path: root/lib/Kconfig
2013-11-21Merge branch 'for-linus2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "In this patchset, we finally get an SELinux update, with Paul Moore taking over as maintainer of that code. Also a significant update for the Keys subsystem, as well as maintenance updates to Smack, IMA, TPM, and Apparmor" and since I wanted to know more about the updates to key handling, here's the explanation from David Howells on that: "Okay. There are a number of separate bits. I'll go over the big bits and the odd important other bit, most of the smaller bits are just fixes and cleanups. If you want the small bits accounting for, I can do that too. (1) Keyring capacity expansion. KEYS: Consolidate the concept of an 'index key' for key access KEYS: Introduce a search context structure KEYS: Search for auth-key by name rather than target key ID Add a generic associative array implementation. KEYS: Expand the capacity of a keyring Several of the patches are providing an expansion of the capacity of a keyring. Currently, the maximum size of a keyring payload is one page. Subtract a small header and then divide up into pointers, that only gives you ~500 pointers on an x86_64 box. However, since the NFS idmapper uses a keyring to store ID mapping data, that has proven to be insufficient to the cause. Whatever data structure I use to handle the keyring payload, it can only store pointers to keys, not the keys themselves because several keyrings may point to a single key. This precludes inserting, say, and rb_node struct into the key struct for this purpose. I could make an rbtree of records such that each record has an rb_node and a key pointer, but that would use four words of space per key stored in the keyring. It would, however, be able to use much existing code. I selected instead a non-rebalancing radix-tree type approach as that could have a better space-used/key-pointer ratio. I could have used the radix tree implementation that we already have and insert keys into it by their serial numbers, but that means any sort of search must iterate over the whole radix tree. Further, its nodes are a bit on the capacious side for what I want - especially given that key serial numbers are randomly allocated, thus leaving a lot of empty space in the tree. So what I have is an associative array that internally is a radix-tree with 16 pointers per node where the index key is constructed from the key type pointer and the key description. This means that an exact lookup by type+description is very fast as this tells us how to navigate directly to the target key. I made the data structure general in lib/assoc_array.c as far as it is concerned, its index key is just a sequence of bits that leads to a pointer. It's possible that someone else will be able to make use of it also. FS-Cache might, for example. (2) Mark keys as 'trusted' and keyrings as 'trusted only'. KEYS: verify a certificate is signed by a 'trusted' key KEYS: Make the system 'trusted' keyring viewable by userspace KEYS: Add a 'trusted' flag and a 'trusted only' flag KEYS: Separate the kernel signature checking keyring from module signing These patches allow keys carrying asymmetric public keys to be marked as being 'trusted' and allow keyrings to be marked as only permitting the addition or linkage of trusted keys. Keys loaded from hardware during kernel boot or compiled into the kernel during build are marked as being trusted automatically. New keys can be loaded at runtime with add_key(). They are checked against the system keyring contents and if their signatures can be validated with keys that are already marked trusted, then they are marked trusted also and can thus be added into the master keyring. Patches from Mimi Zohar make this usable with the IMA keyrings also. (3) Remove the date checks on the key used to validate a module signature. X.509: Remove certificate date checks It's not reasonable to reject a signature just because the key that it was generated with is no longer valid datewise - especially if the kernel hasn't yet managed to set the system clock when the first module is loaded - so just remove those checks. (4) Make it simpler to deal with additional X.509 being loaded into the kernel. KEYS: Load *.x509 files into kernel keyring KEYS: Have make canonicalise the paths of the X.509 certs better to deduplicate The builder of the kernel now just places files with the extension ".x509" into the kernel source or build trees and they're concatenated by the kernel build and stuffed into the appropriate section. (5) Add support for userspace kerberos to use keyrings. KEYS: Add per-user_namespace registers for persistent per-UID kerberos caches KEYS: Implement a big key type that can save to tmpfs Fedora went to, by default, storing kerberos tickets and tokens in tmpfs. We looked at storing it in keyrings instead as that confers certain advantages such as tickets being automatically deleted after a certain amount of time and the ability for the kernel to get at these tokens more easily. To make this work, two things were needed: (a) A way for the tickets to persist beyond the lifetime of all a user's sessions so that cron-driven processes can still use them. The problem is that a user's session keyrings are deleted when the session that spawned them logs out and the user's user keyring is deleted when the UID is deleted (typically when the last log out happens), so neither of these places is suitable. I've added a system keyring into which a 'persistent' keyring is created for each UID on request. Each time a user requests their persistent keyring, the expiry time on it is set anew. If the user doesn't ask for it for, say, three days, the keyring is automatically expired and garbage collected using the existing gc. All the kerberos tokens it held are then also gc'd. (b) A key type that can hold really big tickets (up to 1MB in size). The problem is that Active Directory can return huge tickets with lots of auxiliary data attached. We don't, however, want to eat up huge tracts of unswappable kernel space for this, so if the ticket is greater than a certain size, we create a swappable shmem file and dump the contents in there and just live with the fact we then have an inode and a dentry overhead. If the ticket is smaller than that, we slap it in a kmalloc()'d buffer" * 'for-linus2' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (121 commits) KEYS: Fix keyring content gc scanner KEYS: Fix error handling in big_key instantiation KEYS: Fix UID check in keyctl_get_persistent() KEYS: The RSA public key algorithm needs to select MPILIB ima: define '_ima' as a builtin 'trusted' keyring ima: extend the measurement list to include the file signature kernel/system_certificate.S: use real contents instead of macro GLOBAL() KEYS: fix error return code in big_key_instantiate() KEYS: Fix keyring quota misaccounting on key replacement and unlink KEYS: Fix a race between negating a key and reading the error set KEYS: Make BIG_KEYS boolean apparmor: remove the "task" arg from may_change_ptraced_domain() apparmor: remove parent task info from audit logging apparmor: remove tsk field from the apparmor_audit_struct apparmor: fix capability to not use the current task, during reporting Smack: Ptrace access check mode ima: provide hash algo info in the xattr ima: enable support for larger default filedata hash algorithms ima: define kernel parameter 'ima_template=' to change configured default ima: add Kconfig default measurement list template ...
