[ Upstream commit 2cb80dbbbaba4f2f86f686c34cb79ea5cbfb0edb ]
KUnit tests for initialized data behavior of proc_dointvec that is
explicitly checked in the code. Includes basic parsing tests including
int min/max overflow.
Signed-off-by: Iurii Zaikin <yzaikin@google.com>
Signed-off-by: Brendan Higgins <brendanhiggins@google.com>
Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Reviewed-by: Logan Gunthorpe <logang@deltatee.com>
Acked-by: Luis Chamberlain <mcgrof@kernel.org>
Reviewed-by: Stephen Boyd <sboyd@kernel.org>
Signed-off-by: Shuah Khan <skhan@linuxfoundation.org>
commit 7d32e69310d67e6b04af04f26193f79dfc2f05c7 upstream.
Currently turning on DEBUG_INFO_SPLIT when DEBUG_INFO_BTF is also
enabled will produce invalid btf file, since gen_btf function in
link-vmlinux.sh script doesn't handle *.dwo files.
Enabling DEBUG_INFO_REDUCED will also produce invalid btf file,
and using GCC_PLUGIN_RANDSTRUCT with BTF makes no sense.
Fixes: e83b9f55448a ("kbuild: add ability to generate BTF type info for vmlinux")
Reported-by: Jann Horn <jannh@google.com>
Reported-by: Liu Yiding <liuyd.fnst@cn.fujitsu.com>
Signed-off-by: Slava Bacherikov <slava@bacher09.org>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Acked-by: KP Singh <kpsingh@google.com>
Acked-by: Andrii Nakryiko <andriin@fb.com>
Link: https://lore.kernel.org/bpf/20200402204138.408021-1-slava@bacher09.org
commit 7ecaf069da52e472d393f03e79d721aabd724166 upstream.
Currently, some sanity checks for uapi headers are done by
scripts/headers_check.pl, which is wired up to the 'headers_check'
target in the top Makefile.
It is true compiling headers has better test coverage, but there
are still several headers excluded from the compile test. I like
to keep headers_check.pl for a while, but we can delete a lot of
code by moving the build rule to usr/include/Makefile.
Commit 9012d011660e ("compiler: allow all arches to enable
CONFIG_OPTIMIZE_INLINING") allowed all architectures to enable this
option. A couple of build errors were reported by randconfig, but all of
them have been ironed out.
Towards the goal of removing CONFIG_OPTIMIZE_INLINING entirely (and it
will simplify the 'inline' macro in compiler_types.h), this commit changes
it to always-on option. Going forward, the compiler will always be
allowed to not inline functions marked 'inline'.
This is not a problem for x86 since it has been long used by
arch/x86/configs/{x86_64,i386}_defconfig.
I am keeping the config option just in case any problem crops up for other
architectures.
The code clean-up will be done after confirming this is solid.
Link: http://lkml.kernel.org/r/20190830034304.24259-1-yamada.masahiro@socionext.com
Acked-by: Nick Desaulniers <ndesaulniers@google.com>
Cc: Miguel Ojeda <miguel.ojeda.sandonis@gmail.com>
There are some machines with slow disk and fast CPUs. When they are under
memory pressure, it could take a long time to swap before the OOM kicks in
to free up some memory. As the results, it needs a large mem pool for
kmemleak or suffering from higher chance of a kmemleak metadata allocation
failure. 524288 proves to be the good number for all architectures here.
Increase the upper bound to 1M to leave some room for the future.
Link: http://lkml.kernel.org/r/1565807572-26041-1-git-send-email-cai@lca.pw
Signed-off-by: Qian Cai <cai@lca.pw>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Currently kmemleak uses a static early_log buffer to trace all memory
allocation/freeing before the slab allocator is initialised. Such early
log is replayed during kmemleak_init() to properly initialise the kmemleak
metadata for objects allocated up that point. With a memory pool that
does not rely on the slab allocator, it is possible to skip this early log
entirely.
In order to remove the early logging, consider kmemleak_enabled == 1 by
default while the kmem_cache availability is checked directly on the
object_cache and scan_area_cache variables. The RCU callback is only
invoked after object_cache has been initialised as we wouldn't have any
concurrent list traversal before this.
In order to reduce the number of callbacks before kmemleak is fully
initialised, move the kmemleak_init() call to mm_init().
[akpm@linux-foundation.org: remove WARN_ON(), per Catalin]
Link: http://lkml.kernel.org/r/20190812160642.52134-4-catalin.marinas@arm.com
Cc: Matthew Wilcox <willy@infradead.org>
Cc: Michal Hocko <mhocko@kernel.org>
Cc: Qian Cai <cai@lca.pw>
The current default value (400) is too low on many systems (e.g. some
ARM64 platform takes up 1000+ entries).
syzbot uses 16000 as default value, and has proved to be enough on beefy
configurations, so let's pick that value.
This consumes more RAM on boot (each entry is 160 bytes, so in total
~2.5MB of RAM), but the memory would later be freed (early_log is
__initdata).
Link: http://lkml.kernel.org/r/20190730154027.101525-1-drinkcat@chromium.org
Signed-off-by: Nicolas Boichat <drinkcat@chromium.org>
Suggested-by: Dmitry Vyukov <dvyukov@google.com>
Acked-by: Dmitry Vyukov <dvyukov@google.com>
Cc: Petr Mladek <pmladek@suse.com>
Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Cc: Joe Lawrence <joe.lawrence@redhat.com>
Cc: Uladzislau Rezki <urezki@gmail.com>
Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Cc: Andrey Ryabinin <aryabinin@virtuozzo.com>
When CONFIG_MODULES is disabled, CONFIG_UNUSED_SYMBOLS is pointless,
thus it should be invisible.
Instead of adding "depends on MODULES", I moved it to the sub-menu
"Enable loadable module support", which is a better fit. I put it
close to TRIM_UNUSED_KSYMS because it depends on !UNUSED_SYMBOLS.
Signed-off-by: Jessica Yu <jeyu@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild
Pull more Kbuild updates from Masahiro Yamada:
- match the directory structure of the linux-libc-dev package to that
of Debian-based distributions
- fix incorrect include/config/auto.conf generation when Kconfig
creates it along with the .config file
- remove misleading $(AS) from documents
- clean up precious tag files by distclean instead of mrproper
- add a new coccinelle patch for devm_platform_ioremap_resource
migration
- refactor module-related scripts to read modules.order instead of
$(MODVERDIR)/*.mod files to get the list of created modules
- remove MODVERDIR
- update list of header compile-test
- add -fcf-protection=none flag to avoid conflict with the retpoline
flags when CONFIG_RETPOLINE=y
- misc cleanups
* tag 'kbuild-v5.3-2' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild: (25 commits)
kbuild: add -fcf-protection=none when using retpoline flags
kbuild: update compile-test header list for v5.3-rc1
kbuild: split out *.mod out of {single,multi}-used-m rules
kbuild: remove 'prepare1' target
kbuild: remove the first line of *.mod files
kbuild: create *.mod with full directory path and remove MODVERDIR
kbuild: export_report: read modules.order instead of .tmp_versions/*.mod
kbuild: modpost: read modules.order instead of $(MODVERDIR)/*.mod
kbuild: modsign: read modules.order instead of $(MODVERDIR)/*.mod
kbuild: modinst: read modules.order instead of $(MODVERDIR)/*.mod
scsi: remove pointless $(MODVERDIR)/$(obj)/53c700.ver
kbuild: remove duplication from modules.order in sub-directories
kbuild: get rid of kernel/ prefix from in-tree modules.{order,builtin}
kbuild: do not create empty modules.order in the prepare stage
coccinelle: api: add devm_platform_ioremap_resource script
kbuild: compile-test headers listed in header-test-m as well
kbuild: remove unused hostcc-option
kbuild: remove tag files by distclean instead of mrproper
kbuild: add --hash-style= and --build-id unconditionally
kbuild: get rid of misleading $(AS) from documents
While descending directories, Kbuild produces objects for modules,
but do not link final *.ko files; it is done in the modpost.
