path: root/lib/Kconfig.debug
2011-07-22Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (24 commits) sched: Cleanup duplicate local variable in [enqueue|dequeue]_task_fair sched: Replace use of entity_key() sched: Separate group-scheduling code more clearly sched: Reorder root_domain to remove 64 bit alignment padding sched: Do not attempt to destroy uninitialized rt_bandwidth sched: Remove unused function cpu_cfs_rq() sched: Fix (harmless) typo 'CONFG_FAIR_GROUP_SCHED' sched, cgroup: Optimize load_balance_fair() sched: Don't update shares twice on on_rq parent sched: update correct entity's runtime in check_preempt_wakeup() xtensa: Use generic config PREEMPT definition h8300: Use generic config PREEMPT definition m32r: Use generic PREEMPT config sched: Skip autogroup when looking for all rt sched groups sched: Simplify mutex_spin_on_owner() sched: Remove rcu_read_lock() from wake_affine() sched: Generalize sleep inside spinlock detection sched: Make sleeping inside spinlock detection working in !CONFIG_PREEMPT sched: Isolate preempt counting in its own config option sched: Remove pointless in_atomic() definition check ...
2011-07-05lockup detector: Fix reference to the non-existent CONFIG_DETECT_SOFTLOCKUP ↵Anton Blanchard
option Replace CONFIG_DETECT_SOFTLOCKUP with CONFIG_LOCKUP_DETECTOR. Signed-off-by: Anton Blanchard <anton@samba.org> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Cc: fweisbec@gmail.com Cc: a.p.zijlstra@chello.nl Link: http://lkml.kernel.org/r/20110705133240.25e81a7a@kryten Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-01Merge branch 'sched/core-v2' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing into sched/core
2011-06-23sched: Generalize sleep inside spinlock detectionFrederic Weisbecker
The sleeping inside spinlock detection is actually used for more general sleeping inside atomic sections debugging: preemption disabled, rcu read side critical sections, interrupts, interrupt disabled, etc... Change the name of the config and its help section to reflect its more general role. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Ingo Molnar <mingo@elte.hu>
2011-06-10sched: Make sleeping inside spinlock detection working in !CONFIG_PREEMPTFrederic Weisbecker
Select CONFIG_PREEMPT_COUNT when we enable the sleeping inside spinlock detection, so that the preempt offset gets correctly incremented/decremented from preempt_disable()/preempt_enable(). This makes the preempt count eventually working in !CONFIG_PREEMPT when that debug option is set and thus fixes the detection of explicit preemption disabled sections under such config. Code that sleeps in explicitly preempt disabled section can be finally spotted in non-preemptible kernels. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl>
2011-06-01tile: enable CONFIG_BUGVERBOSEChris Metcalf
Trivial config change to enable backtraces on panic. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2011-05-25lib: consolidate DEBUG_STACK_USAGE optionStephen Boyd
Most arches define CONFIG_DEBUG_STACK_USAGE exactly the same way. Move it to lib/Kconfig.debug so each arch doesn't have to define it. This obviously makes the option generic, but that's fine because the config is already used in generic code. It's not obvious to me that sysrq-P actually does anything caution by keeping the most inclusive wording. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Cc: Chris Metcalf <cmetcalf@tilera.com> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Richard Weinberger <richard@nod.at> Acked-by: Mike Frysinger <vapier@gentoo.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Hirokazu Takata <takata@linux-m32r.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25lib: consolidate DEBUG_PER_CPU_MAPSStephen Boyd
DEBUG_PER_CPU_MAPS is used in lib/cpumask.c as well as in inlcude/linux/cpumask.h and thus it has outgrown its use within x86 and powerpc alone. Any arch with SMP support may want to get some more debugging, so make this option generic. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Cc: <linux-arch@vger.kernel.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) b43: fix comment typo reqest -> request Haavard Skinnemoen has left Atmel cris: typo in mach-fs Makefile Kconfig: fix copy/paste-ism for dell-wmi-aio driver doc: timers-howto: fix a typo ("unsgined") perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course'). treewide: fix a few typos in comments regulator: change debug statement be consistent with the style of the rest Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations" audit: acquire creds selectively to reduce atomic op overhead rtlwifi: don't touch with treewide double semicolon removal treewide: cleanup continuations and remove logging message whitespace ath9k_hw: don't touch with treewide double semicolon removal include/linux/leds-regulator.h: fix syntax in example code tty: fix typo in descripton of tty_termios_encode_baud_rate xtensa: remove obsolete BKL kernel option from defconfig m68k: fix comment typo 'occcured' arch:Kconfig.locks Remove unused config option. treewide: remove extra semicolons ...
