commit da48524eb20662618854bb3df2db01fc65f3070c upstream.
Userland should be able to trust the pid and uid of the sender of a
signal if the si_code is SI_TKILL.
Unfortunately, the kernel has historically allowed sigqueueinfo() to
send any si_code at all (as long as it was negative - to distinguish it
from kernel-generated signals like SIGILL etc), so it could spoof a
SI_TKILL with incorrect siginfo values.
Happily, it looks like glibc has always set si_code to the appropriate
SI_QUEUE, so there are probably no actual user code that ever uses
anything but the appropriate SI_QUEUE flag.
So just tighten the check for si_code (we used to allow any negative
value), and add a (one-time) warning in case there are binaries out
there that might depend on using other si_code values.
Signed-off-by: Julien Tinnes <jln@google.com>
Acked-by: Oleg Nesterov <oleg@redhat.com>
This reverts commit 6f197b73304b3bd3d5a43b931383a5331d6b2987, which was
originally commit a0f7d0f7fc02465bb9758501f611f63381792996 upstream.
This breaks the build, thanks to Jiri Slaby for pointing this out.
Reported-by: Jiri Slaby <jslaby@suse.cz>
commit 723aae25d5cdb09962901d36d526b44d4be1051c upstream.
Mike Galbraith reported finding a lockup ("perma-spin bug") where the
cpumask passed to smp_call_function_many was cleared by other cpu(s)
while a cpu was preparing its call_data block, resulting in no cpu to
clear the last ref and unlock the block.
Having cpus clear their bit asynchronously could be useful on a mask of
cpus that might have a translation context, or cpus that need a push to
complete an rcu window.
Instead of adding a BUG_ON and requiring yet another cpumask copy, just
detect the race and handle it.
Note: arch_send_call_function_ipi_mask must still handle an empty
cpumask because the data block is globally visible before the that arch
callback is made. And (obviously) there are no guarantees to which cpus
are notified if the mask is changed during the call; only cpus that were
online and had their mask bit set during the whole call are guaranteed
to be called.
Reported-by: Mike Galbraith <efault@gmx.de>
Reported-by: Jan Beulich <JBeulich@novell.com>
Acked-by: Jan Beulich <jbeulich@novell.com>
Signed-off-by: Milton Miller <miltonm@bga.com>
commit 45a5791920ae643eafc02e2eedef1a58e341b736 upstream.
Paul McKenney's review pointed out two problems with the barriers in the
2.6.38 update to the smp call function many code.
First, a barrier that would force the func and info members of data to
be visible before their consumption in the interrupt handler was
missing. This can be solved by adding a smp_wmb between setting the
func and info members and setting setting the cpumask; this will pair
with the existing and required smp_rmb ordering the cpumask read before
the read of refs. This placement avoids the need a second smp_rmb in
the interrupt handler which would be executed on each of the N cpus
executing the call request. (I was thinking this barrier was present
but was not).
Second, the previous write to refs (establishing the zero that we the
interrupt handler was testing from all cpus) was performed by a third
party cpu. This would invoke transitivity which, as a recient or
concurrent addition to memory-barriers.txt now explicitly states, would
require a full smp_mb().
However, we know the cpumask will only be set by one cpu (the data
owner) and any preivous iteration of the mask would have cleared by the
reading cpu. By redundantly writing refs to 0 on the owning cpu before
the smp_wmb, the write to refs will follow the same path as the writes
that set the cpumask, which in turn allows us to keep the barrier in the
interrupt handler a smp_rmb instead of promoting it to a smp_mb (which
will be be executed by N cpus for each of the possible M elements on the
list).
I moved and expanded the comment about our (ab)use of the rcu list
primitives for the concurrent walk earlier into this function. I
considered moving the first two paragraphs to the queue list head and
lock, but felt it would have been too disconected from the code.
Cc: Paul McKinney <paulmck@linux.vnet.ibm.com>
commit e6cd1e07a185d5f9b0aa75e020df02d3c1c44940 upstream.
Peter pointed out there was nothing preventing the list_del_rcu in
smp_call_function_interrupt from running before the list_add_rcu in
smp_call_function_many.
Fix this by not setting refs until we have gotten the lock for the list.
Take advantage of the wmb in list_add_rcu to save an explicit additional
one.
I tried to force this race with a udelay before the lock & list_add and
by mixing all 64 online cpus with just 3 random cpus in the mask, but
was unsuccessful. Still, inspection shows a valid race, and the fix is
a extension of the existing protection window in the current code.
Reported-by: Peter Zijlstra <peterz@infradead.org>
We toggle the state from start and stop callbacks but actually
don't check it when the event triggers. Do it so that
these callbacks actually work.
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Stephane Eranian <eranian@google.com>
LKML-Reference: <1299529629-18280-2-git-send-email-fweisbec@gmail.com>
commit 868baf07b1a259f5f3803c1dc2777b6c358f83cf upstream.
When the fuction graph tracer starts, it needs to make a special
stack for each task to save the real return values of the tasks.
All running tasks have this stack created, as well as any new
tasks.
On CPU hot plug, the new idle task will allocate a stack as well
when init_idle() is called. The problem is that cpu hotplug does
not create a new idle_task. Instead it uses the idle task that
existed when the cpu went down.
ftrace_graph_init_task() will add a new ret_stack to the task
that is given to it. Because a clone will make the task
have a stack of its parent it does not check if the task's
ret_stack is already NULL or not. When the CPU hotplug code
starts a CPU up again, it will allocate a new stack even
though one already existed for it.
The solution is to treat the idle_task specially. In fact, the
function_graph code already does, just not at init_idle().
Instead of using the ftrace_graph_init_task() for the idle task,
which that function expects the task to be a clone, have a
separate ftrace_graph_init_idle_task(). Also, we will create a
per_cpu ret_stack that is used by the idle task. When we call
ftrace_graph_init_idle_task() it will check if the idle task's
ret_stack is NULL, if it is, then it will assign it the per_cpu
ret_stack.
Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Suggested-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
commit b75f38d659e6fc747eda64cb72f3920e29dd44a4 upstream.
Don't forget to release cgroup_mutex if alloc_trial_cpuset() fails.
[akpm@linux-foundation.org: avoid multiple return points]
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
Cc: Paul Menage <menage@google.com>
Acked-by: David Rientjes <rientjes@google.com>
Cc: Miao Xie <miaox@cn.fujitsu.com>
commit 3a142a0672b48a853f00af61f184c7341ac9c99d upstream.
When the per cpu timer is marked CLOCK_EVT_FEAT_C3STOP, then we only
can switch into oneshot mode, when the backup broadcast device
supports oneshot mode as well. Otherwise we would try to switch the
broadcast device into an unsupported mode unconditionally. This went
unnoticed so far as the current available broadcast devices support
oneshot mode. Seth unearthed this problem while debugging and working
around an hpet related BIOS wreckage.
Add the necessary check to tick_is_oneshot_available().
Reported-and-tested-by: Seth Forshee <seth.forshee@canonical.com>
LKML-Reference: <alpine.LFD.2.00.1102252231200.2701@localhost6.localdomain6>
commit 6d83f94db95cfe65d2a6359cccdf61cf087c2598 upstream.
With CONFIG_SHIRQ_DEBUG=y we call a newly installed interrupt handler
in request_threaded_irq().
