commit df62db5be2e5f070ecd1a5ece5945b590ee112e0 upstream.
Currently the snapshot trigger enables the probe and then allocates the
snapshot. If the probe triggers before the allocation, it could cause the
snapshot to fail and turn tracing off. It's best to allocate the snapshot
buffer first, and then enable the trigger. If something goes wrong in the
enabling of the trigger, the snapshot buffer is still allocated, but it can
also be freed by the user by writting zero into the snapshot buffer file.
Also add a check of the return status of alloc_snapshot().
Fixes: 77fd5c15e3 ("tracing: Add snapshot trigger to function probes")
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
commit d879d0b8c183aabeb9a65eba91f3f9e3c7e7b905 upstream.
When function tracer has a pid filter, it adds a probe to sched_switch
to track if current task can be ignored. The probe checks the
ftrace_ignore_pid from current tr to filter tasks. But it misses to
delete the probe when removing an instance so that it can cause a crash
due to the invalid tr pointer (use-after-free).
This is easily reproducible with the following:
# cd /sys/kernel/debug/tracing
# mkdir instances/buggy
# echo $$ > instances/buggy/set_ftrace_pid
# rmdir instances/buggy
BUG: KASAN: use-after-free in ftrace_filter_pid_sched_switch_probe+0x3d/0x90
Read of size 8 by task kworker/0:1/17
CPU: 0 PID: 17 Comm: kworker/0:1 Tainted: G B 4.11.0-rc3 #198
Call Trace:
dump_stack+0x68/0x9f
kasan_object_err+0x21/0x70
kasan_report.part.1+0x22b/0x500
? ftrace_filter_pid_sched_switch_probe+0x3d/0x90
kasan_report+0x25/0x30
__asan_load8+0x5e/0x70
? fpid_start+0x130/0x130
__schedule+0x571/0xce0
To fix it, use ftrace_clear_pids() to unregister the probe. As
instance_rmdir() already updated ftrace codes, it can just free the
filter safely.
Link: http://lkml.kernel.org/r/20170417024430.21194-2-namhyung@kernel.org
Fixes: 0c8916c34203 ("tracing: Add rmdir to remove multibuffer instances")
Reviewed-by: Masami Hiramatsu <mhiramat@kernel.org>
Signed-off-by: Namhyung Kim <namhyung@kernel.org>
commit 82cc4fc2e70ec5baeff8f776f2773abc8b2cc0ae upstream.
When two function probes are added to set_ftrace_filter, and then one of
them is removed, the update to the function locations is not performed, and
the record keeping of the function states are corrupted, and causes an
ftrace_bug() to occur.
This is easily reproducable by adding two probes, removing one, and then
adding it back again.
# echo schedule:traceoff > set_ftrace_filter
# echo do_IRQ:traceoff > set_ftrace_filter
# echo \!do_IRQ:traceoff > /debug/tracing/set_ftrace_filter
Causes:
WARNING: CPU: 2 PID: 1098 at kernel/trace/ftrace.c:2369 ftrace_get_addr_curr+0x143/0x220
Modules linked in: [...]
CPU: 2 PID: 1098 Comm: bash Not tainted 4.10.0-test+ #405
Hardware name: Hewlett-Packard HP Compaq Pro 6300 SFF/339A, BIOS K01 v02.05 05/07/2012
Call Trace:
__warn+0x111/0x130
? trace_irq_work_interrupt+0xa0/0xa0
warn_slowpath_null+0x1d/0x20
? __fentry__+0x10/0x10
ftrace_replace_code+0xe3/0x4f0
? ftrace_int3_handler+0x90/0x90
? printk+0x99/0xb5
? 0xffffffff81000000
ftrace_modify_all_code+0x97/0x110
arch_ftrace_update_code+0x10/0x20
ftrace_run_update_code+0x1c/0x60
ftrace_run_modify_code.isra.48.constprop.62+0x8e/0xd0
register_ftrace_function_probe+0x4b6/0x590
? ftrace_startup+0x310/0x310
? debug_lockdep_rcu_enabled.part.4+0x1a/0x30
? update_stack_state+0x88/0x110
? ftrace_regex_write.isra.43.part.44+0x1d3/0x320
? preempt_count_sub+0x18/0xd0
? mutex_lock_nested+0x104/0x800
? __unwind_start+0x1c0/0x1c0
? _mutex_lock_nest_lock+0x800/0x800
ftrace_trace_probe_callback.isra.3+0xc0/0x130
? func_set_flag+0xe0/0xe0
? __lock_acquire+0x642/0x1790
? __might_fault+0x1e/0x20
? trace_get_user+0x398/0x470
? strcmp+0x35/0x60
ftrace_trace_onoff_callback+0x48/0x70
ftrace_regex_write.isra.43.part.44+0x251/0x320
? match_records+0x420/0x420
ftrace_filter_write+0x2b/0x30
__vfs_write+0xd7/0x330
? do_loop_readv_writev+0x120/0x120
? locks_remove_posix+0x90/0x2f0
? do_lock_file_wait+0x160/0x160
? __lock_is_held+0x93/0x100
? rcu_read_lock_sched_held+0x5c/0xb0
? __sb_start_write+0x10a/0x230
? vfs_write+0x222/0x240
vfs_write+0xef/0x240
SyS_write+0xab/0x130
? SyS_read+0x130/0x130
? trace_hardirqs_on_caller+0x182/0x280
? trace_hardirqs_on_thunk+0x1a/0x1c
entry_SYSCALL_64_fastpath+0x18/0xad
RIP: 0033:0x7fe61c157c30
RSP: 002b:00007ffe87890258 EFLAGS: 00000246 ORIG_RAX: 0000000000000001
RAX: ffffffffffffffda RBX: ffffffff8114a410 RCX: 00007fe61c157c30
RDX: 0000000000000010 RSI: 000055814798f5e0 RDI: 0000000000000001
RBP: ffff8800c9027f98 R08: 00007fe61c422740 R09: 00007fe61ca53700
R10: 0000000000000073 R11: 0000000000000246 R12: 0000558147a36400
R13: 00007ffe8788f160 R14: 0000000000000024 R15: 00007ffe8788f15c
? trace_hardirqs_off_caller+0xc0/0x110
---[ end trace 99fa09b3d9869c2c ]---
Bad trampoline accounting at: ffffffff81cc3b00 (do_IRQ+0x0/0x150)
Fixes: 59df055f1991 ("ftrace: trace different functions with a different tracer")
non-root cgroups
commit 77f88796cee819b9c4562b0b6b44691b3b7755b1 upstream.
Creation of a kthread goes through a couple interlocked stages between
the kthread itself and its creator. Once the new kthread starts
running, it initializes itself and wakes up the creator. The creator
then can further configure the kthread and then let it start doing its
job by waking it up.
In this configuration-by-creator stage, the creator is the only one
that can wake it up but the kthread is visible to userland. When
altering the kthread's attributes from userland is allowed, this is
fine; however, for cases where CPU affinity is critical,
kthread_bind() is used to first disable affinity changes from userland
and then set the affinity. This also prevents the kthread from being
migrated into non-root cgroups as that can affect the CPU affinity and
many other things.
Unfortunately, the cgroup side of protection is racy. While the
PF_NO_SETAFFINITY flag prevents further migrations, userland can win
the race before the creator sets the flag with kthread_bind() and put
the kthread in a non-root cgroup, which can lead to all sorts of
problems including incorrect CPU affinity and starvation.
This bug got triggered by userland which periodically tries to migrate
all processes in the root cpuset cgroup to a non-root one. Per-cpu
workqueue workers got caught while being created and ended up with
incorrected CPU affinity breaking concurrency management and sometimes
stalling workqueue execution.
This patch adds task->no_cgroup_migration which disallows the task to
be migrated by userland. kthreadd starts with the flag set making
every child kthread start in the root cgroup with migration
disallowed. The flag is cleared after the kthread finishes
initialization by which time PF_NO_SETAFFINITY is set if the kthread
should stay in the root cgroup.
It'd be better to wait for the initialization instead of failing but I
couldn't think of a way of implementing that without adding either a
new PF flag, or sleeping and retrying from waiting side. Even if
userland depends on changing cgroup membership of a kthread, it either
has to be synchronized with kthread_create() or periodically repeat,
so it's unlikely that this would break anything.
v2: Switch to a simpler implementation using a new task_struct bit
field suggested by Oleg.
Suggested-by: Oleg Nesterov <oleg@redhat.com>
Cc: Peter Zijlstra (Intel) <peterz@infradead.org>
Reported-and-debugged-by: Chris Mason <clm@fb.com>
commit 62277de758b155dc04b78f195a1cb5208c37b2df upstream.
In case of error, the function kthread_run() returns ERR_PTR()
and never returns NULL. The NULL test in the return value check
should be replaced with IS_ERR().
Link: http://lkml.kernel.org/r/1466184839-14927-1-git-send-email-weiyj_lk@163.com
Fixes: 6c43e554a ("ring-buffer: Add ring buffer startup selftest")
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
commit 5402e97af667e35e54177af8f6575518bf251d51 upstream.
In PT_SEIZED + LISTEN mode STOP/CONT signals cause a wakeup against
__TASK_TRACED. If this races with the ptrace_unfreeze_traced at the end
of a PTRACE_LISTEN, this can wake the task /after/ the check against
__TASK_TRACED, but before the reset of state to TASK_TRACED. This
causes it to instead clobber TASK_WAKING, allowing a subsequent wakeup
against TRACED while the task is still on the rq wake_list, corrupting
it.
Oleg said:
"The kernel can crash or this can lead to other hard-to-debug problems.
In short, "task->state = TASK_TRACED" in ptrace_unfreeze_traced()
assumes that nobody else can wake it up, but PTRACE_LISTEN breaks the
contract. Obviusly it is very wrong to manipulate task->state if this
task is already running, or WAKING, or it sleeps again"
Fixes: 9899d11f ("ptrace: ensure arch_ptrace/ptrace_request can never race with SIGKILL")
Link: http://lkml.kernel.org/r/xm26y3vfhmkp.fsf_-_@bsegall-linux.mtv.corp.google.com
Signed-off-by: Ben Segall <bsegall@google.com>
Acked-by: Oleg Nesterov <oleg@redhat.com>
commit de5540d088fe97ad583cc7d396586437b32149a5 upstream.
Under extremely heavy uses of padata, crashes occur, and with list
debugging turned on, this happens instead:
[87487.298728] WARNING: CPU: 1 PID: 882 at lib/list_debug.c:33
__list_add+0xae/0x130
[87487.301868] list_add corruption. prev->next should be next
(ffffb17abfc043d0), but was ffff8dba70872c80. (prev=ffff8dba70872b00).