2011-05-19Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (78 commits) Revert "rcu: Decrease memory-barrier usage based on semi-formal proof" net,rcu: convert call_rcu(prl_entry_destroy_rcu) to kfree batman,rcu: convert call_rcu(softif_neigh_free_rcu) to kfree_rcu batman,rcu: convert call_rcu(neigh_node_free_rcu) to kfree() batman,rcu: convert call_rcu(gw_node_free_rcu) to kfree_rcu net,rcu: convert call_rcu(kfree_tid_tx) to kfree_rcu() net,rcu: convert call_rcu(xt_osf_finger_free_rcu) to kfree_rcu() net/mac80211,rcu: convert call_rcu(work_free_rcu) to kfree_rcu() net,rcu: convert call_rcu(wq_free_rcu) to kfree_rcu() net,rcu: convert call_rcu(phonet_device_rcu_free) to kfree_rcu() perf,rcu: convert call_rcu(swevent_hlist_release_rcu) to kfree_rcu() perf,rcu: convert call_rcu(free_ctx) to kfree_rcu() net,rcu: convert call_rcu(__nf_ct_ext_free_rcu) to kfree_rcu() net,rcu: convert call_rcu(net_generic_release) to kfree_rcu() net,rcu: convert call_rcu(netlbl_unlhsh_free_addr6) to kfree_rcu() net,rcu: convert call_rcu(netlbl_unlhsh_free_addr4) to kfree_rcu() security,rcu: convert call_rcu(sel_netif_free) to kfree_rcu() net,rcu: convert call_rcu(xps_dev_maps_release) to kfree_rcu() net,rcu: convert call_rcu(xps_map_release) to kfree_rcu() net,rcu: convert call_rcu(rps_map_release) to kfree_rcu() ...
2011-05-19Merge branch 'core-locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: seqlock: Don't smp_rmb in seqlock reader spin loop watchdog, hung_task_timeout: Add Kconfig configurable default lockdep: Remove cmpxchg to update nr_chain_hlocks lockdep: Print a nicer description for simple irq lock inversions lockdep: Replace "Bad BFS generated tree" message with something less cryptic lockdep: Print a nicer description for irq inversion bugs lockdep: Print a nicer description for simple deadlocks lockdep: Print a nicer description for normal deadlocks lockdep: Print a nicer description for irq lock inversions
2011-05-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-2.6-cm * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-2.6-cm: kmemleak: Initialise kmemleak after debug_objects_mem_init() kmemleak: Select DEBUG_FS unconditionally in DEBUG_KMEMLEAK kmemleak: Do not return a pointer to an object that kmemleak did not get
2011-05-19kmemleak: Select DEBUG_FS unconditionally in DEBUG_KMEMLEAKCatalin Marinas
In the past DEBUG_FS used to depend on SYSFS and DEBUG_KMEMLEAK selected it conditionally. This is no longer the case, so always select DEBUG_FS via DEBUG_KMEMLEAK. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com>
2011-05-19MIPS: Enable kmemleak for MIPSMaxin John
Signed-off-by: Maxin B. John <maxin.john@gmail.com> To: Catalin Marinas <catalin.marinas@arm.com> Cc: Daniel Baluta <dbaluta@ixiacom.com> Cc: naveen yadav <yad.naveen@gmail.com> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Cc: linux-mm@kvack.org Patchwork: https://patchwork.linux-mips.org/patch/2244/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-05rcu: Enable DEBUG_OBJECTS_RCU_HEAD from !PREEMPTMathieu Desnoyers
The prohibition of DEBUG_OBJECTS_RCU_HEAD from !PREEMPT was due to the fixup actions. So just produce a warning from !PREEMPT. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-05-05rcu: Remove conditional compilation for RCU CPU stall warningsPaul E. McKenney
The RCU CPU stall warnings can now be controlled using the rcu_cpu_stall_suppress boot-time parameter or via the same parameter from sysfs. There is therefore no longer any reason to have kernel config parameters for this feature. This commit therefore removes the RCU_CPU_STALL_DETECTOR and RCU_CPU_STALL_DETECTOR_RUNNABLE kernel config parameters. The RCU_CPU_STALL_TIMEOUT parameter remains to allow the timeout to be tuned and the RCU_CPU_STALL_VERBOSE parameter remains to allow task-stall information to be suppressed if desired. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-04-28watchdog, hung_task_timeout: Add Kconfig configurable defaultJeff Mahoney