2013-11-15lockref: use BLOATED_SPINLOCKS to avoid explicit config dependenciesPeter Zijlstra
Avoid the fragile Kconfig construct guestimating spinlock_t sizes; use a friendly compile-time test to determine this. [kirill.shutemov@linux.intel.com: drop CONFIG_CMPXCHG_LOCKREF] Signed-off-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-11random32: add test cases for taus113 implementationDaniel Borkmann
We generated a battery of 100 test cases from GSL taus113 implemention and compare the results from a particular seed and a particular iteration with our implementation in the kernel. We have verified on 32 and 64 bit machines that our taus113 kernel implementation gives same results as GSL taus113 implementation: [ 0.147370] prandom: seed boundary self test passed [ 0.148078] prandom: 100 self tests passed This is a Kconfig option that is disabled on default, just like the crc32 init selftests in order to not unnecessary slow down boot process. We also refactored out prandom_seed_very_weak() as it's now used in multiple places in order to reduce redundant code. GSL code we used for generating test cases: int i, j; srand(time(NULL)); for (i = 0; i < 100; ++i) { int iteration = 500 + (rand() % 500); gsl_rng_default_seed = rand() + 1; gsl_rng *r = gsl_rng_alloc(gsl_rng_taus113); printf("\t{ %lu, ", gsl_rng_default_seed); for (j = 0; j < iteration - 1; ++j) gsl_rng_get(r); printf("%u, %lu },\n", iteration, gsl_rng_get(r)); gsl_rng_free(r); } Joint work with Hannes Frederic Sowa. Cc: Florian Weimer <fweimer@redhat.com> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-24Add a generic associative array implementation.David Howells
Add a generic associative array implementation that can be used as the container for keyrings, thereby massively increasing the capacity available whilst also speeding up searching in keyrings that contain a lot of keys. This may also be useful in FS-Cache for tracking cookies. Documentation is added into Documentation/associative_array.txt Some of the properties of the implementation are: (1) Objects are opaque pointers. The implementation does not care where they point (if anywhere) or what they point to (if anything). [!] NOTE: Pointers to objects _must_ be zero in the two least significant bits. (2) Objects do not need to contain linkage blocks for use by the array. This permits an object to be located in multiple arrays simultaneously. Rather, the array is made up of metadata blocks that point to objects. (3) Objects are labelled as being one of two types (the type is a bool value). This information is stored in the array, but has no consequence to the array itself or its algorithms. (4) Objects require index keys to locate them within the array. (5) Index keys must be unique. Inserting an object with the same key as one already in the array will replace the old object. (6) Index keys can be of any length and can be of different lengths. (7) Index keys should encode the length early on, before any variation due to length is seen. (8) Index keys can include a hash to scatter objects throughout the array. (9) The array can iterated over. The objects will not necessarily come out in key order. (10) The array can be iterated whilst it is being modified, provided the RCU readlock is being held by the iterator. Note, however, under these circumstances, some objects may be seen more than once. If this is a problem, the iterator should lock against modification. Objects will not be missed, however, unless deleted. (11) Objects in the array can be looked up by means of their index key. (12) Objects can be looked up whilst the array is being modified, provided the RCU readlock is being held by the thread doing the look up. The implementation uses a tree of 16-pointer nodes internally that are indexed on each level by nibbles from the index key. To improve memory efficiency, shortcuts can be emplaced to skip over what would otherwise be a series of single-occupancy nodes. Further, nodes pack leaf object pointers into spare space in the node rather than making an extra branch until as such time an object needs to be added to a full node. Signed-off-by: David Howells <dhowells@redhat.com>
2013-09-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto update from Herbert Xu: "Here is the crypto update for 3.12: - Added MODULE_SOFTDEP to allow pre-loading of modules. - Reinstated crct10dif driver using the module softdep feature. - Allow via rng driver to be auto-loaded. - Split large input data when necessary in nx. - Handle zero length messages correctly for GCM/XCBC in nx. - Handle SHA-2 chunks bigger than block size properly in nx. - Handle unaligned lengths in omap-aes. - Added SHA384/SHA512 to omap-sham. - Added OMAP5/AM43XX SHAM support. - Added OMAP4 TRNG support. - Misc fixes" * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (66 commits) Reinstate "crypto: crct10dif - Wrap crc_t10dif function all to use crypto transform framework" hwrng: via - Add MODULE_DEVICE_TABLE crypto: fcrypt - Fix bitoperation for compilation with clang crypto: nx - fix SHA-2 for chunks bigger than block size crypto: nx - fix GCM for zero length messages crypto: nx - fix XCBC for zero length messages crypto: nx - fix limits to sg lists for AES-CCM crypto: nx - fix limits to sg lists for AES-XCBC crypto: nx - fix limits to sg lists for AES-GCM crypto: nx - fix limits to sg lists for AES-CTR crypto: nx - fix limits to sg lists for AES-CBC crypto: nx - fix limits to sg lists for AES-ECB crypto: nx - add offset to nx_build_sg_lists() padata - Register hotcpu notifier after initialization padata - share code between CPU_ONLINE and CPU_DOWN_FAILED, same to CPU_DOWN_PREPARE and CPU_UP_CANCELED hwrng: omap - reorder OMAP TRNG driver code crypto: omap-sham - correct dma burst size crypto: omap-sham - Enable Polling mode if DMA fails crypto: tegra-aes - bitwise vs logical and crypto: sahara - checking the wrong variable ...