[87487.339011] [<ffffffff9a53d075>] dump_stack+0x68/0xa3
[87487.342198] [<ffffffff99e119a1>] ? console_unlock+0x281/0x6d0
[87487.345364] [<ffffffff99d6b91f>] __warn+0xff/0x140
[87487.348513] [<ffffffff99d6b9aa>] warn_slowpath_fmt+0x4a/0x50
[87487.351659] [<ffffffff9a58b5de>] __list_add+0xae/0x130
[87487.354772] [<ffffffff9add5094>] ? _raw_spin_lock+0x64/0x70
[87487.357915] [<ffffffff99eefd66>] padata_reorder+0x1e6/0x420
[87487.361084] [<ffffffff99ef0055>] padata_do_serial+0xa5/0x120
padata_reorder calls list_add_tail with the list to which its adding
locked, which seems correct:
spin_lock(&squeue->serial.lock);
list_add_tail(&padata->list, &squeue->serial.list);
spin_unlock(&squeue->serial.lock);
This therefore leaves only place where such inconsistency could occur:
if padata->list is added at the same time on two different threads.
This pdata pointer comes from the function call to
padata_get_next(pd), which has in it the following block:
next_queue = per_cpu_ptr(pd->pqueue, cpu);
padata = NULL;
reorder = &next_queue->reorder;
if (!list_empty(&reorder->list)) {
padata = list_entry(reorder->list.next,
struct padata_priv, list);
spin_lock(&reorder->lock);
list_del_init(&padata->list);
atomic_dec(&pd->reorder_objects);
spin_unlock(&reorder->lock);
pd->processed++;
goto out;
out:
return padata;
I strongly suspect that the problem here is that two threads can race
on reorder list. Even though the deletion is locked, call to
list_entry is not locked, which means it's feasible that two threads
pick up the same padata object and subsequently call list_add_tail on
them at the same time. The fix is thus be hoist that lock outside of
that block.
Signed-off-by: Jason A. Donenfeld <Jason@zx2c4.com>
Acked-by: Steffen Klassert <steffen.klassert@secunet.com>
commit 619bd4a71874a8fd78eb6ccf9f272c5e98bcc7b7 upstream.
Since the change in commit:
fd7a4bed1835 ("sched, rt: Convert switched_{from, to}_rt() / prio_changed_rt() to balance callbacks")
... we don't reschedule a task under certain circumstances:
Lets say task-A, SCHED_OTHER, is running on CPU0 (and it may run only on
CPU0) and holds a PI lock. This task is removed from the CPU because it
used up its time slice and another SCHED_OTHER task is running. Task-B on
CPU1 runs at RT priority and asks for the lock owned by task-A. This
results in a priority boost for task-A. Task-B goes to sleep until the
lock has been made available. Task-A is already runnable (but not active),
so it receives no wake up.
The reality now is that task-A gets on the CPU once the scheduler decides
to remove the current task despite the fact that a high priority task is
enqueued and waiting. This may take a long time.
The desired behaviour is that CPU0 immediately reschedules after the
priority boost which made task-A the task with the lowest priority.
Suggested-by: Peter Zijlstra <peterz@infradead.org>
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Fixes: fd7a4bed1835 ("sched, rt: Convert switched_{from, to}_rt() prio_changed_rt() to balance callbacks")
Link: http://lkml.kernel.org/r/20170124144006.29821-1-bigeasy@linutronix.de
commit 1d18c2747f937f1b5ec65ce6bf4ccb9ca1aea9e8 upstream.
pids_can_fork() is special in that the css association is guaranteed
to be stable throughout the function and thus doesn't need RCU
protection around task_css access. When determining the css to charge
the pid, task_css_check() is used to override the RCU sanity check.
While adding a warning message on fork rejection from pids limit,
135b8b37bd91 ("cgroup: Add pids controller event when fork fails
because of pid limit") incorrectly added a task_css access which is
neither RCU protected or explicitly annotated. This triggers the
following suspicious RCU usage warning when RCU debugging is enabled.
cgroup: fork rejected by pids controller in
[ ERR: suspicious RCU usage. ]
4.10.0-work+ #1 Not tainted
./include/linux/cgroup.h:435 suspicious rcu_dereference_check() usage!
rcu_scheduler_active = 2, debug_locks = 0
1 lock held by bash/1748:
#0: (&cgroup_threadgroup_rwsem){+++++.}, at: [<ffffffff81052c96>] _do_fork+0xe6/0x6e0
stack backtrace:
CPU: 3 PID: 1748 Comm: bash Not tainted 4.10.0-work+ #1
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.9.3-1.fc25 04/01/2014
Call Trace:
dump_stack+0x68/0x93
lockdep_rcu_suspicious+0xd7/0x110
pids_can_fork+0x1c7/0x1d0
cgroup_can_fork+0x67/0xc0
copy_process.part.58+0x1709/0x1e90
_do_fork+0xe6/0x6e0
SyS_clone+0x19/0x20
do_syscall_64+0x5c/0x140
entry_SYSCALL64_slow_path+0x25/0x25
RIP: 0033:0x7f7853fab93a
RSP: 002b:00007ffc12d05c90 EFLAGS: 00000246 ORIG_RAX: 0000000000000038
RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007f7853fab93a
RDX: 0000000000000000 RSI: 0000000000000000 RDI: 0000000001200011
RBP: 00007ffc12d05cc0 R08: 0000000000000000 R09: 00007f78548db700
R10: 00007f78548db9d0 R11: 0000000000000246 R12: 00000000000006d4
R13: 0000000000000001 R14: 0000000000000000 R15: 000055e3ebe2c04d
/asdf
There's no reason to dereference task_css again here when the
associated css is already available. Fix it by replacing the
task_cgroup() call with css->cgroup.
Reported-by: Mike Galbraith <efault@gmx.de>
Fixes: 135b8b37bd91 ("cgroup: Add pids controller event when fork fails because of pid limit")
Cc: Kenny Yu <kennyyu@fb.com>
commit e7cc4865f0f31698ef2f7aac01a50e78968985b7 upstream.
While hunting for clues to a use-after-free, Oleg spotted that
perf_event_init_context() can loose an error value with the result
that fork() can succeed even though we did not fully inherit the perf
event context.
Spotted-by: Oleg Nesterov <oleg@redhat.com>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Vince Weaver <vincent.weaver@maine.edu>
Cc: oleg@redhat.com
Fixes: 889ff0150661 ("perf/core: Split context's event group list into pinned and non-pinned lists")
Link: http://lkml.kernel.org/r/20170316125823.190342547@infradead.org
commit e552a8389aa409e257b7dcba74f67f128f979ccc upstream.
Dmitry reported syzcaller tripped a use-after-free in perf_release().
After much puzzlement Oleg spotted the below scenario:
Task1 Task2
fork()
perf_event_init_task()
goto bad_fork_$foo;
perf_event_free_task()
mutex_lock(ctx->lock)
perf_free_event(B)
perf_event_release_kernel(A)
mutex_lock(A->child_mutex)
list_for_each_entry(child, ...) {
/* child == B */
ctx = B->ctx;
get_ctx(ctx);
mutex_unlock(A->child_mutex);
list_del_init(B->child_list)
mutex_unlock(ctx->lock);
put_ctx() /* >0 */
free_task();
mutex_lock(ctx->lock);
mutex_lock(A->child_mutex);
put_ctx() /* 0 */
ctx->task && !TOMBSTONE
put_task_struct() /* UAF */
This patch closes the hole by making perf_event_free_task() destroy the
task <-> ctx relation such that perf_event_release_kernel() will no longer
observe the now dead task.
Cc: fweisbec@gmail.com
Cc: oleg@redhat.com
Fixes: c6e5b73242d2 ("perf: Synchronously clean up child events")
Link: http://lkml.kernel.org/r/20170314155949.GE32474@worktop
Link: http://lkml.kernel.org/r/20170316125823.140295131@infradead.org
commit 17fcbd590d0c3e35bd9646e2215f86586378bc42 upstream.
We hang if SIGKILL has been sent, but the task is stuck in down_read()
(after do_exit()), even though no task is doing down_write() on the
rwsem in question:
INFO: task libupnp:21868 blocked for more than 120 seconds.
libupnp D 0 21868 1 0x08100008
Call Trace:
__schedule()
schedule()
__down_read()
do_exit()
do_group_exit()
__wake_up_parent()
This bug has already been fixed for CONFIG_RWSEM_XCHGADD_ALGORITHM=y in
the following commit:
04cafed7fc19 ("locking/rwsem: Fix down_write_killable()")
... however, this bug also exists for CONFIG_RWSEM_GENERIC_SPINLOCK=y.
Signed-off-by: Niklas Cassel <niklas.cassel@axis.com>
Cc: <mhocko@suse.com>
Cc: Niklas Cassel <niklass@axis.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Fixes: d47996082f52 ("locking/rwsem: Introduce basis for down_write_killable()")
Link: http://lkml.kernel.org/r/1487981873-12649-1-git-send-email-niklass@axis.com
commit 9bbb25afeb182502ca4f2c4f3f88af0681b34cae upstream.
Thomas spotted that fixup_pi_state_owner() can return errors and we
fail to unlock the rt_mutex in that case.
Reported-by: Thomas Gleixner <tglx@linutronix.de>
Reviewed-by: Darren Hart <dvhart@linux.intel.com>
Cc: juri.lelli@arm.com
Cc: bigeasy@linutronix.de
Cc: xlpang@redhat.com
Cc: rostedt@goodmis.org
Cc: mathieu.desnoyers@efficios.com
Cc: jdesfossez@efficios.com
Cc: dvhart@infradead.org
Cc: bristot@redhat.com
Link: http://lkml.kernel.org/r/20170304093558.867401760@infradead.org
commit c236c8e95a3d395b0494e7108f0d41cf36ec107c upstream.
While working on the futex code, I stumbled over this potential
use-after-free scenario. Dmitry triggered it later with syzkaller.
pi_mutex is a pointer into pi_state, which we drop the reference on in
unqueue_me_pi(). So any access to that pointer after that is bad.
Since other sites already do rt_mutex_unlock() with hb->lock held, see
for example futex_lock_pi(), simply move the unlock before
unqueue_me_pi().
Link: http://lkml.kernel.org/r/20170304093558.801744246@infradead.org
[ Upstream commit 6760bf2ddde8ad64f8205a651223a93de3a35494 ]
Martin reported a verifier issue that hit the BUG_ON() for his
test case in the mark_reg_unknown_value() function:
[ 202.861380] kernel BUG at kernel/bpf/verifier.c:467!
