path: root/lib/dynamic_debug.c
2016-08-04dynamic_debug: add jump label supportJason Baron
Although dynamic debug is often only used for debug builds, sometimes its enabled for production builds as well. Minimize its impact by using jump labels. This reduces the text section by 7000+ bytes in the kernel image below. It does increase data, but this should only be referenced when changing the direction of the branches, and hence usually not in cache. text data bss dec hex filename 8194852 4879776 925696 14000324 d5a0c4 vmlinux.pre 8187337 4960224 925696 14073257 d6bda9 vmlinux.post Link: http://lkml.kernel.org/r/d165b465e8c89bc582d973758d40be44c33f018b.1467837322.git.jbaron@akamai.com Signed-off-by: Jason Baron <jbaron@akamai.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Chris Metcalf <cmetcalf@mellanox.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Joe Perches <joe@perches.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-04convert a bunch of open-coded instances of memdup_user_nul()Al Viro
A _lot_ of ->write() instances were open-coding it; some are converted to memdup_user_nul(), a lot more remain... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-11-06lib/dynamic_debug.c: use kstrdup_constRasmus Villemoes
Using kstrdup_const, thus reusing .rodata when possible, saves around 2 kB of runtime memory on my laptop/.config combination. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Cc: Jason Baron <jbaron@akamai.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-05-20module: add extra argument for parse_params() callbackLuis R. Rodriguez
This adds an extra argument onto parse_params() to be used as a way to make the unused callback a bit more useful and generic by allowing the caller to pass on a data structure of its choice. An example use case is to allow us to easily make module parameters for every module which we will do next. @ parse @ identifier name, args, params, num, level_min, level_max; identifier unknown, param, val, doing; type s16; @@ extern char *parse_args(const char *name, char *args, const struct kernel_param *params, unsigned num, s16 level_min, s16 level_max, + void *arg, int (*unknown)(char *param, char *val, const char *doing + , void *arg )); @ parse_mod @ identifier name, args, params, num, level_min, level_max; identifier unknown, param, val, doing; type s16; @@ char *parse_args(const char *name, char *args, const struct kernel_param *params, unsigned num, s16 level_min, s16 level_max, + void *arg, int (*unknown)(char *param, char *val, const char *doing + , void *arg )) { ... } @ parse_args_found @ expression R, E1, E2, E3, E4, E5, E6; identifier func; @@ ( R = parse_args(E1, E2, E3, E4, E5, E6, + NULL, func); | R = parse_args(E1, E2, E3, E4, E5, E6, + NULL, &func); | R = parse_args(E1, E2, E3, E4, E5, E6, + NULL, NULL); | parse_args(E1, E2, E3, E4, E5, E6, + NULL, func); | parse_args(E1, E2, E3, E4, E5, E6, + NULL, &func); | parse_args(E1, E2, E3, E4, E5, E6, + NULL, NULL); ) @ parse_args_unused depends on parse_args_found @ identifier parse_args_found.func; @@ int func(char *param, char *val, const char *unused + , void *arg ) { ... } @ mod_unused depends on parse_args_found @ identifier parse_args_found.func; expression A1, A2, A3; @@ - func(A1, A2, A3); + func(A1, A2, A3, NULL); Generated-by: Coccinelle SmPL Cc: cocci@systeme.lip6.fr Cc: Tejun Heo <tj@kernel.org> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Christoph Hellwig <hch@infradead.org> Cc: Felipe Contreras <felipe.contreras@gmail.com> Cc: Ewan Milne <emilne@redhat.com> Cc: Jean Delvare <jdelvare@suse.de> Cc: Hannes Reinecke <hare@suse.de> Cc: Jani Nikula <jani.nikula@intel.com> Cc: linux-kernel@vger.kernel.org Reviewed-by: Tejun Heo <tj@kernel.org> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-02-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree changes from Jiri Kosina: "Patches from trivial.git that keep the world turning around. Mostly documentation and comment fixes, and a two corner-case code fixes from Alan Cox" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: kexec, Kconfig: spell "architecture" properly mm: fix cleancache debugfs directory path blackfin: mach-common: ints-priority: remove unused function doubletalk: probe failure causes OOPS ARM: cache-l2x0.c: Make it clear that cache-l2x0 handles L310 cache controller msdos_fs.h: fix 'fields' in comment scsi: aic7xxx: fix comment ARM: l2c: fix comment ibmraid: fix writeable attribute with no store method dynamic_debug: fix comment doc: usbmon: fix spelling s/unpriviledged/unprivileged/ x86: init_mem_mapping(): use capital BIOS in comment
2015-01-02dynamic_debug: fix commentMasatake YAMATO
Signed-off-by: Masatake YAMATO <yamato@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2014-12-10printk: add and use LOGLEVEL_<level> defines for KERN_<LEVEL> equivalentsJoe Perches
