path: root/kernel
2014-03-16Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fixes from Ingo Molnar: "Three small fixes" * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched/clock: Prevent tracing recursion in sched_clock_cpu() stop_machine: Fix^2 race between stop_two_cpus() and stop_cpus() sched/deadline: Deny unprivileged users to set/change SCHED_DEADLINE policy
2014-03-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull audit namespace fixes from Eric Biederman: "Starting with 3.14-rc1 the audit code is faulty (think oopses and races) with respect to how it computes the network namespace of which socket to reply to, and I happened to notice by chance when reading through the code. My testing and the automated build bots don't find any problems with these fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: audit: Update kdoc for audit_send_reply and audit_list_rules_send audit: Send replies in the proper network namespace. audit: Use struct net not pid_t to remember the network namespce to reply in
2014-03-11sched/clock: Prevent tracing recursion in sched_clock_cpu()Fernando Luis Vazquez Cao
Prevent tracing of preempt_disable/enable() in sched_clock_cpu(). When CONFIG_DEBUG_PREEMPT is enabled, preempt_disable/enable() are traced and this causes trace_clock() users (and probably others) to go into an infinite recursion. Systems with a stable sched_clock() are not affected. This problem is similar to that fixed by upstream commit 95ef1e52922 ("KVM guest: prevent tracing recursion with kvmclock"). Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/1394083528.4524.3.camel@nexus Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-03-11stop_machine: Fix^2 race between stop_two_cpus() and stop_cpus()Peter Zijlstra
We must use smp_call_function_single(.wait=1) for the irq_cpu_stop_queue_work() to ensure the queueing is actually done under stop_cpus_lock. Without this we could have dropped the lock by the time we do the queueing and get the race we tried to fix. Fixes: 7053ea1a34fa ("stop_machine: Fix race between stop_two_cpus() and stop_cpus()") Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Prarit Bhargava <prarit@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Christoph Hellwig <hch@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/r/20140228123905.GK3104@twins.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-03-11sched/deadline: Deny unprivileged users to set/change SCHED_DEADLINE policyJuri Lelli
Deny the use of SCHED_DEADLINE policy to unprivileged users. Even if root users can set the policy for normal users, we don't want the latter to be able to change their parameters (safest behavior). Signed-off-by: Juri Lelli <juri.lelli@gmail.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1393844961-18097-1-git-send-email-juri.lelli@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-03-10mm: fix GFP_THISNODE callers and clarifyJohannes Weiner
GFP_THISNODE is for callers that implement their own clever fallback to remote nodes. It restricts the allocation to the specified node and does not invoke reclaim, assuming that the caller will take care of it when the fallback fails, e.g. through a subsequent allocation request without GFP_THISNODE set. However, many current GFP_THISNODE users only want the node exclusive aspect of the flag, without actually implementing their own fallback or triggering reclaim if necessary. This results in things like page migration failing prematurely even when there is easily reclaimable memory available, unless kswapd happens to be running already or a concurrent allocation attempt triggers the necessary reclaim. Convert all callsites that don't implement their own fallback strategy to __GFP_THISNODE. This restricts the allocation a single node too, but at the same time allows the allocator to enter the slowpath, wake kswapd, and invoke direct reclaim if necessary, to make the allocation happen when memory is full. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Rik van Riel <riel@redhat.com> Cc: Jan Stancek <jstancek@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-08audit: Update kdoc for audit_send_reply and audit_list_rules_sendEric W. Biederman
The kbuild test robot reported: > tree: git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace.git for-next > head: 6f285b19d09f72e801525f5eea1bdad22e559bf0 > commit: 6f285b19d09f72e801525f5eea1bdad22e559bf0 [2/2] audit: Send replies in the proper network namespace. > reproduce: make htmldocs > > >> Warning(kernel/audit.c:575): No description found for parameter 'request_skb' > >> Warning(kernel/audit.c:575): Excess function parameter 'portid' description in 'audit_send_reply' > >> Warning(kernel/auditfilter.c:1074): No description found for parameter 'request_skb' > >> Warning(kernel/auditfilter.c:1074): Excess function parameter 'portid' description in 'audit_list_rules_s Which was caused by my failure to update the kdoc annotations when I updated the functions. Fix that small oversight now. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2014-03-08Merge branch 'for-3.14-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup fixes from Tejun Heo: "Two cpuset locking fixes from Li. Both tagged for -stable" * 'for-3.14-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: cpuset: fix a race condition in __cpuset_node_allowed_softwall() cpuset: fix a locking issue in cpuset_migrate_mm()