[ 203.291109] Call Trace:
[ 203.296501] [<ffffffff811364d5>] mark_map_reg+0x45/0x50
[ 203.308225] [<ffffffff81136558>] mark_map_regs+0x78/0x90
[ 203.320140] [<ffffffff8113938d>] do_check+0x226d/0x2c90
[ 203.331865] [<ffffffff8113a6ab>] bpf_check+0x48b/0x780
[ 203.343403] [<ffffffff81134c8e>] bpf_prog_load+0x27e/0x440
[ 203.355705] [<ffffffff8118a38f>] ? handle_mm_fault+0x11af/0x1230
[ 203.369158] [<ffffffff812d8188>] ? security_capable+0x48/0x60
[ 203.382035] [<ffffffff811351a4>] SyS_bpf+0x124/0x960
[ 203.393185] [<ffffffff810515f6>] ? __do_page_fault+0x276/0x490
[ 203.406258] [<ffffffff816db320>] entry_SYSCALL_64_fastpath+0x13/0x94
This issue got uncovered after the fix in a08dd0da5307 ("bpf: fix
regression on verifier pruning wrt map lookups"). The reason why it
wasn't noticed before was, because as mentioned in a08dd0da5307,
mark_map_regs() was doing the id matching incorrectly based on the
uncached regs[regno].id. So, in the first loop, we walked all regs
and as soon as we found regno == i, then this reg's id was cleared
when calling mark_reg_unknown_value() thus that every subsequent
register was probed against id of 0 (which, in combination with the
PTR_TO_MAP_VALUE_OR_NULL type is an invalid condition that no other
register state can hold), and therefore wasn't type transitioned such
as in the spilled register case for the second loop.
Now since that got fixed, it turned out that 57a09bf0a416 ("bpf:
Detect identical PTR_TO_MAP_VALUE_OR_NULL registers") used
mark_reg_unknown_value() incorrectly for the spilled regs, and thus
hitting the BUG_ON() in some cases due to regno >= MAX_BPF_REG.
Although spilled regs have the same type as the non-spilled regs
for the verifier state, that is, struct bpf_reg_state, they are
semantically different from the non-spilled regs. In other words,
there can be up to 64 (MAX_BPF_STACK / BPF_REG_SIZE) spilled regs
in the stack, for example, register R<x> could have been spilled by
the program to stack location X, Y, Z, and in mark_map_regs() we
need to scan these stack slots of type STACK_SPILL for potential
registers that we have to transition from PTR_TO_MAP_VALUE_OR_NULL.
Therefore, depending on the location, the spilled_regs regno can
be a lot higher than just MAX_BPF_REG's value since we operate on
stack instead. The reset in mark_reg_unknown_value() itself is
just fine, only that the BUG_ON() was inappropriate for this. Fix
it by making a __mark_reg_unknown_value() version that can be
called from mark_map_reg() generically; we know for the non-spilled
case that the regno is always < MAX_BPF_REG anyway.
Fixes: 57a09bf0a416 ("bpf: Detect identical PTR_TO_MAP_VALUE_OR_NULL registers")
Reported-by: Martin KaFai Lau <kafai@fb.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Acked-by: Alexei Starovoitov <ast@kernel.org>
[ Upstream commit a08dd0da5307ba01295c8383923e51e7997c3576 ]
Commit 57a09bf0a416 ("bpf: Detect identical PTR_TO_MAP_VALUE_OR_NULL
registers") introduced a regression where existing programs stopped
loading due to reaching the verifier's maximum complexity limit,
whereas prior to this commit they were loading just fine; the affected
program has roughly 2k instructions.
What was found is that state pruning couldn't be performed effectively
anymore due to mismatches of the verifier's register state, in particular
in the id tracking. It doesn't mean that 57a09bf0a416 is incorrect per
se, but rather that verifier needs to perform a lot more work for the
same program with regards to involved map lookups.
Since commit 57a09bf0a416 is only about tracking registers with type
PTR_TO_MAP_VALUE_OR_NULL, the id is only needed to follow registers
until they are promoted through pattern matching with a NULL check to
either PTR_TO_MAP_VALUE or UNKNOWN_VALUE type. After that point, the
id becomes irrelevant for the transitioned types.
For UNKNOWN_VALUE, id is already reset to 0 via mark_reg_unknown_value(),
but not so for PTR_TO_MAP_VALUE where id is becoming stale. It's even
transferred further into other types that don't make use of it. Among
others, one example is where UNKNOWN_VALUE is set on function call
return with RET_INTEGER return type.
states_equal() will then fall through the memcmp() on register state;
note that the second memcmp() uses offsetofend(), so the id is part of
that since d2a4dd37f6b4 ("bpf: fix state equivalence"). But the bisect
pointed already to 57a09bf0a416, where we really reach beyond complexity
limit. What I found was that states_equal() often failed in this
case due to id mismatches in spilled regs with registers in type
PTR_TO_MAP_VALUE. Unlike non-spilled regs, spilled regs just perform
a memcmp() on their reg state and don't have any other optimizations
in place, therefore also id was relevant in this case for making a
pruning decision.
We can safely reset id to 0 as well when converting to PTR_TO_MAP_VALUE.
For the affected program, it resulted in a ~17 fold reduction of
complexity and let the program load fine again. Selftest suite also
runs fine. The only other place where env->id_gen is used currently is
through direct packet access, but for these cases id is long living, thus
a different scenario.
Also, the current logic in mark_map_regs() is not fully correct when
marking NULL branch with UNKNOWN_VALUE. We need to cache the destination
reg's id in any case. Otherwise, once we marked that reg as UNKNOWN_VALUE,
it's id is reset and any subsequent registers that hold the original id
and are of type PTR_TO_MAP_VALUE_OR_NULL won't be marked UNKNOWN_VALUE
anymore, since mark_map_reg() reuses the uncached regs[regno].id that
was just overridden. Note, we don't need to cache it outside of
mark_map_regs(), since it's called once on this_branch and the other
time on other_branch, which are both two independent verifier states.
A test case for this is added here, too.
Acked-by: Thomas Graf <tgraf@suug.ch>
[ Upstream commit d2a4dd37f6b41fbcad76efbf63124eb3126c66fe ]
Commmits 57a09bf0a416 ("bpf: Detect identical PTR_TO_MAP_VALUE_OR_NULL registers")
and 484611357c19 ("bpf: allow access into map value arrays") by themselves
are correct, but in combination they make state equivalence ignore 'id' field
of the register state which can lead to accepting invalid program.
Fixes: 484611357c19 ("bpf: allow access into map value arrays")
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
[ Upstream commit 57a09bf0a416700676e77102c28f9cfcb48267e0 ]
A BPF program is required to check the return register of a
map_elem_lookup() call before accessing memory. The verifier keeps
track of this by converting the type of the result register from
PTR_TO_MAP_VALUE_OR_NULL to PTR_TO_MAP_VALUE after a conditional
jump ensures safety. This check is currently exclusively performed
for the result register 0.
In the event the compiler reorders instructions, BPF_MOV64_REG
instructions may be moved before the conditional jump which causes
them to keep their type PTR_TO_MAP_VALUE_OR_NULL to which the
verifier objects when the register is accessed:
0: (b7) r1 = 10
1: (7b) *(u64 *)(r10 -8) = r1
2: (bf) r2 = r10
3: (07) r2 += -8
4: (18) r1 = 0x59c00000
6: (85) call 1
7: (bf) r4 = r0
8: (15) if r0 == 0x0 goto pc+1
R0=map_value(ks=8,vs=8) R4=map_value_or_null(ks=8,vs=8) R10=fp
9: (7a) *(u64 *)(r4 +0) = 0
R4 invalid mem access 'map_value_or_null'
This commit extends the verifier to keep track of all identical
PTR_TO_MAP_VALUE_OR_NULL registers after a map_elem_lookup() by
assigning them an ID and then marking them all when the conditional
jump is observed.
Signed-off-by: Thomas Graf <tgraf@suug.ch>
Reviewed-by: Josef Bacik <jbacik@fb.com>
commit 040757f738e13caaa9c5078bca79aa97e11dde88 upstream.
Always increment/decrement ucount->count under the ucounts_lock. The
increments are there already and moving the decrements there means the
locking logic of the code is simpler. This simplification in the
locking logic fixes a race between put_ucounts and get_ucounts that
could result in a use-after-free because the count could go zero then
be found by get_ucounts and then be freed by put_ucounts.
A bug presumably this one was found by a combination of syzkaller and
KASAN. JongWhan Kim reported the syzkaller failure and Dmitry Vyukov
spotted the race in the code.
Fixes: f6b2db1a3e8d ("userns: Make the count of user namespaces per user")
Reported-by: JongHwan Kim <zzoru007@gmail.com>
Reviewed-by: Andrei Vagin <avagin@gmail.com>
commit 93faccbbfa958a9668d3ab4e30f38dd205cee8d8 upstream.
To support unprivileged users mounting filesystems two permission
checks have to be performed: a test to see if the user allowed to
create a mount in the mount namespace, and a test to see if
the user is allowed to access the specified filesystem.
The automount case is special in that mounting the original filesystem
grants permission to mount the sub-filesystems, to any user who
happens to stumble across the their mountpoint and satisfies the
ordinary filesystem permission checks.
Attempting to handle the automount case by using override_creds
almost works. It preserves the idea that permission to mount
the original filesystem is permission to mount the sub-filesystem.
Unfortunately using override_creds messes up the filesystems
ordinary permission checks.
Solve this by being explicit that a mount is a submount by introducing
vfs_submount, and using it where appropriate.
vfs_submount uses a new mount internal mount flags MS_SUBMOUNT, to let
sget and friends know that a mount is a submount so they can take appropriate
action.
sget and sget_userns are modified to not perform any permission checks
on submounts.
follow_automount is modified to stop using override_creds as that
has proven problemantic.
do_mount is modified to always remove the new MS_SUBMOUNT flag so
that we know userspace will never by able to specify it.
autofs4 is modified to stop using current_real_cred that was put in
there to handle the previous version of submount permission checking.
cifs is modified to pass the mountpoint all of the way down to vfs_submount.
debugfs is modified to pass the mountpoint all of the way down to
trace_automount by adding a new parameter. To make this change easier
a new typedef debugfs_automount_t is introduced to capture the type of
the debugfs automount function.
Fixes: 069d5ac9ae0d ("autofs: Fix automounts by using current_real_cred()->uid")
Fixes: aeaa4a79ff6a ("fs: Call d_automount with the filesystems creds")
Reviewed-by: Trond Myklebust <trond.myklebust@primarydata.com>
Reviewed-by: Seth Forshee <seth.forshee@canonical.com>
commit 907565337ebf998a68cb5c5b2174ce5e5da065eb upstream.
Userspace applications should be allowed to expect the membarrier system
call with MEMBARRIER_CMD_SHARED command to issue memory barriers on
nohz_full CPUs, but synchronize_sched() does not take those into
account.
Given that we do not want unrelated processes to be able to affect
real-time sensitive nohz_full CPUs, simply return ENOSYS when membarrier
is invoked on a kernel with enabled nohz_full CPUs.