Use #defines instead of magic values. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Jason Baron <jbaron@akamai.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-14lib/dynamic_debug.c: use seq_open_private() instead of seq_open()Rob Jones
Using seq_open_private() removes boilerplate code from ddebug_proc_open(). The resultant code is shorter and easier to follow. This patch does not change any functionality. Signed-off-by: Rob Jones <rob.jones@codethink.co.uk> Acked-by: Jason Baron <jbaron@akamai.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-10-03dynamic_debug: change __dynamic_<foo>_dbg return types to voidJoe Perches
The return value is not used by callers of these functions so change the functions to return void. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Jason Baron <jbaron@akamai.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-20net: print net_device reg_state in netdev_* unless it's registeredVeaceslav Falico
This way we'll always know in what status the device is, unless it's running normally (i.e. NETDEV_REGISTERED). Also, emit a warning once in case of a bad reg_state. CC: "David S. Miller" <davem@davemloft.net> CC: Jason Baron <jbaron@akamai.com> CC: Eric Dumazet <edumazet@google.com> CC: Vlad Yasevich <vyasevic@redhat.com> CC: stephen hemminger <stephen@networkplumber.org> CC: Jerry Chu <hkchu@google.com> CC: Ben Hutchings <bhutchings@solarflare.com> CC: Joe Perches <joe@perches.com> Signed-off-by: Veaceslav Falico <vfalico@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-27dynamic_debug: replace obselete simple_strtoul() with kstrtouint()Andrey Ryabinin
Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Cc: Jason Baron <jbaron@akamai.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-27dynamic_debug: fix ddebug_parse_query()Andrey Ryabinin
This fixes following scenario: $ echo 'file dynamic_debug.c line 1-123 +p' > /sys/kernel/debug/dynamic_debug/control -bash: echo: write error: Invalid argument $ dmesg | grep dynamic_debug dynamic_debug:ddebug_parse_query: last-line:123 < 1st-line:1 dynamic_debug:ddebug_parse_query: query parse failed Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Cc: Jason Baron <jbaron@akamai.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-27dynamic_debug: remove wrong error messageAndrey Ryabinin
parse_lineno() returns either negative error code or zero. We don't need to print something here because if parse_lineno fails it will print error message. Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Cc: Jason Baron <jbaron@akamai.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23dynamic_debug: add wildcard support to filter files/functions/modulesDu, Changbin
Add wildcard '*'(matches zero or more characters) and '?' (matches one character) support when qurying debug flags. Now we can open debug messages using keywords. eg: 1. open debug logs in all usb drivers echo "file drivers/usb/* +p" > <debugfs>/dynamic_debug/control 2. open debug logs for usb xhci code echo "file *xhci* +p" > <debugfs>/dynamic_debug/control Signed-off-by: Du, Changbin <changbin.du@gmail.com> Cc: Jason Baron <jbaron@akamai.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-28dynamic debug: line queries failing due to uninitialized local variablejbaron@akamai.com
Settings of the form, 'line x module y +p', can fail arbitrarily due to an uninitialized local variable. With this patch results are consistent, as expected. Signed-off-by: Jason Baron <jbaron@akamai.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-30dynamic_debug: reuse generic string_unescape functionAndy Shevchenko
There is kernel function to do the job in generic way. Let's use it. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Jason Baron <jbaron@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29lib, net: make isodigit() public and use itAndy Shevchenko
There are at least two users of isodigit(). Let's make it a public function of ctype.h. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-17dynamic_debug: add pr_errs before -EINVALsJim Cromie
Ma noted that dynamic-debug is silent about many query errors, so add pr_err()s to explain those errors, and tweak a few others. Also parse flags 1st, so that match-spec errs are slightly clearer. CC: Jianpeng Ma <majianpeng@gmail.com> CC: Joe Perches <joe@perches.com> Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17dynamic_debug: Fix vpr_<foo> logging stylesJoe Perches
vpr_info_dq should be a function and vpr_info should have a do {} while (0) Add missing newlines to pr_<level>s. Miscellaneous neatening too. braces, coalescing formats, alignments, etc... Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-17lib: dynamic_debug: use kbasename()Andy Shevchenko
Remove the custom implementation of the functionality similar to kbasename(). Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Jason Baron <jbaron@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-09-17device and dynamic_debug: Use dev_vprintk_emit and dev_printk_emitJoe Perches