The original implementation (commit a304e1b8) called the handler
_BEFORE_ it was installed, but that caused problems with handlers
calling disable_irq_nosync(). See commit 377bf1e4.
It's braindead in the first place to call disable_irq_nosync in shared
handlers, but ....
Moving this call after we installed the handler looks innocent, but it
is very subtle broken on SMP.
Interrupt handlers rely on the fact, that the irq core prevents
reentrancy.
Now this debug call violates that promise because we run the handler
w/o the IRQ_INPROGRESS protection - which we cannot apply here because
that would result in a possibly forever masked interrupt line.
A concurrent real hardware interrupt on a different CPU results in
handler reentrancy and can lead to complete wreckage, which was
unfortunately observed in reality and took a fricking long time to
debug.
Leave the code here for now. We want this debug feature, but that's
not easy to fix. We really should get rid of those
disable_irq_nosync() abusers and remove that function completely.
Cc: Anton Vorontsov <avorontsov@ru.mvista.com>
Cc: Arjan van de Ven <arjan@infradead.org>
commit 2e725a065b0153f0c449318da1923a120477633d upstream.
Currently we return 0 in swsusp_alloc() when alloc_image_page() fails.
Fix that. Also remove unneeded "error" variable since the only
useful value of error is -ENOMEM.
[rjw: Fixed up the changelog and changed subject.]
Signed-off-by: Stanislaw Gruszka <stf_xl@wp.pl>
commit fb2b2a1d37f80cc818fd4487b510f4e11816e5e1 upstream.
In prepare_kernel_cred() since 2.6.29, put_cred(new) is called without
assigning new->usage when security_prepare_creds() returned an error. As a
result, memory for new and refcount for new->{user,group_info,tgcred} are
leaked because put_cred(new) won't call __put_cred() unless old->usage == 1.
Fix these leaks by assigning new->usage (and new->subscribers which was added
in 2.6.32) before calling security_prepare_creds().
commit 2edeaa34a6e3f2c43b667f6c4f7b27944b811695 upstream.
In cred_alloc_blank() since 2.6.32, abort_creds(new) is called with
new->security == NULL and new->magic == 0 when security_cred_alloc_blank()
returns an error. As a result, BUG() will be triggered if SELinux is enabled
or CONFIG_DEBUG_CREDENTIALS=y.
If CONFIG_DEBUG_CREDENTIALS=y, BUG() is called from __invalid_creds() because
cred->magic == 0. Failing that, BUG() is called from selinux_cred_free()
because selinux_cred_free() is not expecting cred->security == NULL. This does
not affect smack_cred_free(), tomoyo_cred_free() or apparmor_cred_free().
Fix these bugs by
(1) Set new->magic before calling security_cred_alloc_blank().
(2) Handle null cred->security in creds_are_invalid() and selinux_cred_free().
commit de09a9771a5346029f4d11e4ac886be7f9bfdd75 upstream.
It's possible for get_task_cred() as it currently stands to 'corrupt' a set of
credentials by incrementing their usage count after their replacement by the
task being accessed.
What happens is that get_task_cred() can race with commit_creds():
TASK_1 TASK_2 RCU_CLEANER
-->get_task_cred(TASK_2)
rcu_read_lock()
__cred = __task_cred(TASK_2)
-->commit_creds()
old_cred = TASK_2->real_cred
TASK_2->real_cred = ...
put_cred(old_cred)
call_rcu(old_cred)
[__cred->usage == 0]
get_cred(__cred)
[__cred->usage == 1]
rcu_read_unlock()
-->put_cred_rcu()
panic()
However, since a tasks credentials are generally not changed very often, we can
reasonably make use of a loop involving reading the creds pointer and using
atomic_inc_not_zero() to attempt to increment it if it hasn't already hit zero.
If successful, we can safely return the credentials in the knowledge that, even
if the task we're accessing has released them, they haven't gone to the RCU
cleanup code.
We then change task_state() in procfs to use get_task_cred() rather than
calling get_cred() on the result of __task_cred(), as that suffers from the
same problem.
Without this change, a BUG_ON in __put_cred() or in put_cred_rcu() can be
tripped when it is noticed that the usage count is not zero as it ought to be,
for example:
kernel BUG at kernel/cred.c:168!
invalid opcode: 0000 [#1] SMP
last sysfs file: /sys/kernel/mm/ksm/run
CPU 0
Pid: 2436, comm: master Not tainted 2.6.33.3-85.fc13.x86_64 #1 0HR330/OptiPlex
745
RIP: 0010:[<ffffffff81069881>] [<ffffffff81069881>] __put_cred+0xc/0x45
RSP: 0018:ffff88019e7e9eb8 EFLAGS: 00010202
RAX: 0000000000000001 RBX: ffff880161514480 RCX: 00000000ffffffff
RDX: 00000000ffffffff RSI: ffff880140c690c0 RDI: ffff880140c690c0
RBP: ffff88019e7e9eb8 R08: 00000000000000d0 R09: 0000000000000000
R10: 0000000000000001 R11: 0000000000000040 R12: ffff880140c690c0
R13: ffff88019e77aea0 R14: 00007fff336b0a5c R15: 0000000000000001
FS: 00007f12f50d97c0(0000) GS:ffff880007400000(0000) knlGS:0000000000000000
CR2: 00007f8f461bc000 CR3: 00000001b26ce000 CR4: 00000000000006f0
Process master (pid: 2436, threadinfo ffff88019e7e8000, task ffff88019e77aea0)
Stack:
ffff88019e7e9ec8 ffffffff810698cd ffff88019e7e9ef8 ffffffff81069b45
<0> ffff880161514180 ffff880161514480 ffff880161514180 0000000000000000
<0> ffff88019e7e9f28 ffffffff8106aace 0000000000000001 0000000000000246
Call Trace:
[<ffffffff810698cd>] put_cred+0x13/0x15
[<ffffffff81069b45>] commit_creds+0x16b/0x175
[<ffffffff8106aace>] set_current_groups+0x47/0x4e
[<ffffffff8106ac89>] sys_setgroups+0xf6/0x105
[<ffffffff81009b02>] system_call_fastpath+0x16/0x1b
Code: 48 8d 71 ff e8 7e 4e 15 00 85 c0 78 0b 8b 75 ec 48 89 df e8 ef 4a 15 00
48 83 c4 18 5b c9 c3 55 8b 07 8b 07 48 89 e5 85 c0 74 04 <0f> 0b eb fe 65 48 8b
04 25 00 cc 00 00 48 3b b8 58 04 00 00 75
RIP [<ffffffff81069881>] __put_cred+0xc/0x45
RSP <ffff88019e7e9eb8>
---[ end trace df391256a100ebdd ]---
Acked-by: Jiri Olsa <jolsa@redhat.com>
commit 571428be550fbe37160596995e96ad398873fcbd upstream.
free_user() releases uidhash_lock but was missing annotation. Add it.
This removes following sparse warnings:
include/linux/spinlock.h:339:9: warning: context imbalance in 'free_user' - unexpected unlock
kernel/user.c:120:6: warning: context imbalance in 'free_uid' - wrong count at exit
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
Cc: Dhaval Giani <dhaval.giani@gmail.com>
Signed-off-by: Mike Galbraith <efault@gmx.de>
commit 618765801ebc271fe0ba3eca99fcfd62a1f786e1 upstream.
