li <shli@fb.com>
Cc: Sasha Levin <sasha.levin@oracle.com>
Cc: Ben Hutchings <ben@decadent.org.uk>
Cc: Jiri Slaby <jslaby@suse.cz>
commit d6e022f1d207a161cd88e08ef0371554680ffc46 upstream.
When looking up the pool_workqueue to use for an unbound workqueue,
workqueue assumes that the target CPU is always bound to a valid NUMA
node. However, currently, when a CPU goes offline, the mapping is
destroyed and cpu_to_node() returns NUMA_NO_NODE.
This has always been broken but hasn't triggered often enough before
874bbfe600a6 ("workqueue: make sure delayed work run in local cpu").
After the commit, workqueue forcifully assigns the local CPU for
delayed work items without explicit target CPU to fix a different
issue. This widens the window where CPU can go offline while a
delayed work item is pending causing delayed work items dispatched
with target CPU set to an already offlined CPU. The resulting
NUMA_NO_NODE mapping makes workqueue try to queue the work item on a
NULL pool_workqueue and thus crash.
While 874bbfe600a6 has been reverted for a different reason making the
bug less visible again, it can still happen. Fix it by mapping
NUMA_NO_NODE to the default pool_workqueue from unbound_pwq_by_node().
This is a temporary workaround. The long term solution is keeping CPU
-> NODE mapping stable across CPU off/online cycles which is being
worked on.
Reported-by: Mike Galbraith <umgwanakikbuti@gmail.com>
Cc: Tang Chen <tangchen@cn.fujitsu.com>
Cc: Rafael J. Wysocki <rafael@kernel.org>
Cc: Len Brown <len.brown@intel.com>
Link: http://lkml.kernel.org/g/1454424264.11183.46.camel@gmail.com
Link: http://lkml.kernel.org/g/1453702100-2597-1-git-send-email-tangchen@cn.fujitsu.com
commit 1ca8ec532fc2d986f1f4a319857bb18e0c9739b4 upstream.
commit 0ff53d096422 sets the next tick interrupt to the last jiffies update,
i.e. in the past, because the forward operation is invoked before the set
operation. There is no resulting damage (yet), but we get an extra pointless
tick interrupt.
Revert the order so we get the next tick interrupt in the future.
Fixes: commit 0ff53d096422 "tick: sched: Force tick interrupt and get rid of softirq magic"
Link: http://lkml.kernel.org/r/1453893967-3458-1-git-send-email-wanpeng.li@hotmail.com
commit 103502a35cfce0710909da874f092cb44823ca03 upstream.
Before this patch, a process with some permissive seccomp filter
that was applied by root without NO_NEW_PRIVS was able to add
more filters to itself without setting NO_NEW_PRIVS by setting
the new filter from a throwaway thread with NO_NEW_PRIVS.
commit 35a4933a895927990772ae96fdcfd2f806929ee2 upstream.
1e75fa8 "time: Condense timekeeper.xtime into xtime_sec" replaced a call to
clocksource_cyc2ns() from timekeeping_get_ns() with an open-coded version
of the same logic to avoid keeping a semi-redundant struct timespec
in struct timekeeper.
However, the commit also introduced a subtle semantic change - where
clocksource_cyc2ns() uses purely unsigned math, the new version introduces
a signed temporary, meaning that if (delta * tk->mult) has a 63-bit
overflow the following shift will still give a negative result. The
choice of 'maxsec' in __clocksource_updatefreq_scale() means this will
generally happen if there's a ~10 minute pause in examining the
clocksource.
This can be triggered on a powerpc KVM guest by stopping it from qemu for
a bit over 10 minutes. After resuming time has jumped backwards several
minutes causing numerous problems (jiffies does not advance, msleep()s can
be extended by minutes..). It doesn't happen on x86 KVM guests, because
the guest TSC is effectively frozen while the guest is stopped, which is
not the case for the powerpc timebase.
Obviously an unsigned (64 bit) overflow will only take twice as long as a
signed, 63-bit overflow. I don't know the time code well enough to know
if that will still cause incorrect calculations, or if a 64-bit overflow
is avoided elsewhere.