2014-03-07Merge tag 'trace-fixes-v3.14-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull tracing fix from Steven Rostedt: "In the past, I've had lots of reports about trace events not working. Developers would say they put a trace_printk() before and after the trace event but when they enable it (and the trace event said it was enabled) they would see the trace_printks but not the trace event. I was not able to reproduce this, but that's because I wasn't looking at the right location. Recently, another bug came up that showed the issue. If your kernel supports signed modules but allows for non-signed modules to be loaded, then when one is, the kernel will silently set the MODULE_FORCED taint on the module. Although, this taint happens without the need for insmod --force or anything of the kind, it labels the module with that taint anyway. If this tainted module has tracepoints, the tracepoints will be ignored because of the MODULE_FORCED taint. But no error message will be displayed. Worse yet, the event infrastructure will still be created letting users enable the trace event represented by the tracepoint, although that event will never actually be enabled. This is because the tracepoint infrastructure allows for non-existing tracepoints to be enabled for new modules to arrive and have their tracepoints set. Although there are several things wrong with the above, this change only addresses the creation of the trace event files for tracepoints that are not created when a module is loaded and is tainted. This change will print an error message about the module being tainted and not the trace events will not be created, and it does not create the trace event infrastructure" * tag 'trace-fixes-v3.14-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: tracing: Do not add event files for modules that fail tracepoints
2014-03-07Merge branch 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq fixes from Thomas Gleixner: - a bugfix for a long standing waitqueue race - a trivial fix for a missing include * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: genirq: Include missing header file in irqdomain.c genirq: Remove racy waitqueue_active check
2014-03-03tracing: Do not add event files for modules that fail tracepointsSteven Rostedt (Red Hat)
If a module fails to add its tracepoints due to module tainting, do not create the module event infrastructure in the debugfs directory. As the events will not work and worse yet, they will silently fail, making the user wonder why the events they enable do not display anything. Having a warning on module load and the events not visible to the users will make the cause of the problem much clearer. Link: http://lkml.kernel.org/r/20140227154923.265882695@goodmis.org Fixes: 6d723736e472 "tracing/events: add support for modules to TRACE_EVENT" Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Cc: stable@vger.kernel.org # 2.6.31+ Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2014-03-03Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fixes from Ingo Molnar: "Misc fixes, most of them SCHED_DEADLINE fallout" * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched/deadline: Prevent rt_time growth to infinity sched/deadline: Switch CPU's presence test order sched/deadline: Cleanup RT leftovers from {inc/dec}_dl_migration sched: Fix double normalization of vruntime
2014-03-02Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "Misc fixes, most of them on the tooling side" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf tools: Fix strict alias issue for find_first_bit perf tools: fix BFD detection on opensuse perf: Fix hotplug splat perf/x86: Fix event scheduling perf symbols: Destroy unused symsrcs perf annotate: Check availability of annotate when processing samples
2014-02-28audit: Send replies in the proper network namespace.Eric W. Biederman
In perverse cases of file descriptor passing the current network namespace of a process and the network namespace of a socket used by that socket may differ. Therefore use the network namespace of the appropiate socket to ensure replies always go to the appropiate socket. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2014-02-28audit: Use struct net not pid_t to remember the network namespce to reply inEric W. Biederman
In struct audit_netlink_list and audit_reply add a reference to the network namespace of the caller and remove the userspace pid of the caller. This cleanly remembers the callers network namespace, and removes a huge class of races and nasty failure modes that can occur when attempting to relook up the callers network namespace from a pid_t (including the caller's network namespace changing, pid wraparound, and the pid simply not being present). Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2014-02-27Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs Pull filesystem fixes from Jan Kara: "Notification, writeback, udf, quota fixes The notification patches are (with one exception) a fallout of my fsnotify rework which went into -rc1 (I've extented LTP to cover these cornercases to avoid similar breakage in future). The UDF patch is a nasty data corruption Al has recently reported, the revert of the writeback patch is due to possibility of violating sync(2) guarantees, and a quota bug can lead to corruption of quota files in ocfs2" * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs: fsnotify: Allocate overflow events with proper type fanotify: Handle overflow in case of permission events fsnotify: Fix detection whether overflow event is queued Revert "writeback: do not sync data dirtied after sync start" quota: Fix race between dqput() and dquot_scan_active() udf: Fix data corruption on file type conversion inotify: Fix reporting of cookies for inotify events
2014-02-27cpuset: fix a race condition in __cpuset_node_allowed_softwall()Li Zefan
It's not safe to access task's cpuset after releasing task_lock(). Holding callback_mutex won't help. Cc: <stable@vger.kernel.org> Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-02-27cpuset: fix a locking issue in cpuset_migrate_mm()Li Zefan