This was left over from "7c9414385e sched: Remove USER_SCHED"
Acked-by: Dhaval Giani <dhaval.giani@gmail.com>
Cc: Kay Sievers <kay.sievers@vrfy.org>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
LKML-Reference: <20100315082148.GD18181@bicker>
Commit: e51fd5e22e12b39f49b1bb60b37b300b17378a43 upstream
Mike reports that since e9e9250b (sched: Scale down cpu_power due to RT
tasks), wake_affine() goes funny on RT tasks due to them still having a
!0 weight and wake_affine() still subtracts that from the rq weight.
Since nobody should be using se->weight for RT tasks, set the value to
zero. Also, since we now use ->cpu_power to normalize rq weights to
account for RT cpu usage, add that factor into the imbalance computation.
Tested-by: Mike Galbraith <efault@gmx.de>
LKML-Reference: <1275316109.27810.22969.camel@twins>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Commit: d5ad140bc1505a98c0f040937125bfcbb508078f upstream
An earlier commit reverts idle balancing throttling reset to fix a 30%
regression in volanomark throughput. We still need to reset idle_stamp
when we pull a task in newidle balance.
Reported-by: Alex Shi <alex.shi@intel.com>
Signed-off-by: Nikhil Rao <ncrao@google.com>
LKML-Reference: <1290022924-3548-1-git-send-email-ncrao@google.com>
Commit: b5482cfa1c95a188b3054fa33274806add91bbe5 upstream
Commit fab4762 triggers excessive idle balancing, causing a ~30% loss in
volanomark throughput. Remove idle balancing throttle reset.
Originally-by: Alex Shi <alex.shi@intel.com>
Acked-by: Nikhil Rao <ncrao@google.com>
LKML-Reference: <1289928732.5169.211.camel@maggy.simson.net>
Commit: 1e5a74059f9059d330744eac84873b1b99657008 upstream
Instead of dealing with sched classes inside each check_preempt_curr()
implementation, pull out this logic into the generic wakeup preemption
path.
This fixes a hang in KVM (and others) where we are waiting for the
stop machine thread to run ...
Reported-by: Markus Trippelsdorf <markus@trippelsdorf.de>
Tested-by: Marcelo Tosatti <mtosatti@redhat.com>
Tested-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
LKML-Reference: <1288891946.2039.31.camel@laptop>
Commit: aae6d3ddd8b90f5b2c8d79a2b914d1706d124193 upstream
Currently we consider a sched domain to be well balanced when the imbalance
is less than the domain's imablance_pct. As the number of cores and threads
are increasing, current values of imbalance_pct (for example 25% for a
NUMA domain) are not enough to detect imbalances like:
a) On a WSM-EP system (two sockets, each having 6 cores and 12 logical threads),
24 cpu-hogging tasks get scheduled as 13 on one socket and 11 on another
socket. Leading to an idle HT cpu.
b) On a hypothetial 2 socket NHM-EX system (each socket having 8 cores and
16 logical threads), 16 cpu-hogging tasks can get scheduled as 9 on one
socket and 7 on another socket. Leaving one core in a socket idle
whereas in another socket we have a core having both its HT siblings busy.
While this issue can be fixed by decreasing the domain's imbalance_pct
(by making it a function of number of logical cpus in the domain), it
can potentially cause more task migrations across sched groups in an
overloaded case.
Fix this by using imbalance_pct only during newly_idle and busy
load balancing. And during idle load balancing, check if there
is an imbalance in number of idle cpu's across the busiest and this
sched_group or if the busiest group has more tasks than its weight that
the idle cpu in this_group can pull.
Reported-by: Nikhil Rao <ncrao@google.com>
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
LKML-Reference: <1284760952.2676.11.camel@sbsiddha-MOBL3.sc.intel.com>
Commit: b2b5ce022acf5e9f52f7b78c5579994fdde191d4 upstream
Dima noticed that we fail to correct the ->vruntime of sleeping tasks
when we move them between cgroups.
Reported-by: Dima Zavin <dima@android.com>
LKML-Reference: <1287150604.29097.1513.camel@twins>
Commit: b7dadc38797584f6203386da1947ed5edf516646 upstream
KVM uses it for example:
ERROR: "account_system_vtime" [arch/x86/kvm/kvm.ko] undefined!
Cc: Venkatesh Pallipadi <venki@google.com>
LKML-Reference: <1286237003-12406-3-git-send-email-venki@google.com>
Commit: d267f87fb8179c6dba03d08b91952e81bc3723c7 upstream
When CPU is idle and on first interrupt, irq_enter calls tick_check_idle()
to notify interruption from idle. But, there is a problem if this call
is done after __irq_enter, as all routines in __irq_enter may find
stale time due to yet to be done tick_check_idle.
Specifically, trace calls in __irq_enter when they use global clock and also
account_system_vtime change in this patch as it wants to use sched_clock_cpu()
to do proper irq timing.
But, tick_check_idle was moved after __irq_enter intentionally to
prevent problem of unneeded ksoftirqd wakeups by the commit ee5f80a:
irq: call __irq_enter() before calling the tick_idle_check
Impact: avoid spurious ksoftirqd wakeups
Moving tick_check_idle() before __irq_enter and wrapping it with
local_bh_enable/disable would solve both the problems.
Fixed-by: Yong Zhang <yong.zhang0@gmail.com>
Signed-off-by: Venkatesh Pallipadi <venki@google.com>
LKML-Reference: <1286237003-12406-9-git-send-email-venki@google.com>
Commit: aa483808516ca5cacfa0e5849691f64fec25828e upstream
The idea was suggested by Peter Zijlstra here:
http://marc.info/?l=linux-kernel&m=127476934517534&w=2
irq time is technically not available to the tasks running on the CPU.
This patch removes irq time from CPU power piggybacking on
sched_rt_avg_update().
Tested this by keeping CPU X busy with a network intensive task having 75%
oa a single CPU irq processing (hard+soft) on a 4-way system. And start seven
cycle soakers on the system. Without this change, there will be two tasks on
each CPU. With this change, there is a single task on irq busy CPU X and
remaining 7 tasks are spread around among other 3 CPUs.
LKML-Reference: <1286237003-12406-8-git-send-email-venki@google.com>
Commit: 305e6835e05513406fa12820e40e4a8ecb63743c upstream
Scheduler accounts both softirq and interrupt processing times to the
currently running task. This means, if the interrupt processing was
for some other task in the system, then the current task ends up being
penalized as it gets shorter runtime than otherwise.
Change sched task accounting to acoount only actual task time from
currently running task. Now update_curr(), modifies the delta_exec to
depend on rq->clock_task.
Note that this change only handles CONFIG_IRQ_TIME_ACCOUNTING case. We can
extend this to CONFIG_VIRT_CPU_ACCOUNTING with minimal effort. But, thats
for later.
This change will impact scheduling behavior in interrupt heavy conditions.
Tested on a 4-way system with eth0 handled by CPU 2 and a network heavy
task (nc) running on CPU 3 (and no RSS/RFS). With that I have CPU 2
spending 75%+ of its time in irq processing. CPU 3 spending around 35%
time running nc task.
Now, if I run another CPU intensive task on CPU 2, without this change
/proc/<pid>/schedstat shows 100% of time accounted to this task. With this
change, it rightly shows less than 25% accounted to this task as remaining
time is actually spent on irq processing.