2013-09-07Reinstate "crypto: crct10dif - Wrap crc_t10dif function all to use crypto ↵Herbert Xu
transform framework" This patch reinstates commits 67822649d7305caf3dd50ed46c27b99c94eff996 39761214eefc6b070f29402aa1165f24d789b3f7 0b95a7f85718adcbba36407ef88bba0a7379ed03 31d939625a9a20b1badd2d4e6bf6fd39fa523405 2d31e518a42828df7877bca23a958627d60408bc Now that module softdeps are in the kernel we can use that to resolve the boot issue which cause the revert. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-09-02lockref: implement lockless reference count updates using cmpxchg()Linus Torvalds
Instead of taking the spinlock, the lockless versions atomically check that the lock is not taken, and do the reference count update using a cmpxchg() loop. This is semantically identical to doing the reference count update protected by the lock, but avoids the "wait for lock" contention that you get when accesses to the reference count are contended. Note that a "lockref" is absolutely _not_ equivalent to an atomic_t. Even when the lockref reference counts are updated atomically with cmpxchg, the fact that they also verify the state of the spinlock means that the lockless updates can never happen while somebody else holds the spinlock. So while "lockref_put_or_lock()" looks a lot like just another name for "atomic_dec_and_lock()", and both optimize to lockless updates, they are fundamentally different: the decrement done by atomic_dec_and_lock() is truly independent of any lock (as long as it doesn't decrement to zero), so a locked region can still see the count change. The lockref structure, in contrast, really is a *locked* reference count. If you hold the spinlock, the reference count will be stable and you can modify the reference count without using atomics, because even the lockless updates will see and respect the state of the lock. In order to enable the cmpxchg lockless code, the architecture needs to do three things: (1) Make sure that the "arch_spinlock_t" and an "unsigned int" can fit in an aligned u64, and have a "cmpxchg()" implementation that works on such a u64 data type. (2) define a helper function to test for a spinlock being unlocked ("arch_spin_value_unlocked()") (3) select the "ARCH_USE_CMPXCHG_LOCKREF" config variable in its Kconfig file. This enables it for x86-64 (but not 32-bit, we'd need to make sure cmpxchg() turns into the proper cmpxchg8b in order to enable it for 32-bit mode). Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto fixes from Herbert Xu: "This push fixes a memory corruption issue in caam, as well as reverting the new optimised crct10dif implementation as it breaks boot on initrd systems. Hopefully crct10dif will be reinstated once the supporting code is added so that it doesn't break boot" * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: Revert "crypto: crct10dif - Wrap crc_t10dif function all to use crypto transform framework" crypto: caam - Fixed the memory out of bound overwrite issue
2013-07-24Revert "crypto: crct10dif - Wrap crc_t10dif function all to use crypto ↵Herbert Xu
transform framework" This reverts commits 67822649d7305caf3dd50ed46c27b99c94eff996 39761214eefc6b070f29402aa1165f24d789b3f7 0b95a7f85718adcbba36407ef88bba0a7379ed03 31d939625a9a20b1badd2d4e6bf6fd39fa523405 2d31e518a42828df7877bca23a958627d60408bc Unfortunately this change broke boot on some systems that used an initrd which does not include the newly created crct10dif modules. As these modules are required by sd_mod under certain configurations this is a serious problem. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-07-09lib: add lz4 compressor moduleChanho Min
This patchset is for supporting LZ4 compression and the crypto API using it. As shown below, the size of data is a little bit bigger but compressing speed is faster under the enabled unaligned memory access. We can use lz4 de/compression through crypto API as well. Also, It will be useful for another potential user of lz4 compression. lz4 Compression Benchmark: Compiler: ARM gcc 4.6.4 ARMv7, 1 GHz based board Kernel: linux 3.4 Uncompressed data Size: 101 MB Compressed Size compression Speed LZO 72.1MB 32.1MB/s, 33.0MB/s(UA) LZ4 75.1MB 30.4MB/s, 35.9MB/s(UA) LZ4HC 59.8MB 2.4MB/s, 2.5MB/s(UA) - UA: Unaligned memory Access support - Latest patch set for LZO applied This patch: Add support for LZ4 compression in the Linux Kernel. LZ4 Compression APIs for kernel are based on LZ4 implementation by Yann Collet and were changed for kernel coding style. LZ4 homepage : http://fastcompression.blogspot.com/p/lz4.html LZ4 source repository : http://code.google.com/p/lz4/ svn revision : r90 Two APIs are added: lz4_compress() support basic lz4 compression whereas lz4hc_compress() support high compression or CPU performance get lower but compression ratio get higher. Also, we require the pre-allocated working memory with the defined size and destination buffer must be allocated with the size of lz4_compressbound. [akpm@linux-foundation.org: make lz4_compresshcctx() static] Signed-off-by: Chanho Min <chanho.min@lge.com> Cc: "Darrick J. Wong" <djwong@us.ibm.com> Cc: Bob Pearson <rpearson@systemfabricworks.com> Cc: Richard Weinberger <richard@nod.at> Cc: Herbert Xu <herbert@gondor.hengli.com.au> Cc: Yann Collet <yann.collet.73@gmail.com> Cc: Kyungsik Lee <kyungsik.lee@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-09lib: add support for LZ4-compressed kernelKyungsik Lee