This patch allows the default value for sysctl_hung_task_timeout_secs to be set at build time. The feature carries virtually no overhead, so it makes sense to keep it enabled. On heavily loaded systems, though, it can end up triggering stack traces when there is no bug other than the system being underprovisioned. We use this patch to keep the hung task facility available but disabled at boot-time. The default of 120 seconds is preserved. As a note, commit e162b39a may have accidentally reverted commit fb822db4, which raised the default from 120 seconds to 480 seconds. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Acked-by: Mandeep Singh Baines <msb@google.com> Link: http://lkml.kernel.org/r/4DB8600C.8080000@suse.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-04-26Merge branch 'master' into for-nextJiri Kosina
Fast-forwarded to current state of Linus' tree as there are patches to be applied for files that didn't exist on the old branch.
2011-04-10add printk.time=1 boot-time hint to Kconfig.debug help textJim Cromie
Cite Documentation/kernel-parameters.txt for an alternative to building with PRINTK_TIME compiled in. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-04-04kemleak-test: build as module onlyDaniel Baluta
mm/kmemleak-test.c is used to provide an example of how kmemleak tool works. Memory is leaked at module unload-time, so building the test in kernel (Y) makes the leaks impossible and the test useless. Qualify DEBUG_KMEMLEAK_TEST config symbol with "depends on m", to restrict module-only building. Signed-off-by: Daniel Baluta <dbaluta@ixiacom.com> Acked-by: Pekka Enberg <penberg@kernel.org> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22kstrto*: converting strings to integers done (hopefully) rightAlexey Dobriyan
1. simple_strto*() do not contain overflow checks and crufty, libc way to indicate failure. 2. strict_strto*() also do not have overflow checks but the name and comments pretend they do. 3. Both families have only "long long" and "long" variants, but users want strtou8() 4. Both "simple" and "strict" prefixes are wrong: Simple doesn't exactly say what's so simple, strict should not exist because conversion should be strict by default. The solution is to use "k" prefix and add convertors for more types. Enter kstrtoull() kstrtoll() kstrtoul() kstrtol() kstrtouint() kstrtoint() kstrtou64() kstrtos64() kstrtou32() kstrtos32() kstrtou16() kstrtos16() kstrtou8() kstrtos8() Include runtime testsuite (somewhat incomplete) as well. strict_strto*() become deprecated, stubbed to kstrto*() and eventually will be removed altogether. Use kstrto*() in code today! Note: on some archs _kstrtoul() and _kstrtol() are left in tree, even if they'll be unused at runtime. This is temporarily solution, because I don't want to hardcode list of archs where these functions aren't needed. Current solution with sizeof() and __alignof__ at least always works. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22printk: allow setting DEFAULT_MESSAGE_LEVEL via KconfigMandeep Singh Baines
We've been burned by regressions/bugs which we later realized could have been triaged quicker if only we'd paid closer attention to dmesg. To make it easier to audit dmesg, we'd like to make DEFAULT_MESSAGE_LEVEL Kconfig-settable. That way we can set it to KERN_NOTICE and audit any messages <= KERN_WARNING. Signed-off-by: Mandeep Singh Baines <msb@chromium.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Joe Perches <joe@perches.com> Cc: Olof Johansson <olofj@chromium.org> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22kernel/watchdog.c: allow hardlockup to panic by defaultDon Zickus
When a cpu is considered stuck, instead of limping along and just printing a warning, it is sometimes preferred to just panic, let kdump capture the vmcore and reboot. This gets the machine back into a stable state quickly while saving the info that got it into a stuck state to begin with. Add a Kconfig option to allow users to set the hardlockup to panic by default. Also add in a 'nmi_watchdog=nopanic' to override this. [akpm@linux-foundation.org: fix strncmp length] Signed-off-by: Don Zickus <dzickus@redhat.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-21Merge branch 'kbuild' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'kbuild' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: kbuild: Make DEBUG_SECTION_MISMATCH selectable, but not on by default genksyms: Regenerate lexer and parser genksyms: Track changes to enum constants genksyms: simplify usage of find_symbol() genksyms: Add helpers for building string lists genksyms: Simplify printing of symbol types genksyms: Simplify lexer genksyms: Do not paste the bison header file to lex.c modpost: fix trailing comma KBuild: silence "'scripts/unifdef' is up to date." kbuild: Add extra gcc checks kbuild: reenable section mismatch analysis unifdef: update to upstream version 2.5