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
CC: Josh Triplett <josh@joshtriplett.org>
CC: Steven Rostedt <rostedt@goodmis.org>
Cc: Chris Metcalf <cmetcalf@mellanox.com>
Acked-by: Lai Jiangshan <jiangshanlai@gmail.com>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
commit 441398d378f29a5ad6d0fcda07918e54e4961800 upstream.
Currently SS_AUTODISARM is not supported in compatibility mode, but does
not return -EINVAL either. This makes dosemu built with -m32 on x86_64
to crash. Also the kernel's sigaltstack selftest fails if compiled with
-m32.
This patch adds the needed support.
Link: http://lkml.kernel.org/r/20170205101213.8163-2-stsp@list.ru
Signed-off-by: Stas Sergeev <stsp@users.sourceforge.net>
Cc: Milosz Tanski <milosz@adfin.com>
Cc: Nicolas Pitre <nicolas.pitre@linaro.org>
Cc: Waiman Long <Waiman.Long@hpe.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Dmitry Safonov <dsafonov@virtuozzo.com>
Cc: Wang Xiaoqiang <wangxq10@lzu.edu.cn>
commit b5d24fda9c3dce51fcb4eee459550a458eaaf1e2 upstream.
The mem_hotplug_{begin,done} lock coordinates with {get,put}_online_mems()
to hold off "readers" of the current state of memory from new hotplug
actions. mem_hotplug_begin() expects exclusive access, via the
device_hotplug lock, to set mem_hotplug.active_writer. Calling
mem_hotplug_begin() without locking device_hotplug can lead to
corrupting mem_hotplug.refcount and missed wakeups / soft lockups.
[dan.j.williams@intel.com: v2]
Link: http://lkml.kernel.org/r/148728203365.38457.17804568297887708345.stgit@dwillia2-desk3.amr.corp.intel.com
Link: http://lkml.kernel.org/r/148693885680.16345.17802627926777862337.stgit@dwillia2-desk3.amr.corp.intel.com
Fixes: f931ab479dd2 ("mm: fix devm_memremap_pages crash, use mem_hotplug_{begin, done}")
Reported-by: Ben Hutchings <ben@decadent.org.uk>
Cc: Michal Hocko <mhocko@suse.com>
Cc: Toshi Kani <toshi.kani@hpe.com>
Cc: Logan Gunthorpe <logang@deltatee.com>
Cc: Masayoshi Mizuma <m.mizuma@jp.fujitsu.com>
commit f222449c9dfad7c9bb8cb53e64c5c407b172ebbc upstream.
We cannot do printk() from tk_debug_account_sleep_time(), because
tk_debug_account_sleep_time() is called under tk_core seq lock.
The reason why printk() is unsafe there is that console_sem may
invoke scheduler (up()->wake_up_process()->activate_task()), which,
in turn, can return back to timekeeping code, for instance, via
get_time()->ktime_get(), deadlocking the system on tk_core seq lock.
[ 48.950592] ======================================================
[ 48.950622] [ INFO: possible circular locking dependency detected ]
[ 48.950622] 4.10.0-rc7-next-20170213+ #101 Not tainted
[ 48.950622] -------------------------------------------------------
[ 48.950622] kworker/0:0/3 is trying to acquire lock:
[ 48.950653] (tk_core){----..}, at: [<c01cc624>] retrigger_next_event+0x4c/0x90
[ 48.950683]
but task is already holding lock:
[ 48.950683] (hrtimer_bases.lock){-.-...}, at: [<c01cc610>] retrigger_next_event+0x38/0x90
[ 48.950714]
which lock already depends on the new lock.
[ 48.950714]
the existing dependency chain (in reverse order) is:
[ 48.950714]
-> #5 (hrtimer_bases.lock){-.-...}:
[ 48.950744] _raw_spin_lock_irqsave+0x50/0x64
[ 48.950775] lock_hrtimer_base+0x28/0x58
[ 48.950775] hrtimer_start_range_ns+0x20/0x5c8
[ 48.950775] __enqueue_rt_entity+0x320/0x360
[ 48.950805] enqueue_rt_entity+0x2c/0x44
[ 48.950805] enqueue_task_rt+0x24/0x94
[ 48.950836] ttwu_do_activate+0x54/0xc0
[ 48.950836] try_to_wake_up+0x248/0x5c8
[ 48.950836] __setup_irq+0x420/0x5f0
[ 48.950836] request_threaded_irq+0xdc/0x184
[ 48.950866] devm_request_threaded_irq+0x58/0xa4
[ 48.950866] omap_i2c_probe+0x530/0x6a0
[ 48.950897] platform_drv_probe+0x50/0xb0
[ 48.950897] driver_probe_device+0x1f8/0x2cc
[ 48.950897] __driver_attach+0xc0/0xc4
[ 48.950927] bus_for_each_dev+0x6c/0xa0
[ 48.950927] bus_add_driver+0x100/0x210
[ 48.950927] driver_register+0x78/0xf4
[ 48.950958] do_one_initcall+0x3c/0x16c
[ 48.950958] kernel_init_freeable+0x20c/0x2d8
[ 48.950958] kernel_init+0x8/0x110
[ 48.950988] ret_from_fork+0x14/0x24
[ 48.950988]
-> #4 (&rt_b->rt_runtime_lock){-.-...}:
[ 48.951019] _raw_spin_lock+0x40/0x50
[ 48.951019] rq_offline_rt+0x9c/0x2bc
[ 48.951019] set_rq_offline.part.2+0x2c/0x58
[ 48.951049] rq_attach_root+0x134/0x144
[ 48.951049] cpu_attach_domain+0x18c/0x6f4
[ 48.951049] build_sched_domains+0xba4/0xd80
[ 48.951080] sched_init_smp+0x68/0x10c
[ 48.951080] kernel_init_freeable+0x160/0x2d8
[ 48.951080] kernel_init+0x8/0x110
[ 48.951080] ret_from_fork+0x14/0x24
[ 48.951110]
-> #3 (&rq->lock){-.-.-.}:
[ 48.951110] _raw_spin_lock+0x40/0x50
[ 48.951141] task_fork_fair+0x30/0x124
[ 48.951141] sched_fork+0x194/0x2e0
[ 48.951141] copy_process.part.5+0x448/0x1a20
[ 48.951171] _do_fork+0x98/0x7e8
[ 48.951171] kernel_thread+0x2c/0x34
[ 48.951171] rest_init+0x1c/0x18c
[ 48.951202] start_kernel+0x35c/0x3d4
[ 48.951202] 0x8000807c
[ 48.951202]
-> #2 (&p->pi_lock){-.-.-.}:
[ 48.951232] _raw_spin_lock_irqsave+0x50/0x64
[ 48.951232] try_to_wake_up+0x30/0x5c8
[ 48.951232] up+0x4c/0x60
[ 48.951263] __up_console_sem+0x2c/0x58
[ 48.951263] console_unlock+0x3b4/0x650
[ 48.951263] vprintk_emit+0x270/0x474
[ 48.951293] vprintk_default+0x20/0x28
[ 48.951293] printk+0x20/0x30
[ 48.951324] kauditd_hold_skb+0x94/0xb8
[ 48.951324] kauditd_thread+0x1a4/0x56c
[ 48.951324] kthread+0x104/0x148
[ 48.951354] ret_from_fork+0x14/0x24
[ 48.951354]
-> #1 ((console_sem).lock){-.....}:
[ 48.951385] _raw_spin_lock_irqsave+0x50/0x64
[ 48.951385] down_trylock+0xc/0x2c
[ 48.951385] __down_trylock_console_sem+0x24/0x80
[ 48.951385] console_trylock+0x10/0x8c
[ 48.951416] vprintk_emit+0x264/0x474
[ 48.951416] vprintk_default+0x20/0x28
[ 48.951416] printk+0x20/0x30
[ 48.951446] tk_debug_account_sleep_time+0x5c/0x70
[ 48.951446] __timekeeping_inject_sleeptime.constprop.3+0x170/0x1a0
[ 48.951446] timekeeping_resume+0x218/0x23c
[ 48.951477] syscore_resume+0x94/0x42c
[ 48.951477] suspend_enter+0x554/0x9b4
[ 48.951477] suspend_devices_and_enter+0xd8/0x4b4
[ 48.951507] enter_state+0x934/0xbd4
[ 48.951507] pm_suspend+0x14/0x70
[ 48.951507] state_store+0x68/0xc8
[ 48.951538] kernfs_fop_write+0xf4/0x1f8
[ 48.951538] __vfs_write+0x1c/0x114
[ 48.951538] vfs_write+0xa0/0x168
[ 48.951568] SyS_write+0x3c/0x90
[ 48.951568] __sys_trace_return+0x0/0x10
[ 48.951568]
-> #0 (tk_core){----..}:
[ 48.951599] lock_acquire+0xe0/0x294
[ 48.951599] ktime_get_update_offsets_now+0x5c/0x1d4
[ 48.951629] retrigger_next_event+0x4c/0x90
[ 48.951629] on_each_cpu+0x40/0x7c
[ 48.951629] clock_was_set_work+0x14/0x20
[ 48.951660] process_one_work+0x2b4/0x808
[ 48.951660] worker_thread+0x3c/0x550
[ 48.951660] kthread+0x104/0x148
[ 48.951690] ret_from_fork+0x14/0x24
[ 48.951690]
[ 48.951690] Chain exists of:
tk_core --> &rt_b->rt_runtime_lock --> hrtimer_bases.lock
[ 48.951721] Possible unsafe locking scenario:
[ 48.951721] CPU0 CPU1
[ 48.951721] ---- ----
[ 48.951721] lock(hrtimer_bases.lock);
[ 48.951751] lock(&rt_b->rt_runtime_lock);
[ 48.951751] lock(hrtimer_bases.lock);
[ 48.951751] lock(tk_core);
[ 48.951782]
*** DEADLOCK ***
[ 48.951782] 3 locks held by kworker/0:0/3:
[ 48.951782] #0: ("events"){.+.+.+}, at: [<c0156590>] process_one_work+0x1f8/0x808
[ 48.951812] #1: (hrtimer_work){+.+...}, at: [<c0156590>] process_one_work+0x1f8/0x808
[ 48.951843] #2: (hrtimer_bases.lock){-.-...}, at: [<c01cc610>] retrigger_next_event+0x38/0x90
[ 48.951843] stack backtrace:
[ 48.951873] CPU: 0 PID: 3 Comm: kworker/0:0 Not tainted 4.10.0-rc7-next-20170213+
[ 48.951904] Workqueue: events clock_was_set_work
[ 48.951904] [<c0110208>] (unwind_backtrace) from [<c010c224>] (show_stack+0x10/0x14)
[ 48.951934] [<c010c224>] (show_stack) from [<c04ca6c0>] (dump_stack+0xac/0xe0)
[ 48.951934] [<c04ca6c0>] (dump_stack) from [<c019b5cc>] (print_circular_bug+0x1d0/0x308)
[ 48.951965] [<c019b5cc>] (print_circular_bug) from [<c019d2a8>] (validate_chain+0xf50/0x1324)
[ 48.951965] [<c019d2a8>] (validate_chain) from [<c019ec18>] (__lock_acquire+0x468/0x7e8)
[ 48.951995] [<c019ec18>] (__lock_acquire) from [<c019f634>] (lock_acquire+0xe0/0x294)
[ 48.951995] [<c019f634>] (lock_acquire) from [<c01d0ea0>] (ktime_get_update_offsets_now+0x5c/0x1d4)
[ 48.952026] [<c01d0ea0>] (ktime_get_update_offsets_now) from [<c01cc624>] (retrigger_next_event+0x4c/0x90)
[ 48.952026] [<c01cc624>] (retrigger_next_event) from [<c01e4e24>] (on_each_cpu+0x40/0x7c)
[ 48.952056] [<c01e4e24>] (on_each_cpu) from [<c01cafc4>] (clock_was_set_work+0x14/0x20)
[ 48.952056] [<c01cafc4>] (clock_was_set_work) from [<c015664c>] (process_one_work+0x2b4/0x808)
[ 48.952087] [<c015664c>] (process_one_work) from [<c0157774>] (worker_thread+0x3c/0x550)
[ 48.952087] [<c0157774>] (worker_thread) from [<c015d644>] (kthread+0x104/0x148)
[ 48.952087] [<c015d644>] (kthread) from [<c0107830>] (ret_from_fork+0x14/0x24)
Replace printk() with printk_deferred(), which does not call into
the scheduler.
