path: root/lib/dynamic_debug.c
2010-10-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (31 commits) driver core: Display error codes when class suspend fails Driver core: Add section count to memory_block struct Driver core: Add mutex for adding/removing memory blocks Driver core: Move find_memory_block routine hpilo: Despecificate driver from iLO generation driver core: Convert link_mem_sections to use find_memory_block_hinted. driver core: Introduce find_memory_block_hinted which utilizes kset_find_obj_hinted. kobject: Introduce kset_find_obj_hinted. driver core: fix build for CONFIG_BLOCK not enabled driver-core: base: change to new flag variable sysfs: only access bin file vm_ops with the active lock sysfs: Fail bin file mmap if vma close is implemented. FW_LOADER: fix kconfig dependency warning on HOTPLUG uio: Statically allocate uio_class and use class .dev_attrs. uio: Support 2^MINOR_BITS minors uio: Cleanup irq handling. uio: Don't clear driver data uio: Fix lack of locking in init_uio_class SYSFS: Allow boot time switching between deprecated and modern sysfs layout driver core: remove CONFIG_SYSFS_DEPRECATED_V2 but keep it for block devices ...
2010-10-22Dynamic Debug: Initialize dynamic debug earlier via arch_initcallThomas Renninger
Having the ddebug_query= boot parameter it makes sense to set up dynamic debug as soon as possible. I expect sysfs files cannot be set up via an arch_initcall, because this one is even before fs_initcall. Therefore I splitted the dynamic_debug_init function into an early one and a later one providing /sys/../dynamic_debug/control file. Possibly dynamic_debug can be initialized even earlier, not sure whether this still makes sense then. I picked up arch_initcall as it covers quite a lot already. Dynamic debug needs to allocate memory, therefore it's not easily possible to set it up even before the command line gets parsed. Therefore the boot param query string is stored in a temp string which is applied when dynamic debug gets set up. This has been tested with ddebug_query="file ec.c +p" and I could retrieve pr_debug() messages early at boot during ACPI setup: ACPI: EC: Look up EC in DSDT ACPI: EC: ---> status = 0x08 ACPI: EC: transaction start ACPI: EC: <--- command = 0x80 ACPI: EC: ~~~> interrupt ACPI: EC: ---> status = 0x08 ACPI: EC: <--- data = 0xa4 ... ACPI: Interpreter enabled ACPI: (supports S0 S3 S4 S5) ACPI: Using IOAPIC for interrupt routing ACPI: EC: ---> status = 0x00 ACPI: EC: transaction start ACPI: EC: <--- command = 0x80 Signed-off-by: Thomas Renninger <trenn@suse.de> Acked-by: jbaron@redhat.com Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> CC: linux-acpi@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22Dynamic Debug: Introduce ddebug_query= boot parameterThomas Renninger
Dynamic debug lacks the ability to enable debug messages at boot time. One could patch initramfs or service startup scripts to write to /sys/../dynamic_debug/control, but this sucks. This patch makes it possible to pass a query in the same format one can write to /sys/../dynamic_debug/control via boot param. When dynamic debug gets initialized, this query will automatically be applied. Signed-off-by: Thomas Renninger <trenn@suse.de> Acked-by: jbaron@redhat.com Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22Dynamic Debug: Split out query string parsing/setup from proc_writeThomas Renninger
The parsing and applying of dynamic debug strings is not only useful for /sys/../dynamic_debug/control write access, but can also be used for boot parameter parsing. The boot parameter is introduced in a follow up patch. Signed-off-by: Thomas Renninger <trenn@suse.de> Acked-by: jbaron@redhat.com Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-18jump_label: Use more consistent namingPeter Zijlstra
Now that there's still only a few users around, rename things to make them more consistent. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20101014203625.448565169@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-09-22jump label: Convert dynamic debug to use jump labelsJason Baron
Convert the 'dynamic debug' infrastructure to use jump labels. Signed-off-by: Jason Baron <jbaron@redhat.com> LKML-Reference: <b77627358cea3e27d7be4386f45f66219afb8452.1284733808.git.jbaron@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-07-04module: initialize module dynamic debug laterYehuda Sadeh
We should initialize the module dynamic debug datastructures only after determining that the module is not loaded yet. This fixes a bug that introduced in 2.6.35-rc2, where when a trying to load a module twice, we also load it's dynamic printing data twice which causes all sorts of nasty issues. Also handle the dynamic debug cleanup later on failure. Signed-off-by: Yehuda Sadeh <yehuda@hq.newdream.net> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (removed a #ifdef) Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25dynamic_debug: small cleanup in ddebug_proc_write()Dan Carpenter
This doesn't change behavior at all. In the original code, if nwords was zero then ddebug_parse_query() would return -EINVAL, now we just do it earlier. Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-15tree-wide: convert open calls to remove spaces to skip_spaces() lib functionAndré Goddard Rosa
Makes use of skip_spaces() defined in lib/string.c for removing leading spaces from strings all over the tree. It decreases lib.a code size by 47 bytes and reuses the function tree-wide: text data bss dec hex filename 64688 584 592 65864 10148 (TOTALS-BEFORE) 64641 584 592 65817 10119 (TOTALS-AFTER) Also, while at it, if we see (*str && isspace(*str)), we can be sure to remove the first condition (*str) as the second one (isspace(*str)) also evaluates to 0 whenever *str == 0, making it redundant. In other words, "a char equals zero is never a space". Julia Lawall tried the semantic patch (http://coccinelle.lip6.fr) below, and found occurrences of this pattern on 3 more files: drivers/leds/led-class.c drivers/leds/ledtrig-timer.c drivers/video/output.c @@ expression str; @@ ( // ignore skip_spaces cases while (*str && isspace(*str)) { \(str++;\|++str;\) } | - *str && isspace(*str) ) Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Cc: Julia Lawall <julia@diku.dk> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Neil Brown <neilb@suse.de> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Cc: David Howells <dhowells@redhat.com> Cc: <linux-ext4@vger.kernel.org> Cc: Samuel Ortiz <samuel@sortiz.org> Cc: Patrick McHardy <kaber@trash.net> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-28Dynamic debug: fix typo: -/->Roel Kluin
The member was intended, not the local variable. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Greg Banks <gnb@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24Dynamic debug: allow simple quoting of wordsGreg Banks
Allow simple quoting of words in the dynamic debug control language. This allows more natural specification when using the control language to match against printk formats, e.g #echo -n 'format "Setting node for non-present cpu" +p' > /mnt/debugfs/dynamic_debug/control instead of #echo -n 'format Setting\040node\040for\040non-present\040cpu +p' > /mnt/debugfs/dynamic_debug/control Adjust the dynamic debug documention to describe that and provide a new example. Adjust the existing examples in the documentation to reflect the current whitespace escaping behaviour when reading the control file. Fix some minor documentation trailing whitespace. Signed-off-by: Greg Banks <gnb@melbourne.sgi.com> Acked-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24dynamic debug: combine dprintk and dynamic printkJason Baron
This patch combines Greg Bank's dprintk() work with the existing dynamic printk patchset, we are now calling it 'dynamic debug'. The new feature of this patchset is a richer /debugfs control file interface, (an example output from my system is at the bottom), which allows fined grained control over the the debug output. The output can be controlled by function, file, module, format string, and line number. for example, enabled all debug messages in module 'nf_conntrack': echo -n 'module nf_conntrack +p' > /mnt/debugfs/dynamic_debug/control to disable them: echo -n 'module nf_conntrack -p' > /mnt/debugfs/dynamic_debug/control A further explanation can be found in the documentation patch. Signed-off-by: Greg Banks <gnb@sgi.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
