commit c93d89f3dbf0202bf19c07960ca8602b48c2f9a0 upstream.
Export getboottime and monotonic_to_bootbased in order to let them
could be used by following patch.
Signed-off-by: Jason Wang <jasowang@redhat.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
commit 59647b6ac3050dd964bc556fe6ef22f4db5b935c upstream.
The WARN_ON in lookup_pi_state which complains about a mismatch
between pi_state->owner->pid and the pid which we retrieved from the
user space futex is completely bogus.
The code just emits the warning and then continues despite the fact
that it detected an inconsistent state of the futex. A conveniant way
for user space to spam the syslog.
Replace the WARN_ON by a consistency check. If the values do not match
return -EINVAL and let user space deal with the mess it created.
This also fixes the missing task_pid_vnr() when we compare the
pi_state->owner pid with the futex value.
Reported-by: Jermome Marchand <jmarchan@redhat.com>
Acked-by: Darren Hart <dvhltc@us.ibm.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
commit 51246bfd189064079c54421507236fd2723b18f3 upstream.
If the owner of a PI futex dies we fix up the pi_state and set
pi_state->owner to NULL. When a malicious or just sloppy programmed
user space application sets the futex value to 0 e.g. by calling
pthread_mutex_init(), then the futex can be acquired again. A new
waiter manages to enqueue itself on the pi_state w/o damage, but on
unlock the kernel dereferences pi_state->owner and oopses.
Prevent this by checking pi_state->owner in the unlock path. If
pi_state->owner is not current we know that user space manipulated the
futex value. Ignore the mess and return -EINVAL.
This catches the above case and also the case where a task hijacks the
futex by setting the tid value and then tries to unlock it.
commit 5ecb01cfdf96c5f465192bdb2a4fd4a61a24c6cc upstream.
This fixes a futex key reference count bug in futex_lock_pi(),
where a key's reference count is incremented twice but decremented
only once, causing the backing object to not be released.
If the futex is created in a temporary file in an ext3 file system,
this bug causes the file's inode to become an "undead" orphan,
which causes an oops from a BUG_ON() in ext3_put_super() when the
file system is unmounted. glibc's test suite is known to trigger this,
see <http://bugzilla.kernel.org/show_bug.cgi?id=14256>.
The bug is a regression from 2.6.28-git3, namely Peter Zijlstra's
38d47c1b7075bd7ec3881141bb3629da58f88dab "[PATCH] futex: rely on
get_user_pages() for shared futexes". That commit made get_futex_key()
also increment the reference count of the futex key, and updated its
callers to decrement the key's reference count before returning.
Unfortunately the normal exit path in futex_lock_pi() wasn't corrected:
the reference count is incremented by get_futex_key() and queue_lock(),
but the normal exit path only decrements once, via unqueue_me_pi().
The fix is to put_futex_key() after unqueue_me_pi(), since 2.6.31
this is easily done by 'goto out_put_key' rather than 'goto out'.
Signed-off-by: Mikael Pettersson <mikpe@it.uu.se>
This fixes the boot time oops on the 2.6.32-stable tree. It is needed
only in this tree due to the divergance from upstream.
commit b8a1d37c5f981cdd2e83c9fd98198832324cd57a upstream.
Free memory allocated using kmem_cache_zalloc using kmem_cache_free rather
than kfree.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
expression x,E,c;
x = \(kmem_cache_alloc\|kmem_cache_zalloc\|kmem_cache_alloc_node\)(c,...)
... when != x = E
when != &x
?-kfree(x)
+kmem_cache_free(c,x)
// </smpl>
Cc: Steve Dickson <steved@redhat.com>
Signed-off-by: James Morris <jmorris@namei.org>
commit a362c638bdf052bf424bce7645d39b101090f6ba upstream
Commit a9238ce3bb0fda6e760780b702c6cbd3793087d3 broke compilation on
platforms that do not implement GENERIC_TIME (e.g. iop32x):
kernel/time/clocksource.c: In function 'clocksource_register':
kernel/time/clocksource.c:556: error: implicit declaration of function 'clocksource_max_deferment'
Provide the implementation of clocksource_max_deferment() also for
such platforms.
Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi>
commit feae3203d711db0a9965300ee6d592257fdaae4f upstream.
Limit the number of per cpu calibration messages by only
printing out results for the first cpu to boot.