To keep track of modules, Kbuild creates a *.mod file in $(MODVERDIR)
for every module it is building. Some post-processing steps read the
necessary information from *.mod files. This avoids descending into
directories again. This mechanism was introduced in 2003 or so.
Later, commit 551559e13af1 ("kbuild: implement modules.order") added
modules.order. So, we can simply read it out to know all the modules
with directory paths. This is easier than parsing the first line of
*.mod files.
$(MODVERDIR) has a flat directory structure, that is, *.mod files
are named only with base names. This is based on the assumption that
the module name is unique across the tree. This assumption is really
fragile.
Stephen Rothwell reported a race condition caused by a module name
conflict:
https://lkml.org/lkml/2019/5/13/991
In parallel building, two different threads could write to the same
$(MODVERDIR)/*.mod simultaneously.
Non-unique module names are the source of all kind of troubles, hence
commit 3a48a91901c5 ("kbuild: check uniqueness of module names")
introduced a new checker script.
However, it is still fragile in the build system point of view because
this race happens before scripts/modules-check.sh is invoked. If it
happens again, the modpost will emit unclear error messages.
To fix this issue completely, create *.mod with full directory path
so that two threads never attempt to write to the same file.
$(MODVERDIR) is no longer needed.
Since modules with directory paths are listed in modules.order, Kbuild
is still able to find *.mod files without additional descending.
I also killed cmd_secanalysis; scripts/mod/sumversion.c computes MD4 hash
for modules with MODULE_VERSION(). When CONFIG_DEBUG_SECTION_MISMATCH=y,
it occurs not only in the modpost stage, but also during directory
descending, where sumversion.c may parse stale *.mod files. It would emit
'No such file or directory' warning when an object consisting a module is
renamed, or when a single-obj module is turned into a multi-obj module or
vice versa.
Acked-by: Nicolas Pitre <nico@fluxnic.net>
Merge more updates from Andrew Morton:
"VM:
- z3fold fixes and enhancements by Henry Burns and Vitaly Wool
- more accurate reclaimed slab caches calculations by Yafang Shao
- fix MAP_UNINITIALIZED UAPI symbol to not depend on config, by
Christoph Hellwig
- !CONFIG_MMU fixes by Christoph Hellwig
- new novmcoredd parameter to omit device dumps from vmcore, by
Kairui Song
- new test_meminit module for testing heap and pagealloc
initialization, by Alexander Potapenko
- ioremap improvements for huge mappings, by Anshuman Khandual
- generalize kprobe page fault handling, by Anshuman Khandual
- device-dax hotplug fixes and improvements, by Pavel Tatashin
- enable synchronous DAX fault on powerpc, by Aneesh Kumar K.V
- add pte_devmap() support for arm64, by Robin Murphy
- unify locked_vm accounting with a helper, by Daniel Jordan
- several misc fixes
core/lib:
- new typeof_member() macro including some users, by Alexey Dobriyan
- make BIT() and GENMASK() available in asm, by Masahiro Yamada
- changed LIST_POISON2 on x86_64 to 0xdead000000000122 for better
code generation, by Alexey Dobriyan
- rbtree code size optimizations, by Michel Lespinasse
- convert struct pid count to refcount_t, by Joel Fernandes
get_maintainer.pl:
- add --no-moderated switch to skip moderated ML's, by Joe Perches
misc:
- ptrace PTRACE_GET_SYSCALL_INFO interface
- coda updates
- gdb scripts, various"
[ Using merge message suggestion from Vlastimil Babka, with some editing - Linus ]
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (100 commits)
fs/select.c: use struct_size() in kmalloc()
mm: add account_locked_vm utility function
arm64: mm: implement pte_devmap support
mm: introduce ARCH_HAS_PTE_DEVMAP
mm: clean up is_device_*_page() definitions
mm/mmap: move common defines to mman-common.h
mm: move MAP_SYNC to asm-generic/mman-common.h
device-dax: "Hotremove" persistent memory that is used like normal RAM
mm/hotplug: make remove_memory() interface usable
device-dax: fix memory and resource leak if hotplug fails
include/linux/lz4.h: fix spelling and copy-paste errors in documentation
ipc/mqueue.c: only perform resource calculation if user valid
include/asm-generic/bug.h: fix "cut here" for WARN_ON for __WARN_TAINT architectures
scripts/gdb: add helpers to find and list devices
scripts/gdb: add lx-genpd-summary command
drivers/pps/pps.c: clear offset flags in PPS_SETPARAMS ioctl
kernel/pid.c: convert struct pid count to refcount_t
drivers/rapidio/devices/rio_mport_cdev.c: NUL terminate some strings
select: shift restore_saved_sigmask_unless() into poll_select_copy_remaining()
select: change do_poll() to return -ERESTARTNOHAND rather than -EINTR
Add tests for heap and pagealloc initialization. These can be used to
check init_on_alloc and init_on_free implementations as well as other
approaches to initialization.
Expected test output in the case the kernel provides heap initialization
(e.g. when running with either init_on_alloc=1 or init_on_free=1):
test_meminit: all 10 tests in test_pages passed
test_meminit: all 40 tests in test_kvmalloc passed
test_meminit: all 60 tests in test_kmemcache passed
test_meminit: all 10 tests in test_rcu_persistent passed
test_meminit: all 120 tests passed!
Link: http://lkml.kernel.org/r/20190529123812.43089-4-glider@google.com
Signed-off-by: Alexander Potapenko <glider@google.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Nick Desaulniers <ndesaulniers@google.com>
Cc: Kostya Serebryany <kcc@google.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Sandeep Patil <sspatil@android.com>
Cc: Laura Abbott <labbott@redhat.com>
Cc: Jann Horn <jannh@google.com>
Cc: Marco Elver <elver@google.com>
Convert the locking documents to ReST and add them to the
kernel development book where it belongs.
Most of the stuff here is just to make Sphinx to properly
parse the text file, as they're already in good shape,
not requiring massive changes in order to be parsed.
The conversion is actually:
- add blank lines and identation in order to identify paragraphs;
- fix tables markups;
- add some lists markups;
- mark literal blocks;
- adjust title markups.
At its new index.rst, let's add a :orphan: while this is not linked to
the main index.rst file, in order to avoid build warnings.
Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
Acked-by: Federico Vaga <federico.vaga@vaga.pv.it>
Pull Kbuild updates from Masahiro Yamada:
- remove headers_{install,check}_all targets
- remove unreasonable 'depends on !UML' from CONFIG_SAMPLES
- re-implement 'make headers_install' more cleanly
- add new header-test-y syntax to compile-test headers
- compile-test exported headers to ensure they are compilable in
user-space
- compile-test headers under include/ to ensure they are self-contained
- remove -Waggregate-return, -Wno-uninitialized, -Wno-unused-value
flags
- add -Werror=unknown-warning-option for Clang
- add 128-bit built-in types support to genksyms
- fix missed rebuild of modules.builtin
- propagate 'No space left on device' error in fixdep to Make
- allow Clang to use its integrated assembler
- improve some coccinelle scripts
- add a new flag KBUILD_ABS_SRCTREE to request Kbuild to use absolute
path for $(srctree).
- do not ignore errors when compression utility is missing
- misc cleanups
* tag 'kbuild-v5.3' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild: (49 commits)
kbuild: use -- separater intead of $(filter-out ...) for cc-cross-prefix
kbuild: Inform user to pass ARCH= for make mrproper
kbuild: fix compression errors getting ignored
kbuild: add a flag to force absolute path for srctree
kbuild: replace KBUILD_SRCTREE with boolean building_out_of_srctree
kbuild: remove src and obj from the top Makefile
scripts/tags.sh: remove unused environment variables from comments
scripts/tags.sh: drop SUBARCH support for ARM
kbuild: compile-test kernel headers to ensure they are self-contained
kheaders: include only headers into kheaders_data.tar.xz
kheaders: remove meaningless -R option of 'ls'
kbuild: support header-test-pattern-y
kbuild: do not create wrappers for header-test-y
kbuild: compile-test exported headers to ensure they are self-contained
init/Kconfig: add CONFIG_CC_CAN_LINK
kallsyms: exclude kasan local symbols on s390
kbuild: add more hints about SUBDIRS replacement
coccinelle: api/stream_open: treat all wait_.*() calls as blocking
coccinelle: put_device: Add a cast to an expression for an assignment
coccinelle: put_device: Adjust a message construction
Pull networking updates from David Miller:
"Some highlights from this development cycle:
1) Big refactoring of ipv6 route and neigh handling to support
nexthop objects configurable as units from userspace. From David
Ahern.