2011-03-21kbuild: Make DEBUG_SECTION_MISMATCH selectable, but not on by defaultMichal Marek
CONFIG_DEBUG_SECTION_MISMATCH has also runtime effects due to the -fno-inline-functions-called-once compiler flag, so forcing it on everyone is not a good idea. Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-03-05BKL: That's all, folksArnd Bergmann
This removes the implementation of the big kernel lock, at last. A lot of people have worked on this in the past, I so the credit for this patch should be with everyone who participated in the hunt. The names on the Cc list are the people that were the most active in this, according to the recorded git history, in alphabetical order. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Alan Cox <alan@linux.intel.com> Cc: Alessio Igor Bogani <abogani@texware.it> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Andrew Hendry <andrew.hendry@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Christoph Hellwig <hch@infradead.org> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Hans Verkuil <hverkuil@xs4all.nl> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Jan Blunck <jblunck@infradead.org> Cc: John Kacur <jkacur@redhat.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Oliver Neukum <oliver@neukum.org> Cc: Paul Menage <menage@google.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
2011-02-24kbuild: reenable section mismatch analysisUwe Kleine-König
This was disabled in commit e5f95c8 (kbuild: print only total number of section mismatces found) because there were too many warnings. Now we're down to a reasonable number again, so we start scaring people with the details. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-02-08m68knommu: Remove dependencies on nonexistent M68KNOMMUGeert Uytterhoeven
M68KNOMMU is set nowhere. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-01-20kconfig: rename CONFIG_EMBEDDED to CONFIG_EXPERTDavid Rientjes
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option is used to configure any non-standard kernel with a much larger scope than only small devices. This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes references to the option throughout the kernel. A new CONFIG_EMBEDDED option is added that automatically selects CONFIG_EXPERT when enabled and can be used in the future to isolate options that should only be considered for embedded systems (RISC architectures, SLOB, etc). Calling the option "EXPERT" more accurately represents its intention: only expert users who understand the impact of the configuration changes they are making should enable it. Reviewed-by: Ingo Molnar <mingo@elte.hu> Acked-by: David Woodhouse <david.woodhouse@intel.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Greg KH <gregkh@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jens Axboe <axboe@kernel.dk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Robin Holt <holt@sgi.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-22x86, nmi_watchdog: Remove ARCH_HAS_NMI_WATCHDOG and rely on ↵Don Zickus