Also, don't print "CPUx is down" as this is expected, and we
don't need 4096 reminders... ;-)
Signed-off-by: Mike Travis <travis@sgi.com>
Cc: Roland Dreier <rdreier@cisco.com>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Cc: Tejun Heo <tj@kernel.org>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Cc: Yinghai Lu <yhlu.kernel@gmail.com>
Cc: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
Cc: Jack Steiner <steiner@sgi.com>
LKML-Reference: <20091118002219.889552000@alcatraz.americas.sgi.com>
commit 98962465ed9e6ea99c38e0af63fe1dcb5a79dc25 upstream.
The dynamic tick allows the kernel to sleep for periods longer than a
single tick, but it does not limit the sleep time currently. In the
worst case the kernel could sleep longer than the wrap around time of
the time keeping clock source which would result in losing track of
time.
Prevent this by limiting it to the safe maximum sleep time of the
current time keeping clock source. The value is calculated when the
clock source is registered.
[ tglx: simplified the code a bit and massaged the commit msg ]
Signed-off-by: Jon Hunter <jon-hunter@ti.com>
Cc: John Stultz <johnstul@us.ibm.com>
LKML-Reference: <1250617512-23567-2-git-send-email-jon-hunter@ti.com>
commit 0bcdcf28c979869f44e05121b96ff2cfb05bd8e6 upstream.
Based on Peter Zijlstras patch suggestion this enables recalculation of
the scheduler tunables in response of a change in the number of cpus. It
also adds a max of eight cpus that are considered in that scaling.
Signed-off-by: Christian Ehrhardt <ehrhardt@linux.vnet.ibm.com>
LKML-Reference: <1259579808-11357-2-git-send-email-ehrhardt@linux.vnet.ibm.com>
commit bdddd2963c0264c56f18043f6fa829d3c1d3d1c0 upstream.
Anton Blanchard wrote:
> We allocate and zero cpu_isolated_map after the isolcpus
> __setup option has run. This means cpu_isolated_map always
> ends up empty and if CPUMASK_OFFSTACK is enabled we write to a
> cpumask that hasn't been allocated.
I introduced this regression in 49557e620339cb13 (sched: Fix
boot crash by zalloc()ing most of the cpu masks).
Use the bootmem allocator if they set isolcpus=, otherwise
allocate and zero like normal.
Reported-by: Anton Blanchard <anton@samba.org>
Cc: peterz@infradead.org
Cc: <stable@kernel.org>
LKML-Reference: <200912021409.17013.rusty@rustcorp.com.au>
Tested-by: Anton Blanchard <anton@samba.org>
commit 8e1a928a2ed7e8d5cad97c8e985294b4caedd168 upstream.
Include "tick-internal.h" in order to pick up the extern function
prototype for clockevents_shutdown(). This quiets the following sparse
build noise:
warning: symbol 'clockevents_shutdown' was not declared. Should it be static?
LKML-Reference: <BD79186B4FD85F4B8E60E381CAEE190901E24550@mi8nycmail19.Mi8.com>
Reviewed-by: Yong Zhang <yong.zhang0@gmail.com>
Cc: johnstul@us.ibm.com
commit ea9d8e3f45404d411c00ae67b45cc35c58265bb7 upstream.
Marc reported that the BUG_ON in clockevents_notify() triggers on his
system. This happens because the kernel tries to remove an active
clock event device (used for broadcasting) from the device list.
The handling of devices which can be used as per cpu device and as a
global broadcast device is suboptimal.
The simplest solution for now (and for stable) is to check whether the
device is used as global broadcast device, but this needs to be
revisited.
[ tglx: restored the cpuweight check and massaged the changelog ]
Reported-by: Marc Dionne <marc.c.dionne@gmail.com>
Tested-by: Marc Dionne <marc.c.dionne@gmail.com>
Signed-off-by: Xiaotian Feng <dfeng@redhat.com>
LKML-Reference: <1262834564-13033-1-git-send-email-dfeng@redhat.com>
commit 22e190851f8709c48baf00ed9ce6144cdc54d025 upstream.
Anton reported that perf record kept receiving events even after calling
ioctl(PERF_EVENT_IOC_DISABLE). It turns out that FORK,COMM and MMAP
events didn't respect the disabled state and kept flowing in.
LKML-Reference: <1263459187.4244.265.camel@laptop>
events
commit 5d27c23df09b702868d9a3bff86ec6abd22963ac upstream.
Acme noticed that his FORK/MMAP numbers were inflated by about
the same factor as his cpu-count.
This led to the discovery of a few more sites that need to
respect the event->cpu filter.