Fixes: 0bf43f15db85 ("timekeeping: Prints the amounts of time spent during suspend")
Reported-and-tested-by: Tony Lindgren <tony@atomide.com>
Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Cc: Petr Mladek <pmladek@suse.com>
Cc: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com>
Cc: "Rafael J . Wysocki" <rjw@rjwysocki.net>
Cc: John Stultz <john.stultz@linaro.org>
Link: http://lkml.kernel.org/r/20170215044332.30449-1-sergey.senozhatsky@gmail.com
commit fc98c3c8c9dcafd67adcce69e6ce3191d5306c9c upstream.
Use rcuidle console tracepoint because, apparently, it may be issued
from an idle CPU:
hw-breakpoint: Failed to enable monitor mode on CPU 0.
hw-breakpoint: CPU 0 failed to disable vector catch
4.10.0-rc8-next-20170215+ #119 Not tainted
./include/trace/events/printk.h:32 suspicious rcu_dereference_check() usage!
RCU used illegally from idle CPU!
RCU used illegally from extended quiescent state!
2 locks held by swapper/0/0:
#0: (cpu_pm_notifier_lock){......}, at: [<c0237e2c>] cpu_pm_exit+0x10/0x54
#1: (console_lock){+.+.+.}, at: [<c01ab350>] vprintk_emit+0x264/0x474
stack backtrace:
CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.10.0-rc8-next-20170215+ #119
Hardware name: Generic OMAP4 (Flattened Device Tree)
console_unlock
vprintk_emit
vprintk_default
printk
reset_ctrl_regs
dbg_cpu_pm_notify
notifier_call_chain
cpu_pm_exit
omap_enter_idle_coupled
cpuidle_enter_state
cpuidle_enter_state_coupled
do_idle
cpu_startup_entry
start_kernel
This RCU warning, however, is suppressed by lockdep_off() in printk().
lockdep_off() increments the ->lockdep_recursion counter and thus
disables RCU_LOCKDEP_WARN() and debug_lockdep_rcu_enabled(), which want
lockdep to be enabled "current->lockdep_recursion == 0".
Link: http://lkml.kernel.org/r/20170217015932.11898-1-sergey.senozhatsky@gmail.com
Reported-by: Tony Lindgren <tony@atomide.com>
Tested-by: Tony Lindgren <tony@atomide.com>
Acked-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
Cc: Tony Lindgren <tony@atomide.com>
Cc: Russell King <rmk@armlinux.org.uk>
commit 25f71d1c3e98ef0e52371746220d66458eac75bc upstream.
The UEVENT user mode helper is enabled before the initcalls are executed
and is available when the root filesystem has been mounted.
The user mode helper is triggered by device init calls and the executable
might use the futex syscall.
futex_init() is marked __initcall which maps to device_initcall, but there
is no guarantee that futex_init() is invoked _before_ the first device init
call which triggers the UEVENT user mode helper.
If the user mode helper uses the futex syscall before futex_init() then the
syscall crashes with a NULL pointer dereference because the futex subsystem
has not been initialized yet.
Move futex_init() to core_initcall so futexes are initialized before the
root filesystem is mounted and the usermode helper becomes available.
[ tglx: Rewrote changelog ]
Signed-off-by: Yang Yang <yang.yang29@zte.com.cn>
Cc: jiang.biao2@zte.com.cn
Cc: jiang.zhengxiong@zte.com.cn
Cc: zhong.weidong@zte.com.cn
Cc: deng.huali@zte.com.cn
Link: http://lkml.kernel.org/r/1483085875-6130-1-git-send-email-yang.yang29@zte.com.cn
commit 451d24d1e5f40bad000fa9abe36ddb16fc9928cb upstream.
Alexei had his box explode because doing read() on a package
(rapl/uncore) event that isn't currently scheduled in ends up doing an
out-of-bounds load.
Rework the code to more explicitly deal with event->oncpu being -1.
Reported-by: Alexei Starovoitov <alexei.starovoitov@gmail.com>
Tested-by: Alexei Starovoitov <ast@kernel.org>
Tested-by: David Carrillo-Cisneros <davidcc@google.com>
Cc: eranian@google.com
Fixes: d6a2f9035bfc ("perf/core: Introduce PMU_EV_CAP_READ_ACTIVE_PKG")
Link: http://lkml.kernel.org/r/20170131102710.GL6515@twins.programming.kicks-ass.net
commit bfeda41d06d85ad9d52f2413cfc2b77be5022f75 upstream.
Since KERN_CONT became meaningful again, lockdep stack traces have had
annoying extra newlines, like this:
[ 5.561122] -> #1 (B){+.+...}:
[ 5.561528]
[ 5.561532] [<ffffffff810d8873>] lock_acquire+0xc3/0x210
[ 5.562178]
[ 5.562181] [<ffffffff816f6414>] mutex_lock_nested+0x74/0x6d0
[ 5.562861]
[ 5.562880] [<ffffffffa01aa3c3>] init_btrfs_fs+0x21/0x196 [btrfs]
[ 5.563717]
[ 5.563721] [<ffffffff81000472>] do_one_initcall+0x52/0x1b0
[ 5.564554]
[ 5.564559] [<ffffffff811a3af6>] do_init_module+0x5f/0x209
[ 5.565357]
[ 5.565361] [<ffffffff81122f4d>] load_module+0x218d/0x2b80
[ 5.566020]
[ 5.566021] [<ffffffff81123beb>] SyS_finit_module+0xeb/0x120
[ 5.566694]
[ 5.566696] [<ffffffff816fd241>] entry_SYSCALL_64_fastpath+0x1f/0xc2
That's happening because each printk() call now gets printed on its own
line, and we do a separate call to print the spaces before the symbol.
Fix it by doing the printk() directly instead of using the
print_ip_sym() helper.
Additionally, the symbol address isn't very helpful, so let's get rid of
that, too. The final result looks like this:
[ 5.194518] -> #1 (B){+.+...}:
[ 5.195002] lock_acquire+0xc3/0x210
[ 5.195439] mutex_lock_nested+0x74/0x6d0
[ 5.196491] do_one_initcall+0x52/0x1b0
[ 5.196939] do_init_module+0x5f/0x209
[ 5.197355] load_module+0x218d/0x2b80
[ 5.197792] SyS_finit_module+0xeb/0x120
[ 5.198251] entry_SYSCALL_64_fastpath+0x1f/0xc2
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Omar Sandoval <osandov@fb.com>
Cc: kernel-team@fb.com
Fixes: 4bcc595ccd80 ("printk: reinstate KERN_CONT for printing continuation lines")
Link: http://lkml.kernel.org/r/43b4e114724b2bdb0308fa86cb33aa07d3d67fad.1486510315.git.osandov@fb.com
commit 08d85f3ea99f1eeafc4e8507936190e86a16ee8c upstream.
Since commit f3b0946d629c ("genirq/msi: Make sure PCI MSIs are
activated early"), we can end-up activating a PCI/MSI twice (once
at allocation time, and once at startup time).
This is normally of no consequences, except that there is some
HW out there that may misbehave if activate is used more than once
(the GICv3 ITS, for example, uses the activate callback
to issue the MAPVI command, and the architecture spec says that
"If there is an existing mapping for the EventID-DeviceID
combination, behavior is UNPREDICTABLE").
While this could be worked around in each individual driver, it may
make more sense to tackle the issue at the core level. In order to
avoid getting in that situation, let's have a per-interrupt flag
to remember if we have already activated that interrupt or not.
Fixes: f3b0946d629c ("genirq/msi: Make sure PCI MSIs are activated early")
Reported-and-tested-by: Andre Przywara <andre.przywara@arm.com>
Link: http://lkml.kernel.org/r/1484668848-24361-1-git-send-email-marc.zyngier@arm.com
commit 07cd12945551b63ecb1a349d50a6d69d1d6feb4a upstream.
While refactoring cgroup creation, a5bca2152036 ("cgroup: factor out
cgroup_create() out of cgroup_mkdir()") incorrectly onlined subsystems
before the new cgroup is associated with it kernfs_node. This is fine
for cgroup proper but cgroup_name/path() depend on the associated
kernfs_node and if a subsystem makes the new cgroup_subsys_state
visible, which they're allowed to after onlining, it can lead to NULL
dereference.
The current code performs cgroup creation and subsystem onlining in
cgroup_create() and cgroup_mkdir() makes the cgroup and subsystems
visible afterwards. There's no reason to online the subsystems early
and we can simply drop cgroup_apply_control_enable() call from
cgroup_create() so that the subsystems are onlined and made visible at
the same time.
Reported-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Fixes: a5bca2152036 ("cgroup: factor out cgroup_create() out of cgroup_mkdir()")
commit 79c6f448c8b79c321e4a1f31f98194e4f6b6cae7 upstream.
The hwlat tracer creates a kernel thread at start of the tracer. It is
pinned to a single CPU and will move to the next CPU after each period of
running. If the user modifies the migration thread's affinity, it will not
change after that happens.