LKML-Reference: <1286237003-12406-7-git-send-email-venki@google.com>
Commit: b52bfee445d315549d41eacf2fa7c156e7d153d5 upstream
s390/powerpc/ia64 have support for CONFIG_VIRT_CPU_ACCOUNTING which does
the fine granularity accounting of user, system, hardirq, softirq times.
Adding that option on archs like x86 will be challenging however, given the
state of TSC reliability on various platforms and also the overhead it will
add in syscall entry exit.
Instead, add a lighter variant that only does finer accounting of
hardirq and softirq times, providing precise irq times (instead of timer tick
based samples). This accounting is added with a new config option
CONFIG_IRQ_TIME_ACCOUNTING so that there won't be any overhead for users not
interested in paying the perf penalty.
This accounting is based on sched_clock, with the code being generic.
So, other archs may find it useful as well.
This patch just adds the core logic and does not enable this logic yet.
LKML-Reference: <1286237003-12406-5-git-send-email-venki@google.com>
Commit: 6cdd5199daf0cb7b0fcc8dca941af08492612887 upstream
To account softirq time cleanly in scheduler, we need to identify whether
softirq is invoked in ksoftirqd context or softirq at hardirq tail context.
Add PF_KSOFTIRQD for that purpose.
As all PF flag bits are currently taken, create space by moving one of the
infrequently used bits (PF_THREAD_BOUND) down in task_struct to be along
with some other state fields.
LKML-Reference: <1286237003-12406-4-git-send-email-venki@google.com>
Commit: 75e1056f5c57050415b64cb761a3acc35d91f013 upstream
Peter Zijlstra found a bug in the way softirq time is accounted in
VIRT_CPU_ACCOUNTING on this thread:
http://lkml.indiana.edu/hypermail//linux/kernel/1009.2/01366.html
The problem is, softirq processing uses local_bh_disable internally. There
is no way, later in the flow, to differentiate between whether softirq is
being processed or is it just that bh has been disabled. So, a hardirq when bh
is disabled results in time being wrongly accounted as softirq.
Looking at the code a bit more, the problem exists in !VIRT_CPU_ACCOUNTING
as well. As account_system_time() in normal tick based accouting also uses
softirq_count, which will be set even when not in softirq with bh disabled.
Peter also suggested solution of using 2*SOFTIRQ_OFFSET as irq count
for local_bh_{disable,enable} and using just SOFTIRQ_OFFSET while softirq
processing. The patch below does that and adds API in_serving_softirq() which
returns whether we are currently processing softirq or not.
Also changes one of the usages of softirq_count in net/sched/cls_cgroup.c
to in_serving_softirq.
Looks like many usages of in_softirq really want in_serving_softirq. Those
changes can be made individually on a case by case basis.
LKML-Reference: <1286237003-12406-2-git-send-email-venki@google.com>
Commit: 75dd321d79d495a0ee579e6249ebc38ddbb2667f upstream
When SD_PREFER_SIBLING is set on a sched domain, drop group_capacity to 1
only if the local group has extra capacity. The extra check prevents the case
where you always pull from the heaviest group when it is already under-utilized
(possible with a large weight task outweighs the tasks on the system).
For example, consider a 16-cpu quad-core quad-socket machine with MC and NUMA
scheduling domains. Let's say we spawn 15 nice0 tasks and one nice-15 task,
and each task is running on one core. In this case, we observe the following
events when balancing at the NUMA domain:
- find_busiest_group() will always pick the sched group containing the niced
task to be the busiest group.
- find_busiest_queue() will then always pick one of the cpus running the
nice0 task (never picks the cpu with the nice -15 task since
weighted_cpuload > imbalance).
- The load balancer fails to migrate the task since it is the running task
and increments sd->nr_balance_failed.
- It repeats the above steps a few more times until sd->nr_balance_failed > 5,
at which point it kicks off the active load balancer, wakes up the migration
thread and kicks the nice 0 task off the cpu.
The load balancer doesn't stop until we kick out all nice 0 tasks from
the sched group, leaving you with 3 idle cpus and one cpu running the
nice -15 task.
When balancing at the NUMA domain, we drop sgs.group_capacity to 1 if the child
domain (in this case MC) has SD_PREFER_SIBLING set. Subsequent load checks are
not relevant because the niced task has a very large weight.
In this patch, we add an extra condition to the "if(prefer_sibling)" check in
update_sd_lb_stats(). We drop the capacity of a group only if the local group
has extra capacity, ie. nr_running < group_capacity. This patch preserves the
original intent of the prefer_siblings check (to spread tasks across the system
in low utilization scenarios) and fixes the case above.
It helps in the following ways:
- In low utilization cases (where nr_tasks << nr_cpus), we still drop
group_capacity down to 1 if we prefer siblings.
- On very busy systems (where nr_tasks >> nr_cpus), sgs.nr_running will most
likely be > sgs.group_capacity.
- When balancing large weight tasks, if the local group does not have extra
capacity, we do not pick the group with the niced task as the busiest group.
This prevents failed balances, active migration and the under-utilization
described above.
LKML-Reference: <1287173550-30365-5-git-send-email-ncrao@google.com>
Commit: fab476228ba37907ad75216d0fd9732ada9c119e upstream
This patch forces a load balance on a newly idle cpu when the local group has
extra capacity and the busiest group does not have any. It improves system
utilization when balancing tasks with a large weight differential.
Under certain situations, such as a niced down task (i.e. nice = -15) in the
presence of nr_cpus NICE0 tasks, the niced task lands on a sched group and
kicks away other tasks because of its large weight. This leads to sub-optimal
utilization of the machine. Even though the sched group has capacity, it does
not pull tasks because sds.this_load >> sds.max_load, and f_b_g() returns NULL.
With this patch, if the local group has extra capacity, we shortcut the checks
in f_b_g() and try to pull a task over. A sched group has extra capacity if the
group capacity is greater than the number of running tasks in that group.
Thanks to Mike Galbraith for discussions leading to this patch and for the
insight to reuse SD_NEWIDLE_BALANCE.
LKML-Reference: <1287173550-30365-4-git-send-email-ncrao@google.com>
Commit: 2582f0eba54066b5e98ff2b27ef0cfa833b59f54 upstream
When cycling through sched groups to determine the busiest group, set
group_imb only if the busiest cpu has more than 1 runnable task. This patch
fixes the case where two cpus in a group have one runnable task each, but there
is a large weight differential between these two tasks. The load balancer is
unable to migrate any task from this group, and hence do not consider this
group to be imbalanced.
LKML-Reference: <1286996978-7007-3-git-send-email-ncrao@google.com>
[ small code readability edits ]
Commit: ef8002f6848236de5adc613063ebeabddea8a6fb upstream
This patch adds a check in task_hot to return if the task has SCHED_IDLE
policy. SCHED_IDLE tasks have very low weight, and when run with regular
workloads, are typically scheduled many milliseconds apart. There is no
need to consider these tasks hot for load balancing.
LKML-Reference: <1287173550-30365-2-git-send-email-ncrao@google.com>
Commit: 6506cf6ce68d78a5470a8360c965dafe8e4b78e3 upstream
This addresses the following RCU lockdep splat:
[0.051203] CPU0: AMD QEMU Virtual CPU version 0.12.4 stepping 03
[0.052999] lockdep: fixing up alternatives.