Reported-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
LKML-Reference: <20091217121830.215333434@chello.nl>
commit 57785df5ac53c70da9fb53696130f3c551bfe1f9 upstream.
83f9ac removed a call to effective_prio() in wake_up_new_task(), which
leads to tasks running at MAX_PRIO.
This is caused by the idle thread being set to MAX_PRIO before forking
off init. O(1) used that to make sure idle was always preempted, CFS
uses check_preempt_curr_idle() for that so we can savely remove this bit
of legacy code.
Reported-by: Mike Galbraith <efault@gmx.de>
Tested-by: Mike Galbraith <efault@gmx.de>
LKML-Reference: <1259754383.4003.610.camel@laptop>
commit b9f8fcd55bbdb037e5332dbdb7b494f0b70861ac upstream.
Relax stable-sched-clock architectures to not save/disable/restore
hardirqs in cpu_clock().
The background is that I was trying to resolve a sparc64 perf
issue when I discovered this problem.
On sparc64 I implement pseudo NMIs by simply running the kernel
at IRQ level 14 when local_irq_disable() is called, this allows
performance counter events to still come in at IRQ level 15.
This doesn't work if any code in an NMI handler does
local_irq_save() or local_irq_disable() since the "disable" will
kick us back to cpu IRQ level 14 thus letting NMIs back in and
we recurse.
The only path which that does that in the perf event IRQ
handling path is the code supporting frequency based events. It
uses cpu_clock().
cpu_clock() simply invokes sched_clock() with IRQs disabled.
And that's a fundamental bug all on it's own, particularly for
the HAVE_UNSTABLE_SCHED_CLOCK case. NMIs can thus get into the
sched_clock() code interrupting the local IRQ disable code
sections of it.
Furthermore, for the not-HAVE_UNSTABLE_SCHED_CLOCK case, the IRQ
disabling done by cpu_clock() is just pure overhead and
completely unnecessary.
So the core problem is that sched_clock() is not NMI safe, but
we are invoking it from NMI contexts in the perf events code
(via cpu_clock()).
A less important issue is the overhead of IRQ disabling when it
isn't necessary in cpu_clock().
CONFIG_HAVE_UNSTABLE_SCHED_CLOCK architectures are not
affected by this patch.
LKML-Reference: <20091213.182502.215092085.davem@davemloft.net>
commit 7485d0d3758e8e6491a5c9468114e74dc050785d upstream.
Currently, futexes have two problem:
A) The current futex code doesn't handle private file mappings properly.
get_futex_key() uses PageAnon() to distinguish file and
anon, which can cause the following bad scenario:
1) thread-A call futex(private-mapping, FUTEX_WAIT), it
sleeps on file mapping object.
2) thread-B writes a variable and it makes it cow.
3) thread-B calls futex(private-mapping, FUTEX_WAKE), it
wakes up blocked thread on the anonymous page. (but it's nothing)
B) Current futex code doesn't handle zero page properly.
Read mode get_user_pages() can return zero page, but current
futex code doesn't handle it at all. Then, zero page makes
infinite loop internally.
The solution is to use write mode get_user_page() always for
page lookup. It prevents the lookup of both file page of private
mappings and zero page.
Performance concerns:
Probaly very little, because glibc always initialize variables
for futex before to call futex(). It means glibc users never see
the overhead of this patch.
Compatibility concerns:
This patch has few compatibility issues. After this patch,
FUTEX_WAIT require writable access to futex variables (read-only
mappings makes EFAULT). But practically it's not a problem,
glibc always initalizes variables for futexes explicitly - nobody
uses read-only mappings.
Reported-by: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Acked-by: Peter Zijlstra <peterz@infradead.org>
Cc: Nick Piggin <npiggin@suse.de>
Cc: Ulrich Drepper <drepper@gmail.com>
LKML-Reference: <20100105162633.45A2.A69D9226@jp.fujitsu.com>
commit d4703aefdbc8f9f347f6dcefcddd791294314eb7 upstream.
powerpc applies relocations to the kcrctab. They're absolute symbols,
but it's not completely unreasonable: other archs may too, but the
relocation is often 0.
http://lists.ozlabs.org/pipermail/linuxppc-dev/2009-November/077972.html
Inspired-by: Neil Horman <nhorman@tuxdriver.com>
Tested-by: Neil Horman <nhorman@tuxdriver.com>
Acked-by: Paul Mackerras <paulus@samba.org>
commit b4c30aad39805902cf5b855aa8a8b22d728ad057 upstream.