CONFIG_HARDLOCKUP_DETECTOR The x86 arch has shifted its use of the nmi_watchdog from a local implementation to the global one provide by kernel/watchdog.c. This shift has caused a whole bunch of compile problems under different config options. I attempt to simplify things with the patch below. In order to simplify things, I had to come to terms with the meaning of two terms ARCH_HAS_NMI_WATCHDOG and CONFIG_HARDLOCKUP_DETECTOR. Basically they mean the same thing, the former on a local level and the latter on a global level. With the old x86 nmi watchdog gone, there is no need to rely on defining the ARCH_HAS_NMI_WATCHDOG variable because it doesn't make sense any more. x86 will now use the global implementation. The changes below do a few things. First it changes the few places that relied on ARCH_HAS_NMI_WATCHDOG to use CONFIG_X86_LOCAL_APIC (the former was an alias for the latter anyway, so nothing unusual here). Those pieces of code were relying more on local apic functionality the nmi watchdog functionality, so the change should make sense. Second, I removed the x86 implementation of touch_nmi_watchdog(). It isn't need now, instead x86 will rely on kernel/watchdog.c's implementation. Third, I removed the #define ARCH_HAS_NMI_WATCHDOG itself from x86. And tweaked the include/linux/nmi.h file to tell users to look for an externally defined touch_nmi_watchdog in the case of ARCH_HAS_NMI_WATCHDOG _or_ CONFIG_HARDLOCKUP_DETECTOR. This changes removes some of the ugliness in that file. Finally, I added a Kconfig dependency for CONFIG_HARDLOCKUP_DETECTOR that said you can't have ARCH_HAS_NMI_WATCHDOG _and_ CONFIG_HARDLOCKUP_DETECTOR. You can only have one nmi_watchdog. Tested with ARCH=i386: allnoconfig, defconfig, allyesconfig, (various broken configs) ARCH=x86_64: allnoconfig, defconfig, allyesconfig, (various broken configs) Hopefully, after this patch I won't get any more compile broken emails. :-) v3: changed a couple of 'linux/nmi.h' -> 'asm/nmi.h' to pick-up correct function prototypes when CONFIG_HARDLOCKUP_DETECTOR is not set. Signed-off-by: Don Zickus <dzickus@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: fweisbec@gmail.com LKML-Reference: <1293044403-14117-1-git-send-email-dzickus@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-10-27Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: (48 commits) DMAENGINE: move COH901318 to arch_initcall dma: imx-dma: fix signedness bug dma/timberdale: simplify conditional ste_dma40: remove channel_type ste_dma40: remove enum for endianess ste_dma40: remove TIM_FOR_LINK option ste_dma40: move mode_opt to separate config ste_dma40: move channel mode to a separate field ste_dma40: move priority to separate field ste_dma40: add variable to indicate valid dma_cfg async_tx: make async_tx channel switching opt-in move async raid6 test to lib/Kconfig.debug dmaengine: Add Freescale i.MX1/21/27 DMA driver intel_mid_dma: change the slave interface intel_mid_dma: fix the WARN_ONs intel_mid_dma: Add sg list support to DMA driver intel_mid_dma: Allow DMAC2 to share interrupt intel_mid_dma: Allow IRQ sharing intel_mid_dma: Add runtime PM support DMAENGINE: define a dummy filter function for ste_dma40 ...
2010-10-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tileLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: arch/tile: convert a BUG_ON to BUILD_BUG_ON arch/tile: make ptrace() work properly for TILE-Gx COMPAT mode arch/tile: support new info op generated by compiler arch/tile: minor whitespace/naming changes for string support files arch/tile: enable single-step support for TILE-Gx arch/tile: parameterize system PLs to support KVM port arch/tile: add Tilera's <arch/sim.h> header as an open-source header arch/tile: Bomb C99 comments to C89 comments in tile's <arch/sim_def.h> arch/tile: prevent corrupt top frame from causing backtracer runaway arch/tile: various top-level Makefile cleanups arch/tile: change lower bound on syscall error return to -4095 arch/tile: properly export __mb_incoherent for modules arch/tile: provide a definition of MAP_STACK kmemleak: add TILE to the list of supported architectures. char: hvc: check for error case arch/tile: Add a warning if we try to allocate too much vmalloc memory. arch/tile: update some comments to clarify register usage. arch/tile: use better "punctuation" for VMSPLIT_3_5G and friends arch/tile: Use <asm-generic/syscalls.h> tile: replace some BUG_ON checks with BUILD_BUG_ON checks
2010-10-26lib/Kconfig.debug: add list_sort debugging switchArtem Bityutskiy