Add support for extracting LZ4-compressed kernel images, as well as LZ4-compressed ramdisk images in the kernel boot process. Signed-off-by: Kyungsik Lee <kyungsik.lee@lge.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Borislav Petkov <bp@alien8.de> Cc: Florian Fainelli <florian@openwrt.org> Cc: Yann Collet <yann.collet.73@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-05Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto update from Herbert Xu: - Do not idle omap device between crypto operations in one session. - Added sha224/sha384 shims for SSSE3. - More optimisations for camellia-aesni-avx2. - Removed defunct blowfish/twofish AVX2 implementations. - Added unaligned buffer self-tests. - Added PCLMULQDQ optimisation for CRCT10DIF. - Added support for Freescale's DCP co-processor - Misc fixes. * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (44 commits) crypto: testmgr - test hash implementations with unaligned buffers crypto: testmgr - test AEADs with unaligned buffers crypto: testmgr - test skciphers with unaligned buffers crypto: testmgr - check that entries in alg_test_descs are in correct order Revert "crypto: twofish - add AVX2/x86_64 assembler implementation of twofish cipher" Revert "crypto: blowfish - add AVX2/x86_64 implementation of blowfish cipher" crypto: camellia-aesni-avx2 - tune assembly code for more performance hwrng: bcm2835 - fix MODULE_LICENSE tag hwrng: nomadik - use clk_prepare_enable() crypto: picoxcell - replace strict_strtoul() with kstrtoul() crypto: dcp - Staticize local symbols crypto: dcp - Use NULL instead of 0 crypto: dcp - Use devm_* APIs crypto: dcp - Remove redundant platform_set_drvdata() hwrng: use platform_{get,set}_drvdata() crypto: omap-aes - Don't idle/start AES device between Encrypt operations crypto: crct10dif - Use PTR_RET crypto: ux500 - Cocci spatch "resource_size.spatch" crypto: sha256_ssse3 - add sha224 support crypto: sha512_ssse3 - add sha384 support ...
2013-07-03Merge branch 'exotic-arch-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k Pull "exotic" arch fixes from Geert Uytterhoeven: "This is a collection of several exotic architecture fixes, and a few other fixes for issues that were detected while doing the former" * 'exotic-arch-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k: (35 commits) lib: Move fonts from drivers/video/console/ to lib/fonts/ console/font: Refactor font support code selection logic Revert "staging/solo6x10: depend on CONFIG_FONTS" input: cros_ec_keyb_clear_keyboard() depends on CONFIG_PM_SLEEP score: Wire up asm-generic/xor.h score: Remove unneeded <asm/dma-mapping.h> openrisc: Wire up asm-generic/xor.h h8300/boot: Use POSIX "$((..))" instead of bashism "$[...]" h8300: Mark H83002 and H83048 CPU support broken h8300: Switch h8300 to drivers/Kconfig h8300: Limit timer channel ranges in Kconfig h8300: Wire up asm-generic/xor.h h8300: Fill the system call table using a CALL() macro h8300: Fix <asm/tlb.h> h8300: Hardcode symbol prefixes in asm sources h8300: add missing definition for read_barries_depends() frv: head.S - Remove commented-out initialization code cris: Wire up asm-generic/vga.h parport: disable PC-style parallel port support on cris console: Disable VGA text console support on cris ...
2013-06-28lib: Move fonts from drivers/video/console/ to lib/fonts/Geert Uytterhoeven
Several drivers need font support independent of CONFIG_VT, cfr. commit 9cbce8d7e1dae0744ca4f68d62aa7de18196b6f4, "console/font: Refactor font support code selection logic"). Hence move the fonts and their support logic from drivers/video/console/ to its own library directory lib/fonts/. This also allows to limit processing of drivers/video/console/Makefile to CONFIG_VT=y again. [Kevin Hilman <khilman@linaro.org>: Update arch/arm/boot/compressed/Makefile] Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2013-06-05net: core: move mac_pton() to lib/net_utils.cAndy Shevchenko
Since we have at least one user of this function outside of CONFIG_NET scope, we have to provide this function independently. The proposed solution is to move it under lib/net_utils.c with corresponding configuration variable and select wherever it is needed. Signed-off-by: Andy Shevchenko <andy.shevchenko@gmail.com> Reported-by: Arnd Bergmann <arnd@arndb.de> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-20crypto: crct10dif - Wrap crc_t10dif function all to use crypto transform ↵Tim Chen
framework When CRC T10 DIF is calculated using the crypto transform framework, we wrap the crc_t10dif function call to utilize it. This allows us to take advantage of any accelerated CRC T10 DIF transform that is plugged into the crypto framework. Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2013-04-15Move utf16 functions to kernel core and renameMatthew Garrett
We want to be able to use the utf16 functions that are currently present in the EFI variables code in platform-specific code as well. Move them to the kernel core, and in the process rename them to accurately describe what they do - they don't handle UTF16, only UCS2. Signed-off-by: Matthew Garrett <matthew.garrett@nebula.com> Signed-off-by: Matt Fleming <matt.fleming@intel.com>