Several leaks in audit_tree didn't get caught by commit
318b6d3d7ddbcad3d6867e630711b8a705d873d7, including the leak on normal
exit in case of multiple rules refering to the same chunk.
commit 6f5d51148921c242680a7a1d9913384a30ab3cbe upstream.
... aka "Al had badly fscked up when writing that thing and nobody
noticed until Eric had fixed leaks that used to mask the breakage".
The function essentially creates a copy of old array sans one element
and replaces the references to elements of original (they are on cyclic
lists) with those to corresponding elements of new one. After that the
old one is fair game for freeing.
First of all, there's a dumb braino: when we get to list_replace_init we
use indices for wrong arrays - position in new one with the old array
and vice versa.
Another bug is more subtle - termination condition is wrong if the
element to be excluded happens to be the last one. We shouldn't go
until we fill the new array, we should go until we'd finished the old
one. Otherwise the element we are trying to kill will remain on the
cyclic lists...
That crap used to be masked by several leaks, so it was not quite
trivial to hit. Eric had fixed some of those leaks a while ago and the
shit had hit the fan...
Stable commit 0399123f3dcce1a515d021107ec0fb4413ca3efa didn't match the
original upstream commit. The CONFIG_MMU check was added much too early
in the list disabling a lot of proc entries in the process.
commit b45c6e76bc2c72f6426c14bed64fdcbc9bf37cb0 upstream.
When print-fatal-signals is enabled it's possible to dump any memory
reachable by the kernel to the log by simply jumping to that address from
user space.
Or crash the system if there's some hardware with read side effects.
The fatal signals handler will dump 16 bytes at the execution address,
which is fully controlled by ring 3.
In addition when something jumps to a unmapped address there will be up to
16 additional useless page faults, which might be potentially slow (and at
least is not very efficient)
Fortunately this option is off by default and only there on i386.
But fix it by checking for kernel addresses and also stopping when there's
a page fault.
commit bd4f490a079730aadfaf9a728303ea0135c01945 upstream.
The LTP cgroup test suite generates a "kernel BUG at kernel/cgroup.c:790!"
here in cgroup_diput():
* if we're getting rid of the cgroup, refcount should ensure
* that there are no pidlists left.
BUG_ON(!list_empty(&cgrp->pidlists));
The cgroup pidlist rework in 2.6.32 generates the BUG_ON, which is caused
when pidlist_array_load() calls cgroup_pidlist_find():
(1) if a matching cgroup_pidlist is found, it down_write's the mutex of the
pre-existing cgroup_pidlist, and increments its use_count.
(2) if no matching cgroup_pidlist is found, then a new one is allocated, it
down_write's its mutex, and the use_count is set to 0.
(3) the matching, or new, cgroup_pidlist gets returned back to pidlist_array_load(),
which increments its use_count -- regardless whether new or pre-existing --
and up_write's the mutex.
So if a matching list is ever encountered by cgroup_pidlist_find() during
the life of a cgroup directory, it results in an inflated use_count value,
preventing it from ever getting released by cgroup_release_pid_array().
Then if the directory is subsequently removed, cgroup_diput() hits the
BUG_ON() when it finds that the directory's cgroup is still populated with
a pidlist.
The patch simply removes the use_count increment when a matching pidlist
is found by cgroup_pidlist_find(), because it gets bumped by the calling
pidlist_array_load() function while still protected by the list's mutex.
Signed-off-by: Dave Anderson <anderson@redhat.com>
Reviewed-by: Li Zefan <lizf@cn.fujitsu.com>
Acked-by: Ben Blum <bblum@andrew.cmu.edu>
Cc: Paul Menage <menage@google.com>
commit 10b465aaf9536ee5a16652fa0700740183d48ec9 upstream.
Commit 35dead4 "modules: don't export section names of empty sections
via sysfs" changed the set of sections that have attributes, but did
not change the iteration over these attributes in add_notes_attrs().
This can lead to add_notes_attrs() creating attributes with the wrong
names or with null name pointers.
Introduce a sect_empty() function and use it in both add_sect_attrs()
and add_notes_attrs().
Reported-by: Martin Michlmayr <tbm@cyrius.com>
Tested-by: Martin Michlmayr <tbm@cyrius.com>
commit 047106adcc85e3023da210143a6ab8a55df9e0fc upstream.
Heiko reported a case where a timer interrupt managed to
reference a root_domain structure that was already freed by a
concurrent hot-un-plug operation.