I can trigger a lockdep warning: # mount -t cgroup -o cpuset xxx /cgroup # mkdir /cgroup/cpuset # mkdir /cgroup/tmp # echo 0 > /cgroup/tmp/cpuset.cpus # echo 0 > /cgroup/tmp/cpuset.mems # echo 1 > /cgroup/tmp/cpuset.memory_migrate # echo $$ > /cgroup/tmp/tasks # echo 1 > /cgruop/tmp/cpuset.mems =============================== [ INFO: suspicious RCU usage. ] 3.14.0-rc1-0.1-default+ #32 Not tainted ------------------------------- include/linux/cgroup.h:682 suspicious rcu_dereference_check() usage! ... [<ffffffff81582174>] dump_stack+0x72/0x86 [<ffffffff810b8f01>] lockdep_rcu_suspicious+0x101/0x140 [<ffffffff81105ba1>] cpuset_migrate_mm+0xb1/0xe0 ... We used to hold cgroup_mutex when calling cpuset_migrate_mm(), but now we hold cpuset_mutex, which causes task_css() to complain. This is not a false-positive but a real issue. Holding cpuset_mutex won't prevent a task from migrating to another cpuset, and it won't prevent the original task->cgroup from destroying during this change. Fixes: 5d21cc2db040 (cpuset: replace cgroup_mutex locking with cpuset internal locking) Cc: <stable@vger.kernel.org> # 3.9+ Signed-off-by: Li Zefan <lizefan@huawei.com> Sigend-off-by: Tejun Heo <tj@kernel.org>
2014-02-27genirq: Include missing header file in irqdomain.cRashika Kheria
Include appropriate header file include/linux/of_irq.h in kernel/irq/irqdomain.c because it contains prototype definition of function define in kernel/irq/irqdomain.c. This eliminates the following warning in kernel/irq/irqdomain.c: kernel/irq/irqdomain.c:468:14: warning: no previous prototype for ‘irq_create_of_mapping’ [-Wmissing-prototypes] Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Link: http://lkml.kernel.org/r/eb89aebea7ff1a46122918ac389ebecf8248be9a.1393493276.git.rashika.kheria@gmail.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-02-27perf: Fix hotplug splatPeter Zijlstra
Drew Richardson reported that he could make the kernel go *boom* when hotplugging while having perf events active. It turned out that when you have a group event, the code in __perf_event_exit_context() fails to remove the group siblings from the context. We then proceed with destroying and freeing the event, and when you re-plug the CPU and try and add another event to that CPU, things go *boom* because you've still got dead entries there. Reported-by: Drew Richardson <drew.richardson@arm.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Will Deacon <will.deacon@arm.com> Cc: <stable@vger.kernel.org> Link: http://lkml.kernel.org/n/tip-k6v5wundvusvcseqj1si0oz0@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-02-27sched/deadline: Prevent rt_time growth to infinityJuri Lelli
Kirill Tkhai noted: Since deadline tasks share rt bandwidth, we must care about bandwidth timer set. Otherwise rt_time may grow up to infinity in update_curr_dl(), if there are no other available RT tasks on top level bandwidth. RT task were in fact throttled right after they got enqueued, and never executed again (rt_time never again went below rt_runtime). Peter then proposed to accrue DL execution on rt_time only when rt timer is active, and proposed a patch (this patch is a slight modification of that) to implement that behavior. While this solves Kirill problem, it has a drawback. Indeed, Kirill noted again: It looks we may get into a situation, when all CPU time is shared between RT and DL tasks: rt_runtime = n rt_period = 2n | RT working, DL sleeping | DL working, RT sleeping | ----------------------------------------------------------- | (1) duration = n | (2) duration = n | (repeat) |--------------------------|------------------------------| | (rt_bw timer is running) | (rt_bw timer is not running) | No time for fair tasks at all. While this can happen during the first period, if rq is always backlogged, RT tasks won't have the opportunity to execute anymore: rt_time reached rt_runtime during (1), suppose after (2) RT is enqueued back, it gets throttled since rt timer didn't fire, replenishment is from now on eaten up by DL tasks that accrue their execution on rt_time (while rt timer is active - we have an RT task waiting for replenishment). FAIR tasks are not touched after this first period. Ok, this is not ideal, and the situation is even worse! What above (the nice case), practically never happens in reality, where your rt timer is not aligned to tasks periods, tasks are in general not periodic, etc.. Long story short, you always risk to overload your system. This patch is based on Peter's idea, but exploits an additional fact: if you don't have RT tasks enqueued, it makes little sense to continue incrementing rt_time once you reached the upper limit (DL tasks have their own mechanism for throttling). This cures both problems: - no matter how many DL instances in the past, you'll have an rt_time slightly above rt_runtime when an RT task is enqueued, and from that point on (after the first replenishment), the task will normally execute; - you can still eat up all bandwidth during the first period, but not anymore after that, remember that DL execution will increment rt_time till the upper limit is reached. The situation is still not perfect! But, we have a simple solution for now, that limits how much you can jeopardize your system, as we keep working towards the right answer: RT groups scheduled using deadline servers. Reported-by: Kirill Tkhai <tkhai@yandex.ru> Signed-off-by: Juri Lelli <juri.lelli@gmail.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/20140225151515.617714e2f2cd6c558531ba61@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-02-27sched/deadline: Switch CPU's presence test orderJuri Lelli
Commit 82b9580 ("sched/deadline: Test for CPU's presence explicitly") changed how we check if a CPU returned by cpudeadline machinery is valid. But, we don't want to call cpu_present() if best_cpu is equal to -1. So, switch the order of tests inside WARN_ON(). Signed-off-by: Juri Lelli <juri.lelli@gmail.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: boris.ostrovsky@oracle.com Cc: konrad.wilk@oracle.com Cc: rostedt@goodmis.org Link: http://lkml.kernel.org/r/1393238832-9100-1-git-send-email-juri.lelli@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-02-27sched/deadline: Cleanup RT leftovers from {inc/dec}_dl_migrationKirill Tkhai