2) Convert explored_states in BPF verifier into a hash table,
significantly decreased state held for programs with bpf2bpf
calls, from Alexei Starovoitov.
3) Implement bpf_send_signal() helper, from Yonghong Song.
4) Various classifier enhancements to mvpp2 driver, from Maxime
Chevallier.
5) Add aRFS support to hns3 driver, from Jian Shen.
6) Fix use after free in inet frags by allocating fqdirs dynamically
and reworking how rhashtable dismantle occurs, from Eric Dumazet.
7) Add act_ctinfo packet classifier action, from Kevin
Darbyshire-Bryant.
8) Add TFO key backup infrastructure, from Jason Baron.
9) Remove several old and unused ISDN drivers, from Arnd Bergmann.
10) Add devlink notifications for flash update status to mlxsw driver,
from Jiri Pirko.
11) Lots of kTLS offload infrastructure fixes, from Jakub Kicinski.
12) Add support for mv88e6250 DSA chips, from Rasmus Villemoes.
13) Various enhancements to ipv6 flow label handling, from Eric
Dumazet and Willem de Bruijn.
14) Support TLS offload in nfp driver, from Jakub Kicinski, Dirk van
der Merwe, and others.
15) Various improvements to axienet driver including converting it to
phylink, from Robert Hancock.
16) Add PTP support to sja1105 DSA driver, from Vladimir Oltean.
17) Add mqprio qdisc offload support to dpaa2-eth, from Ioana
Radulescu.
18) Add devlink health reporting to mlx5, from Moshe Shemesh.
19) Convert stmmac over to phylink, from Jose Abreu.
20) Add PTP PHC (Physical Hardware Clock) support to mlxsw, from
Shalom Toledo.
21) Add nftables SYNPROXY support, from Fernando Fernandez Mancera.
22) Convert tcp_fastopen over to use SipHash, from Ard Biesheuvel.
23) Track spill/fill of constants in BPF verifier, from Alexei
Starovoitov.
24) Support bounded loops in BPF, from Alexei Starovoitov.
25) Various page_pool API fixes and improvements, from Jesper Dangaard
Brouer.
26) Just like ipv4, support ref-countless ipv6 route handling. From
Wei Wang.
27) Support VLAN offloading in aquantia driver, from Igor Russkikh.
28) Add AF_XDP zero-copy support to mlx5, from Maxim Mikityanskiy.
29) Add flower GRE encap/decap support to nfp driver, from Pieter
Jansen van Vuuren.
30) Protect against stack overflow when using act_mirred, from John
Hurley.
31) Allow devmap map lookups from eBPF, from Toke Høiland-Jørgensen.
32) Use page_pool API in netsec driver, Ilias Apalodimas.
33) Add Google gve network driver, from Catherine Sullivan.
34) More indirect call avoidance, from Paolo Abeni.
35) Add kTLS TX HW offload support to mlx5, from Tariq Toukan.
36) Add XDP_REDIRECT support to bnxt_en, from Andy Gospodarek.
37) Add MPLS manipulation actions to TC, from John Hurley.
38) Add sending a packet to connection tracking from TC actions, and
then allow flower classifier matching on conntrack state. From
Paul Blakey.
39) Netfilter hw offload support, from Pablo Neira Ayuso"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (2080 commits)
net/mlx5e: Return in default case statement in tx_post_resync_params
mlx5: Return -EINVAL when WARN_ON_ONCE triggers in mlx5e_tls_resync().
net: dsa: add support for BRIDGE_MROUTER attribute
pkt_sched: Include const.h
net: netsec: remove static declaration for netsec_set_tx_de()
net: netsec: remove superfluous if statement
netfilter: nf_tables: add hardware offload support
net: flow_offload: rename tc_cls_flower_offload to flow_cls_offload
net: flow_offload: add flow_block_cb_is_busy() and use it
net: sched: remove tcf block API
drivers: net: use flow block API
net: sched: use flow block API
net: flow_offload: add flow_block_cb_{priv, incref, decref}()
net: flow_offload: add list handling functions
net: flow_offload: add flow_block_cb_alloc() and flow_block_cb_free()
net: flow_offload: rename TCF_BLOCK_BINDER_TYPE_* to FLOW_BLOCK_BINDER_TYPE_*
net: flow_offload: rename TC_BLOCK_{UN}BIND to FLOW_BLOCK_{UN}BIND
net: flow_offload: add flow_block_cb_setup_simple()
net: hisilicon: Add an tx_desc to adapt HI13X1_GMAC
net: hisilicon: Add an rx_desc to adapt HI13X1_GMAC
Pull Documentation updates from Jonathan Corbet:
"It's been a relatively busy cycle for docs:
- A fair pile of RST conversions, many from Mauro. These create more
than the usual number of simple but annoying merge conflicts with
other trees, unfortunately. He has a lot more of these waiting on
the wings that, I think, will go to you directly later on.
- A new document on how to use merges and rebases in kernel repos,
and one on Spectre vulnerabilities.
- Various improvements to the build system, including automatic
markup of function() references because some people, for reasons I
will never understand, were of the opinion that
:c:func:``function()`` is unattractive and not fun to type.
- We now recommend using sphinx 1.7, but still support back to 1.4.
- Lots of smaller improvements, warning fixes, typo fixes, etc"
* tag 'docs-5.3' of git://git.lwn.net/linux: (129 commits)
docs: automarkup.py: ignore exceptions when seeking for xrefs
docs: Move binderfs to admin-guide
Disable Sphinx SmartyPants in HTML output
doc: RCU callback locks need only _bh, not necessarily _irq
docs: format kernel-parameters -- as code
Doc : doc-guide : Fix a typo
platform: x86: get rid of a non-existent document
Add the RCU docs to the core-api manual
Documentation: RCU: Add TOC tree hooks
Documentation: RCU: Rename txt files to rst
Documentation: RCU: Convert RCU UP systems to reST
Documentation: RCU: Convert RCU linked list to reST
Documentation: RCU: Convert RCU basic concepts to reST
docs: filesystems: Remove uneeded .rst extension on toctables
scripts/sphinx-pre-install: fix out-of-tree build
docs: zh_CN: submitting-drivers.rst: Remove a duplicated Documentation/
Documentation: PGP: update for newer HW devices
Documentation: Add section about CPU vulnerabilities for Spectre
Documentation: platform: Delete x86-laptop-drivers.txt
docs: Note that :c:func: should no longer be used
Pull locking updates from Ingo Molnar:
"The main changes in this cycle are:
- rwsem scalability improvements, phase #2, by Waiman Long, which are
rather impressive:
"On a 2-socket 40-core 80-thread Skylake system with 40 reader
and writer locking threads, the min/mean/max locking operations
done in a 5-second testing window before the patchset were:
40 readers, Iterations Min/Mean/Max = 1,807/1,808/1,810
40 writers, Iterations Min/Mean/Max = 1,807/50,344/151,255
After the patchset, they became:
40 readers, Iterations Min/Mean/Max = 30,057/31,359/32,741
40 writers, Iterations Min/Mean/Max = 94,466/95,845/97,098"
There's a lot of changes to the locking implementation that makes
it similar to qrwlock, including owner handoff for more fair
locking.