[0.054105]
[0.054106] ===================================================
[0.054999] [ INFO: suspicious rcu_dereference_check() usage. ]
[0.054999] ---------------------------------------------------
[0.054999] kernel/sched.c:616 invoked rcu_dereference_check() without protection!
[0.054999]
[0.054999] other info that might help us debug this:
[0.054999]
[0.054999]
[0.054999] rcu_scheduler_active = 1, debug_locks = 1
[0.054999] 3 locks held by swapper/1:
[0.054999] #0: (cpu_add_remove_lock){+.+.+.}, at: [<ffffffff814be933>] cpu_up+0x42/0x6a
[0.054999] #1: (cpu_hotplug.lock){+.+.+.}, at: [<ffffffff810400d8>] cpu_hotplug_begin+0x2a/0x51
[0.054999] #2: (&rq->lock){-.-...}, at: [<ffffffff814be2f7>] init_idle+0x2f/0x113
[0.054999]
[0.054999] stack backtrace:
[0.054999] Pid: 1, comm: swapper Not tainted 2.6.35 #1
[0.054999] Call Trace:
[0.054999] [<ffffffff81068054>] lockdep_rcu_dereference+0x9b/0xa3
[0.054999] [<ffffffff810325c3>] task_group+0x7b/0x8a
[0.054999] [<ffffffff810325e5>] set_task_rq+0x13/0x40
[0.054999] [<ffffffff814be39a>] init_idle+0xd2/0x113
[0.054999] [<ffffffff814be78a>] fork_idle+0xb8/0xc7
[0.054999] [<ffffffff81068717>] ? mark_held_locks+0x4d/0x6b
[0.054999] [<ffffffff814bcebd>] do_fork_idle+0x17/0x2b
[0.054999] [<ffffffff814bc89b>] native_cpu_up+0x1c1/0x724
[0.054999] [<ffffffff814bcea6>] ? do_fork_idle+0x0/0x2b
[0.054999] [<ffffffff814be876>] _cpu_up+0xac/0x127
[0.054999] [<ffffffff814be946>] cpu_up+0x55/0x6a
[0.054999] [<ffffffff81ab562a>] kernel_init+0xe1/0x1ff
[0.054999] [<ffffffff81003854>] kernel_thread_helper+0x4/0x10
[0.054999] [<ffffffff814c353c>] ? restore_args+0x0/0x30
[0.054999] [<ffffffff81ab5549>] ? kernel_init+0x0/0x1ff
[0.054999] [<ffffffff81003850>] ? kernel_thread_helper+0x0/0x10
[0.056074] Booting Node 0, Processors #1lockdep: fixing up alternatives.
[0.130045] #2lockdep: fixing up alternatives.
[0.203089] #3 Ok.
[0.275286] Brought up 4 CPUs
[0.276005] Total of 4 processors activated (16017.17 BogoMIPS).
The cgroup_subsys_state structures referenced by idle tasks are never
freed, because the idle tasks should be part of the root cgroup,
which is not removable.
The problem is that while we do in-fact hold rq->lock, the newly spawned
idle thread's cpu is not yet set to the correct cpu so the lockdep check
in task_group():
lockdep_is_held(&task_rq(p)->lock)
will fail.
But this is a chicken and egg problem. Setting the CPU's runqueue requires
that the CPU's runqueue already be set. ;-)
So insert an RCU read-side critical section to avoid the complaint.
Commit: b0a0f667a349247bd7f05f806b662a25653822bc upstream
> /home/greearb/git/linux.wireless-testing/kernel/sched.c:618 invoked rcu_dereference_check() without protection!
> 1 lock held by ifup/23517:
> #0: (&rq->lock){-.-.-.}, at: [<c042f782>] task_fork_fair+0x3b/0x108
> stack backtrace:
> Pid: 23517, comm: ifup Not tainted 2.6.36-rc6-wl+ #5
> Call Trace:
> [<c075e219>] ? printk+0xf/0x16
> [<c0455842>] lockdep_rcu_dereference+0x74/0x7d
> [<c0426854>] task_group+0x6d/0x79
> [<c042686e>] set_task_rq+0xe/0x57
> [<c042f79e>] task_fork_fair+0x57/0x108
> [<c042e965>] sched_fork+0x82/0xf9
> [<c04334b3>] copy_process+0x569/0xe8e
> [<c0433ef0>] do_fork+0x118/0x262
> [<c076302f>] ? do_page_fault+0x16a/0x2cf
> [<c044b80c>] ? up_read+0x16/0x2a
> [<c04085ae>] sys_clone+0x1b/0x20
> [<c04030a5>] ptregs_clone+0x15/0x30
> [<c0402f1c>] ? sysenter_do_call+0x12/0x38
Here a newly created task is having its runqueue assigned. The new task
is not yet on the tasklist, so cannot go away. This is therefore a false
positive, suppress with an RCU read-side critical section.
Reported-by: Ben Greear <greearb@candelatech.com
Tested-by: Ben Greear <greearb@candelatech.com
Commit: b3bc211cfe7d5fe94b310480d78e00bea96fbf2a upstream
If a high priority task is waking up on a CPU that is running a
lower priority task that is bound to a CPU, see if we can move the
high RT task to another CPU first. Note, if all other CPUs are
running higher priority tasks than the CPU bounded current task,
then it will be preempted regardless.
Cc: Gregory Haskins <ghaskins@novell.com>
LKML-Reference: <20100921024138.888922071@goodmis.org>
Commit: 43fa5460fe60dea5c610490a1d263415419c60f6 upstream
When first working on the RT scheduler design, we concentrated on
keeping all CPUs running RT tasks instead of having multiple RT
tasks on a single CPU waiting for the migration thread to move
them. Instead we take a more proactive stance and push or pull RT
tasks from one CPU to another on wakeup or scheduling.
When an RT task wakes up on a CPU that is running another RT task,
instead of preempting it and killing the cache of the running RT
task, we look to see if we can migrate the RT task that is waking
up, even if the RT task waking up is of higher priority.
This may sound a bit odd, but RT tasks should be limited in
migration by the user anyway. But in practice, people do not do
this, which causes high prio RT tasks to bounce around the CPUs.
This becomes even worse when we have priority inheritance, because
a high prio task can block on a lower prio task and boost its
priority. When the lower prio task wakes up the high prio task, if
it happens to be on the same CPU it will migrate off of it.
But in reality, the above does not happen much either, because the
wake up of the lower prio task, which has already been boosted, if
it was on the same CPU as the higher prio task, it would then
migrate off of it. But anyway, we do not want to migrate them
either.
To examine the scheduling, I created a test program and examined it
under kernelshark. The test program created CPU * 2 threads, where
each thread had a different priority. The program takes different
options. The options used in this change log was to have priority
inheritance mutexes or not.
All threads did the following loop:
static void grab_lock(long id, int iter, int l)
ftrace_write("thread %ld iter %d, taking lock %d\n",
id, iter, l);
pthread_mutex_lock(&locks[l]);
ftrace_write("thread %ld iter %d, took lock %d\n",
id, iter, l);
busy_loop(nr_tasks - id);
ftrace_write("thread %ld iter %d, unlock lock %d\n",
id, iter, l);
pthread_mutex_unlock(&locks[l]);
void *start_task(void *id)
while (!done) {
for (l = 0; l < nr_locks; l++) {
grab_lock(id, i, l);
ftrace_write("thread %ld iter %d sleeping\n",
id, i);
ms_sleep(id);
i++;
The busy_loop(ms) keeps the CPU spinning for ms milliseconds. The
ms_sleep(ms) sleeps for ms milliseconds. The ftrace_write() writes
to the ftrace buffer to help analyze via ftrace.