2013-01-17lib: remove depends on CONFIG_EXPERIMENTALKees Cook
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a while now and is almost always enabled by default. As agreed during the Linux kernel summit, remove it from any "depends on" lines in Kconfigs. CC: Andrew Morton <akpm@linux-foundation.org> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> CC: Dmitry Kasatkin <dmitry.kasatkin@intel.com> CC: James Morris <james.l.morris@oracle.com> CC: "Michael S. Tsirkin" <mst@redhat.com> CC: Akinobu Mita <akinobu.mita@gmail.com> CC: Ingo Molnar <mingo@kernel.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-17percpu_rw_semaphore: introduce CONFIG_PERCPU_RWSEMOleg Nesterov
Currently only block_dev and uprobes use percpu_rw_semaphore, add the config option selected by BLOCK || UPROBES. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Anton Arapov <anton@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Michal Marek <mmarek@suse.cz> Cc: Mikulas Patocka <mpatocka@redhat.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-08X.509: Implement simple static OID registryDavid Howells
Implement a simple static OID registry that allows the mapping of an encoded OID to an enum value for ease of use. The OID registry index enum appears in the: linux/oid_registry.h header file. A script generates the registry from lines in the header file that look like: <sp*>OID_foo,<sp*>/*<sp*>1.2.3.4<sp*>*/ The actual OID is taken to be represented by the numbers with interpolated dots in the comment. All other lines in the header are ignored. The registry is queries by calling: OID look_up_oid(const void *data, size_t datasize); This returns a number from the registry enum representing the OID if found or OID__NR if not. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-07-30Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge Andrew's first set of patches: "Non-MM patches: - lots of misc bits - tree-wide have_clk() cleanups - quite a lot of printk tweaks. I draw your attention to "printk: convert the format for KERN_<LEVEL> to a 2 byte pattern" which looks a bit scary. But afaict it's solid. - backlight updates - lib/ feature work (notably the addition and use of memweight()) - checkpatch updates - rtc updates - nilfs updates - fatfs updates (partial, still waiting for acks) - kdump, proc, fork, IPC, sysctl, taskstats, pps, etc - new fault-injection feature work" * Merge emailed patches from Andrew Morton <akpm@linux-foundation.org>: (128 commits) drivers/misc/lkdtm.c: fix missing allocation failure check lib/scatterlist: do not re-write gfp_flags in __sg_alloc_table() fault-injection: add tool to run command with failslab or fail_page_alloc fault-injection: add selftests for cpu and memory hotplug powerpc: pSeries reconfig notifier error injection module memory: memory notifier error injection module PM: PM notifier error injection module cpu: rewrite cpu-notifier-error-inject module fault-injection: notifier error injection c/r: fcntl: add F_GETOWNER_UIDS option resource: make sure requested range is included in the root range include/linux/aio.h: cpp->C conversions fs: cachefiles: add support for large files in filesystem caching pps: return PTR_ERR on error in device_create taskstats: check nla_reserve() return sysctl: suppress kmemleak messages ipc: use Kconfig options for __ARCH_WANT_[COMPAT_]IPC_PARSE_VERSION ipc: compat: use signed size_t types for msgsnd and msgrcv ipc: allow compat IPC version field parsing if !ARCH_WANT_OLD_COMPAT_IPC ipc: add COMPAT_SHMLBA support ...
2012-07-30atomic64_test: simplify the #ifdef for atomic64_dec_if_positive() testCatalin Marinas
Introduce CONFIG_ARCH_HAS_ATOMIC64_DEC_IF_POSITIVE and use this instead of the multitude of #if defined() checks in atomic64_test.c Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: "More hardware support across the field including a bunch of device drivers. The highlight however really are further steps towards device tree. This has been sitting in -next for ages. All MIPS _defconfigs have been tested to boot or where I don't have hardware available, to at least build fine." * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (77 commits) MIPS: Loongson 1B: Add defconfig MIPS: Loongson 1B: Add board support MIPS: Netlogic: early console fix MIPS: Netlogic: Fix indentation of smpboot.S MIPS: Netlogic: remove cpu_has_dc_aliases define for XLP MIPS: Netlogic: Remove unused pcibios_fixups MIPS: Netlogic: Add XLP SoC devices in FDT MIPS: Netlogic: Add IRQ mappings for more devices MIPS: Netlogic: USB support for XLP MIPS: Netlogic: XLP PCIe controller support. MIPS: Netlogic: Platform changes for XLR/XLS I2C MIPS: Netlogic: Platform NAND/NOR flash support MIPS: Netlogic: Platform changes for XLS USB MIPS: Netlogic: Remove NETLOGIC_ prefix MIPS: Netlogic: SMP wakeup code update MIPS: Netlogic: Update comments in smpboot.S MIPS: BCM63XX: Add 96328avng reference board MIPS: Expose PCIe drivers for MIPS MIPS: BCM63XX: Add PCIe Support for BCM6328 MIPS: BCM63XX: Move the PCI initialization into its own function ...