The original code created the thread at the first instance it was called,
but later was changed to destroy the thread after the tracer was finished,
and would not be created until the next instance of the tracer was
established. The code that initialized the affinity was only called on the
initial instantiation of the tracer. After that, it was not initialized, and
the previous affinity did not match the current newly created one, making
it appear that the user modified the thread's affinity when it did not, and
the thread failed to migrate again.
Fixes: 0330f7aa8ee6 ("tracing: Have hwlat trace migrate across tracing_cpumask CPUs")
commit 0b3589be9b98994ce3d5aeca52445d1f5627c4ba upstream.
Andres reported that MMAP2 records for anonymous memory always have
their protection field 0.
Turns out, someone daft put the prot/flags generation code in the file
branch, leaving them unset for anonymous memory.
Reported-by: Andres Freund <andres@anarazel.de>
Cc: Don Zickus <dzickus@redhat.com
Cc: Stephane Eranian <eranian@gmail.com>
Cc: acme@kernel.org
Cc: anton@ozlabs.org
Cc: namhyung@kernel.org
Fixes: f972eb63b100 ("perf: Pass protection and flags bits through mmap2 interface")
Link: http://lkml.kernel.org/r/20170126221508.GF6536@twins.programming.kicks-ass.net
commit a76a82a3e38c8d3fb6499e3dfaeb0949241ab588 upstream.
Dmitry reported a KASAN use-after-free on event->group_leader.
It turns out there's a hole in perf_remove_from_context() due to
event_function_call() not calling its function when the task
associated with the event is already dead.
In this case the event will have been detached from the task, but the
grouping will have been retained, such that group operations might
still work properly while there are live child events etc.
This does however mean that we can miss a perf_group_detach() call
when the group decomposes, this in turn can then lead to
use-after-free.
Fix it by explicitly doing the group detach if its still required.
Tested-by: Dmitry Vyukov <dvyukov@google.com>
Cc: syzkaller <syzkaller@googlegroups.com>
Fixes: 63b6da39bb38 ("perf: Fix perf_event_exit_task() race")
Link: http://lkml.kernel.org/r/20170126153955.GD6515@twins.programming.kicks-ass.net
commit 321027c1fe77f892f4ea07846aeae08cefbbb290 upstream.
Di Shen reported a race between two concurrent sys_perf_event_open()
calls where both try and move the same pre-existing software group
into a hardware context.
The problem is exactly that described in commit:
f63a8daa5812 ("perf: Fix event->ctx locking")
... where, while we wait for a ctx->mutex acquisition, the event->ctx
relation can have changed under us.
That very same commit failed to recognise sys_perf_event_context() as an
external access vector to the events and thereby didn't apply the
established locking rules correctly.
So while one sys_perf_event_open() call is stuck waiting on
mutex_lock_double(), the other (which owns said locks) moves the group
about. So by the time the former sys_perf_event_open() acquires the
locks, the context we've acquired is stale (and possibly dead).
Apply the established locking rules as per perf_event_ctx_lock_nested()
to the mutex_lock_double() for the 'move_group' case. This obviously means
we need to validate state after we acquire the locks.
Reported-by: Di Shen (Keen Lab)
Tested-by: John Dias <joaodias@google.com>
Cc: Min Chong <mchong@google.com>
Fixes: f63a8daa5812 ("perf: Fix event->ctx locking")
Link: http://lkml.kernel.org/r/20170106131444.GZ3174@twins.programming.kicks-ass.net
commit ff9f8a7cf935468a94d9927c68b00daae701667e upstream.
We perform the conversion between kernel jiffies and ms only when
exporting kernel value to user space.
We need to do the opposite operation when value is written by user.
Only matters when HZ != 1000
commit 880a38547ff08715ce4f1daf9a4bb30c87676e68 upstream.
The ucounts_lock is being used to protect various ucounts lifecycle
management functionalities. However, those services can also be invoked
when a pidns is being freed in an RCU callback (e.g. softirq context).
This can lead to deadlocks. There were already efforts trying to
prevent similar deadlocks in add7c65ca426 ("pid: fix lockdep deadlock
warning due to ucount_lock"), however they just moved the context
from hardirq to softrq. Fix this issue once and for all by explictly
making the lock disable irqs altogether.
Dmitry Vyukov <dvyukov@google.com> reported:
> I've got the following deadlock report while running syzkaller fuzzer
> on eec0d3d065bfcdf9cd5f56dd2a36b94d12d32297 of linux-next (on odroid
> device if it matters):
> [ INFO: inconsistent lock state ]
> 4.10.0-rc3-next-20170112-xc2-dirty #6 Not tainted
> inconsistent {SOFTIRQ-ON-W} -> {IN-SOFTIRQ-W} usage.
> swapper/2/0 [HC0[0]:SC1[1]:HE1:SE0] takes:
> (ucounts_lock){+.?...}, at: [< inline >] spin_lock
> ./include/linux/spinlock.h:302
> (ucounts_lock){+.?...}, at: [<ffff2000081678c8>]
> put_ucounts+0x60/0x138 kernel/ucount.c:162
> {SOFTIRQ-ON-W} state was registered at:
> [<ffff2000081c82d8>] mark_lock+0x220/0xb60 kernel/locking/lockdep.c:3054
> [< inline >] mark_irqflags kernel/locking/lockdep.c:2941
> [<ffff2000081c97a8>] __lock_acquire+0x388/0x3260 kernel/locking/lockdep.c:3295
> [<ffff2000081cce24>] lock_acquire+0xa4/0x138 kernel/locking/lockdep.c:3753
> [< inline >] __raw_spin_lock ./include/linux/spinlock_api_smp.h:144
> [<ffff200009798128>] _raw_spin_lock+0x90/0xd0 kernel/locking/spinlock.c:151
> [< inline >] spin_lock ./include/linux/spinlock.h:302
> [< inline >] get_ucounts kernel/ucount.c:131
> [<ffff200008167c28>] inc_ucount+0x80/0x6c8 kernel/ucount.c:189
> [< inline >] inc_mnt_namespaces fs/namespace.c:2818
> [<ffff200008481850>] alloc_mnt_ns+0x78/0x3a8 fs/namespace.c:2849
> [<ffff200008487298>] create_mnt_ns+0x28/0x200 fs/namespace.c:2959
> [< inline >] init_mount_tree fs/namespace.c:3199
> [<ffff200009bd6674>] mnt_init+0x258/0x384 fs/namespace.c:3251
> [<ffff200009bd60bc>] vfs_caches_init+0x6c/0x80 fs/dcache.c:3626
> [<ffff200009bb1114>] start_kernel+0x414/0x460 init/main.c:648
> [<ffff200009bb01e8>] __primary_switched+0x6c/0x70 arch/arm64/kernel/head.S:456
> irq event stamp: 2316924
> hardirqs last enabled at (2316924): [< inline >] rcu_do_batch
> kernel/rcu/tree.c:2911
> invoke_rcu_callbacks kernel/rcu/tree.c:3182
> __rcu_process_callbacks kernel/rcu/tree.c:3149
> hardirqs last enabled at (2316924): [<ffff200008210414>]
> rcu_process_callbacks+0x7a4/0xc28 kernel/rcu/tree.c:3166
> hardirqs last disabled at (2316923): [< inline >] rcu_do_batch
> kernel/rcu/tree.c:2900
> hardirqs last disabled at (2316923): [<ffff20000820fe80>]
> rcu_process_callbacks+0x210/0xc28 kernel/rcu/tree.c:3166
> softirqs last enabled at (2316912): [<ffff20000811b4c4>]
> _local_bh_enable+0x4c/0x80 kernel/softirq.c:155
> softirqs last disabled at (2316913): [< inline >]
> do_softirq_own_stack ./include/linux/interrupt.h:488
> invoke_softirq kernel/softirq.c:371
> softirqs last disabled at (2316913): [<ffff20000811c994>]
> irq_exit+0x264/0x308 kernel/softirq.c:405
> CPU0
> lock(ucounts_lock);
> <Interrupt>
> lock(ucounts_lock);
> *** DEADLOCK ***
> 1 lock held by swapper/2/0:
> #0: (rcu_callback){......}, at: [< inline >] __rcu_reclaim
> kernel/rcu/rcu.h:108
> #0: (rcu_callback){......}, at: [< inline >] rcu_do_batch
> kernel/rcu/tree.c:2919
> #0: (rcu_callback){......}, at: [<ffff200008210390>]
> rcu_process_callbacks+0x720/0xc28 kernel/rcu/tree.c:3166
> stack backtrace:
> CPU: 2 PID: 0 Comm: swapper/2 Not tainted 4.10.0-rc3-next-20170112-xc2-dirty #6
> Hardware name: Hardkernel ODROID-C2 (DT)
> Call trace:
> [<ffff20000808fa60>] dump_backtrace+0x0/0x440 arch/arm64/kernel/traps.c:500
> [<ffff20000808fec0>] show_stack+0x20/0x30 arch/arm64/kernel/traps.c:225
> [<ffff2000088a99e0>] dump_stack+0x110/0x168
> [<ffff2000082fa2b4>] print_usage_bug.part.27+0x49c/0x4bc
> kernel/locking/lockdep.c:2387
> [< inline >] print_usage_bug kernel/locking/lockdep.c:2357
> [< inline >] valid_state kernel/locking/lockdep.c:2400
> [< inline >] mark_lock_irq kernel/locking/lockdep.c:2617
> [<ffff2000081c89ec>] mark_lock+0x934/0xb60 kernel/locking/lockdep.c:3065
> [< inline >] mark_irqflags kernel/locking/lockdep.c:2923
> [<ffff2000081c9a60>] __lock_acquire+0x640/0x3260 kernel/locking/lockdep.c:3295
> [<ffff2000081678c8>] put_ucounts+0x60/0x138 kernel/ucount.c:162
> [<ffff200008168364>] dec_ucount+0xf4/0x158 kernel/ucount.c:214
> [< inline >] dec_pid_namespaces kernel/pid_namespace.c:89
> [<ffff200008293dc8>] delayed_free_pidns+0x40/0xe0 kernel/pid_namespace.c:156
> [< inline >] __rcu_reclaim kernel/rcu/rcu.h:118
> [< inline >] rcu_do_batch kernel/rcu/tree.c:2919
> [< inline >] invoke_rcu_callbacks kernel/rcu/tree.c:3182
> [< inline >] __rcu_process_callbacks kernel/rcu/tree.c:3149
> [<ffff2000082103d8>] rcu_process_callbacks+0x768/0xc28 kernel/rcu/tree.c:3166
> [<ffff2000080821dc>] __do_softirq+0x324/0x6e0 kernel/softirq.c:284
> [< inline >] do_softirq_own_stack ./include/linux/interrupt.h:488
> [< inline >] invoke_softirq kernel/softirq.c:371
> [<ffff20000811c994>] irq_exit+0x264/0x308 kernel/softirq.c:405
> [<ffff2000081ecc28>] __handle_domain_irq+0xc0/0x150 kernel/irq/irqdesc.c:636
> [<ffff200008081c80>] gic_handle_irq+0x68/0xd8
> Exception stack(0xffff8000648e7dd0 to 0xffff8000648e7f00)
> 7dc0: ffff8000648d4b3c 0000000000000007
> 7de0: 0000000000000000 1ffff0000c91a967 1ffff0000c91a967 1ffff0000c91a967
> 7e00: ffff20000a4b6b68 0000000000000001 0000000000000007 0000000000000001
> 7e20: 1fffe4000149ae90 ffff200009d35000 0000000000000000 0000000000000002
> 7e40: 0000000000000000 0000000000000000 0000000002624a1a 0000000000000000
> 7e60: 0000000000000000 ffff200009cbcd88 000060006d2ed000 0000000000000140
> 7e80: ffff200009cff000 ffff200009cb6000 ffff200009cc2020 ffff200009d2159d
> 7ea0: 0000000000000000 ffff8000648d4380 0000000000000000 ffff8000648e7f00
> 7ec0: ffff20000820a478 ffff8000648e7f00 ffff20000820a47c 0000000010000145
> 7ee0: 0000000000000140 dfff200000000000 ffffffffffffffff ffff20000820a478
> [<ffff2000080837f8>] el1_irq+0xb8/0x130 arch/arm64/kernel/entry.S:486
> [< inline >] arch_local_irq_restore
> ./arch/arm64/include/asm/irqflags.h:81
> [<ffff20000820a47c>] rcu_idle_exit+0x64/0xa8 kernel/rcu/tree.c:1030
> [< inline >] cpuidle_idle_call kernel/sched/idle.c:200
> [<ffff2000081bcbfc>] do_idle+0x1dc/0x2d0 kernel/sched/idle.c:243
> [<ffff2000081bd1cc>] cpu_startup_entry+0x24/0x28 kernel/sched/idle.c:345
> [<ffff200008099f8c>] secondary_start_kernel+0x2cc/0x358
> arch/arm64/kernel/smp.c:276
> [<000000000279f1a4>] 0x279f1a4
Fixes: add7c65ca426 ("pid: fix lockdep deadlock warning due to ucount_lock")
Fixes: f333c700c610 ("pidns: Add a limit on the number of pid namespaces")
Link: https://www.spinics.net/lists/kernel/msg2426637.html
Signed-off-by: Nikolay Borisov <n.borisov.lkml@gmail.com>
commit 52d7e48b86fc108e45a656d8e53e4237993c481d upstream.