Convert direct calls of vprintk_emit and printk_emit to the dev_ equivalents. Make create_syslog_header static. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: David S. Miller <davem@davemloft.net> Tested-by: Jim Cromie <jim.cromie@gmail.com> Acked-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-17netdev_printk/netif_printk: Remove a superfluous logging colonJoe Perches
netdev_printk originally called dev_printk with %pV. This style emitted the complete dev_printk header with a colon followed by the netdev_name prefix followed by a colon. Now that netdev_printk does not call dev_printk, the extra colon is superfluous. Remove it. Example: old: sky2 0000:02:00.0: eth0: Link is up at 100 Mbps, full duplex, flow control both new: sky2 0000:02:00.0 eth0: Link is up at 100 Mbps, full duplex, flow control both Signed-off-by: Joe Perches <joe@perches.com> Acked-by: David S. Miller <davem@davemloft.net> Tested-by: Jim Cromie <jim.cromie@gmail.com> Acked-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-17netdev_printk/dynamic_netdev_dbg: Directly call printk_emitJoe Perches
A lot of stack is used in recursive printks with %pV. Using multiple levels of %pV (a logging function with %pV that calls another logging function with %pV) can consume more stack than necessary. Avoid excessive stack use by not calling dev_printk from netdev_printk and dynamic_netdev_dbg. Duplicate the logic and form of dev_printk instead. Make __netdev_printk static. Remove EXPORT_SYMBOL(__netdev_printk) Whitespace and brace style neatening. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: David S. Miller <davem@davemloft.net> Tested-by: Jim Cromie <jim.cromie@gmail.com> Acked-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-17dev_dbg/dynamic_debug: Update to use printk_emit, optimize stackJoe Perches
commit c4e00daaa9 ("driver-core: extend dev_printk() to pass structured data") changed __dev_printk and broke dynamic-debug's ability to control the dynamic prefix of dev_dbg(dev,..). commit af7f2158fd ("drivers-core: make structured logging play nice with dynamic-debug") made a minimal correction. The current dynamic debug code uses up to 3 recursion levels via %pV. This can consume quite a bit of stack. Directly call printk_emit to reduce the recursion depth. These changes include: dev_dbg: o Create and use function create_syslog_header to format the syslog header for printk_emit uses. o Call create_syslog_header and neaten __dev_printk o Make __dev_printk static not global o Remove include header declaration of __dev_printk o Remove now unused EXPORT_SYMBOL() of __dev_printk o Whitespace neatening dynamic_dev_dbg: o Remove KERN_DEBUG from dynamic_emit_prefix o Call create_syslog_header and printk_emit o Whitespace neatening Signed-off-by: Joe Perches <joe@perches.com> Acked-by: David S. Miller <davem@davemloft.net> Tested-by: Jim Cromie <jim.cromie@gmail.com> Acked-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-07Revert "dynamic_debug: remove unneeded includes"Greg Kroah-Hartman
This reverts commit 04db6e5fddca55186b6a74339a62c800150648bc. Odds are, we really don't want to revert all of these, and need to be more careful in the future to make sure we don't break the build of other arches. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-04dynamic_debug: remove unneeded includesJim Cromie
These arent currently needed, so drop them. Some will probably get re-added when static-branches are added, but include loops prevent that at present. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-30dynamic_debug: init with early_initcall, not arch_initcallJim Cromie
1- Call dynamic_debug_init() from early_initcall, not arch_initcall. 2- Call dynamic_debug_init_debugfs() from fs_initcall, not module_init. RFC: This works for me on a 64 bit desktop and a i586 SBC, but is untested on other arches. I presume there is or was a reason original code used arch_initcall, maybe the constraints have changed. This makes facility available as soon as possible. 2nd change has a downside when dynamic_debug.verbose=1; all the vpr_info()s called in the proc-fs code are activated, causing voluminous output from dmesg. TBD: Im unsure of this explanation, but the output is there. This could be fixed by changing those callsites to v2pr_info(if verbose > 1). 1st change is still not early enough to enable pr_debugs in kernel/params, so parsing of boot-args isnt logged. The reparse of those args is however visible after params.dyndbg="+p" is processed. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Acked-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-30dynamic_debug: add modname arg to exec_query callchainJim Cromie