While hunting a non-existing bug in 'list_sort()', I've improved the 'list_sort_test()' function which tests the 'list_sort()' library call. Although at the end I found a bug in my code, but not in 'list_sort()', I think my clean-ups and improvements are worth merging because they make the test function better. This patch: Make the self-tests selectable via Kconfig rather than by manual enabling of DEBUG_LIST_SORT. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Cc: Don Mullis <don.mullis@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26percpu_counter: add debugobj supportTejun Heo
All percpu counters are linked to a global list on initialization and removed from it on destruction. The list is walked during CPU up/down. If a percpu counter is freed without being properly destroyed, the system will oops only on the next CPU up/down making it pretty nasty to track down. This patch adds debugobj support for percpu counters so that such problems can be found easily. As percpu counters don't make sense on stack and can't be statically initialized, debugobj support is pretty simple. It's initialized and activated on counter initialization, and deactivatd and destroyed on counter destruction. With this patch applied, the bug fixed by commit 602586a83b719df0fbd94196a1359ed35aeb2df3 (shmem: put_super must percpu_counter_destroy) triggers the following warning on tmpfs unmount and the system won't oops on the next cpu up/down operation. ------------[ cut here ]------------ WARNING: at lib/debugobjects.c:259 debug_print_object+0x5c/0x70() Hardware name: Bochs ODEBUG: free active (active state 0) object type: percpu_counter Modules linked in: Pid: 3999, comm: umount Not tainted 2.6.36-rc2-work+ #5 Call Trace: [<ffffffff81083f7f>] warn_slowpath_common+0x7f/0xc0 [<ffffffff81084076>] warn_slowpath_fmt+0x46/0x50 [<ffffffff813b45cc>] debug_print_object+0x5c/0x70 [<ffffffff813b50e5>] debug_check_no_obj_freed+0x125/0x210 [<ffffffff811577d3>] kfree+0xb3/0x2f0 [<ffffffff81132edd>] shmem_put_super+0x1d/0x30 [<ffffffff81162e96>] generic_shutdown_super+0x56/0xe0 [<ffffffff81162f86>] kill_anon_super+0x16/0x60 [<ffffffff81162ff7>] kill_litter_super+0x27/0x30 [<ffffffff81163295>] deactivate_locked_super+0x45/0x60 [<ffffffff81163cfa>] deactivate_super+0x4a/0x70 [<ffffffff8117d446>] mntput_no_expire+0x86/0xe0 [<ffffffff8117df7f>] sys_umount+0x6f/0x360 [<ffffffff8103f01b>] system_call_fastpath+0x16/0x1b ---[ end trace cce2a341ba3611a7 ]--- Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Thomas Gleixner <tglxlinutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-24Merge branch 'master' into for-linusPekka Enberg
Conflicts: include/linux/percpu.h mm/percpu.c
2010-10-22Merge branch 'config' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'config' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: BKL: introduce CONFIG_BKL. dabusb: remove the BKL sunrpc: remove the big kernel lock init/main.c: remove BKL notations blktrace: remove the big kernel lock rtmutex-tester: make it build without BKL dvb-core: kill the big kernel lock dvb/bt8xx: kill the big kernel lock tlclk: remove big kernel lock fix rawctl compat ioctls breakage on amd64 and itanic uml: kill big kernel lock parisc: remove big kernel lock cris: autoconvert trivial BKL users alpha: kill big kernel lock isapnp: BKL removal s390/block: kill the big kernel lock hpet: kill BKL, add compat_ioctl
2010-10-21Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (163 commits) tracing: Fix compile issue for trace_sched_wakeup.c [S390] hardirq: remove pointless header file includes [IA64] Move local_softirq_pending() definition perf, powerpc: Fix power_pmu_event_init to not use event->ctx ftrace: Remove recursion between recordmcount and scripts/mod/empty jump_label: Add COND_STMT(), reducer wrappery perf: Optimize sw events perf: Use jump_labels to optimize the scheduler hooks jump_label: Add atomic_t interface jump_label: Use more consistent naming perf, hw_breakpoint: Fix crash in hw_breakpoint creation perf: Find task before event alloc perf: Fix task refcount bugs perf: Fix group moving irq_work: Add generic hardirq context callbacks perf_events: Fix transaction recovery in group_sched_in() perf_events: Fix bogus AMD64 generic TLB events perf_events: Fix bogus context time tracking tracing: Remove parent recording in latency tracer graph options tracing: Use one prologue for the preempt irqs off tracer function tracers ...