In deadline class we do not have group scheduling. So, let's remove unnecessary X = X; equations. Signed-off-by: Kirill Tkhai <ktkhai@parallels.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Juri Lelli <juri.lelli@gmail.com> Link: http://lkml.kernel.org/r/1393343543.4089.5.camel@tkhai Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-02-27sched: Fix double normalization of vruntimeGeorge McCollister
dequeue_entity() is called when p->on_rq and sets se->on_rq = 0 which appears to guarentee that the !se->on_rq condition is met. If the task has done set_current_state(TASK_INTERRUPTIBLE) without schedule() the second condition will be met and vruntime will be incorrectly adjusted twice. In certain cases this can result in the task's vruntime never increasing past the vruntime of other tasks on the CFS' run queue, starving them of CPU time. This patch changes switched_from_fair() to use !p->on_rq instead of !se->on_rq. I'm able to cause a task with a priority of 120 to starve all other tasks with the same priority on an ARM platform running 3.2.51-rt72 PREEMPT RT by writing one character at time to a serial tty (16550 UART) in a tight loop. I'm also able to verify making this change corrects the problem on that platform and kernel version. Signed-off-by: George McCollister <george.mccollister@gmail.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: stable@vger.kernel.org Link: http://lkml.kernel.org/r/1392767811-28916-1-git-send-email-george.mccollister@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-02-27genirq: Remove racy waitqueue_active checkChuansheng Liu
We hit one rare case below: T1 calling disable_irq(), but hanging at synchronize_irq() always; The corresponding irq thread is in sleeping state; And all CPUs are in idle state; After analysis, we found there is one possible scenerio which causes T1 is waiting there forever: CPU0 CPU1 synchronize_irq() wait_event() spin_lock() atomic_dec_and_test(&threads_active) insert the __wait into queue spin_unlock() if(waitqueue_active) atomic_read(&threads_active) wake_up() Here after inserted the __wait into queue on CPU0, and before test if queue is empty on CPU1, there is no barrier, it maybe cause it is not visible for CPU1 immediately, although CPU0 has updated the queue list. It is similar for CPU0 atomic_read() threads_active also. So we'd need one smp_mb() before waitqueue_active.that, but removing the waitqueue_active() check solves it as wel l and it makes things simple and clear. Signed-off-by: Chuansheng Liu <chuansheng.liu@intel.com> Cc: Xiaoming Wang <xiaoming.wang@intel.com> Link: http://lkml.kernel.org/r/1393212590-32543-1-git-send-email-chuansheng.liu@intel.com Cc: stable@vger.kernel.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-02-23Merge branch 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer fix from Thomas Gleixner: "Serialize the registration of a new sched_clock in the currently ARM only generic sched_clock facilty to avoid sched_clock havoc" * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched_clock: Prevent callers from seeing half-updated data
2014-02-21sched/deadline: Remove useless dl_nr_totalKirill Tkhai
In deadline class we do not have group scheduling like in RT. dl_nr_total is the same as dl_nr_running. So, one of them should be removed. Cc: Ingo Molnar <mingo@redhat.com> Cc: Juri Lelli <juri.lelli@gmail.com> Signed-off-by: Kirill Tkhai <tkhai@yandex.ru> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/368631392675853@web20h.yandex.ru Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-02-21sched/deadline: Test for CPU's presence explicitlyBoris Ostrovsky
A hot-removed CPU may have ID that is numerically larger than the number of existing CPUs in the system (e.g. we can unplug CPU 4 from a system that has CPUs 0, 1 and 4). Thus the WARN_ONs should check whether the CPU in question is currently present, not whether its ID value is less than num_present_cpus(). Cc: Ingo Molnar <mingo@kernel.org> Cc: Juri Lelli <juri.lelli@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Reported-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Boris Ostrovsky <boris.ostrovsky@oracle.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1392646353-1874-1-git-send-email-boris.ostrovsky@oracle.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-02-21sched: Add 'flags' argument to sched_{set,get}attr() syscallsPeter Zijlstra
Because of a recent syscall design debate; its deemed appropriate for each syscall to have a flags argument for future extension; without immediately requiring new syscalls. Cc: juri.lelli@gmail.com Cc: Ingo Molnar <mingo@redhat.com> Suggested-by: Michael Kerrisk <mtk.manpages@gmail.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20140214161929.GL27965@twins.programming.kicks-ass.net Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-02-21sched: Fix information leak in sys_sched_getattr()Vegard Nossum
We're copying the on-stack structure to userspace, but forgot to give the right number of bytes to copy. This allows the calling process to obtain up to PAGE_SIZE bytes from the stack (and possibly adjacent kernel memory). This fix copies only as much as we actually have on the stack (attr->size defaults to the size of the struct) and leaves the rest of the userspace-provided buffer untouched. Found using kmemcheck + trinity. Fixes: d50dde5a10f30 ("sched: Add new scheduler syscalls to support an extended scheduling parameters ABI") Cc: Dario Faggioli <raistlin@linux.it> Cc: Juri Lelli <juri.lelli@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1392585857-10725-1-git-send-email-vegard.nossum@oracle.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-02-21sched,numa: add cond_resched to task_numa_workRik van Riel