The higher the id, the higher the prio, the shorter it does the
busy loop, but the longer it spins. This is usually the case with
RT tasks, the lower priority tasks usually run longer than higher
priority tasks.
At the end of the test, it records the number of loops each thread
took, as well as the number of voluntary preemptions, non-voluntary
preemptions, and number of migrations each thread took, taking the
information from /proc/$$/sched and /proc/$$/status.
Running this on a 4 CPU processor, the results without changes to
the kernel looked like this:
Task vol nonvol migrated iterations
0: 53 3220 1470 98
1: 562 773 724 98
2: 752 933 1375 98
3: 749 39 697 98
4: 758 5 515 98
5: 764 2 679 99
6: 761 2 535 99
7: 757 3 346 99
total: 5156 4977 6341 787
Each thread regardless of priority migrated a few hundred times.
The higher priority tasks, were a little better but still took
quite an impact.
By letting higher priority tasks bump the lower prio task from the
CPU, things changed a bit:
0: 37 2835 1937 98
1: 666 1821 1865 98
2: 654 1003 1385 98
3: 664 635 973 99
4: 698 197 352 99
5: 703 101 159 99
6: 708 1 75 99
7: 713 1 2 99
total: 4843 6594 6748 789
The total # of migrations did not change (several runs showed the
difference all within the noise). But we now see a dramatic
improvement to the higher priority tasks. (kernelshark showed that
the watchdog timer bumped the highest priority task to give it the
2 count. This was actually consistent with every run).
Notice that the # of iterations did not change either.
The above was with priority inheritance mutexes. That is, when the
higher prority task blocked on a lower priority task, the lower
priority task would inherit the higher priority task (which shows
why task 6 was bumped so many times). When not using priority
inheritance mutexes, the current kernel shows this:
0: 56 3101 1892 95
1: 594 713 937 95
2: 625 188 618 95
3: 628 4 491 96
4: 640 7 468 96
5: 631 2 501 96
6: 641 1 466 96
7: 643 2 497 96
total: 4458 4018 5870 765
Not much changed with or without priority inheritance mutexes. But
if we let the high priority task bump lower priority tasks on
wakeup we see:
0: 115 3439 2782 98
1: 633 1354 1583 99
2: 652 919 1218 99
3: 645 713 934 99
4: 690 3 3 99
5: 694 1 4 99
6: 720 3 4 99
7: 747 0 1 100
Which shows a even bigger change. The big difference between task 3
and task 4 is because we have only 4 CPUs on the machine, causing
the 4 highest prio tasks to always have preference.
Although I did not measure cache misses, and I'm sure there would
be little to measure since the test was not data intensive, I could
imagine large improvements for higher priority tasks when dealing
with lower priority tasks. Thus, I'm satisfied with making the
change and agreeing with what Gregory Haskins argued a few years
ago when we first had this discussion.
One final note. All tasks in the above tests were RT tasks. Any RT
task will always preempt a non RT task that is running on the CPU
the RT task wants to run on.
LKML-Reference: <20100921024138.605460343@goodmis.org>
Commit: 58b26c4c025778c09c7a1438ff185080e11b7d0a upstream
scheduler uses cache_nice_tries as an indicator to do cache_hot and
active load balance, when normal load balance fails. Currently,
this value is changed on any failed load balance attempt. That ends
up being not so nice to workloads that enter/exit idle often, as
they do more frequent new_idle balance and that pretty soon results
in cache hot tasks being pulled in.
Making the cache_nice_tries ignore failed new_idle balance seems to
make better sense. With that only the failed load balance in
periodic load balance gets accounted and the rate of accumulation
of cache_nice_tries will not depend on idle entry/exit (short
running sleep-wakeup kind of tasks). This reduces movement of
cache_hot tasks.
schedstat diff (after-before) excerpt from a workload that has
frequent and short wakeup-idle pattern (:2 in cpu col below refers
to NEWIDLE idx) This snapshot was across ~400 seconds.
Without this change:
domainstats: domain0
cpu cnt bln fld imb gain hgain nobusyq nobusyg
0:2 306487 219575 73167 110069413 44583 19070 1172 218403
1:2 292139 194853 81421 120893383 50745 21902 1259 193594
2:2 283166 174607 91359 129699642 54931 23688 1287 173320
3:2 273998 161788 93991 132757146 57122 24351 1366 160422
4:2 289851 215692 62190 83398383 36377 13680 851 214841
5:2 316312 222146 77605 117582154 49948 20281 988 221158
6:2 297172 195596 83623 122133390 52801 21301 929 194667
7:2 283391 178078 86378 126622761 55122 22239 928 177150
8:2 297655 210359 72995 110246694 45798 19777 1125 209234
9:2 297357 202011 79363 119753474 50953 22088 1089 200922
10:2 278797 178703 83180 122514385 52969 22726 1128 177575
11:2 272661 167669 86978 127342327 55857 24342 1195 166474
12:2 293039 204031 73211 110282059 47285 19651 948 203083
13:2 289502 196762 76803 114712942 49339 20547 1016 195746
14:2 264446 169609 78292 115715605 50459 21017 982 168627
15:2 260968 163660 80142 116811793 51483 21281 1064 162596
With this change:
0:2 272347 187380 77455 105420270 24975 1 953 186427
1:2 267276 172360 86234 116242264 28087 6 1028 171332
2:2 259769 156777 93281 123243134 30555 1 1043 155734
3:2 250870 143129 97627 127370868 32026 6 1188 141941
4:2 248422 177116 64096 78261112 22202 2 757 176359
5:2 275595 180683 84950 116075022 29400 6 778 179905
6:2 262418 162609 88944 119256898 31056 4 817 161792
7:2 252204 147946 92646 122388300 32879 4 824 147122
8:2 262335 172239 81631 110477214 26599 4 864 171375
9:2 261563 164775 88016 117203621 28331 3 849 163926
10:2 243389 140949 93379 121353071 29585 2 909 140040
11:2 242795 134651 98310 124768957 30895 2 1016 133635
12:2 255234 166622 79843 104696912 26483 4 746 165876
13:2 244944 151595 83855 109808099 27787 3 801 150794
14:2 241301 140982 89935 116954383 30403 6 845 140137
15:2 232271 128564 92821 119185207 31207 4 1416 127148
LKML-Reference: <1284167957-3675-1-git-send-email-venki@google.com>
Commit: da2b71edd8a7db44fe1746261410a981f3e03632 upstream
Currently sched_avg_update() (which updates rt_avg stats in the rq)
is getting called from scale_rt_power() (in the load balance context)
which doesn't take rq->lock.
Fix it by moving the sched_avg_update() to more appropriate
update_cpu_load() where the CFS load gets updated as well.
