path: root/lib/decompress_unlzma.c
2011-01-13Decompressors: validate match distance in decompress_unlzma.cLasse Collin
Validate the newly decoded distance (rep0) in process_bit1(). This is to detect corrupt LZMA data quickly. The old code can run for long time producing garbage until it hits the end of the input. Signed-off-by: Lasse Collin <lasse.collin@tukaani.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Alain Knaff <alain@knaff.lu> Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com> Cc: Phillip Lougher <phillip@lougher.demon.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13Decompressors: check for write errors in decompress_unlzma.cLasse Collin
The return value of wr->flush() is not checked in write_byte(). This means that the decompressor won't stop even if the caller doesn't want more data. This can happen e.g. with corrupt LZMA-compressed initramfs. Returning the error quickly allows the user to see the error message quicker. There is a similar missing check for wr.flush() near the end of unlzma(). Signed-off-by: Lasse Collin <lasse.collin@tukaani.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Alain Knaff <alain@knaff.lu> Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com> Cc: Phillip Lougher <phillip@lougher.demon.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13Decompressors: check for read errors in decompress_unlzma.cLasse Collin
Return value of rc->fill() is checked in rc_read() and error() is called when needed, but then the code continues as if nothing had happened. rc_read() is a void function and it's on the top of performance critical call stacks, so propagating the error code via return values doesn't sound like the best fix. It seems better to check rc->buffer_size (which holds the return value of rc->fill()) in the main loop. It does nothing bad that the code runs a little with unknown data after a failed rc->fill(). This fixes an infinite loop in initramfs decompression if the LZMA-compressed initramfs image is corrupt. Signed-off-by: Lasse Collin <lasse.collin@tukaani.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Alain Knaff <alain@knaff.lu> Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com> Cc: Phillip Lougher <phillip@lougher.demon.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13Decompressors: fix header validation in decompress_unlzma.cLasse Collin
Validation of header.pos calls error() but doesn't make the function return to indicate an error to the caller. Instead the decoding is attempted with invalid header.pos. This fixes it. Signed-off-by: Lasse Collin <lasse.collin@tukaani.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Alain Knaff <alain@knaff.lu> Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com> Cc: Phillip Lougher <phillip@lougher.demon.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13Decompressors: remove unused function from lib/decompress_unlzma.cLasse Collin
2011-01-13Decompressors: include <linux/slab.h> in <linux/decompress/mm.h>Lasse Collin
Currently users of mm.h need to include <linux/slab.h> to use the macros malloc() and free() provided by mm.h. This fixes it. Signed-off-by: Lasse Collin <lasse.collin@tukaani.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Alain Knaff <alain@knaff.lu> Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com> Cc: Phillip Lougher <phillip@lougher.demon.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13Decompressors: get rid of set_error_fn() macroLasse Collin
set_error_fn() has become a useless complication after c1e7c3ae59 ("bzip2/lzma/gzip: pre-boot malloc doesn't return NULL on failure") fixed the use of error() in malloc(). Only decompress_unlzma.c had some use for it and that was easy to change too. This also gets rid of the static function pointer "error", which should have been marked as __initdata. Signed-off-by: Lasse Collin <lasse.collin@tukaani.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Alain Knaff <alain@knaff.lu> Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com> Cc: Phillip Lougher <phillip@lougher.demon.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13Decompressors: add missing INIT (i.e. __init)Lasse Collin
2009-09-24lzma/gzip: fix potential oops when input data is truncatedPhillip Lougher
If the lzma/gzip decompressors are called with insufficient input data (len > 0 & fill = NULL), they will attempt to call the fill function to obtain more data, leading to a kernel oops. Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-07lib/decompress_*: only include <linux/slab.h> if STATIC is not definedAlbin Tonnerre
These includes were added by 079effb6933f34b9b1b67b08bd4fd7fb672d16ef ("kmemtrace, kbuild: fix slab.h dependency problem in lib/decompress_inflate.c") to fix the build when using kmemtrace. However this is not necessary when used to create a compressed kernel, and actually creates issues (brings a lot of things unavailable in the decompression environment), so don't include it if STATIC is defined. Signed-off-by: Albin Tonnerre <albin.tonnerre@free-electrons.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Cc: Phillip Lougher <phillip@lougher.demon.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-07bzip2/lzma: remove nasty uncompressed size hack in pre-boot environmentPhillip Lougher
decompress_bunzip2 and decompress_unlzma have a nasty hack that subtracts 4 from the input length if being called in the pre-boot environment. This is a nasty hack because it relies on the fact that flush = NULL only when called from the pre-boot environment (i.e. arch/x86/boot/compressed/misc.c). initramfs.c/do_mounts_rd.c pass in a flush buffer (flush != NULL). This hack prevents the decompressors from being used with flush = NULL by other callers unless knowledge of the hack is propagated to them. This patch removes the hack by making decompress (called only from the pre-boot environment) a wrapper function that subtracts 4 from the input length before calling the decompressor. Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-03kmemtrace, kbuild: fix slab.h dependency problem in lib/decompress_unlzma.cPekka Enberg
Impact: cleanup lib/decompress_unlzma.c depends on slab.h without including it: CC lib/decompress_unlzma.o lib/decompress_unlzma.c: In function ‘rc_free’: lib/decompress_unlzma.c:122: error: implicit declaration of function ‘kfree’ lib/decompress_unlzma.c: In function ‘unlzma’: lib/decompress_unlzma.c:551: error: implicit declaration of function ‘kmalloc’ lib/decompress_unlzma.c:551: warning: assignment makes pointer from integer without a cast make[1]: *** [lib/decompress_unlzma.o] Error 1 make: *** [lib/] Error 2 It gets included implicitly currently - but this will not be the case with upcoming kmemtrace changes. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> LKML-Reference: <1237886521.25315.58.camel@penberg-laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-04bzip2/lzma: library support for gzip, bzip2 and lzma decompressionAlain Knaff
Impact: Replaces inflate.c with a wrapper around zlib_inflate; new library code This is the first part of the bzip2/lzma patch The bzip patch is based on an idea by Christian Ludwig, includes support for compressing the kernel with bzip2 or lzma rather than gzip. Both compressors give smaller sizes than gzip. Lzma's decompresses faster than bzip2. It also supports ramdisks and initramfs' compressed using these two compressors. The functionality has been successfully used for a couple of years by the udpcast project This version applies to "tip" kernel 2.6.28 This part contains: - changed inflate.c to accomodate rest of patch - implementation of bzip2 compression (not used at this stage yet) - implementation of lzma compression (not used at this stage yet) - Makefile routines to support bzip2 and lzma kernel compression Signed-off-by: Alain Knaff <alain@knaff.lu> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