Solve this like the regular sched_domain stuff is also
synchronized, by adding a synchronize_sched() stmt to the free
path, this ensures that a root_domain stays present for any
atomic section that could have observed it.
Reported-by: Heiko Carstens <heiko.carstens@de.ibm.com>
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com>
Cc: Gregory Haskins <ghaskins@novell.com>
Cc: Siddha Suresh B <suresh.b.siddha@intel.com>
LKML-Reference: <1258363873.26714.83.camel@laptop>
commit 6ad4c18884e864cf4c77f9074d3d1816063f99cd upstream.
Since (e761b77: cpu hotplug, sched: Introduce cpu_active_map and redo
sched domain managment) we have cpu_active_mask which is suppose to rule
scheduler migration and load-balancing, except it never (fully) did.
The particular problem being solved here is a crash in try_to_wake_up()
where select_task_rq() ends up selecting an offline cpu because
select_task_rq_fair() trusts the sched_domain tree to reflect the
current state of affairs, similarly select_task_rq_rt() trusts the
root_domain.
However, the sched_domains are updated from CPU_DEAD, which is after the
cpu is taken offline and after stop_machine is done. Therefore it can
race perfectly well with code assuming the domains are right.
Cure this by building the domains from cpu_active_mask on
CPU_DOWN_PREPARE.
LKML-Reference: <new-submission>
Cc: Holger Hoffstätte <holger.hoffstaette@googlemail.com>
sysctl_max_map_count-should-be-non-negative.patch
commit 3e26120cc7c819c97bc07281ca1fb9017cfe9a39 upstream.
It is a mistake that we used 'proc_dointvec', it should be
'proc_dointvec_minmax', as in the original patch.
Signed-off-by: WANG Cong <amwang@redhat.com>
commit 70da2340fbc68e91e701762f785479ab495a0869 upstream.
Jan Engelhardt reported we have this problem:
setting max_map_count to a value large enough results in programs dying at
first try. This is on 2.6.31.6:
15:59 borg:/proc/sys/vm # echo $[1<<31-1] >max_map_count
15:59 borg:/proc/sys/vm # cat max_map_count
1073741824
15:59 borg:/proc/sys/vm # echo $[1<<31] >max_map_count
Killed
This is because we have a chance to make 'max_map_count' negative. but
it's meaningless. Make it only accept non-negative values.
Reported-by: Jan Engelhardt <jengelh@medozas.de>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
commit 6e1415467614e854fee660ff6648bd10fa976e95 upstream.
In NOMMU mode clamp dac_mmap_min_addr to zero to cause the tests on it to be
skipped by the compiler. We do this as the minimum mmap address doesn't make
any sense in NOMMU mode.
mmap_min_addr and round_hint_to_min() can be discarded entirely in NOMMU mode.
Acked-by: Eric Paris <eparis@redhat.com>
commit bb6eddf7676e1c1f3e637aa93c5224488d99036f upstream.
Xiaotian Feng triggered a list corruption in the clock events list on
CPU hotplug and debugged the root cause.
If a CPU registers more than one per cpu clock event device, then only
the active clock event device is removed on CPU_DEAD. The unused
devices are kept in the clock events device list.
On CPU up the clock event devices are registered again, which means
that we list_add an already enqueued list_head. That results in list
corruption.
Resolve this by removing all devices which are associated to the dead
CPU on CPU_DEAD.
Reported-by: Xiaotian Feng <dfeng@redhat.com>
Tested-by: Xiaotian Feng <dfeng@redhat.com>
commit e4f4288842ee12747e10c354d72be7d424c0b627 upstream.
We should skip !SD_LOAD_BALANCE domains.
LKML-Reference: <20091216170517.653578430@chello.nl>
commit e6c8fba7771563b2f3dfb96a78f36ec17e15bdf0 upstream.
Make sure not to access sched_fair fields before verifying it is
indeed a sched_fair task.
LKML-Reference: <20091216170517.577998058@chello.nl>
commit 0f624e7e5625f4c30c836b7a5decfe2553582391 upstream.
It is quite legitimate for CPUs to be numbered sparsely, meaning
that it possible for an online CPU to have a number which is
greater than the total count of possible CPUs.
Currently find_get_context() has a sanity check on the cpu
number where it checks it against num_possible_cpus(). This
test can fail for a legitimate cpu number if the
cpu_possible_mask is sparsely populated.