Normally task_numa_work scans over a fairly small amount of memory, but it is possible to run into a large unpopulated part of virtual memory, with no pages mapped. In that case, task_numa_work can run for a while, and it may make sense to reschedule as required. Cc: akpm@linux-foundation.org Cc: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Rik van Riel <riel@redhat.com> Reported-by: Xing Gang <gang.xing@hp.com> Tested-by: Chegu Vinod <chegu_vinod@hp.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1392761566-24834-2-git-send-email-riel@redhat.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-02-21sched/core: Make dl_b->lock IRQ safeJuri Lelli
Fix this lockdep warning: [ 44.804600] ========================================================= [ 44.805746] [ INFO: possible irq lock inversion dependency detected ] [ 44.805746] 3.14.0-rc2-test+ #14 Not tainted [ 44.805746] --------------------------------------------------------- [ 44.805746] bash/3674 just changed the state of lock: [ 44.805746] (&dl_b->lock){+.....}, at: [<ffffffff8106ad15>] sched_rt_handler+0x132/0x248 [ 44.805746] but this lock was taken by another, HARDIRQ-safe lock in the past: [ 44.805746] (&rq->lock){-.-.-.} and interrupts could create inverse lock ordering between them. [ 44.805746] [ 44.805746] other info that might help us debug this: [ 44.805746] Possible interrupt unsafe locking scenario: [ 44.805746] [ 44.805746] CPU0 CPU1 [ 44.805746] ---- ---- [ 44.805746] lock(&dl_b->lock); [ 44.805746] local_irq_disable(); [ 44.805746] lock(&rq->lock); [ 44.805746] lock(&dl_b->lock); [ 44.805746] <Interrupt> [ 44.805746] lock(&rq->lock); by making dl_b->lock acquiring always IRQ safe. Cc: Ingo Molnar <mingo@redhat.com> Signed-off-by: Juri Lelli <juri.lelli@gmail.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1392107067-19907-3-git-send-email-juri.lelli@gmail.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-02-21sched/core: Fix sched_rt_global_validateJuri Lelli
Don't compare sysctl_sched_rt_runtime against sysctl_sched_rt_period if the former is equal to RUNTIME_INF, otherwise disabling -rt bandwidth management (with CONFIG_RT_GROUP_SCHED=n) fails. Cc: Ingo Molnar <mingo@redhat.com> Signed-off-by: Juri Lelli <juri.lelli@gmail.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1392107067-19907-2-git-send-email-juri.lelli@gmail.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-02-21sched/deadline: Fix overflow to handle period==0 and deadline!=0Steven Rostedt
While debugging the crash with the bad nr_running accounting, I hit another bug where, after running my sched deadline test, I was getting failures to take a CPU offline. It was giving me a -EBUSY error. Adding a bunch of trace_printk()s around, I found that the cpu notifier that called sched_cpu_inactive() was returning a failure. The overflow value was coming up negative? Talking this over with Juri, the problem is that the total_bw update was suppose to be made by dl_overflow() which, during my tests, seemed to not be called. Adding more trace_printk()s, it wasn't that it wasn't called, but it exited out right away with the check of new_bw being equal to p->dl.dl_bw. The new_bw calculates the ratio between period and runtime. The bug is that if you set a deadline, you do not need to set a period if you plan on the period being equal to the deadline. That is, if period is zero and deadline is not, then the system call should set the period to be equal to the deadline. This is done elsewhere in the code. The fix is easy, check if period is set, and if it is not, then use the deadline. Cc: Juri Lelli <juri.lelli@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20140219135335.7e74abd4@gandalf.local.home Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-02-21sched/deadline: Fix bad accounting of nr_runningJuri Lelli
Rostedt writes: My test suite was locking up hard when enabling mmiotracer. This was due to the mmiotracer placing all but one CPU offline. I found this out when I was able to reproduce the bug with just my stress-cpu-hotplug test. This bug baffled me because it would not always trigger, and would only trigger on the first run after boot up. The stress-cpu-hotplug test would crash hard the first run, or never crash at all. But a new reboot may cause it to crash on the first run again. I spent all week bisecting this, as I couldn't find a consistent reproducer. I finally narrowed it down to the sched deadline patches, and even more peculiar, to the commit that added the sched deadline boot up self test to the latency tracer. Then it dawned on me to what the bug was. All it took was to run a task under sched deadline to screw up the CPU hot plugging. This explained why it would lock up only on the first run of the stress-cpu-hotplug test. The bug happened when the boot up self test of the schedule latency tracer would test a deadline task. The deadline task would corrupt something that would cause CPU hotplug to fail. If it didn't corrupt it, the stress test would always work (there's no other sched deadline tasks that would run to cause problems). If it did corrupt on boot up, the first test would lockup hard. I proved this theory by running my deadline test program on another box, and then run the stress-cpu-hotplug test, and it would now consistently lock up. I could run stress-cpu-hotplug over and over with no problem, but once I ran the deadline test, the next run of the stress-cpu-hotplug would lock hard. After adding lots of tracing to the code, I found the cause. The function tracer showed that migrate_tasks() was stuck in an infinite loop, where rq->nr_running never equaled 