Another microbenchmark shows how across the spectrum the
improvements are:
"With a locking microbenchmark running on 5.1 based kernel, the
total locking rates (in kops/s) on a 2-socket Skylake system
with equal numbers of readers and writers (mixed) before and
after this patchset were:
# of Threads Before Patch After Patch
2 2,618 4,193
4 1,202 3,726
8 802 3,622
16 729 3,359
32 319 2,826
64 102 2,744"
The changes are extensive and the patch-set has been through
several iterations addressing various locking workloads. There
might be more regressions, but unless they are pathological I
believe we want to use this new implementation as the baseline
going forward.
- jump-label optimizations by Daniel Bristot de Oliveira: the primary
motivation was to remove IPI disturbance of isolated RT-workload
CPUs, which resulted in the implementation of batched jump-label
updates. Beyond the improvement of the real-time characteristics
kernel, in one test this patchset improved static key update
overhead from 57 msecs to just 1.4 msecs - which is a nice speedup
as well.
- atomic64_t cross-arch type cleanups by Mark Rutland: over the last
~10 years of atomic64_t existence the various types used by the
APIs only had to be self-consistent within each architecture -
which means they became wildly inconsistent across architectures.
Mark puts and end to this by reworking all the atomic64
implementations to use 's64' as the base type for atomic64_t, and
to ensure that this type is consistently used for parameters and
return values in the API, avoiding further problems in this area.
- A large set of small improvements to lockdep by Yuyang Du: type
cleanups, output cleanups, function return type and othr cleanups
all around the place.
- A set of percpu ops cleanups and fixes by Peter Zijlstra.
- Misc other changes - please see the Git log for more details"
* 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (82 commits)
locking/lockdep: increase size of counters for lockdep statistics
locking/atomics: Use sed(1) instead of non-standard head(1) option
locking/lockdep: Move mark_lock() inside CONFIG_TRACE_IRQFLAGS && CONFIG_PROVE_LOCKING
x86/jump_label: Make tp_vec_nr static
x86/percpu: Optimize raw_cpu_xchg()
x86/percpu, sched/fair: Avoid local_clock()
x86/percpu, x86/irq: Relax {set,get}_irq_regs()
x86/percpu: Relax smp_processor_id()
x86/percpu: Differentiate this_cpu_{}() and __this_cpu_{}()
locking/rwsem: Guard against making count negative
locking/rwsem: Adaptive disabling of reader optimistic spinning
locking/rwsem: Enable time-based spinning on reader-owned rwsem
locking/rwsem: Make rwsem->owner an atomic_long_t
locking/rwsem: Enable readers spinning on writer
locking/rwsem: Clarify usage of owner's nonspinaable bit
locking/rwsem: Wake up almost all readers in wait queue
locking/rwsem: More optimal RT task handling of null owner
locking/rwsem: Always release wait_lock before waking up tasks
locking/rwsem: Implement lock handoff to prevent lock starvation
locking/rwsem: Make rwsem_spin_on_owner() return owner state
Pull irq updates from Thomas Gleixner:
"The irq departement provides the usual mixed bag:
Core:
- Further improvements to the irq timings code which aims to predict
the next interrupt for power state selection to achieve better
latency/power balance
- Add interrupt statistics to the core NMI handlers
- The usual small fixes and cleanups
Drivers:
- Support for Renesas RZ/A1, Annapurna Labs FIC, Meson-G12A SoC and
Amazon Gravition AMR/GIC interrupt controllers.
- Rework of the Renesas INTC controller driver
- ACPI support for Socionext SoCs
- Enhancements to the CSKY interrupt controller
- The usual small fixes and cleanups"
* 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (39 commits)
irq/irqdomain: Fix comment typo
genirq: Update irq stats from NMI handlers
irqchip/gic-pm: Remove PM_CLK dependency
irqchip/al-fic: Introduce Amazon's Annapurna Labs Fabric Interrupt Controller Driver
dt-bindings: interrupt-controller: Add Amazon's Annapurna Labs FIC
softirq: Use __this_cpu_write() in takeover_tasklets()
irqchip/mbigen: Stop printing kernel addresses
irqchip/gic: Add dependency for ARM_GIC_MAX_NR
genirq/affinity: Remove unused argument from [__]irq_build_affinity_masks()
genirq/timings: Add selftest for next event computation
genirq/timings: Add selftest for irqs circular buffer
genirq/timings: Add selftest for circular array
genirq/timings: Encapsulate storing function
genirq/timings: Encapsulate timings push
genirq/timings: Optimize the period detection speed
genirq/timings: Fix timings buffer inspection
genirq/timings: Fix next event index function
irqchip/qcom: Use struct_size() in devm_kzalloc()
irqchip/irq-csky-mpintc: Remove unnecessary loop in interrupt handler
dt-bindings: interrupt-controller: Update csky mpintc
Since this is not really a device with all capabilities, this test
ensures that it has *enough* to make it through the data path
without causing unwanted side-effects (read crash!).
Signed-off-by: Mahesh Bandewar <maheshb@google.com>
A Reed-Solomon code with minimum distance d can correct any error and
erasure pattern that satisfies 2 * #error + #erasures < d. If the
error correction capacity is exceeded, then correct decoding cannot be
guaranteed. The decoder must, however, return a valid codeword or report
failure.
There are two main tests:
- Check for correct behaviour up to the error correction capacity
- Check for correct behaviour beyond error corrupted capacity
Both tests are simple:
1. Generate random data
2. Encode data with the chosen code
3. Add errors and erasures to data
4. Decode the corrupted word
5. Check for correct behaviour
When testing up to capacity we test for:
- Correct decoding
- Correct return value (i.e. the number of corrected symbols)
- That the returned error positions are correct
There are two kinds of erasures; the erased symbol can be corrupted or
not. When counting the number of corrected symbols, erasures without
symbol corruption should not be counted. Similarly, the returned error
positions should only include positions where a correction is necessary.
We run the up to capacity tests for three different interfaces of
decode_rs:
- Use the correction buffers
- Use the correction buffers with syndromes provided by the caller
- Error correction in place (does not check the error positions)
When testing beyond capacity test for silent failures. A silent failure is
when the decoder returns success but the returned word is not a valid
codeword.
There are a couple of options for the tests:
- Verbosity.
- Whether to test for correct behaviour beyond capacity. Default is to
test beyond capacity.
- Whether to allow erasures without symbol corruption. Defaults to yes.
Note that the tests take a couple of minutes to complete.
Signed-off-by: Ferdinand Blomqvist <ferdinand.blomqvist@gmail.com>
Link: https://lkml.kernel.org/r/20190620141039.9874-2-ferdinand.blomqvist@gmail.com
The owner field in the rw_semaphore structure is used primarily for
optimistic spinning. However, identifying the rwsem owner can also be
helpful in debugging as well as tracing locking related issues when
analyzing crash dump. The owner field may also store state information
that can be important to the operation of the rwsem.
So the owner field is now made a permanent member of the rw_semaphore
structure irrespective of CONFIG_RWSEM_SPIN_ON_OWNER.
Signed-off-by: Waiman Long <longman@redhat.com>
Cc: Davidlohr Bueso <dave@stgolabs.net>
Cc: Tim Chen <tim.c.chen@linux.intel.com>
Cc: huang ying <huang.ying.caritas@gmail.com>
Link: https://lkml.kernel.org/r/20190520205918.22251-2-longman@redhat.com
In Linux build system, build targets and installation targets are
separated.
Examples are:
- 'make vmlinux' -> 'make install'
- 'make modules' -> 'make modules_install'
- 'make dtbs' -> 'make dtbs_install'
- 'make vdso' -> 'make vdso_install'
The intention is to run the build targets under the normal privilege,
then the installation targets under the root privilege since we need
the write permission to the system directories.
We have 'make headers_install' but the corresponding 'make headers'
stage does not exist. The purpose of headers_install is to provide
the kernel interface to C library. So, nobody would try to install
headers to /usr/include directly.
If 'sudo make INSTALL_HDR_PATH=/usr/include headers_install' were run,
some build artifacts in the kernel tree would be owned by root because
some of uapi headers are generated by 'uapi-asm-generic', 'archheaders'
targets.