LKML-Reference: <1282596171.2694.3.camel@sbsiddha-MOBL3>
Commit: 32bd7eb5a7f4596c8440dd9440322fe9e686634d upstream
This is left over from commit 7c9414385e ("sched: Remove USER_SCHED"")
LKML-Reference: <4BA9A05F.7010407@cn.fujitsu.com>
Commit: 7c9414385ebfdd87cc542d4e7e3bb0dbb2d3ce25 upstream
Remove the USER_SCHED feature. It has been scheduled to be removed in
2.6.34 as per http://marc.info/?l=linux-kernel&m=125728479022976&w=2
[trace from referenced thread]
[1046577.884289] general protection fault: 0000 [#1] SMP
[1046577.911332] last sysfs file: /sys/devices/platform/coretemp.7/temp1_input
[1046577.938715] CPU 3
[1046577.965814] Modules linked in: ipt_REJECT xt_tcpudp iptable_filter ip_tables x_tables coretemp k8temp
[1046577.994456] Pid: 38, comm: events/3 Not tainted 2.6.32.27intel #1 X8DT3
[1046578.023166] RIP: 0010:[] [] sched_destroy_group+0x3c/0x10d
[1046578.052639] RSP: 0000:ffff88043e5abe10 EFLAGS: 00010097
[1046578.081360] RAX: ffff880139fa5540 RBX: ffff8803d18419c0 RCX: ffff8801d2f8fb78
[1046578.109903] RDX: dead000000200200 RSI: 0000000000000000 RDI: 0000000000000000
[1046578.109905] RBP: 0000000000000246 R08: 0000000000000020 R09: ffffffff816339b8
[1046578.109907] R10: 0000000004e6e5f0 R11: 0000000000000006 R12: ffffffff816339b8
[1046578.109909] R13: ffff8803d63ac4e0 R14: ffff88043e582340 R15: ffffffff8104a216
[1046578.109911] FS: 0000000000000000(0000) GS:ffff880028260000(0000) knlGS:0000000000000000
[1046578.109914] CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b
[1046578.109915] CR2: 00007f55ab220000 CR3: 00000001e5797000 CR4: 00000000000006e0
[1046578.109917] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[1046578.109919] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[1046578.109922] Process events/3 (pid: 38, threadinfo ffff88043e5aa000, task ffff88043e582340)
[1046578.109923] Stack:
[1046578.109924] ffff8803d63ac498 ffff8803d63ac4d8 ffff8803d63ac440 ffffffff8104a2c3
[1046578.109927] <0> ffff88043e5abef8 ffff880028276040 ffff8803d63ac4d8 ffffffff81050395
[1046578.109929] <0> ffff88043e582340 ffff88043e5826c8 ffff88043e582340 ffff88043e5abfd8
[1046578.109932] Call Trace:
[1046578.109938] [] ? cleanup_user_struct+0xad/0xcc
[1046578.109942] [] ? worker_thread+0x148/0x1d4
[1046578.109946] [] ? autoremove_wake_function+0x0/0x2e
[1046578.109948] [] ? worker_thread+0x0/0x1d4
[1046578.109951] [] ? kthread+0x79/0x81
[1046578.109955] [] ? child_rip+0xa/0x20
[1046578.109957] [] ? kthread+0x0/0x81
[1046578.109959] [] ? child_rip+0x0/0x20
[1046578.109961] Code: 3c 00 4c 8b 25 02 98 3d 00 48 89 c5 83 cf ff eb 5c 48 8b 43 10 48 63 f7 48 8b 04 f0 48 8b 90 80 00 00 00 48 8b 48 78 48 89 51 08 <48> 89 0a 48 b9 00 02 20 00 00 00 ad de 48 89 88 80 00 00 00 48
[1046578.109975] RIP [] sched_destroy_group+0x3c/0x10d
[1046578.109979] RSP
[1046578.109981] ---[ end trace 5ebc2944b7872d4a ]---
Signed-off-by: Dhaval Giani <dhaval.giani@gmail.com>
LKML-Reference: <1263990378.24844.3.camel@localhost>
LKML-Reference: http://marc.info/?l=linux-kernel&m=129466345327931
commit 6dc19899958e420a931274b94019e267e2396d3e upstream.
I noticed a failure where we hit the following WARN_ON in
generic_smp_call_function_interrupt:
if (!cpumask_test_and_clear_cpu(cpu, data->cpumask))
continue;
data->csd.func(data->csd.info);
refs = atomic_dec_return(&data->refs);
WARN_ON(refs < 0); <-------------------------
We atomically tested and cleared our bit in the cpumask, and yet the
number of cpus left (ie refs) was 0. How can this be?
It turns out commit 54fdade1c3332391948ec43530c02c4794a38172
("generic-ipi: make struct call_function_data lockless") is at fault. It
removes locking from smp_call_function_many and in doing so creates a
rather complicated race.
The problem comes about because:
- The smp_call_function_many interrupt handler walks call_function.queue
without any locking.
- We reuse a percpu data structure in smp_call_function_many.
- We do not wait for any RCU grace period before starting the next
Imagine a scenario where CPU A does two smp_call_functions back to back,
and CPU B does an smp_call_function in between. We concentrate on how CPU
C handles the calls:
CPU A CPU B CPU C CPU D
smp_call_function
walks
call_function.queue sees
data from CPU A on list
smp_call_function
walks
(stale) CPU A on list
smp_call_function int
clears last ref on A
list_del_rcu, unlock
smp_call_function reuses
percpu *data A
data->cpumask sees and
clears bit in cpumask
might be using old or new fn!
decrements refs below 0
set data->refs (too late!)
The important thing to note is since the interrupt handler walks a
potentially stale call_function.queue without any locking, then another
cpu can view the percpu *data structure at any time, even when the owner
is in the process of initialising it.
The following test case hits the WARN_ON 100% of the time on my PowerPC
box (having 128 threads does help :)
#include <linux/module.h>
#include <linux/init.h>
#define ITERATIONS 100
static void do_nothing_ipi(void *dummy)
static void do_ipis(struct work_struct *dummy)
int i;
for (i = 0; i < ITERATIONS; i++)
smp_call_function(do_nothing_ipi, NULL, 1);
printk(KERN_DEBUG "cpu %d finished\n", smp_processor_id());
static struct work_struct work[NR_CPUS];
static int __init testcase_init(void)
int cpu;
for_each_online_cpu(cpu) {
INIT_WORK(&work[cpu], do_ipis);
schedule_work_on(cpu, &work[cpu]);
return 0;
static void __exit testcase_exit(void)
module_init(testcase_init)
module_exit(testcase_exit)
MODULE_LICENSE("GPL");
MODULE_AUTHOR("Anton Blanchard");
I tried to fix it by ordering the read and the write of ->cpumask and
->refs. In doing so I missed a critical case but Paul McKenney was able
to spot my bug thankfully :) To ensure we arent viewing previous
iterations the interrupt handler needs to read ->refs then ->cpumask then
->refs _again_.
Thanks to Milton Miller and Paul McKenney for helping to debug this issue.
[miltonm@bga.com: add WARN_ON and BUG_ON, remove extra read of refs before initial read of mask that doesn't help (also noted by Peter Zijlstra), adjust comments, hopefully clarify scenario ]
[miltonm@bga.com: remove excess tests]
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
commit 01e05e9a90b8f4c3997ae0537e87720eb475e532 upstream.
The wake_up_process() call in ptrace_detach() is spurious and not
interlocked with the tracee state. IOW, the tracee could be running or
sleeping in any place in the kernel by the time wake_up_process() is
called. This can lead to the tracee waking up unexpectedly which can be
dangerous.
The wake_up is spurious and should be removed but for now reduce its
toxicity by only waking up if the tracee is in TRACED or STOPPED state.