2012-07-23of/lib: Allow scripts/dtc/libfdt to be used from kernel codeDavid Daney
libfdt is part of the device tree support in scripts/dtc/libfdt. For some platforms that use the Device Tree, we want to be able to edit the flattened device tree form. We don't want to burden kernel builds that do not require it, so we gate compilation of libfdt files with CONFIG_LIBFDT. So if it is needed, you need to do this in your Kconfig: select LIBFDT And in the Makefile of the code using libfdt something like: ccflags-y := -I$(src)/../../../scripts/dtc/libfdt Signed-off-by: David Daney <david.daney@cavium.com> Cc: linux-mips@linux-mips.org Cc: devicetree-discuss@lists.ozlabs.org Cc: Grant Likely <grant.likely@secretlab.ca> Cc: linux-kernel@vger.kernel.org Acked-by: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-06-10Merge commit 'v3.5-rc2' into nextJames Morris
2012-05-26Merge branch 'generic-string-functions'Linus Torvalds
This makes <asm/word-at-a-time.h> actually live up to its promise of allowing architectures to help tune the string functions that do their work a word at a time. David had already taken the x86 strncpy_from_user() function, modified it to work on sparc, and then done the extra work to make it generically useful. This then expands on that work by making x86 use that generic version, completing the circle. But more importantly, it fixes up the word-at-a-time interfaces so that it's now easy to also support things like strnlen_user(), and pretty much most random string functions. David reports that it all works fine on sparc, and Jonas Bonn reported that an earlier version of this worked on OpenRISC too. It's pretty easy for architectures to add support for this and just replace their private versions with the generic code. * generic-string-functions: sparc: use the new generic strnlen_user() function x86: use the new generic strnlen_user() function lib: add generic strnlen_user() function word-at-a-time: make the interfaces truly generic x86: use generic strncpy_from_user routine
2012-05-26Merge tag 'stmp-dev' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull arm-soc stmp-dev library code from Olof Johansson: "A number of devices are using a common register layout, this adds support code for it in lib/stmp_device.c so we do not need to duplicate it in each driver." Fix up trivial conflicts in drivers/i2c/busses/i2c-mxs.c and lib/Makefile * tag 'stmp-dev' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: i2c: mxs: use global reset function lib: add support for stmp-style devices
2012-05-26lib: add generic strnlen_user() functionLinus Torvalds
This adds a new generic optimized strnlen_user() function that uses the <asm/word-at-a-time.h> infrastructure to portably do efficient string handling. In many ways, strnlen is much simpler than strncpy, and in particular we can always pre-align the words we load from memory. That means that all the worries about alignment etc are a non-issue, so this one can easily be used on any architecture. You obviously do have to do the appropriate word-at-a-time.h macros. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-26Revert "crypto: GnuPG based MPI lib - additional sources (part 4)"Dmitry Kasatkin
This reverts commit 7e8dec918ef8e0f68b4937c3c50fa57002077a4d. RSA verification implementation does not use this code. James Morris has asked to remove that. Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Requested-by: James Morris <james.l.morris@oracle.com> Signed-off-by: James Morris <james.l.morris@oracle.com>
2012-05-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparcLinus Torvalds
Pull sparc changes from David S. Miller: "This has the generic strncpy_from_user() implementation architectures can now use, which we've been developing on linux-arch over the past few days. For good measure I ran both a 32-bit and a 64-bit glibc testsuite run, and the latter of which pointed out an adjustment I needed to make to sparc's user_addr_max() definition. Linus, you were right, STACK_TOP was not the right thing to use, even on sparc itself :-) From Sam Ravnborg, we have a conversion of sparc32 over to the common alloc_thread_info_node(), since the aspect which originally blocked our doing so (sun4c) has been removed." Fix up trivial arch/sparc/Kconfig and lib/Makefile conflicts. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc: sparc: Fix user_addr_max() definition. lib: Sparc's strncpy_from_user is generic enough, move under lib/ kernel: Move REPEAT_BYTE definition into linux/kernel.h sparc: Increase portability of strncpy_from_user() implementation. sparc: Optimize strncpy_from_user() zero byte search. sparc: Add full proper error handling to strncpy_from_user(). sparc32: use the common implementation of alloc_thread_info_node()
2012-05-24lib: Sparc's strncpy_from_user is generic enough, move under lib/David S. Miller
To use this, an architecture simply needs to: 1) Provide a user_addr_max() implementation via asm/uaccess.h 2) Add "select GENERIC_STRNCPY_FROM_USER" to their arch Kcnfig 3) Remove the existing strncpy_from_user() implementation and symbol exports their architecture had. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: David Howells <dhowells@redhat.com>
2012-05-02ddr: add LPDDR2 data from JESD209-2Aneesh V
add LPDDR2 data from the JEDEC spec JESD209-2. The data includes: 1. Addressing information for LPDDR2 memories of different densities and types(S2/S4) 2. AC timing data. This data will useful for memory controller device drivers. Right now this is used by the TI EMIF SDRAM controller driver. Signed-off-by: Aneesh V <aneesh@ti.com> Reviewed-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Benoit Cousson <b-cousson@ti.com> [santosh.shilimkar@ti.com: Moved to drivers/memory from drivers/misc] Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Tested-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-20lib: add support for stmp-style devicesWolfram Sang
MX23/28 use IP cores which follow a register layout I have first seen on STMP3xxx SoCs. In this layout, every register actually has four u32: 1.) to store a value directly 2.) a SET register where every 1-bit sets the corresponding bit, others are unaffected 3.) same with a CLR register 4.) same with a TOG (toggle) register Also, the 2 MSBs in register 0 are always the same and can be used to reset the IP core. All this is strictly speaking not mach-specific (but IP core specific) and, thus, doesn't need to be in mach-mxs/include. At least mx6 also uses IP cores following this stmp-style. So: Introduce a stmp-style device, put the code and defines for that in a public place (lib/), and let drivers for stmp-style devices select that code. To avoid regressions and ease reviewing, the actual code is simply copied from mach-mxs. It definately wants updates, but those need a seperate patch series. Voila, mach dependency gone, reusable code introduced. Note that I didn't remove the duplicated code from mach-mxs yet, first the drivers have to be converted. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Dong Aisheng <dong.aisheng@linaro.org>
2012-03-28crc32: add help text for the algorithm select optionDarrick J. Wong
Add help text to the crc32 algorithm selection option in Kconfig. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Reported-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-27Merge branch 'for-linus-3.4-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rw/uml Pull UML changes from Richard Weinberger: "Mostly bug fixes and cleanups" * 'for-linus-3.4-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rw/uml: (35 commits) um: Update defconfig um: Switch to large mcmodel on x86_64 MTD: Relax dependencies um: Wire CONFIG_GENERIC_IO up um: Serve io_remap_pfn_range() Introduce CONFIG_GENERIC_IO um: allow SUBARCH=x86 um: most of the SUBARCH uses can be killed um: deadlock in line_write_interrupt() um: don't bother trying to rebuild CHECKFLAGS for USER_OBJS um: use the right ifdef around exports in user_syms.c um: a bunch of headers can be killed by using generic-y um: ptrace-generic.h doesn't need user.h um: kill HOST_TASK_PID um: remove pointless include of asm/fixmap.h from asm/pgtable.h um: asm-offsets.h might as well come from underlying arch... um: merge processor_{32,64}.h a bit... um: switch close_chan() to struct line um: race fix: initialize delayed_work *before* registering IRQ um: line->have_irq is never checked... ...