Anyway, I believe it makes sense to split the header installation into
two stages.
[1] 'make headers'
Process headers in uapi directories by scripts/headers_install.sh
and copy them to usr/include
[2] 'make headers_install'
Copy '*.h' verbatim from usr/include to $(INSTALL_HDR_PATH)/include
For the backward compatibility, 'headers_install' depends on 'headers'.
Some samples expect uapi headers in usr/include. So, the 'headers'
target is useful to build up them in the fixed location usr/include
irrespective of INSTALL_HDR_PATH.
Another benefit is to stop polluting the final destination with the
time-stamp files '.install' and '.check'. Maybe you can see them in
your toolchains.
Lastly, my main motivation is to prepare for compile-testing uapi
headers. To build something, we have to save an object and .*.cmd
somewhere. The usr/include/ will be the work directory for that.
Commit 5318321d367c ("samples: disable CONFIG_SAMPLES for UML") used
a big hammer to fix the build errors under the samples/ directory.
Only some samples actually include uapi headers from usr/include.
Introduce CONFIG_HEADERS_INSTALL since 'depends on HEADERS_INSTALL' is
clearer than 'depends on !UML'. If this option is enabled, uapi headers
are installed before starting directory descending.
I added 'depends on HEADERS_INSTALL' to per-sample CONFIG options.
This allows UML to compile some samples.
$ make ARCH=um allmodconfig samples/
[ snip ]
CC [M] samples/configfs/configfs_sample.o
CC [M] samples/kfifo/bytestream-example.o
CC [M] samples/kfifo/dma-example.o
CC [M] samples/kfifo/inttype-example.o
CC [M] samples/kfifo/record-example.o
CC [M] samples/kobject/kobject-example.o
CC [M] samples/kobject/kset-example.o
CC [M] samples/trace_events/trace-events-sample.o
CC [M] samples/trace_printk/trace-printk.o
AR samples/vfio-mdev/built-in.a
AR samples/built-in.a
Prior to commit 257edce66d31 ("kbuild: exploit parallel building for
CONFIG_HEADERS_CHECK"), the sanity check of exported headers was done
as a side-effect of build rule of vmlinux.
That commit is good, but I missed to update the prompt of the Kconfig
entry. For the sake of preciseness, lets' say "when building 'all'".
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
Due to the complexity of the code and the difficulty to debug it, add some
selftests to the framework in order to spot issues or regression at boot
time when the runtime testing is enabled for this subsystem.
This tests the circular buffer at the limits and validates:
- the encoding / decoding of the values
- the macro to browse the irq timings circular buffer
- the function to push data in the circular buffer
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Cc: andriy.shevchenko@linux.intel.com
Link: https://lkml.kernel.org/r/20190527205521.12091-7-daniel.lezcano@linaro.org
Add SPDX license identifiers to all Make/Kconfig files which:
- Have no license information of any form
These files fall under the project license, GPL v2 only. The resulting SPDX
license identifier is:
GPL-2.0-only
It turned out that DEBUG_SLAB_LEAK is still broken even after recent
recue efforts that when there is a large number of objects like
kmemleak_object which is normal on a debug kernel,
# grep kmemleak /proc/slabinfo
kmemleak_object 2243606 3436210 ...
reading /proc/slab_allocators could easily loop forever while processing
the kmemleak_object cache and any additional freeing or allocating
objects will trigger a reprocessing. To make a situation worse,
soft-lockups could easily happen in this sitatuion which will call
printk() to allocate more kmemleak objects to guarantee an infinite
loop.
Also, since it seems no one had noticed when it was totally broken
more than 2-year ago - see the commit fcf88917dd43 ("slab: fix a crash
by reading /proc/slab_allocators"), probably nobody cares about it
anymore due to the decline of the SLAB. Just remove it entirely.
Suggested-by: Vlastimil Babka <vbabka@suse.cz>
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Patch series "init: Do not select DEBUG_KERNEL by default", v5.
CONFIG_DEBUG_KERNEL has been designed to just enable Kconfig options.
Kernel code generatoin should not depend on CONFIG_DEBUG_KERNEL.
Proposed alternative plan: let's add a new symbol, something like
DEBUG_MISC ("Miscellaneous debug code that should be under a more
specific debug option but isn't"), make it depend on DEBUG_KERNEL and be
"default DEBUG_KERNEL" but allow itself to be turned off, and then
mechanically change the small handful of "#ifdef CONFIG_DEBUG_KERNEL" to
"#ifdef CONFIG_DEBUG_MISC".
This patch (of 5):
Introduce DEBUG_MISC ("Miscellaneous debug code that should be under a
more specific debug option but isn't"), make it depend on DEBUG_KERNEL
and be "default DEBUG_KERNEL" but allow itself to be turned off, and
then mechanically change the small handful of "#ifdef
CONFIG_DEBUG_KERNEL" to "#ifdef CONFIG_DEBUG_MISC".
Link: http://lkml.kernel.org/r/20190413224438.10802-2-okaya@kernel.org
Signed-off-by: Sinan Kaya <okaya@kernel.org>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Cc: Anders Roxell <anders.roxell@linaro.org>
Cc: Christophe Leroy <christophe.leroy@c-s.fr>
Cc: Chris Zankel <chris@zankel.net>
Cc: Florian Westphal <fw@strlen.de>
Cc: James Hogan <jhogan@kernel.org>
Cc: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu>
Cc: Max Filippov <jcmvbkbc@gmail.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Michal Hocko <mhocko@suse.com>
Cc: Mike Rapoport <rppt@linux.ibm.com>
Cc: Pablo Neira Ayuso <pablo@netfilter.org>
Cc: Paul Burton <paul.burton@mips.com>
Cc: Thomas Bogendoerfer <tbogendoerfer@suse.de>
This is a lot more appropriate than PI_LIST, which in the kernel one
would assume that it has to do with priority-inheritance; which is not
-- furthermore futexes make use of plists so this can be even more
confusing, albeit the debug nature of the config option.
Link: http://lkml.kernel.org/r/20190317185434.1626-1-dave@stgolabs.net
Signed-off-by: Davidlohr Bueso <dbueso@suse.de>
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
Commit 60a3cdd06394 ("x86: add optimized inlining") introduced
CONFIG_OPTIMIZE_INLINING, but it has been available only for x86.
The idea is obviously arch-agnostic. This commit moves the config entry
from arch/x86/Kconfig.debug to lib/Kconfig.debug so that all
architectures can benefit from it.
This can make a huge difference in kernel image size especially when
CONFIG_OPTIMIZE_FOR_SIZE is enabled.
For example, I got 3.5% smaller arm64 kernel for v5.1-rc1.
dec file
18983424 arch/arm64/boot/Image.before
18321920 arch/arm64/boot/Image.after
This also slightly improves the "Kernel hacking" Kconfig menu as
e61aca5158a8 ("Merge branch 'kconfig-diet' from Dave Hansen') suggested;
this config option would be a good fit in the "compiler option" menu.
Link: http://lkml.kernel.org/r/20190423034959.13525-12-yamada.masahiro@socionext.com
Acked-by: Borislav Petkov <bp@suse.de>
Cc: Boris Brezillon <bbrezillon@kernel.org>
Cc: Brian Norris <computersforpeace@gmail.com>
Cc: Marek Vasut <marek.vasut@gmail.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Mathieu Malaterre <malat@debian.org>
Cc: Miquel Raynal <miquel.raynal@bootlin.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Cc: Stefan Agner <stefan@agner.ch>
"Highlights:
1) Support AES128-CCM ciphers in kTLS, from Vakul Garg.
2) Add fib_sync_mem to control the amount of dirty memory we allow to
queue up between synchronize RCU calls, from David Ahern.
3) Make flow classifier more lockless, from Vlad Buslov.
4) Add PHY downshift support to aquantia driver, from Heiner
Kallweit.
5) Add SKB cache for TCP rx and tx, from Eric Dumazet. This reduces
contention on SLAB spinlocks in heavy RPC workloads.