Still, an incorrect forwards clock adjustment will cause less trouble than
time going backwards. So, this patch removes the potential for
intermediate signed overflow.
Suggested-by: Laurent Vivier <lvivier@redhat.com>
Tested-by: Laurent Vivier <lvivier@redhat.com>
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
Signed-off-by: John Stultz <john.stultz@linaro.org>
commit 1b9f23727abb92c5e58f139e7d180befcaa06fe0 upstream.
The posix_clock_poll function is supposed to return a bit mask of
POLLxxx values. However, in case the hardware has disappeared (due to
hot plugging for example) this code returns -ENODEV in a futile
attempt to throw an error at the file descriptor level. The kernel's
file_operations interface does not accept such error codes from the
poll method. Instead, this function aught to return POLLERR.
The value -ENODEV does, in fact, contain the POLLERR bit (and almost
all the other POLLxxx bits as well), but only by chance. This patch
fixes code to return a proper bit mask.
Credit goes to Markus Elfring for pointing out the suspicious
signed/unsigned mismatch.
Reported-by: Markus Elfring <elfring@users.sourceforge.net>
igned-off-by: Richard Cochran <richardcochran@gmail.com>
Cc: John Stultz <john.stultz@linaro.org>
Cc: Julia Lawall <julia.lawall@lip6.fr>
Link: http://lkml.kernel.org/r/1450819198-17420-1-git-send-email-richardcochran@gmail.com
commit 570540d50710ed192e98e2f7f74578c9486b6b05 upstream.
commit 71f64340fc0e changed the handling of irq_desc->action from
CPU 0 CPU 1
free_irq() lock(desc)
lock(desc) handle_edge_irq()
if (desc->action) {
handle_irq_event()
action = desc->action
unlock(desc)
desc->action = NULL handle_irq_event_percpu(desc, action)
action->xxx
to
CPU 0 CPU 1
if (desc->action) {
handle_irq_event()
unlock(desc)
action->xxx
So if free_irq manages to set the action to NULL between the unlock and before
the readout, we happily dereference a null pointer.
We could simply revert 71f64340fc0e, but we want to preserve the better code
generation. A simple solution is to change the action loop from a do {} while
to a while {} loop.
This is safe because we either see a valid desc->action or NULL. If the action
is about to be removed it is still valid as free_irq() is blocked on
synchronize_irq().
CPU 0 CPU 1
handle_irq_event(desc)
set(INPROGRESS)
unlock(desc)
handle_irq_event_percpu(desc)
desc->action = NULL while (action) {
action->xxx
action = action->next;
sychronize_irq()
while(INPROGRESS); lock(desc)
clr(INPROGRESS)
free(action)
That's basically the same mechanism as we have for shared
interrupts. action->next can become NULL while handle_irq_event_percpu()
runs. Either it sees the action or NULL. It does not matter, because action
itself cannot go away before the interrupt in progress flag has been cleared.
Fixes: commit 71f64340fc0e "genirq: Remove the second parameter from handle_irq_event_percpu()"
Reported-by: zyjzyj2000@gmail.com
Cc: Huang Shijie <shijie.huang@arm.com>
Cc: Jiang Liu <jiang.liu@linux.intel.com>
Link: http://lkml.kernel.org/r/alpine.DEB.2.11.1601131224190.3575@nanos
commit 93f834df9c2d4e362dfdc4b05daa0a4e18814836 upstream.
devm_memremap() returns an ERR_PTR() value in case of error.
However, it returns NULL when memremap() failed. This causes
the caller, such as the pmem driver, to proceed and oops later.
Change devm_memremap() to return ERR_PTR(-ENXIO) when memremap()
failed.
Signed-off-by: Toshi Kani <toshi.kani@hpe.com>
Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com>
[ Upstream commit a1b14d27ed0965838350f1377ff97c93ee383492 ]
When ctx access is used, the kernel often needs to expand/rewrite
instructions, so after that patching, branch offsets have to be
adjusted for both forward and backward jumps in the new eBPF program,
but for backward jumps it fails to account the delta. Meaning, for
example, if the expansion happens exactly on the insn that sits at
the jump target, it doesn't fix up the back jump offset.