2012-03-25Introduce CONFIG_GENERIC_IORichard Weinberger
There are situations where CONFIG_HAS_IOMEM is too restrictive. For example CONFIG_MTD_NAND_NANDSIM depends on CONFIG_HAS_IOMEM but it works perfectly fine if an architecture without io memory just includes asm-generic/io.h or implements everything defined in it. UML is such a corner case. Signed-off-by: Richard Weinberger <richard@nod.at>
2012-03-23crc32: select an algorithm via KconfigDarrick J. Wong
Allow the kernel builder to choose a crc32* algorithm for the kernel. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Cc: Bob Pearson <rpearson@systemfabricworks.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23crc32: bolt on crc32cDarrick J. Wong
Reuse the existing crc32 code to stamp out a crc32c implementation. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Bob Pearson <rpearson@systemfabricworks.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23crc32: simplify unit test codeBob Pearson
Replace the unit test provided in crc32.c, which doesn't have a makefile and doesn't compile with current headers, with a simpler self test routine that also gives a measure of performance and runs at module init time. The self test option can be enabled through a configuration option CONFIG_CRC32_SELFTEST. The test stresses the pre and post loops and is thus not very realistic since actual uses will likely have addresses and lengths that are at least 4 byte aligned. However, the main loop is long enough so that the performance is dominated by that loop. The expected values for crc32_le and crc32_be were generated with the original version of crc32.c using CRC_BITS_LE = 8 and CRC_BITS_BE = 8. These values were then used to check all the values of the BITS parameters in both the original and new versions. The performance results show some variability from run to run in spite of attempts to both warm the cache and reduce the amount of OS noise by limiting interrutps during the test. To get comparable results and to analyse options wrt performance the best time reported over a small sample of runs has been taken. [djwong@us.ibm.com: Minor changelog tweaks] Signed-off-by: Bob Pearson <rpearson@systemfabricworks.com> Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-07Merge tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhostLinus Torvalds
arch: fix ioport mapping on mips,sh Kevin Cernekee reported that recent cleanup that replaced pci_iomap with a generic function failed to take into account the differences in io port handling on mips and sh architectures. Rather than revert the changes reintroducing the code duplication, this patchset fixes this by adding ability for architectures to override ioport mapping for pci devices. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> * tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost: sh: use the the PCI channels's io_map_base mips: use the the PCI controller's io_map_base lib: add NO_GENERIC_PCI_IOPORT_MAP
2012-02-02lib: Fix multiple definitions of clz_tabDavid Miller
Both sparc 32-bit's software divide assembler and MPILIB provide clz_tab[] with identical contents. Break it out into a seperate object file and select it when SPARC32 or MPILIB is set. Reported-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: James Morris <jmorris@namei.org>
2012-01-31lib: add NO_GENERIC_PCI_IOPORT_MAPMichael S. Tsirkin
Some architectures need to override the way IO port mapping is done on PCI devices. Supply a generic macro that calls ioport_map, and make it possible for architectures to override. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de>
2012-01-18lib: Removed MPILIB, MPILIB_EXTRA, and SIGNATURE promptsDmitry Kasatkin
As modules are expected to select MPILIB, MPILIB_EXTRA, and SIGNATURE, removed Kconfig prompts. Requested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: James Morris <jmorris@namei.org>
2012-01-18lib: MPILIB Kconfig description updateDmitry Kasatkin
It was reported that description of the MPILIB_EXTRA is confusing. Indeed it was copy-paste typo. It is fixed here. Reported-by: Valdis Kletnieks <Valdis.Kletnieks@vt.edu> Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: James Morris <jmorris@namei.org>
2012-01-18lib: digital signature dependency fixDmitry Kasatkin
Randy Dunlap reported build break: ERROR: "crypto_alloc_shash" [lib/digsig.ko] undefined! ERROR: "crypto_shash_final" [lib/digsig.ko] undefined! ERROR: "crypto_shash_update" [lib/digsig.ko] undefined! ERROR: "crypto_destroy_tfm" [lib/digsig.ko] undefined! Added CRYPTO dependency and selected SHA1 algorithm. Reported-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: James Morris <jmorris@namei.org>
2012-01-18lib: digital signature config option name changeDmitry Kasatkin
It was reported that DIGSIG is confusing name for digital signature module. It was suggested to rename DIGSIG to SIGNATURE. Requested-by: Linus Torvalds <torvalds@linux-foundation.org> Suggested-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: James Morris <jmorris@namei.org>
2012-01-10Merge branch 'for-linus' of git://selinuxproject.org/~jmorris/linux-securityLinus Torvalds
* 'for-linus' of git://selinuxproject.org/~jmorris/linux-security: (32 commits) ima: fix invalid memory reference ima: free duplicate measurement memory security: update security_file_mmap() docs selinux: Casting (void *) value returned by kmalloc is useless apparmor: fix module parameter handling Security: tomoyo: add .gitignore file tomoyo: add missing rcu_dereference() apparmor: add missing rcu_dereference() evm: prevent racing during tfm allocation evm: key must be set once during initialization mpi/mpi-mpow: NULL dereference on allocation failure digsig: build dependency fix KEYS: Give key types their own lockdep class for key->sem TPM: fix transmit_cmd error logic TPM: NSC and TIS drivers X86 dependency fix TPM: Export wait_for_stat for other vendor specific drivers TPM: Use vendor specific function for status probe tpm_tis: add delay after aborting command tpm_tis: Check return code from getting timeouts/durations tpm: Introduce function to poll for result of self test ... Fix up trivial conflict in lib/Makefile due to addition of CONFIG_MPI and SIGSIG next to CONFIG_DQL addition.