This fixes the problem by checking the CPU number against
nr_cpumask_bits instead, since that is the appropriate check to
ensure that the cpu number is same to pass to cpu_isset()
subsequently.
Reported-by: Michael Neuling <mikey@neuling.org>
Tested-by: Michael Neuling <mikey@neuling.org>
LKML-Reference: <20091215084032.GA18661@brick.ozlabs.ibm.com>
commit 722d0172377a5697919b9f7e5beb95165b1dec4e upstream.
get_user_pages() must be called with mmap_sem held.
Cc: Andrew Morton <akpm@linuxfoundation.org>
Cc: Darren Hart <dvhltc@us.ibm.com>
LKML-Reference: <20091208121942.GA21298@basil.fritz.box>
commit 4b731d50ff3df6b9141a6c12b088e8eb0109e83c upstream.
commit d8e180dcd5bbbab9cd3ff2e779efcf70692ef541 "bsdacct: switch
credentials for writing to the accounting file" introduced credential
switching during final acct data collecting. However, uid/gid pair
continued to be collected from current which became credentials of who
created acct file, not who exits.
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=14676
Reported-by: Juho K. Juopperi <jkj@kapsi.fi>
Acked-by: Serge Hallyn <serue@us.ibm.com>
Reviewed-by: Michal Schmidt <mschmidt@redhat.com>
commit eae0c9dfb534cb3449888b9601228efa6480fdb5 upstream.
Commit 1b9508f, "Rate-limit newidle" has been confirmed to fix
the netperf UDP loopback regression reported by Alex Shi.
This is a cleanup and a fix:
- moved to a more out of the way spot
- fix to ensure that balancing doesn't try to balance
runqueues which haven't gone online yet, which can
mess up CPU enumeration during boot.
Reported-by: Alex Shi <alex.shi@intel.com>
Reported-by: Zhang, Yanmin <yanmin_zhang@linux.intel.com>
Signed-off-by: Mike Galbraith <efault@gmx.de>
LKML-Reference: <1257821402.5648.17.camel@marge.simson.net>
commit 1b9508f6831e10d53256825de8904caa22d1ca2c upstream.
Rate limit newidle to migration_cost. It's a win for all
stages of sysbench oltp tests.
commit fd210738f6601d0fb462df9a2fe5a41896ff6a8f upstream.
Ingo Molnar reported:
[ 26.804000] BUG: using smp_processor_id() in preemptible [00000000] code: events/1/10
[ 26.808000] caller is vmstat_update+0x26/0x70
[ 26.812000] Pid: 10, comm: events/1 Not tainted 2.6.32-rc5 #6887
[ 26.816000] Call Trace:
[ 26.820000] [<c1924a24>] ? printk+0x28/0x3c
[ 26.824000] [<c13258a0>] debug_smp_processor_id+0xf0/0x110
[ 26.824000] mount used greatest stack depth: 1464 bytes left
[ 26.828000] [<c111d086>] vmstat_update+0x26/0x70
[ 26.832000] [<c1086418>] worker_thread+0x188/0x310
[ 26.836000] [<c10863b7>] ? worker_thread+0x127/0x310
[ 26.840000] [<c108d310>] ? autoremove_wake_function+0x0/0x60
[ 26.844000] [<c1086290>] ? worker_thread+0x0/0x310
[ 26.848000] [<c108cf0c>] kthread+0x7c/0x90
[ 26.852000] [<c108ce90>] ? kthread+0x0/0x90
[ 26.856000] [<c100c0a7>] kernel_thread_helper+0x7/0x10
[ 26.860000] BUG: using smp_processor_id() in preemptible [00000000] code: events/1/10
[ 26.864000] caller is vmstat_update+0x3c/0x70
Because this commit:
a1f84a3: sched: Check for an idle shared cache in select_task_rq_fair()
broke ->cpus_allowed.
Cc: arjan@infradead.org
LKML-Reference: <1257415066.12867.1.camel@marge.simson.net>
commit a1f84a3ab8e002159498814eaa7e48c33752b04b upstream.
When waking affine, check for an idle shared cache, and if
found, wake to that CPU/sibling instead of the waker's CPU.
This improves pgsql+oltp ramp up by roughly 8%. Possibly more
for other loads, depending on overlap. The trade-off is a
roughly 1% peak downturn if tasks are truly synchronous.
Cc: Arjan van de Ven <arjan@infradead.org>
LKML-Reference: <1256654138.17752.7.camel@marge.simson.net>
commit ec70ccd806111ba3caf596def91a8580138b12db upstream.