The current preemptible RCU implementation goes through three phases
during bootup. In the first phase, there is only one CPU that is running
with preemption disabled, so that a no-op is a synchronous grace period.
In the second mid-boot phase, the scheduler is running, but RCU has
not yet gotten its kthreads spawned (and, for expedited grace periods,
workqueues are not yet running. During this time, any attempt to do
a synchronous grace period will hang the system (or complain bitterly,
depending). In the third and final phase, RCU is fully operational and
everything works normally.
This has been OK for some time, but there has recently been some
synchronous grace periods showing up during the second mid-boot phase.
This code worked "by accident" for awhile, but started failing as soon
as expedited RCU grace periods switched over to workqueues in commit
8b355e3bc140 ("rcu: Drive expedited grace periods from workqueue").
Note that the code was buggy even before this commit, as it was subject
to failure on real-time systems that forced all expedited grace periods
to run as normal grace periods (for example, using the rcu_normal ksysfs
parameter). The callchain from the failure case is as follows:
early_amd_iommu_init()
|-> acpi_put_table(ivrs_base);
|-> acpi_tb_put_table(table_desc);
|-> acpi_tb_invalidate_table(table_desc);
|-> acpi_tb_release_table(...)
|-> acpi_os_unmap_memory
|-> acpi_os_unmap_iomem
|-> acpi_os_map_cleanup
|-> synchronize_rcu_expedited
The kernel showing this callchain was built with CONFIG_PREEMPT_RCU=y,
which caused the code to try using workqueues before they were
initialized, which did not go well.
This commit therefore reworks RCU to permit synchronous grace periods
to proceed during this mid-boot phase. This commit is therefore a
fix to a regression introduced in v4.9, and is therefore being put
forward post-merge-window in v4.10.
This commit sets a flag from the existing rcu_scheduler_starting()
function which causes all synchronous grace periods to take the expedited
path. The expedited path now checks this flag, using the requesting task
to drive the expedited grace period forward during the mid-boot phase.
Finally, this flag is updated by a core_initcall() function named
rcu_exp_runtime_mode(), which causes the runtime codepaths to be used.
Note that this arrangement assumes that tasks are not sent POSIX signals
(or anything similar) from the time that the first task is spawned
through core_initcall() time.
Fixes: 8b355e3bc140 ("rcu: Drive expedited grace periods from workqueue")
Reported-by: "Zheng, Lv" <lv.zheng@intel.com>
Reported-by: Borislav Petkov <bp@alien8.de>
Tested-by: Stan Kain <stan.kain@gmail.com>
Tested-by: Ivan <waffolz@hotmail.com>
Tested-by: Emanuel Castelo <emanuel.castelo@gmail.com>
Tested-by: Bruno Pesavento <bpesavento@infinito.it>
Tested-by: Borislav Petkov <bp@suse.de>
Tested-by: Frederic Bezies <fredbezies@gmail.com>
commit f466ae66fa6a599f9a53b5f9bafea4b8cfffa7fb upstream.
It is now legal to invoke synchronize_sched() at early boot, which causes
Tiny RCU's synchronize_sched() to emit spurious splats. This commit
therefore removes the cond_resched() from Tiny RCU's synchronize_sched().
commit add7c65ca426b7a37184dd3d2172394e23d585d6 upstream.
[ INFO: possible irq lock inversion dependency detected ]
4.10.0-rc2-00024-g4aecec9-dirty #118 Tainted: G W
swapper/1/0 just changed the state of lock:
(&(&sighand->siglock)->rlock){-.....}, at: [<ffffffffbd0a1bc6>] __lock_task_sighand+0xb6/0x2c0
but this lock took another, HARDIRQ-unsafe lock in the past:
(ucounts_lock){+.+...}
and interrupts could create inverse lock ordering between them.
Chain exists of: &(&sighand->siglock)->rlock --> &(&tty->ctrl_lock)->rlock --> ucounts_lock
Possible interrupt unsafe locking scenario:
CPU0 CPU1
lock(ucounts_lock);
local_irq_disable();
lock(&(&sighand->siglock)->rlock);
lock(&(&tty->ctrl_lock)->rlock);
<Interrupt>
*** DEADLOCK ***
This patch removes a dependency between rlock and ucount_lock.
Signed-off-by: Andrei Vagin <avagin@openvz.org>
Acked-by: Al Viro <viro@ZenIV.linux.org.uk>
commit b6416e61012429e0277bd15a229222fd17afc1c1 upstream.
Modules that use static_key_deferred need a way to synchronize with
any delayed work that is still pending when the module is unloaded.
Introduce static_key_deferred_flush() which flushes any pending
jump label updates.
Signed-off-by: David Matlack <dmatlack@google.com>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
commit f931ab479dd24cf7a2c6e2df19778406892591fb upstream.
Both arch_add_memory() and arch_remove_memory() expect a single threaded
context.
For example, arch/x86/mm/init_64.c::kernel_physical_mapping_init() does
not hold any locks over this check and branch:
if (pgd_val(*pgd)) {
pud = (pud_t *)pgd_page_vaddr(*pgd);
paddr_last = phys_pud_init(pud, __pa(vaddr),
__pa(vaddr_end),
page_size_mask);
continue;
pud = alloc_low_page();
paddr_last = phys_pud_init(pud, __pa(vaddr), __pa(vaddr_end),
page_size_mask);
The result is that two threads calling devm_memremap_pages()
simultaneously can end up colliding on pgd initialization. This leads
to crash signatures like the following where the loser of the race
initializes the wrong pgd entry:
BUG: unable to handle kernel paging request at ffff888ebfff0000
IP: memcpy_erms+0x6/0x10
PGD 2f8e8fc067 PUD 0 /* <---- Invalid PUD */
Oops: 0000 [#1] SMP DEBUG_PAGEALLOC
CPU: 54 PID: 3818 Comm: systemd-udevd Not tainted 4.6.7+ #13
task: ffff882fac290040 ti: ffff882f887a4000 task.ti: ffff882f887a4000
RIP: memcpy_erms+0x6/0x10
Call Trace:
? pmem_do_bvec+0x205/0x370 [nd_pmem]
? blk_queue_enter+0x3a/0x280
pmem_rw_page+0x38/0x80 [nd_pmem]
bdev_read_page+0x84/0xb0
Hold the standard memory hotplug mutex over calls to
arch_{add,remove}_memory().
Fixes: 41e94a851304 ("add devm_memremap_pages")
Link: http://lkml.kernel.org/r/148357647831.9498.12606007370121652979.stgit@dwillia2-desk3.amr.corp.intel.com
commit c1a9eeb938b5433947e5ea22f89baff3182e7075 upstream.
When a disfunctional timer, e.g. dummy timer, is installed, the tick core
tries to setup the broadcast timer.
If no broadcast device is installed, the kernel crashes with a NULL pointer
dereference in tick_broadcast_setup_oneshot() because the function has no
sanity check.
Reported-by: Mason <slash.tmp@free.fr>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Anna-Maria Gleixner <anna-maria@linutronix.de>
Cc: Richard Cochran <rcochran@linutronix.de>
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Cc: Daniel Lezcano <daniel.lezcano@linaro.org>
Cc: Peter Zijlstra <peterz@infradead.org>,
Cc: Sebastian Frias <sf84@laposte.net>
Cc: Thibaud Cornic <thibaud_cornic@sigmadesigns.com>
Cc: Robin Murphy <robin.murphy@arm.com>
Link: http://lkml.kernel.org/r/1147ef90-7877-e4d2-bb2b-5c4fa8d3144b@free.fr
commit c0af52437254fda8b0cdbaae5a9b6d9327f1fcd5 upstream.
Commit 34c3d9819fda ("genirq/affinity: Provide smarter irq spreading
infrastructure") introduced a better IRQ spreading mechanism, taking
account of the available NUMA nodes in the machine.
Problem is that the algorithm of retrieving the nodemask iterates
"linearly" based on the number of online nodes - some architectures
present non-linear node distribution among the nodemask, like PowerPC.
If this is the case, the algorithm lead to a wrong node count number
and therefore to a bad/incomplete IRQ affinity distribution.