1 to break out of it. When I added a trace_printk() to see what that number was, it was 335 and never decrementing! Looking at the deadline code I found: static void __dequeue_task_dl(struct rq *rq, struct task_struct *p, int flags) { dequeue_dl_entity(&p->dl); dequeue_pushable_dl_task(rq, p); } static void dequeue_task_dl(struct rq *rq, struct task_struct *p, int flags) { update_curr_dl(rq); __dequeue_task_dl(rq, p, flags); dec_nr_running(rq); } And this: if (dl_runtime_exceeded(rq, dl_se)) { __dequeue_task_dl(rq, curr, 0); if (likely(start_dl_timer(dl_se, curr->dl.dl_boosted))) dl_se->dl_throttled = 1; else enqueue_task_dl(rq, curr, ENQUEUE_REPLENISH); if (!is_leftmost(curr, &rq->dl)) resched_task(curr); } Notice how we call __dequeue_task_dl() and in the else case we call enqueue_task_dl()? Also notice that dequeue_task_dl() has underscores where enqueue_task_dl() does not. The enqueue_task_dl() calls inc_nr_running(rq), but __dequeue_task_dl() does not. This is where we get nr_running out of sync. [snip] Another point where nr_running can get out of sync is when the dl_timer fires: dl_se->dl_throttled = 0; if (p->on_rq) { enqueue_task_dl(rq, p, ENQUEUE_REPLENISH); if (task_has_dl_policy(rq->curr)) check_preempt_curr_dl(rq, p, 0); else resched_task(rq->curr); This patch does two things: - correctly accounts for throttled tasks (that are now considered !running); - fixes the bug, updating nr_running from {inc,dec}_dl_tasks(), since we risk to update it twice in some situations (e.g., a task is dequeued while it has exceeded its budget). Cc: mingo@redhat.com Cc: torvalds@linux-foundation.org Cc: akpm@linux-foundation.org Reported-by: Steven Rostedt <rostedt@goodmis.org> Reviewed-by: Steven Rostedt <rostedt@goodmis.org> Tested-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Juri Lelli <juri.lelli@gmail.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1392884379-13744-1-git-send-email-juri.lelli@gmail.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-02-20Merge branch 'for-3.14-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup fixes from Tejun Heo: "Quite a few fixes this time. Three locking fixes, all marked for -stable. A couple error path fixes and some misc fixes. Hugh found a bug in memcg offlining sequence and we thought we could fix that from cgroup core side but that turned out to be insufficient and got reverted. A different fix has been applied to -mm" * 'for-3.14-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: cgroup: update cgroup_enable_task_cg_lists() to grab siglock Revert "cgroup: use an ordered workqueue for cgroup destruction" cgroup: protect modifications to cgroup_idr with cgroup_mutex cgroup: fix locking in cgroup_cfts_commit() cgroup: fix error return from cgroup_create() cgroup: fix error return value in cgroup_mount() cgroup: use an ordered workqueue for cgroup destruction nfs: include xattr.h from fs/nfs/nfs3proc.c cpuset: update MAINTAINERS entry arm, pm, vmpressure: add missing slab.h includes
git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq Pull workqueue fixes from Tejun Heo: "Two workqueue fixes. One for an unlikely but possible critical bug during kworker shutdown and the other to make lockdep names a bit more descriptive" * 'for-3.14-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: workqueue: ensure @task is valid across kthread_stop() workqueue: add args to workqueue lockdep name
2014-02-20user_namespace.c: Remove duplicated word in commentBrian Campbell
Signed-off-by: Brian Campbell <brian.campbell@editshare.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-02-19sched_clock: Prevent callers from seeing half-updated dataStephen Boyd
The generic sched_clock registration function was previously done lockless, due to the fact that it was expected to be called only once. However, now there are systems that may register multiple sched_clock sources, for which the lack of locking has casued problems: If two sched_clock sources are registered we may end up in a situation where a call to sched_clock() may be accessing the epoch cycle count for the old counter and the cycle count for the new counter. This can lead to confusing results where sched_clock() values jump and then are reset to 0 (due to the way the registration function forces the epoch_ns to be 0). Fix this by reorganizing the registration function to hold the seqlock for as short a time as possible while we update the clock_data structure for a new counter. We also put any accumulated time into epoch_ns instead of resetting the time to 0 so that the clock doesn't reset after each successful registration. [jstultz: Added extra context to the commit message] Reported-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Will Deacon <will.deacon@arm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Josh Cartwright <joshc@codeaurora.org> Link: http://lkml.kernel.org/r/1392662736-7803-2-git-send-email-john.stultz@linaro.org Signed-off-by: John Stultz <john.stultz@linaro.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-02-18cgroup: update cgroup_enable_task_cg_lists() to grab siglockTejun Heo
Currently, there's nothing preventing cgroup_enable_task_cg_lists() from missing set PF_EXITING and race against cgroup_exit(). Depending on the timing, cgroup_exit() may finish with the task still linked on css_set leading to list corruption. Fix it by grabbing siglock in cgroup_enable_task_cg_lists() so that PF_EXITING is guaranteed to be visible. This whole on-demand cg_list optimization is extremely fragile and has ample possibility to lead to bugs which can cause things like once-a-year oops during boot. I'm wondering whether the better approach would be just adding "cgroup_disable=all" handling which disables the whole cgroup rather than tempting fate with this on-demand craziness. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com> Cc: stable@vger.kernel.org