Pass module name into ddebug_exec_queries(), ddebug_exec_query(), and ddebug_parse_query() as separate parameter. In ddebug_parse_query(), the module name is added into the query struct before the query-string is parsed. This allows the query-string to be shorter: instead of: $modname.dyndbg="module $modname +fp" do this: $modname.dyndbg="+fp" Omitting "module $modname" from the query string is actually required for $modname.dyndbg rules; the set-only-once check added in a previous patch will throw an error if its added again. ddebug_query="..." has no $modname associated with it, so the query string may include it. This also fixes redundant "module $modname" otherwise needed to handle multiple queries per string: $modname.dyndbg="func foo +fp; func bar +fp" Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Acked-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-30dynamic_debug: print ram usage by ddebug tables if verboseJim Cromie
Print ram usage of dynamic-debug tables and verbose section so user knows cost of enabling CONFIG_DYNAMIC_DEBUG. This only counts the size of the _ddebug tables for builtins and the __verbose section that they refer to, not those used in loadable modules. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Acked-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-30dynamic_debug: simplify dynamic_debug_init error exitJim Cromie
We dont want errors while parsing ddebug_query to unload ddebug tables, so set success after tables are loaded, and return 0 after query parsing is done. Simplify error handling code since its no longer used for success, and change goto label to out_err to clarify this. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Acked-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-30dynamic_debug: combine parse_args callbacks togetherJim Cromie
Refactor ddebug_dyndbg_boot_param_cb and ddebug_dyndbg_module_param_cb into a common helper function, and call it from both. The handling of foo.dyndbg is unneeded by the latter, but harmless. The 2 callers differ only by pr_info and the return code they pass to the helper for when an unknown param is handled. I could slightly reduce dmesg clutter by putting the vpr_info in the common helper, after the return on_err, but that loses __func__ context, is overly silent on module_cb unknown param errors, and the clutter is only when dynamic_debug.verbose=1 anyway. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Acked-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-30dynamic_debug: deprecate ddebug_query, suggest dyndbg insteadJim Cromie
With ddebug_dyndbg_boot_params_cb() handling bare dyndbg params, we dont need ddebug_query param anymore. Add a warning when processing ddebug_query= param that it is deprecated, and to change it to dyndbg= Add a deprecation notice for v3.8 to feature-removal-schedule.txt, and add a suggested deprecation period of 3 releases to the header. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Acked-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-30dynamic_debug: make dynamic-debug work for module initializationJim Cromie
This introduces a fake module param $module.dyndbg. Its based upon Thomas Renninger's $module.ddebug boot-time debugging patch from https://lkml.org/lkml/2010/9/15/397 The 'fake' module parameter is provided for all modules, whether or not they need it. It is not explicitly added to each module, but is implemented in callbacks invoked from parse_args. For builtin modules, dynamic_debug_init() now directly calls parse_args(..., &ddebug_dyndbg_boot_params_cb), to process the params undeclared in the modules, just after the ddebug tables are processed. While its slightly weird to reprocess the boot params, parse_args() is already called repeatedly by do_initcall_levels(). More importantly, the dyndbg queries (given in ddebug_query or dyndbg params) cannot be activated until after the ddebug tables are ready, and reusing parse_args is cleaner than doing an ad-hoc parse. This reparse would break options like inc_verbosity, but they probably should be params, like verbosity=3. ddebug_dyndbg_boot_params_cb() handles both bare dyndbg (aka: ddebug_query) and module-prefixed dyndbg params, and ignores all other parameters. For example, the following will enable pr_debug()s in 4 builtin modules, in the order given: dyndbg="module params +p; module aio +p" module.dyndbg=+p pci.dyndbg For loadable modules, parse_args() in load_module() calls ddebug_dyndbg_module_params_cb(). This handles bare dyndbg params as passed from modprobe, and errors on other unknown params. Note that modprobe reads /proc/cmdline, so "modprobe foo" grabs all foo.params, strips the "foo.", and passes these to the kernel. ddebug_dyndbg_module_params_cb() is again called for the unknown params; it handles dyndbg, and errors on others. The "doing" arg added previously contains the module name. For non CONFIG_DYNAMIC_DEBUG builds, the stub function accepts and ignores $module.dyndbg params, other unknowns get -ENOENT. If no param value is given (as in pci.dyndbg example above), "+p" is assumed, which enables all pr_debug callsites in the module. The dyndbg fake parameter is not shown in /sys/module/*/parameters, thus it does not use any resources. Changes to it are made via the control file. Also change pr_info in ddebug_exec_queries to vpr_info, no need to see it all the time. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> CC: Thomas Renninger <trenn@suse.de> CC: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-30dynamic_debug: replace if (verbose) pr_info with macro vpr_infoJim Cromie