6) Partial GSO offload support in XFRM, from Boris Pismenny.
7) Add fast link down support to ethtool, from Heiner Kallweit.
8) Use siphash for IP ID generator, from Eric Dumazet.
9) Pull nexthops even further out from ipv4/ipv6 routes and FIB
entries, from David Ahern.
10) Move skb->xmit_more into a per-cpu variable, from Florian
Westphal.
11) Improve eBPF verifier speed and increase maximum program size,
12) Eliminate per-bucket spinlocks in rhashtable, and instead use bit
spinlocks. From Neil Brown.
13) Allow tunneling with GUE encap in ipvs, from Jacky Hu.
14) Improve link partner cap detection in generic PHY code, from
Heiner Kallweit.
15) Add layer 2 encap support to bpf_skb_adjust_room(), from Alan
Maguire.
16) Remove SKB list implementation assumptions in SCTP, your's truly.
17) Various cleanups, optimizations, and simplifications in r8169
driver. From Heiner Kallweit.
18) Add memory accounting on TX and RX path of SCTP, from Xin Long.
19) Switch PHY drivers over to use dynamic featue detection, from
Heiner Kallweit.
20) Support flow steering without masking in dpaa2-eth, from Ioana
Ciocoi.
21) Implement ndo_get_devlink_port in netdevsim driver, from Jiri
Pirko.
22) Increase the strict parsing of current and future netlink
attributes, also export such policies to userspace. From Johannes
Berg.
23) Allow DSA tag drivers to be modular, from Andrew Lunn.
24) Remove legacy DSA probing support, also from Andrew Lunn.
25) Allow ll_temac driver to be used on non-x86 platforms, from Esben
Haabendal.
26) Add a generic tracepoint for TX queue timeouts to ease debugging,
from Cong Wang.
27) More indirect call optimizations, from Paolo Abeni"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1763 commits)
cxgb4: Fix error path in cxgb4_init_module
net: phy: improve pause mode reporting in phy_print_status
dt-bindings: net: Fix a typo in the phy-mode list for ethernet bindings
net: macb: Change interrupt and napi enable order in open
net: ll_temac: Improve error message on error IRQ
net/sched: remove block pointer from common offload structure
net: ethernet: support of_get_mac_address new ERR_PTR error
net: usb: smsc: fix warning reported by kbuild test robot
staging: octeon-ethernet: Fix of_get_mac_address ERR_PTR check
net: dsa: support of_get_mac_address new ERR_PTR error
net: dsa: sja1105: Fix status initialization in sja1105_get_ethtool_stats
vrf: sit mtu should not be updated when vrf netdev is the link
net: dsa: Fix error cleanup path in dsa_init_module
l2tp: Fix possible NULL pointer dereference
taprio: add null check on sched_nest to avoid potential null pointer dereference
net: mvpp2: cls: fix less than zero check on a u32 variable
net_sched: sch_fq: handle non connected flows
net_sched: sch_fq: do not assume EDT packets are ordered
net: hns3: use devm_kcalloc when allocating desc_cb
net: hns3: some cleanup for struct hns3_enet_ring
Pull block updates from Jens Axboe:
"Nothing major in this series, just fixes and improvements all over the
map. This contains:
- Series of fixes for sed-opal (David, Jonas)
- Fixes and performance tweaks for BFQ (via Paolo)
- Set of fixes for bcache (via Coly)
- Set of fixes for md (via Song)
- Enabling multi-page for passthrough requests (Ming)
- Queue release fix series (Ming)
- Device notification improvements (Martin)
- Propagate underlying device rotational status in loop (Holger)
- Removal of mtip32xx trim support, which has been disabled for years
(Christoph)
- Improvement and cleanup of nvme command handling (Christoph)
- Add block SPDX tags (Christoph)
- Cleanup/hardening of bio/bvec iteration (Christoph)
- A few NVMe pull requests (Christoph)
- Removal of CONFIG_LBDAF (Christoph)
- Various little fixes here and there"
* tag 'for-5.2/block-20190507' of git://git.kernel.dk/linux-block: (164 commits)
block: fix mismerge in bvec_advance
block: don't drain in-progress dispatch in blk_cleanup_queue()
blk-mq: move cancel of hctx->run_work into blk_mq_hw_sysfs_release
blk-mq: always free hctx after request queue is freed
blk-mq: split blk_mq_alloc_and_init_hctx into two parts
blk-mq: free hw queue's resource in hctx's release handler
blk-mq: move cancel of requeue_work into blk_mq_release
blk-mq: grab .q_usage_counter when queuing request from plug code path
block: fix function name in comment
nvmet: protect discovery change log event list iteration
nvme: mark nvme_core_init and nvme_core_exit static
nvme: move command size checks to the core
nvme-fabrics: check more command sizes
nvme-pci: check more command sizes
nvme-pci: remove an unneeded variable initialization
nvme-pci: unquiesce admin queue on shutdown
nvme-pci: shutdown on timeout during deletion
nvme-pci: fix psdt field for single segment sgls
nvme-multipath: don't print ANA group state by default
nvme-multipath: split bios with the ns_head bio_set before submitting
git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest
Pull Kselftest updates from Shuah Khan:
- fixes to seccomp test, and kselftest framework
- cleanups to remove duplicate header defines
- fixes to efivarfs "make clean" target
- cgroup cleanup path
- Moving the IMA kexec_load selftest to selftests/kexec work from Mimi
Johar and Petr Vorel
- A framework to kselftest for writing kernel test modules addition
from Tobin C. Harding
* tag 'linux-kselftest-5.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest: (29 commits)
selftests: build and run gpio when output directory is the src dir
selftests/ipc: Fix msgque compiler warnings
selftests/efivarfs: clean up test files from test_create*()
selftests: fix headers_install circular dependency
selftests/kexec: update get_secureboot_mode
selftests/kexec: make kexec_load test independent of IMA being enabled
selftests/kexec: check kexec_load and kexec_file_load are enabled
selftests/kexec: Add missing '=y' to config options
selftests/kexec: kexec_file_load syscall test
selftests/kexec: define "require_root_privileges"
selftests/kexec: define common logging functions
selftests/kexec: define a set of common functions
selftests/kexec: cleanup the kexec selftest
selftests/kexec: move the IMA kexec_load selftest to selftests/kexec
selftests/harness: Add 30 second timeout per test
selftests/seccomp: Handle namespace failures gracefully
selftests: cgroup: fix cleanup path in test_memcg_subtree_control()
selftests: efivarfs: remove the test_create_read file if it was exist
rseq/selftests: Adapt number of threads to the number of detected cpus
lib: Add test module for strscpy_pad
Three trivial overlapping conflicts.
If CONFIG_TEST_KMOD is set to M, while CONFIG_BLOCK is not set, XFS and
BTRFS can not be compiled successly.
Link: http://lkml.kernel.org/r/20190410075434.35220-1-yuehaibing@huawei.com
Fixes: d9c6a72d6fa2 ("kmod: add test driver to stress test the module loader")
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
Cc: Robin Murphy <robin.murphy@arm.com>
Cc: Luis Chamberlain <mcgrof@kernel.org>
Cc: <stable@vger.kernel.org>
Two easy cases of overlapping changes.
Pull in v5.1-rc6 to resolve two conflicts. One is in BFQ, in just a
comment, and is trivial. The other one is a conflict due to a later fix
in the bio multi-page work, and needs a bit more care.