2014-02-18workqueue: ensure @task is valid across kthread_stop()Lai Jiangshan
When a kworker should die, the kworkre is notified through WORKER_DIE flag instead of kthread_should_stop(). This, IIRC, is primarily to keep the test synchronized inside worker_pool lock. WORKER_DIE is first set while holding pool->lock, the lock is dropped and kthread_stop() is called. Unfortunately, this means that there's a slight chance that the target kworker may see WORKER_DIE before kthread_stop() finishes and exits and frees the target task before or during kthread_stop(). Fix it by pinning the target task before setting WORKER_DIE and putting it after kthread_stop() is done. tj: Improved patch description and comment. Moved pinning above WORKER_DIE for better signify what it's protecting. CC: stable@vger.kernel.org Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-02-18inotify: Fix reporting of cookies for inotify eventsJan Kara
My rework of handling of notification events (namely commit 7053aee26a35 "fsnotify: do not share events between notification groups") broke sending of cookies with inotify events. We didn't propagate the value passed to fsnotify() properly and passed 4 uninitialized bytes to userspace instead (so it is also an information leak). Sadly I didn't notice this during my testing because inotify cookies aren't used very much and LTP inotify tests ignore them. Fix the problem by passing the cookie value properly. Fixes: 7053aee26a3548ebaba046ae2e52396ccf56ac6c Reported-by: Vegard Nossum <vegard.nossum@oracle.com> Signed-off-by: Jan Kara <jack@suse.cz>
2014-02-17printk: fix syslog() overflowing user bufferLinus Torvalds
This is not a buffer overflow in the traditional sense: we don't overflow any *kernel* buffers, but we do mis-count the amount of data we copy back to user space for the SYSLOG_ACTION_READ_ALL case. In particular, if the user buffer is too small to hold everything, and *if* there is a continuation line at just the right place, we can end up giving the user more data than he asked for. The reason is that we first count up the number of bytes all the log records contains, then we walk the records again until we've skipped the records at the beginning that won't fit, and then we walk the rest of the records and copy them to the user space buffer. And in between that "skip the initial records that won't fit" and the "copy the records that *will* fit to user space", we reset the 'prev' variable that contained the record information for the last record not copied. That meant that when we started copying to user space, we now had a different character count than what we had originally calculated in the first record walk-through. The fix is to simply not clear the 'prev' flags value (in both cases where we had the same logic: syslog_print_all and kmsg_dump_get_buffer: the latter is used for pstore-like dumping) Reported-and-tested-by: Debabrata Banerjee <dbanerje@akamai.com> Acked-by: Kay Sievers <kay@vrfy.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-02-15Merge branches 'irq-urgent-for-linus' and 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq update from Thomas Gleixner: "Fix from the urgent branch: a trivial oneliner adding the missing Kconfig dependency curing build failures which have been discovered by several build robots. The update in the irq-core branch provides a new function in the irq/devres code, which is a prerequisite for driver developers to get rid of boilerplate code all over the place. Not a bugfix, but it has zero impact on the current kernel due to the lack of users. It's simpler to provide the infrastructure to interested parties via your tree than fulfilling the wishlist of driver maintainers on which particular commit or tag this should be based on" * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: genirq: Add missing irq_to_desc export for CONFIG_SPARSE_IRQ=n * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: genirq: Add devm_request_any_context_irq()
2014-02-15Merge branch 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer fixes from Thomas Gleixner: "The following trilogy of patches brings you: - fix for a long standing math overflow issue with HZ < 60 - an onliner fix for a corner case in the dreaded tick broadcast mechanism affecting a certain range of AMD machines which are infested with the infamous automagic C1E power control misfeature - a fix for one of the ARM platforms which allows the kernel to proceed and boot instead of stupidly panicing for no good reason. The patch is slightly larger than necessary, but it's less ugly than the alternative 5 liner" * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: tick: Clear broadcast pending bit when switching to oneshot clocksource: Kona: Print warning rather than panic time: Fix overflow when HZ is smaller than 60
2014-02-13tick: Clear broadcast pending bit when switching to oneshotThomas Gleixner
AMD systems which use the C1E workaround in the amd_e400_idle routine trigger the WARN_ON_ONCE in the broadcast code when onlining a CPU. The reason is that the idle routine of those AMD systems switches the cpu into forced broadcast mode early on before the newly brought up CPU can switch over to high resolution / NOHZ mode. The timer related CPU1 bringup looks like this: clockevent_register_device(local_apic); tick_setup(local_apic); ... idle() tick_broadcast_on_off(FORCE); tick_broadcast_oneshot_control(ENTER) cpumask_set(cpu, broadcast_oneshot_mask); halt(); Now the broadcast interrupt on CPU0 sets CPU1 in the broadcast_pending_mask and wakes CPU1. So CPU1 continues: local_apic_timer_interrupt() tick_handle_periodic(); softirq() tick_init_highres(); cpumask_clr(cpu, broadcast_oneshot_mask); tick_broadcast_oneshot_control(ENTER) WARN_ON(cpumask_test(cpu, broadcast_pending_mask); So