Use vpr_info to declutter code, reduce indenting, and change one additional pr_info call in ddebug_exec_queries. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Acked-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-01-24dynamic_debug: process multiple debug-queries on a lineJim Cromie
Insert ddebug_exec_queries() in place of ddebug_exec_query(). It splits the query string on [;\n], and calls ddebug_exec_query() on each. All queries are processed independent of errors, allowing a query to fail, for example when a module is not installed. Empty lines and comments are skipped. Errors are counted, and the last error seen (negative) or the number of callsites found (0 or positive) is returned. Return code checks are altered accordingly. With this, multiple queries can be given in ddebug_query, allowing more selective enabling of callsites. As a side effect, a set of commands can be batched in: cat cmd-file > $DBGMT/dynamic_debug/control We dont want a ddebug_query syntax error to kill the dynamic debug facility, so dynamic_debug_init() zeros ddebug_exec_queries()'s return code after logging the appropriate message, so that ddebug tables are preserved and $DBGMT/dynamic_debug/control file is created. This would be appropriate even without accepting multiple queries. This patch also alters ddebug_change() to return number of callsites matched (which typically is the same as number of callsites changed). ddebug_exec_query() also returns the number found, or a negative value if theres a parse error on the query. Splitting on [;\n] prevents their use in format-specs, but selecting callsites on punctuation is brittle anyway, meaningful and selective substrings are more typical. Note: splitting queries on ';' before handling trailing #comments means that a ';' also terminates a comment, and text after the ';' is treated as another query. This trailing query will almost certainly result in a parse error and thus have no effect other than the error message. The double corner case with unexpected results is: ddebug_query="func foo +p # enable foo ; +p" Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-24dynamic_debug: factor vpr_info_dq out of ddebug_parse_queryJim Cromie
Factor pr_info(query) out of ddebug_parse_query, into vpr_info_dq(), for reuse later. Also change the printed labels: file, func to agree with the query-spec keywords accepted in the control file. Pass "" when string is null, to avoid "(null)" output from sprintf. For format print, use precision to skip last char, assuming its '\n', no great harm if not, its a debug msg. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-24dynamic_debug: add trim_prefix() to provide source-root relative pathsJim Cromie
trim_prefix(path) skips past the absolute source path root, and returns the pointer to the relative path from there. It is used to shorten the displayed path in $DBGMT/dynamic_debug/control via ddebug_proc_show(), and in ddebug_change() to allow relative filenames to be used in applied queries. For example: ~# echo file kernel/freezer.c +p > $DBGMT/dynamic_debug/control kernel/freezer.c:128 [freezer]cancel_freezing p " clean up: %s\012" trim_prefix(path) insures common prefix before trimming it, so out-of-tree module paths are shown as full absolute paths. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-24dynamic_debug: enlarge command/query write bufferJim Cromie
Current query write buffer is 256 bytes, on stack. In comparison, the ddebug_query boot-arg is 1024. Allocate the buffer off heap, and enlarge it to 4096 bytes, big enough for ~100 queries (at 40 bytes each), and error out if not. This makes it play nicely with large query sets (to be added later). The buffer should be enough for most uses, and others should probably be split into subsets. [jbaron@redhat.com: changed USER_BUF_PAGE from 4095 -> 4096 ] Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-24dynamic_debug: chop off comments in ddebug_tokenizeJim Cromie
If a token begins with #, the remainder of query string is a comment, so drop it. Doing it here avoids '#' in quoted strings. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-24dynamic_debug: early return if _ddebug table is emptyJim Cromie
If _ddebug table is empty (in a CONFIG_DYNAMIC_DEBUG build this shouldn't happen), then warn (error?) and return early. This skips empty table scan and parsing of setup-string, including the pr_info call noting the parse. By inspection, copy return-code handling from 1st ddebug_add_module() callsite to 2nd. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-24dynamic_debug: tighten up error checking on debug queriesJim Cromie