2010-10-21BKL: introduce CONFIG_BKL.Arnd Bergmann
With all the patches we have queued in the BKL removal tree, only a few dozen modules are left that actually rely on the BKL, and even there are lots of low-hanging fruit. We need to decide what to do about them, this patch illustrates one of the options: Every user of the BKL is marked as 'depends on BKL' in Kconfig, and the CONFIG_BKL becomes a user-visible option. If it gets disabled, no BKL using module can be built any more and the BKL code itself is compiled out. The one exception is file locking, which is practically always enabled and does a 'select BKL' instead. This effectively forces CONFIG_BKL to be enabled until we have solved the fs/lockd mess and can apply the patch that removes the BKL from fs/locks.c. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2010-10-14kmemleak: add TILE to the list of supported architectures.Chris Metcalf
All the necessary functionality was already there; we just need to make it possible to select the config option. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2010-10-07move async raid6 test to lib/Kconfig.debugDan Williams
The prompt for "Self test for hardware accelerated raid6 recovery" does not belong in the top level configuration menu. All the options in crypto/async_tx/Kconfig are selected and do not depend on CRYPTO. Kconfig.debug seems like a reasonable fit. Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-10-06slub: Enable sysfs support for !CONFIG_SLUB_DEBUGChristoph Lameter
Currently disabling CONFIG_SLUB_DEBUG also disabled SYSFS support meaning that the slabs cannot be tuned without DEBUG. Make SYSFS support independent of CONFIG_SLUB_DEBUG Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Pekka Enberg <penberg@kernel.org>
2010-09-23rcu: Add advice to PROVE_RCU_REPEATEDLY kernel config parameterPaul E. McKenney
The PROVE_RCU_REPEATEDLY has no "Say Y"/"Say N" advice, so this commit adds it. Reported-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-08-31tracing/lockdep: Fix dependency of TRACE_IRQFLAGSSteven Rostedt
When CONFIG_IRQSOFF_TRACER is set and CONFIG_PROVE_LOCKING is not, we get the following error: $ make oldconfig scripts/kconfig/conf --oldconfig arch/x86/Kconfig warning: (IRQSOFF_TRACER && TRACING_SUPPORT && FTRACE && TRACE_IRQFLAGS_SUPPORT && !ARCH_USES_GETTIMEOFFSET) selects TRACE_IRQFLAGS which has unmet direct dependencies (DEBUG_KERNEL && TRACE_IRQFLAGS_SUPPORT && PROVE_LOCKING) warning: (IRQSOFF_TRACER && TRACING_SUPPORT && FTRACE && TRACE_IRQFLAGS_SUPPORT && !ARCH_USES_GETTIMEOFFSET) selects TRACE_IRQFLAGS which has unmet direct dependencies (DEBUG_KERNEL && TRACE_IRQFLAGS_SUPPORT && PROVE_LOCKING) This is because IRQSOFF_TRACER selects TRACE_IRQFLAGS but TRACE_IRQFLAGS has PROVE_LOCKING as a dependency. This code is incorrect, and this patch changes the TRACE_IRQFLAGS to be just a simple bool that does not depend or select anything. Instead both IRQSOFF_TRACER and PROVE_LOCKING select it. Reported-by: Richard Kennedy <richard@rsk.demon.co.uk> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-08-19rcu: Allow RCU CPU stall warnings to be off at boot, but manually enablablePaul E. McKenney
Currently, if RCU CPU stall warnings are enabled, they are enabled immediately upon boot. They can be manually disabled via /sys (and also re-enabled via /sys), and are automatically disabled upon panic. However, some users need RCU CPU stalls to be disabled at boot time, but to be enabled without rebuilding/rebooting. For example, someone running a real-time application in production might not want the additional latency of RCU CPU stall detection in normal operation, but might need to enable it at any point for fault isolation purposes. This commit therefore provides a new CONFIG_RCU_CPU_STALL_DETECTOR_RUNNABLE kernel configuration parameter that maintains the current behavior (enable at boot) by default, but allows a kernel to be configured with RCU CPU stall detection built into the kernel, but disabled at boot time. Requested-by: Clark Williams <williams@redhat.com> Requested-by: John Kacur <jkacur@redhat.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-08-19rcu: make CPU stall warning timeout configurablePaul E. McKenney
Also set the default to 60 seconds, up from the previous hard-coded timeout of 10 seconds. This allows people who care to set short timeouts, while avoiding people with unusual configurations (make randconfig!!!) from being bothered with spurious CPU stall warnings. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2010-08-19rcu: define __rcu address space modifier for sparsePaul E. McKenney