* tag 'v5.1-rc6': (770 commits)
Linux 5.1-rc6
block: make sure that bvec length can't be overflow
block: kill all_q_node in request_queue
x86/cpu/intel: Lower the "ENERGY_PERF_BIAS: Set to normal" message's log priority
coredump: fix race condition between mmget_not_zero()/get_task_mm() and core dumping
mm/kmemleak.c: fix unused-function warning
init: initialize jump labels before command line option parsing
kernel/watchdog_hld.c: hard lockup message should end with a newline
kcov: improve CONFIG_ARCH_HAS_KCOV help text
mm: fix inactive list balancing between NUMA nodes and cgroups
mm/hotplug: treat CMA pages as unmovable
proc: fixup proc-pid-vm test
proc: fix map_files test on F29
mm/vmstat.c: fix /proc/vmstat format for CONFIG_DEBUG_TLBFLUSH=y CONFIG_SMP=n
mm/memory_hotplug: do not unlock after failing to take the device_hotplug_lock
mm: swapoff: shmem_unuse() stop eviction without igrab()
mm: swapoff: take notice of completion sooner
mm: swapoff: remove too limiting SWAP_UNUSE_MAX_TRIES
mm: swapoff: shmem_find_swap_entries() filter out other types
slab: store tagged freelist for off-slab slabmgmt
The help text for CONFIG_ARCH_HAS_KCOV is stale, and describes the
feature as being enabled only for x86_64, when it is now enabled for
several architectures, including arm, arm64, powerpc, and s390.
Let's remove that stale help text, and update it along the lines of hat
for ARCH_HAS_FORTIFY_SOURCE, better describing when an architecture
should select CONFIG_ARCH_HAS_KCOV.
Link: http://lkml.kernel.org/r/20190412102733.5154-1-mark.rutland@arm.com
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Add a test module for the new strscpy_pad() function. Tie it into the
kselftest infrastructure for lib/ tests.
Signed-off-by: Tobin C. Harding <tobin@kernel.org>
Signed-off-by: Shuah Khan <shuah@kernel.org>
Currently support for 64-bit sector_t and blkcnt_t is optional on 32-bit
architectures. These types are required to support block device and/or
file sizes larger than 2 TiB, and have generally defaulted to on for
a long time. Enabling the option only increases the i386 tinyconfig
size by 145 bytes, and many data structures already always use
64-bit values for their in-core and on-disk data structures anyway,
so there should not be a large change in dynamic memory usage either.
Dropping this option removes a somewhat weird non-default config that
has cause various bugs or compiler warnings when actually used.
This patch adds new config option to trigger generation of BTF type
information from DWARF debuginfo for vmlinux and kernel modules through
pahole, which in turn relies on libbpf for btf_dedup() algorithm.
The intent is to record compact type information of all types used
inside kernel, including all the structs/unions/typedefs/etc. This
enables BPF's compile-once-run-everywhere ([0]) approach, in which
tracing programs that are inspecting kernel's internal data (e.g.,
struct task_struct) can be compiled on a system running some kernel
version, but would be possible to run on other kernel versions (and
configurations) without recompilation, even if the layout of structs
changed and/or some of the fields were added, removed, or renamed.
This is only possible if BPF loader can get kernel type info to adjust
all the offsets correctly. This patch is a first time in this direction,
making sure that BTF type info is part of Linux kernel image in
non-loadable ELF section.
BTF deduplication ([1]) algorithm typically provides 100x savings
compared to DWARF data, so resulting .BTF section is not big as is
typically about 2MB in size.
[0] http://vger.kernel.org/lpc-bpf2018.html#session-2
[1] https://facebookmicrosites.github.io/bpf/blog/2018/11/14/btf-enhancement.html
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Daniel Borkmann <daniel@iogearbox.net>
Cc: Alexei Starovoitov <ast@fb.com>
Cc: Yonghong Song <yhs@fb.com>
Cc: Martin KaFai Lau <kafai@fb.com>
Signed-off-by: Andrii Nakryiko <andriin@fb.com>
Acked-by: Alexei Starovoitov <ast@kernel.org>
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
- do not generate unneeded top-level built-in.a
- let git ignore O= directory entirely
- optimize scripts/kallsyms slightly
- exclude DWARF info from *.s regardless of config options
- fix GCC toolchain search path for Clang to prepare ld.lld support
- do not generate modules.order when CONFIG_MODULES is disabled
- simplify single target rules and remove VPATH for external module
build
- allow to add optional flags to dpkg-buildpackage when building
deb-pkg
- move some compiler option tests from Makefile to Kconfig
- various Makefile cleanups
* tag 'kbuild-v5.1' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild: (40 commits)
kbuild: remove scripts/basic/% build target
kbuild: use -Werror=implicit-... instead of -Werror-implicit-...
kbuild: clean up scripts/gcc-version.sh
kbuild: remove cc-version macro
kbuild: update comment block of scripts/clang-version.sh
kbuild: remove commented-out INITRD_COMPRESS
kbuild: move -gsplit-dwarf, -gdwarf-4 option tests to Kconfig
kbuild: [bin]deb-pkg: add DPKG_FLAGS variable
kbuild: move ".config not found!" message from Kconfig to Makefile
kbuild: invoke syncconfig if include/config/auto.conf.cmd is missing
kbuild: simplify single target rules
kbuild: remove empty rules for makefiles
kbuild: make -r/-R effective in top Makefile for old Make versions
kbuild: move tools_silent to a more relevant place
kbuild: compute false-positive -Wmaybe-uninitialized cases in Kconfig
kbuild: refactor cc-cross-prefix implementation
kbuild: hardcode genksyms path and remove GENKSYMS variable
scripts/gdb: refactor rules for symlink creation
kbuild: create symlink to vmlinux-gdb.py in scripts_gdb target
scripts/gdb: do not descend into scripts/gdb from scripts
Pull DMA mapping updates from Christoph Hellwig:
- add debugfs support for dumping dma-debug information (Corentin
Labbe)
- Kconfig cleanups (Andy Shevchenko and me)
- debugfs cleanups (Greg Kroah-Hartman)
- improve dma_map_resource and use it in the media code
- arch_setup_dma_ops / arch_teardown_dma_ops cleanups
- various small cleanups and improvements for the per-device coherent
allocator
- make the DMA mask an upper bound and don't fail "too large" dma mask
in the remaning two architectures - this will allow big driver
cleanups in the following merge windows
* tag 'dma-mapping-5.1' of git://git.infradead.org/users/hch/dma-mapping: (21 commits)
Documentation/DMA-API-HOWTO: update dma_mask sections
sparc64/pci_sun4v: allow large DMA masks
sparc64/iommu: allow large DMA masks
sparc64: refactor the ali DMA quirk
ccio: allow large DMA masks
dma-mapping: remove the DMA_MEMORY_EXCLUSIVE flag
dma-mapping: remove dma_mark_declared_memory_occupied
dma-mapping: move CONFIG_DMA_CMA to kernel/dma/Kconfig
dma-mapping: improve selection of dma_declare_coherent availability
dma-mapping: remove an incorrect __iommem annotation
of: select OF_RESERVED_MEM automatically
device.h: dma_mem is only needed for HAVE_GENERIC_DMA_COHERENT
mfd/sm501: depend on HAS_DMA
dma-mapping: add a kconfig symbol for arch_teardown_dma_ops availability
dma-mapping: add a kconfig symbol for arch_setup_dma_ops availability
dma-mapping: move debug configuration options to kernel/dma
dma-debug: add dumping facility via debugfs
dma: debug: no need to check return value of debugfs_create functions
videobuf2: replace a layering violation with dma_map_resource
dma-mapping: don't BUG when calling dma_map_resource on RAM
git://git.kernel.org/pub/scm/linux/kernel/git/pmladek/printk
Pull printk updates from Petr Mladek:
- Allow to sort mixed lines by an extra information about the caller
- Remove no longer used LOG_PREFIX.
- Some clean up and documentation update.
* tag 'printk-for-5.1' of git://git.kernel.org/pub/scm/linux/kernel/git/pmladek/printk:
printk/docs: Add extra integer types to printk-formats
printk: Remove no longer used LOG_PREFIX.
lib/vsprintf: Remove %pCr remnant in comment
printk: Pass caller information to log_store().
printk: Add caller information to printk() output.
git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux
Pull gcc-plugins updates from Kees Cook:
"This adds additional type coverage to the existing structleak plugin
and adds a large set of selftests to help evaluate stack variable
zero-initialization coverage.
That can be used to test whatever instrumentation might be performing
zero-initialization: either with the structleak plugin or with Clang's
coming "-ftrivial-auto-var-init=zero" option.