In the CONFIG_PERF_USE_VMALLOC case, perf_mmap_data_free() only
schedules the cleanup of the perf_mmap_data struct. In that
case we have to wait until the work has been done before we free
data.
Signed-off-by: Kristian Høgsberg <krh@bitplanet.net>
LKML-Reference: <1259697901-1747-1-git-send-email-krh@bitplanet.net>
commit 59d069eb5ae9b033ed1c124c92e1532c4a958991 upstream.
In current code in perf_swevent_hrtimer(), data.period is not
initialized, The result is obvious wrong:
# ./perf record -f -e cpu-clock make
# ./perf report
# Samples: 1740
# Overhead Command ......
1025422183050275328.00% sh libc-2.9.90.so ...
1025422183050275328.00% perl libperl.so ...
1025422168240043264.00% perl [kernel] ...
1025422030011210752.00% perl [kernel] ...
Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com>
LKML-Reference: <4B14E220.2050107@cn.fujitsu.com>
commit dbe01350fa8ce0c11948ab7d6be71a4d901be151 upstream.
Some variants of gcc are reputed to dislike forward references
to functions declared "inline". Remove the "inline" keyword
from such functions.
Cc: laijs@cn.fujitsu.com
Cc: dipankar@in.ibm.com
Cc: mathieu.desnoyers@polymtl.ca
Cc: josh@joshtriplett.org
Cc: dvhltc@us.ibm.com
Cc: niv@us.ibm.com
Cc: rostedt@goodmis.org
Cc: Valdis.Kletnieks@vt.edu
Cc: dhowells@redhat.com
Cc: Benjamin Gilbert <bgilbert@cs.cmu.edu>
LKML-Reference: <12578890422402-git-send-email->
commit 9160306e6f5b68bb64630c9031c517ca1cf463db upstream.
Impose a clear locking design on the note_new_gpnum()
function's use of the ->gpnum counter. This is done by updating
rdp->gpnum only from the corresponding leaf rcu_node structure's
rnp->gpnum field, and even then only under the protection of
that same rcu_node structure's ->lock field. Performance and
scalability are maintained using a form of double-checked
locking, and excessive spinning is avoided by use of the
spin_trylock() function. The use of spin_trylock() is safe due
to the fact that CPUs who fail to acquire this lock will try
again later. The hierarchical nature of the rcu_node data
structure limits contention (which could be limited further if
need be using the RCU_FANOUT kernel parameter).
Without this patch, obscure but quite possible races could
result in a quiescent state that occurred during one grace
period to be accounted to the following grace period, causing
this following grace period to end prematurely. Not good!
Cc: niv@us.ibm.com
LKML-Reference: <12571987492350-git-send-email->
commit d09b62dfa336447c52a5ec9bb88adbc479b0f3b8 upstream.
Impose a clear locking design on the rcu_process_gp_end()
function's use of the ->completed counter. This is done by
creating a ->completed field in the rcu_node structure, which
can safely be accessed under the protection of that structure's
lock. Performance and scalability are maintained by using a
form of double-checked locking, so that rcu_process_gp_end()
only acquires the leaf rcu_node structure's ->lock if a grace
period has recently ended.
This fix reduces rcutorture failure rate by at least two orders
of magnitude under heavy stress with force_quiescent_state()
being invoked artificially often. Without this fix,
unsynchronized access to the ->completed field can cause
rcu_process_gp_end() to advance callbacks whose grace period has
not yet expired. (Bad idea!)
Cc: niv@us.ibm.com
LKML-Reference: <12571987494069-git-send-email->
->completed counter
commit 281d150c5f8892f158747594ab49ce2823fd8b8c upstream.
Impose a clear locking design on non-NO_HZ handling of the
->completed counter. This increases the distance between the
RCU and the CPU-hotplug mechanisms.
Cc: niv@us.ibm.com
LKML-Reference: <12571987491353-git-send-email->
On the parisc architecture we face for each and every loaded kernel module
this kernel "badness warning":
sysfs: cannot create duplicate filename '/module/ac97_bus/sections/.text'
Badness at fs/sysfs/dir.c:487
Reason for that is, that on parisc all kernel modules do have multiple
.text sections due to the usage of the -ffunction-sections compiler flag
which is needed to reach all jump targets on this platform.