2012-01-10Merge tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhostLinus Torvalds
lib: use generic pci_iomap on all architectures Many architectures don't want to pull in iomap.c, so they ended up duplicating pci_iomap from that file. That function isn't trivial, and we are going to modify it https://lkml.org/lkml/2011/11/14/183 so the duplication hurts. This reduces the scope of the problem significantly, by moving pci_iomap to a separate file and referencing that from all architectures. * tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost: alpha: drop pci_iomap/pci_iounmap from pci-noop.c mn10300: switch to GENERIC_PCI_IOMAP mn10300: add missing __iomap markers frv: switch to GENERIC_PCI_IOMAP tile: switch to GENERIC_PCI_IOMAP tile: don't panic on iomap sparc: switch to GENERIC_PCI_IOMAP sh: switch to GENERIC_PCI_IOMAP powerpc: switch to GENERIC_PCI_IOMAP parisc: switch to GENERIC_PCI_IOMAP mips: switch to GENERIC_PCI_IOMAP microblaze: switch to GENERIC_PCI_IOMAP arm: switch to GENERIC_PCI_IOMAP alpha: switch to GENERIC_PCI_IOMAP lib: add GENERIC_PCI_IOMAP lib: move GENERIC_IOMAP to lib/Kconfig Fix up trivial conflicts due to changes nearby in arch/{m68k,score}/Kconfig
2012-01-08Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (53 commits) Kconfig: acpi: Fix typo in comment. misc latin1 to utf8 conversions devres: Fix a typo in devm_kfree comment btrfs: free-space-cache.c: remove extra semicolon. fat: Spelling s/obsolate/obsolete/g SCSI, pmcraid: Fix spelling error in a pmcraid_err() call tools/power turbostat: update fields in manpage mac80211: drop spelling fix types.h: fix comment spelling for 'architectures' typo fixes: aera -> area, exntension -> extension devices.txt: Fix typo of 'VMware'. sis900: Fix enum typo 'sis900_rx_bufer_status' decompress_bunzip2: remove invalid vi modeline treewide: Fix comment and string typo 'bufer' hyper-v: Update MAINTAINERS treewide: Fix typos in various parts of the kernel, and fix some comments. clockevents: drop unknown Kconfig symbol GENERIC_CLOCKEVENTS_MIGR gpio: Kconfig: drop unknown symbol 'CS5535_GPIO' leds: Kconfig: Fix typo 'D2NET_V2' sound: Kconfig: drop unknown symbol ARCH_CLPS7500 ... Fix up trivial conflicts in arch/powerpc/platforms/40x/Kconfig (some new kconfig additions, close to removed commented-out old ones)
2011-11-29dql: Dynamic queue limitsTom Herbert
Implementation of dynamic queue limits (dql). This is a libary which allows a queue limit to be dynamically managed. The goal of dql is to set the queue limit, number of objects to the queue, to be minimized without allowing the queue to be starved. dql would be used with a queue which has these properties: 1) Objects are queued up to some limit which can be expressed as a count of objects. 2) Periodically a completion process executes which retires consumed objects. 3) Starvation occurs when limit has been reached, all queued data has actually been consumed but completion processing has not yet run, so queuing new data is blocked. 4) Minimizing the amount of queued data is desirable. A canonical example of such a queue would be a NIC HW transmit queue. The queue limit is dynamic, it will increase or decrease over time depending on the workload. The queue limit is recalculated each time completion processing is done. Increases occur when the queue is starved and can exponentially increase over successive intervals. Decreases occur when more data is being maintained in the queue than needed to prevent starvation. The number of extra objects, or "slack", is measured over successive intervals, and to avoid hysteresis the limit is only reduced by the miminum slack seen over a configurable time period. dql API provides routines to manage the queue: - dql_init is called to intialize the dql structure - dql_reset is called to reset dynamic values - dql_queued called when objects are being enqueued - dql_avail returns availability in the queue - dql_completed is called when objects have be consumed in the queue Configuration consists of: - max_limit, maximum limit - min_limit, minimum limit - slack_hold_time, time to measure instances of slack before reducing queue limit Signed-off-by: Tom Herbert <therbert@google.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