Analysis on what the check in adjust_branches() is currently doing:
/* adjust offset of jmps if necessary */
if (i < pos && i + insn->off + 1 > pos)
insn->off += delta;
else if (i > pos && i + insn->off + 1 < pos)
insn->off -= delta;
First condition (forward jumps):
Before: After:
insns[0] insns[0]
insns[1] <--- i/insn insns[1] <--- i/insn
insns[2] <--- pos insns[P] <--- pos
insns[3] insns[P] `------| delta
insns[4] <--- target_X insns[P] `-----|
insns[5] insns[3]
insns[5]
First case is if we cross pos-boundary and the jump instruction was
before pos. This is handeled correctly. I.e. if i == pos, then this
would mean our jump that we currently check was the patchlet itself
that we just injected. Since such patchlets are self-contained and
have no awareness of any insns before or after the patched one, the
delta is correctly not adjusted. Also, for the second condition in
case of i + insn->off + 1 == pos, means we jump to that newly patched
instruction, so no offset adjustment are needed. That part is correct.
Second condition (backward jumps):
Before: After:
insns[0] insns[0]
insns[1] <--- target_X insns[1] <--- target_X
insns[2] <--- pos <-- target_Y insns[P] <--- pos <-- target_Y
insns[4] <--- i/insn insns[P] `-----|
insns[5] insns[3]
insns[5]
Second interesting case is where we cross pos-boundary and the jump
instruction was after pos. Backward jump with i == pos would be
impossible and pose a bug somewhere in the patchlet, so the first
condition checking i > pos is okay only by itself. However, i +
insn->off + 1 < pos does not always work as intended to trigger the
adjustment. It works when jump targets would be far off where the
delta wouldn't matter. But, for example, where the fixed insn->off
before pointed to pos (target_Y), it now points to pos + delta, so
that additional room needs to be taken into account for the check.
This means that i) both tests here need to be adjusted into pos + delta,
and ii) for the second condition, the test needs to be <= as pos
itself can be a target in the backjump, too.
Fixes: 9bac3d6d548e ("bpf: allow extended BPF programs access skb fields")
commit 4355efbd80482a961cae849281a8ef866e53d55c upstream.
Commit f2411da746985 ("driver-core: add driver module
asynchronous probe support") added async probe support,
in two forms:
* in-kernel driver specification annotation
* generic async_probe module parameter (modprobe foo async_probe)
To support the generic kernel parameter parse_args() was
extended via commit ecc8617053e0 ("module: add extra
argument for parse_params() callback") however commit
failed to f2411da746985 failed to add the required argument.
This causes a crash then whenever async_probe generic
module parameter is used. This was overlooked when the
form in which in-kernel async probe support was reworked
a bit... Fix this as originally intended.
Cc: Hannes Reinecke <hare@suse.de>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> [minimized]
commit 2e7bac536106236104e9e339531ff0fcdb7b8147 upstream.
This trivial wrapper adds clarity and makes the following patch
smaller.
commit 51cbb5242a41700a3f250ecfb48dcfb7e4375ea4 upstream.
As Helge reported for timerfd we have the same issue in itimers. We return
remaining time larger than the programmed relative time to user space in case
of CONFIG_TIME_LOW_RES=y. Use the proper function to adjust the extra time
added in hrtimer_start_range_ns().
Cc: Helge Deller <deller@gmx.de>
Cc: linux-m68k@lists.linux-m68k.org
Cc: dhowells@redhat.com
Link: http://lkml.kernel.org/r/20160114164159.528222587@linutronix.de
commit 572c39172684c3711e4a03c9a7380067e2b0661c upstream.
As Helge reported for timerfd we have the same issue in posix timers. We
return remaining time larger than the programmed relative time to user space
in case of CONFIG_TIME_LOW_RES=y. Use the proper function to adjust the extra
time added in hrtimer_start_range_ns().
Link: http://lkml.kernel.org/r/20160114164159.450510905@linutronix.de