This bug can possibly be used as an attack vector. I don't think it
will take too much effort to come up with an attack which triggers oops
somewhere. Most sleeps are wrapped in condition test loops and should
be safe but we have quite a number of places where sleep and wakeup
conditions are expected to be interlocked. Although the window of
opportunity is tiny, ptrace can be used by non-privileged users and with
some loading the window can definitely be extended and exploited.
Acked-by: Roland McGrath <roland@redhat.com>
commit e0a70217107e6f9844628120412cb27bb4cea194 upstream.
posix-cpu-timers.c correctly assumes that the dying process does
posix_cpu_timers_exit_group() and removes all !CPUCLOCK_PERTHREAD
timers from signal->cpu_timers list.
But, it also assumes that timer->it.cpu.task is always the group
leader, and thus the dead ->task means the dead thread group.
This is obviously not true after de_thread() changes the leader.
After that almost every posix_cpu_timer_ method has problems.
It is not simple to fix this bug correctly. First of all, I think
that timer->it.cpu should use struct pid instead of task_struct.
Also, the locking should be reworked completely. In particular,
tasklist_lock should not be used at all. This all needs a lot of
nontrivial and hard-to-test changes.
Change __exit_signal() to do posix_cpu_timers_exit_group() when
the old leader dies during exec. This is not the fix, just the
temporary hack to hide the problem for 2.6.37 and stable. IOW,
this is obviously wrong but this is what we currently have anyway:
cpu timers do not work after mt exec.
In theory this change adds another race. The exiting leader can
detach the timers which were attached to the new leader. However,
the window between de_thread() and release_task() is small, we
can pretend that sys_timer_create() was called before de_thread().
commit 364829b1263b44aa60383824e4c1289d83d78ca7 upstream.
The file_ops struct for the "trace" special file defined llseek as seq_lseek().
However, if the file was opened for writing only, seq_open() was not called,
and the seek would dereference a null pointer, file->private_data.
This patch introduces a new wrapper for seq_lseek() which checks if the file
descriptor is opened for reading first. If not, it does nothing.
Signed-off-by: Slava Pestov <slavapestov@google.com>
LKML-Reference: <1290640396-24179-1-git-send-email-slavapestov@google.com>
commit 1497dd1d29c6a53fcd3c80f7ac8d0e0239e7389e upstream.
The user-space hibernation sends a wrong notification after the image
restoration because of thinko for the file flag check. RDONLY
corresponds to hibernation and WRONLY to restoration, confusingly.
commit dbd87b5af055a0cc9bba17795c9a2b0d17795389 upstream.
This fixes a bug as seen on 2.6.32 based kernels where timers got
enqueued on offline cpus.
If a cpu goes offline it might still have pending timers. These will
be migrated during CPU_DEAD handling after the cpu is offline.
However while the cpu is going offline it will schedule the idle task
which will then call tick_nohz_stop_sched_tick().
That function in turn will call get_next_timer_intterupt() to figure
out if the tick of the cpu can be stopped or not. If it turns out that
the next tick is just one jiffy off (delta_jiffies == 1)
tick_nohz_stop_sched_tick() incorrectly assumes that the tick should
not stop and takes an early exit and thus it won't update the load
balancer cpu.
Just afterwards the cpu will be killed and the load balancer cpu could
be the offline cpu.
On 2.6.32 based kernel get_nohz_load_balancer() gets called to decide
on which cpu a timer should be enqueued (see __mod_timer()). Which
leads to the possibility that timers get enqueued on an offline cpu.
These will never expire and can cause a system hang.
This has been observed 2.6.32 kernels. On current kernels
__mod_timer() uses get_nohz_timer_target() which doesn't have that
problem. However there might be other problems because of the too
early exit tick_nohz_stop_sched_tick() in case a cpu goes offline.
The easiest and probably safest fix seems to be to let
get_next_timer_interrupt() just lie and let it say there isn't any
pending timer if the current cpu is offline.
I also thought of moving migrate_[hr]timers() from CPU_DEAD to
CPU_DYING, but seeing that there already have been fixes at least in
the hrtimer code in this area I'm afraid that this could add new
subtle bugs.
LKML-Reference: <20101201091109.GA8984@osiris.boeblingen.de.ibm.com>
commit 61ab25447ad6334a74e32f60efb135a3467223f8 upstream.
This patch fixes a hang observed with 2.6.32 kernels where timers got enqueued
on offline cpus.
printk_needs_cpu() may return 1 if called on offline cpus. When a cpu gets
offlined it schedules the idle process which, before killing its own cpu, will
call tick_nohz_stop_sched_tick(). That function in turn will call
printk_needs_cpu() in order to check if the local tick can be disabled. On
offline cpus this function should naturally return 0 since regardless if the
tick gets disabled or not the cpu will be dead short after. That is besides the
fact that __cpu_disable() should already have made sure that no interrupts on
the offlined cpu will be delivered anyway.
In this case it prevents tick_nohz_stop_sched_tick() to call
select_nohz_load_balancer(). No idea if that really is a problem. However what
made me debug this is that on 2.6.32 the function get_nohz_load_balancer() is
used within __mod_timer() to select a cpu on which a timer gets enqueued. If
printk_needs_cpu() returns 1 then the nohz_load_balancer cpu doesn't get
updated when a cpu gets offlined. It may contain the cpu number of an offline
cpu. In turn timers get enqueued on an offline cpu and not very surprisingly
they never expire and cause system hangs.
This has been observed 2.6.32 kernels. On current kernels __mod_timer() uses
get_nohz_timer_target() which doesn't have that problem. However there might be
other problems because of the too early exit tick_nohz_stop_sched_tick() in
Easiest way to fix this is just to test if the current cpu is offline and call
printk_tick() directly which clears the condition.
Alternatively I tried a cpu hotplug notifier which would clear the condition,
however between calling the notifier function and printk_needs_cpu() something
could have called printk() again and the problem is back again. This seems to
be the safest fix.
LKML-Reference: <20101126120235.406766476@de.ibm.com>
commit 33dd94ae1ccbfb7bf0fb6c692bc3d1c4269e6177 upstream.
If a user manages to trigger an oops with fs set to KERNEL_DS, fs is not
otherwise reset before do_exit(). do_exit may later (via mm_release in
fork.c) do a put_user to a user-controlled address, potentially allowing
a user to leverage an oops into a controlled write into kernel memory.
This is only triggerable in the presence of another bug, but this
potentially turns a lot of DoS bugs into privilege escalations, so it's
worth fixing. I have proof-of-concept code which uses this bug along
with CVE-2010-3849 to write a zero to an arbitrary kernel address, so
I've tested that this is not theoretical.
A more logical place to put this fix might be when we know an oops has
occurred, before we call do_exit(), but that would involve changing
every architecture, in multiple places.
Let's just stick it in do_exit instead.
[akpm@linux-foundation.org: update code comment]
Signed-off-by: Nelson Elhage <nelhage@ksplice.com>
commit 38715258aa2e8cd94bd4aafadc544e5104efd551 upstream.
Per task latencytop accumulator prematurely terminates due to erroneous
placement of latency_record_count. It should be incremented whenever a
new record is allocated instead of increment on every latencytop event.
Also fix search iterator to only search known record events instead of
blindly searching all pre-allocated space.
Signed-off-by: Ken Chen <kenchen@google.com>
Reviewed-by: Arjan van de Ven <arjan@infradead.org>