Issue error when a match-spec is given multiple times in a rule. Previous code kept last one, but was silent about it. Docs imply only one is allowed by saying match-specs are ANDed together, given that module M cannot match both A and B. Also error when last_line < 1st_line. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-24dynamic_debug: describe_flags with '=[pmflt_]*'Jim Cromie
Change describe_flags() to emit '=[pmflt_]+' for current callsite flags, or just '=_' when they're disabled. Having '=' in output allows a more selective grep expression; in contrast '-' may appear in filenames, line-ranges, and format-strings. '=' also has better mnemonics, saying; "the current setting is equal to <flags>". This allows grep "=_" <dbgfs>/dynamic_debug/control to see disabled callsites while avoiding the many occurrences of " = " seen in format strings. Enlarge flagsbufs to handle additional flag char, and alter ddebug_parse_flags() to allow flags=0, so that user can turn off all debug flags via: ~# echo =_ > <dbgfs>/dynamic_debug/control Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-24dynamic_debug: drop explicit !=NULL checksJim Cromie
Convert 'if (x !=NULL)' checks into 'if (x)'. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-24dynamic_debug: pr_err() call should not depend upon verbosityJim Cromie
Issue keyword/parsing errors even w/o verbose set; uncover otherwize mysterious non-functionality. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-24dynamic_debug: replace strcpy with strlcpy, in ddebug_setup_query()Jim Cromie
Replace strcpy with strlcpy, and add define for the size constant. [jbaron@redhat.com: Use DDEBUG_STRING_SIZE for overflow check] Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-24dynamic_debug: change verbosity at runtimeJim Cromie
Allow changing dynamic_debug verbosity at run-time, to ease debugging of ddebug queries as you add them, improving usability. at boot time: dynamic_debug.verbose=1 at runtime: root@voyage:~# echo 1 > /sys/module/dynamic_debug/parameters/verbose Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-24dynamic_debug: drop enabled field from struct _ddebug, use _DPRINTK_FLAGS_PRINTJim Cromie
Currently any enabled dynamic-debug flag on a pr_debug callsite will enable printing, even if _DPRINTK_FLAGS_PRINT is off. Checking print flag directly allows "-p" to disable callsites without fussing with other flags, so the following disables everything, without altering flags user may have set: echo -p > $DBGFS/dynamic_debug/control Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-24dynamic_debug: fix whitespace complaints from scripts/cleanfileJim Cromie
Style cleanups. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-25Merge branch 'driver-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core * 'driver-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (38 commits) mm: memory hotplug: Check if pages are correctly reserved on a per-section basis Revert "memory hotplug: Correct page reservation checking" Update email address for stable patch submission dynamic_debug: fix undefined reference to `__netdev_printk' dynamic_debug: use a single printk() to emit messages dynamic_debug: remove num_enabled accounting dynamic_debug: consolidate repetitive struct _ddebug descriptor definitions uio: Support physical addresses >32 bits on 32-bit systems sysfs: add unsigned long cast to prevent compile warning drivers: base: print rejected matches with DEBUG_DRIVER memory hotplug: Correct page reservation checking memory hotplug: Refuse to add unaligned memory regions remove the messy code file Documentation/zh_CN/SubmitChecklist ARM: mxc: convert device creation to use platform_device_register_full new helper to create platform devices with dma mask docs/driver-model: Update device class docs docs/driver-model: Document device.groups kobj_uevent: Ignore if some listeners cannot handle message dynamic_debug: make netif_dbg() call __netdev_printk() dynamic_debug: make netdev_dbg() call __netdev_printk() ...
2011-10-18dynamic_debug: fix undefined reference to `__netdev_printk'Jason Baron
Dynamic debug recently added support for netdev_printk. It uses __netdev_printk() to support this functionality. However, when CONFIG_NET is not set, we get the following error: lib/built-in.o: In function `__dynamic_netdev_dbg': (.text+0x9fda): undefined reference to `__netdev_printk' Fix this by making the call to netdev_printk() contingent upon CONFIG_NET. We could have fixed this by defining netdev_printk() to a 'no-op' in the !CONFIG_NET case. However, this is not consistent with how the networking layer uses netdev_printk. For example, CONFIG_NET is not set, netdev_printk() does not have a 'no-op' definition defined. Signed-off-by: Jason Baron <jbaron@redhat.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