For example, this problem were found in a machine with 128 CPUs and two
nodes, namely nodes 0 and 8 (instead of 0 and 1, if it was linearly
distributed). This led to a wrong affinity distribution which then led to
a bad mq allocation for nvme driver.
Finally, we take the opportunity to fix a comment regarding the affinity
distribution when we have _more_ nodes than vectors.
Fixes: 34c3d9819fda ("genirq/affinity: Provide smarter irq spreading infrastructure")
Reported-by: Gabriel Krisman Bertazi <gabriel@krisman.be>
Signed-off-by: Guilherme G. Piccoli <gpiccoli@linux.vnet.ibm.com>
Reviewed-by: Gabriel Krisman Bertazi <gabriel@krisman.be>
Reviewed-by: Gavin Shan <gwshan@linux.vnet.ibm.com>
Cc: linux-pci@vger.kernel.org
Cc: linuxppc-dev@lists.ozlabs.org
Cc: hch@lst.de
Link: http://lkml.kernel.org/r/1481738472-2671-1-git-send-email-gpiccoli@linux.vnet.ibm.com
commit 9a29d0fbc2d9ad99fb8a981ab72548cc360e9d4c upstream.
Smatch complains that we started using the array offset before we
checked that it was valid.
Fixes: 017c59c042d0 ('relay: Use per CPU constructs for the relay channel buffer pointers')
Link: http://lkml.kernel.org/r/20161013084947.GC16198@mwanda
commit 794de08a16cf1fc1bf785dc48f66d36218cf6d88 upstream.
Both the wakeup and irqsoff tracers can use the function graph tracer when
the display-graph option is set. The problem is that they ignore the notrace
file, and record the entry of functions that would be ignored by the
function_graph tracer. This causes the trace->depth to be recorded into the
ring buffer. The set_graph_notrace uses a trick by adding a large negative
number to the trace->depth when a graph function is to be ignored.
On trace output, the graph function uses the depth to record a stack of
functions. But since the depth is negative, it accesses the array with a
negative number and causes an out of bounds access that can cause a kernel
oops or corrupt data.
Have the print functions handle cases where a tracer still records functions
even when they are in set_graph_notrace.
Also add warnings if the depth is below zero before accessing the array.
Note, the function graph logic will still prevent the return of these
functions from being recorded, which means that they will be left hanging
without a return. For example:
# echo '*spin*' > set_graph_notrace
# echo 1 > options/display-graph
# echo wakeup > current_tracer
# cat trace
_raw_spin_lock() {
preempt_count_add() {
do_raw_spin_lock() {
update_rq_clock();
Where it should look like:
_raw_spin_lock() {
preempt_count_add();
do_raw_spin_lock();
update_rq_clock();
Cc: Namhyung Kim <namhyung.kim@lge.com>
Fixes: 29ad23b00474 ("ftrace: Add set_graph_notrace filter")
commit 9c1645727b8fa90d07256fdfcc45bf831242a3ab upstream.
The clocksource delta to nanoseconds conversion is using signed math, but
the delta is unsigned. This makes the conversion space smaller than
necessary and in case of a multiplication overflow the conversion can
become negative. The conversion is done with scaled math:
s64 nsec_delta = ((s64)clkdelta * clk->mult) >> clk->shift;
Shifting a signed integer right obvioulsy preserves the sign, which has
interesting consequences:
- Time jumps backwards
- __iter_div_u64_rem() which is used in one of the calling code pathes
will take forever to piecewise calculate the seconds/nanoseconds part.
This has been reported by several people with different scenarios:
David observed that when stopping a VM with a debugger:
"It was essentially the stopped by debugger case. I forget exactly why,
but the guest was being explicitly stopped from outside, it wasn't just
scheduling lag. I think it was something in the vicinity of 10 minutes
stopped."
When lifting the stop the machine went dead.
The stopped by debugger case is not really interesting, but nevertheless it
would be a good thing not to die completely.
But this was also observed on a live system by Liav:
"When the OS is too overloaded, delta will get a high enough value for the
msb of the sum delta * tkr->mult + tkr->xtime_nsec to be set, and so
after the shift the nsec variable will gain a value similar to
0xffffffffff000000."
Unfortunately this has been reintroduced recently with commit 6bd58f09e1d8
("time: Add cycles to nanoseconds translation"). It had been fixed a year
ago already in commit 35a4933a8959 ("time: Avoid signed overflow in
timekeeping_get_ns()").
Though it's not surprising that the issue has been reintroduced because the
function itself and the whole call chain uses s64 for the result and the
propagation of it. The change in this recent commit is subtle:
s64 nsec;
- nsec = (d * m + n) >> s:
+ nsec = d * m + n;
+ nsec >>= s;
d being type of cycle_t adds another level of obfuscation.
This wouldn't have happened if the previous change to unsigned computation
would have made the 'nsec' variable u64 right away and a follow up patch
had cleaned up the whole call chain.
There have been patches submitted which basically did a revert of the above
patch leaving everything else unchanged as signed. Back to square one. This
spawned a admittedly pointless discussion about potential users which rely
on the unsigned behaviour until someone pointed out that it had been fixed
before. The changelogs of said patches added further confusion as they made
finally false claims about the consequences for eventual users which expect
signed results.
Despite delta being cycle_t, aka. u64, it's very well possible to hand in
a signed negative value and the signed computation will happily return the
correct result. But nobody actually sat down and analyzed the code which
was added as user after the propably unintended signed conversion.
Though in sensitive code like this it's better to analyze it proper and
make sure that nothing relies on this than hunting the subtle wreckage half
a year later. After analyzing all call chains it stands that no caller can
hand in a negative value (which actually would work due to the s64 cast)
and rely on the signed math to do the right thing.
Change the conversion function to unsigned math. The conversion of all call
chains is done in a follow up patch.
This solves the starvation issue, which was caused by the negative result,
but it does not solve the underlying problem. It merily procrastinates
it. When the timekeeper update is deferred long enough that the unsigned
multiplication overflows, then time going backwards is observable again.
It does neither solve the issue of clocksources with a small counter width
which will wrap around possibly several times and cause random time stamps
to be generated. But those are usually not found on systems used for
virtualization, so this is likely a non issue.
I took the liberty to claim authorship for this simply because
analyzing all callsites and writing the changelog took substantially
more time than just making the simple s/s64/u64/ change and ignore the
rest.
Fixes: 6bd58f09e1d8 ("time: Add cycles to nanoseconds translation")
Reported-by: David Gibson <david@gibson.dropbear.id.au>
Reported-by: Liav Rehana <liavr@mellanox.com>
Reviewed-by: David Gibson <david@gibson.dropbear.id.au>
Cc: Parit Bhargava <prarit@redhat.com>
Cc: Laurent Vivier <lvivier@redhat.com>
Cc: "Christopher S. Hall" <christopher.s.hall@intel.com>
Cc: Richard Cochran <richardcochran@gmail.com>
Link: http://lkml.kernel.org/r/20161208204228.688545601@linutronix.de
commit 2d13bb6494c807bcf3f78af0e96c0b8615a94385 upstream.
We've got a delay loop waiting for secondary CPUs. That loop uses
loops_per_jiffy. However, loops_per_jiffy doesn't actually mean how
many tight loops make up a jiffy on all architectures. It is quite
common to see things like this in the boot log:
Calibrating delay loop (skipped), value calculated using timer
frequency.. 48.00 BogoMIPS (lpj=24000)
In my case I was seeing lots of cases where other CPUs timed out
entering the debugger only to print their stack crawls shortly after the
kdb> prompt was written.
Elsewhere in kgdb we already use udelay(), so that should be safe enough
to use to implement our timeout. We'll delay 1 ms for 1000 times, which
should give us a full second of delay (just like the old code wanted)
but allow us to notice that we're done every 1 ms.
[akpm@linux-foundation.org: simplifications, per Daniel]
Link: http://lkml.kernel.org/r/1477091361-2039-1-git-send-email-dianders@chromium.org
Signed-off-by: Douglas Anderson <dianders@chromium.org>
Reviewed-by: Daniel Thompson <daniel.thompson@linaro.org>
Cc: Jason Wessel <jason.wessel@windriver.com>
Cc: Brian Norris <briannorris@chromium.org>
commit 4d1f0fb096aedea7bb5489af93498a82e467c480 upstream.
NMI handler doesn't call set_irq_regs(), it's set only by normal IRQ.
Thus get_irq_regs() returns NULL or stale registers snapshot with IP/SP
pointing to the code interrupted by IRQ which was interrupted by NMI.
NULL isn't a problem: in this case watchdog calls dump_stack() and
prints full stack trace including NMI. But if we're stuck in IRQ
handler then NMI watchlog will print stack trace without IRQ part at
all.
This patch uses registers snapshot passed into NMI handler as arguments:
these registers point exactly to the instruction interrupted by NMI.
Fixes: 55537871ef66 ("kernel/watchdog.c: perform all-CPU backtrace in case of hard lockup")
Link: http://lkml.kernel.org/r/146771764784.86724.6006627197118544150.stgit@buzz
Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Ulrich Obergfell <uobergfe@redhat.com>
Cc: Aaron Tomlin <atomlin@redhat.com>
commit 84d77d3f06e7e8dea057d10e8ec77ad71f721be3 upstream.
It is the reasonable expectation that if an executable file is not
readable there will be no way for a user without special privileges to
read the file. This is enforced in ptrace_attach but if ptrace
is already attached before exec there is no enforcement for read-only
executables.
As the only way to read such an mm is through access_process_vm
spin a variant called ptrace_access_vm that will fail if the
target process is not being ptraced by the current process, or
the current process did not have sufficient privileges when ptracing
began to read the target processes mm.
In the ptrace implementations replace access_process_vm by
ptrace_access_vm. There remain several ptrace sites that still use
access_process_vm as they are reading the target executables
instructions (for kernel consumption) or register stacks. As such it
does not appear necessary to add a permission check to those calls.
This bug has always existed in Linux.
Fixes: v1.0
Reported-by: Andy Lutomirski <luto@amacapital.net>
commit 64b875f7ac8a5d60a4e191479299e931ee949b67 upstream.
When the flag PT_PTRACE_CAP was added the PTRACE_TRACEME path was
overlooked. This can result in incorrect behavior when an application
like strace traces an exec of a setuid executable.
Further PT_PTRACE_CAP does not have enough information for making good
security decisions as it does not report which user namespace the
capability is in. This has already allowed one mistake through
insufficient granulariy.
I found this issue when I was testing another corner case of exec and
discovered that I could not get strace to set PT_PTRACE_CAP even when
running strace as root with a full set of caps.
This change fixes the above issue with strace allowing stracing as
root a setuid executable without disabling setuid. More fundamentaly
this change allows what is allowable at all times, by using the correct
information in it's decision.
Fixes: 4214e42f96d4 ("v2.4.9.11 -> v2.4.9.12")