Summary:
- Add scalar and array initialization coverage
- Refactor Kconfig to make options more clear
- Add self-test module for testing automatic initialization"
* tag 'gcc-plugins-v5.1-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux:
lib: Introduce test_stackinit module
gcc-plugins: structleak: Generalize to all variable types
git://git.kernel.org/pub/scm/linux/kernel/git/livepatching/livepatching
Pull livepatching updates from Jiri Kosina:
- support for something we call 'atomic replace', and allows for much
better handling of cumulative patches (which is something very useful
for distros), from Jason Baron with help of Petr Mladek and Joe
Lawrence
- improvement of handling of tasks blocking finalization, from Miroslav
Benes
- update of MAINTAINERS file to reflect move towards group
maintainership
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/livepatching/livepatching: (22 commits)
livepatch/selftests: use "$@" to preserve argument list
livepatch: Module coming and going callbacks can proceed with all listed patches
livepatch: Proper error handling in the shadow variables selftest
livepatch: return -ENOMEM on ptr_id() allocation failure
livepatch: Introduce klp_for_each_patch macro
livepatch: core: Return EOPNOTSUPP instead of ENOSYS
selftests/livepatch: add DYNAMIC_DEBUG config dependency
livepatch: samples: non static warnings fix
livepatch: update MAINTAINERS
livepatch: Remove signal sysfs attribute
livepatch: Send a fake signal periodically
selftests/livepatch: introduce tests
livepatch: Remove ordering (stacking) of the livepatches
livepatch: Atomic replace and cumulative patches documentation
livepatch: Remove Nop structures when unused
livepatch: Add atomic replace
livepatch: Use lists to manage patches, objects and functions
livepatch: Simplify API by removing registration step
livepatch: Don't block the removal of patches loaded after a forced transition
livepatch: Consolidate klp_free functions
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver updates from Greg KH:
"Here is the big char/misc driver patch pull request for 5.1-rc1.
The largest thing by far is the new habanalabs driver for their AI
accelerator chip. For now it is in the drivers/misc directory but will
probably move to a new directory soon along with other drivers of this
type.
Other than that, just the usual set of individual driver updates and
fixes. There's an "odd" merge in here from the DRM tree that they
asked me to do as the MEI driver is starting to interact with the i915
driver, and it needed some coordination. All of those patches have
been properly acked by the relevant subsystem maintainers.
All of these have been in linux-next with no reported issues, most for
quite some time"
* tag 'char-misc-5.1-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (219 commits)
habanalabs: adjust Kconfig to fix build errors
habanalabs: use %px instead of %p in error print
habanalabs: use do_div for 64-bit divisions
intel_th: gth: Fix an off-by-one in output unassigning
habanalabs: fix little-endian<->cpu conversion warnings
habanalabs: use NULL to initialize array of pointers
habanalabs: soft-reset device if context-switch fails
habanalabs: print pointer using %p
habanalabs: fix memory leak with CBs with unaligned size
habanalabs: return correct error code on MMU mapping failure
habanalabs: add comments in uapi/misc/habanalabs.h
habanalabs: extend QMAN0 job timeout
habanalabs: set DMA0 completion to SOB 1007
habanalabs: fix validation of WREG32 to DMA completion
habanalabs: fix mmu cache registers init
habanalabs: disable CPU access on timeouts
habanalabs: add MMU DRAM default page mapping
habanalabs: Dissociate RAZWI info from event types
misc/habanalabs: adjust Kconfig to fix build errors
Move the PAGE_OWNER option from submenu "Compile-time checks and
compiler options" to dedicated submenu "Memory Debugging".
Link: http://lkml.kernel.org/r/20190120024254.6270-1-changbin.du@gmail.com
Signed-off-by: Changbin Du <changbin.du@gmail.com>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Randy Dunlap <rdunlap@infradead.org>
This adds a new kernel module for analysis of vmalloc allocator. It is
only enabled as a module. There are two main reasons this module should
be used for: performance evaluation and stressing of vmalloc subsystem.
It consists of several test cases. As of now there are 8. The module
has five parameters we can specify to change its the behaviour.
1) run_test_mask - set of tests to be run
id: 1, name: fix_size_alloc_test
id: 2, name: full_fit_alloc_test
id: 4, name: long_busy_list_alloc_test
id: 8, name: random_size_alloc_test
id: 16, name: fix_align_alloc_test
id: 32, name: random_size_align_alloc_test
id: 64, name: align_shift_alloc_test
id: 128, name: pcpu_alloc_test
By default all tests are in run test mask. If you want to select some
specific tests it is possible to pass the mask. For example for first,
second and fourth tests we go 11 value.
2) test_repeat_count - how many times each test should be repeated
By default it is one time per test. It is possible to pass any number.
As high the value is the test duration gets increased.
3) test_loop_count - internal test loop counter. By default it is set
to 1000000.
4) single_cpu_test - use one CPU to run the tests
By default this parameter is set to false. It means that all online
CPUs execute tests. By setting it to 1, the tests are executed by
first online CPU only.
5) sequential_test_order - run tests in sequential order
By default this parameter is set to false. It means that before running
tests the order is shuffled. It is possible to make it sequential, just
set it to 1.
Performance analysis:
In order to evaluate performance of vmalloc allocations, usually it
makes sense to use only one CPU that runs tests, use sequential order,
number of repeat tests can be different as well as set of test mask.
For example if we want to run all tests, to use one CPU and repeat each
test 3 times. Insert the module passing following parameters:
single_cpu_test=1 sequential_test_order=1 test_repeat_count=3
with following output:
<snip>
Summary: fix_size_alloc_test passed: 3 failed: 0 repeat: 3 loops: 1000000 avg: 901177 usec
Summary: full_fit_alloc_test passed: 3 failed: 0 repeat: 3 loops: 1000000 avg: 1039341 usec
Summary: long_busy_list_alloc_test passed: 3 failed: 0 repeat: 3 loops: 1000000 avg: 11775763 usec
Summary: random_size_alloc_test passed 3: failed: 0 repeat: 3 loops: 1000000 avg: 6081992 usec
Summary: fix_align_alloc_test passed: 3 failed: 0 repeat: 3, loops: 1000000 avg: 2003712 usec
Summary: random_size_align_alloc_test passed: 3 failed: 0 repeat: 3 loops: 1000000 avg: 2895689 usec
Summary: align_shift_alloc_test passed: 0 failed: 3 repeat: 3 loops: 1000000 avg: 573 usec
Summary: pcpu_alloc_test passed: 3 failed: 0 repeat: 3 loops: 1000000 avg: 95802 usec
All test took CPU0=192945605995 cycles
<snip>
The align_shift_alloc_test is expected to be failed.
Stressing:
In order to stress the vmalloc subsystem we run all available test cases
on all available CPUs simultaneously. In order to prevent constant behaviour
pattern, the test cases array is shuffled by default to randomize the order
of test execution.
For example if we want to run all tests(default), use all online CPUs(default)
with shuffled order(default) and to repeat each test 30 times. The command
would be like:
modprobe vmalloc_test test_repeat_count=30
Expected results are the system is alive, there are no any BUG_ONs or Kernel
Panics the tests are completed, no memory leaks.
[urezki@gmail.com: fix 32-bit builds]
Link: http://lkml.kernel.org/r/20190106214839.ffvjvmrn52uqog7k@pc636
[urezki@gmail.com: make CONFIG_TEST_VMALLOC depend on CONFIG_MMU]
Link: http://lkml.kernel.org/r/20190219085441.s6bg2gpy4esny5vw@pc636
Link: http://lkml.kernel.org/r/20190103142108.20744-3-urezki@gmail.com
Signed-off-by: Uladzislau Rezki (Sony) <urezki@gmail.com>
Cc: Matthew Wilcox <willy@infradead.org>
Cc: Oleksiy Avramchenko <oleksiy.avramchenko@sonymobile.com>
Cc: Shuah Khan <shuah@kernel.org>