while we remove CPU1 from the broadcast_oneshot_mask when we switch over to highres mode, we do not clear the pending bit, which then triggers the warning when we go back to idle. The reason why this is only visible on C1E affected AMD systems is that the other machines enter the deep sleep states via acpi_idle/intel_idle and exit the broadcast mode before executing the remote triggered local_apic_timer_interrupt. So the pending bit is already cleared when the switch over to highres mode is clearing the oneshot mask. The solution is simple: Clear the pending bit together with the mask bit when we switch over to highres mode. Stanislaw came up independently with the same patch by enforcing the C1E workaround and debugging the fallout. I picked mine, because mine has a changelog :) Reported-by: poma <pomidorabelisima@gmail.com> Debugged-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Olaf Hering <olaf@aepfle.de> Cc: Dave Jones <davej@redhat.com> Cc: Justin M. Forbes <jforbes@redhat.com> Cc: Josh Boyer <jwboyer@redhat.com> Link: http://lkml.kernel.org/r/alpine.DEB.2.02.1402111434180.21991@ionos.tec.linutronix.de Cc: stable@vger.kernel.org # 3.10+ Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-02-12Revert "cgroup: use an ordered workqueue for cgroup destruction"Tejun Heo
This reverts commit ab3f5faa6255a0eb4f832675507d9e295ca7e9ba. Explanation from Hugh: It's because more thorough testing, by others here, found that it wasn't always solving the problem: so I asked Tejun privately to hold off from sending it in, until we'd worked out why not. Most of our testing being on a v3,11-based kernel, it was perfectly possible that the problem was merely our own e.g. missing Tejun's 8a2b75384444 ("workqueue: fix ordered workqueues in NUMA setups"). But that turned out not to be enough to fix it either. Then Filipe pointed out how percpu_ref_kill_and_confirm() uses call_rcu_sched() before we ever get to put the offline on to the workqueue: by the time we get to the workqueue, the ordering has already been lost. So, thanks for the Acks, but I'm afraid that this ordered workqueue solution is just not good enough: we should simply forget that patch and provide a different answer." Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Hugh Dickins <hughd@google.com>
2014-02-11ring-buffer: Fix first commit on sub-buffer having non-zero deltaSteven Rostedt (Red Hat)
Each sub-buffer (buffer page) has a full 64 bit timestamp. The events on that page use a 27 bit delta against that timestamp in order to save on bits written to the ring buffer. If the time between events is larger than what the 27 bits can hold, a "time extend" event is added to hold the entire 64 bit timestamp again and the events after that hold a delta from that timestamp. As a "time extend" is always paired with an event, it is logical to just allocate the event with the time extend, to make things a bit more efficient. Unfortunately, when the pairing code was written, it removed the "delta = 0" from the first commit on a page, causing the events on the page to be slightly skewed. Fixes: 69d1b839f7ee "ring-buffer: Bind time extend and data events together" Cc: stable@vger.kernel.org # 2.6.37+ Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2014-02-11cgroup: protect modifications to cgroup_idr with cgroup_mutexLi Zefan
Setup cgroupfs like this: # mount -t cgroup -o cpuacct xxx /cgroup # mkdir /cgroup/sub1 # mkdir /cgroup/sub2 Then run these two commands: # for ((; ;)) { mkdir /cgroup/sub1/tmp && rmdir /mnt/sub1/tmp; } & # for ((; ;)) { mkdir /cgroup/sub2/tmp && rmdir /mnt/sub2/tmp; } & After seconds you may see this warning: ------------[ cut here ]------------ WARNING: CPU: 1 PID: 25243 at lib/idr.c:527 sub_remove+0x87/0x1b0() idr_remove called for id=6 which is not allocated. ... Call Trace: [<ffffffff8156063c>] dump_stack+0x7a/0x96 [<ffffffff810591ac>] warn_slowpath_common+0x8c/0xc0 [<ffffffff81059296>] warn_slowpath_fmt+0x46/0x50 [<ffffffff81300aa7>] sub_remove+0x87/0x1b0 [<ffffffff810f3f02>] ? css_killed_work_fn+0x32/0x1b0 [<ffffffff81300bf5>] idr_remove+0x25/0xd0 [<ffffffff810f2bab>] cgroup_destroy_css_killed+0x5b/0xc0 [<ffffffff810f4000>] css_killed_work_fn+0x130/0x1b0 [<ffffffff8107cdbc>] process_one_work+0x26c/0x550 [<ffffffff8107eefe>] worker_thread+0x12e/0x3b0 [<ffffffff81085f96>] kthread+0xe6/0xf0 [<ffffffff81570bac>] ret_from_fork+0x7c/0xb0 ---[ end trace 2d1577ec10cf80d0 ]--- It's because allocating/removing cgroup ID is not properly synchronized. The bug was introduced when we converted cgroup_ida to cgroup_idr. While synchronization is already done inside ida_simple_{get,remove}(), users are responsible for concurrent calls to idr_{alloc,remove}(). tj: Refreshed on top of b58c89986a77 ("cgroup: fix error return from cgroup_create()"). Fixes: 4e96ee8e981b ("cgroup: convert cgroup_ida to cgroup_idr") Cc: <stable@vger.kernel.org> #3.12+ Reported-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-02-11genirq: Add missing irq_to_desc export for CONFIG_SPARSE_IRQ=nPaul Gortmaker
In allmodconfig builds for sparc and any other arch which does not set CONFIG_SPARSE_IRQ, the following will be seen at modpost: CC [M] lib/cpu-notifier-error-inject.o CC [M] lib/pm-notifier-error-inject.o ERROR: "irq_to_desc" [drivers/gpio/gpio-mcp23s08.ko] undefined! make[2]: *** [__modpost] Error 1 This happens because commit 3911ff30f5 ("genirq: export handle_edge_irq() and irq_to_desc()") added one export for it, but there were actually two instances of it, in an if/else clause for CONFIG_SPARSE_IRQ. Add the second one. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Jiri Kosina <jkosina@suse.cz> Cc: stable@vger.kernel.org # 3.4+ Link: http://lkml.kernel.org/r/1392057610-11514-1-git-send-email-paul.gortmaker@windriver.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