An objdump on such a kernel module gives:
Sections:
Idx Name Size VMA LMA File off Algn
0 .note.gnu.build-id 00000024 00000000 00000000 00000034 2**2
CONTENTS, ALLOC, LOAD, READONLY, DATA
1 .text 00000000 00000000 00000000 00000058 2**0
CONTENTS, ALLOC, LOAD, READONLY, CODE
2 .text.ac97_bus_match 0000001c 00000000 00000000 00000058 2**2
3 .text 00000000 00000000 00000000 000000d4 2**0
Since the .text sections are empty (size of 0 bytes) and won't be
loaded by the kernel module loader anyway, I don't see a reason
why such sections need to be listed under
/sys/module/<module_name>/sections/<section_name> either.
The attached patch does solve this issue by not exporting section
names which are empty.
This fixes bugzilla http://bugzilla.kernel.org/show_bug.cgi?id=14703
Signed-off-by: Helge Deller <deller@gmx.de>
CC: rusty@rustcorp.com.au
CC: akpm@linux-foundation.org
CC: James.Bottomley@HansenPartnership.com
CC: roland@redhat.com
CC: dave@hiauly1.hia.nrc.ca
Move slow_work's debugging proc file to debugfs.
Requested-and-acked-by: Ingo Molnar <mingo@elte.hu>
Commits 3d7a641 ("SLOW_WORK: Wait for outstanding work items belonging to a
module to clear") introduced some code to make sure that all of a module's
slow-work items were complete before that module was removed, and commit
3bde31a ("SLOW_WORK: Allow a requeueable work item to sleep till the thread is
needed") further extended that, breaking it in the process if CONFIG_MODULES=n:
CC kernel/slow-work.o
kernel/slow-work.c: In function 'slow_work_execute':
kernel/slow-work.c:313: error: 'slow_work_thread_processing' undeclared (first use in this function)
kernel/slow-work.c:313: error: (Each undeclared identifier is reported only once
kernel/slow-work.c:313: error: for each function it appears in.)
kernel/slow-work.c: In function 'slow_work_wait_for_items':
kernel/slow-work.c:950: error: 'slow_work_unreg_sync_lock' undeclared (first use in this function)
kernel/slow-work.c:951: error: 'slow_work_unreg_wq' undeclared (first use in this function)
kernel/slow-work.c:961: error: 'slow_work_unreg_work_item' undeclared (first use in this function)
kernel/slow-work.c:974: error: 'slow_work_unreg_module' undeclared (first use in this function)
kernel/slow-work.c:977: error: 'slow_work_thread_processing' undeclared (first use in this function)
make[1]: *** [kernel/slow-work.o] Error 1
Fix this by:
(1) Extracting the bits of slow_work_execute() that are contingent on
CONFIG_MODULES, and the bits that should be, into inline functions and
placing them into the #ifdef'd section that defines the relevant variables
and adding stubs for moduleless kernels. This allows the removal of some
#ifdefs.
(2) #ifdef'ing out the contents of slow_work_wait_for_items() in moduleless
kernels.
The four functions related to handling module unloading synchronisation (and
their associated variables) could be offloaded into a separate .c file, but
each function is only used once and three of them are tiny, so doing so would
prevent them from being inlined.
Reported-by: Ingo Molnar <mingo@elte.hu>
Add a function to allow a requeueable work item to sleep till the thread
processing it is needed by the slow-work facility to perform other work.
Sometimes a work item can't progress immediately, but must wait for the
completion of another work item that's currently being processed by another
slow-work thread.
In some circumstances, the waiting item could instead - theoretically - put
itself back on the queue and yield its thread back to the slow-work facility,
thus waiting till it gets processing time again before attempting to progress.
This would allow other work items processing time on that thread.
However, this only works if there is something on the queue for it to queue
behind - otherwise it will just get a thread again immediately, and will end
up cycling between the queue and the thread, eating up valuable CPU time.
So, slow_work_sleep_till_thread_needed() is provided such that an item can put
itself on a wait queue that will wake it up when the event it is actually
interested in occurs, then call this function in lieu of calling schedule().
This function will then sleep until either the item's event occurs or another
work item appears on the queue. If another work item is queued, but the
item's event hasn't occurred, then the work item should requeue itself and
yield the thread back to the slow-work facility by returning.
This can be used by CacheFiles for an object that is being created on one
thread to wait for an object being deleted on another thread where there is
nothing on the queue for the creation to go and wait behind. As soon as an
item appears on the queue that could be given thread time instead, CacheFiles
can stick the creating object back on the queue and return to the slow-work
facility - assuming the object deletion didn't also complete.