This commit provides definitions for the __rcu annotation defined earlier. This annotation permits sparse to check for correct use of RCU-protected pointers. If a pointer that is annotated with __rcu is accessed directly (as opposed to via rcu_dereference(), rcu_assign_pointer(), or one of their variants), sparse can be made to complain. To enable such complaints, use the new default-disabled CONFIG_SPARSE_RCU_POINTER kernel configuration option. Please note that these sparse complaints are intended to be a debugging aid, -not- a code-style-enforcement mechanism. There are special rcu_dereference_protected() and rcu_access_pointer() accessors for use when RCU read-side protection is not required, for example, when no other CPU has access to the data structure in question or while the current CPU hold the update-side lock. This patch also updates a number of docbook comments that were showing their age. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Christopher Li <sparse@chrisli.org> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2010-08-17latencytop: Fix kconfig dependency warningsRandy Dunlap
warning: (LATENCYTOP && HAVE_LATENCYTOP_SUPPORT) selects SCHED_DEBUG which has unmet direct dependencies (DEBUG_KERNEL && PROC_FS) warning: (LATENCYTOP && HAVE_LATENCYTOP_SUPPORT) selects SCHEDSTATS which has unmet direct dependencies (DEBUG_KERNEL && PROC_FS) Add depends on STACKTRACE_SUPPORT for 'select STACKTRACE'. Add depends on PROC_FS since that is where the output goes. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Arjan van de Ven <arjan@linux.intel.com> LKML-Reference: <20100812123121.a7c99cde.randy.dunlap@oracle.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-08-10Merge branch 'kmemleak' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-2.6-cm * 'kmemleak' of git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-2.6-cm: kmemleak: Fix typo in the comment lib/scatterlist: Hook sg_kmalloc into kmemleak (v2) kmemleak: Add DocBook style comments to kmemleak.c kmemleak: Introduce a default off mode for kmemleak kmemleak: Show more information for objects found by alias
2010-08-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (28 commits) driver core: device_rename's new_name can be const sysfs: Remove owner field from sysfs struct attribute powerpc/pci: Remove owner field from attribute initialization in PCI bridge init regulator: Remove owner field from attribute initialization in regulator core driver leds: Remove owner field from attribute initialization in bd2802 driver scsi: Remove owner field from attribute initialization in ARCMSR driver scsi: Remove owner field from attribute initialization in LPFC driver cgroupfs: create /sys/fs/cgroup to mount cgroupfs on Driver core: Add BUS_NOTIFY_BIND_DRIVER driver core: fix memory leak on one error path in bus_register() debugfs: no longer needs to depend on SYSFS sysfs: Fix one more signature discrepancy between sysfs implementation and docs. sysfs: fix discrepancies between implementation and documentation dcdbas: remove a redundant smi_data_buf_free in dcdbas_exit dmi-id: fix a memory leak in dmi_id_init error path sysfs: sysfs_chmod_file's attr can be const firmware: Update hotplug script Driver core: move platform device creation helpers to .init.text (if MODULE=n) Driver core: reduce duplicated code for platform_device creation Driver core: use kmemdup in platform_device_add_resources ...
2010-08-06Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (162 commits) tracing/kprobes: unregister_trace_probe needs to be called under mutex perf: expose event__process function perf events: Fix mmap offset determination perf, powerpc: fsl_emb: Restore setting perf_sample_data.period perf, powerpc: Convert the FSL driver to use local64_t perf tools: Don't keep unreferenced maps when unmaps are detected perf session: Invalidate last_match when removing threads from rb_tree perf session: Free the ref_reloc_sym memory at the right place x86,mmiotrace: Add support for tracing STOS instruction perf, sched migration: Librarize task states and event headers helpers perf, sched migration: Librarize the GUI class perf, sched migration: Make the GUI class client agnostic perf, sched migration: Make it vertically scrollable perf, sched migration: Parameterize cpu height and spacing perf, sched migration: Fix key bindings perf, sched migration: Ignore unhandled task states perf, sched migration: Handle ignored migrate out events perf: New migration tool overview tracing: Drop cpparg() macro perf: Use tracepoint_synchronize_unregister() to flush any pending tracepoint call ... Fix up trivial conflicts in Makefile and drivers/cpufreq/cpufreq.c
